Domoticz - open source domotica systeem - deel 4 Vorige deel Overzicht Laatste deel
Pagina: 1 ... 15 ... 112 Laatste
  • 584.811 views
  • BlakHawk
  • Laatst online: 09-01-2021
Toppe schreef op woensdag 6 februari 2019 @ 12:00:
@dfrenner 6.1% op je hardeschijf, ik teken er voor... Zit over de 38% :')
Draait op V4.10363
Build Hash: 60182597
Build Date: 2019-01-23 08:18:45
Dat begrijp ik, alleen de groei die nu continu plaatsvind is niet normaal...
Youtube: DashcamNL
  • BlakHawk
Ik denk dat ik iets gevonden heb:
29
30
31
32
33
34
35
36
37
38
39
Feb  4 05:48:29 Domoticz sshd[24552]: PAM service(sshd) ignoring max retries; 5 > 3
Feb  4 05:48:30 Domoticz sshd[24565]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:31 Domoticz sshd[24565]: Failed password for root from 24.106.185.190 port 23661 ssh2
Feb  4 05:48:32 Domoticz sshd[24567]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:33 Domoticz sshd[24565]: Failed password for root from 24.106.185.190 port 23661 ssh2
Feb  4 05:48:34 Domoticz sshd[24567]: Failed password for root from 106.15.190.105 port 53794 ssh2
Feb  4 05:48:34 Domoticz sshd[24567]: Connection closed by 106.15.190.105 port 53794 [preauth]
Feb  4 05:48:36 Domoticz sshd[24565]: Failed password for root from 24.106.185.190 port 23661 ssh2
Feb  4 05:48:36 Domoticz sshd[24576]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:38 Domoticz sshd[24576]: Failed password for root from 106.15.190.105 port 53860 ssh2
Feb  4 05:48:38 Domoticz sshd[24565]: Failed password for root from 24.106.185.190 port 23661 ssh2
Feb  4 05:48:38 Domoticz sshd[24576]: Connection closed by 106.15.190.105 port 53860 [preauth]
Feb  4 05:48:40 Domoticz sshd[24565]: Failed password for root from 24.106.185.190 port 23661 ssh2
Feb  4 05:48:40 Domoticz sshd[24565]: Connection reset by 24.106.185.190 port 23661 [preauth]
Feb  4 05:48:40 Domoticz sshd[24565]: PAM 4 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=2$
Feb  4 05:48:40 Domoticz sshd[24565]: PAM service(sshd) ignoring max retries; 5 > 3
Feb  4 05:48:41 Domoticz sshd[24585]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:41 Domoticz sshd[24590]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:43 Domoticz sshd[24585]: Failed password for root from 106.15.190.105 port 53932 ssh2
Feb  4 05:48:43 Domoticz sshd[24585]: Connection closed by 106.15.190.105 port 53932 [preauth]
Feb  4 05:48:44 Domoticz sshd[24590]: Failed password for root from 24.106.185.190 port 59760 ssh2
Feb  4 05:48:45 Domoticz sshd[24595]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:46 Domoticz sshd[24590]: Failed password for root from 24.106.185.190 port 59760 ssh2
Feb  4 05:48:47 Domoticz sshd[24595]: Failed password for root from 106.15.190.105 port 54008 ssh2
Feb  4 05:48:48 Domoticz sshd[24595]: Connection closed by 106.15.190.105 port 54008 [preauth]
Feb  4 05:48:48 Domoticz sshd[24590]: Failed password for root from 24.106.185.190 port 59760 ssh2
Feb  4 05:48:50 Domoticz sshd[24607]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:50 Domoticz sshd[24590]: Failed password for root from 24.106.185.190 port 59760 ssh2
Feb  4 05:48:52 Domoticz sshd[24607]: Failed password for root from 106.15.190.105 port 54070 ssh2
Feb  4 05:48:52 Domoticz sshd[24607]: Connection closed by 106.15.190.105 port 54070 [preauth]
Feb  4 05:48:53 Domoticz sshd[24590]: Failed password for root from 24.106.185.190 port 59760 ssh2
Feb  4 05:48:53 Domoticz sshd[24590]: Connection reset by 24.106.185.190 port 59760 [preauth]
Feb  4 05:48:53 Domoticz sshd[24590]: PAM 4 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=2$
Feb  4 05:48:53 Domoticz sshd[24590]: PAM service(sshd) ignoring max retries; 5 > 3
Feb  4 05:48:54 Domoticz sshd[24621]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:55 Domoticz sshd[24616]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser$
Feb  4 05:48:56 Domoticz sshd[24621]: Failed password for root from 24.106.185.190 port 55491 ssh2
Feb  4 05:48:56 Domoticz sshd[24616]: Failed password for root from 106.15.190.105 port 54138 ssh2
De hele logging staat vol met inkomende attempts...
Youtube: DashcamNL
dfrenner schreef op woensdag 6 februari 2019 @ 15:05:
Dit kan alleen als er poorten open staan, ik zou je modem eens volledig dichtzetten :)
Misschien wel handig om je logs tussen [code] [/code] te zetten, blijft het leesbaar :)
  • BlakHawk
Toppe schreef op woensdag 6 februari 2019 @ 15:10:
Staat idd open.
Poortje aangepast en nu opeens weer 0,27% CPU gebruik :+
wel toevallig dat dit samenhangt met de PIP installatie...
[ Voor 7% gewijzigd door BlakHawk op 06-02-2019 15:13 ]
Youtube: DashcamNL
dfrenner schreef op woensdag 6 februari 2019 @ 15:13:
Staat idd open.
Ze scannen gewoon bepaalde IP adressen eens in de zoveel tijd en als de poort openstaan doen ze brute-force :)
Je hebt me overigens wel aan het denken gezet qua belasting. Zit hier constant op 18%... :P
root      1844 47.2  8.7 362440 82792 ?        Ssl  feb03 2154:23 /home/pi/domoticz/domoticz -daemon -www 80 -sslwww 443
[ Voor 12% gewijzigd door Toppe op 06-02-2019 15:19 ]
  • BlakHawk
Toppe schreef op woensdag 6 februari 2019 @ 15:18:
Welke logging houdt dit allemaal bij?
Ik werd getriggerd door:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
root@Domoticz:/var/log# ls -l
total 130972
-rw-r--r-- 1 root root        0 Feb  6 06:25 alternatives.log
-rw-r--r-- 1 root root      280 Feb  5 15:33 alternatives.log.1
-rw-r--r-- 1 root root      192 Jan 16 10:47 alternatives.log.2.gz
drwxr-xr-x 2 root root     4096 Feb  6 10:10 apt
-rw-r----- 1 root adm  59284880 Feb  6 15:25 auth.log
-rw-r----- 1 root adm    128784 Feb  3 06:25 auth.log.1
-rw-r----- 1 root adm    646802 Jan 28 06:25 auth.log.2.gz
-rw-r----- 1 root adm      7040 Jan 20 06:25 auth.log.3.gz
-rw-r----- 1 root adm      4100 Jan 18 06:25 auth.log.4.gz
-rw-r--r-- 1 root root     3723 Feb  6 10:24 boot.log
-rw-r--r-- 1 root root        0 Nov 13 15:02 bootstrap.log
-rw------- 1 root utmp 63473280 Feb  6 15:10 btmp
-rw------- 1 root utmp  8481408 Feb  1 06:09 btmp.1
-rw-r----- 1 root adm    283702 Feb  6 15:25 daemon.log
-rw-r----- 1 root adm      9500 Feb  2 19:39 daemon.log.1
-rw-r----- 1 root adm      6394 Jan 27 19:00 daemon.log.2.gz
-rw-r----- 1 root adm      4306 Jan 19 18:45 daemon.log.3.gz
-rw-r----- 1 root adm     32133 Jan 18 00:02 daemon.log.4.gz
-rw-r----- 1 root adm      5980 Feb  6 10:24 debug
-rw-r----- 1 root adm      3588 Feb  5 17:15 debug.1
-rw-r----- 1 root adm       422 Jan 23 10:17 debug.2.gz
-rw-r----- 1 root adm       423 Jan 18 11:38 debug.3.gz
-rw-r----- 1 root adm      1705 Jan 17 21:05 debug.4.gz
-rw-r--r-- 1 root root     8383 Feb  6 10:11 dpkg.log
-rw-r--r-- 1 root root    28764 Feb  5 15:33 dpkg.log.1
-rw-r--r-- 1 root root     6445 Jan 16 10:50 dpkg.log.2.gz
-rw-r--r-- 1 root root        0 Nov 13 15:02 faillog
-rw-r----- 1 root adm    210511 Feb  6 10:24 kern.log
-rw-r----- 1 root adm       825 Jan 29 14:45 kern.log.1
-rw-r----- 1 root adm      6851 Jan 23 10:17 kern.log.2.gz
-rw-r----- 1 root adm      6884 Jan 18 11:38 kern.log.3.gz
-rw-r----- 1 root adm     39395 Jan 17 21:05 kern.log.4.gz
-rw-rw-r-- 1 root utmp   292292 Feb  6 15:25 lastlog
-rw-r----- 1 root adm    210266 Feb  6 13:03 messages
-rw-r----- 1 root adm      2639 Feb  3 06:25 messages.1
-rw-r----- 1 root adm      6936 Jan 28 06:25 messages.2.gz
-rw-r----- 1 root adm      6862 Jan 20 06:25 messages.3.gz
-rw-r----- 1 root adm     39278 Jan 18 06:25 messages.4.gz
drwxr-x--- 2 root adm      4096 Aug 13 22:49 samba
-rw-r----- 1 root adm    325343 Feb  6 15:25 syslog
-rw-r----- 1 root adm    272587 Feb  6 06:25 syslog.1
-rw-r----- 1 root adm       702 Feb  5 06:25 syslog.2.gz
-rw-r----- 1 root adm       936 Feb  4 06:25 syslog.3.gz
-rw-r----- 1 root adm       914 Feb  3 06:25 syslog.4.gz
-rw-r----- 1 root adm       719 Feb  2 06:25 syslog.5.gz
-rw-r----- 1 root adm       843 Feb  1 06:25 syslog.6.gz
-rw-r----- 1 root adm       740 Jan 31 06:25 syslog.7.gz
drwxr-xr-x 2 root root     4096 May 25  2017 sysstat
-rw-r----- 1 root adm      8559 Feb  6 13:03 user.log
-rw-r----- 1 root adm       722 Feb  2 10:14 user.log.1
-rw-r----- 1 root adm       289 Jan 26 19:32 user.log.2.gz
-rw-r----- 1 root adm       202 Jan 18 11:38 user.log.3.gz
-rw-r----- 1 root adm       735 Jan 17 21:05 user.log.4.gz
-rw-rw-r-- 1 root utmp    41856 Feb  6 15:25 wtmp
-rw-rw-r-- 1 root utmp    11520 Jan 23 23:35 wtmp.1
Regel 7:
59MB is een hoop voor logging, maar niet heel vreemd toch?
Youtube: DashcamNL
dfrenner schreef op woensdag 6 februari 2019 @ 15:28:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
total 130972
Regel 7:
Doe maar eens ps aux via SSH :9
  • BlakHawk
Toppe schreef op woensdag 6 februari 2019 @ 15:32:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
root@Domoticz:/var/log# ps aux
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         1  0.0  0.6   9668  6148 ?        Ss   10:24   0:16 /sbin/init
root         2  0.0  0.0      0     0 ?        S    10:24   0:00 [kthreadd]
root         4  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/0:0H]
root         6  0.0  0.0      0     0 ?        I<   10:24   0:00 [mm_percpu_wq]
root         7  0.0  0.0      0     0 ?        S    10:24   0:02 [ksoftirqd/0]
root         8  0.1  0.0      0     0 ?        I    10:24   0:18 [rcu_sched]
root         9  0.0  0.0      0     0 ?        I    10:24   0:00 [rcu_bh]
root        10  0.0  0.0      0     0 ?        S    10:24   0:00 [migration/0]
root        11  0.0  0.0      0     0 ?        S    10:24   0:00 [cpuhp/0]
root        12  0.0  0.0      0     0 ?        S    10:24   0:00 [cpuhp/1]
root        13  0.0  0.0      0     0 ?        S    10:24   0:00 [migration/1]
root        14  0.0  0.0      0     0 ?        S    10:24   0:00 [ksoftirqd/1]
root        16  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/1:0H]
root        17  0.0  0.0      0     0 ?        S    10:24   0:00 [cpuhp/2]
root        18  0.0  0.0      0     0 ?        S    10:24   0:00 [migration/2]
root        19  0.0  0.0      0     0 ?        S    10:24   0:00 [ksoftirqd/2]
root        21  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/2:0H]
root        22  0.0  0.0      0     0 ?        S    10:24   0:00 [cpuhp/3]
root        23  0.0  0.0      0     0 ?        S    10:24   0:00 [migration/3]
root        24  0.0  0.0      0     0 ?        S    10:24   0:00 [ksoftirqd/3]
root        26  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/3:0H]
root        27  0.0  0.0      0     0 ?        S    10:24   0:00 [kdevtmpfs]
root        28  0.0  0.0      0     0 ?        I<   10:24   0:00 [netns]
root        33  0.0  0.0      0     0 ?        S    10:24   0:00 [khungtaskd]
root        34  0.0  0.0      0     0 ?        S    10:24   0:00 [oom_reaper]
root        35  0.0  0.0      0     0 ?        I<   10:24   0:00 [writeback]
root        36  0.0  0.0      0     0 ?        S    10:24   0:00 [kcompactd0]
root        37  0.0  0.0      0     0 ?        I<   10:24   0:00 [crypto]
root        38  0.0  0.0      0     0 ?        I<   10:24   0:00 [kblockd]
root        39  0.0  0.0      0     0 ?        I<   10:24   0:00 [watchdogd]
root        40  0.0  0.0      0     0 ?        I<   10:24   0:00 [rpciod]
root        41  0.0  0.0      0     0 ?        I<   10:24   0:00 [xprtiod]
root        44  0.0  0.0      0     0 ?        S    10:24   0:00 [kswapd0]
root        45  0.0  0.0      0     0 ?        I<   10:24   0:00 [nfsiod]
root        55  0.0  0.0      0     0 ?        I<   10:24   0:00 [kthrotld]
root        56  0.0  0.0      0     0 ?        I<   10:24   0:00 [iscsi_eh]
root        57  0.0  0.0      0     0 ?        I<   10:24   0:00 [dwc_otg]
root        58  0.0  0.0      0     0 ?        I<   10:24   0:00 [DWC Notificati
root        59  0.0  0.0      0     0 ?        S<   10:24   0:00 [vchiq-slot/0]
root        60  0.0  0.0      0     0 ?        S<   10:24   0:00 [vchiq-recy/0]
root        61  0.0  0.0      0     0 ?        S<   10:24   0:00 [vchiq-sync/0]
root        62  0.0  0.0      0     0 ?        S    10:24   0:00 [vchiq-keep/0]
root        65  0.0  0.0      0     0 ?        S    10:24   0:00 [mmcqd/0]
root        66  0.0  0.0      0     0 ?        S    10:24   0:00 [scsi_eh_0]
root        67  0.0  0.0      0     0 ?        I<   10:24   0:00 [scsi_tmf_0]
root        68  0.0  0.0      0     0 ?        S    10:24   0:04 [usb-storage]
root        69  0.0  0.0      0     0 ?        S    10:24   0:02 [jbd2/sda1-8]
root        70  0.0  0.0      0     0 ?        I<   10:24   0:00 [ext4-rsv-conve
root        71  0.0  0.0      0     0 ?        I<   10:24   0:00 [ipv6_addrconf]
root        91  1.2  0.6  29496  6056 ?        Ss   10:24   3:50 /lib/systemd/sy
root       124  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/1:1H]
root       126  0.0  0.3  14352  3252 ?        Ss   10:24   0:00 /lib/systemd/sy
systemd+   230  0.0  0.3  17284  3620 ?        Ssl  10:24   0:00 /lib/systemd/sy
root       232  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/2:1H]
avahi      254  0.0  0.3   6532  3132 ?        Ss   10:24   0:09 avahi-daemon: r
root       256  0.2  0.2  23748  2816 ?        Ssl  10:24   0:46 /usr/sbin/rsysl
pi         257  0.2  4.5 112408 45832 ?        Ssl  10:24   0:42 homebridge
message+   258  0.0  0.3   6496  3408 ?        Ss   10:24   0:00 /usr/bin/dbus-d
avahi      268  0.0  0.1   6404  1540 ?        S    10:24   0:00 avahi-daemon: c
root       273  0.0  0.2   5328  2520 ?        Ss   10:24   0:00 /usr/sbin/cron
nobody     277  0.0  0.2   5296  2420 ?        Ss   10:24   0:00 /usr/sbin/thd -
root       279  0.0  0.4   7416  4232 ?        Ss   10:24   0:00 /lib/systemd/sy
root       299  0.0  0.0      0     0 ?        I<   10:24   0:00 [cfg80211]
root       337  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/3:1H]
root       341  0.0  0.0      0     0 ?        I<   10:24   0:00 [kworker/0:1H]
root       400  0.0  0.1   2884  1552 ?        Ss   10:25   0:00 /sbin/dhcpcd -q
root       416  0.0  0.1   4196  1468 tty1     Ss+  10:25   0:00 /sbin/agetty --
root       417  0.0  0.1   3976  1824 ttyAMA0  Ss+  10:25   0:00 /sbin/agetty --
root       422  0.1  0.5  10212  5364 ?        Ss   10:25   0:33 /usr/sbin/sshd
root      2402  0.0  0.0      0     0 ?        I    15:16   0:00 [kworker/0:0]
root      2429  0.0  0.0      0     0 ?        I    15:19   0:00 [kworker/2:2]
root      2467  0.1  0.5  11664  5868 ?        Rs   15:24   0:00 sshd: root@pts/
root      2477  0.0  0.4   6104  4128 pts/1    Ss   15:25   0:00 -bash
root      2501  0.0  0.0      0     0 ?        I    15:25   0:00 [kworker/2:1]
root      2507  0.0  0.0      0     0 ?        I    15:26   0:00 [kworker/0:1]
root      2573  0.0  0.0      0     0 ?        I    15:28   0:00 [kworker/u8:0]
root      2601  0.0  0.0      0     0 ?        I    15:30   0:00 [kworker/2:0]
root      2606  0.0  0.0      0     0 ?        I    15:31   0:00 [kworker/0:2]
root      2620  0.0  0.2   7744  2868 pts/1    R+   15:34   0:00 ps aux
root     20660  1.2  4.7 272380 47984 ?        Ssl  13:03   1:53 /home/pi/domoti
root     24860  0.0  0.0      0     0 ?        I    14:39   0:00 [kworker/3:2]
root     26286  0.0  0.0      0     0 ?        I    14:43   0:02 [kworker/u8:1]
root     27703  0.3  0.5  11664  5844 ?        Ss   14:47   0:10 sshd: root@pts/
root     27734  0.0  0.4   9192  4644 ?        Ss   14:47   0:00 /lib/systemd/sy
root     27737  0.0  0.1  11332  1408 ?        S    14:47   0:00 (sd-pam)
root     27747  0.0  0.4   6136  4180 pts/0    Ss   14:47   0:00 -bash
root     29465  0.0  0.0      0     0 ?        I    14:52   0:00 [kworker/3:1]
root     29836  0.0  0.0      0     0 ?        I    14:54   0:00 [kworker/1:2]
root     31607 11.0  7.8  80288 78112 pts/0    S+   14:59   3:53 nano auth.log
root     32069  0.0  0.0      0     0 ?        I    15:01   0:00 [kworker/1:0]
Kun je ergens binnen de pi instellen dat bij x connecties vanaf een bepaald ip een blokkade plaatsvind?
Youtube: DashcamNL
dfrenner schreef op woensdag 6 februari 2019 @ 15:35:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
Fail2Ban doet dit :)
  • flexje
  • Laatst online: 21-10 20:23
flexje
got-father
Kan iemand mij even helpen met een simpele dzvents scriptje.
Ik haal uit mijn denon receiver een volume level, stop die in een text variabele in domoticz, en deze past de volume dimmer automatisch aan dmv het volgende:
return {
    on = {
        devices = {
            'Denon_Volume', -- text var, update via bash
    execute = function(domoticz, device)
        local denon_vol_text = domoticz.devices('Denon_Volume') -- text var
        local vol_dimmer = domoticz.devices('Denon_Dim_Vol') -- dimmer in domoticz
        local vol_var = domoticz.utils.round(vol_dimmer.level, 1)
        if (vol_dimmer.lastUpdate.secondsAgo >= 179 and vol_dimmer.state == 'On' and vol_var ~= denon_vol_text.text) then
            vol_dimmer.dimTo(denon_vol_text.text)
            domoticz.log('1 ********** LEVEL VAN DENON NAAR DZ IS AANGEPAST NAAR ' .. denon_vol_text.text .. ' % **********', domoticz.LOG_INFO)
        else
            --domoticz.log('2 ********** DENON UIT OF NET GEUPDATE, DUS NIKS AANGEPAST, LAATSTE UPDATE IS ' .. vol_dimmer.lastUpdate.minutesAgo .. ' MIN GELEDEN **********', domoticz.LOG_INFO)
        end
    end
Nu wil ik dat hij alleen de dimmer level aanpast als de text variabele en de dimmer level niet gelijk is vol_var ~= denon_vol_text.text.
Maar hij blijft altijd updaten. Ik denk dat dit komt omdat de dimmer level zonder decimaal is, dus. 30 en de text variabele 30.0
Ik probeerde een extra decimaal te krijgen dmv de domoticz.utils.round functie, maar dat doet hij dus niet.
[ Voor 9% gewijzigd door flexje op 06-02-2019 17:35 ]
"Try not to become a man of success but rather to become a man of value..."
flexje schreef op woensdag 6 februari 2019 @ 17:29:
return {
    on = {
        devices = {
        else
        end
    end
Even een snel -tijdens het bereiden van voedsel- idee
local vol_dimmer = domoticz.devices('Denon_Dim_Vol')..".0"-- dimmer in domoticz
En ik zou beginnen met de waardes statisch invullen, test vaak wat makkelijker dan dynamisch :)
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 17:45:
Zou leuk zijn, alleen Denon werkt ook met .5 haha :D
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 17:47:
Maar werkt het wel? Dan is die .5 de volgende uitdaging :)
ja dat werkt idd :D
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 18:10:
En dit?
        local vol_var = domoticz.utils.round(vol_dimmer.level, 0)
Als het goed is heb je dan geen .0 of .5
Dacht ik ook aan , alleen de receiver werkt toch echt met decimalen, dus bij het pollen krijg ik altijd een .0 of een .5 die ik moet vergelijken met de dimmer level....
Heb intussen ook de tonumber functie geprobeerd en dan de round(), gooit alsnog geen decimaal erachter.
Moet toch niet zo moeilijk zijn haha
[ Voor 3% gewijzigd door flexje op 06-02-2019 18:15 ]
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 18:17:
Ben bezig voor je met een scriptje, even eten.
Je Denon stuurt 44.5 of 67.0 uit qua volume?
Si, eet smakelijk
29
return {
    on = {
        devices = {
    local dimmerVirtual = domoticz.devices('Denon_Dim_Vol')
        local volumeDenon       = domoticz.devices('Denon_Volume').text
        local volumeVirtual     = dimmerVirtual.level
        local lastUpdate        = dimmerVirtual.lastUpdate.secondsAgo
        local dimState          = dimmerVirtual.state
        if(lastUpdate >= 179 and dimState == 'On') then
            if(volumeVirtual == volumeDenon..".0" or volumeVirtual == volumeDenon..".5") then
                dimmerVirtual.dimTo(volumeDenon)
            end
        else
        end
    end
Deze dan? Niet gecheckt op typo's :P
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 18:54:
29
return {
    on = {
        devices = {
            end
        else
        end
    end
Hij blijft hem 'updaten'...
Oh wacht...
Moet het niet zijn:
            if(volumeDenon ~= volumeVirtual..".0" or volumeDenon ~= volumeVirtual..".5") then
            end
[ Voor 7% gewijzigd door flexje op 06-02-2019 19:44 ]
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 19:44:
regel 17:
if(volumeVirtual ~= volumeDenon..".0" or volumeVirtual ~= volumeDenon..".5") then
Hij moet hem alleen update'n als hij niet gelijk is :')
@flexje Klopt. Heb 'm aangepast :')
Begrijp er geen kloot meer van...
2019-02-06 19:51:01.845 Status: dzVents: Info: Handling events for: "Denon_Volume", value: "42.0"
2019-02-06 19:51:01.845 Status: dzVents: Info: ------ Start internal script: volumeDenonIn: Device: "Denon_Volume (Denon)", Index: 70
2019-02-06 19:51:01.846 Status: dzVents: Info: # volume slider in dz aangepast van 42 naar 42.0%
2019-02-06 19:51:01.846 Status: dzVents: Info: ------ Finished volumeDenonIn
flexje schreef op woensdag 6 februari 2019 @ 19:51:
Deze doet het sowieso:
return {
    on = {
        devices = {
            end
        else
        end
    end
  • flexje
flexje
got-father
Toppe schreef op woensdag 6 februari 2019 @ 19:54:
return {
    on = {
        devices = {
            end
        else
        end
    end
De volumeVirtual moet toch een .0 of .5 krijgen? Die van jou blijft bij mij ook updaten....
  • flexje
flexje
got-father
Mede door @Toppe (thanks!) werkend gekregen:
return {
    on = {
        devices = {
        local dimmerVirtual     = domoticz.devices('Denon_Dim_Vol') -- dimmer dz
        local volumeDenon       = domoticz.devices('Denon_Volume').text -- text var
        local volumeVirtual     = dimmerVirtual.level -- level van dimmer dz
            if(volumeDenon == volumeVirtual..".0" or volumeDenon == volumeVirtual..".5") then
                domoticz.log('# niks aangepast', domoticz.LOG_INFO)
            else
                domoticz.log('# volume slider in dz aangepast van ' .. volumeVirtual .. ' naar ' .. volumeDenon .. '% ', domoticz.LOG_INFO)
            end
        end
    end
  • Remius
  • Laatst online: 18-03-2023
Ik heb Domoticz draaiende op een Raspberry Pi 3B+. Werkt allemaal erg soepel, behalve de Hue motion sensor. Die reageert in Domoticz veel te traag. Ik heb bijv een 'nachtlampje' blockly gemaakt, maar met een vertraging van soms wel 5 seconden heb je allang je teen gestoten aan de tafel voordat de lampen aanspringen. Ik gebruik nu voor deze scene iConnecthue (iOS) en die reageert bijna direct. Iemand enig idee hoe ik dit kan oplossen in Domoticz? Ik draai overigens wel de beta, want anders worden mijn Hue lampen niet gevonden...
  • uibeltje
  • Laatst online: 20-10 18:52
uibeltje
Idiotheque
Ik heb met blockly iets gemaakt waarbij op bepaalde tijdstippen het setpoint CV gewijzigd wordt, dit via Toon die ook aanwezig is in mijn domoticz installatie. Kwam er later achter dat ik dit ook kan doen via Timers bij het Setpoint.
Ik heb daarom de blockly weer verwijderd maar de eerder ingestelde setpoints in de blockly blijven terugkomen :?
Domoticz 4.9700
Weet iemand hoe ik deze echt definitef kan verwijderen/stoppen?
  • luigi87
  • Laatst online: 23-10 20:57
luigi87
Domotica Fanaticus
uibeltje schreef op donderdag 7 februari 2019 @ 10:40:
Domoticz 4.9700
Even je Domoticz rebooten?
Normaal gesproken als je blocky verwijderd zou die niet meer kunnen functioneren
- leeg -
  • Knielen
  • Laatst online: 14:51
Remius schreef op woensdag 6 februari 2019 @ 21:05:
Geen blockly maar DzVents gebruiken
  • uibeltje
uibeltje
Idiotheque
luigi87 schreef op donderdag 7 februari 2019 @ 11:27:
Al meerdere keren geprobeerd maar de blockly blijft uitgevoerd worden terwijl deze niet meer bestaat 8)7
  • DaRk PoIsOn
  • Laatst online: 12:21
Ik ben maar weer eens aan een poging gegaan om mijn meterstand naar mindergas te krijgen.
Bij mij gebeurt er alleen nog steeds dit:
Afbeeldingslocatie: https://tweakers.net/ext/f/T0BOxGerEgaEo7WTXoKWEXPL/full.png
[ Voor 28% gewijzigd door DaRk PoIsOn op 07-02-2019 16:37 ]
who put a "stop payment" on my reality check
  • Wiley99
  • Laatst online: 08:44
uibeltje schreef op donderdag 7 februari 2019 @ 13:55:
Misschien is 'ie stiekem niet weg uit de database. Weet je de naam nog? Je kan proberen om een nieuwe 'lege' blocky aan te maken en die op te slaan onder dezelfde naam. Dan wordt de oude misschien overschreven.
(Ken Toon niet maar zou het kunnen dat die setpoints nu in de Toon zitten?)
  • DaRk PoIsOn
Toppe schreef op donderdag 7 februari 2019 @ 16:49:
Moet je die API wel tussen < & > zetten?
Geen idee, had het even aangepast zoals het in het voorbeeld stond, maar zonder krijg ik de zelfde foutmelding.
Als ik het curl commando uitvoer, krijg ik netjes de data van idx2.
  • Rgerr
  • Registratie: Juni 2017
  • Laatst online: 23-10 18:37
DaRk PoIsOn schreef op donderdag 7 februari 2019 @ 16:58:
jq wel geïnstalleerd?
  • DaRk PoIsOn
pi@domoticz:~ $ sudo apt-get install jq
Reading package lists... Done
Building dependency tree
Reading state information... Done
jq is already the newest version (1.5+dfsg-1.3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
  • DaRk PoIsOn
Toppe schreef op donderdag 7 februari 2019 @ 17:15:
@DaRk PoIsOn haal die comment eens weg die begint met #fetch meterstand in je script
<> Weggehaald en # weggehaald.
Zelfde foutmelding
  • Wiley99
loyske schreef op donderdag 3 januari 2019 @ 09:46:
Ik gebruik hier inderdaad al een Fibaro rookmelder en enkele multisensors. Maar ben nu op zoek naar goedkope sensors voor het meten van enkel temperatuur en/of vochtgehalte. Dit voor enkele plekken in huis en ook in de tuin ivm het weg vallen van WeatherUnderground.
Had je die nog gevonden? Ik zoek ze ook nu, sinds ik toch maar een RFXcom heb aangeschaft :9
Maar het is lastig de fora door te spitten naar een goed advies, merk ik.
  • DaRk PoIsOn
Toppe schreef op donderdag 7 februari 2019 @ 18:04:
Heb je alleen '#' weg gehaald of de hele regel? Want alleen '#' heeft weinig effect
De hele regel.
Ik blijf: no such file or directory krijgen
@Toppe Alles stap voor stap gedaan volgens het voorbeeld.
In december had ik het ook geprobeerd en kreeg ik een http error 403.
Ik pas maar ff mijn bericht aan, voordat er teveel over 1 probleem gaat
[ Voor 27% gewijzigd door DaRk PoIsOn op 07-02-2019 18:35 ]
  • Stubby
  • Laatst online: 13:07
Toppe schreef op donderdag 7 februari 2019 @ 18:58:
Ik wil beginnen met Z-Wave, iemand een tof idee als eerste apparaat? 8)
Aeotec zwave stick natuurlijk als controller. Daarnaast wat neo coolcam sensoren / actuators. Via Ali goedkoop te vinden begreep ik, maar ook via de Nederlandse kanalen direct te vinden
  • DaRk PoIsOn
Toppe schreef op donderdag 7 februari 2019 @ 19:29:
Is de Aeotec veel beter dan 1 van Z-Wave.me? Die kan ik namelijk gratis krijgen :P Ik zat nu te denken aan een Fibaro bewegingsmelder voor boven maar maak me een beetje zorgen in combinatie met de katten :'(
https://buildyoursmarthome.co/reviews/best-z-wave-usb-stick/
  • Stubby
Ik heb zelf Neo Coolcam Pirs, maar die triggeren inderdaad ook op mijn katten. Die hebben wel een instelling voor gevoeligheid, maar daar heb ik nog niet mee gespeeld. Zoveel configuratie parameter, zo weinig tijd ;)
Stubby schreef op donderdag 7 februari 2019 @ 20:05:
Heb beneden ze van Ikea en die gaat al af door de katten, deze wou ik in de badkamer plaatsen maar ja, daar vliegen ze ook wel eens doorheen... en niet fijn als je ‘s nachts wakker wordt door dat licht en daar heb ik dus geen zin in.
Het blokkeren van bepaalde tijden is geen optie omdat ik ze juist koop om te schakelen op tijd
slapen is een hobby en daar maak ik tijd voor vrij
[ Voor 15% gewijzigd door Toppe op 07-02-2019 20:10 ]
  • Siewert
  • Registratie: December 2015
  • Laatst online: 23-10 23:21
@Stubby Parameter 1
Deze staat bij mij op 45 en werkt perfect.
Mensen worden gedetecteerd an mijn katten niet...
☀️Enphase IQ8+ 8,1kWp (8x Oost / 11x West) 🇳🇱
🔋12,8kWh DIY Thuisbatterij & MT Venus E v3
❄️MHI SRK50ZS-WF & SCM50ZS-W - 2x SRF25ZS-W
🛵Segway E125s
🔋piBattery Project @ GitHub
  • Chrisje1983
  • Laatst online: 11:43
Ik zou even uitkijken met chineze z-wave, quality control is flink beneden peil gezakt.
Ik heb totaal 60 neo coolcam pir, deur, sirenes en sockets en ook heiman rookmelders.
Ik heb er totaal 7 defect, waarvan de laatste sirene en 2 deurmelders DOA aankwamen. Het begon met een sirene welke elke 24 uur 2 duracel batterijen leeg trekt, ik heb dat ding getest met labvoeding en multimeters en het ding viel na 1 sirene triggering nooit meer terug in sleep mode, foto's met test uitslag verstuurd naar neo coolcam en je kent de overdreven manier wel hoe dat gaat, sorry grote vriend, dit gaat nooit meer gebeuren, jaja...
Inmiddels wat defecte neo coolcam nodes verder en ondanks dat ik video's heb geupload waarin aan getoond wordt dat de deur melders niet goed zijn en de sirene harstikke dood is (DOA bij aankomst) wil Neo coolcam wil mij niets meer vergoeden of helpen, en blijft hardnekkig spelen. Ze willen dat ik de sensors op eigen kosten toe stuur, of de andere optie: dat ik 3 sensors koop en er 1 gratis bij krijg.
van de 20 heiman rook melders zijn er inmiddels 2 overleden, zo uit het niets begonnen ze met elke 53 seconden een dubbele beep. Dan zijn ze dus kapot, hier heb ik nog wel nieuwe voor gekregen. Maar ik denk dat ik er na kan fluiten als er nog meer bezwijken.
Wees gewaarschuwd, het lijkt leuk, je begint met een paar z-wave nodes, al gauw verzin je dat je er meer wilt hebben en in elke ruimte een deursensor, pir en rookmelder wil ophangen maar als jij inmiddels voor 1500 euro aan chineze z-wave hebt opgehangen en alles gaat langzaam aan dood dan wordt het toch wel een minder leuk grapje.
Voor het geen wat nog werkt ben ik erg tevreden, ik heb alleen het vertrouwen verloren in een eeuwige werking. Het spul is nog geen jaar oud want ik ben pas maart 2018 begonnen met domotica.
Ik heb ook het idee dat de quality control flink gezakt is daar bij neo coolcam de laatste maanden van 2018, het is echt bagger. Ik heb dit dan ook aangegeven bij neo coolcam.
Als ik dan kijk naar het andere spul (sonoff en nodemcu) wat allemaal via wifi en mqtt werkt, dat is zo stabiel als maar kan en nooit geen problemen mee. Maar rookmelders, deurmelders, en pirs zelf te gaan bouwen met een nodemcu wordt natuurlijk geen mooi gezicht in huis.
Chrisje1983 schreef op donderdag 7 februari 2019 @ 21:08:
Zit daarom zelf te kijken naar Fibaro, lees je veel positieve recensies over en is vrij compleet
  • Chrisje1983
Ja achteraf gezien had ik ook liever de hogere kosten betaald en gekozen voor een product verkrijgbaar in de buurt met garantie.
  • uibeltje
uibeltje
Idiotheque
Wiley99 schreef op donderdag 7 februari 2019 @ 15:55:
Heb het zojuist maar geprobeerd om lege blockly te maken met zelfde naam. Duurt weer ff voordat ik kan zien of dit werkt.
Setpoints in Toon lijkt mij niet te kunnen.
Waarom geen Xiaomi hardware icm Zigbee2MQTT stick of Gateway.
Ziet er netjes uit en werkt uiterst stabiel en prima prijzen ;)
Inmiddels aardig wat spullen hier hagen maar nog geen 1 die defect is geraakt of waar de batterij van leeg is geraakt of belangrijkste het werkt altijd.
  • loyske
  • Laatst online: 22-10 11:20
Wiley99 schreef op donderdag 7 februari 2019 @ 17:53:
Nee nog steeds niet, dus ben nog op zoek |:(
Maar het goedkoopste is toch een Cresta TX320 of iets dergelijks, dus neig daar maar naar.
  • rimave
  • Laatst online: 24-10 10:38
Ik heb een domme vraag. Ja, ze bestaan nog. Ik wil graag Domoticz gaan gebruiken op mijn Synology. Package draait al, maar wat prik ik nu in mijn Syno als communicatie device?
Ik vindt eigenlijk alleen info over een Raspberry Pi, maar die wil ik niet gaan gebruiken. Ik wil een clean setup. Niet teveel extra devices in mijn netwerk als het ook op een Syno draaien kan.
Wat wil ik? Domoticz gebruiken icm een Toon. Ik heb daarnaast nog Hue lampen en wat Kaku spul:een Regenmeter en twee temp sensoren en een wallplug. Domoticz zal wel niet overweg kunnen met een Ring deurbell en Unifi camera's?
  • FunFair
  • Laatst online: 24-10 22:44
FunFair schreef op dinsdag 5 februari 2019 @ 20:53:
Ik heb het maar 'opgelost' door "sudo service domoticz.sh restart" toe te voegen aan /etc/rc.local
Net even een cold boot gedaan en dat lijkt in ieder geval te werken.
Fijn... nu heb ik al 2 avonden dat Domoticz om 0:00 plotseling stopt en ik er 's ochtends achter kom en de service moet restarten. Wat de f...
Logging maar aangezet in de hoop dat ik daar wat in kan vinden als hij het vannacht weer flikt.
rimave schreef op vrijdag 8 februari 2019 @ 10:49:
Wat betreft je KAKU spul: Als je geen basis station hebt moet je inderdaad kijken naar een 443Mhz ontvanger in de vorm van een RFXCom, deze kan je gewoon aansluiten via USB. Apparaatjes kosten wel wat (€100 ofzo) dus je moet even kijken wat voordeliger is: De rest vervangen of de ontvanger kopen. 443Mhz is niet beveiligd en heeft geen feedback oplossing, de laatste was voor mij de reden om deze oplossing volledig te verbannen.
Toon heeft een plugin, moet werken (misschien wel alleen de root versie? Toon kennis verder is 0)
Hue heeft volgens mij ook een plugin en dat zou dan ook moeten werken.
Deurbel: Klopt. Weet niet wat je als achterliggend platform gaat gebruiken (HomeKit, Google Home?) maar daar zijn vaak wel plugins voor beschikbaar..
Wat betreft je camera: Als hij een RSTP stream heeft moet het lukken. Voor meer info: https://www.ispyconnect.com/man.aspx?n=Unifi
  • Rgerr
Toppe schreef op vrijdag 8 februari 2019 @ 11:45:
Iemand hier trouwens ervaring met Harmony Hub en Apple TV in Domoticz?
Wil de Apple TV kunnen aan én uitzetten met HomePod. Aan lukt nu wel maar uit is lastiger :(
Als de Harmony Hub dit wel kan...
Jij doet ook niks anders hè. :+
  • Rgerr
FunFair schreef op vrijdag 8 februari 2019 @ 10:55:
Al eens gekeken naar Monit? Die checkt je draaiende services en herstart ze indien nodig.
  • FunFair
Rgerr schreef op vrijdag 8 februari 2019 @ 12:07:
Had ik iets over gelezen inderdaad. Maar het idiote is dat domoticz rapporteert dat de service gewoon actief is, terwijl de webserver dus niet actief is. Daarnaast snap ik dat een programma kan crashen, maar 2x achter elkaar om 0:00 exact lijkt mij geen toeval. Eerst even kijken of logging iets gaat opleveren.
  • funske
  • Laatst online: 31-01-2023
Ik gebruik mijn Harmony (via Domoticz naar HomeBridge) in HomeKit met allerlei opdrachten oftewel activiteiten genoemd in de Harmony app. Dus ik zou niet weten waarom je daarmee niet gewoon de Apple tv kunt aan- en uitzetten. Dat is gewoon een kwestie van een activiteit aanmaken in de Harmony app en dan werkt het prima.
Waarschijnlijk begreep ik je verkeerd; je bedoelt dat als de Harmony dit kan de HomePod dit ook zou moeten kunnen…...
[ Voor 9% gewijzigd door funske op 08-02-2019 12:35 ]
Have Fun Funske
  • Rgerr
FunFair schreef op vrijdag 8 februari 2019 @ 12:11:
Mocht je logging nou niets opleveren, misschien een tijdelijke oplossing om Domoticz via crontab te laten (her)starten om 00.01u?
funske schreef op vrijdag 8 februari 2019 @ 12:32:
Ik ga het maar heel beperkt gebruiken want heb alleen een Apple TV aangesloten op de TV. Het zou voor mij dan ook puur om het uitschakelen gaan want dat kan ik nu niet.
Althans, ik neem niet aan dat ik via de Harmony hub kan zeggen "Start netflix" wat betekend TV aan, Apple TV aan en Netflix op starten?
Als ik gewoon een aan/uit schakelaar per apparaat in HomeKit heb dan ben ik al heel tevreden. Dus gewoon Apple TV aan/uit, TV aan/uit. Eventueel een bepaalde knop volgorde automatisch uitvoeren (Siri knop lang indrukken, dan 3 naar beneden en dan OK) etc.
Denk dat ik dat ding maar gewoon eens moet bestellen om te kijken of het wat is. Heeft die afstandsbediening met LCD echt een toegevoegde waarde?
Ik herhaal 't nog maar een keer: HomeKit is echt mooi, maar waarom z'n beperkte ondersteuning voor hun eigen apparaten? Zo zou ik ook héél graag de HomePod muziek willen laten afspelen na zonsondergang als er niemand thuis is... Ook dat kan niet :(
Edit: Zojuist deze besteld :9~
[ Voor 33% gewijzigd door Toppe op 08-02-2019 13:05 ]
  • funske
Tegen Siri kan ik van alle zeggen en dat wordt keurig uitgevoerd door mijn Harmony. Bijvoorbeeld:
“Zet Sky aan”; Skyradio speelt af via mijn HEOS boxen,
“Zet LXClassics aan” LXClassics speelt af via mijn HEOS boxen
“Zet tv aan”; de tv wordt aangezet, tegelijk met mijn HEOS Home Cinema en mijn VU+ Uno apparaat
“Zet Mede8er aan“; de tv wordt aangezet en mijn Mede8er-player, en de input wordt netjes hierop afgestemd
En zo kan ik elk apparaat samen met de tv aanzetten met de juist gekozen ingang.
Have Fun Funske
  • Phoolie
  • Laatst online: 20-10 15:21
Toppe schreef op vrijdag 8 februari 2019 @ 12:50:
Maar werkt de Apple TV dan wel met infrarood? Ik dacht dat die remote via BT werkt.
  • schumi2004
  • Laatst online: 23-10 13:35
flexje schreef op woensdag 2 januari 2019 @ 22:07:
Ik heb in totaal 21 tradfri gu10 spots en 1 rgbw tradfri lamp op zigbee2mqtt. Ook heb ik een aantal werkend icm een xiaomi motion sensor en de rgbw lamp gekoppeld met de ronde dimmer van ikea. Geen enkele knippert en werkt lekker snel.
Heb de kant en klare stick op marktplaats gekocht.
Kan dit niet via de Xiaomi Gateway dan, die is toch ook een soort van zigbee2mqtt stick?
  • FunFair
funske schreef op vrijdag 8 februari 2019 @ 13:37:
Hoe spreek je Mede8er uit richting Siri? :D :P
  • flexje
flexje
got-father
schumi2004 schreef op vrijdag 8 februari 2019 @ 13:51:
Bedoeling is dat alle gateways de deur uitgaan....
Vind de mqtt ondersteuning ook lekker
  • schumi2004
flexje schreef op vrijdag 8 februari 2019 @ 13:59:
Wat gateways betreft ben ik het met je eens. Ik zal eens kijken of ik zo'n zigbee2mqtt stick op mijn Synology prikken kan en ook kan laten werken natuurlijk ;)
Ik heb geen Docker support dus is misschien een uitdaging maar dat zoek ik even uit.
Was namelijk benieuwd of zo'n Xiaomi gatway ook werkte want dan had ik voorlopig namelijk een oplossing ;)
  • Phoolie
Toppe schreef op vrijdag 8 februari 2019 @ 13:57:
Beide, je kan de 4de generatie koppelen op de hub, dat zegt Logitech tenminste zelf :D
O, dan zal het vast wel werken :)
  • funske
FunFair schreef op vrijdag 8 februari 2019 @ 13:53:
Klopt, ik zeg inderdaad Mediaspeler i.p.v. Mede8er. :+
Mede8er snapte Siri niet helemaal, maar Mediaspeler gaat prima.
Ik vind het een geweldig apparaat!!
[ Voor 39% gewijzigd door funske op 09-02-2019 13:26 ]
Have Fun Funske
  • funske
O-)
[ Voor 99% gewijzigd door funske op 09-02-2019 13:26 ]
Have Fun Funske
  • Duci
Aanrader inderdaad! Had het nooit, en het is toch behoorlijk lastig als Domoticz down gaat terwijl alles erdoor aangestuurd wordt bij mij thuis. Zeker als het de vriendin gebeurt terwijl ik niet thuis ben.
Nu krijg ik eens in de 1,5 maand een serie berichtjes van Monit dat de boel herstart is. Moet wel heel erg toevallig zijn als ik er dan ben om daar (een paar minuten) last van te hebben.
  • funske
Toppe schreef op vrijdag 8 februari 2019 @ 16:12:
Heb ik nou zoveel onmogelijke eisen? Heel enthousiast dat ding besteld maar kom er achter dat het echt niet meer is dan een afstandsbediening. Denk dat hij al terug gaat voordat ik überhaupt de doos heb geopend.
Damn, waarom is het onmogelijk om mijn wensen kunnen voldoen. Iemand nog ideeën?
Het is een afstandsbediening die je m.b.v. HomeBridge kunt gebruiken voor Siri, zonder echt de afstandsbediening zelf te gebruiken..
Maar wat doet hij dan niet volgens jou??
[ Voor 4% gewijzigd door funske op 08-02-2019 16:23 ]
Have Fun Funske
funske schreef op vrijdag 8 februari 2019 @ 16:22:
Ik wil gewoon Apple TV via HomeKit kunnen bedienen.
Sorry, ik ben echt even over de zeik.
Apple stelt een API beschikbaar om het leven makkelijker te maken, waarom kan je dan in vredesnaam niet vanuit Home een Apple TV aan of uitzetten? Als groot fan moet ik toch zeggen dat ze hier de plank volledig misslaan.
Ik moet nu een apparaat van €100 kopen om die Apple TV automatisch uit te kunnen zetten. Belachelijk!
Waarom zo'n beperkte ondersteuning voor hun eigen apparaten, ik snap dat echt niet. Ik wil toch gewoon muziek kunnen starten als ik thuis kom zonder dat ik wat tegen Siri moet zeggen...
Er is tot nu toe geen enkele fatsoenlijke oplossing voor dit probleem. Ja, ik heb die HomeBridge plugin geprobeerd te installeren maar loop vast op Sodium@2.0.3 die geïnstalleerd is maar de plugin vindt dat het niet de goede versie is.
[ Voor 13% gewijzigd door Toppe op 08-02-2019 16:36 ]
@Toppe @Rgerr @funske Even een reminder om de 'Wijzig' knop te gebruiken als je als laatste iets hebt gepost en nog iets wil toevoegen. Meerdere berichten na elkaar wordt als irritant ervaren ;)
  • Remius
Knielen schreef op donderdag 7 februari 2019 @ 13:31:
Thnx! Ik wil dit graag eens testen, maar ik kom er niet uit met DzVents. Kan iemand mij helpen om het volgende script te bouwen?
als het tussen 23:00 uur en 05:00 uur is;
en 'lux' is lager dan 2;
en 'motion' is gedetecteerd;
dan 'woonkamer' aan
Remius schreef op vrijdag 8 februari 2019 @ 18:14:
dan 'woonkamer' aan
return {
    on = {
        timer = { 'at 23:00-05:00' },
        devices = { 'motion' }
    execute = function(domoticz, triggeredItem)
        if(item.isDevice and item.active and domoticz.devices('lux').lux < 2) then
            domoticz.devices('woonkamer').switchOn().checkFirst()
        end
    end
Zoiets?
  • DaRk PoIsOn
Toppe schreef op vrijdag 8 februari 2019 @ 16:34:
Homebridge heeft toch gewoon de "sleep" en "suspend" functies?
Ik kan ook compleet mislezen hoor, maar volgens mij zit het er standaard in
@Toppe
Als ik het goed begrijp, wil je hem aan en uit kunnen zetten toch?
Eventueel een paar handelingen uitvoeren zonder de tv daarvoor aan te hebben of tegen siri te praten.
Homebridge heeft die functies voor de apple tv en er is een plugin voor wol om de apple tv uit zijn slaap te halen.
[ Voor 11% gewijzigd door DaRk PoIsOn op 08-02-2019 19:35 ]
DaRk PoIsOn schreef op vrijdag 8 februari 2019 @ 19:21:
Ik volg je in deze even niet, ik wil Apple TV kunnen opnemen in een automatisering, hoe HomeBridge mij hier mee kunnen helpen dan?
@DaRk PoIsOn uit zijn slaap lukt wel, al dan niet via Siri. Het gaat er juist om dat hij gaat slapen.
Het bizarre? Volgens deze support pagina van Apple zou je een remote moeten kunnen toevoegen in Home. Exact wat ik wil maar zodra je er op klikt kom je geen stap verder.
Je hebt de HomeBridge plugin "homebridge-apple-tv" maar die krijg je met geen mogelijkheid geïnstalleerd... Althans ik niet.
sudo npm install -g homebridge-apple-tv
> sodium@2.0.3 preinstall /usr/local/lib/node_modules/homebridge-apple-tv/node_modules/sodium
> node install.js --preinstall
Static libsodium was not found at /usr/local/lib/node_modules/homebridge-apple-tv/node_modules/sodium/deps/build/lib/libsodium so compiling libsodium from source.
libtoolize: error: Failed to create 'build-aux'
make: *** [libsodium] Fout 1
Makefile:61: recept voor doel 'libsodium' is mislukt
/usr/local/lib/node_modules/homebridge-apple-tv/node_modules/sodium/install.js:287
throw new Error(cmdLine + ' exited with code ' + code);
Error: make libsodium exited with code 2
at ChildProcess.<anonymous> (/usr/local/lib/node_modules/homebridge-apple-tv/node_modules/sodium/install.js:287:19)
at ChildProcess.emit (events.js:182:13)
at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! sodium@2.0.3 preinstall: `node install.js --preinstall`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sodium@2.0.3 preinstall script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2019-02-08T18_41_26_822Z-debug.log
Hij mist Sodium, maar dat is al geïnstalleerd evenals alle andere opties die op internet voorbij komen heb ik al geprobeerd, handmatig geïnstalleerd en alles. Er is nog 1 ander NPM Package maar die kan ik weer niet installeren vanwege "Code 128" :O
Dus, andere mensen hier die hun Apple TV kunnen uitzetten met Domoticz/HomeKit/HomeBridge?
[ Voor 77% gewijzigd door Toppe op 08-02-2019 19:46 ]
  • Remius
Toppe schreef op vrijdag 8 februari 2019 @ 18:37:
return {
    on = {
        end
    end
Zoiets?
Goed startpunt :9 Ik heb de tijden aangepast (om nu te testen) en aangegeven dat de woonkamer 'group' aan moet gaan.
return {
    on = {
        timer = { 'at 18:00-20:00' },
        devices = { 'Motion' }
        if(item.isDevice and item.active and domoticz.devices('Lux').lux < 2) then
            domoticz.groups('Woonkamer').switchOn()
        end
    end
Werkt nog niet helaas, ik krijg de volgende log:
Info: ------ Start internal script: Nachtlampje:, trigger: at 18:00-20:00
Error (2.4.13): An error occured when calling event handler Nachtlampje
Error (2.4.13): ...moticz/scripts/dzVents/generated_scripts/Nachtlampje.lua:7: attempt to index global 'item' (a nil value)
Info: ------ Finished Nachtlampje
Remius schreef op vrijdag 8 februari 2019 @ 19:46:
return {
    on = {
        end
    end
#tesnel.
regel 6 moet dit worden:
execute = function(domoticz, item)
  • Remius
Toppe schreef op vrijdag 8 februari 2019 @ 19:50:
#tesnel.
Dank! Het werkt! Helaas is er nog steeds sprake van een vertraging van meerdere seconden |:( .
Dan maar iConnectHue blijven gebruiken voor mijn motion sensor :O.
  • luigi87
luigi87
Domotica Fanaticus
Heb weer even de hulp nodig van jullie hier.
Ik heb onderstaande blocky gemaakt en loop tegen een probleem aan
De stap Zomermodus = On AND Temperatuur buiten windmeter <18 SET Zomermodus = OFF
werkt niet terwijl beide voorwaarden waar zijn, echter denk ik dat hij deze stap niet eens uitvoert om de blocky al gestopt is met uitvoeren omdat stappen erboven onwaar zijn.
Ik heb al geprobeerd hem te versimpelen door de buiten temp eruit te halen, maar de zomermodus wordt gewoon nooit op off gezet.
Klopt het dat de stap gewoon niet gedaan wordt omdat de blocky niet helemaal tot de laatste Else if wordt afgelopen als er een eerdere Else if al niet waar was?
Afbeeldingslocatie: https://tweakers.net/ext/f/EGTmN6UJqQe09SJcbTXwcuik/full.jpg
Anders moet ik namelijk een deel van deze blocky in een nieuwe blocky zetten.
[ Voor 43% gewijzigd door luigi87 op 09-02-2019 09:18 ]
- leeg -
Toppe schreef op woensdag 6 februari 2019 @ 13:56:
Iemand zoiets al werkend gekregen?
Bekijk GARDENA Smart Water Control - Besproeiingsduur 1min tot 10u op: https://www.bol.com/nl/p/...socialshare_pdp_iphoneapp
Ik wil namelijk de boel kunnen bewateren ook als ik er niet ben. Kraan zit boven de bloembak die van water voorzien moet worden :D
op Ali vindt je heel veel van die dingen. die lijken me beter integreerbaar dan gardena. Je kan daar ook kiezen uit zwave etc..
Over mijn post over de versterker die het ineens niet meer doet.
ik zag foutmelding in console dat ik de daemon-reload moest doen. gedaan, en toen kreeg ik pardoes onderstaande log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
Last login: Tue Feb 5 19:55:05 2019 from 192.168.69.23
pi@pi-domo:~ $ sudo service domoticz status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (running) since Sun 2019-01-27 19:17:40 CET; 1 weeks 2 days ago
Docs: man:systemd-sysv-generator(8)
Process: 471 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCE CGroup: /system.slice/domoticz.service
├─ 507 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
├─ 1240 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 1242 nc 192.168.69.222 6001
├─ 1382 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 1384 nc 192.168.69.222 6001
├─ 1456 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 1459 nc 192.168.69.222 6001
├─ 2119 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 2121 nc 192.168.69.222 6001
├─ 2154 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 2156 nc 192.168.69.222 6001
├─ 2284 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 2286 nc 192.168.69.222 6001
├─ 2541 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 2543 nc 192.168.69.222 6001
├─ 3018 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 3020 nc 192.168.69.222 6001
├─ 3121 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 3123 nc 192.168.69.222 6001
├─ 3254 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 3256 nc 192.168.69.222 6001
├─ 3596 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 3598 nc 192.168.69.222 6001
├─ 3624 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 3626 nc 192.168.69.222 6001
├─ 3708 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 3710 nc 192.168.69.222 6001
├─ 4344 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 4346 nc 192.168.69.222 6001
├─ 4352 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 4354 nc 192.168.69.222 6001
├─ 5001 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 5003 nc 192.168.69.222 6001
├─ 5786 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 5788 nc 192.168.69.222 6001
├─ 6024 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─ 6026 nc 192.168.69.222 6001
├─10388 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─10390 nc 192.168.69.222 6001
├─10615 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─10617 nc 192.168.69.222 6001
├─11035 sh -c echo -n -e " " | nc 192.168.69.222 6001
├─11037 nc 192.168.69.222 6001
├─11233 sh -c echo -n -e " " | nc 192.168.69.222 6001
lines 1-50
betekent dit dat netcat de hexa code niet doorgeeft?
făbŞŤĄŘ - Mijn PC
@Toppe , daar lijkt het op. terwijl ik toch echt dit uitvoer in de console:
echo -n -e "\x02\x04\xA0\x60\x00\x00\xFC" | nc 192.168.69.222 6001
inderdaad moet de hexa code tussen de aanhalingstekens staan. RAARRRRRRRRRRRR
pffff. ik word er ondertussen wel beetje moe van hoor. er is verdorie altijd wat met die home automation. op zich leuke hobby, maar je moet er wel veul tijd in stoppen.
heb je het ene gerepareerd, doet het andere het weer niet. zuchttt
Domoticz 4.9700
ik ben bezig om mijn vaatwasser via de zonneboiler te laten lopen, tenzij er gedoucht wordt. daarvoor wil ik de setpoint van het domestic hot water (DHW) aanpassen via de OTGW naar de Remeha Calenta. Heeft iemand het voor elkaar gekregen om de DHW setpoint aan te passen? bij mij werkt het niet. gevolg: als vaatwasser water trekt, verbruik ik gas want ZB is niet op temperatuur.
zwave stick van aeon labs. werkt perfect. beter dan ik verwacht had van te voren. en de NEO coolcam shizzle, werkt prima. en voor dat geld...ach, laat er eens eentje kapot gaan. Fibaro switch voor 65 euro, of 3 stuks voor dat geld van Neo coolcam. mogen er 2 kapot gaan voor zelfde geld. niet zo zeuren....
daarnaast, heb jaren geleden eens die greenwave zwave tussenstekkers en 6-sloffen gekocht, daarvan heb ik er ook nog maar de helft over want die geven ook allemaal de geest. toevallig gisteren weer eentje van de droger ontploft.
Chrisje1983 schreef op donderdag 7 februari 2019 @ 21:14:
hier genoeg inbouw fibaro, qubino in de muren. daar heb ik er ook meerdere van teruggestuurd naar de dealer, in de buurt met garantie. dus mijn advies, ga gewoon lekker voor NEO, ik koop niks anders meer...
ook nog zo een ding wat ik niet aan de gang krijg hier op mijn rpi 3B. op kale installatie van domoticz komen de devices domoticz binnenrollen. zet ik mijn backup van mijn domoticz rpi1 terug op mijn rpi3B, zie ik ze niet...
zuchtttt
făbŞŤĄŘ - Mijn PC
  • Knielen
luigi87 schreef op vrijdag 8 februari 2019 @ 20:40:
[Afbeelding: plaatje]
Zou juist wel moeten werken als alles erboven niet waar is. Andersom kan ik me wel voorstellen, dat het script stopt zodra er 1 wel waar is.
  • luigi87
luigi87
Domotica Fanaticus
Knielen schreef op vrijdag 8 februari 2019 @ 21:54:
Ja en toch execute die regel niet. Alle statements erboven zijn niet waar door dat die alleen executen op de dag zondag.
Ook een simpele check op die switch of die on is. Resulteert niet in een off en melding op mail.
- leeg -
  • Stubby
Siewert schreef op donderdag 7 februari 2019 @ 20:28:
@Stubby Parameter 1
Na wat experimenteren ben ik uitgekomen op de waarde 100 voor parameter 1. Kortom het is de moeite waard even te pielen met de gevoeligheid.
Iemand enig idee of het mogelijk is in dzVents om een foreach te maken zonder daadwerkelijk gebruik te maken van de domoticz.devices?
Ik wil een lijst met IP adressen controleren op status 200 (dus online), alle adressen zijn te benaderen via HTTP.
Het probleem waar ik nu tegen aanloop is dat domoticz.openurl een callback nodig heeft en dit werkt niet lekker omdat hij eerst de volledige for loop afloopt en daarna pas de callback opent. Het resultaat is te bedenken: Hij pakt de status van het laatst gecontroleerde IP adres en geeft die status voor alle voorgaande adressen door.
De oplossing zou eenvoudig zijn: geen callback maar meteen er op handelen, maar volgens mij is dit niet mogelijk in dzVents?
  • luigi87
luigi87
Domotica Fanaticus
Begrijpen doe ik het niet, maar heb me 3 IFs met zomermodus naar een nieuwe blocky gezet. en de volgorde een beetje aangepast en nu lopen beiden blockys af tot aan de laatste IF.
Toch het idee dat die ene regel de rest blokkeerde ofzo....
Nu ben ik benieuwd of ik Zondag in de kou zit of niet.
Ik laat komende Zondag Domoticz (met een check of we thuis zijn) de thermostaat bedienen.
[ Voor 14% gewijzigd door luigi87 op 09-02-2019 13:02 ]
- leeg -
  • jobr
  • Laatst online: 26-07-2025
Toppe schreef op zaterdag 9 februari 2019 @ 09:13:
Wellicht gebruik maken van io.open:
  local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
    handle:close()
  • behave
  • Laatst online: 23-01-2024
Ik heb denk ik alles goed ingesteld. via putty kan ik een npm start uitvoeren en daar gaat alles goed. Na het aanzetten van een lamp zag ik deze pairen dus ook dat ging goed. Wat ik echter niet voor elkaar krijg is om dit in domotics te krijgen. Ik heb de plugings gedaan adhv deze pagina https://github.com/stas-demydiuk/domoticz-zigbee2mqtt-plugin maar als ik daarna domoticz opstart heb ik bij hardware niet de Zigbee2MQTT staan om toe te kunnen voegen.
Iemand een idee?
  • Scripts/code graag tussen ~[code] ~[/code] tags voor de leesbaarheid.
  • dzVents vragen? Lees eerst even de wiki door!
  • Lees ook de openingspost door!
  • Sommige vragen kunnen opgelost worden door zelf even Google te gebruiken, probeer dat eerst voordat je een vraag hier stelt!
