Iemand enig idee wat ik hier verkeerd doe
https://www.sony.co.uk/el...e-7rm3/downloads/00015516
https://www.sony.co.uk/el...ce-7m3/downloads/00015510
A7III: https://www.sony.co.uk/el...series/ilce-7m3#downloads
A7RIII: https://www.sony.co.uk/el...eries/ilce-7rm3#downloads
Benefits and Improvements from the latest update
- Support of "SEL400F28GM"and "SEL24F14GM"
- Optimization of the optical image stabilization performance, and addition of a new image stabilization mode of the lens (Mode 3)(Only "SEL400F28GM").
- Addition of a Function Ring(Lens) to the menu.
- Note: For the SEL400F28GM lens, the APS-C S35/Full Frame Sel. setting is assignable to the Function Ring in addition to Power Focus.
- Addition of [Aperture Drive in AF] setting in the menu.
- *Using the lens "SEL400F28GM" or "SEL24F14GM", when [Silent priority] is selected, the sound emitted by the aperture drive will be reduced. This is useful in shooting conditions where camera.
- noise should be kept to a minimum. Note that Auto Focus may become slower when [Silent priority] is selected.
- New features:
- [AF Track Sens] can be assigned to a custom key.
- When used with the LA-EA3 mount adaptor, all focus areas are supported.
- Note : Focus Area options added : Zone, Expand Flexible Spot, and Lock-on AF.
- Bracket shooting is available during silent shooting when [File Format] is set to [RAW] or [RAW & JPEG] and [RAW File Type] is set to [Uncompressed].
- Other improvements
- Improvement of the performance and the overall stability of the camera.
- Better reproduction of the gradation of RAW pictures.
- Note: Imaging Edge software needs to be updated to benefit from the improvement in the RAW processing.
- When shooting with a flash in an environment with flickering light sources, the stability of the exposure is improved.
- Improvement of managing continuously shot images as a group.
- Please refer to the HelpGuide for updated function usage.
New A7III and A7rIII 2.0 firmware causes issues with third party batteries
https://www.sonyalpharumo...th-third-party-batteries/
[ Voor 15% gewijzigd door Daan_ op 12-10-2018 12:34 ]
MTB24.nl plekje op het web voor filmpjes :)
Ik zal het maandag eens uittesten met een Hähnell accu.Verwijderd schreef op zaterdag 13 oktober 2018 @ 09:34:
Die waarschuwing is niet per se iets mis mee. Sony kan op afstand lastig bepalen of goed gaat immers.
Ik was namelijk afgelopen dagen enkele Bracketing opnames aan het uitvoeren, zegt de camera dat deze bezet is wanneer ik het resultaat wil bekijken. Dit fenomeen heb ik zelfs bij 1 enkele opname, iets wat ik bij Fujifilm niet had?
Slot 1
sandisk extreme pro 128gb
https://www.dataio.nl/wp-.../01/Extreme-Pro-128GB.jpg
Slot 2
sandisk ultra 128gb sd card
https://asset.conrad.com/...388582_BB_00_FB/image.jpg
[ Voor 10% gewijzigd door Moris op 14-10-2018 15:25 ]
Dat wordt alvast een extra sd-kaartje Sandisk extreme pro 128GB halen.
Had die ook zon hoge resolutie en grote bestanden dan? Denk het niet toch?Moris schreef op maandag 15 oktober 2018 @ 08:35:
Wel vreemd dat ik bij Fujifilm dit niet ervaarde.
Als je snelheid wil dan moet je voor een UHS-2 kaart gaan.
De Sony A7 III heeft twee slots. 1x UHS I 1x UHS II. Welk slot heb je de kaart. Schrijf je RAW un-compresed weg? Etc.... wat meer informatie is wel handig. En heb je zelf ook gezocht? is best veel te vinden hierover ;-)Moris schreef op zondag 14 oktober 2018 @ 11:15:
Iemand die me kan zeggen waarom mijn camera A7iii met de onderstaande geheugenkaartjes zo traag wegschrijft en deze tijdens het wegschrijven voor andere zaken bezet houdt?
Slot 1
Slot 2
https://fstoppers.com/gea...memory-sony-a7-iii-247482
Slot 1 is jpeg, slot 2 is voor RAW un-compresed, wat met bivenstaande info duidelijker wordt.
[ Voor 20% gewijzigd door Moris op 15-10-2018 12:36 ]
Die geeft dus ook hetzelfde probleem. Het bijzondere is dat het even duurt voordat hij de melding geeft. Je kunt hem wel gewoon gebruiken.Universal Creations schreef op zaterdag 13 oktober 2018 @ 18:54:
https://www.sonyalpharumors.com/
Dat kun je beter andersom doen.Moris schreef op maandag 15 oktober 2018 @ 12:22:
Ik schrijf de bestanden als volgt weg.
Slot 1 kan UHS-II aan en is dus het snellere slot. Uiteraard hangt het van je kaartje af of die dat ondersteund/kan bijbenen. Om de buffer niet te gek groot te laten worden is het slim om voor compressed raw te gaan. Ik zie in de praktijk echt 0,0 verschil met uncompressed raw.
Slot 2 met een wat trager kaartje voor JPG moet kunnen, hoewel als hij te traag is houd hij alsnog de boel op. Dit zou je kunnen testen door met en zonder 2e kaartje in dit slot te schieten en zien of je verschil merkt of kan meten.
Succes
Trouwfotografie.nl
dekunstvanfotografie.nl
Sony A7RVI | A9III
Sigma: 17 F4.0 || Sony: 25 F1.4 GM | 35 F1.4 GM | 50 F1.2 GM | 50-150 F2 | 100-400 F4.5-5.6 GM
DJI: Mavic 3s en Mini2
Nu ik net terug uit vakantie ben kan ik na het nemen van een back-up het wisselen van de kaartjes zonder gegevensverlies vanavond eens testen.
Bedankt voor de tip
Alleen blijf ik met de vraag zitten waarom de snelheid na het formatteren van de sd-kaartjes opeens hoger werden, lijkt wel of één van de sd-kaartjes ruk zijn?
De SD-kaartjes en instellingen zaten voorheen als volgt.
Slot 1 is Jpeg
Slot 2 is RAW un-compresed.
Heb de instellingen aan de hand van de info van Mud.Starrr nu als volgt geplaatst en dit verhoogt uiteraard de snelheid.Hoe kon het ook anders.
Slot 1 > RAW compressed
Slot 2 > Jpeg
Trouwfotografie.nl
Sony A7RVI | A9III
Ik heb al een tijd de A7 III in gebruik en ben zeer tevreden, er valt me alleen iets op bij het uitzetten van de camera. Soms lijkt het of de sluiter nog een keer open en dicht gaat, ofwel gewoon een foto maakt als ik de camera uitzet. Is dit de sensor cleaning of iets anders? En hebben meer mensen hier last van?
Dit had ik ook met mijn A7iii en lijkt te maken te hebben met de sensor remapping:cunodb schreef op woensdag 17 oktober 2018 @ 09:51:
Hi Allen,
https://www.dpreview.com/forums/thread/4264098
Je had het ook? Dus bent terug gegaan naar de winkel en nu is het gefixed? Of heb je het nog steeds? Het maakt bij mij ook niet uit of er een lens op zit.SkyThes schreef op woensdag 17 oktober 2018 @ 10:01:
Nee mijn A7 is tijdens mijn vakantie gestolen paar weken geleden helaas...cunodb schreef op woensdag 17 oktober 2018 @ 10:09:
Maar het is niet iets om je zorgen over te maken.
Als ik op de play button druk na het fotograferen, dan telt mijn camera de complete shuttercount in de view reeks. Stel dat is nu 100, ik maak een foto, dan wordt het 101. Maar dat blijft dus altijd rechts bovenin staan, ook al heb ik de geheugen kaartjes leeg gemaakt.
Dus ik haal 100 foto's van het geheugen kaartje af, ik druk deze weer in de camera en maak een foto, ik kom op 101 uit en ik ga reviewen, dan kan ik dus ook scrollen tussen 101 foto's, maar er staat er maar 1 op natuurlijk, dus die andere 100 zie ik alleen "Unable to display". Met het terugkijken is dat wel verdomd lastig want dan weet ik ook niet precies wat ik heb geschoten.
Ik heb de geheugen kaartjes ook al beide geformateerd, misschien dat daar iets in werd bijgehouden maar dat is ook niet het geval.
Misschien een beetje lastig uit te leggen, maar hier op zoeken schiet ook niet echt op als je alleen het woord "review" er al in hebt zitten.
Iemand enig idee?
Sony A7III | Sony a6300 | Sony ZV-E1 | 12 2.0 | 21 1.4 | 24 1.4 | 35 2.8 | 50 1.4 | 135 1.8 | 16-28 2.8 | 16-70 4 | 28-75 2.8 | 70-200 2.8 II |
Hoewel formatteren eigenlijk ook zou moeten helpen natuurlijk... (in de camera gedaan of in je PC?)
Wel vaag, want ik had de kaartjes al geformateerd, maar dan zal die zelf ook nog wel iets bijhouden in de camera wat dat betreft, maar gelukkig werkt het nu. Hartelijk dank!
(ik zat al ergens op 2074 dus dat is dan opeens wel veel scrollen enzo)
Gisteren via een tip hier de GABALE QR L Plate Bracket Camera Grip Camera Holder for Sony A7MIII mogen ontvangen en ben hierover zeer tevreden over. Prijs/kwaliteit is dus dik in orde
https://www.ebay.nl/itm/G...819acf:g:bEYAAOSw5cJao57g
Update.Mud.Starrr schreef op dinsdag 16 oktober 2018 @ 21:09:
Dat het na het formateren sneller loopt kan ik niet verklaren, maar fijn dat mijn tip heeft geholpen.
Om even terug te komen op mijn probleem met de Sandisk geheugenkaartjes.
Ik heb dit probleem bij de support van Sandisk voorgelegd, waarbij ik verschillende testen dienden uit te voeren en de nodige printsreens met bijbehorende logs moest bezorgen. Na intern onderzoek werd er beslist om beide geheugenkaartjes onder garantie te vervangen.
Aangezien ik voor het wegschrijven van raw en jpeg-bestanden mijn traagste geheugenkaartje wil vervangen, wou ik even jullie raad hierin hebben.
Ik zoek een betrouwbaar UHS-II 128GB geheugenkaartje en dacht hierbij aan SONY SDXC 128GB EXTRA PRO M CLASS 10 UHS-II
Iemand met dit kaartje goede ervaring of zijn er andere en betere alternatieven
Als je camera het aan kan kun je overwegen om voor het zelfde bedrag de 64GB versie te kopen die 3x zo snel is met schrijven. Beetje een afweging die je moet maken denk ik.Moris schreef op dinsdag 6 november 2018 @ 10:21:
Update.
Het hangt ook van je camera af (ben even kwijt welke jij hebt).Moris schreef op dinsdag 6 november 2018 @ 10:21:
Update.
Ik heb op de A7 III (en RIII in mindere mate) prima ervaringen met 128GB Integral Ultima Pro X2 kaartjes. (SDXC V60 II).
Deze doen op papier 280MB read/100MB per sec write. In de praktijk op de 7R III doen deze ongeveer 75MB/sec write.
Verder heb ik zeer goede ervaringen met 32gb Sony G SDHC II kaartjes, 300MB/299MB per sec op papier. Dit zijn de snelste kaartjes die je momenteel kunt krijgen, en zijn ook de kaartjes die je als Sony Pro van Sony krijgt. Dit omdat de A9 deze snelheid ook gewoon nodig heeft om de buffer op 20fps snel weg te schrijven.
In de praktijk op de A7R III rond de 127MB/sec.
De sony’s die jij noemt zitten hier een beetje tussenin qua snelheid. Rond de 88MB in de praktijk.
Volgens de tests zit er in de praktijk op een A7III niet super veel snelheidsverschil tussen, en dat is ook mijn ervaring. De camera hoeft natuurlijk ook ‘maar’ 24 megapixel bestanden weg te schrijven, en heeft ook een wat minder snelle processor dan zn duurdere broers.
Je merkt het met de R wel duidelijk als je de buffer helemaal volgooit dat het wat langer duurt om hem weg te schrijven. Dit omdat je gewoon veel meer data kwijt moet. Een snellere kaart is dan wel fijn.
Voor video maakt het allemaal niet zoveel uit als je maar aan de minimale snelheid voldoet voor 4k 100fps 50p (dat ligt rond de 20MB/sec).
[ Voor 27% gewijzigd door Mud.Starrr op 06-11-2018 13:44 . Reden: Een hoop info toegevoegd ]
Trouwfotografie.nl
Sony A7RVI | A9III
@Mud.Starrr
Bedankt.
Ik heb als camera een Sony A7 III.
Voor het wegschrijven en bufferen van raw-bestanden hoef ik blijkbaar niet het snelste kaartje zoals de Sony G SDHC II aan te kopen. Ook 128GB Integral Ultima Pro X2 zal ruim moeten volstaan.
Ik zit te kijken naar een "goedkoopje", dus een van de oudere NEX / a5000-achtige modellen, die tweedehands voor ca. 150-250€ weggaan. Of is het beter om het dan maar helemaal te laten zitten?
Op een of andere manier blijft deze camera terug op mijn pad komen. (Heb hem inmiddels 3x verkocht en weer opnieuw gekocht, voor prijzen waar ik geen nee tegen kon zeggen. Dit is zo'n camera die je tweedehands kan kopen, mee spelen en als je het niks vindt weer kan verkopen zonder verlies!
Ik gebruik hem voornamelijk voor TimeLapsen (zowel in de studio als op locatie) BTS shots, en tegelijkertijd als backup camera.
Het is bijna Black Friday en gegarandeerd dat deze weer tegen stuntprijzen te koop wordt aangeboden.
Ik vind het fijn om op vakantie nog een back-up te hebben waar ook de objectieven op passen.
Daarnaast is het ook de onderwatercamera (wel in een behuizing uiteraard).
De 5n is zeker met het 16/50 objectief erg compact.
::. PV N/Z 10281Wp :: 15.1kWh accu :: All Electric .::
Voordat ik het kaartje uit de verpakking haal en naar aanleiding van dit artikel wil ik graag weten of er hier A7iii gebruikers zijn die met deze kaart geen problemen hebben? Indien wel, gaat deze uiteraard ongeopend de verkoop in.
[ Voor 19% gewijzigd door Moris op 16-11-2018 12:31 ]
Dat is vreemd, want volgens mij worden die kaartjes door legio Sony A7III eigenaren gebruikt.Hielko schreef op vrijdag 16 november 2018 @ 13:23:
Toen ik mijn Sony A7 III kocht had ik er een SanDisk SDXC Extreme Pro 64GB 95MB/s V30 bijgekocht. Die heb ik dezelfde dag nog omgeruild voor een Sony kaartje omdat ie niet werkte in de camera... dus lijken iig wel wat meer SanDisk kaartjes niet goed te werken.
Ik bekijk het wel verder.
2.0 for A7rIII has been removed
Sony realized there is a bug with the SD cards that needs to be fixed.
https://www.sony.com/elec...e-7rm3/downloads/00015520
[ Voor 4% gewijzigd door Daan_ op 08-12-2018 14:45 ]
Sony A7 III
https://www.sony.com/elec...dy-ilce-7-series/ilce-7m3
Sony A7R III
https://www.sony.com/elec...y-ilce-7-series/ilce-7rm3
Improves the following:
In rare cases, the camera may stop functioning while writing RAW data onto an SD card that has already been used multiple times
Notes:
This may also cause abnormalities in the files managing the images, preventing the images from displaying on the camera.
No image data in the memory card will be corrupted or deleted aside from the data that was being written at the time the interruption occurred.
Solves the problem caused by a specific third-party memory card, which would not be recognised by Sony cameras
Improvement of the overall stability of the camera
Die van mij heb ik ook wel eens op de stenen laten kletteren vol op de zoeker. Buiten wat verbogen kunstof niets mee aan de hand.Milo. schreef op zaterdag 11 augustus 2018 @ 17:52:
Andere kleine noot, mijn oude a7 is een keer wat sneller dan ikzelf een trap bij het strand afgedaald. Buiten wat zwarte pixels op jet scherm die na een tijd weer bijtrokken was er niets aan de hand.
Die oude A7 is echt niet onbetrouwbaar hoor, zijn relatief weinig repararie gevallen.
Capture One of de pro variant.ChiLLeR schreef op dinsdag 14 augustus 2018 @ 08:47:
Helaas werkt de A7iii nog steeds niet op de mac foto's app. Want de Sony memories applicatie is wel zo ingewikkeld om mee te werken... Iemand een simpele manier om toch de foto's eenvoudig in Mac foto's te importeren?
Die kon je eerst gratis krijgen en de pro met korting als je een Sony Camera hebt. Geen idee of dat nog zo is.
En anders Gimp downloaden of een ander alternatief. Kun je meteen veel meer mee dan Apple’s Photo’s.
[ Voor 4% gewijzigd door Mud.Starrr op 13-01-2019 09:42 ]
Trouwfotografie.nl
Sony A7RVI | A9III
https://www.dpreview.com/...r-iii-and-a9-improving-af
Key features:
* Animal Eye AF Tracking
* Real Time Eye AF Tracking (Door de shutter knop half ingedukt te houden)
* En Time Lapse is terug!!!!!
Klopt, was mij ook niet helemaal duidelijk. Wel echt een mooie ontwikkeling dat er echt nieuwe functies worden toegevoegd in plaats van een nieuw model lanceren met nieuwe functies.Hielko schreef op dinsdag 15 januari 2019 @ 22:00:
Real-time Eye AF, als ik het goed begrijp is het niet meer nodig om een speciale knop te mappen om Eye AF te activeren? Lijkt mij een nuttige verbetering, snapte eigenlijk al nooit zo goed waarom dat überhaupt nodig was.
[ Voor 15% gewijzigd door ChiLLeR op 16-01-2019 09:08 ]
>> Signature?
Nee was mij ook totaal onduidelijk waarom dit altijd moet. Heb zelfs de handleiding en internet paar keer doorgespit omdat ik er vrij zeker van was dit ik iets verkeerd deed. Merken als Panasonic en Olympus implementeren dat al jaren en het is super handig.Hielko schreef op dinsdag 15 januari 2019 @ 22:00:
Mijn A7R II zal natuurlijk geen update meer krijgen maar die zou het ook prima kunnen. Jammer.
Oh en je zal net geld hebben uitgegeven aan die suffe timelapse feature (die er sowieso standaard in had moet en zitten natuurlijk).
[ Voor 8% gewijzigd door sys64738 op 16-01-2019 09:13 ]
Flickr | Photography 101: Skills > Patience > Gear
Toen ik overstapte naar de A7III miste ik de feauture wel dus toen maar met een intervalometer aan de slag gegaan.
Hier een video van de nieuwe TimeLapse i.c.m. een powerbank voor extra lange opnames zodat je lekker je 8 uur slaap kan pakken
Regelmatig zie ik mensen nog zorgen maken over het aantal genomen foto's met hun camera's, handig tooltje om dit even snel uit te lezen door je laatst gemaakte foto er in te slepen.
http://tools.science.si
Zit zelf nu op een kleine 9K in ~ 10 maanden tijd, dus laten het afronden op ruim 1000 foto's per maand.
Als ik geruchten van 150.000 mag geloven, dan zou dat betekenen dat ik 15 jaar vooruit kan zonder zorgen;)
We doen ±4 jaar met een body, daarna komt er echt wel wat nieuws.
Max zitten we dan rond de 100k (grofweg 100 shots per dag per camera).
De topmodellen van tegenwoordig kunnen echt enorme aantallen aan, en als je niet in een productstudio of als sportfotograaf (burst) werkt zou ik me er niet zo druk om maken. Zeker niet met een spiegelloge camera, want we hebben wel eens wat kapotte spiegel mechanismes gehad (hoewel zelden), en maar 1x een kapotte shutter.
En dan gebruik je met je Sony wellicht de digitale shutter ook nog regelmatig, afgewisseld met de normale, scheelt ook weer.
Trouwfotografie.nl
Sony A7RVI | A9III
Volgens de uitleg die ik vond op https://www.alphashooters...iii/dual-card-slot-setup/
Simultaneous Images
In this mode the camera will record images (RAW/JPEG) to both slots 1 and 2 at the same time, and will record videos to slot 1. I’m using this option myself 99% of the time.
Wanneer ik deze instelling activeer wordt er op slot 2 geen data opgeslagen
Iemand die me kan zeggen of ik iets over het hoofd zie?
Sinds kort ben ik ook lid van de Sony FF familie. Komende van een Olympus m43 is een A7R III toch wel een mooie stap
Heb inmiddels een A7iii en 24-105 aangeschaft.
Bij Foto Verschoore loopt er op dit moment een BTW actie, die neerkomt op een korting van 17%
Misschien interessant als je nog iets wilde aanschaffen.
Heb zojuist de grip besteld voor 265 euro en de 85 mm 1.8 voor 539 euro
http://www.avfoto.nl
Sinds 3 jaar A6000 gebruiker. Sinds een jaar de wens om naar fullframe over te stappen. Ook bij het kopen van lenzen al rekening mee gehouden (50 en 85mm FF aangeschaft bijv.). Verder ben ik geen pro, maar wel een heel enthousiaste amateur en wil ook wel wat professioneler aan de slag wil.
Ben bijvoorbeeld door een vriendin gevraagd om in maart/april portretten/productfotos (ze start een eigen kleine kledinglijn) te maken.
Nu ben ik eigenlijk aan het sparen voor een A7iii maar budget laat dit nog niet toe. Verwachting is volgende herfst/winter. Nu zag ik gisteren een tweedehands A7ii body incl. Sony batterygrip staan, bij mij om de hoek voor €800, zeg dat ik tot €750 kan afdingen.
Dit zou een tussenstap zijn om met de het A7-platform en FF te leren schieten zonder meteen €2200 neer te hoeven tellen. Over een jaar zou ik dan alsnog kunnen zeggen, ik verkoop de A7ii en koop dan de A7iii (dan wellicht in prijs gezakt).
Ik ben er wel enthousiast over. Denk ook niet dat je met de A7ii iets fout doet (uitgaande van goede kwaliteit van dit tweedehands exemplaar), ben me natuurlijk sinds een jaar al in het inlezen in de A7 serie.
Maar toch, zie ik hier iets over het hoofd?
Prijs is netjes, denk niet dat je heel veel verlies maakt als je hem voor 750 kan overnemen.
Aangezien je al een A6000 hebt, heb je waarschijnlijk genoeg accus’s dus dat is een plus.
Grootste voordeel t.o.v. De A6000 is EYE Af in AF-C modus, wat erg fijn is als je je portretten gaat schieten.
Ik heb zelf de A6000 tegenwoordig als backup / scouting en time lapse camera😏
@Unidentified, Eye-AF heb je dus -niet- bij AF-C op een A7ii, alleen op een A7iii (helaas).
Thanks! Ik weet ook nog niet of ik dan direct mijn A6000 verkoop of nog even houd. Zo veel levert die natuurlijk ook niet meer op, hoewel ik nog wel redelijk wat APS-C glas heb liggen.Unidentified schreef op dinsdag 5 februari 2019 @ 14:13:
@Malfoi Ik heb beide camera’s (gehad) en de A7II is een prima camera, heb er zelf meer dan een jaar mee geschoten en nu ook de eigenaar van een a7III.
Trouwens, de A7ii heeft ook zo'n modus dat je APS-C glas nog kan blijven gebruiken toch?
Oké, dat bevestigt ook mijn twijfels. Eye-AF is natuurlijk leuk maar niet super noodzakelijk (voor mij). Net zo min is dat dual card slot, gezien ik nu ook met meerdere kleinere SDs werk dan met één grote. 4K video gebruik ik ook niet, sowieso weinig video. In ieder geval de meerprijs (nog) niet waard.Garyu schreef op dinsdag 5 februari 2019 @ 14:19:
Ik heb dezelfde overstap gemaakt van a6000 naar a7ii, ook tweedehands voor een relatief zacht prijsje op de kop getikt. Ja, je mist een aantal features, zoals 4K video, eye-AF in AF-C, een tweede / snel geheugenslot, nog wat minder belangrijke dingen. Maar daar 1500€ meer voor neer te leggen was voor mij financieel gewoon niet te rechtvaardigen geweest. De A7ii is gewoon een prima apparaat. Ik heb er een jaar geleden ongeveer tweedehands 800€ voor betaald.
De camera is wel van een professionele studiofotograaf geweest, maar een (vermoedelijk) hoge shutter count is bij ILCs minder erg dan bij DSLRs toch? --> Laat maar, posts hierboven over shutter count even over het hoofd gezien.
Yes, zo'n modus bestaat. Echter schakelt de camera daarbij terug naar 10MP, je gebruikt immers een flink deel van de sensor niet meer. De andere voordelen van een FF heb je natuurlijk nog wel (ruis, DoF-controle, stabilisatie..).Malfoi schreef op dinsdag 5 februari 2019 @ 16:21:
[ Voor 0% gewijzigd door Garyu op 05-02-2019 16:55 . Reden: stabilisatie toegevoegd ;) ]
Ruis (in de totale afbeelding) en DOF is in dat geval exact hetzelfde als bij een APS-C camera.Garyu schreef op dinsdag 5 februari 2019 @ 16:30:
Ruis per pixel is lager omdat de pixels groter zijn, maar de resolutie is ook lager. Die twee gaan hand in hand.
Ik zag in een YouTube video over de A7iii dat die een "Clear Image Zoom" functie heeft, waarbij de volledige resolutie behouden blijft. Heeft de A7ii dit niet?Garyu schreef op dinsdag 5 februari 2019 @ 16:30:
Zat te kijken naar de pricewatch: Sony A PCK-LG1 Screenprotector maar vind hem echt te prijzig
Er zijn op de bekende websites als DX etc. goedkopere te vinden. Zelf tijdje goedkope van DX erop gehad, maar die uiteindelijk in de kliko gegooid en toch voor de Sony gegaan.
Hippos are apparently just rage filled hate tanks
Verder zijn er vast wel ervaringen van de aanbieder via Google te vinden? En kijk anders in Shopping Forum? Daar staan ervaringen met diverse aanbieders/winkels....
[ Voor 15% gewijzigd door Daan_ op 02-03-2019 11:24 ]
Ga in mei naar Tokyo, dus daar ook nog maar eens even speuren naar een of meerdere leuke lenzen voor erbij.
Canon | Fujifilm | www.tobiasvanstijn.nl
https://www.sony.nl/electronics/support/articles/00220555
Handige artikel voor de details : http://www.markgaler.com/...g-for-a7iii-a7riii-and-a9
Fotografie kanalen: Website - Royz.nl | YouTube - @Royz.nl | Instagram - @Royz.nl.
Het vervelende is ook dat nog niet duidelijk is, welke instellingen wel en welke niet worden overschreven toch? Sowieso vereist het hele menu uitpluizen al wat manuren dus ik vul mijn dagen welDaan_ schreef op woensdag 3 april 2019 @ 12:42:
Exacte datum kan men je nog niet geven. Die is vanuit Sony nog niet gecommuniceerd. Ergens in April is de verwachting. Laatst wel met nieuwe firmware gespeeld en zeker leuke welkome update ;-)
[ Voor 1% gewijzigd door Daan_ op 03-06-2019 13:17 ]
Durf niet met 100% zekerheid te zeggen welke instellingen worden overschreven. De upgrade nog niet zelf uitgevoerd enkel op demo Sony A7 III gespeeld die voorzien was met de firmware. Eye AF wordt wel stuk gebruikers vriendelijker. Dit wat gelijk opviel.Royz schreef op woensdag 3 april 2019 @ 12:51:
Verder zou ik daar niet op wachten, gewoon alvast met instellingen experimenteren en je voorkeuren even ergens noteren. Dan kan je toch alvast aan de gang met de camera, er zit boordevol aan custom buttons en mogelijkheden in.
[ Voor 4% gewijzigd door Moris op 09-04-2019 17:48 ]
Ik hoor serieus dat die timelapse tot 9999 images gaat. Ik heb ook een Olympus en die gaat tot 999, dat is echt te weinigMoris schreef op dinsdag 9 april 2019 @ 17:48:
Eindelijk is het bijna zover... de lang verwachte update op 11 april Firmware 3.0 voor de A7rIII en A7III
Nice, ik heb zaterdag een fotoshoot, dus dan kan ik het gelijk testenMoris schreef op dinsdag 9 april 2019 @ 17:48:
En hier de Windows versie. Ik ben benieuwd hoe het werkt, de update is hier bezigMoris schreef op donderdag 11 april 2019 @ 09:27:
Yes, de firmware 3.0 staat inmiddels klaar voor de Ar7II en de A7III
Wat ik wil een beetje mis is dat er volgens mij geen manier is om snel tussen human eye-AF en animal eye-AF te switchen behalve door in het menu te duiken? Zou mooi zijn als je dat bijv. onder een custom key zou kunnen zetten, heb er tenslotte nu weer 1 vrij nu eye-AF automatisch activeert.
nee bij mij zijn alle settings mooi blijven staanRoyz schreef op donderdag 11 april 2019 @ 11:46:
Voor degenen die hem al hebben geïnstalleerd... moest je veel (custom) settings weer opnieuw instellen?
hmm op windows doet hij het wel direct. ligt blijkbaar aan (mijn) mac
[ Voor 15% gewijzigd door Royz op 11-04-2019 16:34 ]
Dat kan, je kunt AF3 (scherm 6/23) Subject Detection pakken om onder een custom button te stoppen.Hielko schreef op donderdag 11 april 2019 @ 11:41:
Thanks, dat is hem inderdaad.PatMan schreef op zaterdag 13 april 2019 @ 00:03:
Ik pak altijd het bestand uit de Resources map "SystemSoftwareUpdater" dan loopt die netjes door. Ook met een niet Sony kabel. Gebruik zelf een USB-C laadkabel van een van de MacBooks.Royz schreef op donderdag 11 april 2019 @ 16:22:
Ik dacht ik doe het even snel tussendoor, maar de Updater ziet mijn camera niet ook niet met de originele usb kabel. De camera staat wel in USB mode (mass storage)... Na ja vanavond maar verder kijken
Ja dat deed ik ook, in de eerste stap herkende hij mijn camera wel dan moet je hem disconnecten. Vervolgens moet je hem connecten en daarna kan hij hem niet meer vinden. Anyway met Windows is het wel gelukt, volgende keer doe ik het wel gelijk zoDaan_ schreef op zaterdag 13 april 2019 @ 10:55:
- Update_ILCE7RM3V300.dmg openen
-- kies niet de "UpdateSettingTool, maar open de map "Resources"
--- kies dan voor SystemSoftwareUpdater"
---- volg instructies opgegeven moment geeft die aan dat die usb ontkoppelt heeft, maar hier liep het altijd netjes door.
[ Voor 5% gewijzigd door Daan_ op 03-06-2019 13:18 ]
>> Signature?
Voor vragen of discussie m.b.t objectieven kun je terecht in het daarvoor bedoelde topic; Het Sony E-Mount objectieven topic 2018
Voor Aankoopadvies kun je terecht in Foto & Video Aankoopadvies
