• gjs
  • Laatst online: 23-09 09:43
gjs
Scoobydoobydoo
Verwijderd schreef op vrijdag 07 mei 2010 @ 00:31:
Ik zie nu de Emm berichten binnen komen. Is het normaal dat om de ongeveer 2 minuten hetvolgende verschijnt?
[ 00:28:57 ] [ Irdeto ] Card AU on reader 0 (reader1) was successfull
[ 00:28:57 ] [ Irdeto ] emmok: 1 data00:02 providerID:00
De rest van de tijd krijg ik dit
[ 00:29:46 ] [ Irdeto ] Card AU on reader 0 (reader1) was not successfull
[ 00:29:46 ] [ Irdeto ] emmok: 0 data00:02 providerID:00
Stukje uit mijn log (filter op 'was successull').
[ 10:07:27 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:08:54 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:09:14 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:09:28 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:09:51 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:11:17 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:11:26 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:12:41 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:13:25 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
[ 10:14:03 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was successfull
Dus grof weg om de halve minuut een succesvolle emm update.
De zelfde tijd perdiode maar dan 'was not successull'.
[ 10:07:57 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:08:01 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:08:25 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:08:39 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:09:16 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:10:00 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:10:17 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:10:38 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:11:38 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:11:58 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:12:00 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:12:37 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:13:05 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:13:27 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
[ 10:14:00 ] [ Irdeto ] Card AU on reader 0 (Phoenix on Com2) was not successfull
Zo lang je maar 1 keer in het half uur (dacht ik) een successfull emm update krijgt, blijf je kaart gewoon werken.
Waarschijnlijk verschilt het aantal updates wel in de verschillende Ziggo gebieden.
Kortom niets om je zorgen over te maken.
GA-Z68X-UD3H-B3 I7-2600K@4.4GHz 24Gb Ram 7Tb HDD
Ok dan hoef ik me inderdaad geen zorgen te maken :)
  • eXisTa
Heeft iemand het "rolling code" van de EMM probleem al opgelost met de AnySee?
eXisTa schreef op vrijdag 07 mei 2010 @ 14:17:
wat?
  • ThinkPad
Even een paar vraagjes, van deze "DVB-C op je PC-noob"
  1. Ik ben van plan een FloppyDTV te kopen, maar zie nu dat m'n PC geen FireWire heeft. Nu staan er in Vraag & Aanbod wel wat FireWire kaartjes, maar maakt het nog uit welke chipset ik pak? Of kan ik gewoon ieder FireWire kaartje gebruiken :) ?
  2. En kun je met een FloppyDTV + Alphacrypt CAM + Ziggo smartcard ook HD zenders bekijken? (die je normaal met een Ziggo HD Decoder ook zou kijken, Ned1,2,3 HD enzo)
  3. Wat is de meest snelle software om mee te kijken? Ik bedoel daarmee: Welke heeft bij een coldboot van je PC het snelste beeld? Ik heb namelijk geen zin om 5 minuten te wachten voordat ik beeld heb :X
[ Voor 41% gewijzigd door ThinkPad op 13-05-2010 11:03 ]
  • gjs
gjs
Scoobydoobydoo
ThinkPadd schreef op donderdag 13 mei 2010 @ 11:01:
  1. geen idee
  2. ja dat kan
  3. denk dat Windows Media Centre het snelste werkt. Wil je een snelle coldboot, neem een SSD.
  • amontillado
  • Laatst online: 13-10 20:10
  1. Ik ben van plan een FloppyDTV te kopen..
  2. Wat is de meest snelle software om mee te kijken? Ik bedoel daarmee: Welke heeft bij een coldboot van je PC het snelste beeld? Ik heb namelijk geen zin om 5 minuten te wachten voordat ik beeld heb :X
Je kunt het bijgeleverde firedtv viewer gebruiken, is erg snel. Ik gebruik DVBViewer Pro, en heb in 45 seconden bij een cold boot beeld (win7 64)
"All that we see or seem, is but a dream within a dream" E.A. Poe
1. Maakt wel uit maar niet veel, volgens mij was Texas Instruments chipset het snelst en geeft iets minder problemen dan VIA, maar zelf had ik altijd een PCI insteekkaartje met een VIA chipset en had vrijwel nooit problemen, en de problemen die ik had waren niet terug te herleiden naar deze kaart.
2. Ja, op voorwaarde dat je software dat ondersteund.
3. Meest snelle software is afhankelijk van je hardware. Snap ook echt niet waarom het vanuit een coldboot van belang is, je zet hem toch op standby. Mijn setup is sneller uit standby dan'dat m'n tv beeld geeft. Wil je een snelle coldboot dan zal je inderdaad aan een SSD moeten gaan denken.
Heb zelf niet het idee dat mediacenter sneller of langzamer is dan bijv mediaportal of xbmc qua initiele opstart.
  • Promy
  • Laatst online: 14-10 08:51
Ik vernam dat het met dvb-c of C+ mogelijk zou zijn om een aantal HD kanalen te ontvangen van het telenet aanbod in Belgie. meer bepaald de free-to-air kanalen (één+,canvas+,...)
Dit werkt alleszins op tv's van Philips, maar ik vroeg me af of dit ook zou werken op een dvb-c kaart voor in de htpc.
Ik heb hier niet de hardware liggen om dit te testen, vandaar deze oproep >:)
  • CAD-tekenaar
  • Laatst online: 12-10 06:23
Ook ik werk volgens de handleiding van The Zep Man (met dezelfde geadviseerde hardware/software) onder win7 x64. Maar het is me nog steeds niet gelukt dat newcs direct de juiste caid vindt. Na enkele herstarts van newcs.exe lukt het uiteindelijk wel, maar niet altijd gelijk de eerste keer goed.
In de handleiding (zie stap 4) schrijft The Zep Men dat smartcard.conf gewist kan worden omdat hij overbodig is. Dit heb ik dan ook gedaan.
Zelf twijfel ik nog een beetje of dit nog steeds nodig is om bovengenoemd probleem op te lossen.
Kan iemand mij toelichten of ik smartcard.conf alsnog nodig heb? Zo ja, hoe moet ik deze dan moet instellen om mijn probleem op te lossen? (Ziggo 9003, caid 0604)
[ Voor 3% gewijzigd door CAD-tekenaar op 15-05-2010 22:37 ]
  • ThinkPad
Vandaag lekker aan het prutsen geweest met m'n FloppyDTV C/CI
Alles aan de praat gekregen uiteindelijk (FireDTV viewer, Win7 Mediacenter, DVBViewer).
Hier het config bestand voor Ziggo 9700:
29
30
31
32
33
34
[SATTYPE]
1=4000
2=Ziggo 9700
[DVB]
0=28
1=578000,3,6875
2=506000,3,6875
3=554000,3,6875
4=658000,3,6875
5=818000,3,6875
6=730000,3,6875
7=810000,3,6875
8=682000,3,6875
9=762000,3,6875
10=618000,3,6875
11=610000,3,6875
12=738000,3,6875
13=482000,3,6875
14=385000,3,6875
15=393000,3,6875
16=401000,3,6875
17=369000,3,6875
18=626000,3,6875
19=377000,3,6875
20=754000,3,6875
21=642000,3,6875
22=586000,3,6875
23=650000,3,6875
24=409000,3,6875
25=794000,3,6875
26=425000,3,6875
27=417000,3,6875
28=184750,3,6875
Ik moet alleen nog wel een snellere mediacenter bouwen, deze trekt Film1 HD en andere HD zenders niet lekker :P
  • gjs
gjs
Scoobydoobydoo
CAD-tekenaar schreef op zaterdag 15 mei 2010 @ 22:35:
Zoals ik je al een paar maal heb proberen uit te leggen; wijzigingen aan de client klant (Acamd) lossen jouw verkeerde kaart detectie door de server (NewCS) niet op. Het enige zinnige wat je in smartcard.conf zou kunnen zetten is:
irdeto: [0604] PLAIN
Maar zonder of met de default smartcard.conf werkt het ook...
Ik heb misschien nog wel een tipje, probeer het eens met OSCam daar ben ik zelf van de week ook nog even mee aan het stoeien geweest en dat draait hier nu ook onder Linux. OSCam is opensource in tegenstelling tot NewCS en kan zich als meerdere servers presenteren oa. NewCS en CCcam.
Het is echter wel op linux achtigen gericht maar met CygWin moet het ook onder Windows kunnen draaien (heb ik geen ervaring mee). Zie hier voor een Ziggo configuratie. Je moet hier op zoek naar een Windows binary en CygWin heb je ook nodig. Zie ook hier.
[edit]
Ik zit er nog even over na te denken, het is misschien een losse flodder maar probeer het eens met de volgende ACamd_PMT.txt. Dit zorgt er voor dat de aanvragen van 0604 omgezet worden naar 0600 richting NewCS. Probeer ook eens de plaats van 0604 en 0600 om te wisselen.
# [R] Rename from to
#  CAID Provider CAID Provider Name
R:0604:00000000:0600:00000000:Ziggo
[ Voor 16% gewijzigd door gjs op 16-05-2010 11:17 ]
  • gjs
gjs
Scoobydoobydoo
ThinkPadd schreef op zaterdag 15 mei 2010 @ 23:23:
Je moet vooral denken aan een video kaart die hardwarematig h264 kan encoden decoden.
  • McRubz
gjs schreef op zondag 16 mei 2010 @ 11:01:
Je moet vooral denken aan een video kaart die hardwarematig h264 kan encoden decoden :-).
Ik lees hierboven over mensen die nog zo'n FloppyTV willen aanschaffen, maar is het niet zo dat deze apparaten niet meer werken zodra Ziggo dat beslist (middels CI+)?
  • ThinkPad
Je moet vooral denken aan een video kaart die hardwarematig h264 kan encoden.
Ja ik heb hier ook een Sapphire HD 4550 liggen, daarmee kan je alle 1080p films zonder problemen spelen, maar ik heb nog geen PC waar hij in kan :P
  • gjs
gjs
Scoobydoobydoo
McRubz schreef op zondag 16 mei 2010 @ 14:43:
Die mogelijkheid is altijd aanwezig, maar de Alphacrypt werkt al een paar jaartjes en zo lang Ziggo zich strikt aan de IRDeto protocollen houdt blijft het ook gewoon werken.
Wil je safe zijn koop dan een Anysee, deze werkt met een software cam en zou in theorie dan met wat nieuwe software weer vrolijk verder kunnen draaien als Ziggo toch besluit om iets aan te passen in de codering. Of die software update er dan ook komt of uberhaupt gemaakt kan worden is ook weer een gok. Wil je echt op safe, koop dan een Ziggo PVR.
  • The Zep Man
  • Laatst online: 23:18
The Zep Man
🏴‍☠️Certified Cyber Pirate
gjs schreef op zondag 16 mei 2010 @ 20:37:
Klopt. Een andere 'safe' optie is om geheel afhankelijk te zijn van software met een domme smartcard reader. Hierdoor is wel wat meer creativiteit nodig voor niet open-source Windows MCE-achtige oplossingen.
Ik heb het idee dat Ziggo alleen CI+ heeft geïmplementeerd zodat het eindelijk mogelijk is om op TV's zonder losse decoder digitale TV te kijken. Al hun oude decoders zijn niet compatible met CI+ en ik betwijfel of Ziggo een migratietraject wilt starten, kort nadat digitale televisie zo aanslaat.
Maar ja, dan wordt het nut van dit topic ook wat minder. ;)
RC3 van MediaPortal 1.1 is nu al een klein tijdje uit en lijkt een stuk stabieler. Binnenkort ga ik maar weer eens aan die handleiding werken. ;)
You best start believing in cyberpunk dystopias. You're in one.
The Zep Man schreef op dinsdag 18 mei 2010 @ 10:12:
CI+ staat voor Common Interface Plus. Ofwel een slot in een apparaat waarin digitale TV uitbreidingsmodules gaan met het PCMCIA hardware formaat. De bekendste uitbreidingsmodule is de Conditional Access Modules (CAM) waarmee een apparaat na aankoop geschikt gemaakt kan worden voor het door de digitale TV provider gekozen Conditional Access System (CAS). Bij Ziggo gebruikt men een Irdeto CAS, dus is er een Irdeto CAM nodig en Ziggo heeft gekozen voor een variant van het Common Interface (CI) slot waar extra te activeren beperkingen op mogelijk zijn, namelijk CI+. Voor Ziggo is daarom een Irdeto CI+ CAM nodig en een apparaat met een CI+ slot i.p.v. een CI slot.
Alle door Ziggo "goedgekeurde" kabel ontvangers hebben een geïntegreerde Irdeto softCAM library en geen CI(+) slot. Als zodanig valt er dus helemaal niets CI+ compatible te maken bij Ziggo kabel ontvangers.
  • The Zep Man
The Zep Man
ArChie schreef op dinsdag 18 mei 2010 @ 18:54:
Dit wist ik al. Vergeet niet aan te geven dat voor een apparaat met een CI+ slot ook daadwerkelijk een CI+ CAM nodig heeft omdat Ziggo dit technisch afdwingt (vroeger werkte een CI CAM nog in een CI+ slot).
Dus je onderschrijft mijn punt: de oude decoders ondersteunen geen CI+ (doordat ze geen CI of CI+ slot voor een CAM hebben). Om ze CI+ ondersteuning te geven (dus een CI+ slot en de benodigde CI+ CAM, welke allebei eventueel hardwarematig ingebouwd zijn in losse decoders) zou niet rendabel zijn, tenzij ook de smartcard en de huidige Irdeto-implementatie vervangen worden. Op die manier kan het complete pad van Ziggo uitzending tot smartcard tot TV (HDCP) beveiligd worden (direct via de TV of via de decoder) en zouden alle bestaande oplossingen (PVR's, smartcard readers, DVB-C kaarten met (ingebouwde) softcams) waardeloos worden. Tenminste, totdat de nieuwe standaard is gehackt.
Ziggo heeft ondersteuning genomen voor CI+ en denkt hiermee alvast vooruit. Over vijf jaar hoeven alleen de oude decoders en smartcards vervangen te worden. Tegen die tijd kennen TV's met DVB-C + CI+ meer marktpenetratie, waardoor een overstap zachter aankomt. Het migratietraject kan rekening houden met de verkoop van een nieuw soort decoder over enkele jaren welke voorzien is van (ingebouwde) CI+ welke met de toekomstige standaard kan werken. Op die manier kunnen gebruikers bij de overgang met een decoder van minder dan drie jaar oud niet zeuren dat deze niet meer ondersteund wordt. Gebruikers met oudere decoders krijgen tegen een inruilprijs een nieuwe decoder aangeboden.
[ Voor 17% gewijzigd door The Zep Man op 18-05-2010 21:14 ]
The Zep Man schreef op dinsdag 18 mei 2010 @ 21:07:
Ik denk dat je het verkeerde idee hebt bij CI+. CI+ is niets anders dan een hardware specificatie voor een Common Interface Plus slot, het protocol dat een apparaat met zo'n CI+ slot en de CI+ module via de PCMCIA interface uitwisselen om met elkaar te kunnen communiceren en een specificatie van de mogelijkheden die de digitale TV provider heeft om het CI+ slot en de daarin gestoken CI+ CAM te besturen. CI+ heeft daarom alleen maar betrekking op apparatuur waarin een CI+ slot zit. Het is geen vervanging van Irdeto, Nagravision, Conax of wat voor een CAS dan ook. Sterker nog, voor de genoemde CAS'sen zijn er ondertussen ook al CI+ CAM's in de maak net zoals er nu voor het Irdeto CAS een Irdeto CI+ CAM is.
Waarom zou Ziggo de huidige Irdeto softCAM in de door hen "goedgekeurde" kabel ontvangers gaan vervangen door een hardware CI+ oplossing? Dat heeft toch geen enkele zin aangezien dat zou betekenen dat ze in iedere kabel ontvanger de hoofdprintplaat met smartcard reader moeten vervangen door een exemplaar met CI+ slot. Als Ziggo en Irdeto iets willen wijzigen aan het Irdeto CAS vervangen ze gewoon de Irdeto softCAM in de door Ziggo "goedgekeurde" ontvangers voor een nieuwer exemplaar die het aangepaste Irdeto protocol van de Irdeto CAS begrijpt en daarna vallen andere oplossingen uit. Smartcard vervangen is ook niet nodig aangezien Irdeto juist prat gaat op hun mogelijkheid om de smartcard firmware aan te passen indien nodig.
Daarnaast heeft Ziggo al in de door hen goedgekeurde PVR's diverse extra beperkingen laten inbouwen die vergelijkbaar zijn met de beperkingen die ze via CI+ kunnen afdwingen, dus ook voor die PVR is het niet nodig om opeens een Common Interface Plus slot te gaan inbouwen.
  • CAD-tekenaar
Kunt u misschien ook in de handleiding uitleggen wat te doen wanneer niet altijd direct de juiste caid wordt uitgelezen?
Bij mij leest hij dus niet altijd direct de juiste caid wanneer de pc opgestart wordt! (Soms is het 0600, dan weer 00FA of 0604)
Ik werk volgens uw handleiding met dezelfde geadviseerde hardware/software onder win7 x64 + MediaPortal 1.1.0 RC1 singleseat (in Ziggo gebied 9003). Maar het is me nog steeds niet gelukt dat newcs direct de juiste caid vindt. Na enkele herstarts van newcs.exe lukt het uiteindelijk wel, maar niet altijd gelijk de eerste keer goed.
Ik probeer e.e.a. te begrijpen m.b.t. client en server, maar 100% snappen doe ik het nog niet.
(de handleiding en gebruiker GJS hebben me aardig op weg geholpen.)
  • Rowdy.nl
  • Laatst online: 12-10 14:22
Rowdy.nl
Koekje d'r bij?
Iemand (link naar) een lijst met Phoenix compatible cardreaders?
Ben gisteren een tijdje aan het kloten geweest met met cardreaders op mijn Gentoo Linux bak, maar het vooralsnog niet aan de praat gekregen. En voordat ik heel veel overbodige packages ga installeren om het aan de praat te krijgen is het maybe handig om te weten of ik (een van) deze readers überhaupt wel kan gebruiken... Heb al zitten zoeken, maar ik kan niets vinden, niet via Google, niet via de site van de fabrikanten... :/
Ik heb deze twee readers, maar kan dus nergens vinden of ze Phoenix compatible zijn...[list]
• Towitoko Chipdrive Micro (Let op, PDF! Serieel, Conrad branded)
• Gemplus GemPC Twin USB (USB)
Rowdy.nl - X++ by day. C# by night. I drink coffee in the morning and beer in the evening.
  • gjs
gjs
Scoobydoobydoo
Rowdy.nl schreef op woensdag 19 mei 2010 @ 10:36:
Je moet even kijken wat voor kristal/oscillator er in zit, meestal zijn die (oude) dingen 3.57MHz, ik neem aan dat je hem voor IRdeto kaarten wilt gebruiken ? Dan heb je 6MHz nodig !
Voor die USB variant zal je waarschijnlijk ftdi drivers nodig hebben. Volgens mij hebben een hoop linuxen deze tegenwoordig standaard in huis.
Ik zit er aan de te denken om deze aan te schaffen ter vervanging van mij seriele phoenix readers.
  • Rowdy.nl
Rowdy.nl
Koekje d'r bij?
Net een tijdje met die Towitoko aan de gang geweest, maar daar kom ik dus idd ook niet verder mee. Ik wil 'm inderdaad voor IRdeto kaarten (Ziggo) gaan gebruiken.
Voor de GemPC was ik gisteravond (nacht) al bezig geweest met FTDI, dat stond niet aan in de kernel, maar na ze als modules gecompileerd te hebben kwam ik ook niet veel verder. Nu maar even inbakken in de kernel, maybe dat dat soelaas bied.
Ik krijg nu iig dit, het lijkt er op dat ie dus de reader wel gevonden heeft?
pcscd -d -f
pcscdaemon.c:267:main() pcscd set to foreground with debug send to stderr
pcscdaemon.c:512:main() pcsc-lite 1.5.5 daemon ready.
hotplug_libhal.c:318:get_driver() Looking a driver for VID: 0x08E6, PID: 0x3437
hotplug_libhal.c:366:HPAddDevice() Adding USB device: usb_device_8e6_3437_noserial_if0
readerfactory.c:1024:RFInitializeReader() Attempting startup of Gemplus GemPC Twin 00 00 using /usr/lib64/readers/usb/ifd-ccid.bundle/Contents/Linux/libccid.so
readerfactory.c:877:RFBindFunctions() Loading IFD Handler 3.0
ifdhandler.c:1532:init_driver() Driver version: 1.3.11
ifdhandler.c:1545:init_driver() LogLevel: 0x0003
ifdhandler.c:1565:init_driver() DriverOptions: 0x0000
ifdhandler.c:82:IFDHCreateChannelByName() lun: 0, device: usb:08e6/3437:libhal:/org/freedesktop/Hal/devices/usb_device_8e6_3437_noserial_if0
ccid_usb.c:285:OpenUSBByName() Manufacturer: Ludovic Rousseau (ludovic.rousseau@free.fr)
ccid_usb.c:295:OpenUSBByName() ProductString: Generic CCID driver
ccid_usb.c:301:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later version.
ccid_usb.c:501:OpenUSBByName() Found Vendor/Product: 08E6/3437 (Gemplus GemPC Twin)
ccid_usb.c:503:OpenUSBByName() Using USB bus/device: 003/003
ccid_usb.c:929:get_data_rates() declared: 10753 bps
[..] (dit gaat wel ff door)
ccid_usb.c:929:get_data_rates() declared: 344086 bps
ifdhandler.c:364:IFDHGetCapabilities() tag: 0xFB0, usb:08e6/3437:libhal:/org/freedesktop/Hal/devices/usb_device_8e6_3437_noserial_if0 (lun: 0)
readerfactory.c:249:RFAddReader() Using the pcscd polling thread
ifdhandler.c:364:IFDHGetCapabilities() tag: 0xFAE, usb:08e6/3437:libhal:/org/freedesktop/Hal/devices/usb_device_8e6_3437_noserial_if0 (lun: 0)
ifdhandler.c:418:IFDHGetCapabilities() Reader supports 1 slot(s)
ifdhandler.c:1043:IFDHPowerICC() action: PowerUp, usb:08e6/3437:libhal:/org/freedesktop/Hal/devices/usb_device_8e6_3437_noserial_if0 (lun: 0)
hotplug_libhal.c:318:get_driver() Looking a driver for VID: 0x1D6B, PID: 0x0001
commands.c:225:CmdPowerOn Invalid ATR first byte
ifdhandler.c:1096:IFDHPowerICC() PowerUp failed
eventhandler.c:292:EHStatusHandlerThread() Error powering up card: -2146435050 0x80100016
Ik ben nu even m'n nieuwe kernel aan het installen, kijken hoever ik daarna kom :)
  • eXisTa
Voor de geínsteresseerden, hier de meest complete transponderlijst van Ziggo zone 1111 (brabant-limburg): http://cid-a9817593bc0127...sponderlists/NL^_1111.TPL
Hiermee zou je alle kanalen moet kunnen vinden en geen problemen met NL1-2-3 HD moeten hebben.
  • The Zep Man
The Zep Man
CAD-tekenaar schreef op dinsdag 18 mei 2010 @ 22:05:
Het kan zijn dat je smartcard reader niet goed functioneert. Als NewCS een ander CAID herkent en je stelt deze in in ACamd (in plaats van de correcte), werkt het decoderen dan?
Ik heb geen lijst voor je, maar de in mijn handleiding aangehaalde Smargo Smartreader (USB) werkt perfect onder Windows of Linux met de drivers van FTDI.
[ Voor 16% gewijzigd door The Zep Man op 20-05-2010 09:05 ]
  • Rowdy.nl
Rowdy.nl
Koekje d'r bij?
The Zep Man schreef op donderdag 20 mei 2010 @ 09:01:
I know... :)
Maar als ik readers thuis heb liggen ga ik natuurlijk eerst proberen of ik die aan de praat krijg voordat ik 35 euro ga spenderen aan een nieuwe reader... ;)
gjs schreef op woensdag 19 mei 2010 @ 18:16:
Stuk goedkoper dan de Smargo readers, however, is deze (itt mijn vervelende readers) wel eenvoudig aan de praat te krijgen?
  • grun93
  • Laatst online: 25-06 05:40
Maar het is me nog steeds niet gelukt dat newcs direct de juiste caid vindt. Na enkele herstarts van newcs.exe lukt het uiteindelijk wel, maar niet altijd gelijk de eerste keer goed. k probeer e.e.a. te begrijpen m.b.t. client en server, maar 100% snappen doe ik het nog niet.
Ik snap het ook niet, dat wil zeggen dat ik ook hetzelfde probleem heb, tot maximaal drie keer newcs opstarten, maar dat is maar 1x per dag. Mijn ervaring is dat ie het dan de rest van de dag wel goed doet, en blijft doen. Als het niet erger is... daar kan ik wel mee leven. Eerlijk gezegd begrijp ik niet goed waarom je dit zo reuze belangrijk lijkt te vinden.
  • ThinkPad
Heb je met zo'n smartcard reader geen CAM nodig :?
  • CAD-tekenaar
grun93 schreef op donderdag 20 mei 2010 @ 12:21:
Ik vind het gewoon lastig/irritant dat ik dan elke dag in mijn woonkamer mijn muis+keyboard tevoorschijn moet pakken om newcs af te sluiten en deze weer opnieuw op moet starten. :( Niet erg WAF vriendelijk en niet via de afstandsbediening op te lossen.
Ik wil dat het gewoon in 1x werkt zonder dat MP telkens meldt dat de verbinding met de TV-server verloren is.
[ Voor 4% gewijzigd door CAD-tekenaar op 20-05-2010 12:56 ]
  • Loekie
  • Laatst online: 02-10 15:39
ThinkPadd schreef op donderdag 20 mei 2010 @ 12:43:
Nope, die functie wordt door software vervuld en is heel ruwweg wat zo'n cam met een dedicated processor doet.
specs
  • The Zep Man
The Zep Man
CAD-tekenaar schreef op donderdag 20 mei 2010 @ 12:54:
Wat je kan doen is de tool Smartreader.exe uit dit pakket proberen om de instellingen te wijzigen. Probeer eens de standaardinstellingen. Als deze niet werken, zet dan de 'Mode' op 'Fixed' en 'Frequency' op '6.00'. Ik adviseer om voor elke herconfiguratie de Ziggo smartcard te verwijderen en na elke herconfiguratie de Smargo opnieuw aan te sluiten via USB.
  • gjs
gjs
Scoobydoobydoo
The Zep Man schreef op donderdag 20 mei 2010 @ 15:50:
Dat heb ik een tijdje geleden ook al gezegd @CAD-tekenaar maar dat maakte geen verschil.
  • gjs
gjs
Scoobydoobydoo
Rowdy.nl schreef op donderdag 20 mei 2010 @ 11:13:
Dat weet ik dus ook niet 100% zeker, volgens mij moet hij gewoon werken. FTDI drivers zul je nodig blijven houden ivm de usb. Hij voldoet in ieder geval aan alle specs en dit staat er ook bij: "Suitable as an external card reader for the Dreambox, D-Box, Friz Box and other Linux and Windows applications."
  • CAD-tekenaar
gjs schreef op donderdag 20 mei 2010 @ 20:58:
Inderdaad. Ik heb hier thuis het net even nagekeken. Hij stond al op mode=fixed met freq.=6 Mhz
  • CAD-tekenaar
Je bedoelt de ene regel in cardclient.conf aanpassen?
Dat zal ik even proberen, maar dat zal pas na het weekend worden.
Kan ik je ook PM-en?
  • gjs
gjs
Scoobydoobydoo
CAD-tekenaar schreef op donderdag 20 mei 2010 @ 21:29:
Dat is ook nog een idee, wel een workarround maar als het werkt...
Zet meerdere regels in je cardclient.conf met de verschillende caids er in, hij pakt er dan zelf wel 1 die werkt.
  • ThinkPad
.reg Transponder list voor Ziggo 9700 (Groningen)
Ik vind hiermee 260 kanalen in Windows 7 Mediacenter, klopt dat?
29
30
31
32
33
34
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\DigitalEverywhere\FireDTV\Transponder\Cable]
"473833"="578000, 6875"
"474000"="506000, 6875"
"474167"="554000, 6875"
"481833"="658000, 6875"
"482000"="818000, 6875"
"482167"="730000, 6875"
"489833"="810000, 6875"
"490000"="682000, 6875"
"490167"="762000, 6875"
"497833"="618000, 6875"
"498000"="610000, 6875"
"498167"="738000, 6875"
"505833"="482000, 6875"
"506000"="385000, 6875"
"506167"="393000, 6875"
"513833"="401000, 6875"
"514000"="369000, 6875"
"514167"="626000, 6875"
"521833"="377000, 6875"
"522000"="754000, 6875"
"522167"="642000, 6875"
"529833"="586000, 6875"
"530000"="650000, 6875"
"530167"="409000, 6875"
"537833"="794000, 6875"
"538000"="425000, 6875"
"538167"="417000, 6875"
"545833"="184750, 6875"
Oja nog een vraagje, ik gebruik mijn tuner in Windows 7 mediacenter.
Maar nu staan de radiozenders ook in de TV gids.
Als ik ga naar Muziek > Radio dan zegt hij dat ik een radiotuner moet aanschaffen 8)7
Kan ik de radiozenders daar niet op de een of andere manier krijgen?
Ik heb ook al even op internet gekeken maar kon niet echt een oplossing vinden. Of ben ik de enige die dit heeft?
[ Voor 18% gewijzigd door ThinkPad op 22-05-2010 21:02 ]
  • ThaHandy
  • Laatst online: 16:39
ThaHandy
Discovery Channel
Nou nou, alles werkt, na een uur of 8 kloten met MP en 2 dvb-c kaarten icm smartreader én een (2e) ziggo kaartje, werkt et zoals het bijna moet :+
Issues waar ik tegenaan ben gelopen(zepman's howto gebruikt):
* Newcs die de kaart niet vind of mij een caid 0000 geeft ipv 0604 die ik moet hebben (moet nu standaard newcs 3x starten (van niets, 0000 naar 0604)
* Uren "verkloot" aan die dual tuner BSOD's (er was dus een fix voor, met dank aan zepman, link je em ook in de howto? :z ). het was voor mij tot die tijd de ene tuner OF de andere tuner en zo nu en dan een BSOD (mtsbda) Na de "dual tuner" driver, MP opnieuw installeren en ACamd/MDAPI configgen, dat was 15 min werk :9
* Daarna nog een tijdje aan het prutsen geweest met dual tuner's en de dubblele naam in de config. Ik heb nl. de "Een extra TV kaart installeren en configureren" ff niet gezien :P
verdere dingen die tot nu toe niet lekker lopen/werken:
* zappen van HD kanalen is buggy/traag (in TVserver schakelt i netjes over binnen 2sec)
* MP Web Interface werkt nog niet
* EPG TV gids
tot morgen \o
  • gjs
gjs
Scoobydoobydoo
Ik heb zojuist even een nieuwe Logo file gemaakt voor MediaPortal en Ziggo Casema/Multikabel gebied.
Hij is gebasseerd op de transparent Dutch TV and Radio logos addon die te vinden is op de MediaPortal site.
Ik heb her en der wat namen aangepast zodat alle Logos werken in het Casema/Multikabel gebied.
Ik mis alleen een echt logo voor SBS 6 HD en Veronica HD/Disney XD daar heb ik dus het SD logo voor in de plaats gezet.
Pak de zip file uit in "C:\ProgramData\Team MediaPortal\MediaPortal\Thumbs\tv".
[edit] nu met custom SBS 6 HD en Veronica HD/Disney XD logos.
[ Voor 4% gewijzigd door gjs op 23-05-2010 13:07 ]
  • Cybergamer
  • Laatst online: 20-06 15:26
Cybergamer
Wanna Play a Game?
Hoi allemaal! Na heel veel gelezen te hebben over digitale kabel op PC op verschillende sites (en dit topic + vorige delen doorgespit te hebben) ben ik er eindelijk over uit!
Ik volg het project van The Zep Man (Bedankt!), en heb nu een Cinergy C PCI HD kaart op de kop getikt voor weinig. De Ziggo kaart is ook gekocht en ik heb mijn oog op deze smartmouse/smartreader laten vallen. (met dank aan gjs voor de originele link!)
De prijs is mooi, en volgens mijn research werkt deze net zo goed als de Smargo. Mijn enige vraag is: Op welke voltage dat ding zou moeten draaien? 3V of 5V? Voor de rest lijkt het mij vrij duidelijk hoe ik die kaart moet instellen, behalve het voltage.
cybergamers.nl
babyxl schreef op maandag 24 mei 2010 @ 01:40:
De smargo draait meen ik op 5 volt. Maar er zit een switch op dus kun je toch gewoon beide proberen?
  • gjs
gjs
Scoobydoobydoo
De standaard Phoenix seriele readers die ik heb zijn allemaal 5V. Ze krijgen hun voeding via USB of de PS/2 poort en er zitten verder geen spannings regulators oid op. Ik durf dus wel met zekerheid te zeggen 5V !
  • Cybergamer
Cybergamer
Wanna Play a Game?
Toppie!
Nou, ik heb er een besteld dus we zullen wel zien hoe die het doet! :)
Op het moment ben ik nog aan het rommelen met een analoge kaart (just for kicks), maar daar het ik soms nog wel wat problemen mee met MP (geen signaal ed. - waardoor ik de TV Service moet herstarten). Ik hoop dat dat probleem over zal zijn met digitale TV.
Heeft iemand nog ervaring met DVBLink? Dat ziet er ook erg mooi uit namelijk...
cybergamers.nl
DVBlink werkt fantastisch!! Heb het zelf ook draaien. Het is alleen noodzakelijk als je media center van windows wil gebruiken. Voor media portal heb je het niet nodig.
  • Promy
Misschien een heel idiote vraag, maar ik kan het nergens terugvinden...
Als ik een dvb-C kaart in m'n computer steek, kan ik dan naast de digitale kanalen van telenet (de free-to-air), ook de analoge bekijken, of heb ik hier een aparte tuner voor nodig? :?
  • Nielson
  • Laatst online: 00:23
Bijna altijd ben je een aparte tuner nodig. Er bestaan wel hybrid tuners maar dit is meestal de combinatie dvb-t/analoog, met dvb-c ken ik ze zo niet.
  • CAD-tekenaar
Helaas werkt je voorstel niet.
Ik heb 1 regel in bestand "C:\Program Files (x86)\Team MediaPortal\MediaPortal TV Server\MDPlugins\Cinergy C PCI Digital Capture0\cardclient.conf" gewijzigd.
Onderstaande regel:
newcamd:127.0.0.1:15050:1/0604/ffff:gebruiker1:wachtwoord1:0102030405060708090A0B0C0D0E
heb ik gewijzigd in:
newcamd:127.0.0.1:15050:1/00FA,0600,0604/ffff:gebruiker1:wachtwoord1:0102030405060708090A0B0C0D0E
Hiermee zou hij dus meerdere caid kunnen herkennen, maar helaas. :(
Pas na enkele keren herstarten van newcs.exe wordt caid 0604 herkent en pas dan werkt het weer.
Kortom: dezelfde problemen als voorheen.
Heb je nog een andere oplossing?
  • Nielson
Ergens een lowpower linux bakje neerzetten er daar newcs of oscam in native vorm op draaien. Op die manier heb je die herstartfase waarbij het mis kan gaan niet meer, en best kans dat het probleem veroorzaakt wordt doordat de windows port niet helemaal fijn is of omdat dit een oudere versie is.
Is er niemand die mijn oplossing voor het newcs standby probleem heeft geprobeerd?? Ik draai al 2 weken lang zonder problemen. Heb het nu zelfs voor mekaar dat newcs 3 maal herstart wordt in zijn standaard dos scherm zonder de newcsgui te gebruiken.
  • CAD-tekenaar
Nielson schreef op dinsdag 25 mei 2010 @ 22:40:
Een aparte server-pc maken ga ik niet doen. ik werk nu met 1 pc (MP singleseat-configuratie met tv-server/client)
Wat bedoel je met windows port niet helemaal fijn cq. oudere versie?
(ik heb in sept. 2009 deze pc nieuw gekocht.)
  • grun93
Verwijderd schreef op dinsdag 25 mei 2010 @ 17:36:
Ik heb een tijdje met Media Center gewerkt (icm Digitenne) toen ik enkele maanden geleden Win7 64-bit Ultimate installeerde, en ik vind het een prettige viewer.
Kun je iets meer over de installatie van DVBlink vertellen, want ik wil dat ook wel eens proberen. Uitgaande van Zep Man's manual? Ik heb de downloadlink naar de trial versie gevonden, de manual van DVBlink ook. Dat de registratie een paar euro kost maakt me niks uit. Gewoon de Server van MP vervangen door die van DVBlink Server en DVBlink Source? Zijn er speciale dingetjes, tips en trucs waar ik op moet letten?
De configuratie van Media Center zelf kom ik wel uit, het gaat me er even om hoe DVBlink te combineren met NewCS en Acam enzo.
Bedankt alvast.
Newcs kun je gewoon instellen als in de handleiding van zepman. In dvblink moet je de acamd plugin zetten. Alleen de acamd ini file en de cardclient file. Het aanpassen van de cardclient file kun je ook doen volgens de handleiding van zepman. Deze 2 files plaats je in de plugin directory van iedere tv sourche. Deze plugin map kun je vinden onder dvblink/tvsourche/plugin als ik me niet vergis. In de plugin dir gewoon die 2 bestanden zetten. Zorg er wel voor dat iedere tvsourche een eigen login en wachtword krijgt in de cardclient file!! Ook dit staat ik de handleiding van zepman.
DVBlink i.c.m Media Center:
Volg de handleiding van dvblink precies!! Als je alles goed doet zul je geen problemen hebben.
DVBlink i.c.m Mediaportal:
Wederom de handleiding volgen alleen het laatste gedeelte van Media Center niet. DVBlink maakt 4 virtuele tuners aan in apparaatbeheer. Deze 4 tuners zou je dan bij Media Portal moeten kunnen selecteren. Hoe je de zenders dan moet zoeken/toekennen in Media Portal weet ik niet. Maar zoals ik al eerder zei, als je Media Portal gaat gebruiken heb je DVBlink eigenlijk niet nodig.
Op de site van DVBlogic staat ook nergens dat het media portal ondersteunt. Het zal best wel aan de gang te krijgen zijn maar ik denk dat je dan nog wel even bezig bent. Misschien dat het forum van dvblogic je daar meer hulp bij kan bieden.
Persoonlijk zou ik dvblink gaan combineren met media center. Ik heb zelf ook die combinatie lopen zonder problemen. Mijn vrouw kijkt het meeste tv dus ik moet iets stabiels hebben!!! Heb het nu een maand draaien.
Succes
[ Voor 16% gewijzigd door Verwijderd op 26-05-2010 17:26 ]
  • gjs
gjs
Scoobydoobydoo
CAD-tekenaar schreef op dinsdag 25 mei 2010 @ 23:36:
Newcs onder Windows is een port van de Linux versie echter zit de Linux versie op 1.67RC1, de Windows versie is 1.65 en wordt volgens mij ook niet meer ontwikkeld.
  • Cybergamer
Cybergamer
Wanna Play a Game?
gjs schreef op woensdag 26 mei 2010 @ 17:45:
Is het dan niet een idee om een Virtuele server op te zetten, puur voor NewCS?
Ik zelf wil nl. MP of DVBLink op een server hebben draaien, en als daar een kleine virtuele linux distro in VM op mee draait vind ik het best.
cybergamers.nl
  • grun93
Verwijderd schreef op woensdag 26 mei 2010 @ 17:21:
Succes
Bedankt voor de snelle reply en tips, ik ga er binnenkort mee aan de gang.
babyxl schreef op woensdag 26 mei 2010 @ 18:16:
Zodra je MP of DVBlink op een server gaat draaien die topch 24/7 aan staat kun je newcs windows versie gewoon laten draaien. Newcs heeft aleen problemen met de kaart inlezen als de pc uit de standby komt. Als de pc dus gewoon aan blijft staan zul je nergens last van hebben
  • gjs
gjs
Scoobydoobydoo
Ik heb voor alle mensen met Newcs problemen onder Windows een pakketje gemaakt gebasseerd op OSCam.
In deze zip file vind je een oscam.exe (laatste build) config files en de benodigde Cygwin componenten.
Ik moet er wel bij vermelden dat ik hem niet getest heb onder Windows met echte reader, op Linux wel. Ik heb het wel getest met een Newcamd reader richting mijn Linux Newcs.
Volgens mij moet het wel werken, wel even de juiste com poort instellen in de oscam.server file. Verder heb ik dezelfde poort (15050), des-key en gebruikers aangehouden (gebruiker1,wachtwoord1) als The Zep Man in zijn Newcs config gebruikt.
In principe zou je dus OSCam zo kunnen gaan draaien ipv Newcs.
Laat maar even horen wat de resultaten zijn.
Ik zal het eens proberen vanavond maar ik denk niet dat het probleem bij Newcs ligt.
We zeggen wel altijd dat newcs 3 maal moet herstarten voordat het werkt maar dat komt volgens mij door de cardreader. Deze heeft het probleem om uit standby te komen. Ik verwacht dus dat oscam precies hetzelfde probleem gaat geven.
  • Cybergamer
Cybergamer
Wanna Play a Game?
Verwijderd schreef op woensdag 26 mei 2010 @ 19:13:
Ahh, ok.. Daar maakte ik mij dus een beetje zorgen over :) Met herstarten en evt. uit/aan ook geen problemen dan? Alleen standby dus? (Want dat staat mijn server toch nooit).
cybergamers.nl
babyxl schreef op woensdag 26 mei 2010 @ 22:24:
Een Reboot weet ik niet zeker. Een cold boot werkt ie wel in 1 keer. Maar als je de pc eens in de week automatische laat opstarten dan kun je mijn batch bestanden gebruiken om newcs altijd 3 maal te laten opstarten. Na 3 keer is het altijd goed.
  • Cybergamer
Cybergamer
Wanna Play a Game?
Verwijderd schreef op woensdag 26 mei 2010 @ 22:26:
Kun je een link sturen/plaatsen van dat bestand? (Ik wilde je een PM sturen, maar zie geen optie daarvoor?)
cybergamers.nl
Wat voor een windows versie staat op je server?
  • Cybergamer
Cybergamer
Wanna Play a Game?
Windows 2008 R2 (Windows Home Server "Vail" Public Beta).
En ik moet zeggen, dat ding is super en werkt perfect!
cybergamers.nl
babyxl schreef op woensdag 26 mei 2010 @ 22:51:
Probleem is dat een batch bestand op verschillende versies van windows anders werkt. Ik heb zelf windows 7.
Je moet 2 batch bestanden aanmaken.
start.cmd moet het volgende bevatten:
start /min c:\newcs\win32\run.cmd
PING 1.1.1.1 -n 5 -w 500 >NUL
taskkill /f /im newcs.exe
PING 1.1.1.1 -n 2 -w 200 >NUL
run.cmd moet het volgende bevatten:
c:\newcs\win32\newcs.exe
Zorg dat newcs ook in deze directories staat of wijzig de verwijzingen in je batch bestand naar de plek waar newcs dan wel staat. Wat ook belangrijk is dat beide batch bestanden in dezelfde map staan waar newcs.exe staat!!
Als alles werkt dat heb je in je taakbalk een setje van 3 dos scherpjes alle 3 geminimaliseerd. 2 schermen zijn gewone dos schermen waarin newcs in is beeindigd en 1 scherm bevat newcs actief.
En kijk even of je het bestand taskkill.exe op je schijf hebt stan. Zit standaard in windows 7. Zit volgens mij in windows/system32. Zonder dit bestand werkt het batch bestand niet.
  • Rubke
  • Laatst online: 13-10 11:37
misschien al vele malen langs gekomen
maar stel dat CI+ ook in werking gesteld wordt
in hoeverre werkt dan bv deze kaart nog
Terratec Cinergy HTC USB XS HD
CI+ is al in werkig. Maar dit heet alleen invloed op het codeer gedeelte. Je zult ten alle tijden gewoon signaal ontvangen. De codeer methode die zepman gebruikt heet softcam. Hier komt geen CI of CI+ aan te pas. Op het moment dat je een CI cam module in een CI+ slot steekt zal er niet gecodeerd worden. Je zult dan een CI+ cam module (die van ziggo) moeten gebruiken. Maar zoals ik al zei een softcam werkt heel anders.
  • eXisTa
Geweldig! Nieuwe zoekactie naar kanalen levert sinds gisteren HD-kanalen bij Ziggo (1111).
SBS6HD, Veronica HD en NET5HD :D
  • Rubke
Verwijderd schreef op donderdag 27 mei 2010 @ 13:36:
thnx voor de snelle reactie, als ik even resumeeer... stel voor het wordt allemaal met CI+ gecodeerd zal er dus iets aan de softcam gewijzigd moeten worden? en niet aan de hardware, die zal het signaal wel blijven ontvangen toch?
  • ThinkPad
eXisTa schreef op donderdag 27 mei 2010 @ 14:00:
Maar daar moet je een abbonement op hebben toch? Ik ontvang ze hier in Ziggo 9700 ook, maar kan ze niet bekijken.
  • Nielson
Rubke schreef op donderdag 27 mei 2010 @ 15:22:
Deze vraag is al vaker langsgekomen en ook beantwoord, zie bv hier, hier en hier.
  • Rowdy.nl
Rowdy.nl
Koekje d'r bij?
Voor de liefhebber, ik heb een script geschreven waarmee je NewCS als deamon kunt draaien op je Gentoo Linux bak. Dit werkt waarschijnlijk met minimale aanpassingen ook op andere linux systemen, maar dat kun je zelf aanpassen. ;)
Als eerste twee scripts, deze moeten aangemaakt worden in de init.d en de conf.d mappen. Ook moet het init script uitvoerbaar gemaakt worden.
# touch /etc/init.d/newcs
# touch /etc/conf.d/newcs
# chmod a+x /etc/init.d/newcs
#!/sbin/runscript
# Copyright 2010 Rowdy.nl
# Distributed under the terms of the GNU General Public License v2
# Custom NewCS Initscript
depend() {
  need net
start() {
  ebegin "Starting NewCS"
  start-stop-daemon --start -c ${NEWCS_USER} -g ${NEWCS_GROUP} --exec ${NEWCS_EXECUTABLE} -- -c ${NEWCS_CONFIGFILE} ${NEWCS_OPTS} &> /dev/null
  eend $?
stop() {
  ebegin "Stopping NewCS"
  start-stop-daemon --stop --exec ${NEWCS_EXECUTABLE} &> /dev/null
  eend $?
# /etc/conf.d/newcs
# Config file for newcs init script
# Which user to run newcs as, you should change this.
NEWCS_USER="newcs"
NEWCS_GROUP="users"
# Provide the path and name of the executable.
# This is done so you can choose your own newcs architecture,
# i.e. newcs.x86 for x86 based systems, or newcs.x86_64 for amd64 based systems
NEWCS_EXECUTABLE="/etc/newcs/newcs.x86_64"
# Make sure the user specified above can read this file.
NEWCS_CONFIGFILE="/etc/newcs.xml"
# Specify some other cli-options if you want.
# ie nofork option, prevents the core dumps: -nd
NEWCS_OPTS=""
Je moet wel even de config file aanpassen naar jouw installatie, het path waar je je executable en configfile hebt staan bijvoorbeeld. Ik heb zelf ervoor gekozen om de service niet als root te laten draaien maar onder een eigen gebruikersaccount.
# groupadd newcs
# useradd -G users,wheel,newcs newcs
Nu kun je de service gebruiken net als je elke andere service gebruikt binnen Gentoo.
# /etc/init.d/newcs start
 * Starting NewCS ...                                                             [ ok ]
# /etc/init.d/newcs stop
 * Stopping NewCS ...                                                             [ ok ]
En je kunt 'm toevoegen aan je runlevels, zodat ie altijd start bij het booten van je server... :)
# rc-update add newcs default
 * service newcs added to runlevel default
Vragen/opmerkingen? Just shoot... :)
  • eXisTa
ThinkPadd schreef op donderdag 27 mei 2010 @ 15:28:
Schijnbaar wel inderdaad maar ik heb die een half jaar gratis op proef gekregen van Ziggo.
Gewoon telefonische verkoopdesk bellen.
  • TheVMaster
  • Laatst online: 22:34
TheVMaster
Moderator WOS
eXisTa schreef op vrijdag 28 mei 2010 @ 15:20:
En wat voor verhaal moet je dan ophangeN? :+
Zijn er nog mensen naar de TV-op-je-pc Consumentensessies geweest van Microsoft en de Groene knop?
DiscVault - Beheer je fysieke schijvencollectie | Beschikbaar als Self-Hosted, iOS (ook TestFlight) en Android (beta).
TheVMaster schreef op vrijdag 28 mei 2010 @ 15:24:
Jo ben ik geweest,
voor de ervaren gebruiker niet echt interessant. Er wordt veel tijd besteed aan het delen van je media bestanden op je netwerk. Dat je die bestanden ook met dlna apparaten kan openen. Een stukje homeserver komt ook aan bod. Het daadwerkelijk live tv kijken en hoe je dat precies voor mekaar krijgt hoe je niet echt te verwachten. Ook Hauppage is aanwezig en heeft wat producten bij zich. Ze hebben momenteel maar 1 product voor ziggo. Is eigenlijk hetzelfde als dat firedtv heeft gemaakt alleen dan de usb versie. Kosten klauwen vol geld aangezien je een cam module moet kopen. 2 tuners is dus ook 2 cam modules.
Hoi,
Ik heb sinds gister een AnySee E30TC
Ik heb de laatste drivers geinstalleerd. 1.1.9h
Alles verder volgens de tutorial.
Nu start ik AnySee viewer op en dan zoek ik naar kanalen en dan kan hij er geen vinden. Bijna overal staat Geen Signaal.
De paar die wel een naam hebben zijn film1 enz maar daar heb ik geen abbo op. Dus daar heb ik ook niets aan.
Als ik Windows Media Center opstart, dan en alles heb ingesteld vindt hij 258 kanalen, wat goed is, maar ik kan alleen Nederland 1 HD bekijken, de rest doet het niet, niet eens Ned 2, 3 enz...
Ik heb werkelijk geen idee meer wat ik kan doen.
Help me alsjeblieft ik ben al 2 dagen non stop hiermee bezig.
BVD
Er vanuitgaande dat je ziggo hebt,
Als je alleen Ned 1 kan zien en de rest niet werkt het coderen niet. Smartcard is geactiveerd?
[ Voor 16% gewijzigd door Verwijderd op 28-05-2010 18:53 ]
Verwijderd schreef op vrijdag 28 mei 2010 @ 18:52:
Ja, ik heb 3000 keer dat nummer gebeld. Ik heb 500 keer op internet geactiveerd en hij zegt op internet steeds dat hij geactiveerd is.
Wel vreemd waarom alleen nederland 1? en niet eens nederland 2, 3?
dat komt omdat nederland 1 ongecodeerd doorkomt. nederland 2 en 3 zijn gecodeerd. Probeer maar eens het ziggo kanaal. Deze is ook niet gecodeerd en zal het ook doen. Heb je de smartcard al eens in een normale ontvanger geduwd?
Verwijderd schreef op vrijdag 28 mei 2010 @ 19:00:
Ik heb helaas geen normale ontvanger, en ik ken ook niemand met zo'n ontvanger.
dus je hebt een losse smartcard aangeschafd bij ziggo? Tijdens het activeren tune je in op een kanaal neem ik aan?
Tja ik weet niet precies.
De laatste keer deed ik eerst bellen. Nummers doorgeven. Kaart in de E30 en wachten maar.
Met anysee viewer krijg ik niet eens Nederland 1 in de lijst.
Ik had een nieuwe ziggo kaart gekocht bij mijn anysee.
[ Voor 13% gewijzigd door Verwijderd op 28-05-2010 19:12 ]
  • Nielson
Verwijderd schreef op vrijdag 28 mei 2010 @ 18:19:
Hoi,
Weet je zeker dat dat de laatste driver is?
/edit: Laat maar, keek niet goed. Fijne site trouwens :)
[ Voor 22% gewijzigd door Nielson op 28-05-2010 19:16 ]
Nielson schreef op vrijdag 28 mei 2010 @ 19:13:
Weet je zeker dat dat de laatste driver is? Als ik op de Anysee site kijk staat daar 2.1.0 beta7
die heb ik geprobeerd later weer terug gegaan naar 1.1.6 toen naar 1.1.9. Ik had namelijk gelezen dat daar die problemen niet bij waren. Schijnbaar dus toch.
  • ThaHandy
ThaHandy
Discovery Channel
Ik kreeg ook een e30 op alles behalve ned1 op mijn "nieuwe" (2e) @home kaart die ik 2 jaar geleden heb gekocht.
Ik most em even in de decoder houden en heb nu tijdelijk alle kanalen.
Nu hopen dat het zo blijft zinsdien ik em niet meer in de decoder heb gehad en nu em in de smartreader gebruik. :9
over activatie/update:
Iemand die weet of ook de activatie van de kanalen die ik (niet meer)mag kijken, ook vie de smartreader kan gaan? of werkt dat alleen via een officiële decoder?
pbeumer2001 & Nielson bedankt voor jullie tijd en gedachten.
Ik heb de tuner 3 uur lang aan laten staan en onder tussen maar andere dingen gaan doen. Toen ik terug kwam, alles opnieuw geinstalleerd, incl windows 7 en alle drivers. Opeens deed alles het. Ik heb werkelijk géén idee hoe dat komt, want ik heb alles precies hetzelfde gedaan.
Nu geniet ik in ieder geval van de tv op de pc!
  • gjs
gjs
Scoobydoobydoo
ThaHandy schreef op vrijdag 28 mei 2010 @ 20:43:
In principe zou dat gewoon moeten kunnen, het ligt er echter aan of er filtering op de EMM pakketjes wordt toegepast, bij Newcs kan je dit bv instellen met de opties: blocksa, blockua, blockga, blockc0.
Ik neem aan dat Anysee zelf geen filtering doet.
[ Voor 3% gewijzigd door gjs op 29-05-2010 11:02 ]
  • CAD-tekenaar
Verwijderd schreef op woensdag 26 mei 2010 @ 23:00:
Ik was helemaal je tip vergeten en heb 'm nu geprobeerd.
Power Triggers heb ik nu geinstalleerd en geconfigureerd.
run.cmd in map start - alle programma's - opstarten
kill.cmd (suspend action power triggers)
start.cmd (resume action power triggers)
taskkill.exe staat in c:\windows\system32 en c:\windows\syswow64
Ik gebruik window 7 NL x64 met UAC aan.
Maar ik heb 2 problemen:
1) Power triggers wordt niet bij het opstaren van de pc gestart. Is dit nodig?
2) Ik krijg een foutmelding: "proces newcs.exe is niet gevonden"
Wat moet ik doen om Power Triggers te laten werken?
  • ThaHandy
ThaHandy
Discovery Channel
gjs schreef op zaterdag 29 mei 2010 @ 11:01:
enige info over sa ua ga en c0? ik kan er niets over vinden
  • kwafo
  • Laatst online: 06-12-2025
Hallo
Ben een tijdje bezig vandaag met de zepman post
heb zelfde kaart, cincergy etc etc.
alles doorlopen en unscrambled zender (bijv ned1) doet het,
ned2 krijg ik niet aan de praat, wat opvalt:
in NewCS als ik ned2 klik om te kijken verschijnt er:
Newcamd ECM gebruiker1 (NOT OK) 0604 .......
Ik neem dat daar de fout zit waardoor ik ned2 niet kan kijken,
wat mij ook nog opviel is dat er ook staat: - starting telnet on port 0 (moet dat niet een normale poort zijn?)
Iemand ideeen of hebben jullie meer informatie nodig?
[ Voor 11% gewijzigd door kwafo op 29-05-2010 17:10 ]
  • gjs
gjs
Scoobydoobydoo
kwafo schreef op zaterdag 29 mei 2010 @ 16:02:
starting telnet on port 0, is ok, dat is het probleem niet.
Werkt de smartcard wel in een normale decoder ? Weet je zeker dat je ook een caid 0604 kaart hetb ?
Post eens een stukje newcs log wat begint met [ ATR ] Historical bytes: I R D E T O A C S V 5 . x en eindigt met: Newcamd thread Server started on port 15050
  • kwafo
Smartcard is volgens ziggo gerigistreerd en geactiveerd, zo ook volgens "mijn ziggo" op internet, ik heb geen normale decoder tot mijn beschikking.
Ik heb de instructies van zepman opgevolgd en daar kon ik die caid 0604 handhaven, ik weet niet precies waar die newcs log te vinden is, en ik ben deze week ook weer van mijn ouderlijk huis weg dus moet ik weer een weekje wachten voordat ik er verder aan kan werken.
Digitale televisie is namelijk voor mijn ouders en zusje thuis (ik woon zelf op kamers)
http://public.blu.livefil...qg/NewCS%20in%20actie.png
Deze komt van zepman, en de mijne is identiek op een paar dingen na:
Telnet poort (maar dat maakte niets uit)
irdeto acs is bij mij 5.7
  • gjs
gjs
Scoobydoobydoo
kwafo schreef op zondag 30 mei 2010 @ 00:10:
Wat getoond wordt in dat plaatje dat is de newcs log. Dat nummer achter IRdeto ACS is het kaart versie nummer, dat kan verschillen. Ik vraag naar het caid gebeuren omdat er ook kaarten uit het voorheen Casema gebied bestaan met een caid 0602, dit zijn oudere kaarten.
Ik denk dat je de kaart even moet activeren in een echte Ziggo decoder, via Acamd/Newcs lukt dat (meestal) niet.
Acamd stopt met het sturen van EMM berichten naar de kaart (en die heb je juist nodig om hem te activeren) als hij geen valide ECM berichten krijgt, althans dat is mijn ervaring. Zo lang de kaart niet geactiveerd is krijg je geen valide ECM berichten, dus zit je in een loop waar je niet uitkomt.
  • kwafo
oke, opzoek naar iemand met zon decoder in dorp van mn ouders , misschien weet ik wel iemand
ik zal volgende week mijn progressie laten weten (tja moet een beetje haasten nu het wk dichterbij komt, dat wil mijn vader perse op HD zien XD)
  • CAD-tekenaar
@pbeumer2001:
Ik ben er achter gekomen dat de foutmelding: "proces newcs.exe is niet gevonden" veroorzaakt doordat newcs.exe niet opgestart wordt door run.cmd
bestand start.cmd begint met:
start /min "D:\MediaPortal_setup\newcs-1.65\win32\run.cmd"
enzovoorts....
bestand run.cmd (in map D:\MediaPortal_setup\newcs-1.65\win32) bevat:
D:\MediaPortal_setup\newcs-1.65\win32\newcs.exe
Alle bestanden staan in map "D:\MediaPortal_setup\newcs-1.65\win32" inclusief newcs.exe
Kan jij uitleggen wat er fout gaat waarom newcs.exe niet opgestart wordt?
(ik werkt met win7 x64 NL met UAC aan)
@CAD,
power triggers kun je mee laten opstarten door een snelkoppeling in start/alle programma`s/opstarten te plaatsen.
Wat gebeurt er als je run.cmd gewoon laat draaien door er dubbel op te klikken? Je kunt als 2e regel in run.cmd pause zetten. Gewoon door het woord pause neer te zetten. Dan blijft het dos venster open en zie je wat de foutmelding is en waarom hij niet opstart.
Ik heb zelf windows 7 32 bit volgens mij zonder uac
  • CAD-tekenaar
Verwijderd schreef op zondag 30 mei 2010 @ 12:48:
@CAD,
Dubbelklikken op run.cmd werkt gewoon zoals het hoort. Bestand newcs.exe wordt opgestart. :)
Hetzelfde lukt ook via de opdrachtprompt, maar om hetzelfde te laten doen via een bestand zoals start.cmd werkt weer niet. :( (newcs.exe wordt gewoon niet gestart)
Heb je enig idee waarom dit niet werkt?
Als je nu pause even laat staan in run.cmd ook een pause toevoegd na de 1e regel van start.cmd en in start.cmd voor alle regels behalve de 1e en pause het volgende te zetten.
rem(spatie)
nu wordt aleen de 1e regel in start.cmd uitgevoerd en daarna het batch op pause gezet.
Wordt het run.cmd bestand nu wel uitgevoerd?
  • alt-92
alt-92
ye olde farte
De Scheduled Task waarmee je je batchfiles aftrapt Elevated rechten geven. Je UAC zit nu in de weg namelijk.
Hallo, mijn naam is Robert en nieuw hier op het forum.
Ik ben van plan een media center in de woonkamer te gaan zetten met een tv-tuner dvb-c omdat onze kabelaanbieder in oktober over gaat op alleen digitaal signaal.
Omdat de harddisk recorder dan ook niet meer gebruikt kan worden bem ik op zoek naar een dual tuner, zodat ik kan kijken naar het ene programma en een tweede kan opnemen.
Zijn er eigenlijk dual tuners? en zo ja welke?
ben zeer benieuwd naar de antwoorden, alvast bedankt
Pagina: 1 ... 13 ... 19 Laatste
