Het ATi HD4XXX Serie Ervaringen Topic - Deel 8 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 4 ... 8 Laatste
  • 52.316 views
Alle 102 producten
  • Alfa Novanta
  • Laatst online: 14:34
Alfa Novanta
VRRROOOAAARRRP
Yes, hij is uit!!! *O*
http://www.sapphiretech.c...product/?psn=0001&pid=259
Afbeeldingslocatie: http://www.sapphiretech.com/images/product/gallery/0259/259_20090526_483.jpg
Afbeeldingslocatie: http://www.sapphiretech.com/images/product/gallery/0259/259_20090526_6824.jpg
Afbeeldingslocatie: http://www.sapphiretech.com/images/product/gallery/0259/259_20090526_7644.jpg
Specifications
  • I/O Output: Display Port+HDMI+DL-DVI+VGA
  • Core Clock: 870 MHz
  • Memory Clock: 1050 MHz, 4.2 Gbps
  • PCI Express 2.0 x16 bus interface
  • 1024MB /256bit GDDR5 memory interface
  • Dual Slot Vapor-X Cooler
  • HDMI compliant via dongle
  • 7.1 Audio Channel Support
  • Microsoft® DirectX® 10.1 support
  • Shader Model 4.1 support
Features
  • Factory overclocked at 870 MHz.
  • 1 GB of GDDR5 memory
  • Sapphire Patent Pending Black Diamond Choke
  • Quite and Powerful Dual Slot Vapor-Chamber Cooler, Under 20 dbA in 2D Operation, under 30 DbA in 3D Operation before 85 degree ℃.
  • Solid Capacitors
  • DirectX® 10.1 support
  • 800 stream processing units
  • 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
  • Quad mode ATI CrossFireX™ multi-GPU support for highly scalable performance1
  • PCI Express® 2.0 support
  • Dynamic geometry acceleration
  • Game physics processing capability
  • ATI Avivo™ HD video and display technology2
    * Unified Video Decoder 2 (UVD 2) for Blu-ray™ and HD Video
    * Accelerated Video Transcoding (AVT)
    * DVD Upscaling
    * Dynamic Contrast
    * Built-in HDMI with 7.1 surround sound support
  • Dynamic power management with ATI PowerPlay™ technology2
  • ATI Stream technology2
en hier nog enige reviews ...
http://www.pureoverclock.com/article756.html
http://www.amdzone.com/in...re-4890-vapor-x?showall=1
http://www.elitebastards....ask=view&id=720&Itemid=27
Afbeeldingslocatie: http://www.pureoverclock.com/images/review/video_cards/sapphire_4890/sapphire_4890_summary.jpg
Volgens www.amdzone.com is een overclock mogelijk tot 990 MHz voor de core en 1150 MHz voor het geheugen. :9
E.e.a. wordt compleet geleverd .. incl. HDMI naar DVI-I adapter!
Afbeeldingslocatie: http://www.pureoverclock.com/images/review/video_cards/sapphire_4890/sapphire_4890_4.jpg
Leuk spul dacht ik zo. Wordt dat wachten toch nog beloond.
Meteen maar even aangemeld voor de pricewatch! :)
[ Voor 8% gewijzigd door Alfa Novanta op 31-05-2009 10:34 ]
  • Cobiwan
Even een vraagje... Ik heb mijn Sapphire Radeon 4890 geoverclockt naar 925/1000 (standaard is ie 850/975)... Na ongeveer 15min 640x480 furmark zag ik geen artifacts en werd dat ding ongeveer 82c, 5 min 1280x1024 furmark werd hij 91 graden max en bleef ie rond de 90 hangen. Ook geen artifacts... Is dit dan een goede overclock? Bij spellen wordt ie trouwens maar max 77 ofzo, bij crysis warhead o.i.d. De fan staat gewoon auto en ik heb ati overdrive gebruikt.
[ Voor 6% gewijzigd door Cobiwan op 31-05-2009 16:56 ]
  • mdj84nl
  • Laatst online: 19-03-2025
Sj44k13 schreef op zondag 31 mei 2009 @ 16:54:
Mijn 4870 draait nu 850mhz core en 1200mhz ram @ maximaal 50 graden (scythe mushasi)
Snelhedenkunnen niet hoger via ati overdrive, en heb geen zin om een ander programma te proberen.
Dus je temps zijn wel erg hoog vind ik
  • Cobiwan
Zonder die overclock kwam hij met crysis 2 graadjes lager uit, dus denk dat het dan meevalt? Heb alles gewoon stock qua koeler btw.
  • AlexanderB
  • Laatst online: 22-12-2025
AlexanderB
7800 rpm
:/ iemand enig idee of het normaal is om de hele tijd "driver has stopped responding and has recovered" te krijgen? (en dat icm n heel scherm vol artefacts)
  • Alfa Novanta
Alfa Novanta
VRRROOOAAARRRP
wat denk je zelf?? :P
  • THE_FIREFOX
  • Laatst online: 02-11 00:29
AlexanderB schreef op zondag 31 mei 2009 @ 17:11:
Het kan heel veel dingen zijn, maar wat heb jij zelf onderzocht? Het kan komen door een te warme videokaart of door een te hoge overclock of zelfs instabiel werkgeheugen (mij 2 keer gebeurd met OCZ geheugen.....)
  • AlexanderB
AlexanderB
7800 rpm
hm, graka temps rond de 60, mobo en mem zou gewoon prima moeten zijn, draait namelijk al n hele tijd gewoon prima.. waarschijnlijk n driver issue oid, heb net de drivers gedeinstalled, cleaned en de nieuwste geinstalled.. (kijken of het weg is nu)
(tis meer n vraag van, hebben jullie dit eerder gezien --> doa? of andere obvious fouten..
[edit:] geen stress issue, draait al 4560+ minuten furmark, temp. stabiel op 70 graden.
[ Voor 11% gewijzigd door AlexanderB op 31-05-2009 20:52 ]
  • agoNITE
  • Laatst online: 26-10 21:11
Sj44k13 schreef op zondag 31 mei 2009 @ 00:55:
mijne zegt ook 4870, zal wel domme fout zijn
Das inderdaad gewoon reclame..ik heb mn onboard tijdelijk in gebruik (780G, HD3200) ook die geeft HD4870 tijdens Catalyst install :P
Bij www.dunnet.nl is de XFX HD4770 met dual slot cooler weer op voorraad trouwens :)
Deze dus :
Afbeeldingslocatie: http://images.ncix.com/forumimages/CF1E0A44-16E3-1570-356214E98497B704.jpg
  • Dani86
  • Laatst online: 29-10 18:59
Dani86
AeroGeek
Probleem:
Asrock P43RTwins wifi
Coolermaster 650W
Sapphire HD4850 non-ref.
Win XP x64
Ik had de catalyst 9.5 drivers geïnstalleerd. Maar de HD4850 ging er met de 9.5 drivers op achteruit qua performance. Dus wil ik de 9.4 drivers opnieuw installeren.
De 9.5 driver eraf gehaald met de Ati uninstall utility, en driver cleaner pro er achteraan. Daarna de 9.4 drivers geïnstalleerd. Maar als hij klaar is met installeren en ik reboot, dan krijg ik een spontane reboot voordat mn PC in het windows welcome scherm komt. De PC blijft in een loop rebooten, opstarten in de veilige modus en de 9.5 driver weer installeren biedt soelaas.
Maar ik wil gewoon de 9.4 driver.
Iemand een idee wat er mis is? Of wat ik over het hoofd zie?
Ryzen 5 7500F - 32GB RAM @ 6000 MHz - RX7700XT - WD SN770 1TB nvme
  • Scrtz
  • Laatst online: 16:30
AgoNitE schreef op zondag 31 mei 2009 @ 20:43:
Deze dus :
jep heb m meteen besteld zaterdag aangezien mijn ati hd3870 BSOD's aan het geven was en sowieso geen fancontrol heeft en dus 24/7 een herrie geeft.
Ben benieuwd wat de overclockbaarheid van dit ding is :)
  • Cobiwan
Even voordat ik van de pagina verdwijn...
"Even een vraagje... Ik heb mijn Sapphire Radeon 4890 geoverclockt naar 925/1000 (standaard is ie 850/975)... Na ongeveer 15min 640x480 furmark zag ik geen artifacts en werd dat ding ongeveer 82c, 5 min 1280x1024 furmark werd hij 91 graden max en bleef ie rond de 90 hangen. Ook geen artifacts... Is dit dan een goede overclock? Bij spellen wordt ie trouwens maar max 77 ofzo, bij crysis warhead o.i.d. De fan staat gewoon auto en ik heb ati overdrive gebruikt."
  • agoNITE
Scrtz schreef op maandag 01 juni 2009 @ 11:10:
Ik ga ook naar deze kaart vanaf een HD3870, ben benieuwd.
Tijdens mn bestelling was er nog genoeg voorraad, echt de dag erna was er niets meer, en zou ik het standaard model krijgen (die met andere koeling o.a.). Dag erna werd ik gebeld dat ik toch de door mij bestelde kaart zou krijgen, morgen levering! Samen met een nieuwe cpu :)
  • Scrtz
AgoNitE schreef op maandag 01 juni 2009 @ 13:09:
ben allang blij als ik eindelijk van die herrie afben die me hd3870 maakt :P, ben zelf ook erg benieuwd hoe die het gaat doen, verder hoop ik stiekem dat ze een uitzondering maken bij paradigit en ik m na me werk meteen mee mag nemen, toch vooruit betaald :P
hallo allemaal,
sindskort heb ik mijn Nvidia GeForce 8600GT 256M 640 vervangen voor een Ati Radeon 4870 512MB GDDR5 van Sapphire.....
tot nu toe ben ik er vrijwel erg tevreden ermee.
maar toch wat ik mij afvraag, kan de CPU die momenteel erin zit een bottlenek zijn?
mijn systeem zoals het er nu eruit ziet.
AMD Athlon X2 6000+ Dual Core AM2 ( standaard geklokt )
6144MB werkgeheugen ( 2X 1Gb Geil DDR2 PC800 en 2X 2Gb Geil DDR2 PC800)
MSi KA790GX plank met AM3 ondersteuning
2X 500GB SATA 300 schijfjes.... niet in raid modus....
en de Sapphire Radeon 4870 512 MB versie....
is het zinvol om de X2 Dual Core te vervangen voor een X3 / X4?
tevens van AM2 naar AM2+/AM3 te gaan verhuizen?
en dan natuurlijk de vraag. is het wel zinvol om de huidige processor te vervangen. of beter nog even wachten?
alvast bedankt, Bas ;)
  • Scrtz
Verwijderd schreef op maandag 01 juni 2009 @ 13:59:
hallo allemaal,
zinvol of niet ligt eraan wat je te besteden hebt, en nog veel belangrijker wat je allemaal van plan bent ermee te spelen en wat je huidig speelt, welke monitor je gebruikt etc etc, als je weinig gamed zou ik het zo laten, game je wekelijks uren per dag en tevens ook echt alleen het nieuwste van het nieuwste, dan is zo'n upgrade het zeker waard.
Je moet jezelf gewoon afvragen of je er genoeg uit gaat halen, bij zon investering
Upgraden naar een phenom 2 is zeker een idee. De 6000+ is nog niet eens een echte bottlenek. Een ander moederbord nemen lijkt me niet nodig. Naar AM3 gaan is ook niet nodig.
Verwijderd schreef op maandag 01 juni 2009 @ 14:06:
de AMD Phenom™ II X4 940 Black Edition (Boxed) de juiste keuze?
of moet ik dan tevens de DDR2 PC 800 rimmetjes vervangen omdat die dan de bottleneck gaan vormen voor de videokaart?
Verwijderd schreef op maandag 01 juni 2009 @ 14:20:
In iederval een prima keuze. ;)
Nee nergens voor nodig. :)
even een vraagje,
wat zou mij de hoogste preformace upgrade geven? ( budget 300 euro)
een hd4850 x2 2gb
of 2* een kaart uit de 4xxx serie?
Verwijderd schreef op maandag 01 juni 2009 @ 16:56:
even een vraagje,
een hd4850 x2 2gb
2 keer een pricewatch: Asus EAH4870/HTDI/1G kom je alleen wel iets over de 300 euro heen.
Anders pricewatch: Sapphire HD 4850 X2 1G GDDR3 PCI-E alleen is dit niet de stilste videokaart.
Of twee pricewatch: Club3D HD 4770 512MB GDDR5 als je de videokaart van plan bent te overklokken. :)
Verwijderd schreef op maandag 01 juni 2009 @ 17:13:
Wat zou het beste zijn voor 1920*1080 resolutie? :)
bestaat er trouwens een 4770 1gb versie?
  • Scrtz
Verwijderd schreef op maandag 01 juni 2009 @ 17:42:
nee nog niet, maar het schijnt dat XFX daarmee bezig is.
Wat versta je onder het beste?
Aan de prijs is wel te zien welke de snelste is.
Is maar net wat voor instellingen je wilt, want met een enkele HD 4770 kun je elk spel wel spelen op jouw resolutie. :)
Verwijderd schreef op maandag 01 juni 2009 @ 17:50:
lots of eyecandy :)
Dan twee HD 4870's met 512MB of 1GB of een HD 4870 X2.
  • Scrtz
Trouwens mensen met ervaring in de overclockbaarheid van een ati hd4770 ( liefste de xfx hd4770 dualslot versie ) :o?
Scrtz schreef op maandag 01 juni 2009 @ 19:13:
En vertel er dan ook bij welk PCB je hebt. :)
Deze:
Afbeeldingslocatie: http://xtreview.com/images/HD%204770%20Retail%20edition%20and%20Media%20edition%208.jpg
Of deze:
Afbeeldingslocatie: http://xtreview.com/images/HD%204770%20Retail%20edition%20and%20Media%20edition%207.jpg
De onderste zou namelijk een stuk beter overklokken, maar de XFX Media Edition heeft volgens mij de bovenste. :)
  • Scrtz
moet hem nog binnen krijgen, en het wordt idd de media edition, weet dus niet precies welk PCB die heeft
  • AlexanderB
AlexanderB
7800 rpm
hm, ik hoop dat ik het nu gefixed heb, als ik het goed begrepen heb heeft CCC n probleem met windows 7, dus als je alleen de losse driver installeert zou het probleem opgelost moeten zijn.. ben benieuwd :)
ik heb een 22 inch monitor(1680*1050)en een sapphire 4850 512 mb. Mijn huidige videokaart functioneert niet naar behoren(hoge temperaturen en black artifacts) en daarom wil ik een nieuwe gaan halen. Zelf wil ik voor 200 euro uitgeven voor nieuwe videokaart en 4890 van sapphire was voor mij de juiste keuze, maar de 4870 vapor en de toxic editie vond ik ook interessant.Zowel op forum van tweakers.net en andere sites ben ik op zoek gegaan wat mensen van de 4870 en de 4890 vinden. De keuze is moeilijk, want dat aangeraden wordt om voor 4870(vapor x editie of toxic) te gaan maar volgens de specs is de 4890 toch beter. Ik kan ook moeilijk onderscheidt maken wat beter presteert de 4870 vapor/toxic editie of the 4890. De resultaten of wel de benchmark van de 4870 vapor/toxic editie en de 4890 zijn zo verschillend op verschillende website dat het voor mij moeilijk wordt welke videokaart ik wil nemen. Daarom vraag ik aan jullie wat de beste keuze is
De beste keuze kan alleen jij zelf maken. De HD4890 is sneller ja, heeft meer overclock potentieel ja. Is minder stil en koel ja. Wat jij belangrijk vind bepaalt de doorslag.
  • Mizitras
Hopelijk is dit waardevol op deze moment voor zij die erover twijfelen om een HD 4770 te kopen (in Benelux):
De HD 4770 komt héél slecht binnen bij de verdelers, in Vlaanderen vind ik hem zo goed als niet meer; in Nederland valt dat nog wel mee, maar stijgen de levertijden ook. Wel handig voor wie twijfelt tussen de 4850 en de 4770, de prijs van de 4850 (en de prestaties die 5 à 15% hoger liggen), zal waarschijnlijk dalen bij veel winkels, om de 4770 tegemoet te komen.
De prestaties van de uitgave van ASUS en MSI zijn overigens zééééér gelijkaardig; dat gezegd zijnde over de prestaties, is het slecht nieuws dat beide hier bij de courante verdelers niet meer beschikbaar zijn :/
"the fucking alpha cpp compiler seems to fuck up the goddam type "LPITEMIDLIST", so to work around the fucking peice of shit compiler we pass the last param as an void *instead of a LPITEMIDLIST"
  • Scrtz
Mizitras schreef op dinsdag 02 juni 2009 @ 17:23:
4850 haalt de 15% meer geeneens hoor, heb mijn hd4770 morgen binnen, iig kreeg er net mail van dat dat de verwachte levertijd is. heb m in t weekend besteld dus erg netjes, bij www.dunnet.nl btw.
  • Alfa Novanta
Alfa Novanta
VRRROOOAAARRRP
Verwijderd schreef op dinsdag 02 juni 2009 @ 16:08:
pssst .. of je neemt de 4890 Vapor-X ;)
ing._Buttje in "Het ATi HD4XXX Serie Ervaringen Topic - ..."
Zou eerder gaan voor een HD 4890 OC die al een GPU snelheid heeft van 1GHz. ;)
  • Mizitras
Scrtz schreef op dinsdag 02 juni 2009 @ 19:31:
off-topic: maar Dunnet.nl beschrijft nergens iets over verzending naar België, dus dat is voor wij Belgen geen optie ;)
  • AlexanderB
AlexanderB
7800 rpm
fail. crashprobleem nogsteeds niet opgelost..
zover ik kan nagaan is het geen hardware probleem, en het gebeurt alleen als ik rustig op mn desktop/internetbrowser wat bezig ben.. (niet als ik aan het stresstesten ben, bijv, furmark met xtremeburn aan)
blijft over drivers, of iets met het terugklokken van de kaart in idle modus..
wat ik trouwens ook niet snap is dat als ik op de grafieken kijk, dat ie met bijna 0 belasting, nogsteeds af en toe (eigenlijk best vaak) heen en weer springt tussen 2d en 3d clocks, misschien komt het daarom?
AlexanderB schreef op dinsdag 02 juni 2009 @ 22:49:
Volgens mij is het zo dat als je gaat overklokken met RivaTuner de videokaart niet meer na 2D modus gaat, dus misschien even een overklok van 1MHz doen. :p
  • Alfa Novanta
Alfa Novanta
VRRROOOAAARRRP
Verwijderd schreef op dinsdag 02 juni 2009 @ 19:40:
.. maar da's een stofzuiger ;)
  • AlexanderB
AlexanderB
7800 rpm
bedankt voor de tip, en, dat werkt :) nu ff kijken of het gezeur over is nu :P
ing._Buttje schreef op woensdag 03 juni 2009 @ 00:26:
Er zijn wel meerdere, er is niet alleen de XFX versie. ;)
  • Alfa Novanta
Alfa Novanta
VRRROOOAAARRRP
welke bedoel je dan .. die van MSI Powercolor met die Zerotherm koeler?
[ Voor 13% gewijzigd door Alfa Novanta op 03-06-2009 14:12 ]
Sapphire Atomic HD 4890 Vapor-X
MSI R4890 Cyclone
Powercolor PCS++ HD 4890
ASUS EAH4890 Formula
Ze zijn alleen nog niet echt beschikbaar in NL. ;)
[ Voor 7% gewijzigd door Verwijderd op 03-06-2009 22:38 ]
  • Tunda
  • Laatst online: 18-10 11:54
Goedendag luitjes,
Ik zit al een tijdje te kijken naar een videokaart omdat werkelijk mijn bagger Geforce 7300le het niet trekt voor mijn doen.
Nou heb ik zelf al een tijdje een videokaart op het oog, maar werkelijk waar ik zie allemaal nummers coreclock, shaders etc. en ik zou bij god niet weten waar ik voor moet kijken, zonder dat ik op een bottleneck terecht kom.
Dus zal ik maar even mijn situatie uitleggen en hopelijk kan iemand mij een beetje de juiste richting in pushen.
Intel E2180 standaard 2,0 GHZ(geclockt naar 2,5 GHZ)
2048MB werkgeheugen ( 2X kingston 1024 MB 667MHz ddr2)
dit alles op een ASUS P5GC-MX/1333
De pc word vooral gebruikt voor dagelijks gaming, vooral world of warcraft niet zo zeer andere spellen.
Ik ben op zoek naar een grafiekkaartje tot de ~160/170 euro's
Doel is simpelweg om WoW met max. settings te kunnen spelen en toch soepel kunnen spelen met een hoog FPS.
Tevens draait dit op een 19 inch wide screen: Samsung Syncmaster 923NW @ 1440 x 900
Videokaart waar ik zelf aan zat te denken:
Palit Radeon HD 4870 Sonic Dual Edition:
pricewatch: Palit Radeon HD 4870 Sonic Dual Edition
Hopelijk genoeg informatie, kort samengevat: wat kan mij aangeraden worden(waarom) en wat kan eventueel een probleem, bottleneck zijn.
Panasonic MDC05J3E5 * Hewalex PCWU 3.0 KW + 200L
  • MikeyMan
  • Laatst online: 19:31
MikeyMan
Vidi, Vici, Veni
In alle eerlijkheid denk ik dat je met een 4770 al prima geholpen bent...
  • Steffy
  • Laatst online: 17-10 11:01
Steffy
Ayreonaut
Ik zat zelf aan een 4770 te denken, 2 stuks want ik heb voor een zeer zacht prijsje namelijk een crossfire bordje kunnen krijgen. Samen met een Athlon X2 7750 Black Edition en 4gig PC8500 leek het mij wel wat om daar 2 van die kaartjes op te plakken maar ik vond ze verdacht prijzig als ze op voorraad waren en waar ze goedkoop waren, lees rond de 80 euro was de levertijd een maand maar die dingen worden dus vrijwel niet geleverd. Jammer het leek me wel wat maar nu moet ik wat langer wachten.
Is er iemand die enig idee heeft wanneer je daar een verbetering in gaat zien, de leveringen?
  • agoNITE
Heb zelf de dual slot verzie van XFX besteld bij dunnet.nl. 89,95 excl.
Op moment van bestelling waren ze door de voorraad heen, maar 3 dagen later was er weer een partij binnen :)
  • Scrtz
zo hd4770 binnen, was even gekloot met drivers, 9.4/9.5 werken beiden niet bij mij, alleen de XFX 9.4 drivers werkte, maar het draait nu eindelijk lekker, even getest aangezien ik nog weinig tijd heb, met hd3870 had ik ~30 fps in half life 2 episode two, in het begin waar je die "portal storm" krijgt, met ati hd4770 is dat ~80 fps dus een aanzienlijke prestatiewinst, in het weekend meer tests in gta IV etc :)
  • Rainesh
  • Laatst online: 08:56
Scrtz schreef op woensdag 03 juni 2009 @ 21:22:
Ati 9.5 werkt gewoon prima met mn XFX HD4770, echter heb ik sinds vandaag problemen met mn profielen voor mn schermen.. :( Hij onthoudt mijn profielen maar niet, heel irritant want ik gebruik ze om mn films op mn tv te kunnen kijken en gewoon surfen op mijn tft.
Verwijderd schreef op woensdag 03 juni 2009 @ 12:37:
MSI R4890 Cyclone
Weet jij wanneer de ASUS EAH4890 Formula in NL beschikbaar is.
Verwijderd schreef op donderdag 04 juni 2009 @ 00:17:
Nee ik weet alleen dit: http://www.nordichardware.com/news,9415.html ;)
  • haakjesluiten
  • Laatst online: 02-11 08:55
ik heb net eens de koelpasta van mijn asus HD4850 TOP vervangen. Er zat een soort aangebakken korst op ipv koelpasta Gekke is alleen dat nu ik er een of andere koelpasta van cooler master op heb gedaan dat de temps gewoon precies gelijk zijn gebleven zou toch wat lagere temps verwachten aangezien die meuk die erop zat nooit goed gewerkt kan hebben kreeg die koeler amper los zo vast zat ie gebakken.
  • ClementL
  • Laatst online: 08-09 08:24
Deze dus :
Bedankt voor de tip, heb er net 2 van binnen :D
  • agoNITE
ClementL schreef op donderdag 04 juni 2009 @ 15:23:
Krijg mijn pakketje ook net binnen, op mn werk helaas! dus kan vanavond pas inbouwen en testen :(
Ben erg benieuwd!!
  • Scrtz
Rainesh schreef op woensdag 03 juni 2009 @ 22:01:
welke hd4770 heb je dan? bij mij wou ATi dan niet starten, en na heel wat gekloot kreeg ik een popup van quit of in advanced mode starten, drukte je op advanced mode kreeg je nog niks..
  • AlexanderB
AlexanderB
7800 rpm
geen crashes meer tot nu toe, volgens mij is die powerplay troep de oorzaak van mn crashes, opgelost dus :)
  • Room42
Ik ben echt helemaal klaar met ATi/AMD doordat ze totaal geen linux support hebben. Ja, ze bieden de drivers wel aan, maar draaien, ho maar. Ik heb een 4870x2 maar onder Linux (Ubuntu 9.04) kom ik niet verder dan de oss 2D drivers. Niet echt wat ik ervan verwacht had voordat ik hem kocht. Toen las ik juist dat de support nu beter geworden zou zijn.
Onder Windows doet ie het prima, hoor. Maar ik draai 96% van de tijd Linux. Zodra ik hem verkocht heb, stap ik over op Nvidia.
  • haakjesluiten
eh ik weet niet wat je verwacht van nvidea maar hun nieuwste high end kaarten worden ook niet uitgebreid ondersteund in linux...
Edit: koelpasta lijkt beter te zijn ingewerkt temps zijn stuk gezakt met 5-6grade @ idle naar 44 ook heb ik met RBE de bios iets aangepast zodat ie @ idle maar op 400/650 loopt en iets undervolt.
[ Voor 43% gewijzigd door haakjesluiten op 04-06-2009 20:22 ]
Volgens mij werkt CrossFire nog niet helemaal zo als het moet onder Linux, voor de rest zou het even ongeveer even goed/slecht moeten zijn als bij nVidia, maar ik weet niet hoe het met SLi ondersteuning in Linux zit.
  • Room42
Ik hoef ook helemaal geen SLI/Crossfire. Ik wil gewoon decent 3D acceleratie :) Maar ik ben inderdaad in de veronderstelling dat het met Nvidia beter zal zijn... Ik hoop dat ik niet bedrogen uit zal komen.
Je hebt immers wel CrossFire nodig. ;)
[ Voor 8% gewijzigd door Verwijderd op 04-06-2009 20:40 ]
  • Room42
Je bedoeld om beide kaarten van de 4870x2 te laten werken? Van mij mag ie het ook op één doen, hoor. Of zit ik nu te verklappen dat dit niet mijn kennisgebied is? ;)
Idd. ;)
  • AlexanderB
AlexanderB
7800 rpm
Room42 schreef op donderdag 04 juni 2009 @ 20:54:
in dat geval wil ik em wel ruilen voor een enkele 4870 xxx editie O-)
linux drivers kan ik je niet aan helpen, helaas..
hd4870 is kickass, en 40 graden @ load met waterkoeling is fijn :)
  • Room42
Leg maar uit, dan. Want voor wat ik begrepen heb, is de x2 niets meer dan 2 kaarten op één bord. En als je geen crossfire gebruikt, gebruik je dus maar 1 kaart.
@alexander: hij is nog te koop* voor 250 euro.
*Geen idee of jij die ad nog kan zien omdat hij reeds vervallen is.
[ Voor 43% gewijzigd door Room42 op 04-06-2009 21:28 ]
  • AlexanderB
AlexanderB
7800 rpm
kan, je kan met dual monitor ook iedere kaart zn eigen monitor geven, maar waarschijnlijk werkt dat net zo brak onder linux..
x2 is inderdaad 2 kaarten op 1 bord..
en 250 euro.. nja, ik heb net 2 dagen mn hd4870 :)
  • dunn0w
  • Laatst online: 27-10 16:23
Morgen krijg ik de 4850 binnne..
Welke driver kan ik het beste installeren? De laatste nieuwe of gaat ie dan problemen geven, met gamen?
  • KiLLaHeRTz
  • Laatst online: 01-11 19:30
De laatste van de AMD site kan je het beste nemen :)
  • agoNITE
Beetje balen, had ik na redelijk lang wachten eindelijk mn HD4770 binnen, allemaal artifacts:
[HD4770]Artifacts
Vanochtend RMA aangevraagd voor DOA, morgen versturen.
Heeft er iemand enig idee hoelang de RMA procedure bij Dunnet duurt? Zit er namelijk niet op te wachten om nog anderhalf tot twee weken zonder GPU te zitten...mis mn games toch wel een beetje :P
En een ander idee, een lokale PC toko krijgt vandaag of morgen weer een voorraad HD4770 van XFX binnen. Ik denk dat ik daar een kaartje op ga halen. Hoe groot is de kans dat ik mijn HD4770, welk via RMA nog terugkomt, zonder al te veel verlies via V&A of MP weer kan doorverkopen? (Nieuw met garantie dus..)
  • haakjesluiten
tja je zal hem wel kunnen verkopen maar je gaat er wel op verliezen want niemand betaald de nieuw prijs voor een "2e hands kaart" kan je toevallig geen xfire draaien @ je mobo
  • agoNITE
Crazyanz schreef op vrijdag 05 juni 2009 @ 15:03:
Helaas niet, wel gekeken al naar een xfire bordje...is nog een optie :)
Hm nu ik er over nadenk, nieuwprijs is wel veel gevraagd misschien, maar er zit gewoon nog garantie op natuurlijk..net alsof je m in de winkel koopt. Doos gesealed en al...ach op MP misschien ;)
  • jorisw86
  • Laatst online: 22-10 18:48
weet iemand wanneer de sapphire 4890 atomic leverbaar is?
al sinds 1 mei berichten overal revieuws maar nergens de kaart te vinden.
  • Scrtz
AgoNitE schreef op vrijdag 05 juni 2009 @ 15:51:
ik zal eens vragen hoelang die RMA ongeveer duurt maandag dan, werk bij paradigit, daar is dunnet ook van ;)
  • Gojira
  • Laatst online: 12-04-2023
AgoNitE schreef op donderdag 04 juni 2009 @ 15:30:
Agh, dat valt nog wel mee. Ik krijg de rest van mijn systeem pas op 18 juni binnen, terwijl de HD 4770 al een dag onder m'n -jawel- bed ligt. :z
Crazyanz schreef op donderdag 04 juni 2009 @ 15:11:
Hoi wat voor middel heb je gebruikt om de pasta schoon te maken. Waar kan je zo;n reiniging spul kopen, want ik weet wel waar je koelpasta's kopen maar een reiniging spul om de huidige koelpasta schoon te maken zie op geen computerwinkels(zowel off/alsonlineshops.)
  • Wapwap
  • Laatst online: 03-11 19:35
Voor de mensen geïnteresseerd in de Arctic Cooling Accelero XTREME 4870X2, hij is inmiddels verkrijgbaar in Noord Amerika.
De eerste reacties van kopers zijn zeer positief te noemen en hij voldoet aan de verwachtingen. Enkel het monteren van de koeler blijkt een helse stoeipartij te zijn.
Meer info hier en hier.
  • Plurk.
  • Laatst online: 29-09 21:27
Verwijderd schreef op vrijdag 05 juni 2009 @ 23:35:
Ik gebruik deze altijd;
pricewatch: Arctic Silver ArctiClean (Reinigingskit)
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Of gewoon wasbenzine?
  • Plurk.
Wasbenzine laat residu achter en is dus niet optimaal
  • Alfa Novanta
Alfa Novanta
VRRROOOAAARRRP
Wasbenzine is ontzettend agressief ... perfect spul, maar los (te)veel op.
Wij hebben altijd wel dit spul in huis, werkt prima :P
Afbeeldingslocatie: https://www.directapotheek.nl/product_img/sterilon%20applicatievloeistof.jpg
Afbeeldingslocatie: http://www.rezobv.nl/public/images/Basic_Wattenstaafjes2.jpg
d:)b
[ Voor 13% gewijzigd door Alfa Novanta op 06-06-2009 11:40 ]
  • Supertip
Plurk. schreef op zaterdag 06 juni 2009 @ 11:03:
Ik gebruik altijd nagelak remover werkt perfect...............
En mijn gainward 4850 GS met GDDR5 knettert nog lekker door, top-product zeg maar...... :9~
[ Voor 29% gewijzigd door Supertip op 07-06-2009 20:04 ]
12X Rec peak energy 275 WP pal Zuid platdak 20° Growatt 3000 MTL-S /bj. Half mei 2018
  • KillaZ
  • Laatst online: 19:16
Eigenlijk overal waar ethanol in zit werkt goed.
K to the KillaZ
  • jorisw86
als je 2x 4890 in crossfire zet kan je dan nog wel op 1 videokaart beide dvi uitgangen gebruiken voor 2 schermen?
bij nvidia werkt dit namelijk volgens mij niet?
alvast bedankt.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Residu? Het verdampt waar je bij staat... Even een droog doekje eroverheen en niks aan de hand...
En teveel oplossen? Zoals wat? Core kan weinig mis mee gaan iig...
  • Alfa Novanta
Alfa Novanta
VRRROOOAAARRRP
Het zou de tekst op de heatspreader kunnen oplossen bijv. of de laklaag op de pcb eronder. Het is imho voor deze situatie voor dit doel redelijk overkill. Met wat alcohol/ethanol ben je er ook :)
  • AlexanderB
AlexanderB
7800 rpm
jorisw86 schreef op dinsdag 09 juni 2009 @ 09:12:
alvast bedankt.
ja, dat kan gewoon :) en nee, bij NV dus niet, lekker verwarrend inderdaad ;)
  • jorisw86
ook op beide beeldschermen verschillende resoluties draaien met crossfire enabled?
  • Steffy
Steffy
Ayreonaut
Ik heb even na zitten denken over een 4770 crossfire opstelling maar ik denk dat ik maar voor een 4870 crossfire opstelling ga. De 4870 512MB nadert met sprongen de prijs van een leverbare 4770 want die zijn onder de 90 euro vrijwel niet te krijgen en de goedkoopste 4870 zit onder de 110 euro en met de aangekondigde prijsverlaging in de komende weken denk ik dat er voor 90 euro wel een 4870 op de kop getikt kan worden.
De vraag is of het een goede keuze is, ik heb er kwa warmte productie niet echt naar gekeken maar daar weten mensen hier vast meer van. De 4870 is volgens mij sneller dan de 4770 maar zal mekaar vast niet extreem veel ontlopen. De 4770 lijkt goed OCbaar te zijn, hoe zit dat met de 4870? Is het een goede keuze om nog een maandje aan te kijken hoe de prijzen zich ontwikkelen en als ze straks bijna evenveel kosten of de 4870 een goede keuze is ten opzichte van de 4770.
  • haakjesluiten
4870 is een stuk sneller dan de 4770 ;) de 4770 zit zoon beetje rond een 4850 en de 4870 is gemiddeld 20% sneller dan een 4850. Ook zijn 4870's prima te oc'en maar 2 hd4870's heb je voorlopig ook zonder oc genoeg aan lijkt me. Kwa warmte moet je zelf maar kijken of je beetje goede airflow heb in je kast want zal wel een warme bedoeling worden anders.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Tsjah, die aangekondigde prijsverlagingen zijn leuk, maar het is maar afwachten of en wanneer ze daadwerkelijk doorgevoerd zijn...
Als dat twee maanden duurt, zal de 4770 ook wel weer beter leverbaar zijn...
Imo heeft het weinig zin om te speculeren op prijsverlagingen op het gebied van computeronderdelen...
  • haakjesluiten
hehe kan jij wel vinden. Maar het is zonde om nieuwe spullen te kopen die na een maand alweer 30% in waarde zijn gedaald. Als ik nieuwe spullen koop tegenwoordig kijk ik altijd eerst of er snel iets nieuws aan komt of dat er een prijsverlaging is aangekondigd en aangezien bij de HD48xx serie beide het geval is is wachten zeker de moeite waard. Vaak kan je namelijk makkelijk nog even wachten ;)
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Ja, dat snap ik, maar dat is dus een continu proces...
  • haakjesluiten
och je weet dat een kaart gemiddeld een jaar mee gaat voor er een betere versie komt ;) dus als je dan na 11 maanden een nieuwe koopt loop je achter de feiten aan aangezien er 1 maand later voor een niet veel grotere investering en kaart gehaald kan worden die bv zomaar 20% sneller is.
  • jorisw86
mikey heeft wel gelijk zo blijf je wachten.
daarom ook 2x 4890 toxic aangeschaft die gaan gewoon 1 a 1,5 jaar mee.
erna weer nieuwe.
Pff, ik wacht nu drie weken op mijn Sapphire HD4770, besteld bij Azerty. Ze kunnen er geen duidelijkheid over geven wanneer hij ongeveer binnen wordt verwacht. Zijn er hier toevallig mensen die ook zitten te wachten op deze kaart, of van een ander merk of dat misschien onlangs hebben gedaan? Hoe lang hebben de (Sapphire) HD4770 bezitters ongeveer moeten wachten tot ie binnen was? Ik weet niet of ik nu moet blijven wachten of dat ik hem misschien ergens anders moet bestellen. Ik heb nog een aantal andere zaken besteld bij Azerty dat allemaal al binnen is maar dat wordt nu al een paar weken opgehouden door die videokaart. ;(
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Moet het perse een sapphire zijn dan?
Zie dat ze bij bijvoorbeeld informatique de club3d variant gewoon op voorraad hebben...
Koeling zal niet veel verschillen ivm reference design...
Ik heb mijn sapphire overigens na eerste levering meteen opgehaald bij Alternate...
  • Enfer
  • Laatst online: 17-10 17:02
Ik vraag mij wel eens af wat het verschil tussen een pricewatch: XFX Radeon HD 4870 512MB DDR5 XXX is en een pricewatch: Sapphire HD 4870 512MB GDDR5 PCI-E .
Qua specs ziet de xxx er beter uit, en hij is goedkoper, wat te mooi lijkt om waar te zijn eigenlijk. Vanwaar dit verschil?
  • YoupS
  • Registratie: Oktober 2008
  • Laatst online: 11:45
Misschien heeft XFX groter ingekocht en daardoor meer korting kunnen krijgen bij ATi?
  • Mili
  • Laatst online: 27-05-2024
xfx heeft jaren lang de beste prijs prestatie verhouding gehad toen ze alleen nvidia videokaarten maakte.
dat ze dat nu keihard dunnetjes over doen nu ze ook ATI's maken verbaasd mij eigenlijk niet.
als het kon had ik graag my Sapphire 4870X2 ingeruild voor een XFX 4870X2 omdat ik uit ervaring weet dat de XFX makelijker overklokt, al snel 10 graden koeler is stockcooled en vaak ook nog een stillere stock koeler heeft.
Voordat je post, lees eerst de regels van dit topic!
Dit topic is bedoeld om ervaringen te delen over de HD4XXX kaarten. Basic vragen zoals 'welke moet ik kopen', 'is mijn voeding sterk genoeg' en 'werkt CF op een SLI moederbord' etc etc, zijn al heel vaak beantwoord. Gebruik dus de Search.
Veel antwoorden kan je vinden in de topic start of in de FAQ van het ATI Nieuwsdiscussie Topic. Staat je antwoord hier niet en brengt Google geen soelaas? Dan heb je vast een goeie vraag!
