• Donderstraaltje
Donderstraaltje
Beta Release 2.6.12
This patch update fixes the continuous IR repeat feature and updates the Home Assistant integration.
Known issues:
• WiFi high-channels (>11) do not work anymore, we are working on a fix.
• WoWLAN periodically wakes up the device from standby. A support case with the manufacturer is in progress.
• Automatic display brightness and button backlight settings in the UI are not yet working. They are currently disabled in the web-configurator.
• Remote 3: the ambient light sensor sensitivity will be increased with a firmware update.
• Sonos integration: a recent speaker firmware update affects the local device API access. Connection issues might be resolved temporarily by power-cycling the Sonos device(s). We are planning a rewrite of the Sonos integration using a different API.
Fixed
• Continuous IR repeat command is interrupted (#484).
• This also requires an updated Dock firmware release v0.8.0 or newer, which will be released shortly.
• Remote 3: Display initialization adjustment to avoid sporadic interlace effects after wakeup (#561).
• Outdated integration information, new driver metadata was not always refreshed after a driver update.
Web-configurator:
• A newly added key in an IR remote is not immediately available in the UI & button mapping screens and requires a manual refresh.
• Integration setup: the last item in a scroll list is not always selectable depending on screen size.
• Disabling beta updates requires a reboot.
Home Assistant integration:
• The first time setup showed the old server configuration screen and could end up in a configuration loop.
• Initial setup with a wss:// Home Assistant URL or switching from ws to wss doesn't require a reboot anymore.
• The correct integration version is reported without the "-dirty" suffix.
• Only the documented sensor states "ON," "UNAVAILABLE" and "UNKNOWN" are used.
Changed
• Added initial support for a continuous command-repeat feature for external remote-entities usable by all integrations, similar to the continuous IR-repeat feature.
• Updated Home Assistant integration to v0.13.1.
• Updated TLS runtime and certificate validation for better compatibility (#189, integration-home-assistant#73).
• Option to disable TLS certificate validation of HA WebSocket server (integration-home-assistant#71).
• Change binary sensor mapping: use the new "binary" device class, store binary sensor device class in the unit attribute (integration-home-assistant#74).
• Configured entities will automatically migrate by opening the HA integration in the web-configurator.
• Sensor UI screens will be improved in a future update.
• Updated ca-certificates to 20250419.
  • Donderstraaltje
Donderstraaltje
Dock 3 Beta Release 0.8.0
Fixed
• Delay function used for sending IR codes was inaccurate for delays greater than 16ms, causing issues for certain IR protocols and native IR repeats (#34, feature-and-bug-tracker#484).
• Stop active IR repeat if WebSocket client disconnects.
• Memory leak in async ir_send responses.
Added
• Optional system runtime statistics (#28).
• Status led patterns for dock setup, IR learning and OTA (#37).
• Sending an IR code for a specific time.
Changed
• Support higher modulation frequencies and better PWM precision for sending IR (#29).
• Enhance IR repeat functionality (#35).
• Do not enter WiFi setup mode if connection setup failed (feature-and-bug-tracker#612).
  • Donderstraaltje
Donderstraaltje
Wat bevindingen nadat we wat weekjes verder zijn;
- Na een paar updates van zowel de firmware als de integration kan ik er niet langer overheen installeren (nouja niks aan het handje maar geeft aan hoe erg in ontwikkeling het nog is)
- Alle instellingen dit keer wel weg bij integration weghalen/herinstalleren
- via de remote instellingen lukte dit keer niet meer, webbrowser wel
- daarna prompt op remote om het instellen verder af te maken, nette interactie dit
Hierna kon ik opnieuw een custom button mapping doen en... werkte dit keer wel! Ofwel liep tegen een bug aan ofwel ontwikkeling was nog niet zo ver een paar weken terug.
Nu kan ik de tv gids oproepen (ik gebruik een PVR backend ter vervanging van het Ziggo kastje) en kan ook ondertiteling aan/uit zetten! Long en short button press nog niet getest. Dit is nu al 95% wat ik met de kodi integration wil. Voor de laatste 5% moet ik even mijn setup overdenken (hoe zet ik de htpc nu aan???). Ja IR kan maar heb nog wat andere ideeën. Geen haast meer.
Voor Lyrion nog geen integration gespot (of gezocht eerder gezegd) dus dat wordt zoeken of die er intussen wel is. Natuurlijk ben ik blij dat de kodi integration nu werkt maar buiten dat gezien hoe ik nu zinvolle foutmeldingen krijg en het een beetje fijn werkt / geen timeouts continue zit het aardig op het niveau waarvan ik vind dat het bij versturen remote two had moeten zijn.
En kan nu eindelijk dagelijks gebruik testen en daarmee de batterijduur. Zo waar eindelijk een beetje blij met de aankoop.
  • ArniD
  • Laatst online: 27-11 18:11
Donderstraaltje schreef op vrijdag 26 september 2025 @ 13:49:
Voor de HTPC kan je eventueel het volgende overwegen:
https://github.com/kennymc-c/ucr2-integration-requests
Gebruik het zelf niet maar lijkt erop dat je via die weg een wake on lan command kan sturen naar de HTPC.
  • Donderstraaltje
Donderstraaltje
ArniD schreef op vrijdag 26 september 2025 @ 14:00:
Ah mooi hoef ik die niet te zoeken! WOL is wel hit or miss en in het verleden niet veel geluk mee gehad. Maar dat hebben anderen weer niet met CEC en dat werkt hier perfect. Mocht WOL werken wil ik het eigenlijk mappen binnen de kodi integration als short button press op de power button, long button press voor uitzetten. Voelt heel natuurlijk om het zo te doen. Wellicht klusje voor dit weekend en of het exact zo werkend te krijgen is.
Voor IR heb ik wel iets moois liggen maar dat is voor de toekomst eventueel. Om meerdere redenen nu geen zin in en tevens voorlopig geen optie.
  • tobasfxp
  • Laatst online: 20-11 16:44
Boedha schreef op zondag 17 augustus 2025 @ 23:01:
Wanneer worden ze eigenlijk geleverd? Heeft iemand daar zicht op? In mei de bestelling gedaan.
Ik heb de remote op 15 juni besteld, en heb deze vorige week ontvangen.
Op de site van Unfolded Circle is geen info te vinden voor eventuele uitlever batches, jammer genoeg is het dus gewoon afwachten.
  • FireFly3k
  • Laatst online: 25-11 16:08
tobasfxp schreef op maandag 29 september 2025 @ 16:27:
Het zou inderdaad leuk zijn om te weten hoeveel wachtenden er nog voor je zijn.
Ik heb de mijne op 27 juli besteld en ik ga eigenlijk maar uit van eind december. Als ie eerder komt is het meegenomen, maar na jouw bericht hoop ik natuurlijk wel dat het eerder wordt. :D
PSN - 500px - Flickr
  • Pierre
  • Laatst online: 12:00
Pierre
Van nature lui!
Bijzonder ik heb gebacked in Februari, dus ben wel benieuwd wanneer die van mij verzonden gaat worden.
Inderdaad off topic sorry
[ Voor 14% gewijzigd door Pierre op 30-09-2025 10:03 ]
  • Jorgen
  • Laatst online: 11:56
Jorgen
Moderator Beeld & Geluid
AV Liefhebber
Letten we erop dat dit een ervaringentopic is? De perikelen rondom je aankoop zijn hier off-topic
Voor prijzen, levertijden, etc hebben we het Shopping forum en voor specifieke aanbiedingen hebben we Aanbiedingen en kortingscodes
Tea. Earl Grey. Hot.
  • Dalike
  • Laatst online: 12:22
Ik ben nog vol spanning aan het wachten op de mijne. Maar zijn er al mensen die versie 3 hebben en de nieuwe Telenet TV box hebben? Ik had ergens een lijst gevonden met compatibele toestellen, en die stond daar precies nog niet bij.
Toch iemand die het aan de praat gekregen heeft? Wel een voorwaarde om de WAF in orde te krijgen hier.
  • nklerk
  • Laatst online: 19-11 08:29
Als je de originele afstandsbediening hebt dan leer je de codes aan R3 met gemak. Als je pronto codes hebt dan is het nog eenvoudiger.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.7.0
This update contains the long-awaited WiFi update with support for high channels and to keep the WiFi connection enabled during sleep.
Known issues:
• WiFi security mode WPA3 is not yet supported.
Fixed
• Various WiFi connectivity issues fixed with a renewed WiFi stack containing updated drivers and firmware.
• WiFi 2.4 GHz high-channel support (12, 13 where permitted).
• Remote 3: 5 GHz DFS channels (where permitted).
• Option to keep WiFi connected during sleep for much faster reconnection after wakeup.
• Support for WoWLAN magic packet wakeup.
• Please note that the Remote can still wake up if the access point triggers a group key update/rotation when new encryption keys are generated.
• Most routers rotate keys every 1–24 hours.
• Other wakeup reasons are deauthentication or disconnect events if a connection loss is detected.
• Focus handling in the power button popup menu on the main page.
• Improved button mapping and entity data handling when loading UI screens (#176, #615).
• Remote 3: Include STOP, MENU, RECORD buttons in the automatic button mappings.
Web-configurator:
• Upload CSV file button in IR-remote entity missing (#621).
• Edit mode in the UI customization screen jumps back to the first item (#635).
• Overlap in button mapping page (#634).
• UI page rename didn't show an error if the new name already exists.
• Invalid button command text for mapped buttons in the IR-remote button mapping.
• Invalid default activity group is shown for activities without an activity group.
Added
• Web-configurator: request web app reload after a system update.
• Binary sensor support in the user interface.
• The Sensor UI screens will be further improved in a future update. A widget for activity screens is planned too.
Changed
• Improved the sharpness and clarity of icons and text.
• Added a default activity group for all newly created activities.
• Existing Activities can be added and removed from the default activity.
• The new default activity can be edited but not deleted.
• Starting an activity from another activity will open the new activity's UI (#636).
Improved WiFi settings menu:
• Showing connected WiFi network within the known network list.
• Show loading icon next to WiFi network when connecting.
• Replaced manual connect menu option with "join and disable other networks.
• New options to enable and disable known networks.
  • tobasfxp
Ik ben bezig om de remote te configureren en wil eigenlijk de acties ongeveer gelijk maken aan de acties van mijn Harmony remote.
Nu loop ik tegen hetgeen aan dat als ik op de harmony van actie wissel, de lopende actie afgesloten word.
Alleen krijg ik dit niet voor elkaar op de UCR3.
voorbeeld:
Actie "TV Kijken"
- TV gaat aan
- Settopbox gaat aan
- TV op HDMI 1
Dan door op actie "Netflix Kijken"
- TV Blijft aan
- Settopbox gaat uit
- TV gaat naar Netflix app
Bij de UCR3 blijft de settopbox aan staan als ik de actie netflix start, maar gaat uit als ik weer de actie TV Kijken start.
zie ik iets over het hoofd of is dit niet mogelijk op dit moment ?
  • Donderstraaltje
Donderstraaltje
tobasfxp schreef op woensdag 1 oktober 2025 @ 16:31:
Kan het zijn dat het IR signaal voor power aan/uit van de remote van de STB identiek is?
Heb een soortgelijke setup, maar met een HTPC, en mijn HTPC gaat nu aan via WOL (schrijf ik later meer van) ipv IR ook mede om dit probleem te ondervangen. De rest gaat met mij ook aan/uit maar dan via CEC.
  • tobasfxp
Donderstraaltje schreef op woensdag 1 oktober 2025 @ 16:51:
Klopt !
Het IR signaal voor mijn KPN STB (Arris VIP-5202) is een toggle, dus geen apart aan of uit signaal.
Nu heb ik de IR codes van de Arris VIP 2952 gebruikt, omdat de ik geen codes van de 5202 kon vinden en ook het IR signaal niet geleerd kon worden (AB is waarschijnlijk bluetooth)
  • Donderstraaltje
Donderstraaltje
tobasfxp schreef op woensdag 1 oktober 2025 @ 17:08:
Klopt !
Heb even lopen googlen, maar het lijkt erop dat de Arris VIP-5202 wel op poort 80 luistert maar dichtgezet is.
Wat je zou kunnen doen; Probeer eens via je modem (of sticker onder de Arris) te kijken of je het MAC adres kunt achterhalen? Wellicht staat WOL open. Heb hier buiten PC's geen ervaring mee. Dan kun je via WOL voor aan en IR voor uit differentiëren.
Heb zelf om volledige controle te kunnen hebben nog altijd die HTPC. Juist omdat het altijd te maken is en ik voordelen heb die met de STB tegenwoordig zijn afgenomen zoals vooruit/terugskippen op bepaalde zenders en opnemen zonder reclames met daarbij onbeperkte houdbaarheid. Ben erg blij dat mijn Live TV (heb geen streamingsdiensten) setup nu voor 99% werkt zoals gewenst; laatste 1% kan (nog) niet. Muziek streamer gedeelte wordt nog wel een uitdaging.
Als laatste wat nog een optie zou kunnen zijn, en dat moet dan een aangevraagd worden als request, is via een product als dit; https://www.amazon.nl/afs...uiting/dp/B0CLDMCV6B?th=1
Hiermee kun je een oogje IR signaal via HDMI mee laten lopen. Als hack kun je het volgende doen indien er support is; 3,5" audiojack kabel in de hub, deze in dit stekkertje, en stekkertje in een receiver of TV. In de plaats van een IR signaal te sturen kan dan een CEC een signaal gestuurd worden. Ik heb zo iets gedaan en waarom is voor hier een te lang verhaal. Vereist ook wel de nodige kennis helaas.
Maar ik denk dat het nu niet anders kan want dat kastje is helemaal dichtgetimmerd.
  • tobasfxp
Donderstraaltje schreef op woensdag 1 oktober 2025 @ 18:04:
Thanks !
Ik kan van het weekend weer aan de slag, en zal kijken of ik de WOL aan de praat krijg.
  • SunBeech
@nklerk : Ik gebruik jouw Unfolded Circle app voor Homey. Bedankt in ieder geval voor het ontwikkelen hiervan! Erg fijn dat er een integratie voor Homey bestaat.
Een paar vragen:
  • Klopt het dat deze app (vooralsnog?) alleen apparaten met een aan/uit capability beschikbaar maakt aan de Remote 3 (zoals slimme stekkers)? Naast uiteraard flows die starten met de ALS-kaart uit jouw app. Ben je van plan om ook sensoren beschikbaar te maken?
  • Wat betreft verlichting: ik heb een 'domme' lamp gekoppeld met een slimme tussenstekker, die ook kan dimmen. Ik had begrepen dat de Remote 3 voor dimbare lampen over een slider control beschikt, waarmee je het dimpercentage runt regelen. In mijn geval zie ik als control door deze lamp alleen een aan/uitschakelaar in de Remote 3. Hoe krijg ik de dimfunctionaliteit beschikbaar in de Remote 3?
  • nklerk
SunBeech schreef op vrijdag 3 oktober 2025 @ 17:00:
Een paar vragen:
De integratie ondersteund aan/uit, sterkte , hue, kleur verzadiging en kleur temperatuur. Voor lampen.
Naast lampen worden er veel meer device typen ondersteund.
Ik moet kijken welke functies en van een schakelaar worden ondersteund. Ben ik nu niet toe instaat.
Dimmen is een functie die niet “gebruikelijk” is bij een schakelaar aangezien deze toepassing enkel werkt op een deel van de lampen en zelfs schade kan aanrichten aan andere type apparaten. Daarmee vermoed ik dat ik dim niet heb bedacht mee te nemen in de ondersteuning, maar dit moet ik valideren.
Wat ook zou kunnen is dat de functie in de homey driver een niet gereserveerde parameters gebruikt maar door de ontwikkelaar zelfbedachte oplossingen.
Lang verhaal kort: ja dimmen word normaal ondersteund, in specifieke gevallen niet, daar kan ik wat aan doen.
  • tobasfxp
Dit weekend geprobeerd om WOL aan de praat te krijgen, maar deze optie staat niet open op de Arris.
Nu de switch tussen de activiteiten met een tussenstop aangemaakt
Activiteit 1 aan --> Activiteit 1 uit --> Activiteit 2 aan
Dit werkt goed voor nu.
Alleen merk ik dat als je in een activiteit 2 IR commands plaatst, je er een delay tussen moet zetten anders voert hij bij mij maar 1 command uit.
  • Donderstraaltje
Donderstraaltje
tobasfxp schreef op maandag 6 oktober 2025 @ 08:46:
Mooi! Hier ook dichter bij mijn ideale setup gekomen dus daar plaats ik met ter tijd nog een update van. Loop nu nog met de kodi addon te klooien want ik krijg geen custom commands gestuurd. Als iemand weet hoe dat moet houd ik me aanbevolen… via discord kom ik er gewoon niet uit.
Integrations updaten vind ik tot op heden nog het aller frustrerendste van allemaal.
  • nklerk
Het niet ondersteunen van discrete IR commands zou je het liefst van tevoren willen weten. Mijn Huidige TV ondersteund geen discrete Power ON/OFF en geen Discrete Inputs. Je staat gelijk 3-0 achter als je wat wil automatiseren.
Als je geen delay's gebruikt dan worden de ir commando's direct achter elkaar afgevuurd. 9 van de 10 gevallen zal je een delay willen plaatsen om dat de ontvanger nog niet klaar is voor het volgende signaal.
  • Malignant
  • Laatst online: 27-11 08:38
Sinds afgelopen weekend ook mijn R3 binnen gekregen.
Moet zeggen dat in basis alles best lekker werkt.
Duurde bij mij helaas even voordat ik in de gaten had dat mijn gemaakte activiteiten als "entitty" aan mijn hoofdscherm moesten worden toegevoegd. Heb me helemaal kapot lopen zoeken hoe ik een activiteit op het scherm moest krijgen :)
Maar toen ik dat in de gaten had ging het best vlot en het werkt voor mij best goed, maar helaas moet ik nog wat eigenaardigheden er uit zien te krijgen voordat vrouwlief het gaat accepteren.
De belangrijkste issue waar ik momenteel tegenaan loop is het niet goed functioneren van de Odido TV box.
Met de originele Odido BT AB kan je de fast forward or rewind knop ingedrukt houden en dan gaat de box spoelen.
Maar ik krijg dit gedrag niet gedupliceerd naar de R3. Het enige wat ik er in krijg is een korte of lange druk op de knop, maar geen 'knop vasthouden' gedrag.
Doe ik hier iets verkeerd en heeft iemand dit wel werkend gekregen ?
LG OLED 55C7 - Denon AVR X6300H - 2x Focal 816W - Focal 800CC - 2x Focal 800SR - 4x Focal IC105 - SVS SB-2000 - MB Next - Playstation 5 - Oppo UDP-203 - Rega RP1 + Elys 2 - BlueSound
  • Pierre
Pierre
Van nature lui!
Het hoort hier niet thuis maar die van mij is vandaag verzonden, volgende week dinsdag komt die binnen.
  • Donderstraaltje
Donderstraaltje
Een korte maar toch:
Dock 3: Beta Release 0.8.1
Changed
Increase of overcurrent limitation to 2000mA (#41).
  • Malignant
Inmiddels afgelopen weekend een tweede poging gedaan om de AB in te stellen.
Was niet tevreden met het eerste resultaat, dus een volledige reset gedaan en weer opnieuw begonnen.
Eerste keer probeerde ik met zoveel mogelijk integrations op de AB te werken, maar dit leverde vooral met KODI heel onbetrouwbare resultaten op.
Nu de tweede keer probeer ik het geheel vanuit HA te benaderen, dus ook vanuit HACS de koppeling geinstalleerd. Moet zeggen dat dat het leven een heel stuk makkelijker maakt om vanuit HA de entities te pushen naar de AB.
Maar helaas levert dit ook niet het gewenste resultaat op. Probleem zit hem in de Power on / Power off acties die uit de activiteiten komen. Deze reageren extreem onbetrouwbaar helaas en het is 50/50 of het apparaat wel of niet aan gaat. Maar als het goed gaat werkt het wel allemaal, enkel is het door de lage betrouwbaarheid gewoon niet te doen. Stomme is dat de diverse scripts in HA wel getriggered worden voor het verturen van de magic packets voor WOL.
Dus van het weekend nog maar een keer proberen en dan maar naar ouderwets IR helaas.
Kijken of met name de LG TV en Minix/Kodi box dit wel leuk vinden. Mijn Denon werkt wel gewoon perfect met IP control.
  • Donderstraaltje
Donderstraaltje
Malignant schreef op woensdag 12 november 2025 @ 09:11:
Als ik het al niet eerder geschreven had, meende het wel, belangstelling voor met welke stappen ik het met Windows met daarop kodi werkend gekregen heb? Mijn WOL is 100% betrouwbaar hoewel ik hoorde dat het soms ook aan de biosversie en/of moederbord ligt.
  • JAM
  • Laatst online: 21-09 14:53
JAM
Malignant schreef op maandag 27 oktober 2025 @ 15:05:
Bij de Remote 3 (ik heb em zelf nu ongeveer een maand) werkt het herhalen van een code, zoals rewind/fast forward alleen als de knop niet dubbel geprogrammeerd is. Om een code te laten herhalen moet het commando vastgelegd worden onder 'Short Press' en dus niets onder 'Long Press'. ;)
  • JAM
JAM
Bij mij heeft het ook even geduurd voordat ik erachter kwam dat de commando's 'Power on' en 'Power off' in een vast formaat in de On- en Off-sequences moeten staan en hoofdlettergevoelig zijn.
In de On-sequence moet er een 'POWER_ON' (of 'Switch on' voor integraties) opgenomen worden voor elk apparaat met, waar nodig, een delay ertussen.
In de Off-sequence moet er een 'POWER_OFF' (of 'Switch off' voor integraties) opgenomen worden voor elk apparaat.
Als het te schakelen apparaat alleen een power toggle heeft, dan moet je daarvoor dus een 'POWER_ON' en een 'POWER_OFF' aanmaken, met onder beide hetzelfde toggle-commando.
  • Malignant
JAM schreef op vrijdag 14 november 2025 @ 23:07:
Inmiddels ben ik er achter dat dit een issue is met de Android TV integration zelf.
Die kan alleen maar een short press of long press registreren.
Geen Press and hold.
Dit staat op de issue lijst en wordt vermoedelijk met een volgende update gefixed.
Het herhalen van het short press commando werkt in dit geval helaas niet, ik moet echt een press and hold functie hebben anders wordt de FFWD niet correct getriggered.
Maar dank voor de input :)
  • Malignant
Inmiddels weer een weekje verder en begint te wennen.
Power issues met mijn LG TV opgelost door via HA gewoon een repeat op het commando van de Magic Packet te zetten. Hierdoor gaat de TV in ieder geval altijd aan.
Android integration draait ook stabiel de laatste week. Zondag een update geweest maar die heb ik nog niet geinstalleerd.
Moet enkel zeggen dat de accu echt wel een dingetje is inderdaad. Met prevent sleep af en keep wifi connected on heb ik het gevoel dat het niet heel lekker werkt. Dus ik heb voor de activiteiten waar de TV bij aan staat prevent sleep aan. Na een middag/avond thuis van ~1700 tot 2100 ben ik dan gezakt van 100% tot 60%. Geen enkel probleem want 's avonds gaat de AB toch in de lader.
Maar daar heb ik helaas wel wat issues gehad, vanochtend weer. Gisteren avond er in gezet, dock geeft aan "charging" en bij oppakken deze ochtend gaf de AB ook 100% aan. Maar toen ik het nieuws gekeken had en hem weer terug in de dock wou zetten had ik nog maar 17% over. Lijkt er dus op dat hij niet geladen heeft vannacht, en dit is nu al de 2x keer dat me dit overkomt......
  • Pierre
Pierre
Van nature lui!
Sinds een paar weken is de mijne ook binnen, hij ligt nog in de doos te wachten tot ik een keer tijd heb.
Binnenkort eens kijken of ik alles op de juiste manier aan de praat kan krijgen.
Dit is de hardware die ik heb staan:
  1. Samsung Soundbar
  2. Sony TV
  3. Shield TV
  4. Ziggo Next
Met name Ziggo schijnt nog al een dingetje te zijn, zijn er mensen hier die het via HA voor elkaar gekregen hebben.
  • Malignant
Zelf geen Ziggo meer dus kan niet testen.
Integration voor op de remote : https://github.com/mase1981/uc-intg-horizon
HACS Integration : https://github.com/Sholofly/lghorizon
  • Pierre
Pierre
Van nature lui!
Malignant schreef op dinsdag 25 november 2025 @ 11:02:
Ik moet er eens goed voor gaan zitten thanks voor de tips
  • Mozart
  • Laatst online: 10:26
Werkt de remote ook samen met de KPN tv boxjes die via bluetooth bedient moeten worden?
PSN: PcDCch
  • Malignant
Mozart schreef op dinsdag 25 november 2025 @ 12:49:
KPN weet ik niet, maar heb zelf een Odido box (AndroidTV) en die heb ik gewoon gekoppeld via BlueTooth en dat werkt. Als ik dan de activiteit "TV Kijken" aan heb staan zitten er diverse commando's gemapped als BT commando en sommige via IP Control. Werkt lekker door elkaar.
  • Malignant
Nieuwe beta 2.7.2
Beta Release 2.7.2
This update adds touch slider configuration, sensor widget support and contains many smaller fixes and improvements.
Known issues:
Fixed
Remote 3:
Reduce accidental wakeups while the "keep WiFi connected during sleep" option is enabled.
Remote Two: WiFi initialization issue with 2.7.0. The update will be rolled out after more testing.
Allow minimal screen brightness setting of 5% (#672).
Visibility of software update icon in the status bar.
Failed macro sequences not shown.
Wifi network list empty during dock setup.
Popup menu trims text for long text items.
Allow popup menu titles to wrap into two lines.
Web-configurator: improved widget rearrangement in UI grid.
Android TV integration:
Potential reconnection failures in some scenarios. Contributed by @albaintor, thanks! (integration-androidtv#83).
Crash when Chromecast publishes an artwork. Contributed by @albaintor, thanks! (integration-androidtv#99).
Apple TV integration:
Missing state information and state information not clearing in some cases. Contributed by @henrikwidlund, thanks! (integration-appletv#66).
Filtering of whitespace characters that can't be rendered (integration-appletv#75).
Denon AVR integration:
"Eco off" command text in remote-entity UI screen.
Volume commands in http-mode.
Quick/smart select.
Added
Touch slider configuration support (#474).
Available configuration options for supported entities:
Media-player: volume or seek
Light: brightness
Cover: set position
Sensor widget support for activities (#291).
Web-configurator:
Copy-paste support for button mapping (#630).
Ability to run activity sequences and macros (#598).
Logout option in hamburger menu.
Discrete commands for stereo and mono by @henrikwidlund (integration-denonavr#132).
Support for more commands: Dolby Atmos Toggle, Page/Ch Up/Down, Input Mode (Select, Auto, HDMI, Digital, Analog), new Marantz commands by @henrikwidlund (integration-denonavr#122, integration-denonavr#133.
Changed
Notify before starting an activity if an integration is not ready.
Notify with option to try again if command fails due to device not being ready.
Charging screen shows up when a power supply is detected with additional information if the device is charging or just being supplied with power.
The web-configurator IP address is shown by default instead of hostname.
Improved sensor UI layout.
Web-configurator:
Revised command selection dialog so it's easier to see commands for just one entity.
Button mapping popup: the whole line is clickable instead of just the icon.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.7.3
This patch release fixes a web-configurator regression in 2.7.2 that blocks adding new UI widgets.
Known issues:
Fixed
• Sensor value not shown within activity.
Web-configurator:
• Adding a widget does not open in the remote UI editor.
• Possible fix for scrolling window inside seqence-list is not possible (#693).
• Artwork not always being cleared (integration-appletv#79).
Changed
• Improved media image loading.
  • SunBeech
@nklerk Ik begrijp dat de laatste beta versie van de Remote 3 ook de weergave van sensorwaardes ondersteunt. Vooralsnog lijkt dit te zijn voorbehouden aan sensoren in Home Assistant. Is een dergelijke ondersteuning van sensoren in Homey ook gepland?
  • nklerk
SunBeech schreef op vrijdag 28 november 2025 @ 20:29:
@nklerk Ik begrijp dat de laatste beta versie van de Remote 3 ook de weergave van sensorwaardes ondersteund. Vooralsnog lijkt dit te zijn voorbehouden aan sensoren in Home Assistant. Is een dergelijke ondersteuning van sensoren in Homey ook gepland?
Ja zeker! Dit is zeker de bedoeling maar nog geen tijd gehad.
  • FireFly3k
Sinds afgelopen vrijdag heb ik mijn pre-order remote 3 + dock binnen. Het instellen is niet zo simpel als bij de Harmony, maar dat wist ik al. Het is wel leuk dat je veel meer kan instellen voor Kodi bijvoorbeeld.
Het grootste nadeel wat ik tot nu toe ben tegengekomen is dat de afstandsbediening actief moet zijn of in het dock/lader moet zitten om vanuit Home Assistant een activity aan te zetten. Dit gebruik ik om bijvoorbeeld de muziek automatisch aan te zetten als ik thuiskom. Hopelijk komt hier nog een oplossing voor. Helaas heb ik dit niet gevonden/gemist tijdens het onderzoeken naar deze remote.
Verder nog lekker alles aan het uitzoeken en configureren.
  • nklerk
FireFly3k schreef op zondag 30 november 2025 @ 21:20:
Je zou een WoL packet moeten kunnen sturen voorafgaand aan het aansturen van de remote. de WoL packet zorgt er voor dat de processor uit de slaapstand gaat. Hoe dit in Homeassistant kan weet ik helaas niet. ik weet zeker dat iemand die dit wel weet dit leest en mij aan zou willen vullen.
Ik gebruik geen Homeassistant en heb zelf geen activiteiten aangestuurd op de remote zelf in een van mijn processen dus ik kan er naast zitten. Wel heb ik heel veel WoL testen uitgevoerd het wakker worden was destijds het probleem niet. soms werdt de remote wakker zonder een WoL packet. iets dat is verholpen btw.
  • FireFly3k
nklerk schreef op dinsdag 2 december 2025 @ 15:23:
Bedankt voor de tip! Dit zou mijn "probleem" moeten oplossen. WoL vanuit Home Assistant gaat wel lukken.
  • Kenhas
  • Laatst online: 28-11 10:56
FireFly3k schreef op dinsdag 2 december 2025 @ 17:02:
Is, op het eerste zicht, zelfs redelijk simpel: https://www.home-assistant.io/integrations/wake_on_lan/
2x Marstek Venus E 5.12 v155 - CT003 V122 - BMS 216
  • FireFly3k
Het zou inderdaad simpel moeten zijn. Helaas draai ik HA in docker zonder network als host en kan je dan geen WOL versturen, maar dat is op te lossen.
De afstandsbediening begint steeds beter te werken hier. Het is soms wel een beetje zoeken waarom iets fout gaat.
  • Kenhas
Het lijkt er toch op dat er al paar tevreden gebruikers zijn. Nu nog in mijn hoofd krijgen om zoveel geld uit te geven en ik kan ook de stap zetten
FireFly3k schreef op donderdag 4 december 2025 @ 09:29:
Hoe ga je dan activiteiten starten vanuit Home Assistant? Als je al geen WOL kunt versturen, hoe ga je dan opdrachten versturen?
  • FireFly3k
Kenhas schreef op donderdag 4 december 2025 @ 10:40:
De opties die je hebt om vanuit Home Assistant de remote via WOL wakker te maken zijn volgens mij:
  1. HA OS op een raspberry pi of ander device draaien
  2. HA in docker met network_mode: host draaien
  3. HA in docker met een macvlan netwerk
De eerste 2 opties zijn makkelijker, maar ik ben voor de 3e optie gegaan omdat het beter bij mijn setup lijkt te passen (en ik nu traefik nog via docker-compose kan instellen).
Als ik de afstandsbediening via WOL wakker maak zie ik power mode niet in HA veranderen, maar ik kon wel direct een activity activeren.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.8.1
Voice is here: initial support for Home Assistant voice commands, with more options coming soon. For details, see the Using Voice Assistants support article.
Known issues:
• Beta updates for Remote Two are currently disabled. We are working on a secure upgrade path from the WiFi initialization and factory reset issue.
Fixed
• Improved media-player artwork download and display.
• Charging screen shown after reboot.
• Remote 3: pixel artifacts on the bottom of the screen that was present on some devices after the last update (#561).
Web-configurator:
• Integration state is not updated in integration screen.
• Android TV integration: Fixed infinite update of media image url update using Chromecast. Contributed by @albaintor (integration-androidtv#115).
• Denon AVR integration - a big thanks to @henrikwidlund for the contributions:
• Invalid command map and validation (integration-denonavr#126).
• Invalid send_cmd (integration-denonavr#141).
• Slow volume changes and updates when using http mode (integration-denonavr#42, integration-denonavr#135).
• Added rate limiter to avoid commands from timing out (integration-denonavr#145).
• Power off command in remote-entity returns an error.
• Guard against decrease/increase volume outside valid volume range (integration-denonavr#149).
Added
• Initial voice assistant support with Home Assistant.
• Voice support for Android TV will follow soon.
• Multiple voice assistants are supported, with the option to use a global voice assistant and an individual one per activity.
• Microphone access is now available to 3rd party integrations.
• Command retry after wakeup. Wakeup window is configurable in Power Saving settings on the Remote.
Changed
• Increased speaker volume for voice assistant speech feedback. This also affects the current volume setting for sound effects.
• Replacing all non-printable whitespace characters in media information fields with a normal space.
• Filter out all emoji characters in media information fields until we have full emoji support. This makes displaying YouTube video titles endurable again :-)
• Disabling certificate validation for media-player artwork download. Unfortunately we can't convince everyone to use valid certificates for their self-hosted services.
Web-configurator:
• Showing a sensor widget placeholder icon in the UI grid if the sensor doesn't have a label, value and unit.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.8.2
Android TV voice commands, Denon/Marantz AVR sensors and many small bug fixes.
Known issues:
Fixed
• Same sensor value shown for all sensors.
• Custom sensor label shows "Custom".
• Invalid status message showed after voice assistant finished processing the command.
• Various activity handling fixes and improvements.
• Entity name missing when starting activity for first time (#724).
• Displaying invalid media player state.
• Media image not shown on main page entities.
• Touch slider commands are sent even when entity is unavailable.
• Voice UI lets button presses through to the background.
• Processing of different audio stream formats for developers of third-party voice assistant integrations.
Web-configurator:
• Performance improvements for editing button mappings, UI widgets, activity- and macro-sequences.
• Media-player seek command returning an error when used in a UI widget.
• Connection / sleep status check after sleep timer expires.
• Improvements to sensor display.
• Sensor entity filter removed from activities and macros. Sensors do not need to be included and cannot execute commands.
• Handle timeout event when starting an activity- or macro-sequence.
• Improved activity- and macro-sequence layout for commands with parameters.
Added
• Google voice commands (integration-androidtv#120).
• New FULL_SCREEN command in Dune HD Homatic Profile (integration-androidtv#125).
• Denon AVR integration: sensors to get an easy overview of the current volume, sound mode, the current input source and mute state. Contributed by @henrikwidlund (integration-denonavr#146, integration-denonavr#169).
• Additional sensors are available when using Telnet (not all receivers support all values):
• Dimmer status (the dimmer mode of the unit's display)
• ECO mode (Auto, On, Off, note that Auto will remain even if the volume is increased above -30db)
• Sleep timer (how long it's left until the device will power down)
• Audio Delay (shows the amount of ms audio is delayed to match the video)
• Audio Signal (Dolby Digital, DTS etc)
• Audio Sampling Rate (48 kHz etc)
• Monitor output (the port currently used to output video)
• Video signal in and out (4K24 for example)
• Channel input/output info (5.1, 7.1.4 etc)
• HDR format (HDR10, Dolby Vision)
• Pixel depth (8-bit, 10-bit, 12-bit)
• Max FRL
• Max Resolution and Bandwidth (4K18Gbit)
Changed
• Maximum sequence runtime extended to 5 minutes (#137).
• Android TV integration: optimized Plex artwork image loading with Chromecast feature (integration-androidtv#80, integration-androidtv#113).
• Apple TV integration: improved reconnection logic (integration-appletv#80).
• Improved log integration with log level filters for DBeta Release 2.8.2
• Android TV voice commands, Denon/Marantz AVR sensors and many small bug fixes.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.8.3
New Select entity and bug fixes.
Known issues:
Fixed
Web-configurator:
• Potential fix for IR commands no longer showing in activity sequences (#738).
• Not all entity states were updated in the integration screen.
• A busy indicator is shown until the log download starts.
• Inconsistent sample rate values (integration-denonavr#174).
• Slow volume response on AVRs not supporting advanced video queries (integration-denonavr#175).
Added
• New Select-entity with a new UI-widget.
• Home Assistant integration: support Select entity and input select.
Changed
• Improved battery level reporting (#708).
• Prefer IPv4 for external integrations (#734).
• Show more detailed error reasons for integration errors.
  • Malignant
Kijk, de Denon fix is er eindelijk. Hopelijk kan ik het volume weer normaal regelen nu.
Moet wel zeggen dat ik het packagen van integrations in de FW niet echt een slimme zet vind.
De fix voor de Denon problemen was er al binnen een paar uur na overleg met de developer hiervan, maar dik een week moeten wachten op een officiele FW update voor de uitrol. Gekoppelde integrations zijn volgens mij niet handmatig te updaten.....
  • Donderstraaltje
Donderstraaltje
Voor R2 users;
The first update will be 2.6.13. For R2s already on 2.7.0 will skip the first update and directly get the 2nd 2.8.x. Both updates will include the updated recovery system. Only downside is a slightly larger update. We'll also soon use a CDN for faster OTA updates, but can't promise if it's already enabled for the first rollout.
en;
The 2.6.13 update for Remote Two will be available on the beta OTA channel starting at 15:00 CET (in about 16min).
Please make sure to create a backup in the web configurator before installing.
The initial rollout is limited to 20 devices located in the Netherlands, Denmark, and Germany (based on GeoIP).
This update is functionally identical to 2.6.12, but includes a new recovery system. The factory image stored on your device remains unchanged.
We’d appreciate it if you could share quick feedback in this channel once the update completes successfully — this will help us safely extend the rollout to more devices and regions.
en;
The Remote Two 2.6.13 update is available for DE, NL, DK, AT, BE, FR, IT, FI, NO, SE since this morning.
So far everything looks good. Until tomorrow morning we should have 60 installations and can hopefully enable it for everyone.
[ Voor 11% gewijzigd door Donderstraaltje op 13-02-2026 18:06 ]
  • nklerk
Ik heb een zeer grote update doorgevoerd in de Homey app. deze is te vinden als testversie op https://homey.app/en-us/a....uc/Unfolded-Circle/test/
er worden heel wat nieuwe devices ondersteund zoals, blinds, curtain, sunshade, windowcoverings, garagedoor, sensors en nog een aantal
Ik hoor graag of alles werkt, of dat er issues zijn.
  • nklerk
Pierre schreef op dinsdag 25 november 2025 @ 10:44:
  1. Samsung Soundbar
  2. Sony TV
  3. Shield TV
  4. Ziggo Next
Ik gebruik deze integratie en werkt voor mij echt super! https://github.com/mase1981/uc-intg-horizon
  • Pierre
Pierre
Van nature lui!
nklerk schreef op vrijdag 13 februari 2026 @ 22:18:
Bedankt voor de link, zoals ik er nu tegen aan kijk is dat ik hem in de verkoop ga gooien. Mooi ding, maar een hele steile leercurve en daar heb ik te weinig tijd voor.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.8.4
Many small bug fixes in the web-configurator, option to disable the activity readiness check and additional sensor- and selection support in the Denon AVR integration.
Remote Two updates will be rolled out shortly.
Known issues:
Fixed
Web-configurator:
• Grid size in remote- and activity-page reset to default 4x6 size when renaming page (#626, #655).
• Improved sensor values display.
• Improved pre-selection of input fields for direct text entry.
• Entity list does not refresh in the "customize your remote" view.
• The light-entity "set color" command is displayed incorrectly during sequence execution.
• Continuous firmware update checks.
• Correction of the error response when a firmware update was started multiple times.
• Denon AVR integration: media-player dependency no longer required for mute toggle to work in remote entity. Contributed by @henrikwidlund (denonavr#179).
Added
• Option to disable the activity readiness check (#753).
• Add support for colorspace sensors. Contributed by @henrikwidlund (denonavr#177).
• Add support for Select entity types. Contributed by @henrikwidlund (denonavr#178).
• Sound Mode
• Input Source
• Dimmer
• Eco Mode
• Monitor Output
• Dirac Filter (if supported by the device)
• Speaker Preset
• Reference Level
• Dynamic Volume
Changed
Web-configurator:
• List pagination settings are now saved in the user session (#430, #697).
• Renamed generic toggle button command based on entity type.
• Android TV integrations: updated libraries
• Sort the available apps by name. Contributed by @henrikwidlund (appletv#101).
• Updated libraries (appletv#95).
• Content Delivery Network support for future updates.
  • SunBeech
nklerk schreef op vrijdag 13 februari 2026 @ 22:08:
Dank voor het toevoegen van sensoren!
Afbeeldingslocatie: https://tweakers.net/i/W0lS058bvFIjRK6OGtq42BetjO8=/x800/filters:strip_icc():strip_exif()/f/image/7zsqx5TOIRwxtnevLXaUnE1J.jpg?f=fotoalbum_large
  • SunBeech
@nklerk : M.b.t. sensoren blijkt dat sensoren van een virtual device (zoals temperatuur- en luchtvochtigheidssensoren) niet doorkomen via de integratie naar de afstandsbediening.
Ik heb bijvoorbeeld een Tuya-gebaseerde sensor, die Homey niet standaard ondersteunt, maar waarvoor ik wel de waardes (temperatuur, luchtvochtigheid, batterijniveau/-alarm) kan ophalen. Ik gebruik een Advanced Virtual Device voor het weergeven van die waarden (gebaseerd op de standaard capabilities voor temperatuur, luchtvochtigheid en batterijpercentage en -alarm).
Het lijkt erop dat de Unfolded Circle app voor Homey virtuele apparaten negeert. Is dat een bug of wellicht iets dat je nog van plan bent om toe te voegen?
  • nklerk
SunBeech schreef op maandag 9 maart 2026 @ 12:50:
Ik denk dat het geen bug betreft maar een gevolg dat ik enkel een selectie laat zien van devices welke ondersteund worden. Help mij naar de aankomende versie herinneren mocht het dan niet wel werken. Ik heb deze versie in test staan maar de volgende versie staat ook al klaar om te gaan gaan testen maar moet nog even wachten voor dat ik deze kan vrijgeven. Dus tegen de tijd dat ik weer verder kan is de kans groot dat ik het ga vergeten. Om het op voorhand goed te maken :-D hier een kleine teaser....
Afbeeldingslocatie: https://tweakers.net/i/QDITY3hUWESVGNx9vKHA4tK8bhU=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/jX7cLQM9COSukXuZqKuk02aW.png?f=user_large
Afbeeldingslocatie: https://tweakers.net/i/KyaV3PyM_7ydT93sJ8sIt5-2SPQ=/800x/filters:strip_exif()/f/image/HjhiTHC9iEUNVpBPcYsWQ2bj.png?f=fotoalbum_large
  • SunBeech
nklerk schreef op maandag 9 maart 2026 @ 20:05:
Nice! Meer info over de UC docks/afstandsbedieningen en aansturing van de afstandsbediening met nieuwe flowkaarten, zo te zien :).
  • nklerk
SunBeech schreef op dinsdag 10 maart 2026 @ 10:51:
het is de bedoeling dat je de dock vanuit Homey kan aansturen en dus IR signalen kan sturen of de afstandsbediening opdracht geeft om dingen uittevoeren. dus het starten van een activiteit of een commando te versturen. het mooie is is dat hij netjes de remote wakker maakt om het te sturen. technisch super cool. Het zijn wel edge cases maar goed. het kan technisch dus heb ik het gebouwd :-D
  • Clarijs
  • Registratie: Juli 2015
  • Laatst online: 28-11 15:08
Ik heb voor openHAB een integratie gemaakt (installatie op openHAB server, niet op de remote)
In het kort, ondersteunt deze integratie:
  • UC remote gebruiken om openHAB (items) aan te sturen
  • starten van UC remote activities vanaf openHAB
  • wisselen tussen UC remote profiles met openHAB
  • voice control met UC remote
  • alle UC docks gebruiken met alle UC remotes
Voor meer informatie kun je mijn post op op de openHAB community lezen (hierin ook de links naar de github resources)
https://community.openhab...system-integration/168770
Met de integratie zijn veel scenarios te bouwen, die ik niet allemaal zelf kan verzinnen en testen. Dus graag feedback en bugmeldingen!
  • SunBeech
nklerk schreef op dinsdag 10 maart 2026 @ 17:08:
@nklerk : Ik zie dat vandaag de 2.0.0 testversie is geïnstalleerd op mijn Homey, met de nieuwe functies :) .
Ik probeer mijn Dock 3 toe te voegen in Homey, maar de UC app vaagt mij dan om een pincode (van de dock). Mijn dock heeft wél een wachtwoord, maar geen pincode, zover ik weet. De instructie geeft aan dat ik die kan vinden in de webconfigurator en dan bij Integraties/Dock. Ik vind daar echter geen pincode. Wel de instelling van mijn wachtwoord.
Waar vind ik de pincode van mijn Dock 3?
  • Clarijs
SunBeech schreef op zondag 15 maart 2026 @ 20:32:
Als je het nooit heb ingesteld, is default pincode van docks 0000
  • SunBeech
Clarijs schreef op zondag 15 maart 2026 @ 20:57:
Die code werkt helaas niet. Heb ook nooit een PIN ingesteld. Wel een wachtwoord tijdens de oorspronkelijke installatie. Ik kan in de webconfigurator ook geen optie vinden om een PIN specifiek voor de dock in te stellen.
Weet je wellicht waar je die kunt instellen/terugvinden?
  • nklerk
Probeer eens 0000 ik stel hem zelf nooit in nml
  • nklerk
SunBeech schreef op zondag 15 maart 2026 @ 21:32:
Ik moet zelf ook eens goed in de documentatie duiken om te onderzoeken hoe het ook alweer wekt :-D. Mocht je eerder een oplossing hebben dan hoor ik het graag.
  • nklerk
Het was mij niet eerder gelukt om een beetje achtergrond info te geven over de aanpassingen en wijzigingen in de Homey App (2.0.0)
De Homey integratie kan nu Voice commandos van de remote afhandelen door speech to text (STT) toe te passen. Ik heb meerdere AI mogelijkheden ondersteund waaronder een EU en GDPR vriendelijke, een offline en de meest bekende online diensten. zelf heb ik veel getest met Gemini. (is gratis en werkt erg goed)
De tekst kan in homey gebruikt worden. zo kan je je eigen Siri in elkaar knutsellen. (de flow kaart staat onder de app. niet onder een device.)
De Remote en Dock zijn nu toe te voegen aan Homey. je kan nu in flows beide apparaten aansturen en of uitlezen.
Verder zijn er een hele sloot aan Homey devices en sensoren beschikbaar gesteld van Homey aan de remote.
Ik heb nog niet alle features door en door getest dus ik ga er vanuit dat er issues in zitten. om dit kanaal vrij te houden van troep graag mij even een DM sturen als je tegen iets aanloopt.
## [2.0.0]
### Added
- **UC Dock driver** — Control your Unfolded Circle Dock (UCD3) as a Homey device. Discover docks via mDNS-SD, pair using the token PIN code, and control LED brightness via the `dim` capability.
- **Flow action: Send IR code (dock)** — Send an IR code (HEX or Pronto format) from a dock output port.
- **Flow action: Identify dock** — Blink the dock LEDs to identify the device.
- **Flow action: Enable/disable IR learning mode (dock)** — Start or stop IR learning mode on the dock.
- **Flow action: Reboot dock** — Reboot the UC Dock.
- **Flow trigger: IR code learned (dock)** — Triggers when a new IR code is learned, with `ir_code` and `ir_format` tokens.
- **Flow action: Run macro** — Run a macro on the UC Remote with autocomplete selection.
- **Flow action: Remote system command** — Send a raw system command (e.g. `RESTART_UI`, `REBOOT`) to the UC Remote.
- **Flow trigger: Entity state changed** — Triggers when any entity's state changes on the UC Remote (real-time via WebSocket). Optionally filter by a specific entity using autocomplete.
- **Real-time entity state WebSocket** — Persistent WebSocket connection to the UC Remote Core-API receives entity state change events instantly, keeping flow triggers responsive without polling.
- **Profile management** — Switch the active user profile on the UC Remote from Homey.
- **Flow action: Switch profile** — Switch to any profile on the remote using an autocomplete dropdown. Automatically restarts the remote UI so the change is immediately visible.
- **Active profile in device settings** — The currently active profile name is displayed as a label in the remote's Advanced Settings and is updated on every poll cycle.
- **Device status capabilities** — Three new selectable status items appear on the UC Remote device tile:
- **Active Profile** — Displays the name of the currently active user profile.
- **Connection Status** — Shows `Connected` or `Standby`, updated instantly on wake/sleep events.
- **Charging** — Was already present as a boolean sensor; now explicitly included in the status selection.
- **Flow condition cards (And)** — Nine new condition cards for the UC Remote:
- **Activity is active** — Check whether a selected activity is currently running (cached, updated via WebSocket).
- **Active user is** — Check whether the active profile matches a selected profile (cached, updated on poll).
- **Battery is charging** — Check whether the remote is currently charging.
- **Remote is connected** — Check whether the remote is online.
- **Remote is in standby** — Check whether the remote is in standby.
- **Lux is greater than / less than** — Compare the current ambient light level against a threshold.
- **Battery level is greater than / less than** — Compare the current battery percentage against a threshold.
- **Activity & profile state caching** — Activity states and the active profile ID are cached in memory. Condition cards read from cache (no live API call). Cache is refreshed on every poll cycle and activity states are kept live via the event WebSocket.
- **Redesigned settings page** — Complete UI overhaul. The settings page now reflects the full UC integration scope (not just voice). New 4-tab layout: Overview, Voice Settings, Help, and Logging.
- **Overview tab** — Feature cards for Remote Control, Voice Commands, Homey Entities, and Flow Triggers. Quick-start steps.
- **Help tab** — In-app documentation with 6 sub-pages: Getting Started, Remote Setup, Add to Homey (pairing UC Remote/Dock as Homey devices), Voice Setup, Entities & Flows (add/remove entities via remote or web configurator), and STT Providers.
- **Logging tab** — Live log viewer with HH:MM timestamps, per-level color coding, and auto-refresh toggle.
- **STT model selection** — Voice Settings tab now includes a model selector that dynamically populates available models for the selected provider. Selected model is persisted to Homey settings and passed to the STT provider on every transcription.
- **STT provider comparison table** — Quick-reference table in the Help → STT Providers sub-page showing cost, free tier, and notes for all supported providers.
- **UC logo in settings header** — The app header icon now uses the actual Unfolded Circle brand mark.
### Fixed
- **Run macro command** — Fixed incorrect `cmd_id: 'on'` for macros; now correctly uses `cmd_id: 'run'`.
- **Pairing device list** — Fixed `ReferenceError` caused by undeclared `devices` variable in the driver's `onPairListDevices` method.
- **Entity cache pagination** — Entity cache is now populated using paginated API calls (max 100 per page) to correctly handle remotes with more than 100 entities.
- **Voice transcription audio format** — WAV header is now built using the actual sample rate, channel count, and bit depth advertised by the remote in the `voice_start` `audio_cfg` message, eliminating sample rate mismatches that caused inaccurate transcriptions.
## [1.4.0]
### Added
- **UC Remote driver** — Control your Unfolded Circle Remote as a Homey device. Discover remotes via mDNS-SD, pair using the web-configurator PIN code, and monitor/control power state, display brightness, battery level, battery alarm, ambient light, and charging status.
- **Smart standby detection** — 3-layer wake detection using UC integration Connect events (instant), heartbeat polling (30s), and mDNS discovery announcements. Automatically transitions between normal polling and standby heartbeat mode.
- **Wake-on-LAN** — Turn on the remote from Homey by sending a WoL magic packet. MAC address is resolved via ARP or the remote's network API.
- **Custom `charging` capability** — Boolean sensor indicating whether the remote is currently charging, with Insights support.
- **Flow action: Send entity command** — Send any command to any entity on the UC Remote, with autocomplete for both entity and command selection (commands derived from entity features).
- **Flow action: Start activity** — Start an activity on the UC Remote with autocomplete selection.
- **Flow action: Stop activity** — Stop a running activity on the UC Remote with autocomplete selection.
- **`ucDriver` export** — Exposed `ucDriver` instance from `uc_driver.js` for use by the new UC Remote driver's standby/wake event listeners.
  • Malignant
Beta Release 2.9.0
Media browsing, searching and playback! The Home Assistant, Roon, Roku and B&O integrations already support this new
feature and is available for 3rd party integrations. This initial release might still be a little rough and will be
improved in future updates.
Updated components:
Core 0.70.6
UI 0.71.1
Web-configurator 2.0.0-beta.56
B&O 0.2.2
Home-Assistant 0.16.3
Roku 0.3.1
Roon 0.5.1
Known issues:
Fixed
Web-configurator:
Scrolling window inside seqence-list is not possible (#693).
Activity UI edit page screen shows invalid page name if a previous error was not cleared.
Improved entity command parameter editing.
Prevent spurious reconnect screen on transient WS drops.
Various improvements and reduced runtime resource usage.
Roon integration: volume control for different volume types (roon#66).
B&O integration: removing a configured device could cause memory problems over time.
Roku integration: the setup flow could show duplicate screens or not wait for user selection.
Added
Media browsing, searching and playback support in the UI (#70).
The web-configurator will be enhanced in a future update.
Download progress for software updates in the UI.
Web-configurator:
Support optional command parameters.
Application credential management for upcoming integrations requiring OAuth 2.0 Authorization Code Grant.
This is a development feature and cannot be used yet with existing integrations.
Media browsing support in the Home Assistant and Roon integrations.
B&O integration:
Early support for Mozart platform devices. This is still a preview feature, so please contact us if you use these devices.
A guided device selection step during driver setup.
Added support for manual IP configuration.
New media controls: Stop, Shuffle, Repeat, and Select Source.
Support for browsing media.
Roku integration:
Remote control entity for discovered devices.
New sensor entities for each device.
Media browsing and play media support for supported apps and TV channels.
Media information is now more detailed, including duration, playback position, artwork, and media type, when supported by the app.
Roku TV input sources, including HDMI 1–4, AV, and Live TV.
Info command in the media-player entity.
Changed
Remote 3 display initialization adjustment after wakeup (#561).
Web-configurator:
Improved sequence command layout.
Improve IR send-command editing in activities & macros: show defined IR commands in dropdown list.
B&O integration:
Improved device discovery and command handling process.
Roku integration:
Improved setup flow with manual IP entry
  • FireFly3k
Heeft iemand het media browsen en zoeken al werkend gekregen na de 2.9.0 update? Ik heb de Kodi integration geupdate die er support voor heeft, maar ik zie geen opties oid in de configurator of op de remote zelf.
  • nklerk
FireFly3k schreef op zaterdag 21 maart 2026 @ 11:09:
Ik heb het niet nagekeken maar vermoed zomaar dat de Kodi integratie dat ook nog niet ondersteund.
  • SunBeech
Het is even zoeken, maar op de afstandsbediening moet je de Kodi media player-entiteit zelf openen. Bijvoobeeld als je in een acttiviteit zit waar die entiteit onderdeel van is.
  • Je kunt dan boven in het scherm tikken op de koptekst waar 'Tik voor meer' staat. Dan krijg je een lijst met alle in die activiteit opgenomen entiteiten;
  • Tik dan op de Kodi media player-entiteit, zodat die full screen opent;
  • Vervolgens tik je in die entiteit links onder in het scherm. Daar hoort een knop te staan, maar die zie je niet (is een bug begrijp ik). Vervogens kom je in de media browser.
  • FireFly3k
SunBeech schreef op zaterdag 21 maart 2026 @ 18:11:
"Tik voor meer" dat is hem inderdaad. Dat had ik nooit gevonden 🥲
Thanks!
  • nklerk
Met de laatste versie van de UC app en mijn AI assistent app op homey https://homey.app/nl-nl/a...erk.ai/AI-Assistent/test/ kan heb je een volwaardige AI assistent via de remote. het kan van allerlei vragen beantwoorden maar ook alle apparaten bedienen of uitlezen. Echt super cool
  • nklerk
Naast de voorgedefinieerde sensor data vanuit homey zou custom sensors nu ook moeten worden ondersteund. kan je dit controleren met versie 2.2.0?
  • SunBeech
nklerk schreef op zondag 29 maart 2026 @ 12:23:
Ik zie inderdaad meer sensoren naar voren komen in de integratie op de afstandsbediening, maar niet alle sensoren in een AVD. Ik stuur je PM met meer details.
  • Malignant
Beta Release 2.9.1
Media browsing support in the media-player UI widget, including color Emoji support for modern media titles.
Rewritten Philips Hue integration with Hue Hub Pro support, but with breaking changes - please read release notes before upgrading.
Updated components:
Core 0.71.1
UI 0.72.0
Denon/Marantz AVR 0.15.0
Home-Assistant 0.16.4
Philips Hue 0.3.2
Roon 0.6.0
Known issues:
Breaking Changes
Philips Hue is now using the new Philips Hue v2 API. The generation 1 Hue Bridge (round version) is no longer supported! (Full changelog).
An old configuration is migrated and configured lights using v1 identifiers (short numeric IDs) will continue to work.
Newly discovered lights will use v2 identifiers (UUIDs).
It is recommended to migrate to v2 identifiers by removing and re-adding lights in the web configurator.
Fixed
Sensor and select widget clipping (#760).
Media browsing pagination stopping early if no total count is available.
Retry handling when media browsing fails.
Web-configurator:
Renaming Remote pages doesn't always work.
Select-entity cannot be included when creating a new macro or activity.
Select-UI-widget without a value is not visible in UI grid.
Button mapping broken for external remote-entities. Please note that only remote-entities that provide simple commands can be edited. The generic send command is not supported (#768).
Denon/Marantz AVR fixes contributed by @henrikwidlund:
Check Dirac support when reconfiguring (denonavr#187).
Stale audio sensors on some receivers (denonavr#190).
Home-Assistant: Ignore media browse items without a title and filter out non-playable media content ids (home-assistant#93, home-assistant#94).
Roon:
Correct volume % for dB scales, use a fixed relative step of 1 (ignore reported volume step by Roon) (#769).
A failed media-player command crashed the integration (roon#70).
Stable media identifiers are only supported in media-browsing (roon#69).
Added
Noto Color Emoji font support in text fields.
Media browser and playback controls in the media widget.
Option to show the battery indicator everywhere.
Web-configurator: media browse dialog for selecting a media item for the play command.
Denon/Marantz AVR: Add absolute volume sensor. Contributed by @henrikwidlund (denonavr#189).
Philips Hue:
Hue Hub Pro support.
Support for rooms and zones. Contributed by @henrikwidlund (philipshue#49).
Manual Hue hub setup option (philipshue#39).
Roon:
Support power commands and standby detection (roon#68).
Changed
  • Donderstraaltje
Donderstraaltje
Ik zie dat anderen hier de firmware updates plaatsen; mag ik stellen dat dit definitief van me overgenomen wordt? Prima hoor
  • coptician
  • Laatst online: 28-11 17:08
Ik heb nog een Remote Two liggen die ik niet gebruik. Ik heb ‘m wel eens op V&A gezet maar zonder respons.
Mocht iemand interesse hebben, stuur me even een berichtje :).
HP Brio - Pentium iii 733 MHz - 128 MB SDRAM - 20 GB Ultra-ATA/66 - 3.5" 1.44MB FDD - S3 ProSavage 8MB graphics - 1024x768 - Windows Me
  • Malignant
Donderstraaltje schreef op woensdag 15 april 2026 @ 10:49:
No offense ment, was niet de bedoeling in iemand anders zijn vaarwater te zitten.
Deed het enkel omdat het er vanochtend niet op stond tijdens mijn rondje sites bij de koffie.
Zal me inhouden voortaan en gewoon geduld hebben.
  • Donderstraaltje
Donderstraaltje
Malignant schreef op woensdag 15 april 2026 @ 10:55:
Denk dat je het verkeerd leest en uit het verband trekt; had al eerder een oproep gedaan om mij te helpen met het topic. Een paar keer is iemand mij nu net voor geweest dus dacht; kant voortaan laten!
  • tzeunis
  • Laatst online: 25-11 19:45
Hi all,
heeft iemand een idee hoe ik een Nedis elektrisch bediende TV mount met RF kan aansturen middels de remote 2? Ik had de hoop dit met een Sofabaton U2 te doen, maar niets. Die kan het ook niet terwijl er wal staat dat deze RF kan uitsturen.
https://nedis-shop.nl/en/...vwm5880bk-vast-1-apparaat
Replacement RF remote control for your Nedis TV mount. Works wirelessly at 2.4 GHz. Compatible with 8 Nedis models. Batteries not included.
[ Voor 39% gewijzigd door tzeunis op 17-04-2026 08:45 ]
| Losing my religion |
  • nklerk
tzeunis schreef op vrijdag 17 april 2026 @ 08:20:
Hi all,
Ik ben bang dat ik je moet teleurstellen, omdat:
RF 2.4 GHz betekent zoveel als er zit een radio in op de 2.4ghz frequentie maar de communicatie is niet gangbaar. (lees geen Wifi of Bluetooth) De UC Remote gaat dat zeker niet ondersteunen en ik betwijfel of er IOT oplossingen zijn die dat wel zouden kunnen. laat staan daadwerkelijk ondersteunen. de meeste IOT oplossingen welke "RF" ondersteunen werken op 433, 868 of 915Mhz en geen 2.4Ghz. Al zou je een oplossing vinden dat RF 2.4Ghz ondersteund dan is het daarmee niet gezegd dat het de nodige protocollen van de TV mount ondersteund.
  • nklerk
Donderstraaltje schreef op woensdag 15 april 2026 @ 11:56:
Je werk en dat van de anderen wordt enorm gewaardeerd. Logischerwijs zou ik het moeten delen aangezien mijn lijntjes het kortst zijn maar mijn beschikbaarheid is extreem wisselvallig en ik lees vaak hier als eerst dat we een nieuwe update hebben _/-\o_
Ik draai doorgaans specifieke test builds waardoor ik eerder blind ben voor reguliere updates.
  • tzeunis
nklerk schreef op vrijdag 17 april 2026 @ 10:12:
Hier was ik al bang voor.. toch bedankt voor je antwoord.. baal wel enorm nu eerlijk gezegd.. misschien dan toch maar een Vogels bestellen die app controlled is..
  • nklerk
tzeunis schreef op vrijdag 17 april 2026 @ 11:12:
Als je een beetje handig bent met electronica, solderen en microcontrollers zou je een werkende afstandsbediening kunnen laten verbinden en bedienen vanuit een microcontroller. bijvoorbeeld een esp8266 of esp32. een AI kan je er stap voor stap bij helpen. een andere oplossing voorzie ik op dit moment niet. mischien dat iemand anders een geniaal idee heeft.
  • DutchKel
  • Laatst online: 07:48
Is dit niet een ander alternatief nog? https://nedis.com/en-us/p...ontrolled-abs-steel-black
Don't drive faster than your guardian angel can fly.
  • Donderstraaltje
Donderstraaltje
Van Discord, er schijnen random buttons ingedrukt te worden op het scherm...
I'm going to pin a message to this channel, and hope that people will read it. if someone asks again about the display and ghost touches, please ask them to read the pinned message
The display artifacts where the the image looks interlaced with a monotone color and ghost touches is a software issue and is being worked on. The issue has not been introdued in any recent firmware. If you've not experienced it before, then you've simply been lucky.
The issue has to do with how the display is initialized which sometimes can cause interference resulting in those two issues.
Please be patient, the issue is very difficult to fix as it is random and requires collaboration with other hardware manufacturers.
  • Malignant
Klopt, al meerdere malen last van gehad. Enige wat dan werkt is de afstandsbediening snel rebooten.
Best gevaarlijk want soms gaat hij ook aan de haal met het volume van mijn avr.
Moet zeggen dat ik met de laatste FW het (nog) niet ervaren heb.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.2
This patch update fixes a few bugs in the Denon/Marantz AVR and Philips Hue integrations.
Updated components:
• Core 0.72.0
• UI 0.73.2
• Web-configurator 2.0.1
• Android TV 0.8.4
• Apple TV 0.20.4
• Denon/Marantz AVR 0.15.1
• Philips Hue 0.3.3
Fixed
• Climate detail view showing the temperature with a wrong unit (#747).
• Color wheel sending invalid hue values and the selector escaping the circle on fast drags (#778).
• Widgets (notably the media widget) showing stale data after the remote wakes from sleep (#781).
Denon/Marantz AVR:
• Clear duplicate cache on power on and source change by @henrikwidlund (denonavr#195).
• Fix manual query of wrong events for channels by @henrikwidlund (denonavr#196).
• Philips Hue: improved color conversion using gamma decode, wide RGB D65 matrix, gamut clipping by @stakats and @henrikwidlund (philipshue#127).
• Web-configurator: US English text (core-api#83).
Changed
• Strictly validate light command parameters and attributes to prevent invalid color change commands.
• Android TV and Apple TV: updating dependencies.
Developer Notes
• Sending unsubscribe_entity events to integrations when removing configured entities.
• Update Node.js runtime to v22.22.2
• The custom integration sandbox environment now contains the ca-certificate files in /etc/ssl/certs/
Known Issues
• Automatic display brightness and button backlight settings in the UI are not yet working. They are currently disabled in the web-configurator.
• Remote 3: the ambient light sensor sensitivity will be increased with a firmware update.
Sonos integration:
• a recent speaker firmware update affects the local device API access. Connection issues might be resolved temporarily by power-cycling the Sonos device(s). We are planning a rewrite of the Sonos integration using a different API.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.3
This patch update fixes an Apple TV regression with tvOS 26.5 and fixes setup handling for custom integration drivers.
Updated components:
• Core 0.73.1[l/i]
• UI 0.73.4
• Web-configurator 2.0.2
• Android TV 0.8.5
• Apple TV 0.21.1
• Denon/Marantz AVR 0.15.2
Fixed
• Wait up to 30s for custom integrations to startup when running the integration setup (#448).
• Command retries stopping early.
• Media-widget not always showing media image (#781).
• Android TV: Homescreen app icon extraction error handling. Contributed by @albaintor (androidtv#142).
Apple TV:
• Regression with tvOS 26.5. Contributed by @albaintor (appletv#110).
• Entity state is not updated if Apple TV device disconnects. Entities will now be unavailable if there's no connection to the device (appletv#93).
• Show correct global volume setting in setup flow (appletv#125).
• Various improvements and reliability fixes (appletv#107, appletv#120, appletv#121, appletv#122).
Added
• Update option in the custom integration upload dialog. Custom integrations no longer have to be removed and reinstalled.
Apple TV:
• Add remote-entity. Contributed by @henrikwidlund (appletv#61, appletv#115).
• Select- and sensor-entities for app and sound output. Contributed by @albaintor (appletv#111).
Changed
• Security fixes.
• Updated libraries in Android TV, Apple TV, Denon AVR integrations.
Known Issues
• Remote 3 display artifacts after wakeup (#561).
• Some Remote 3 are affected by ghost touches after wakeup. This is a different issue than the display artifacts. If you have constant ghost touches, please contact support.
Sonos integration:
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.4
This patch update improves dock connectivity by replacing the mDNS IP resolving logic with Avahi.
It also fixes Dock 3 updates when multiple dock revisions are present. A separate Dock 3 update with additional connectivity fixes will be released shortly.
Updated components:
Core 0.74.0
Web-configurator 2.0.3
Apple TV 0.22.1
Bang & Olufsen 0.2.3
Denon/Marantz AVR 0.16.0
Sonos 0.4.2
Fixed
• The Remote sometimes does not display the correct battery level.
• Dock 3 update when multiple dock revisions are present.
• Include firmware and API version information in mDNS discovery data.
Apple TV:
• Fixed power state reporting, including screensaver state, for newer tvOS versions. Contributed by @albaintor (appletv#127).
• Update select- and sensor-entities when the audio output changes (appletv#128).
• Connect to newly added devices after setup completes (appletv#133).
• Security fixes.
Added
• Denon/Marantz AVR: Added support for Tactile Transducer, Room Size, Page Up/Down, Quick/Smart Select Memory, Reference Level Offset, and Tone Control. Contributed by @henrikwidlund (denonavr#203).
Changed
• Resolve mDNS hostnames with Avahi instead of systemd. This should be more reliable on certain networks.
• Touchscreen driver refinements.
• Updated display backlight control for Remote 3.
• Apple TV: reduced the number of output device combinations. Contributed by @henrikwidlund (appletv#126).
• Bang & Olufsen and Sonos integrations: only enable mDNS while searching for devices.
Known Issues
• Some Remote 3 devices are affected by ghost touches after wakeup. This is a different issue than the display artifacts. If you experience constant ghost touches, please contact support.
• WPA3 Wi-Fi security mode is not yet supported.
• Automatic display brightness and button backlight settings are not yet working in the UI. They are currently disabled in the web-configurator.
• Sonos integration: a recent speaker firmware update affects local device API access. Power-cycling the Sonos device may temporarily resolve connection issues. We are planning to rewrite the Sonos integration using a different API.
  • FireFly3k
  • Laatst online: 25-11 16:08
Ik ben al een hele tijd bezig geweest met een integration voor BluOS en denk dat ie nu goed genoeg is om te delen. De hele integration is met AI gemaakt als experiment en omdat ik zelf niet de tijd heb helaas, maar dat is misschien iets om rekening mee te houden mocht je het niet vertrouwen.
De integration kan natuurlijk alle standaard acties zoals afspelen, pauzeren, etc. Daarnaast werkt de media browser (heb het alleen met Tidal kunnen testen), auto discovery tijdens setup, presets vanuit de BluOS app, devices groeperen en nog wat dingen.
Er zijn vast nog meer verbeteringen te bedenken, maar voor mij is dit op dit moment voldoende.
Mocht je interesse hebben en het niet erg vinden dat het met AI gemaakt is, dan is ie te vinden op: https://github.com/bjekel/uc-integration-bluos
PSN - 500px - Flickr
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.5
This patch update improves the Remote 3 display driver, fixes Apple TV connection issues with multiple clients, and adds Philips Hue scene support.
Updated components:
• UI 0.73.5
• Apple TV 0.22.2
• Denon/Marantz AVR 0.16.1
• Philips Hue 0.4.0
Fixed
• Apple TV connection issues when multiple clients are connected. This regression was introduced in 2.9.3 while adding support for newer tvOS versions (appletv#134).
Denon/Marantz AVR:
• Adjusted range validation. Contributed by @henrikwidlund (denonavr#204).
• Duplicate Sound Mode entries and incorrect Mono mapping. Contributed by @mase1981 (denonavr#206).
Added
• Denon/Marantz AVR: added AVR commands, sensors, Select-entities, and remote UI pages. Contributed by @mase1981 (denonavr#206).
• Philips Hue: added scene support. Each room or zone with scenes is exposed as a Select-entity. Contributed by @stakats (hue#134).
Changed
• Improved the Remote 3 display driver. Wakeup times for the display are slightly slower to prevent sporadic artifacts after wakeup (#561).
Known Issues
  • Donderstraaltje
Donderstraaltje
There is new beta Dock 3 firmware!
Beta Release 0.10.3
Changes since the last public release, 0.8.2.
Fixed
• Improved overall stability and automatic cleanup of stuck client connections.
• Fixed support for IR codes with a data value of 0, such as the digit “0” on Philips TVs using the RC6 protocol (bug-tracker#721).
• Improved Ethernet connection reliability (#89).
• UART settings can now be changed without restarting the Dock (#84).
Added
• Added an embedded web management interface for configuring and managing the Dock from a browser (#76).
• Added support for static network configuration, allowing manual IP address settings (#81).
• Added RS232 support with an optional TCP serial bridge (#72).
• On current devices, RS232 mode is limited to port 2. Port 1 may send startup output that some connected RS232 devices could interpret as commands.
• UART TTL adapters are not supported because they use different signal levels.
• Added a new log router to improve diagnostics and troubleshooting (#77).
• Added support for learning and sending RAW IR commands (#85, #87).
Changed
• If the maximum number of client connections is reached, the least active connection is now closed automatically to allow a new connection (#58).
• Clients that do not authenticate are now disconnected after 30 seconds (#59).
• Increased the maximum number of client connections from 7 to 18 (#60).
• Unified support for firmware revisions 4 and 6 (#66).
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.6
This patch update improves the Remote 3 display driver, adds an "Off" option to the Hue scene selection, and fixes Hue hub authentication with Remote Two.
Updated components:
• Android TV 0.9.0
• Apple TV 0.23.0
• Denon/Marantz AVR 0.17.0
• Global Cache 0.1.2
• Philips Hue 0.4.1
• Roon 0.6.1
Fixed
• Denon/Marantz AVR: mute and power state handling. Contributed by @henrikwidlund (denonavr#209, denonavr#210).
• Philips Hue: hub authentication with Remote Two (#787).
Added
• Philips Hue: added an "Off" option to the scene selection. Contributed by @stakats (hue#150).
Changed
• Improved the Remote 3 display driver (#561).
• Android TV, Apple TV, Denon AVR, Global Cache, Philips Hue, Roon: updated dependencies.
Known Issues
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.7
This patch update improves Web-Configurator connectivity and login reliability, and adds offline Dock password and custom URL editing.
Updated components:
Core 0.74.1
Web-Configurator 2.1.0
Fixed
General improvements in voice streaming and Bluetooth connectivity.
Web-Configurator:
Fixed unnecessary reloads and refresh loops caused by connection events.
Improved app refresh behavior after a system update so the latest version loads more reliably.
Fixed repeated login issues by clearing stored PINs after authentication failures.
Fixed widget placement issues where widgets could incorrectly overlap.
Fixed incorrect behavior for some button list items.
Added
Added the ability to change the locally stored Dock password in the Remote and to change the custom dock URL while disconnected.
Changed
Web-Configurator:
Major rewrite of connection and reconnection handling for improved connectivity, more stable recovery after temporary network issues, and faster detection when the Remote connects or disconnects.
Improved login behavior and authentication error handling.
Improved real-time updates so device and remote changes are handled more consistently.
Improved error handling and error messages in several areas.
Known Issues
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.8
This beta update contains several major internal updates to Bluetooth, the Web-Configurator, and network handling.
If you rely on the beta as your daily driver, please be aware that this release has a higher risk of unexpected issues than a typical patch update.
Updated components:
  • Web-configurator 2.2.0
  • UI 0.74.1
  • Sonos 0.5.1
  • Bluetooth stack and daemon 0.8.0
  • System: DHCP client
Breaking Changes
  • Updated Bluetooth stack with improved security and reliability fixes.
  • Devices that were paired using the older Bluetooth pairing method (typically some older TVs) may not reconnect automatically after the update.
    If your TV no longer connects with Bluetooth after this update: remove the Remote from the TV's Bluetooth device list, then pair it again once. This is a one-time step.
    Other modern devices (like Apple TV, Chromecast / Google TV, etc.) are not affected, no action needed.
  • This update prepares upcoming enhancements for low power mode (using less battery in standby) and connected standby with paired devices.
Fixed
  • Improved "keep Wi‑Fi connected during sleep" reliability.
  • -Prevents repeated unintended wakeups in certain network environments; the device will now only wake if required for Wi‑Fi security updates (for example, WPA key rotation / rekeying). -Trade-off: if your access point restarts or significantly changes (for example, channel changes or mesh steering) while the remote is asleep, wake-over-Wi‑Fi (WoWLAN) may not work until you wake the remote manually.[/li]
  • Improved compatibility with certain routers (DHCP).
    -Helps ensure the remote keeps the same IP address after waking from sleep, reducing connection issues in some setups.
    -Eliminates rare background network errors.
  • Bluetooth: fixed a bug where the Remote could silently stop being discoverable and connectable until the next reboot.
  • Web-Configurator: Improved reliability when loading or refreshing data after temporary backend errors.
    User interface: general stability improvements and bug fixes.
    -Fixed several touch slider issues, including brightness control for dimmable lights and cases where the slider could stop responding after suspend or volume changes (#668, #685).
    -Improved media player and media widget reliability, including empty activity header widgets, missing player features, shuffle/repeat on speakers, and media browsing with special characters.
    -Fixed outdated device information after reconnects or integration reconfiguration, and profile pages failing to load.
    -Fixed several interaction issues, including repeated device names in activity errors, incorrect button handling, power-off on long press, and voice control stopping after audio playback.
    -Improved long-term UI performance during extended use.
  • Sonos: Reduced connection usage to prevent interference with the Sonos app (#258).
Added
  • A Touch Slider settings screen to adjust the slider sensitivity per use case (volume, brightness, cover position, seek) with a live test area.
  • Smoother and more precise touch slider tracking that follows your finger movement.
Changed
  • Smoother scrolling and a more responsive interface, especially while media is playing.
  • Album art loads faster.
  • Faster and more responsive touch slider.
  • Web-Configurator:
    -Major internal update to improve stability, responsiveness, and long-term maintainability.
    -Improved error handling and feedback: failed save operations and backend requests are now reported more reliably instead of failing silently.
    -Improved navigation behavior by remembering selected sub-sections when switching between configuration areas.
Known Issues
    -Remote 3: the ambient light sensor sensitivity will be increased with a firmware update.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.9.9
This beta update improves Web-Configurator reliability, Wi‑Fi behavior after standby, and Philips Hue scene handling.
It also fixes several regressions introduced in beta 2.9.8.
Updated components:
Web-configurator 2.3.0
UI 0.74.2
Philips Hue 0.4.2
System: WiFi driver
Fixed
  • Improved Wi‑Fi reconnection after resuming from standby.
  • Fixed touch sliders not working for lights in activities.
  • Fixed pages unexpectedly jumping to the top when scrolling past boundaries.
  • Web-Configurator:
  • Fixed duplicate integration driver cards after creating an integration (regression from 2.9.8).
  • Fixed the "Add new UI page" button function (regression from 2.9.8).
  • Improved connection recovery after a browser tab was frozen or suspended.
  • IR Learning: improved feedback when the Dock is disconnected.
  • After manually reloading, the app reverts to the previous language.
  • Philips Hue: fixed scene select entities showing unknown state attributes. Contributed by @henrikwidlund (philipshue#170).
Added
• Web-Configurator translations for Danish, Dutch, French, Hungarian, and Italian. More translations are being prepared on SimpleLocalize and will be available soon.
Changed
Web-Configurator:
  • Deferred non-critical assets to improve initial load time.
  • Modernized dependencies and the toolchain by upgrading core libraries and tools.
Known Issues
  • Donderstraaltje
Donderstraaltje
Web-Configurator translations for: Dutch
Hoop dat dit voor mensen hier een beetje op weg helpt.
Zelf heb ik hem nog altijd eigenlijk in ongebruik de remote 2, voor kodi werkt het aardig maar daar had ik al wat voor. Mijn muziekspeler op LMS is nu wel een addon voor maar werkt niet zo lekker als destijds de Logitech remotes. Het spulletje voelt dan wel weer stabiel aan intussen en ze zijn ook bezig met de accuduur. ga het denk ik toch nog eens de nodige kans geven over een paar weken als ik met vakantie kan.
Pagina: 1 2 3 4 5 Laatste
Dit topic is voor de afstandsbedieningen van Unfolded Circle.
Voor Logitech Harmony is er [AB] Logitech Harmony Advanced Universal Remotes [deel 3]
Voor Cantata Haptique is er Cantata Haptique RS90 en RS90x smart afstandsbediening
Voor andere alternatieven voor de Logitech Harmony, zoals Philips, One For All en Sofabaton is er [AB] Alternatieven voor Logitech Harmony
