• Malignant
  • Laatst online: 27-11 08:38
En vanaf heden kan er op de site ook een preorder gedaan worden zie ik.
Levering verwacht eind July.
Eerst maar eens zien dan de kickstarters uitgeleverd worden.
LG OLED 55C7 - Denon AVR X6300H - 2x Focal 816W - Focal 800CC - 2x Focal 800SR - 4x Focal IC105 - SVS SB-2000 - MB Next - Playstation 5 - Oppo UDP-203 - Rega RP1 + Elys 2 - BlueSound
  • Donderstraaltje
Donderstraaltje
Beta Release 2.4.5
This patch update fixes the Denon AVR command timeouts, adds app & media metadata support to Android TV (preview) and adds enhanced volume management in the Apple TV integration.
Known issues: WiFi high-channels (>11) do not work anymore, we are working on a fix.
Fixed
Denon AVR integration:
  • UI timeout errors due to missing response status codes when using http requests. Contributed by @henrikwidlund, thanks! (integration-denonavr#56)
  • Power toggle command (integration-denonavr#59).
Web-configurator:
  • Pre-select the search field in the icon picker dialog.
Added
Preview features in Android TV integration:
  • Google cast option to retrieve running application name and artwork (requires app support, e.g. Stremio). Contributed by @albaintor, thanks!
  • Retrieve application icon from Google Play. Contributed by @thomasm789, thanks!
  • The preview features must be enabled in the device configuration of the setup flow. Enabling both options may produce an occasional flicker between app and media images.
Apple TV integration:
  • New global volume management and setting specific volume levels.
  • This only works for connected devices like HomePod, but not for HDMI output.
  • This feature can be disabled in the device options. Contributed by @albaintor, thanks! (integration-appletv#37).
Android TV, Apple TV, Home Assistant integrations:
  • Set media player attribute "media_position_updated_at" (#443).
Changed
  • Denon AVR, Android TV, Apple TV integrations:
  • Update Python runtime to 3.11.12 and upgrade common Python libraries.
  • Add a support article link in the first setup flow screen.
Zo te zien nog altijd geen stable 2.x versie... mijn remote ligt nog altijd als een baksteen in de kast dus ik check niet of er in tussentijd andere versies gepusht worden. 1.7.14 is bij mij de laatst bekende versie.
  • nklerk
  • Laatst online: 19-11 08:29
Donderstraaltje schreef op maandag 28 april 2025 @ 17:04:
Beta Release 2.4.5
Zonde, Gewoon updaten naar 2.x
Toevoeging: 2.x is mijn inziens stabieler als 1.x
[ Voor 6% gewijzigd door nklerk op 28-04-2025 20:20 ]
  • Donderstraaltje
Donderstraaltje
nklerk schreef op maandag 28 april 2025 @ 20:19:
Omdat wat ik wil/nodig heb nog altijd niet kan?
Wellicht moet het via openhab ofzo maar het is/werkt allemaal uitermate frustrerend. Heb vrienden met een remote two en het is echt een haat/liefde verhouding.
Ik heb zelfs getwijfeld om te leren programmeren om zelf een integration te kunnen maken. Liever wacht ik nog met die weg inslaan tot de boel meer volwassen is. Wellicht is wat ik wil te specifiek maar zeker niet niche.
  • nklerk
Ik weet niet wat je wilt bereiken, wellicht kan ik iets betekenen, feit is dat de remote het beste tot zijn recht komt naast een oplossing als Home assistant of wat ik zelf gebruik Homey.
  • Donderstraaltje
Donderstraaltje
nklerk schreef op maandag 28 april 2025 @ 23:29:
Zelfstandig gebruik, dus zonder extra servers direct een addon/app/extension give it name. Ik heb geen verdere domotica slechts alles in mijn tv meubel wil ik (eventueel los) kunnen aansturen. TV/Amp/Kodi/Squeezebox.
Op enig moment wil ik Kodi bedienen; dat was destijds al aangekondigd. Dat kan ik nu los met een 10 euro remote en CEC en dat werkt perfect! TV en amp gaan mee aan en uit en volume kan bedient worden. Dit heeft voor nu geen prio om dat werkend over te zetten naar de remote two.
Wat wil ik specifiek;
Die Logitech remotes hadden nog een functionaliteit, van een productlijn wat ook de kop omgedraaid is; Logitech Music Player en ook server, nu Lyrion. Helemaal opensource en een tegenhanger van Roon.
Wat ik nu doe; lekker CD’tje erin; haalt info en coverart op, voegt het toe aan relevante playlists en voila ik heb mijn eigen strreamingservice vol met alle knallers van de jaren 60/70/80 en wat 90.
Wil nu eigenlijk zoals de Roon extension werkt dit ook heel simpel op de remote;
Via kodi (werkt geweldig maar via tv is het geen bedienen);
https://github.com/kodi-c...s/plugin.audio.squeezebox
En deze laat helemaal mooi zien wat er kan;
https://lyrion.org/players-and-controllers/squeezeplay/
GitHub staat vermeld.
Gewoon dit, heel simpel ongeveer 1:1 de functionaliteit terug zoals ook op de Logitech remotes. Gewoon muziek(lijst) van de server kunnen selecteren, radio stationnetje, speler selecteren en uitzetten. Cover art op het scherm. En de afmaker is de volume kunnen bedienen op de amp.
Werkte echt geniaal destijds. Geen servers of niks extra nodig, eigenlijk wat volgens mij de Roon extension in de basis kan. Alleen ik ga geen 830USD neerleggen voor Roon! Wellicht wil ik iets wat te simpel is, maar volgens mij met een beetje (Python?) kennis is een van de twee bovenstaande ook simpel te porten naar de remote. De enige reden dat ik er nog niet zelf mee begonnen ben is dat er iets anders net wat hoger op mijn lijstje staat wat echt eerst moet.
Afbeeldingslocatie: https://tweakers.net/i/4W9AtugaQQlFc6qoaamY1aBHCxY=/fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():strip_exif()/f/image/yMjOKiOeq3X8b5Z4SbgTW0en.jpg?f=user_large
Gewoon simpel en geniaal. En helaas ook de kop ingedrukt met het killen van de harmony lijn. En voor wie komt met het kan ook via de telefoon; dat is geen vervanging voor fysieke knoppen. Dat is wat vaak aangedragen wordt.
Hoop dat het te volgen is…
[ Voor 3% gewijzigd door Donderstraaltje op 29-04-2025 06:09 ]
  • nklerk
Wat ik zo zie kan je dat nu al met de kodi integrate -> https://github.com/albaintor/integration-kodi
Kan je hier eens naar kijken?
Wat je in de screenshots deelt is hoe ik ook mijn muziek bedien met R2 en R3.
  • Donderstraaltje
Donderstraaltje
nklerk schreef op dinsdag 29 april 2025 @ 12:06:
Ik gebruik dus kodi niet voor muziek; dat is zeker als je een wat grote bibliotheek hebt onbeheersbaar. Dus helaas niet de oplossing. Juist daarom is Roon zo populair. Zelf 5 jaar terug de stap terug naar LMS gemaakt. Zou dit pakket 300 euro kosten had ik het er nog wel voor over maar een factor 3? En het steunt zwaar op opensource dus dat vind ik zelfs nog bezwaarlijk.
[ Voor 20% gewijzigd door Donderstraaltje op 29-04-2025 12:19 ]
  • Donderstraaltje
Donderstraaltje
Donderstraaltje schreef op maandag 28 april 2025 @ 21:01:
Had vandaag tijdens de pauze het er over met collega's... in de categorie wat al niet ter (lunch)tafel komt en had het geeneens zelf geïntroduceerd maar het ging over de AB van de airco.... Eigenlijk werd het daar heel mooi gevangen wat hierboven aangehaald werd over hoe wij er totaal anders in lijken te staan.
Wat ik, en velen zoeken, is iets dat niet persé laagdrempelig is maar, als het woord al bestaat middelbaardrempelig. En dat in een jasje dat niet heel cheap aanvoelt maar waarvan je bij de eerste paar keer vallen niet het idee van hebt dat het meteen kapot gaat. Wat bedoelen wij dan met middelbaardrempelig? Nou dat je in principe "alles" vanaf de remote kan instellen met behoud van de meeste functionaliteit van de originele remote, Velen, net als ik, zijn niet persé opzoek naar een hele domotica oplossing maar een "één remote op de bank'-oplossing. De scenario's komen dan nog niet altijd eens naar boven bleek.
De kracht van de Harmony zat hem erin dat dit het bovenstaande perfect raakte. Ja er kon meer maar de basisfunctionaliteit was gewoon goed voor de meeste mensen; ook voor hen die niet persé super technisch onderlegd waren maar met een uur of 2-3 klooien het voor langere tijd werkend hadden. Ja doordat de ontwikkeling lange tijd stilstond heeft het een beetje de echte domotica doorontwikkeling gemist.
Zelf ben ik een beetje aan het ont-hobbyen en ook ik ben op zoek naar iets wat gewoon net er ergens tussen in valt maar met de optie tot (er mogelijk ooit) diep induiken.
Ben eigenlijk een beetje benieuwd voor de discussie hier of mensen zich ook hier in kunnen vinden.
  • Amersfoort
  • Laatst online: 29-11 21:23
De eerste recente kennismakingsvideo van de Remote 3 is verschenen op YouTube.
De video is een beetje rommelig. @nklerk Dat kun je vast beter met een werkende Remote 3 en een gesproken toelichting op de software.
  • nklerk
Amersfoort schreef op maandag 5 mei 2025 @ 12:11:
[YouTube: Has the Best Universal Remote Got Better? - Remote 3]
Ik denk dat je mij te hoog hebt zitten. Deze man is duidelijk gewend om video’s te maken. De tour door de instellingen heen is inderdaad niet sterk.
Als je bekent bent met remote 2 dan is de ervaring van R3 gelijk aan R2 laatste Beta versie.
Als er specifieke dingen zijn die je wilt zien dan hoor ik dat graag, wellicht dat ik wat kan delen
  • Amersfoort
nklerk schreef op maandag 5 mei 2025 @ 14:02:
Ik ben op zoek naar een opvolger van mijn Logitech afstandsbediening, en heb (ook) geen kennis van de Remote 2. Alle informatie van een werkende R3 hardware, software en Homey koppeling is welkom, graag met een gesproken toelichting, zodat we beter kunnen volgen wat we zien.
  • SunBeech
In betreffende video geeft hij aan dat er nog een vervolgvideo komt met meer details over het opzetten/instellen van de afstandsbediening. Wellicht dat die video wat meer structuur/houvast biedt.
  • Donderstraaltje
Donderstraaltje
SunBeech schreef op dinsdag 6 mei 2025 @ 14:21:
Als er echt wat goede video’s komen zal ik ze ook in de OP opnemen. Zal eens kijken of ik dit weekend ook de specs van remote 3 en de losse dok kan opnemen. Heb zelf nog een losse dok bijbesteld maar nog niks van versturen of adresbevestiging vernomen.
  • Malignant
Complete setup video nu ook op YT,
  • TweakWouter
  • Laatst online: 02-11 21:37
Heeft er iemand met de uc2 of uc3 al ervaring met het bedienen van:
  • Ziggo Next Mini
  • Samsung Smart TV (zoals een Neo Qled)
De Next mini is alleen via Bluetooth te bedienen, maar de UC lijkt daar nog niet echt ondersteuning voor te bieden?!
Nb: ik heb gelezen dat de Samsung smart tv via Home Assistent aan te sturen is, maar ik heb (nog) geen HA, en wil dit bij voorkeur direct met de ab kunnen doen.
Opvallend vind ik dan ook dat de Samsung TV's op de UC website niet genoemd wordt als ondersteunde devices, en het ook niet bij de toekomstige plannen staat?!
  • nklerk
TweakWouter schreef op zondag 11 mei 2025 @ 18:22:
  • Ziggo Next Mini
Ik heb een next mini liggen maar niet echt in gebruik. Zodra ik tijd heb zal ik testen.
  • SunBeech
  • Ziggo Next Mini
Ik lees op de Discord server van Unfolded Circle in deze sectie dat een community-ontwikkelaar gisteren een integratie voor Samsung TV’s beschikbaar heeft gemaakt.
  • Donderstraaltje
Donderstraaltje
Voor wie een extra dock besteld heeft of andere accessoires; net bericht gekregen dat het verstuurd is!
Mijn idee is om deze in een kast achter de apparatuur te leggen. Dit zodat ik met jack to jack kabels de apparatuur kan aansturen zonder dat ik een dock op de kast zelf hoef te hebben. We gaan zien of dit werkt.
En ik kijk binnenkort eens naar de OP nu ik vakantie heb opgenomen.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.5.0
Known issues:
  • WiFi high-channels (>11) do not work anymore, we are working on a fix.
  • WoWLAN periodically wakes up the device from standby. A support case with the manufacturer is in progress.
  • Dock 3: automatic detection of 2 IR blasters currently does not work with all docks. Workaround: use the new manual configuration mode in this update to configure two IR-blasters.
  • Automatic display brightness and button backlight settings are not yet working.
  • Remote 3: the ambient light sensor sensitivity will be increased with a firmware update.
  • Remote 3: on some media-player screens, the bottom icons are cut off, or the volume slider doesn't work.
This update fixes the volume control issue with Android TV, non-working buttons with Remote 3 and adds a manual Dock 3 output port configuration.
Breaking changes
  • Dock 3: dynamic IR-emitter outputs based on port configuration, combine internal IRs into one output.
  • The new combined "Dock" output port must be assigned to existing IR-remote entities if an internal IR port was used before.
  • Remote 3: disabled "Keep WiFi connected in standby" (WoWLAN) setting until it is fixed.
Fixed
  • The turn-off menu only shows entities with on/off features available (#456).
  • Display artifacts after wakeup.
Web-configurator:
  • Remote-entity toggle test feature uses the correct command and doesn't clear parts of the entity screen.
  • Debounce search input: don't send a search request for every key press.
  • Correctly handle no longer available IR-emitter output ports in the remote-entity screen.
  • Select a new backup file after the restore process.
  • Regular volume control with Android TV keycodes (regression with Google Cast addition in v0.7.0) (integration-androidtv#72).
  • Pre-selection of the configuration option in the setup process if a device already exists (integration-androidtv#73).
  • Roon integration: remove unsupported OnOff feature (#456).
Remote 3:
  • Commands cannot be assigned to the stop, record and menu buttons (#458).
  • Wireless charging control with Core-API.
Added
Web-configurator:
  • Dock 3: manual configuration for IR-blasters and IR-emitters. RS232 and trigger support will be provided with future updates.
  • Multi-device support (integration-denonavr#20).
  • Additional commands. Contributed by @henrikwidlund, thanks! (integration-denonavr#65).
  • Configurable volume step when using Google Cast volume control. Contributed by @albaintor, thanks! (integration-androidtv#72)
  • d-vine
  • Laatst online: 19:29
Hoe staat het momenteel met leveringen.
Tot nu toe alleen nog pre order te maken?
Wat is de verwachting komend jaar.
Misschien heeft iemand meer informatie.
  • nklerk
Donderstraaltje schreef op vrijdag 23 mei 2025 @ 14:28:
wat jij wil kan inderdaad. je kan simpel aangevel waar het signaal vandaan moet komen. inclusief de dock 2
  • Malignant
d-vine schreef op zaterdag 24 mei 2025 @ 20:32:
Uitlevering volgens de site staat nu op eind Q3 van dit jaar. Er zijn vorige week enkele kickstarters verzonden voor zover ik heb kunnen achterhalen. Volgens mij ging het om de eerste 100 stuks. Als daar geen grote issues mee kwamen zou men het leveren opschalen had ik gelezen.
Maar zowel op de unfolded community site als op Discord vind ik het nog angstvallig stil.
Zit zelf nog steeds op feedback van de eerste echte gebruikers groep te wachten voordat ik mijn preorder doe. Verwacht wel dat het goed komt, maar toch....
  • StealthBlade
  • Laatst online: 18:41
@nklerk wordt de Homey app nog opensource gemaakt? Ik mis namelijk nog integratie met airco's en gordijnen/blinds en zou deze graag willen toevoegen.
  • nklerk
StealthBlade schreef op dinsdag 27 mei 2025 @ 20:23:
Daar zou ik zelf heel blij mee zijn. ik heb geen blinds/airco om mee te werken. De code wordt zeker opensource dat is een feit. zouden we eigenlijk al weken geleden open willen hebben. ik zal een balletje opgooien.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.5.1
This patch update fixes some UI issues, non-working commands in the Denon AVR integration and improves the Sonos integration.
Fixed
  • Denon AVR integration: non-working HDMI output, ECO, dimmer and dirac commands (integration-denonavr#69).
  • Remote 3: on some media-player screens, the bottom icons are cut off, or the volume slider doesn't work, although the "set-volume" function is available.
  • Handling of transparent media images.
  • Media image is sometimes not shown.
  • Activity bar height resizes and the page scrolling position resets when the media image changes.,
  • Wifi icon size in known networks.
Web-configurator:
  • Directly add an integration on the integration screen and infrared- and BT-remote entities on the corresponding screens.
  • Show Bluetooth setup instructions for Dock 3.
  • Dock search only works with lower-case search input.
  • Activity search result shows "add your first activity" if nothing is found.
  • Lock UI after a reboot action.
Changed
  • Sonos integration: improved device detection, setup-flow and logging, stability fixes.
  • We are preparing a renewal of the Sonos integration and evaluating new client libraries.
  • We really hope to continue using their local device APIs despite their announcement of moving to cloud-based authentication even for local control.
  • nklerk
  • Ziggo Next Mini
Ik heb vandaag de next mini aangesloten. De next mini heeft geen optie om een aparaat te koppellen via bluetooth. daarmee kunnen wij (en anderen) dus ook niet koppellen. Mocht er een methode zijn waarmee je wel een bluetooth koppeling kan maken met de next, dan hoor ik het graag.
  • nklerk
Ik heb zojuist een nieuwe update van de Homey integratie ge-pushed. Enkel wat tekstuele en visuele aanpassingen.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.5.3
This patch update fixes some web-configurator issues and adds a configurable timeout in the Denon AVR integration.
Known issues:
  • Dock 3: automatic detection of 2 IR blasters currently does not work with all docks. Workaround: use the new manual configuration mode introduced with 2.5.0 to configure two IR-blasters.
  • Automatic display brightness and button backlight settings in the UI are not yet working. They are currently disabled in the web-configurator.
Sonos integration:
  • a recent speaker firmware update affects the local device API access. Connection issues might be resolved temporarily by power-cycling the Sonos device(s). We are planning a rewrite of the Sonos integration using a different API.
Fixed
Web-configurator:
  • Command parameter dropdown closes by itself (#452).
  • Skip the last entity-selection screen in the integration setup if no new entities are available.
  • Keep applied filters when returning from a detail screen.
  • Set input focus to search fields when changing screens.
  • Localization change doesn't change language in settings menu.
Changed
  • Denon AVR integration: Make connection and request timeouts configurable. Contributed by @henrikwidlund, thanks! (integration-denonavr#70).
Web-configurator:
  • Buttons on the remote picture are clickable for button mappings.
  • The expanded-view in button mapping is now the default.
  • Backup restore automatically starts after selecting a backup file.
  • Backup file selection for restore requires the ".backup" file extension.
  • Preparation of translations. Various translations will be available soon.
  • Show entity identifier in detail view.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.5.4
This patch update fixes a command timeout issue introduced in 2.5.3 with the Denon AVR integration.
Known issues:
  • Sonos integration: a recent speaker firmware update affects the local device API access. Connection issues might be resolved temporarily by power-cycling the Sonos device(s). We are planning a rewrite of the Sonos integration using a different API.
Fixed
  • Remove faulty command repeat handling in Remote UI.
  • Denon AVR integration: Timeout time units for connections and requests (mixup of ms / s). (integration-denonavr#84).
  • Arjantje72
  • Laatst online: 19:39
Goed bezig met de updates,
Mij alleen iets te prijzig, hopelijk gaan de prijzen later iets zakken :)
  • batteries4ever
  • Laatst online: 29-11 20:17
Wat mij irriteerde is dat zo’n ding veel minder kan dan mijn iPhone, alleen mis ik dan de fysieke knoppen en de IR/Zigbee/… radio’s.
Maar b.v. Muziek uit mijn library zien en kiezen, Kodi e.d. kan de Unfloded Circle dat?
  • Donderstraaltje
Donderstraaltje
Beta Release 2.5.5
This patch update fixes some web-configurator issues.
Known issues:
Fixed
Web-configurator:
  • English language fallback for translated integrations if configured language is not available.
  • Automatic update of the infrared commands after the import of a CSV IR dataset.
  • Buttons are not shown on smaller screens in the icon upload resize screen.
  • Improved error handling when adding widgets to a UI screen.
  • Show the correct color and type for Dock 3.
  • Text overflow in timezone dropdown field.
Added
Web-configurator:
  • Search option for Macros (#463).
  • About information in the settings page.
Changed
  • Core-API: enhanced filter option in entity retrieval to prepare for proper paging in web-configurator.
  • ratz
  • Laatst online: 11-11 22:08
ratz
Gadgetgeek
Ik heb m’n shipment notification gekregen van de Kickstarter Remote 3. Volgende week bezorgd.
Fujifilm X100VI ||| QNAP TS473A ||| XS4ALL ||| Ubiquiti UniFi & Protect ||| Homey Pro (2023) ||| Philips Hue ||| Jan Janssen Venom Ultegra Di2 ||| 6710 Wp ZZO/WZW SolarEdge
  • Malignant
Ben heel erg beniewd (en jaloers).
Eerste indrukken die ik op discord langs zie komen zijn goed.
Binnenkort ook maar eens een preorder gaan doen dan.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.5.6
This patch update improves charging with certain chargers, improves Remote 3 display and touch initialization after wakeup, and fixes some web-configurator issues.
Known issues:
Remote 3: the ambient light sensor sensitivity will be increased with a firmware update.,
Fixed
Improved charging parameters to accommodate for chargers without cable compensation.
Remote 3:
Adjusted display initialization to avoid sporadic interlace effects after wakeup.
Improved touch driver handling for suspend/resume.
Web-configurator:
Dock images are no longer loading (#490).
Customize remote: page edit button missing on touchscreen devices.
Added
Web-configurator:
Add a logout option to the profile menu.
Display the web-configurator version on the about page in the settings.
  • Amiet01
  • Laatst online: 26-11 09:37
Amiet01
Master_A
Mijn shipment is onderweg en ik kan er morgen waarschijnlijk mee aan de slag! Ben benieuwd hoe het geheel gaat werken, vooral de integratie met Homey ben ik ook wel naar benieuwd.
Master_A
  • Amersfoort
Amiet01 schreef op donderdag 26 juni 2025 @ 10:52:
Deel graag je ervaringen!
  • Donderstraaltje
Donderstraaltje
Beta Release 2.6.0
This patch update addresses a WiFi initialization issue on Remote 3.
Fixed
Remote 3 WiFi controller initialization. Some boards had sporadic initialization issues at power-up or wakeup due to a vendor bug. This fix uses more conservative settings for stable operation.
  • Donderstraaltje
Donderstraaltje
Ik kan bovenstaande post niet meer editen; deze firmware is voor remote 3 only. Oude 2 zul je hem dus niet zien.
  • Malignant
Na alle goede berichten ook maar besloten toch te bestellen.
Nu maar wachten, eind Q3 gaf de site aan. Zal wel met de kerst geleverd worden 😁
  • Amiet01
Amiet01
Master_A
De Remote 3 is gisteren eindelijk binnengekomen. Mijn eerste indruk: WAUW! Wat een prachtig premium apparaat, ik wil het bijna niet eens aanraken. Van materiaalkeuze tot aan het geweldig reagerende touchscreen met ook de touchslider onderaan. Zelfs typen met een toetsenbord op zo'n klein scherm gaat vrij goed.
Komende tijd moet ik even de tijd vinden om alles (proberen) te programmeren en integreren. Vooral het volgende moet ik nog uitzoeken:
- Ziggo Mediabox Next toevoegen
- Spotify integratie?
- Kodi integratie? Heb een community integratie gezien, maar geen idee hoe die te installeren.
- Projectiescherm van Vividstorm besturen via IR (heb geen originele IR remote hiervan)
- Activiteiten aanmaken
Nog veel om uit te zoeken en programmeren, maar het geheel is tot nu toe geweldig te noemen.
Master_A
  • Donderstraaltje
Donderstraaltje
Beta Release 2.6.1 (voor remote 2+3)
This patch update contains another improvement for certain chargers and the Remote 3 display initialization.
Known issues:
Fixed
• Improved charging parameters to accommodate for chargers without cable compensation.
• Toggle IR codes from the IR database result in "invalid request" errors (#495).
• Remote 3: Another display initialization adjustment to avoid sporadic interlace effects after wakeup.
Changed
Web-configurator:
• Support for uploading multiple image files at the same time. If multiple files are selected, they must be in the required format. The resize editor is only available for single uploads.
• Auto-reboot remote after enabling and confirming beta updates.
  • ratz
ratz
Gadgetgeek
Ik heb mijn Unfolded Circle Remote 3 inmiddels ook binnen. Hij gaat de NEEO vervangen. Ik stond sinds December 2022 op de wachtlijst voor een Remote 2 en had daardoor Kickstarter shipping #575.
Verpakking is premium en bouwkwaliteit vergelijkbaar met de NEEO. De Remote 3 (rechts) is wat zwaarder dan de NEEO (links).
Afbeeldingslocatie: https://tweakers.net/i/k0HdCE4QNZwfYk1Dv-wikTobAAM=/800x/filters:strip_icc():strip_exif()/f/image/uTOcRJXkXQQ0fOI0na6wmkIO.jpg?f=fotoalbum_large
Ik heb een setup met een redelijk standaard Marantz versterker en LG OLED tv. Daarnaast draait er een Naim Uniti voor de aansturing van de front speakers (ook in 5.1) en streaming via een AppleTV. Daarnaast nog een Panasonic Bluray speler en een KPN Arcadyan settop box. En een Homey Pro, Roon en Philips Hue.
Integraties voor Philips Hue, AppleTV en Marantz/Denon waren standaard meegeleverd snel aan de praat. Homey integratie via de Homey-app van @nklerk.
Helaas deed de GitHub-integratie voor de LG tv en de Panasonic Bluray het niet (installatie was probleemloos via webinterface) en heb ik voor aansturing via infrarood gekozen. Voor een aantal veelgebruikte apparaten (zoals de LG en Panasonic) zijn voorgedefinierde IR codes via de webinterface makkelijk te laden door een nieuwe infrarood-entiteit aan te maken.
De Arcadyan was een ander verhaal: Niet standaard aanwezig en de IR learning met afstandsbediening gaf foutmeldingen. Dit betekende uiteindelijk handmatig alle Pronto codes invoeren na downloads van de ir-database op https://irdb.globalcache.com/.
Ook de Naim gaf wat hoofdbrekens omdat er een Zigbee afstandsbediening is. Gelukkig gaf de http PUT/GET GitHub integratie een oplossing via http-commando’s naar de Naim. Daarnaast werkt de Roon integratie prima.
Al met al 1.5 dagen klussen om de functionaliteit van de NEEO volledig over te nemen en meer. Alleen krijg wél de devices van Homey maar niet de UC3-flows te zien als entiteit.
Mijn voorlopige ervaringen:
Mooie kwaliteit smart remote met veel mogelijkheden. Ik was bang dat het aan de praat krijgen van alle apparaten wat problemen op zou leveren, maar na wat uitdagingen getackled te hebben viel dat reuze mee. Nog niet echt een apparaat voor het algemene publiek qua instelgemak. De batterij gaat duidelijk sneller leeg dan die van de NEEO. De Remote 3 hoort ‘s nachts in de oplader. De UC3 dock laadde eerst wat langzaam en onregelmatig, maar na een firmware upgrade naar 2.6.1 lijkt het laden wat stabieler te zijn. De layout van Remote 3 kan veel meer aangepast worden dan de NEEO. De webinterface is redelijk gebruiksvriendelijk, ook om custom GitHub tar.gz integraties te uploaden. Alles werkt lokaal op de Remote 3 wat privacy technisch een enorme pré is. Alleen verliest de webinterface z’n connectie steeds als de Remote op standby gaat. Waarschijnlijk alleen een ergernis bij het instellen.
Ben benieuwd wat de verdere ontwikkeling van de Remote 3 gaat brengen. Ben in ieder geval blij dat ik niet voor de Cantata Kickstarter ben gegaan - want het geavanceerde model lijkt flink vertraagd. Dan is 6 maanden vertraging van de Remote 3 niet. Ach, met alle NEEO ervaring (2,5 jr vertraging en binnen 2 jaar verkocht aan Control4) was het eigenlijk een supersnelle levering!
  • nklerk
Mooi en terechte feedback. bedankt daarvoor.
Ik ben niet altijd even snel met reageren. zou je mij een PM willen sturen? (mag van mij ook in de post maar dan kaap ik die onbedoeld voor ondersteuning.)
Zou je een standaard flow willen maken met als Als kaart de UC: "Start <text> Flow from Remote Two" en bij text een naam in typen (deze zou zichtbaar moeten worden in de remote als entiteit)
En kan je hetzelfde doen met een andere naam in een advanced flow.
Ik ben benieuwd welke je wel en niet terug vindt in de afstandsbediening.
als je vervolgens de UC app herstart op homey.
Vind je ze nu wel als entiteit in de afstandsbediening?
  • ratz
ratz
Gadgetgeek
Misschien nog even goed om aan te vullen dat de advanced flows van Homey wel via de Homey integratie werken (de normale flows in de app zijn bij mij nog niet zichtbaar, maar daar wordt aan gewerkt) - zo heb ik de bediening van de roborock S7 in de afstandsbediening op kunnen nemen via Homey - de UC remote 3 heeft hiermee de WAF status bereikt.
Afbeeldingslocatie: https://tweakers.net/i/_lIj_cmCRzzyHBYo8C_a8q7KiRI=/800x/filters:strip_icc():strip_exif()/f/image/MYAlbGQOGSR8bdwNbXt8Z6Rf.jpg?f=fotoalbum_large
Buiten de bekende laadproblemen (power cycle van de dock helpt dan meestal) en de relatief beperkte batterij (1 volle avond series bingen 100 —> 30%) is het echt een prima smart remote met oneindig veel opties qua layout en instellingen. Een aantal apparaten (zoals AppleTV voor streaming en Roon voor muziek) ondersteunt album/serie art en runtime. Er is een mooie onofficiële app voor de Remote 3 voor iOS; handig als je niet steeds de webinterface wil laden.
Afbeeldingslocatie: https://tweakers.net/i/lu-TGWiQsu5dJMfgVLQg_6xA5SQ=/800x/filters:strip_icc():strip_exif()/f/image/dhuXvh7XcuYfgPt8NxFLOIO3.jpg?f=fotoalbum_large
De NEEO remote gaat al bijna de lade in voor een verdiend pensioen na 8 jaar trouwe dienst.
  • Amiet01
Amiet01
Master_A
Ziet er erg nice uit zo! Zal ook eens wat meer activiteiten aanmaken en mooie layouts knutselen. Heb jij nog enige suggesties voor ideeën @ratz ? Welke app bedoel je overigens op iOS voor de Remote 3? Kun je dan ook zonder de remote fysiek te bedienen al bepaalde activiteiten starten/stoppen?
Master_A
  • Malignant
ratz schreef op dinsdag 15 juli 2025 @ 15:26:
Bovenstaande is voor mij het magische woord. Dit was met mijn Harmony ook altijd het geval dus dan zal het nu ook wel goed moeten komen.
Nu alleen nog wachten totdat alle kickstarters verstuurd zijn, hopelijk ben ik daarna snel aan de beurt :)
  • Pierre
Pierre
Van nature lui!
Vanmiddag kwam ik er achter dat https://www.remotecentral.com/ binnenkort weer beschikbaar is. Toen ik mijn Pronto nog had regelmatig dingen bekeken, om die Pronto goed te programmeren.
  • ratz
ratz
Gadgetgeek
Amiet01 schreef op dinsdag 15 juli 2025 @ 18:03:
Het is de iOS app gemaakt door user albaintor: https://apps.apple.com/us/app/u-remote-control/id6740058993. Je kunt er inderdaad ook remote commando’s mee uitvoeren.
  • ratz
ratz
Gadgetgeek
Ik ben begonnen met basisaktiviteiten (Streaming, TV, bluray, Roon) en ben het langzaam verder uit aan het breiden.
Heb je een Smart Home systeem zoals HA of Homey? Want dat voegt veel extra mogelijkheden toe zoals bedienen van smart devices zoals de Roborock, de warmtepomp, de Hue verlichting. Verder ben ik nog bezig met de Roon integratie om m’n afspeelervaring (playlists, 3 Roon endpoints in huis) te optimaliseren.
  • Amiet01
Amiet01
Master_A
Die iOS app is geweldig, thanks voor de info!
Ik heb inderdaad ook een Homey, en heb mijn HEOS speakers er hierdoor ook in gekregen (hoewel met beperkte functionaliteit). Ik zal er inderdaad nog even mee moeten spelen om mijn verlichting enzo aan toe te voegen.
Hoe heb jij het overigens voor elkaar gekregen om de volume slider te gebruiken in een activiteit? Ik heb ook een Marantz, maar die volume slider werkt niet binnen een activiteit en alleen in de Marantz entiteit zelf.
Master_A
  • ratz
ratz
Gadgetgeek
Amiet01 schreef op woensdag 16 juli 2025 @ 10:09:
De slider is inderdaad nog niet los programmeerbaar maar bedient nu standaard het volume van de media widget. Deze stel je in bij het “user interface” scherm van Activities & Macros.
In de foto waar ik de slider bedien (Bluray activity) heb ik de Marantz als media widget ingesteld om het volume te kunnen bedienen. Als je de bluray speler selecteert werkt de slider inderdaad niet.
Afbeeldingslocatie: https://tweakers.net/i/MLBYLqrvNU-b1e2D3tZ1eEwweR8=/x800/filters:strip_icc():strip_exif()/f/image/nXu1ZHbngHlSFm2BgBp7x8A3.jpg?f=fotoalbum_large
Volgens mij staat een programmeerbare slider in de firmware roadmap.
  • Donderstraaltje
Donderstraaltje
Beta Release 0.7.0
Fixed
• External port detection with two blasters.
• Show error on screen for over-current detection (#17).
• PRONTO code parsing with trailing whitespace (#13).
• Send authentication error message response to allow setup with a custom password on Remotes <= 2.6.1 (#16).
• Show correct charging changes in info screen (#6).
• Invalid ethernet connection state in get_sysinfo (#12).
• Memory leak in failed ota authentication (#14).
• Use after free for non-raw PRONTO code error message.
Added
• Low voltage charger check (#18).
Changed
• Improve ADC reading and allow higher charging current to compensate different voltage threshold on production docks.
• Disable IR decoding of AC protocols (#7).
• Use both internal IR outputs if no active output has been specified.
• Determine vcc charger offset at startup to prevent toggling charging / non charging screens.
  • ratz
ratz
Gadgetgeek
Hopelijk lost deze dock firmware update het oplaad probleem (stop laden door overcurrent protection). Morgen beschikbaar op de non-beta update channels.
  • Donderstraaltje
Donderstraaltje
Heeft iemand die Kodi integration al werkend?
Ik krijg deze nog altijd niet tussen de integrations gevonden, ook niet op de 2.x beta.
Wil eigenlijk de komend tijd echt wel eens een integration testen anders overweeg ik het hele spul maar in v&a te zetten. Begint na zo lange tijd wel een beetje frustrerend te worden dat ik er nog helemaal niks mee kan.
  • ratz
ratz
Gadgetgeek
Donderstraaltje schreef op vrijdag 18 juli 2025 @ 14:44:
Bedoel je dat je de Kodi integratie van Albaintor op Github nog niet gezien hebt? Die had een eerste versie in april 2024, en staat al een tijd op de unfolded circle website bij “supported devices”. Hij is inderdaad nog niet standaard in de webinterface geintegreerd.
Directe link naar GitHub: https://github.com/albaintor/integration-kodi/releases
Custom integrations zijn vrij makkelijk te installeren door de *.tar.gz repository te uploaden in de user interface: Integrations > + > install custom integration (het *tar.gz bestand uploaden). Daarna verschijnt ‘ie in de lijst.
  • Amiet01
Amiet01
Master_A
Er is een externe Kodi integration via Github, maar ik weet zelf ook niet hoe in deze kan installeren. Je moet een bepaald bestand uploaden, maar ik weet niet hoe je dit bestand aanmaakt via de Github pagina.
Edit: Ratz was me net voor. Hoe komen we aan de tar.gz file van deze integration?
[ Voor 16% gewijzigd door Amiet01 op 18-07-2025 18:15 ]
Master_A
  • ratz
ratz
Gadgetgeek
Amiet01 schreef op vrijdag 18 juli 2025 @ 18:13:
Dat kan vrij simpel:
*.tar.gz downloaden van de GitHub pagina (eerste of tweede bestand onder “Assets”):
Afbeeldingslocatie: https://tweakers.net/i/1I0z2QsKy3a30aJUv4EX7atCVug=/x800/filters:strip_icc():strip_exif()/f/image/6nCahM0Zq47QojrrC1OjUdAw.jpg?f=fotoalbum_large
In de webinterface: Integrations > + > install custom > tar.gz uploaden:
Afbeeldingslocatie: https://tweakers.net/i/BgV1koSxTxOYNt4ZfopI6MBnZJE=/800x/filters:strip_icc():strip_exif()/f/image/ck6KfX7YMsq4183bLVw2XCTY.jpg?f=fotoalbum_large
En vervolgens staat de custom integratie in je lijst:
Afbeeldingslocatie: https://tweakers.net/i/TPsl75RE_eq7DOO3q7HUoUVUqpY=/x800/filters:strip_icc():strip_exif()/f/image/EXxwdokbLvvUWkJMKlljSmL6.jpg?f=fotoalbum_large
Je vindt overigens een overzicht van beschikbare integraties op de unfolded circle website (niet compleet) en op de unfolded circle Discord onder “community projects”.
[ Voor 8% gewijzigd door ratz op 18-07-2025 19:25 ]
  • Veertien14
  • Laatst online: 17:19
Ik heb momenteel een Harmony Ultimate, door de jaren heen heel weinig gebruikt met als reden dat het scherm zo gevoelig is dat bij het aanklikken/wijzigen etc van een activiteit, of andere opties indrukken, ik vaak een knop vlak erboven of eronder indrukte, alle apparaten wat anders deden en ik uiteindelijk sneller was met de losse ab's om die activiteit te voltooien.
Hoe is dit met de remote 3? of kan ik beter naar een andere ab opzoek?
  • ratz
ratz
Gadgetgeek
Veertien14 schreef op zaterdag 19 juli 2025 @ 11:35:
De Remote 3 heeft vrij veel fysieke knoppen:
Afbeeldingslocatie: https://tweakers.net/i/tVZlhBFH0N4kz08NlVB4oVQ_KXY=/800x/filters:strip_icc():strip_exif()/f/image/uaSQ10zGK8ZzWmhgyOTxC3Dd.jpg?f=fotoalbum_large
Deze knoppen zijn allemaal per aktiviteit los programmeerbaar. Per knop kun je ook nog een functie instellen voor “long press” en “short press”. Zo hoef je de basisfuncties niet via het touch screen te bedienen.
Verder kun je het touchscreen helemaal zelf instellen met zoveel ruimte tussen software buttons als je zelf wilt.
  • Donderstraaltje
Donderstraaltje
ratz schreef op vrijdag 18 juli 2025 @ 18:11:
Deze had ik eerder al wel gezien, hier zelfs aangehaald. Maar installeren lukte niet en de guide die er toen was was niet om doorheen te komen. Had intussen wel verwacht dat ie tussen de integrations zou staan in de beta firmware. Moet even kijken wat verder nog supported is maar zo veel apparaten heb ik geeneens in huis om het mee te testen.
Nu wil ik op enig moment die tar.gz wel eens gaan proberen maar hoop oprecht dat allemaal eens fijner gaat werken. Ik kan me zo indenken dat via deze manier de integrations ook niet ge-update worden en wellicht zelfs breaken. En zo kan ik nog wat dingetjes verzinnen, waarvan ik geen idee heb of dat ook zo is. Dat het op zo’n manier werkend te krijgen is wilt nog niet zeggen dat het een goede manier is.
Wil hobbymatig eerst even wat anders nog doen voordat ik me hiermee ga bezighouden.
  • ratz
ratz
Gadgetgeek
Donderstraaltje schreef op zaterdag 19 juli 2025 @ 13:45:
[...]Deze had ik eerder al wel gezien, hier zelfs aangehaald. Maar installeren lukte niet en de guide die er toen was was niet om doorheen te komen.
Ah, okay - installatie was het probleem. Dat is inmiddels een stuk gebruikersvriendelijker geworden met de recente webinterface voor de Remote 3. Je hebt geen command prompt install meer nodig, maar het werkt simpel door het ene *.tar.gz bestand te uploaden en de webinterface doet de rest. Maakt experimenteren ook weer wat makkelijker.
Zeker, automatische updates van alle integraties zouden natuurlijk het fijnst zijn (zoals bij Homey), maar handmatig is echt niet zo moeilijk meer tegenwoordig.
  • Veertien14
ratz schreef op zaterdag 19 juli 2025 @ 13:02:
Duidelijk, dank!
  • batteries4ever
Riiiight... maar nog planeten weg van b.v. de Harmony, al zijn daar de mogelijkheden natuurlijk beperkter. Ik kijk telkens weer naar de AB en het forum, maar 2 dingen houden me tegen:
1) De prijs voor iets wat prima als een app op mijn iPhone zou lopen €400 is en blijft gewoon veel geld voor het genot van fysieke knoppen.
2) De knutselfactor. Ik heb al "tar gedoe" op de Kodi en haat het - blijft allemaal hit-and-miss: soms werkt het prima na een paar simpele commando's, soms berust op bergen afhankelijkheden waardoor het dan toch niet werkt en alweer een middagje zoeken op forums opslokt. Leuk als dat je hobby is, maar niets voor mij. Ik zit op een oude versie van Kodi en UI en zolang het blijft werken kom ik zelfs niet in de buurt van de setup...
  • Donderstraaltje
Donderstraaltje
batteries4ever schreef op maandag 21 juli 2025 @ 16:27:
Je vangt hier wel twee dingen; los van de kosten krijg ik ook vaak terug van waarom pak je niet gewoon je telefoon? daar kan het gewoon op. Ja maar sommige willen juist die knoppen. Het is mogelijk een generatiedingetje, althans dat leek onder de collega's zo te zijn als je ging kijken naar de leeftijd. Zelf nog van de pre-netfliix generatie en zap gewoon lekker op tv (met knoppen) en kijk amper tot geen films/series.
Dat hoge knutselgehalte is een heel stuk minder maar is er nog wel. Op zich is dat niet erg maar zoals in een eerdere post aangegeven niet iedereen zit überhaupt op enig knutselgehalte te wachten. En we zijn aardig wat tijd verder en dan mag het wel een keer. Met zo'n prijs verwacht je ook wel enig gemak. Zouden ze bijvoorbeeld nu een plastic variant uit brengen als goedkopere optie dan loopt het om de populariteit van de harmony lijn te behalen daarop weer spaak.
Het is een prachtig ding en mijn prijs vanuit de kickstarter is een stuk lager maar het is nog altijd niet wat er van gehoopt was. Ook niet tegen die prijs afgezet. Grootste nadeel; er is ook echt geen alternatief. De ontwikkeling van de Neeo (had ik ook) is stopgezet en die spaarzame andere kickstarters zijn er ook nog niet.
Ik heb vanwege vervelende redenen voldoende tijd dus op enig moment ga ik maar die tar methode proberen. Zoals aangegeven geen top oplossing maar als het werkt nouja dan gaan we dat maar testen.
  • batteries4ever
Donderstraaltje schreef op maandag 21 juli 2025 @ 17:13:
Oh ja!
ik ben ook helemaal van de generatie knopjes, al was het maar dat ik film kan kijken en knopjes bedienen, maar niet film kan kijken en touchscreen bedienen. Ik heb een Harmony Elite, en alhoewel het apparaat niet in de buurt komt van de Unfolded Circle en het schermpje bijna nutteloos is, is hij wel beter dan het gros van de ABs. Maar anderzijds is een moderne smartphone ook ongelooflijk goed, en veel krachtiger dan de Unfolded Circle.
ik zit ook op dit forum omdat ik me bewust ben van het gebrek aan alternatieven - maar irritant is het wel!
  • Theetjuh
  • Laatst online: 19:34
Idem hoor ... ik volg het topic inmiddels sinds een paar dagen en zat juist te kijken of de Unfolded Circle een mogelijk vervanger zou zijn voor de Harmony Elite.
Aangezien ik ook gebruik maak van Home Assistant lijkt het de beste opvolger tot nu toe, ik lees alleen veel over dat de afstandbediening na langere tijd niet gebruikt te zijn, te lang erover doet om weer connected te zijn.
Dit zou voor af en toe pauze of volume up/down een deal breaker zijn.
  • Donderstraaltje
Donderstraaltje
Theetjuh schreef op woensdag 23 juli 2025 @ 11:26:
ik lees alleen veel over dat de afstandbediening na langere tijd niet gebruikt te zijn.
Laat je niet te veel afschrikken door mijn posts over de veredelde press papier. Dit was echt omdat extensions gewoon voor geen meter te installeren waren. Dat lijkt nu wel te kunnen. Binnenkort ga ik eens testen.
Maar echt een pracht ding kwa bouwkwaliteit en van alle alternatieven echt de beste optie so far.
  • nklerk
Dit is een beetje een wij van WC eend verhaal van mijn kant, misschien dat anderen dat kunnen beamen. De afstandsbediening is extreem snel in het opzetten van nieuwe verbindingen. een verbinding vast houden is een optie maar verbruikt iets meer batterij. in de meest spaarzame stand kan het dus zijn dat je de AB oppakt, en deze 1 seconde aan het verbinden is.
  • batteries4ever
In de meest spaarzame stand kan het dus zijn dat je de AB oppakt, en deze 1 seconde aan het verbinden is.
Kwestie van smaak en gewenning maar komende vanaf de harmony, zoals de meesten hier, vind ik 1 s al een eeuwigheid als het erom gaat de film op een of ander spectaculair moment te stoppen. Tuurlijk, je kan even een paar seconden terug, maar toch... maar goed, dan zet ik hem constant in zijn dock naast mijn stoel.
  • ArniD
  • Laatst online: 29-11 20:01
batteries4ever schreef op woensdag 23 juli 2025 @ 13:48:
Dit probleem heb ik opgelost door een simpele knop onder de salontafel te plakken en deze via Home Assistant de mediaspeler op pauze te zetten als ik er op klik. Gaat nog sneller dan elke afstandsbediening haha.
  • Donderstraaltje
Donderstraaltje
nklerk schreef op woensdag 23 juli 2025 @ 13:30:
Maar je kan hem dus wel in een andere stand zetten voor snellere respons? Waar zit dat in het instellingen menu want die vind ik niet terug namelijk.
Zie wel wakeup, display en sleep timers.
  • ratz
ratz
Gadgetgeek
Donderstraaltje schreef op woensdag 23 juli 2025 @ 13:59:
[...]Maar je kan hem dus wel in een andere stand zetten voor snellere respons? Waar zit dat in het instellingen menu want die vind ik niet terug namelijk.
Dat doe je denk ik in “Activities” en niet in de settings:
Afbeeldingslocatie: https://tweakers.net/i/DeS0Dv1LSaJoT2AlsHO16aCBHro=/x800/filters:strip_icc():strip_exif()/f/image/cTimBEfzE6waqgze4DsaPxkF.jpg?f=fotoalbum_large
  • Donderstraaltje
Donderstraaltje
ratz schreef op woensdag 23 juli 2025 @ 18:45:
Ah daar, dat je per activiteit kunt aangeven wel of niet. Ergens is dat wel handig bedacht maar vergt wel even omdenken. Daar was ik niet op bedacht en het dus niet gaan zoeken.
  • Donderstraaltje
Donderstraaltje
Mijn bevindingen met integrations (Kodi)
Had toch tijd en heb dit naar voren gehaald; Installeren is gelukt! Het gaat nèt iets anders dan uit de post van de vorige pagina maar dat is vooral te wijten aan de ontwikkeling. Je moet niet de tweede maar de eerste van GitHub hebben ofwel de versie met 'aarch64' in de titel. Verder volgen de versies zich aardig snel op.
Een mooie versie hoe het in de basis (nu) gaat herik hierin gevonden maar mij was het ook bijna zonder extra googlen gelukt;
YouTube: Updating an Integration on the Unfolded Circle Remote 3
Is dit het hele verhaal? Nou ik kan alleen met Kodi testen omdat dat het enige is wat ik heb wat nu ondersteund is. Vanaf hier werd het een frustrerend verhaal en daarom leg ik het spulletje nu weer weg.
Er blijken voor Kodi 3 versies of modi te zijn (weet het woord nog niet binnen de setting van de remote). Een is remote, tweede is film en derde is muziek. De basisnavigatie werkt prima in de remote en film "modus". Maar dan... custom buttonmapping.
Als eerste je kunt via de webinterface alleen naar de remote wegschrijven als het scherm actief is. Dan komt het; wil je een button mapping doorvoeren moet je de remote herstarten. Ik krijg het anders voor geen enkele andere manier voor elkaar dus dat lijkt zo te moeten. So far no biggy!
Nu komt het; dit lukte mij alleen in de film "modus"; ik zou graag de remote "modus" editen en dat lukt voor geen ene meter! Deze heeft nummers 0-9 om te kunnen zappen. Welke twee ik had willen toevoegen waren Kodi:guide om de tv guide op te roepen want ik kijk via mijn Kodi box ook tv. Opnames staan klaar zonder reclame want die worden eruit gefilterd en ik kan gewoon doorspoelen; in een woord heerlijk. Verder wilde ik ondertiteling via een knop aan/uit kunnen zetten voor net die dialecten of een taal welke je niet spreekt. Opnemen heb ik voor nu gelaten. Nou dat alles gaat dus alleen in film "modus"... je lijkt ook de remote "modus" aan te kunnen vinken maarde blijft niet aan staan?
Uiteindelijk was het resultaat via de webinterface of remote toevoegen nèt anders. In het kort via de remote is het verwachtingspatroon voorspelbaarder. Alleen niet prettiger vanwege het kleine schermpje maar dat kun je vooraf weten. Een IP toevoegen gaat overigens super door een keyboard met cijfers en karakters; dat wisselen tussen twee toetsenborden op andere remotes vond ik toch echt wel super vervelend.
Waar zitten de problemen nu echt? ik denk haast bij de integration omdat het via de ene "modus" wel aardig lukt en de andere niet. Het voelt heel erg beta en dat komt ook wel overeen. Toch had ik inde tijd verwacht dat het wel iets verder zou zijn. Wellicht breaking changes op de achtergrond? who knows.
Er is wellicht meer uit te halen als je een slag dieper zou kijken waarin je meer op de hobbytour komt wat overduidelijk een flink aantal mensen hier ook niet willen. Je blijft dan waarschijnlijk flink fixen. Maar; in de basis is het zoals het nu gemaakt is bovenal wèl gebruiksvriendelijk! Mijn eindoordeel; nog te vroeg voor de masses; te doen als je alleen basic dingen wilt; wil je hobbyen be prepared for frustration. Het zal wel waarschijnlijk integration specifiek zijn maar ik kan gewoonweg niet verder testen dan Kodi nu anders dan een aantal zaken via infrarood; maar dat heb ik juist al jaren perfect vervangen voor CEC en stuurt Kodi zelf perfect aan. Muziek heb ik van Kodi afgesplitst en voor Lyrion is nog geen integration. Tot zover...
  • Donderstraaltje
Donderstraaltje
Beta Release 2.6.3
This patch update includes many web-configurator improvements, an active WiFi scanning mode for improved connectivity and updated Apple TV and Denon AVR integrations.
Known issues:Beta Release 2.6.3
Known issues:
• WiFi high-channels (>11) do not work anymore, we are working on a fix.•
Sonos integration: a recent speaker firmware update affects the local device API access. Connection issues might be resolved temporarily by power-cycling the Sonos device(s). We are planning a rewrite of the Sonos integration using a different API.,
Fixed
• Denon AVR integration: Fix power state mismatch and update of volume when using HTTP. Contributed by @henrikwidlund, thanks! (integration-denonavr#89, integration-denonavr#90).
• Apple TV integration: Setup flow fails when using manual IP address (integration-appletv#48).
• Custom integrations: set execute permissions on all files in the bin folder to allow starting other processes.
Remote 3:
• Increase button backlight brightness. The slight color shift when using white as background color will be improved in a future update.
• Increased output power of the internal IR transmission LED in the remote (#541)).
Fixed
Added
Web-configurator:
• Keepalive option while editing.
• Initial German and Swiss German translations. More translations will follow!
• WiFi band configuration for Remote 3 (restrict to 5 or 2.4 Ghz).
• Configuration for active WiFi scan.
• Test mode for commands in an activity.
• Apple TV integration: support for EPG/Guide command. Contributed by @henrikwidlund, thanks! (integration-appletv#45).
Changed
Web-configurator:
• Dock discovery: option to restart discovery, support article links, show friendly dock name if available.
Show a clear message if no IR output is available.
• IR-remote entity: show the reset option only for customized commands, remove "saving changes" popup.
Improve resource list layout.
• Redesign IR test function when adding an IR remote.
• Prompt for entity addition when copying.
• Highlight dangling entities in the activity screen.
• Improve custom IR & learning screens.
• Multi-language fields only show available languages with option to add the current language.
• Add missing list paging instead of auto-load or preload all data.
• Denon AVR integration - all contributed by @henrikwidlund, thanks!
• Add remote entity with support for original Denon IP commands and pre-defined UI screens (integration-denonavr#87).
• Discrete commands for inputs (#527).
• Support for Quick/Smart commands (#486).
• Add HEOS playback control support for Denon and discrete mute control (integration-denonavr#91).
• Only subscribe to relevant Telnet events (integration-denonavr#85).
• Include Marantz in the driver name (integration-denonavr#86).
• Decrease the polling interval to keep state up to date (integration-denonavr#88).
• Crowdin translations, and adding Dutch, Spanish and Swedish translations (integration-appletv#12).
• Update pyatv library to 0.16.1 that should fix connection issues with tvOS 18.4+ (integration-appletv#53.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.6.5
This patch update fixes some web-configurator regressions from the last update.
Known issues:
Fixed
• Active WiFi scan option cannot be disabled in remote user interface.
• High CPU consumption while media-player "loading" animation is running.
Web-configurator regressions from last release:
• Custom icons are no longer shown in the icon picker (#547).
• Adding or removing a user interface in the activity view requires a manual refresh (#549).
• Denon AVR integration: remote-entity user interface page names.
• Remote 3: another display initialization adjustment to avoid sporadic interlace effects after wakeup.
  • batteries4ever
Dit is toch de achilleshiel van de Unfolded Circle. Dit topic begon begin 2024, anderhalf jaar later zijn we aan het klooien met een aantal basic zaken als Kodi besturing en naar mijn indruk een zooitje code die enthousiaste gebruikers hebben geschreven en issues als Wifi met de hogere kanalen (niet per se nodig, maar idioot dat dat niet gefixed is).
Ik schreef in Februari 2024: "De prijs is een dubbel probleem: het kost meer (duh...) maar daardoor zal deze remote ook niet zo populair worden dat er een grote user base ontstaat met fora tips, ontwikkelingen e.d. Komt er een Chinees die een grote database aan remotes heeft en dat ding goed programmeerbaar maakt, veegt ie deze van de tafel, voor 100€ (maar niet zo mooi als deze). De hardware hebben ze kennelijk voor elkaar, de software is waar ik de problemen zie..."
Ik wilde maar dat ik er volledig naast gezeten had en we een prachtige AB hebben met een fantastische database, een geweldig UI en een enthousiaste fanbase. In plaats daarvan...
Overigens ziet het er bij de competitie eerder slechter uit: Cantata Haptigue is maar weer eens een kickstarter begonnen... https://www.kickstarter.c...iversal-remote-controller
[ Voor 9% gewijzigd door batteries4ever op 12-08-2025 10:59 ]
  • Theetjuh
Voor nu blijf ik het topic gewoon nog volgen en kijken of het iets wordt.
De Harmony Elite werkt voor nu nog goed genoeg, maar als dit goed omarmd wordt en zoals je al benoemd meer ondersteuning krijgt, zie ik er zeker vanuit een opensource en cloud-free echt wel heil in.
  • Donderstraaltje
Donderstraaltje
Waar ik net achter kom... als je de Kodi integration wilt updaten naar 1.5.0 over 1.4.3 moet je eerst 1.4.3 verwijderen... dat is ook lekker handig. Daarom had ik toch echt gehoopt, dit is ook zeker een populaire integration geloof ik zo, dat deze direct uit de lijst te installeren was en werd geüpdate.
De custom button mappings onthoudt ie wel alleen links en rechts wel rode foutmeldingen. Niet alle settings blijven dus behouden.
  • Pierre
Pierre
Van nature lui!
Tegen de tijd dat die van mij op de mat valt zijn dit soort issues wel verholpen hoop ik :z
  • Arfman
  • Laatst online: 29-11 11:38
Arfman
Drome!
Pierre schreef op dinsdag 12 augustus 2025 @ 14:28:
Dat hoop ik ook maar. In juni 500+ euro overgemaakt naar aanleiding van o.a. dit topic, reviews op internet en de website. Ik mag toch hopen dat je voor dat geld geen seconde(n) hoeft te wachten voordat je het volume harder of zachter kunt zetten ...
  • nklerk
batteries4ever schreef op dinsdag 12 augustus 2025 @ 10:50:
Ik wil hier toch even op reageren, want in mijn ogen is je bericht wat kort door de bocht. Kodi bediening in de basis stelt geen reet voor, er zijn meerdere manieren waarmee we prima kodi out of the box ondersteunen. denk aan bluetooth, Infrarood. Via een API vergt specifieke ontwikkeling en we zijn erg blij dat een communitymember dit voor zijn rekening neemt. dit opent nieuwe mogelijkheden welke uniek zijn.
Op het moment ondersteund de firmware mischien niet kanaal 11+ op 2,4Ghz. (een fix wordt overigens nu getest), dit idioot vinden mag maar is wat overdreven hoop ik. Kanaal 12 en 13 worden vrijwel nooit gebruikt en 5Ghz is in alle gevallen aan te raden. baarnaast zijn we voor driver ontwikkeling voor een deel aangewezen op de fabrikant.
Ik hoor vaak dat de afstandsbediening prijzig/duur is, als je het plat slaat is het een hoop geld voor een afstandsbediening. Helaas is het wel een reële prijs. een product op de markt brengen gaat gepaard met enorme kosten en dat zit verwerkt in de prijs. desondanks hebben we een enorm kundige community weten op te bouwen waar een hoop integraties vandaan komen.
Ik hoop dat mijn bericht een beetje de andere kant van het verhaal verteld. maar het blijft wij van WC-eend dat begrijp ik :-D
  • nklerk
Donderstraaltje schreef op donderdag 24 juli 2025 @ 10:24:
Ik denk dat je het beste je bediening kan doen via IR of bluetooth en de extras kan gebruiken van de Kodi Integratie. en dus combineren, dit doe je door een activity aan te maken, hier kan je meerdere entiteiten in combineren. Zo kan je CEC, IR, Bluetooth en whatever combineren. Mijn Android TV bedien ik voor 70% met de android integratie de andere 30% (inclusief volume) via IR omdat mijn TV niet alle Android standaarden heeft overgenomen.
Ik moet je adviseren om eens op de UC Discord of Forum te kijken, daar is heel veel kennis en kunnen anderen je in specifieke gevallen verder helpen.
  • nklerk
Donderstraaltje schreef op dinsdag 12 augustus 2025 @ 14:03:
Neem even contact op met de developer van de integratie. misschien heeft hij tips voor je.
  • nklerk
Als ik mij niet vergis is dit iets wat op de ToDo lijst staat om te implementeren in activities. Zal er zeker aan komen, de vraag is even waneer, daar heb ik geen antwoord op.
  • nklerk
Voor de Homey gebruikers onder ons, wie o wie zou mij willen helpen met het testen van een nieuwe versie?
Er zijn verschillende issues opgelost, de meeste hebben te maken met devices welke niet meer in homey staan maar nog wel bekend waren in de afstandsbediening. dit gaf dan weer issues voor andere devices.
https://homey.app/a/com.unfoldedcircle.uc/test/
Geen nieuwe dingen, wel een hoop issues opgelost.
  • canonball
  • Laatst online: 19:28
nklerk schreef op woensdag 13 augustus 2025 @ 13:32:
maakt het wat uit of op de UC zelf de beta of gewone firmware draait voor het testen?
  • Theetjuh
nklerk schreef op woensdag 13 augustus 2025 @ 12:58:
Ben ik zeker met je eens, ik denk ook niet zo zeer dat de prijs het probleem is.
Maar in mijn ogen wel de prijs voor het product wat het nu is, althans zo het na het nodige onderzoek lijkt.
Voor mij nog zeker geen vervanger van de Harmony Elite en gewoon te prijzig om de gok te nemen.
Ik vind het ook zeer jammer dat de dock en charger niet apart zijn.
Dat is voor mij iig, aangezien ik al m'n audio/video buiten zicht heb, geen oplossing zonder een extra dock te moeten kopen (als dat al werkt 2 docks in 1 profiel).
Welke ook al een enorme prijs heeft.
  • Donderstraaltje
Donderstraaltje
nklerk schreef op woensdag 13 augustus 2025 @ 13:12:
CEC werkt al perfect en Bluetooth gebruik ik niet. IR kan een optie worden maar eigenlijk is dat een fallback voor mij. Denk eerder dat ik tegen een bug aanloop want behoudens de custom button mapping werkt het perfect.
  • nklerk
Theetjuh schreef op woensdag 13 augustus 2025 @ 13:40:
Elke dock heeft 2 uitgangen voor IR zenders in bijvoorbeeld een afgesloten kast. verder kan je meerdere IR docks en IR zenders koppellen. zo heb ik meerdere ruimtes ingericht.
  • nklerk
canonball schreef op woensdag 13 augustus 2025 @ 13:38:
Voor Remote two zou ik zeker de beta versie draaien en denk dat het wel uitmaakt omdat er zoveel anders is. Voor Remote 3 maat het niets uit.
  • Theetjuh
nklerk schreef op woensdag 13 augustus 2025 @ 13:52:
Mooi dat het kan, maar dan ben ik 620 euro kwijt voor … een test nog even te duur ;)
  • Boedha
  • Laatst online: 17:42
Boedha
Niks
Wanneer worden ze eigenlijk geleverd? Heeft iemand daar zicht op? In mei de bestelling gedaan.
Tja, wat zullen we daar nou op zeggen!
  • Pierre
Pierre
Van nature lui!
Boedha schreef op zondag 17 augustus 2025 @ 23:01:
Ik zou zeggen kijk eens hier https://www.kickstarter.c...le-remote-3?ref=user_menu ze zitten pas op 35 procent, dus voorlopig duurt het nog wel een poos.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.6.6
This patch update fixes handling of translated language texts in the user interface and some web-configurator issues.
Known issues:
Fixed
• Dynamic update of modified language texts (#188, #405, #568).
Web-configurator:
• Select custom icon element missing in mobile Safari browser (#508).
• Initial fix for command selection box cut off with send command/sequence. Dialog elements still overflow on smaller screens. (#510).
• Renaming a page removes all widgets from the page (#558).
• Search field for background images disappears.
• 'Check your input' error when adding a missing entity while duplicating a page or UI element.
• High CPU consumption while display is off for certain screen elements.
• Denon AVR integration: Denon / Marantz specific quick-select commands (integration-denonavr#108).
Remote 3:
• Display initialization adjustment to avoid sporadic interlace effects after wakeup (#561).
• The sensitivity of the wake-up function using movement (gyroscope) cannot be configured or deactivated. (#572).
Changed
IR database:
• Onkyo AVR1 IR dataset: add missing CURSOR_DOWN command (#571).
• Sony projector VPL-VW270 as temporary workaround for the non-working generic IR dataset, thanks to @kennymc-c for the IR codes! (#520).
• Add Rowenta fans VU5670, VU5770.
  • Donderstraaltje
Donderstraaltje
Beta Release 2.6.9
This patch update adds support for PRONTO IR toggle codes, fixes issues with the QR code, and the installation of custom integrations.
Known issues:
• The native IR-repeat command gets interrupted when a button is held down. We are working on a fix.
Fixed
• Web-configurator QR code in pull-down menu and during onboarding (#499, #589).
• Popup menu closed when home button released when it has opened (#507).
Web-configurator:
• Command selection box cut off with send command/sequence (#510).
• Administrator password help text in settings (#590).
• Custom integration installation: copy the optional config and data directories from installation archive #592.
Changed
• Web-configurator: support IR toggle codes with two PRONTO codes and HEX / PRONTO sequences #484.
  • Donderstraaltje
Donderstraaltje
Dock 3 Beta Release 0.7.1
Added
• Documentation for firmware flashing with esptool and web-serial (#26, #27).
Changed
• Increase of overcurrent limitation to 1850mA (#30).
Pagina: 1 2 3 4 5 Laatste
Dit topic is voor de afstandsbedieningen van Unfolded Circle.
Voor Logitech Harmony is er [AB] Logitech Harmony Advanced Universal Remotes [deel 3]
Voor Cantata Haptique is er Cantata Haptique RS90 en RS90x smart afstandsbediening
Voor andere alternatieven voor de Logitech Harmony, zoals Philips, One For All en Sofabaton is er [AB] Alternatieven voor Logitech Harmony
