Raven schreef op zondag 29 maart 2026 @ 11:34:
Septillion @
tagican @
BGFG @
TheFes Het is gelukt de Myggbett toe te voegen
, overigens zonder smartphone gedaan ->
How to use Home Assistant to add Matter devices without a phone
Eerst werkte die methode niet:
Matter Server
| 2026-03-29 10:22:52.968 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:38555i with Node: <0000000000000000, 0> S:0 M:232652494] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2026-03-29 10:23:21.158 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2026-03-29 10:26:23.158 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:38556i with Node: <0000000000000000, 0> S:0 M:232652495] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2026-03-29 10:26:47.186 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2026-03-29 10:29:50.500 (Dummy-2) CHIP_ERROR [chip.native.EM] <<5 [E:38557i with Node: <0000000000000000, 0> S:0 M:232652496] (U) Msg Retransmission to 0:0000000000000000 failure (max retries:4)
2026-03-29 10:30:13.211 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33 |
OTBR
| 00:32:09.433 [N] MeshForwarder-: Dropping IPv6 UDP msg, len:146, chksum:a71d, ecn:no, sec:yes, error:AddressQuery, prio:low, radio:all
00:32:09.433 [N] MeshForwarder-: src:[fd78:*:*:*:*:*:*:*]:42444
00:32:09.433 [N] MeshForwarder-: dst:[fd78:*:*:*:*:*:*:*]:5540
00:32:09.747 [N] MeshForwarder-: Dropping IPv6 UDP msg, len:146, chksum:a71d, ecn:no, sec:yes, error:Drop, prio:low, radio:all
00:32:09.747 [N] MeshForwarder-: src:[fd78:*:*:*:*:*:*:*]:42444
00:32:09.747 [N] MeshForwarder-: dst:[fd78:*:*:*:*:*:*:*]:5540
00:32:12.641 [N] MeshForwarder-: Dropping IPv6 UDP msg, len:146, chksum:a71d, ecn:no, sec:yes, error:Drop, prio:low, radio:all
00:32:12.641 [N] MeshForwarder-: src:[fd78:*:*:*:*:*:*:*]:42444
00:32:12.641 [N] MeshForwarder-: dst:[fd78:*:*:*:*:*:*:*]:5540 |
Toen las ik dat de BT-adapter niet toegevoegd mag zijn als apparaat, gezien de al toegevoegde BT-adapter al in gebruik was (aanwezigheid detectie) een 2e BT ontvanger aan de HASS-VM gekoppeld maar deze niet als apparaat toegevoegd (als ontdekt laten staan) en nu werkt het pairen wel
Hierbij wel opgemerkt dat de streepjes van de pairingcode niet ingevoerd dienen te worden, zie ook
https://www.reddit.com/r/.../1q61vi5/comment/ny96e4v/
Nog bedankt voor de suggestie! Het heeft anderhalf maand geduurd, maar deze methode wordt inmiddels ook voor mij. Eigenlijk is het vrij simpel voor een bestaande situatie: je hebt een bluetooth stickje (met BLE ondersteuning) nodig om een apparaat te kunnen commissionen via de Thread app zelf. Ik heb de
ASUS USB-BT500 stick (Bluetooth 5.0, compatibel met versies 2.1, 3 en 4) gekocht (< € 10).
Stappen plan voor mij was (HA VM in Proxmox installatie):
1. USB stick inpluggen op de host
2. In Proxmox naar de VM gaan, tabje "Hardware"
3. Add > USB Device: Selecteer USB Vendor/Device ID
4. Selecteer de USB waarbij Manufacturer "Realtei" staat. Het device begint bij mij met "0b05". Weet je het niet zeker of je de goeie hebt? Sluit het venster en haal de stick uit. Als je de actie opnieuw uitvoert staat deze niet in het overzicht. Sluit het venster weer en voeg 'm opnieuw toe.
Hierna wordt de USB stick automatisch herkend door HomeAssistant
5. In HomeAssistant, ga naar System > Integrations. De stick staat nu direct bij "Discovered" (of "Ontdekt"?). Noteer het getal achter de 'hci'. Bij mij was het hci0, dus 0.
6. Ga vervolgens, in HomeAssistant, naar System > Apps > Matter Server en klik boven op Configuration.
7. Selecteer de Toggle voor 'Show unused optional configuration options' en vul het getal van stap 5 in bij "Bluetooth Adapter ID". Dus enkel de 0, zonder de 'hci' .
8. Sla de configuratie op en herstart de addon.
9. Als je nu via de Web UI van de addon op "Commission node" zie je dat de opties "Commission new WiFi device" en "Comission new Thread device" niet langer uitgegrijsd zijn.
Mijn eerste device dat ik heb toegevoegd was overigens ook een MYGGBETT deursensor. Dat werkt prima. (Nadat ik eerst een aantal keer het apparaat in Touchlink mode had gezet ipv Matter pairing mode
