• nero355
  • Laatst online: 10-07 17:18
Buffalo schreef op vrijdag 16 december 2022 @ 17:10:
Gedaan, maar dan krijg ik dit: Kennelijk is er wel iets mis met de lijsten.
[code] [i] Neutrino emissions detected...
[✓] Pulling blocklist source list into range
[✓] Preparing new gravity database
[i] Using libz compression
[i] Target: https://raw.githubusercon...nBlack/hosts/master/hosts
[✓] Status: Retrieval successful
[i] Analyzed 166010 domains
[i] List has been updated
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[✗] Status: Not found
[✗] List download failed: no cached list available
[i] Target: https://s3.amazonaws.com/...ct.me/simple_tracking.txt
[✓] Status: No changes detected
[i] Analyzed 34 domains
[i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
[i] Analyzed 2701 domains
[i] Target: https://blocklist.site/app/dl/malware
[✗] Status: Connection Timed Out (Cloudflare)
[i] Target: https://blocklist.site/app/dl/ransomware
[i] Target: https://blocklist.site/app/dl/tracking
[i] Target: https://blocklist.site/app/dl/fraud
[i] Target: https://blocklist.site/app/dl/phishing
[i] Target: https://v.firebog.net/hosts/AdguardDNS.txt
[i] Analyzed 47352 domains
[i] Target: https://1hos.cf
[✗] Status: 1hos.cf is blocked by https://dbl.oisd.nl/. Using DNS on 208.67.222.222 to download https://1hos.cf
[i] Target: https://zeustracker.abuse...?download=domainblocklist
[✗] Status: Connection Refused
[i] Target: https://hosts-file.net/grm.txt
[i] Target: https://reddestdream.gith...HostsBlocker/minimalhosts
[i] Analyzed 710 domains
[i] Target: https://raw.githubusercon...aster/data/KADhosts/hosts
[i] Analyzed 84409 domains
[i] Target: https://raw.githubusercon...aster/data/add.Spam/hosts
[i] Analyzed 57 domains
[i] List stayed unchanged
[i] Target: https://v.firebog.net/hosts/static/w3kbl.txt
[i] Analyzed 356 domains
[i] Target: https://v.firebog.net/hosts/BillStearns.txt
[i] Target: https://adaway.org/hosts.txt
[i] Analyzed 7355 domains
[i] Target: https://raw.githubusercon...list/master/adservers.txt
[i] Analyzed 42553 domains
[i] Target: https://v.firebog.net/hosts/Easyprivacy.txt
[i] Analyzed 15240 domains
[i] Target: https://raw.githubusercon...track/master/trackers.txt
[i] Target: https://raw.githubusercon...master/data/hosts/spy.txt
[i] Analyzed 347 domains
[i] Target: https://raw.githubusercon...cklist/master/SmartTV.txt
[i] Analyzed 225 domains
[i] Target: https://s3.amazonaws.com/...e/simple_malvertising.txt
[i] Analyzed 2735 domains
[i] Target: https://www.malwaredomainlist.com/hostslist/hosts.txt
[i] Analyzed 0 domains
[i] Target: https://dbl.oisd.nl/
[i] Analyzed 848900 domains
[✓] Creating new gravity databases
[✓] Storing downloaded domains in new gravity database
[✓] Building tree
[✓] Swapping databases
[✓] The old database remains available.
[i] Number of gravity domains: 1218984 (989483 unique domains)
[i] Number of exact blacklisted domains: 4
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 201
[i] Number of regex whitelist filters: 4
[✓] Cleaning up stray matter
Zo te zien gaat daar echt goed iets mis en moet je echt goed naar je Pi-Hole draaiend bakkie kijken wat betreft het netwerkgedeelte! ;)
Dit is trouwens een leuk voorbeeld van teveel Blocklists hebben :
:o Blocklist die een andere Blocklist tegenhoudt! :D _O- :')
  • dss58
  • Laatst online: 25-04 10:36
nero355 schreef op vrijdag 16 december 2022 @ 17:40:
hahaha, ik ooit meer dan 17 miljoen domains geblokt, gewoon om te kijken of de pi3b het bij kan houden, dat ding gaf geen krimp, aan de load was niks te zien en memory use was weinig meer dan 2 miljoen domains :)
functioneel was het natuurlijk een grote ramp :)
[ Voor 3% gewijzigd door dss58 op 16-12-2022 18:32 ]
  • Webgnome
  • Laatst online: 08:25
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
  [i] Target: https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
  [i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
  [i] Target: https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist
  [i] Target: https://reddestdream.github.io/Projects/MinimalHosts/etc/MinimalHostsBlocker/minimalhosts
  [i] Target: https://raw.githubusercontent.com/StevenBlack/hosts/master/data/KADhosts/hosts
  [i] Target: https://raw.githubusercontent.com/StevenBlack/hosts/master/data/add.Spam/hosts
  [i] Target: https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
  [i] Target: https://raw.githubusercontent.com/quidsup/notrack/master/trackers.txt
  [i] Target: https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
  [i] Target: https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/SmartTV.txt
  [i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt
  [✓] Building tree
  [✓] FTL is listening on port 53
     [✓] UDP (IPv4)
     [✓] TCP (IPv4)
     [✓] UDP (IPv6)
     [✓] TCP (IPv6)
  [✓] Pi-hole blocking is enabled
Kleine tip. Ruim je gebruikte lijsten eens op... :+
Strava | AP | IP | AW
  • Buffalo
  • Laatst online: 08:33
Webgnome schreef op vrijdag 16 december 2022 @ 23:42:
Dit is leuk, want ik heb nog nooit iets aan die lijsten gedaan.
Misschien maar beter om pi-hole helemaal opnieuw te installeren.
  • Webgnome
Buffalo schreef op zaterdag 17 december 2022 @ 07:20:
Hoe komen ze er dan in? M.a.w. iemand heeft ze er in gezet ooit. Dat zijn geen standaard lijsten. Je kunt ze er gewoon uit gooien daar hoef je pihole niet voor opnieuw te installeren. Ik ben zelf nog steeds fan van de the blocklist project en een eigen customized list
[ Voor 17% gewijzigd door Webgnome op 17-12-2022 10:48 ]
  • Church of Noise
  • Laatst online: 15-08 20:55
Church of Noise
Drive it like you stole it
Webgnome schreef op zaterdag 17 december 2022 @ 08:41:
Hoe komen ze er dan in? Dat zijn geen standaard lijsten. Je kunt ze er gewoon uit gooien daar hoef je pihole niet voor opnieuw te installeren.
Exact.
Ik geloof dat op vandaag enkel
als blocklist gebruikt wordt bij een verse installatie.
Hier staat wat meer nuttige info rond hoe je terug naar de 'virgin' situatie komt: https://discourse.pi-hole...lt-pi-hole-adlist-s/32323
  • hjs
hjs
Wat is nu de simpelste, snelste en energiezuinigste manier om een Pi-Hole te draaien?
Heb hem nu op een Zero W draaien maar heb altijd het "gevoel" dat via wifi niet optimaal is.
  • Webgnome
hjs schreef op zaterdag 17 december 2022 @ 10:58:
Waarom zou een Zero W niet optimaal zijn? Ik draai al jaren mijn (nu secundaire) pihole op een Zero W en dat draait als een zonnetje. Een jaartje geleden heb ik hiervoor een Ethernet hat gekocht maar dat was eigenlijk niet strikt noodzakelijk maar meer een gimmick.
Qua zuinigheid kan er bijna niets tegen de Zero W op overigens. De zero W is ook meer dan krachtig genoeg
om een gemiddeld thuisnetwerk te kunnen servicen.
Dus waarom denk je dat het niet optimaal werkt? Als je je Pi naast je router / access point hebt staan dan is er toch niks mis mee?
[ Voor 10% gewijzigd door Webgnome op 17-12-2022 11:05 ]
  • hjs
hjs
Webgnome schreef op zaterdag 17 december 2022 @ 11:04:
Staat op de Fritz inderdaad en wordt van stroom voorzien door de Fritz. En waarom, het idee van bedraad is beter ;)
[ Voor 6% gewijzigd door hjs op 17-12-2022 11:10 ]
  • Webgnome
hjs schreef op zaterdag 17 december 2022 @ 11:08:
zoals gezegd dat is als je hem naast je Fritz hebt geen argument meer. De ethernetpoort kan ook stuk gaan (of de kabel etc). Als je het zeker wil weten koop je een zero w ethernet hat en dan ben je er zeker van. Energiezuiniger wordt het er in ieder geval niet van want die poort moet ook stroom hebben. Misschien dat het door het uitzetten van W dan weer beter is.
Het kan dus wel maar of het 15 euro waard is? Ik heb het een jaar geleden wel gedaan omdat ik het geld kon missen maar achteraf gezien was het niet echt nodig.
[ Voor 7% gewijzigd door Webgnome op 17-12-2022 11:13 ]
  • nero355
Raspberry Pi 3B scoren @ https://tweakers.net/aanbod/ d:)b
Is IMHO nog steeds de beste Pi qua prestaties/verbruik verhouding!
Een goede tweede is de oude 2B maar die heeft weer minder geheugen dus daar moet je niet teveel tegelijk op willen draaien naast Pi-Hole i.c.m. Unbound ;)
Disclaimer : Daarbij moet ik wel zeggen dat ik nog steeds geen soortgelijke vergelijking heb gezien met de 4B erbij en de data die ik in mijn hoofd heb stamt uit de tijd dat de 3B+ uitkwam en het dus slechter deed dan een 3B of een 2B wat prestaties/verbruik betreft!
Sowieso! 8) :*) :Y) d:)b
  • Buffalo
Voordat ik Pihole op een Rp4 draaide, had ik ook een Zero W.
Ik vond de prestaties daarvan tegenvallen. Ik merkte duidelijk dat websites langer aan het laden waren. Met speedtest kwam ik ook niet boven de 5mbit uit.
  • hjs
hjs
Buffalo schreef op zaterdag 17 december 2022 @ 15:38:
Dat is hier niet, merk geen verschil als ik de pihole voor vijf minuten uitzet.
  • Church of Noise
Church of Noise
Vreemd dat er effect gevoeld wordt van systemen die sneller zijn dan een Zero W.
Pi-Hole zelf (ik ga er voor de eenvoud van uit dat enkel pi-hole draait, de situatie verandert uiteraard als er andere zaken op hetzelfde systeem draaien) verbruikte op mijn Zero W een 6-tal procent van de CPU (behalve bij updates van de db natuurlijk) en ook een zeer beperkt deel van het RAM geheugen.
Behalve DNS queries en responses gaat er overigens géén verkeer via je Pi-Hole, dus ik versta niet hoe dit de snelheid zou bepalen.
Experimenten met snellere systemen gaven voor mij overigens geen enkele tastbare verhoging van snelheid...
@Buffalo thx voor het draaien!
Ik had dat rdisc6 tooltje nog niet eerder gebruikt en de output is zo te zien goed bruikbaar.
Zo te zien antwoord onderstaande LLA IP op de router discovery:
Met onderstaande MAC:
Buffalo schreef op vrijdag 16 december 2022 @ 17:26:
 Source link-layer address: 3C:A6:2F:XX:XX:XX
Welke vermoed ik je Fritzbox router is:
pi@ph5b:~ $ pihole-FTL sqlite3 /etc/pihole/macvendor.db "SELECT vendor FROM macvendor WHERE mac LIKE '3C:A6:2F'"
AVM Audiovisuelles Marketing und Computersysteme GmbH
En hij adverteert onderstaande eigen ULA IP als DNS server:
 Recursive DNS server     : fd00::3ea6:XXXX:XXXX:XXXX
Ik neem aan dat nu je IPv6 hebt uitgeschakeld op de router, dat je nu geen RA data meer ziet als je dat rdisc6 tooltje draait toch?
Wat je boven doet is wat velen fout constateren/redeneren.
Wat je moet realiseren is dat als eenmaal de namen naar IP's zijn opgezocht via DNS, dat deze worden gecached in zowel Pi-hole als op de client zelf.
Als deze eenmaal zijn gecached, is Pi-hole helemaal niet meer betrokken bij het laden van een web pagina etc.
Idem voor speedtest.com, DNS latency heeft daar helemaal geen invloed op.
There are only 10 types of people in the world: those who understand binary, and those who don't
nero355 schreef op zaterdag 17 december 2022 @ 14:11:
Ik vind wel dat je dan rekening moet houden met welke funtie je Pi gaat verrichten.
Als dit alleen voor DNS is en mogelijk als VPN server met alleen DNS ge-route, dan volstaat een Pi Zero W prima.
  • nero355
deHakkelaar schreef op zaterdag 17 december 2022 @ 16:15:
Dat zeg ik toch ook! :P
@nero355 , jawel maar daarmee leg je, met een Pi 2B (900MHz en 1GB), de lat hoger dan nodig is.
Zoals je weet draai ik Pi-hole + Unbound nog op een Pi 1B (700MHz en 256MB).
  • Webgnome
zullen we het er maar op houden dat een zero w krachtig genoeg is om een gemiddeld thuisnetwerk van DNS / DHCP te voorzien ( eventueel i.c.m. unbound ) :+
@Webgnome , En mogelijk dat deze ook wel een VPN server erbij kan draaien voor alleen de DNS verzoekjes (dus geen full tunnel).
Niet geprobeerd nog maar met de huidige load die ik zie op m'n Pi 1B kan dat er gemakkelijk bij.
  • Webgnome
@deHakkelaar ja hoor die kan dat. Mijn zero w draait al jaar en dag ook wireguard en dat gaat prima.
zoals al wel vaker beschreven mijn huidige setup ziet er als volgt uit:
Primaire DNS -> rpi 3b
Secondaire DNS + Wireguard -> Zero W
Orange Pi one -> unbound
Eerder draaide er op de secondaire DNS ook unbound en dat was geen enkel probleem. Wat je natuurlijk niet moet doen is een tool als GRC's | DNS Nameserver Performance Benchmark draaien op al je systemen en dan verwachten dat dns requests nog snel gaan.. Dat vind zelfs een 3b niet meer grappig. ( ervaring? nee :+ )
  • Raymond P
  • Laatst online: 09:24
Dat heeft waarschijnlijk minder met de computing power maar meer met de network stack te maken.
Afhankelijk van je surfgedrag kan je dat zeker wel merken. Al is dat tegenwoordig al wat minder dan vroegah toen CDN's nog geen gemeengoed waren en je browser niet meer dan 3 requests parallel deed.
- knip -
  • nero355
deHakkelaar schreef op zondag 18 december 2022 @ 12:53:
Ik onthoud een hoop (soms nutteloze!) dingen, maar dat dus echt niet! :P
@nero355 , stomme aannames van mij elke keer ;)
Ik heb zelfs een poosje Pi-hole + Kodi MC op een Pi 2B gedraaid zonder problemen.
Alleen waren er wel DNS latency spikes als Kodi in transitie was zoals nieuwe media opstarten etc.
Als eenmaal de media speelde merkte je er niks van op DNS niveau.
Toch ben ik er een voorstander van om Pi-hole etc op dedicated HW te draaien of in een container/VM als de host betrouwbaar en zwaar genoeg is.
EDIT: Ow en ik heb ook een poosje Pi-hole + AdvMAME op een Pi 2B gedraaid zonder enige nadelige effecten.
AdvMAME draaide in etalage modus dus deze was constant in een loop de arcade spelletjes aan het opstarten voor een aantal minuten.
Alleen met "Rampage" had ik DNS spikes ;)
[ Voor 24% gewijzigd door deHakkelaar op 18-12-2022 16:11 ]
  • Church of Noise
Church of Noise
https://discourse.pi-hole...-web-v5-18-released/59959
FTL versie 5.20 en Web versie 5.18 zijn gereleased.
Voornaamste nieuws:
FTL: nieuwe versie dnsmasq en grotere cache voor SQLite3.
Draaide deze al even in Dev zonder problemen.
  • ps4mm
  • Laatst online: 06-08 13:38
Als je 'n pihole instelt op je thuisnetwerk, blijft deze gewoon doordraaien als je van provider wisselt?
Of moet je dan (naast netwerk/wachtwoord uiteraard) veel dingen opnieuw instellen?
We stappen vrijwel elk jaar over en gebruiken de meegeleverde modem/router van de provider. Ik ben nu bezig een Zero W in te stellen, maar over 3 weken gaan we van KPN glasvezel (huidig) naar Ziggo kabel dus vraag me af of ik niet beter even kan wachten om dubbel werk te voorkomen..
Hopelijk geen domme vraag.. maar kon in dit topic geen vergelijkbaar vraag/antwoord vinden helaas!
  • hjs
hjs
In het modem het ip adres aanpassen van de verwijzing naar de zero-w @ps4mm volgens mij.
  • Airw0lf
  • Laatst online: 15-08 21:19
ps4mm schreef op woensdag 21 december 2022 @ 23:29:
Hang er vanaf - met een eigen router kan het zo ingeregeld worden dat je jaarlijks alleen de KPN router vervangt door die van Ziggo (en v.v.). Zonder eigen router moet je in de KPN/Ziggo-router:
(1) - minimaal een eigen DNS server (de Zero W) in kunnen stellen.
(2) - DHCP uitschakelen en dit de Zero W laten doen (met de KPN/Ziggo-router als default gw).
Vraagje van mijn kant (off-topic):
Gebruik je van KPN/Ziggo ook de TV-box om programma's op te nemen?
Indien ja: wat doe je dan met die opnames?
makes it run like clockwork
  • Webgnome
Dat hangt helemaal af van je setup. In het beste geval dien je alleen even het netwerk aan te passen in de Router zodat de W automagisch connect met de nieuwe router, daarna de DNS in je router goed in te stellen zodat die de Phole doorstuurt naar de clients en als laatste in pihole de juiste gateway instellen.
Als je de W ook DHCP laat doen dan is het al helemaal een eitje. Wijzig het netwerk in je router zodat die hetzelfde is als in de oude situatie, zet de DHCP uit van je router, wijzig de gateway setting in je Pihole en voila het zou moeten werken.
  • ps4mm
Bedankt voor de hulp en info :) Als netwerk noob ben ik nog aan het uitvogelen wat ik precies wil.
Het lijkt me sws een goed idee om een eigen modem/router te hebben omdat het nogal een gedoe is jaarlijks alles om te pluggen. Plus dan kun je een eigen gastnetwerk instellen etc.
We hebben verder een simpele opstelling, standaard modem/router van provider, daaraan NAS/PS4/tv-box bekabeld. Verder hebben we een 'domme' tv en wat WiFi standaard gebruikers (chromecasts/laptop/telefoons etc).
Lijkt me nu een goed moment om er eens 1 aan te schaffen. Zie dat de Fritzbox hier vaak voorbij komt.
Het zou bij 1 device blijven, heb verder geen bedraad netwerk voor APs en boven is het WiFi signaal ook gewoon OK.
Airw0lf schreef op donderdag 22 december 2022 @ 07:38:
Nee we nemen niks op.. kijken wel eens wat terug maar hebben geen database van opnames die we dan kwijtraken.
Webgnome schreef op donderdag 22 december 2022 @ 07:44:
Heb inmiddels de Pi in het netwerk en kan erbij, nu nog verder met instellen van PiHole etc.
Thx voor de hulp, we gaan het even uitzoeken allemaal!
  • Hann1BaL
  • Laatst online: 23-07 14:22
Hann1BaL
Do you stay for dinner?Clarice
Als punt 1 werkt is punt 2 niet nodig.
Als punt 1 niet kan, gebruik je punt 2 om de limitatie van punt 1 te omzeilen.
  • Airw0lf
Hann1BaL schreef op donderdag 22 december 2022 @ 11:49:
Punt 2 is niet persé nodig - klopt. Maar geeft je net wat meer flexibiliteit bij het uitdelen van adressen en DNS-caching parameters.
Ik gebruik het om mac-based IP's uit te delen zodat devices een vast IP adres hebben.
Tevens heb ik langs deze weg de DNS caching voor endpoints maximaal gezet zodat het werk voor pihole (en daarmee de Zero) tot een minimum beperkt is.
  • Hann1BaL
Hann1BaL
Airw0lf schreef op donderdag 22 december 2022 @ 14:16:
Dit kunnen heel veel routers/modems uiteraard ook gewoon. Dus dat hangt er weer vanaf waarachter de Pi-hole hangt. Maar dan gebruik je het dus met een andere reden.
  • Airw0lf
Hann1BaL schreef op donderdag 22 december 2022 @ 14:19:
Ook dat klopt - maar de vraag ging nu over de functies van de standaard Ziggo/KPN routers.
En die kunnen dat niet (caching) of beperkt (DHCP).
  • Hann1BaL
Hann1BaL
Airw0lf schreef op donderdag 22 december 2022 @ 14:37:
Ben ik wel met je eens hoor. Bij KPN kunnen mensen alleen wel de keuze maken voor een Fritzbox waarbij dat wel kan. Dus het gaat dan specifiek om de “default” opties.
Ik ben nu een jaar weg bij Ziggo, maar mijn modem kon DHCP reserveringen maken, dus mijn apparaten kregen een fixed IP. Dit was nog een Cisco modem, maar dat kan nu wel eens ander zijn.
  • Airw0lf
Zie ook de cijfers in de rode kaders van bijgevoegde afbeelding:
Enig idee wat die precies betekenen? En hoe ze zich tot elkaar verhouden?
Ik heb in een post op het pihole forum gelezen dat de cijfers achter "Load:" betrekking hebben op de belasting van de laatste minuut, 5 minuten en 15 minuten. Maar de meningen zijn verdeeld over wat er dan precies bedoeld wordt met de term "Load".
Enige context over de "utilization"-cijfers van de "Settings >> Sytem"-pagina heb ik nog niet kunnen vinden. Laat staan of (en welk?) verband er eventueel is.
Afbeeldingslocatie: https://tweakers.net/i/kKS445rI1mlIabp1SJVZ88hP7LU=/800x/filters:strip_exif()/f/image/F3R97Agk8VCwWPIB35gyBfQp.png?f=fotoalbum_large
  • Raymond P
@Airw0lf Die info linksboven is systemwide en komt rechtstreeks uit /proc/meminfo en PHP functie sys-getloadavg: https://www.php.net/manual/en/function.sys-getloadavg.php
De info rechts is enkel voor het FTL process: https://github.com/pi-hol...pi-hole/php/func.php#L676
- knip -
  • Webgnome
Zoals @Raymond P ook aangegeven heeft links is system wide (en wat PHP denkt hoe het zit) en rechts i van een enkel proces. In ieder geval @Airw0lf niks om je zorgen over te maken.
Raymond P schreef op vrijdag 23 december 2022 @ 11:57:
@Airw0lf Die info linksboven is systemwide en komt rechtstreeks uit /proc/meminfo ...
Ter info, de load/belasting komt daar ook vandaan:
pi@ph5b:~ $ uptime; echo; cat /proc/loadavg
 17:37:43 up 102 days, 13:25,  1 user,  load average: 0.61, 0.34, 0.19
0.61 0.34 0.19 1/119 25146
pi@ph5b:~ $ man proc
       /proc/loadavg
              The first three fields in this file  are  load  average  figures
              giving  the number of jobs in the run queue (state R) or waiting
              for disk I/O (state D) averaged over 1, 5, and 15 minutes.  They
              are  the same as the load average numbers given by uptime(1) and
              other programs.  The fourth field consists of two numbers  sepa‐
              rated  by a slash (/).  The first of these is the number of cur‐
              rently runnable kernel scheduling entities (processes, threads).
              The value after the slash is the number of kernel scheduling en‐
              tities that currently exist on the system.  The fifth  field  is
              the  PID  of  the  process that was most recently created on the
              system.
De andere stats die worden weergegeven:
pi@ph5b:~ $ ps -o user,group,%cpu,%mem,rss -C pihole-FTL
USER     GROUP    %CPU %MEM   RSS
pihole   pihole    0.7  1.9  8612
EDIT: Ik verveelde me terwijl ik voor iets moest wachten ;)
Satus:
pi@ph5b:~ $ systemctl is-active pihole-FTL
active
Load:
pi@ph5b:~ $ awk '{print $1,$2,$3}' /proc/loadavg
0.29 0.15 0.10
Memory usage:
pi@ph5b:~ $ free | awk '/Mem/{print $3/$2 * 100.0}'
15.0636
Temp:
pi@ph5b:~ $ vcgencmd measure_temp | awk -F = '{print $2}'
48.7'C
FTL version:
pi@ph5b:~ $ pihole-FTL --version
v5.18.1
PID:
pi@ph5b:~ $ pidof pihole-FTL
22930
Time FTL started:
pi@ph5b:~ $ ps h -C pihole-FTL -o lstart
Fri Dec  2 22:18:38 2022
User / Group:
pi@ph5b:~ $ ps h -C pihole-FTL -o user,group
pihole   pihole
Total CPU utilization:
pi@ph5b:~ $ ps h -C pihole-FTL -o %cpu
 0.7
Memory utilization:
pi@ph5b:~ $ ps h -C pihole-FTL -o %mem
 1.9
Used memory:
pi@ph5b:~ $ ps h -C pihole-FTL -o rss
 8612
DNS cache size:
pi@ph5b:~ $ dig +short @localhost chaos txt cachesize.bind
"10000"
DNS cache insertions:
pi@ph5b:~ $ dig +short @localhost chaos txt insertions.bind
"14455"
DNS cache evictions:
pi@ph5b:~ $ dig +short @localhost chaos txt evictions.bind
"0"
[ Voor 30% gewijzigd door deHakkelaar op 23-12-2022 22:27 . Reden: foutjes ]
  • nero355
Gewoon lekker voor altijd bij KPN blijven zitten en daarvan genieten! :Y) 8) :*) d:)b
Vooral nu beiden IPv6 aanbieden en het standaard is geactiveerd wil je echt niet met dat Dynamisch geneuzel van Ziggo blijven knoeien elke keer! }:| :F :r
Disclaimer :
* nero355 is na 20+ jaar xDSL een ontzettend KPN Fanboy geworden wat betreft hun opzet qua netwerk en de betrouwbaarheid daarvan enz... :$ O-) :+
  • ps4mm
nero355 schreef op zondag 25 december 2022 @ 18:53:
Disclaimer :
Pihole draait nu lekker op KPN, was even zoeken in het modem wat er nu precies ingesteld kon/moest worden, maar als ik het goed heb begrepen heb k de pihole op vast IP gezet en de DNS van de router datzelfde ip gegeven. Werkt prima. DHCP settings kon ik niks aan veranderen (kpn box 12 aan glasvezel).
M'n vrouw is nog niet helemaal 'om' aangezien er nu google ads te zien zijn die niet klikbaar zijn. En in sommige android apps komen alsnog ads (instagram?)
  • Gunner
Gunner
Invincibles
ps4mm schreef op maandag 26 december 2022 @ 19:36:
Kan je de range niet aanpassen of de DNS niet?
oplossing hier.
[ Voor 7% gewijzigd door jpgview op 26-12-2022 22:42 ]
  • Xqlus1ve
  • Registratie: Augustus 2019
  • Laatst online: 15-08 21:24
Xqlus1ve
Ik roep ook maar wat…
Haar telefoon en tablets hebben nu een andere DNS, zoek het maar uit met je advertenties _O-
Maar wel continu zeiken over youtube en facebook reclames :')
  • nero355
Kwestie van africhten! >:) :+
Kan allerlei redenen hebben...
Is al zo vaak besproken dat je dat zelf mag opzoeken met de Topic Search bovenaan! ;)
Xqlus1ve schreef op maandag 26 december 2022 @ 22:46:
Je kan haar ook gewoon in een excluded groepje zetten via de Pi-Hole webGUI ;)
Voor YouTube zou ik effe checken of je nog via iemand aan de installatie meuk van YouTube Vanced kan komen! }) :*)
  • Lizard
nero355 schreef op dinsdag 27 december 2022 @ 00:05:
Of zelf patchen met de nieuwe Revanced manager. :P
  • vj_slof
  • Laatst online: 15-08 17:55
Ik heb zelf in de browser een bookmark gemaakt waarmee Pihole tijdelijk is uit te schakelen. Je kunt in de url zelf het aantal secondes vooraf ingeven. Dus loopt er iemand in het netwerk tegen een adblock aan en toch de pagina persé moet bezoeken kunnen ze op de vooraf ingestelde url klikken en daarna toch de pagina met de ads bezoeken.
  • sweetdude
  • Laatst online: 12:09
sweetdude schreef op zondag 11 december 2022 @ 16:46:
Door mijn eigen antwoord er plots achterkomen dat ik het zelf niet meer werkend heb.
In mijn OpenWRT had ik onderstaande (de meeste wel bekende) code in gebruik:
#keep network on pi-hole
iptables -t nat -I PREROUTING -i lan -p tcp --dport 53 -j DNAT --to 192.168.0.9:53
iptables -t nat -I PREROUTING -i lan -p udp --dport 53 -j DNAT --to 192.168.0.9:53
#punch DNS hole for pi-hole
iptables -t nat -I PREROUTING -i lan -p tcp -s 192.168.0.9 --dport 53 -j ACCEPT
iptables -t nat -I PREROUTING -i lan -p udp -s 192.168.0.9 --dport 53 -j ACCEPT
Echter, met de overstap van IPtables naar NFTtables in de laatste OpenWRT versies zijn deze komen te vervallen.
Zelf ben ik te weinig wegwijs in deze materie om dit te converteren.
Of is er nu een andere/ betere oplossing om dit te doen?
Ik had zelf deze guide gevonden. Echter ga ik nat [phun intended] op de NAT rule omdat ik daar geen destination port kan opgeven in Luci. Ik draai momenteel versie 22.3.
Ondertussen erachter gekomen dat het door mijn eigen stommiteit komt, RTFM en voldoende alcohol de afgelopen dagen die de half afgestorven hersencellen defintief de nek hebben omgedraaid.
Deze guide werkt perfect voor hetgeen ik wil:
https://jeff.vtkellers.co...ough-pihole-with-openwrt/]deze guide
LET OP:
Bij de portforward regel op de advanced tab dient er een "!" voor het IP adres van de pihole te staan.
Bij de NAT rules moet je het TCP en UDP protocol aanvinken (en dan komen de source/ destination poort velden erbij te staan 8)7
  • nero355
Lizard schreef op dinsdag 27 december 2022 @ 09:17:
Er is dus een nieuwe versie van :?
If so...: NICE!!! :*)
  • Satangel
  • Laatst online: 13-08 11:40
Ik lees hier ;
Note: Many content providers (like YouTube / Reddit / Twitch / Spotify / Pandora / Facebook / Hulu) now stream/serve ads from the same servers as the content (meaning if you attempt to block the ads using a Pi-Hole you will also block the content).
Is een Pihole zo anno 2023 het eigenljk nog waard? Dat lijkt me irritant.
Domme vraag wellicht, complete noob hier. Aan het kijken of ik dit eindelijk eens een kans ga geven om te draaien op mijn Synology DS420.
  • JorzoR
  • Laatst online: 02-08 08:50
Satangel schreef op woensdag 28 december 2022 @ 15:24:
Ik lees hier ;
Ik gebruik de PiHole sinds een paar weken, maar ik heb daar nog nooit last van gehad. Dagelijks gaan hier in huis heel wat YouTube filmpjes er doorheen. Wordt er flink wat gepost op Facebook. En zit ik regelmatig te browsen op Reddit. Ik heb er in ieder geval nog niets van gemerkt met aardig wat adlists actief en deze whitelist :9
En mocht het zo ver komen, dan kijken we dan wel weer hoe we daar omheen kunnen werken. Je moet sowieso even in je achterhoofd houden dat als iets niet werkt op de interwebs, het mogelijk kan zijn dat PiHole iets blocked. PiHole even uitzetten en opnieuw proberen en dan weet je het. Daarna whitelisten of zo laten en weer door.
[ Voor 21% gewijzigd door JorzoR op 28-12-2022 15:37 ]
  • Satangel
JorzoR schreef op woensdag 28 december 2022 @ 15:28:
Klinkt heel erg gelijkaardig aan de NoScript die ik thuis draaien heb in mijn browser. Niet altijd even handig, die blocked by default alles op een site die ik niet specifiek goedkeur.
Hoe vaak is dat zo dat je op de PiHole het probleem moet oplossen ivm blocking/whitelist op een nieuwe site? Ik kijk ook vaak naar sportsstreams, niet altijd even legaal, en daar loopt het wel eens mis met blocking.
  • JorzoR
Satangel schreef op woensdag 28 december 2022 @ 15:59:
Tot nu toe nog nooit. Maargoed, dat verschilt natuurlijk per persoon, ligt er helemaal aan wat voor websites je bezoekt en hoe heavy die zijn met tracking/ads/analytics e.d.
Eigenlijk moet je het gewoon even uitproberen :9 Uitzetten kan altijd.
[ Voor 8% gewijzigd door JorzoR op 28-12-2022 16:05 ]
  • Church of Noise
Church of Noise
Ik lees hier ;
Ja, want Pi-Hole houdt andere ads tegen, en daarenboven worden een aantal andere zaken (die minder zichtbaar zijn, zoals bvb tracking) ook mogelijks tegengehouden mits je de juiste blocklists gebruikt.
Ik zou zeggen: lees je eens even in.
  • Webgnome
@Satangel ja. Als je kijkt wat er nog allemaal tegen gehouden wordt is dat zeer zeker wel het geval. Daarnaast zie je dat ze nog vaak andere subdomeinen gebruiken dus kun je die specifiek blokkeren. Daarnaast is het natuurlijk meer dan een add blocker. Het blokkeert ook tracking domeinen etc. Of bepaalde ongewenste content (starts with a p )
Maar bij Youtube gaat het sowieso niet werken aangezien het in de video stream verwerkt zit (zie ook de topic warning)
[ Voor 18% gewijzigd door Webgnome op 28-12-2022 17:33 ]
  • nero355
Ik lees hier ;
[YouTube / Reddit / Twitch / Spotify / Pandora / Facebook / Hulu]
Mensen die dergelijke diensten via een app op hun telefoon/tablet gebruiken verdienen het dan ook om geïrriteerd te worden door advertenties! >:) :P :+
Alles maar dan ook ALLES kan je gewoon via een BROWSER bezoeken en blokkeren wat je maar wilt! :Y) 8) :*)
Vooral iets als Reddit : Dat is gewoon een Forum dat je niet eens wilt bezoeken zonder een PC of Laptop vanwege de leesbaarheid!
Spotify is een draak van een dienst en ik sta er nog steeds van versteld dat het zo populair is... :X
Een beetje applicatie voor muziek zoals FooBar2000 of Audacious laat dat stomme Electron onding alle hoeken van de kamer zien! :P
/RANT van een happy Pi-Hole verslaafde O+ :+
  • Raven
Raven
Marion Raven fan
Neem een smartphone, installeer wat gratis apps (zitten meestal ads in). Gebruik dan die apps achter PiHole en later niet achter PiHole, bijv. wifi uit en dan via 4G. Geloof me, je gaat erg blij zijn met PiHole ;)
Oscar Wilde
  • schroevendraaier480
  • Laatst online: 14-08 15:02
schroevendraaier480
certified prutser
Ik kon zo gauw niet terugvinden hier op het forum of iemand wel eens naar technitium dns server heeft gekeken, dus ik meld mijn ervaringen.
https://technitium.com/dns/
is gratis te gebruiken voor Windows, Mac, Linux, Raspi. Ook is er een docker versie, die gebruik ik zelf.
Installatie van docker container is eenvoudig
docker pull technitium/dns-server:latest
dan met docker compose toevoegen en aanpassen naar behoefte
https://github.com/Techni...master/docker-compose.yml
dan eerste keer aanloggen en admin user aanmaken en vervolgens kan je los gaan op de instellingen. Installeer sowieso de *app* SQLite zodat je de logs in kan kijken.
Wat kan je instellen, anders dan Pihole kan je hier ook een DoT, DoH server van maken. Technitium kent ook allowlists en blocklists. Je kan er ook je eigen domein DNS mee hosten. Caching kan goed worden ingesteld.
Je kan recursive DNS doen, maar ook upstream DoH of DoT en natuurlijk traditioneel DNS. En uiteraard ook fancy grafiekjes over het gebruik.
Jammer dat er zo weinig over te vinden is want het werkt super. Ik heb vanaf mijn Macbook met dnsperf 100k queries er op afgeschoten en geen reconnects of drops, terwijl met diezelfde test Pihole en Aduard nog wel eens een steekje laten vallen.
Dus als je eens wilt experimenteren met zelf hosted DNS ad blockers, kijk dan ook eens naar Technitium DNS.
wat nou router, gewoon een kroonsteentje!
  • Webgnome
@schroevendraaier480 hoe heb je 100k requests afgevuurd?
schroevendraaier480
certified prutser
@Webgnome
Op de Mac kan je met homebrew dnsperf installeren
https://formulae.brew.sh/formula/dnsperf
Dan kun je een content file downloaden:
https://github.com/DNS-OARC/sample-query-data
en dan vanaf de cli
IPv4
dnsperf -f inet -s 1.1.1.1 -d input.txt -v
IPv6
dnsperf -f inet6 -s 2606:4700:4700::1112 -d input.txt -v
Je kan ook DoT of DoH doen, dan moet je een poort argument meegeven
Ik weet niet of je provider er blij van wordt, dus use at your own risk :-)
[ Voor 8% gewijzigd door schroevendraaier480 op 30-12-2022 19:15 ]
  • nero355
schroevendraaier480 schreef op vrijdag 30 december 2022 @ 19:05:
Een beetje raar om dit op je website te zetten :
Nobody really bothers about domain name resolution since it works automatically behind the scenes and is complex to understand. Most computer software use the operating system's DNS resolver that usually query the configured ISP's DNS server using UDP protocol. This way works well for most people but, your ISP can see and control what website you can visit even when the website employ HTTPS security. Not only that, some ISPs can redirect, block or inject content into websites you visit even when you use a different DNS provider like Google DNS or Cloudflare DNS. Having Technitium DNS Server configured to use DNS-over-TLS or DNS-over-HTTPS forwarders, these privacy & security issues can be mitigated very effectively.
En dan vervolgens dit te zeggen :
Privacy & Security
Technitium DNS Server supports using DNS-over-TLS and DNS-over-HTTPS protocols for forwarders allowing you to use popular public DNS resolvers like Cloudflare, Google & Quad9. These protocols provides privacy by encrypting your DNS traffic on the network and protects you from man-in-the-middle attacks.
Dus :
- Vertrouw niemand!
- Maar vertrouw vervolgens wel bedrijven die dus gewoon je data harvesten! 7(8)7 :F
Op je telefoon of zo :?
Mijn Linux bakken werken alleen maar met APPLICATIES !!! :P
Daar hebben wij Unbound voor :)
Dat kan ook allemaal met Pi-Hole en zo te zien komen de Default Blocklists zelfs flink overeen :
Afbeeldingslocatie: https://technitium.com/dns/ScreenShot3.png
Ik ken die URL's net niet uit mijn hoofd... :P
Zie eerdere comments...
AdGuard moet je sowieso niet gebruiken : Zit een commerciële toestand achter!
Wat dat betreft twijfel ik ook aan dit project, want gesponsord door een grote Europe Hoster :
Afbeeldingslocatie: https://technitium.com/img/logo-eltris-bg.svg
Liever niet :)
* nero355 wordt erg achterdochtig als iemand ineens dit soort dingen gaat zitten promoten, terwijl het gebruikte account amper actief is geweest :
Registratie: April 2002
Posthistorie (142 berichten)
Daarnaast komt de nickname me totaal niet bekend voor... :/
schroevendraaier480
certified prutser
@nero355
Ieder zijn ding, als je tevreden bent met Pihole en/of unbound dan die lekker blijven gebruiken.
De *app* is iets binnen Technitium, dus niet op je telefoon gelukkig. Standaard wordt niets gelogd in Technitium tenzij je dus een database aansteekt.
Ik gebruik mijn account niet veel en lees meestal mee, maar als je argument is dat ik daarom less credible ben dan mag je dat vinden hoor :) Ik heb geen kwade bedoelingen en deel graag hier mijn ervaring met Technitium. Misschien dat anderen een andere mening zijn toegedaan, dat is prima. Ik ben er blij mee en dat wilde ik graag delen.
[ Voor 42% gewijzigd door schroevendraaier480 op 30-12-2022 20:04 ]
  • andregroeneveld
  • Laatst online: 03-04 16:13
Hallo allemaal, sinds gisteren worden er diversen pagina's geblokt door de pi-hole die ik voorheen normaal kon bezoeken. Zelfs diverse school pagina`s van mijn dochter en zelfs deze pagina van tweakers. Ik moet nu diverse malen mijn pi-hole uitzetten. Is er wat veranderd sinds gisteren?
Als ik alle lijsten bij ad list disable krijg de pagina`s nog steeds niet.
[ Voor 11% gewijzigd door andregroeneveld op 05-01-2023 06:09 ]
Groetjes André,
  • Webgnome
andregroeneveld schreef op donderdag 5 januari 2023 @ 06:02:
  • Welke add lists gebruik je ?
  • Pihole heeft een update script. Zou die gedraaid kunnen hebben?
  • zo ja, Welke add lists zijn er veranderd?
  • Je kan in pihole zien welk domein op welke add list staat meen ik
  • Je weet dat wanneer je pihole uitzet je waarschijnlijk tegen de dns cache van je systeem aan zit te klikken?
Addlist disablen, browser sluiten, browser openen en kijken of het werkt.
  • Airw0lf
Mijn 0,100 Euro: lijkt erop dat er iets is veranderd in je netwerk.
Wat denkt het apparaat (Windows?) wat zijn DNS server(s) en default gateway is?
Oftewel wat is de output van "ipconfig /all" (Windows-only)?
Zitten daar misschien twee verschillende DNS-servers tussen?
  • andregroeneveld
Ik heb op diverse apparaten in huis hetzelfde probleem. Ik ben niet zo handig maar heb alle lijsten uitgezet en dan nog krijg ik die pagina's niet. Misschien moet ik eerst dan rebooten voordat ik dit check?
Addlist disablen, browser sluiten, browser openen en kijken of het werkt. Dit ga ik eerst proberen.
Bedankt voor jullie respons!
Groetjes André,
  • Webgnome
Mocht het nou niet werken dan kun je ook nog in een commandline
ipconfig /flushdns ( als je op windows zit tenminste ). Maar ik denk zomaar dat er een addlist is veranderd aangezien op je al je apparaten niet meer bij die domeinen kan komen.
Wat je ook kunt doen is in de log van pihole kijken of dat wanneer je naar een van die domeine gaat, of dat deze dan in de lijst rood tevoorschijn komt. Als dat het geval is dan weet je dat dit domein op een van de addlists staat.
Nog een vraag. Krijg je direct als je naar www.domein.com gaat ( de website waar je van zegt dat die het niet meer doet dus ) een not found meldin in je browser of kom je er wel op en werken er dingen niet?
Airw0lf schreef op donderdag 5 januari 2023 @ 07:23:
Gezien de reactie dat het op alle devices in huis lijkt te zijn, lijkt mij dat pihole een gravity update heeft gedaan en dat er nu op een van de lists die domeinen zijn geblokkeerd
[ Voor 30% gewijzigd door Webgnome op 05-01-2023 10:26 ]
  • andregroeneveld
Webgnome schreef op donderdag 5 januari 2023 @ 08:07:
Ik ben nu op mijn werk dus ik ga dat op een ander tijdstip bekijken. Ik kom hier op terug. Maar ik denk dat het zoiets is.
Groetjes André,
  • Airw0lf
Mja - eens - maar er is ook gesteld dat het probleem zich ook voordoet als "alle lijsten uitgezet" zijn. Als dat inderdaad het geval is, dan speelt een gravity-update-probleem geen rol meer - toch? Dan is pihole niet meer dan een "gewone" DNS-server?
  • Webgnome
Dat is natuurlijk de vraag. Vandaar dat ik wilde weten als ie alles laat zoals het is en browsed naar een van die domeinen of ze dan in de pihole log terecht komen. Als die er in komen en ze zijn groen en ze doen het nog niet is er wat anders aan de hand. Zijn ze rood dan is het uitzetten van lists niet goed gegaan of zit ie tegen dns cache aan te kijken
  • andregroeneveld
Ik heb alle lijsten uitgezet en daarna de browser uit, de pi hole gereboot en dan kan ik nog niet naar tweakers en anderen toe. Het zijn echt een hoop pagina`s die ik niet meer kan bereiken. Ik moet elke keer de pi hole 10 seconden uit zetten om er te komen. Dus dat is wel apart.
[ Voor 30% gewijzigd door andregroeneveld op 06-01-2023 06:01 ]
Groetjes André,
  • Webgnome
andregroeneveld schreef op vrijdag 6 januari 2023 @ 05:56:
En wat zeggen de logs van Pihole ?
Webgnome schreef op vrijdag 6 januari 2023 @ 06:29:
@andregroeneveld , doe eens het volgende:
log in op Pi-hole via SSH;
voer het commando pihole -t uit om de logs live te volgen;
browse met een client naar 1 vd probleem sites;
en copieer/plak de resulterende log regels naar hier zodat we kunnen spieken ofdat er wat fout gaat.
  • andregroeneveld
Ik ga dat doen. Alvast bedankt voor jullie opties om dit te tackelen.
Ik kan de raspberry pi niet meer bereiken met putty. Er is wel iets geks aan de hand?
[ Voor 39% gewijzigd door andregroeneveld op 06-01-2023 19:29 ]
Groetjes André,
  • Opi
Opi
Is het mogelijk hoge latency te voorkomen wanneer ik pihole op een nas in docker draai en de nas cpu intensieve taken uitvoert?
Op dit moment ben ik uitgeweken naar een raspberry pi die via pxe een image van de nas ophaalt tijdens het booten. Deze oplossing vind ik nogal omslachtig (maar voorkomt de afhankelijkheid van een sd-kaartje).
  • Webgnome
Waarom zou je pi op een nas willen draaien als je ook een aparte rpi hebt liggen? Ik zou er gewoon een sd kaartje in stoppen. Het is nou niet dat die dingen wekelijks stuk gaan ;)
  • Opi
Opi
Mijn vraag is niet of de nas of de pi de optimale oplossing is voor mijn use case, maar of ik een hoge latency kan voorkomen met als randvoorwaarde dat ik pihole op de nas draai. :)
Maar om toch je nieuwsgierigheid te bevredigen wil ik geen device hebben draaien als het niet nodig is, heb ik wel slechte ervaringen met sd-kaartjes en werkt wat dat betreft de pxe oplossing net wat relaxter dan de sd-oplossing. ;)
  • Raymond P
@Opi Je zou logging geheel uit kunnen zetten en privacy op anonymous mode, dat scheelt (een hoop) cycles.
- knip -
  • Church of Noise
Church of Noise
Hier ook een voorstander om het apart te draaien.
En als je log2ram gebruikt, of meteen DietPi als distro, dan beperk je het aantal writes ook...
  • Opi
Opi
@Raymond P, dank voor de suggestie. Doel je hierbij op de nas-oplossing of de sd-variant?
  • Raymond P
Opi schreef op vrijdag 6 januari 2023 @ 19:25:
Het is een manier om cpu cycles te ontlopen, een antwoord op je vraag dus (NAS).
Nu vraagt pihole sowieso al niet al te veel resources, dus het zal maar minimaal helpen.
Als dat niet helpt zou je naar cpu scheduling priority kunnen kijken. Hoe en of dat werkt in een docker opgeving weet ik niet.
- knip -
  • Opi
Opi
Thanks, @Raymond P. Eens kijken wat dat oplevert.
  • andregroeneveld
deHakkelaar schreef op vrijdag 6 januari 2023 @ 06:37:
SD kaartje is ook niet meer te lezen, ik heb het pas allemaal nieuw gekocht pi 4 met sd??? Echt raar?
Ik ga nu alles opnieuw instaleren op een ssd schijf.
[ Voor 13% gewijzigd door andregroeneveld op 07-01-2023 09:37 ]
Groetjes André,
  • Xqlus1ve
Xqlus1ve
EA Origin game launcher wou maar niet werken, even Pi-Hole op pauze gezet en opnieuw ingelogd, sinsdien werkt hij weer, iemand dit eerder gehad (Terug zoeken gaf 0 resultaten en ben wel nieuwsgierig door wat eigenlijk).
  • Church of Noise
Church of Noise
Xqlus1ve schreef op zaterdag 7 januari 2023 @ 10:21:
Pi-Hole logs doorlopen...
  • Church of Noise
Church of Noise
andregroeneveld schreef op zaterdag 7 januari 2023 @ 08:54:
Het lijkt er heel erg op dat je SD kaart kaput is...
Dan doen ze heel onverstaanbare dingen, soms zelfs intermittent en zo (no need to ask how I know :) )
  • andregroeneveld
Het werkt nu weer als vanouds. Ik ga maar proberen een nieuwe sd te krijgen want dit is wel heel snel defect geraakt. Op de SSD doet hij het trouwens ook goed.
Groetjes André,
  • andregroeneveld
deHakkelaar schreef op zaterdag 7 januari 2023 @ 11:28:
@andregroeneveld , is je voedingsprobleem nou goed verholpen? Ja, ik heb een nieuwe zwaardere voeding gekocht.Dat was met de pi 3B+
andregroeneveld in "Raspberry Pi: Ervaringen en Discussie - deel 2"
Zo hoort het eruit te zien:
deHakkelaar in "Raspberry Pi: Ervaringen en Discussie - deel 2"
Het draait nu weer goed met de pi 4
Groetjes André,
  • nero355
andregroeneveld schreef op zaterdag 7 januari 2023 @ 10:37:
Deze gebruik ik al 4 jaar of zo : https://www.dataio.nl/san...icro-sd-32gb-met-adapter/
En nu is deze tekoop die wat groter en amper duurder is : https://www.dataio.nl/san...s-i-v30-a2-geheugenkaart/
Combineer dat met een originele voeding en het kan eigenlijk niet meer verkeerd gaan, tenzij je ontzettend veel pech hebt! :)
  • ewf
  • Laatst online: 15-08 21:58
ewf
Als je problemen hebt met een SD kaart zou je ook een EMMC kaartje kunnen overwegen, gaat langer mee en is meestal sneller.
Kijk eens op: https://www.uugear.com/pr...-module-for-raspberry-pi/
  • DikkieDick
  • Laatst online: 02-06 12:56
Gewoon op SSD blijven draaien. Doe ik ook. Zo nu en dan ff een backup naar de sd-kaart, alhoewel ik me afvraag of dat echt nodig is. :-) De belangrijke data gaat toch al sowieso middels backup naar externe schijf gekoppeld aan de Fritzbox. Maar ja, mocht die SSD het ooit begeven kan ik ook redelijk snel weer online zijn.
aka pluim003 - Marstek Venus v1 - UGreen DXP2800
  • nero355
ewf schreef op zondag 8 januari 2023 @ 18:58:
Die heb ik volgens mij weleens eerder gepost in dit topic of het algemene Pi Topic maar eigenlijk wil je het liefst gewoon UFS geheugen of inderdaad een HDD/SSD gebruiken, want eMMC is precies wat het zegt : Enhanced MMC
En dat is stiekem dus helemaal niet zo geweldig en puur een budget alternatief voor UFS geheugen! :D
  • HyperBart
  • Laatst online: 10:55
Ik gebruik al een aantal jaar Pi-Hole maar sinds een half jaartje (denk ik) merk ik op iPhones heel veel moeite hebben naar een aantal websites te surfen.
Met name de websites van de Belgische VRT en Sporza lijken hier heel vaak niet te laden. De balk geeft dan al weer "vrt.be" maar hij geraakt er niet of HEEL moeizaam door. Als ik even 4G aanzet en dan terug Wifi gaat alles supersnel, het lijkt ergens dus een "eerste connectie of validatie" die niet goed gaat. Met een iPhone troubleshooten is ook niet echt evident.
Iemand een plan van aanpak om dit uit te zoeken?
PiHole is up to date en draait op een VM'tje op ESXi bij mij thuis.
Pi-hole v5.14.2 FTL v5.20 Web Interface v5.18
Upstream DNS zijn Comodo en Quad9 (heb zonet Quad9 uitgezet en ben naar CloudFlare DNSSEC gegaan)
Ik zie geen blocks op domeinen die met VRT gerelateerd zijn.
Pi Hole Diagnosis geeft ook geen grote fouten (buiten een aantal rond DNS packetsize maar die heeft hij al gelowered dus)
Use DNS SEC staat aan.
Ik maak gebruik van 1 adlist: https://dbl.oisd.nl/
[ Voor 29% gewijzigd door HyperBart op 10-01-2023 09:38 ]
  • Webgnome
@HyperBart Had je al in dit topic de search gebruikt om te kijken of iemand anders vergelijkbare problemen heeft ( hint: ja ).
Misschien heeft het hier mee te maken:
I don't think this is a pi-hole issue.
Also, the reddit link you posted has a solution:
Go into the network settings for each wifi or ethernet connection and disable Limit IP Adress Tracking.
Verder als je via 4g geen problemen hebt en via pihole wel, zou het dan stiekem niet en of ander domeintje zijn dat vrt nu ineens wel nodig heeft? Videoland is er ook zo eentje. De aller eerste keer inloggen moet je van alles en nog wat deblokkeren anders kom je niet door je prefs controle heen. Daarna is het goed
  • nero355
HyperBart schreef op dinsdag 10 januari 2023 @ 09:26:
Teveel om op te noemen wat er mis kan gaan : Tot allerlei iOS specifieke meuk qua instellingen tot iets totaal anders als het DNS verkeer of alle verkeer dat ineens stil valt door brakke firmware van je Accesspoint of gewoon de verkeerde instellingen...
Ik zou zeggen pak de Search bovenaan erbij en test alle gerelateerde termen uit : Apple/iOS/Sporza/VRT/enz. :)
in tweakers, software update, Microsoft Edge 109.0.1518.49
zie mijn opmerkingen over DoH discovery en HTTPS queries. Zolang pihole actief is vormt de DoH discovery geen probleem, tenzij er naast het IP van pihole nog een DNS server gevonden word. Dit kan gebeuren wanneer je ook IPv6 gebruikt op je client machine. Wat edge doet met de data, verkregen door de HTTPS query, is mij niet bekend, alles werd al geblocked (HTTPS -> nodata)
countermeasures:
- pihole regex:
.*;querytype=HTTPS;reply=nodata
-suricata:
reject dns any any -> $EXTERNAL_NET 53 (msg:"HTTPS query"; content:"|00 01 00 00 00 00 00 01|"; content:"|00 00 41 00 01|"; fast_pattern; distance:3; classtype:external-ip-check; sid:1000002; rev:5; metadata:affected_product Any, attack_target Client_Endpoint, created_at 2023_01_01, deployment Perimeter, former_category DNS, signature_severity Minor, updated_at 2023_01_01;)
- RPZ, lees hier, block alle bekende DoH servers, lijst groeit elke dag.
- firewall: lees hier, block de IP addressen van alle bekende DoH servers, uitzonderingen zijn nodig (zie pdf).
@jpgview , tjemig das wel heel radicaal om alle HTTPS DNS verzoekjes af te schieten.
Breek je daarmee niet andere functionaliteit van bv Apple apparaten die ik geloof veelvuldig van dit type records gebruik maken?
HTTPS records zijn er niet alleen voor DoH discovery.
deHakkelaar schreef op vrijdag 13 januari 2023 @ 19:03:
De HTTPS regex is al een hele tijd actief, eerste vemelding hier, nu heb ik er reply=nodata aan toegevoegd, omdat de reply time dan lager word (0.3ms, 0.4ms). Zelf heb ik geen apple devices, maar krijg er wel regelmatig over de vloer (en dus mijn wifi gebruiken - MAC based IP assignment only). Die devices doen inderdaad regelmatig HTTPS queries, en ondergaan dus de regex (blocked). Nog geen merkbare problemen gehad, zelfs wanneer er een OS update word uitgevoerd (laatst nog een volledige monterey over big sur op macbook pro, geen problemen).
Het zal nu inderdaad even afwachten zijn, of microsoft services (cloud?) die van de HTTPS info gebruik zouden maken, nog werken. Gelukkig maak ik zelden gebruik van cloud based services, ik hou er niet zo van om dingen in de cloud te gebruiken en / of op te slaan, met de regelmaat van de klok word er wel een of ander datalek bekend gemaakt, waarbij je (cloud) (account) gegevens op staat liggen. Liever niet dus...
Zelf heb ik tot op heden géén negatieve effecten van die regex block gehad, time will tell, effect mogelijks anders voor andere gebruikers (andere apps, browser habbits, ...) Ik ga er vanuit dat het allemaal wel zal meevallen, immers, wanneer je firefox gebruikt zie je (op windows) totaal geen HTTPS queries, voorlopig dus geen impact op de browser experience.
Ik block trouwens ook alle ANY queries en de (meer recente) SVCB queries.
edit
Na een paar dagen is het mij eindelijk duidelijk geworden waarom de suricata rule toch regelmatig een alert gaf: pi-hole whitelist entries! De oplossing lijkt een regex whitelist te gebruiken, die bepaalde query types uitsluit. helaas kan je dit momenteel slechts voor één type. Het goede nieuws is dat de developer dit onderzoekt. Topic (feature request?) hier.
/edit
[ Voor 10% gewijzigd door jpgview op 15-01-2023 12:57 ]
Ik las vandaag over de mogelijk om een Pi-Hole gebruik te laten maken van Secure DNS, zodat je met android apparaten via Private DNS gebruik kunt maken van je Pi-Hole. Weet iemand hier een goede complete handleiding voor, die voor een relatieve leek te gebruiken is?
Pagina: 1 ... 88 ... 112 Laatste
Let op. Pi-Hole werkt niet voor het blokkeren van YouTube reclames.
Bekijkt eerst je eigen logs, voordat je hier een vraag stelt.
