Onderstaande toevallig?
pi@ph5b:~ $ cat /proc/cpuinfo
Model           : Raspberry Pi Model B Rev 2
pi@ph5b:~ $ lsb_release -a
Description:    Raspbian GNU/Linux 11 (bullseye)
pi@ph5b:~ $ journalctl -u unbound | grep Consumed
Nov 13 13:51:59 ph5b systemd[1]: unbound.service: Consumed 2.223s CPU time.
Nov 13 13:54:23 ph5b systemd[1]: unbound.service: Consumed 1.086s CPU time.
Nov 21 14:56:19 ph5b systemd[1]: unbound.service: Consumed 1min 3.555s CPU time.
Nov 21 15:09:16 ph5b systemd[1]: unbound.service: Consumed 1.018s CPU time.
Dec 06 04:41:50 ph5b systemd[1]: unbound.service: Consumed 1min 46.469s CPU time.
Dec 06 05:20:40 ph5b systemd[1]: unbound.service: Consumed 1.592s CPU time.
Dec 31 12:44:07 ph5b systemd[1]: unbound.service: Consumed 56.975s CPU time.
Jan 06 18:44:02 ph5b systemd[1]: unbound.service: Consumed 41.729s CPU time.
Jan 07 22:31:54 ph5b systemd[1]: unbound.service: Consumed 10.151s CPU time.
Tov een ouder model Pi (EDIT: en OS):
pi@ph5a:~ $ cat /proc/cpuinfo
Model           : Raspberry Pi Model B Rev 1
pi@ph5a:~ $ lsb_release -a
Description:    Raspbian GNU/Linux 10 (buster)
pi@ph5a:~ $ journalctl -u unbound | grep Consumed
pi@ph5a:~ $
Beiden zijn identiek ingericht (EDIT: Ow behalve dan dat de oude Pi ook nog DHCP extra doet).
There are only 10 types of people in the world: those who understand binary, and those who don't
  • nero355
  • Laatst online: 10-07 17:18
@deHakkelaar
NOPE.AVI :-(
Maar ik ben wel erachter dat die UDP melding een cosmetisch is iets blijkbaar sinds de laatste update :
# pihole status
  [✓] FTL is listening on port 53
     [✗] UDP (IPv4)
     [✓] TCP (IPv4)
     [✗] UDP (IPv6)
     [✓] TCP (IPv6)
  [✓] Pi-hole blocking is enabled
vs.
# lsof -Pni:53
COMMAND    PID   USER   FD   TYPE   DEVICE SIZE/OFF NODE NAME
pihole-FT 6548 pihole    4u  IPv4 24566060      0t0  UDP *:53
pihole-FT 6548 pihole    5u  IPv4 24566061      0t0  TCP *:53 (LISTEN)
pihole-FT 6548 pihole    6u  IPv6 24566062      0t0  UDP *:53
pihole-FT 6548 pihole    7u  IPv6 24566063      0t0  TCP *:53 (LISTEN)
Rare meuk...
  • ed1703
nero355 schreef op woensdag 12 januari 2022 @ 14:44:
@deHakkelaar
NOPE.AVI :-(
# pihole status
     [✗] UDP (IPv4)
     [✓] TCP (IPv4)
     [✗] UDP (IPv6)
     [✓] TCP (IPv6)
vs.
# lsof -Pni:53
Rare meuk...
Raar, hier gewoon alle vinkjes :)
  • Koepert
  • Laatst online: 17-08 21:34
Hier ook alle vinkjes EN up to date.
@nero355 , idem alle vinkjes.
pi@ph5b:~ $ which pihole
/usr/local/bin/pihole
pi@ph5b:~ $ file /usr/local/bin/pihole
/usr/local/bin/pihole: Bourne-Again shell script, ASCII text executable
pi@ph5b:~ $ less /usr/local/bin/pihole
statusFunc() {
  # Determine if there is a pihole service is listening on port 53
  local listening
  listening="$(lsof -Pni:53)"
  if grep -q "pihole" <<< "${listening}"; then
    if [[ "${1}" != "web" ]]; then
      analyze_ports "${listening}"
    fi
  else
    case "${1}" in
      "web") echo "-1";;
      *) echo -e "  ${CROSS} DNS service is NOT listening";;
    esac
    return 0
  fi
analyze_ports() {
  # FTL is listening at least on at least one port when this
  # function is getting called
  echo -e "  ${TICK} DNS service is listening"
  # Check individual address family/protocol combinations
  # For a healthy Pi-hole, they should all be up (nothing printed)
  if grep -q "IPv4.*UDP" <<< "${1}"; then
      echo -e "     ${TICK} UDP (IPv4)"
  else
      echo -e "     ${CROSS} UDP (IPv4)"
  fi
  if grep -q "IPv4.*TCP" <<< "${1}"; then
      echo -e "     ${TICK} TCP (IPv4)"
  else
      echo -e "     ${CROSS} TCP (IPv4)"
  fi
  if grep -q "IPv6.*UDP" <<< "${1}"; then
      echo -e "     ${TICK} UDP (IPv6)"
  else
      echo -e "     ${CROSS} UDP (IPv6)"
  fi
  if grep -q "IPv6.*TCP" <<< "${1}"; then
      echo -e "     ${TICK} TCP (IPv6)"
  else
      echo -e "     ${CROSS} TCP (IPv6)"
  fi
  echo ""
Eigenlijk doet de code dit:
pi@ph5b:~ $ listening="$(sudo lsof -Pni:53)"
pi@ph5b:~ $
pi@ph5b:~ $ echo $listening
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME pihole-FT 971 pihole 4u IPv4 14486 0t0 UDP *:53 pihole-FT 971 pihole 5u IPv4 14487 0t0 TCP *:53 (LISTEN) pihole-FT 971 pihole 6u IPv6 14488 0t0 UDP *:53 pihole-FT 971 pihole 7u IPv6 14489 0t0 TCP *:53 (LISTEN)
pi@ph5b:~ $ grep "IPv4.*UDP" <<< $listening
[ Voor 3% gewijzigd door deHakkelaar op 12-01-2022 22:01 ]
Heb ook maar ff de updates gedraaid:
pi@ph5b:~ $ pihole -up
  [i] Checking for updates...
  [i] Pi-hole Core:     update available
  [i] Web Interface:    update available
  [i] FTL:              update available
     [✓] UDP (IPv4)
     [✓] TCP (IPv4)
     [✓] UDP (IPv6)
     [✓] TCP (IPv6)
  • nero355
Koepert schreef op woensdag 12 januari 2022 @ 16:29:
Welke RaspBian versie draaien jullie precies ?!
Ik kwam een topic tegen waarin iemand hetzelfde probleem had omdat hij nog Stretch draaide en die draai ik blijkbaar ook... :$ O-)
Binnenkort dus maar eens kijken of ik dat veilig geüpgrade krijg naar een nieuwere versie voordat het straks ineens Juni 2022 is! :+
De mijne:
deHakkelaar schreef op woensdag 12 januari 2022 @ 00:17:
  • Koepert
nero355 schreef op woensdag 12 januari 2022 @ 23:39:
Proxmox met een debian (nu) bullseye container
  • ed1703
Ik draai buster. Aangezien dat prima draait, ga ik voorlopig ook niet upgraden.
Hardware is Raspberry Pi 4 Model B Rev 1.2
[ Voor 8% gewijzigd door ed1703 op 13-01-2022 07:49 ]
  • Church of Noise
  • Laatst online: 15-08 20:55
Church of Noise
Drive it like you stole it
Bullseye, en alle vinkjes hier.
  • Raven
Raven
Marion Raven fan
@deHakkelaar
NOPE.AVI :-(
# pihole status
     [✗] UDP (IPv4)
     [✓] TCP (IPv4)
     [✗] UDP (IPv6)
     [✓] TCP (IPv6)
vs.
# lsof -Pni:53
Rare meuk...
Same here, met Raspbian .... 9.
Oscar Wilde
@nero355 & @Raven , wat doet onderstaande voor julie?
pi@ph5b:~ $
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME pihole-FT 11535 pihole 4u IPv4 55625 0t0 UDP *:53 pihole-FT 11535 pihole 5u IPv4 55626 0t0 TCP *:53 (LISTEN) pihole-FT 11535 pihole 6u IPv6 55627 0t0 UDP *:53 pihole-FT 11535 pihole 7u IPv6 55628 0t0 TCP *:53 (LISTEN)
pi@ph5b:~ $ if grep -q "IPv4.*UDP" <<< $listening; then echo -e "OK tick voor UDP (IPv4)"; fi
  • Raven
Raven
Marion Raven fan
deHakkelaar schreef op donderdag 13 januari 2022 @ 10:42:
pi@ph5b:~ $
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME pihole-FT 2135 pihole 4u IPv4 20484644 0t0 UDP *:53 pihole-FT 2135 pihole 5u IPv4 20484645 0t0 TCP *:53 (LISTEN) pihole-FT 2135 pihole 6u IPv6 20484646 0t0 UDP *:53 pihole-FT 2135 pihole 7u IPv6 20484647 0t0 TCP *:53 (LISTEN)
Oscar Wilde
  • Canis Lupus
  • Laatst online: 22:18
Canis Lupus
Vosbot
Mijn PiHole reageerde gisteren opeens niet meer, lijkt een foutje in het filesysteem.
Een kernel-panic met een unmountable vfs.
Dan merk je pas hoeveel ads hij blokkeert :P
Komende week zien of het te repareren is, anders een nieuw SD kaartje erin en opnieuw installeren...
CD's&LP's - Last.fm - About me - PSN&Xbox: CanisLupusNL
  • Webgnome
  • Laatst online: 08:59
mijn advies:
  • als het even kan laat het ding booten van een SSD
  • hanger een SSD aan zodat je de logs etc daar op kan laten schrijven.
  • of gebruik zoiets als log2ram.
[ Voor 11% gewijzigd door Webgnome op 13-01-2022 15:06 ]
Strava | AP | IP | AW
  • nero355
Wat doet onderstaande voor julie?
Dat antwoord heb je al als het goed is! ;)
Maar zullen we het simpel houden ;
# dig @10.0.0.139 ts.31gaming.nl
; <<>> DiG 9.16.1-Ubuntu <<>> @10.0.0.139 ts.31gaming.nl
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61702
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;ts.31gaming.nl.                        IN      A
;; ANSWER SECTION:
ts.31gaming.nl.         3562    IN      A       82.139.82.27
;; Query time: 8 msec
;; SERVER: 10.0.0.139#53(10.0.0.139)
;; WHEN: do jan 13 16:31:49 CET 2022
;; MSG SIZE  rcvd: 59
Dat domein deed het dus eerst niet, terwijl ik die heel vaak gebruik! 8)7
  • allure
  • Registratie: Mei 2001
  • Laatst online: 08:22
allure
Titaan fase 2/3
Sinds de laatste update heb ik aan de lopende band de volgende waarschuwing in de webinterface, weet iemand wat ik hieraan kan/moet doen?
Insecure DS reply received for us-east-1.elb.amazonaws.com, check domain configuration and upstream DNS server DNSSEC support
  • Lizard
  • Laatst online: 16-08 23:22
allure schreef op vrijdag 14 januari 2022 @ 16:27:
Lijkt me een misconfiguratie bij aws? https://dnssec-analyzer.v...-east-1.elb.amazonaws.com
  • allure
allure
Titaan fase 2/3
Awh! nu zie ik het ook ja, wel ergerlijk die knipperende driehoek...
Afbeeldingslocatie: https://tweakers.net/i/YBZGCAwYgJ0X50c2kTTTdT6hkDE=/800x/filters:strip_icc():strip_exif()/f/image/nYkRL8x2ftNrhl11JIYn326N.jpg?f=fotoalbum_large
Ik krijg ineens enorm veel requests van onze eneco toon, iemand ideeën?
  • nero355
Verwijderd schreef op vrijdag 14 januari 2022 @ 19:52:
Kijk effe rond in [Toon] Ervaringen of één van de andere topics waarin dat gekke ding voorkomt :)
Meestal slaat zo'n ding op hol op het moment dat er iets down/offline is gegaan... :X
nero355 schreef op vrijdag 14 januari 2022 @ 20:09:
thnks
  • DikkieDick
  • Laatst online: 02-06 12:56
Een eigenaardig fenomeen. Als ik lokaal naar de webinterface ga via intern ip-nummer:poort dan kan ik wel de submenu's uitvouwen bij bv. Group Management en Disable, maar ga ik daar via mijn duckdns.org heen dan lukt dat niet. Gebeurt er niks als je er op klikt.
Ik draai dit op de Raspberry Pi 4 met Nginx proxy manager. Meerdere met een soortgelijke configuratie die dit 'probleem' herkennen?
aka pluim003 - Marstek Venus v1 - UGreen DXP2800
  • nero355
DikkieDick schreef op zaterdag 15 januari 2022 @ 14:18:
Waarom is je Pi-Hole via het Internet benaderbaar :?
Doe jezelf en ons een lol en prop die achter een VPN ;)
  • Webgnome
Zoals al is gezegd. Waarom staat je pihole naar internet open? Of gaat het via VPN. Tweede, heb je foutmeldingen in je browser console?
  • DikkieDick
Webgnome schreef op zaterdag 15 januari 2022 @ 18:10:
Het gaat alleen om de webinterface. Soms handig. Maar idd ook niet echt noodzakelijk.
VPN kreeg ik vooralsnog niet werkend, maar dat is een volgende stap.
Naar foutmeldingen in browser console zal ik eens speuren.
En waarom ik via duckdns.org-subdomein erheen wil? Vanaf kantoor kan ik niet iets met ip-adress:poort doen. Enige poort die nu open staat is dan 443 en de nginx proxymanager vangt de domeinen af. Zo ook voor mijn HomeAssistant. En mijn VPN-kennis gaat nog niet dermate ver dat dit goed zou gaan met een VPN. Als ik het zo lees heb ik altijd iets met ip-adres:poort nodig, of ik zie iets heel ergs over het hoofd.
[ Voor 30% gewijzigd door DikkieDick op 16-01-2022 10:14 ]
  • Church of Noise
Church of Noise
Hoe je je Pi-Hole via VPN kan benaderen staat heel helder uitgelegd in de Pi-Hole documentatie. Je kan kiezen tussen Wireguard en OpenVPN.
  • nero355
DikkieDick schreef op zondag 16 januari 2022 @ 09:45:
Die heeft ook weleens wat exploits die worden gefixt dus die wil je eigenlijk ook niet direct aan het Internet hangen zonder iets van een (SSL) VPN ertussen! ;)
Ik gok 10 minuten werk met PiVPN :*)
Maak dan tenminste je Proxy Setup op zo'n manier dat de webpagina's alleen worden weergegeven als de Client Browser het juiste certificaat aan boord heeft! ;)
Anders kan iedereen erbij en dat is niet handig...
Je kan Wireguard of OpenVPN ook op poort 443 draaien als het goed is...
En anders iets van IPSec/L2TP die dat volgens mij sowieso kan!
Moet je effe zelf uitzoeken... :)
  • DikkieDick
nero355 schreef op zondag 16 januari 2022 @ 15:06:
Ik duik er eens ff in. Thanx… Nee, dat iedereen erbij kan is idd niet handig. Alhoewel je om in te loggen een ww nodig hebt en bij HomeAssistant staat 2FA aan.
  • Koepert
Iemand toevallig ervaring met deze Blocklist?
https://github.com/nickspaargaren/no-google
T klinkt positief, gelijktijdig denk ik, als je zoveel kunt omtrekken, gaat t vast niet lang werken.
Reden van de vraag: Vandaag opeens VEEEEEL Blocks in mn query log van androidtvchannels-pa.googleapis.com..
Gooi dat in DuckduckGo/Startpage en je komt op vanalles omtrent Nvidia Shields, en dus deze blocklist.
[ Voor 35% gewijzigd door Koepert op 17-01-2022 15:45 . Reden: Aanleiding toegevoegd ]
  • MAdD
  • Laatst online: 18-08 16:29
Koepert schreef op maandag 17 januari 2022 @ 15:44:
jou URL komt in veel meer blocklist voor:
Exact matches for androidtvchannels-pa.googleapis.com found in:
  - https://raw.githubusercontent.com/hectorm/hmirror/master/data/adguard-simplified/list.txt
  - https://v.firebog.net/hosts/AdguardDNS.txt
  - https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/SmartTV.txt
 Match found in https://raw.githubusercontent.com/hectorm/hmirror/master/data/adguard-simplified/list.txt:
 Match found in https://v.firebog.net/hosts/AdguardDNS.txt:
 Match found in https://raw.githubusercontent.com/Perflyst/PiHoleBlocklist/master/SmartTV.txt:
Assumption is the mother of all fuck-ups / You're MAdD. Well thank God for that, 'cause if I wasn't this would probably never work
  • Koepert
MAdD schreef op maandag 17 januari 2022 @ 15:52:
Hij werd ook wel geblockt hoor ;) dat was t punt niet.. Vroeg me in eerste instantie af wat t was omdat t vandaag dus opeens een spike is.
  • nero355
De Google invloeden verpesten de Nvidia Shield TV steeds meer zoals je waarschijnlijk wel hebt gelezen in [Nvidia Shield] Ervaringen & Discussie dus ik gok dat die troep er ook bij hoort tegenwoordig door i.p.v. een relatief laag aantal requests per dag het aantal requests naar een flink hoger getal te verhogen! :| :F
  • Koepert
nero355 schreef op maandag 17 januari 2022 @ 19:52:
K heb geen Shield :+ Ik heb wel een Android TV (Sony Bravia..) die doet t dus.
  • nero355
Koepert schreef op maandag 17 januari 2022 @ 19:56:
Ik heb geen Shield :+ Ik heb wel een Android TV (Sony Bravia..) die doet t dus.
Ik ben een beetje duf op het moment dus dat zal ik dan inderdaad wel zelf hebben verzonnen, maar goed...
Een willekeurig Android TV apparaat is ook goed! O-) :+
  • GG85
  • Laatst online: 11-08 03:50
GG85
Maar dit blockt alles van Google of? Dan wordt het namelijk lastig met een Android smartphone
[ Voor 4% gewijzigd door GG85 op 17-01-2022 20:17 ]
  • nero355
GG85 schreef op maandag 17 januari 2022 @ 20:16:
Niet als je een Custom ROM of zelfs een ander OS erop flashed! :*)
  • Koepert
Dat weet k zo niet, maar die indruk wekt t wel.. daarom vroeg k me t ook af..
  • dss58
  • Laatst online: 25-04 10:36
ik heb die bloklijst is bekeken, ze blokken domains van googlevideo.com en dat is gewoon, dom !!! daarom hoef ik die lijst niet, wat mij betreft niet over nagedacht 8)7
  • Webgnome
Geen ervaring mee. 'Gewoon' dit project in de gaten houden.
https://blocklistproject.github.io/Lists/
  • nero355
dss58 schreef op maandag 17 januari 2022 @ 21:19:
Prima deGoogle lijstje dus! }) :P :+
  • TheCeet
  • Laatst online: 18-08 21:42
Misschien niet echt een pi-hole vraag.
Bestaat er een list waarin fake links staan? Hiermee bedoel ik dat links nagemaakt worden, dat ze hard lijken op de echte link maar dat er bv. één karakter aangepast is.
  • Webgnome
TheCeet schreef op dinsdag 18 januari 2022 @ 08:46:
Om phising etc te kunnen voorkomen? Dat is zeer zeker wel een pihole vraagje als je het mij vraagt. Als ik even naar https://blocklistproject.github.io/Lists/ kijk dan zie ik in de 'abuse' list al een groot aantal *fake*
rabobank adressen staan dus die zou je denk ik kunnen gebruiken?
[ Voor 36% gewijzigd door Webgnome op 18-01-2022 09:40 ]
  • TheCeet
Webgnome schreef op dinsdag 18 januari 2022 @ 09:39:
Ja om phishing, spoofing etc te voorkomen.
Blijkbaar noemt die term 'typo squatting'.
Google.be > Go0gle.be als voorbeeld
Hier nog zo'n lijst gevonden:
https://raw.githubusercon...ocklisten/DomainSquatting
  • Webgnome
Ik zou eerst eens die blocklistproject uitproberen voordat je van alles en nog wat gaat toevoegen. Al moet ik wel zeggen dat die github https://github.com/RPiList/specials aardig actief is. Dus misschien is het inderdaad niet heel verkeerd
[ Voor 41% gewijzigd door Webgnome op 18-01-2022 12:35 ]
  • pieterraxis
  • Registratie: Juni 2016
  • Laatst online: 16-09-2025
Novarion schreef op woensdag 19 mei 2021 @ 15:53:
Sinds gister weer eens de Pihole gereset en opnieuw geïnstalleerd.
Draai het op een Raspberry Pi Zero W, aangesloten via de usb-poort van de router.
Nu heb ik (als alles goed is gegaan) Pi-Hole draaien i.c.m. log2ram en Unbound.
Log2ram en Unbound heb ik voorheen niet gebruikt, dus dat is nieuw.
Op de router heb ik als DNS het IP-adres van de Pi ingesteld en in Pi-Hole het DNS adres van Unbound.
Nu ben ik geen programmeur en netwerkspecialist, ik kan enkel mijn weg vinden in het uitvoeren van guides en de ssh commando's uitvoeren. Nu wil ik graag weten of alles naar behoren werkt, hoe kan ik dit controleren?
Edit: Ik heb nu de standaardlijst met 80.000 domeinen op de blocklist, volstaat dit? Of zijn er nog aanbevolen lijsten om toe te voegen? Is het toevoegen van een whitelist dan ook aan te raden?
Ik had voordat ik Unbound installeerde eerst Cloudflared gebruikt, dit heb ik eraf gehaald om Unbound te installeren, volgens mij kon dat niet samen, daar begon de verwarring en het gebrek aan kennis. Zo ook de twijfel of ik het goed heb gedaan en niet de boel heb gesloopt, via het Pi-Hole adminpanel lijkt alles wel netjes te werken.
Weet iemand of unbound en cloudflarED (doh) te combinen zijn?
Ik wil die ene query die dan toch naar buiten moet via doh laten lopen. maar zoals novarion zegt (daar begon de verwarring) kom ik er ook niet aan uit.
  • Church of Noise
Church of Noise
pieterraxis schreef op vrijdag 21 januari 2022 @ 20:55:
Wat is de use case?
De security die je denkt te hebben door DoH te gebruiken, ben je meteen aan de andere kant kwijt door al je DNS verkeer aan Cloudflare te geven. Je kiest er dus voor om je DNS query verkeer te verbergen voor je ISP en te geven aan Cloudflare. Je internet verkeer zelf gaat nog altijd via je ISP overigens...
Het alternatief is Unbound te gebruiken als resolver en rechtstreeks van je netwerk de authoritative DNS servers (verspreid over de hele wereld en niet verbonden aan een instantie zoals Cloudflare, Google, ...). Je kan raden dat dit mijn voorkeur heeft, gezien geen ene partij al je DNS verkeer 'bezit'...
  • pieterraxis
Church of Noise schreef op zaterdag 22 januari 2022 @ 08:33:
Wat is de use case?
Om de verbinding naar de authoritative DNS servers ook af te schermen voor mijn isp.
Of is unbouned ---> authoritative DNS server al encrypted??
  • ed1703
pieterraxis schreef op zaterdag 22 januari 2022 @ 08:42:
De upstream root-servers ondersteunen geen DoH vziw, dus je bereikt weinig met deze effort.
  • pieterraxis
ed1703 schreef op zaterdag 22 januari 2022 @ 10:15:
Maar kan mijn isp dan niet zien welk adres ik aan de top level vraag?
  • ed1703
pieterraxis schreef op zaterdag 22 januari 2022 @ 11:22:
Als de root-servers het zouden ondersteunen ja, maar dat doen ze vziw niet. (tenzij iemand hier andere info over heeft)
Wat je bereikt met DoH of zelfs DoT is dat je opgevraagde dns-records bij cloudflare of google liggen, omdat er geen ondersteuning is voor de protocollen met de upstream root-servers. Je bent dan overgeleverd aan die partijen, want die ondersteunen het wel.
Dan heb ik vanuit privacy-oogpunt liever dat de NL-ISP weet wat ik doe, dan cloudflare, quad9 of google.
  • dss58
Deze video met Bert Hubert YouTube: Tweakers Digital Meet-up Privacy & Security - Bert Hubert gaat voor een groot deel over DNS, met ins en outs en voor en nadelen. :)
  • pieterraxis
ed1703 schreef op zaterdag 22 januari 2022 @ 11:34:
Doen ze niet helaas
Afbeeldingslocatie: https://assets.website-files.com/5fda06d4fe4b4ba14ad334dc/612ea16c9ed4e9fc3f1e071a_6011e04341567714e7bf54b9_DoT-or-DoH-Blog_07162020_AuthoritativeDNS-e1594910168526.png
https://www.dnsfilter.com/blog/dns-over-tls
There is still work that needs to be done in both DNS encryption and SNI (Server Name Indication) encryption.
SNI is the layer above TLS and an extension of the TLS layer. Once you make a DNS request and TLS makes a secure connection with that IP address, SNI tells the server in clear text (not encrypted) what the name of that domain is. While this does not impact things like man-in-the-middle attacks, it does impact privacy. Currently, SNI is not encrypted, though it is something that is being worked on.
While DoT and DoH are the most secure and standardized methods for encrypting DNS, they do not encrypt the request that goes to the authoritative DNS. That request is received in clear text. This is a point of vulnerability in both DoT and DoH, as well as DNSCrypt. Right now there is no standard for encrypting this information.
https://blog.cloudflare.c...on-endgame-an-ech-update/
Cloudflare is wél bezig met ech
in collaboration with other participants in the standardization community and members of industry, we embarked towards a solution for encrypting all sensitive TLS metadata in transit. The result: TLS Encrypted ClientHello (ECH), an extension to protect this sensitive metadata during connection establishment.
Last year, we described the current status of this standard and its relation to the TLS 1.3 standardization effort, as well as ECH's predecessor, Encrypted SNI (ESNI). The protocol has come a long way since then, but when will we know when it's ready? There are many ways by which one can measure a protocol. Is it implementable? Is it easy to enable? Does it seamlessly integrate with existing protocols or applications? In order to assess these questions and see if the Internet is ready for ECH, the community needs deployment experience. Hence, for the past year, we’ve been focused on making the protocol stable, interoperable, and, ultimately, deployable. And today, we’re pleased to announce that we’ve begun our initial deployment of TLS ECH.
What does ECH mean for connection security and privacy on the network? How does it relate to similar technologies and concepts such as domain fronting? In this post, we’ll dig into ECH details and describe what this protocol does to move the needle to help build a better Internet.
  • ed1703
Maar dan nog begrijp ik wel wat sommigen hier willen, maar ook weer niet.
Zodra je een dienst aanspreekt wat in de VS, China of zelfs in het VK zit sta je in de logging. De wens begrijp ik, maar de uitwerking zal je nooit voor elkaar krijgen. Een deel zal loggen, al is het alleen al github waar je de code vandaan haalt.
  • pieterraxis
ed1703 schreef op zaterdag 22 januari 2022 @ 13:41:
En als ik dns over protonvpn stuur? Als ik er één moet vertrouwen dan zijn het die mensen bij cern (Die duivelse openingsceremonie daar gelaten) ivbm Zwitserse privacy wetgeving.
Als iemand een guide weet om cloudflared (om toch protonvpn buiten te sluiten ja) over pivpn te sturen dan ben ik een tevreden mens
  • nero355
pieterraxis schreef op zaterdag 22 januari 2022 @ 14:36:
Dan sta je in hun logging met een beetje pech, ondanks dat zijn claimen dat niet te doen... :+
En daarom is mijn "Default Policy" : TRUST NO ONE!!! :P
Vooral in deze rare tijden waarin dat soort details steeds meer naar boven komen! :| :/
Dan configureer je toch PiVPN zo dat die Pi-Hole voor DNS gebruikt en je Pi-Hole weer de Cloudflare DNS Servers als Upstream Servers gebruikt :?
  • pieterraxis
Eens. Hoe heb jij het draaien dan?
Bonus: https://youtu.be/utL2SQEA2wM tupac: trust NOBODY!!
  • nero355
Gewoon Pi-Hole + Unbound en geen VPN toestanden :Y)
Als je toch al een VPN wilt via een IP dat niet van je ISP is en je af en toe kan wisselen dan zou je een VPS kunnen overwegen en daarop je eigen VPN draaien en dan om de zoveel tijd je webhoster lief aankijken en om een ander IP adres vragen ;)
Ik vermijd YouTube zoveel mogelijk dus die laat ik effe gaan zolang er niet wat meer context bij staat... ;)
  • pieterraxis
Tnx, dan kan ik weer aan de hobby
Filmpje van 43 sec. Geknipt uit een interview uit 1995. Vooral niet kijken :-p
Tnx man
Root en TLD DNS servers hebben idd geen DoH, DoT of enige encryptie.
Authoritative DNS servers voor een domein hebben ook meestal geen DoH of DoT.
Er zullen er misschien een paar zijn die het wel hebben maar dat maakt voor de recursieve Unbound setup niet uit want deze schakelt toch niet zomaar over van Do53 naar DoT of DoH.
Dat zou veels te ingewikkeld worden om voor Unbound uit te zoeken wie wel of geen DoT of DoH heeft.
Do53 is gewoon een beetje oud ;)
Niet het volledig adres vanwege de recursie.
Ik had een keertje uitgezocht welke verzoekjes Unbound allemaal maakte voor een www.instagram.com A record lookup en dat zag er zo uit:
pi@ph5b:~ $ ./unbound_check.sh unbound.good.log | column -t
dig  +norecurse  @192.203.230.10   .                                   NS      IN
dig  +norecurse  @199.9.14.201     com.                                A       IN
dig  +norecurse  @192.54.112.30    instagram.com.                      A       IN
dig  +norecurse  @205.251.193.128  www.instagram.com.                  A       IN
dig  +norecurse  @192.112.36.4     org.                                A       IN
dig  +norecurse  @192.36.148.17    uk.                                 A       IN
dig  +norecurse  @202.12.27.33     net.                                A       IN
dig  +norecurse  @199.19.53.1      awsdns-40.org.                      A       IN
dig  +norecurse  @192.35.51.30     facebook.com.                       A       IN
dig  +norecurse  @192.54.112.30    awsdns-44.net.                      A       IN
dig  +norecurse  @205.251.196.43   ns-1349.awsdns-40.org.              A       IN
dig  +norecurse  @129.134.31.12    c10r.facebook.com.                  A       IN
dig  +norecurse  @205.251.195.46   ns-868.awsdns-44.net.               A       IN
dig  +norecurse  @129.134.30.11    z-p42-instagram.c10r.facebook.com.  A       IN
dig  +norecurse  @43.230.48.1      co.uk.                              A       IN
dig  +norecurse  @156.154.102.3    awsdns-60.co.uk.                    A       IN
dig  +norecurse  @192.36.148.17    .                                   DNSKEY  IN
dig  +norecurse  @192.33.4.12      _ta-4f66.                           A       IN
dig  +norecurse  @192.52.178.30    com.                                DNSKEY  IN
dig  +norecurse  @205.251.198.1    ns-2016.awsdns-60.co.uk.            A       IN
EDIT:
192.203.230.10 = 1 vd root.hints
199.9.14.201 = 1 vd root servers
192.54.112.30 = 1 vd TLD servers
205.251.193.128 = Authoritative server
EDIT2:
pi@ph5b:~ $ dig +short -x 192.203.230.10
e.root-servers.net.
pi@ph5b:~ $ dig +short -x 199.9.14.201
b.root-servers.net.
pi@ph5b:~ $ dig +short -x 192.54.112.30
h.gtld-servers.net.
pi@ph5b:~ $ dig +short -x 205.251.193.128
ns-384.awsdns-48.com.
[ Voor 16% gewijzigd door deHakkelaar op 22-01-2022 20:01 ]
Even bovenstaande buiten beschouwing houden, ja je ISP kan al je un-encrypted verkeer sniffen als ze willen ;)
  • pieterraxis
Dat bedoel ik ja
Dan is het wachten op Encrypted ClientHello :-)
  • GG85
GG85
deHakkelaar schreef op zaterdag 22 januari 2022 @ 20:17:
Maar wat maakt het uit want nadat ze (al dan wel of niet) zien dat je een DNS request doet voor www.instagram.com zien ze alsnog dat je naar het ip adres van instagram gaat.
Dus al zouden de Root en TLD DNS servers DoT of DoH hebben dan ziet je provider alsnog dat je naar de ip van instagram.com surft.
Dat kan je alleen tegen gaan met een VPN maar dan ziet de VPN provider dat allemaal.
Daarom zit ik liever bij een goede NL provider (Freedom) dan bi een shady VP provider.
  • Cyberpope
Cyberpope
When does the hurting stop??
Is er een manier om een snelkoppeling te maken (b.v. in je favorieten op de internetbalk) om b.v. pihole 10 minuten uit te schakelen. Ik krijg mijn vriendin niet helder hoe ze dat via de interface doet.
De manieren die ik gevonden heb op internet werken niet.
B.v. http://192.168.2.13/admin...ble=600&auth=<verwijderd>
  • Kapitein187
  • Laatst online: 17-08 15:26
Cyberpope schreef op zondag 23 januari 2022 @ 09:04:
Evt Pi-remote downloaden (iOS, zullen vast wel Android alternatieven zijn). Daar kan je op de homepage met twee klikken alles uitzetten. Klik 1 is op de knop “schakel alles uit” klik 2 is op één van de voorgestelde tijdspanne.
"Op de wind van gisteren kun je vandaag niet zeilen"
  • rvk
rvk
Of even kijken waarom de api.php manier niet werkt. Want als die niet werkt, dan werkt pi-remote of elk ander programma natuurlijk ook niet (want die werken op dezelfde manier met api.php).
Hier krijg ik {"status":"disabled"} wanneer ik de api-url gebruik. Wat krijg jij te zien?
  • Cyberpope
Cyberpope
Ik krijg "Not authorized!" Terwijl wachtwoord 100% klopt. En wachtwoord tussen " en " geeft ook niets.
Dank.. jullie beiden hebben me op juiste spoort gezet. Ik moet een api-key vullen ipv mijn wachtwoord.
[ Voor 33% gewijzigd door Cyberpope op 23-01-2022 11:01 ]
  • pieterraxis
GG85 schreef op zondag 23 januari 2022 @ 08:42:
Snap ik. Ik weet dat isp dns MOETEN loggen voor x tijd, dus dacht ik dan maken we dat iig zo moeilijk mogelijk voor de standaard log instrumenten.
Dat de man in het midden uiteindelijk adhv de ip adressen die bezoekt nóg alles kan weten, daar kunnen we met een halve eeuw oud ip protocol niets aan doen helaas.
Tnx voor de freedom isp tip
  • nero355
Tijd voor een nieuwe vriendin dan! :)
Maar effe serieus :
Waarom maak je niet een aparte config voor haar apparaten die bepaalde zooi doorlaten :?
Dat kan sinds een bepaalde versie van Pi-Hole namelijk :
- https://docs.pi-hole.net/database/gravity/groups/
- https://pi-hole.net/blog/...5-0-is-here/#page-content
Succes alvast! :)
  • Cyberpope
Cyberpope
nero355 schreef op zondag 23 januari 2022 @ 14:56:
Daar heb ik de koopkracht niet voor :+
Maar effe serieus :
Succes alvast! :)
Is ook een optie, maar ik heb de knop nu werkend en dat vind ik voor nu goed genoeg.
Nog mooier als dat apparaat specifiek zou kunnen, maar geen tijd en/of zin om dat uit te zoeken.
  • nero355
Cyberpope schreef op zondag 23 januari 2022 @ 15:03:
_O- :+
Ik kan me herinneren dat het echt enkele clicks was om zoiets voor elkaar te krijgen dus heel veel werk zou het je niet moeten opleveren :)
  • Koepert
nero355 schreef op zondag 23 januari 2022 @ 15:26:
_O- :+
Dit kan ik beamen. Recent in enkele clicks een groep voor m’n vrouw haar devices aangemaakt om daar een aantal Google adservices wel door te laten
  • Cyberpope
Cyberpope
Voor mijn zwager (keukenboer) is het afstellen van paar scharniertjes in de keuken, slechts een paar slagen met een schroevendraaier. Als ik het doe ben ik 2 uur aan het kloten en dan hangen ze net zo scheef als ik begon (of erger).
Ergo.. als ik echt tijd heb ga ik er naar kijken, eerder niet.
  • nero355
@Cyberpope
Bedoelde meer te zeggen dat het redelijk straightforward is maar goed...
Succes alvast wanneer je er straks aan begint! ;)
pieterraxis schreef op zaterdag 22 januari 2022 @ 23:16:
Dat bedoel ik ja
Ja soms focus ik teveel op een enkel detail zoals "welk adres ik aan de top level vraag" ;)
Zolang de SNI handshake niet encrypted is, maakt het toch niet zoveel uit ofdat DNS dat ook niet is.
Het is zelfs makkelijker om de SNI te sniffen dan de DNS packets te analyseren.
  • Toppe
  • Laatst online: 07:43
Toppe
Oké ✅
Weet iemand of het mogelijk is om de geadverteerde google advertenties in de zoek resultaten wél te white listen?
Zoek ik bijvoorbeeld op ‘Stokke flexibel bath xl’ dan wil ik gewoon een resultaat willen aanklikken. Nu krijg ik een offline pagina te zien.
Toppe schreef op dinsdag 25 januari 2022 @ 19:04:
https://jpgpi250.github.i...20with%20Pi-hole%20v5.pdf
  • nero355
Ik drink geen koffie! :P
Jij moet gewoon van je luie reet af komen en GoT gebruiken zoals het de bedoeling is! >:)
Want dit :
Kan je dus ook met de Search bovenaan vinden... :z
  • Toppe
Toppe
Oké ✅
nero355 schreef op dinsdag 25 januari 2022 @ 21:32:
Want dit :
Als jullie dan de pin optie gebruiken :+
  • nero355
Toppe schreef op dinsdag 25 januari 2022 @ 21:35:
Niet nodig voor iets wat al 100 keer is genoemd en ik ben de TS niet of één van de TS members dus dat laat ik lekker aan hen over! :P
  • pletse
  • Registratie: Januari 2022
  • Laatst online: 01-05 08:20
Beste
Ik slaag er als Belg niet in om de website goplay (site van vier.be) aan de praat te krijgen zodat ik de programma's kan bekijken met pi-hole actief.
Weet iemand wat ik moet whitelisten in pi-hole om content te kunnen bekijken vanaf goplay.be ?
Alvast bedankt voor jullie input!
  • Freee!!
  • Laatst online: 18-08 10:55
pletse schreef op woensdag 26 januari 2022 @ 11:51:
Beste
Probeer het te starten en kijk dan in de log wat er geblokkeerd wordt.
  • pletse
Freee!! schreef op woensdag 26 januari 2022 @ 11:53:
Wel, ik heb dit al ettelijke malen geprobeerd, en zowat alles vrijgegeven wat geblokkeerd werd, maar t lukt me nog niet. Zet ik pi-hole even uit, dan krijg ik de episodes toch te zien...
Ben geen al te grote krak in deze dingen, en misschien heeft een andere Belg toevallig het antwoord, daarom mijn vraag.
Merci alvast om mee te denken!
  • TheCeet
pletse schreef op woensdag 26 januari 2022 @ 11:59:
Welke blocklist(s) gebruik je?
Hier geen issues (wel geen pi-hole gebruiker maar AdGuard Home)
Ik gebruik OISD list en nog andere lists en kan vlot kijken naar afleveringen op Goplay.be
  • pletse
TheCeet schreef op woensdag 26 januari 2022 @ 12:05:
Ik heb er toch een vijvenveertigtal, met o.a. specifieke voor LG en Xiaomi. De lijst kan je hier zien:
https://drive.google.com/...QBuSABce/view?usp=sharing
  • dss58
pletse schreef op woensdag 26 januari 2022 @ 12:24:
tjonge, hoeveel domains heb je dan wel niet geblokt ?
ik zie dit ertussen staan https://raw.githubusercon...le/master/youtubelist.txt een volstrekt overbodige lijst voor pihole dus er zullen er vast meer tussen zitten die niet zo handig zijn, als ik zoiets zie twijfel ik of de samensteller van die lijst wel snapt waarover hij/zij het heeft, i feel sorry 8)7
  • pletse
dss58 schreef op woensdag 26 januari 2022 @ 13:40:
Klopt, deze heb ik ondertussen geschrapt.
Ik heb nu 1.360.000 domains op de blacklist
  • nero355
Kortom : Appels met Peren vergelijking :)
Ik ben effe naar die website met een browser zonder add-ons gegaan en de Cookiewall zit er zo eng uit dat ik maar de boel heb weggeclickt... :| :/
Zoo jammer dat men niet gewoon een "NEE IK WIL GEEN TROEP" optie inbouwt, zoals andere websites dat WEL doen! |:(
En met een browser die wel alles filtert lijkt het erop dat ik niks kan bekijken zonder een account dus tot zover met behulpzaam zijn in dit geval! :') _O- :+
  • Webgnome
* Webgnome mompelt iets over https://blocklistproject.github.io/Lists/
  • pletse
nero355 schreef op woensdag 26 januari 2022 @ 14:18:
Toch bedankt voor de moeite!
  • pletse
Bedankt voor jouw tip! Ik heb even de Everything-lijst ingeladen, en zit nu aan 3 miljoen domains (al de rest even op disabled gezet). Helaas nog geen geluk om goplay.be te kunnen bekijken :'(
  • Webgnome
pletse schreef op woensdag 26 januari 2022 @ 17:23:
dan zou ik heel miniscul de pihole log openen en eens kijken wat er voor domeinen er gebruikt worden. Er moet toch iets zijn dat ie tegenhoud waardoor het niet werkt. Dat moet dan in de log tevoorschijn komen.
Zo weet ik van videoland dat er een aantal conviva ( als ik het goed heb) domeinen zijn die gewhitelist moeten zijn anders werkt dat spul ook niet.
Pagina: 1 ... 68 ... 112 Laatste
Let op. Pi-Hole werkt niet voor het blokkeren van YouTube reclames.
Bekijkt eerst je eigen logs, voordat je hier een vraag stelt.
