• SirLenncelot
Mede-auteur:
  • theduke1989
  • Laatst online: 11-10 09:20
theduke1989
Xiaomi Redmi Note 5 (Pro) - Ervaringen & Discussie Topic
Redmi Note 5 Pro head
Inleiding
Redmi Note 5 Pro is our fastest Redmi Note yet, and it features the global debut of all-new Snapdragon 636 — Qualcomm's newest 14nm offering. This cutting-edge octa-core processor implements Kryo architecture which greatly improves overall performance and power efficiency. The Snapdragon 636 outperforms it's predecessor* by up to 40%. The large 1.25μm pixel dual camera delivers high-quality images, even in low light conditions. Pairing high-quality Sony and Samsung sensors offers a depth of field not available on typical smartphone cameras. The 15.2cm (5.99) FHD+ display uses an 18:9 aspect ratio — the new standard for smartphone displays. 2.5D curved Corning® Gorilla® Glass display. Feels and looks incredible while being extremely resistant to wear.
Naamgeving
Hoewel dit toestel in India gereleased is als de Redmi Note 5 Pro lijkt het erop dat dit toestel in China gereleased wordt onder de naam Redmi Note 5. Bron
Specificaties
OS:Miui9, Android 8.1
Scherm formaat: 15.2cm (5.99) (Diagonal), 2160 x 1080 FHD+, 403 PPI, 8:9 full screen display(~403 ppi)
Chipset:Snapdragon 636, octa-core
CPU:8x Qualcomm® Kryo™ 260 CPU, up to 1.8 Ghz.
GPU:Qualcomm® Adreno™ 509 GPU
2G Netwerk:GSM2/3/5/8
3G Netwerk:WCDMA1/2/5/8
4G Netwerk:4GFDD-LTE, TDD-LTE1/3/5/20/40/41 (120MHz)
Camera (achterkant):Dual camera; 12MP primary sensor, 1.25μm, f/2.2 aperture, 5MP secondary lens, 1.12μm, f/2.0 aperture
Camera (voorkant):20MP sensor, 1.0μm, f/2.2 aperture
SD card:microSD, up to 128 GB (uses SIM 2 slot)
Opslag geheugen (ROM):32 / 64 GB eMMC 5.0 flash storage
Werkgeheugen (RAM):3 GB / 4GB / 6GB LPDDR4X
Luidspreker:1 luidspreker
Simkaart:Dual SIM (Micro-SIM/Nano-SIM, dual stand-by) When two SIM cards are used simultaneously, the primary SIM supports 4G+/4G/3G/2G calling and data while the secondary SIM supports only 3G calls.
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth:v5.0, A2DP, LE
NFC:Nee
Vingerafruklezen:Ja
USB:USB 2.0
Sensoren:Electronic compass, Accelerometer, Proximity sensor, Infrared, Ambient light sensor, Gyroscope, Hall sensor
GPS:GPS, A-GPS, GLONASS, Beidou
Formaat:158,6 mm x 75,4 mm x 8,05 mm
Gewicht:181 g
Accu:4000mAh (typ) / 3900mAh (min) lithium-ion polymer battery 5V/2A charging, QC2.0
Kleuren verkrijgbaar:Black, Gold, Rose Gold, Lake Blue
Er zijn diverse toestellen onder dezelfde naam. Daarmee vooral opletten bij de Note 5 en Note 5 Pro. De Pro versie is de Indische release zonder band 20. De Note 5 is de Chinese release met band 20 en een iets gevoeligere camera. Onderstaande schema maakt eea overzichtelijk.
modellenredminote5
layout redmi note 5 pro
Prijzen
XIAOMI Redmi Note 5 Pro: Levertijden & Prijzen
4G in NL
Sinds de release in China eind maart 2018 is er een versie van de Note 5 die de in NL veelgebruikt band 20 ondersteunt. Verdiep je voor aanschaf goed in de versie die je gaat bestellen.
Links:
Preview door Arnoud Wokke
Nieuwsbericht over rebranding naar Redmi Note 5 in China
Indase Xiaomi Redmi Note 5 Pro pagina
Custom ROM's
Reddit wiki
GoT topic over MIUI custom roms.
MIUI10 officieel beschikbaar voor Xiaomi Redmi Note Pro(Global) via Xiaomi.eu!!!
Google Camera officiele website voor alle builds.
Topicstart schaamteloos geknipt en geplakt vanuit @theduke1989 in Redmi Note 4 topic.
[ Voor 18% gewijzigd door theduke1989 op 08-07-2018 13:40 ]
  • SirLenncelot
Ik zag dat er nog geen topic voor dit toestel gemaakt is. Het is in ieder geval een toestel waarvan ik erg hoop dat er een versie uitkomt die wel Band 20 ondersteunt.
[ Voor 24% gewijzigd door SirLenncelot op 22-02-2018 22:50 ]
  • Dxue
  • Laatst online: 30-09 23:06
Dxue
PSN:EvilDrunk
wat ik heb gelezen over de ervaringen in het verleden is dat we nog wel even moeten wachten voordat er een global versie op de markt komt die band 20 ondersteunt. maar misschien wilt/kan xiaomi nu direct de grote vraag aan en maken ze gewoon 1 hardware matige versie qua banden ipv 2 verschillende.
Het geheim van het handhaven van een succes berust vaak op het succes van het handhaven van een geheim.
  • SirLenncelot
Het is nog wat wisselvallig wanneer en welke toestellen band 20 geschikt gemaakt worden. Wat mij hoopvol stemt is dat de Note 5 (plus) al vrij snel een band 20 versie kreeg en dat er deze maand al een release van de 5 pro buiten India plaatsvindt.
  • Bever!
  • Laatst online: 22:59
Bever!
Zie dit toestel voor beduidend hogere prijzen in de xiaomi shop staan op aliexpress dan genoemd in TS.
  • Rubiks
  • Registratie: September 2015
  • Laatst online: 30-06 00:44
Ik hoop dat de Global versie snel uitkomt en dat hij onder de € 200 gaat kosten.
Is het misschien een optie om de RMN5 i.c.m. een T-mobile abonnement te nemen i.v.m. de 4G banden?
  • Grannd
  • Laatst online: 11-10 20:38
Grannd
da Granndest
Volgens mij komt dit toestel overeen met de Redmi Note 5 die op banggood staat aangeboden, incl. B20 vanaf 200 euro:
https://www.banggood.com/...s=search&cur_warehouse=HK
  • SirLenncelot
Ja die heb ik ook gezien. Echter heeft die dan weer 3gb RAM en slechts 32gb ROM. Dat komt niet overeen met de originele specs van de telefoon. Ik zou hem niet bestellen in ieder geval :X
[ Voor 40% gewijzigd door SirLenncelot op 20-03-2018 16:16 ]
  • Grannd
Grannd
da Granndest
In China wordt hij gewoon in 3GB en 4GB verkocht met resp. 32 en 64GB, zie: http://www.mi.com/redminote5/specs/
Niets geks aan dus.
  • theduke1989
@Rubiks de 3GB variant is onder de €200,-
@SirLenncelot de 4GB variant is op banggood €214,-
Al is de 3GB variant ook prima. Ik had de Note4 Global uitermate geode telefoon en snel niks mis mee.
  • SirLenncelot
Ja ik zie het nu. Xiaomi heeft ook niet echt een duidelijke lijn in zijn producten he..
Deze phone is al onder twee namen gereleased en de 3GB versie is er spontaan bijgekomen ofzo?
Ik heb de OP aangepast.
  • theduke1989
Kan nergens uit het lijstje terug vinden of deze smartphone met Project Treble uitkomt of niet?
als ik xiaomi.eu mag geloven komt er alsnog Android 7.1, en dus geen (PT) op dit is erg jammer natuurlijk.
[ Voor 4% gewijzigd door theduke1989 op 23-03-2018 09:00 ]
  • SirLenncelot
Goede toevoeging, ik heb de OP aangepast.
Interessante link over dit onderwerp.
  • theduke1989
Telefoon staat bij mij al in het mandje bij aliexpress.com €227,- moet nog betalen, heb Aliexpress gekozen wegens de repair warrenty in Spanje/Duitsland dus hoef niet naar China terug te sturen zoals bij Gearbest of Banggood.com.
Helaas als je zo bekijkt met de updatebeleid is dat wat minder. Maar goed we kijken even de kat uit de boom.
Op XDA staat er wel een TWRP beschikbaar, alleen nu nog de roms.
- https://forum.xda-develop...mi-note-5-pro/development
@SirLenncelot als ik jou link bekijk is het wel om te huilen dat er geen Android P uitkomt. Maar goed als we het lijstje van xiaomi.eu bekijken.
Afbeeldingslocatie: https://i.imgur.com/dtmkyT8.png
Dan is eigenlijk 9/10 keer alles toch wel nog op android 7 :( dat is wel een grote minpunt bij Xiaomi.
Al verwacht ik dat er wel LOS15.1 gaat komen, mag hopen van wel (vooral door de India community)
[ Voor 24% gewijzigd door theduke1989 op 23-03-2018 10:19 ]
  • SirLenncelot
De update naar Android 7 voor de Note 4x was volgens mij ook erg laat.
  • nwagenaar
  • Laatst online: 21:18
nwagenaar
God, root. What's the differen
Miui loopt zeker achter qua Android versie, maar ze backporten gewoon de beveiligingspatches en brengen deze ook wekelijks (development branches van de ROM) of maandelijks uit (stable branches).
Mijn Neo Geo MVS collectie
  • ArnieNFW
  • Laatst online: 16-10 01:19
In de uitverkoop over 3 dagen:
https://nl.aliexpress.com...l-Camera/32854848418.html
€170 + UPS verzendkosten.
Er wordt vermeldt:
Global ROM, in overzicht geen NL te vinden echter.
2G: GSM: B: 2/3/8
3G:TD-SCDMA B34: 2100/B39: 1900WCDMA 1/2/5/8
4G:FDD LTE B5: 850/B8: 900 /B3: 1800/B1: 2100/B7: 2600 B4: 1700/B20: 800
TD LTE B38: 2600/B40: 2300
Dus B20(800MHz) lijkt op het toestel te zitten.
De PLUS versie (met de snapdragon 625) gaat voor €135 in de uitverkoop.
Overigens: het is wat lastig wat de verschillen zijn tussen de 5, 5 PRO en 5 PLUS. Heb het idee dat het allemaal door elkaar gebruikt wordt. Keuze stress!!
[ Voor 46% gewijzigd door ArnieNFW op 25-03-2018 11:20 . Reden: B20 vermeld ]
  • radavl
  • Registratie: Maart 2014
  • Laatst online: 19-11-2023
Ben normaal geen fan van pre-orders.
Maar voor die prijs wel eens het overwegen waard.
  • Eleni
  • Laatst online: 21-09 20:16
Banggood heeft hem ook met band 20
  • ArnieNFW
radavl schreef op zondag 25 maart 2018 @ 12:22:
Verdorie; dat had ik gemist:
Tips: Xiaomi Redmi Note 5 Global Versie heeft niet aangekomen, het is pre-sale voor nu.
verwacht 24 April uitgangspunt verzending.
  • SirLenncelot
ArnieNFW schreef op zondag 25 maart 2018 @ 11:09:
Volgens mij zit het zo:
Redmi 5, Snapdragon 450
Redmi 5 plus, Snapdragon 626
Redmi Note 5 Pro, Snapdragon 636, Indische release zonder band 20.
Redmi Note 5, Snapdragon 636, rebrand van de Note 5 Pro voor de Chinese/Global markt met band 20.
  • Reeker
  • Laatst online: 18-09 17:29
Er wordt vermeldt:
2G: GSM: B: 2/3/8
Wat zijn de importkosten?
  • vuurtjih
  • Laatst online: 19:50
Er wordt vermeldt:
2G: GSM: B: 2/3/8
Die 170 is wel voor de gouden versie, de zwarte is een paar tientjes duurder.
1+15 | PS5
  • theduke1989
Er wordt vermeldt:
2G: GSM: B: 2/3/8
Daarnaast moet je geluk hebben dat het nog niet gepakt wordt door de douane. En die kans is vrij groot nu.
Zit je ook nog eens aan de €28,- kosten. Ik heb de mijne voor €217,- inclusief TAX FREE met DHL besteld.
Zie trouwens als je voor de zwarte gaat inclusief DHL het ook rond de €216,- kost met daarbij waarschijnlijk met taxes komt.
[ Voor 5% gewijzigd door theduke1989 op 26-03-2018 08:28 ]
  • Rubiks
theduke1989 schreef op maandag 26 maart 2018 @ 08:26:
Volgens mij kan je dan beter de gratis verzending kiezen, dan heb je minder kans op douanekosten.
  • theduke1989
@radavl Ik ook niet vaak, maar ik heb nu een loan toestel s4 mini dus moet wel upgraden soon.
@Rubiks duurt langer meestal? 1 maand en de kans op gepakt worden blijft.
Voor mij maakt het dan niet echt veel uit om €10,- meer te betalen om zo het sneller te krijgen en geen doaunekosten te krijgen.
Ik vindt het alleen jammer dat er zoveel modellen zijn en je dus echt goed moet zoeken welke je kiest. En het nog niet is ge-released..
  • Stoffa
  • Laatst online: 20:48
Link hier eens naar?
  • ArnieNFW
Het toestel is dus over 2 dagen €170. Ik zie geen prijs verschil per kleur. Zwart/blauw/goud = zelfde prijs.
In mn winkelwagentje is inderdaad het verschil in prijs te zien. Blauw is €178.
DHL €9.
Douane kosten €28; althans, dat wordt hier boven gezegd
Totale kosten dus €207, of €179 als je toestel erdoor glipt. Willekeur, volgens mij.
Overigens: iemand enig idee waarom bij de blauwe -die ik wil hebben- de glass-protector niet te kiezen valt? Zover ik nl kan zien is de voorkant bij de gouden ook wit; en daar kan je er wel eentje kiezen.
[ Voor 24% gewijzigd door ArnieNFW op 26-03-2018 19:58 . Reden: vraag glass protector erbij gezet ]
  • Rubiks
ArnieNFW schreef op maandag 26 maart 2018 @ 19:30:
DHL €9.
Volgens mij is alles van te voren ingepakt. De pakketjes met protector zijn dan op.
  • theduke1989
Klopt ik heb dit ook bij een andere store. Als je de TPU + glass protection wilt, is de zwarte niet leverbaar alleen goud / blauw. En als je bijvoorbeeld de piston in-ear + glass protection neemt is de zwarte leverbaar maar goud weer niet. Echt vaag. Snap dit ook niet.
Maar heb gewoon 3 verschillende cases + 2.D temp glass protection voor 11USD gekocht. Moeten als het goed is een beetje samen op tijd komen de telefoon en de extra cases.
  • radavl
Staat klaar in mijn winkelmandje bij Ali, enkel nog wachten op de uitverkoop korting.
  • Stoffa
Net de aankondiging van de Mi Mix 2s gekeken (kijken of ik verleid kon worden tot een duurder toestel). Wat een oninteressante hap zeg. Al dat gedoe over Ai, augmented reality etc doet me echt niks.
  • theduke1989
radavl schreef op dinsdag 27 maart 2018 @ 09:24:
Welke kleur heb je gekozen? De zwarte komt uit op €207,- hierboven genoemd.
  • radavl
theduke1989 schreef op dinsdag 27 maart 2018 @ 09:45:
De zwarte. Komt morgen met de korting op 183 EUR met glassfilm
  • Rubiks
Hoe zit het eigenlijk met met dat langere scherm formaat? Zijn de foto's dan ook in dat formaat of krijg je zwarte randen of wordt het bijgeneden? En de apps zijn die ook in dat formaat? Hoe worden bijvoorbeeld YouTube filmpjes weergegven?
  • theduke1989
@Rubiks neem aan dat de apps responive Werken. Zou raar zijn als niet.
  • SirLenncelot
goed nieuws op XDA, het is blijkbaar al mogelijk om Android 8.1 te flashen naar de Redmi Note 5 (Pro). En onderaan het bericht ook een opmerking over LineageOS.
Overigens, als ik die aliexpress links bekijk dan zag ik tot gisteren nog een disclaimer staan dat het een onaangekondigde versie betreft waar je preorders voor kunt plaatsen. Vandaag staat de verzendtermijn op 35 dagen.
[ Voor 47% gewijzigd door SirLenncelot op 28-03-2018 08:39 ]
  • BdK9001
  • Laatst online: 20:07
BdK9001
Kalm aan en rap een beetje
SirLenncelot schreef op woensdag 28 maart 2018 @ 08:37:
Sweet! Dan weet ik al helemaal zeker dat ik over een halfuur (AliExpress Sale FTW!) een zwarte ga pre-orderen 8)
Kalm aan! En rap een beetje!
  • hwkinderman
  • Laatst online: 14-10 22:39
Review van TechTablets op Youtube: YouTube: Xiaomi Redmi Note 5 Unboxing (New Chinese Version) & Giveaway
Let op! Hij benoemt dat de Chinese versie (Redmi Note 5) een andere camera heeft dan de Indische versie (Redmi Note 5 Pro), maar dat de Chinese versie dan weer band 20 mist.
Als ik naar zijn video en camera samples kijk, dan hoop ik dat de chinese versie met band 20 komt, dan haal ik die waarschijnlijk en niet de Nokia 7+, omdat de Redmi Note 5 volgens mij ook meer developer-friendly is (het is toch de Whyred (Chinese en Indische variant?))
  • theduke1989
@SirLenncelot er is inderdaad een LOS versie beschikbaar: https://forum.xda-develop...m-lineageos-14-1-t3765529 , en alles werkt dus dat is ideaal. alleen Kernel is nog niet vrijgegeven zie ik: https://forum.xda-develop...hp?p=75942389&postcount=9
Eerste wat ik altijd doe wanneer ik een Xiaomi toestel koop is de Bootloader unlocken. Ik ga niet eerst gebruik maken van de telefoon en dan enkele maanden later om de bootloader te unlocken en zo data te verliezen. Dus meteen unlocken / TWRP installeren ROM installeren of back-up maken en beginnen maar. Veel mensen wachten maanden lang en gaan dan bootloader unlocken Is beetje raar.
echter niet een officiele build van lineageos.org zelf (nightly) maar goed dat het er al is
Kreeg trouwens melding van de ''verkoper'' dat het binnen two weeks wordt verzonden. Dus hopelijk niet de 35 dagen.
[ Voor 39% gewijzigd door theduke1989 op 28-03-2018 08:53 ]
  • SirLenncelot
Ja, de telefoon is nog vrij nieuw en volgens mij is er nog geen uitgestabiliseerde versie van TWRP, Xiaomi.eu rom of LOS. Zou zonde zijn als je het toestel krijgt en je deze vervolgens niet direct van (redelijk) stabiele software kunt voorzien. https://androidjungles.co...-5-install-twrp-recovery/
Ik denk zelf dat ik nog even wacht met het bestellen van de telefoon.
  • radavl
Besteld en betaald. Nu maar wachten.
Helaas is geduldigheid iets wat ik niet goed beheers.
  • BdK9001
BdK9001
radavl schreef op woensdag 28 maart 2018 @ 09:48:
Same here! 8) Ben heel benieuwd hoe deze zich gaat verhouden tot mijn huidige Nexus 5X
  • Stoffa
Zwarte met screen protector betaald. 9 dollar aan coupons + cashback site gebruikt. Kost echt drie keer niks zo deze telefoon.
  • theduke1989
Stoffa schreef op woensdag 28 maart 2018 @ 10:20:
waar bested? en welke variant??
  • Stoffa
theduke1989 schreef op woensdag 28 maart 2018 @ 10:32:
Ali, zwart met glass screen protector. Je kan 2x2 dollar en 1x5 dollar coupon gebruiken. En een cashback website voor nog eens 3%.
  • ArnieNFW
Denk dat ik te laat ben; kan alleen nog met MI BAND bestellen :-(
  • theduke1989
welke store hebben jullie gekozen? ik kan alleen maar €1.60 aan coupons krijgen.. als ik test ....
  • radavl
theduke1989 schreef op woensdag 28 maart 2018 @ 11:36:
Xiaomi online store. Ik had een coupon van ook zoiets van de store. En dan nog eens net geen 5 euro coupon die in had gekregen deze week met hun anniversary acties.
  • Rubiks
Is er al een Xiaomi EU Rom voor de Global?
  • radavl
Afwachten wat de board name is zeker? Als die whyred is wel
De CN versie heeft alleszinds de eu rom
[ Voor 26% gewijzigd door radavl op 29-03-2018 17:05 . Reden: Extra info ]
  • Rubiks
Dat vraag ik me dus af of het Whyred is.
[ Voor 28% gewijzigd door Rubiks op 29-03-2018 17:41 ]
  • radavl
Rubiks schreef op donderdag 29 maart 2018 @ 17:30:
Als ik met niet vergis hebben de global versies altijd dezelfde naam als de CN versie.
  • rens-br
  • Laatst online: 23:44
@SirLenncelot de laatste paar berichten gaan alleen maar over Levertijden & Prijzen. Zou jij of iemand anders even een nieuw topic kunnen starten, zodat het op de goede plek besproken kan worden?
  • Rubiks
Heb geïnformeerd op het Xiaoi EU forum.
Code naam voor Redmi Note 5 Global is idd Whyred !
  • Vlizzjeffrey
  • Laatst online: 13-10 17:10
Als je t-mobile hebt kan je beter niet de global versie nemen, die mist 4g op 900 mhz, de normale versie heeft wel 4g 900 mhz.
Heb je vodafone kan je wel beter de global versie nemen, die heeft 4g 800 mhz, de normale heeft geen 4g op 800mhz.
https://www.kimovil.com/e...,xiaomi-redmi-note-5-32gb
Ik heb hem besteld voor 160 euro, 3gb 32gb versie, de ''normale'' versie, niet global ( ik heb t-mobile).
Fantacy op aliexpress, goede ervaringen mee ( 4x besteld, elke keer'' geluk'' met invoer.)
[ Voor 40% gewijzigd door Vlizzjeffrey op 30-03-2018 03:53 ]
  • theduke1989
  • GS88
  • Laatst online: 13-10 22:41
GS88
π raat
SirLenncelot schreef op zondag 25 maart 2018 @ 17:13:
En volgens GSMArena is de resolutie van de Redmi 5 720p ipv. 1080p. Schermgrootte is 5,7" ipv. 6,0".. en de batterij 3300mAh ipv 4000.
Ik vond het ook in 1e instantie erg onduidelijk wat de verschillen tussen die toestellen nou waren, verder vind ik bij de Note 5 (Pro) de positie van de camera beter. Zo weet je zeker dat je de fingerprintreader gebruikt en niet met je vette vingers over de lens van de camera heen gaat :D
Rotterdam
  • SirLenncelot
Ja er zijn uiteraard meer verschillen tussen de toestellen. De camera is bijvoorbeeld ook een feature die verschilt tussen de toestellen. De Note versies hebben een dubbele camera en er zit ook een verschil tussen de Note versies.
  • rens-br
Vanaf nu mogen berichten over bestellen, leveringen, aanbiedingen, winkels e.d. in: [Xiaomi Redmi Note 5 Pro] Levertijden & Prijzen. Met dank aan @theduke1989.
  • Stoffa
Vlizzjeffrey schreef op vrijdag 30 maart 2018 @ 03:45:
Balen, heb de global versie besteld en heb tmobile. Wel zie ik dat zij naast 900mhz ook 1800mhz gebruiken voor 4g, dus misschien valt t mee?
Überhaupt ben ik geen zware data gebruiker (mail, whatsapp, websites voornamelijk). Iemand een idee of t 4g gebruik dan wel voldoende is zo zonder b8?
  • Vlizzjeffrey
Stoffa schreef op zaterdag 31 maart 2018 @ 14:27:
Het bleek een fout te zijnn in de kimovil info, het is nu aangepast, de global heeft ook 4g 900 mhz :)
Ik ook maar even mijn order gecanceld en de global versie besteld, ook al heb ik band 20 niet nodig, misschien ooit toch handig.
[ Voor 11% gewijzigd door Vlizzjeffrey op 31-03-2018 16:08 ]
  • radavl
Vlizzjeffrey schreef op zaterdag 31 maart 2018 @ 16:03:
Was exact mijn redenering. Ik heb mobile vikings, dus band 20 missen is geen ramp. Maar je weet nooit voor de toekomst...
  • theduke1989
https://www.gsmarena.com/...le_support-news-30391.php
Redmi Note 5 Pro wordt dus met Project Treble ondersteund. Zou betekenen veel sneller Android 8.0 erop ondanks dat ze het met Android 7 leveren :S wat in mijn optiek echt slecht is bij een gloed nieuwe device in 2018.
  • Rubiks
theduke1989 schreef op dinsdag 3 april 2018 @ 17:19:
Xiaomi-EU Rom heeft ook Android 8.1
Afbeeldingslocatie: https://tweakers.net/ext/f/hJBUBFnX7vBZaFTkd6iX55j0/full.png
  • SirLenncelot
Ik weet het niet zeker, maar kan TWRP al geflasht worden naar de Note 5? Kan het nu niet meer vinden maar meen ergens een willekeurige forumpost gelezen te hebben dat de custom roms beschikbaar waren voordat TWRP goed draaide.
  • Rubiks
@SirLenncelot
Er is wel een TWRP bestand voor de RN5
  • theduke1989
Helaas is er nog geen nightly voor de PRO:
https://download.lineageos.org
  • SirLenncelot
Er was wel een onofficiële LOS ROM voor de pro. Dus de nightly zal niet lang op zich laten wachten.
  • Reeker
Is het mogelijk dat iemand de 'goede' link mij even via de pm stuurt? Ik zie zoveel versies en ik zoek wel de versie met de goede camera en bandondersteuning.
  • subwaysurfer
  • Laatst online: 15-10 21:42
Reeker schreef op donderdag 5 april 2018 @ 17:25:
Dat is ook precies wat ik zoek. Ben bang de verkeerde te bestellen....
  • mirod
  • Laatst online: 15-10 07:23
Ik begrijp dat bij de Global versie de camera wat anders (minder) is dan in de normale Chinese versie?
zie https://www.chinahandys.net/xiaomi-redmi-note-5-testbericht/
F2.2 ipv F1.9
  • SirLenncelot
Ik heb wel gelezen dat er een verschil in camera is tussen de India release en de China release. Die Global stempels zijn volgens mij niet officieel van Xiaomi, day is volgens mij iets wat de tussenhandelaren doen. Correct me if I'm wrong.
Het is bij Xiaomi weer opletten geblazen dat je bestelt wat je wilt. En ook nog goed controleren dat je krijgt wat je bestelt ;)
  • theduke1989
Nu nog wachten op de device it self:
https://twrp.me/xiaomi/xiaomiredminote5pro.html
En de LOS15.1 is al actief: https://forum.xda-develop...m-lineageos-15-1-t3774630
Dus de account klaar hebben zodat je an unlocken en installeren. BE AWARE: Ik hoorde in de andere topic wil je de Bootloader unlocken je account(actiefiteit) verbonden bent. Dus als je hogere rang hebt en je bent vaak online je niet 72 uur of 360 uur moet wachten totdat je kan unlocken!!!!!!!!! <- DIT IS NIEUW VOOR MIJ OOK DUS....
@SirLenncelot welke globals zijn er als ik vragen mag? kan je een lijstje terug vinden??
Kon dit vinden in een ander topic:
Afbeeldingslocatie: http://i66.tinypic.com/103x6io.jpg
Heb zelf de 5de model!
[ Voor 39% gewijzigd door theduke1989 op 09-04-2018 13:03 ]
  • SirLenncelot
Volgens mij is er tot nu toe enkel de Indiase release en de Chinese release geweest. De Chinese release heeft de 'betere' camera en band 20 ondersteuning.
Verder is het lijstje waar je naar linkt wel lekker overzichtelijk. Ik zal hem in de OP meenemen.
  • SirLenncelot
jammer dat ook met de verbeterde camera de kwaliteit bij weinig licht nog steeds erg matig is. Ik had gehoopt dat de grotere dynamic range hier ook voor een verbetering ging zorgen.
[ Voor 61% gewijzigd door SirLenncelot op 10-04-2018 22:20 ]
  • Rubiks
SirLenncelot schreef op dinsdag 10 april 2018 @ 22:17:
[video]
Misschien dat het installeren van goolge cam nog voor wat verbetering kan zorgen.
  • nocalimero
  • Laatst online: 21:41
theduke1989 schreef op maandag 9 april 2018 @ 12:54:
Klopt dit overzicht wel?
Want hieruit zou blijken dat de Redmi Note 5 met betere camera (f1.9) wel band nr. 20 heeft. Volgens mij is dat nu juist niet het geval.
Dat blijkt ook uit de video review die Noisia postte, toch?
video
Daarin wordt de Chinese versie gereviewed en bij de pro's en cons staat dat deze wel de betere camera heeft, maar geen band 20.
@theduke1989 theduke1989] :
Je geeft aan dat je de Redmi Note 5 hebt. Kun je aangeven of je band 20 op je toestel hebt en welke camera er in zit? En hoe heb je hem nu al binnen?
  • theduke1989
@nocalimero ik heb deze nog niet ontvangen. Hij wordt waarschijnlijk pas aan het einde van April geleverd aan de verkopers en wordt dan pas verstuurd.
hier meer informative te vinden.
Daarnaast ik heb de SD636 versie, de 5A versie is met een andere SoC volgens mij.
[ Voor 39% gewijzigd door theduke1989 op 11-04-2018 14:16 ]
  • SirLenncelot
Kan het nu even niet terugvinden, maar hij noemt niet expliciet band20 meen ik. Hij benoemt enkel dat de band die bij hem gebruikelijk is niet ondersteund wordt.
  • Piet91
Er zijn 3 versies, zoals in de OP hier ook al wordt aangegeven: theduke1989 in "[Xiaomi Redmi Note 5 Pro] Levertijden & Prijzen"
Redmi Note 5 Pro. Bestemd voor Indiase markt. Heeft geen band 20 ondersteuning.
Redmi Note 5 China version. Bestemd voor Chinese markt. Heeft ook geen band 20 ondersteuning.
Redmi Note 5 Global Version. Bestemd voor de Global markt. Heeft wél band 20 ondersteuning.
Deze laatste versie kun je al wel bestellen/pre-order plaatsen, maar wordt nog nergens verzonden; dit gebeurd pas eind deze maand.
De laatste 2 versies zijn op band 20 ondersteuning na gelijk.
T.o.v. van de Indiase variant hebben ze nog 3 voordelen:
- Camera. andere sensor, f/1.9 versus f/2.2 en dual-pixel phase-detection autofocus,
andere front camera (20MP op de Indiase, 13MP op de Chinese/Global version).
- Accu. De Chinese/Global version ondersteunt Quick Charge 3.0. De Indiase versie Quick Charge 2.0.
- De Indiase variant komt met Android 7.1.2 en de Note 5 met Android 8.1.
Chris van TechTablets heeft dus de Chinese variant, zonder band 20.
Persoonlijk vind ik het woord "Pro" in de topictitels dus ook niet echt handig gekozen, tenzij men het hier natuurlijk over de Indiase variant wil hebben.
[ Voor 20% gewijzigd door Piet91 op 11-04-2018 17:32 ]
  • SirLenncelot
Toen ik het topic aanmaakte was er enkel de Indische variant. De Pro aanduiding is later gedropt door Xiaomi. Ik heb een TR aangemaakt om de titel te laten wijzigen.
Ik zal ook even een aangepast overzicht maken van de verschillende versies Redmi Note 5. Daar laat ik de Redmi 5 serie uit.
  • nocalimero
Piet91 schreef op woensdag 11 april 2018 @ 17:18:
Volgens mij klopt dit niet helemaal toch?
Volgens mij zijn er inderdaad 3 versies, maar heeft de 3e versie (Global Version), die nog niet is uitgeleverd, de camera's van de Indiase versie en QC 2.0. Dat lijkt in ieder geval zo te zijn als ik de Bang Good website check:
  • radavl
nocalimero schreef op woensdag 11 april 2018 @ 19:43:
Als ik jouw link bekijk zie ik geen overeenkomsten met de Indiase versie hoor.
De Indiase heeft 20mp frontcam
  • nocalimero
radavl schreef op woensdag 11 april 2018 @ 19:45:
Je hebt gelijk over de MP van de camera, maar de lens van de Global Version lijkt mij anders dan de Chinese versie. Die is f1.9 voor de Chinese versie en f2.0 voor de Global Version (en blijkbaar f2.2 voor de Indiase versie, maar die heeft weer een 20MP camera?).
Of ben ik in de war?
Blijft staan dat de Xiaomi Redmi Note 5 Global Version een erg interessante mobiel is. Het zou zo maar mijn volgende mobiel kunnen worden ...
  • radavl
nocalimero schreef op donderdag 12 april 2018 @ 09:02:
Zullen het pas echt weten als ze geleverd worden waarschijnlijk. Ongeduldig aan het wachten.
  • SirLenncelot
Ik dacht juist dat de global versie een f1.9 zou krijgen net als de CN versie. Zie nu op Banggood staan 2.0
ach, eerst maar eens afwachten wat er uiteindelijk geleverd gaat worden.
Ik begin wel langzaam te denken dat NFC op het toestel toch nodig wordt. Volgens mij biedt Rabobank al de mogelijkheid om hiermee te betalen..
  • theduke1989
@SirLenncelot bij Xiaomi toestellen heb je niet bij alle NFC chip. Voor mij maakt het niet zoveel uit. Aangezien de banken bij ons in Duitsland echt achterop lopen.
  • Piet91
De Asus lijkt qua uiterlijk ook sprekend op de Note 5. :P
Wel grotere accu. Zal van camera-prestaties, prijs, verkrijgbaarheid en (custom) support afhangen of het een betere keus is dan de Note 5.
  • theduke1989
@Piet91 graantje meepikken van de successen van Xiaomi Redmi note series, vooral in India is dit een erg populaire toestel.
  • SirLenncelot
Piet91 schreef op maandag 23 april 2018 @ 18:27:
In de eerste YouTube vergelijkingen komt de camera van de Redmi Note 5 als (slightly) beter naar voren. Fotos lijken even scherp kleuren zijn iets meer verzadigd en bij het filmen is de image stabilisatie bij de RN5 heel fijn. Tevens vind ik het scherm van de Asus wat gelig ogen vergeleken met de Xiaomi.
Of je veel verschil tussen de accu's gaat merken weet ik niet, ik haal nu prima 2 dagen met mijn RN4 en dat vind ik voldoende.
Enige voordeel van de ZenFone Max Pro lijkt mij de drie-sim zodat je 2 sims en een sd-kaart tegelijk kunt gebruiken. edit: nog geen prijs bekend maar de ZF zou wel eens lager kunnen worden dan de RN5 bij grijze import
Momenteel heeft de RN5 nog mijn voorkeur, en ik lees in het levertijd topic dat de 4GB zwart versie met b20 nu door Xiaomi aan handelaren geleverd wordt. :9~
[ Voor 5% gewijzigd door SirLenncelot op 26-04-2018 08:08 ]
Vanaf komende vrijdag is hij te koop bij de officiële Xiaomi winkels in Hongkong :D Ik ga hem dan direct kopen, aangezien ik graag een nieuw toestel wil hebben.
Vooral omdat de batterij van mijn Xiaomi Redmi Note 4 Mediatek niet meer zo lang mee gaat. Maar ik twijfel wel nog een heel klein beetje, of het wel een waardige opvolger is van de Redmi Note 4.
Zelf heb ik vooral het idee dat de upgrade zit in de dual-camera, welke een heel stuk beter zou zijn dan van de Redmi Note 4. En natuurlijk het 5.99 inch scherm.
Wat betreft de Snapdragon 636, dat lijkt mij een fijne chipset. Een stuk beter dan de 625 natuurlijk, behalve lust die iets meer energie. In vergelijking met de Mediatek uit mijn Redmi Note 4 zou die Snapdragon 636 een stuk zuiniger zijn.
En ik heb het idee, dat ondanks de Mediatek wellicht hoger scoort in Benchmarks. Dat de Snapdragon beter geoptimaliseerd.
Dus kwa presentaties verwacht niet echt een grote vooruitgang: maar wel het scherm vind ik een stuk mooier en de camera.
Maar wat vinden jullie?
  • Freich
  • Laatst online: 01-03-2025
Freich
YOU ARE NEX!
Mooi review die de Asus en Xiaomi vergelijkt.
Ik neig nog steeds naar de Note 5.
https://www.techradar.com...ax-pro-m1-vs-nokia-6-2018
3 Inches of Bloodsport!
Ik heb zelf in Hongkong veel verschillende telefoons bekeken: maar Xiaomi steekt gewoon met kop en schouder uit boven de rest! Dus de keuze is eigenlijk niet zo moeilijk.
Enige wat ik wel nadeel bij Xiaomi vind: in de 1.5 jaar dat ik mijn Redmi Note 4 Mediatek heb, is er geen enkele Android update gekomen. De telefoon draait nog steeds op Android 6.x die er ook in 2016 al opstond....
Ze updaten gelukkig wel MIUI zelf, dus als je niks om de Android versie geeft valt daar goed mee te leven. Is mij wel opgevallen dat ze dit vooral flikken bij Mediatek toestellen :(
Overall lijkt mij de Xiaomi Redmi Note 5 momenteel het meeste waar voor je geld te bieden: als midrange toestel. Al ga ik wel zeker weten het model kopen met 6GB RAM aan boord.
Wel jammer trouwens dat Xiaomi bewust hun Android One toestellen prijstechnisch minder aantrekkelijk maakt, dan de Redmi toestellen.
Een A1 zou ik echt niet kopen, nu je een Redmi Note 5 kunt krijgen met een stuk betere hardware aan boord voor hetzelfde geld.
  • theduke1989
@Verwijderd
De mediatek variant wil je vermeiden, en neem gewoon de Qualcomm variant. Want uit Custom ROM oogpunt is het een aantrekkelijk device.
2. Prijstechnisch is het prima, aangezien de Android One een 6 is ;) maar niet aantrekkelijk is in Europa etc. In India enz is de Mi 6 prima...
theduke1989 schreef op woensdag 2 mei 2018 @ 14:09:
@Verwijderd
Volgens mij is er van de Redmi Note 5 geen Mediatek variant, dus dat is mooi :D Overigens beschouw ik custom ROMs als iets onwenselijk: dus wil gewoon dat de fabrikant het in 1x goed doet.
Heb bij geen enkele Android telefoon het gevoel gehad, dat een in elkaar geflanste custom de telefoon beter liet functioneren. Behalve dan bij custom ROMs, die op de stock ROM gebaseerd waren.
In dat opzicht doet Xiaomi het gewoon goed: MIUI is echt goed in elkaar gezet, weleens waar gedeeltelijk gejat van Apple. Maar beter goed gekopieerd/geïnspireerd, dan slecht bedacht.
Ik vind Stock Android eerlijk gezegd een beetje rommelig overkomen, dus ik heb zelf liever MIUI. Enige wat mij serieus stoort aan Xiaomi, is dat je door de bomen het bos niet meer ziet.
In de Redmi lijn hebben ze de Redmi 5, Redmi 5 Plus en dan nu eindelijk de Redmi Note 5. En techsites, die dachten dat de Redmi 5 Plus de Redmi Note 5 zou zijn......
Ze konden er niet meer naast zitten! Gelukkig had ik dan ook niet direct de Redmi 5 Plus gekocht, en toch nog eventjes op echte Redmi Note 5 gewacht. Die ik dus vrijdag in Hongkong kan gaan kopen :D
  • Luke-san
  • Laatst online: 23-09 10:21
Verwijderd schreef op woensdag 2 mei 2018 @ 14:32:
.... Die ik dus vrijdag in Hongkong kan gaan kopen :D
Ben ook naar deze telefoon aan het kijken. Wat ik vreemd vind is dat meeste reviewers de 6GB hebben ontvangen, heel youtube staat er vol van zeg maar, maar op Gearbest en nog een paar andere sites staat enkel de 3 en 4GB versie. Zou het zoveel verschil maken?
Trouwens staat nu de 4GB gouden op Gearbest 191€ en op Banggood de 6GB zwarte voor 252€ wat toch een meer dan behoorlijk verschil is.
Ben heel benieuwt naar je eerste ervaring. Ik hoop dat je deze hier ook gaat posten?
  • Dxue
Dxue
PSN:EvilDrunk
de 3gb, 4g en 6gb versie scheelt in china allemaal 300 yuan van elkaar. tussen de 3 en 6 gb zit er dus 600 yuan verschil en dat is ~85 euro ofzo. de vraag is dus hoeveel verschillende apps wil je tegelijkertijd open hebben staan en waarschijnlijk hoe 'high end' je zit te gamen op je mobiel. dat zijn de enige 2 dingen waar je op dit moment veel ram voor nodig hebt. ik heb op mijn 2gb oude telefoon genoeg vrije ruimte om ook nog een chrome met 10 tabs open te hebben staan en 3 apps ofzo. voor mij toendertijd meer dan genoeg en om eerlijk te zijn nu ook nog wel. de apps starten tegenwoordig zo snel, die 5 sec ook niet echt veel uitmaakt voor mij. Maar ik kan ook niet in de toekomst kijken en misschien komt er volgens jaar wel ineens iets uit waar je juist veel ram voor nodig hebt.
Pagina: 1 2 ... 16 Laatste
- Winkels, aanbieden en bestellen: [Xiaomi Redmi Note 5 Pro] Levertijden & Prijzen
- Hoesjes, laders, oortjes, accessoires: [Xiaomi Redm Note 5 / Pro] Accessoires.
