Xiaomi Redmi Note 5 (Pro) - Ervaringen & Discussie Topic
Inleiding
Redmi Note 5 Pro is our fastest Redmi Note yet, and it features the global debut of all-new Snapdragon 636 — Qualcomm's newest 14nm offering. This cutting-edge octa-core processor implements Kryo architecture which greatly improves overall performance and power efficiency. The Snapdragon 636 outperforms it's predecessor* by up to 40%. The large 1.25μm pixel dual camera delivers high-quality images, even in low light conditions. Pairing high-quality Sony and Samsung sensors offers a depth of field not available on typical smartphone cameras. The 15.2cm (5.99) FHD+ display uses an 18:9 aspect ratio — the new standard for smartphone displays. 2.5D curved Corning® Gorilla® Glass display. Feels and looks incredible while being extremely resistant to wear.Naamgeving
Hoewel dit toestel in India gereleased is als de Redmi Note 5 Pro lijkt het erop dat dit toestel in China gereleased wordt onder de naam Redmi Note 5. BronSpecificaties
| OS: | Miui9, Android 8.1 |
| Scherm formaat: | 15.2cm (5.99) (Diagonal), 2160 x 1080 FHD+, 403 PPI, 8:9 full screen display(~403 ppi) |
| Chipset: | Snapdragon 636, octa-core |
| CPU: | 8x Qualcomm® Kryo™ 260 CPU, up to 1.8 Ghz. |
| GPU: | Qualcomm® Adreno™ 509 GPU |
| 2G Netwerk: | GSM2/3/5/8 |
| 3G Netwerk: | WCDMA1/2/5/8 |
| 4G Netwerk: | 4GFDD-LTE, TDD-LTE1/3/5/20/40/41 (120MHz) |
| Camera (achterkant): | Dual camera; 12MP primary sensor, 1.25μm, f/2.2 aperture, 5MP secondary lens, 1.12μm, f/2.0 aperture |
| Camera (voorkant): | 20MP sensor, 1.0μm, f/2.2 aperture |
| SD card: | microSD, up to 128 GB (uses SIM 2 slot) |
| Opslag geheugen (ROM): | 32 / 64 GB eMMC 5.0 flash storage |
| Werkgeheugen (RAM): | 3 GB / 4GB / 6GB LPDDR4X |
| Luidspreker: | 1 luidspreker |
| Simkaart: | Dual SIM (Micro-SIM/Nano-SIM, dual stand-by) When two SIM cards are used simultaneously, the primary SIM supports 4G+/4G/3G/2G calling and data while the secondary SIM supports only 3G calls. |
| WLAN: | Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot |
| Bluetooth: | v5.0, A2DP, LE |
| NFC: | Nee |
| Vingerafruklezen: | Ja |
| USB: | USB 2.0 |
| Sensoren: | Electronic compass, Accelerometer, Proximity sensor, Infrared, Ambient light sensor, Gyroscope, Hall sensor |
| GPS: | GPS, A-GPS, GLONASS, Beidou |
| Formaat: | 158,6 mm x 75,4 mm x 8,05 mm |
| Gewicht: | 181 g |
| Accu: | 4000mAh (typ) / 3900mAh (min) lithium-ion polymer battery 5V/2A charging, QC2.0 |
| Kleuren verkrijgbaar: | Black, Gold, Rose Gold, Lake Blue |
Er zijn diverse toestellen onder dezelfde naam. Daarmee vooral opletten bij de Note 5 en Note 5 Pro. De Pro versie is de Indische release zonder band 20. De Note 5 is de Chinese release met band 20 en een iets gevoeligere camera. Onderstaande schema maakt eea overzichtelijk.
Prijzen
XIAOMI Redmi Note 5 Pro: Levertijden & Prijzen4G in NL
Sinds de release in China eind maart 2018 is er een versie van de Note 5 die de in NL veelgebruikt band 20 ondersteunt. Verdiep je voor aanschaf goed in de versie die je gaat bestellen.Links:
Preview door Arnoud WokkeNieuwsbericht over rebranding naar Redmi Note 5 in China
Indase Xiaomi Redmi Note 5 Pro pagina
Custom ROM's
Reddit wikiGoT topic over MIUI custom roms.
MIUI10 officieel beschikbaar voor Xiaomi Redmi Note Pro(Global) via Xiaomi.eu!!!
Google Camera officiele website voor alle builds.
Topicstart schaamteloos geknipt en geplakt vanuit @theduke1989 in Redmi Note 4 topic.
[ Voor 18% gewijzigd door theduke1989 op 08-07-2018 13:40 ]
hoe valt dit op te lossen.
ik sluit vaak de achtergrond apps automatically om juist dit te voorkomen. Ga eens kijken om 1-2 Werktagen het niet te doen. Om te kijken of er een patroon is.
:no_upscale():strip_icc():fill(white):strip_exif()/f/image/mxZNxME5y6JF7woYIorLonCt.jpg?f=user_large)
