• theduke1989
  • Laatst online: 23-11 03:26
Xiaomi Redmi Note 5 (Pro) - Accessories Topic
Redmi Note 5 Pro head
Inleiding
Redmi Note 5 Pro is our fastest Redmi Note yet, and it features the global debut of all-new Snapdragon 636 — Qualcomm's newest 14nm offering. This cutting-edge octa-core processor implements Kryo architecture which greatly improves overall performance and power efficiency. The Snapdragon 636 outperforms it's predecessor* by up to 40%. The large 1.25μm pixel dual camera delivers high-quality images, even in low light conditions. Pairing high-quality Sony and Samsung sensors offers a depth of field not available on typical smartphone cameras. The 15.2cm (5.99) FHD+ display uses an 18:9 aspect ratio — the new standard for smartphone displays. 2.5D curved Corning® Gorilla® Glass display. Feels and looks incredible while being extremely resistant to wear.
Naamgeving
Hoewel dit toestel in India gereleased is als de Redmi Note 5 Pro lijkt het erop dat dit toestel in China gereleased wordt onder de naam Redmi Note 5. Bron
Specificaties
OS:Miui9, Android 8.1
Scherm formaat: 15.2cm (5.99) (Diagonal), 2160 x 1080 FHD+, 403 PPI, 8:9 full screen display(~403 ppi)
Chipset:Snapdragon 636, octa-core
CPU:8x Qualcomm® Kryo™ 260 CPU, up to 1.8 Ghz.
GPU:Qualcomm® Adreno™ 509 GPU
2G Netwerk:GSM2/3/5/8
3G Netwerk:WCDMA1/2/5/8
4G Netwerk:4GFDD-LTE, TDD-LTE1/3/5/20/40/41 (120MHz)
Camera (achterkant):Dual camera; 12MP primary sensor, 1.25μm, f/2.2 aperture, 5MP secondary lens, 1.12μm, f/2.0 aperture
Camera (voorkant):20MP sensor, 1.0μm, f/2.2 aperture
SD card:microSD, up to 128 GB (uses SIM 2 slot)
Opslag geheugen (ROM):32 / 64 GB eMMC 5.0 flash storage
Werkgeheugen (RAM):3 GB / 4GB / 6GB LPDDR4X
Luidspreker:1 luidspreker
Simkaart:Dual SIM (Micro-SIM/Nano-SIM, dual stand-by) When two SIM cards are used simultaneously, the primary SIM supports 4G+/4G/3G/2G calling and data while the secondary SIM supports only 3G calls.
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth:v5.0, A2DP, LE
NFC:Nee
Vingerafruklezen:Ja
USB:USB 2.0
Sensoren:Electronic compass, Accelerometer, Proximity sensor, Infrared, Ambient light sensor, Gyroscope, Hall sensor
GPS:GPS, A-GPS, GLONASS, Beidou
Formaat:158,6 mm x 75,4 mm x 8,05 mm
Gewicht:181 g
Accu:4000mAh (typ) / 3900mAh (min) lithium-ion polymer battery 5V/2A charging, QC2.0
Kleuren verkrijgbaar:Black, Gold, Rose Gold, Lake Blue
Er zijn diverse toestellen onder dezelfde naam. Daarmee vooral opletten bij de Note 5 en Note 5 Pro. De Pro versie is de Indische release zonder band 20. De Note 5 is de Chinese release met band 20 en een iets gevoeligere camera. Onderstaande schema maakt eea overzichtelijk.
modellenredminote5
layout redmi note 5 pro
Prijzen
XIAOMI Redmi Note 5 Pro: Levertijden & Prijzen
4G in NL
Sinds de release in China eind maart 2018 is er een versie van de Note 5 die de in NL veelgebruikt band 20 ondersteunt. Verdiep je voor aanschaf goed in de versie die je gaat bestellen.
Links:
Preview door Arnoud Wokke
Nieuwsbericht over rebranding naar Redmi Note 5 in China
Indase Xiaomi Redmi Note 5 Pro pagina
Custom ROM's
GoT topic over MIUI custom roms.
Er is een Xiaomi.eu rom beschikbaar voor de Redmi Note 5 Pro
Ervariningen & Discussie
[Xiaomi Redmi Note 5] Ervaringen & Discussie
Text gekopieerd van @SirLenncelot
[ Voor 100% gewijzigd door theduke1989 op 13-06-2018 13:04 ]
  • dumbledore
  • Laatst online: 26-11 02:27
Ik ben opzoek naar een goede compatible QC3.0 lader voor de RN5 pro global met 2 QC3.0 outputs. Iemand met een tip?
  • theduke1989
@dumbledore https://www.aliexpress.co...ae803_2&priceBeautifyAB=0 denk dat je wel goed zit met deze?
Vandaag deze besteld:
CHOETECH Für Xiaomi Redmi 5 Plus Displayschutzfolie Full Coverage 9 H Härte Gehärtetem Glas Für Redmi Hinweis 5 Pro Schützende Film
https://www.aliexpress.co...042311.0.0.3da24c4dHzVYAd
MOFI Crazy Horse Retro PU Ledertasche für Xiaomi Redmi Hinweis 5 klassische Luxus Abdeckung Mit Fashion Logo für Redmi Hinweis 5 Pro Fällen
GerTong Cover Gehärtetem Glas Für Xiaomi Mi A1 Redmi 5 Plus 4X 5A Redmi Hinweis 5 Pro Note 4 4X 5A Prime Displayschutzfolie
Xiaomi Redmi Hinweis 5 Pro fall abdeckung note5 globale version zurück abdeckung silikon rand stoff fall coque MOFi Redmi hinweis 5 pro fall
Ben benieuwd naar de kwaliteit. Qua reviews allemaal goed. Totaalkosten zijn €21
[ Voor 54% gewijzigd door theduke1989 op 14-06-2018 15:32 ]
  • Marco de Vries
  • Registratie: Oktober 2017
  • Laatst online: 18-12-2025
Ik heb deze telefoon nu 2 weken en ben op zoek naar een glazen screenprotector maar heb nog niet echt wat gevonden of moet ik bij AliExpress bestellen.
  • Piet91
Gisteren bij Banggood de telefoon besteld (koopje), net ook maar even een case en tweemaal
full cover screenprotector besteld.
Zat ook nog even te denken aan zowel een QC3.0 Wall charger en Car Charger; maar die beide heb ik al in de vorm van QC2.0. (auto / 230V (maar dan de QC2.0 voorloper hiervan))
Maar QC3.0 biedt lijkt me niet echt veel waarde boven QC2.0.
Wel grappig dat ruim 2 jaar na aankoop van bovenstaande laders ik nu pas voor het eerst een telefoon ga hebben die ook daadwerkelijk Quick Charge ondersteunt. :P
Nu kijken wat van de drie het eerst binnenkomt. :P
  • theduke1989
Piet91 schreef op donderdag 21 juni 2018 @ 13:54:
de quick charge voor die prijs is goed. Ik zelf had de https://www.aliexpress.co...042311.0.0.27424c4djIpKlM besteld puur op merk. Maar zie geen quikcharge :( misschien toch ook de verkeerde gekocht.
Kocht je dit door de naam van de winkel of omdatje quikcharge zag???
  • Piet91
theduke1989 schreef op donderdag 21 juni 2018 @ 15:19:
Zoals gezegd heb ik die laders al een paar jaar en toen stonden zowel Banggood als Blitzwolf al bekend als betrouwbare webshops/merken. Denk bijvoorbeeld aan deze site: https://lygte-info.dk/
Voordeel van die 230V lader is dat die 2 poorten heeft, 1 mét en 1 zonder QC.
's nachts kun je dan dus gewoon gebruik maken van non-QC (aangezien je tijd genoeg hebt en non-QC laden beter is voor je accu) en heb je haast; dan gebruik je wel de QC-poort.
(maar ik heb dus - zelf - nog nooit gebruik gemaakt van QC omdat mijn telefoons dat niet ondersteunden :+ )
Enig nadeel; ik ervaar dat zodra de lader niet meer een apparaat laadt (of niets op aangesloten is); dat deze een zacht piep geluid maakt (coil whine). Op zich niets mis mee; maar kan irritant zijn.
Echter komt dit euvel weinig voor; heb het wel eens nagevraagd en meerderheid van de Tweakers/FOK!kers hadden dit niet.
  • hansie_k
  • Laatst online: 26-11 16:16
Zojuist deze
https://nl.aliexpress.com...042311.0.0.436d4c4dth9SES
besteld voor mij Note.
Inclusief hardglass screenprotector, ben benieuwd (of het wat is, en hoe snel ik het heb...).
Live from Denmark
  • theduke1989
@hansie_k deze ook besteld maar dan geen flipcover. 2 weken geleden. Alleen nog Niet binnen. Accessoires duurt vaak lang.
  • hansie_k
theduke1989 schreef op dinsdag 26 juni 2018 @ 05:29:
Oef...hoop dat die ik bestelt heb sneller komt.
Ik ben zo’n figuur die z’n telefoon niet zonder hoesje wil gebruiken (nee, meegeleverde dingetje voldoet niet... ;) ).
Telefoon ligt al week in de la... :+
Live from Denmark
  • hansie_k
Vandaag Mofi Flip cover en glass screenprotector binnen gekregen.
Screenprotector past als gegoten, geen ervaring met glas, maar deze zit meteen, zonder belletjes, vuil, ..
Hoesje zit ook mooi, voelt degelijk aan.
Aanrader
[edit]
En het glas is er weer vanaf...het was net een spiegel.
Zag alleen mezelf, de LED-bakken in t plafond....of niks als ik buiten was.
Jammer. Andere keer maar weer matte folie.
[ Voor 29% gewijzigd door hansie_k op 06-07-2018 19:27 ]
Live from Denmark
  • theduke1989
theduke1989 in "[Xiaomi Redm Note 5 / Pro] Accessoires"
Xiaomi RMN5 GerTong case werkt echt goed. Smartphone viel plat op het scherm en alleen de screen protector was gebarsten scherm was netjes in contact.
Gelukkig veel van gekocht.
  • cy-gor25
  • Laatst online: 06:45
Jammer, de spigen cover is niet voor de note 5 maar enkel de Pro waar de camera in het midden zit. Is er een andere cover die wel ok is? De meeste die ik heb teruggevonden zijn van bedenkelijke kwaliteit. Ik heb er er eentje gezien van Nillikin maar die is open aan de onderkant en eentje van case2go.
Tempered glass van Ringke - Invisible Shield lijkt me wel ok.
  • discusws
  • Laatst online: 26-11 20:07
@theduke1989 die gertong screen, sluit deze wel goed aan aan de randen?
Ik heb nu deze maar die laat rondom een randje lucht over.
https://goo.gl/CMEg4N
Een 5D screen protector lijkt dit probleem niet te hebben volgens de uitleg? Heeft iemand al eens een 5D protected screen gebruikt? (is inmiddels besteld)
https://goo.gl/JN3ePP
Ik heb op mijn redmi note 3 pro een PAKY hoes, die zit er nog steeds om en heeft altijd de telefoon beschermd. Ook voor de note 5 een PAKY hoes besteld en ziet er ook goed uit.
https://goo.gl/Ru1oJG
de witte stippen zitten er niet op, dat acentueerd alleen het patroon wat er op zit, hij is bij mij helamaal zwart.
pvoutput 10 x 405WP N, 4 x 405WP Z
  • jaxel70
  • Laatst online: 10:11
discusws schreef op vrijdag 10 augustus 2018 @ 19:15:
Ja, 5D tempered glass van pzoz 3c store, eenvoudige bevestiging. Bevalt goed. Sluit goed aan.
  • Piet91
Ik heb deze screen protector.
Destijds maar direct 2 besteld voor de zekerheid.
Maar nu heb ik al voor de tweede keer dat ik een buts heb aan de zijkant/rand van de protector.
Gok dat er dus iets hards (sleutels, tafel o.i.d.?) tegen de zijkant komt en dan dus een stukje afbreekt.
Irritant...
  • hansie_k
Hoe is het met het reflectie van deze screenprotectors?
Die ik van Mofi had spiegelde als een malle...
Live from Denmark
  • jaxel70
hansie_k schreef op woensdag 15 augustus 2018 @ 10:54:
Die van pzoz niet, oogt mat, enige nadeel dat vingerafdrukken erg zichtbaar zijn.
  • discusws
ik heb de volgende 5d screen ontvangen:
https://goo.gl/qKzHTU
past perfect, reflectie is vergelijkbaar als het orginele scherm. was niet de duurste maar ook niet de goedkoopste. Heb een extra besteld en een goedkopere variant om te checken of het hetzelfde is ;-)
https://goo.gl/4ggSpg
  • hars73
  • Laatst online: 12-11 22:36
Mijn RMN5 is nog niet binnen, maar bij Banggood deze twee maar alvast even besteld:
Een Bakeey full cover screen protector:
https://www.banggood.com/...=myorder&cur_warehouse=CN
En zowel een zwarte als blauwe Bakeey case:
https://www.banggood.com/...Note-5-Pro-p-1285607.html
  • xxxneoxxx
  • Laatst online: 31-10 15:35
hars73 schreef op donderdag 6 september 2018 @ 10:01:
Hopelijk heb jij meer geluk met Bakeey als ik tot nu toe heb met accessoires van het merk. Covers voor mijn eigen telefoon van hetzelfde merk (geen Redmi note) die krassen als een malle en waar stukjes vanaf springen..
Lurk hier gewoon een beetje verder. Wederhelft heeft een Note 5 en is ook nog in de markt voor een goed passende screenprotector.
Zelf ervaringen met deze case voor de Note 5:
https://nl.aliexpress.com...042311.0.0.2a334c4dh3pvMb
Prima case. Nillkin heeft gewoon naar mijn ervaring altijd kwaliteits accesoires. Verder deze nog aangeschaft:
Erg mooie case als ie er op zit. Helaas is het spiegelende gedeelte er op de buitenkant op gespoten, wat dus, zeker bij een vrouw die de telefoon los met een case zo in d'r tas mikt, leidt tot krassen in de opgespoten laag. Ma.w; ziet er erg mooi uit maar dat duurt niet heel erg lang. Desalniettemin werd de case wel warm onthaald bij binnenkomst. :P
  • hars73
xxxneoxxx schreef op vrijdag 21 september 2018 @ 13:07:
Hopelijk heb jij meer geluk met Bakeey als ik tot nu toe heb met accessoires van het merk. Covers voor mijn eigen telefoon van hetzelfde merk (geen Redmi note) die krassen als een lamme en waar stukjes vanaf springen..
Ik heb m'n Note 5 sinds eergisteren binnen, maar de Bakeey accessoires nog niet. Voorlopig dus alleen nog met de originele backcover die ik er een beetje slapjes omheen vindt zitten. Maar het functioneert voorlopig.
Ik zal die Nilkin ff onthouden als alternatief, mocht blijken dat Bakeey uiteindelijk niet geweldig blijft. Dat zal ik hier nog wel even laten weten. Ook hoe de screenprotector bevalt.
  • hansie_k
Iemand hier ervaring met andere (snel-) laders?
Ik zit te kijken naar een Aukey QC3.0 lader, goede ervaring met dat merk qua solar Powerbank.
Nu heb ik ergens gelezen dat snelladen niet al te best is voor de accu, zou sneller slijten.
Iemand die dit kan onderbouwen?
Zijn er mensen hier die snelladers gebruiken, en hoe bevalt dat?
Live from Denmark
  • hars73
hansie_k schreef op dinsdag 25 september 2018 @ 22:11:
Ik heb thuis een Aukey QC2.0 liggen naast de bank. Maar daar ligt ie vrijwel nooit aan, want ik kom probleemloos de dag door met de batterij. Heb volgens mij wel gezien dat ie daaraan gaat snelladen (extra icoontje in de statusbalk?) En 's nachts gaat ie aan een standaard lader naast het bed.
Heb inmiddels een zwarte Bakeey cover binnen sinds dit weekend. Tot nu toe prima. Zit stevig om het toestel heen, voelt een soort rubberachtig stroef aan en krast nog niet. De screenprotector en blauwe case moeten nog binnenkomen.
[ Voor 39% gewijzigd door hars73 op 03-10-2018 09:15 ]
  • xxxneoxxx
hars73 schreef op woensdag 3 oktober 2018 @ 09:01:
Haha top! Dan is de Bakeey cover voor mijn eigen ZUK telefoon gewoon een miskleun geweest denk ik. Goed om te weten dat hun case voor de xiaomi gewoon ok is.
  • hars73
Inmiddels sinds gisteren de Bakeey Tempered Glass Screen Protector ook ontvangen en op m'n Note 5 gezet. Op zich prima, maar ik heb wel het bekende (ik kende het niet, maar nu wel) rainbow effect. Nog even kijken of dat weg te krijgen is.
EDIT: Nee dus.. wat ik ook probeer, dat rainbow effect (alsof er een soort olievlekje onder de protector zit) krijg ik niet weg. Lees het wel meer, zou ermee te maken hebben dat niet de hele protector plakt, maar alleen aan de randen. Waardoor ie in het midden dus niet goed aansluit.
Daarnaast zit het ding ook binnen de kortste keren enorm onder de vingervlekken en spiegelt ie ook behoorlijk.
Volgende poging zal deze ChoeTech worden: https://nl.aliexpress.com...042311.0.0.76e94c4d60lFkU
Moet toch niet zo moeilijk zijn zou ik zeggen, een goeie screen protector vinden....
[ Voor 59% gewijzigd door hars73 op 10-10-2018 11:12 ]
  • hansie_k
@hars73 waarom moet t allemaal "glas" zijn..?
Doe mij maar een gewone, matte, folie...
Werkte de afgelopen jaren prima bij mij, en dat die dan niet helemaal tot aan de rand is ,went ook wel weer.
Ben ook nog steeds zoekende.
Live from Denmark
  • hars73
hansie_k schreef op vrijdag 12 oktober 2018 @ 22:22:
Ik vind glas makkelijker aanbrengen. En het zou het scherm misschien net iets beter kunnen beschermen bij vallen.
Wat folie betreft, deze dan?
NILLKIN For Xiaomi Redmi Note 5/Note 5 Pro Screen Protector Super High Clear/Matte Soft Film With Package
https://s.click.aliexpress.com/e/cdD255Bw
