  • +1Henk 'm!
  • theduke1989
  • Laatst online: 15:42
Xiaomi Redmi Note 5 (Pro) - Accessories Topic
Inleiding
Redmi Note 5 Pro is our fastest Redmi Note yet, and it features the global debut of all-new Snapdragon 636 — Qualcomm's newest 14nm offering. This cutting-edge octa-core processor implements Kryo architecture which greatly improves overall performance and power efficiency. The Snapdragon 636 outperforms it's predecessor* by up to 40%. The large 1.25μm pixel dual camera delivers high-quality images, even in low light conditions. Pairing high-quality Sony and Samsung sensors offers a depth of field not available on typical smartphone cameras. The 15.2cm (5.99) FHD+ display uses an 18:9 aspect ratio — the new standard for smartphone displays. 2.5D curved Corning® Gorilla® Glass display. Feels and looks incredible while being extremely resistant to wear.
Naamgeving
Hoewel dit toestel in India gereleased is als de Redmi Note 5 Pro lijkt het erop dat dit toestel in China gereleased wordt onder de naam Redmi Note 5. Bron
Specificaties
OS:Miui9, Android 8.1
Scherm formaat: 15.2cm (5.99) (Diagonal), 2160 x 1080 FHD+, 403 PPI, 8:9 full screen display(~403 ppi)
Chipset:Snapdragon 636, octa-core
CPU:8x Qualcomm® Kryo™ 260 CPU, up to 1.8 Ghz.
GPU:Qualcomm® Adreno™ 509 GPU
2G Netwerk:GSM2/3/5/8
3G Netwerk:WCDMA1/2/5/8
4G Netwerk:4GFDD-LTE, TDD-LTE1/3/5/20/40/41 (120MHz)
Camera (achterkant):Dual camera; 12MP primary sensor, 1.25μm, f/2.2 aperture, 5MP secondary lens, 1.12μm, f/2.0 aperture
Camera (voorkant):20MP sensor, 1.0μm, f/2.2 aperture
SD card:microSD, up to 128 GB (uses SIM 2 slot)
Opslag geheugen (ROM):32 / 64 GB eMMC 5.0 flash storage
Werkgeheugen (RAM):3 GB / 4GB / 6GB LPDDR4X
Luidspreker:1 luidspreker
Simkaart:Dual SIM (Micro-SIM/Nano-SIM, dual stand-by) When two SIM cards are used simultaneously, the primary SIM supports 4G+/4G/3G/2G calling and data while the secondary SIM supports only 3G calls.
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth:v5.0, A2DP, LE
NFC:Nee
Vingerafruklezen:Ja
USB:USB 2.0
Sensoren:Electronic compass, Accelerometer, Proximity sensor, Infrared, Ambient light sensor, Gyroscope, Hall sensor
GPS:GPS, A-GPS, GLONASS, Beidou
Formaat:158,6 mm x 75,4 mm x 8,05 mm
Gewicht:181 g
Accu:4000mAh (typ) / 3900mAh (min) lithium-ion polymer battery 5V/2A charging, QC2.0
Kleuren verkrijgbaar:Black, Gold, Rose Gold, Lake Blue
Er zijn diverse toestellen onder dezelfde naam. Daarmee vooral opletten bij de Note 5 en Note 5 Pro. De Pro versie is de Indische release zonder band 20. De Note 5 is de Chinese release met band 20 en een iets gevoeligere camera. Onderstaande schema maakt eea overzichtelijk.
Prijzen
XIAOMI Redmi Note 5 Pro: Levertijden & Prijzen
4G in NL
Sinds de release in China eind maart 2018 is er een versie van de Note 5 die de in NL veelgebruikt band 20 ondersteunt. Verdiep je voor aanschaf goed in de versie die je gaat bestellen.
Links:
Preview door Arnoud Wokke
Nieuwsbericht over rebranding naar Redmi Note 5 in China
Indase Xiaomi Redmi Note 5 Pro pagina
Custom ROM's
GoT topic over MIUI custom roms.
Er is een Xiaomi.eu rom beschikbaar voor de Redmi Note 5 Pro
Ervariningen & Discussie
[Xiaomi Redmi Note 5] Ervaringen & Discussie
Text gekopieerd van @SirLenncelot
[Voor 100% gewijzigd door theduke1989 op 13-06-2018 13:04]
  • jaxel70
  • Laatst online: 13:11
hansie_k schreef op woensdag 15 augustus 2018 @ 10:54:
Hoe is het met het reflectie van deze screenprotectors?
Die ik van Mofi had spiegelde als een malle...
Die van pzoz niet, oogt mat, enige nadeel dat vingerafdrukken erg zichtbaar zijn.
  • xxxneoxxx
  • Laatst online: 24-03 11:14
hars73 schreef op donderdag 6 september 2018 @ 10:01:
Mijn RMN5 is nog niet binnen, maar bij Banggood deze twee maar alvast even besteld:
Een Bakeey full cover screen protector:
https://www.banggood.com/...=myorder&cur_warehouse=CN
En zowel een zwarte als blauwe Bakeey case:
https://www.banggood.com/...Note-5-Pro-p-1285607.html
Hopelijk heb jij meer geluk met Bakeey als ik tot nu toe heb met accessoires van het merk. Covers voor mijn eigen telefoon van hetzelfde merk (geen Redmi note) die krassen als een malle en waar stukjes vanaf springen..
Lurk hier gewoon een beetje verder. Wederhelft heeft een Note 5 en is ook nog in de markt voor een goed passende screenprotector.
Zelf ervaringen met deze case voor de Note 5:
https://nl.aliexpress.com...042311.0.0.2a334c4dh3pvMb
Prima case. Nillkin heeft gewoon naar mijn ervaring altijd kwaliteits accesoires. Verder deze nog aangeschaft:
Erg mooie case als ie er op zit. Helaas is het spiegelende gedeelte er op de buitenkant op gespoten, wat dus, zeker bij een vrouw die de telefoon los met een case zo in d'r tas mikt, leidt tot krassen in de opgespoten laag. Ma.w; ziet er erg mooi uit maar dat duurt niet heel erg lang. Desalniettemin werd de case wel warm onthaald bij binnenkomst. :P
  • hars73
  • Laatst online: 25-03 09:26
hars73
Papa van Dewi en Robin :-)
xxxneoxxx schreef op vrijdag 21 september 2018 @ 13:07:
Hopelijk heb jij meer geluk met Bakeey als ik tot nu toe heb met accessoires van het merk. Covers voor mijn eigen telefoon van hetzelfde merk (geen Redmi note) die krassen als een lamme en waar stukjes vanaf springen..
Ik heb m'n Note 5 sinds eergisteren binnen, maar de Bakeey accessoires nog niet. Voorlopig dus alleen nog met de originele backcover die ik er een beetje slapjes omheen vindt zitten. Maar het functioneert voorlopig.
Ik zal die Nilkin ff onthouden als alternatief, mocht blijken dat Bakeey uiteindelijk niet geweldig blijft. Dat zal ik hier nog wel even laten weten. Ook hoe de screenprotector bevalt.
  • hars73
hars73
hansie_k schreef op dinsdag 25 september 2018 @ 22:11:
Iemand hier ervaring met andere (snel-) laders?
Ik zit te kijken naar een Aukey QC3.0 lader, goede ervaring met dat merk qua solar Powerbank.
Nu heb ik ergens gelezen dat snelladen niet al te best is voor de accu, zou sneller slijten.
Iemand die dit kan onderbouwen?
Zijn er mensen hier die snelladers gebruiken, en hoe bevalt dat?
Ik heb thuis een Aukey QC2.0 liggen naast de bank. Maar daar ligt ie vrijwel nooit aan, want ik kom probleemloos de dag door met de batterij. Heb volgens mij wel gezien dat ie daaraan gaat snelladen (extra icoontje in de statusbalk?) En 's nachts gaat ie aan een standaard lader naast het bed.
Heb inmiddels een zwarte Bakeey cover binnen sinds dit weekend. Tot nu toe prima. Zit stevig om het toestel heen, voelt een soort rubberachtig stroef aan en krast nog niet. De screenprotector en blauwe case moeten nog binnenkomen.
[Voor 39% gewijzigd door hars73 op 03-10-2018 09:15]
  • hars73
hars73
hansie_k schreef op vrijdag 12 oktober 2018 @ 22:22:
@hars73 waarom moet t allemaal "glas" zijn..?
Doe mij maar een gewone, matte, folie...
Werkte de afgelopen jaren prima bij mij, en dat die dan niet helemaal tot aan de rand is ,went ook wel weer.
Ben ook nog steeds zoekende.
Ik vind glas makkelijker aanbrengen. En het zou het scherm misschien net iets beter kunnen beschermen bij vallen.
Wat folie betreft, deze dan?
NILLKIN For Xiaomi Redmi Note 5/Note 5 Pro Screen Protector Super High Clear/Matte Soft Film With Package
https://s.click.aliexpress.com/e/cdD255Bw
Tweakers maakt gebruik van cookies
Tweakers plaatst functionele en analytische cookies voor het functioneren van de website en het verbeteren van de website-ervaring. Deze cookies zijn noodzakelijk. Om op Tweakers relevantere advertenties te tonen en om ingesloten content van derden te tonen (bijvoorbeeld video's), vragen we je toestemming. Via ingesloten content kunnen derde partijen diensten leveren en verbeteren, bezoekersstatistieken bijhouden, gepersonaliseerde content tonen, gerichte advertenties tonen en gebruikersprofielen opbouwen. Hiervoor worden apparaatgegevens, IP-adres, geolocatie en surfgedrag vastgelegd.
Meer informatie vind je in ons cookiebeleid.
Sluiten
Toestemming beheren
Hieronder kun je per doeleinde of partij toestemming geven of intrekken. Meer informatie vind je in ons cookiebeleid.
Functioneel en analytisch
Deze cookies zijn noodzakelijk voor het functioneren van de website en het verbeteren van de website-ervaring. Klik op het informatie-icoon voor meer informatie. Meer details
janee
    Relevantere advertenties
    Dit beperkt het aantal keer dat dezelfde advertentie getoond wordt (frequency capping) en maakt het mogelijk om binnen Tweakers contextuele advertenties te tonen op basis van pagina's die je hebt bezocht. Meer details
    Tweakers genereert een willekeurige unieke code als identifier. Deze data wordt niet gedeeld met adverteerders of andere derde partijen en je kunt niet buiten Tweakers gevolgd worden. Indien je bent ingelogd, wordt deze identifier gekoppeld aan je account. Indien je niet bent ingelogd, wordt deze identifier gekoppeld aan je sessie die maximaal 4 maanden actief blijft. Je kunt deze toestemming te allen tijde intrekken.
    Ingesloten content van derden
    Deze cookies kunnen door derde partijen geplaatst worden via ingesloten content. Klik op het informatie-icoon voor meer informatie over de verwerkingsdoeleinden. Meer details
    janee
