  • +1Henk 'm!
  • theduke1989
  • Laatst online: 16-03 15:08
Xiaomi Redmi Note 5 (Pro) - Accessories Topic
Inleiding
Redmi Note 5 Pro is our fastest Redmi Note yet, and it features the global debut of all-new Snapdragon 636 — Qualcomm's newest 14nm offering. This cutting-edge octa-core processor implements Kryo architecture which greatly improves overall performance and power efficiency. The Snapdragon 636 outperforms it's predecessor* by up to 40%. The large 1.25μm pixel dual camera delivers high-quality images, even in low light conditions. Pairing high-quality Sony and Samsung sensors offers a depth of field not available on typical smartphone cameras. The 15.2cm (5.99) FHD+ display uses an 18:9 aspect ratio — the new standard for smartphone displays. 2.5D curved Corning® Gorilla® Glass display. Feels and looks incredible while being extremely resistant to wear.
Naamgeving
Hoewel dit toestel in India gereleased is als de Redmi Note 5 Pro lijkt het erop dat dit toestel in China gereleased wordt onder de naam Redmi Note 5. Bron
Specificaties
OS:Miui9, Android 8.1
Scherm formaat: 15.2cm (5.99) (Diagonal), 2160 x 1080 FHD+, 403 PPI, 8:9 full screen display(~403 ppi)
Chipset:Snapdragon 636, octa-core
CPU:8x Qualcomm® Kryo™ 260 CPU, up to 1.8 Ghz.
GPU:Qualcomm® Adreno™ 509 GPU
2G Netwerk:GSM2/3/5/8
3G Netwerk:WCDMA1/2/5/8
4G Netwerk:4GFDD-LTE, TDD-LTE1/3/5/20/40/41 (120MHz)
Camera (achterkant):Dual camera; 12MP primary sensor, 1.25μm, f/2.2 aperture, 5MP secondary lens, 1.12μm, f/2.0 aperture
Camera (voorkant):20MP sensor, 1.0μm, f/2.2 aperture
SD card:microSD, up to 128 GB (uses SIM 2 slot)
Opslag geheugen (ROM):32 / 64 GB eMMC 5.0 flash storage
Werkgeheugen (RAM):3 GB / 4GB / 6GB LPDDR4X
Luidspreker:1 luidspreker
Simkaart:Dual SIM (Micro-SIM/Nano-SIM, dual stand-by) When two SIM cards are used simultaneously, the primary SIM supports 4G+/4G/3G/2G calling and data while the secondary SIM supports only 3G calls.
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth:v5.0, A2DP, LE
NFC:Nee
Vingerafruklezen:Ja
USB:USB 2.0
Sensoren:Electronic compass, Accelerometer, Proximity sensor, Infrared, Ambient light sensor, Gyroscope, Hall sensor
GPS:GPS, A-GPS, GLONASS, Beidou
Formaat:158,6 mm x 75,4 mm x 8,05 mm
Gewicht:181 g
Accu:4000mAh (typ) / 3900mAh (min) lithium-ion polymer battery 5V/2A charging, QC2.0
Kleuren verkrijgbaar:Black, Gold, Rose Gold, Lake Blue
Er zijn diverse toestellen onder dezelfde naam. Daarmee vooral opletten bij de Note 5 en Note 5 Pro. De Pro versie is de Indische release zonder band 20. De Note 5 is de Chinese release met band 20 en een iets gevoeligere camera. Onderstaande schema maakt eea overzichtelijk.
Prijzen
XIAOMI Redmi Note 5 Pro: Levertijden & Prijzen
4G in NL
Sinds de release in China eind maart 2018 is er een versie van de Note 5 die de in NL veelgebruikt band 20 ondersteunt. Verdiep je voor aanschaf goed in de versie die je gaat bestellen.
Links:
Preview door Arnoud Wokke
Nieuwsbericht over rebranding naar Redmi Note 5 in China
Indase Xiaomi Redmi Note 5 Pro pagina
Custom ROM's
GoT topic over MIUI custom roms.
Er is een Xiaomi.eu rom beschikbaar voor de Redmi Note 5 Pro
Ervariningen & Discussie
[Xiaomi Redmi Note 5] Ervaringen & Discussie
Text gekopieerd van @SirLenncelot
[Voor 100% gewijzigd door theduke1989 op 13-06-2018 13:04]
  • theduke1989
@dumbledore https://www.aliexpress.co...ae803_2&priceBeautifyAB=0 denk dat je wel goed zit met deze?
Vandaag deze besteld:
CHOETECH Für Xiaomi Redmi 5 Plus Displayschutzfolie Full Coverage 9 H Härte Gehärtetem Glas Für Redmi Hinweis 5 Pro Schützende Film
https://www.aliexpress.co...042311.0.0.3da24c4dHzVYAd
MOFI Crazy Horse Retro PU Ledertasche für Xiaomi Redmi Hinweis 5 klassische Luxus Abdeckung Mit Fashion Logo für Redmi Hinweis 5 Pro Fällen
GerTong Cover Gehärtetem Glas Für Xiaomi Mi A1 Redmi 5 Plus 4X 5A Redmi Hinweis 5 Pro Note 4 4X 5A Prime Displayschutzfolie
Xiaomi Redmi Hinweis 5 Pro fall abdeckung note5 globale version zurück abdeckung silikon rand stoff fall coque MOFi Redmi hinweis 5 pro fall
Ben benieuwd naar de kwaliteit. Qua reviews allemaal goed. Totaalkosten zijn €21
[Voor 54% gewijzigd door theduke1989 op 14-06-2018 15:32]
  • theduke1989
Piet91 schreef op donderdag 21 juni 2018 @ 13:54:
Gisteren bij Banggood de telefoon besteld (koopje), net ook maar even een case en tweemaal
full cover screenprotector besteld.
Zat ook nog even te denken aan zowel een QC3.0 Wall charger en Car Charger; maar die beide heb ik al in de vorm van QC2.0. (auto / 230V (maar dan de QC2.0 voorloper hiervan))
Maar QC3.0 biedt lijkt me niet echt veel waarde boven QC2.0.
Wel grappig dat ruim 2 jaar na aankoop van bovenstaande laders ik nu pas voor het eerst een telefoon ga hebben die ook daadwerkelijk Quick Charge ondersteunt. :P
Nu kijken wat van de drie het eerst binnenkomt. :P
de quick charge voor die prijs is goed. Ik zelf had de https://www.aliexpress.co...042311.0.0.27424c4djIpKlM besteld puur op merk. Maar zie geen quikcharge :( misschien toch ook de verkeerde gekocht.
Kocht je dit door de naam van de winkel of omdatje quikcharge zag???
  • theduke1989
@hansie_k deze ook besteld maar dan geen flipcover. 2 weken geleden. Alleen nog Niet binnen. Accessoires duurt vaak lang.
  • theduke1989
theduke1989 in "[Xiaomi Redm Note 5 / Pro] Accessoires"
Xiaomi RMN5 GerTong case werkt echt goed. Smartphone viel plat op het scherm en alleen de screen protector was gebarsten scherm was netjes in contact.
Gelukkig veel van gekocht.
Tweakers maakt gebruik van cookies
Tweakers plaatst functionele en analytische cookies voor het functioneren van de website en het verbeteren van de website-ervaring. Deze cookies zijn noodzakelijk. Om op Tweakers relevantere advertenties te tonen en om ingesloten content van derden te tonen (bijvoorbeeld video's), vragen we je toestemming. Via ingesloten content kunnen derde partijen diensten leveren en verbeteren, bezoekersstatistieken bijhouden, gepersonaliseerde content tonen, gerichte advertenties tonen en gebruikersprofielen opbouwen. Hiervoor worden apparaatgegevens, IP-adres, geolocatie en surfgedrag vastgelegd.
Meer informatie vind je in ons cookiebeleid.
Sluiten
Toestemming beheren
Hieronder kun je per doeleinde of partij toestemming geven of intrekken. Meer informatie vind je in ons cookiebeleid.
Functioneel en analytisch
Deze cookies zijn noodzakelijk voor het functioneren van de website en het verbeteren van de website-ervaring. Klik op het informatie-icoon voor meer informatie. Meer details
janee
    Relevantere advertenties
    Dit beperkt het aantal keer dat dezelfde advertentie getoond wordt (frequency capping) en maakt het mogelijk om binnen Tweakers contextuele advertenties te tonen op basis van pagina's die je hebt bezocht. Meer details
    Tweakers genereert een willekeurige unieke code als identifier. Deze data wordt niet gedeeld met adverteerders of andere derde partijen en je kunt niet buiten Tweakers gevolgd worden. Indien je bent ingelogd, wordt deze identifier gekoppeld aan je account. Indien je niet bent ingelogd, wordt deze identifier gekoppeld aan je sessie die maximaal 4 maanden actief blijft. Je kunt deze toestemming te allen tijde intrekken.
    Ingesloten content van derden
    Deze cookies kunnen door derde partijen geplaatst worden via ingesloten content. Klik op het informatie-icoon voor meer informatie over de verwerkingsdoeleinden. Meer details
    janee
