rsync naar een linux systeem zodat de rechten behouden blijven.
Je kan ook overwegen om gewoon de hele root te kopieren. Gaat sowieso sneller gaan dan hele image maken.
Ik maak een backup van enkele Pi's met dit script:
29
30
31
32
33
#!/usr/bin/env ash
cp /volume1/homes/guy/BackupWWW/RPI.sh /usr/local/etc/rc.d/RPI.sh
NOW=$(date +"%Y-%m-%d")
LOGFILE=/volume1/homes/guy/BackupWWW/_logs/RPi-PiHole-$NOW.txt
echo -------------------------------------------- Syncing RPi-PiHole ---- $(date +"%Y-%m-%d %H:%M:%S") >> $LOGFILE
rsync -av --stats --delete -e "ssh -i /root/.ssh/id_rsa" --exclude-from '/volume1/homes/guy/BackupWWW/excludedfiles.txt' root@192.168.2.2:/ /volume1/homes/guy/BackupWWW/RPi-PiHole/ >> $LOGFILE
echo -------------------------------------------- Finished ---- $(date +"%Y-%m-%d %H:%M:%S") >> $LOGFILE
LOGFILE=/volume1/homes/guy/BackupWWW/_logs/RPi-PiCam1-$NOW.txt
echo -------------------------------------------- Syncing RPi-PiCam1 ---- $(date +"%Y-%m-%d %H:%M:%S") >> $LOGFILE
rsync -av --stats --delete -e "ssh -i /root/.ssh/id_rsa" --exclude-from '/volume1/homes/guy/BackupWWW/excludedfiles.txt' root@192.168.2.11:/ /volume1/homes/guy/BackupWWW/RPi-PiCam1/ >> $LOGFILE
LOGFILE=/volume1/homes/guy/BackupWWW/_logs/RPi-PiCam2-$NOW.txt
echo -------------------------------------------- Syncing RPi-PiCam2 ---- $(date +"%Y-%m-%d %H:%M:%S") >> $LOGFILE
rsync -av --stats --delete -e "ssh -i /root/.ssh/id_rsa" --exclude-from '/volume1/homes/guy/BackupWWW/excludedfiles.txt' root@192.168.2.12:/ /volume1/homes/guy/BackupWWW/RPi-PiCam2/ >> $LOGFILE
LOGFILE=/volume1/homes/guy/BackupWWW/_logs/RPi-PiCam3-$NOW.txt
echo -------------------------------------------- Syncing RPi-PiCam3 ---- $(date +"%Y-%m-%d %H:%M:%S") >> $LOGFILE
rsync -av --stats --delete -e "ssh -i /root/.ssh/id_rsa" --exclude-from '/volume1/homes/guy/BackupWWW/excludedfiles.txt' root@192.168.2.13:/ /volume1/homes/guy/BackupWWW/RPi-PiCam3/ >> $LOGFILE
LOGFILE=/volume1/homes/guy/BackupWWW/_logs/RPi-Kevin-Domoticz-$NOW.txt
echo -------------------------------------------- Syncing RPi-Kevin-Domoticz ---- $(date +"%Y-%m-%d %H:%M:%S") >> $LOGFILE
rsync -av --stats --delete -e "ssh -i /root/.ssh/id_rsa -p 1605" --exclude-from '/volume1/homes/guy/BackupWWW/excludedfiles.txt' root@kevin.minja.be:/home/pi /volume1/homes/guy/BackupWWW/RPi-Kevin-Domoticz/ >> $LOGFILE
In excludedfiles.txt zet je wat niet moet meekomen, temp-, log-files etc. Even de logging in de gaten houden om te zien wat telkens gekopieerd wordt.
/var/lib/pacman/sync/*
/cdrom/*
/dev/*
/proc/*
/sys/*
/tmp/*
/run/*
/mnt/*
/media/*
/lost+found
/var/swap
/var/run
/etc/fake-hwclock.data
/etc/resolv.conf
/run/
/tmp/
/var/lib/ntp/
/var/lib/ntp/ntp.drift
/var/log/
/var/www/scheduleLog.txt
/var/lib/nginx/fastcgi/
/var/lib/systemd/random-seed
/var/lib/systemd/rfkill/platform
Een restore doe ik door de image van Jessie-Lite op SD te zetten, opstarten, IP adres zoeken en dit commando:
bv ./RestoreRPI.sh PiCam1 192.168.2.217
#!/usr/bin/env ash
HOST="$1"
IP="$2"
EXCL='/volume1/homes/guy/BackupWWW/excludedfiles.txt'
echo /volume1/homes/guy/BackupWWW/RPi-$HOST/ root@$IP:/
rsync -Irv --links --delete --stats -e "ssh -i /root/.ssh/id_rsa" --exclude-from $EXCL /volume1/homes/guy/BackupWWW/RPi-$HOST/ root@$IP:/
Omdat alles gerestored wordt staat de RPi na herstart weer exact als voorheen.
Script is nu niet specifiek voor Domoticz, maar als je Domoticz op een RPi draait zou het perfect moeten werken.
Edit: Een logfile ziet er zo uit, als er niks diende gekopieerd te worden.
Files die gewijzigd werden staan vermeld onder 'receiving...'.
Zoals je ziet aan de timestamps duurt een backup op deze manier amper 15 seconden.
Uiteraard zal dat iets langer zijn indien er veel updates waren. Bv na apt-get upgrade en rpi-update, dan zie ik iets van 4 minuten.
-------------------------------------------- Syncing RPi-PiCam2 ---- 2016-10-05 19:24:27
receiving incremental file list
Number of files: 61806
Number of files transferred: 0
Total file size: 1575367818 bytes
Total transferred file size: 0 bytes
Literal data: 0 bytes
Matched data: 0 bytes
File list size: 1353066
File list generation time: 0.003 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 35994
Total bytes received: 1387989
sent 35994 bytes  received 1387989 bytes  91869.87 bytes/sec
total size is 1575367818  speedup is 1106.31
-------------------------------------------- Finished ---- 2016-10-05 19:24:42
[ Voor 11% gewijzigd door Verwijderd op 06-10-2016 10:36 ]
  • trekker22
  • Laatst online: 20:44
ai ai ai standaard zwave / domoticz issues. Je voegt 3 nieuwe zwave stekkers toe, plugt usb weer in en geeft meteen een domoticz update en alle sensors komen weer als rood op....
Gelukkig lost een 2e reboot dit meestal op, maar is altijd weer ff schrikken :) Nu even wat events/lua/telegram dingen maken voor wasmachine,droger en vaatwasser. Vooral de irritante langdurige piepjes wil ik vanaf >:)
[ Voor 38% gewijzigd door trekker22 op 06-10-2016 12:00 ]
trekker22 schreef op donderdag 06 oktober 2016 @ 11:55:
Kan je die dan niet uitschakelen op het toestel zelf?
  • SpikeHome
  • Laatst online: 21:44
Verwijderd schreef op donderdag 06 oktober 2016 @ 10:21:
Ik zal er eens mee gaan spelen!
TNX
  • trekker22
Verwijderd schreef op donderdag 06 oktober 2016 @ 12:18:
droger wel, andere niet. maar telegram bericht is sowieso wel handig
  • tweak_IggY
  • Laatst online: 11-03 16:48
Ik ga binnenkort verhuizen en gebruik domoticz voor schakelen van lampen etc etc.
Nu wil ik ook een alarm in het nieuwe huis. Raden jullie aan om een kant en klaar alarm aan te schaffen en dat te koppelen met domoticz? of zelf iets te knutselen in domoticz?
Wat ik bv belangrijk vind is dat de bewegingssensor niet af gaat als de iroomba voorbij komt :)
Als ik een kant en klaar alarm aan moet schaffen welke raden jullie dan aan?
  • maomanna
  • Laatst online: 25-11 23:27
tweak_IggY schreef op donderdag 06 oktober 2016 @ 15:27:
ik heb een aantal fibaro motion sensors, een Neato Botvac.
Met de fibaro motions heb ik een alarmsysteempje gemaakt.
http://domoticz.com/forum...=38&t=9031&p=71043#p71013
werkt als een trein!
https://pvoutput.org/intraday.jsp?id=102416&sid=90116
  • trekker22
MikeOO schreef op woensdag 13 april 2016 @ 08:44:
Heb je meer info over hoe je een screenshot van de cam op een Windows PC laat zien.
Gebruik het al wel via Telegram maar zou mooi zijn als ik dit ook op de PC's te zien krijg.
terug gevonden dat het zou moeten kunnen middels EventGhost + AutoRemote plugin. Ik ga er mee puzzelen!
EDIT het is vrij eenvoudig:
- installeer EventGhost + AutoRemote plugin.
- Voeg macro toe middels de wizard en kies voor het opstarten van een Windows batch.
De ziet er hier uit als:
exe: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
parameters: rtsp://user:password@172.16.0.43:88/videoMain (dit moet je ip cam wel ondersteunen)
- voeg een event toe en vul in AutoRemote.Message.ARPAR (dit laatste is vrij te kiezen)
in de ssh van je raspberry kun je dan testen of het werkt:
curl -m 1 "http://172.16.254.254:1817/?message=ARPAR=:=ARCOMM"
let op dit poort nummer 1817 moet ook in je autoremote plugin settings gezet worden! en je message moet overeen komen.
Als er nu wordt aangebeld en ben op zolder aan het werk springt automatisch VLC open met de IP-camera stream!
[ Voor 49% gewijzigd door trekker22 op 06-10-2016 16:14 ]
  • tozzke
  • Laatst online: 21:56
tozzke
aka tozzert
Verwijderd schreef op donderdag 06 oktober 2016 @ 07:05:
Denk dat je er gewoon nog een EN had moeten bij zetten ipv die variable.
IF PIR = ON AND Lamp != Off AND Lamp != 50
Set lamp 50
Ik weet niet of dat tegenwoordig werkt, maar een level in de If statement, werkt(e) niet
't Ja, geen blockly gebruiken he. Gebruik een echt script als lua, php, ...
Pas dan kan je je verbeelding vrije loop laten.
  • erikvanhoutert
  • Laatst online: 11-11 20:45
Ik heb momenteel ook een nieuwe woning en zou ook graag Domoticz willen installeren. Nu ga ik drastische verbouwen en zou ik graag alle lampen gekoppeld willen hebben, zodat ik alles bij het weggaan of slapen /uit kan zetten.
Iedereen gebruikt Z-wave of een ander draadloos protocool. Wat zijn de mogelijkheden als ik het bedraad aan wil leggen? Ik kan nergens een I/O moudle vinden die bedraad op Domoticz werkt?
  • trekker22
Iemand al eens een evergreen tussenstekker gehad waar power functie niet werkt?
Van de andere 2 kwam er een power meter/usage bij en de laatste staat vermeld als inknown/usage
  • BizzieBis
  • Laatst online: 25-11 18:12
Ik zie een aantal dingen voorbij komen over het backuppen van een raspberry SD kaart.
Ik gebruik hier zelf twee scripts voor:
1) om een één-op-één kopie van de SD kaart te maken naar een netwerk share
2) om de image te resizen zodat er een image over blijft ter grootte van de daadwerkelijk gebruikte ruimte
Het resultaat is dat ik met een 16GB SD kaart een bestand overhoud van 2,4GB. Deze file kan ik met Win32DiskImager terug zetten naar een willekeurige SD kaart van minimaal 4GB. Daarna met 'raspi-config' het filesystem expanden en alles is weer klaar voor gebruik :)
Het backup script: http://pastebin.com/C21EpXw8
Het image_resizer.sh script:
Bash:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
#!/bin/bash
# Automatic Image file resizer
# Written by SirLagz
strImgFile=$1
export PATH=$PATH:/sbin
if [[ ! $(whoami) =~ "root" ]]; then
    echo ""
    echo "**********************************"
    echo "*** This should be run as root ***"
    echo ""
    exit
fi
if [[ -z $1 ]]; then
    echo "Usage: ./image_resizer.sh your_image.img"
    exit
fi
if [[ ! -e $1 || ! $(file $1) =~ "x86" ]]; then
    echo "Error : Not an image file, or file doesn’t exist"
    exit
fi
partinfo=`parted -ms $1 unit B p`
existRootPart=`echo “$partinfo” | grep -o 'B:ext4:\|B:ext3:'`
numberOfMatchPart=`echo "$existRootPart" | wc -l`
if [[ $existRootPart == "" || $numberOfMatchPart -eq 0 || $numberOfMatchPart -gt 1 ]] ; then
    echo "Error : Your partition layout is not currently supported by this tool."
    exit
fi
fileSystemType=`echo "$existRootPart" | cut -d: -f2`
partnumber=`echo "$partinfo" | grep $fileSystemType | awk -F: ' { print $1 } '`
partstart=`echo "$partinfo" | grep $fileSystemType | awk -F: ' { print substr($2,0,length($2)) } '`
loopback=`losetup -f --show -o $partstart $1`
e2fsck -fy $loopback
minsize=`resize2fs -P $loopback | awk -F': ' ' { print $2 } '`
# Modified minsize calc by Kevin Rattai
# original minsize produces 0bytes on partition, calculated as:
# minsize=`echo “$minsize+1000″ | bc`
# New minsize calc produces 10% minsize as available space
minsize=`echo "($minsize+($minsize*0.1))/1" | bc`
resize2fs -p $loopback $minsize
sleep 1
losetup -d $loopback
partnewsize=`echo "$minsize * 4096" | bc`
newpartend=`echo "$partstart + $partnewsize" | bc`
parted $1 rm $partnumber
parted $1 unit B mkpart primary $partstart $newpartend
endresult=`parted -m $1 unit B print free | tail -1 | awk -F: ' { print substr($2,0,length($2)) } '`
truncate -s $endresult $1
  • commentator
  • Laatst online: 21:36
Ik heb een vreemd probleem. Ik wil met Domoticz afhankelijk van de tijd en de huidige lichtsterkte van de HUE lampen iets doen. Maar
otherdevices['Keuken']
geeft alleen terug
Set Level ipv Set Level 40% oid
En
otherdevices_svalues['Keuken']
is zelfs leeg
Iemand een idee hoe dit aan te passen is zodat ik wel dat % ook kan zien?
Heb zelfs al bijgewerkt naar de laatste beta maar die lost het probleem ook niet op
[ Voor 8% gewijzigd door commentator op 06-10-2016 23:05 ]
  • ibeerens
  • Laatst online: 16-09-2022
Ik ben op zoek naar een CO2 meter die ik in Domoticz kan integreren. Iemand ervaring met een goede CO2 meter?
commentator schreef op donderdag 06 oktober 2016 @ 22:57:
geeft alleen terug
En
is zelfs leeg
Zeker van? Ik gebruik enkel otherdevices en moet dan steeds de set level eraf strippen in mijn code.
Bij Events zie je dat ook duidelijk:
Afbeeldingslocatie: https://i.imgur.com/NxQBY0l.png
Let wel: dit is van een gewone dimmer, ik heb geen hue spullen.
[ Voor 4% gewijzigd door Verwijderd op 06-10-2016 23:19 ]
  • commentator
Verwijderd schreef op donderdag 06 oktober 2016 @ 23:18:
Ja, tenminste ik neem toch aan dat een print alles van die other devices laat zien
Kijk eens in de device tabel in onder Setup > More options > Events > Show current states.
Daar staan ze allemaal samen.
Je draait een recente versie?
  • Gonadan
Gonadan
Beweging gaat meestal op infrarood, is zo'n stofzuiger dan überhaupt wel te zien?
Zeiss Distagon 21 f/2.8
Als die warm wordt mogelijks wel :P
Ik vind het vooral leuk om de bewegingsdetectoren die gekoppeld zijn aan Domoticz een dubbele functie te geven.
Als we thuis zijn schakelen ze lichten, als we niet thuis zijn gaat een sirene en krijgen wij bericht.
Door de dubbele functie enigszins aanvaardbaar qua prijs.
  • commentator
Verwijderd schreef op donderdag 06 oktober 2016 @ 23:37:
Ja, ook daar staat alleen "Set Level"
ja draai nu laatste beta omdat het in stable ook al zo was
Dan is dat wellicht een bug, misschien beter om dat even te melden op het Domoticzforum?
  • commentator
Verwijderd schreef op vrijdag 07 oktober 2016 @ 06:48:
ga ik nu ook doen, maar mijn ervaring is dat de response hier beter is dan daar ;)
  • EBOOZ
  • Laatst online: 24-11 13:29
BizzieBis schreef op donderdag 06 oktober 2016 @ 21:25:
Dank voor het delen! Ik ga er mee aan de slag.
Laatst door een upgrade naar Jessie de hele installatie verkloot. Het was nog wel even een werkje om alles weer 'up and running' te krijgen. Domoticz en de scripts enzo is vrij makkelijk, maar dan aaaaal die tweaks die je in het verleden een keer hebt uitgevoerd en zoals het goed IT-er betaamd niet hebt gedocumenteerd :+
  • Gonadan
Gonadan
commentator schreef op vrijdag 07 oktober 2016 @ 00:13:
Heb je het script draaien om de status te updaten? Van hue is bekend dat je anders problemen met waarden krijgt. Bij mij deed hij het zonder ook niet goed.
  • commentator
Gonadan schreef op vrijdag 07 oktober 2016 @ 14:27:
Nee, heb ik niet draaien omdat ik op mijn dashboard gewoon de juiste waarde zie staan. Maar zal t eens gaan proberen.
  • Brutuss
  • Laatst online: 17-11 18:12
Beste Mede Domoticz gebruikers,
Wie van jullie gebruikt de "System Alive Checker (Ping)" in Domoticz. Ik heb deze nu een redelijk tijd in gebruik maar moet toch zeggen dat deze vaak de plank mis slaat.
Mijn "Telefoon Switch" wordt bijvoorbeeld vaker aan en dan weer uitgezet terwijl ik gewoon op het werk zit... In de nacht gaat deze vaak tientallen minuten uit en dan weer aan.
Al onze devices krijgen een vast IP adres toegeven vanuit de DHCP server in de router. Een ander apparaat kan dit IP dus niet krijgen.
Mijn domoticz draait op Windows ik ben dus redelijk beperkt qua programmeer talen. Ik heb een simpel script gevonden voor het pingen van devices in LUA maar dat kan maar 1 keer per minuut.
  • maomanna
Verwijderd schreef op donderdag 06 oktober 2016 @ 23:55:
stel je een specifieke parameter in, of gebruik je ze in losse events en dus op een andere manier?
Ik gebruik maar 1 'event'. Alles wordt in 1 script geregeld.
Heel veel is afhankelijk van 2 dummy schakelaars 'Weg' en 'Slapen'.
Bv de pir op de hall boven:
Indien weg = ON = meldingen
Indien weg = Off en slapen = On => enkel licht traphal beneden
Indien weg = Off en slapen = Off => licht boven en beneden traphal
Met nog wat extra spullen erbij ziet dat er zo uit:
PHP:
function pirhall(){
    global $a,$s,$i,$t;
    if($a=="On"){
        if($s['slapen']=='Off'&&$s['hall']=='Off'&&(time < strtotime('8:00')||$s['zon']<100))sw($i['hall'],'On','hal');
        if($s['inkom']=='Off'&&(time<strtotime('8:00')||$s['zon']<200))sw($i['inkom'],'On','inkom');
        alarm('hall',false);
function alarm($naam,$slapen=true){
    global $a,$s,$i,$t;
    if(($s['weg']=='On'||($s['slapen']=='On'&&$slapen==true))&&$s['meldingen']=='On'&&strtotime($t['weg'])<driemin&&strtotime($t['slapen'])<driemin){
        if(cget('timealert'.$naam)<eenmin){
            sw($i['sirene'],'On');
            $msg='Beweging '.$naam.' om '.strftime("%H:%M:%S",time);
            cset('timealert'.$naam,time);
            telegram($msg,false,'channel');
            ios($msg);
            if(sms===true)sms($msg);
[ Voor 56% gewijzigd door Verwijderd op 07-10-2016 16:13 ]
  • reddo
  • Laatst online: 14-10 21:52
hoe zou het kunnen dat vanaf de command line in putty dit werkt
python /home/pi/domoticz/scripts/python/tplink_smartplug.py -t 192.168.1.218 -c on
maar vanuit domoticz vanuit een virtual switch dit niet ?
script:///home/pi/domoticz/scripts/python/tplink_smartplug.py -t 192.168.1.218 -c on
Iemand ?? Ik heb zolangzamerhand alles geprobeerd maar niets helpt tot nu toe.
[ Voor 13% gewijzigd door reddo op 08-10-2016 16:19 ]
http://www.pvoutput.org/intraday.jsp?id=13642&sid=11522
  • Gonadan
Gonadan
commentator schreef op vrijdag 07 oktober 2016 @ 15:49:
Dat had ik ook dus initieel het script ook niet. Maar omdat ik dan de waarden niet kon gebruiken in events toch maar het script toegevoegd.
Het staat blijkbaar niet voor niets op de wiki. :P
  • matthijsph
  • Laatst online: 25-04 06:53
commentator schreef op donderdag 06 oktober 2016 @ 23:28:
Nee, dat is volgens mij niet zo. Als je bijvoorbeeld doet
local status = otherdevices['hueLamp']
print('status: '..status)
dan krijg je in de log alleen te zien dat de status "on" of "off" is.
Als je meer informatie van het device wilt hebben zou je met json kunnen gaan werken. Dan kun je eigenlijk alles altijd wel vinden. Je kunt dan eventueel ook direct vanuit je Hue zelf de informatie ophalen. Ik heb dat ooit hier gedocumenteerd.
  • commentator
Gonadan schreef op vrijdag 07 oktober 2016 @ 19:11:
uitgeprobeerd, maar t maak niets uit.
matthijsph schreef op vrijdag 07 oktober 2016 @ 20:13:
Is toch vreemd. Als je op het dashboard wel een % ziet en vervolgens niet aan dat % kunt komen.
  • niki_lauda
  • Laatst online: 22:11
niki_lauda
3840Wp/VW ID3B/WeHeat Sparrow
Brutuss schreef op vrijdag 07 oktober 2016 @ 15:51:
Ik gebruik een script via bluetooth. Met mijn telefoons werkt dit goed (android en WP). Ik begrijp wel dat Apples hier vaker problemen mee hebben. Maar hij mist ook wel eens een schakelpunt. Daarom een dummy switch aangemaakt die uitschakelt als een telefoon langer dan 3 minuten niet gezien is.
Lol >:)
Afbeeldingslocatie: https://egregius.be/wp-content/2016/10/zwave-mesh.gif
  • MikeOO
  • Laatst online: 26-11 06:56
MikeOO
Die werkt inderdaad niet betrouwbaar. Heb dezelfde ervaring.
Gebruik Presence detection en dan heb je nergens last van.
  • M.v.Veelen
  • Laatst online: 22-11 18:51
M.v.Veelen
Sodeju !
Is het nu allemaal naar wens? Heb je je doel bereikt?
¯\_(ツ)_/¯
Ja hoor, van ca 1100 verbindingen naar bijna 1400 gegaan.
Werkt lekker nu :)
  • Delirius
  • Laatst online: 24-11 22:16
Ben in bezit van Sensative Strips raam/deur sensor. Aangemeld in Domoticz en leverde geen probleem op. Echter, apparaat blijft in deep sleep modus hangen. Kan m er wel uithalen door m handmatig wakker te maken en dan functioneert ook alles, maar na verloop van tijd schiet ie weer in slaap modus en werkt sensor niet meer.
Iemand een tip/suggestie?
[ Voor 3% gewijzigd door Delirius op 08-10-2016 12:20 ]
  • CSB
  • Laatst online: 26-11 12:10
CSB
:D
GVD! Het updaten van Domoticz op een Syno via de package van Jumbotroll werkt dus gewoon niet. Ik wordt er schijtziek van dat ik elke keer mijn installatie volledig opnieuw moet installeren omdat Domoticz na het updaten niet meer wil starten.
Ik ga een Rasp Pi aanschaffen denk ik. Ben ik misschien van dit gezeik af. Pff...
Met zo'n administrator heb je geen users meer nodig...
  • degroot
Ligt dat niet gewoon aan de cache van je browseR? Ik heb dat ook vaak , maar ik moet dan altijd domoticz even herstarten en safari opnieuw opstarten. Want mijn Domotix app op iPhone werkt wel gewoon
www.degroot-it.nl
  • Gonadan
Gonadan
Wat een omslachtig script is dat, lijkt me ook wel foutgevoelig sinds de wifi stil gelegd wordt bij features als doze. De netgear routers hebben een API, zou die niet te misbruiken zijn om gewoon de tabel uit te lezen? :P
  • M.v.Veelen
M.v.Veelen
CSB schreef op zaterdag 08 oktober 2016 @ 12:47:
Koop jij maar een RPi en loop dan misschien tegen hetzelfde probleem aan.
Beter is om te kijken wat er loos is, want ik gebruik al zeer geruime tijd het package van Jumbotroll en dat gaat allemaal prima. En met mij maken vele anderen er gebruik van zonder de door jou genoemde problemen.
Weet je wel zeker dat de service niet gestart is? Is het niet zo dat je inderdaad met de cache zit? Al een andere browser geprobeerd? Nogmaals: je kunt beter eerst kijken wat er nu precies mis gaat voordat je geld uit gaat geven en misschien erna hetzelfde probleem hebt.
Verwijderd schreef op zaterdag 08 oktober 2016 @ 11:30:
Werkt lekker nu :)
Lopen de verbindingen nu ook anders / logischer? Dit omdat bij mij nog steeds vrijwel alles via de repeteer (onlogisch) loopt en ik soms zit te denken om eens alles opnieuw te doen vwb ZWave.
[ Voor 16% gewijzigd door M.v.Veelen op 08-10-2016 15:02 ]
¯\_(ツ)_/¯
  • MikeOO
MikeOO
Gonadan schreef op zaterdag 08 oktober 2016 @ 14:38:
Is geen omslachtig script. Script plaatsen en in je cronjob een regel aanmaken die de ping uitvoert naar het apparaat. 5 min werk en werkt probleemloos al ruim 1 jaar. Licht schakel ik aan de hand van de aanwezigheid van de diverse gsm. Niemand thuis dan gebruikt hij een ander plan. Werkt als ruim een jaar en mis niets.
Wifi zet je op altijd en dan geen problemen met doze.
Zelf heb ik nog een tijd via ARP gedaan omdat 1 toestel soms niet meer gezien werd. Maar helaas is de ARP tabel dan ook niet betrouwbaar genoeg. Router denk dat toestel online is en dat is hij dan soms niet en levert ook geen betrouwbaar beeld op. Uiteindelijk de gsm opnieuw geïnstalleerd en toen werkt hij wel goed.
API zou kunnen mits je dat met een script kunt uitlezen en dat de lijst ook altijd actueel is en er geen vertraging optreed. Elk netwerk is toch net weer iets anders en wat bij 1 goed werkt doet het bij een ander niet lekker. Kwestie van dingen uitproberen wat voldoet voor je.
Alles is mogelijk >:)
  • Gonadan
Gonadan
MikeOO schreef op zaterdag 08 oktober 2016 @ 15:09:
Het gebruik van het script is niet omslachtig, het script zelf is omslachtig. ;)
Dat zou mij verbazen. Hij houdt dan namelijk wel de verbinding in stand maar laat hem wel slapen. Ping zou daardoor wel beïnvloed worden.
Ja dat is ook weer het aantrekkelijke. Het is veel leuker om iets in elkaar te tweaken dan om een script van een ander te gebruiken. :P
De status in mijn router is erg actueel en wordt zeer snel ververst viel mij op. Maar goed, ik zou sowieso met geen enkele methode puur op aanwezigheid van apparaten vertrouwen.
  • Brutuss
MikeOO schreef op zaterdag 08 oktober 2016 @ 08:14:
Thnx voor de info maar ben een Windows user dus kan dit niet geheel toepassen in mijn omgeving.
  • M.v.Veelen
M.v.Veelen
Iemand die een LUX scriptje in elkaar heeft geknutseld om een (virtuele) switch "IsDonker" om te zetten bij een bepaalde waarde?
Ik heb een simpel scriptje gemaakt dat dit wel doet, maar hij blijft dan telkens het log vol schrijven omdat aan de voorwaarde =< wordt voldaan (of >). Ik wil eigenlijk dat hij bij een vooraf ingestelde waarde een switch omzet en dat dit dan eenmalig wordt geschakeld c.q. weggeschreven in het log.
¯\_(ツ)_/¯
  • martenjw
  • Registratie: November 2014
  • Laatst online: 02-02 20:03
<?php
$i = 0;
$on = 0;
$off = 0;
// Check 10 times
while($i < 10)
$data = file_get_contents('http://192.168.2.10:8080/json.htm?type=devices&rid=250');
$parsed = json_decode($data);
$lux = substr($parsed->result[0]->Data,0,-4);
// If still on and lux lower than 200
if( $lux < 200 )
$on++;
elseif( $lux > 200 )
$off++;
// Check again after 60 seconds
sleep( 60 );
$i++;
if( $on == 10 )
$result = file_get_contents('http://192.168.2.10:8080/json.htm?type=command&param=switchlight&idx=318&switchcmd=On');
if( $off == 10)
$result = file_get_contents('http://192.168.2.10:8080/json.htm?type=command&param=switchlight&idx=318&switchcmd=Off');
maak zelf gebruik van dit script, als lux gedurende 10min onder bepaalde waarde blijft zet hij een virtuele schakelaar om, script moet nog wel ff wat bijgeschaafd worden.
  • B@rt_d@_M@n
  • Laatst online: 17:07
B@rt_d@_M@n
Happy Landing!
reddo schreef op vrijdag 07 oktober 2016 @ 18:17:
Probeer eens:
script:///home/pi/domoticz/scripts/python/python tplink_smartplug.py -t 192.168.1.218 -c on
  • reddo
B@rt_d@_M@n schreef op zaterdag 08 oktober 2016 @ 17:22:
Probeer eens:
Had ik al eens gedaan, geen foutmelding maar ook geen actie :(
2016-10-08 17:24:04.230 User: redmer initiated a switch command (62/wifi switch hs100/On)
2016-10-08 17:24:04.232 (3D printer) Lighting 1 (wifi switch hs100)
2016-10-08 17:24:20.662 User: redmer initiated a switch command (62/wifi switch hs100/Off)
2016-10-08 17:24:20.664 (3D printer) Lighting 1 (wifi switch hs100)
  • M.v.Veelen
M.v.Veelen
Ik heb nu:
Lua:
commandArray = {}
-- Get valueas from the Lux sensor
v = otherdevices_svalues['LUX-meter']
-- Turn on virtual switch when LUX >= 270
if     (v >= "270" and otherdevices['SchemerschakelaarBuiten'] == 'On') then
 commandArray['SchemerschakelaarBuiten']='Off'
 print('Bright light! Bright light!')
-- Turn off virtual switch when LUX < 270
elseif     (v < "270" and otherdevices['SchemerschakelaarBuiten'] == 'Off') then
 commandArray['SchemerschakelaarBuiten']='On'
 print('Darkness falls across the land......')
end
Eens kijken wat dit doet. De LUX heb ik even ingesteld op een waarde waar ik nu iets mee kan, alleen om te testen dus.
[ Voor 7% gewijzigd door M.v.Veelen op 08-10-2016 18:28 ]
¯\_(ツ)_/¯
[b]M.v.Veelen schreef op zaterdag 08 oktober 2016 @ 15:01
Zeker!
Voorheen maar een 12-tal powered nodes die rechtstreeks met de controller verbonden waren, op het laatste zelfs maar 9 meer.
Nu 25 >:)
Enkel 2 van de 3 op zolder niet, maar dat zijn ook effectief de verste en met 2 lagen beton tussen.
Edit: vergeten te vermelden: voor alles zeer rustig de tijd genomen. Alles included via de knop in Domoticz. Eerst de dichtste powered nodes, dan de verdere, gevolgd door de battery spullen.
Na elke include een netwerk heal en heal node en ondertussen alle devices mooi benoemd zodat er geen hoop unknown devices bij staan. In totaal toch dik 12 uur mee bezig geweest.
Nu maar hopen dat de verbindingen zo blijven. Ik ga in ieder geval nu een poos geen updates meer plaatsen ook. Heb zo het idee dat er soms iets mindere openzwave versies gereleased worden en dat de 'schade' dat die toebrengen niet makkelijk hersteld wordt.
[ Voor 36% gewijzigd door Verwijderd op 08-10-2016 18:35 ]
commentator schreef op vrijdag 07 oktober 2016 @ 20:55:
Misschien kun je hier iets mee, de stand van m'n zonnescherm in % lees ik als volgt uit:
Lua:
zonneschermstand = tonumber(otherdevices_svalues["Zonnescherm"])
print('Het zonnescherm staat op: '..zonneschermstand..'% geschoven.
  • M.v.Veelen
M.v.Veelen
M.v.Veelen schreef op zaterdag 08 oktober 2016 @ 18:25:
Hmmm....als de waarde onder de ingestelde grens komt, dan wordt wel in het log de regel geprint, maar de switch wordt niet omgezet. Ziet iemand een fout in de IF / ELSEIF ?
De waarde lager ingesteld en nog eens getest zonder iets anders te veranderen, en nu wordt de switch wél geschakeld.
Hoe zit dat precies? Is dit niet waterdicht dan? Het is toch OF >= OF < ?!
[ Voor 20% gewijzigd door M.v.Veelen op 08-10-2016 19:07 ]
¯\_(ツ)_/¯
  • commentator
Verwijderd schreef op zaterdag 08 oktober 2016 @ 18:42:
Lua:
Dank voor je reactie, maar zoals al aangegeven is de svalues zelfs helemaal leeg. Dus dat werkt niet.
  • B@rt_d@_M@n
B@rt_d@_M@n
Happy Landing!
reddo schreef op zaterdag 08 oktober 2016 @ 17:25:
Je had wel gezien dat ik er een extra "python " tussenin heb gezet?
  • reddo
B@rt_d@_M@n schreef op zaterdag 08 oktober 2016 @ 22:47:
Yep :)
  • Siewert
  • Registratie: December 2015
  • Laatst online: 22:04
Dat script werkt erg lekker en rete stabiel.
Ook hier al ruim een jaar draaiende zonder hickups.
Enige hickup is mijn klote ZIGGO modem/router (Cisco EPC3928AD)
Die wil eens in de 3 á 4 weken alle dhcp adressen vervangen.
En dus alle ip-adressen kan uitzoeken en aanpassen.
Static adressen zijn een nogo omdat hij die niet slik en ik te lui ben om zelf een andere modem/router te halen.
Gebruik Chopperrob zijn Presence detection script nu alleen nog maar voor mijn 2 Youlessen, tv en mediabox aangezien die wel een static hebben en behouden.
Maar laptops en telefoons slik dat ding van Ziggo niet, al sla je me dood maar zou niet weten waarom.
Sinds deze week alle 3 laptops voorzien van een BT mini dongle en telefoons BT altijd aan.
En dmv een standard lua script uit de Domoticz wiki op mijn PI3 welke ik een beetje heb aanpast nu presence detection op BT als dat mogelijk is.
Nadeel van dit lua scriptje is dat bij 2 of meer devices offline je errors krijgt in de trant van "lua scripts is running longer then 10 seconds" omdat hcitool bij het niet vinden van je device 5 seconden blijft pingen.
Dus nu voor elk device 1 script en werkt super tot op heden.
Heb het script een klein beetje aangepast.
Aangezien dochter lief en de vrouw wel eens BT uitzetten om een of andere reden.
Mocht dat het geval zijn dan zoek het scriptje als backup naar de mac van wifi hardware.
Vooralsnog zonder problemen.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
-- Title: script_time_bt_check.lua
-- Date:  4-10-2016
debug=false
prefixe="(PING) "
local ping={}
local ping_success
local bt_success
--------/ Device Ethernet  \-/  Domo Switch \-/  Uservariable \-/ Device Bluetooth \-/--
ping[1]={'12:34:56:78:90:00', 'Siewert GSM M9', 'IsSiewertGSM', '12:34:56:78:90:00', 1}
for ip = 1, #ping do
  if ping[ip][4] ~= 'nil' then
    f = assert (io.popen ("sudo l2ping -c 1 "..ping[ip][4]))
    bt = f:read()
    if bt==nil then
      bt_success=false
    if ping[ip][1] ~= 'nil' then
    ping_success=os.execute('sudo arp-scan --localnet | grep -e '..ping[ip][1])
    end
    else
      bt_success=true
    end
    f:close()
   end
  if ping_success or bt_success then
    if (debug==true) then
    if ping_success then
      print(prefixe.."Network ping success "..ping[ip][2])
    else
      print(prefixe.."BT ping success "..ping[ip][2])
    end
    end
    if (otherdevices[ping[ip][2]]=='Off') then
      commandArray[ping[ip][2]]='On'
    end
    if (uservariables[ping[ip][3]]) ~= 1 then
      commandArray['Variable:'..ping[ip][3]]= tostring(1)
    end
  else
      print(prefixe.."ping fail "..ping[ip][2])
    end
    if (otherdevices[ping[ip][2]]=='On') then
      if (uservariables[ping[ip][3]])==ping[ip][5] then
        commandArray[ping[ip][2]]='Off'
      else
        commandArray['Variable:'..ping[ip][3]]= tostring((uservariables[ping[ip][3]]) + 1)
      end
    end
  end
end
return commandArray
Nu alleen nog iets verzinnen om rssi te bepalen zonder al te veel resources op te slurpen.
BT op de gsm en PI3 is best sterk in reikwijdte en wil dus het huis uit offline halen terwijl we bij de overburen op visite zijn...
☀️Enphase IQ8+ 8,1kWp (8x Oost / 11x West) 🇳🇱
🔋MT Venus E v3 & DiY Thuisbatterij @ 12,8kWh
❄️MHI SRK50ZS-WF & SCM50ZS-W - 2x SRF25ZS-W
🛵Segway E125s
🔋piBattery Project @ GitHub
Siewert schreef op zondag 09 oktober 2016 @ 00:02:
Net daarom dat ik een dummy schakelaar bedien. Dan ben ik tenminste zeker dat hij juist staat.
  • MikeOO
MikeOO
Ik heb nu:
Lua:
commandArray = {}
end
Gebruik deze na volle tevredenheid.
commandArray = {}
local light_intensity = 'LUX Buiten'
local isdark_switch = 'State - IsDonker'
local lux_lower = 180
local lux_upper = 250
if (devicechanged[light_intensity]) then
lux = tonumber(otherdevices_svalues[light_intensity])
   if lux <= tonumber(lux_lower) and otherdevices[isdark_switch] == 'Off' then
    commandArray[isdark_switch] = 'On'
        print('<font color="blue">isdonker is ingeschakeld!!</font>')
   elseif lux >= tonumber(lux_upper) and otherdevices[isdark_switch] == 'On' then
        commandArray[isdark_switch] = 'Off'
        print('<font color="blue">isdonker is uitgeschakeld!!</font>')
   end
end
return commandArray
  • MikeOO
MikeOO
Daarom gebruik is dus een eigen router. Elk apparaart krijg een vast ip-adres zodat dit probleem niet voorkomt.
De tijd die je steeds weer krijgt bent als iets mogelijk niet werkt is dan snel terugverdiend en kun je weer lekker lui zijn >:)
Voor mij werkt dit 100% goed en de keren dat we bij de buren zijn doe ik niet moelijk over en doe ik de lampen zelf wel even uit via de app. Schakelaar om dit handmatig om te zetten heb ik nog over nageacht maar na een jaar nog niet gemist dus laat ik voorlopig nog zo.
Hooguit om evt problemen te voorkomen als er eens wat fout gaat je dit kunt overrulen.
Voor de foutmelding dat een script langer dan 10 sec draait kun je dit nog proberen van een medetweaker.
Nog niet geprobeerd maar mogelijk een oplossing voor je probleem.
Gonadan's blogje: Lua script has been running for more than 10 seconds
  • MikeOO
MikeOO
Brutuss schreef op zaterdag 08 oktober 2016 @ 15:51:
In Windows kun je LAU volgens mij ook gebruiken
https://github.com/rjpcomputing/luaforwindows
of uitgebreider
http://lua-users.org/wiki/BuildingLuaInWindowsForNewbies
  • MikeOO
MikeOO
Gonadan schreef op zaterdag 08 oktober 2016 @ 15:33:
Maar het werkt wel >:)
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/2118042/Naamloos1.png
En hier ben ik 2 dagen niet met de telefoon weggeweest en blijft deze ook keurig Online in Domoticz
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/2118042/Naamloos2.png
Bijvoorbeeld om 11:59 kom ik thuis en telefoon ligt tot 15:20 op tafel tot ik weer weg ga.
Telefoon blijft keuig pingbaar. Om de 2 min wordt dit gecontroleerd door het script.
Overig tijden komen wat rommelig over misschien maar dat komt als je even de deur uitloopt en niet meer in het bereik van WiFi zit ;)
[ Voor 11% gewijzigd door MikeOO op 09-10-2016 09:07 ]
  • M.v.Veelen
M.v.Veelen
MikeOO schreef op zondag 09 oktober 2016 @ 08:41:
commandArray = {}
   end
end
return commandArray
Ik ga deze eens proberen. Vanmorgen werd het licht een paar keer aan- en uitgezet. En als laatste aan, terwijl het buiten toch echt licht was.
¯\_(ツ)_/¯
  • Wolfboy
Wolfboy
ubi dubium ibi libertas
Ik heb gisteren eens mijn domoticz en openzwave geupdate naar de laatste versie (git master) en dat geeft wel hele vreemde resultaten... op een of andere manier zijn er nu willekeurige z-wave devices aan elkaar gelinkt in het netwerk.
De lichtknop in de slaapkamer zet opeens een hele stapel lampen aan en doet de gordijnen open... ik snap er niets van. Iemand enig idee?
[ Voor 3% gewijzigd door Wolfboy op 09-10-2016 14:51 ]
Blog [Stackoverflow] [LinkedIn]
  • MikeOO
MikeOO
M.v.Veelen schreef op zondag 09 oktober 2016 @ 10:30:
In theorie zou dit kunnen gebeuren als de LUX steeds veranderd van hogere waarde - lagere waarde - hogere waarde. Maar ervaring leert wel dat deze waarde zo snel veranderd dat dit hier nog niet is voorgekomen en heb met de LUX sensor (mysensors) geen last van.
In het lichtplan check ik buiten het feit of het donker / licht switch om is ook of de variable (Schemer_licht_aan) de juiste waarde heeft. Misschien dat dit nog helpt.
Uitleg waarde variable
0 = Als het licht is geworden
1 = Als er iemand thuis komt of is
2 = Als er iemand weg gaat of niemand thuis is.
LUA Lichtplan
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
local presence_switch = 'IemandThuis'
local Vakantie_timer = 'Vakantietimer'
vSchemer_licht_aan = tonumber(uservariables['Schemer_licht_aan'])
function sleep(n)
  os.execute("sleep " .. tonumber(n))
end
commandArray = {}
if devicechanged[isdark_switch] then
    if (otherdevices[isdark_switch] == 'Off' and otherdevices['Zon op-onder'] == 'Off' and vSchemer_licht_aan >= 1) then
        commandArray['Buitenlamp voordeur']='Off'
        commandArray['Lampen bij bank']='Off'
        commandArray['Ganglamp (Kerst)']='Off'
        commandArray['Lamp bij TV']='Off'
        commandArray['Lamp op sidetable']='Off'
        commandArray['Leeslamp']='Off'
        commandArray['LED Sidetable']='Off'
        commandArray['Buitenverlichting (kerst)']='Off'
        commandArray['Vakantiebovenswitch01']='Off'
        commandArray['Vakantietimer']= 'Off'
        commandArray['Variable:Schemer_licht_aan'] = tostring(0)
        print('<font color="blue">LICHT - Het is licht geworden - Alle lampen uit!!</font>')
    elseif (otherdevices[presence_switch] == 'On' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 0) then
        commandArray['Vakantietimer']= 'On'
        commandArray['Lampen bij bank']='On'
        commandArray['Ganglamp (Kerst)']='On'
        commandArray['Lamp bij TV']='On AFTER 600'
        commandArray['Lamp op sidetable']='On AFTER 601'
        commandArray['Buitenverlichting (kerst)']='On AFTER 1800'
        commandArray['Variable:Schemer_licht_aan'] = tostring(1)
        print('<font color="blue">THUIS - Het is donker en er is iemand Thuis - Lichten gaan aan!!</font>')
    elseif (otherdevices[presence_switch] == 'Off' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 0) then
        commandArray['Lamp op sidetable']='On'
        commandArray['Variable:Schemer_licht_aan'] = tostring(2)
        print('<font color="blue">NIET-THUIS - Er is niemand Thuis - Het is donker - Licht op de sidetable gaat aan!!</font>')
    elseif (otherdevices['Vakantie'] == 'On' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 0) then
        commandArray['Vakantiebovenswitch01']='On AFTER 27000'
        print('<font color="blue">VAKANTIEMODE - Er is niemand Thuis - Het is donker - Licht op de sidetable & boven gaan aan!!</font>')
    end
end
if devicechanged[presence_switch] then
    if (otherdevices[presence_switch] == 'Off' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 1) then
        print('<font color="blue">WEGGAAN - De laatste persoon heeft heeft het huis verlaten- Het is donker - Alle lichten gaan uit en Licht op de sidetable gaat aan!!</font>')
    elseif (otherdevices[presence_switch] == 'On' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 2) then
        commandArray['Buitenlamp voordeur']='On FOR 3'
        commandArray['Lamp bij TV']='On'
        commandArray['Buitenverlichting (kerst)']='On'
        print('<font color="blue">THUISKOMEN - Het is donker en er komt iemand thuis - Lichten gaan aan!!</font>')
    end
end
if devicechanged[Vakantie_timer] then
    if (otherdevices['Vakantietimer'] == 'Off' and otherdevices['Vakantie'] == 'On' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 2) then
        print('<font color="blue">VAKANTIEMODE - Er is niemand Thuis - Slaapstand actief - Alle lichten gaan uit!!</font>')
    end
end
return commandArray
  • Siewert
Verwijderd schreef op zondag 09 oktober 2016 @ 08:36:
Is een mogelijkheid.
Maar probeer dat nou net te vermijden, mooiste is om helemaal niks te hoeven aanklikken danwel manual te moeten overriden.
We gaan zien waar het schip strand ;-)
MikeOO schreef op zondag 09 oktober 2016 @ 08:50:
Andere router is wel de enige optie.
Die oplossing zoals daar beschreven voor die 10sec error werkt niet voor mij.
Aangezien in de script een os.execute word uitgevoerd.
En daar kun je niks aan doen als een execute langer dan 10sec duurt.
Voorals nog werkt het prima met 1 enkele device per script.
🛵Segway E125s
  • M.v.Veelen
M.v.Veelen
MikeOO schreef op zondag 09 oktober 2016 @ 14:39:
-knip-
Ik heb hierachter een script hangen die juist die "flipstorm" voorkomt. Er zit een time-out in dat script, en toch is het licht een paar keer uit- en weer aangesprongen. Ik ga het eens met dit script (het script uit je eerdere bericht) testen. Het script hoeft alleen een virtuele switch te triggeren en dan doet een ander Lua script de verder afhandeling. Ben benieuwd :)
¯\_(ツ)_/¯
  • Aegle
  • Laatst online: 15:52
M.v.Veelen schreef op zondag 09 oktober 2016 @ 16:46:
Om het ongewenst in- en uitschakelen te voorkomen kun je misschien een hysteresis in het script bakken? Beneden x lux aan en pas boven x+n weer uit?
33 x ET Solar 270Wp = 8910Wp @ SMA Sunny TriPower STP 8000TL-20 Live: PVOutput | Anker SOLIX Solarbank Max AC 7 kWh
  • M.v.Veelen
M.v.Veelen
Ik heb dit nu:
http://pastebin.com/1pdEXg46
en dan ook : http://pastebin.com/ZgZ1txYa
De laatste schakelt dus de SchemerschakelaarBuiten, dus het 1e script gaat daar dan mee aan de slag.
So far, so good. buitenverlichting is net aan gegaan. Moet de waarde nog wel wat naar beneden instellen omdat het nog net iets te licht is buiten, maar de 1e schakeling is goed gegaan.
[ Voor 33% gewijzigd door M.v.Veelen op 09-10-2016 19:01 ]
¯\_(ツ)_/¯
  • BartRot
  • Laatst online: 02-11 06:22
Ik heb in het verleden op dit forum iets gelezen om met een PHP script de schakeltijden in domoticz drastische te verkorten. Ik kan dat stuk alleen niet meer vinden. Zou iemand me even op weg willen helpen?
Alvast bedankt!
  • Sneezydevil
  • Laatst online: 29-09-2025
  • BartRot
  • Matis
  • Laatst online: 26-11 09:03
Matis
Rubber Rocket
Ik krijg de laatste tijd steeds minder vaak mijn 433MHz schakelaars geschakeld middels Domoticz icm RFLink. De lampjes gaan niet aan of uit. Ik heb helaas nog geen verband kunnen ontdekken.
Nu hebben we op de zaak op een aantal Energenie spanningssloffen, welke we via WiFi of LAN kunnen schakelen.
Ze bieden ook een enkele WiFi spanningsschakelaar aan: pricewatch: Gembird Wifi Smarthome Socket Maar 35+ euro vind ik wel erg gortig.
Nu heb ik op ebay mogelijke "alternatieven" gevonden. Maar ik kan in dit topic nergens vinden of deze ten eerste ondersteunt worden door Domoticz en ten tweede enige ervaringen.
Zijn er meer mensen die Domoticz hun WiFi spanningsschakelaar laten bedienen?
Misschien ten overvloede; Ik draai Domoticz Version 3.4834 (March 2nd 2016) op een RPi.
[ Voor 4% gewijzigd door Matis op 09-10-2016 20:55 ]
  • matthijsph
Matis schreef op zondag 09 oktober 2016 @ 20:52:
Ik heb hier een Orvibo S20 in gebruik, deze schakel ik vanuit domoticz dmv een bash script. Werkt opzich prima, het enige minpunt is dat het ding niet geaard is.
Correct :)
Iemand op domoticz forum haalde er deze week verbluffende resultaten mee. Van 4 seconden naar 23 milliseconden!
Ikzelf haal nu een stabiele 43 milliseconden, snel zat.
  • Brutuss
Het script waar jij naar verwijst gebruikt Python. Lua zit ingebakken in Domoticz. Heb al mijn scripts onder LUA draaien binnen de events van Domoticz. Python wordt "nog" niet ondersteund.
Installeer dan Python en je kan ook Python scripts gebruiken.
Omdat lua native in domoticz zit is dat de enige goede keuze?
Think again...
  • MikeOO
MikeOO
Voorheen had ik een kaku lichtsensor en gebruikte ik ook flipstorm want die wilde de lichten wel eens laten knipperen.
Nu ik een LUX sensor gebruik gebruik ik flipstorm niet meer en schakelt het zonder problemen en ook geen last van lampen die steeds aan/uit gaan.
Maar mogelijk met de herst/winter periode dat dit wel gaat gebeuren en dan ga ik deze ook weer inzetten.
Mooi dat de eerste test goed gegaan is.
  • M.v.Veelen
M.v.Veelen
De 2e test is ook goed gegaan. Vanmorgen bij het lichter worden buiten, werden de buitenlichten ook netjes uitgeschakeld.
Die flipstorm hou ik er wel in denk ik. Het zorgt hooguit voor een vertraging van enkele minuten en dat werkt eigenlijk wel heel fijn.
Ik loop misschien op de zaken vooruit, maar het lijkt nu wel goed te gaan :)
¯\_(ツ)_/¯
  • peauke
  • Laatst online: 17-11 08:51
Hallo mede tweakers,
Ben al een poos aan het kijken naar domotica oplossingen in onze woning. Al geruime tijd KaKu in huis maar niet geautomatiseerd. Toch recent de poging gewaagd om met een Pi 2 domoticz te gaan draaien en kijken of ik het eea voor elkaar kan krijgen. Ook maar gelijk een RFlink besteld om de KaKu te bedienen met domoticz.
Installatie Domoticz met de SD image installatie was geen probleem. De standaard configuratie doorlopen, so far so good. Schakelaren van KaKu werken via Domoticz. Nu de volgende stap wat ik wel interessant vond aan het hele systeem, Siri via Homebridge op de Pi en daar ging het enigszins mis.
De wiki doorlopen maar kreeg diverse malen wat foutmeldingen voor mijn kiezen maar uiteindelijk homebridge werkdend gekregen. De bottleneck was dat bij de configuratie je op een gegeven moment "npm run start" als command moest geven maar er kwamen een aantal errors dat het bestand niet bestond etc. Na wat google vond ik ergens dat het ook "npm run dev" kon zijn doordat er een nieuwe versie was en de "npm run start" niet werkte/bestond. Goed dit werkte maar nu komt de clou, ik wil dit natuurlijk altijd laten draaien maar zodra ik de SSH verbinding verbreek met de Pi was ook homebridge offline. Ik krijg dus met geen mogelijkheid een opstart script o.i,d. draaiende zodat homebridge continu draait en bij opstarten Pi ook homebridge mee opstart. Ik heb Wiki gevolgd, google geraadpleegd, maar krijg foutmeldingen krijgen.
Nou ben ik geen ster met Linux commando's en programmeertaal maar met google zou je toch een eind moeten komen. Wie kan mij een goede duw in de richting geven om toch e.e.a. voor elkaar te krijgen, bvd.
5760 WP ET-Solar met SB 5000-tl21 en 4080 WP Yingli met StecaGrid Coolcept 3600, ZW, 20gr hellend dak, Zonneplan nexus 20 kWh, Warmtepomp 14Kw Waterstage HT
  • luigi87
  • Laatst online: 13:41
luigi87
Domotica Fanaticus
Heeft iemand al ervaring hier met het maken van een soort automatische "slaap" modus, zonder een slaapknop te maken in Domoticz.
Wat ik zou willen realiseren is dat Domoticz kan herkennen dat we slapen, en de automatische hal en toilet verlichting gedimd aangaat.
De lampen zijn al voorzien van Fibaro dimmers 2 en worden nu automatisch bediend met behulp van een begin en eindtijd.
Deze eindtijd wil ik dus vervangen door een manier dat het systeem weet dat we slapen/in bed liggen.
Het mooiste zou zijn herkennen van dat de telefoon op stil staat, aan de lader ligt en de telefoon zich binnen het Wifi netwerk bevindt, wat dat is de handeling die dan altijd plaats vindt.
Andere ideeën zijn uiteraard ook welkom!
- leeg -
  • Possible
  • Laatst online: 23:02
Hmmmm lees nu h.e.e.a. over dat homebrige gebeuren... Is het dan mogelijk om met siri Milight lampen te bedienen ?
  • peauke
Possible schreef op maandag 10 oktober 2016 @ 11:11:
Moet volgens mij gewoon mogelijk zijn. :)
  • tsjoender
  • Laatst online: 21:58
luigi87 schreef op maandag 10 oktober 2016 @ 11:09:
https://www.openhardware.io/view/65/Bed-Occupancy-Sensor
  • luigi87
luigi87
Domotica Fanaticus
Dank je die is wel leuk. Had er al beetje over nagedacht met behulp van druksensoren. Hou hem in me achterhoofd :+ , denk niet dat dat hem wordt wegens dat er een extra laken op het bed moet en je deze eigenlijk ook moet verschonen.
kwam deze ook nog tegen.
http://www.domoticz.com/wiki/Sleep_as_android
Dat zou betekenen dat we nog steeds maar één knop moeten indrukken.
- leeg -
  • commentator
Of misschien kun je iets vinden wat werkt als je je telefoon erop legt?
  • pjeterinfo
  • Laatst online: 19:29
Idee om het stopcontact waarop de laders zitten te voorzien van een tussenstekker met verbruiksmeter? Daarmee zal je bij het aansluiten van de telefoons op verbruik kunnen triggeren.
intentionally left blank
  • luigi87
luigi87
Domotica Fanaticus
commentator schreef op maandag 10 oktober 2016 @ 11:44:
Ja zou moeten kunnen, heb een keer wat voorbij zien komen over RFC stickers. alleen weet ik niet of mijn vriendin een telefoon heeft met RFC functie
pjeterinfo schreef op maandag 10 oktober 2016 @ 12:15:
Zou kunnen alleen is het niet helemaal Failproef, want als ik me telefoon of powerbank een keer op die lader laad overdag denk die dat ik slaap.
MikeOO schreef op maandag 10 oktober 2016 @ 12:58:
Je zou een NFC sticker op je nachtkastje kunnen plakken. Leg daar je telefoon op en met bv Tasker laat je dan een switch omzetten of andere actie uitvoeren waardoor het systeem weet dat je gaat slapen. Met opstaan herhaal je deze actie weer.
Je kan ook beweginsensoren gaan gebruiken en na x aantal min geen beweging meer gaan de lichten uit.
Nadeel is wel dat er altijd scenarios bestaan dat het systeem niet werkt omdat je de telefoon een keer vergeet lang de sticker te halen of met een sensor dat je te lang stil zit in een ruimte waardoor het systeem denkt dat je er niet bent.
Een schakelaar is betrouwbaar maar wel minder hoog gadget gehalte >:)
Inderdaad met de sticker heb ik al eens een keer voorbij zien komen, maar ja wat je zegt het kan wel is mis gaan. en ik moet ff uitzoeken of me vriendin een telefoon heeft hiermee.
[ Voor 76% gewijzigd door luigi87 op 10-10-2016 13:02 ]
- leeg -
  • MikeOO
MikeOO
  • tozzke
tozzke
aka tozzert
Met Tasker kun je al deze voorwaarden in een profile zetten en vervolgens een switch/variable in Domoticz omschakelen middels een HTTP Get actie (lijstje)
Variable Value %INTERRUPT ~ alarms
Power Any
Wifi Connected <jouw SSID>
[ Voor 3% gewijzigd door tozzke op 10-10-2016 13:29 ]
  • luigi87
luigi87
Domotica Fanaticus
tozzke schreef op maandag 10 oktober 2016 @ 13:21:
Power Any
Ow Kick, die app ga ik is testen.
nu ben ik alleen echt een noob met die JSON URL's
Ik wil dan dus de "Toggle a switch state between on/off" gebruiken. Deze URL zet ik achter het standaard format deel. Maar wat is het blok eronder met "
"status" : "OK",
"title" : "SwitchLight"
- leeg -
  • tozzke
tozzke
aka tozzert
Ik zou een Enter task de schakelaar 'Slapen' aan laten zetten (of 'Wakker' uit...) en een Exit task maken die de schakelaar weer uitzet (of 'Wakker' aan...).
Dus als de IDX van die bewuste schakelaar 99 zou zijn, dan krijg je @ Enter task:
http(s)://<IP Domoticz>:<port Domoticz>/json.htm?type=command&param=switchlight&idx=99&switchcmd=On
en @ Exit task:
http(s)://<IP Domoticz>:<port Domoticz>/json.htm?type=command&param=switchlight&idx=99&switchcmd=Off
  • luigi87
luigi87
Domotica Fanaticus
tozzke schreef op maandag 10 oktober 2016 @ 13:52:
en @ Exit task:
Is inderdaad beter, want anders zou je nog verkeerd kunnen schakelen.
Dank je :*)
- leeg -
  • luigi87
luigi87
Domotica Fanaticus
Sorry voor de dubbelpost :F
Power Any
Net ff geprobeerd via de Trail om dit aan te maken, maar begrijp niet helemaal hoe programma werkt.
Ik probeerde in profiles de voorwaarden te stoppen alleen als ik de eerste voorwaarde erin heb zeurt die om een task name.
En waar vindt ik de Http GET functie ?
- leeg -
  • maomanna
en wat nou als je gewoon in bed ligt en je pakt je telefoon om wat op te zoeken?
Dan moet je een soort controle maken met een timer en is later dan maar vroeger...
  • luigi87
luigi87
Domotica Fanaticus
maomanna schreef op maandag 10 oktober 2016 @ 15:15:
Goede tip, maar dan blijven die bovenstaande voorwaarden waar. tenzij ik hem van de power cable ontkoppel.
En dan is er ook nog mijn vriendin die de slaapmodus dan heeft geactiveerd.
Pas als beide onze telefoons uit de slaapmodus zijn wordt de offset geactiveerd in Domoticz, en gaan de lampen in de hal vol aan ipv gedimd. en de rolluiken op.
En door aanwezigheids-detectie werkt het ook nog goed als één van ons beide niet thuis is.
- leeg -
  • tozzke
tozzke
aka tozzert
luigi87 schreef op maandag 10 oktober 2016 @ 15:04:
De profiles zijn de voorwaarden wanneer een task uitgevoerd moet worden. Dus je moet ook een task maken welke je dan aan de bewuste profile koppelt.
Onder 'Select Action Category' kies je 'Net' en daar heb je 'HTTP Get' staan. Je kunt ook bij het toevoegen van een task, bij 'Filter' 'http get' beginnen te typen en je krijgt resultaten.
  • Possible
peauke schreef op maandag 10 oktober 2016 @ 10:08:
Ik loop nu precies tegen hetzelfde aan.. Heb jij inmiddels al een oplossing ?
  • Speedy-Andre
  • Laatst online: 01:07
Speedy-Andre
Sony ZL, XA, Nokia XR20
Is het mogelijk om data uit Domoticz naar pvoutput te sturen?
Afbeeldingslocatie: https://tweakers.net/ext/f/2gw4bTis3WDh2BSt8LuZqivl/medium.jpg
Zeg maar deze gegevens, dit is het dagelijkse verbruik van een airco.
Ik heb data van elke 5 min en dat zou in pvoutput prima moeten passen :)
[edit]Het gaat om een eenvoudige verbruiksmeter, geen slimme meter met z'n speciale eigenschappen.
Pvoutput zou wat mij betreft de ruwe data moeten krijgen en dat opslaan, niets bewerken of berekenen.
[ Voor 21% gewijzigd door Speedy-Andre op 10-10-2016 17:14 ]
Pagina: 1 ... 85 ... 100 Laatste
Voor je je vraag stelt, lees eerst de topicstart eens door om te kijken of je vraag daar wellicht al in staat.
  • De changelog van Domoticz updates (commits) vind je op de Github repo.
  • Ook is er een Domoticz wiki
  • En een eigen Domoticz forum
  • Lees ook de Domoticz handleiding eens door
Gebruik bij het posten van stukjes code de ~~~[code]-tag!
~~~[code=lua] ... ~~~[/code]
~~~[code=python] ... ~~~[/code] etc.
