• Sissors
Heb je een logic analyzer die erbij kan pakken? Zodat je rechtstreeks de PWM waardes te zien krijgt. Kan je code posten?
  • LED-Maniak
  • Laatst online: 19:12
Instellen van de timer:
C:
      //Enable system clock to timer clock
      LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);
      //Set as GPIO output function
      LPC_IOCON->PIO1_9 = (1<<0);
      LPC_IOCON->PIO1_10 = (1<<0);
      // 72e6 / ( 15 * (2^8) )= 18.75 kHz, 8 bit
      LPC_TMR16B1->PR = 17;     //MHZ_PRESCALE; 16.5kHz
      //reset and interrupt on match MR3, 8-bit resolution
      LPC_TMR16B1->MR3 = 255;
      LPC_TMR16B1->MCR = (1<<9 | 1<<10);
      //Output on MR0 and MR1
      LPC_TMR16B1->PWMC = (1<<0 | 1<<1);
      LPC_TMR16B1->MR0 = 0x7F; //50% duty cycle
      LPC_TMR16B1->MR1 = 0x7F;
      // Enable the TIMER1 Interrupt
    //  NVIC_SetPriority(TIMER_16_1_IRQn, -1); //Lowest priority
      NVIC_EnableIRQ(TIMER_16_1_IRQn); //Used to load new PWM data
Uitvoeren van de interrupt:
C:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
unsigned char rawData[495] = {
    0x80, 0x84, 0x89, 0x8E, 0x93, 0x98, 0x9C, 0xA1, 0xA6, 0xAB, 0xAF, 0xB4,
    0xB8, 0xBC, 0xC1, 0xC5, 0xC9, 0xCD, 0xD1, 0xD4, 0xD8, 0xDB, 0xDF, 0xE2,
    0xE5, 0xE8, 0xEB, 0xED, 0xF0, 0xF2, 0xF4, 0xF6, 0xF8, 0xF9, 0xFB, 0xFC,
    0xFD, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFD, 0xFC,
    0xFB, 0xFA, 0xF8, 0xF7, 0xF5, 0xF3, 0xF1, 0xEE, 0xEC, 0xE9, 0xE6, 0xE3,
    0xE0, 0xDD, 0xDA, 0xD6, 0xD2, 0xCF, 0xCB, 0xC7, 0xC3, 0xBE, 0xBA, 0xB6,
    0xB1, 0xAD, 0xA8, 0xA4, 0x9F, 0x9A, 0x95, 0x91, 0x8C, 0x87, 0x82, 0x7D,
    0x78, 0x73, 0x6E, 0x6A, 0x65, 0x60, 0x5B, 0x57, 0x52, 0x4E, 0x49, 0x45,
    0x41, 0x3C, 0x38, 0x34, 0x30, 0x2D, 0x29, 0x25, 0x22, 0x1F, 0x1C, 0x19,
    0x16, 0x13, 0x11, 0x0E, 0x0C, 0x0A, 0x08, 0x07, 0x05, 0x04, 0x03, 0x02,
    0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x02, 0x03, 0x04,
    0x06, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x12, 0x15, 0x17, 0x1A, 0x1D, 0x20,
    0x24, 0x27, 0x2B, 0x2E, 0x32, 0x36, 0x3A, 0x3E, 0x43, 0x47, 0x4B, 0x50,
    0x54, 0x59, 0x5E, 0x63, 0x67, 0x6C, 0x71, 0x76, 0x7B, 0x80, 0x84, 0x89,
    0x8E, 0x93, 0x98, 0x9C, 0xA1, 0xA6, 0xAB, 0xAF, 0xB4, 0xB8, 0xBC, 0xC1,
    0xC5, 0xC9, 0xCD, 0xD1, 0xD4, 0xD8, 0xDB, 0xDF, 0xE2, 0xE5, 0xE8, 0xEB,
    0xED, 0xF0, 0xF2, 0xF4, 0xF6, 0xF8, 0xF9, 0xFB, 0xFC, 0xFD, 0xFE, 0xFF,
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFD, 0xFC, 0xFB, 0xFA, 0xF8,
    0xF7, 0xF5, 0xF3, 0xF1, 0xEE, 0xEC, 0xE9, 0xE6, 0xE3, 0xE0, 0xDD, 0xDA,
    0xD6, 0xD2, 0xCF, 0xCB, 0xC7, 0xC3, 0xBE, 0xBA, 0xB6, 0xB1, 0xAD, 0xA8,
    0xA4, 0x9F, 0x9A, 0x95, 0x91, 0x8C, 0x87, 0x82, 0x7D, 0x78, 0x73, 0x6E,
    0x6A, 0x65, 0x60, 0x5B, 0x57, 0x52, 0x4E, 0x49, 0x45, 0x41, 0x3C, 0x38,
    0x34, 0x30, 0x2D, 0x29, 0x25, 0x22, 0x1F, 0x1C, 0x19, 0x16, 0x13, 0x11,
    0x0E, 0x0C, 0x0A, 0x08, 0x07, 0x05, 0x04, 0x03, 0x02, 0x01, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x02, 0x03, 0x04, 0x06, 0x07, 0x09,
    0x0B, 0x0D, 0x0F, 0x12, 0x14, 0x17, 0x1A, 0x1D, 0x20, 0x24, 0x27, 0x2B,
    0x2E, 0x32, 0x36, 0x3A, 0x3E, 0x43, 0x47, 0x4B, 0x50, 0x54, 0x59, 0x5E,
    0x62, 0x67, 0x6C, 0x71, 0x76, 0x7B, 0x80, 0x84, 0x89, 0x8E, 0x93, 0x98,
    0x9C, 0xA1, 0xA6, 0xAB, 0xAF, 0xB4, 0xB8, 0xBC, 0xC1, 0xC5, 0xC9, 0xCD,
    0xD1, 0xD4, 0xD8, 0xDB, 0xDF, 0xE2, 0xE5, 0xE8, 0xEB, 0xED, 0xF0, 0xF2,
    0xF4, 0xF6, 0xF8, 0xF9, 0xFB, 0xFC, 0xFD, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF,
    0xFF, 0xFF, 0xFF, 0xFE, 0xFD, 0xFC, 0xFB, 0xFA, 0xF8, 0xF7, 0xF5, 0xF3,
    0xF1, 0xEE, 0xEC, 0xE9, 0xE6, 0xE3, 0xE0, 0xDD, 0xDA, 0xD6, 0xD2, 0xCF,
    0xCB, 0xC7, 0xC3, 0xBE, 0xBA, 0xB6, 0xB1, 0xAD, 0xA8, 0xA4, 0x9F, 0x9A,
    0x95, 0x91, 0x8C, 0x87, 0x82, 0x7D, 0x78, 0x73, 0x6F, 0x6A, 0x65, 0x60,
    0x5B, 0x57, 0x52, 0x4E, 0x49, 0x45, 0x41, 0x3C, 0x38, 0x34, 0x30, 0x2D,
    0x29, 0x25, 0x22, 0x1F, 0x1C, 0x19, 0x16, 0x13, 0x11, 0x0E, 0x0C, 0x0A,
    0x08, 0x07, 0x05, 0x04, 0x03, 0x02, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x01, 0x02, 0x03, 0x04, 0x06, 0x07, 0x09, 0x0B, 0x0D, 0x0F,
    0x12, 0x14, 0x17, 0x1A, 0x1D, 0x20, 0x24, 0x27, 0x2B, 0x2E, 0x32, 0x36,
    0x3A, 0x3E, 0x43, 0x47, 0x4B, 0x50, 0x54, 0x59, 0x5E, 0x63, 0x67, 0x6C,
    0x71, 0x76, 0x7B
void TIMER16_1_IRQHandler(void)
static unsigned long CurrentByte;
    //Timer 16bit, 1, match 0
    if ( LPC_TMR16B1->IR & 0x1 )
      timer16_1_counter++;
      LPC_TMR16B1->IR = 1;          /* clear interrupt flag */
    //Timer 16bit, 1, match 3
    if ( LPC_TMR16B1->IR & (1<<3) )
        LPC_TMR16B1->MR0 = rawData[CurrentByte++];
        if(CurrentByte >= 495)
            CurrentByte = 0;
        LPC_TMR16B1->IR = 1<<3;         /* clear interrupt flag */
  if ( LPC_TMR16B1->IR & (0x1<<4) )
    LPC_TMR16B1->IR = 0x1<<4;       // clear interrupt flag
    timer16_1_capture++;
  return;
Helaas heb ik geen logic analyzer of scope in huis, maar moet ik het nu met een soundcard scope doen. :+
Het lijkt er op dat zodra de waarde dichtbij de top komt, hij stilvalt voor x waardes en dan weer verder gaat.
[edit]
OPGELOST!! :D :D :D 8)
Je mag blijkbaar niet op hetzelfde moment dat je Timer counter reset ook de PWM waardes updaten. Ik heb nu zuivere golven _/-\o_
[ Voor 3% gewijzigd door LED-Maniak op 24-04-2015 21:06 ]
  • Ploink
  • Laatst online: 27-09 16:25
LED-Maniak schreef op vrijdag 24 april 2015 @ 19:14:
Ik ben echt radeloos. Het enige wat ik gedaan heb is de timer instellen en elke keer bij een overflow van de timer een nieuwe waarde in het match register laden uit een byte array. :?
Is dat match register gebufferd?
Als dat niet zo is dan kun je het probleem krijgen dat als je een lagere waarde schrijft naar dat match register, dat de teller daar al voorbij is, maar nog niet de vorige, hogere waarde heeft bereikt. In dat geval krijg je eenmalig helemaal geen match.
  • LED-Maniak
Nope, ongebufferd. Wat je nu omschrijft blijkt wel de oorzaak te zijn.
Problem solved, lessons learned :D
  • Ploink
Misschien had ik mijn vermoeden gister even moeten melden maar was daar te lui voor, sorry :P
  • LED-Maniak
Slapeloze nachten zeg ik je. Bedankt hè?
:P
  • lordprimoz
  • Laatst online: 17:10
iemand enig idee waar ik hier in nederland een beetje betaalbaar een bga reballing set kan vinden?(bestaande uit minimaal de balletjes, 0.6mm loodhoudend, met het bijhorende stencil).
Op ebay kan ik ze wel vinden en kost het geen drol, maar gezien het gaat om een chip voor een monitor die best warm wordt wil ik eigenlijk toch wel iets hebben van een hogere kwaliteit.
Individueel kan ik bij bijv eleshop.nl wel de componenten los krijgen( http://www.eleshop.nl/sol....html?___store=eleshop_nl). Enkel de stencils niet. De kit die ze aanbieden vind ik dan weer behoorlijk prijzig en overkill voor mijn doel.
  • RobV
RobV
Welcome to the grid, Program.
(overleden)
fijn dat je het gevonden hebt.. kun je inderdaad veel tijd mee kwijt zijn,met dit soort zaken 8)7
 | Mijn joystick / simpit project | Blog | Elite Dangerous CMDR Cataclysm72
  • LED-Maniak
Ik vraag mij af.. stel dat ik een koper + zink of staal elektrode neem en in de grond stop. Dan heb ik een galvanische reactie die een heel klein stroompje zal opwekken. Wat als ik hier een joule thief achter zet om de spanning op te krikken en er een condensator mee oplaad.
Zou dit genoeg energie zijn om een microcontroller te laten draaien en een kleine wifi, bluetooth of 868MHz zender te laten werken voor een paar seconde elk uur? :)
  • ThinkPad
  • Laatst online: 19:54
Kun je beter met een citroen ofzo doen, dat levert meer op denk ik.
  • LED-Maniak
Het is juist het idee om het niet met een citroen te doen, maar met grond. Dan kan je bijvoorbeeld metingen doen op plekken waar zon schaars is en je ook niet telkens batterijen wilt wisselen.
  • ThinkPad
OK. Maar gaat zwaar tegenvallen denk ik, als je hier ziet: Wikipedia: Lemon battery dat je voor één LED al 3 citroenen moet hebben...
  • LED-Maniak
Yes, daarom ook die joule thief. Die kan met zeer kleine spanningen overweg en dit opkrikken naar bijvoorbeeld 3 volt.
  • marcop23
  • Laatst online: 15:37
LED-Maniak schreef op zaterdag 25 april 2015 @ 17:39:
Maar die galvanische reactie werkt toch doordat je twee verschillende elektroden gebruikt en na een poosje raken je elektroden toch uitgeput? Dus moet je elektroden verwisselen.
Als je nou twee AA batterijtjes gebruikt, kan je als je gemiddeld 400 µA verbruikt al bijna een jaar vooruit. Ik weet alleen niet of dat haalbaar is voor de hoeveelheid hardware die je wilt.
  • LED-Maniak
Daar heb je inderdaad een goed punt.. Heel langzaam zal een van de elektroden slijten. Verdorie :(
Het idee was om het stukje elektronica in te potten. Dus een kleine accu met spoel voor draadloos opladen is ook een optie.
Food for thought :)
[ Voor 4% gewijzigd door LED-Maniak op 25-04-2015 17:56 ]
  • RobV
RobV
(overleden)
Uiteindelijk toch maar besloten om een berichtje te sturen naar G&C supermarket (ebay) dat ik mijn 10 stuks NRF24L01 na 38 dagen (26 werkdagen) nog steeds niet ontvangen heb. Ik heb hele goede ervaringen met G&C en tot nu toe was alles altijd netjes binnen 15 werkdagen geleverd.
Ik heb uit coulance niet gelijk een conflict geopend ik hoop dat hij met een goede oplossing komt. Het meest vervelende is dat het waarschijnlijk gewoon nóg 3 weken gaat duren voordat ze binnenkomen. Echt een probleem is het niet want ik heb er 2 gekocht bij de hackerspace, daar hadden ze er nog een paar op voorraad.
  • mux
  • Laatst online: 19-08 08:27
mux
99% efficient!
Ik ben momenteel bezig met een projectje met min of meer de goedkoopste MCU die ik kon vinden die makkelijk te solderen is (attiny24A - 2kB flash). Voor een bepaalde functie had ik floating point math gebruikt, puur omdat dat daar goed uitkwam. Vrij simpel project, compile -> 2236 bytes!
Dat kan niet correct zijn....
Ik comment het floating point gedeelte weg: 1056 bytes. Wow, nooit gedacht dat het zo'n grote impact heeft op de TinyAVR!
  • Ploink
mux schreef op zaterdag 25 april 2015 @ 21:31:
Ik ook :)
Ik zal er aan denken geen floating point te gebruiken, maar eerst afwachten of mijn sata connectoren ooit nog aankomen (ik wacht al 25 dagen) en dan de printjes laten fabrieken.
ps: ik heb ook maar deze sata power connectors besteld, misschien toch handiger dan de data connector die ik niet gebruik er af te zagen ;) Ik maak gewoon beide shapes op mijn printje en dan kies ik later wel, scheelt een paar weken wachten.
AliExpress heeft tegenwoordig ook Ideal betaling zie ik :)
[ Voor 26% gewijzigd door Ploink op 25-04-2015 22:34 ]
  • RobV
RobV
(overleden)
De belangrijkste reden voor die 1056 bytes is de auto linking van de floating point methodes die je gebruikt. Welke methods heb je gebruikt in je code? Wellicht kunnen er een paar eenvoudiger.
Ipv floating point kun je overigens veel beter fixed point algebra gebruiken, dat is niet alleen sneller, maar kost ook minder memory.
  • mux
mux
99% efficient!
Veruit de moeilijkste functie die ik gebruikte was een float-int multiplication, dat is waar veruit het meeste in ging zitten. Hier is wat optimalisatie in math.h voor toegevoegd, maar dat scheelde niet echt genoeg.
De enige reden dat ik floats gebruikte was gemakzucht. Ik heb het uiteindelijk gewoon vervangen door integer math, zonder boeiende nauwkeurigheidsproblemen. Nu is m'n programma nog maar 1000 bytes.
Ik stond er vooral van versteld dat float-int casting en float-int multiplication zo ontzettend zwaar was. Voor m'n gevoel was dit nooit zo'n probleem op avr MEGA en XMEGA. Wellicht is de (iets) uitgebreidere instructieset daar de redding?
  • RobV
RobV
(overleden)
mux schreef op zaterdag 25 april 2015 @ 23:09:
Het lijkt mij wel interessant om te zien welke code dat je had. Ik vermoed namelijk dat het niet perse aan de berekeningen ligt maar aan een printf of een andere formatting functie van/naar string. Die trekken namelijk gelijk de hele library mee in de linker, en dat gaat dan heel snel.
  • Hans1990
http://avr.8b.cz/asmhelp/Html/ATmega8_instructions.html
http://avr.8b.cz/asmhelp/Html/ATtiny13_Instruction_Set.htm
Laat nou juist de multiplication math wel opgenomen zijn in de ATMEGA maar niet in ATTINY. Er zal ook nog wel een floating point library nodig zijn voor de ATMEGA, maar het lijkt mij dat die flink compacter kan zijn dan op een ATTINY.
Ik zou verwachten dat als je hem voor een ATMEGA compileert, het stukje compacter wordt.
Nog grappiger is floating point op een PIC16 doen. Voor 1 maal float x int8 multiplication: 411 words. printf("%f") -> 2632 words. Zonder optimizer: past niet in PIC met 4K words geheugen :')
  • nurdo
  • Laatst online: 17-11-2024
Ik ben bezig met 3W RGB LEDs, deze hebben volgende eigenschappen
KanaalVf (V)If (mA)
R2.4-2.6400
G3.4-3.6350
B3.4-3.6350
Als voeding gebruik ik een pc-voeding die 5V 25A kan leveren. Nu heb ik enkele berekeningen gemaakt om de voorschakelweerstand te bepalen.
Rode kanaal:
UR = 5V - 2.6V = 2.4V
RR = 2.4V / 0.400A = 6 ohm
PR = 2.4V * 0.400A = 0.96 W
Groene kanaal:
UG = 5V - 3.6V = 1.4V
RG = 1.4V / 0.350A = 4 ohm
PG = 1.4V * 0.350A = 0.49 W
Blauwe kanaal:
UB = 5V - 3.6V = 1.4V
RB = 1.4V / 0.350A = 4 ohm
PB = 1.4V * 0.350A = 0.49 W
Hierbij stel ik mij enkele vragen. Als spanning over de LED kies ik voor het rode kanaal bijvoorbeeld een waarde van 2.6V omdat dit de maximum waarde is. Is mijn redenering hier juist, of dien ik hier beter de ondergrens te kiezen?
Vervolgens heb ik ook enkele vragen bij de berekende vermogens voor de weerstanden. Ik heb enkel 1/4W weerstanden liggen en hiermee getest. Omdat ik niet de juiste waardes heb, heb ik op elk kanaal 2 weerstanden van 10 Ohm 1/4W in parallel geplaatst, dus resulterend in een vervangingsweerstand van 5 ohm. Deze weerstanden worden totaal niet warm. De totale warmte wordt nu wel steeds over deze 2 weerstanden verdeeld, right? Omdat ik nu de juiste waardes weerstanden wil aankopen weet ik niet goed welk vermogen die moeten aankunnen. 1W weerstanden lijken mij zo overkill, kan iemand me hierbij helpen?
  • Ploink
nurdo schreef op zondag 26 april 2015 @ 10:04:
De Vf geldt bij de opgegeven If. Er is een range opgegeven vanwege de mogelijke produkt variatie. Op basis van mijn persoonlijke ervaring zou ik zeggen dat de werkelijke Vf vaker aan de ondergrens zit dan aan de bovengrens.
Als je een voorschakelweerstand gebruikt en de Vf blijkt lager dan je verwacht, dan is de spanning over de weerstand groter en dus de stroom hoger dan in je berekening. Om een veilige waarde te nemen kun je dus beter uitgaan van de ondergrens voor Vf.
  • mux
mux
99% efficient!
RobV schreef op zaterdag 25 april 2015 @ 23:17:
printf? Dit ding heeft als enige interface 4 LEDs en een knopje :P
Nope, puur deze regels:
float dc = pwm_dc / pwm_per; //PWM duty cycle 0...1
int16_t pwm = (int16_t) (dc * TIMER0_PERIOD);
Da's 1000 bytes :D
  • RobV
RobV
(overleden)
leermomentje! :D neen, dat had ik ook niet verwacht, lol.
  • lordprimoz
Mux,
Jouw gevoel dat het op een xmega sneller was/minder resources kost klopt, gezien de core twee bytes kan vermenigvuldigen per tick tegenover 1 per tick van de attiny.
Beide versies hebben overigens geen floating points, dit wordt allemaal in software gedaan, wat dus een hele hoop resources kost.
Leuk voorbeeld van de verschillen per methode:http://www.nongnu.org/avr-libc/user-manual/benchmarks.html
[ Voor 22% gewijzigd door lordprimoz op 26-04-2015 12:17 ]
  • Ploink
Ik heb een THD connector met halve pitch in Eagle, 1.27mm / 50mil.
Door de minimum restring van 10 mil in de DRU worden de pads nog ietsje groter dan afgebeeld.
Wat is wijsheid, de restring tegen de regels van de printboer in verkleinen naar 8mil of de grotere pads gebruiken met risico op soldeer brugjes. Het is een sata power connector en daar wil ik uiteraard geen kortsluiting.
Afbeeldingslocatie: http://i.imgur.com/rObkwXK.png
  • Cassettebandje
  • Laatst online: 15-10 15:42
Cassettebandje
SA-C90 TDK
Grotere pads, maar niet zo groot dat er geen soldermask meer tussen zit. Dan zou je niet meer risico mogen hebben op soldeerbruggen dan nu.
  • Ploink
De minimum restring voor een pin is 10mil en voor een via 6mil. (Smart-Prototyping pcb service)
In theorie is er toch geen verschil tussen via en pad, behalve voldoende ruime om aan te solderen?
Met de ovale pads is er nog voldoende vlees om te solderen, dus met 8mil voor alleen dat nauwe stukje kom ik wel weg dacht ik.
Met grotere pads zit er nog 6mil soldeermasker tussen de pinnen.
  • Harrie
  • Laatst online: 18:34
Harrie
NederVlaming
Ik heb laatst exact hetzelfde probleem gehad, ook voor een SATA power connector.
Ik heb inderdaad de minimale restring verlaagd, en er voor gezorgd dat er nog net een randje soldeermask zit.
Dat is allemaal goed gekomen (via seeedstudio)
PCB HDD activity LED
(klik voor groot)
  • Ploink
Ik zie dat jij die connector ook afgezaagd hebt :D (als ik het goed zie) dat was ik ook van plan, maar heb nu ook deze besteld. Ik heb lang gezocht, maar dat was de enige power connector die ik kon vinden, bij de meesten zit data+power aan elkaar.
Ik heb nu voor de zekerheid de drill vergroot naar 0.6mm. Op basis van de foto van de verkoper en het tellen van pixels dacht ik dat 0.5 genoeg moest zijn, maar better safe than sorry ;)
Nu is de pad wat groter en de restring is 8mil. Dit gaat wel lukken zo, bedankt!
  • Harrie
Harrie
NederVlaming
Inderdaad, ik heb een connector afgezaagd, omdat ik er geen kon vinden. Jij hebt dus nog iets beter gezocht :D Die jij hebt gevonden is denk ik wel een betere optie, en zal de connector nog wat beter op zijn plaats houden. Gelukkig zitten de connectoren ook bij mij al redelijk strak.
  • LED-Maniak
Wat doen jullie met die SATA aansluitingen? Big-ass opslag voor je microcontroller? :+
  • Harrie
Harrie
NederVlaming
LED-Maniak schreef op zondag 26 april 2015 @ 16:18:
Ik heb een printje gemaakt om pin 11 toegankelijk te maken, dat is de pin die veel fabrikanten gebruiken om voor een activiteitssignaal. Daar heb ik dan een LED aan gekoppeld, zodat je per schijf een activiteits-LED hebt. Ik weet niet wat Ploink zijn toepassing is.
De connector waar we over spraken is enkel de voedingsconnector, die kan je dus ook gewoon gebruiken om 12V en 5V van je PC voeding op je print te gebruiken. (echter is pin 11 van die connector dus door de fabrikanten vaak voor iets anders gebruikt)
Wikipedia: Serial ATA
Pin 11 can function for staggered spinup, activity indication, both, or nothing. It is an open collector signal, that may be pulled down by the connector or the drive. If pulled down at the connector (as it is on most cable-style SATA power connectors), the drive spins up as soon as power is applied. If left floating, the drive waits until it is spoken to. This prevents many drives from spinning up simultaneously, which might draw too much power. The pin is also pulled low by the drive to indicate drive activity. This may be used to give feedback to the user through an LED.
  • Damic
  • Laatst online: 19:34
Damic
Tijd voor Jasmijn thee
mux schreef op zondag 26 april 2015 @ 11:15:
Da's 1000 bytes :D
gebruik je die dc nog ergens anders? Anders zou ik alles op 1 regel gooien
C:
//float dc = pwm_dc / pwm_per; //PWM duty cycle 0...1
int16_t pwm = (int16_t) (pwm_dc / pwm_per * TIMER0_PERIOD);
Weet niet of dat iets helpt maar zou maar zo eens kunnen :)
  • mux
mux
99% efficient!
Het punt is dat mixed int/float math heel veel ruimte kost; hoe je het formatteert is volledig onbelangrijk. De compiler is slim genoeg om zooi bij elkaar te gooien.
  • RobV
RobV
(overleden)
mux schreef op zondag 26 april 2015 @ 17:37:
Niet helemaal waar. Als je eerst vermenigvuldigd, en daarna pas deelt heb je de precisie van een float niet nodig, bijvoorbeeld:
//er vanuit gaande dan c en d ongeveer dezelfde range hebben.
int a1 =  b * (c /  d);
int a2 =( b * c)  / d;
beiden zijn wiskunde identiek, maar voor a2 heb je geen floats nodig. Zou je a1 berekenen met alleen ints dan krijg je dikke afrondfouten, voorbeeld:
int a1 = 100 * (20 / 80);
          = 100 * 0 ( want 20/80 is 0.25, en voor een integer is dat 0)
          = 0
//terwijl
int a2 = (100 * 20) / 80;
          = 2000 / 80;
          = 25;
(de waarden 100, 20 en 80 zijn bewust gekozen hier om het voorbeeld te versterken.
  • Ploink
Zal ik verklappen als hij klaar is :P
Ik gebruik alleen de SATA power connector.
  • mux
mux
99% efficient!
@RobV: een variatie daarop is dus exact wat ik al had gedaan. De float was gemakzucht, omdat ik dacht 'ach, hoe erg kan het zijn'?
Heel erg dus :+
  • RobV
RobV
(overleden)
mux schreef op zondag 26 april 2015 @ 19:53:
Heel erg dus :+
Ik had niks te doen dus ik dacht: ik leg um effe uit. 8)
  • mux
mux
99% efficient!
Hm, ik hoef trouwens niet heel geheimzinnig te doen, full disclosure:
Een paar weken geleden benaderde een medetweaker me over het maken van een fan-controller die tussen een moederbord en fan kan worden gegooid, welke het tachometer-signaal en PWM-signaal manipuleert zodat je bijv. langzame fans op servermoederborden kunt aansluiten (die een fan <2000rpm niet slikken), enz.
Dus die heb ik gemaakt, en ik ben nu de laatste loodjes aan de code aan het leggen. Geheel wordt opensource en wordt m'n eerste testprojectje op Tindie. Daar is deze code dus voor :)
  • Ploink
Leuk project. Ik wist niet dat server moederborden zo moeilijk kunnen doen over fan speed.
Mijn projectje wil ik ook opensource maken, maar het kan nog even duren voordat het af is. Ik heb pas net de printen besteld en ik hou het nog even onder de pet tot het (bijna) af is.
  • lordprimoz
mux schreef op zondag 26 april 2015 @ 21:16:
Is het geheel dan ook softwarematig vanuit de pc aan te sturen? Of enkel een soort hardware mod uitbreiding?
  • RobV
RobV
(overleden)
Mijn projectje is al open source, of eigenlijk creative commons. Je kunt zo bij de sources/designs, doe wat je ermee wilt doen, maar laat het me effe weten dat vind ik leuk.
Edit: dat kiezen van een license is drommelsch niet eenvoudig zeg.
http://www.smashingmagazi...rce-and-similar-licenses/
[ Voor 32% gewijzigd door RobV op 27-04-2015 12:10 ]
  • LED-Maniak
Hoop gedoe inderdaad, maar veel lof dat je het doet! :)
Stel dat je een joule thief maakt volgens bijvoorbeeld dit schema:
http://www.electro-tech-o...ired-boost-regulator.594/
Ik wil dit gebruiken om met een mini zonnepaneel een AA batterij op te laden. Nu moet de PCB zo klein mogelijk, maar in die schema's staat vrijwel nooit de impedantie of zelfinductie van de spoel. Alleen het aantal wikkelingen. Hoe weet ik nu welke RF choke SMD spoel ik hiervoor kan pakken?
  • mux
mux
99% efficient!
lordprimoz schreef op maandag 27 april 2015 @ 11:53:
100% hardware, zitten wel knopjes op om hem in te stellen. De prijs van een usb-versie, hoewel makkelijker om te programmeren, zou te hoog worden om iets leuks van te maken. Dan zit je al gauw op ~15 euro verkoopprijs (€5 BOM) en dat is veel te hoog.
  • RobV
RobV
(overleden)
Ze hebben het druk in Hongkong. Zojuist een mailtje gekregen dat mijn pcb's verstuurd zijn (18/4 besteld, 27/4 shipped). Maar dat mag de pret niet drukken, ik ben nog steeds trots en benieuwd.
Vandaag nog 2 vrij grote lcd's gekocht voor 1 euro per stuk. De verkoper wist er verder niks van. Hij had 2 volle dozen liggen. (Helaas was ik niet slim genoeg om meteen te kijken wat voor lcd's het waren)
Een beetje hier en daar gekeken maar nog niet helemaal uit kunnen komen. Dit staat op de PCB HG16501-B. Er zit wel een standaard Toshiba T6963C controller op.
  • RobV
RobV
(overleden)
fotootje is meestal wel handig ;)
  • Ploink
Verwijderd schreef op maandag 27 april 2015 @ 21:38:
Een echte Hyundai van $120?
Of 145 euro?
Koop de hele partij en schuif ze door voor 50 eur/st ;)
[ Voor 9% gewijzigd door Ploink op 28-04-2015 00:10 ]
  • XRayXI
  • Laatst online: 30-09-2025
Klein kort vraagje, zijn er nog soldeerders hier? ;)
V&A gevraagd: Reparatie Voeding: Delta DPS-220UB A
Wees beleefd en lief voor je PC, soms eet het niets en mag je uitzoeken, wat niet smaakt
  • lordprimoz
Wie weet wat er allemaal is doorgebrand. Met een beetje geluk is het enkel een fuse, maar ik denk niet dat het het waard is om dat ding te repareren.
Ploink schreef op maandag 27 april 2015 @ 23:55:
Of 145 euro?
:o :o :o :o :o :o |:( Wat ben ik toch stom geweest, ja dat is precies wat ik heb. Ik dacht eerst dat de prijzen op alibaba overdreven waren. Dat is ook het eerste wat ik krijg vanuit google. Blijkbaar kloppen de prijzen toch wel.
Paar foto's die ik er van had gemaakt: https://www.flickr.com/photos/incyi/
  • lordprimoz
Verwijderd schreef op dinsdag 28 april 2015 @ 09:20:
als je er nog een paar scoort wil ik er voor die ene euro best wel eentje van je overnemen =P
Hoe vind ik iemand terug die een doos lcd's had staan op koningsdag ? :( Ik weet wel nog waar hij precies stond.
Goed, nu maar eerst een complete datasheet opsporen.
[ Voor 20% gewijzigd door Verwijderd op 28-04-2015 09:47 ]
  • Pizza_Boom
  • Laatst online: 15-10 17:18
Jeuj, DX bestelling binnen. Week werk gehad, das snel voor bestellingen uit China. Bestelling uit het VK is al sinds vrijdag onderweg... Ben benieuwd.
  • Djesse8999
  • Laatst online: 14-10 03:47
Djesse8999
Houd van (T)weekend!
Pizza_Boom schreef op dinsdag 28 april 2015 @ 14:04:
Mijn record vanuit china was met relais voor de Arduino, duurde 6 dagen van bestelling tot met de post binnen :o
  • lutkeveld
  • Laatst online: 17-07 19:01
Kan je een MIC-in als een LINE-in gebruiken als je de input met een spanningsdeler omlaag krikt?
druk en typefouten voorbehouden
  • wesleytjuh
  • Laatst online: 13-10 12:35
Lijkt me wel, maar je mag er wel vanuit gaan dat je een lading ruis cadeau krijgt.
AccuSafe.nl: Alles voor je kistradio | Store | Kistradio FAQ | Onze video's | Onze versterker!
  • Ploink
Inderdaad, je verzwakt het signaal en dan versterk je het weer, dat geeft meestal extra noise, hoewel dat op goed apparatuur wel mee zal vallen. Om wat voor apparaat gaat het?
  • mux
mux
99% efficient!
Pff, je wilt niet weten wat een gedoe het was om dit correct geprogrammeerd te krijgen:
Wat je hier ziet: een 3-button interface (up/down/select) waarmee door 5 items kan worden gecycled en ieder item apart kan worden ingesteld. Dit is een fancontroller die de PWM output van je moederbord kan manipuleren naar de fan toe, en omgekeerd het tachometersignaal van de fan ook weer kan manipuleren. Zo kun je een fan langzamer laten draaien dan het moederbord anders zou toelaten, of kun je een fan laten lijken alsof hij sneller/langzamer draait dan hij eigenlijk doet.
1966 bytes is de firmware trouwens :P past precies
Nu nog testen met een paar fans en dan is-ie klaar, denk ik.
edit: nog wat meer uitleg over wat je in het filmpje daadwerkelijk ziet: de meest rechtse knop cyclet door 5 items:
  • Tach output max
  • Tach output min
  • PWM output max
  • PWM output min
  • NTC enable
Met de knopjes links ervan (UP/DOWN) kun je de verschillende settings instellen, en alle LEDs flikkeren wanneer je op de laagste of hoogste setting zit (zodat je weet waar je bent met het knopjesdrukken). De eerste vier settings hebben hun eigen dedicated LED die harder of zachter gaat branden als hij hoger of lager zit, de NTC enable/disable setting is aan als alle LEDs aan zijn en uit als ze allemaal uit zijn. Beetje vaag zo uit de video, maar in de praktijk werkt het aardig.
[ Voor 32% gewijzigd door mux op 28-04-2015 22:43 ]
  • RobV
RobV
(overleden)
netjes!
  • Sibylle
  • Laatst online: 13-07-2023
mux schreef op dinsdag 28 april 2015 @ 22:35:
[video]
  • Tach output max
  • Tach output min
  • PWM output max
  • PWM output min
  • NTC enable
Wat was je grootste uitdaging precies in het programmeren?
Ik programmeer veelal in 2k chips (attiny2313 bijv. veel mee gedaan) en de 'GUI' met knopjes zoals jij dat hebt is meestal niet zo veel. De daadwerkelijke functionaliteit lijkt me lastig te passen.
Wat oude code voor de 'GUI' die ik zo snel kon vinden, voor een 2kb attiny2313 met 3 knopjes. Beetje zelfde idee?
C:
29
30
31
32
33
34
35
                                   // line1           line2           line3           Go
uint8_t cursor_pos[13]              ={195,198,201,204,147,150,153,156,211,214,217,220,222};
uint8_t cursor_pointsto_relay[12]   ={  0,  1,  2,  3,  0,  1,  2,  3,  0,  1,  2,  3};
uint8_t cursor_pointsto_dhl[12]     ={  0,  0,  0,  0,  1,  1,  1,  1,  2,  2,  2,  2};
uint8_t cursor_position=12;
int main(){
    initialize();
    while(1){
        if(left_flag){
            if(move_cursor_flag){
                if(cursor_position-- <= 0){cursor_position=12;}
            }else{change_time(0,&times[cursor_pointsto_relay[cursor_position]][cursor_pointsto_dhl[cursor_position]]);}
            reset_flags();
        }else if(right_flag){
                if(cursor_position++ >= 12){cursor_position=0;}
            }else{change_time(1,&times[ cursor_pointsto_relay[cursor_position] ] [ cursor_pointsto_dhl[cursor_position] ]);}
            reset_flags();
        }else if(ok_flag){
            //toggle move_cursor_flag
            move_cursor_flag=1-move_cursor_flag;
            if(cursor_position==12){
                lcd_initialize(LCD_FUNCTION_8x2, LCD_CMD_ENTRY_INC, LCD_CMD_ON);
                start_pulses();
                move_cursor_flag=1;
            reset_flags();
        lcd_move_cursor(0,cursor_pos[cursor_position]);
    return(0);
Ctrl+k
  • Ploink
Ik zou gewoon een paar trimpotjes en de ADC van de attiny gebruiken om dingen in te stellen, lekker oldskool user interface :)
  • RobV
RobV
(overleden)
of een rotary encoder met een led ring.
  • mux
mux
99% efficient!
Trimpotjes zijn een suboptimale interface; het is moeilijk te zien (zeker met een behuizinkje eromheen) waar hij precies staat en je hebt weinig feedback.
Rotary encoder had ik inderdaad ook liever gedaan (dat was m'n vorige project, volumeknop voor plank2) maar dat gaat écht niet in het budget... of form factor. Beetje encoder is al gauw 4 euro in kleine hoeveelheden, of je moet voor non-sealed gaan (en dat heb ik ook al eens in computerbehuizingen geprobeerd: stof gooit alles in de war).
Code komt gewoon online te staan (open source), dus dan kun je zien wat er zo moeilijk aan is. Het is vooral ruimtevretend omdat ik het een beetje algemeen wilde houden (zodat er functies bij geklust kunnen worden zonder de hele code te hoeven omgooien); het kan absoluut een stuk kleiner als ik het echt purpose-made had gemaakt. Anyway, zodra alles opgeschoond is blog ik er wel over en kan iedereen ermee doen wat hij/zij wil.
  • Ploink
mux schreef op woensdag 29 april 2015 @ 14:38:
Met de 3-knop bediening zie je helemaal niet wat er ingesteld is, pas als je een setting wijzigt zie je wanneer je de min of max hebt bereikt maar verder tast je volledig in het duister. Bovendien is het aantal stappen beperkt.
Met trimmers heb je minimaal 256 stappen (8-bit adc) en je ziet aan de stand wat je hebt ingesteld, zelfs als de voeding niet aangesloten is. (hoewel je idd even goed moet kijken om ze af te lezen). Voor de "NTC enable" zou ik gewoon een schakelaartje nemen.
Maar het zal iets duurder worden vermoed ik en user interfaces zijn ook een kwestie van persoonlijke voorkeur. Ik heb liever een directe hardware interface, zoals de draaiknop op mijn soldeerstation. Up/down knopjes heb ik een hekel aan. Ik ben een beetje ouderwets ;)
Gelukkig is het open source, dus wie het anders wil kan er lekker in hakken :D
  • mux
mux
99% efficient!
Tja inderdaad; daarom is het OSH. Ik heb 'maar wat gemaakt' (de hardware is letterlijk niet meer dan een uur werk geweest), 100% gefocust op BOM kosten en mijn idee van een interface :P.
Er zit een opvallend uitgebreide ADC op (sterker nog, die wordt nu al gebruikt voor de NTC-ingang), het is vrij simpel om de LEDjes te vervangen door potmeters. Ik ben benieuwd of iemand dit daadwerkelijk oppikt en er wat anders van maakt :)
Daar is V&A voor.
[ Voor 92% gewijzigd door Sprite_tm op 30-04-2015 01:38 ]
  • RobV
RobV
(overleden)
(kroegpraat) ik heb eindelijk genoegspullen binnen om een 1e netwerkje te kunnen bouwen, met 3 nrf24's en een (goed werkende!) esp8266. Ikmoest wel eventjes wat low level protocollen uitzoeken voor een gestroomlijnde data doorvoer, maar het resultaat is nu al erg bevredigend. Na wachten op 3v ftdi boardjes om de data goed te monitoren zonder breadboarddrama lijkt het nu erg goed te werken.
- site: draait, met /configure en email notificaties.
- hub transmit: prototype
- hub collect: prototype
- hub configure: uitdaging, waarschijnlijk gewoon flashen.
- sensor nodes: 95% af
Morgen de puzzelstukjes tegen elkaar schuiven en mooi maken!
  • Ploink
mux schreef op woensdag 29 april 2015 @ 17:43:
Stel dat het ledje een X aantal keer knippert als je de functie selecteert, om aan te geven wat de stand is?
Lijkt me leuk als iemand je project verder ontwikkelt. Mogen de Chinezen het ook namaken en voor $3 op ebay dumpen?
  • CrashOverDrive
  • Laatst online: 13:21
Te zien (als unbox) in de nieuwste eevblog
Afbeeldingslocatie: http://www.liteplacer.com/wp-content/uploads/2015/01/machine-from-left.jpg
Doooo want.
Open Hardware pick-and-place machine. Best leuk ding :D
  • mux
mux
99% efficient!
Ploink schreef op woensdag 29 april 2015 @ 19:07:
Eerst maar even het MVP uitproberen, daarna feature creep :D
Heb ik een keuze? Het is administratief voor mij makkelijker om dit OSH of CC te maken.
  • Puch-Maxi
  • Laatst online: 13-10 23:29
CrashOverDrive schreef op woensdag 29 april 2015 @ 19:25:
Heb je misschien een linkje, ik kan hem (nog) niet vinden?
  • ThinkPad
Vanmiddag een DHT22 gesoldeerd op printplaatje van projectje, maar het lijkt nu wel of het ding een hogere temperatuur aangeeft dan voorheen. Terwijl hij op dezelfde plek in de kamer staat... En op het printplaatje staat hij niet in de buurt van onderdelen die warm worden ofzo....
Zou het ding te warm geworden zijn ofzo? Heb nog een DHT22 liggen, zal die morgen eens met losse jumper wires aansluiten, kijken wat die aangeeft.
[ Voor 14% gewijzigd door ThinkPad op 29-04-2015 20:30 ]
  • Ploink
mux schreef op woensdag 29 april 2015 @ 19:44:
* Ploink zoekt op wat al die afkortingen betekenen...
Heeft het kiezen van een licentie model nog voordelen t.o.v. een simpel "hier is het, doe er mee wat je wil" ?
  • CrashOverDrive
Puch-Maxi schreef op woensdag 29 april 2015 @ 20:21:
Members only:
Microsoft Releases Free Visual Studio Code for Windows, Mac and Linux
- http://fossbytes.com/micr...or-windows-mac-and-linux/
  • Puch-Maxi
Ah vandaar, dat wist ik niet! Thnx. David (aka Dave2) mag hem nu in elkaar gaan zetten :D
ThinkPadd schreef op woensdag 29 april 2015 @ 20:30:
Het toeval wil dat Electronupdate er vandaag een video over heeft gemaakt! :)
  • mux
mux
99% efficient!
Ploink schreef op woensdag 29 april 2015 @ 20:33:
MVP = minimum viable product
OSH = open source hardware (doorgaans is de 'standaard' OSH licentie hiermee geïmpliceerd, oftewel (L)GPL)
CC = creative commons
GPL betekent heel erg kortweg: zeg dat ik het heb gemaakt, maar doe er verder mee wat je wilt. CC betekent: gebruik het, doe alsof het van jezelf is, zeg dat ik een kindermoordenaar ben, kan me niet bommen. Er zijn overal varianten op (bijvoorbeeld CC-BY-SA, waarbij weer wel om attribution wordt gevraagd), maar dit is de algemene richting die ik zou kiezen. Ofwel LGPL, ofwel full-on CC.
Hier speelt ook een beetje mee dat een project als dit vrij makkelijk kan worden veranderd tot op zo'n niveau dat je nauwelijks meer van transformative work kunt spreken. Binnen 2 uur heb je iets totaal anders ervan gemaakt. Hoeveel nut heeft attribution dan nog?
  • RobV
RobV
(overleden)
Verwijderd schreef op woensdag 29 april 2015 @ 20:58:
Gigantisch off-topic, maar super bedankt voor deze notificatie and had ik het volledig gemist.
* Rob prefereert C# ver boven PHP
  • Pizza_Boom
Kent iemand nog een goede en goedkope webshop met winkel/afhaalmogelijkheid (a la SOS Solutions) in Noord Holland? Mijn webshop heeft best lang nodig om te antwoorden op de kapotte Arduino en ik sta stil...
  • sebastius
  • Laatst online: 00:14
sebastius
Laten we lekker link gaan doen
OpenCircuit.nl verzend gigasnel in mijn ervaring.
  • RobV
RobV
(overleden)
Weer genoeg voor vandaag:
Arduino library met nonblocking calls voor webrequests. Voorbereid op een transmit queue zodat ik meerdere pending webrequests kan stacken mochten de sensortjes onverhoopt allemaal tegelijkertijd hun data indienen.
  • LED-Maniak
CrashOverDrive schreef op woensdag 29 april 2015 @ 20:43:
Members only:
1300 USD, dat is best een flink prijsje voor een paar rails. Markt zal klein zijn dus wat dat betreft niet meteen heel vreemd.
  • Pizza_Boom
sebastius schreef op woensdag 29 april 2015 @ 22:13:
SOS ook, maar ik wil het eigenlijk gewoon meteen kunnen ophalen en doorgaan met wat ik doe.
  • Ploink
Miskoop gedaan :(
http://www.ebay.com/itm/111623337165
Ik dacht dat deze soldeerpasta mijn Edsyn CR44 kan vervangen die misschien een beetje begint te verouderen na al die jaren, maar dit spul is echt antiek en totaal uitgedroogd.
De verkoper heeft gefraudeerd door de datum stikker op de voorkant van de verpakking te verwijderen. Op de achterkant zit een nieuwe van "3-4-2015".
Ik heb een refund aanvraag gedaan.
Afbeeldingslocatie: http://i.imgur.com/tGDEaEvl.jpg
  • LED-Maniak
Zelfs met originele stikker gaat die chinese meuk in syringe ontzettend snel achteruit(en in syringe bewaren en gebruiken is ellende omdat je door de druk de flux er uit drukt en het uithard).
Ik heb zelf kleine potjes van dealextreme die echt geweldig werken. Mocht hij te lang open hebben gestaan dan wil ik het nog wel eens verdunnen met IPA.
  • RobV
RobV
(overleden)
LED-Maniak schreef op woensdag 29 april 2015 @ 23:21:
Aangezien mijn pasta bijna op is, heb je een linkje naar de juiste pasta op DX? ikben bang om anders het verkeerde spul te kopen, soms is het alleen flux.
  • LED-Maniak
Volgens mij was het deze:
http://www.dx.com/p/lodes...ste-50g-4711#.VUFNAReX1E4
In mails staat alleen niet wat je bestelt en op de site kan ik de order niet meer terugvinden(is alweer even geleden, had een paar potjes tegelijk besteld). Als ik hem weer tegenkom zal ik het opschrijven.
Uit de reviews op dx.com kan je overigens ook heel veel halen. Daar ben ik toen op af gegaan.
Deze flux is overigens ook prima:
http://www.dx.com/p/solde...e-flux-grease-10cc-117099
Meer gel-like, wat super fijn kan zijn vergeleken die vloeibare pennen.
  • RobV
RobV
(overleden)
Allereerst dank. Ja, de lodestar. Helaas is die 'sold out' dus blijft het voor mij gokken welke dan wel, want bij alles staat 'no description available' 8)7
  • Ploink
Dit spul is Pools, geleverd vanuit Zweden.
Mijn spuitje Edsyn CR44 is al zes jaar oud en ik heb er nooit problemen mee gehad. Altijd <0°C bewaard.
Dat het de laatste keer niet zo goed werkte kwam omdat ik de temperatuur te laag had ingesteld, ietsje warmer en het werkt weer prima.
Ik kan het niet vaak genoeg zeggen, meteen na gebruik in de vriezer.
RobV schreef op woensdag 29 april 2015 @ 23:24:
http://www.ebay.com/itm/180926725385
Ik heb 'm zelf niet, maar met "1236 sold" zal hij wel goed zijn denk ik dan :)
  • RobV
RobV
(overleden)
Dank!
  • LED-Maniak
Ploink schreef op woensdag 29 april 2015 @ 23:51:
Het spul is Pools ;)
Ah ok :+.
Probleem dat ik vooral heb ik als ik een panel met stencil ingesmeerd heb dat het weer droger terug in het potje gaat. Na een paar keer houdt dat gewoon op en is het IPA erbij en kan je het weer prima gebruiken.
Remark:this item is marked 50g,but it is real about 35g.
Haha :+ . Wat zou er dan echt in zitten? :)
[ Voor 7% gewijzigd door LED-Maniak op 30-04-2015 00:00 ]
  • Ploink
Was de meest populaire handelaar die ik kon vinden, stond in mijn watch list.
Je wil geen handelaar die de spullen een half jaar in het magazijn heeft staan, maar eentje met een snelle turnover die vers spul kan leveren.
LED-Maniak schreef op woensdag 29 april 2015 @ 23:59:
Ah, ik snap het. Ik vroeg me al af hoe je zo'n potje ooit op krijgt.
Ik heb nooit met stencils gewerkt en voor 1 printje of een paar led sterren ofzo ga ik geen stencil laten maken.
Een spuitje is zo zuinig in gebruik, met 10g kun je tientallen printen doen.
Deze shop zegt het tenminste eerlijk, kan ik wel waarderen.
Hij staat ook op DX met goede reviews.
[ Voor 55% gewijzigd door Ploink op 30-04-2015 00:13 ]
  • lordprimoz
LED-Maniak schreef op woensdag 29 april 2015 @ 22:23:
Het is ook niet alleen de rails waar je voor betaald, maar ook de R&D + software van het apparaat. Het mag dan wel opensource zijn, maar de persoon wil nog wel verdienen aan zijn ontwikkeling.
trouwens voor de (hobbie) pcb ontwikkelaars onder ons. Over een week of twee komt het Eagle alternatief van Altium in open beta. Het gaat om Circuit maker: http://www.circuitmaker.com/
Gezien het van de makers van Altium komt en ze redelijk veel tijd in de development hebben zitten verwacht ik dat het een best aardig pakket zal zijn.
pffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff was een typische kroeg opmerking, maar ik ken je inmiddels :(
  • lutkeveld
Website ziet er in ieder geval prima uit!
Heb mij maar eens aangemeld. Gebruik nu DipTrace, ooit begonnen met Eagle maar kon daar mijn weg niet in vinden. Dit ziet er erg gebruiksvriendelijk uit.
  • lutkeveld
double post
[ Voor 94% gewijzigd door lutkeveld op 30-04-2015 10:40 ]
Pagina: 1 ... 19 ... 116 Laatste
