[FS2002/2004] Vragen en mooiste screenshots, deel 62 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 6 ... 11 Laatste
  • 5.593 views sinds 30-01-2008
  • klaaz
  • Laatst online: 23-11 18:59
klaaz
it's me!
Ik weet niet of ie al eens voorbij is gekomen:
QUANTAS
Never let it be said that ground crews and engineers lack a sense of
humor. Here are some actual logged maintenance complaints by QUANTAS
pilots and the corrective action recorded by mechanics. By the way,
Qantas is the only major airline that has never had an accident.
P stands for the Problem the pilots entered in the log, and S stands
for the Corrective Action taken by the mechanics.
> P: Left inside main tire almost needs replacement.
> S: Almost replaced left inside main tire.
> P: Test flight OK, except autoland very rough.
> S: Autoland not installed on this aircraft.
> P: Something loose in cockpit.
> S: Something tightened in cockpit.
> P: Dead bugs on windshield.
> S: Live bugs on back - order.
> P: Autopilot in altitude-hold mode produces a 200-fpm descent.
> S: Cannot reproduce problem on ground.
> P: Evidence of leak on right main landing gear.
> S: Evidence removed.
> P: DME volume unbelievably loud.
> S: DME volume set to more believable level.
> P: Friction locks cause throttle levers to stick.
> S: That's what they're there for!
> P: IFF inoperative.
> S: IFF always inoperative in OFF mode.
> P: Suspected crack in windscreen.
> S: Suspect you're right.
> P: Number 3 engine missing. (note: this was for a piston-engined
> airplane; the pilot meant the engine was not running smoothly -
> misfiring)
> S: Engine found on right wing after brief search.
> P: Aircraft handles funny.
> S: Aircraft warned to straighten up, fly right, and be serious.
> P: Radar hums.
> S: Reprogrammed radar with words.
> P: Mouse in cockpit.
> S: Cat installed.
Mooie plaatjes trouwens allemaal!
[ Voor 8% gewijzigd door klaaz op 10-11-2003 11:16 ]
  • ravw
  • Laatst online: 16:05
ravw
Zo even wat anders .... ps door tijd gebrek kon ik niet vliegen maar vanmidag komen meer foto's er van.
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Fightdeck-01.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Fightdeck-02.jpg
Systeem:AMD Ryzen 7 9800X3D ,RTX 5080 OC,FURY 64 GB DDR5-6000,ASUS TUF Gaming B850M-PLUS WIFI, SAMSUNG 990 EVO Plus 4 TB
  • kenneth
kenneth
achter de duinen
@Klaaz:
Tis Qantas, niet Quantas :)
En ja, hij komt vaker langs in allerlei aviation humor websites enzo :)
  • Jochem
  • Laatst online: 18-11 16:08
ja tuurlijk. Tornado vanaf een vliegdekschip. Ja tuurlijk die Bomber van LIRQ naar EHAM en zeker landen op 06. Beetje ongeloofwaardig allemaal. Maar ja goed, ieder zijn hobby en als het maar leuk is.
  • ravw
ravw
Jochem schreef op 10 november 2003 @ 12:36:
:( die tornado was beter dan een Cessna :)
Want ik had even niets anders :)..
dus daarom.
  • DutchCommando
  • Laatst online: 24-11 21:10
Blackhole schreef op 10 november 2003 @ 12:45:
dus daarom.
Met het enige verschil dat er geen tornado's landen op Schiphol en heel af en toe wel een Cessna :?
  • klaaz
klaaz
it's me!
kenneth schreef op 10 november 2003 @ 12:31:
@Klaaz:
't was een copy/paste job. Ik vondt hem wel leuk en had hem nog niet gezien ;)
  • ravw
ravw
DutchCommando schreef op 10 november 2003 @ 13:06:
Wie het het over landen opschiphol ..
ik had het over het vliegdekschip :)
Ach als je het over Eham heb , ik zie ook geen 3 torens staan op Schiphol :) zeker niet zo als in FS9 :)
Dus waar gaat dit om.
Het gaat gewoon even om de foto's:)
[ Voor 23% gewijzigd door ravw op 10-11-2003 13:36 ]
  • Jochem
Torens op schiphol heeft de gebruiker geen invloed op. Cessna's landend op RWY06 wel.
Blackhole schreef op 08 november 2003 @ 21:41:
PS als je antwoord heb laat het ons dan ook even weten.
Voor de geïnteresseerden: bij deze een checklist voor de FSD Pilatus PC-6 Porter, zelf samengesteld uit de (summiere) FSD checklist en info van het internet.
Ik ga er hierbij vanuit dat je begint met een cold and dark cockpit. Alle dingen die alleen maar gechecked moeten worden heb ik niet vermeld: er staat alleen maar in wat je daadwerkelijk moet doen en waar je op moet letten (anders vond ik het voor me zelf te onoverzichtelijk worden. Bovendien staat er na het laden van mijn default flight toch nooit wat fout, dus... ;))
Als iemand tips, toevoegingen of opmerkingen heeft (om het allemaal nog realistischer te maken (als ik bijvoorbeeld ergens toch nog iets niet in de goede volgorde doe) of gewoon ter correctie) laat het dan ff weten! En o ja, die Water rudders zitten natuurlijk alleen op het watervliegtuig... ;)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
PILATUS PC-6 PORTER CHECKLIST
PRE-START
[ ] Battery Switch             On
[ ] Light Switches             Beacon on
[ ] Avionics Master Switch     On
[ ] GPS/NAV Switch             Set
[ ] Radios, AP and Heading Bug As required (AP VS at 900)
[ ] ECS Bleed Air              On
[ ] ECS Mode                   Auto
[ ] ECS Ice Protection         As required
[ ] ECS Pitot/Static Heat      On when OAT is below 4 degrees
START
[ ] Power                      Normal (full aft) position
[ ] Propeller                  Full
[ ] Fuel Pump Switch           On
[ ] Ignition Switch            On
[ ] Starter Switch             Start (hold until engine starts)
                               At 15% RPM Fuel Condition Lever High
[ ] Generator Switch           On
[ ] Fuel Boost Switch          Off
TAXI
[ ] Light Switches             Strobe and taxi on
[ ] Water Rudders              Down
[ ] Power                      15 PSI
[ ] Speed                      Maximum 20 MPH
[ ] Fuel Condition Lever       Low if required
TAKEOFF
[ ] Wing Flaps                 12-18 degrees (Amphibian 24-30)
[ ] Light Switches             Landing on, taxi off
[ ] Fuel Boost Switch          On
[ ] Water Rudders              Up
[ ] Power                      Full
[ ] Rotate                     65-70 KIAS
CLIMB
[ ] Pitch                      10-15 degrees
[ ] Best rate of climb         950 ft/min
[ ] Climb Speed                75-80 KIAS (Amphibian 85-95)
[ ] Propeller                  1900 RPM
[ ] Power                      42 - 43 PSI
[ ] Wing Flaps                 Retract after reaching 80 KIAS (Amphibian 90)
[ ] Light Switches             Landing off
CRUISE
[ ] Maximum Level Speed        125 KTAS
[ ] Power                      40 PSI
ENROUTE CLIMB
[ ] Airspeed                   90-100 KIAS (80-90 for maximum performance climb)
[ ] Propeller                  1900 RPM (2000 for maximum performance climb)
DESCENT
[ ] Speed                      100 KIAS
[ ] Power                      12 PSI
FINAL APPROACH
[ ] Propeller                  Full
[ ] Autopilot                  Off
[ ] Wing Flaps                 12 at 99 KIAS
                               18-24 at 94 KIAS
                               30-48 at 88 KIAS
[ ] Airspeed                   75-85 KIAS
LANDING
[ ] Airspeed                   65-70 KIAS (Amphibian 75-85)
[ ] Power                      Beta range after touchdown (cancel at 40 MPH)
GO-AROUND
[ ] Power                      Full
[ ] Wing Flaps                 Retract to 20 degrees
[ ] Climb Speed                70 KIAS minimum until obstacles are cleared
[ ] Wing Flaps                 Retract after reaching safe altitude and airspeed
AFTER LANDING
[ ] Wing Flaps                 Up
[ ] Light Switches             Landing off, taxi on
[ ] Transponder                1200
[ ] Fuel Condition Lever       Low when clear of the runway
SHUTDOWN AND SECURING
[ ] Parking                    Brake set
[ ] Avionics Master Switch     Off
[ ] ECS Ice Protection         Off
[ ] ECS Mode                   Off
[ ] ECS Bleed Air              Off
[ ] Propeller                  Feather
[ ] Fuel Condition Lever       Cutoff
[ ] Light Switches             All off
[ ] Ignition Switch            Off
[ ] Generator Switch           Off
[ ] Battery Switch             Off
[ Voor 6% gewijzigd door Verwijderd op 10-11-2003 14:24 ]
  • ravw
ravw
Om dat er hier altijd maar gezeur is over welke video kaart vind ik het beste
Daarom vind ik dat deze link wil in de start post mag komen ..
http://www.tomshardware.c...1015/radeon9600xt-24.html
(ook gelijk de discussie weg welke kaart het beste is, ook weer van de baan hier zo )
Radeon of Gforce.
Zeg niets :X :X
[ Voor 32% gewijzigd door ravw op 10-11-2003 14:56 ]
Blackhole schreef op 10 november 2003 @ 14:53:
Radeon of Gforce.
Zeg niets :X :X
Sjah en toch doet zo'n test me niets.
De meeste Ati pics van users blijven ranzig en alle problemen zijn ook altijd omtrent Ati.
Spoken.
Mag ik u eraan herinneren dat een keuze voor de videokaart niet alleen afhangt van de FPS score... :)
(Of is dit nou juist het verschil tussen ATI en Nvidia gebruikers?? :+)
  • ravw
ravw
Verwijderd schreef op 10 november 2003 @ 15:11:
Kijk die link zou ik even zeggen :)
Verwijderd schreef op 10 november 2003 @ 15:00:
Spoken.
Vind ik niet zo gek he .....
Want Nvidia loopt al een tijdje langer mee dan ATI.
ALleen het grote verschil is dat veel game makers er nog steds intrappen om hun software op Nvidia af te stemmen.
( Zie de vele logo's bij het begin van het opstarten bij spellen. )
Maar ik denk dat over een paar maanden de rollen wel anders zullen liggen , dat mer game makers nu over gaan stappen op ATI.
Want je moet niet vergeten dat de meeste Software die nu uit komt al ruim 2 jaar oud is.
Duis toen was ATI nog niet zo ver.
Maar kijk een na wat ze de laaste tijd allemaal berijkt hebben. vind ik een heel hoop.
Dus laat mij maar gewoon lekker via mijn ATI het beeld zien.
Want het bevalt me prima.
Daar bij komt ook nog eens dat een Nvidia kaart meer stroom verbruikt dan een gemiddelde Radeon.
[ Voor 71% gewijzigd door ravw op 10-11-2003 15:29 ]
Blackhole schreef op 10 november 2003 @ 15:21:
We weten dat je een ATi Radeon 9600 PRO hebt. Nu tevreden?
OMG, stroomverbruik zal me jeuken
[ Voor 11% gewijzigd door Verwijderd op 10-11-2003 15:59 ]
  • ravw
ravw
Verwijderd schreef op 10 november 2003 @ 15:23:
IK wel jij ook? .. maar die pro doet het in die test niet echt goed hoor :)
Radeon of Gforce.
Zeg niets :X :X
Bedankt voor de link! Ik ga op de HCC-dagen misschien een nieuwe videokaart kopen, dus...
Wat ik wel altijd jammer vind van dit soort test is dat me nooit duidelijk wordt in hoeverre zo'n superkaart nou effect heeft in m'n huidige systeem... Ik heb nu een Athlon 1600+ met een GeForce 3 Ti200. Nu is het altijd beter ook een snellere CPU aan te schaffen, maar dan moet ik ook meteen een nieuw mobo en RAM en etc. kopen en daar heb ik absoluut geen geld voor nu...
Heeft het veel nut om een 9800 Pro in m'n pc te hangen zonder dat ik die CPU vervang? Het zal toch allicht beter lopen? Zo niet met hogere resoluties dan wel toch met meer anti-aliasing en filtering.. Toch...?
  • rdluca
rdluca
Verwijderd schreef op 10 november 2003 @ 16:05:
Ik zou ff drie X op je kop krabben voordat je die ATI-prullaria aanschaft. Let the pics speak zou ik zeggen ;)
[ Voor 4% gewijzigd door rdluca op 10-11-2003 16:21 ]
  • The_FrankO
The_FrankO
rdluca schreef op 10 november 2003 @ 16:21:
Er is niet veel keus meer he ;) Die Geforce FX is helemaal brak :/ om nou nog een geforce 4 te kopen zou een beetje lomp zijn.
iRacing Profiel | Mijn SimRig
  • Sleepie
  • Laatst online: 24-11 14:40
Ik zou daar ook een beetje bij nadenken of je in de nabije toekomst nog verder gaat upgraden. Als bv je moederbord alleen 2x AGP ondersteunt, zou ik nog even goed nadenken of je uberhaupt wel je grafische kaart wil upgraden.
Dan misschien beter je geld nu uitsparen tot je geld genoeg hebt om alles in 1 keer te upgraden.
  • DutchCommando
Sleepie schreef op 10 november 2003 @ 16:51:
Als we het toch over upgrades hebben. Ben ik even blij met mijn nieuwe stuff:
• 512 MB PC2700 (Corsair) (totaal nu 1024MB)
• 80 GB Western Digital 8MB (totaal nu 160GB)
Meer ram = sneller voor FS
2 HDD's = paging file op andere HDD dan windows = sneller.
  • Dark Master
  • Laatst online: 15:22
Dit is echt het coolste spel ooit :*) ik zweer echt ik heb me sinds die domme flight simulator 98 niet meer bezig gehouden met dit spel maar toen ik dit topic leeste toen kwijlde ik toch wel weer van de screenshots echt er is zoveel verbetert sinds 98 graphics,ATC het beste stuk 8) .
dit was zeker weten mijn beste koop tot nu toe ik blijf nu lekker simmen iemand die dit wil kopen en graag wil fliegen vooral realtime gebaseerd >:)
dit is 80 euro waard hier ga ik nog veel plezier aan beleven
heel veel dank aan alle tweakers hier _/-\o_ _/-\o_ jullie hebben me er toe aangezet het spel te gaan kopen Flightsim rulezzz.
nu ga ik weet lekker verder vliege :+
Razer 18 * 32GB * i9 13950HX 5,5 GHz * 4TB ssd * RTX 4090
  • ND863
  • Laatst online: 09-07-2022
ND863
Forget aircraft - Fly Airbus
Dark Master schreef op 10 november 2003 @ 18:02:
Wow zon enthousiasme hebben we (geloof ik) nog niet meegemaakt 8) Goed om te horen dat je het naar je zin hebt met de sim :)
Fun, ja jongens daar doen we het voor _/-\o_
To be, or not to be a FRUITVLIEG!??
  • Dark Master
trouwens er komen nog screenshots ik moet het eerst weer een beetje onder de knie krijgen en dat zal zekerzz wel lukken jullie zien me nog wel vaak verschijnen bij deze topic >:)
adios medetweakers :)
  • Megamind
  • Laatst online: 16-09 16:54
En dan kom ik met mijn GeForce4 Ti 4800 en AMD 1100MHZ / 380MB (jaja) en 17fps en alle settings op ultrahigh? :P :O
Geforce toch de beste :+
Ben maar weer terug gegaan naar Europe, kreeg heimwee... ;)
Hiero vluchtje Frankfurt - Brussels. Landing maar eens met het handje gedaan, zoals te zien is.... :)
Excuses voor de slechte kwaliteit, ik ben maar in het bezit van zo'n nietige FX...
Afbeeldingslocatie: http://www.achappey.nl/plqany9.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany15.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany20.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany34.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany39.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany43.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany45.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany47.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany60.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany70.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany74.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany79.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany84.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany86.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany89.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany92.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany98.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany100.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany103.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany105.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany106.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany109.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany113.jpg
Afbeeldingslocatie: http://www.achappey.nl/plqany117.jpg
Omdat FS9 continu loopt te swappen heb ik de swapfile met een vaste grootte (768MB) op m'n 2e HD gezet. Deze WDC W300AB (30GB Western Digital) is al wat ouder t.o.v. de 160GB Seagate (ST3160021A, 7200rpm). Op de 160GB schijf staat zowel XP als FS9.
Ik dacht dus dat, ook al is de schijf langzamer, dat het swappen op een 2e HD sneller zou gaan. Nou, na 1 vluchtje heb ik de swapfile maar weer gauw teruggezet! U zijt gewaarschuwd.
Conclusie: Dat wordt dus 512MB erbij prikken :(
  • ND863
ND863
Maar een FFX, hijs wel mooi zat :)
BTW met afcad2 kan je toch taxiways maken? Iemand al gelukt de nieuwe taxiways op schiphol te maken? (Z, verleng A,B en de extra entry points voor 36C)
  • Sleepie
Probeer eens op beide schijven een swapfile aan te maken, misschien helpt dat wel ?
  • Sleepie
ND schreef op 10 november 2003 @ 19:29:
Zeker weer geen zin om t zelf te doen ????
Ga controllen Noofmans !! ;) :>
  • ND863
ND863
Sleepie schreef op 10 november 2003 @ 19:30:
AFCAD en ik is net water met bier :P (en ja ook geen zin O-) )
Trouwens, ik heb t verloopje binnen!! Thanks! 8)
En ik ben al online Hansman :7 (wel uber rustig majah :))
[ Voor 10% gewijzigd door ND863 op 10-11-2003 19:36 ]
  • Sleepie
ND schreef op 10 november 2003 @ 19:34:
Volgens mij moet het best te doen zijn, als je maar precies weet waar die nieuwe stukken liggen (kaartje met coordinaten zou handig zijn).
Ik ben er ook niet zo handig in, maar als ik nog eens tijd heb (oei..dat komt heel weinig voor) zal ik wel eens proberen.
Verloopje heeft de Brabantse Reis snel afgelegd dan, krijgen we nu binnenkort screenshots in 3200x1200 ? :P
En niet editen terwijl ik een antwoord aan t typen ben he }) Ik had al gezien dat je aan t controllen was, daarom zei ik het ook. Ow ... and don't expect the KLM11717771171 today, because it's pilot has to go DIRECT Kilo Romeo Oscar Echo Golf again :P
[ Voor 18% gewijzigd door Sleepie op 10-11-2003 19:40 ]
Ik blijf gewoon allerlei info posten die betrekking hebben op m'n nieuwe liefde, de FSD Pilatus PC-6 Porter! :)
Zo vond ik op mijn zoektocht naar info over turboprops de site van de makers van de engine (dat ik daar niet eerder aan gedacht heb...). Op die site staat (o.a.) een flash-uitleg over turboprops (en ook turbofan, rocket en land bases turbine engines). Leuk om te zien en leerzaam. Zie hier!
Zo, op naar m'n volgende Daily Porter Info Post... ;)
Megamind schreef op 10 november 2003 @ 19:13:
ja zonder ai, addon planes en addon scenery kan ik wel 100 fps halen ;)
  • DutchCommando
Ik heb wel de Z taxiways gemaakt in AFCAD ja, maar volgens mij is het niet de mooiste ;).
  • Ensinker
  • Laatst online: 14:35
Ensinker
Verwijderd schreef op 10 november 2003 @ 19:53:
Dank u :)
Ik zal mijn schoonheid ook weer eens uit de kast trekken, eigenlijk mag die in geen hangar ontbreken, toch?
  • ravw
ravw
THX alle info is mooi .. ook al heb ik dat ding niet maar om het te lezen is het ook wel leuk en dan weet je weer wat ......
Maar een mooie site van P and W
[ Voor 4% gewijzigd door ravw op 10-11-2003 20:18 ]
Sleepie schreef op 10 november 2003 @ 19:29:
Ga ik proberen, thanks.
btw. Ik heb vanavond met 2 monitoren gevlogen!! Echt Super: Links Cockpitview en rechts FMC en Spotplane view! Thanks Sleepie _/-\o_ , kom ff op MSN ik heb misschien wat voor je.
  • ND863
ND863
Sleepie schreef op 10 november 2003 @ 19:38:
aaah, keey geen KLM :)
Maar check de winds :
winds 060 at 6, runway 06, cleared to land, expect garrival gate E6, and switch at A6 :o
  • DutchCommando
ND schreef op 10 november 2003 @ 21:04:
Duivels }) 666? ;)
  • ravw
ravw
Hier even 4 mooie shots van de bekende Boeing Flight deck hier op GoT :)
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/B737-01.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/B737-02.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/B737-03.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/B737-04.jpg
Deze foto's zijn door Basten_iFDG geplaats in het forum van FSmagazine in een topic van mij met mooie Flight deck foto's
http://www.fsmagazine.nl/
Hawker Sea Fury T Mk20 Royal Navy. Rondje EHAM (Niet echt realistisch, maar ja..)
Vliegt lekker gevoelig, maar landen is knap lastig
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury1.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury2.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury5.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury7.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury8.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury9.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury10.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury12.jpg
OEPS }) Een 737 heeft er 2, en deze maar 1. Motor was met geen enkele knop meer aan de praat te krijgen. Dat heb je met die oude meuk (En CTRL+E was ik ff vergeten :? )....dus........MAY DAY, MAY DAY
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury14.jpg
Zou ik het nog halen?
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury16.jpg
Keurige landing dacht ik, maar FS denkt daar iets anders over.
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/SeaFury18.jpg
Achteraf denk ik dat Valkenburg een beter alternatief voor de noodlanding was geweest
Nofriiii... kom eens op msn ;) ik heb zo iets voor je :*)
  • ravw
ravw
Verwijderd schreef op 10 november 2003 @ 21:29:
Fijn toestel he :) vluegels kunnen ook ingeklapt worden , dus goed op vliegdeck schepen ....
Ik ben er ook een halve dag mee bezig geweest.
Maar over dat probleem dat de motor uitval, daar heb ik ook mijn vraag tekens bij....
Maar ik kreeg hem wel aan met CRTL en E , maar je moet geduld hebben.
Maar wel een wentbaar toestel.
Blackhole schreef op 10 november 2003 @ 21:33:
Ik heb CTRL+E niet eens geprobeerd....niet aan gedacht
Ik denk trouwens dat de toenmalige piloten ook geen CTRL+E hadden om de motor weer aan te zetten ;)
Btw hoe kan ik die vleugels inklappen?
  • ravw
ravw
Verwijderd schreef op 10 november 2003 @ 21:47:
Die wings moet met Wingfold of tail hook.
Maar je heb ze alle twee nodig
Nee maar ik weet nu wel hoe je die motor aan kan houden zonder problemen.
Je moet je motor niiet vol belasten en je mengverhouding op iets over het midden zetten.
En wat met je Coolings flaps zettings doen.
Hier even een mooi vluchtje met dezelfde
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_01.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_02.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_03.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_04.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_05.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_06.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_07.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_08.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_09.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_010.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_011.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_012.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_013.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_014.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_015.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_016.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_017.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_018.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_019.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_020.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_021.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_022.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/Hawker_Sea_Fury_T_Mk20_Royal_Navy_023.jpg
Blackhole schreef op 10 november 2003 @ 22:30:
Gave pics en landing! Waar ligt dat schip? of is dat payware scenery? In FS98 ben ik wel eens op een vliegdekschip geland met een cessna, maar da's lang geleden. Hoe vaak ben je in zee gestort voordat je deze pics maakte?
  • ravw
ravw
Verwijderd schreef op 10 november 2003 @ 22:49:
Hier kan je hem vandaan halen.
Ook die plane is daar vandaan.
http://www.fsplanet.com/04112003.htm
En hoe veel ik in zee ben gestort ??
Ach geen 1 keer, wel 2 keer een doorstart moeten maken.
Omdat ik dit wel eens vaker heb gedaan.
Alleen jammer dat het schip niet echt op en neer gaat.
Want dan zou het eens stukje moeilijker zijn.
oja als je die Flightdeck schip heb geinstalleerd , dan moet je even naar je Fightfiles gaan die al voor gepland zijn. daar staan ze bij dan sta je ook gelijk op het schip zelf ..
[ Voor 18% gewijzigd door ravw op 10-11-2003 23:10 ]
Thank you and goodnight
  • ravw
ravw
Oke maar blijf ook eens snacht op dat schip staan :)
Je zal wel zien wat er gebeurd.
  • Ensinker
Ensinker
Ladies and Gentlemen....
Thank you for your opinions on the topic of whether or not PMDG should
provide regular updates on our development schedule. Some of the opinions
above are well thought out, and others are well informed. (A few are
both...)
I'm terribly sorry that PMDG is not providing you with a time update for the
SU2 release. Many of you may recall that PMDG was the target of some
particularly unsavory behavior in the forums after we moved the SU1-1 update
four times in order to ensure it was adequately prepared for release.
I made it very clear at the conclusion of that "event" that we would not
announce the release date of the next Service Update as a result of what we
learned.
The PMDG development team continues to work on the kinks out of the SU2
update in order to ensure that the PMDG 737 continues to be unmatched
anywhere else in the simming community.
In fact, we have taken a number of development stages from our upcoming
800/900 product and move them backward into the 600/700 in order to provide
you with even greater value in the airplane.
This update has been in very heavy testing for two months, and the PROJECTED
RELEASE DATE HAS BEEN MOVED NINE TIMES.
I cringe to imagine the invective commentary we'd be handling if we had
announced the expected release dates only to move them again and again....
The unfortunate reality that we are managing in the sim community is this:
-> If we announce the date and move it- then we are described as
undependable and disappointing for missing a release date.
-> If we don't announce the date and simply develop until we are finished,
then we see some folks upset because we aren't providing updates.
The reality is that PMDG has always been very coy about release date
announcements. We very very rarely announce release dates in advance, and
we have found that this approach allows us the flexibility to complete
products and tasks as we desire.
So. bear with us on the update cycle and release dates for new and updated
products. In all cases I can assure you that the wait will be worth it- and
that it will be better to be surprised by a release than disappointed by a
change in date.
Robert S. Randazzo
Precision Manuals Development Group
www.precisionmanuals.com
Dan blijven we maar wachten :O
  • Bolk
Bolk
Change the equation.
Gilly schreef op 10 november 2003 @ 23:13:
Ach, zo lang ze maar waar maken wat ze beloven. Daar wil ik best wel een tijdje voor wachten.
Anyway, ik was net nog ff op schiphol (of ik ff de overburen naar schiphol wilde brengen om 9 uur 's avonds :() en wat mij opviel was dat RWY 06 in use was. Je zou zeggen dat ze 18R zouden gebruiken.
Niet veel bijzonders gezien overigens. 4 Transavia kisten die allen op de autoland neerkwamen :z :P
Ik bespeur hier een zekere mate van onethische logica.
  • Floppie
  • Laatst online: 15:49
Waarom zou je 18R denken. Wat wind betreft is 06 een hele normale keuze voor landing. ;)
EHAM Amsterdam METAR observed at: 10 Nov 23:25 UTC (40 minutes ago)
Wind direction: from 70 degrees varying from 40 to 100 degrees
Wind speed: 8 knots
Visibility: 2000 meters
Present weather: Mist
Sky conditions:
Few (1/8-2/8) at 200 feet
Scattered (3/8-4/8) at 300 feet
Broken (5/8-7/8) at 400 feet
Temperature: 4 degrees Celsius, Dew point: 4 degrees Celsius
Altimeter setting: 1024 hectopascal
[ Voor 6% gewijzigd door Floppie op 11-11-2003 01:06 ]
  • Bolk
Bolk
rellehenk schreef op 11 november 2003 @ 01:04:
Wind speed: 8 knots
Sky conditions:
Aan de grond was het windstil, dus vandaar :) Ik kon de windrichting niet voelen.
  • ravw
ravw
Hier een testvluchtje vanaf Woensdrecht met een F104 Starfighter
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_01.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_02.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_03.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_04.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_05.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_06.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_08.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_09.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_010.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_011.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_012.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_013.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_014.jpg
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/F104_Starfighter_015.jpg
  • Jochem
06 is de meest preferente landingsbaan. Dus als het winds calm is (onder 5 knopen) wordt er op 06 geland.
Die starfighter is een erg mooie kist. Ik vraag mezelf alleen sterk af of die niet heel toevallig van captainsim is. En dan vraag ik me nog sterker af of die wel legaal geregeld is.
  • ravw
ravw
Jochem schreef op 11 november 2003 @ 11:03:
deze is van Captain sim ja,
En op de 2de vraag .... :X nee ik krijg het me strot niet uit , wat een ezel ben ik toch .... :X
  • Sleepie
Verwijderd schreef op 10 november 2003 @ 20:40:
Hey....bij jou is het verloopje ook aangekomen dus :)
Sorry, op maandagavond ben ik nooit thuis, overdag kan ik hier op de zaak niet meer op MSN. Dus je ziet me vanavond weer online.
  • Sleepie
WonkaBonka, nu ben ik trouwens wel benieuwd hoe je de dual monitor setup gebruikt. Wat zet je allemaal op je tweede monitor ?
Staat er gewoon bij...beter kijken SlaapMans :X :X :X :Z :Z :Z
[ Voor 24% gewijzigd door Sleepie op 11-11-2003 13:59 ]
Hallo medesimmers :)
Ik heb een vraagje: als je gaat vliegen met ATC gebeurt het me wel eens dat je de instructies krijgt van ATC en dan op volgt en dan naar bijv. FL21 klimt en daarna gewoon helemaal niks meer hoort van die gasten?!
Het is dan wel zo dat je als je dan opeens van hun koers af wijkt instructies krijgt om snel weer je vorige koers te volgen, terwijl het dan nog helemaal niet richting je bestemming gaat!?
Dan vlieg je daar dus maar maar is de lol er al snel van af.....
Hebben jullie enig idee waar dat door zou kunnen komen?
Alvast bedankt evt. en veel vliegplezier met deze MEESTERLIJKE SIM !!!! _/-\o_
Greetz,
Makadocias, P. O-)
  • kenneth
kenneth
achter de duinen
Stomme ATC, gewoon negeren. Lekker online met IVAO of VATSIM.
Moet ik zeggen, heb nog geen minuut online gevlogen :Y)
  • Ensinker
Ensinker
Blackhole schreef op 11 november 2003 @ 09:24:
Dat je de Porter niet gekocht hebt ipv deze :? die wou je toch zo graag hebben ??
  • ravw
ravw
Gilly schreef op 11 november 2003 @ 14:37:
Deze kwam ik plotseling tegen ... stond in een keer tussen mijn rijdje met planes ....
En die porter nog niet .... :/
Blackhole schreef op 11 november 2003 @ 14:47:
Zomaar in je rijtje met planes? :? Hoe hebbie dat gedaan dan? .CFG tweak?
  • ravw
ravw
Verwijderd schreef op 11 november 2003 @ 14:53:
???. cfg tweak ....... nee gewoon makkelijker installeren en klaar.
Want hij vliegt al vrij rond op het inet :) dus geen probleem.
Verwijderd schreef op 11 november 2003 @ 14:27:
Greetz,
Makadocias, P. O-)
Hangt van je route af... Als je een heel eind rechtuit over de oceaan gaat vliegen zul je niet vaak de ATC horen.
Check je de ATC berichten wel regelmatig (als je ze niet automatisch in beeld krijgt)? Soms moet je overschakelen naar een andere controller (dat zeggen ze dan) maar als je dan 'bye' zegt maar niet daadwerkelijk contact maakt met de nieuwe controller, ja, dan hoor je dus inderdaad helemaal niets meer.
O... ik lees nu net dat je wel wat hoort als je van je koers afwiijkt... Ja, dan zit je dus schijnbaart gewoon op een lang recht hihjway te vliegen...
De ATC leidt je overigens niet (altijd) rechtstreeks op de doel af: ze zorgen er voor dat je niet al te veel bochten hoeft te maken vlak voor de landing: dus dat je netjes recht op de landingsbaan afgaat. Het kan dus wel eens lijken dat ze je helemaal voorbij het vliegveld laten vliegen, maar da's dus dan om deze reden.
Mooi stukje over ATI kaarten...
http://www.webwereld.nl/column/03_45.phtml
Mooie titel ook... Boerenbedrog van ATI
  • DutchCommando
Verwijderd schreef op 11 november 2003 @ 16:55:
En dus nep:
Het wachten is dus op een nieuwe driver. Dat duurt "een paar weken, misschien een maand", aldus ATI's supportdesk, die vooral goed is in mensen aan het lijntje houden: dat was ruim acht maanden geleden.
De Radeon zit nog altijd in de doos. Het zou net zo goed een onderdeel uit een stofzuiger kunnen zijn. It sucks!
In die 8 maanden tijd zijn er al heel wat drivertjes uitgekomen :?
[ Voor 3% gewijzigd door DutchCommando op 11-11-2003 19:51 ]
  • Sleepie
Yep, en ik heb een Ati-kaart die het wel gewoon prima doet.
Ik heb ook een NVidia kaart gehad die het niet wilde doen om een of andere vage reden.
En zo zijn er vast verhaaltjes zat te vinden over wel en niet werkende spullen.
Zullen we die grafische kaarten "oorlog" lekker laten voor wat het is, en weer over vliegtuigen en FS gaan lullen ?? 8)
  • ravw
ravw
HAHA leuk stukje maar vul nu bij elke zin dat hij ATI zegt Nvidia in...
Wat wordt je dan wijzer uit dit stuk?
Helemaal niets.
1) Hij zegt duidelijk niet over welke kaart het gaat.
JA een ATI kaart,en een nieuwe.
Ja maar een nieuwe kan ook een R7200 als je hem in de winkel koopt.
Dus dit stukje is gewoon nergens op gebazeerd.
Want zelf ooit een Vodoo 2 kaart gekocht, was ook zo trots als een pauw.
Maar de lol was er snel vanaf , dit ding liep alleen maar in windows goed .
Maar zodra je een spel aan wilde sturen met dat ding was het zwart beeld.
( zelfde omschrijving als wat die man aangaf.)
Dus maar even een nieuwe gehaald.
En die deed het dus wel. ( en toen kon ik eindelijk Turok 1 spelen op mijn eigen PC )
Zo ook met een Intel kaartje heb ik het gehad.
Maar moet ik dan maar gelijk gaan lopen blaten dat de Creativelabs (Vodoo 2(3dfx)
slecht is ?
Nee...
Want mij Soundblasters heb ik er in al die jaren er maar 3 van gehad. en ze doen het nog alle 3 :)
Dus wel raar dat zo/n verhaal zo uit te hangen over ATI dat zegt meer wat over de persoon dan over ATI.
Blackhole schreef op 11 november 2003 @ 17:10:
Helemaal niets.
slecht is ?
Nee...
Leuk dat je er gewoon weer op ingaat.
Zegt meer over de persoon dan ATi.
  • ravw
ravw
Verwijderd schreef op 11 november 2003 @ 17:13:
Ach maar was niet de eerste, er er zijn er ook medere die het zo vinden dat dit een vaag stukje is ...... :)
Want wie zou nou zo iets over ATI willen posten.
:) maar oke zeg al niet meer . :X :X :X
  • Ensinker
Ensinker
Couple of days at max.
Johan
Phoenix Simulation Software
Afbeeldingslocatie: http://www.lagoonline.net/files/PRimages/MD/radio_stack_update.jpg
:P
[ Voor 53% gewijzigd door Ensinker op 11-11-2003 19:41 ]
o laatmaar , md80 natuurlijk
[ Voor 79% gewijzigd door Verwijderd op 11-11-2003 19:51 ]
  • ND863
ND863
Net als de A330/A340 zeker, couple of days a patch, en flyable zonder patch. Kan er weinig van geloven
Damn wat verlang ik terug naar FS2002 waar het wel goed werkt (addons), jammer dat FS2k2 grafisch zo tegenvalt als je net van FS9 afkomt :'(
bergen-copenhagen
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr000.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr002.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr007.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr008.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr009.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr011.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr016.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr026.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr030.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr036.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr041.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr047.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr059.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr062.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr069.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr070.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr074.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr076.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr079.jpg
Afbeeldingslocatie: http://bleij.demon.nl/stefan/ENBR-EKCH/fsscr080.jpg
  • Ensinker
Ensinker
ND schreef op 11 november 2003 @ 20:32:
Mijn post was in 2 delen :)
1 over de patch en 2 over de Lago Mad dog
@Deniem-G: Mooie pics, vooral die met die opkomende maan
Ik ben toevallig net ook op Copenhagen geland (heb je niet gezien trouwens :) ). Dit is volgens mij geen standaard scenery, toch?
  • McFlipp
  • Laatst online: 22-04-2023
McFlipp
24...
LOL! 8)7
Wat een enorme crap echt... |:( Heeft die gast nooit gehoord van een schone windows installatie als je een onderdeel aan je pc veranderd? Dat doe ik altijd, en als ik het niet doe heb ik altijd problemen (heb btw een nVidia kaart)!
En dan "in 8 maanden nog geen nieuwe driver". Wat een onzin echt... komen ongeveer om de 2 weken nieuwe drivers uit! En daar zitten maar weinig fixes in voor games die het niet deden, omdat die er al snel na de release van de Radeon 9700 Pro uit zijn gehaald, sindsdien zijn de belangrijkste dingen in de drivers, de snelheid en af en toe wordt er nog een klein probleempje opgelost...
Achja, het is net als met Intel en AMD, alle Vobis klanten denk dat Intel het beste is omdat ze die het beste kennen. En AMD is ook nog eens veel goedkoper, nouja dan zal die AMD wel slecht zijn, en trouwens de Intel heeft ook nog eens meer Mhz'en! Nou appeltje eitje voor die domme Vobis klant... Terwijl als ie zich erin verdiept er achter komt dat AMD een VEEL betere prijskwaliteit levert dan Intel.
Nouja iedereen mag wat mij betreft de oogkleppen ophouden, voor mij nooit meer een nVidia, deze GF4 Ti4200 is de laatste nVidia die ooit in mijn pc'tje zal zitten...
Mijn Airliners.net foto's
A bird in the hand is worth two in the bush - Aesop
Verwijderd schreef op 11 november 2003 @ 21:37:
Tnx, die airport is van http://www.swedflight.com/
oja waarschijnlijk heb je mij niet gezien omdat fs crashte 2 seconde voor de landing 8)7 >:)
[ Voor 13% gewijzigd door Verwijderd op 11-11-2003 21:46 ]
  • DutchCommando
McFlipp schreef op 11 november 2003 @ 21:42:
LOL! 8)7
Ik heb een PIV 2,26 Ghz en ben geen Vobis klant, hoe kan dat? Mag dat? (De pc is zelfbouw).
http://www.tweakers.net/gallery/sys/564
[ Voor 3% gewijzigd door DutchCommando op 11-11-2003 21:48 ]
  • rdluca
rdluca
Lang leve mijn ASUS V8420S ;)
Afbeeldingslocatie: http://home.hccnet.nl/r.luca/hgg49.jpg
LOL! 8)7
Na al het gezeik ben ik toch wel bij met mn 9700 :9
En mn pentium 2.4 van € 100 doet ook goed zn werk hoor...amd sucks ;)
[ Voor 86% gewijzigd door Verwijderd op 11-11-2003 21:55 ]
  • nealzie
  • Laatst online: 03-07-2024
Nvidia rules |:(
jongens jongens toch :P
maarre, ati is ook nog eens duurder :P want nu hoor ik flipp wel over de prijs-qualiteit verhouding bij amd en intel,m aar niet over nvidia en ati... dat verschil is er ook wel degelijk, en was bij mijn keuze ook een zeer grote factor...
  • McFlipp
McFlipp
24...
nealzie schreef op 11 november 2003 @ 22:11:
Nvidia rules |:(
Nou voor 2 tientjes meer dan die FX 5600 van jou heb je een Radeon 9600 Pro...
Kijk voor de gein nog eens in die Benchmark @ tomshardware van laatst... ;)
  • ND863
ND863
Gilly schreef op 11 november 2003 @ 21:31:
Oeps, sorry :P Ik zag PSS commentaar en een plaatje, maar de streepjes niet want ik wilde me al te gauw afreageren :7
Sorry Gil :>
* Nd zegt : *MODBREAK* HOUD NOU EENS OP MET DAT ONZINNIGE ATI VS NVIDIA GEDOE! :r nee ik ben gen mod, maar heb (had) zekers wel de aandacht right? :P Komop jongens ff serieus, dat ATI/VS gezeik heeft niets met FS of luchtvaart te maken en ik vind de discussie zowiezo al vrij doelloos. Je bent tevreden of niet, er zijn gebruikers die nvidia niets vinden, er zijn gebruikers die ati toppie vinden, er zijn gebruikers die ati brak vinden en er zijn tevreden nvidia gebruikers, punt uit. Dus ipv van zitten zeiken (wat in een ander forum hoort) kun je beter op vatsim gaan vliegen zodat het wat drukker is en ik mn ATC kan oefenen ofzo ;)
[ Voor 51% gewijzigd door ND863 op 11-11-2003 22:27 ]
  • Ensinker
Ensinker
ND schreef op 11 november 2003 @ 22:23:
Sorry Gil :>
*** & A340 roeleren
Wat moet ik zeggen ;)
  • ND863
ND863
Gilly schreef op 11 november 2003 @ 22:26:
*** & A340 roeleren
D'r staat toch ook niet dat de het de PSS **** & A340 ruleren.
Wat wil je lezen ;)
  • Sleepie
Helemaal mee eens Nofri !!
Maar zorg dan ook dat je online bent als controller 8)
  • ND863
ND863
FS2003 : Krijg je nou ook de hemeltextures van FS2004? (want dat vond ik wel beetje paint achtig in FS2k2 :7))
Sleepie : Tsja er zijn zo weinig piloten op momenten dat ik kan (maximaal 1,5 uur :() en dan heeft het ook niet zoveel zin om 2 uur te wachten. Ik wil wel Eurobook gebruiken, maar als mn inet er ens een keer uitligt ben ik de pineut :(
  • Ensinker
Ensinker
ND schreef op 11 november 2003 @ 23:01:
Geen idee, maar ik vind het wel een intressante optie ..
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/FS2003.jpg
  • Sleepie
Kweenie of deze al voorbij gekomen was :?
21 November aanstaande Milano Real Schedule Night
http://www.ellebi.org/luca/develop/realopsbook/
  • jos_zwa
  • Laatst online: 15-04-2019
jos_zwa
Flying Dutchman
mensen vraagje:
ik dacht dat je niet alleen met het mach nummer maar op met de grounspeed in knots je werkelijke snelheid in km/h kon bepalen:
Afbeeldingslocatie: http://server2.fs2002.com/uploaded_images/naamloos_8.JPG
ik vlieg hier 0.719 mach. dat is dus de 1 mach in km/h * 0.719 dus:
1235 km/h (mach 1) * 0.719 = 888 km/h afgrond.
dit zal ook wel kloppen denk ik maar nu wil ik van GS naar km/h
1 knot = 1.866 km/h dus:
GS = 401 knots * 1.866 = 748 km/h afgerond
een behoorlijk verschil lijkt me zo.. iemand ?
laat maar heb het al:
http://www.aerospaceweb.org/question/atmosphere/q0112.shtml
ik dacht dat mach 1 altijd 1235 km/h was op welke hoogte ook, wat dus niet zo is.
[ Voor 16% gewijzigd door jos_zwa op 12-11-2003 00:55 ]
Nikon D60 + AF-S DX 18-105mm G VR
  • Sleepie
1235 km/h = mach 1.0 geldt alleen op zeeniveau bij een bepaalde standaard luchtdruk.
Die moet je corrigeren naar de hoogte waarop je vliegt, en daar zal Mach 1.0 een heel andere snelheid zijn. En dan zou het verder moeten kloppen.
Uit deze link (die je zelf gaf :D )
haal je dat Mach 1.0 op 40000 ft (=40000 * 0.3048 = 12192 meter) staat voor 1062.3 km/hr
Dus op jouw plaatje 0.719 * 1062.3 = 764 km/hr
Voor zover ik weet moet je niet je GS maar je TAS beschouwen nu, die kan ik niet aflezen, maar gezien de winds die ik nog net kan zien is je TAS ongeveer 410 kts.
Dat wordt 410 * 1.853 = 760 km/hr
Niet echt veel verschil volgens mij.
[ Voor 58% gewijzigd door Sleepie op 12-11-2003 01:02 ]
  • kenneth
kenneth
achter de duinen
Ik dacht dat de nautische mijl was vastgelegd op 1852 meter, dus 1kt = 1,852 km/h
Ja, Pietje precies. Dit keer zelfs op de derde decimaal achter de komma 8)7
Je moet toch érgens over zeiken :Y)
  • davhor
  • Laatst online: 02-12-2025
davhor
www.fon.com
Een fotobijdrage van mij. Geschoten op Schiphol Rwy 06 in augustus.
Afbeeldingslocatie: http://www.davhor.com/vliegtuigen/1-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/2-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/3-200.jpg
Afbeeldingslocatie: http://www.davhor.com/vliegtuigen/4-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/5-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/6-200.jpg
Afbeeldingslocatie: http://www.davhor.com/vliegtuigen/7-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/8-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/9-200.jpg
Afbeeldingslocatie: http://www.davhor.com/vliegtuigen/10-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/11-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/12-200.jpg
Afbeeldingslocatie: http://www.davhor.com/vliegtuigen/13-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/14-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/15-200.jpg
Afbeeldingslocatie: http://www.davhor.com/vliegtuigen/16-200.jpgAfbeeldingslocatie: http://www.davhor.com/vliegtuigen/17-200.jpg
*edit even naar een ander servertje verplaatst / en dus toch rwy06
[ Voor 21% gewijzigd door davhor op 12-11-2003 13:01 ]
FON - WiFi for Everyone | Flickr
  • Jochem
^^^^ rwy 06 @ EHAM
[ Voor 50% gewijzigd door Jochem op 12-11-2003 12:22 ]
  • nealzie
heb jij die laatste transavia 757 op
2048xiets voor mij? :)
  • davhor
davhor
www.fon.com
Op verzoek en nog een van de transavia resolutie 2560X1920:
Transavia 1
Transavia 2
[ Voor 38% gewijzigd door davhor op 12-11-2003 13:46 ]
  • jos_zwa
jos_zwa
Flying Dutchman
davhor schreef op 12 november 2003 @ 13:12:
Transavia 1
Transavia 2
kun je dan please deze ook even groot posten ?
deze vind ik geweldig :D
