Heishamon <> Node Red voor Panasonic warmtepompen
Pagina: 1 ... 40 ... 136 Laatste
  • MikeyMan
  • Laatst online: 18:15
MikeyMan
Vidi, Vici, Veni
Log staat er nog wel:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
07/12 16:35:10 - SYSTEM: Start---------------------------------------------------------------
07/12 16:25:53 - Function SoftStart: Compressor Inactive - Correction: 0
07/12 16:25:53 - Compressor: stopped
07/12 16:25:48 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 16:25:48 - Function SoftStart: Correction: 7 > 0 °C - (STABLE) Freq: 34Hz, SP_Final: 25°C
07/12 16:24:13 - Function SoftStart: Correction: 6.5 > 7 °C - (CATCH) Freq: 35Hz, SP_Final: 32°C
07/12 16:24:08 - MQTT Command - SetZ1HeatRequestTemperature: 32
07/12 16:24:08 - Function SoftStart: Correction: 6.25 > 6.5 °C - (CATCH) Freq: 35Hz, SP_Final: 31.5°C
07/12 16:24:03 - Function SoftStart: Correction: 5.5 > 6.25 °C - (CATCH) Freq: 35Hz, SP_Final: 31.25°C
07/12 16:23:58 - MQTT Command - SetZ1HeatRequestTemperature: 31
07/12 16:23:58 - Function SoftStart: Correction: 4.75 > 5.5 °C - (CATCH) Freq: 35Hz, SP_Final: 30.5°C
07/12 16:23:53 - MQTT Command - SetZ1HeatRequestTemperature: 30
07/12 16:23:53 - Function SoftStart: Correction: 4 > 4.75 °C - (CATCH) Freq: 35Hz, SP_Final: 29.75°C
07/12 16:23:48 - MQTT Command - SetZ1HeatRequestTemperature: 29
07/12 16:23:48 - Function SoftStart: Correction: 2.75 > 4 °C - (CATCH) Freq: 35Hz, SP_Final: 29°C
07/12 16:23:43 - MQTT Command - SetZ1HeatRequestTemperature: 28
07/12 16:23:43 - Function SoftStart: Correction: 1.5 > 2.75 °C - (CATCH) Freq: 35Hz, SP_Final: 27.75°C
07/12 16:23:38 - MQTT Command - SetZ1HeatRequestTemperature: 27
07/12 16:23:38 - Function SoftStart: Correction: 0.25 > 1.5 °C - (CATCH) Freq: 34Hz, SP_Final: 26.5°C
07/12 16:23:33 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 16:23:33 - Function SoftStart: Correction: -1 > 0.25 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
07/12 16:23:28 - Function SoftStart: Correction: -1.25 > -1 °C - (CATCH) Freq: 34Hz, SP_Final: 24°C
07/12 16:23:28 - MQTT Command - SetZ1HeatRequestTemperature: 24
07/12 16:23:28 - Function SoftStart: Correction: -2 > -1.25 °C - (CATCH) Freq: 34Hz, SP_Final: 23.75°C
07/12 16:22:48 - MQTT Command - SetZ1HeatRequestTemperature: 23
07/12 16:22:48 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 19Hz, SP_Final: 23°C
07/12 16:22:48 - Compressor: is running now
07/12 16:21:23 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 16:21:23 - Function RTC: Correction change: From 1 to 0 °C (Room actual: 20.35 °C)
07/12 16:19:38 - Function SoftStart: Compressor Inactive - Correction: 0
07/12 16:19:38 - Compressor: stopped
07/12 16:19:30 - MQTT Command - SetZ1HeatRequestTemperature: 26
07/12 16:19:29 - Function SoftStart: Correction: 7 > 0 °C - (STABLE) Freq: 34Hz, SP_Final: 26°C
07/12 16:19:08 - Function SoftStart: Correction: 6.75 > 7 °C - (CATCH) Freq: 35Hz, SP_Final: 33°C
07/12 16:18:53 - Function SoftStart: Correction: 6.5 > 6.75 °C - (CATCH) Freq: 35Hz, SP_Final: 32.75°C
07/12 16:18:33 - MQTT Command - SetZ1HeatRequestTemperature: 33
07/12 16:18:33 - Function SoftStart: Correction: 6 > 6.5 °C - (CATCH) Freq: 35Hz, SP_Final: 32.5°C
07/12 16:18:18 - Function SoftStart: Correction: 5.5 > 6 °C - (CATCH) Freq: 35Hz, SP_Final: 32°C
07/12 16:18:13 - MQTT Command - SetZ1HeatRequestTemperature: 32
07/12 16:18:13 - Function SoftStart: Correction: 5.25 > 5.5 °C - (CATCH) Freq: 34Hz, SP_Final: 31.5°C
07/12 16:18:03 - Function SoftStart: Correction: 4.75 > 5.25 °C - (CATCH) Freq: 34Hz, SP_Final: 31.25°C
07/12 16:17:58 - Function SoftStart: Correction: 4.5 > 4.75 °C - (CATCH) Freq: 34Hz, SP_Final: 30.75°C
07/12 16:17:53 - MQTT Command - SetZ1HeatRequestTemperature: 31
07/12 16:17:53 - Function SoftStart: Correction: 4 > 4.5 °C - (CATCH) Freq: 34Hz, SP_Final: 30.5°C
07/12 16:17:48 - Function SoftStart: Correction: 3.75 > 4 °C - (CATCH) Freq: 35Hz, SP_Final: 30°C
07/12 16:17:48 - MQTT Command - SetZ1HeatRequestTemperature: 30
07/12 16:17:48 - Function SoftStart: Correction: 3.25 > 3.75 °C - (CATCH) Freq: 35Hz, SP_Final: 29.75°C
07/12 16:17:43 - Function SoftStart: Correction: 3 > 3.25 °C - (CATCH) Freq: 34Hz, SP_Final: 29.25°C
07/12 16:17:38 - Function SoftStart: Correction: 2.5 > 3 °C - (CATCH) Freq: 34Hz, SP_Final: 29°C
07/12 16:17:33 - MQTT Command - SetZ1HeatRequestTemperature: 29
07/12 16:17:33 - Function SoftStart: Correction: 1.75 > 2.5 °C - (CATCH) Freq: 34Hz, SP_Final: 28.5°C
07/12 16:17:28 - Function SoftStart: Correction: 1.5 > 1.75 °C - (CATCH) Freq: 34Hz, SP_Final: 27.75°C
07/12 16:17:24 - MQTT Command - SetZ1HeatRequestTemperature: 28
07/12 16:17:23 - Function SoftStart: Correction: 1 > 1.5 °C - (CATCH) Freq: 34Hz, SP_Final: 27.5°C
07/12 16:17:23 - MQTT Command - SetZ1HeatRequestTemperature: 27
07/12 16:17:23 - Function SoftStart: Correction: 0.25 > 1 °C - (CATCH) Freq: 34Hz, SP_Final: 27°C
07/12 16:17:18 - MQTT Command - SetZ1HeatRequestTemperature: 26
07/12 16:17:18 - Function SoftStart: Correction: -0.75 > 0.25 °C - (CATCH) Freq: 35Hz, SP_Final: 26.25°C
07/12 16:17:13 - Function SoftStart: Correction: -1.5 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
07/12 16:17:08 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 16:17:08 - Function SoftStart: Correction: -2 > -1.5 °C - (CATCH) Freq: 35Hz, SP_Final: 24.5°C
07/12 16:16:21 - MQTT Command - SetZ1HeatRequestTemperature: 24
07/12 16:16:21 - Function RTC: Correction change: From 2 to 1 °C (Room actual: 20.2 °C)
07/12 16:16:21 - SETUP - Sensors: Custom room temperature sensor FOUND and used
07/12 16:16:13 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 16:16:13 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 20Hz, SP_Final: 25°C
07/12 16:16:13 - Compressor: is running now
07/12 16:15:40 - MQTT Command - SetZ1HeatRequestTemperature: 27
07/12 16:15:40 - Function RTC: Correction change: From 0 to 2 °C (Room actual: 20 °C)
07/12 16:15:40 - Function - SoftStart Quietmode: OFF (restored to level 0)
07/12 16:15:40 - Function - SoftStart: 1
07/12 16:15:39 - Function - RTC: 1
07/12 16:15:34 - Function - WAR: 1
07/12 16:15:32 - SYSTEM - HEISHAMON Connection: Online
07/12 16:15:31 - SYSTEM: WAR settings OK
07/12 16:15:31 - SYSTEM: MQTT-Commands to HP will be send normally.
07/12 16:15:31 - Function Solar: 1
07/12 16:15:30 - Function NightReduction: 0
07/12 16:15:30 - RTC: Room setpoint changed to: 20.5 °C
07/12 16:15:30 - MQTT Command - SetHeatpump: 1
07/12 16:15:30 - Function NightReduction: New correction: -1 °C
07/12 16:15:30 - Function SoftStart: Compressor Inactive - Correction: 0
07/12 16:15:30 - Compressor: stopped
07/12 16:15:30 - SYSTEM: Heatpump is in DIRECT mode
07/12 16:15:30 - Function Pump speed: 0
07/12 16:15:30 - SYSTEM - HEISHAMON Connection: Offline
07/12 16:15:30 - SYSTEM: Start---------------------------------------------------------------
  • edterbak
  • Laatst online: 05-09 21:53
MikeyMan schreef op woensdag 7 december 2022 @ 16:50:
@edterbak sorry, lichte paniek, hij sloeg echt enorm op hol.
In bijvoorbeeld deze post:
edterbak in "Heishamon <> Node Red voor Panasonic warmtepompen"
verwijs je naar 21.21. Maar das niet helemaal correct, aangezien ie naar de branch verwijst.
Erop klikken geeft dus niet 21.21 ;)
Daarvoor moet je in de historie naar de commit van 5 december.
Wat inmiddels gelukt is, en de rust is weergekeerd.
Of het met de decimalen te maken heeft geen idee. Heb hem snel teruggezet, en nu loopt er weer een langere run.
Okay. sowieso is paniek niet nodig.
het vriest niet eens... :9
Wat je zegt over die linkjes klopt. De methode zal ook zo blijven. deep links naar exacte versies is m.i. te veel werk voor wat het waard is.
En na een paar klikjes kun je het zelf ook vinden, zoals je inmiddels ook hebt gedaan :) ruuustuuugg. :)
Technisch.
Nu je weer terug bent naar de vorige versie, zullen we ook niet kunnen ontdekken wat er mis is/was.
Ik ben zelf niet bezig geweest met softstart. Ik denk Maarten ook niet
Maar weet je zeker dat het geen defrost run was?
  • edterbak
@MikeyMan
Dank voor het log stukje. Leerzaam.
Het lijkt er op dat je "Max water temp. increase" op 0 heb/had staan. Klopt dat?
En ik zie dat je FW 3 gebruikt met de meerdere decimalen. Ook antwoord op die vraag nu :)
En het was geen defrost :) ook een antwoord uit het log. :)
[ Voor 4% gewijzigd door edterbak op 07-12-2022 17:00 ]
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Nee max water increase staat op 2 nu. Was idd geen defrost.
Kou maakte ik me ook niet zo''n zorgen over, maar hij leek in een soort loop te komen.
  • Aikon
edterbak schreef op woensdag 7 december 2022 @ 16:50:
@Aikon
Wat is je hardware die je hebt?
1 rpi over
1 ??? voor HA in gebruik?
Ik draai HA, incl NR dus, op een rpi4 4GB met een SSD.
Daarnaast heb ik een rpi zero 2 w met pi-hole, want die is cruciaal voor het netwerk met DNS en DHCP.
En ik heb zo'n zelfde rpi zero 2 w nog over.
En dan nog een nodemcu om m'n panelen uit te lezen, en 1 voor de watermeter en thermometer en wat shelly's.
En dat allemaal in 1 jaar bij elkaar geprutst :P Maar het smart home gebeuren is wel echt leuk.
  • edterbak
Amen _/-\o_ _/-\o_ _/-\o_ _/-\o_
  • edterbak
MikeyMan schreef op woensdag 7 december 2022 @ 17:05:
Als 'ie' echt 2 was, zou hij nooit naar 0 mogen terug vallen. correctie van 7>0.
Maar je hebt een T-CAP toch?
Veel vermogen dat hij er in het begin in blijft duwen. :O
De softstart functie heeft 2 fasen. Te noemen: "Fase 1" en "Fase 2" 8)7 8)7
Fase 1 is nu fixed op 180 seconden. (aka 3 minuten)
Misschien dat ik die 180 seconden uit de code en in het dashboard kan presenteren?
IK heb het gevoel dat die T-CAPs een langere aanlooptijd nodig hebben.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
@edterbak ja heb een tcap. Maar dit gedrag heb ik nooit gezien zo. Is ook niet nodig, heb ruim 200m2 vloerverwarming liggen. ;)
Nu terug naar 21.21 draait ie ook alweer netjes 40 minuten zonder problemen. Runs zijn vandaag grotendeels langer dan drie uur geweest.
Dus ja wellicht kan het beter, maar er gebeurde nu iets geks.
[ Voor 10% gewijzigd door MikeyMan op 07-12-2022 17:18 ]
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
SYSTEM
Flow version
21.21 beta (experimental)
07/12 17:05:38 - MQTT Command - SetZ1HeatRequestTemperature: 26
07/12 17:05:38 - Function SoftStart: Correction: 2 > 0 °C - (ENDING) Freq: 34Hz, Tout: 29°C
07/12 17:01:12 - Scheduler - Operation Mode: 2
07/12 17:00:12 - MQTT Command - SetOperationMode: 2
07/12 17:00:12 - Scheduler - Operation Mode: 2
07/12 16:49:33 - MQTT Command - SetZ1HeatRequestTemperature: 28
07/12 16:49:33 - Function SoftStart: Correction: 1 > 2 °C - (STABLE) Freq: 35Hz, Tout: 28°C
07/12 16:43:53 - MQTT Command - SetZ1HeatRequestTemperature: 27
07/12 16:43:53 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 35Hz, Tout: 27°C
07/12 16:38:48 - MQTT Command - SetZ1HeatRequestTemperature: 26
07/12 16:38:48 - Function SoftStart: Correction: -1 > 0 °C - (STABLE) Freq: 34Hz, Tout: 26°C
07/12 16:36:31 - Function SoftStart: Correction: -2 > -1 °C - (CATCH) Freq: 34Hz, Tout: 26°C
07/12 16:36:31 - Function RTC: Correction change: From 2 to 1 °C (Room actual: 20.2 °C)
07/12 16:36:31 - SETUP - Sensors: Custom room temperature sensor FOUND and used
07/12 16:35:38 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 16:35:38 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 18Hz, Tout: 21°C
07/12 16:35:38 - MQTT Command - SetMaxPumpDuty: 150
07/12 16:35:38 - Compressor: is running now
07/12 16:35:38 - Function Pumpspeed: Pumpspeed restored to: 150
07/12 16:35:20 - MQTT Command - SetZ1HeatRequestTemperature: 27
07/12 16:35:20 - Function RTC: Correction change: From 0 to 2 °C (Room actual: 20 °C)
07/12 16:35:19 - Function - SoftStart Quietmode: OFF (restored to level 0)
07/12 16:35:19 - Function - SoftStart: 1
07/12 16:35:19 - Function - RTC: 1
07/12 16:35:14 - Function - WAR: 1
07/12 16:35:13 - SYSTEM - HEISHAMON Connection: Online
07/12 16:35:11 - SYSTEM: WAR settings OK
07/12 16:35:11 - SYSTEM: MQTT-Commands to HP will be send normally.
07/12 16:35:10 - Function Solar: 1
07/12 16:35:10 - Function NightReduction: 0
07/12 16:35:10 - RTC: Room setpoint changed to: 20.5 °C
07/12 16:35:10 - MQTT Command - SetHeatpump: 1
07/12 16:35:10 - Function NightReduction: New correction: -1 °C
07/12 16:35:10 - Function SoftStart: Compressor Inactive - Correction: 0
07/12 16:35:10 - Compressor: stopped
07/12 16:35:10 - SYSTEM: Heatpump is in DIRECT mode
07/12 16:35:10 - SYSTEM - HEISHAMON Connection: Offline
Dit is na de downgrade.
  • Maarten69
  • Registratie: Augustus 2022
@MikeyMan Wat vreemd dat jij korte runs krijgt met deze versie. Zou het niet aan iets anders kunnen liggen?
8680 Wp, Panasonic Mono-bloc J-Generation WH-MDC07J3E5 1-fase 7kW. Heishamon v3.2.3 , NRflow *custom* , Home Assistant + " kamaradclimber / heishamon-homeassistant", Kaifa MA105 + Shelly PRo 3EM (120A), 3x Marstek 5,12kW v151, lilygo-modbus-485 HA
  • edterbak
@Maarten69
Het valt mij op dat @MikeyMan in de laatste flow 20x een temperatuurmeting (in 3 minuten) in het logboek ziet verschijnen, tegenover 2 in de oude flow.
(ter info dit) ik zit hardop te denken wat het kan zijn.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 17:51:
Uitgesloten. Er is direct vergelijk met de .21 versie.
Wat het precies is, geen idee. De logs geven mij niet direct een eureka moment
  • edterbak
Wat we kunnen doen is deze functie gebruiken om de getallen naar beneden af te ronden
Math.floor(x)
22.00 > 22
22.25 > 22
22.50 > 22
22.75 > 22
Zo is het aantal triggers een stuk lager.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
@edterbak zie ik goed dat de softstart correctie in de .24 log tot 7 graden ging? In de oude zie ik maar 2 graden.
7 graden is veel te veel. Das van 25 naar 32. Dan moet de pump flow echt heel ver omhoog.
En het is meer dan ingesteld ook.
[ Voor 49% gewijzigd door MikeyMan op 07-12-2022 18:01 ]
  • edterbak
Leuk om te zien dat bij 28.5 >> hup 29 afgerond wordt en SP verhoogd wordt. :)
Het zou het aantal metingen kunnen zijn. ( is everedig met het aantal herbepalingen van de functie)
[ Voor 32% gewijzigd door edterbak op 07-12-2022 18:01 ]
  • edterbak
MikeyMan schreef op woensdag 7 december 2022 @ 17:59:
Ja, heb ik aangepast op wat geluiden hier met +1.
Maar hoort geen significant effect te hebben. Niet het probleem waar we het nu zojuist over hebben.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
edterbak schreef op woensdag 7 december 2022 @ 18:02:
7 graden is echt enorm. Niet gek dat ie afslaat.
  • edterbak
@MikeyMan
Het was 6. nu 7.
Het is niet de oorzaak van wat we hier zien.
Dit getal wordt alleen gehanteerd als max in de 1e 3 minuten.
  • edterbak
Dude...
  • edterbak
  • Maarten69
@MikeyMan Het log toont niet de reden van afslaan, dat doet de Pana ook zelf.
Kan het zijn dat je Tinlet te snel oploopt tijdens een start?
als Final SP gelijk is aan Tinlet gaat de compressor namelijk uit.
  • Maarten69
Volgende keer ook gewoon zelf je flow exporteren t.b.v. backup, wel zo verstandig als je tegen problemen aanloopt denk ik.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 18:05:
Ik ben er vrij zeker van dat die softstart correctie de oorzaak is van de korte runs. Als ik verder terug scroll zie ik nooit hoger dan 2 graden.
Vraag is dan vervolgens wel hoe het komt dat ie nu tot 7 graden gaat. Misschien toch door de interval.
Zal zo ff Ta en Tr grafieken erbij zoeken.
  • Maarten69
De SoftStart mag in de opstartfase (180 sec) corrigeren tot +7 dit om juist te voorkomen dat hij uitvalt.
Toch @edterbak
  • edterbak
Eerst bereikte je niet eens de 6 graden. Slechts 2. Ddus ook 7 had geen probleem geweest in de code.
Die 6(of7) heb ik ingebouwd is er voor als je NET uit een dhw run komt.
Dan is het water in de pomp en leidingen nog 50+ graden.
Als dan de logica van Setpoint is T aanvoer -2 graden vast houd, dan gaat hij gelijk aan zodat de overburen wakker worden.
Dat is de reden geweest dat ik een temp als bovengrens in het begin heb gezet.
Nu had ik ooit in het begin 5C.
Dit bleek niet voldoende omdat die TCAPs te veel en te lang warmte in het water blijven duwen, dat die 5C te laag was.
tcap bracht een dT aan van meer dan 6 graden, zodat de temperatuur te hoog wordt uitgaand tov setpoint en er een intern STOP signaal komt.
Dat is de reden dat ik de 5, naar 6, naar 7 laat kruipen.
  • edterbak
Maarten69 schreef op woensdag 7 december 2022 @ 18:11:
Toch @edterbak
ja exact. zie boven
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
edterbak schreef op woensdag 7 december 2022 @ 18:13:
Nee, maar blijkbaar was dat ook niet nodig. Heb er runs van 480 minuten op zitten gisteren ;)
Sterker nog, de huidige run draait nog, nu 100 minuten.
Maar wellicht begrijp ik niet helemaal wat je bedoelt…?
Mijn vraag is, waarom gaat .24 wel >2 graden en .21 niet?
[ Voor 22% gewijzigd door MikeyMan op 07-12-2022 18:16 ]
  • edterbak
Ik 'mag' eten maken.
straks meer hier over :)
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Wat een topper, ook nog eten maken! Heb je daar nog geen NR flow voor geknutseld? :+
Deel van de paniek werd ook veroorzaakt door een baby die al de hele dag uit z'n hum is. Dacht even vijf minuten te hebben voor de update, maar die was er dus niet...
Goed, stukje achtergrond dan. De temperaturen tussen 16:00 en 17:00:
Afbeeldingslocatie: https://tweakers.net/i/38Zb_CgPfELGSRzP3c9GarlUWJo=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/pYv5Yzu3NaFHAPcwM3VSla3c.png?f=user_large
Influxdb ziet er iets beter uit, maar ben ik niet goed in:
Afbeeldingslocatie: https://tweakers.net/i/Hdh-aTBzEBrWu5CzRX1xlnBd8-o=/800x/filters:strip_exif()/f/image/ySxU4sgtf88xaBHiLZzTQ9il.png?f=fotoalbum_large
Lijkt erop dat we hier de oorzaak hebben:
Afbeeldingslocatie: https://tweakers.net/i/KUkWSiYRAmKBLanz62vbNvaN9FY=/800x/filters:strip_exif()/f/image/fu4bnUPdHofiVYldnRGkqn9A.png?f=fotoalbum_large
pump flow werd niet snel genoeg opgehoogd denk ik?
Kan kloppen, want ik had de losse flow uitgezet...
Zal 21.24 weer installeren, maar nu met de losse flow aan.
@Maarten69 als je me dan kunt vertellen waar ik de instellingen van de ingebouwde pumpflow verlaging kan vinden?
[ Voor 59% gewijzigd door MikeyMan op 07-12-2022 19:48 ]
  • weert14
  • Laatst online: 16:55
Goedenavond,
Ik heb de RTC functie aan gezet. Gebruik een Zigbee thermometer die nu 21.8 graden meet. Ik zou verwachten dat die nu -1 zou doen omdat de setpoint 21.6 staat ingesteld?
Afbeeldingslocatie: https://tweakers.net/i/lUz1FCar6gQRhIDkUW2Kt7waEx0=/x800/filters:strip_exif()/f/image/L1sCTPhiuOWAx1ZCFgZ33IbU.png?f=fotoalbum_large
  • sjampeter
  • Registratie: November 2021
  • Laatst online: 10-09 13:56
zet hem eens op 0.1 ipv 0.2?
  • weert14
Dan schiet die idd wel op -1
Als ik hem vervolgens weer op 0.2 zet, schiet die weer naar 0
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Lijkt goed te gaan, maar run liep nog... Fingers crossed!
Ben benieuwd wat de volgende start voor SS correction laat zien...
[ Voor 87% gewijzigd door MikeyMan op 07-12-2022 19:59 ]
  • Aikon
Maarten69 schreef op woensdag 7 december 2022 @ 09:56:
Vraagje @edterbak als de room temp < rtc_on gaat de WP pas aan:
function node Function RTC on / off
        //      Scenario 2: the roomtemperature is low enough again. Function end
        if (rtc_dT < rtc_on)
Zou je voor de on/off check niet beter kunnen controleren met <= en >=
Nu gaat WP pas aan beneden die drempel en uit boven die drempel, of is dat wenselijk en zoals bedoeld?
EDIT: Nevermind, beschrijving noemt het ook zo (bedankt @MikeyMan )
Goede timing @weert14
Het is op zich hetzelfde als wat @Maarten69 hier aangeeft. Het is nu zo dat je bij meer dan die 0.2graad verschil +1 krijgt, dus niet bij 0.2 precies, maar bij 0.3 graad verschil.
Ik denk dat ik jouw denkwijze ook logischer vindt, maar goed, als je het weet maakt het niet uit natuurlijk :)
  • sjampeter
mij lijkt ook dat hij bij exact de ingestelde waarde moet schakelen. +1 voor Aikon. (niet afgerond _O- )
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
@Maarten69 ik heb wel een log regel gevonden voor de pomp functie:
07/12 19:57:24 - Function Pump speed: 0
Maar waar ik de functie aan zet heb ik nog niet gevonden :?
@Aikon @weert14 @sjampeter Er staat hier inderdaad niet op het scherm of je een > of >= kunt verwachten.
Maar denk dat dat sowieso wel beter zou kunnen.
More than 0.5 too warm sets -3...
Maarja, zet dat maar eens netjes op het scherm ;)
[ Voor 18% gewijzigd door MikeyMan op 07-12-2022 20:08 ]
  • edterbak
MikeyMan schreef op woensdag 7 december 2022 @ 18:14:
Cest le question du jambon..
  • Aikon
@MikeyMan Nah ja, er staat 'too warm' en dan 0.1. En dan een bijbehorende waarde. Dat is an sich gewoon duidelijk ;) Dus 0.1 te warm dan +1. Alleen er gebeurd wat anders, maar ik weet niet of daar een (NR?) logica achter zit?
  • Aikon
edterbak schreef op woensdag 7 december 2022 @ 20:11:
Het probleem speelt sinds .22 toch?
[2022-12-06] v21.22 beta (experimental). Changes:
[FIX] 4th RTC threshold was not calculated correctly after previous update (always +10)
[NEW] New function Reduce pump speed added to System Health (temporary location)
[NEW] Flow can now handle quarter water temperatures from inlet and outlet.
Alleen @MikeyMan heeft het probleem, en alleen hij gebruikt de reduce pump speed toch? Dus @MikeyMan : speelt het probleem ook als je reduce pump speed uitzet?
Wellicht heb ik wat gemist hoor, maar even logisch benaderd :)
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Aikon schreef op woensdag 7 december 2022 @ 20:16:
Ja zie boven ;)
Ah, system health dus :P
  • edterbak
Aikon schreef op woensdag 7 december 2022 @ 20:13:
Okay. Dat is een kwestie van typisch geval definitie duidelijk op noteren.
Doe maar een voorstel.
[ Voor 3% gewijzigd door edterbak op 07-12-2022 20:18 ]
  • Aikon
edterbak schreef op woensdag 7 december 2022 @ 20:17:
Volgens mij idd > veranderen naar =>. Ik krijg de indruk dat de meeste dat als meest logisch ervaren.
  • edterbak
Er zijn nog meer variabelen onder de motorkap.
Fw 3
2 decimalen
Vraag is of mikeyman en test voor ons wil doen. Ik heb een idee om dit te debunken..
  • Aikon
edterbak schreef op woensdag 7 december 2022 @ 20:21:
Fw 3
2 decimalen
Ja uiteraard, maar die 2 variabele zijn minder verdacht, want die gebruikt iedereen automatisch al ;) En er zijn vast wat andere wijzigingen, en het kan natuurlijk ook gewoon buiten NR liggen.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Fw 3
2 decimalen
Jahoor... Kleine ligt nu voor het eerst vandaag te slapen :P
Maar pumpspeed leek inderdaad de boosdoener te zijn.
Overigens lijkt het er wel op dat met 21.24 zowel de losse pumpspeed-flow als de ingebouwde niet werken, maar tis nog te vroeg om daar helemaal zeker van te zijn.'
Sterker nog, de instellingen voor de pumpspeed op system health lijken helemaal niet door te komen O-)
en de logs bevatten een tikfout:
07/12 20:20:25 - SYSTEM: MQTT-Commands to HP will be send normally.
[ Voor 11% gewijzigd door MikeyMan op 07-12-2022 20:27 ]
  • sjampeter
Aikon schreef op woensdag 7 december 2022 @ 20:19:
lijkt mij ook
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Nog een opmaak dingetje:
Afbeeldingslocatie: https://tweakers.net/i/aTvopVEit4APWuh32j_kvjYPUcE=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/c1Eug4eLKgutl5AgwsHpjPoj.png?f=user_large
Lijkt mij netter om dit altijd met dezelfde aantallen decimalen te tonen.
  • -SimJoc-
Ik zie tot mijn schrik dat ik nog helemaal niet in dit topic hebt gereageerd. Ik heb nu inmiddels een kleine maand node red en de plugin geïnstalleerd en het werkt echt fantastisch. Voorheen liet ik Loxone alles regelen, maar dit werkt toch echt beter.
Keep up the good work! :)
  • Maarten69
-SimJoc- schreef op woensdag 7 december 2022 @ 21:11:
Dit soort berichten zijn altijd fijn, bedankt.
@MikeyMan Je hebt wel gelijk hoor met die opmaak, dat komt vast goed bij afwerken.
Pump speed staat inderdaad (tijdelijk) onder System Health.
Waarom denk je dat hij trager is dan oude functie? Heb hier met 3 runs getest en reageerd direct als de compressor freq > 0 Hz is.
Kan zijn dat de Heishamon te laat die waarden doorgeeft via MQTT, maar dan had je dat eerder ook moeten hebben...
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 21:28:
Nee dat was mijn eerste gedachte.
Maar, omdat die functie er nu standaard in zit had ik de custom functie uit gezet.
En kon hem niet vinden, dus hij heeft nooit aan gestaan. Pomp stond daardoor nog op 7L/min, dus kon zijn warmte niet kwijt.
Echter, ik krijg nu geen enkele reactie van de functie op health tab lijkt het. Heb de settings al verwijderd maar no luck.
Hij reageert wel direct op de instelling op het settings tabblad.
Heb nog geprobeerd om de custom functie weer aan te zetten, maar dat doet ook niets meer lijkt het. Verschijnt ook niets in de logs.
Compressor staat nu uit maar waterpomp staat nog op 30l/min
[ Voor 12% gewijzigd door MikeyMan op 07-12-2022 21:38 ]
  • Maarten69
Het is alleen instellen van lowspeed en dan schakelaar om zetten. Na circa 10/20 seconden zou je in log moeten zien dat lowspeed ingesteld word. (beide logs) indien compressor nu uit is.
Werkt dat bij jou niet?
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 21:51:
Nope... Niks...
Heb alles al hoger en lager, aan en uit gezet.
Linker waarde loopt wel mee met de instelling voor hoog. Maar de algemene setting wordt niet gezet.
Compressor is nu uit, maar de high setting wordt ook niet meegenomen.
Maar het losse flowtje werkt ook niet meer nu.
[ Voor 10% gewijzigd door MikeyMan op 07-12-2022 21:56 ]
  • Maarten69
Dat de setting niet aangepast wordt op dasboard setting ben ik nu even niet zeker van, dacht wel dat ik daar een link-out naar toe bracht, maar even niet zeker.
Maar het log moet het gewoon tonen, dat heb ik goed getest. (vond ik dan ;) )
Zit je dan weer terug op 21.24 nu?
[ Voor 6% gewijzigd door Maarten69 op 07-12-2022 22:05 ]
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 22:05:
Yup... 21.24 nu...
Gebeurt precies niks :)
  • Maarten69
Ik ga morgen meteen checken, zit nog op werk nu.
EDIT: lees net je log nog eens door, daar stond de functie helaas nog uit dus dat zegt daar nog niets.
Als je switch aan zet zie je toch wel in log (main-log) Function Pump speed: 1 ?
[ Voor 66% gewijzigd door Maarten69 op 07-12-2022 22:18 ]
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 22:16:
Nope, helemaal niks...
Net heel node red opnieuw opgestart voor de zekerheid.
Dit is de log tot nut toe.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
SYSTEM
Flow version
21.24 beta (experimental)
07/12 22:21:21 - MQTT Command - SetMaxPumpDuty: 150
07/12 22:20:42 - MQTT Command - SetZ1HeatRequestTemperature: 24
07/12 22:20:42 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 33Hz, SP_Final: 24°C
07/12 22:20:11 - MQTT Command - SetZ1HeatRequestTemperature: 23
07/12 22:20:11 - Function RTC: Correction change: From 0 to -2 °C (Room actual: 20.5 °C)
07/12 22:20:11 - SETUP - Sensors: Custom room temperature sensor FOUND and used
07/12 22:18:42 - Function SoftStart: Correction: -0.25 > 0 °C - (STABLE) Freq: 35Hz, SP_Final: 25°C
07/12 22:16:22 - Function SoftStart: Correction: -0.5 > -0.25 °C - (CATCH) Freq: 35Hz, SP_Final: 24.75°C
07/12 22:16:07 - MQTT Command - SetZ1HeatRequestTemperature: 25
07/12 22:16:07 - Function SoftStart: Correction: -1 > -0.5 °C - (CATCH) Freq: 35Hz, SP_Final: 24.5°C
07/12 22:16:02 - MQTT Command - SetZ1HeatRequestTemperature: 24
07/12 22:16:02 - Function SoftStart: Correction: -1.75 > -1 °C - (CATCH) Freq: 35Hz, SP_Final: 24°C
07/12 22:15:57 - Function SoftStart: Correction: -2 > -1.75 °C - (CATCH) Freq: 34Hz, SP_Final: 23.25°C
07/12 22:15:45 - Function - SoftStart Quietmode: OFF (restored to level 0)
07/12 22:15:45 - Function - SoftStart: 1
07/12 22:15:45 - Function - RTC: 1
07/12 22:15:42 - MQTT Command - SetZ1HeatRequestTemperature: 23
07/12 22:15:39 - MQTT Command - SetDHWTemp: 48
07/12 22:15:39 - MQTT Command - SetZ1HeatRequestTemperature: -2
07/12 22:15:39 - Function - WAR: 0
07/12 22:15:39 - Function - Calculate new SP: New final T shift calculated: Current T shift: 0 °C. New calculated T shift: -2 °C
07/12 22:15:39 - Function SoftStart: Correction: n/a > -2 °C - (STARTUP) Freq: 28Hz, SP_Final: 23°C
07/12 22:15:39 - Function WAR: RoomThermostat found or using Compensation curve. Using internal Panasonic WAR function. NodeRed WAR function is now disabled
07/12 22:15:37 - SYSTEM: WAR settings OK
07/12 22:15:36 - SYSTEM: MQTT-Commands to HP will be send normally.
07/12 22:15:36 - Function Solar: 1
07/12 22:15:36 - Function NightReduction: New correction: -1 °C
07/12 22:15:36 - Function NightReduction: 0
07/12 22:15:36 - RTC: Room setpoint changed to: 20 °C
07/12 22:15:36 - MQTT Command - SetZ1HeatRequestTemperature: NaN
07/12 22:15:36 - MQTT Command - SetHeatpump: 1
07/12 22:15:36 - Function - WAR: 1
07/12 22:15:36 - Compressor: is running now
07/12 22:15:36 - SYSTEM: Heatpump is in DIRECT mode
07/12 22:15:37 - SYSTEM - HEISHAMON Connection: Online
07/12 22:15:36 - SYSTEM - HEISHAMON Connection: Offline
07/12 22:15:36 - SYSTEM: Start
Laatste commando is vanaf settings page gedaan.
[ Voor 8% gewijzigd door MikeyMan op 07-12-2022 22:24 ]
  • edterbak
Leuk te lezen. Thanks
  • Maarten69
MikeyMan schreef op woensdag 7 december 2022 @ 22:20:
Mis bij jou al bij start deze in log: (Function Pump speed: 0)
07/12 12:51:56 - Compressor: stopped
07/12 12:51:56 - SYSTEM: MQTT-Commands to HP will be send normally.
07/12 12:51:56 - SYSTEM: Heatpump is in DIRECT mode
07/12 12:51:56 - Function NightReduction: 0
07/12 12:51:56 - Function Pump speed: 0
07/12 12:51:56 - RTC: Room setpoint changed to: 20.6 °C
07/12 12:51:56 - SYSTEM - HEISHAMON Connection: Offline
07/12 12:51:55 - SYSTEM: Start---------------------------------------------------------------
Net even aan/uit gezet (compressor loopt):
07/12 23:02:51 - MQTT Command - SetMaxPumpDuty: 142
07/12 23:02:51 - Function Pump speed: 1
  • Maarten69
Wie met v21.24 kan even testen of Reduce pump speed werkt?
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 23:12:
Heb net weer eens de pumpspeed context values verwijderd. Hielp helaas niet.
Zou de downgrade iets geblokkeerd kunnen hebben?
Kan ik nog andere context values proberen te verwijderen?
  • Maarten69
Je zou deze allemaal kunnen wissen en daarna een flow herstart kunnen doen:
ReducePumpSpeed
SavedPumpspeed
LowSpeed
en controleren of de context var PumpMaxFlowSetting wel jouw pompsnelheid bevat.
verder zie ik nu niet wat fout kan gaan.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Maarten69 schreef op woensdag 7 december 2022 @ 23:22:
ReducePumpSpeed
SavedPumpspeed
LowSpeed
Already done... Kreeg toen NAN op tab.
Wijzigen van settings verhielp dat, maar log blijft leeg.
  • Maarten69
en waarde van PumpMaxFlowSetting?
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Yup
Deze volgt vervolgens netjes de instelling.
  • Maarten69
Zal morgen verder kijken, iets te moe nu. Komt goed.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
@Maarten69 zit ff naar de flows te kijken, ik zie dat de losse oude flow getriggerd wordt door TOP8.
En de nieuwe een @boot input heeft en daarna elke 30 minuten?
Aan de normal speed zit inderdaad wel een link out naar link in 9 op dashboard.
Gekke is dat ik deze nodes:
Afbeeldingslocatie: https://tweakers.net/i/-eVcIi3-hxOjUqiF5OMLFuq2T9g=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/oipr5AfQp91LGoi9uof7Slmv.png?f=user_large
Wel zie reageren op de input. Er lijkt daarna alleen niets te gebeuren?
Iets met de block node?
[ Voor 77% gewijzigd door MikeyMan op 08-12-2022 09:12 ]
  • Maarten69
Goedemorgen.
@MikeyMan
Deze functie wordt net zo goed getriggerd door TOP8.
Die at boot, gebeurd bij startup op de waarden te controleren en zetten indien nodig.
Hier mijn hele log vanaf gisteravond.
Tijdens een defrost wordt de pompsnelhied nu niet meer verlaagd.
Ook zie je veel SoftStart correcties, maar worden niet onnodig verstuurd.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
08/12 09:13:40 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 09:13:40 - Function SoftStart: Correction: 1 > 0 °C - (ENDING) Freq: 54Hz, SP_Final: 29°C
08/12 09:13:00 - Function SoftStart: Correction: 0.5 > 1 °C - (STABLE) Freq: 53Hz, SP_Final: 30°C
08/12 09:12:50 - Function SoftStart: Correction: 1 > 0.5 °C - (STABLE) Freq: 53Hz, SP_Final: 29.5°C
08/12 09:12:40 - Function SoftStart: Correction: 0.5 > 1 °C - (STABLE) Freq: 53Hz, SP_Final: 30°C
08/12 09:10:30 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 53Hz, SP_Final: 29.5°C
08/12 09:10:19 - Function RTC: Operation mode 0 (Heat only)
08/12 09:10:11 - Function SoftStart: Correction: 0.5 > 0.25 °C - (STABLE) Freq: 54Hz, SP_Final: 29.25°C
08/12 09:10:10 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 09:10:10 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 53Hz, SP_Final: 29.5°C
08/12 09:08:20 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 53Hz, SP_Final: 29.25°C
08/12 09:08:10 - Function SoftStart: Correction: 0.25 > -0.25 °C - (STABLE) Freq: 54Hz, SP_Final: 28.75°C
08/12 09:08:00 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 54Hz, SP_Final: 29.25°C
08/12 09:06:30 - Function SoftStart: Correction: -0.5 > -0.25 °C - (STABLE) Freq: 54Hz, SP_Final: 28.75°C
08/12 09:04:50 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 53Hz, SP_Final: 28.5°C
08/12 09:04:41 - Function SoftStart: Correction: -0.5 > -1 °C - (STABLE) Freq: 54Hz, SP_Final: 28°C
08/12 09:04:40 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 09:04:40 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 54Hz, SP_Final: 28.5°C
08/12 09:02:30 - Function SoftStart: Correction: -1.25 > -1 °C - (STABLE) Freq: 54Hz, SP_Final: 28°C
08/12 09:02:00 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 09:02:00 - Function SoftStart: Correction: -1.75 > -1.25 °C - (STABLE) Freq: 53Hz, SP_Final: 27.75°C
08/12 09:01:10 - Function SoftStart: Correction: -2 > -1.75 °C - (STABLE) Freq: 54Hz, SP_Final: 27.25°C
08/12 09:00:30 - Function SoftStart: Correction: -2.5 > -2 °C - (STABLE) Freq: 54Hz, SP_Final: 27°C
08/12 08:59:00 - Function SoftStart: Correction: -2 > -2.5 °C - (STABLE) Freq: 54Hz, SP_Final: 26.5°C
08/12 08:58:40 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 08:58:40 - Function SoftStart: Correction: -1.25 > -2 °C - (STABLE) Freq: 53Hz, SP_Final: 27°C
08/12 08:58:30 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 08:58:30 - Function SoftStart: Correction: -0.5 > -1.25 °C - (STABLE) Freq: 54Hz, SP_Final: 27.75°C
08/12 08:58:20 - Function SoftStart: Correction: 0 > -0.5 °C - (STABLE) Freq: 54Hz, SP_Final: 28.5°C
08/12 08:57:10 - Function SoftStart: Correction: -0.25 > 0 °C - (STABLE) Freq: 68Hz, SP_Final: 29°C
08/12 08:57:00 - Function SoftStart: Correction: -0.5 > -0.25 °C - (STABLE) Freq: 68Hz, SP_Final: 28.75°C
08/12 08:56:50 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 08:56:50 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 68Hz, SP_Final: 28.5°C
08/12 08:56:40 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 08:56:40 - Function SoftStart: Correction: -2 > -1 °C - (STABLE) Freq: 68Hz, SP_Final: 28°C
08/12 08:53:40 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 08:53:40 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 30Hz, SP_Final: 27°C
08/12 08:53:40 - MQTT Command - SetMaxPumpDuty: 142
08/12 08:53:40 - Compressor: is running now
08/12 08:53:40 - Function Pump speed: restored to: 142 (41%)
08/12 08:50:10 - MQTT Command - SetHeatpump: 1
08/12 08:50:10 - CONTROLLER: Manual ON detected on wallmounted unit
08/12 08:50:01 - MQTT Command - SetHeatpump: 1
08/12 08:50:01 - Function RTC: on/off - Turn on power (Room temp: 20.2°C)
08/12 08:01:13 - Scheduler - Quiet Mode: 0
08/12 08:00:13 - MQTT Command - SetQuietMode: 0
08/12 08:00:13 - Scheduler - Quiet Mode: 0
08/12 07:01:13 - Scheduler - Quiet Mode: 1
08/12 07:00:13 - MQTT Command - SetQuietMode: 1
08/12 07:00:13 - Scheduler - Quiet Mode: 1
08/12 06:50:08 - MQTT Command - SetHeatpump: 0
08/12 06:50:08 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 06:50:08 - MQTT Command - SetMaxPumpDuty: 100
08/12 06:50:08 - CONTROLLER: Manual OFF detected on wallmounted unit - Default action used: Unrestricted
08/12 06:50:08 - Compressor: stopped
08/12 06:50:08 - Function Pump speed: reduced to 100 (19%)
08/12 06:49:58 - MQTT Command - SetHeatpump: 0
08/12 06:49:58 - Function RTC: on/off activated - Turn off power (Room temp: 20.7°C)
08/12 06:14:48 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 06:14:48 - Function SoftStart: Correction: 1 > 0 °C - (ENDING) Freq: 45Hz, SP_Final: 29°C
08/12 06:11:08 - Function SoftStart: Correction: 0.5 > 1 °C - (STABLE) Freq: 45Hz, SP_Final: 30°C
08/12 06:10:58 - Function SoftStart: Correction: 1 > 0.5 °C - (STABLE) Freq: 45Hz, SP_Final: 29.5°C
08/12 06:10:48 - Function SoftStart: Correction: 0.5 > 1 °C - (STABLE) Freq: 44Hz, SP_Final: 30°C
08/12 06:05:48 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 06:05:48 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 44Hz, SP_Final: 29.5°C
08/12 06:03:28 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 44Hz, SP_Final: 29.25°C
08/12 06:03:18 - Function SoftStart: Correction: 0.25 > -0.25 °C - (STABLE) Freq: 44Hz, SP_Final: 28.75°C
08/12 06:03:08 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 45Hz, SP_Final: 29.25°C
08/12 06:02:48 - Function SoftStart: Correction: 0.25 > -0.25 °C - (STABLE) Freq: 44Hz, SP_Final: 28.75°C
08/12 06:02:38 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 45Hz, SP_Final: 29.25°C
08/12 06:02:28 - Function SoftStart: Correction: 0.25 > -0.25 °C - (STABLE) Freq: 45Hz, SP_Final: 28.75°C
08/12 06:01:58 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 06:01:58 - Function SoftStart: Correction: 0.5 > 0.25 °C - (STABLE) Freq: 45Hz, SP_Final: 29.25°C
08/12 06:01:38 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 06:01:38 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 47Hz, SP_Final: 29.5°C
08/12 06:00:28 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 50Hz, SP_Final: 29.25°C
08/12 05:59:48 - Function SoftStart: Correction: -0.5 > -0.25 °C - (STABLE) Freq: 51Hz, SP_Final: 28.75°C
08/12 05:59:18 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 05:59:18 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 50Hz, SP_Final: 28.5°C
08/12 05:58:48 - Function SoftStart: Correction: -1.25 > -1 °C - (STABLE) Freq: 50Hz, SP_Final: 28°C
08/12 05:57:48 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 05:57:48 - Function SoftStart: Correction: -2 > -1.25 °C - (STABLE) Freq: 51Hz, SP_Final: 27.75°C
08/12 05:57:18 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 05:57:18 - Function SoftStart: Correction: -1.5 > -2 °C - (STARTUP) Freq: 56Hz, SP_Final: 27°C
08/12 05:57:08 - Function SoftStart: Correction: -1.25 > -1.5 °C - (CATCH) Freq: 56Hz, SP_Final: 27.5°C
08/12 05:56:58 - Function SoftStart: Correction: -0.75 > -1.25 °C - (CATCH) Freq: 57Hz, SP_Final: 27.75°C
08/12 05:56:48 - *DEFROSTING: Finished
08/12 05:56:18 - Function SoftStart: Correction: -1.25 > -0.75 °C - (CATCH) Freq: 48Hz, SP_Final: 28.25°C
08/12 05:55:58 - Function SoftStart: Correction: -0.75 > -1.25 °C - (CATCH) Freq: 41Hz, SP_Final: 27.75°C
08/12 05:55:28 - Function SoftStart: Correction: -1.25 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 28.25°C
08/12 05:55:18 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 05:55:18 - Function SoftStart: Correction: -2 > -1.25 °C - (CATCH) Freq: 34Hz, SP_Final: 27.75°C
08/12 05:54:48 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 05:54:48 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 20Hz, SP_Final: 27°C
08/12 05:54:48 - Compressor: is running now
08/12 05:53:48 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 05:53:48 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 05:53:48 - Compressor: stopped
08/12 05:52:28 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 05:52:28 - Function SoftStart: Correction: -2 > -3 °C - (STABLE) Freq: 58Hz, SP_Final: 26°C
08/12 05:49:28 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 05:49:28 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 21Hz, SP_Final: 27°C
08/12 05:49:28 - Compressor: is running now
08/12 05:48:28 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 05:48:28 - Compressor: stopped
08/12 05:47:38 - [debug]: Not reducing pump speed while defrosting <test>
08/12 05:47:27 - *DEFROSTING: Toutside: 3.8°C
08/12 03:58:06 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 03:58:06 - Function SoftStart: Correction: 0.5 > 0 °C - (ENDING) Freq: 50Hz, SP_Final: 29°C
08/12 03:55:16 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 03:55:16 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 51Hz, SP_Final: 29.5°C
08/12 03:53:46 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 03:53:46 - Function SoftStart: Correction: 0.5 > 0.25 °C - (STABLE) Freq: 51Hz, SP_Final: 29.25°C
08/12 03:53:26 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 03:53:26 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 56Hz, SP_Final: 29.5°C
08/12 03:52:06 - Function SoftStart: Correction: -0.25 > 0.25 °C - (STABLE) Freq: 56Hz, SP_Final: 29.25°C
08/12 03:50:26 - Function SoftStart: Correction: -0.5 > -0.25 °C - (STABLE) Freq: 57Hz, SP_Final: 28.75°C
08/12 03:48:16 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 03:48:16 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 57Hz, SP_Final: 28.5°C
08/12 03:47:26 - Function SoftStart: Correction: -1.25 > -1 °C - (STABLE) Freq: 57Hz, SP_Final: 28°C
08/12 03:46:56 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 03:46:56 - Function SoftStart: Correction: -1.75 > -1.25 °C - (STABLE) Freq: 56Hz, SP_Final: 27.75°C
08/12 03:45:56 - Function SoftStart: Correction: -2 > -1.75 °C - (STABLE) Freq: 57Hz, SP_Final: 27.25°C
08/12 03:45:16 - Function SoftStart: Correction: -2.5 > -2 °C - (STABLE) Freq: 56Hz, SP_Final: 27°C
08/12 03:44:06 - Function SoftStart: Correction: -2 > -2.5 °C - (STABLE) Freq: 57Hz, SP_Final: 26.5°C
08/12 03:43:46 - Function SoftStart: Correction: -1.75 > -2 °C - (STABLE) Freq: 56Hz, SP_Final: 27°C
08/12 03:43:37 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 03:43:37 - Function SoftStart: Correction: -1.25 > -1.75 °C - (STABLE) Freq: 56Hz, SP_Final: 27.25°C
08/12 03:43:36 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 03:43:36 - Function SoftStart: Correction: -0.5 > -1.25 °C - (STABLE) Freq: 56Hz, SP_Final: 27.75°C
08/12 03:43:26 - Function SoftStart: Correction: 0.25 > -0.5 °C - (STABLE) Freq: 57Hz, SP_Final: 28.5°C
08/12 03:43:16 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 03:43:16 - Function SoftStart: Correction: 1 > 0.25 °C - (STABLE) Freq: 57Hz, SP_Final: 29.25°C
08/12 03:43:09 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 03:43:09 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 57Hz, SP_Final: 30°C
08/12 03:42:06 - Function SoftStart: Correction: -0.25 > 0 °C - (STABLE) Freq: 69Hz, SP_Final: 29°C
08/12 03:41:56 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 03:41:56 - Function SoftStart: Correction: -1 > -0.25 °C - (STABLE) Freq: 69Hz, SP_Final: 28.75°C
08/12 03:41:46 - Function SoftStart: Correction: -1.25 > -1 °C - (STABLE) Freq: 68Hz, SP_Final: 28°C
08/12 03:41:36 - Function SoftStart: Correction: -1 > -1.25 °C - (STABLE) Freq: 68Hz, SP_Final: 27.75°C
08/12 03:41:26 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 03:41:26 - Function SoftStart: Correction: 0 > -1 °C - (STABLE) Freq: 69Hz, SP_Final: 28°C
08/12 03:41:06 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 03:41:06 - Function SoftStart: Correction: -0.75 > 0 °C - (STABLE) Freq: 68Hz, SP_Final: 29°C
08/12 03:40:57 - Function SoftStart: Correction: -1.25 > -0.75 °C - (CATCH) Freq: 69Hz, SP_Final: 28.25°C
08/12 03:40:56 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 03:40:56 - Function SoftStart: Correction: -2 > -1.25 °C - (CATCH) Freq: 69Hz, SP_Final: 27.75°C
08/12 03:38:06 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 03:38:06 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 20Hz, SP_Final: 27°C
08/12 03:38:06 - MQTT Command - SetMaxPumpDuty: 142
08/12 03:38:06 - Compressor: is running now
08/12 03:38:06 - Function Pump speed: restored to: 142 (41%)
08/12 03:36:49 - Function RTC: Operation mode 0 (Heat only)
08/12 03:35:06 - MQTT Command - SetHeatpump: 1
08/12 03:35:06 - CONTROLLER: Manual ON detected on wallmounted unit
08/12 03:34:57 - CONTROLLER: Manual OFF detected on wallmounted unit - Default action used: Unrestricted
08/12 03:34:56 - MQTT Command - SetHeatpump: 1
08/12 03:34:56 - Function RTC: on/off - Turn on power (Room temp: 20.2°C)
08/12 00:44:14 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 00:44:14 - MQTT Command - SetMaxPumpDuty: 100
08/12 00:44:14 - Compressor: stopped
08/12 00:44:14 - Function Pump speed: reduced to 100 (19%)
08/12 00:44:04 - MQTT Command - SetHeatpump: 0
08/12 00:44:04 - Function RTC: on/off activated - Turn off power (Room temp: 20.7°C)
07/12 23:34:23 - HA Thermostat: Room setpoint changed to: 20.6 °C
07/12 23:34:18 - MQTT Command - SetQuietMode: 0
07/12 23:34:18 - Function - SoftStart Quietmode: OFF (restored to level 0)
07/12 23:34:18 - Function - SoftStart: 1
07/12 23:34:18 - Function - RTC: 1
07/12 23:34:15 - SETUP - Sensors: Custom room temperature sensor FOUND and used
07/12 23:34:13 - Function - WAR: 1
07/12 23:34:13 - SYSTEM - HEISHAMON Connection: Online
07/12 23:34:10 - SYSTEM: WAR settings OK
07/12 23:34:10 - SETUP - Sensors: Custom outside temperature sensor FOUND and used
07/12 23:34:09 - MQTT Command - SetHeatpump: 1
07/12 23:34:09 - Function NightReduction: New correction: 0 °C
07/12 23:34:09 - MQTT Command - SetMaxPumpDuty: 142
07/12 23:34:09 - SYSTEM: Heatpump is in DIRECT mode
07/12 23:34:09 - Compressor: is running now
07/12 23:34:09 - SYSTEM: MQTT-Commands to HP will be send normally.
07/12 23:34:09 - Function NightReduction: 0
07/12 23:34:09 - Function Pump speed: 1
07/12 23:34:10 - SYSTEM - HEISHAMON Connection: Offline
07/12 23:34:09 - SYSTEM: Start---------------------------------------------------------------
  • Maarten69
Wacht eens even!
Heb jij niet gewoon een import probleem?
Je had deel van deze code al op jouw WP Personal tab.
Bij importeren van 21.24 zit daar een deel van die functie in.
Denk dat je die nodes (net als we bij MQTT-node doen) niet geïmporteerd hebt!
Zo moet het er namelijk uit zien onderaan op flow WP Debug:
Afbeeldingslocatie: https://tweakers.net/i/8EP3oA7Rm-ChpIARQyPwMhjzUn0=/800x/filters:strip_exif()/f/image/1yNlwEchEIttNBG5PC5JECGZ.png?f=fotoalbum_large
Dit omdat je zelf als zegt dat ik nu geen TOP8 meer als trigger gebruik, maar dus wel doe!
  • Maarten69
Als dat het niet is moet ik even wachten op iemand met 21.24 die het wilt testen, ik zie niet waar het fout zou kunnen gaan namelijk.
  • Maarten69
fixed typo
08/12 09:47:07 - SYSTEM: MQTT-Commands to HP will be sent normally.
  • edterbak
Block functie is nieuwe, dus die mogen we ook verdenken.
  • Maarten69
@edterbak In bovenstaande log schakelt de RTC on/off.
Toch krijg ik daardoor onterecht dit soort meldingen:
  • Maarten69
edterbak schreef op donderdag 8 december 2022 @ 09:54:
Eej, die block functie is erg gevoelig voor kritiek hoor O-)
Blocken zonder een log vermelding geloof ik niet eigenlijk.
[ Voor 11% gewijzigd door Maarten69 op 08-12-2022 09:55 ]
  • edterbak
Maarten69 schreef op donderdag 8 december 2022 @ 09:54:
Ja. Precies.
Ik ga even kijken naar hoe dit kan.
Word pas ergens rond lunch.
  • edterbak
Maarten69 schreef op donderdag 8 december 2022 @ 09:55:
Nee hoor, ik ben niet zo gevoelig voor kritiek.
Ik hoor verbeter kansen.
:9
  • Maarten69
Laat even weten voordat je wilt beginnen, dan kan ik misschien nog een upload doen.
Moet om 14:00 toch weer werken, eigenlijk geen tijd voor maar ja ;)
Gather HP data aangevuld:
Target=29°C, Inlet=26.75°C, Outlet=29.75°C, Freq=36 Hz, 1000 W, OM=Heat only, fan1: 520 rpm, COP=4.67
Toont Quietmode alleen indien <> 0
Toont Powerful alleen <> 0
Toont Fan2 alleen <> 0
Met COP (DHW of HEAT) afhankelijk van OM. :)
[ Voor 49% gewijzigd door Maarten69 op 08-12-2022 10:08 ]
  • Aikon
Maarten69 schreef op woensdag 7 december 2022 @ 13:00:
@Aikon Voor jou heb ik een functie toegevoeg die nu alleen logt of je in booster range zit.
Dus tussen level +3 en +custom.
Laat even weten als je dat terug ziet in log. De functie doet verder niets anders.
Mijn plan is namelijk om in die booster range de setpoint langzaam te verlagen en dus bij een +10 naar +3 niet meteen de compressor af te laten slaan (in die booster range)
Hij staat online nu. Ik moet zo gaan werken dus morgen kan ik pas weer verder.[/URL]
Ik heb 21.24 er op gezet, toevallig precies terwijl ik in de +3 zone zat. Toen even de grens aangepast zodat ik weer in de +4 viel (met +4 graden nu ipv +15). Zo te zien werkt het :) Wel een afrondingsdingetje ;) Weet je zo genoeg?
29
30
08/12 10:06:57 - Function RTC: Operation mode 0 (Heat only)
08/12 10:06:26 - MQTT Command - SetZ1HeatRequestTemperature: 43
08/12 10:06:26 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 10:06:26 - Function RTC: Correction change: From 4 to 3 °C (Room actual: 18.9 °C)
08/12 10:06:26 - Function RTC: Operation mode 0 (Heat only)
08/12 09:59:11 - MQTT Command - SetZ1HeatRequestTemperature: 44
08/12 09:59:10 - Function RTC: Correction change: From 3 to 4 °C (Room actual: 18.9 °C)
08/12 09:58:19 - MQTT Command - SetQuietMode: 0
08/12 09:58:19 - Function - SoftStart Quietmode: finished, now restoring to level 0
08/12 09:57:29 - MQTT Command - SetQuietMode: 3
08/12 09:57:29 - Function - SoftStart Quietmode: ON (Timer: 5 min, Restore level 0)
08/12 09:57:29 - Function - SoftStart: 1
08/12 09:57:29 - Function - RTC: 1
08/12 09:57:26 - SETUP - Sensors: Custom room temperature sensor FOUND and used
08/12 09:57:24 - Function - WAR: 1
08/12 09:57:22 - SYSTEM: WAR settings OK
08/12 09:57:21 - Function RTC: Operation mode 0 (Heat only)
08/12 09:57:21 - SETUP - Sensors: Custom outside temperature sensor FOUND and used
08/12 09:57:21 - MQTT Command - SetHeatpump: 1
08/12 09:57:21 - Function NightReduction: New correction: -12 °C
08/12 09:57:21 - Compressor: is running now
08/12 09:57:21 - SYSTEM: MQTT-Commands to HP will be send normally.
08/12 09:57:21 - SYSTEM: Heatpump is in DIRECT mode
08/12 09:57:21 - Function Solar: 0
08/12 09:57:21 - Function NightReduction: 0
08/12 09:57:21 - Function Pump speed: 0
08/12 09:57:21 - RTC: Room setpoint changed to: 19.4 °C
08/12 09:57:21 - SYSTEM - HEISHAMON Connection: Online
08/12 09:57:21 - SYSTEM - HEISHAMON Connection: Offline
08/12 09:57:20 - SYSTEM: Start-
Afbeeldingslocatie: https://tweakers.net/i/m7ATU48kpjmELOHPFPb0F8_ELAA=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/fGbKsEvscwHPfKof3hwDnPPI.png?f=user_large
Ik zie dat je When changing RTC room setpoint, match Night-reduction room temperature (normal) accordingly. bij de to do lijst hebt gezet. Helemaal goed, en moet ook gebeuren. Maar zoals je ziet heb ik om een uur of 18:00 even bewust die setpoint gewijzigd bij RTC, en dat werkt eigenlijk ideaal als tijdelijke verlaging. Zou een goede functie zijn voor een verlaging die met de nachtverlaging automatisch wordt rechtgetrokken voor als je een keer laat thuis komt. Kan je die 'functie' behouden en kopieren naar elders? _/-\o_
  • Maarten69
Aikon schreef op donderdag 8 december 2022 @ 10:17:
Ja bedankt, kan ik daar mee verder (booster).
Leg die laatste alinea nog eens even uit in een PM, want ik volg je niet helemaal.
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
@Maarten69 mijn flow ziet er inderdaad anders uit. Zal de losse flow eruit kegelen en nog eens proveren.
Zou ook misschien verklaren waarom de losse flow is omgevallen.
  • Maarten69
MikeyMan schreef op donderdag 8 december 2022 @ 10:34:
Denk echt dat dat het was :)
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Grappige is wel dat ik niet de melding kreeg dat er duplicate nodes waren. Dat check ik altijd.
Ben per ongeluk op kantoor vandaag, dus kan er ff niet bij ;)
Stiekem toch een kleine bijdrage geleverd aan de oplossing? :P
[ Voor 9% gewijzigd door MikeyMan op 08-12-2022 11:02 ]
  • Maarten69
Current version: 21.25 beta (experimental)
- [NEW] - Added fan(s) speed and COP to Gather HP data.
- [Improvement] - Polling room setpoint more efficiently to log.
- [TEST] - Test RTC booster temp leveling between +3 and +custom levels (currently showing only in log).
typo send --> sent fixed
@edterbak Ik ben weer klaar voor vandaag.
[ Voor 4% gewijzigd door Maarten69 op 08-12-2022 12:23 ]
  • Maarten69
@edterbak Weet jij een manier om Fan 2 niet te tonen op HOME indien niet aanwezig? (=0)
  • Aikon
Maarten69 schreef op donderdag 8 december 2022 @ 12:11:
Ik ga hem gelijk installeren 8)
  • Maarten69
Dan zou in jouw geval @Aikon het log de correcties moeten laten zien:
--------------+3------------------19.0 (+3)
----------------------------------18.9 (+5.4)
----------------------------------18.8 (+7.8)
----------------------------------18.7 (+10.2)
----------------------------------18.6 (+12.6)
--------+custom-------------------18.5 (+15 cor)
voorwaarde is wel dat +custom onder +3 level ligt.
[ Voor 7% gewijzigd door Maarten69 op 08-12-2022 12:32 ]
  • Aikon
Heb de Pana uitgezet, waarna deze weer aansprong bij 0.4 onder setpoint, maar dat is in de booster level range (als we die termen gaan gebruiken, de booster range is alles onder de 4 waarde toch ;)). Was ik even vergeten. Maar heb je zo de info die je nodig hebt? @Maarten69
29
30
31
32
33
34
35
36
37
08/12 13:22:44 - MQTT Command - SetZ1HeatRequestTemperature: 42
08/12 13:22:44 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:22:44 - Function SoftStart: Correction: -1 > -0.5 °C - (CATCH) Freq: 35Hz, SP_Final: 41.5°C
08/12 13:22:05 - MQTT Command - SetZ1HeatRequestTemperature: 41
08/12 13:22:05 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:22:05 - Function SoftStart: Correction: -0.5 > -1 °C - (CATCH) Freq: 35Hz, SP_Final: 41°C
08/12 13:22:04 - MQTT Command - SetZ1HeatRequestTemperature: 42
08/12 13:22:04 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:22:04 - Function SoftStart: Correction: -1 > -0.5 °C - (CATCH) Freq: 36Hz, SP_Final: 41.5°C
08/12 13:22:03 - SYSTEM: MQTT-Commands to HP will be send normally.
08/12 13:21:49 - Function SoftStart: Correction: -1.5 > -1 °C - (CATCH) Freq: 35Hz, SP_Final: 41°C
08/12 13:21:44 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:21:44 - Function SoftStart: Correction: -1.75 > -1.5 °C - (CATCH) Freq: 34Hz, SP_Final: 40.5°C
08/12 13:21:39 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:21:34 - Function SoftStart: Correction: -2 > -1.75 °C - (CATCH) Freq: 34Hz, SP_Final: 40.25°C
08/12 13:21:19 - Function SoftStart: Correction: -1.75 > -2 °C - (STARTUP) Freq: 27Hz, SP_Final: 40°C
08/12 13:21:09 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:21:09 - Function SoftStart: Correction: 0 > -1.75 °C - (CATCH) Freq: 20Hz, SP_Final: 40.25°C
08/12 13:21:09 - Compressor: is running now
08/12 13:20:58 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:20:28 - The room temp (18.9 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:20:28 - Function RTC: Operation mode 0 (Heat only)
08/12 13:19:58 - The room temp (19 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:19:28 - The room temp (19 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:18:58 - The room temp (19 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:18:28 - The room temp (19 °C) is in booster range (18.599999999999998°C - 19.099999999999998°C): undefined
08/12 13:17:58 - MQTT Command - SetHeatpump: 1
08/12 13:17:58 - Function RTC: Correction change: From 2 to 3 °C (Room actual: 19 °C)
08/12 13:17:58 - Function RTC: on/off - Turn on power (Room temp: 19°C)
08/12 13:10:58 - Function RTC: Correction change: From 1 to 2 °C (Room actual: 19.1 °C)
08/12 13:06:28 - Function RTC: Correction change: From 0 to 1 °C (Room actual: 19.2 °C)
08/12 12:51:19 - MQTT Command - SetQuietMode: 3
08/12 12:51:19 - Function - SoftStart Quietmode: Run finished, reset for next run
08/12 12:51:03 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 12:51:03 - Compressor: stopped
08/12 12:51:03 - MQTT Command - SetHeatpump: 0
@edterbak Ter info, de pana gaat dus aan vanwege RTC on, maar kreeg wel een pop-up van 'manual press detected'
Ook met het uitzetten via NR kreeg ik:
08/12 12:51:03 - CONTROLLER: Manual OFF detected on wallmounted unit - Default action used: Block custom
Maar ik denk dat dat de bedoeling is toch? Alleen de tekst 'on wallmounted unit' zou dan eruit moeten?
  • Maarten69
@Aikon Bedankt, zit dus nog een foutje in (undefined) en afronding. Waar dat nou vandaan komt...
[ Voor 4% gewijzigd door Maarten69 op 08-12-2022 13:52 ]
  • Maarten69
@Aikon Jij hebt ook een import fout gemaakt. Die tijdelijke functie heb ik namelijk verwijderd:
Deze regel wordt nu zo opgemaakt:
msg99.payload = "Booster correction at " + rtc_PV + "°C " + "should be " + rtc_correction + "°C";
Wat iets naar logt schrijft als:
Booster correction at 18.8°C should be 8,5°C";
[ Voor 36% gewijzigd door Maarten69 op 08-12-2022 13:54 ]
  • Aikon
Ik heb een import zoals altijd gedaan vziw. Wat zou ik verkeerd hebben gedaan dan?
  • Maarten69
Check maar even, maar hier zou nu niets meer moeten staan en dat heb jij blijkbaar nog wel:
Afbeeldingslocatie: https://tweakers.net/i/ZYIKIBj4g7DktTwTXYMudujUHrs=/800x/filters:strip_exif()/f/image/qQSBqrlMT5T2ZclmkrkgCCzf.png?f=fotoalbum_large
  • Maarten69
Tot later, moet weg.
  • Aikon
Daar stonden nog 2 blokkies ja, heb nu verwijderd. Apart, want dan zou ik het tabblad niet hebben verwijderd dus... nah ja kan natuurlijk.
Later ;w ;)
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Die blokjes staan er bij mij ook...
Afbeeldingslocatie: https://tweakers.net/i/y7IuvQg6IicrwOBF7qFGy2qyh00=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/gIAeY60vz7t92n25DHY0woMH.png?f=user_large
Maar hoe verwijder je die dan op fatsoenlijke manier? Het zijn volgens mij geen config nodes.
Zowel het verwijderen van de tabbladen als de config nodes zelf is dan niet genoeg?
Zou dat toch in de deploy tussen verwijderen tabbladen en importeren van nieuw spul kunnen zitten?
Denk niet dat we het een 'import fout' kunnen noemen eerlijk gezegd ;)
Nu met een deploy tussen verwijderen en importeren gedaan, en dat lijkt goed te gaan... Maar 1 zwaluw maakt nog geen zomer natuurlijk ;)
29
30
31
32
33
34
35
36
08/12 14:31:29 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 14:31:29 - Function SoftStart: Correction: 1 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 27°C
08/12 14:31:04 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 14:31:04 - Function SoftStart: Correction: -0.25 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 26°C
08/12 14:31:04 - Function RTC: Correction change: From 4 to 0 °C (Room actual: 20.4 °C)
08/12 14:31:04 - SETUP - Sensors: Custom room temperature sensor FOUND and used
08/12 14:30:18 - Function SoftStart: Correction: -0.5 > -0.25 °C - (STABLE) Freq: 47Hz, SP_Final: 28.75°C
08/12 14:29:38 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 14:29:34 - Function SoftStart: Correction: -0.5 > -1 °C - (STABLE) Freq: 48Hz, SP_Final: 28°C
08/12 14:29:34 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 14:29:33 - Function SoftStart: Correction: -1 > -0.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 14:28:47 - MQTT Command - SetMaxPumpDuty: 149
08/12 14:28:39 - MQTT Command - SetMaxPumpDuty: 149
08/12 14:28:28 - Function SoftStart: Correction: -1.5 > -1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 14:28:12 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 14:28:12 - Function SoftStart: Correction: 1 > -1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 27.5°C
08/12 14:28:12 - Function RTC: Correction change: From 0 to 4 °C (Room actual: 19 °C)
08/12 14:28:11 - Function - SoftStart Quietmode: OFF (restored to level 0)
08/12 14:28:11 - Function - SoftStart: 1
08/12 14:28:11 - Function - RTC: 1
08/12 14:28:06 - Function - WAR: 1
08/12 14:28:03 - SYSTEM: WAR settings OK
08/12 14:28:02 - SYSTEM: MQTT-Commands to HP will be sent normally.
08/12 14:28:02 - Function Solar: 1
08/12 14:28:02 - Function NightReduction: 0
08/12 14:28:02 - RTC: Room setpoint changed to: 20.5 °C
08/12 14:28:02 - MQTT Command - SetHeatpump: 1
08/12 14:28:02 - Function NightReduction: New correction: -1 °C
08/12 14:28:02 - MQTT Command - SetMaxPumpDuty: 151
08/12 14:28:02 - Compressor: is running now
08/12 14:28:02 - SYSTEM: Heatpump is in DIRECT mode
08/12 14:28:02 - Function Pump speed: 1
08/12 14:28:03 - SYSTEM - HEISHAMON Connection: Online
08/12 14:28:02 - SYSTEM - HEISHAMON Connection: Offline
08/12 14:28:02 - SYSTEM: Start---------------------------------------------------------------
Function pump speed staat vermeld in de logs. En de laatste pump duty verandering komt van system health *O*
Zie nog geen log regel voor de lowspeed.
Overigens nog een suggestie. Is het een idee om bij elkaar horende global context data ook een herkenbare naam te geven.
Zeg maar van :
ReducePumpSpeed
SavedPumpspeed
LowSpeed
PumpMaxFlowSetting
naar
PumpspeedReducePumpSpeed
PumpspeedSaved
PumpspeedLow
PumpspeedMax
Of iets in die richting?
Zodoende komen ze volgens mij bij elkaar te staan in het overzicht.
[ Voor 101% gewijzigd door MikeyMan op 08-12-2022 14:34 ]
  • MikeyMan
  • Laatst online: 18:15
MikeyMan
Vidi, Vici, Veni
Log van vanmorgen is overigens wel druk te noemen:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
08/12 14:26:29 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 14:26:28 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 48Hz, SP_Final: 26°C
08/12 14:25:57 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 14:25:57 - Function SoftStart: Correction: -2.5 > 0 °C - (STABLE) Freq: 48Hz, SP_Final: 25°C
08/12 14:25:57 - Function RTC: Correction change: From 4 to 0 °C (Room actual: 20.4 °C)
08/12 14:25:57 - SETUP - Sensors: Custom room temperature sensor FOUND and used
08/12 14:25:54 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 14:25:53 - Function SoftStart: Correction: -2.75 > -2.5 °C - (STABLE) Freq: 46Hz, SP_Final: 26.5°C
08/12 14:25:43 - Function SoftStart: Correction: -3 > -2.75 °C - (STABLE) Freq: 45Hz, SP_Final: 26.25°C
08/12 14:24:33 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 14:24:33 - Function SoftStart: Correction: -2 > -3 °C - (STABLE) Freq: 34Hz, SP_Final: 26°C
08/12 14:21:23 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 14:21:23 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 19Hz, SP_Final: 27°C
08/12 14:21:23 - Compressor: is running now
08/12 14:21:05 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 14:21:04 - Function RTC: Correction change: From 0 to 4 °C (Room actual: 19 °C)
08/12 14:21:03 - Function - SoftStart Quietmode: OFF (restored to level 0)
08/12 14:21:03 - Function - SoftStart: 1
08/12 14:21:03 - Function - RTC: 1
08/12 14:20:58 - Function - WAR: 1
08/12 14:20:58 - SYSTEM - HEISHAMON Connection: Online
08/12 14:20:55 - SYSTEM: WAR settings OK
08/12 14:20:55 - MQTT Command - SetHeatpump: 1
08/12 14:20:55 - Function NightReduction: New correction: -1 °C
08/12 14:20:55 - SYSTEM: MQTT-Commands to HP will be send normally.
08/12 14:20:55 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 14:20:55 - Function Solar: 1
08/12 14:20:55 - Function NightReduction: 0
08/12 14:20:55 - Compressor: stopped
08/12 14:20:55 - SYSTEM: Heatpump is in DIRECT mode
08/12 14:20:55 - RTC: Room setpoint changed to: 20.5 °C
08/12 14:20:55 - SYSTEM - HEISHAMON Connection: Offline
08/12 14:20:54 - SYSTEM: Start---------------------------------------------------------------
08/12 13:50:35 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 13:50:35 - Function RTC: Correction change: From 1 to 0 °C (Room actual: 20.33 °C)
08/12 13:28:23 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 13:28:23 - Compressor: stopped
08/12 13:25:17 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 13:25:17 - Function SoftStart: Correction: 2 > 0 °C - (ENDING) Freq: 39Hz, SP_Final: 26°C
08/12 13:20:49 - MQTT Command - SetMaxPumpDuty: 159
08/12 13:05:22 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 13:05:22 - Function SoftStart: Correction: 1 > 2 °C - (STABLE) Freq: 40Hz, SP_Final: 28°C
08/12 13:00:17 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 13:00:17 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 27°C
08/12 12:58:27 - Function SoftStart: Correction: -0.25 > 0 °C - (STABLE) Freq: 34Hz, SP_Final: 26°C
08/12 12:58:22 - Function SoftStart: Correction: 0 > -0.25 °C - (STABLE) Freq: 34Hz, SP_Final: 25.75°C
08/12 12:58:17 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 12:58:17 - Function SoftStart: Correction: -1.25 > 0 °C - (STABLE) Freq: 35Hz, SP_Final: 26°C
08/12 12:56:27 - Function SoftStart: Correction: -0.75 > -1.25 °C - (CATCH) Freq: 34Hz, SP_Final: 24.75°C
08/12 12:56:12 - Function SoftStart: Correction: -1.25 > -0.75 °C - (CATCH) Freq: 34Hz, SP_Final: 25.25°C
08/12 12:55:57 - Function SoftStart: Correction: -1.5 > -1.25 °C - (CATCH) Freq: 35Hz, SP_Final: 24.75°C
08/12 12:55:52 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 12:55:52 - Function SoftStart: Correction: -2 > -1.5 °C - (CATCH) Freq: 35Hz, SP_Final: 24.5°C
08/12 12:55:12 - MQTT Command - SetZ1HeatRequestTemperature: 24
08/12 12:55:12 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 19Hz, SP_Final: 24°C
08/12 12:55:12 - Compressor: is running now
08/12 12:54:56 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 12:54:56 - Function RTC: Correction change: From 0 to 1 °C (Room actual: 20.27 °C)
08/12 12:34:44 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 12:34:44 - Function RTC: Correction change: From 1 to 0 °C (Room actual: 20.3 °C)
08/12 12:27:42 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 12:27:42 - Compressor: stopped
08/12 12:24:35 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 12:24:35 - Function RTC: Correction change: From 2 to 1 °C (Room actual: 20.17 °C)
08/12 12:05:42 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 12:05:42 - Function SoftStart: Correction: 2 > 0 °C - (ENDING) Freq: 44Hz, SP_Final: 27°C
08/12 12:04:22 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 12:04:21 - Function RTC: Correction change: From 3 to 2 °C (Room actual: 19.93 °C)
08/12 11:59:57 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 47Hz, SP_Final: 30°C
08/12 11:57:12 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 29.5°C
08/12 11:57:07 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 30°C
08/12 11:56:42 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 29.5°C
08/12 11:55:07 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 30°C
08/12 11:55:02 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 29.5°C
08/12 11:54:52 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 47Hz, SP_Final: 30°C
08/12 11:54:47 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 29.5°C
08/12 11:54:42 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 47Hz, SP_Final: 30°C
08/12 11:54:16 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 11:54:16 - The room temp (19.9 °C) is in booster range (19.5°C - 19.9°C): undefined
08/12 11:54:16 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 29.5°C
08/12 11:54:16 - Function RTC: Correction change: From 2 to 3 °C (Room actual: 19.9 °C)
08/12 11:49:22 - Function SoftStart: Correction: 1.75 > 2 °C - (STABLE) Freq: 47Hz, SP_Final: 29°C
08/12 11:48:17 - Function SoftStart: Correction: 1.5 > 1.75 °C - (STABLE) Freq: 48Hz, SP_Final: 28.75°C
08/12 11:46:57 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 11:46:57 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 11:46:37 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 11:46:27 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 48Hz, SP_Final: 28°C
08/12 11:46:27 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 11:46:27 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 11:46:22 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 11:46:07 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 11:46:07 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 11:46:07 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 11:45:57 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 11:45:57 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 11:44:10 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 11:44:10 - Function RTC: Correction change: From 1 to 2 °C (Room actual: 20.03 °C)
08/12 11:40:47 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 11:40:46 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 27°C
08/12 11:38:46 - Function SoftStart: Correction: -0.5 > 0 °C - (STABLE) Freq: 34Hz, SP_Final: 26°C
08/12 11:38:37 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 11:38:36 - Function SoftStart: Correction: -0.75 > -0.5 °C - (CATCH) Freq: 35Hz, SP_Final: 25.5°C
08/12 11:37:47 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 11:37:42 - Function SoftStart: Correction: -0.5 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
08/12 11:37:42 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 11:37:41 - Function SoftStart: Correction: -0.75 > -0.5 °C - (CATCH) Freq: 35Hz, SP_Final: 25.5°C
08/12 11:37:36 - Function SoftStart: Correction: -0.5 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
08/12 11:37:23 - Function SoftStart: Correction: -0.75 > -0.5 °C - (CATCH) Freq: 34Hz, SP_Final: 25.5°C
08/12 11:37:22 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 11:37:17 - Function SoftStart: Correction: -0.5 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
08/12 11:37:16 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 11:37:07 - Function SoftStart: Correction: -0.75 > -0.5 °C - (CATCH) Freq: 34Hz, SP_Final: 25.5°C
08/12 11:37:06 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 11:37:06 - Function SoftStart: Correction: -0.5 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
08/12 11:36:31 - Function SoftStart: Correction: -0.75 > -0.5 °C - (CATCH) Freq: 34Hz, SP_Final: 25.5°C
08/12 11:36:27 - Function SoftStart: Correction: -0.5 > -0.75 °C - (CATCH) Freq: 34Hz, SP_Final: 25.25°C
08/12 11:36:26 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 11:36:26 - Function SoftStart: Correction: -0.75 > -0.5 °C - (CATCH) Freq: 34Hz, SP_Final: 25.5°C
08/12 11:36:21 - Function SoftStart: Correction: -1.25 > -0.75 °C - (CATCH) Freq: 34Hz, SP_Final: 25.25°C
08/12 11:36:16 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 11:36:16 - Function SoftStart: Correction: -2 > -1.25 °C - (CATCH) Freq: 34Hz, SP_Final: 24.75°C
08/12 11:35:41 - MQTT Command - SetZ1HeatRequestTemperature: 24
08/12 11:35:41 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 19Hz, SP_Final: 24°C
08/12 11:35:41 - Compressor: is running now
08/12 11:32:31 - Compressor: stopped
08/12 11:03:42 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 11:03:42 - Function RTC: Correction change: From 0 to 1 °C (Room actual: 20.17 °C)
08/12 11:01:26 - Scheduler - Operation Mode: 6
08/12 11:00:56 - Compressor: is running now
08/12 11:00:26 - MQTT Command - SetOperationMode: 6
08/12 11:00:26 - Scheduler - Operation Mode: 6
08/12 09:57:59 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 09:57:59 - Function RTC: Correction change: From 1 to 0 °C (Room actual: 20.37 °C)
08/12 09:50:55 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 09:50:55 - Compressor: stopped
08/12 09:47:50 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 09:47:50 - Function SoftStart: Correction: 2 > 0 °C - (ENDING) Freq: 34Hz, SP_Final: 26°C
08/12 09:37:48 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 09:37:48 - Function RTC: Correction change: From 2 to 1 °C (Room actual: 20.17 °C)
08/12 09:32:45 - Function SoftStart: Correction: 1.25 > 2 °C - (STABLE) Freq: 40Hz, SP_Final: 29°C
08/12 09:32:45 - Function RTC: Correction change: From 3 to 2 °C (Room actual: 20.03 °C)
08/12 09:32:35 - Function SoftStart: Correction: 0.75 > 1.25 °C - (STABLE) Freq: 39Hz, SP_Final: 29.25°C
08/12 09:32:30 - Function SoftStart: Correction: 1.25 > 0.75 °C - (STABLE) Freq: 40Hz, SP_Final: 28.75°C
08/12 09:32:25 - Function SoftStart: Correction: 0.75 > 1.25 °C - (STABLE) Freq: 40Hz, SP_Final: 29.25°C
08/12 09:32:20 - Function SoftStart: Correction: 1.25 > 0.75 °C - (STABLE) Freq: 39Hz, SP_Final: 28.75°C
08/12 09:32:15 - Function SoftStart: Correction: 0.75 > 1.25 °C - (STABLE) Freq: 39Hz, SP_Final: 29.25°C
08/12 09:31:55 - Function SoftStart: Correction: 1.25 > 0.75 °C - (STABLE) Freq: 39Hz, SP_Final: 28.75°C
08/12 09:31:50 - Function SoftStart: Correction: 0.75 > 1.25 °C - (STABLE) Freq: 39Hz, SP_Final: 29.25°C
08/12 09:31:45 - Function SoftStart: Correction: 1.25 > 0.75 °C - (STABLE) Freq: 40Hz, SP_Final: 28.75°C
08/12 09:31:40 - Function SoftStart: Correction: 0.75 > 1.25 °C - (STABLE) Freq: 40Hz, SP_Final: 29.25°C
08/12 09:29:20 - Function SoftStart: Correction: 1.25 > 0.75 °C - (STABLE) Freq: 40Hz, SP_Final: 28.75°C
08/12 09:27:55 - Function SoftStart: Correction: 1 > 1.25 °C - (STABLE) Freq: 40Hz, SP_Final: 29.25°C
08/12 09:27:42 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 09:27:42 - The room temp (19.9 °C) is in booster range (19.5°C - 19.9°C): undefined
08/12 09:27:42 - Function RTC: Correction change: From 2 to 3 °C (Room actual: 19.9 °C)
08/12 09:22:55 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 09:22:55 - Function SoftStart: Correction: 0 > 1 °C - (STABLE) Freq: 44Hz, SP_Final: 28°C
08/12 09:20:50 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 09:20:50 - Function SoftStart: Correction: -1 > 0 °C - (STABLE) Freq: 34Hz, SP_Final: 27°C
08/12 09:19:30 - Function SoftStart: Correction: -0.75 > -1 °C - (CATCH) Freq: 35Hz, SP_Final: 26°C
08/12 09:19:25 - Function SoftStart: Correction: -1 > -0.75 °C - (CATCH) Freq: 34Hz, SP_Final: 26.25°C
08/12 09:19:20 - Function SoftStart: Correction: -0.75 > -1 °C - (CATCH) Freq: 34Hz, SP_Final: 26°C
08/12 09:18:40 - Function SoftStart: Correction: -1 > -0.75 °C - (CATCH) Freq: 35Hz, SP_Final: 26.25°C
08/12 09:18:30 - Function SoftStart: Correction: -1.5 > -1 °C - (CATCH) Freq: 35Hz, SP_Final: 26°C
08/12 09:18:25 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 09:18:25 - Function SoftStart: Correction: -1.75 > -1.5 °C - (CATCH) Freq: 35Hz, SP_Final: 25.5°C
08/12 09:18:20 - Function SoftStart: Correction: -2 > -1.75 °C - (CATCH) Freq: 35Hz, SP_Final: 25.25°C
08/12 09:17:50 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 09:17:50 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 20Hz, SP_Final: 25°C
08/12 09:17:50 - Compressor: is running now
08/12 09:17:31 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 09:17:31 - Function RTC: Correction change: From 1 to 2 °C (Room actual: 20.03 °C)
08/12 09:16:22 - MQTT Command - SetForceDefrost: 0
08/12 09:11:05 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 09:11:05 - Compressor: stopped
08/12 09:08:00 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 09:08:00 - Function SoftStart: Correction: 2 > 0 °C - (ENDING) Freq: 36Hz, SP_Final: 26°C
08/12 09:07:27 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 09:07:26 - Function RTC: Correction change: From 2 to 1 °C (Room actual: 20.13 °C)
08/12 08:57:35 - Function SoftStart: Correction: 1.75 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 29°C
08/12 08:53:29 - Function SoftStart: Correction: 1.5 > 1.75 °C - (STABLE) Freq: 47Hz, SP_Final: 28.75°C
08/12 08:52:44 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 08:52:39 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 08:52:35 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 08:52:34 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 08:51:54 - Function SoftStart: Correction: 0.5 > 1 °C - (STABLE) Freq: 48Hz, SP_Final: 28°C
08/12 08:49:55 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 08:49:54 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 47Hz, SP_Final: 27.5°C
08/12 08:49:49 - Function SoftStart: Correction: 0 > 0.25 °C - (STABLE) Freq: 47Hz, SP_Final: 27.25°C
08/12 08:49:45 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 08:49:44 - Function SoftStart: Correction: -0.75 > 0 °C - (STABLE) Freq: 46Hz, SP_Final: 27°C
08/12 08:49:40 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 08:49:39 - Function SoftStart: Correction: -2.25 > -0.75 °C - (STABLE) Freq: 44Hz, SP_Final: 26.25°C
08/12 08:49:35 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 08:49:34 - Function SoftStart: Correction: -3 > -2.25 °C - (STABLE) Freq: 44Hz, SP_Final: 24.75°C
08/12 08:49:24 - *DEFROSTING: Finished
08/12 08:46:22 - MQTT Command - SetForceDefrost: 1
08/12 08:41:04 - MQTT Command - SetZ1HeatRequestTemperature: 24
08/12 08:41:04 - Function SoftStart: Correction: -2 > -3 °C - (STABLE) Freq: 86Hz, SP_Final: 24°C
08/12 08:37:54 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 08:37:54 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 21Hz, SP_Final: 25°C
08/12 08:37:54 - Compressor: is running now
08/12 08:36:09 - *DEFROSTING: Toutside: 3°C
08/12 08:36:09 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 08:36:09 - Compressor: stopped
08/12 08:32:08 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 08:32:08 - Function RTC: Correction change: From 3 to 2 °C (Room actual: 19.97 °C)
08/12 08:12:54 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 08:12:54 - The room temp (19.9 °C) is in booster range (19.5°C - 19.9°C): undefined
08/12 08:12:54 - Function SoftStart: Correction: 1.5 > 0 °C - (ENDING) Freq: 47Hz, SP_Final: 28°C
08/12 08:10:19 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 29.5°C
08/12 08:02:14 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 30°C
08/12 08:02:09 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 29.5°C
08/12 08:02:04 - Function SoftStart: Correction: 1.5 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 30°C
08/12 08:01:45 - MQTT Command - SetZ1HeatRequestTemperature: 30
08/12 08:01:45 - The room temp (19.9 °C) is in booster range (19.5°C - 19.9°C): undefined
08/12 08:01:45 - Function SoftStart: Correction: 2 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 29.5°C
08/12 08:01:45 - Function RTC: Correction change: From 2 to 3 °C (Room actual: 19.9 °C)
08/12 07:59:39 - Function SoftStart: Correction: 1.75 > 2 °C - (STABLE) Freq: 48Hz, SP_Final: 29°C
08/12 07:57:29 - Function SoftStart: Correction: 1.5 > 1.75 °C - (STABLE) Freq: 48Hz, SP_Final: 28.75°C
08/12 07:57:24 - Function SoftStart: Correction: 1.75 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 07:57:19 - Function SoftStart: Correction: 1.5 > 1.75 °C - (STABLE) Freq: 48Hz, SP_Final: 28.75°C
08/12 07:54:49 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 07:54:44 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 07:54:44 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 07:54:44 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 07:54:34 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 07:54:34 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 07:54:29 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 07:54:24 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 07:54:22 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 07:54:19 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 07:54:14 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 07:53:59 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 48Hz, SP_Final: 28°C
08/12 07:53:59 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 07:53:59 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 48Hz, SP_Final: 28.5°C
08/12 07:53:54 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 07:53:49 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 07:53:49 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 07:53:49 - Function SoftStart: Correction: 1.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 07:53:04 - Function SoftStart: Correction: 1.75 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 07:52:59 - Function SoftStart: Correction: 1.5 > 1.75 °C - (STABLE) Freq: 47Hz, SP_Final: 28.75°C
08/12 07:52:59 - MQTT Command - SetZ1HeatRequestTemperature: 29
08/12 07:52:59 - Function SoftStart: Correction: 1 > 1.5 °C - (STABLE) Freq: 47Hz, SP_Final: 28.5°C
08/12 07:50:34 - Function SoftStart: Correction: 0.5 > 1 °C - (STABLE) Freq: 47Hz, SP_Final: 28°C
08/12 07:49:44 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 48Hz, SP_Final: 27.5°C
08/12 07:49:39 - Function SoftStart: Correction: 0.5 > 0.25 °C - (STABLE) Freq: 48Hz, SP_Final: 27.25°C
08/12 07:49:39 - MQTT Command - SetZ1HeatRequestTemperature: 28
08/12 07:49:39 - Function SoftStart: Correction: 0.25 > 0.5 °C - (STABLE) Freq: 48Hz, SP_Final: 27.5°C
08/12 07:48:34 - Function SoftStart: Correction: 0 > 0.25 °C - (STABLE) Freq: 48Hz, SP_Final: 27.25°C
08/12 07:47:34 - Function SoftStart: Correction: -0.5 > 0 °C - (STABLE) Freq: 47Hz, SP_Final: 27°C
08/12 07:47:24 - MQTT Command - SetZ1HeatRequestTemperature: 27
08/12 07:47:24 - Function SoftStart: Correction: -0.75 > -0.5 °C - (STABLE) Freq: 48Hz, SP_Final: 26.5°C
08/12 07:47:15 - Function SoftStart: Correction: -1.25 > -0.75 °C - (STABLE) Freq: 45Hz, SP_Final: 26.25°C
08/12 07:45:54 - MQTT Command - SetZ1HeatRequestTemperature: 26
08/12 07:45:54 - Function SoftStart: Correction: -2 > -1.25 °C - (STABLE) Freq: 34Hz, SP_Final: 25.75°C
08/12 07:42:54 - MQTT Command - SetZ1HeatRequestTemperature: 25
08/12 07:42:54 - Function SoftStart: Correction: 0 > -2 °C - (STARTUP) Freq: 20Hz, SP_Final: 25°C
08/12 07:42:54 - Compressor: is running now
08/12 07:04:18 - Function SoftStart: Compressor Inactive - Correction: 0
08/12 07:04:18 - Compressor: stopped
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
Fixed: Afbeeldingslocatie: https://tweakers.net/i/pcsUZRdbYNsS0FNrkuUWToL1jec=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/3PqnyaFgpeEwJd3Xxm6MvIYs.png?f=user_large
Thanks @Maarten69 !
  • Aikon
edterbak schreef op woensdag 30 november 2022 @ 20:06:
var current_sp          =global.get('Main_Target_Temp');                        // TOP27
    if (current_sp === undefined)   {return null;}
Regel 2 stond er niet. Nu wel.
Als hij geen waarde vond in 'Main_Target_Temp', dan ging de functie wel door met werken en liep hij verder op misschien de kans dat 'undefined' als 0 gezien word.
Dit kan spelen TOT dat de eerste mqtt opdracht binnen komt met een waarde in TOP27.
De waarde Main_Target_Temp wordt namelijk niet naar FILE geschreven maar naar geheugen.
Ik ben er inmiddels achter dat Z1 en main_target heel even op nul gaan bij het simpelweg stoppen en starten van NR. Iets in het opstarten van de flow wijzigt deze waarde dus. :)
  • edterbak
  • Laatst online: 05-09 21:53
Maarten69 schreef op donderdag 8 december 2022 @ 12:21:
Hmm.. Die vraag heb ik al gehad.
Ik heb de 2e fan al een keer er uit gesloopt..>>> resulteerde in commentaar (=verbeter suggestie)
Ik heb de 2e fan weer terug geduwd >>>>>>>> resulteerde in commentaar (=verbeter suggestie)
Om dit dynamisch te maken is lastig.
Ik kan wel een menu sectie maken met 2 fans, en een menu sectie maken met 1 fan.
Dan als de fan 2 een keer > 0 is, automatisch laten zien.
Zo niet, dan blijft hij verborgen.
Maar het vervelende aan die oplossing is, dat de locatie van die 1/2 fans dan random is. :'(
  • edterbak
Aikon schreef op donderdag 8 december 2022 @ 15:10:
Je ziet het dus nog steeds??
  • Aikon
edterbak schreef op donderdag 8 december 2022 @ 16:52:
Wat bedoel je precies? Als ik NR herstart wordt heel even Z1 en main_target op nul gezet, dat is wat ik zie ;) Dat zal af en toe voor problemen zorgen ben ik bang, als de oorzaak hiervan achterhaalt kan worden zal dat alleen maar de stabiliteit ten goede komen, of vage problemen voorkomen :)
[ Voor 26% gewijzigd door Aikon op 08-12-2022 17:40 ]
  • edterbak
Aikon schreef op donderdag 8 december 2022 @ 16:57:
Wat bedoel je precies? Als ik NR herstart wordt heel even Z1 en main_target op nul gezet, dat is wat ik zie ;) Dat zal af en toe voor problemen zorgen ben ik bang, als de oorzaak hiervan achter kan worden zal dat alleen maar de stabiliteit ten goede komen, of vage problemen voorkomen :)
Zie je dat in heishamon of in log van node red?
Pagina: 1 ... 40 ... 136 Laatste
