Itho Daalderop - open source wifi control add-on module
Pagina: 1 ... 17 ... 71 Laatste
  • arjenhiemstra
  • Laatst online: 12:22
banaliteit schreef op donderdag 27 januari 2022 @ 11:09:
Vandaag wilde ik weer naar de webpagina gaan van de Itho. Die was niet bereikbaar. Ik heb daarna met de Itho remote de ventilatie op stand 3 gezet en daarna weer terug op stand auto. Nu is de webpagina wel weer bereikbaar. Hoort dit? :)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
2022-01-27 09:56:50 N: Mode:STA
2022-01-27 09:56:50 N: Status:3
2022-01-27 09:56:50 N: IP:192.168.1.194
2022-01-27 09:56:50 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 09:56:51 N: MQTT: connected, System config: 1
2022-01-27 09:56:51 N: Webserver: started
2022-01-27 09:56:51 N: mDNS: started
2022-01-27 09:56:51 N: Hostname: nrg-itho-11aa
2022-01-27 09:56:52 N: Setup: done
2022-01-27 09:57:26 N: Error: Task SysControl timed out!
2022-01-27 09:57:34 N: System boot, last reset reason: SDIO_RESET
2022-01-27 09:57:34 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 09:57:38 N: WiFi: connection successful
2022-01-27 09:57:39 N: WiFi info:
2022-01-27 09:57:39 N: Mode:STA
2022-01-27 09:57:39 N: Status:3
2022-01-27 09:57:39 N: IP:192.168.1.194
2022-01-27 09:57:40 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 09:57:40 N: MQTT: connected, System config: 1
2022-01-27 09:57:40 N: Webserver: started
2022-01-27 09:57:40 N: mDNS: started
2022-01-27 09:57:40 N: Hostname: nrg-itho-11aa
2022-01-27 09:57:40 N: Setup: done
2022-01-27 09:58:15 N: Error: Task SysControl timed out!
2022-01-27 09:58:23 N: System boot, last reset reason: SDIO_RESET
2022-01-27 09:58:23 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 09:58:28 N: WiFi: connection successful
2022-01-27 09:58:28 N: WiFi info:
2022-01-27 09:58:28 N: Mode:STA
2022-01-27 09:58:28 N: Status:3
2022-01-27 09:58:28 N: IP:192.168.1.194
2022-01-27 09:58:28 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 09:58:28 N: MQTT: connected, System config: 1
2022-01-27 09:58:29 N: Webserver: started
2022-01-27 09:58:29 N: mDNS: started
2022-01-27 09:58:29 N: Hostname: nrg-itho-11aa
2022-01-27 09:58:29 N: Setup: done
2022-01-27 09:59:03 N: Error: Task SysControl timed out!
2022-01-27 09:59:12 N: System boot, last reset reason: SDIO_RESET
2022-01-27 09:59:12 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 09:59:16 N: WiFi: connection successful
2022-01-27 09:59:16 N: WiFi info:
2022-01-27 09:59:16 N: Mode:STA
2022-01-27 09:59:16 N: Status:3
2022-01-27 09:59:16 N: IP:192.168.1.194
2022-01-27 09:59:17 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 09:59:17 N: MQTT: connected, System config: 1
2022-01-27 09:59:17 N: Webserver: started
2022-01-27 09:59:18 N: mDNS: started
2022-01-27 09:59:18 N: Hostname: nrg-itho-11aa
2022-01-27 09:59:18 N: Setup: done
2022-01-27 09:59:52 N: Error: Task SysControl timed out!
2022-01-27 10:00:00 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:00:00 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:00:05 N: WiFi: connection successful
2022-01-27 10:00:05 N: WiFi info:
2022-01-27 10:00:05 N: Mode:STA
2022-01-27 10:00:05 N: Status:3
2022-01-27 10:00:05 N: IP:192.168.1.194
2022-01-27 10:00:05 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:00:06 N: MQTT: connected, System config: 1
2022-01-27 10:00:06 N: Webserver: started
2022-01-27 10:00:07 N: mDNS: started
2022-01-27 10:00:07 N: Hostname: nrg-itho-11aa
2022-01-27 10:00:07 N: Setup: done
2022-01-27 10:00:41 N: Error: Task SysControl timed out!
2022-01-27 10:00:50 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:00:50 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:00:54 N: WiFi: connection successful
2022-01-27 10:00:54 N: WiFi info:
2022-01-27 10:00:54 N: Mode:STA
2022-01-27 10:00:54 N: Status:3
2022-01-27 10:00:54 N: IP:192.168.1.194
2022-01-27 10:00:54 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:01:02 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:01:02 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:01:06 N: WiFi: connection successful
2022-01-27 10:01:07 N: WiFi info:
2022-01-27 10:01:07 N: Mode:STA
2022-01-27 10:01:07 N: Status:3
2022-01-27 10:01:07 N: IP:192.168.1.194
2022-01-27 10:01:07 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:01:08 N: MQTT: connected, System config: 1
2022-01-27 10:01:08 N: Webserver: started
2022-01-27 10:01:08 N: mDNS: started
2022-01-27 10:01:08 N: Hostname: nrg-itho-11aa
2022-01-27 10:01:08 N: Setup: done
2022-01-27 10:01:42 N: Error: Task SysControl timed out!
2022-01-27 10:01:51 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:01:51 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:01:55 N: WiFi: connection successful
2022-01-27 10:01:55 N: WiFi info:
2022-01-27 10:01:56 N: Mode:STA
2022-01-27 10:01:56 N: Status:3
2022-01-27 10:01:56 N: IP:192.168.1.194
2022-01-27 10:01:56 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:01:57 N: MQTT: connected, System config: 1
2022-01-27 10:01:57 N: Webserver: started
2022-01-27 10:01:57 N: mDNS: started
2022-01-27 10:01:57 N: Hostname: nrg-itho-11aa
2022-01-27 10:01:57 N: Setup: done
2022-01-27 10:02:31 N: Error: Task SysControl timed out!
2022-01-27 10:02:40 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:02:40 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:02:44 N: WiFi: connection successful
2022-01-27 10:02:44 N: WiFi info:
2022-01-27 10:02:44 N: Mode:STA
2022-01-27 10:02:44 N: Status:3
2022-01-27 10:02:44 N: IP:192.168.1.194
2022-01-27 10:02:45 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:02:45 N: MQTT: connected, System config: 1
2022-01-27 10:02:45 N: Webserver: started
2022-01-27 10:02:45 N: mDNS: started
2022-01-27 10:02:46 N: Hostname: nrg-itho-11aa
2022-01-27 10:02:46 N: Setup: done
2022-01-27 10:03:20 N: Error: Task SysControl timed out!
2022-01-27 10:03:29 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:03:30 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:03:34 N: WiFi: connection successful
2022-01-27 10:03:34 N: WiFi info:
2022-01-27 10:03:34 N: Mode:STA
2022-01-27 10:03:34 N: Status:3
2022-01-27 10:03:34 N: IP:192.168.1.194
2022-01-27 10:03:35 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:03:35 N: MQTT: connected, System config: 1
2022-01-27 10:03:35 N: Webserver: started
2022-01-27 10:03:35 N: mDNS: started
2022-01-27 10:03:35 N: Hostname: nrg-itho-11aa
2022-01-27 10:03:36 N: Setup: done
42493 N: Error: Task SysControl timed out!
2022-01-27 10:04:18 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:04:18 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:04:23 N: WiFi: connection successful
2022-01-27 10:04:23 N: WiFi info:
2022-01-27 10:04:23 N: Mode:STA
2022-01-27 10:04:23 N: Status:3
2022-01-27 10:04:23 N: IP:192.168.1.194
2022-01-27 10:04:24 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:04:24 N: MQTT: connected, System config: 1
2022-01-27 10:04:24 N: Webserver: started
2022-01-27 10:04:24 N: mDNS: started
2022-01-27 10:04:24 N: Hostname: nrg-itho-11aa
2022-01-27 10:04:25 N: Setup: done
2022-01-27 10:04:59 N: Error: Task SysControl timed out!
2022-01-27 10:05:07 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:05:07 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:05:11 N: WiFi: connection successful
2022-01-27 10:05:11 N: WiFi info:
2022-01-27 10:05:11 N: Mode:STA
2022-01-27 10:05:12 N: Status:3
2022-01-27 10:05:12 N: IP:192.168.1.194
2022-01-27 10:05:12 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:05:13 N: MQTT: connected, System config: 1
2022-01-27 10:05:13 N: Webserver: started
2022-01-27 10:05:13 N: mDNS: started
2022-01-27 10:05:13 N: Hostname: nrg-itho-11aa
2022-01-27 10:05:13 N: Setup: done
2022-01-27 10:05:47 N: Error: Task SysControl timed out!
2022-01-27 10:05:56 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:05:56 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:06:00 N: WiFi: connection successful
2022-01-27 10:06:00 N: WiFi info:
2022-01-27 10:06:00 N: Mode:STA
2022-01-27 10:06:01 N: Status:3
2022-01-27 10:06:01 N: IP:192.168.1.194
2022-01-27 10:06:01 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:06:01 N: MQTT: connected, System config: 1
2022-01-27 10:06:02 N: Webserver: started
2022-01-27 10:06:02 N: mDNS: started
2022-01-27 10:06:02 N: Hostname: nrg-itho-11aa
2022-01-27 10:06:02 N: Setup: done
2022-01-27 10:06:36 N: Error: Task SysControl timed out!
2022-01-27 10:06:45 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:06:45 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:06:49 N: WiFi: connection successful
2022-01-27 10:06:49 N: WiFi info:
2022-01-27 10:06:49 N: Mode:STA
2022-01-27 10:06:49 N: Status:3
2022-01-27 10:06:49 N: IP:192.168.1.194
2022-01-27 10:06:49 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:06:50 N: MQTT: connected, System config: 1
2022-01-27 10:06:50 N: Webserver: started
2022-01-27 10:06:50 N: mDNS: started
2022-01-27 10:06:50 N: Hostname: nrg-itho-11aa
2022-01-27 10:06:51 N: Setup: done
2022-01-27 10:07:25 N: Error: Task SysControl timed out!
2022-01-27 10:07:33 N: System boot, last reset reason: SDIO_RESET
2022-01-27 10:07:33 N: HW rev: 2, FW ver.: 2.3.5
2022-01-27 10:07:37 N: WiFi: connection successful
2022-01-27 10:07:38 N: WiFi info:
2022-01-27 10:07:38 N: Mode:STA
2022-01-27 10:07:38 N: Status:3
2022-01-27 10:07:38 N: IP:192.168.1.194
2022-01-27 10:07:38 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:07:39 N: MQTT: connected, System config: 1
2022-01-27 10:07:39 N: Webserver: started
2022-01-27 10:07:39 N: mDNS: started
2022-01-27 10:07:39 N: Hostname: nrg-itho-11aa
2022-01-27 10:07:39 N: Setup: done
Wat heb je nog meer nodig aan informatie voor de diagnose?
De stand van de itho zou geen invloed moeten hebben op de webinterface.
Deze meldingen:
Zouden niet voor moeten komen, samen met dat je itho versie niet bekend is doet mij vermoeden dat er iets in de itho firmware niet lekker gaat. Heb je de itho al een power cycle gegeven? Zo niet, zou je dat eens willen proberen?
  • banaliteit
arjenhiemstra schreef op donderdag 27 januari 2022 @ 11:19:
Deze meldingen:
2240 N: System boot, last reset reason: POWERON_RESET
2410 N: HW rev: 2, FW ver.: 2.3.5
6416 N: WiFi: connection successful
6595 N: WiFi info:
6789 N: Mode:STA
7123 N: Status:3
7303 N: IP:192.168.1.194
7433 N: Setup: Virtual remote ID: 107,68,172
2022-01-27 10:20:25 N: MQTT: connected, System config: 1
2022-01-27 10:20:25 N: Webserver: started
2022-01-27 10:20:25 N: mDNS: started
2022-01-27 10:20:25 N: Hostname: nrg-itho-11aa
2022-01-27 10:20:25 N: Setup: done
2022-01-27 10:20:32 N: I2C init: QueryDevicetype - fw:27 hw:27
2022-01-27 10:20:32 N: I2C init: QueryStatusFormat - items:12
2022-01-27 10:20:33 N: I2C init: QueryStatus
2022-01-27 10:20:33 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
Aan en uit - maar niet in die volgorde en de Itho status is weer beschikbaar. Hij reageert ook weer normaal.
Ik hoop wel dat we de oorzaak kunnen achterhalen of dat dit eenmalig is. :) Laat maar weten als je meer informatie nodig hebt.
  • gns1l
  • Registratie: Maart 2018
Met een föhn heb ik de temperatuursensoren getest. Daarvoor heb ik de WW uitgenomen en vervolgens de HRU op Low laten draaien.
De luchtstromen worden dan al zo dat de Exhaust en de Supply sensoren verschillende temperaturen aan blijven geven. Deze zijn ook echt verschillend.
Beide sensoren reageren op verwarmen. De Supply sensor geeft vrijwel hetzelfde aan als de IR thermometer. De Exhaust sensor geeft een te hoge waarde aan, maar lijkt te werken.
Nadat ik de WW weer gemonteerd had was ik vergeten de add-on te verwijderen. De HRU startte ditmaal zonder de ongezonde geluiden op.
  • Heijmenberg99
  • Laatst online: 23-10 20:16
Ik wil een bordje bestellen voor m’n nieuwe huis. Ik heb deze set: https://www.ithodaalderop...essional/product/03-00404
Gaat de module werken? @arjenhiemstra
[ Voor 5% gewijzigd door Heijmenberg99 op 28-01-2022 15:45 ]
  • arjenhiemstra
Heijmenberg99 schreef op vrijdag 28 januari 2022 @ 12:09:
Zeker, kort gezegd werken alle cve fans die je nu bij itho kunt kopen goed met de add-on
  • MadDog11
  • Laatst online: 09:39
Hallo @arjenhiemstra
Hier werkt het bordje al geruime tijd naar wens, standaard aangestuurd door middel van Homey, rules voor toiletbezoek, baderen en koken (als afzuigkap aan, dan Itho CVE hoog)
2 extra remotes gekoppeld via de Itho CVE WiFi controller, werkt ook perfect.
Mijn vraag is of deze RFT CO2 230V https://www.ithodaalderop...essional/product/04-00045 inmiddels aan de Itho CVE WiFi controller te koppelen is ?
  • Dave7
  • Laatst online: 19-01-2025
Hoe heb je de afzuigkap aan homey kunnen koppelen ?
  • arjenhiemstra
MadDog11 schreef op vrijdag 28 januari 2022 @ 17:34:
Ja! Sinds de 2.3 serie zit support voor de RFT CO2 en RFT RV in de firmware.
Een paar beperkingen:
  • Hij werkt als standaard remote, op CO2 waarde de add-on besturen zit er niet standaard in. Dat zul je dus via je domotica systeem moeten regelen op dit moment
  • Joinen werkt maar niet helemaal compleet. De waardes komen binnen op de add-on maar er wordt geen status verstuurd naar de CO2/RV sensor. (je kunt wel de CO2 sensor aan je itho gekoppeld laten als je de besturing verder prima vind. Dan monitor je alleen de CO2 waardes)
  • In de huidige firmware zitten nog niet de auto en autonacht commando's, dat komt in de volgende firmware versie waar ik nu mee bezig ben
  • MadDog11
Dave7 schreef op vrijdag 28 januari 2022 @ 18:19:
Gewoon via een slimme Zwave stekker, en gebruik altijd maar 1 stand om af te zuipen. Lampjes vervangen door andere Zigbee lampen zodat deze met de keuken verlichting op Hue mee schakelen.
  • MadDog11
arjenhiemstra schreef op vrijdag 28 januari 2022 @ 18:27:
Thx, dan wacht ik nog even met koppelen, gebruik die gewoon nog als backup
  • Hilus
  • Laatst online: 16:36
Wat een mooi product! Na een middagje fröbelen werkt het prima. Ik ben nogal beginner op dit vlak, maar met de verschillende instructies is het goed te doen.
Voor mij als noob op dit gebied: via de wiki-instructie heb ik in Domoticz (op Windows 11) de sensor voor RV en Temp toegevoegd, en de switch voor traploze instelling van de ventilatorsnelheid. Maar hoe maak je bijvoorbeeld een sensor aan waarmee je ventilatorsnelheid of -percentage uitleest?
  • jelgervanzaane
  • Laatst online: 30-07-2025
arjenhiemstra schreef op woensdag 26 januari 2022 @ 13:42:
Man man, wat een prijzen!
Als het nog kan, stuur de boel terug. Die itho is inderdaad behoorlijk oud, nog een wisselstroom motor model en werkt inderdaad helaas niet samen met de add-on.
De nieuwere itho’s verbruiken door toepassing gelijkstroom motor een stuk minder energie en op marktplaats vind je soms gloednieuwe voor 70 euro, soms zelfs incl. Remote.
Dat is denk ik uiteindelijk een goedkopere oplossing (mocht je het printje nog terug kunnen sturen)
Ik probeer hetzelfde als Robnocop. Op mijn ecofan 2 zit al een plaatje, verbonden met een 9 pins aansluiting. In de handleiding van het apparaat staat wel dat het een gelijkstroommotor heeft, daarom vraag ik het toch voor de zekerheid.
Klopt het dat mijn itho ventilatiebox te oud is voor gebruik met deze module? of is er een manier om deze toch aan te sluiten? hieronder een foto van de (vieze) printplaat
Afbeeldingslocatie: https://tweakers.net/i/_WFJaYyThAPfLjtCyawImG00E6g=/x800/filters:strip_icc():strip_exif()/f/image/InmI6AhRRH3tIgn96W3vPmGS.jpg?f=fotoalbum_large
en een foto zonder de geïnstalleerde module
Afbeeldingslocatie: https://tweakers.net/i/SLB0gbGvPPhHcfvdezE46DQpr-g=/x800/filters:strip_icc():strip_exif()/f/image/9nsnFVsmjLDWHR0jyp9Lms9m.jpg?f=fotoalbum_large
  • Onl1ne1373
  • Registratie: Januari 2017
  • Laatst online: 19-10 17:02
Hallo, bedankt voor dit mooie project!
Ik heb het eerste bordje voor de WPU met cc1101 op stroom gezet. MQTT geconfigureerd en ik zie de lwt online message. Losse afstandbediening ingeleerd op het bordje en de commando's ontvangt hij. Nu had ik eigenlijk verwacht dat er MQTT berichten zouden worden verstuurd als hij een command van de afstandsbediening zou krijgen of iets van een state verandering, maar ik zie niets anders dan lwt berichten.
Voor de duidelijkheid, dit is een test opstelling in m'n oude huis. Nieuwe huis is WPU + Spider AutoTemp + HRU ECO 300 DuoZone. WPU en AutoTemp wil ik direct gaan verbinden, HRU via rf.
  • jtonk
  • Laatst online: 14-05-2024
Ik heb net deze module ook op mijn itho CVE-S eco fan geinstalleerd appletje eitje. Een veel nettere en inzichtelijkere oplossing dan de esphome oplossing die ik eerder had, maar toch zijn er een aantal dingen nog onduidelijk voor mij.
Ik heb begrepen dat de fan op auto (relative luchtvochtigheids mode) om commando's te kunnen sturen.
1. betekent dit dat de ventilator altijd reageert op de relative luchtvochtigheid?
2. zo ja, hoe zet je dat uit?
3. zo nee, hoe zet je dat weer aan?
ik heb de Virtual remote geactiveerd.
ik begrijp overigens ook niet wat map RF remotes to virtual remotes zou moeten doen.
Als home automation draai ik Home Assistant en mijn doel is om in de nacht of afwezigheid de ventilator zo laag mogelijk te laten draaien en overdag op relative luchtvochtigheid (aan als er gedouched wordt) of een manuele override voor een tijdelijke hoge ventilatie (toilet).
kan iemand dit verduidelijken, de handleiding geeft dit niet duidelijk aan.
/////// EDIT ////////////
ergens in dit draadje vond ik het antwoord. De ingebouwde sensor heeft prioriteit, dus zal het toerental niet terug te draaien zijn als de box het nog te vochtig vindt. Enige manier om dit te omzeilen is door de ITHO uit de AUTO/MEDIUM stand te halen en naar LOW te zetten, maar ik zie niet zo snel hoe dat kan met de add-on. terugzetten naar MEDIUM kan weer wel. Zou toch moeten kunnen met de virtual remote.... nog even verder zoeken...
/////// EDIT 2//////////
De i2c virtual interface was blijkbaar niet gekoppeld, daarmee kan ik hem weer in LOW krijgen om de vochtigheids sensor te omzeilen.
[ Voor 37% gewijzigd door jtonk op 04-02-2022 15:31 ]
  • arjenhiemstra
Onl1ne1373 schreef op vrijdag 4 februari 2022 @ 11:55:
Bedoel je dat je de add-on niet aan een itho device hebt hangen maar alleen aan USB power?
Er worden namelijk allerlei zaken automatisch geconfigureerd op basis van het gedetecteerde itho apparaat. Veel functies werken niet als er geen itho aangesloten is (in de volgende firmware versie zal dat aangepast worden)
  • willemd
Ik gebruik sinds een maand de add-on op mijn CVE-S Optima-ventilator (met de ingebouwde co2- en rv-sensors) in combinatie met HA via MQTT. Ik heb er nog geen automations mee gemaakt, alleen puur even monitoren. (Want ik ben nog een newbie in HA.)
Heel af en toe crasht de add-on (of de verbinding met HA). Gemiddeld eens in de tien dagen denk ik.
In HA merk ik dat doordat de cijfers niet meer veranderen, of de status op unavailable staat:
Afbeeldingslocatie: https://i.imgur.com/Dff093h.jpg
Dit is uit het debug log uit de web-interface:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
2022-02-04 23:39:13 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:39:13 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:39:44 N: Setup: Wifi connect STA failed
2022-02-04 23:39:46 N: wifi AP mode started
2022-02-04 23:39:46 N: Setup: AP mode active
2022-02-04 23:39:46 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:39:54 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:39:54 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:39:57 N: WiFi: connection successful
2022-02-04 23:39:58 N: WiFi info:
2022-02-04 23:39:58 N: Mode:STA
2022-02-04 23:39:58 N: Status:3
2022-02-04 23:39:58 N: IP:192.168.9.19
2022-02-04 23:39:59 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:39:59 N: MQTT: connected, System config: 1
2022-02-04 23:39:59 N: Webserver: started
2022-02-04 23:39:59 N: mDNS: started
2022-02-04 23:39:59 N: Hostname: nrg-itho-3ff4
2022-02-04 23:39:59 N: Setup: done
2022-02-04 23:40:34 N: Error: Task SysControl timed out!
2022-02-04 23:40:42 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:40:42 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:41:13 N: Setup: Wifi connect STA failed
2022-02-04 23:41:15 N: wifi AP mode started
2022-02-04 23:41:15 N: Setup: AP mode active
2022-02-04 23:41:15 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:41:23 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:41:23 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:41:27 N: WiFi: connection successful
2022-02-04 23:41:27 N: WiFi info:
2022-02-04 23:41:27 N: Mode:STA
2022-02-04 23:41:27 N: Status:3
2022-02-04 23:41:27 N: IP:192.168.9.19
2022-02-04 23:41:27 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:41:28 N: MQTT: connected, System config: 1
2022-02-04 23:41:28 N: Webserver: started
2022-02-04 23:41:28 N: mDNS: started
2022-02-04 23:41:28 N: Hostname: nrg-itho-3ff4
2022-02-04 23:41:28 N: Setup: done
2022-02-04 23:42:03 N: Error: Task SysControl timed out!
2022-02-04 23:42:11 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:42:11 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:42:42 N: Setup: Wifi connect STA failed
2022-02-04 23:42:43 N: wifi AP mode started
2022-02-04 23:42:44 N: Setup: AP mode active
2022-02-04 23:42:44 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:42:51 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:42:52 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:42:55 N: WiFi: connection successful
2022-02-04 23:42:56 N: WiFi info:
2022-02-04 23:42:56 N: Mode:STA
2022-02-04 23:42:56 N: Status:3
2022-02-04 23:42:56 N: IP:192.168.9.19
2022-02-04 23:42:56 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:42:56 N: MQTT: connected, System config: 1
2022-02-04 23:42:57 N: Webserver: started
2022-02-04 23:42:57 N: mDNS: started
2022-02-04 23:42:57 N: Hostname: nrg-itho-3ff4
2022-02-04 23:42:57 N: Setup: done
2022-02-04 23:43:31 N: Error: Task SysControl timed out!
2022-02-04 23:43:40 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:43:40 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:44:11 N: Setup: Wifi connect STA failed
2022-02-04 23:44:12 N: wifi AP mode started
2022-02-04 23:44:12 N: Setup: AP mode active
2022-02-04 23:44:13 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:44:20 N: System boot, last reset reason: SDIO_RESET
2022-02-04 23:44:20 N: HW rev: 2, FW ver.: 2.3.5
2022-02-04 23:44:24 N: WiFi: connection successful
2022-02-04 23:44:24 N: WiFi info:
2022-02-04 23:44:25 N: Mode:STA
2022-02-04 23:44:25 N: Status:3
2022-02-04 23:44:25 N: IP:192.168.9.19
2022-02-04 23:44:25 N: Setup: Virtual remote ID: 107,63,244
2022-02-04 23:44:26 N: MQTT: connected, System config: 1
2022-02-04 23:44:26 N: Webserver: started
2022-02-04 23:44:26 N: mDNS: started
2022-02-04 23:44:26 N: Hostname: nrg-itho-3ff4
2022-02-04 23:44:26 N: Setup: done
      2276 N: System boot, last reset reason: POWERON_RESET
      2607 N: HW rev: 2, FW ver.: 2.3.5
     33323 N: Setup: Wifi connect STA failed
     34997 N: wifi AP mode started
     35115 N: Setup: AP mode active
     35244 N: Setup: Virtual remote ID: 107,63,244
     35551 N: I2C init: QueryDevicetype - fw:27 hw:27
     35815 N: I2C init: QueryStatusFormat - items:12
     36051 N: I2C init: QueryStatus
     53680 N: MQTT: connection failed, System config: 1
     53873 N: Webserver: started
     54211 N: mDNS: started
     54371 N: Hostname: nrg-itho-3ff4
     54490 N: Setup: done
     88831 N: Error: Task MQTT timed out!
    935007 N: Reboot requested
      2256 N: System boot, last reset reason: SDIO_RESET
      2427 N: HW rev: 2, FW ver.: 2.3.5
      6245 N: WiFi: connection successful
2022-02-05 00:00:40 N: WiFi info:
2022-02-05 00:00:40 N: Mode:STA
2022-02-05 00:00:41 N: Status:3
2022-02-05 00:00:41 N: IP:192.168.9.19
2022-02-05 00:00:41 N: Setup: Virtual remote ID: 107,63,244
2022-02-05 00:00:41 N: MQTT: connected, System config: 1
2022-02-05 00:00:41 N: Webserver: started
2022-02-05 00:00:41 N: mDNS: started
2022-02-05 00:00:41 N: Hostname: nrg-itho-3ff4
2022-02-05 00:00:42 N: Setup: done
2022-02-05 00:00:49 N: I2C init: QueryDevicetype - fw:27 hw:27
2022-02-05 00:00:49 N: I2C init: QueryStatusFormat - items:12
2022-02-05 00:00:50 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
2022-02-05 06:00:34 N: Mem free: 131136, Mem low: 85860, Mem block: 59320
Aan het eind zie je dat ik hem gereset heb door even de stroom van de box af te halen. Tegelijk heb ik HA ook maar even opnieuw gestart. Voorlopig doet hij het weer prima.
Mijn wifi is voor zover ik weet stabiel, en het access point hangt op twee meter van de box, dus bereik zal ook geen probleem zijn. De add-on draait versie 2.3.5.
Dit is de info over de box zelf: Itho device type: CVE-Silent. Itho fw version: 27
Is dit een bekend fenomeen? Is er een oplossing? Kan ik verder helpen een oplossing te vinden?
  • DiyMichael
  • Registratie: Februari 2022
  • Laatst online: 20-02 14:38
Goedemorgen,
Sinds gister in het bezig van een non-cve add-on module.
Alles lijk te werken. De status gegevens komen netjes binnen in HA MQTT werkt I2c staat op connect.
Alleen reageert de ventilatie box niet op de snelheden.
Ik heb een HRU ECO RFT LE
iemand enig idee wat dit kan zijn?
onderstaand mijn log file:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
2022-02-04 15:02:38 N: I2C init: QueryDevicetype - fw:0 hw:0
      2184 N: System boot, last reset reason: POWERON_RESET
      2249 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2453 N: wifi config saved
      2608 N: Setup: Wifi config load failed
      2312 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2478 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2645 N: Setup: Wifi config load failed
      2274 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2437 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2790 N: Setup: Wifi config load failed
      2328 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2523 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2663 N: Setup: Wifi config load failed
      2205 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2326 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2555 N: Setup: Wifi config load failed
      2250 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2413 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2701 N: Setup: Wifi config load failed
      4605 N: wifi AP mode started
      4838 N: Setup: AP mode active
      4935 N: Setup: Virtual remote ID: 107,66,72
      5049 N: Webserver: started
      5173 N: mDNS: started
      5306 N: Hostname: nrg-itho-4248
      5449 N: Setup: done
     15183 N: I2C init: QueryDevicetype - fw:11 hw:3
     15436 N: I2C init: QueryStatusFormat - items:22
     15674 N: I2C init: QueryStatus
    183303 N: wifi config saved
    424991 N: Error: Task MQTT timed out!
    470101 N: Reboot requested
      2261 N: System boot, last reset reason: SDIO_RESET
      2424 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
     33290 N: Setup: Wifi connect STA failed
     35025 N: wifi AP mode started
     35269 N: Setup: AP mode active
     35368 N: Setup: Virtual remote ID: 107,66,72
     35494 N: Setup: init of CC1101 RF module successful
     35621 N: I2C init: QueryDevicetype - fw:11 hw:3
     35858 N: I2C init: QueryStatusFormat - items:22
     36063 N: I2C init: QueryStatus
     53753 N: MQTT: connection failed, System config: 1
     53918 N: Webserver: started
     54094 N: mDNS: started
     54278 N: Hostname: nrg-itho-4248
     54520 N: Setup: done
     88881 N: Error: Task MQTT timed out!
      2203 N: System boot, last reset reason: TG0WDT_SYS_RESET
      2340 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      6511 N: WiFi: connection successful
      6651 N: WiFi info:
      6801 N: Mode:STA
      6967 N: Status:3
      7143 N: IP:192.168.178.59
      7321 N: Setup: Virtual remote ID: 107,66,72
      7542 N: Setup: init of CC1101 RF module successful
     12744 N: MQTT: connected, System config: 1
     12873 N: Webserver: started
     13003 N: mDNS: started
     13138 N: Hostname: nrg-itho-4248
     13285 N: Setup: done
2022-02-05 15:57:41 N: I2C init: QueryDevicetype - fw:11 hw:3
2022-02-05 15:57:41 N: I2C init: QueryStatusFormat - items:22
2022-02-05 15:57:42 N: I2C init: QueryStatus
      2392 N: System boot, last reset reason: TG0WDT_SYS_RESET
      2532 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      6613 N: WiFi: connection successful
      6734 N: WiFi info:
      6863 N: Mode:STA
      7004 N: Status:3
      7146 N: IP:192.168.178.59
      7305 N: Setup: Virtual remote ID: 107,66,72
      2262 N: System boot, last reset reason: SW_RESET
      2449 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2339 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2447 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      7937 N: WiFi: connection successful
      8059 N: WiFi info:
      8197 N: Mode:STA
      8342 N: Status:3
      8498 N: IP:192.168.178.59
      8659 N: Setup: Virtual remote ID: 107,66,72
      8851 N: Setup: init of CC1101 RF module successful
      2278 N: System boot, last reset reason: SW_RESET
      2498 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      6694 N: WiFi: connection successful
      6818 N: WiFi info:
      6948 N: Mode:STA
      7082 N: Status:3
      7233 N: IP:192.168.178.59
      7395 N: Setup: Virtual remote ID: 107,66,72
      7584 N: Setup: init of CC1101 RF module successful
     12238 N: MQTT: connected, System config: 1
     12440 N: Webserver: started
     12713 N: mDNS: started
     12807 N: Hostname: nrg-itho-4248
     12916 N: Setup: done
     15161 N: I2C init: QueryDevicetype - fw:11 hw:3
     15394 N: I2C init: QueryStatusFormat - items:22
     15605 N: I2C init: QueryStatus
2022-02-05 16:04:36 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
2022-02-05 16:18:27 N: Reboot requested
2022-02-05 16:18:28 N: System boot, last reset reason: SDIO_RESET
2022-02-05 16:18:28 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
2022-02-05 16:18:32 N: WiFi: connection successful
2022-02-05 16:18:32 N: WiFi info:
2022-02-05 16:18:32 N: Mode:STA
2022-02-05 16:18:32 N: Status:3
2022-02-05 16:18:33 N: IP:192.168.178.59
2022-02-05 16:18:33 N: Setup: Virtual remote ID: 107,66,72
2022-02-05 16:18:33 N: Setup: init of CC1101 RF module successful
2022-02-05 16:18:33 N: MQTT: connected, System config: 1
2022-02-05 16:18:33 N: Webserver: started
2022-02-05 16:18:37 N: mDNS: started
2022-02-05 16:18:37 N: Hostname: nrg-itho-4248
2022-02-05 16:18:37 N: Setup: done
2022-02-05 16:18:45 N: I2C init: QueryDevicetype - fw:11 hw:3
2022-02-05 16:18:45 N: I2C init: QueryStatusFormat - items:22
2022-02-05 16:18:46 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
      2280 N: System boot, last reset reason: POWERON_RESET
      2575 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2189 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2300 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2212 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2343 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2234 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2394 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2263 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2452 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2346 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2450 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      2203 N: System boot, last reset reason: RTCWDT_SYS_RESET
      2331 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
      6603 N: WiFi: connection successful
      6752 N: WiFi info:
      6906 N: Mode:STA
      7073 N: Status:3
      7257 N: IP:192.168.178.59
      7445 N: Setup: Virtual remote ID: 107,66,72
      7676 N: Setup: init of CC1101 RF module successful
      7787 N: MQTT: connected, System config: 1
      7921 N: Webserver: started
      8053 N: mDNS: started
      8187 N: Hostname: nrg-itho-4248
      8332 N: Setup: done
2022-02-05 16:32:40 N: I2C init: QueryDevicetype - fw:11 hw:3
2022-02-05 16:32:41 N: I2C init: QueryStatusFormat - items:22
2022-02-05 16:32:41 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
2022-02-05 22:32:25 N: Mem free: 128452, Mem low: 85120, Mem block: 59320
2022-02-06 04:32:25 N: Mem free: 129288, Mem low: 85120, Mem block: 59320
2022-02-06 09:05:48 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
2022-02-06 09:28:25 N: System boot, last reset reason: OWDT_RESET
2022-02-06 09:28:26 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
2022-02-06 09:28:30 N: WiFi: connection successful
2022-02-06 09:28:30 N: WiFi info:
2022-02-06 09:28:30 N: Mode:STA
2022-02-06 09:28:30 N: Status:3
2022-02-06 09:28:30 N: IP:192.168.178.59
2022-02-06 09:28:30 N: Setup: Virtual remote ID: 107,66,72
2022-02-06 09:28:31 N: Setup: init of CC1101 RF module successful
2022-02-06 09:28:31 N: MQTT: connected, System config: 1
2022-02-06 09:28:31 N: Webserver: started
2022-02-06 09:28:31 N: mDNS: started
2022-02-06 09:28:31 N: Hostname: nrg-itho-4248
2022-02-06 09:28:31 N: Setup: done
2022-02-06 09:28:38 N: I2C init: QueryDevicetype - fw:11 hw:3
2022-02-06 09:28:39 N: I2C init: QueryStatusFormat - items:22
2022-02-06 09:28:39 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
2022-02-06 09:29:10 N: Reboot requested
2022-02-06 09:29:14 N: System boot, last reset reason: SDIO_RESET
2022-02-06 09:29:15 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
2022-02-06 09:29:19 N: WiFi: connection successful
2022-02-06 09:29:19 N: WiFi info:
2022-02-06 09:29:19 N: Mode:STA
2022-02-06 09:29:19 N: Status:3
2022-02-06 09:29:20 N: IP:192.168.178.59
2022-02-06 09:29:20 N: Setup: Virtual remote ID: 107,66,72
2022-02-06 09:40:06 N: Setup: init of CC1101 RF module successful
2022-02-06 09:40:06 N: MQTT: connected, System config: 1
2022-02-06 09:40:06 N: Webserver: started
2022-02-06 09:40:06 N: mDNS: started
2022-02-06 09:40:06 N: Hostname: nrg-itho-4248
2022-02-06 09:40:07 N: Setup: done
2022-02-06 09:40:14 N: I2C init: QueryDevicetype - fw:11 hw:3
2022-02-06 09:40:14 N: I2C init: QueryStatusFormat - items:22
2022-02-06 09:40:14 N: HA DISCOVERY: Start publishing MQTT Home Assistant Discovery...
  • smesjz
Virtual remote al gekoppeld?
  • DiyMichael
@smesjz Ja stom overheen gelezen dank je. Hij reageert nu via de debug knoppen in ieder geval. maar nog niet via de MQTT berichten vanuit HA.
  • Onl1ne1373
arjenhiemstra schreef op zaterdag 5 februari 2022 @ 01:08:
Klopt, alleen aan usb stroom. Ik hoopte dat ik dan via de cc1101 de afzuig kon aansturen en de state kon weten in Home Assistant.
Ik heb de virtual remote aangezet en zie dat hij in de debug log een id krijgt, maar mijn afzuig wil hem helaas niet pakken. Een losse afstandsbediening koppelen was geen probleem.
Wat ik wel apart vind is dat de setting “Send join command on next power on” aan blijft staan na power cycle en restart.
Het zou mooi zijn als ik een bordje zou kunnen gebruiken op usb stroom die alleen de cc1101 gebruikt voor het aansturen van de afzuig en die de state vasthoudt en doorgeeft aan mqtt. Maar als hij echt aan een itho apparaat met service tool interface moet hangen is dat in mijn volgende huis ook geen probleem. Maar aangezien ik straks een niet ondersteunde HRU Eco 300 heb zou de state en mogelijkheid tot aansturen fantastisch zijn via de cc1101.
  • arjenhiemstra
Onl1ne1373 schreef op zondag 6 februari 2022 @ 12:28:
Op dit moment werkt het dus alleen als je de module aan je itho hangt.
Als je even een PB stuurt met je email adres dan zorg ik dat je een een tijdelijke firmware krijgt waar je de module alleen aan de stroom kunt hangen (was er toevallig voor iemand onlangs mee bezig).
De huidige firmware logt elke 5 seconden dat er geen itho is gevonden en dat is niet zo handig voor de levensduur van het flash geheugen...
Dan werkt overigens alleen nog het ontvangen van RF berichten, het versturen kan technisch wel maar zit (nog) niet in de firmware omdat alle communicatie ook mogelijk is via de I2C bus / service interface. Ik ben nu bezig met het uitbreiden van de virtual remote commands, waarschijnlijk is het hiermee ook vrij eenvoudig mogelijk dit door te koppelen naar de CC1101 module. Dat zal ik alleen niet binnen een paar weken klaar hebben vrees ik.
Je moet een join gegeven binnen 2 minuten na inschakelen van je itho. Eventueel via de debug pagina als het niet lukt met “Send join command on next power on”.
  • arjenhiemstra
willemd schreef op zaterdag 5 februari 2022 @ 12:23:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
Het lijkt erop dat de I2C bus / itho firmware vastloopt. Misschien een proberen de update frequentie wat naar beneden bij te stellen? (staat standaard op 5 sec., naar bijvoorbeeld 30 seconden oid). Wellicht is het wat te druk op de I2C bus met ook de CO2 module erbij. Heb die situatie nog niet uitgebreid kunnen testen.
  • willemd
arjenhiemstra schreef op zondag 6 februari 2022 @ 12:44:
Top! Ga ik proberen!
  • DiyMichael
Goedemiddag,
Als ik via HA een MQTT bericht stuur met een snelheid dan krijg ik een lastcmd bericht met de juiste snelheid terug:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
Bericht 984 ontvangen op itho/lastcmd om 13:59:
    "source": "MQTT API",
    "command": "speed:120",
    "timestamp": 1644152373
QoS: 0 - Retain: false
Bericht 983 ontvangen op itho/remotesinfo om 13:59:
Bericht 982 ontvangen op itho/ithostatus om 13:59:
    "Speed status": 26.5,
    "Internal fault": 0,
    "Frost cycle": 0,
    "Filter dirty": 0,
    "Requested speed (%)": 30,
    "Balance (%)": 69.8,
    "Supply requested (rpm)": 1283,
    "Supply actual (rpm)": 1288,
    "Drain requested (rpm)": 1840,
    "Drain actual (rpm)": 1850,
    "Temp of supply air (°C)": 20.39,
    "Temp of exhaust air (°C)": 14.23,
    "Status": 0,
    "room temp (°C)": 20.39,
    "Outdoor temp (°C)": 14.23,
    "Valve position (pulse)": 0,
    "Bypass position (pulse)": 0,
    "summer counter": 0,
    "Summer day": 0,
    "Frost timer (sec)": 0,
    "boiler timer (min)": 177,
    "Frost lock": 121,
    "Current pos": 0,
    "VKK switch": 0,
    "GHE switch": 0,
    "Air filter counter": 22
Bericht 981 ontvangen op itho/cmd om 13:59:
medium
Alleen verandert de HRU niet van snelheid.
weet iemand wat dit kan zijn?
[ Voor 59% gewijzigd door DiyMichael op 06-02-2022 14:00 ]
  • arjenhiemstra
DiyMichael schreef op zondag 6 februari 2022 @ 13:44:
Goedemiddag,
Bericht 954 ontvangen op itho/lastcmd om 13:40:
    "command": "speed:220",
    "timestamp": 1644150914
het speed commando werkt alleen op CVE units (en de HRU200 omdat deze eigenlijk een CVE on steroids is)
Je moet voor HRU en DemandFlow de virtual remote gebruiken
Zie ook hier:
https://github.com/arjenh...#how-to-control-the-speed
  • DiyMichael
@arjenhiemstra ik heb in mijn eerder bericht een aanpassing gedaan in de MQTT berichten.
ik stuur een bericht low, medium of high en krijgt die speed: terug is dat niet goed?
  • DiyMichael
deze code gebruik ik in HA:
29
30
fan:
  - platform: mqtt
    unique_id: "Itho_Fan"
    state_topic: "itho/lwt"
    state_value_template: "{% if value == 'online' %}ON{% else %}OFF{% endif %}"
    command_topic: "itho/cmd"
    preset_mode_state_topic: "itho/ithostatus"
    preset_mode_value_template: >
        {% set am = value_json.Actual_Mode | int %}
          {% if am == 1 %}
            low
          {% elif am == 2 %}
            medium
          {% elif am == 3 %}
            high
          {% elif am == 24 %}
            auto
          {% else %}
            {{ am }}
          {% endif %}
    preset_mode_command_topic: "itho/cmd"
    preset_modes:
       - "low"
       - "medium"
       - "high"
       - "auto"
       - "timer1"
       - "timer2"
       - "timer3"
  • smesjz
Deze verwacht een Actual Mode maar jouw device ondersteunt dat niet. In je Home Assistant logs moet je meldingen over zien. Op basis van die Actual Mode krijg je nl. altijd de goede waarde terug omdat je WTW ook nog steeds via fysieke remotes handmatig kan bedienen of wanneer er tijdsgestuurde veranderingen op zitten.
Dit werkt prima bij een HRU350 maar voor jouw device heb je waarschijnlijk iets anders nodig.
  • DiyMichael
Goedeavond,
Het aansturen is geluk :-). @arjenhiemstra @smesjz Bedank voor het sturen in de juiste richting.
Heb er een regel aan toe gevoegd voor de vremote.
[preset_mode_command_template: "{ vremote: '{{ value }}'}"
In Ha geeft hij alleen nog niet aan in welke stand hij draait.
Omdat mijn unit geen actual mode terug geeft wil ik graag Requested_speed_(%) gebruiken. Deze geeft de waardes 0 bij low, 30 bij medium en 100 bij high.
Het probleem is dat er nu een error komt vanwege het % teken. iemand een idee om dit op te lossen.
Ik heb het voor de test met een andere waarde geprobeerd zonder het (%) en dat werk dus de yaml code klopt verder.
Invalid config for [fan.mqtt]: invalid template (TemplateSyntaxError: unexpected '%') for dictionary value @ data['preset_mode_value_template'].
Got '{% set am = value_json.Requested_speed_(%) | int %}\n {% if am == 0 %}\n low\n {% elif am == 30 %}\n medium \n {% elif am == 100 %}\n high\n {% elif am == 24 %}\n auto\n {% else %}\n {{ am }}\n {% endif %}\n'. (See ?, line ?).
29
30
31
fan:
  - platform: mqtt
          {% if am == 0 %}
            low
          {% elif am == 30 %}
            medium
            high
          {% elif am == 24 %}
            auto
          {% else %}
            {{ am }}
          {% endif %}
    preset_modes:
       - "low"
       - "medium"
       - "high"
       - "auto"
       - "timer1"
       - "timer2"
       - "timer3"
Iemand een idee hoe HA het (%) gedeelte wel accepteert?
  • smesjz
value_json[“Requested_speed_(%)”] zou moeten werken
  • DiyMichael
Bedankt voor de snelle reactie.
Helaas geeft HA nog steeds een error:
Invalid config for [fan.mqtt]: invalid template (TemplateSyntaxError: unexpected char '“' at 24) for dictionary value @ data['preset_mode_value_template']. Got '{% set am = value_json.[“Requested_speed_(%)”] | int %}\n {% if am == 0 %}\n low\n {% elif am == 30 %}\n medium \n {% elif am == 100 %}\n high\n {% elif am == 24 %}\n auto\n {% else %}\n {{ am }}\n {% endif %}\n'. (See ?, line ?).
  • smesjz
DiyMichael schreef op vrijdag 11 februari 2022 @ 21:58:
value_json['Requested_speed_(%)'] , dus zonder punt na value_json en enkele quotes
  • DiyMichael
Weer bedankt voor de snelle reactie!
Top geen error meer maar nu krijgt HA er geen waarde uit.
Heb even een Sensor aangemaakt met deze regel en daar komt ook geen waarde.
Ga er van het weekend even hiermee stoeien hopen dat het lukt.
  • S0epkip
  • Laatst online: 23-10 14:44
Hmmmm mijn Itho CVE start volgens mij niet op als ik de add-on toevoeg, alleen de Itho status LED knippert zwakjes:
Zonder add-on start hij wel gewoon op:
Wat betekent deze error?
Nog wat foto's van de box:
Afbeeldingslocatie: https://tweakers.net/i/ny5Vk0dYUprnF9Fvcxgbre_1240=/x800/filters:strip_icc():strip_exif()/f/image/sBX7tkwFd7iSeDJxoliiHrz1.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/EC-wJAFy50d6xfSAmZ1KtE9MhpI=/800x/filters:strip_icc():strip_exif()/f/image/7cmh00D3K8MJblnRYzKqciLL.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/KrWzOmHCNn2jVJkVn2xsp8W00PI=/800x/filters:strip_icc():strip_exif()/f/image/L6kqoRXOoGQ18Tg68VsRc81C.jpg?f=fotoalbum_large
[ Voor 61% gewijzigd door S0epkip op 13-02-2022 10:03 ]
PVO
  • arjenhiemstra
S0epkip schreef op zondag 13 februari 2022 @ 10:01:
[YouTube: itho cve add on]
[YouTube: itho CVE zonder add-on]
Heeft ie het eerder wel gedaan? Het lijkt erop dat de voeding van de itho niet voldoende vermogen kan leveren voor de add-on. Dat is vreemd want dit type itho heeft een prima voeding.
Kan 2 dingen betekenen:
1. de add-on heeft een issue waardoor het opstarten niet goed gaat (vraagt teveel stroom oid door kapot component bijvoorbeeld)
2. Je itho is niet helemaal lekker waardoor de voeding tegen zijn grenzen aan zit
  • S0epkip
arjenhiemstra schreef op zondag 13 februari 2022 @ 10:52:
Nope, eerste keer geïnstalleerd.
Wat kan ik nog proberen?
PVO
  • muppet99
  • Laatst online: 19-10 15:26
Je kan de pinnen voor spanning even aansluiten op een alternatieve spanningsbron. Kijken of hij dan wel opkomt.
Carpe Diem
  • brammh
  • Laatst online: 11:41
Ik krijg het nog niet werkend met deze mooie Non-CVE module. Heb een demand flow systeem, en kan de status prima uitlezen, maar geen response op een low/medium/high vremote of I2C command, nope/nada/niks.
Probeer nu wat te debuggen, en met de standaard remote proberen de status te veranderen en kijken wat er gebeurd. Maar die remote ben ik dus kwijt. Heb nu een andere remote met de [A] knop, die ik probeer toe te voegen, maar dat werkt niet met de beschreven procedure van ITHO.
Vraag, kan ik de RF remote met de [A] knop gebruiken als default remote, of moet ik echt die remote met het 'pannetje' hebben om als default te gebruiken?
De vremote join bij reboot optie staat 'on', evenals het medium force bericht, en map rf remotes naar virtual.
Log:
2251 N: System boot, last reset reason: POWERON_RESET
2427 N: HW rev: NON-CVE 1, FW ver.: 2.3.5
6438 N: WiFi: connection successful
6621 N: WiFi info:
6919 N: Mode:STA
7032 N: Status:3
2022-02-13 13:29:50 N: IP:192.168.0.81
2022-02-13 13:29:50 N: Setup: Virtual remote ID: 107,66,60
2022-02-13 13:29:50 N: Setup: init of CC1101 RF module successful
2022-02-13 13:29:50 N: MQTT: connected, System config: 1
2022-02-13 13:29:51 N: Webserver: started
2022-02-13 13:29:51 N: mDNS: started
2022-02-13 13:29:51 N: Hostname: Nrg_Itho
2022-02-13 13:29:51 N: Setup: done
2022-02-13 13:29:58 N: I2C init: QueryDevicetype - fw:13 hw:11
2022-02-13 13:29:58 N: I2C init: QueryStatusFormat - items:61
2022-02-13 13:29:58 N: I2C init: Virtual remote join command send
Daarnaast heeft de Non-CVE module de fysieke remote (met de [A]) toegevoegd onder RF Remotes met ID: 116,200,239
Iemand tips? Zou graag zelf de itho aansturen, de control settings van Itho zijn echt dramatisch (veel te laat afzuigen als het vochtig is, en geen zachte modus voor in de nacht).
thanks!
  • S0epkip
Het bleek de externe RV-sensor te zijn!
Ik heb de add-on correct kunnen starten zonder sensor.
Vervolgens basic setup gedaan, sensor in de software aangezet, sensor aangesloten; en hoppa! Werkt :)
Afbeeldingslocatie: https://tweakers.net/i/2vYHFNIZN6U3nXbJJAbN4l31J_A=/800x/filters:strip_exif()/f/image/LNru1dPI0R677e6WpvHy4Aom.png?f=fotoalbum_large
Ik heb - vind ik zelf - ook een geniale plaats gevonden voor de RV-sensor. Deze kun je precies bij het mounting bracket van je Itho PCB-houder naar binnen prikken! 8)
Afbeeldingslocatie: https://tweakers.net/i/DtEu9dMYf3J6TpJ1Kkj8pc6Jljo=/800x/filters:strip_icc():strip_exif()/f/image/J107Cj7OWYez8pK1e4vsJJHP.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/sZuDBfSqjkpCDx6AItLwE1enHOM=/800x/filters:strip_icc():strip_exif()/f/image/6yJF3ALY9Pv5tiDtDnhGorCk.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/b-nxkbm01exr7poamM4yiXEWmxk=/800x/filters:strip_icc():strip_exif()/f/image/IOtnvNkKy02yYmk06oDsTqSL.jpg?f=fotoalbum_large
PVO
  • arjenhiemstra
S0epkip schreef op maandag 14 februari 2022 @ 13:29:
Ah, toch nog een optie 3 dus! Nice dat je het gevonden hebt.
Was de sensor niet goed aangesloten?
  • FutureCow
FutureCow
(C) FutureCow
Misschien even een beetje off-topic vraagje hier. Ik heb nu een jaar of 12 de Itho ECO Fan (blauwe kap) en bestuur ik via de add-on WiFi module.
Na een aantal jaren heb ik de MV afzuigbuis in de woonkamer weer hersteld (bij een nieuwe keuken is deze ooit weggehaald...)
Nu moet ik wel een beetje wennen aan het geluid. Op Low (20) is een een zachte wat lage brom te horen. Wellicht dat dit gewoon hoort, maar na jaren zonder geluid, valt het extra op...
Op andere standen is het uiteraard nog luider te horen, maar vooral het lagere geluid overstemt dan.
Ik zit dus te twijfelen om de box te vervangen, maar alleen als ik zeker weet dat de nieuwe box minder/geen geluid maakt bij Low. Is de Itho CVE-S Eco dan een beste oplossing? Of zijn er stillere boxen(waar de add-on module natuurlijk op passen) Of zijn er hele andere oplossingen?
  • eymey
  • Laatst online: 23-10 13:25
Net als @FutureCow vind ik dit eigenlijk ook wel een interessant vraagstuk. Al vrees ik een beetje dat het eigenlijk inherent is aan het 'basisplatform' van alle Itho boxen dat ze zo 'brommerig' zijn.
Ook onze oudere box uit 2012 (uitgerust met Arjen z'n module) bromt er flink op los, irritant genoeg juist op de lagere standen. In het 'middengebied' (van 90 tot en met 130) zijn er standen waar de resonantie grotendeels weg valt en het windgeruis ook op acceptabel niveau is (de middenstand hebben we nu op 108 staan, en dat is eigenlijk waar we hem in principe ook 24/7 op hebben). LOW staat nu op 20.
Onder bepaalde omstandigheden (stand van roosters van ramen? Wind? ) wil 108 ook nog wel eens irritant klinken in de nacht en zet m'n vriendin hem alsnog naar LOW.
Ik zou er ook een nieuwe box voor over hebben als deze niet zo brommerig zou zijn, maar vraag me af of je die uberhaupt bij Itho zal vinden.....
Marstek Venus 5.12kWh v154, CT002 V118, CT003 V118 DSMR5.5, PV 11xEnphase IQ7+ Z-O, 5xEnphase IQ7+ N-W - ~4,7Wp theoretisch, ~3,5Wp praktijk.
  • arjenhiemstra
Ik heb hier 4 verschillende itho's staan om te testen, van de oudere modellen tot de laatste uitvoering. Ik heb niet het idee dat er een wezenlijk verschil is de geluidsproductie en de toonhoogte van het geluid. De constructie van de motor en waaier lijken ook precies hetzelfde te zijn.
Enige optie waaraan ik zat de denken is de dakuitvoering van itho, de CVD-S ECO. Is alleen een beetje een duur ding zie ik net.
  • barteg
  • Laatst online: 12:00
FutureCow schreef op maandag 14 februari 2022 @ 21:03:
Ik heb 11 jaar zo'n Itho fan met blauwe kap gehad. Deze kon ik altijd horen bij de afzuigings kanalen op midden en hoog stand. Afgelopen kerst heb ik deze vervangen door een Itho HRU 350. Ik heb dezelfde afvoer kanalen gebruikt echter nu met geluidsdempers. Nu kan ik de unit in het geheel niet meer horen. Zelfs op de hoogste stand kan ik alleen maar heel zacht het geluid van stroomende lucht horen. Niet de unit zelf. Voor mijn gevoel produceerd de nieuwe unit echt niet minder geluid. Zeker niet als je er naast staat.
Ecodan 7,5Kw - 4000wp Solar - Itho HRU 350
  • Ittie
  • Laatst online: 23-10 20:21
Laten we beginnen met het feit dat de WiFi control add-on een super toevoeging is voor een huisautomatisering. Thanks voor alle inzet @arjenhiemstra !
Recentelijk zat ik te grasduinen in de Home Assistant database om te kijken wie nou het meest in de database zette en wat denk je de Itho WiFI controller is goed vertegenwoordigd in de top 10.
Eerlijk gezegd erg vertegenwoordigd, op nummer 1 de fan en de extra temp & hum sensor op 3 & 10
De fan staat op 1 met de volgende stats:
  • count van 175090 wat 7 procent van alle states is in de state tabel
  • 205490791 bytes wat 38 procent van alle bytes is in de state tabel
Ik zie dat hij elke 5 seconde een update doet. Misschien een idee dat ik die update frequentie maar eens wat lager zet. Maar wat nog meer opviel is het hoge aantal bytes en helemaal het percentage. Blijkbaar verstuurd hij nogal wat data bij een update. Hier kan ik niet zoveel aandoen.
Zie dit bericht meer als een opmerking en niet als een echt probleem.
In de toekomst misschien wat minder attributes data aan de fan zelf hangen.
SQL:
SELECT
  COUNT(*) AS cnt,
  COUNT(*) * 100 / (SELECT COUNT(*) FROM states) AS cnt_pct,
  SUM(LENGTH(attributes)) AS bytes,
  SUM(LENGTH(attributes)) * 100 / (SELECT SUM(LENGTH(attributes))  FROM states) AS bytes_pct,
  entity_id
FROM states
GROUP BY entity_id
ORDER BY cnt DESC
state_iddomainentity_idstateattributesevent_idlast_changedlast_updatedcreatedold_state_id
65105460fanfan.nrg_itho_8e70_fanon{"speed_list":["off","low","medium","high"],"preset_modes":[],"speed":"low","percentage":10,"percentage_step":1.0,"preset_mode":null,"temp":23.8,"hum":36.9,"ppmw":6860,"Speed status":15,"Internal fault":0,"Frost cycle":0,"Filter dirty":0,"AirQuality (%)":"not available","AirQbased on":0,"CO2level (ppm)":"not available","Indoorhumidity (%)":50,"Outdoorhumidity (%)":"not available","Exhausttemp (\u00b0C)":"not available","SupplyTemp (\u00b0C)":"not available","IndoorTemp (\u00b0C)":"not available","OutdoorTemp (\u00b0C)":"not available","SpeedCap":63488,"BypassPos (%)":"not available","FanInfo":"auto","ExhFanSpeed (%)":15,"InFanSpeed (%)":0,"RemainingTime (min)":0,"PostHeat (%)":"not available","PreHeat (%)":"not available","InFlow (l sec)":"not available","ExhFlow (l sec)":"not available","Ventilation setpoint (%)":15,"Fan setpoint (rpm)":724,"Fan speed (rpm)":726,"Error":0,"Selection":7,"Startup counter":60,"Total operation (hours)":9243,"Absence (min)":0,"Highest CO2 concentration (ppm)":"not available","Highest RH concentration (%)":50,"RelativeHumidity":"not available","Temperature":"not available","friendly_name":"Bathroom fan","supported_features":1}6536179838:33.212:01.412:01.4
65105469fanfan.nrg_itho_8e70_fanon{"speed_list":["off","low","medium","high"],"preset_modes":[],"speed":"low","percentage":10,"percentage_step":1.0,"preset_mode":null,"temp":23.8,"hum":37.1,"ppmw":6889,"Speed status":15,"Internal fault":0,"Frost cycle":0,"Filter dirty":0,"AirQuality (%)":"not available","AirQbased on":0,"CO2level (ppm)":"not available","Indoorhumidity (%)":50,"Outdoorhumidity (%)":"not available","Exhausttemp (\u00b0C)":"not available","SupplyTemp (\u00b0C)":"not available","IndoorTemp (\u00b0C)":"not available","OutdoorTemp (\u00b0C)":"not available","SpeedCap":63488,"BypassPos (%)":"not available","FanInfo":"auto","ExhFanSpeed (%)":15,"InFanSpeed (%)":0,"RemainingTime (min)":0,"PostHeat (%)":"not available","PreHeat (%)":"not available","InFlow (l sec)":"not available","ExhFlow (l sec)":"not available","Ventilation setpoint (%)":15,"Fan setpoint (rpm)":724,"Fan speed (rpm)":726,"Error":0,"Selection":7,"Startup counter":60,"Total operation (hours)":9243,"Absence (min)":0,"Highest CO2 concentration (ppm)":"not available","Highest RH concentration (%)":50,"RelativeHumidity":"not available","Temperature":"not available","friendly_name":"Bathroom fan","supported_features":1}6536180738:33.212:06.312:06.365105460
  • ppeterr
Hey allemaal :)
Ik kijk al een tijdje mee in dit topic, want ik vind het bar interresant. Sinds een maand of 6 woon
ik in mijn nieuwe huis. En speel al een tijdje met de gedachte om dit ook te gaan toepassen.
Vooral omdat ik de stekker van de ventilatie eigenlijk het meeste van de tijd eruit heb, omdat
hij lawaai maakt. Dus ik sta voor de keuze om hem te vervangen, of eerst dit te proberen.
De domotica zooi in huis is verder goed op orde, en redelijk afgerond. Dus ik dacht ik bestel er een :)
Nou kom ik er dus achter dat ik geen Itho heb, maar een Buva :|
Wat zijn nou mijn opties, buiten dat ding vervangen ?
Afbeeldingslocatie: https://tweakers.net/i/dUCD72sfPGQRxhPEtzcXS2GupZU=/x800/filters:strip_icc():strip_exif()/f/image/lOA1AqQpTHGrMiGjemZxw0Ul.jpg?f=fotoalbum_large
  • arjenhiemstra
ppeterr schreef op woensdag 16 februari 2022 @ 11:13:
Hey allemaal :)
Mijn collega knutselaar Eelco heeft een leuke oplossing voor de Buva:
https://github.com/eelcohn/nRF905-API
  • ppeterr
arjenhiemstra schreef op woensdag 16 februari 2022 @ 14:53:
Dat is top, maar ik denk dat ik er niet handig genoeg voor ben om in elkaar te knutselen...
  • Rukapul
  • Laatst online: 14:37
ppeterr schreef op woensdag 16 februari 2022 @ 17:56:
Als ik het zo zie hoef je alleen maar wat kabeltjes te prikken en wat software te flashen. Zowel de sensor als de esp32/esp8266 zijn verkrijgbaar met pinnen er al vast op met voeding middels micro-USB.
Het kost dus hooguit tijd :+
[ Voor 6% gewijzigd door Rukapul op 16-02-2022 18:17 ]
  • arjenhiemstra
Toen ik hem laatst sprak was hij met wat hardware bezig om een kant en klare oplossing te bieden, weet niet of hij dit al af heeft maar je kunt altijd ff contact met hem opnemen, wie weet.
  • Arathorn8
  • Laatst online: 18-10 06:28
Vandaag heb ik de add-on ontvangen, meteen geinstalleerd en het lijkt goed te gaan. In m'n badkamer heb ik een RFT Remote W hangen, dus heb virtual remote join command uitgevoerd en Force medium mode aangezet. Daarna ben ik gaan hannesen met domoticz, maar aangezien ik vooral wil dat de itho 's avonds stil wordt en 's ochtends aangaat heb ik besloten om de volgende crontab regels in m'n thuisserver te zetten:
0 7 * * * /usr/bin/curl http://10.0.0.40/api.html?speed=150 # ventilation strong for shower time
0 9 * * * /usr/bin/curl http://10.0.0.40/api.html?speed=100 # ventilation normal during the day
0 18 * * * /usr/bin/curl http://10.0.0.40/api.html?speed=20 # ventilation silent for the night
Mankeert daar iets aan?
"I came here to chew gum and kick ass... and I'm all out of gum." -- They Live
  • arjenhiemstra
Arathorn8 schreef op woensdag 16 februari 2022 @ 20:10:
Als 10.0.0.40 het IP van je add-on is lijken dit prima commando's. Voor deze heb je de virtual remote niet eens nodig overigens.
  • eymey
arjenhiemstra schreef op maandag 14 februari 2022 @ 22:31:
Hehe... dat is ook weer zoiets. En dan zou die bij ons ook nog op de 1 of andere manier op een schuin dak moeten. Dat is nou ook weer 'not worth the effort' :P
barteg schreef op dinsdag 15 februari 2022 @ 08:50:
Hmm, interessant. Hoe zien die dempers eruit? En zouden die ook (makkelijk) op een ' gewone' itho kunnen? (wellicht gewoon dezelfde maten qua diameter). Zou nog wel een optie zijn om dat hier te proberen. Het laatste stukje van de buis naar de itho, zowel aan de aanvoerkant als de afvoerkant, is flexibel :).
  • TOMMY1985
  • Laatst online: 12-10 00:45
[/quote]
Op deze site kan je ook gewoon losse dempers kopen en zelfs meerdere achter elkaar plaatsen.
Hoe meer ovale delen je eruit haalt hoe minder weerstand je krijgt.
Link Ventilatieshop Ø125mm dempers
Lisse Live 4400Wp ZZW
  • gns1l
eymey schreef op woensdag 16 februari 2022 @ 21:43:
Hiermee zou je de flexibele slang kunnen vervangen https://www.ventilatielan...isoleerde-ventilatieslang
  • Rukapul
TOMMY1985 schreef op donderdag 17 februari 2022 @ 09:39:
[/quote]
Interessant. Maar deze moeten dus minimaal 50cm van unit / ventiel / andere demper geplaatst worden. Dat roept wel wat praktische vragen op, bv hoe je zorgt dat de dempers niet dichtslibben met stof, etc.
* Rukapul vindt het wel interessant om te proberen op badkamer / WC maar dan het liefst vrijwel direct achter het ventiel. Heb namelijk het idee dat ik ergens ook een (water)leiding in een koof tegen de spirobuis drukt met extra resonantie als gevolg.
  • eymey
[/quote]
Ik had deze inderdaad ook al gevonden, maar ben vooral benieuwd naar degene die @barteg heeft gebruikt, omdat hij nu dus concrete ervaring heeft met het resultaat van een bepaalde demper :)
Invloed op de luchtverplaatsing is sowieso wel een zorgenpunt. Ik wil natuurlijk niet dat geluidsreductie ten koste gaat van de ventilatiecapaciteit.
Ziet er ook nog interessant uit :).
De situatie hier is dat de Itho achter een knieschot naast de trap naar de zolder zit. En ik heb aan de binnenkant van het knieschot simpele geluidsisolerende bekleding van de Gamma geplakt. En van de box zelf is er dus ook amper meer herrie.
Maar de afvoerbuis van de Itho komt door het knieschot naar buiten en gaat dan hoog in de nok door het dak heen. En in die buis resoneert het geluid toch nog behoorlijk. En dus hetzelfde bij de diverse ventielen in huis.
[ Voor 29% gewijzigd door eymey op 17-02-2022 10:12 ]
  • Bas Post
  • Laatst online: 08:32
Ten eerste, wat een super gaaf project en module, complimenten naar Arjan! En wat een snelle service.
Ik ben ooit bezig geweest met het "Smart" maken van deze Itho box, een Arduino met CC1101, Humidity sensor, leuke behuizing, gekoppeld aan Homey. Dat werkte op zich goed, maar ik had wel een unit in de badkamer in het zicht. Na verbouwing 2019 van de badkamer, niet meer terug gezet.
Maar nu zag ik deze inbouw oplossing, helemaal tegek! Gelijk besteld.
Als het goed is krijg ik vanmiddag mijn Add-on met sensor uitbreiding geleverd voor mijn 8 jaar oude Itho CVE.
Maar ik heb een vraag. Ik heb al een RFT remote gekoppeld aan de Itho. Hoe moet je deze toevoegen aan de Add-On. Eerst connectie verwijderen en dan koppelen aan de remote? Wat is de beste toepassin en werking in deze?
BP on the move!!!
  • eymey
Bas Post schreef op donderdag 17 februari 2022 @ 10:07:
Heb je de Itho Add-on ook met CC1101 module erop besteld?
Je moet inderdaad de bestaande directe connectie tussen remotes en Itho verwijderen. Daarna kan je ze gemakkelijk met de add-on koppelen.
Het grote voordeel van direct met de add-on koppelen vind ik persoonlijk dat je de drie vanuit de remote oproepbare timers helemaal kan aanpassen qua tijdsduur.
Zo heb ik nu 1 druk op de timerknop een half uur gegeven, 2 drukken een uur en 3 drukken 1,5 uur :P.
  • Arathorn8
arjenhiemstra schreef op woensdag 16 februari 2022 @ 21:06:
Dan begrijp ik de virtual remote functie niet helemaal. Ik dacht dat het was om de commando's van de add-on te laten werken als je ook een remote gebruikt. Bij het testen merkte ik ook op dat na een commando van de remote de itho niet meer reageerde op commando's in de web interface van de add-on. Is dat niet wat de virtual remote hoort te omzeilen?
  • arjenhiemstra
  • Laatst online: 12:22
Arathorn8 schreef op donderdag 17 februari 2022 @ 12:43:
Als je een fysieke remote gekoppeld hebt aan je itho dan heeft de virutal remote inderdaad wel een functie (om te zorgen dat de itho altijd in medium mode staat voor een speed commando)
  • skobus
  • Registratie: Augustus 2021
  • Laatst online: 30-10-2025
Geluidsdempende flexibele slangen worden veel gebruikt, bijv. deze https://www.ventilatielan...SEY8psMhgVnRoCTpcQAvD_BwE
Als ik de specificatie zie is de demping beter dan die van INNO dempers
  • ghostygod
  • Laatst online: 31-03 20:12
skobus schreef op donderdag 17 februari 2022 @ 16:02:
Ik raad af om iets bij ventilatieland te kopen maar in de betere shops te gaan, ikzelf ben ventilatie technieker/verslaggever/onderhoudsman en de luchtkanalen van ventiland zijn zo lek als een zeef! Al meerdere moeten vervangen omdat de ketel het vereiste debiet niet haalt en als het niet door een fout in de uitvoering was dan meestal omdat aan en afvoer van ventilatieland komt... met de geluidsdempers nog geen ervaring maar ik vrees het ergste ook.... Ga voor een goed en bekend merk voor iets meer geld maar ook veel beter van kwaliteit.
  • barteg
@eymey Deze flexibele geluidsdemper heb ik gebruikt:
https://www.ventilatielan...tilatieslang-5-meter.html
  • Voogel
  • Registratie: April 2016
  • Laatst online: 16:15
ghostygod schreef op vrijdag 18 februari 2022 @ 09:44:
[...]met de geluidsdempers nog geen ervaring maar ik vrees het ergste ook[...]
Ik heb zowel de 50cm als de 100cm van Ventilatieland in gebruik en er is niks mis met de kwaliteit en de demping was echt meer dan ik had verwacht. Zeker op de inblaas is het geluid van de unit nu niet meer te horen.
6 zonnepanelen, 4kWh thuis accu en een Flint op een huisje uit 1896
  • eymey
Thanks! Prijs valt ook nog wel mee (hoewel 5 meter natuurlijk veel te veel is).
Is het spul een beetje makkelijk te verwerken / op maat te maken? En werk je uiteindelijk weer met gewone klemmen om het om de solide buis en de ventielen op de box te verbinden?
En heb je nog iets gemerkt aan het effect op de luchtstroom? (neem aan dat je dit niet hebt gemeten? )
  • barteg
eymey schreef op vrijdag 18 februari 2022 @ 15:35:
Ik heb nu een WTW unit en heb alle 4 de aansluitingen voorzien van van ongeveer een meter hiervan. De slang is bij mij ook voor de isolatie. De slang is dubbel wandig. De binnenwand heb ik met een lange tiewrap om een koppelstuk vast gemaakt. Dit koppelstuk (https://www.ventilatielan...50-mm-voor-spirobuis.html) past weer in mijn WTW of spiro buis. De buitenwand heb ik met aluminium tape vast geplakt aan de pijpen/unit. Dit is vrij makkelijk zelf te doen.
Wat het doet voor de luchtstroom weet ik niet omdat ik een nieuwe ventilatie unit heb nu. WTW versus alleen afzuiging doet wel een hoop (ten goede) voor het klimaat in huis. En heel veel stiller zonder die roosters boven de ramen.
  • gns1l
We raken wel een beetje off-topic...
Het voordeel van de flexibele dempers tov de slang is dat de uiteinden al netjes afgewerkt zijn. Het nadeel de prijs. Voordeel van de slang is dat je een lengte kunt kopen en daarvan meerdere stukken precies op lengte kunt maken.
Als je de slang op maat wilt maken heb je tape, een schaar of mes en een kniptang nodig. Beschermende handschoenen zijn fijn ivm de glaswol. Als je de uiteinden netjes aftaped, kun je ook gewone klemmen gebruiken om ze vast te zetten.
Als je ongerust bent over eventuele extra weerstand van de flexibele demper kun je een maat grotere diameter nemen en via een spiro verloopstuk aansluiten. Dat heb ik bij onze HRU gedaan.
Je kunt in de Sonodec specificaties zien hoeveel dat de geluidsdemping beïnvloed.
  • DiyMichael
na een tijdje stoeien met de instellingen krijg ik het maar niet werkend.
aansturen gaat prima maar de huidige stand uitlezen lukt maar niet.
het probleem lijkt hem echt in het % teken te zitten.
bij deze regel geeft HA een error
bij deze regel geen HA geen error maar werkt het niet.
{% set am = value_json['Requested_speed_(%)'] | int %}
iemand nog een suggestie
zou graag de huidige snelheid kunnen uitlezen zodat ik daar de automatiseringen op kan laten schakelen.
totale code
29
30
31
fan:
  - platform: mqtt
          {% if am == 0 %}
            low
          {% elif am == 30 %}
            medium
            high
          {% elif am == 24 %}
            auto
          {% else %}
            {{ am }}
          {% endif %}
    preset_modes:
       - "low"
       - "medium"
       - "high"
       - "auto"
       - "timer1"
       - "timer2"
       - "timer3"
  • arjenhiemstra
DiyMichael schreef op zondag 20 februari 2022 @ 14:55:
totale code
29
30
31
fan:
  - platform: mqtt
          {% if am == 0 %}
            low
          {% elif am == 30 %}
            medium
            high
          {% elif am == 24 %}
            auto
          {% else %}
            {{ am }}
          {% endif %}
    preset_modes:
       - "low"
       - "medium"
       - "high"
       - "auto"
       - "timer1"
       - "timer2"
       - "timer3"
Staat "Requested_speed_(%)" er wel tussen onder het menu 'Itho Status'?
  • smesjz
totale code
29
30
31
fan:
  - platform: mqtt
          {% if am == 0 %}
            low
          {% elif am == 30 %}
            medium
            high
          {% elif am == 24 %}
            auto
          {% else %}
            {{ am }}
          {% endif %}
    preset_modes:
       - "low"
       - "medium"
       - "high"
       - "auto"
       - "timer1"
       - "timer2"
       - "timer3"
Is het niet makkelijker om daar gewoon een template sensor voor te maken? Iets als:
- platform: mqtt
name: Itho HRU Actual mode
state_topic: "ithohru/ithostatus"
value_template: >
{% if am == 0 %}
low
{% elif am == 30 %}
medium
high
{% else %}
{{ am }}
{% endif %}
unique_id: itho_actual_hru_mode
in je automation kan je dan sensor.itho_actual_hru_mode uitlezen
  • smesjz
arjenhiemstra schreef op zondag 20 februari 2022 @ 15:50:
Bij mijn HRU-350 staat ie er in als "Requested fanspeed (%)" met laatste firmware. Ik zie nergens nog iets met underscores.
  • arjenhiemstra
Ik heb zojuist een testversie 2.4.0-alpha1 op github gezet. Voornamelijk om te kunnen testen.
Naast wat bugfixes met name de eerste stappen gezet op het supporten van meerdere en verschillende types remote als virtual remote. Werkt op dit moment alleen via de webinterface (dus nog niet via MQTT API of WebAPI).
Version 2.4.0-alpha1
Feat: Add filterReset command to debug page (need testing)
Feat: Log deviceType query failure
Feat: Add support for extra itho remote commands (Auto, AutoNight, Cook30, Cook60)
Feat: Add possibility to configure number of virtual remotes
Feat: Add possibility to copy ID of existing remote to be used with a virtual remote
Fix: update MQTT status when no itho is detected
Fix: crash when having multiple browser tabs open and requesting settings
Fix: properly initialise RF debug buffer
CVE HW rev 2 FW:
https://github.com/arjenh...tho-hw2-v2.4.0-alpha1.bin
Non-CVE FW:
https://github.com/arjenh...-noncve-v2.4.0-alpha1.bin
  • smesjz
arjenhiemstra schreef op zondag 20 februari 2022 @ 15:55:
CVE HW rev 2 FW:
Non-CVE FW:
Nieuwe firmware is nog echt een success na flash van de module die aan de HRU-350 hangt. Module is niet meer bereikbaar na flashes en opnieuw op starten (kabel er uit / er in) doet niet veel. LEDs branden wel...
  • DiyMichael
@arjenhiemstra "Requested speed (%)" staat er tussen.
@smesjz het werkt het waren inderdaad de underscores die ik uit het voorbeeld had overgenomen. Was me niet opgevallen dat deze nu weg waren.
Bedankt @arjenhiemstra en @smesjz voor het mee denken en de snelle reacties!!
  • arjenhiemstra
smesjz schreef op zondag 20 februari 2022 @ 16:07:
In de categorie domme knip-plak fouten.... ik heb mijzelf van een klein stukje geschiedvervalsing bediend, als je de binary opnieuw download zou die wel moeten werken.
  • smesjz
arjenhiemstra schreef op zondag 20 februari 2022 @ 16:28:
Ok, dus eerst stappen volgen voor fail-safe boot en dan via /update opnieuw gedownloade firmware pakken?
  • arjenhiemstra
smesjz schreef op zondag 20 februari 2022 @ 16:38:
Yes
  • smesjz
Ok, dat werkt. :)
Feat: Add support for extra itho remote commands (Auto, AutoNight, Cook30, Cook60) <-- dat is nog niet vermeld bij API documentatie bij de add-on?
  • arjenhiemstra
smesjz schreef op zondag 20 februari 2022 @ 16:53:
Ok, dat werkt. :)
Nee, deze commando's zijn voor nu alleen toegevoegd aan de CC1101 lib en aan de virtual remote via de webinterface. Binnen de API moeten deze commando's en het selecteren van de juiste remote (ik denk op basis van index en/of naam) nog toegevoegd worden.
  • smesjz
arjenhiemstra schreef op zondag 20 februari 2022 @ 17:02:
En neem aan dat je straks gewoon vremote=auto kan sturen zonder verplicht remote aan te geven wanneer je geen QF/DF hebt? Bijv met slechts HRU-350
  • arjenhiemstra
smesjz schreef op zondag 20 februari 2022 @ 17:30:
Ik denk dat het qua backwards compatibility het handigst is om vremote op index 0 te pakken als er geen vremote naam of index meegegeven is.
Standaard zal vremote op index 0 qua ID gelijk zijn aan de vremote nu, zal het standaard type de RFT CVE zijn (dat is de variant die het nu ook is).
Kortom, als je niets doet blijft alles werken is het doel. Mocht je meer willen en het type remote willen veranderen dan kan dat.
  • ParaDroid2
  • Laatst online: 16:37
Recent deze wifimodule besteld en gisteren geïnstalleerd, werkt perfect inclusief integratie in Home Assistant! Nu kan ik de ventilatie weer aansturen, want blijkbaar is er ooit door vorige bewoners besloten dat er alleen een driewegknop in de keuken zit, waarbij stand 1 de gehele stroom van de ventilatie afhaalt en stand 3 de ventilatie in idle zet...
Nu nog wachten op de luchtvochtigheidssensoren, zodat ik de ventilatie kan aansturen a.d.h. van de luchtvochtigheid in de douche.
Bedankt voor het nuttige werk!
  • barteg
Since twee maanden heb ik een itho HRU 350 hangen en nu ruim een maand de wifimodule. Wat een fantatische module. Nu heb ik een vraagje over de "/status" output. Deze lees ik met MQTT uit en heeft tot op heden de waarde "0" wat volgens mij "normaal" is. Of de waarde "5" welke de unit weergeeft voor ongeveer voor 2 uur, nadat de unit onder stroom wordt gezet. Is er soms een overzicht van de mogelijke waardes en hun betekenins?
  • Bas Post
Afgelopen week mijn Add-on setje mogen ontvangen.
Direct geïnstalleerd, nadat ik maar eerst de ITHO ook heb schoongemaakt, wat wel nodig was.
Installatie was zeer makkelijk en snel te doen.
De sensor bij de steuntjes van de behuizing in het slakkenhuis kunnen steken.
Precies op dezelfde manier als:
https://gathering.tweaker...message/70590192#70590192
Integratie in Homey en Homebridge via Mqtt was ook zeer makkelijk te doen.
Schakelen o.b.v. luchtvochtigheid gaat ook prima!
Al om al, zeer tevreden!
Echter een vraagje. Ik ben op zoek naar een inbouwmodule met stroommeting om mijn afzuigkap te kunnen uitlezen (stroomverbruik) en daarop de ITHO mee te laten schakelen.
Ik dacht aan een Sonoff POW R2, maar is niet meer te krijgen. De POW R3 is veel te groot.
Iemand een idee? De stekker van de afzuigkap zit direct met lasklemmen in een inbouwdoos
Afbeeldingslocatie: https://tweakers.net/i/A0m2inLJ1SOly-k7zSC87BMFWnw=/800x/filters:strip_icc():strip_exif()/f/image/sIJhFDTiSDLhlLP38ZU6gVM0.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/mGux2Bs2qenVO44I8h1q8QXf1qE=/800x/filters:strip_icc():strip_exif()/f/image/BgsNTWOPnFsfMuQEkp9FpJog.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/akI4jU2buH9dBSAsrFdMv9efVI0=/x800/filters:strip_icc():strip_exif()/f/image/Up4HqQTQtCihmlc4zb9XQ3Q9.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/UQ8pJt4kztMf5po183LGOLNphNs=/x800/filters:strip_icc():strip_exif()/f/image/IoksxZSSIIyhPzRifqdkhskt.jpg?f=fotoalbum_large
Afbeeldingslocatie: https://tweakers.net/i/gT28ykypemxlDpVeu9LIkik9iX4=/x800/filters:strip_icc():strip_exif()/f/image/Y6W4JgqbHAbVSZghcrbhBBIS.jpg?f=fotoalbum_large
BP on the move!!!
  • JeroenE
@Bas Post Een Shelly zoals de 1PM? Ze hebben tegenwoordig ook de Plus 1PM. Die is een paar euro duurder maar kan veel meer.
  • Ierlandfan
  • Laatst online: 17-10 17:29
Een half jaar geleden zag ik een post voorbij komen waarin Arjan schreef over een PR mbt automatische vochtregeling in de firmware. Ik kan de PR niet zo een twee drie vinden maar is dat inmiddels ingebouwd?
  • Bas Post
JeroenE schreef op maandag 21 februari 2022 @ 13:36:
Ik kan eventueel bij Amazon bestellen.
Waar doe ik goed aan? Een Sonoff of Shelly?
Usercase is alleen uitlezen van stroomverbruik van de afzuigkap.
Deze waarde gebruik ik alleen om de ITHO mee te laten lopen op hoge stand.
Afbeeldingslocatie: https://tweakers.net/i/riDjb3_ucplqjP61qf39Zxm5YlI=/800x/filters:strip_icc():strip_exif()/f/image/peaTdD4DyvvvYXqIa0GFf5n0.jpg?f=fotoalbum_large
BP on the move!!!
  • JeroenE
@Bas Post Ik zou zeggen: kies degene waar je al ervaring mee hebt en gebruik die. Kijk ook nog even goed na of je domotica controller jouw keuze wel ondersteunt.
Als er verder geen verschil in die antwoorden zit dan zou ik de Shelly kiezen. Die is kleiner en goedkoper.
  • skobus
JeroenE schreef op maandag 21 februari 2022 @ 15:51:
En de Shelly heeft standaard MQTT ondersteuning. Mijn Sonoff POWR2 was niet erg betrouwbaar, daar heb ik Tasmota op gezet. Dat werkt wel, maar Shelly met standaard MQTT vind ik makkelijker.
  • Bas Post
skobus schreef op maandag 21 februari 2022 @ 23:44:
Goed om te weten! Inmiddels een Shelly 1PM besteld. Ben benieuwd naar de integratie.
BP on the move!!!
  • Wolfensteijn
  • Laatst online: 15:09
Sinds vandaag heb ik de non-CVE versie aan mijn HRU ECO-fan hangen. In eerste instantie is voor mij het doel data verzamelen, en dan vooral de lucht temperaturen. Ik woon in een tussenwoning uit 2008, dat als voordeel heeft goed geïsoleerd te zijn dus de warmte blijft lang hangen. In de zomer is dat het nadeel, de warmte blijft lang hangen.
Puur voor mijzelf om dat inzichtelijk te krijgen wil ik dus de luchttemperaturen van de HRU weten, en met deze unit is dat mogelijk.
Volgende stap is eigenlijk alle status data als sensors in Home Assistant en InfluxDB krijgen. En hier loop ik helaas tegen een stukje gebrek aan kennis aan. Met het MQTT sensor voorbeeld op Github krijg ik temperatuur waarde van 0, en ik snap niet goed wat ik moet veranderen om de gemeten luchttemperaturen goed zichtbaar te krijgen.
In de MQTT message zie ik "Outdoor temp (°C)" en "room temp (°C)" langskomen, en specifiek die wil ik dus in Home Assistant als sensor kunnen zien. Enig meedenken zal ik zeer op prijs stellen.
Vervolg stappen zullen zijn om de HRU via Home Assistant aan te sturen op basis van CO2 en PM data uit een andere sensor.
  • Wolfensteijn
De gemeten data naar InfluxDB sturen is mij ondertussen gelukt. Deel van het probleem daar was dat ik de webinterface van InfluxDB een keer moest refreshen voordat de boel zichtbaar werd.
Gebruikte telegraf config:
[[inputs.mqtt_consumer]]
  servers = ["tcp://IP:1883"]
  topics = [
    "itho/ithostatus",
  data_format = "json_v2"
  [[inputs.mqtt_consumer.json_v2]]
    [[inputs.mqtt_consumer.json_v2.object]]
      path = "@this"
Met deze config krijg ik alle beschikbare labels gelogged.
Voor logging hoeft dit verder niet meer via Home Assistant te lopen. Dus alleen controle over de fan speed zal ik daar moeten doen. En dat op basis van CO2 metingen.
  • S0epkip
Okay; de add-on werkt goed in mijn CVE en nu heb ik bezig met HomeAssistant automatiseren.
DMV MQTT heb ik nu een FAN entity in mijn HA en alla data komt goed binnen. So far so good.
Afbeeldingslocatie: https://tweakers.net/i/dED_ortz0v2G7UWwH-CzPDZOckk=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/J8JWf1VCGODVk5qjxpYtSh0m.jpg?f=user_large
Afbeeldingslocatie: https://tweakers.net/i/ww7P0rUoURSBfag00b5Rufznrig=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/fZ0LN940f9iha4tTTn3faouG.jpg?f=user_large
Als ik echter de fanspeed op "high" laat zetten, dan gaat hij op max rpm (254) in plaats van de in de add-on ingestelde 221 als high. Iemand een idee hoe dit kan?
29
30
31
alias: itho high humidity high fan speed
description: Bathroom high humidity increases fan speed
trigger:
  - type: humidity
    platform: device
    device_id: 017fcdabfd429fdbbc2d0a0c404e7aa0
    entity_id: sensor.nrg_itho_e288_humidity
    domain: sensor
    above: 50
    for:
      hours: 0
      minutes: 0
      seconds: 30
condition: []
action:
  - service: fan.set_speed
    target:
      entity_id:
        - fan.nrg_itho_e288_fan
    data:
      speed: high
  - wait_template: ''
    timeout: '00:20:00'
    continue_on_timeout: true
    target:
      entity_id:
    data:
      speed: low
mode: single
Ik heb geprobeerd een specifieke snelheid mee te geven, maar daar lijkt de Itho niet op te reageren?
Bijvoorbeeld:
action:
    data:
      speed: '95'
    target:
      entity_id: fan.nrg_itho_e288_fan
Kan ik op een andere manier een specifieke fanspeed meegeven?
ventilation% lijkt de itho ook niet op te reageren.
Overigens werkt de add-on zelf en de humidty sensor goed. Ook de bestaande RF remote heb ik easy peasy aan de add-on kunnen koppelen en die werkt weer als vanouds. Wat dat betreft zeer soepel allemaal en props to Arjen.
Current firmware version: 2.3.5
Hardware revision: 2
Latest firmware version: firmware is up-to-date
Itho fw version: 11
Afbeeldingslocatie: https://tweakers.net/i/3LEeD_B_4_zypiOieYTxiDgOzBE=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/8gXwyPDyjPBMSbcPaqqmmm0Y.jpg?f=user_large
[ Voor 37% gewijzigd door S0epkip op 27-02-2022 19:36 ]
PVO
  • arjenhiemstra
S0epkip schreef op zondag 27 februari 2022 @ 19:27:
29
30
31
trigger:
  - type: humidity
    platform: device
    domain: sensor
    above: 50
    for:
      hours: 0
      minutes: 0
      seconds: 30
condition: []
action:
    target:
      entity_id:
    data:
      speed: high
  - wait_template: ''
    timeout: '00:20:00'
    target:
      entity_id:
    data:
      speed: low
mode: single
Bijvoorbeeld:
action:
    data:
      speed: '95'
    target:
Ik denk dat HA high hier vertaald naar 100% wat het commando 254 naar de add-on verstuurd.
service: fan.set_speed lijkt overigens ook deprecated te zijn volgens de HA documentatie. Je zou service: fan.set_percentage misschien kunnen gebruiken.
De high setting van 221 wordt gebruikt als je het commando "high" naar de add-on verstuurd (door een json {"command":"high"} naar het MQTT cmd topic van de add-on te sturen)
  • S0epkip
arjenhiemstra schreef op maandag 28 februari 2022 @ 12:22:
Ja die werkt :)
29
30
31
32
33
trigger:
  - type: humidity
    platform: device
    domain: sensor
    above: 55
    for:
      hours: 0
      minutes: 0
      seconds: 30
condition: []
action:
  - service: fan.set_percentage
    data:
      percentage: 87
    target:
  - service: notify.notify
    data:
      message: ff douchen
      title: ' fan up'
  - wait_template: ''
    timeout: '00:20:10'
    data:
      percentage: 8
    target:
mode: single
Nog tips mbt hoogte van humidity om bij te schakelen en durations van de tweakers hier?
PVO
  • skobus
S0epkip schreef op dinsdag 1 maart 2022 @ 11:27:
Omdat de relatieve vochtigheid ook afhankelijk is van de temperatuur werk ik voor de douche-ventilatie met de absolute vochtigheid, die is onafhankelijk van de temperatuur (ppmw, watergehalte in mg water per kg lucht).
Ik vergelijk de actuele ppmw waarde met de minimum waarde over de laatste 8 minuten. Wanneer de toename meer is dan 1000 ppmw schakelt de ventilatie op . Daarna vergelijk ik de absolute vochtigheid met de maximale waarde van de afgelopen 8 minuten, wanneer de afname meer dan 700 ppmw is start een timer. Na 10 minuten gaat de ventilatie naar de vorige (lagere) waarde.
  • S0epkip
skobus schreef op dinsdag 1 maart 2022 @ 12:03:
Nice :)
Ben benieuwd naar je HomeAssistant .YAML voor deze automatie? :D
PVO
  • skobus
S0epkip schreef op dinsdag 1 maart 2022 @ 12:22:
Nee, alles in Note-RED, zie https://github.com/arjenh...wiki/Node-Red-integration
  • Erik804
  • Registratie: December 2020
  • Laatst online: 14-04-2022
Hallo allemaal,
Recentelijk de Itho add-on geïnstalleerd, werkt prima, maar wil hem graag integreren/koppelen in de Google home routines. (Heb nu alles gekoppeld met Home en kaku)
Heeft iemand ervaringen hiermee of ideeën hoe dit aan te pakken?
Zou hem graag schakelen als de lamp aangaat de itho bv op een hogere stand schakeld
Alvast bedankt
Erik
[ Voor 13% gewijzigd door Erik804 op 02-03-2022 08:47 ]
Pagina: 1 ... 17 ... 71 Laatste
