Kan hem zo snel ook niet terugvinden..
Deze vond ik wel maar is niet wat ik zocht en niet heel erg volledig, bjorn had een overzicht wat behoorlijk compleet was.
Road Tripping in the Ioniq
Given how efficient the Ioniq is, and how quickly it can charge, it might do quite well on a road trip, even given its low range. You’d have to stop regularly to charge, but it might not require as long of a stop. The problem is, that the Ioniq cannot make our standard road trip model. (1000km at 120km/h with 200km legs). Its range is too short. However, shortening the leg distance gives it:
Model 3 Long Range: Total trip duration 09:43, of which charging 01:23
Model S100D: Total trip duration 10:05, of which charging 01:45
Model X100D: Total trip duration 10:29, of which charging 02:09
Model S60: Total trip duration 10:35, of which charging 02:15
Ioniq EV: Total trip duration 10:40, of which charging 02:20 (115km legs)
Model X60: Total trip duration 11:28, of which charging 03:08
Bolt EV: Total trip duration 12:20, of which charging 04:00
With this adjustment, the road trip requires 8 charging stops, and you’re stopping almost every hour. Given the number of stops, adding “fiddling with the charger” time to that will make your road trip longer, so 10:40 might be an overly optimistic number.
Finally, comparing on the charging speed, we get:
Looking at the charge speeds this way, we see an interesting side effect of the small-but-efficient path, as well as an up-side of the more “hockey-stick” shaped charge curves a lot of manufacturers are using in upcoming vehicles. Because the Ioniq is so efficient, it gets a very high relative charge speed, even though it’s actually charging o
nly slightly faster than the Bolt measured by kW. The hockey stick really shows itself when comparing against the S60. Even though it starts out slower, around 50% the Ioniq starts charging faster, and maintains longer than the S60. This is important for the Ioniq’s small battery, and contributes to its decent road tripping time.
https://forum.abetterrout...entry/4-hyundai-ioniq-ev/
Voor 104% gewijzigd door
revolution-nl op 28-12-2018 23:27
Vroemt met EV | 10.000WP | 14kWh Thuisaccu | 2x MHI SRK/SRC 35 ZS | LG-WH27s Boiler
