Verwijderd schreef op vrijdag 13 maart 2015 @ 11:23:
hoi snarfie
ik zie m inderdaad nagenoeg dagelijks voorbij komen ( soms niet ivm het weer vermoed ik )
kan je eens i
nloggen op de omnikportal en dan 3 reporst maken
1 van gisteren , 1 van eergisteren en 1 van 3 dagen terug
er moet iets zijn wat hem triggert op dat tijdstip
Wat ik zie is dat op dat tijdstip ook mijn 2de string dan net in de schaduw komt.
Het feit dat hij een korrectie maakt vind ik wel interessant hoe komt dat?.
Bijgaand gedeelte van het raport even voor 13:57 en wat erna. Rechts zie je het wattage.
Gisteren
legenda: Inverter Vpv1 Vpv2 Vpv3 Ipv1 Ipv2 Ipv3 Vac1 Vac2 Vac3 Iac1 Iac2 Iac3 Pac1 Pac2 Pac3 Fac Temp(℃) Time(GMT +1) Today's Energy(kWh)
Total Energy(kWh
NLDN4020138M1017,"181.9","297.3","0.0","2.78","2.78","0.0","240.0","0.0","0.0","5.3","0.0","0.0","1297","0","0","50.07","30.0","Mar.12 13:51,2015","13.54","1916.7"
NLDN4020138M1017,"188.2","321.5","0.0","2.51","1.95","0.0","240.0","0.0","0.0","4.3","0.0","0.0","1071","0","0","50.05","29.6","Mar.12 13:56,2015","13.64","1916.8"
NLDN4020138M1017,"190.1","317.8","0.0","2.00","0.57","0.0","240.0","0.0","0.0","2.2","0.0","0.0","538","0","0","50.04","28.6","Mar.12 14:01,2015","13.71","1916.9"
NLDN4020138M1017,"150.6","257.7","0.0","2.38","2.38","0.0","240.0","0.0","0.0","3.8","0.0","0.0","943","0","0","50.03","28.6","Mar.12 14:07,2015","13.8","1917"
NLDN4020138M1017,"144.5","256.3","0.0","2.21","2.21","0.0","238.4","0.0","0.0","3.5","0.0","0.0","860","0","0","50.03","28.3","Mar.12 14:12,2015","13.88","1917"
11 maart
NLDN4020138M1017,"245.9","294.2","0.0","0.47","2.81","0.0","239.2","0.0","0.0","3.8","0.0","0.0","916","0","0","50.07","29.2","Mar.11 13:53,2015","7.99","1902"
NLDN4020138M1017,"251.9","329.1","0.0","0.47","1.22","0.0","238.4","0.0","0.0","2.0","0.0","0.0","499","0","0","50.06","28.4","Mar.11 13:58,2015","8.06","1902.1"
NLDN4020138M1017,"246.9","260.2","0.0","0.47","2.45","0.0","236.0","0.0","0.0","3.0","0.0","0.0","731","0","0","50.0","28.2","Mar.11 14:04,2015","8.12","1902.2"
NLDN4020138M1017,"167.7","250.7","0.0","2.03","2.40","0.0","233.6","0.0","0.0","3.8","0.0","0.0","915","0","0","50.0","28.2","Mar.11 14:09,2015","8.19","1902.2"
NLDN4020138M1017,"148.9","255.8","0.0","2.07","2.26","0.0","234.4","0.0","0.0","3.6","0.0","0.0","862","0","0","50.03","28.2","Mar.11 14:14,2015","8.27","1902.3"
NLDN4020138M1017,"150.2","259.2","0.0","1.95","1.67","0.0","238.4","0.0","0.0","2.9","0.0","0.0","706","0","0","50.02","28.2","Mar.11 14:19,2015","8.34","1902.4"
10 maart:
NLDN4020138M1017,"232.5","289.1","0.0","0.64","2.73","0.0","237.6","0.0","0.0","3.7","0.0","0.0","911","0","0","50.05","30.6","Mar.10 13:49,2015","11.91","1892.8"
NLDN4020138M1017,"240.3","292.7","0.0","0.57","2.75","0.0","237.6","0.0","0.0","3.7","0.0","0.0","914","0","0","50.06","30.4","Mar.10 13:54,2015","11.99","1892.9"
NLDN4020138M1017,"245.1","311.4","0.0","0.64","1.38","0.0","236.8","0.0","0.0","2.3","0.0","0.0","563","0","0","50.05","29.6","Mar.10 13:59,2015","12.06","1893"
NLDN4020138M1017,"171.6","252.6","0.0","2.09","2.27","0.0","237.6","0.0","0.0","3.7","0.0","0.0","907","0","0","50.03","29.5","Mar.10 14:04,2015","12.12","1893"
NLDN4020138M1017,"138.9","268.4","0.0","2.12","1.84","0.0","236.8","0.0","0.0","3.1","0.0","0.0","767","0","0","50.02","29.2","Mar.10 14:15,2015","12.27","1893.2"
NLDN4020138M1017,"137.7","270.4","0.0","2.02","0.96","0.0","236.8","0.0","0.0","2.1","0.0","0.0","516","0","0","50.03","28.9","Mar.10 14:21,2015","12.33","1893.3"
14 x Suntech STP285 (-87 graden OOZ) - 2 x Bisol BMU250 (180 graden Z) - Omnik 4.0 TL - Soladin 600 - Airco Daikin Comfora FTXP-M35 - RXP35M
