• VonFoX
  • Laatst online: 26-07 09:00
VonFoX
Las noches de Diciembre
Firmware (versie 100) geinstalleerd op mijn 32pfl9603. Zie of merk niets, maar ja :)
Yo.
  • etamboer
  • Laatst online: 06-12-2024
Sorry, onbedoeld bericht verwijderd ;-) Ik heb 101 erop.
[ Voor 132% gewijzigd door etamboer op 26-07-2010 22:55 ]
  • VonFoX
VonFoX
Voor de p32pfl9603 is 100 de laatste. En er is zelfs een change log:
Q591E_0.101.0.0
• enabling the MPEG4 reception for Italy.
• Improvement use of free to air common interface card to decode mp4 digital
channels.
Q591E_0.100.0.0
• implementation to switch off the overnight update.
• Regression caused on HDMI has been resolved.
Q591E_0.97.0.0
• Solution for picture drops when watching digital broadcasts in the United
Kingdom.
Q591E_0.94.0.0
• audio issue solved when switching between HDMI sources.
• Optimalisation Audio SPDIF for HTS3367
Q591E_0.93.0.0
• Upgrade Madrid solution.
• Improvement for Riks-TV.
• Improved picture quality via availability of more colors.(color gamut)
Q591E_0.91.0.0
• Solution for the Madrid Broadcast issue.
• Improvement digital channel reception La7 DVB payTV channel Italy.
• DGTVi approved.
Q591E_0.89.0.0
• Improvement of Teletext.(no longer mixed pages or skipped parts)
• Solution for loosen channels overnight in Denmark.
• Reboot of the 42PFL9803D/10 after switching to the HDMI(Philips 1080)
solved.
Q591E_0.83.0.0
• replaces all previous releases, including Q591E_1.58.14.0.
• problems with installation algorithm for DVB-T UK solved.
• audio problems with certain STB devices solved.
Q591E_0.58.14.1
• Improvements for DNLA(decrease time to display thumbnails)
• Improvements DVB-T for France(region with the Belgian boarder)
Q591E_0.58.11.0
• Improvement of the OSD after start-up.
Q591E_0.58.8.0
• Missing of information on TXT pages has been solved.
• Improved settings when identifying the source as a 'PC'.
• Resolving the fact that mouse movements lag behind.
• Solution about disappearing subtitles with DVB-C.
• Sporadically no picture on DVB-C channels with specific CAM's and when
starting up the TV, has been solved.
Q591E_0.58.5.0
• Improvement of the connection via HDMI with Bose system.
• Improvement of stand-by behaviour.
• Improvements for EPG behavior in UK.
• Functionality added for Australia and Finland.
• Improvement scroll behavior remote control.
• supports MPEG4 in Spain.
Q591E_0.25.26.1
• Improved channel reception in Spain.
Q591E_0.25.24.1
• Improved black impression.
Q591E_0.25.21.0
• A 1080p 60Hz type of input signal does no longer show flashes on screen
with this software upgrade.
• The Common Interface functionality is now enabled for the UK with this
software upgrade.
• Possible picture judder with MPEG4 signals is solved with this software
upgrade.
• While the TV relaunches its software during normal use, strange picture
and sound artefacts no longer appear, with this software upgrade
Yo.
  • 2frankie
  • Laatst online: 05-04 14:11
Mochten er nog gebruikers zijn van de Philips 42PFL9803 op 't forum, dan ben ik zeer benieuwd naar de settings die zijn gemaakt.
Bedankt ;)
[ Voor 37% gewijzigd door 2frankie op 06-02-2011 18:38 ]
  • HDADDICT
  • Laatst online: 04-07-2021
Er is weer een nieuwe firmware upgrade 000.102.000.000 voor de 9xx3 serie. Heb em gisteren geinstalleerd, maar kan alleen maar zeggen dat mijn tv er moeite mee had. Hij reageerde wat langzamer als normaal. Wat er precies veranderd is weet ik zo 123 niet. Er staat nog geen release note online.
Ik heb nog wel een paar ideeën voor een firmware upgrade:
VIA DVB-C
* EPG problemen met ingang wintertijd.
* bij het radio luisteren via de tv blijft het scherm actief ( kunnen ze ook op zwart gooien wel geluid geen beeld)
VIA Set Top Box en DVB-C
* Automatische afstelling volume kan niet geregeld worden bij HD zenders, bij het zappen heb je dan van SD zender naar HD zender een gigantisch volume verschil.
  • HDADDICT
Overigens kijk ik via de interne dvb-c tuner.
Nou ik zou maar even wachten met de update. Bij het switchen naar SBS6 HD of Net5 HD moet ik minstens 15 seconden wachten voor dat ik beeld krijg. Dat is nu weer opgelost, want ik heb weer software 101 erop gezet. Het zal vast wel dingen verbeteren, maar ik wacht wel totdat er een release note te vinden is of wanneer het voor mij van toepassing is.
  • UltraSub
  • Laatst online: 27-11 10:32
Heb een issue met geluid over hdmi in combinatie met een PopcornHour C200.
Draadje gestart op het networkedmediatank forum omdat het volgens mij een bug is in de c200 software. Gaan ze beginnen over CEC. Lijkt me toch totaal niet van toepassing?
Iemand hier met een soortgelijke setup?
37PFL7603 <> HDMI <> C200
http://www.networkedmedia....php?tid=50605&pid=473017
  • etamboer
Ik zie voor de 9703 nog steeds versie 000.101.000.000...
  • HDADDICT
Ik zie het nu ook. En heb gekeken op de Philips site en kwam er achter dat de update voor de 9803 en de 9903 geschikt is.
  • GekkeCoen
  • Laatst online: 20-02-2025
Ik heb geprobeerd via de hoofdtelefoon en de zwart/witte tulpaansluitingen een externe speaker aan te sluiten, maar het vervelende is dat ik het volume van de hoofdtelefoon en de tulpaansluitingen niet met de Philips afstandsbediening kan bedienen. Is hier een oplossing voor?
  • GorgeousMetal
  • Laatst online: 14:15
Er is toch weer een nieuwe firmware (103):
http://www.p4c.philips.co...oftware&hlt=Link_Software
Goede wijn is nog geen bier.
  • etamboer
Ook net gezien. Hij staat erop. De bijbehorende changelog rept niet over 103 maar gaat slechts tot 101...
Ben benieuwd. Het enige probleem dat ik tot nu toe had is het geflikker bij ondertiteling over bewegende beelden.
  • GorgeousMetal
Releases Notes zijn beschikbaar. Hieronder de veranderingen van 102 en 103 (niet echt schokkend):
Q591E_0.103.0.0
• Solution for problem in south Italy(area Naples due to analog switch Off)
Q591E_0.102.0.0
• Solution for the video format that was not compatible for TELEMADRID HD.
Ik kom er even niet meer uit, ik heb zelf een 42pfl7623d10 staan in combinatie met een rampzalige Samsung HD ontvanger waarvan de afstandbediening voor geen meter reageerd. Nou ben ik eens een beetje aan het rond kijken of er ook een CI+ module in kan, en werkt met HD zenders. Maar ik kom er geen wijs uit ...
Iemand die mij kan vertellen of dat gaat werken?
  • Raymond
  • Laatst online: 15:30
Je kan bij ziggo op de site kijken of'ie gecertificeerd is.
Maar een toestel van meer dan 2 jaar oud doet over het algemeen geen ci+ Sterker nog: volgens mij hebben die toestellen vaak niet eens een dvb-c ontvanger aan boord. Je kan ff de handleiding opzoeken en kijken of het er in vermeld wordt
  • Prutsky
  • Laatst online: 10:06
Ik heb tegenwoordig een DVR (sinds kort de Horizon) van UPC aan mijn tv hangen om digitale tv te kijken. Wat mij voorheen al stoorde en nu nog steeds doet, is dat de tv niet op de goede HDMI poort start bij het aanzetten. Hij begint altijd op mijn "video" kanaal. Hier is nog steeds geen oplossing voor?
[ Voor 9% gewijzigd door Prutsky op 17-09-2012 16:51 ]
  • siz
  • Laatst online: 04-02-2025
siz
Hai all!
Dit draadje is al een beetje oud.. Maar vroeg me af of t iemand inmiddels gelukt is om met een Philips 37PFL7603D/10 en ci+ module via ziggo (amsterdam) te gebruiken? Ik heb dit enkele jaren geleden geprobeerd maar toen lukte het niet omdat de tv niet gecertificeerd is. Heb even rondgezocht op internet en vlgs mij is nog steeds het geval?
Q582e-o-.64.79.0
Tv520 r1
2009-12-18 08.07.57pm
Dank voor de info iig! (Hopelijk leest iemand dit topic nog :p)
'Eve!
  • MedionAkoya
  • Laatst online: 26-11 23:16
MedionAkoya
Niet geschoten is altijd mis
Verkeerde topic. |:(
[ Voor 94% gewijzigd door MedionAkoya op 25-11-2016 17:29 ]
Trein?
  • PC_EVERYDAY
  • Registratie: September 2014
  • Laatst online: 22-11 14:14
Ik kan u niet verder helpen met uw vraag.
Echter heb ik ook een vraag over de zelfde tv en aangezien u deze ook hebt kunt u mij misschien verder helpen.
Als ik het goed heb zit er ook ambient lichting op echter krijg ik deze niet gevonden in het menu maar zie ze wel fysiek zitten op de TV zelf, Deze hebben het ook gedaan maar i.v.m verhuizing zijn alle stekers er uit geweest en sinds dien doet hij het bij mijn weten niet meer. Weet u misschien ik deze weer aan kan zetten?
Alvast bedankt!
Met vriendelijke groet,
Thijs
  • RoyK
  • Laatst online: 29-11 21:13
RoyK
Hobby tekenaar
Beste kenners,
ik bezit een 47pfl9703D en heb recent een sonos soundbar aangekocht. Ik ben er blind vanuit gegaan dat ik met deze dure tv van een paar jaar geleden vast wel alle connecties bezit om de soundbar aan te sturen. Maar tot mijn verbazing kan ik geen optical out vinden achter de tv om de soundbar te verbinden. :X
Is dit correct? zoja, wat moet ik dan doen om de soundbar toch te koppelen? echt veel geld wil ik er niet tegenaan gooien. De tv moet op kort termijn vanvangen worden. Maar dat kan zomaar nog een jaartje duren.
Mijn portfolio op Instagram
  • Exirion
  • Laatst online: 13:32
Exirion
Gadgetfetisjist
RoyK schreef op zaterdag 25 november 2017 @ 21:00:
Beste kenners,
Hij heeft coax SPDIF en dat kun je omzetten naar optisch SPDIF (Toslink).
Bijvoorbeeld met: https://nl.aliexpress.com...To-Power/32799212151.html
  • RoyK
RoyK
Hobby tekenaar
Exirion schreef op zaterdag 25 november 2017 @ 21:13:
dat valt reuze mee. Bedankt Exirion! :>
  • Exirion
Exirion
Gadgetfetisjist
RoyK schreef op zaterdag 25 november 2017 @ 21:19:
Of: https://www.bol.com/nl/p/...-female/9200000063230103/
Deze is wat dichter bij huis :)
  • RoyK
RoyK
Hobby tekenaar
Ik was al een beetje aan het googlen haha. Thanks!!
Pagina: 1 2 3 4 5 Laatste
