[WC] Het Grote Waterkoelingstopic Deel XV Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 3 ... 11 Laatste
  • 8.236 views sinds 30-01-2008
Is zo iets niet wat voor je ?
Afbeeldingslocatie: http://www.alphacool.de/xt/images/product_images/info_images/3432_0.jpglphacool AGB-Eheim 1000 Station 12V
Submerged pump station including Eheim compact 1000 pump 12 volts. The container is made of Degussa plexiglass. The Eheim Compact 1000 submerged pump has a delivery performance of 1000 l/h, i.e. a lifting height of 200cm. The container is provided with 1/4" connections and can be equipped with diverse adapters. The pump is mounted in a way, that the vibrations at the outlet are buffered by help of an o-ring sealing, as well as by means of rubber footings. The filling hole has a diameter of 42mm (G1" - oil inspection glass), for the comfortable filling. The pump can be taken out together with the cover. For a bubble-free operation after having switched-off the pump, there is a plexiglass hose extention at the inlet, so that water runs back into the hose - and not air. The container has LED bores in the cover (4x5mm) in order to give it an individual appearance.
Measures of the pump container:
Diameter: 10cm
Height: 14cm
Connections: 2x G1/4" internal screw-thread
Filling nozzle: G1"-oil inspection glass
Pump capacity: 300-1000 l/h
Lifting height: 2.0 m
Power input: 23 watt
Others: 4x5mm LED drilling holes in the cover.
12V DC/AC PCI Slot plate is also supplied!
The reservoir is delivered without connections! Please order your desired connections at hoses & connections
Ongeveer 65,- euro, via bytes @ work te bestellen bij alphacool.de 12volt pomps zijn zowiezo duurder dan 220v.
[ Voor 3% gewijzigd door Verwijderd op 24-10-2005 17:43 ]
  • ND863
  • Laatst online: 09-07-2022
ND863
Forget aircraft - Fly Airbus
Poeh das een flinke prijs. Alhoewel valt ook wel mee, voor een losse res en pomp betaal je al gauw 80-90,- voor. Ik ga verder met zoeken naar meer pomp & res in 1. Als je iets hebt van 'die of die MOET je hebben!' dan hoor ik dat natuurlijk graag B)
To be, or not to be a FRUITVLIEG!??
De 220v versie is 50 euro, en de versie met een mindere krachtige pomp is weer 10 euro goedkoper. Nadeel van een 12volt pomp is dat die van je 12v vreet, meer verbuikt, en meer kost vanwege de DC to AC omvormer.
Hier een overzichtigje van Alpha cool.
http://www.alphacool.de/xt/index.php?cPath=5_40_41
Ik ben zelf wat gaan googlen en kwam bij dit uit
http://www.alphacool.de/x...ts_id=117&cPath=5_302_170
iemand ervaring mee ?
Nu is mijn vraag is de radiator nog sterk genoeg om je Vga ook te koelen ? en eventueel je chipset ook ?
Dat kan al van af een radiator met 2 12cm fans, met zo triple rad gaat het zeker lukken.
Dus met dit setje zou ik mijn VGA en chipset zonder probleem moeten kunnen koelen ?
http://www.alphacool.de/x...ts_id=115&cPath=5_302_169
Dan het volgende probleem de case ?
Gaat het in een gewone case
bv de deze : http://www.alternate.nl/pix/spacer.gif
Of moet je dan al voor een grotere case gaan ?
Alvast bedankt
  • Roamor
Verwijderd schreef op maandag 24 oktober 2005 @ 20:41:
Alvast bedankt
Nogmaals: wat moet die set gaan koelen? Laten we even aannemen dat je geen exotische setup hebt, dan moet dat setje absoluut geen probleem hebben om je set te koelen. Ik heb lange tijd tijd mijn setup met een single 120mm rad gekoeld, dus een dubbele zal daar ook zijn hand niet voor om draaien. :)
Trouwens, Alternate linkt wat moeilijk. ;)
Dus de VGA en Chipset
ben ook van plan om mijn graka te OC
Specs :
P4 2.6 Ghz @ 3.2
Mobo : P4GD1
graka : Geforce 6600 GT PCI-E
2X 512 DDR RAM pc 3200
Maxtor 120 Gb
Maxtor 40 Gb
Pinnacle PCTV rave
DVD schrijver
DVD lezer
en dan nog 3 Fans
en zou dan die set in deze case passen
set : http://www.alphacool.de/x...ts_id=115&cPath=5_302_169
Case : http://www.the-outsiders....ine/ObliviA/2128-2146.gif
Ty
Edit : link gaat weer
[ Voor 19% gewijzigd door Verwijderd op 24-10-2005 21:04 ]
  • arnoman
  • Laatst online: 20:13
Zo'n setje als dat past in vrijwel alle cases. Echter is de link van je case dood..
  • Roamor
Met een Dremel past alles natuurlijk, ook in deze Soprano. Volgens de specs heb je de beschikking over een 1200mm intake en outtake. Met een dual-rad van 2x120mm kom je dus aan beide uiteinden van je kast ruimte tekort. Als je geen bezwaar hebt tegen het verbouwen van je kast (bijvoorbeeld in het dak van je kast) dan kun je deze kast wel nemen. Zie je daar erg tegenop, dan kun je beter een fullsize kast nemen, zoals een Coolermaster Stacker oid.
ja die case wordt idd een probleem
als ik die 2x120 radiator neem en ik wil niet boren enzo moet ik al gaan voor zo een uber case van chieftec..(veel te groot vind ik)
http://www.the-outsiders....ne/ObliviA/BA-01B-B-B.jpg
Deze vind ik ook wel mooi maar dan heb je weer maar plaats voor 1x120 mm rad
http://www.the-outsiders....nline/ObliviA/BX-02BK.jpg
weet iemand misschien een case waar genoeg plaats voor is
  • Roet
  • Laatst online: 16:49
Afbeeldingslocatie: http://www.tweakers.net/ext/i.dsp/1126282531.jpg
Afbeeldingslocatie: http://www.alphacool.de/xt/images/product_images/popup_images/3393_0.jpg
Review
Gigabyte Aurora. Past standaard een 240mm rad in en er zitten 2 gaten voor slangen aan de achterkant.
  • _avalanche_
  • Laatst online: 12:09
<!-- ik weet niet of het hier mag maar in vraag en aanbod reageert er toch niemand op. Ik heb hier een 120mm rad liggen (volgens mij gewoon een blackice) die mag voor €10,- ik weet niet of iemand intresse heeft? -->
Modbreak:Dit is niet de bedoeling. Voor vraag en aanbod hebben we http://tweakers.net/aanbod
[ Voor 23% gewijzigd door Twynn op 26-10-2005 13:29 ]
  • sander817
  • Laatst online: 15-11 19:37
sander817
5260 Wp + 13,2GJ Zonneboiler
<!-- ja
mail me at s-kerkhoff@home.nl -->
iemand ervaring met betsllen bij aquacomputers.de?
[ Voor 5% gewijzigd door Twynn op 26-10-2005 13:30 ]
  • arnoman
[modbreak]Dit is niet de bedoeling. Voor vraag en aanbod hebben we http://tweakers.net/aanbod [/modbreak]
1300A schreef op dinsdag 25 oktober 2005 @ 10:04:
Hé 1300A, dit is idd hier niet de bedoeling. Ik ben echter wel heel erg geïnteresseerd! Ik heb je geprobeerd te mailen, maar je hebt geen mail/msn adres in je profiel staan...
Je aanbieding is trouwens niet terug te vinden in de VA -->
[ Voor 15% gewijzigd door arnoman op 19-06-2019 14:12 ]
Op gebied van waterkoeling ben ik een echte noob
Bij de Bigwater SE heb je een pomp die 90 L /h doet
En bij de Alphacool Basic Set 240 Radiator Socket 600 L /h
Hoe meer L op een uur hoe bter toch ? Maakt dat nou zoveel verschil uit voor je temps ?
greetz
Ty voor de replay van de case weet je misschien nog 1tje met een window ?
  • martijn_tje
  • Laatst online: 14-11 12:53
Lijkt me een heerlijke kast om een WC in te bouwen. Niet al te groot en makkelijk om je rad in kwijt te kunnen
Sony A6600 + Sigma 16 f/1.4, Tamron 17-70 f/2.8, Sigma 30 f/1.4, Sigma 56 f/1.4, Tamron 70-180 f/2.8 en Meike Mk320
Misschien is dit wel een mogelijkheid
Afbeeldingslocatie: http://www.the-outsiders.sohosted.com/online/ObliviA/Case.JPG
Cooling System
Front (intake)
120x120x25 mm, Blue LED Fan, 1300rpm, 17dBA
120 x 120 x25 mm blue LED fan, 1300rpm, 17dBA
Als je de radiator vanvoor zet in de case ?
  • lemming_nl
mail me :) lemming_nl @ hotdinges
[ Voor 14% gewijzigd door Twynn op 26-10-2005 13:31 ]
Geluk is een weerloos oud vrouwtje, alleen op straat met een bom geld
Verwijderd schreef op dinsdag 25 oktober 2005 @ 18:12:
Cooling System
Front (intake)
daar zit afaik die hdd rek voor.
  • icecoolsniper
  • Laatst online: 15-11 23:22
icecoolsniper
never run from a sniper!
Eergisteren is mijn pompje van mijn ttake aquarius in rook opgegaan. Ik heb een nieuwe pomp en een nieuw reservoir uitgezocht.
De pomp is de asetek hydor l20 met 10mm fitting. Het reservoir is de asetek dyo rsv02 met 10mm aansluitingen. Het probleem is echter dat de aquiarius 6mm slangen heeft en ik kan nergens 6mm>10mm verloopstukjes vinden. Ik heb ook al gezocht naar 6mm>8mm en 8mm>10mm en ik kan alleen de 8mm>10mm koppelstukjes vinden.
Weet iemand misschien waar ik deze koppelstukjes kan halen?
http://www.tweakers.net/gallery/58175/sys
  • ravenge
  • Laatst online: 06-11 16:36
ravenge
Wij Schoppen Kont!
Eindelijk draait mijn WC-setupje een beetje stabiel. Had in het begin wat aanslag doordat ik alleen maar gedestilleerd water had gebruikt. Heb de boel pas schoongemaakt en hem maar gevuld met koelvloeistof. De pomp die ratelde ook, maar dankzij wat teflon tape is hij nu stil :Y)
Specs:
Asus P4P800-E deluxe
CPU: P4 2,53Ghz + Alphacool NexXxoS HP Pro
Hercules 9700 pro + Innovatek Graph-O-Matic
2x256 MB Dane-Elec DDR400 dual channel
Eheim 1048 (met teflontape mod)
Dual 120MM Rad
8mm slangen
Heb geen NB koeler, vond ik niet echt nodig.
Cpu geeft idle iets van 36C, stressed heb ik niet echt gebenchmarked maar dat zit daar niet ver vanaf. :)
Pic's:
Afbeeldingslocatie: http://www.ravenge.dds.nl/Tumbnails/DSC04167_thumb.JPG
Afbeeldingslocatie: http://www.ravenge.dds.nl/Tumbnails/DSC044421_small.jpg
Tis nog niet netjes in de kast maar dat komt nog wel ;)
Voor het bepalen van mijn WC setup heb ik veel in dit topic gelezen en heb daar veel aan gehad, dank daarvoor _/-\o_
  • arnoman
Een beetje extra cable management kan geen kwaad :)
Voor de rest leuke setup, wat voor case is het?
Ik denk van DIY :+
Het ziet er erg mooi uit ;-) . Bij mijn vorige kast had ik dat ook alle schijfen onderin met een plek voor een stuk of 8 (met ventilatie ruimte er tussen).
Verwijderd schreef op zondag 23 oktober 2005 @ 15:57:
ik heb mijn waterkoelings spullen altijd bij bytesatwork gehaald, super zaak. kreeg toen zelfs korting was ik nog goedkoper uit, dan als bij alphacool zelf >:)
Hoe had jij dat voor elkaar gekregen ?
Ik heb ondertussen al me bestelling gewijzigd en het is nu wachten op alphacool. Ik kreeg van bytes @ work dat hun elktijd het hele pakket aanbieden van aplhacool. Het staat alleen niet zo duidelijk op de site, maar dat zijn ze van plan om het er duidelijker op te zetten.
sander815 schreef op dinsdag 25 oktober 2005 @ 10:40:
<!-- ja
Ja, betaald met credit card en afgezien van een paar lullige mailtjes dat de bestelling verzonden was nooit meer iets gehoord. Bestelling zou op 4 oktober verzonden zijn maar hier nooit aangekomen. Erg fijns, 160 euro naar de kloten! }) }) }) }) Kreeg vandaag eindelijk een berichtje dat het pakketje echt verstuurd is en al 6 x aangeboden maar er niemand thuis was. Waarom laten ze dan geen berichtje achter in de brievenbus? 8)7 8)7 8)7
[ Voor 19% gewijzigd door Verwijderd op 27-10-2005 01:34 ]
Verwijderd schreef op dinsdag 25 oktober 2005 @ 19:19:
dat is niet het probleem die kan je eruit halen :P
hoi
Op het gebied van waterkoeling ben ik een echte noob!
Maar ik wil gaan OC mijn cpu is een p4 2.6 Ghz @3.2 Ghz en een zalman koeler en die is idle zo een 24 ° stresed 35 ° Dus daar ga ik geen waterkoeling opzetten.
Mijn VGA wordt stresed 65 ° dus ik zou waterkoeling voor VGA en chipset willen omdat ik mijn Graka wil OC
Ik heb het volgende setje samangesteld
Radiator Dual Alphacool NexXos Pro 2 30 €
Water additive Tec-prtect clear 1 L 8 €
Flue green UV 4.50 €
Fans 2x 120 mm North Q tornado 40 €
Pomp Eheim 600 Station 40 €
ik heb nog geen VGA koelblok gevonden voor men VGA (Geforce 6600 GT pci-e , iemand een voorstel ?)
Slangen 5 €
Totale prijs : een 170 €
Nu is men vraag is dit een goei setje om te beginnen ? en valt ook de prijs mee ?
Of is het misschien beter om met een Thermaltake Bigwater Se te beginnen
Edit : ik wil vooral gaan voor de stilte en de prestaties
[ Voor 4% gewijzigd door Verwijderd op 26-10-2005 16:54 ]
Nogal dure fans en zo weinig voor een radiator uitgeven ?
Ik zou voor de fans wat minder uitgeven en met het geld wat je dan overhoudt een extreme neme, die wordt ook geleverd met een hele set schroeven + silicone fan decoupling voor nog stiller resoltaat.
Waterbloks die ook het gehugen coolt van een 6600 ken ik niet, maar wie weet kan je het wel vinden met google.
[ Voor 43% gewijzigd door Verwijderd op 26-10-2005 17:50 ]
De gewone is wat dikker en met 30bar getest. De Xtreme is met 8bar getest, welke beter koelt durf ik niet te zeggen. Al is erg mischien wel een revieuw die het antwoord heeft.
  • Vandread
  • Laatst online: 09:42
http://www.alphacool.de/x...ucts_id=713&cPath=5_34_35
Die kiezen, die heeft platte lamellen waar het water doorheen gaat wat dus beter voor koeling en flow is :)
PilatuS schreef op woensdag 26 oktober 2005 @ 19:57:
Ik ben er vrij zeker van dat de Alphacool NexXxoS HC 240-LE beter koelt dan Alphacool NexXxoS Xtreme I.
En die ik laat zien nog beter 8)7
[ Voor 43% gewijzigd door Vandread op 26-10-2005 20:05 ]
  • PilatuS
[ Voor 19% gewijzigd door PilatuS op 26-10-2005 19:57 ]
Ok als ik die dan neem :
http://www.alphacool.de/x..._id=713&cPath=5_34_35
En voor de rest heb ik dan een goede waterkoeling ?
Alphacool NexXxoS Xtreme II: 37 €
Slangen 5 €
[ Voor 5% gewijzigd door Verwijderd op 26-10-2005 20:15 ]
  • magiel
  • Laatst online: 09-11 14:17
Ik ga bij Aquacomputer.de het een en ander bestellen, maar nou wil ik ook de niet onbekende Tygon Slangen hebben. Alleen is mijn duits niet meer wat het geweest is toen ik nog op middelbare school zat 2 jaar tjes geleden, dus weet iemand hier of deze
slangen Tygon slangen zijn?
Ik wil het er _niet_ over hebben.
  • Vandread
PE is PVC? dacht ik... geen tygon.. is het ook te goedkoop voor aangezien dat voor 9-10 euro de meter gaat :+
Ik denk ook wel dat de Alphacool NexXxoS HC 240-LE: beter is als de Alphacool NexXxoS Xtreme II: Alphacool NexXxoS Xtreme II:
Want bij de Hc 240 is al 4 € duurder + je hebt er ook geen fans bij en bij de Xtreme II krijg je al 2 fans
  • arnoman
AC verkoopt geen tygon, dat past niet in het plug-and-cool aansluitingen
  • Vandread
Verwijderd schreef op woensdag 26 oktober 2005 @ 23:23:
Wat een onderbouwing 8)7 hij is duurder dus beter, een kachelradiateur van de autosloop is goedkoper en is nog beter B) Zie jij de logica ;)
Bij de Alphacool NexXxoS Xtreme II zie ik geen fans zitten?
Lieferumfang:
1x NexXxoS Xtreme II Radiator, 8x Schrauben M3 x 31mm
En bij de Alphacool NexXxoS HC 240-LE:
Lieferumfang: 1x NexXxos HC-Radiator Dual, 4x
Schrauben
De extreme II lijkt duidelijk op een BIX welke toch vaak tot een van de betere behoort.
  • magiel
Vandread schreef op woensdag 26 oktober 2005 @ 23:06:
Humz, vervelend, ik heb 3 meter meebesteld. Dat word dus even m`n engelse kennis raadplegen, en hopen dat ze inderdaad engels begrijpen bij AC.de.
  • arnoman
magiel schreef op donderdag 27 oktober 2005 @ 00:16:
Zie mijn post..
En ja ze spreken daar engels (ze hebben tenslotte ook een UK forum ;) )
ObliviA007 schreef op woensdag 26 oktober 2005 @ 23:23:
Bel/ mail ze en vraag het ;)
  • Vandread
"Arnieeeee wiefiel ist die winstmarge auf diese tzwei radiatoooren"
*antwoord*
"Alsogut jah! Ich schik mal die mit die groosste marge"
  • 3p0x
  • Laatst online: 11:42
Vandread schreef op donderdag 27 oktober 2005 @ 00:05:
Lieferumfang:
Schrauben
Ik denk dat ie "2x 120mm silicone fan decoupling" heeft zien staan :+
Net ff een setupje uitgezocht voor me beide dual opterons: samen bijna 400 euro 8)7 daar wacht ik nog wel ff mee...
Alpacool is wel een stuk goedkoper, ik ben nu nog maar iets meer dan de helft kwijt _/-\o_
[ Voor 7% gewijzigd door 3p0x op 27-10-2005 11:31 ]
  • Fuske
  • Laatst online: 30-10 14:14
Ben sinds kort ook op zoek naar waterkoelsetje mijn oog viel meteen op de volgende waterkoelingsetjes:
Thermaltake Bigwater SE €90,- alleen cpu blokje
Thermaltake Rocket €125,- alleen cpu blokje
Kingwin AWC-1 €120,- cpu en vga
Ik wil gewoon een simpel, en niet te duur setje waar ik m'n cpu en vga mee kan koelen, eventueel ook nog de chipset maar dat is geen punt.
Welke van deze 3 zou ik dan het beste kunnen nemen gekeken naar:
totaalprijs(dus eventueel met alle koelblokjes erbij) - prestaties - geluid.
Andere tips zijn ook welkom
[ Voor 21% gewijzigd door Fuske op 27-10-2005 11:59 ]
  • arnoman
tommy schreef op donderdag 27 oktober 2005 @ 11:42:
Thermaltake Rocket
Kingwin AWC-1
We weten niet allemaal precies hoe duur elk setje is hoor ;) richtprijzen kunnen geen kwaad :)
de rocket is natuurlijk het stilst, maar de peformance.. dunno
  • Fuske
Prijzen erbij gezet
  • arnoman
Tommy, al eens naar 2ehands oplossingen gekeken? In sommige gevalle zelfs goedkoper en zeker beter presterend.
  • Fuske
arnoman schreef op donderdag 27 oktober 2005 @ 12:04:
Had ik al gedaan, maar staat op dit moment niet veel soeps op. Hooguit een bigwater setje met flow indicator http://tweakers.net/aanbod/advertentie/23104
[ Voor 14% gewijzigd door Fuske op 27-10-2005 12:15 ]
  • Vandread
http://tweakers.net/aanbod/advertentie/21395 ?
edit: eventuele commisie bereken ik nog wel :+
[ Voor 36% gewijzigd door Vandread op 27-10-2005 14:20 ]
  • Fuske
Hmm had niet gezien dat hierbij alles bijzat, dacht alleen de cpu block. Probeerde met net aan te melden bij tweakers.net, dit moest om te kunnen mailen. Even geregistreerd maar nu krijg ik maar geen activatiecode toegestuurt.. :?
[ Voor 23% gewijzigd door Fuske op 27-10-2005 14:22 ]
  • arnoman
tommy schreef op donderdag 27 oktober 2005 @ 14:14:
Tjek je bulk mail of mail femme
  • Fuske
Ik heb um al binnen gekregen...
Heb diegene gemailt nu nog even wachten op een reactie! €130 euro is dat te doen? Of hoeveel is zoiets nog waard. €240 nieuwprijs. Gaat hier om de Waterchill KT12-L20
Ligt heel erg af van de staat, geen roest, plexiglas nog goed doorzichtig, de onderkant nog mooi spiegelend of moet het opnieuw worden gepolijst ?
En geen scheurtjes in de plexiglas. Al moet ik zeggen dat het voor de prijs van 130 euro het in zeer goede staat moet zijn wil deze prijs redelijk zijn.
Bij http://www.bytesatwork.be/ die alles op aanvraag leverd van aplha cool.
CPU Alphacool 35,-
Radiator Alphacool NexXxoS Xtreme II 40,- (twee keer 12cm fans nodig)
GFX Alphacool NexXxoS GPX-N Geforce 30,-
Fitting 1/4" 8/10mm 8X1,30 = 10,40
PVC Tube 8/10mm (1m) 2X2,20 = 4,40
Water additive power fluid Blue UV 5,-
Resevoir van een blokker bakje 3,-
Gedistileerd water bij de halfords ±2,30
Bestel kosten 9,-
Totaal 139,-
Alphacool heeft ook leuke setjes http://www.alphacool.de/xt/index.php?cPath=5_302 . Je moet even aan bytes @ work vragen of er nog wat bij de prijs bij komt.
In dit geval zal ik voor de nieuw koop gaan. Geen gedoe met schoonmaken van waterblokjes, opnieuwe polijsten. beschadigenen, en dat er onderelen missen (is bijna elktijd met tweedehands).
Waneer ik me besteling binne heb dan heb ik binne kort een cpu blok, auto radiator, 600L/H pomp die dan de deur uit mag voor totaal 50,- (het cpu blok zal ik nog wel even polijsten).
Oja, wat zijn je spec's. De waterblokjes moete natuurlijk wel passen ;)
[ Voor 11% gewijzigd door Verwijderd op 27-10-2005 15:56 ]
  • Fuske
Specs:
AMD64 3000+ S939
Gigabyte k8ns-ultra 939 nforce 3
Radeon 9600xt
Maar ik wil liever een set kopen waarvan ik weet dat alles goed is etc. Bij een complete set hoef ik verder niks te doen. Als ik alles apart koop...misschien beter voor zelfde geld. maar ik zou echt niet weten wat ik allemaal moet kopen en waar ik moet beginnen, Ben egt een nieuweling op het gebied van waterkoeling. Iemand toevallig zin om een setje voor me samen te stellen die goed is voor mijn specs? :*) _/-\o_
[ Voor 77% gewijzigd door Fuske op 27-10-2005 16:05 ]
Alpha cool heeft opzich wele en aardige compleete set
Ik ga later op de dag wel kijken wat het kost waneer je het los koopt zodat je 8/10mm slang kan neme, en schroefslang klemmen in de plaats van de push ins.
Wel je ook je chipset waterkoelen ? (kost ongeveer zo 29 euro meer.)
[ Voor 12% gewijzigd door Verwijderd op 27-10-2005 16:47 ]
  • Fuske
Hmm dat is niet zo'n punt, als het derbij zit is ut altijd handig natuurlijk...
Ik ben eindelijk van plan om mjn PC ze voorzien van waterkoeling. Ik ben van plan om een setje te kopen bij aquacomputers.de bestaande uit de volgende onderdelen:
1 x aquastream 12V Pumpe Rev. 3.5
1 x cuplex XT 2-Loch-mounting A64 without fittings
1 x aquagraFX for 7800 GTX without fittings
1 x twinplex Rev. 1.2 Chipset without fittings
1 x aquadrive Dual BLUE without fittings
2 x Water reservoir aquatube Rev. 1.1 without fittings, black
1 x ClearBlue Wasserzusatz 50 ml UV-aktiv
1 x aquaero 4.00 USB Fan-Controller, VF-Display
plus nog 2 keer een BI rad.
Ik ben een absolute n00b in waterkoeling dus heb ik een aantal vragen:
Er staat bij de koelblokken "without fittings", maar welke fittings moeten er dan bij? En welke maat slang. Ik kwam er niet echt uit op de site. En is deze opstelling goed?
  • Arieke
  • Laatst online: 24-05-2022
Arieke
live your life, dont waste it.
ik was voor een voeding aan het zien voor een peltier, ik had op conrad.nl die reingkern transfos gezien. Ze leveren 15V en leveren 5A dus dat is voldoende om een peltier van 40w aan te zetten. Maar op die datasheet heb ik gezien dat die Uo 16.53V is. Maar die peltier is voor een max van 15.4V. Dus ik kan deze voeding gebruiken of niet?
P4 2.4Ghz @ 3.5Ghz l MSI 875P Neo FIS2R l 512MB 400Mhz @ 466 Corsair x2 l WD 120 Gb 7200 | Sapphire 9700Pro 128Mb DDR 399/714Mhz l Benq 52/32/52 | Chieftec MX-01BLD-S l Hercules Fortisimo III 7.1 | Air Cooling all the way
Ik heb mijn setje eindelijk uitgekozen maar nu is de vraag welke slangen of screws of plugins moet ik gaan kopen ? zijn de dikke slangen het mooiste ?
Rad : Alphacool NexXxoS Xtreme II: http://www.alphacool.de/x...ucts_id=713&cPath=5_34_35
Pomp : moet je daar ook schroeven ofzo voor kopen ? http://www.alphacool.de/x...ucts_id=823&cPath=5_26_27
en Die Eheim 600 station zit daar al een reservoir in ?
  • Vandread
Verwijderd schreef op donderdag 27 oktober 2005 @ 17:50:
Please order your wished connections under Hoses&Connections! staat er bij :+ dus wat denk je?
imho zijn dikkere slangen beter maar! de koppelingen zijn weer van dit soort systemen zijn nogal klein vaak dus ik denk dat 10/8mm prima is :) met Screw connection adapters 10/8mm en je bent klaar :)
En wtf bedoel je met of er bij dat station ding een reservoir in zit... dat hele ding IS een reservoir?
dat is toch een pomp ^^
  • sander817
sander817
pomp en res ineen ja :)
tommy schreef op donderdag 27 oktober 2005 @ 16:55:
Bij www.bytesatwork.be
CPU Alphacool NexXxoS XP Bold AMD 64 35,-
GFX Alphacool GP-A ATI 9xxx 30,-
Alphacool NexXxoS Xtreme II Radiator 40,-
Fitting 1/4" 8/10mm 1,30 X 8 = 10,40
Slang Pur 10/8mm high transparent (uv gekleurde slangen is ook mogelijk) Geschat 3 euro/per meter 2 X 6,-
Water additive power fluid Blue UV(je heb keuze uit meerder kleuren ) 5,-
Pomp + resvoir Alphacool AGB-Eheim 600 Station Geschat 45,-
Totaal 173,70
Optie twee
Alphacool Basic Set 240 Radiator Socket939 geschat 140,-
Fitting 1/4" 8/10mm 1,30 X 2 = 2,60
Totaal 172,60
(verschil) Dunner slang, pus in slang aansluitingen in de plaats van schroef klemmen, twee 12cm fans, 0,5L destileerd water met fluid in de plaats van 1L)
Aangezien somige producten niet op de site staan van byt@work moest ik somige prijzen schatten. Waneer je de setup wilt gaan bestellen kan je ze het beste een mailtjes sturen met een de lijst wat je wilt bestellen.
Dit zijn twee compleete configs, al moet je bij config 1 nog wel twee 12cm fans aanschaffen mog je die niet hebben. Veder kan je voor iets meer prijs je waterkoel set verbeteren. Een triple rad voor 9 euro meer, voor iets meer een cpu blok met verlichting, enz. Daarom raad ik je aan voor dat gaat bestellen even rond te kijken op http://www.alphacool.de/xt/index.php?cPath=5 en www.bytesatwork.be . Later maar horen als je weet wat je uiteindelijk wilt bestellen.
@ObliviA007
Je moet voor je pomp, radiator en cpu blok slangaansluitingen bestellen aangezien alphacool ze er niet standaard bij leverd.
[ Voor 6% gewijzigd door Verwijderd op 27-10-2005 20:11 ]
  • Vandread
dude... ga es lezen en kijken!
http://www.alphacool.de/x...es/popup_images/823_0.jpg
Is toch duidelijk bedoelt als reservoir.
Je kan de boel ook op engels zetten he, dan staat er een hele boel een stuk duidelijker (voor mij iig :P)
Trouwens JCKEN krijg jij comissie van alphacool ofzo :*) ;)
Nee, maar ze zijn gewoon goedkoop :+ en op den duur ken je zo hun prijze uit je hoofd :) . Ik vergat alleen nog iets.
Meer prijs voor chipset koeler;
MB Alphacool NexXxoS NBX-A Northbrid 26,-
Schroefklemmen 8/10mm 1,30 X 2 = 2,60
Totaal 28,60
Je kan er ook voor kiezen om eventueel een paar onderelen tweedehands te kopen of via een inkoopactie om d ekosten te drukken.
[ Voor 20% gewijzigd door Verwijderd op 27-10-2005 20:32 ]
  • sander817
sander817
wat is het verschil tussen pushin en die metalen schreofkoppelingen? de eerste is slang induwen en klaar, de andere is slanginduwen, aanschroeven en klaar?
weet iemand of je van een swiftech mcp556 ook van de 1/2" naar de 10/8 mm van de alphacool connectors kunt gaan?
Heeft die 1/2 inche schroef aansluitingen waar je de slang aansluitingen nog in moet draaien, of heeft die een aansluiting voor 1/2Inche slang ?
Je hebt in iedergeval diversen slankopelingen met een 1/2 schroefdraad, voor welke maat 1/2inche slang staat weet ik niet. Maar er zijn vast wel andere die dat wel weten.
Schroef kopelingen zijn wat steviger tot zo ver push in. Al zijn er somige die liever voor push in kiezen
  • sander817
sander817
zie hier: http://www.swiftnets.com/products/mcp655.asp
geen idee
of levert zon pomp te veel druk voor een 10/8 mm slangen? (alphacool)
1/2" ID tubing Of wel 1/2inch slang aansluiting, ik weet alleen niet voor welke maat 1/2inche slangg staat in mm.
Het hoef geen probleem te zijn aangezien je in de plaats van de 8/10mm schroefslang klemmen ook slangpilaren kan neme tot wel 12mm.
[ Voor 8% gewijzigd door Verwijderd op 27-10-2005 22:56 ]
  • Fuske
Ik denk toch dat ik een nieuw ga kopen. En dan wel de Bigwater SE. Maar kan ik met het standaar pakketje dus pomp-reservoir-cpu block, ook nog het vga block aanhangen, zonder dat ik een andere pomp of radiateur ofzo moet aanschaffen..?
ja dat kan allemaal maar ik weet niet als het dan nog zo goed gaat koelen , dan moet je eerder ook al een ander radiator kopen
  • Fuske
En welke zou ik dan moeten kopen? €?
Ik denk een Dual rad ofzo ~40 €
  • Fuske
die m2 radiator van thermaltake is die goed genoeg?
  • Fuske
Hmmm net bij megamagazijnomruiming.nl van mycom:
Koolance liquid cooled case. Zit alles bij behalve de koelblokken..€199
tommy schreef op vrijdag 28 oktober 2005 @ 10:21:
Gaat wel lukken, aangezien de Radeon 9600xt niet zo veel verbruik. Al kan je wel minder ver occen, ik zal zowiezo voor een dualrad gaan.
Aangezien je niet de juiste link heb gegeven kan ik niet zien om welke het gaat. Koolanche is niet echt the way to go voor waterkoeling producten. Door op zoek te gaan naar revieuws kan je er wel wachter komen wat nou beter koelt (koolance of de Bigwater SE).
  • Fuske
Hoezo voor zowiezo een dual rad? Thermaltake heeft ook een rad M2. €40,- als ik die erbij hang of hoe dat ook werkt is dat dan genoeg voor m'n hele systeem.
Dus CPU-GPU-NB
Ik heb een Thermaltake Bigwater, nu wil ik mijn northbridge ook waterkoelen omdat ik daar nu een passief ding op heb van Zalmann, maar die wordt veel te warm! Weet iemand een goed koelblokje voor de NB wat op de Bigwtaer past..
Ik heb zelf deze gevonden:KLIK
Zou deze passen en werkt deze goed bij Bigwater?
trouwens.. Even een compliment voor mijn WC set.. Na 3,5 uur Serious Sam 2 gespeeld te hebben werd m'n proc niet warmer dan 41! :) Nou als dat niet stressed is dan weet ik het niet! :) Ben er dus wel blij mee!
[ Voor 22% gewijzigd door Verwijderd op 28-10-2005 18:09 ]
kheb nog een vraagje
is er veel verschil tussen een Dual Rad of 2 x een single Radiator ?
Gaan die 2 gewone radiators enevn goed koelen als een Dual ?
Ty
  • Roamor
Verwijderd schreef op vrijdag 28 oktober 2005 @ 18:08:
Ty
2x single is flexibeler om op te stellen, maar het brengt ook meer werk met zich mee uiteraard. Qua koelcapaciteit zal er geen verschil zijn.
tommy schreef op vrijdag 28 oktober 2005 @ 15:19:
Dus CPU-GPU-NB
De nut om waterkoeling toe te passen is om goede temps te halen, daarom vind ik een dual rad zeker zinvol. maar is net wat je wilt, vandaar dat je zelf moet beslissen wat je nu gaat doen.
Verwijderd schreef op donderdag 27 oktober 2005 @ 17:20:
Hey Hardware-4u heb je de spullen al besteld ?
ik heb hier namelijk nog een ongebruikte xt liggen voor amd64 mocht je intresse hebben wil em voor ong 50 euro verkopen( hij is nieuw en niet gebruikt )
voor de rest is het een zeker een goede setup naar mijn mening
Grt
[ Voor 7% gewijzigd door Verwijderd op 28-10-2005 21:28 ]
  • arnoman
Verwijderd schreef op vrijdag 28 oktober 2005 @ 18:43:
De nut om waterkoeling toe te passen is om goede temps te halen, .
en stilte ;)
stilte kan je ook met luchtkoeling ook erg goed voor me kaar krijgen hoor.
MIj gaat het vooral om de prestaties te verbeteren.
[ Voor 28% gewijzigd door Verwijderd op 29-10-2005 15:42 ]
  • arnoman
Verwijderd schreef op zaterdag 29 oktober 2005 @ 15:41:
Het is waar dat je met luchtkoeling tegenwoordig heel erg in de buurt kunt komen ja. Maar toch is waterkoeling toch stiller, met daarbij komend betere temperaturen
Stilte kun je natuurlijk per definitie niet voor elkaar krijgen met luchtkoeling. Niets irritanters dan het gezoem van fans, hoe zacht ook.
  • arnoman
Verwijderd schreef op zaterdag 29 oktober 2005 @ 18:35:
Idd nu ik erover nadenk, waterkoeling kent ook passieve oplossinge 8)7
m.a.w. met luchtkoeling kan je idd nooit net zo stil zijn als waterkoeling :7
  • k0ewl
  • Laatst online: 14-11 10:50
Is het niet zo dat als je je radiator koelt met een stel fans die ook lawaai maken?
Maarja ik zat zelf ook te denken aan een waterkoeling setup.
- CPU: Zalman ZM-WB3 GOLD
- GPU: Zalman ZM-GWB1
- Northbridge: Zalman ZM-NWB1
Maar ik moet er alleen nog een radiator bij zoeken en een pompje.
In de kast heb ik geen plaats voor een 120mm radiator daarom aan de achterkant een dubbele 80mm radiator
A byte walks into a bar and orders a pint. Bartender asks him "What's wrong?" Byte says "Parity error." Bartender nods and says "Yeah, I thought you looked a bit off."
  • arnoman
k0ewl schreef op zaterdag 29 oktober 2005 @ 20:37:
:Y)
Een mooie dual 80mm Bi-Ex of zo'n mooie blauwe switch dual rad?
Die Zalman blokken die je wil zijn over het algemeen zeer goed te krijgen in de VA, misschien de moeite waard?
Daarom ga ik ook voor de reserator plus. Waterkoeling zonder fans.
  • lemming_nl
Verwijderd schreef op zondag 30 oktober 2005 @ 11:49:
Zit nog steeds een pomp in die ook geluid maakt...
Aangezien voeding overleden is van mijn pc maak ik mooi van de gelegenheid gebruik om mijn waterkoeling te installeren. Wacht nog op het binnen komen van een vga en chipset blokje en dan kan ik het geheel eens gaan testen. Wel krap, waterkoeling in een antec sonata zonder hem te modden :P. Eheim 1048 op bodem van kast staan. Rad buiten de kast (kachel radiator, past never nooit in de kast (is zo'n beetje even breed) en achterop monteren gaat helaas ook niet vanwege de breedte en kabels maar hij koelt wel lekker :D.
  • Roamor
lemming_nl schreef op zondag 30 oktober 2005 @ 13:09:
Geloof me, die hoor je niet. ;) Alleen als je je oor tegen de Reserator houdt, zul je hem heel zachtjes horen. Aangezien het nooit echt stil in je kamer, kun je veilig stellen dat je die pomp niet gaat horen.
Na wat doorgelezen te hebben op tweakers.net dacht ik dat de reserator de ultieme koeloplossing zou zijn. Helaas heb ik de laatste tijd al weer teveel geld erdoorheen gejast om ook nog iets als een reserator te kopen. Bovendien was ik bang dat de reserator (kleine 300 euro voor 3 voudige koeling) niet voldoende zou zijn voor de drievoudige koeling van Amd 64 3200+ (newcastle, probeer 20% over te klokken), NForce4 en Ati radeon 9800+ die ik ook nog wat harder wil gaan laten lopen. We gaan dus gewoon voor een radiator (passief omdat ik de huidige herriebak de mond wil snoeren, staat in me kamer en is always on) icm met http://cgi.ebay.nl/ws/eBa...?ViewItem&item=6814816982 & http://cgi.ebay.nl/ws/eBa...?ViewItem&item=6813234397 en een radiator voor passieve koeling (nog mee in onderhandeling).
Edit: die radiotor is geen zuinige hoor: 17 cm dik, 29 cm breed en 36 cm hoog. En mocht ik niet de uitverkorene voor die radiotor zijn, dan kunnen we altijd nog een innovatek radiator nemen of we gaan riching de autosloop...
Momenteel heb ik een Asus k8v deluxe (met Via chipset), maar heb nu een MSI mobo aangeschaft (zie: http://cgi.ebay.nl/ws/eBa...?ViewItem&item=6814759572). Gelukkig met AGR zag ik later (stelletje apparten, bovendien staat me 9800 Pro niet in compat. lijst, maar blijkt er toch wel op te werken 8)7). Ik zal hiervoor ook nog ff een geheugenbenchmark doen.
Ik ga ook proberen de huidige snelheid (en lawaai) van de 120 mm fan van me ATX 450W voeding 50% (of variabel) te verlagen; is niet meer nodig nl. Ik heb helaas geen dB meter (mn broer op z'n mobiel, maar of die nou zo betrouwbaar is...), dat zou ook interessant zijn, denk ik.
Ik zal een uitgebreide review schrijven over de WC-installatie en behaalde temperaturen. :)
En natuurlijk uiteindelijk de win 64 uittesten, maar dat mag hier niet :o.
Tot zover de roadmap voor Aldert's 64'je
[ Voor 8% gewijzigd door Verwijderd op 30-10-2005 14:51 ]
  • Fuske
Ben aant twijfelen tussen 2 waterkoelingsetjes:
wil in de toekomst ook mijn nb en vga ermee gaan koelen.
Nieuwe Bigwater SE. €86,- pw-prijs
2ehands asetek watechill kt12-l20: Vraagprijs €130
  • Dark Angel
  • Laatst online: 15:58
Dark Angel
Corvette LS Power
Ik heb vandaag een waterkoeling set samen gesteld, alleen ben ik er nog niet uit wat voor koelblok ik moet gebruiken voor mijn SLI setup met 2x7800gtx.
ik heb tot dus ver besteld:
Pomp: Swiftech MCP655
CPU: Danger Den DTX athlon 64
Rad1: Blackice pro 2
Rad2: Blackice Extreme
Slang: Tygon 1/2"
Res:coolplex 25
Kan iemand mij een advies geven welke 7800 werken met 1/4" schroefdraad aansluiting voor 1/2"slangepilaren.
Ik weet dat er een Danger Den set is maar die is nog niet makkelijke te verkrijgen.
|D3 Battletag: <SG>DarkAngelnl#2829| WOT DarkAngelnl
  • rabor
  • Laatst online: 19-06 11:49
Dark Angel schreef op zondag 30 oktober 2005 @ 18:40:
Ik heb mijn DD SLI-kit HIER gekocht..
Kepi_nl
  • Motaro
  • Laatst online: 11-11 10:26
Motaro
PSN: Sovietwarbear_NL
ik heb dit nu in bestelling staan Innovatek Cool-Matic NV40LE / G70 heeft iemand hier ervaaring mee of hij goed koelt ? op een 7800 GTX
Ik heb dyslexie, hierdoor is mijn schrijftaal niet helemaal correct. Stoor je er niet aan, doe ik zelf wel:)
  • k0ewl
Voordat ik dus mijn setje ga bestellen vroeg ik mij af of die Zalman ZM-GWB1 een niet overclocked X800 kan koelen. Ik kan het namelijk nergens vinden op de Zalman site terwijl er bij de rest van de producten wel een snelheidsindicatie bijstaat.
En zal het genoeg koelen als ik de volgende setup maak:
Afbeeldingslocatie: http://img382.imageshack.us/img382/1617/cooling1ym.gif
1: Dual 80 mm radiator Black Ice Micro II
2. Zalman ZM-WB3 Gold (komt een 4400+ X2 onder)
3. Zalman ZM-NWB1 (nForce4 chipset)
4. Pomp (nog geen idee over doorstroomsnelheid, want tis mijn eerste watercooling setup)
5. Zalman ZM-GWB1(Sapphire X800)
Nog iemand tips waar ik op moet letten en natuurlijk of dit setje mijn systeem aankan?
[ Voor 8% gewijzigd door k0ewl op 30-10-2005 23:15 ]
  • lemming_nl
k0ewl schreef op zondag 30 oktober 2005 @ 23:14:
Ik zou de loop van het water anders maken. Aangezien de cpu de meeste warmte afgeeft wil je daar het koudste water. Dit komt van de radiator af. Beste loop is: Pomp - Rad - CPU - Graka/NB - Pomp - Rad. Door de pomp voor de radiator te zetten geeft de pomp geen warmte af aan het water voor koeling.
  • arnoman
tommy schreef op zondag 30 oktober 2005 @ 16:50:
zeker de waterchill!
  • PilatuS
lemming_nl schreef op maandag 31 oktober 2005 @ 07:15:
Volgorde maakt niets uit.
Het water stroomt zo snel door het systeem dat het nauwelijks tijd heeft om op te warmen, het temp verschil voor en na het cpu blok zal minder zijn dan een halve graad.
Ik zou de volgorde nemen die het makkelijkste is, en dat lijkt mij zoals het op het plaatje te zien is.
