MSI 865 (P/PE/G) 875P Neo [Ervaringen Deel 2]
Pagina: 1 2 3 4 Laatste
  • 1.212 views sinds 30-01-2008
Afbeeldingslocatie: http://www.msi.com.tw/images/page/products/mainboard/product_mb_logo.gif
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/mbd_img/S_6728.gif
Deel 1
Deel 2 van het MSI 865(P/PE/G)/875P Neo [Ervaringen] topic
Post hier al je problemen, vragen, tips, ervaring, oc-ervaringen over de volgende moederborden van MSI:
865P
• 865P Neo (Standard Version)
• 865P Neo-L (Onboard 10/100 LAN)
865PE
• 865PE Neo2-S [Standard Version, Serial ATA(SB)]
• 865PE Neo2-LS [10/100 LAN, Serial ATA(SB)]
• 865PE Neo2-FIS2R [Gb LAN, IEEE1394, SATA(SB), Ultra/SATA RAID(Promise)]
nieuwe 865PE
• 865PE Neo2-PS [Standard Version, Serial ATA]
• 865PE Neo2-PLS [10/100 LAN, Serial ATA]
• 865PE Neo2-PFS [Gb LAN, Serial ATA]
• 865PE Neo2-PFISR [Gb LAN, IEEE1394, SATA, SATA RAID]
865G
• 865G Neo2-S [Standard Version]
• 865G Neo2-LS [Onboard 10/100 LAN]
875P
• 875P Neo-LSR [10/100 LAN, Serial ATA RAID]
• 875P Neo-FIS2R [GbE LAN, IEEE 1394, Serial ATA(SB),
Ultra/Serial ATA RAID(Promise)]
Specs 865PE
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/other/mainboard/pic/865pe_ht.gif
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(S478)
• Supports up 3.2GHz/800MHz and higher speed
Chipset
• Intel® 865PE Chipset
- Supports FSB 800/533/*400(Northwood only)MHz.
- Supports AGP 8X interface.
- Supports Dual Channel DDR 400/333/266 memory interface.
- A Gigabit Ethernet (GbE) controller is supported through the CSA interface.
• Intel® ICH5/ICH5R Southbridge
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, 8 ports.
- 2 Serial ATA/150 ports.
- 2 channel Ultra ATA 100 bus Master IDE controller.
- PCI Master v2.3.
FSB
• Support *100(Northwood only)/133/200MHz FSB
• Support *400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
Memory
• Supports four unbuffered DIMM of 2.5V DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• Supports Dual channel DDR266/333/400MHz and up.
Slots
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5/ICH5R.
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5/ICH5R.
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
- Supports Serial ATA RAID 0 (Optional)
Promise 20378 On-Board
• Supports Ultra ATA, Serial ATA, Ultra ATA RAID 0 or 1 , Serial
ATA RAID 0 or 1, Ultra/Serial ATA RAID 0+1 supported.
• Connect up to 2 Serial ATA devices and 2 Ultra ATA 133 devices.
Audio
• 6 channels software audio codec C-Media 9739A.
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via S-Bracket only.
LAN
• Intel® PRO/1000CT Desktop Connection and Intel® 82562EZ Dual layout.
- Integrated Fast Ethernet MAC and PHY in one chip.
- Supports 10/100Mb/s and 1000Mb/s (1000Mb/s only for Intel® PRO/1000CT)
- Compliance with PCI 2.2.
- Supports ACPI Power Management.
On-Board Peripherals
- 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port (COM A)
- 1 parallel port supports SPP/EPP/ECP mode.
- 1 Line-in/Line-out/MIC port
- 8 USB 2.0 ports (Rear x 6/Front x 2 or Rear x 4 / Front x 4)
- 1 RJ-45 LAN jack (Optional)
- 3 IEEE 1394 pinheaders (Optional)
Specs 875P
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/other/mainboard/pic/875p_ht.gif
CPU
Chipset
• Intel® 875P Chipset
- Supports FSB 800/533MHz.
- Supports ECC memory.
- Supports Single/Dual Channel DDR 400/333/266 memory up to 4GB.
• Intel® ICH5R Southbridge
- PCI Master v2.3.
- I/O APIC.
- Supports both ACPI and legacy APM power management.
- Serial ATA/150 RAID 0 (Optional, Only ICH5R Chipset).
FSB
• Support 133/200MHz FSB
• Support 533/800MHz Intel NetBurst micro-architecture bus.
Memory
• Supports up to 4GB memory size with ECC.
Slots
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V(3.3V is not supported).
On-Board IDE
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R.
Serial ATA/150 controller integrated in ICH5R
- Supports SATA RAID 0 (Optional)
Audio
• 6 channels ADI 1980/1985 software audio codec
- Compliance with AC97 v2.2 Spec (for 1980) / PC99 v2.3 Spec (for 1985).
- Can support SPDIF Out via SPDIF-Bracket only.
LAN (Optional, 875P Neo-FIS2R only)
• Intel® Intel PRO/1000CT and Intel® 82562EZ Dual layout.
- 2 serial port (COM A & COM B)
Reviews
MSI 875P Neo-FIS2R
MSI 875P Neo-FIS2R
MSI 875P Neo-FIS2R
Intel 875p (o.a. MSI)
Intel 865PE en 875P (2x MSI)
MSI 865PE Neo2-FIS2R
Meer MSI reviews
Pricewatch
MSI 875P Neo-FIS2R
MSI 875P Neo-LSR LS
MSI 865PE NEO2-FIS2R
MSI 865PE NEO-LS
MSI 865P Neo-LS
Filmpje :)
MSI Led Fan
Plaatjes
Afbeeldingslocatie: http://www.obengware.com/telaah/2003/msi875pneo2.jpg
Afbeeldingslocatie: http://techseekers.net/Images/reviews/875pneo/box2.jpg
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/mbd_img/6758.jpg
Afbeeldingslocatie: http://techseekers.net/images/reviews/875pneo/board.jpg
Afbeeldingslocatie: http://www.3dnews.ru/documents/5371/msi-875p-back_panel.jpg
Afbeeldingslocatie: http://www.3dnews.ru/documents/5371/msi-875p-socket.jpg
Links
MSI P4 Forum
Downloads
Msi Corecenter Msi Live Update
MSI Corecell + Corecenter
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/feature_img/corecenter.gif
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/feature_img/core_cell.gif
Alle MSI 865 moederborden zijn voorzien van de nieuwste technologieën zoals de MSI CoreCell chip en MSI CoreCenter software. Deze software past automatisch de processorsnelheid en de Vcore-ratio van de CPU en de AGP videokaart aan om optimaal te kunnen presteren. Het controleert de systeemtemperatuur, de diverse spanningen, de ventilatoren en andere belangrijke onderdelen. De kans dat het systeem beschadigt, wordt zo tot een minimum gereduceerd.
v1.40
[ Voor 35% gewijzigd door Verwijderd op 19-02-2004 16:34 ]
  • BvK P4
  • Laatst online: 25-03-2017
Mooi dat hier weer een topic over loopt! Heb namelijk een MSI 865PE neo2 FIS2R + Pentium 4 3,0GHz + HT. Het loopt bij mij allemaal niet zo goed... Heb het vorige grote msi 865 (P/PE/G) 875P neo topic helemaal doorgelezen. Iedereen kon mooi overclocken met bios 1.2, maar ik niet. Als ik dat doe, wordt PCI/AGP ook automatisch verhoogt. Dat schijnt niet goed te zijn voor de hardeschijf. Dus wil ik wel eens weten hoe anderen wel konden overclocken?
laptopleasing.nl - complete IT-werkplekken
  • Domino
  • Registratie: Juli 1999
  • Laatst online: 13:05
Voor de 865 PE gebruik ik bios 1.3. Daarmee kan ik de PCI/AGP bus vastzetten op 33/66 MHz.
Weet trouwens iemand het verschil tussen de 'oude' FIS2R en de 'nieuwe' 865PE Neo2-PFISR? Ik kan zo snel niets ontdekken, behalve de 'Prescott ready' slogan.
[ Voor 48% gewijzigd door Domino op 04-01-2004 17:49 ]
  • BvK P4
Die P versie is speciaal voor het overclocken gemaakt. Ook het onboard spul is veranderd. Op de site van msi staat er wel wat over als het goed is. Heb het laatst nog gelezen iig...
Waarom heb je bios 1.9 er niet op zitten domino? Of werkt die niet zo goed?
In het vorige topic waren een paar mensen die zeiden dat ze met bios versie 1.00 het beste konden overclocken... Daar kon je PCI/AGP toch ook niet vast zetten of wel?
Ik heb indertijd als een van de eersten de 875P Neo-FIS2R gekregen.
Board loopt prima met 2 bijzonderheden.
Behoorlijk eigenwijs wat betreft geheugen. Met Kingston HyperX PC3500 geheugen wil hij geen kant op, terwijl hij met "goedkoop" Dane-Elec PC3200 geheugen prima wil overklokken.
Ten tweede heb last gehad van behoorlijke ruis op m'n SoundBlaster Audigy, wat gelukkig verholpen is met de laatste bios.
Maar verder niets dan lof over dit board.
  • Domino
Ahh, nu zie ik het, de promise RAID controller is vervangen door een VIA exemplaar.
Wat berteft het gebruik van BIOS 1.3 : Ik heb het bord vanaf het in Nederland leverbaar was. Sinds BIOS 1.3 heb ik geen problemen meer, dus die heb ik gewoon laten staan. Ik heb nogwel even 1.4 gebrobeerd (beta geloof ik), was niet echt een succes.
  • BvK P4
Hey CrashNet, welke versie van dat geheugen had jij? Heb zelf ook Kingston HyperX 433MHz erin zetten. De versies die eindigden op A00 waren na korte tijd kapot, maar heb er nu versie A01 in zitten en die draait nog.
Zou graag weten welke jij toen had.
  • oli4100
Ik heb ook een 875P FIS2R met 2x 256 MB PC4000 Corsair Twinx geheugen, ik draai BIOS 1.9, en ik kan mn FSB verhogen (ik heb dat tot nu toe maar naar 210 gedaan). Anyways, de DDR Clock wordt dan 420 (2x 210, logisch).
Het lukt mij echter niet om de DDR frequency op 500 te zetten, dan wil WinXP niet booten. Ik heb ook geprobeerd ipv slow de performance mode op "Fast" te zetten, en het spread spectrum op disabled. Ik kom dan nog wel het BIOS in, en zie dan dat de DDR clock bij een 200 Mhz FSB in een keer op 501 staat....:? :?, maar hij wil niet XP booten.
Ik heb ook al het voltage verhoogd naar 2.75 V (Corsair heeft ze daarop getest, dus dat moet kunnen, en dat doet hij ook), de timings zijn 3-4-4-8 (met 3-4-4-7 wil hij niet booten, dat was namelijk de auto instelling van het BIOS).( Overigens zijn 3-4-4-8 ook de opgegeven timings voor dit geheugen.)
Ik vroeg me dus af, hoe moet ik dit geheugen sneller laten lopen? Mijn SiSoft scores zijn nu ongeveer 4,2 GB/s, natuurlijk zwaar ondermaats voor dit geheugen.
De enige oplossing die ik kan bedenken is:
- FSB 250 Mhz (Dat natuurlijk, maar als ik de DDR frequency dan op auto zet loopt ie volgens mij nog langzamer dan wanneer die op 500 staat, want dat is ook zo bij FSB 210 Mhz (dat kon eerst nog wel met BIOS 1.4)
- Die frequency op 500 krijgen, maar met welke andere instellingen????
- Performance mode op iets? Nog iets anders? Timings?? Ik heb werkelijk geen flauw idee.
De frequency verhogen kon dus wél met BIOS 1.4, maar vanwege andere bootproblemen heb ik toch geupdate naar 1.9. Maar nu doet hij dat dus niet meer, maar ik denk dat er best wel een manier is om het aan de praat te krijgen, maar hoe?
Verder loopt ie als een tiet... :)
/edit: Ik zit net in CPU-Z te kijken, en daar staat dat ik DDR-SDRAM PC3700 heb!!!! Terwijl ik er 1000% zeker van ben dat ik PC4000 had gekocht. Wiens fout is dit? Kan CPU-Z het fout hebben?
[ Voor 6% gewijzigd door oli4100 op 05-01-2004 16:02 ]
  • BvK P4
Als je CPU snelheid wordt verhoogt, dan gaat het geheugen mee. Dus kun je hem het beste op auto zetten. Er zijn ook andere progjes dan CPUz. Zoals Aida32 en WCPUID. Probeer het daar eens mee.
Kan je het geheugen dan niet in plaats van op automatisch op 500 MHz zetten, dit is bij mij wel mogelijk.
  • oli4100
Verwijderd schreef op 05 januari 2004 @ 19:59:
Dat lukt dus niet; dan boot ie XP niet meer.
  • TimmyUt
  • Laatst online: 30-09 19:56
Bedankt voor dit topic thotha ik zat er echt op te wachten.........
Ik heb het volgende probleem met mijn MSI neo2 fis2r... Ik heb daarop HyperX 3500 geheugen van Kingston zitten. Het is me al een paar keer gelukt om de FSB op 233 te krijgen (ik zit met een p4 2.6 800) waardoor mijn proc op 3043 mhz uitkwam :9~.
Probleem is echter dat hij dan voor geen meter stabiel is (voltages; ddr 2,85 cpu 1,6 AGP/PCI ~ 67.43/34.33). Is er iemand met hetzelfde bord en hetzelfde geheugen die even zijn timings en voltages wil posten???
Timmy.
  • BvK P4
Heey TimmyUt, eindelijk iemand die dezelfde combinatie heeft gekozen als mij... Heb tot nu toe nog niet overgeclockt, maar met dat geheugen alleen maar problemen tot nu... Ik had namelijk eerst 2 modules die eindigden op A00. Die gingen zonder overclocken al kapot. Nu heb ik 1 die eindigt op A01. Tot nu toe alles goed, maar ik wacht op een nieuwe MSI 865PE neo2 FIS2R omdat ik me bios niet meer inkom...
Misschien kan een bios update helpen. Weet niet welke versie je nu hebt... PCI/AGP kun je volgens mij ook beter op 66/33 zetten. Ook al scheelt het ook niet zo veel. Verder weet ik het ook niet.
Welke versie van dat kingston hyperx heb je TimmyUt?
  • Domino
TimmyUt schreef op 06 januari 2004 @ 12:56:
Timmy.
Kun je de AGP/PCI bus niet vastzetten op 66/33 MHz?
Mijn config gaat feilloos op een FSB van 233. Kan zelfs nog hoger maar dan moet ik de CPUfan een slinger geven, is nu zo goed als stil (~ 1800 rpm).
config:
865PE Neo2 FIS2R
P4 2.4c @ 2.8 met Zalman 6500 AlCu koeler
TwinMOS DDR466 op 2.5-4-4-8
  • TimmyUt
@ BvK P4
Ik heb voor de zekerheid ook maar even een memtest gedraaid, geen problemen waar kan ik dat serienummer vinden???
@ Domino
Wat heb je dan aan voltage instellingen van de verschillende onderdelen?? En verder heb ik mijn geheugen snelheid op automatisch staan wat kan ik daar aan veranderen (heeft iets met die divider te maken ben als een gek aan het zoeken geweest maar kon geen echt duidelijk antwoord vinden dat ik begreep hehehe O+ )
Als ik probeer hoger te gaan met mijn FSB gaat die AGP/PCI bus automatisch mee.........divider?????
Ik heb overigens kingston 433 geheugen 3500 2 x 256 mb.....
Thanx bij voorbaat.....!!!! :*)
  • PcManiaxx
  • Laatst online: 09-09 23:14
PcManiaxx
ondertitel duh
Ik heb zelf de MSI NEO 865PE fisr2 met een P4 2.8 @ 3.2 ghz.
2x 512 Pc 3200 ADATA.
Wat me al gelijk opviel is dat je de timings in je bios niet in kon stellen.
Dit vind ik dus echt balen! Is er niet een andere manier? Performance mode staat op Turbo. Ram gewoon op ''auto''.
Heeft iemand anders dit ook gehad. En kom bitte niet met een bios flash, want daar begin ik echt niet aan ;)
  • BvK P4
@ TimmyUt
Het serienummer is op de modules zelf te vinden. Als het goed is eindigt het op A00, A01, A02 enz. Zelf had ik eerst 2x A00, en dat was na korte tijd kapot zonder dat ik eigenlijk had overgeclockt.
Verder kun je, denk ik, de geheugen snelheid het beste op “auto” zetten zodat hij dan automatisch met de CPU meeclockt. Tenzij je heel ver gaat overclocken, dan zul je misschien een divider moeten gebruiken.
Het hangt van de bios versie af of je PCI/AGP automatisch meeclockt met de CPU/Geheugen. Ik heb zelf bios versie 1.2 (die er standaard bij mij opzat) erop zitten, en daar word PCI/AGP automatisch meeverhoogd met de CPU overclock. Een kleine overclocken kan misschien wel (2MHz ofzo :P), doe je verder, dan gaat je hardeschijf als eerste denk ik problemen geven. Anders wel de PCI kaartjes die je erin hebt zitten of de videokaart. Dus wil je overclocken, dan minsters bios versie 1.3 of iets in die richting erop zetten. De nieuwste is 1.9.
Heb trouwens de standaard timings ingestelt. Namelijk cas2-3-3-7-8 (laatste is burst lenght). Dit draait op 2.5V. Het geheugen kan wel veel strakker worden ingesteld als je de FSB @ 200MHz draait. Ga je overclocken naar 233MHz, zou ik cas2.5-3-3-7 gebruiken en dan langzamerhand steeds strakker zetten totdat hij instabiel wordt.
@ PcManiaxx
Hangt ervan af welke bios versie je hebt. Ik heb versie 1.2, en kan de timings wel veranderen. Heb je een ouderen versie, en het wil niet, zul je denk ik wel een bios update moeten doen. Anders gaat het niet lukken...
  • TimmyUt
@ PcManiaxx
Dat kan je wel je moet in je bios bij dram instellingen detect spd disabelen en dan kan je gewoon je eigen timings instellen (kijk vooral even op de website van je geheugen voor de beste timings.....), bovendien raad ik je sowieso aan om je BIOS te flashen dat kan gewoon met MSI LiveUpdate zelfs onder Windows waarbij er bij mij al 3 keer niks is fout gegaan............... ;) ;) ;)
@TimmyUt, >:) , klein eureka momentje _/-\o_ ........
Hehehe, na ongeveer 3 uur rondsurfen op internet heb ik de volgende voor mij zeer interessante post gevonden op de corsair website: http://www.houseofhelp.co...ead.php?s=&threadid=14798
Daar staat mijn probleem; als ik op een divider (verhouding FSB snelheid en DDR snelheid) van 1:1 probeer te draaien dan komt mijn FSB uit principe niet ver boven de gespecificeerde snelheid van (omgerekend) 217 Mhz (433/2) van mijn kingston reepjes (resultaat is 217 x 13 = 2817 = 2.8 ghz).
Wat ik dus moet doen is de divider op 5:4 (FSB<>DDR) of zelfs op 3:2 zetten.
Gevolg is dan bijv bij 5:4 dat ik met mijn DDR snelheid van (teruggerekend) 217 : 4 = 54.25 x 5 = 271.25 kan halen en aangezien ik een p4 2.6 heb (multiplier 13) kan ik dus theoretisch tot 271.5 x 13 = 3526.25 = 3.5 GHZ !!!!!!!!!!!!
(volgens de website moet je in je bios dit kunnen instellen voor de dividers: DDR400/1:1, DDR333/5:4, and DDR266/3:2, bij mij kwam er zelfs DDR500 en DDR550 bij waarbij het geheugen dus sneller loopt dan de FSB)
*Timmy bedankt zichzelf hoihoihoi*
P.S. ik houd jullie op de hoogte van de vorderingen hehehe
  • TimmyUt
Goed ik type deze reply nu op een p4 2.6 op 3.2 ghz met een divider van 5:4 waarbij mijn frontside bus op 250 draait en mijn geheugen op 250:5 x 4 = 200 Mhz.....(timings 2-3-3-7-8).....
Ik wilde graag ook een screenshot posten ik weet echter niet hoe dat moet dus als iemand me dat kan vertellen dan kan ik het ook nog bewijzen ook!!! :*)
Groeten Timmy.....
  • BvK P4
Kun je nog even vertellen welke versie je hebt TimmyUt? Zou ik wel graag willen weten omdat ik er strax weer mee heen moet, en dan moet ik wel goeie overclock versie hebben :9
  • Domino
Ik heb een voltage van 2.8 ingesteld staan voor mijn TwinMos modules.
Maar je kunt inderdaad ook met de fsb:mem devider werken.
  • TimmyUt
@domino
Jij kan idd gewoon je divider op 1:1 houden omdat je geheugen 466/2 = 233 mhz voor je geheugen draaien waardoor je FSB ook naar 233 kan.... dat kan bij mijn geheugen niet ook al zet je hem op 2.8 volt.... (max voor mijn geheugen is 217)
@Bvk P4
Kingston 3500 433 geheugen zie ook:
http://www.ec.kingston.com/ecom/configurator/memtype.asp
Groet TImmy....
P.S. Wil IEMAND mij alsjeblieft vertellen hoe ik in vredesnaam plaatjes kan posten???
  • Domino
Plaatje op beeldscherm toeveren, toetsencombo ALT+PrintScrn.
Paint openen, plakken.
Uploaden naar webspace provider.
Hier op het forum de code (img)http://www.eenprovider.nl/plaatje.jpg(/img) gebruiken. Maar dan met rechte haken [] ipv ().
  • TRAXION
  • Laatst online: 08-10 20:15
Timmy.
P4 2.6@3.2 @ 250 mhz fsb 1.7 volt O-) })
Dualchannel dane elec @ 200 mhz divider 5:4 2.7volt
Msi 875p neo2 fis2r _/-\o_
[ Voor 3% gewijzigd door TRAXION op 07-01-2004 15:47 ]
  • BvK P4
@ TimmyUt.
Je moet op je geheugen module kijken en dan ff zeggen welke versie het is. Bijvoorbeeld: 9905193-024.A00. Dan vind ik vooral de laatste 3 cijfers het belangrijkste. Ik wil dus weten of jou modules eindigen op A00, A01, A02 enz.
Dat staat op de witte sticker die op je geheugenstaafje is geplakt.
  • PcManiaxx
PcManiaxx
ondertitel duh
TimmyUt schreef op 06 januari 2004 @ 22:56:
@ PcManiaxx
Ik wou dat het zo makkelijk was, als ik het zelfs op manual instel wil het niet lukken, daar ben ik zelf al achter gekomen ;)
Maar een biosupdate vind ik maar niks, ik heb er nare herrinneringen aan :o
In het verleden is het een paar keer misgegaan.
  • Bartjeee
Ik sta op het punt om de MSI Neo Fis2R met 875P cipset. En ik twijfel nog of ik een P4 C 2,8 of 3,0 zal nemen. Ik heb gehoord dat de 2,8 beter te overklokken is hier wil ik mischien ook nog wel aan beginnen. Het geheugen ben ik wel uit het wordt waarschijnlijk Corsair TWINX1024-3200LLPRO PC3200, 400 MHz, Kit of 2, Inclusief LED's, 2, 1024 MB 8) . Maybe PC 4000 maakt dit veel verschil ? En als koeler zat ik te denken aan de Zalman CNPS7000A-AlCu :9 . Heeft iemand nog tips of een suggestie ?
Links:
http://www.zalman.co.kr/english/product/cnps7000a-alcu.htm
http://www.msi.com.tw/pro...ro_mbd_detail.php?UID=434 :+
http://www.corsairmicro.com/ 8)
[ Voor 3% gewijzigd door Bartjeee op 07-01-2004 17:28 ]
  • TimmyUt
@BvK P4
Nou vooruit dan maar hier komen ze:
KHX3500/256
9905193-024.A00 <--- jawel...... ;)
1227457-2.5V CE
ASSY in USA
Warranty void if removed
Heb tijdens het opzoeken ook maar meteen nog een wind koeler geinstalleerd en voila weer 3 graden van m'n cputemp af.... >:)
Ik krijg alleen voor geen meter m'n NB onder de 60 graden, iemand daar ideeen over????
@Bartjee
Ik zou sowieso PC4000 doen dan kun je hoger komen met een 1:1 divider dat is iets sneller dan dat je hetzelfde zou doen met 5:4 en PC3200, overigens met MAT aan is de 865 neo 2 p LS volgens mij even snel als die 875....prijsverschil kan je dan in je zalman stoppen....... ;)
Greetz Timmy
http://www.msi.com.tw/pro...s/mainboard/mbd_index.php
  • PcManiaxx
PcManiaxx
ondertitel duh
Ik vind dit eigenlijk ook maar niks met die NB, bij mij is het ook altijd rond de 60 graden, soms zelfs wel 65. Ik denk niet echt dat dit gezond is. Toeren staan zelfs op 6000RPM nog wat.
Ik heb trouwens nog wel een vraagje aan julllie hier >:)
Ik heb nu geheugendivider staan op 1:1. Maar als ik bijv 5:4 doe, wat is dan de Ram Frequency? 400MHZ? Ik heb em nu op auto staan.
Edit: 333MHZ is 5:4 ;) Ik heb nu mijn Fsb staan op 229 MHZ *14 (3205).
Als ik het op 5:4 instel zat het overklokken dan misschien beter gaan? Ik kom maar niet boven de 229 mhz uit, dan krijg ik kuren, blauwe schermen, vastlopers.
[ Voor 18% gewijzigd door PcManiaxx op 07-01-2004 19:46 ]
PcManiaxx schreef op 07 januari 2004 @ 19:28:
mijn NB blijft idle altijd 50, stressed 52
Heel erg vreemd want sinds ik CoreCenter heb ge-update, is mijn NB zo'n 6 graden omhoog gegaan. Mijn NB was eerst altijd +-45
Heeft iemand al getest zonder die NB fan?
  • BvK P4
@ TimmyUt
Bedankt hè. Heb jij niet de K2 versie? Dat houdt in dat je 2 exact dezelfde geheugenmodules hebt. Dan zijn ze perfect voor dual channel. Bij mij staat er het volgens op mijn geheugen:
KHX3500K2/512
9905193-024.A00 K2
1287532 - 2.6V CE
Assy in USA
Warranty Viod If Removed
We hebben dus dezelfde versie. Wat ik nou zo vreemd vindt is dat die van mij 2.6V moeten hebben terwijl die van jou 2.5V nodig hebben. Ook vind ik het vreemd dat je dezelfde versie hebt, terwijl dat van jou wel stabiel loopt. Ik had er zomaar duizenden errors in bij memtest86.
Mijn NB wordt iets van 30graden. Dan heb ik gekeken bij aida32. Corecenter heb ik niet geinstalleerd.
[ Voor 9% gewijzigd door BvK P4 op 07-01-2004 22:29 ]
  • BvK P4
Er schijnen jammer genoeg niet zoveel mensen te zijn die de 865PE neo2 of de 875P hebben gekocht, want er wordt niet zoveel gereageerd... ;( In deel 1 van dit topic was er best wel veel belangstelling voor. Schijnbaar hebben de meeste mensen toen weer voor een ander moederbord gekozen of ze hebben hem toen gewoon niet gekocht ondanks het enthousiasme (hoop dat ik het laatste woord goed heb gespeld :P )
Ik hoop dat er nog een aantal reacties komen! :)
  • ztupid371
  • Laatst online: 09-01-2016
@BvK P4
Niet gelijk zo teleurgesteld zijn hoor ;)
Hierzo sinds kort een vergelijkbaar setje:
- MSI Neo2 865PE FIS2R
- P4 2.8 @ 3.26
- Corsair TWINX 2x512MB PC3700 (467 Mhz)
- Zalman 7000Cu
Dik tevreden over. Haal met de P4 de 3.4 wel, maar dan wordt ie mij iets te snel heet, en ik heb geen trek om alle fans op volle sterkte te laten draaien. Met een 2.8 kun je de FSB waarschijnlijk iets verder OC'en dan als je een 3.0 neemt.
Zou je misschien niet beter PC3700 of PC4000 geheugen nemen ipv LL geheugen ? Hogere FSB is bij een P4 HT misschien wel belangrijker dan strakke timings.
Ik heb wel de NB fan uitgezet, want die kwam qua geluid overal boven uit. Komt binnenkort nog wel een Zalman NB47J op :). Temp. van NB is rond de 40-45 gr, (zonder fan) en dat is best mooi als ik bovenstaande berichten zie. Op de AGP kaart zit echter wel een Zalman ZM-H80C heatpipe koeler met grote fan die ook lichtjes op de NB blaast.
  • BvK P4
@ ztupid
Mooie OC hoor! Welke bios heb je daarbij erop staan? Ik had in het begin ook die 2.8GHz versie op het oog, maar toen kwam er een prijsverlaging van ongeveer 60 euro. Heb toen gevraagd of ze m'n CPU konden wijzigen in een 3.0GHz versie. Dan had ik een snellere processor voor hetzelfde geld. Later las ik dus ook dat de 3.0GHz van mij veel neer watt verbruikt dan een 2.8GHz variant. Die van mij zit tegen de 80Watt aan en die van jou waarschijnlijk iets tegen de 70Watt.
Verder moet ik nu nog even wachten voordat ik een ander moederbord krijg omdat ik niet meer in m'n bios kan komen. En dat is toch wel noodzakelijk als je gaat overclocken :P Verder is 1 reepje van mijn Kingston HyperX 433MHz cas2 geheugen kapot waardoor ik geen dual channel draai. Dus moet eerst een nieuw moederbord + geheugen hebben voordat ik kan beginnen met OC'en.
PC3500 geheugen is voor mij ook wel genoeg omdat ik maximaal tot FSB@233MHz wil gaan overclocken. Dat HyperX zou dat wel moeten redden met een cas latency van 2.4-3-3-7 oid. Daar moet ik nog een beetje mee experimenteren.
Ben trouwens ook van plan die zalman koeler te kopen, maar dan de aluminium versie daarvan. Das de CNPS7000A-AlCu. Die A staat voor dat ie ook amd compatible is. Niet dat ik dat nodig heb, maar de internetwinkel waar ik em vandaan haal heeft niet de pure pentium 4 versie :7
Zou ook graag willen weten welke bios versie het beste bij jullie voldoet. Dan bedoel ik vooral bij het overclocken.
[ Voor 7% gewijzigd door BvK P4 op 08-01-2004 23:29 ]
  • ztupid371
Mijn huidige bios versie is 1.90 ; eerlijk gezegd heb ik gewoon de laatste versie erop gekwakt, en niet met oudere versies ge-experimenteerd. Grappig trouwens, ik draai nu ook precies op FSB 233 (draai mem dus 1:1 en precies volgens PC3700 spec).
  • Domino
Heeft iemand een 865PE/875P met daarop een promise S-ATA controller lopen met windows 2003? Ik krijg em niet aan de gang met de driver die op de MSI site staat.
Error code is 10 : device could not be started.
  • BvK P4
Heb wel die promise S-ATA controller op mijn MSI 865PE neo2 FIS2R. Maar ik heb er geen windows 2003 op staan. Met mijn Maxtor 120Gb S-ATA ging het installeren van windows XP iig wel goed. Maar daar heb je natuurlijk niets aan.
Ik heb rt trouwens 2 floppies erbij gekregen. 1 voor raid en 1 voor S-ATA. In het begin op F6 drukken als hij erom vraagt, en dan de floppy erin doen. Werkt bij mij perfect :)
  • Domino
Ik heb er geen floppydrive aan hangen. Maar als de promise het bij jou doet met die driver, ga ik dat nu doen.
over die northbridge temp stond dit in de faq op het msi-forum:
On 875P Neo and 865PE Neo2, there is no NB temp sensor! The value you read from CoreCenter does not mean anything. Please update to the latest CoreCenter.
verder vind ik het een geweldig bord, maar ik kan geen DOT vinden op mn neo2-ls, terwijl anderen dit wel hebben. Weet iemand waar dat aan kan liggen?
  • XoReP
  • Laatst online: 13:34
Ik dacht dat als je een deel 2 start van een topic altijd te TS van deel 1 moet vragen of het goed is dat je een deel 2 opent :( (hebk ook een keer gedaan zonder toestemming en toen werd me topic dicht gegooid).
Master Tweaker schreef op 11 januari 2004 @ 14:44:
o sorry dat wist ik niet
Maar vind je het goed?
  • XoReP
Verwijderd schreef op 11 januari 2004 @ 14:48:
Ja hoor het is goed maar dan weet je voor de volgende keer ;)
  • BvK P4
@ Bas424
DOT wordt pas ondersteund vanaf bios versie 1.2. Heb je al een nieuwe versie en je kunt het niet vinden, dan weet ik het ook niet. Je zou het moeten vinden ergens in de 1e tap van links boven in het bios.
Verwijderd schreef op 11 januari 2004 @ 13:58:
"On 875P Neo and 865PE Neo2, there is no NB temp sensor! The value you read from CoreCenter does not mean anything. Please update to the latest CoreCenter."
Idd, ik haal net het kabeltje van de NB fan eruit, doe me pc aan kijk bij Core Center en daar staat: NB 46
Met Fan was dit altijd +- 50 8)7
Maar zoals je al zei is er niet eens een Sensor, hoe kom je dan te weten of die alsnog niet te warm wordt?
En kun je ook een 80x80fan op die NB aansluiting plaatsen?
(Coolermaster 80mm Blue Neon Led)
edit: ja dat kan dus, alleen CoreCenter geeft steeds een alarm dat de NB fan zo langzaam draait (hehe een 80mm gaat geen 7000rpm)
[ Voor 10% gewijzigd door Verwijderd op 11-01-2004 16:21 ]
  • Domino
DOT wordt volgens mij geregeld door de CoreCell chip. Die zit alleen op de FIS2R naar mijn weten.
nee hoor corecell chip zit ook op de neo2-ls
  • BvK P4
Die temperatuur aanduidingen in PC Alert 4 kloppen ook niet helemaal. Zo draait mijn 3.0GHz idle op ongeveer 38graden volgens dat programma, terwijl aida32 en sisoft sandra op zo'n 35graden uitkomen. Onder load (100% divx maken, burn-in) dan geeft PC Alert 4 ongeveer 60graden aan terwijl Aida32 en sisoft sandra weer iets van 55graden aangeeft... 8)7
  • ztupid371
@BvK P4
Wat lees je dan precies uit bij in die programma's ?
Op de website van Motherboard Monitor (MBM) staat bv dat voor mijn mobo (MSI Neo2 865PE FIS2R) je de Winbond2 *diode* moet uitlezen en dan +3 graden corrigeren. Temp in MBM loopt dan precies gelijk met die in Core Center. Lijkt een beetje op het verschil waar jij het over hebt.
  • BvK P4
@ztupid
Heb hetzelfde bord als jou :) Dan klopt het ook wel wat jij zegt, want het zit er meestal een graad of 3 tussen aida32 en sisoft sandra aan de ene kant en PC Alert 4 aan de andere kant.
Bij aida32 moet je naar computer gaan, en dan naar sensors. Daar staat dan hoe heet de CPU word. Bij SiSoft Sandra moet je naar moederbord informatie gaan om te zien hoe heet verschillende onderdelen worden.
Ik ga hem 875 ook halen morgen denk ik bij Mycom. Eerst nog even deel I doorlezen. Ik zat eerst tetwijfelen tussen die Asus en deze. Uiteindelijk gekozen omdat het een mooie kleur heeft. Heb een doorzichtige kast duss :7 is het wel belangrijk.
Verwijderd schreef op 13 januari 2004 @ 21:13:
haha precies wat ik ook dacht toen ik moest kiezen tussen die 2 :9
Shit man ze hebben hem niet opvooraad |:(
mischien haal ik wel die asus of die msi 865. heb nog geen tijd gehad om tekijken naar de msi 865 maar volgens mij is die ook wel goed denk ik. prijsverschil van 80 euro. Mischien haal ik die 865 wel.
  • Domino
Verwijderd schreef op 14 januari 2004 @ 11:44:
De 865PE FIS2R is net zo uitgebreid qua features en onboard zut als de 875P.
Ik weet alleen niet of PAT nog werkt in de nieuwere BIOS versies, dan is ie nagenoeg even snel als de 875P.
ik haal die 865 wel gewoon :)
scheelt me weer lekker 80 euro.
gaat werken icm met een 2,8 Mhz op 800mhz.
en 512 mb Corsair Pro series 3200 , 160 Sata Maxtor en Qtec 550watt en 5900Xt Club 3d. heb ik nu nog iet binnen de laatste 3 dingen krijg ik nog.
binnekort waterkoeling dan ga ik hem proberen ver teoverklokken en post ik het hier. + foto van mijn nieuwe sunbeam Uv bleu kast 8) heb hem net inelkaar gezet. GRUWLIJK. Al me vrienden geile al op die kast :*)
ik heb hem net gekocht.
ik ga hem nu inbouwen.
als alles goed loop dan ben ik vanavond erop.
:Y)
Verwijderd schreef op 14 januari 2004 @ 16:58:
:Y)
suc6! hopelijk doet die het!
bedankt hij zit er iedergeval in.
nu alleen nog ff proc erop doen en vga kaart enzo....
gruwlijk lekker bordje. heb er tot nu toe nog geen problemen gehad.
Alleen was op begin Sata tezetten hij stond op Ide Only.
Ff Xp update enzo....
hoi, ik heb zelf sinds kort een msi 865 NEO2 FIS2R mobo met 1024mb Twinmos (duall channel kitje van 2*512mb) en een ASUS r9600XT. nu heb ik het probleem dat ik in de bios de instelling alleen op slow kan instellen ander gaat hij gelijk rebooten (als tie al opstart), ook bij instellingen hoger als captain => spontane reboots. als iemand hier ervaring mee heeft dan hoor ik het graag.
verder: welke instellingen kun je het beste veranderen als je 'licht' wil OC-en?
(heb het idee dat mijn FSB instellingen in de bios gelocked staan, maar heb nog niet gezocht waar dat aan kan liggen. heb nog helemaal geen oc-ervaring en ben er een beetje huiverig van om dingen in de bios te veranderen. dit komt omdat ik bijna mijn biosflash verkl**t had. 8)7 )
sorry ik weet het niet.
dit is pas mijn eerste Msi :)
ik haal al een overclock van 3,4 met goedkope geheugen met boxed koeler :Y)
edit: nu zelfs 3,6 :+0
edit: maar dan start ie naar een tijdje opnieuw op |:(
[ Voor 27% gewijzigd door Verwijderd op 15-01-2004 08:15 ]
  • Domino
Verwijderd schreef op 14 januari 2004 @ 19:27:
Zet als eerste DOT uit. Geen dynamische overklok waar je geen controle op hebt.
Verder hebben wij nog wel wat gegevens nodig:
BIOS versie moederbord.
Welke modules van twinmos (pc3200/3500/3700).
Voltages van het systeem (vCore, vDimm).
biosversie is 1.09 (dacht ik, het is de laatste als het goed is, zit nu niet thuis dus kan het even niet zien).
geheugen is: twinmos duall channel kitje 2*512mb DDr400 (pc3200) cas2.5.
voltages heb ik niets aan veranderd, zijn volgens mij allemaal goed.
even voor de volledigheid mijn systeem:
P4 2.8 fsb800 HT
MSI 865 NEO2 FIS2R
Twinmos 2*512mb ddr400 (pc3200) cas2.5 (duall channelkitje)
ASUS ati R9600XT
Zalman z400w voeding
nec nc1300a dvd rewr.
msi dvd
Western digital 36.8 gb raptor 10.000 rpm.
Maxtor 120 gb, 8mb cache, 7200 rpm.
OS: windows XP home incl alle updates
Bios mobo: laatste versie
drivers grafische kaart: Laatste versie van ASUS
(zijn volgens mij gebaseerd op ATI catalyst 3.10, zou dat kunnen? geeft in ieder geval de ATI tabbladen bij de instellingen).
verder Norman virusscan, gecombineerd met Ad-aware en spybot
  • Domino
Verwijderd schreef op 15 januari 2004 @ 09:34:
P4 2.8 fsb800 HT
MSI 865 NEO2 FIS2R
ASUS ati R9600XT
msi dvd
Dan heb je bijna hetzelfde systeem als ik, moet o/c-baar zijn.
1. Als eerste even de vDimm controleren, standaard staat die op 2.5 Volt, ik heb em op aanraden van twinmoss zelf (via mail) op 2.7 gehad en inmiddels op 2.75 V.
2. Zoals al eerder gepost, DOT uit.
3. DDR timings controleren.
4. Zelf met stapjes de FSB omhoogschroeven, 233 FSB moet mogelijk zijn (eventueel op CAS3 of a-synchrone FSB/MEM).
5. PCI/AGP bus vastzetten op 33/66 MHz.
  • XoReP
Ik heb de laatste tijd een coldboot probleem :( Zijn er meer mensen die ook een coldboot probleem hebben? A.u.b. posten in dit topic [rml][ Mobo] Coldboot problemen (MSI 875P Neo FIS2R)[/rml]
Welke chips zitten er op de Twinmos. Laatst gehoord dat voorheen Winbond chips werden gebruikt, welke zeer stabiel waren. Nu zouden hoofdzakelijk Twinmos chips worden gebruikt. Deze zouden minder te overklokken zijn.
Klopt dit? Kan iemand dit bevestigen? Of is dit uit de lucht gegrepen?
  • PcManiaxx
PcManiaxx
ondertitel duh
Ff een vraagje, ik heb zelf een Neo 865PE FISR2 en ik heb mijn DOT op Enabled staan. Maakt dit wat uit? Ik heb gelezen dat je het beter kan disablen, maar waarom?
Ik heb mijn 2.8 ghz @ 3.22 ghz.
  • Domino
PcManiaxx schreef op 15 januari 2004 @ 15:06:
DOT is een techniek die je FSB automagisch verhoogd als de PC het druk krijgt. Met onbekende resultaten als gevolg, vooral als de PC als ge-o/c'ed is kan dit het zetje zijn wat de zaak doet vastlopen.
  • BvK P4
@ magliaveli,
Kun je mij vertellen wat jou voltlijnen zijn van jou voeding?? Heb namelijk dezelfde als die van jou, maar mijn 12V lijn loopt op gemiddeld 11,4, en dat is wel een beetje weinig...
Heb ook al es een x DOT geprobeerd en dat resulteerde in een vastloper. Dus je kunt het DOT op disabled laten lijkt mij. Hij clockte daarbij mijn processor van 3.0GHz naar 3.15GHz als hij het zwaar kreeg. Had em dus op de middenste van general, commander enz.
[ Voor 3% gewijzigd door BvK P4 op 15-01-2004 19:04 ]
BvKP4: mijn voeding geeft 11.76V constant (maatje van mij krijgt volgende week dezelfde voeding, zal die ook even checken)
op de chips op mijn geheugen staat: aan de ene kant
W942508CH-5
034 2WI
432645500
aan de andere kant
W942508CH-5
034 25I
433088900
denk dus dat het winbond chips zijn?!
pci/agp stond al op 33/66
ben even aan het kijken hoe de andere veranderingen gaan, resultaten volgen nog
nog even een echte beginners vraag tussendoor. Als ik in de bios iets verander waardoor mijn comp niet echt meer opstart, kan ik toch de bios resetten door die jumper op het mobo even om te zetten toch? :?
  • Kakaroto
  • Laatst online: 13:02
Verwijderd schreef op 15 januari 2004 @ 21:34:
W942508CH-5
034 2WI
432645500
aan de andere kant
W942508CH-5
034 25I
433088900
Ja je heb winbond CH-5 chippies.
Ja als je een verkeerde setting heb ingesteld, kan je dat ongedaan maken door de bios jumper eruit te halen.
Soms wil dat ook niet lukken, had dit bordje ook gehad..... dan gewoon de batterij eruit halen en opstarten met [HOME]
  • BvK P4
Beetje offtopic...maar is 11.4V niet wat weinig voor de 12V lijn? Tis iets meer dan 5% afwijking. Wil ook geen apart topic hierover openen, dus als iemand daar wat over kan zeggen, dan graag! Anders moet deze RMA. Hij is trouwens stressed en idle ongeveer 11.4V.
  • BalusC
BalusC
Carpe diem
Is de bak @default stabiel? Zo ja, dan kan je MSI weinig maken. Anders heb je wel een redelijke kans dat je een RMA mag doen :)
  • Domino
BalusC schreef op 16 januari 2004 @ 06:38:
Gaat nu denk ik over de voeding, niet het MSI bord.
11.4 V op een 12 V lijn is inderdaad aan de lage kant.
Zal vanavond eens kijken wat mijn Zalman 400 W doet.
  • BvK P4
Het gaat over de voeding ja. Eerst was hij altijd rond de 11.87... dat is ook wel goed. Maar nu is hij altijd tussen de 11.4V en de 11.5V in, en dat lijkt me toch wat weinig. M'n computer draait verder wel stabiel, daar niet om, maar ik zag het toevallig en heb het in de gaten gehouden.
Mooi dat je even wilt kijken Domino ;)
[ Voor 9% gewijzigd door BvK P4 op 16-01-2004 12:12 ]
  • begintmeta
begintmeta
Ik heb dan wel geen ervaring met de MSI-bordjes uit de topictitel, maar ik vraag me af ivm een aankoop of deze al ergens verkrijgbaar is (staat niet in de PW). Lijkt me in principe best een OK bordje namelijk. Heeft iemand er misschien al ervaring mee?
pff word er ziek van....
1. elke keer me usb kabel eruit en erin stoppen voor me adsl modem anders dan kan ik geen verbinding maken.
als ik me afmeld en me zusje gaat erop..
dan start ie opnieuw op :(
weet iemand waar het aan ligt?
mischien de nieuwste usb modem drivers ophalen bij Kpn.nl?
http://www.kpnadsl.nl/support/index_usb.html
bios update wil ook nog wel eens helpen
[ Voor 20% gewijzigd door Verwijderd op 16-01-2004 16:32 ]
zit nieuwe bios in 1.9
en nieuwe drivers van etech....
  • BvK P4
@ cocacola11
Probeer es memtest te draaien. Het kan zijn dat het geheugen fouten bevat die pas worden uitgeloost als je zwaardere dingen doet zoals het switchen naar een ander profiel. Dat kost redelijk wat MB's van het geheugen. Ik weet niet cker als het daar aan ligt, maar dat is het enige wat ik in m'n koppie heb als oplossing...
Het kan natuurlijk ook zijn dat je geheugen gewoon te hoog geclockt is ;)
Heb vandaag voor de lol mijn kapotte Kingston HyperX module er weer eens in gedaan. Misschien deed hij het weer dacht ik 8)7 Je weet het maar nooit... Kwam mooi in windows, toen Prime95 en na een minuut viel ie uit, wat ik ook wel had verwacht. Ook voltage verhoging naar 2.75V hielp niet, want dan gaf het moederbord via de ledjes achterin de computer aan dat er iets met de toetsenbordcontroller aan de hand was... |:( Toen dacht ik ook laat ook maar :z Daarna ook nog even memtest gedraait en na een minuut waren er al 1000 fouten gevonden, allemaal in het gebied van 230MB ongeveer. En dan klopt het ook wel als ik Prime95 draai, want de gebruikt bij mij over de 300MB...
[ Voor 6% gewijzigd door BvK P4 op 16-01-2004 17:29 ]
dat kan best wel zo zijn.... is goedkope DDR 2100 van ComPuterland.
maar hij zegt progama kan niet worden geladen... msi progama ik weet niet hoe het heet meer. ik heb het verwijdert.
komt het daardoor mischien?
  • BvK P4
Nee denk niet dat het daar aan ligt. Heb je memtest al gedraaid? Waarom heb je trouwens PC2100 in een MSI 865PE bord? Gebruik je dual channel 400MHz dan heb je precies dezelfde bandbreedte als de..... ben het ff vergeten }:O
  • Domino
Zalman 400 waardes :
3.3 -> 3.39
+5 -> 5.1
+12 -> 11.9
-5 -> -5.1
-12 -> -12.3
+5 SB -> 5.01
  • BvK P4
Bedankt Domino.
Dit zijn mijn waardes (gekeken met aida32):
+3.3 = 3.30a3.31
+5 = 5.00
+12 = rond 11.70, met PC Alert 4 van MSI = tussen 11.50 en 11.60 op moment. Vaak is dat ook 11.40V
-12V = -11.87
-5 = -5.10
BvK P4 schreef op 16 januari 2004 @ 19:35:
omdat ik nog me andere geheugen moet binnen krijgen. Corsair Pro Serier 4000.
ik heb dit en een qtec voeding en videokaart voor ff erin gezet dat ie iniedergeval draait.
Stil..... :O
vond ik ook al, denk dat iedereen met een msi 865 of 875 lekker zit te gamen oid.
maar ja, daar zijn ze dan ook voor, niet om heel de dag bezig te zijn met het zoeken naar oplossingen voor problemen :X
  • BvK P4
Heb je memtest nou wel of niet gedraaid? Want het kan dus aan het geheugen liggen. Je krijgt dat nieuwe geheugen, maar je hebt het nog niet dus zou ik toch ff memtest draaien. Dan weet je tenminste dat het aan je geheugen ligt of aan iets anders. Je kunt ook Prime95 es draaien en dan torture test.
nee nog geen tijd gehad ervoor....
vandaag hele dag weg en nu geen zin erin kga lekker slapen..... :O
Shit ik ga mijn bordje ff ruilen deze week. Kom er net pas achter dat ik de verkeerde heb |:( 8)7 Ik heb de Standaart NeoPe LS. Ik moet Neo2-FIS2R hebben.
  • BvK P4
Er schijnen verschillende nieuwe 865PE bordjes van MSI te zijn gereleased, namelijk:
- 865PE Neo2-PFISR (Volledige prescott support + overclock naar FSB@350MHz mogelijk + rood)
- 865PE Neo2-PFS (Volledige Prescott support + rood)
- 865PE Neo2-PFS PE (Platinum Edition + volledige prescott support + zwart)
Ik weet nu niet echt wat het verschill is tussen deze 3...
Hier een duitse link waar ze alle 3 opstaan:
- http://www.msi-computer.d...st.php?Typ=1&Chipsatz=123
Hier een 2tal links:
Een link van de 865PE Neo2-P PE
- http://www.msi.com.tw/htm...inboard/6728v20/page2.htm
Een link van de 865PE Neo2-PFISR
- http://www.msi.com.tw/htm...inboard/6728v20/page1.htm
Misschien dat jullie hier wat meer over weten.
De MSI 865PE Neo2-PFISR is al te koop bij salland voor €133,-
ongeloofelijk nu weet ik echt niet meer welke ik moet kiezen.
of deze houden of die fis2 nemen of die nieuwere |:(
of gewoon de 875...
welke zal ik beter gaan nemen? 8)7
[ Voor 21% gewijzigd door Verwijderd op 19-01-2004 20:45 ]
  • Domino
De 875 chip is wat mij betreft te duur voor de prestatiewinst die je boekt tov een 865 based bord. De nieuwere P borden zijn ook vrijwel nutteloos. Intel gaat opnieuw een socket transitie inzetten voor de prescott. Er zullen twee of drie prescott CPU's uit gaan komen op het socket478 platform. Daarna gaan we over naar SocketT oftwel socket775 LGA, eventueel vergezeld van de nieuwe vormfactor BTX.
Verder zijn de verschillen tussen de verschillende borden overduidelijk.
F = Firewire, I = Gb LAN, S = S-ATA, R = RAID
PE stelt verder niets voor, het is de benaming van de 'northbridge', die is er namelijk in de smaken 865P, 865PE en 865G. Die verschillen zullen ongetwijfeld in de openingspost of deel 1 van dit topic staan.
De FIS2R heeft dus F(irewire), I (Gbit LAN), S2 (2 S-ATA contollers), R(aid).
Pas sinds een van de laatste BIOS versies is ook de Intel ICH5R geschikt om RAID 1 mee te draaien. Een betere naam zou nu dan ook zijn FIS2R2 ;).
wel weer mooi dat er op de nieuwe reeks weer een heatsink zonder fan zit, leuk hoor die ledjes maar een herrie dat dat dingetje maakt
  • BvK P4
Ja idd, berg herrie. Op moment hoor ik em niet omdat ik er een fan van 12cm in het zitten @ 2000rpm :7 En die overstemt em een BEETJE. Moet hem nog ff op 7V of op 5V laten draaien.
  • TimmyUt
Ik heb gisteren geprobeerd om win xp op mijn neo 2 865 fis2r te installeren waarbij ik 2 IBM 80 GB Parallel schijven op mijn promise raid controller heb aangesloten. Probeer ik tijdens het opstarten met F6 die driver te installeren (nieuwste d/l van msi.com.tw) dan krijg ik de volgende melding:
"file \winXP\fasttx2k.sys caused an unexpected error (18) at line 2108 in d:\xpsp1\base\boot\oemdisk.c."
Iemand hier ervaringen mee??? heb rondgezocht op Got maar het enige wat dat opleverde was andere diskette en andere driver proberen heb dit toch zeker 4 keer gedaan........ :(
  • BvK P4
Heb je in het de bios je promise controller wel op raid gezet? Denk het wel. maar er zijn mensen die dat vergeten... Probeer daarbij die standaard intel controller es helemaal uit te zetten, dus op disabled als dat tenminste kan. Lukt dat niet, probeer dan es beide schijven op die intel controller aan te sluiten en de promise controller op disabled zetten.
Succes
  • Domino
Verwijderd schreef op 19 januari 2004 @ 22:46:
Je kunt de fan gewoon van de northbridge afhalen hoor, was het eerste wat ik deed toen ik het bord had gehaald. Moet je wel zorgen voor een airflow(tje) door je kast.
TimmyUt schreef op 20 januari 2004 @ 03:26:
Wat wil je precies doen? De beide 80 GB's in RAID0/RAID1 hangen of los gebruiken?
Als je ze los gaat gebruiken hang ze dan aan de Intel contoller, je kunt op het blokschema van de 865/875 chipset zien waarom.
Als je ze als RAID0/RAID1 wil gaan gebruiken moet je, naar mijn idee, eerst een stripeset danwel mirror aanmaken. Dit doe je via het promise 'BIOS'.
  • BvK P4
Heb vandaag even mijn 12cm casefan die op 12V loopt, op 7V aangesloten. Hij is nu veel stiller, maar nu maakt mijn CPU cooler weer te veel lawaai... 8)7 Dus ik corecenter installeren, en de CPU en NB fan op het aller laagste zetten. Toen kwam ik erachter dat de CPU fan nog steeds het luidruchtigste was.
Later heb ik Prime95 gedraait. Die crashte steeds na een kwartiertje ongeveer... Dus ik uitzoeken wat het kon zijn, en toen vond ik dat de CPU onder het primen naar onderen zakte naar soms 1.4V. Dit gebeurde dus nadat ik corecenter erop had gezet.
Ook als ik de computer opstart, en corecenter ervoor springt, geeft hij veel te hoge waardes aan. 1.5625V voor de CPU, 2.65V voor geheugen en 1.7V voor AGP. Nadat ik dat weer lager had gezet ging ik dus prime draaien. Hoe zakte dus toen naar 1.4V en crashte dan (prime crashte). Ik core center weer uninstallen en onder Prime gaf hij weer mooi 1.47V aan en kan zo ook wel dagen lopen.
Ik concludeer hier dus uit de "CoreCell" er dus voor zorgt dat er meer spanning wordt geleverd als de CPU het zwaar krijgt, en weer terug zakt als je niks doet. Dit vond ik toch wel een ideale eigenschap. Zo hoef je niet handmatig hoge voltages in het bios in te stellen schijnbaar.
CoreCenter heb ik dus weer uninstalled omdat die er dus voor zorgt dat het zaakje steeds op dezelfde voltage bleef lopen.
Heb hierbij de nieuwste corecenter gedownload. Ook heb ik geprobeerd om de FSB op 203MHz te zetten en het was meteen "floep". Er kwam een scherm voor waarop stond: als dit de eerste keer is dat dit gebeurt, druk dan de computer uit en herstart em enzzz...
Tis misschien allemaal wat vaag uitgelegd, maar hopelijk snappen jullie het een beetje ;) Dus mijn conclusie is: corecenter er niet opzetten om vastloperz in bv prime te voorkomen... Wil je overclocken, zet dan het voltage in de bios een beetje omhoog en "CoreCell" doet dan de rest wel :)
Domino schreef op 20 januari 2004 @ 17:52:
ja vergeten erbij te zetten, ik heb die fan al losgekoppeld en er zelf een 80mm fan op aangesloten. Alleen nu gaat Corecenter steeds flippen omdat hij steeds waarschuwt dat de fan 0 rpm draait, en 1 seconde erna weer 2000 en dan weer 0 enz. Jammer dat je die alarm niet kunt afzetten (je kan hem wel op 0rpm zetten het alarm, maar dat helpt dus niet :) )
