[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie
Pagina: 1 ... 93 ... 105 Laatste
  • ernstoud
  • Laatst online: 22:06
ernstoud
Nu dus al 7 9 meldingen:
ernstoud in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
[ Voor 3% gewijzigd door ernstoud op 27-12-2025 13:42 ]
RIPE Atlas probe: 1005104
  • nescafe
  • Laatst online: 23:35
Een aantal reboots verder..
WEL connectiviteit
04:06:14 script,info WAN IP: 178.231.14.13
05:15:58 script,info WAN IP: 178.231.52.169
05:19:38 script,info WAN IP: 178.230.212.36
05:23:55 script,info WAN IP: 178.231.39.48
05:27:59 script,info WAN IP: 178.230.214.244
05:31:28 script,info WAN IP: 178.231.14.126
05:47:07 script,info WAN IP: 178.230.223.199
05:51:13 script,info WAN IP: 178.228.19.202
05:57:25 script,info WAN IP: 178.228.43.1
06:00:48 script,info WAN IP: 178.230.221.138
06:06:54 script,info WAN IP: 178.230.205.254
06:13:18 script,info WAN IP: 178.230.251.245
09:44:45 script,info WAN IP: 178.230.251.245
09:50:26 script,info WAN IP: 178.228.43.126
10:01:49 script,info WAN IP: 178.228.34.213
10:07:55 script,info WAN IP: 178.231.63.90
10:22:25 script,info WAN IP: 178.230.214.74
10:36:29 script,info WAN IP: 178.231.52.47
10:39:38 script,info WAN IP: 178.230.215.145
10:47:50 script,info WAN IP: 178.230.215.145
10:52:32 script,info WAN IP: 178.230.238.28
10:58:56 script,info WAN IP: 178.228.38.63
11:01:38 script,info WAN IP: 178.228.47.52
12:19:28 script,info WAN IP: 178.228.47.52
12:22:56 script,info WAN IP: 178.231.28.132
12:53:37 script,info WAN IP: 178.230.196.0
13:08:56 script,info WAN IP: 178.230.221.185
13:24:12 script,info WAN IP: 178.230.206.248
13:28:49 script,info WAN IP: 178.228.63.169
13:41:59 script,info WAN IP: 178.228.51.186
13:45:47 script,info WAN IP: 178.231.14.73
13:54:20 script,info WAN IP: 178.228.63.143
02:15:20 script,info WAN IP: 178.231.13.216
02:22:40 script,info WAN IP: 178.231.53.170
02:34:09 script,info WAN IP: 178.228.46.213
02:41:08 script,info WAN IP: 178.228.19.80
02:44:54 script,info WAN IP: 178.230.222.116
02:47:27 script,info WAN IP: 178.228.39.1
02:51:49 script,info WAN IP: 178.230.214.58
04:00:02 script,info WAN IP: 178.228.51.155
11:58:57 script,info WAN IP: 178.228.30.236
GEEN connectiviteit
05:04:51 script,info WAN IP: 178.231.234.28
05:37:25 script,info WAN IP: 178.231.239.33
05:53:42 script,info WAN IP: 178.231.238.7
06:09:59 script,info WAN IP: 178.231.237.235
09:57:57 script,info WAN IP: 178.231.254.194
12:57:07 script,info WAN IP: 178.231.226.191
14:02:12 script,info WAN IP: 178.231.254.60
15:07:20 script,info WAN IP: 178.231.230.228
15:23:37 script,info WAN IP: 178.231.236.114
15:39:55 script,info WAN IP: 178.231.254.21
03:03:48 script,info WAN IP: 178.231.255.67
03:20:05 script,info WAN IP: 178.231.226.69
03:20:31 script,info WAN IP: 178.231.228.150
12:01:33 script,info WAN IP: 178.231.228.149
13:55:33 script,info WAN IP: 178.231.245.215
M.a.w. het probleem lijkt zich te concentreren rond subnet 178.231.224.0/19 (inclusief waarnemingen ernstoud en flaskk)
Script voor het verkrijgen van het WAN IP in RouterOS:
:local ip 192.168.1.1
:local user admin
:local pass password
:local loginData [ :serialize to=json value={"Input_Account"="$user"; "Input_Passwd"=[ :convert $pass to=base64 ]; "currLang"="en"; "RememberPassword"="0"; "SHA512_password"="false"} ]
:local loginResponse [ /tool fetch "https://$ip/UserLogin" http-data=$loginData output=user-with-headers as-value]
:local cookie
:foreach v in=($loginResponse->"http-headers") do={:if ($v~"Set-Cookie:") do={:set cookie [ :pick $v 12 [ :find $v ";" 12 ] ]}}
:local data [ :deserialize from=json value=([ /tool fetch "https://$ip/cgi-bin/DAL?oid=cardpage_status" http-header-field="Cookie:$cookie" output=user as-value ]->"data")]
/log info ("WAN IP: " . $data->"Object"->0->"WanLanInfo"->1->"IPv4Address"->0->"IPAddress")
[ Voor 92% gewijzigd door nescafe op 28-12-2025 15:35 ]
* Barca zweert ook bij fixedsys... althans bij mIRC de rest is comic sans
  • studioph
  • Laatst online: 27-12-2025
Gisteren bleek mijn Klik & Klaar geen internetverbinding meer te hebben. Daar hij dient om beveiliging mogelijk te maken van een object 150km van mijn woning eerst Odido klantenservice gebeld echter zij konden ook geen contact krijgen met de router. Toen afgereisd en binnen het netwerk bleek inderdaad wel verbinding maar geen internet. Electriciteit eraf gehaald en weer aangesloten en de internet verbinding kwam weer tot stand. Tijdklok geplaatst die 2x per 24 uur uit en aanschakelt. Vanochtend opnieuw geen internet en Odido klantenservice gaat pas om 09.00 uur open in het weekend. Router werkte tot nu toe probleemloos.300km voor niets gereden?
Wie weet hoe je doordringt tot 2e lijn service van Odido?
  • flintjoris
  • Registratie: Februari 2021
  • Laatst online: 20-11 16:06
Hier ook last van het bovenstaande probleem sinds 4 dagen
  • ktkaas
  • Laatst online: 21:27
ktkaas
Mobile netwerk fixer
Afgelopen 48 gekke storingen gehad. Bleek een fout bij een knooppunt op de bloemenveiling in Naaldwijk. Zou nu hersteld moeten zijn. Fyi voor omgeving Naaldwijk.
Field Service Engineer Mobile
  • TWeaKLeGeND
  • Laatst online: 05-09 00:17
Is klik&klaar ook in de winkel af te sluiten en meteen mee te nemen danwel als je online besteld met afhalen is er dan de kans dat er gewoon stock aanwezig is of moet er echt een pakketje voor je richting de winkel gaan?
Edit: Ja dus maar opnemen doen ze niet dus vooraf vragen naar voorraad gaat niet en je moet je pinpas bij je hebben ook als je al mobiel odido klant bent? (Mijn pinpas kwijt)
[ Voor 28% gewijzigd door TWeaKLeGeND op 27-12-2025 12:11 ]
  • Keypunchie
Keypunchie
@TWeaKLeGeND Ja hoor, afhalen in de winkel kan gewoon, meeste hebben wel voorraad.
Over de procedures kan ik niks zeggen, maar lijkt me dat als je gewoon je paspoort/id-kaart meeneemt het wel goed komt?
  • flaskk
  • Laatst online: 00:23
Deze werkt ook niet...Afbeeldingslocatie: https://tweakers.net/i/Q6c67iR94ELzHvfMyzvYTdNcSLo=/800x/filters:strip_icc():strip_exif()/f/image/YxQ0QLOHQ8roICyRcR0xWn8p.jpg?f=fotoalbum_large
  • nescafe
@TWeaKLeGeND ik moest eerder dit jaar wel ter plaatse 0,01 euro pinnen (bij afhalen). Was toen nog geen klant, maar voor een extra router moest ik wederom 0,01 euro afrekenen via iDEAL.
[ Voor 39% gewijzigd door nescafe op 27-12-2025 13:30 ]
  • gertvdijk
  • Laatst online: 19:41
Er staat "gateway: -" en, ja, zonder default gateway geen internet. Is dat misschien het probleem in plaats van het IP-adres zelf? Dat die default gateway soms niet goed wordt gegeven door Odido.
[ Voor 6% gewijzigd door gertvdijk op 27-12-2025 13:24 ]
Kia e-Niro 2021 64kWh DynamicPlusLine. 3x Victron MP-II op 15kWh US5000 3f thuisbatterij met 3x25A→3x40A PowerAssist, Victron EVCS, 3200Wp HoyMiles zp. my GitHub, my blog
  • ernstoud
ernstoud
gertvdijk schreef op zaterdag 27 december 2025 @ 13:23:
Bijzonder is dat ik in het log van mijn NR7302 zie dat de gateway 1 adres hoger ligt dat het IPv4 adres, dus als het IP adres bijvoorbeeld 178.231.28.132 is, staat er dat de gateway 178.231.28.133 is. Huh?
  • gertvdijk
ernstoud schreef op zaterdag 27 december 2025 @ 13:46:
Heel normaal in een point-to-point verbinding (vaak /30 of /31-netwerk). Dan is de overkant altijd 1 adresje bij je vandaan.
Bij een broadcast-netwerk (ethernet zoals je thuisnetwerk) is het gebruikelijk om een kleinere prefix (groter netwerk) te kiezen en heb je meer 'buren' in hetzelfde netwerksegment. Het hangt helemaal van Odido af hoe ze dit inrichten met hun K&K natuurlijk.
[ Voor 22% gewijzigd door gertvdijk op 27-12-2025 13:56 ]
  • W1ck1e
  • Laatst online: 22:21
W1ck1e
gertvdijk schreef op zaterdag 27 december 2025 @ 13:52:
/31 heeft naast netid en broadcast geen adressen beschikbaar
/30 heeft 2 adressen vrij, de cliënt en de gateway
Dus dat zal het zijn
Of vergis ik mij nu ?
  • gertvdijk
W1ck1e schreef op zaterdag 27 december 2025 @ 13:56:
Als je geen broadcastnetwerk opzet kan je precies twee endpoints kwijt hoor met een /31 (RFC3021). In elk geval op Linux kan je een point-to-point interface zo instellen. Gebruik ik voor Wireguard en andere type tunnels gewoon. (Niet alle OS'en/netwerkapparaten kunnen ermee overweg)
[ Voor 6% gewijzigd door gertvdijk op 27-12-2025 14:00 ]
  • ernstoud
ernstoud
Ik heb nooit anders gezien dat bij een uplink het IP adres van de gateway gelijk is aan het WAN IP adres. Weer wat geleerd.
Dat gateway adres reageert overigens niet op ICMP verkeer.
  • ernstoud
ernstoud
Ik heb wat zitten wroeten hoe de NR7302 een WAN IP refresh doet.
Dat zou “zcli wan renew servicename [servicename]” moeten zijn. En met “zcli wan show” zie je de services maar geen van de servicenames in dat overzicht (zou “Cellular WAN 1” moeten zijn) wordt geaccepteerd. We zoeken verder…
  • gertvdijk
ernstoud schreef op zaterdag 27 december 2025 @ 13:59:
Dat is toch ook niet hetzelfde? Het is een buuradres.
Overigens kan je nog wel gekkere truuks uithalen. Je kan een point-to-point link volgens mij ook opzetten met een totaal ander adres aan de overkant. Je kan dan een gedeeld IP van die centrale router gebruiken op al die clients. Met bijvoorbeeld router 1.2.3.4 kan je dan client A 1.0.0.1 -> 1.2.3.4 link opzetten en client B 1.0.0.2 -> 1.2.3.4. Zo verspil je helemaal geen IP-adressen meer. Is erg onhandig als je ook maar iets complexer wilt doen zoals meerdere links naar diezelfde router opzetten, maar als je dat niet doet werkt het prima. In point-to-multipoint Wireguard setups werkt het aan de clients zo. In OpenVPN L3-modus zonder de 'net30' optie werkt het volgens mij ook zo.
Verder is het volgens mij gebruikelijk om bij vaste lijnen (zonder tunneling zoals PPPoE/PPPoA) wel vaak een broadcastnetwerk te gebruiken van een groter netwerk zoals een /22 met een gateway ergens in die /22. (En dan kan het daadwerkelijke broadcastverkeer weer worden gefilterd.)
[ Voor 6% gewijzigd door gertvdijk op 27-12-2025 14:16 ]
  • flaskk
Heeft nu wel weer internet zonder gateway ;) Afbeeldingslocatie: https://tweakers.net/i/s_bOR9NgtoR8zG1wAYAsChaqf4c=/800x/filters:strip_icc():strip_exif()/f/image/zG7BfnbjoleJPcv4YT88OgmY.jpg?f=fotoalbum_large
  • nescafe
Zelfs met mijn watchdog een hele tijd offline gebleven, want ik kreeg 3x achter elkaar een niet-routeerbaar adres:
15:07:18 script,warning rebooting gw
15:23:35 script,warning rebooting gw
15:39:52 script,warning rebooting gw
De traceroute ziet er ook vreemd uit voor deze reeks:
Traceroute from 84.82.69.89 to 178.231.236.114
Using GLOBALPING, Probe b92265f9-ea43-5a75-9a18-aec14f272ee1
STARTED QUERY AT 2025/12/27 14:50:16 UTC
traceroute to 178.231.236.114 (178.231.236.114), 20 hops max, 60 byte packets
 1  _gateway (192.168.189.1)  0.811 ms  0.511 ms
 2  static.kpn.net (195.190.228.12)  4.858 ms  4.809 ms
 3  * *
 4  * *
 5  * *
 6  nl-ams14a-ri1-ae-5-0.aorta.net (84.116.135.34)  7.224 ms  7.196 ms
 7  198-86-143-37.ftth.glasoperator.nl (37.143.86.198)  7.166 ms  7.140 ms
 8  * *
 9  * *
10  * *
11  * *
12  * *
13  * *
14  * *
15  84.241.225.42 (84.241.225.42)  19.516 ms  19.365 ms
16  84.241.225.42 (84.241.225.42)  19.292 ms  19.246 ms
17  84.241.225.42 (84.241.225.42)  19.191 ms  19.148 ms
18  84.241.225.42 (84.241.225.42)  19.096 ms  19.050 ms
19  84.241.225.42 (84.241.225.42)  19.314 ms  19.279 ms
20  84.241.225.42 (84.241.225.42)  19.231 ms  19.194 ms
  • ernstoud
ernstoud
nescafe schreef op zaterdag 27 december 2025 @ 15:51:
 3  * *
 4  * *
 5  * *
 8  * *
 9  * *
10  * *
11  * *
12  * *
13  * *
14  * *
Dus als ik het goed begrijp dan lijkt het er op dat elk 178.231.2xx.yyy (waarbij x niet leeg mag zijn) IP adres niet routeert?
Hoe kan zoiets nou? Domme engineer die ergens een routing tabel verkeerd heeft gezet?
Als dit zo is dan moet toch een redelijk percentage K&K gebruikers af en toe geen internet hebben. Henk en Ingrid zijn misschien niet zo bijdehand om de router te herstarten. En zelfs dat werkt dus niet altijd.
  • nescafe
@ernstoud op basis van mijn datapunten en die van jou en flaskk is het een /19-subnet die niet routeerbaar is. Of het puur om inkomende en/of uitgaande data gaat kan ik nu niet testen (of slechts deels), maar potentieel zijn het 8190 adressen of een deel daarvan door verlies aan adresruimte door point-to-point-verbindingen.
Statistisch gezien 25% à 30% kans dat je verbinding eruit ligt (zonder interventie 24 uur geen connectiviteit).
Dit is maar een ruwe analyse, een engineer kan hier meer over zeggen. Helaas kan ik weinig meer doen dan hier mijn bevindingen posten en wat pleisters plakken in de vorm van watchdogs, net zoals we eerder VPN's moesten opzetten om m.n. UDP-data (DNS) te tunnelen. Klik&Klaar is wel bevorderlijk voor mijn netwerkskills, helaas zijn de eindgebruikers minder enthousiast.
[ Voor 7% gewijzigd door nescafe op 27-12-2025 16:59 ]
  • ernstoud
ernstoud
nescafe schreef op zaterdag 27 december 2025 @ 16:58:
Slordig, op de Delta Discord server is soms een Odido engineer aanwezig. Die heb ik een bericht gestuurd.
Misschien zou abuse@odido.nl een ingang zijn? Helaas reageert @joebafra niet, volgens mij heeft hij contacten daar. (Wel dus, zie hieronder.) Heb ook @Hayte van Tweakers getagged.
Voorlopig dan maar een reboot doen als subnet mask 255.255.224.0 op het geleasde adres 178.231.224.0 geeft.
(Of elk adres tussen 178.231.224.1 en 178.231.255.254 weigeren.)
Ook bericht geplaatst op Odido Community: https://community.odido.n...p-adressen-bij-k-k-382077
[ Voor 12% gewijzigd door ernstoud op 27-12-2025 17:55 ]
  • joebafra
  • Registratie: Mei 2018
  • Laatst online: 20:33
ernstoud schreef op donderdag 25 december 2025 @ 18:10:
Ben benieuwd of meer Tweakers hier nu dit probleem gaan krijgen… niet de eerste keer dat Odido een issue heeft de laatste tijd.
Ik heb op de NR7302 root access maar vrijwel al het netwerk management gebeurt met Zyxel eigen niet-gedocumenteerde tooling. Moeilijk te doorgronden. Anders zou ik zelf misschien een WAN IP refresh kunnen doen.
Interface lijkt “rmnet_ipa0” te zijn, een “ip a set rmnet_ipa0 down” verbreekt internet maar na 5 minuten en dan een “up” houd ik hetzelfde IP. Misschien dat er tussen “down” en “up” een langere tijd moet zitten?
@joebafra … Misschien even je contact(en) bij Odido informeren dat meerdere K&K gebruikers na de 24-uur IP wisseling of een reboot wel een nieuw IP krijgen maar geen internet.
Meldingen:
nescafe in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
flaskk in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
Ventieldopje in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
mvdklip in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
Xandrios in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
Waah in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
studioph in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
flintjoris in "[Odido Klik&Klaar - 5G vast internet] Ervaringen & Discussie"
Ook hier te zien dat er rond 14:00 uur vandaag weer problemen waren:
https://smokeping.hostio....et=nl_isp_client.odidofwa
@Hayte … weer problemen bij Odido… het zal eens niet.
Ik heb hem zojuist een bericht gestuurd. Ik heb het zelf ook een keer gehad in de nacht nieuw IP maar geen data. Wel had ik een IP adres.
  • Ventieldopje
  • Laatst online: 18-11 07:46
Ventieldopje
I'm not your pal, mate!
Ik ga het ook eens even bijhouden, maar als ik mij goed herinner had ik inderdaad IPs in die ranges.
Grappige is dat mijn buren nog geen klachten hebben gehad.
www.maartendeboer.net
  • TWeaKLeGeND
TWeaKLeGeND schreef op zaterdag 27 december 2025 @ 12:01:
Om hierop terug te komen: een scan van mijn telefoonscherm met de pas en iban er op was genoeg. Dat ik al klant was speelde niet mee. Mooi een cent bespaart!
Ik kreeg overigens ook een sok mee. Dat ze daar 24,95 voor durven vragen normaal..
500-600 down 120 up so far
[ Voor 3% gewijzigd door TWeaKLeGeND op 27-12-2025 22:03 ]
  • Jeffrey87
  • Registratie: Februari 2016
  • Laatst online: 19-11 06:53
Ik volg dit topic nu al een tijdje en begin steeds meer het gevoel te krijgen dat Odido een beetje een cowboy club is waar het meer gaat om het binnenharken van zoveel mogelijk klanten, maar waar het leveren van een betrouwbaar product ergens onderaan de prioriteitenlijst staat.
Onder andere de stabiliteit, (pro)actief bestrijden van verstoringen, klantenservice en het ontbreken van IPv6 geven mij dit vermoeden.
Ik zat een tijdje te overwegen om dit product te adviseren aan mijn ouders, maar nu ik dit allemaal lees begin ik toch mijn bedenkingen te krijgen.
[ Voor 7% gewijzigd door Jeffrey87 op 28-12-2025 09:10 ]
  • wkloppen
  • Registratie: Januari 2017
  • Laatst online: 18-05 15:54
Jeffrey87 schreef op zondag 28 december 2025 @ 09:08:
Ha Jeffrey...elke provider is een cowboy club. Ook ziggo, KPN of welke provider dan ook heet maar 1 doel...en dat is de mensen zoveel mogelijk geld aftroggelen met een net te accepteren product. Het product heeft niets te maken met wat voor een bedrijf het wel of niet is. Odido doet het veel en veel beter dan de Vodafone ziggo combi bijvoorbeeld. Het product Klik en Klaar is absoluut top. Je moet natuurlijk wel kijken waar de antennes staan bijvoorbeeld. Ik voorspel dat straks alle consumenten een dergelijk product gaan nemen. Die glasaanslutingen zijn echt niet meer nodig voor consumenten. Het is overignes wel verstandig om NIET die zyxel te nemen van Odido maar dat is gevoeglijk bekend....
  • Incognitum
  • Registratie: November 2016
  • Laatst online: 03:36
Een cowboy-club vind ik niet. Het product had ik sinds dag 1 en werkte echt prima tot enkele weken geleden. Na wat flinke storingen achter elkaar is het eigenlijk niet meer zoals het ‘oude’ geworden. Voor mij een reden om terug te gaan naar Ziggo (ondanks dat het een te dure club is) wat wel veel stabieler is.
Of ik het (nu) anderen zou adviseren? Nee denk het niet. Er zijn nog steeds veel kleine dingetjes die niet goed gaan en als je afhankelijk bent kan dat wel een issue zijn.
wkloppen schreef op zondag 28 december 2025 @ 09:28:
Ik weet niet goed of je nu sarcastisch bent of niet, maar dat alle consumenten dit soort product gaan nemen boven glasvezel dat betwijfel ik toch heel erg. Dat het product Top’ is, nee. Daarvoor is het veel te onstabiel (gezien alle meldingen hier). Het was in het begin wel echt top, maar helaas is dat nu mijn inziens niet meer het geval.
Nu is ‘Top’ natuurlijk erg subjectief. De ene accepteert storingen en meerdere resets per dag, de ander niet en vind het product daarom niet goed. Dat is een maatgevend iets waardoor je niet kunt zeggen of een product nu wel of niet ‘Top’ is.
Het is en blijft dus aan de individuele afnemer of men tevreden is ja of nee.
  • flaskk
Denk ook dat deels de problemen zijn ontstaan door te snelle groei van het product.
  • wkloppen
Incognitum schreef op zondag 28 december 2025 @ 09:50:
Is ook zo. Heb zelf nog nooit een reset gehad, gezien. Wel zelf af en toe de modem rebooten maar niet om een specifieke reden of zo. Met HET product bedoel ik niet of het overall goed werkt. Dat is voor mij maatstaf of een product goed of niet goed is. Het product of concept zoals je wil is top en zal de toekomst worden. Het kost helemaal niks en je ziet nergens aan vast. Zoals gezegd...je moet checken welke masten er bij je in buurt staan. Storingen zullen er altijd zijn alhoewel ik dat zelf nog niet heb ervaren na 1,5 jaar. behalve dan een generieke public dns storing die iedereen raakte. Voor 25 euro per maand zit je voor ee dubbeltje op de eerste rang.
  • pribo
  • Laatst online: 22-10 15:42
pribo
ヽ( ͝° ͜ʖ͡°)ヽ
wkloppen schreef op zondag 28 december 2025 @ 10:17:
Maar ook voor 25 euro dient het goed en storingsvrij te werken....menig sim only abonnement is goedkoper en die zouden dus helemaal niet mogen klagen volgens jou.
Ook hier vannacht ineens geen internet op 5G....toen het modem naar 4G gezet en vanmorgen gekeken of 5G het weer deed en inderdaad het werkte weer. Ook vannacht na een paar herstarts geen 5G verbinding, vandaag dat ik naar 4G gegaan ben.
Mensen een fijne zondag, hier schijnt de zon en is het waterkoud... o<:)
  • flaskk
@pribo
Tja hier BEN abbo 25gb/200min/sms en klik en klaar van odido en dan betaal je maar 28,50,- per maand vanwege korting. Wil wel eens weten of je bij een andere provider kan evenaren met dezelfde snelheden 600/100 en prijs. Ik denk dat je vaak het dubbele kwijt ben.
Ben wel eens dat het gewoon moet werken.
[ Voor 7% gewijzigd door flaskk op 28-12-2025 11:20 ]
Voor de mensen die even "geen connectiviteit" hebben, is er helemaal geen connectiviteit of is er geen toegang tot de DNS bijvoorbeeld? Met andere woorden, kun je wel een traceroute doen naar bijvoorbeeld 8.8.8.8 of een simpele ping?
  • Doesnotcompute
  • Registratie: Maart 2015
  • Laatst online: 20:14
De laatste paar dagen werkt het hier weer aardig. Of het product "top" is, is relatief. Voor de 20 euro per maand die ik betaal en het feit dat het of 220/100mbit is, of 12/1 DSL, voor het dubbele, ben ik best bereid wat door de vingers te zien.
Ja, het zou gewoon feilloos moeten werken, absoluut mee eens. Hoop dat odido nog eens met een optie komt om de DSL lijn ook te koppelen. Zoals het "4g voor thuis", maar dan met 5G. Of dat het gewoon verplicht word mensen op glas aan te sluiten, of het nou voor ze rendeert of niet. De huidige maatschappij verplicht je om goed internet te hebben.
  • ernstoud
ernstoud
Verwijderd schreef op zondag 28 december 2025 @ 11:29:
Helemaal niets werkt dan. Krijg je een IP in de genoemde reeks dan heb je geen internet.
  • ernstoud
ernstoud
Natuurlijk! Glas heeft niet de toekomst. Het is echt heel dom dat alle providers wereldwijd op glas overstappen. Enorme investeringen, allemaal voor niets.
</sarcasm mode>
  • Miglow
  • Laatst online: 20:11
Voor mij geldt dat het eigenlijk vrij goed werkt en zelfs in de tijd dat ik het heb iets beter is geworden.
  • Kyle
  • Registratie: Februari 2022
  • Laatst online: 19-11 15:19
Begrijp ik het goed dat Odido IP adressen uitgeeft van een blok dat reeds in gebruik is ?
  • ton14
Van het begin af aan ben ik al klant en heb ook een Ben abonnement in huis dus betaal ik € 20.- per maand voor K&K. Het enige wat ik veranderd heb in de instellingen van de NR5307 router is de bandbreedte naar 20/40/80, dus geen 160.
Mijn desktop aan de kabel zit altijd tussen de 600 - 800mbps down en rond de 60mbps up. Ik zit 600 meter van de mast hier in Zoetermeer, de router staat niet voor het raam, maar in mijn kamer op de2e etage. Hier ervaar ik soms dat een webpagina soms niet snel laadt, maar dat heb ik altijd wel gehad, dus dit ervaar ik niet als probleem. Mijn vrouw brult onmiddellijk als ze ineens geen verbinding meer heeft en die heb ik de laatste maanden niet meer gehoord.
De WiFi in huis fluctueert tussen 500mbps (dichtbij de router) en 150mbps, dus prima voor mijn laptop, de 2 mobiele telefoons en de 2 Samsung tablets (S10+). Het enige wat regelmatig een probleem met de WiFi verbinding geeft is de Ziggo GO app op de tablets, maar dan doen alle andere apps het prima, dus dit heeft niets met Odido te maken.
De laatste 3 maanden heb ik geen handmatige herstart meer gedaan.
Ik heb alleen de grote storingen ervaren tot nu toe, net als iedereen en de verbinding kwam daarna gewoon terug.
Dus voor mij met huis tuin en keuken benodigde internet verbinding is de NR5307 een prima router, geen access points voor WiFi nodig, want alles in huis draait. Je zal begrijpen dat ik geen glasvezel hier nodig heb, dus ook geen gerommel met kabels.
Uit alle commentaar blijkt voor mij duidelijk dat als je mogelijkheden wil hebben om van alles te kunnen aanpassen en zelf wil regelen Odido geen goeie is,
Hierbij de meting van zonet (Mijn desktop aan de kabel).
Afbeeldingslocatie: https://tweakers.net/i/iXNhcYJjO-hv8js0f-nQX3mjDCE=/x800/filters:strip_exif()/f/image/kKS3GqgW1PqBPsejq0WVibb2.png?f=fotoalbum_large
  • joebafra
Ik heb gisteren/vandaag hetzelfde probleem waarbij ik geen internet had met IP 178.231.235.19
Afbeeldingslocatie: https://tweakers.net/i/Xrhahit0l-RfsTqFkv5sQxfC1j0=/x800/filters:strip_exif()/f/image/fHk7akm7CCMfbMH4ZIMAy95r.png?f=fotoalbum_large
[ Voor 7% gewijzigd door joebafra op 28-12-2025 20:14 ]
  • ernstoud
ernstoud
joebafra schreef op zondag 28 december 2025 @ 14:28:
Ik heb zelf weer had IP 178.231.235.19
Had het zo moeten zijn: "Ik heb (had?) zelf weer problemen, ik had IP 178.231.235.19.
Zo niet moet je het wat beter omschrijven denk ik.
  • ernstoud
ernstoud
ton14 schreef op zondag 28 december 2025 @ 14:06:
Die begrijp ik niet. Juist de Tweakers die "wel van alles kunnen aanpassen" kunnen meer met dit K&K product dan anderen; dus tweaken, banden aanpassen, reboot schedulen etc. etc.
Nu er 8192 niet werkende IP adressen uitgegeven worden denk ik juist dat K&K klanten die van niets weten problemen ervaren.
  • ernstoud
ernstoud
Kyle schreef op zondag 28 december 2025 @ 14:05:
Ik denk niet dat dat het issue is. Het betreffende blok is volgens WHOIS van Odido. Alleen wordt (misschien een deel van) dit blok van 8192 IP adressen niet gerouteerd. Je krijgt wel een IP maar er is geen internet.
  • xah5kiDe
  • Registratie: Juli 2017
  • Laatst online: 00:26
xah5kiDe
Usernaam=wachtwoord
Ik heb hier nog geen problemen ervaren maar zie wel dat de nachtelijk IP update er af en toe voor zorgt dat de ping veel stabieler is:
Afbeeldingslocatie: https://tweakers.net/i/6oplZgw0ruaW0LXte-oS_jce2EQ=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/xMQUBkVSMnnnNCDG224ukJCH.png?f=user_large
Hier zie dat het 24 December bijna anderhalve dag stabiel was rond de 20ms. Meestal fluctueert het rond de 25ms
Het reboot script draait nu 1 keer in de week om de IP update midden in de nacht te houden, werkt top!
[ Voor 7% gewijzigd door xah5kiDe op 28-12-2025 16:10 ]
Theo
  • Doesnotcompute
Volgen mij was ik net ook slachtoffer van die IP reeks. Rond 5 uur kreeg ik een nieuw adres en na een reboot van alles werkte het pas weer. Week geleden had ik ook al zoiets.
  • ernstoud
ernstoud
Doesnotcompute schreef op zondag 28 december 2025 @ 17:22:
Volgende keer IP adres even checken in de GUI, heb je geen internet dan heb je waarschijnlijk een 178.231.2xx.yyy adres.
  • nescafe
Kleine statusupdate - het probleem speelt nog steeds:
WEL connectiviteit
2025-12-28 23:30:02 script,info WAN IP: 178.231.47.202
2025-12-29 04:02:18 script,info WAN IP: 178.230.254.218
2025-12-29 09:35:23 script,info WAN IP: 178.230.197.198
2025-12-29 09:42:04 script,info WAN IP: 178.230.247.97
2025-12-29 09:44:22 script,info WAN IP: 178.230.245.212
GEEN connectiviteit
2025-12-29 10:00:32 script,info WAN IP: 178.231.231.82
Ook de helpdesk gebeld, maar die kunnen niets betekenen omdat ik niet fysiek bij het modem aanwezig ben.
nescafe schreef op maandag 29 december 2025 @ 10:23:
GEEN connectiviteit
Als je verder wilt komen bij de klantenservice, moet je echt inzetten op ze zover te krijgen dat ze het aan de technische afdeling gaan doorgeven. Hun belscripts zullen niet helpen. De klantenservice zelf kan dit niet oplossen.
  • nescafe
Verwijderd schreef op maandag 29 december 2025 @ 11:02:
De medewerkers worden gewoon teruggefloten wanneer ze het script niet volledig hebben afgewerkt voor ze iets doorzetten naar tweedelijns. Dus ik ga zeker geen druk uitoefenen om het te laten escaleren.
  • Keypunchie
Keypunchie
De helpdesk kan het wel oplossen: in hun troubleshoot script staat ongetwijfeld een herstart, die voor een nieuw IP zal zorgen, waardoor het (in de meeste gevallen) wel weer werkt.
... dit is natuurlijk alleen geen duurzame oplossing van de onderliggende oorzaak.
  • ernstoud
ernstoud
WEL connectiviteit
GEEN connectiviteit
Hier vanmorgen een 178.230.x.y adres dus geen probleem.
  • W1ck1e
W1ck1e
studioph schreef op zaterdag 27 december 2025 @ 08:23:
Geen antwoord op je uw (vanwege de geboortedatum) vraag, maar ik denk dat een 5g modem / router die opnieuw kan starten wanneer de internet verbinding weg is een betere oplossing is. Een consumenten oplossing gebruiken bij het beveiligen van een object (pand/stukje vastgoed ?) is volgens mij niet de oplossing. Hoe was dat geregeld voor de introductie van OK&K ?
  • Keypunchie
Keypunchie
Waarom niet? Het andere alternatief binnen budget is ongetwijfeld *niet* beveiligen. (Het zal hier niet om Fort Knox gaan, maar gewoon een webcam in een vakantiehuisje of bootje oid).
  • ernstoud
ernstoud
W1ck1e schreef op maandag 29 december 2025 @ 13:53:
Wat stel je dan voor? Stel er is geen VDSL, coax of glasvezel? Dan wordt het toch 4G/5G. Waarbij op het meest kritische stuk van mast tot client device geen enkel verschil zit tussen “consument” en “zakelijk”.
In dit geval van 8192 niet routeerbare IP adressen kan ik me zelfs voorstellen dat deze ook door K&K zakelijk gebruikt worden…
  • W1ck1e
W1ck1e
ernstoud schreef op maandag 29 december 2025 @ 15:36:
Het standaard modem van OK&K is door een aantal gebruikers vervangen door een ander type, vanwege wat voor een reden dan ook. Misschien dat er ook modems zijn die bij een weggevallen wan verbinding opnieuw kunnen starten. Al dan niet met een scriptje. Dan heb je nog steeds geen verbinding zolang het niet opgelost is (aan odido zijde) maar dan hoef je niet langs om het modem te hestarten, Op vaste tijden het modem van de stroom te halen en terug aan te zetten vind ik een beetje bruteforce.
  • waltervl
  • Registratie: Januari 2022
  • Laatst online: 23:33
Het routeringsprobleem zou nu opgelost moeten zijn volgens Odido:
https://community.odido.n...ostid=1907912#post1907912
  • ernstoud
ernstoud
Hoop doet leven.
En dan op naar de volgende Odido storing :) .
  • ernstoud
ernstoud
W1ck1e schreef op maandag 29 december 2025 @ 16:43:
Klopt. Ik heb meerdere Zyxel NR7302 routers draaien. Met root access kun je dan als Tweaker met scripting een hoop bereiken. Zodra ik in de log van de noip DDNS client drie keer geen verbinding zie, reboot ik de router. Ook kent deze router gewoon “scheduled reboot”, een functie die Odido uit de firmware gehaald heeft ondanks verzoeken om het er weer in te zetten.
Maar goed, het zou niet nodig moeten zijn als Odido dit soort rare configuratie fouten niet maakt.
  • ernstoud
ernstoud
@nescafe … kun jij het testen?
  • waltervl
Wel een tip voor de volgende keer: Als je een probleem hebt met Klik en Klaar meldt het dan ook bij de klantenservice of op het Odido forum.
Er is trouwens een speciale telefonische helpdesk voor Klik en Klaar op 088-1005750 die los staat van de normale klantenservice.
Dat er hier gediscussieerd wordt over allerlei tweaker zaken mbt Klik en Klaar is pima maar verwacht niet van Odido dat ze gaan monitoren of er tussen al dat technisch geklets er ook nog wezenlijke storingen worden gedetecteerd.
  • ernstoud
ernstoud
waltervl schreef op maandag 29 december 2025 @ 17:03:
:Y
Dat had ik dus ook gedaan. En toen kwam er inderdaad schot in. Lijkt het.
Dank voor de tip.
Niet helemaal de woorden die ik zou gebruiken voor de discussies hier. Die toch wezenlijk serieuze inhoud hebben. Waardoor ook de problemen met K&K opgelost worden.
En waarom Odido, Vodafone en sinds enige tijd helaas ook Delta niet deelnemen aan Tweakers discussies is onbegrijpelijk. KPN doet dat wel en dat leidt tot veel positieve resultaten.
Dat Odido zelfs dit soort storingen niet lijkt te monitoren maar Tweakers wel is toch winst?
  • waltervl
Voor een niet tweaker op dit gebied (zoals ik) is het geklets (positief bedoeld hoor....).
De moderators op het Odido forum hebben het druk genoeg met hun eigen forum. Maar ik heb uit betrouwbare bron gehoord dat er op support gebied belangrijke ontwikkelingen zullen zijn begin volgend jaar. Ik ben benieuwd, het zal wel met AI te maken hebben.
Er gaat bij Odido regelmatig behoorlijk wat fout ondanks alle goede bedoelingen maar gelukkig heb ik er weinig last van. Ben dik tevreden met mij Klik en Klaar oplossing in het buitengebied.
  • ernstoud
ernstoud
waltervl schreef op maandag 29 december 2025 @ 17:28:
Stel je voor dat ik - weinig tot niet mee bekend - mij meld op een forum voor tandartsen en dan post dat ik het geklets vind… dat is een beetje raar.
Maar goed, je bedoelt het positief dus. Wel goed dat je dat erbij zet.
Dan nog zouden ze - zeker technici - hier moeten deelnemen. Geen idee waarom ze dat niet willen/kunnen/mogen. Waarom je als techneut bij een ISP niet de intrinsieke motivatie hebt om je kennis te verrijken, het product te verbeteren en vooral te weten wat er speelt, is beyond me.
Oh dear. AI to the rescue. Odido gaat ook dat nog uitbesteden? Ben benieuwd.
Er gaat bij Odido regelmatig behoorlijk wat fout ondanks alle goede bedoelingen…
Inderdaad. Hopelijk leren ze er wat van.
…maar gelukkig heb ik er weinig last van. Ben dik tevreden met mij Klik en Klaar oplossing in het buitengebied.
Anderen hebben er wel last van. Dus we blijven scherp.
  • nescafe
Ik kan bevestigen dat dit issue is opgelost:
WEL connectiviteit
2025-12-29 11:55:12 script,info WAN IP: 178.230.247.168
2025-12-29 11:58:36 script,info WAN IP: 178.228.17.148
2025-12-29 12:05:31 script,info WAN IP: 178.231.58.29
2025-12-29 12:12:06 script,info WAN IP: 178.228.11.128
2025-12-29 12:14:32 script,info WAN IP: 178.231.13.227
2025-12-29 12:34:24 script,info WAN IP: 178.231.38.144
2025-12-29 12:51:24 script,info WAN IP: 178.230.198.162
2025-12-29 13:22:01 script,info WAN IP: 178.231.44.106
2025-12-29 20:53:16 script,info WAN IP: 178.231.232.212 <--
2025-12-29 21:06:39 script,info WAN IP: 178.228.38.228
2025-12-29 21:13:13 script,info WAN IP: 178.228.23.17
2025-12-29 21:18:26 script,info WAN IP: 178.230.199.96
2025-12-29 21:24:31 script,info WAN IP: 178.231.229.208 <--
2025-12-29 21:26:47 script,info WAN IP: 178.228.11.163
2025-12-29 21:31:09 script,info WAN IP: 178.231.13.15
2025-12-29 21:33:17 script,info WAN IP: 178.230.199.2
2025-12-29 21:37:10 script,info WAN IP: 178.228.61.160
2025-12-29 20:52:55 script,info WAN IP: 178.228.39.55
2025-12-29 21:07:04 script,info WAN IP: 178.228.38.65
2025-12-29 21:13:02 script,info WAN IP: 178.228.18.116
2025-12-29 21:18:33 script,info WAN IP: 178.228.59.117
2025-12-29 21:24:29 script,info WAN IP: 178.230.197.35
2025-12-29 21:26:52 script,info WAN IP: 178.231.241.242 <--
2025-12-29 21:31:14 script,info WAN IP: 178.228.27.168
2025-12-29 21:34:46 script,info WAN IP: 178.231.7.240
2025-12-29 21:39:01 script,info WAN IP: 178.231.47.96
De IP's in de getroffen range worden nog wel uitgegeven (vetgedrukt) - maar zijn gewoon reachable.
  • ernstoud
ernstoud
nescafe schreef op maandag 29 december 2025 @ 21:42:
WEL connectiviteit
Top. Bedankt.
  • joebafra
Ik heb zojuist ook een reactie gekregen van Odido "contactpersoon" dat het gisteren is opgelost
[ Voor 9% gewijzigd door joebafra op 30-12-2025 10:34 ]
  • ernstoud
ernstoud
joebafra schreef op dinsdag 30 december 2025 @ 10:34:
Waarschijnlijk zonder dat je de oorzaak hoorde?
  • joebafra
ernstoud schreef op dinsdag 30 december 2025 @ 12:44:
Klopt, storing zat op een andere deel van netwerk waar hij niet verantwoordelijk voor is.
  • Bakkertje_01
  • Laatst online: 00:43
Sorry heren, ik ben toch maar weer naar Ziggo overgestapt. (Vorige bewoner heeft de aanleg van glas niet laten uitvoeren 😤)
Alsnog aanleggen schijnt 800+ te kosten
[ Voor 14% gewijzigd door Bakkertje_01 op 30-12-2025 17:03 ]
  • W1ck1e
W1ck1e
Bakkertje_01 schreef op dinsdag 30 december 2025 @ 17:02:
Gekocht of gehuurd ?
Jammer dat een huurder zoiets mag/kan blokkeren.
  • Bakkertje_01
W1ck1e schreef op dinsdag 30 december 2025 @ 17:17:
Koop hoor, geen huur. Ze had het voor +- 200 kunnen laten aanleggen.
  • W1ck1e
W1ck1e
Bakkertje_01 schreef op dinsdag 30 december 2025 @ 17:35:
Dan maar wachten tot een provider het zonder kosten aanlegt.
  • Miglow
Je kunt het vaak gratis door de provider laten regelen als je postcode glas heeft.
  • IJsbeer
Miglow schreef op dinsdag 30 december 2025 @ 18:07:
Dat zijn aannames. In buitengebied werkt dat in het algemeen niet zo. Daar had je zobiezo al aansluitkosten ook als je in het begin meedeed.
Maar goed, allemaal offtopic geneuzel... :+
  • Doesnotcompute
IJsbeer schreef op dinsdag 30 december 2025 @ 21:06:
Ook mijn ervaring. 1800 in het begin, vorige eigenaar geweigerd, nu 4500 euro :+
  • Polyphemus
  • Laatst online: 22:49
Ik gok dat het aan de sneeuwval ligt, maar de verbinding klappert nu 😅
  • Roy Tollenaar
  • Laatst online: 23:03
Polyphemus schreef op vrijdag 2 januari 2026 @ 11:01:
Hier ook in Kesteren gelderland verbindt steeds met verschillende masten.
  • Vae Victus
Vae Victus
Awesome God
Hier regio Barneveld ook problemen met mobiel internet. Glasvezel werkt wel.
I believe in Christianity as I believe that the sun has risen: not only because I see it, but because by it I see everything else. C.S. Lewis
  • ed-win
  • Laatst online: 08-11 23:36
Vae Victus schreef op vrijdag 2 januari 2026 @ 12:39:
Tot 12:12 had ik heel de dag nergens last van, maar tussen 12:12 en 12:40 was mijn K&K verbinding ook niet beschikbaar. Rood lampje (5G) op modem.
2026-01-02 12:12:35 8.8.8.8 8.8.8.8 Online! 28 msec. IP: 8.8.8.8 (1/0)
2026-01-02 12:12:41 8.8.8.8 8.8.8.8 Lost connection!
2026-01-02 12:40:11 8.8.8.8 8.8.8.8 Lost connection!
2026-01-02 12:40:12 8.8.8.8 8.8.8.8 Online! 29 msec. IP: 8.8.8.8 (1/0)
Inmiddels lijkt de verbinding weer wat beter te werken. Rode lampje is nu in ieder geval groen (normaal blauw).
De snelheid is alleen nog wel veel minder dan anders: 29/46 (normaal 600+/100+)
  • ktkaas
ktkaas
De sneeuw blijft 'plakken' aan de straalverbnding-schotel. Hierdoor werkt deze minder of helemaal niet meer. Uit onze eigen veiligheid klimmen we niet met sneeuw in de mast. We zullen moeten wachten tot het weer opklaart.
  • Miglow
Dat is het nadeel van draadloze verbindingen: Als er iets in de lucht zit, verstoort het het signaal.
  • TvanW
ktkaas schreef op vrijdag 2 januari 2026 @ 12:59:
Straal kacheltje :+
  • franssie
  • Laatst online: 02:03
franssie
Save the albatross
Heeft die dan geen verwarming zoals zelfs een Starlink schoteltje dat wel heeft? Of gaan die soms kapot (zoals bij trein wissels)?
  • flaskk
In mijn tijd gebruikte we nog ericsson rau2x zenders. Die ~25w gebruikt, dus wel wat warmte hadden. dish is vaak ook vlak dus bleef bijna geen sneeuw aan plakken. Maar geen idee wat ze tegenwoordig gebruiken.
  • ktkaas
ktkaas
flaskk schreef op vrijdag 2 januari 2026 @ 17:28:
Piepschuim :+
  • Kyle
Vrijdag over een week - 9 januari - wordt een zeer zware storm verwacht, een zgn. "kanaalrat" .Die blaast de boel wel schoon .....
  • laurens0619
  • Laatst online: 00:27
Vanmiddag klik klaar geïnstalleerd in nieuwbouwwoning.
Begane grond gaf 0 signaal dus verplaatst naar zolder. Daar kwam die wel up met 70mbit, prima :) web interface gaf geen 5g aan, alleen lte en lampje was (dus?) oranje
Uur later alle lampjes groen! Interface geeft ook nu 3 streepjes lte en 5g signaal aan. Heb ook een ip adres maar internet ho maar.
Krijg er niets doorheen, hoeveel power cycles ik ook probeer.
Iemand enig idee?
  • ernstoud
ernstoud
laurens0619 schreef op vrijdag 2 januari 2026 @ 22:35:
Iemand enig idee?
Klik&Klaar met de bijgeleverde 5 router? Of eigen spul? Staat APN op “fwainternet”?
  • franssie
franssie
Save the albatross
@laurens0619 welke meuk heb je er achter hangen? Volgens mij heb je best wat eigen netwerk spul. ALs je een eigen router gebruikt, haal die er eerst eens tussenuit. Misschien een VLAN instelling nog ergens vergeten?
  • laurens0619
ernstoud schreef op vrijdag 2 januari 2026 @ 22:54:
Bijgeleverde router en staat
op fwainternet :)
Maar warempel, ik deed een ping test via het modem naar 8.8.8.8, die kwam door en nu ook weer internet via wifi
Niet denderend, dit is de ping test van het odido modem
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=247 time=298.104 ms
64 bytes from 8.8.8.8: seq=1 ttl=247 time=45.165 ms
64 bytes from 8.8.8.8: seq=2 ttl=247 time=105.413 ms
64 bytes from 8.8.8.8: seq=3 ttl=247 time=310.816 ms
Speedtest geeft nu 40/60 aan wat voor mij zat is, als het maar blijft
[ Voor 5% gewijzigd door laurens0619 op 02-01-2026 23:06 ]
  • laurens0619
franssie schreef op vrijdag 2 januari 2026 @ 23:00:
Odido staat op zolder en vanaf dat wifi ap (had ik) geen internet.
Vanuit utp naar meterkast waar het switch in gaat voor mn bekabelde verbindingen en een deco ap
  • franssie
franssie
Save the albatross
laurens0619 schreef op vrijdag 2 januari 2026 @ 23:03:
Zou moeten werken al is het geen sterke router in die doos (dacht 32 klanten max) dus i heb mijn eigen router erachter in DMZ.
Verder als je een managed switch/router gebruikt achter de Odido doos kan je problemen krijgen met je snelheid , zie eerdere posts in dit topic.
  • laurens0619
franssie schreef op vrijdag 2 januari 2026 @ 23:11:
Hmm dat Zou kunnen.
De arp tabel laat nu 19 apparaten zien dus dat valt mee. Ik had eerst mn fritz router ertussen maar dat leek niet te werken om een of andere vage reden. Zal die kabel er eens uithalen als het weer misgaat en kijken wat die dan vanaf het modem doet.
Maar kijkende naar mn ping tijden heeft die denk ik gewoon een brak net wel/net niet signaal
  • franssie
franssie
Save the albatross
@laurens0619 Korte samenvatting van dit topic, het modem is prima, de firmware heeft Odido verkloot. Gebruik de WiFi van het modem niet, hange er een Action switch tussen want unmanaged en ga dan pas los met je eigen backhaul. \Ik draai stabiel 300/100 met de action switch en een Unifi systeem (met de gateway in DMZ) erachter.
[ Voor 3% gewijzigd door franssie op 02-01-2026 23:23 ]
  • ernstoud
ernstoud
In een ideale wereld zorgt Odido er voor dat een:
ethtool -s eth0 speed 1000 duplex full autoneg on
uitgevoerd wordt als het device start. Vrijwel zeker lost dat dit probleem op.
  • laurens0619
Ah hij lijkt wakker geworden :)
Ping vanuit odido modem naar 8.8.8.8 is nu strak 35ms en dowload 850mbit. Misschien nog wel meer maar is max van mn wifi.
Zelfde signal waardes trouwens dus hij leek ff nodig te hebben ofzo
  • Cave_Boy
  • Laatst online: 20-11 15:51
Ik lees hier geregeld dat er wat mindering kan zijn en ook bij velen gebeurt door sneeuw etc.
Zelf zit ik in Purmerend en ja er is wel wat sneeuw (geen bergen). Maar gister en tot dusver vandaag echt eigenlijk geen storingen.
De download en upload blijven hoog. De Ping is met 15ms ook niet heel hoog. Was eerder wel anders maar dat hebben ze opgelost.
  • flaskk
Hier sneeuwt het ook flink en nauwelijks een verschil. Maar ook los.
Denk dat je geen los hebt en aantal daken en/of bomen met sneeuw tussen zit je je inderdaad hoop demping hebt.
[ Voor 3% gewijzigd door flaskk op 03-01-2026 10:22 ]
  • Miglow
laurens0619 schreef op vrijdag 2 januari 2026 @ 23:16:
Hmm dat Zou kunnen.
Ik heb de K&K voor de gein wel eens als backup van mijn glasvezel op de Fritz aangesloten en je moet goed kijken welke LAN poort je instelt, maar daarna werkt het gewoon.
  • Roy Tollenaar
Odido heeft de prijs van Klik en Klaar vandaag met €1 verhoogd, op de bestelpagina zie ik het alleen nog niet terug. Afbeeldingslocatie: https://tweakers.net/i/lQ2sWjoTUdEgbRL78tI5mXBJe60=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/j17UVQWwrZMgiHWoBCY7eF6v.png?f=user_large
Afbeeldingslocatie: https://tweakers.net/i/ty7w0DngbB54_WwoOyLwqfjfYRw=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/686asx5eOEoBw1Bb7zasHyT9.png?f=user_large
Voordat je een vraag stelt in dit topic graag eerst in de Topic FAQ in de openingspost kijken of je vraag daar al is beantwoord.
Berichten over de recente hack mogen in: Odido waarschuwt voor datalek (cyberaanval/hack)
