Home Assistant: Open source Python3 home automation - deel 5 Vorige deel Overzicht
Pagina: 1 ... 7 ... 404 Laatste
  • Fab1Man
  • Laatst online: 21:05
Fab1Man
Live life to the fullest
Geen matches
Obelixxx schreef op maandag 9 januari 2023 @ 09:27:
De code die ik nu in ESP geladen heb is deze:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  password: ""
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "Watermeter-Test Fallback Hotspot"
    password: ""
captive_portal:
sensor:
  - platform: pulse_counter
    pin: GPIO12
    update_interval : 6s
  - platform: pulse_meter
    pin: GPIO12
    name: "Water Pulse Meter"
    unit_of_measurement: "liter/min"
    icon: "mdi:water"
    total:
      name: "Water Total Ltr"
      unit_of_measurement: "L"
      device_class: water
      state_class: total_increasing
    pin: GPIO12
    icon: "mdi:water"
    total:
      name: "Water Total m3"
      unit_of_measurement: "m³"
      device_class: water
      filters:
        - multiply: 0.001
  - platform: template
    name: "Water Usage Liter"
    accuracy_decimals: 1
    unit_of_measurement: "l/min"
    icon: "mdi:water"
    lambda: return (id(water_pulse).state * 10);
    update_interval: 6s
Wat ik zie in de logging is dat ie verbruik blijft geven:
[log]
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.51000 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.51800 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.52500 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.53000 m³ with 0 decimals of accuracy
[08:43:11][D][pulse_counter:174]: 'water pulse': Retrieved counter: 2999.50 pulses/min
[08:43:11][D][sensor:127]: 'water pulse': Sending state 2999.50000 pulses/min with 2 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.53800 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.54300 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.54800 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Pulse Meter': Sending state 6000.00000 liter/min with 2 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.55100 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Pulse Meter': Sending state 0.00000 liter/min with 2 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.56200 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.56900 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.57500 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Usage Liter': Sending state 29995.00000 l/min with 1 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.58100 m³ with 0 decimals of accuracy
[08:43:11][D][sensor:127]: 'Water Total m3': Sending state 2.58800 m³ with 0 decimals of accuracy
[/log]
Bij het bouwen krijg ik ook de melding dat GPIO12 niet ideaal zou zijn.
Welke pin gebruiken jullie?
Ik heb een ESP32 Wroom development V1 board gebruikt nu
Ik heb bijna hetzelfde, maar de sensor is net iets anders opgezet. Denk ook dat wij dezelfde tutorial gevolgd hebben. Bij mij werkt het met een NodeMCU:
YAML:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
esphome:
esp8266:
  board: nodemcuv2
# Enable logging
logger:
api:
  encryption:
    key: "..."
ota:
  password: "..."
wifi:
  ap:
    ssid: "Watersensor Fallback Hotspot"
    password: "..."
captive_portal:
sensor:
  pin: GPIO12
  pin: GPIO12
  icon: "mdi:water"
  total:
    device_class: water
  icon: "mdi:water"
  update_interval: 6s
  • Marsjee
  • Laatst online: 22-06-2025
Geen matches
Hmmbob schreef op maandag 9 januari 2023 @ 07:05:
Steile leercurve, maar wel leuk denk ik!
  • Heb je Nordpool ook uit hacs geïnstalleerd? Dat eerst doen en HA opnieuw starten, dan pas de sensor toevoegen.
  • Je gebruikt een !include, dan moet in het bestand sensor.yaml "sensor:" weg en alle code "2 spaties naar links".
  • "rest:" is een eigen domein (net zoals sensor: ), die moet dus een eigen bestand krijgen. Ook hier geldt het vorige punt
Geweldig, dank voor je uitleg.. Straks weer verder stoeien _/-\o_
  • NeoFoX
  • Laatst online: 06-07 14:45
Geen matches
Morguh!
Ik draai HASS nu al ruime tijd op de normale (geïntegreerde) DB dus SQLlite.
In topic deel-4 had ik een vraag voor een entity die niet meer klopt. Dus ik wil die gaan aanpassen in de DB. Iemand een idee of er ook een add-on via HACS of iets is om je lokale DB in te zien vanuit HASS of is daarvoor alleen zoiets voor (https://sqlitebrowser.org/)?
- The Neo and Only -
  • Goochelaar
  • Laatst online: 04-07 22:02
Geen matches
Hmmbob schreef op zaterdag 7 januari 2023 @ 11:51:
Ik gebruik ook Zonneplan, maar haal de dynamische stroomprijzen op vanaf Nordpool en de gasprijs met een rest-sensor vanaf enever.nl.
Ik zit per 01-02 ook bij Zonneplan en wil mijn HA installatie hier ook alvast op voorbereiden, dus voldoende inspiratie waaronder jouw grafieken ;) Maar het is mij niet helemaal duidelijk waarom je voor gas gebruik maakt van enever.nl maar voor stroom niet. Daarvoor hebben zij toch ook feeds?
  • Hmmbob
  • Laatst online: 21:57
Geen matches
Goochelaar schreef op maandag 9 januari 2023 @ 10:58:
True. Ik had eerst Nordpool en daarna pas Enever ontdekt. Heb de indruk dat ik met Nordpool flexibeler ben, maar zal mekaar niet veel uitmaken denk ik.
  • Yukkie
  • Laatst online: 06-07 13:19
Yukkie
Vorsprung Durch Technik
Geen matches
Kan iemand helpen/adviseren bij het volgende:
De HA installatie bij mijn ouders draait nu op een Pi4 met SD kaartje. Dit SD kaarte begint te overlijden volgens mij, dus heb ik een SSD gepakt die ik nog had liggen en een USB behuizing gekocht. Ik heb HA op die SSD geflashed en een backup gemaakt van het SD kaartje en van het weekend dacht ik de boel om te zetten.
De Pi boot netjes vanaf de SSD en na enkele minuten kan ik de backup terug zetten. Hier begint de ellende: Na enkele minuten in het proces gebeurt er niets meer en kan ik de pi alleen nog maar pingen. Na enkele pogingen (opnieuw flashen van de SSD) denk ik dat het komt door een van de add-ons die gerestored worden vanuit de backup. Ik liep namelijk tegen hetzelfde probleem aan toen ik alleen de add-ons restorede, maar niet toen ik alleen HA restorede. Alleen liep ik tegen het issue aan dat toen ik dat laatste gedaan had, volgens mij niet 1 voor 1 uit de full backup de verschillende Add-ons kon restoren via het backup en restore menu.
Het gekke is overigens wel, dat HA gewoon actief lijkt, ik zie namelijk in Adguard wel dat de pi iedere X minuten contact zoekt met checkonline.home-assistant.io. Maar ik kan dus niet meer op de pi komen, niet via SSH en ook niet via de web interface. Ook het observer adres (Poort 4357) is onbereikbaar, alle drie de poorten (22, 8123 en 4357) geven een connection refused melding.
De Add-ons die ik gebruik zijn (uit mijn hoofd, ik kan het Add-on menu niet meer openen...): mosquitto, zigbee2mqtt, duckdns, ssh, samba, unifi, nginx-proxy, eufy security addon, node-red, wireguard en esphome.
Heeft iemand enig idee hoe ik dit kan oplossen?
We've got that ring of confidence
  • Goochelaar
Geen matches
Hmmbob schreef op maandag 9 januari 2023 @ 10:59:
Bedankt, maar dan ga ik denk ik vooralsnog uit van Enever voor beiden want dan hoef ik Nordpool ook niet te installeren.
  • Hmmbob
Geen matches
Goochelaar schreef op maandag 9 januari 2023 @ 11:08:
Wat ik me nu bedenk: dat had ik zo al werkend maar zodra de Zonneplan integratie werkt (ik ben aan het wachten op mijn zonneplan login) ga ik over naar die integratie.Is dus ook een beetje luiheid :+
[ Voor 3% gewijzigd door Hmmbob op 09-01-2023 11:18 ]
  • Septillion
  • Laatst online: 22:29
Septillion
Geen matches
@NeoFoX Wat klopt er niet? Als het een long term statistiek is kan je dit ook in de UI aanpassen. Dev tools => Statistics => Icoon van helling met pijltje.
  • Goochelaar
Geen matches
Hmmbob schreef op maandag 9 januari 2023 @ 11:17:
Ik heb aangegeven per 01-02 te willen overstappen (eerste mogelijkheid was de 27e) en dus ook nog geen account, maar ik wil wel alvast wat data verzamelen en 'ervaring' opdoen.
Overigens heb ik inmiddels wel een verschil tussen de enever oplossing en die van Nordpool gezien, namelijk het gemiddelde. Dat gebruik jij in je grafiek en krijg je vanuit enever niet mee zo te zien.
N.B. jouw Enever gas sensor haalt nu ieder kwartier de waarde op, maar dat is toch een dagprijs? Is dat ook luiheid? ;)
  • Hmmbob
Geen matches
Goochelaar schreef op maandag 9 januari 2023 @ 11:27:
Klopt gedeeltelijk. Dit zou om 06u aangepast moeten worden, maar dat werd hij een tijdje niet. Dus toen heb ik hem naar eens per 15min gezet, wat ruimschoots binnen de API limit is (max 25 per uur).
  • Goochelaar
Geen matches
Ok. Ik las op de feeds-pagina van enever het volgende:
gasprijs – vandaag: prijs van gas van 06.00 uur (vandaag) tot 06.00 uur (morgen), beschikbaar vanaf uiterlijk 07.00 uuur, meestal 06.00 uur
Volgens mij stond dat er eerst niet, dus blijkbaar hebben ze toch een probleem met dat consequent om 6:00 aan te leveren.
Maar goed, daar ben je vanaf als je de data van Zonneplan zelf gaat gebruiken.
  • lverlaek
  • Laatst online: 16-04 16:49
Geen matches
lverlaek schreef op donderdag 5 januari 2023 @ 09:19:
Vraagje aan jullie;
Ik heb een gecureerde selectie Home Assistant devices via Nabu Casa gekoppeld met Google Home.
Nu heb ik dus bij meerdere, maar niet alle, apparaten dat als ik Google vraag iets aan/uit te zetten het volgende:
De actie wordt wel onmiddellijk uitgevoerd, maar Google geeft ook direct aan dat het apparaat niet beschikbaar is.
Het werkt dus wel, maar krijg van Google een gesproken foutmelding.
Iemand enig idee wat hier mis gaat? Het geeft, zeker bij mijn vrouw, toch wat onzekerheid of een actie nu wel of niet is uitgevoerd.
(Alvast bedankt voor het meedenken!)
Even een schaamteloze kick O-)
  • NeoFoX
Geen matches
Septillion schreef op maandag 9 januari 2023 @ 11:20:
Gaat om een counter die ik gemaakt heb op basis van een entity (Water meter in m3).
Ik moest nog even mijn HASS updaten (just did).. en kan dus nu ook een counter individueel updaten:
Afbeeldingslocatie: https://tweakers.net/i/1pjyaM9pcYeuPCHk-ta6yEFu8V4=/800x/filters:strip_exif()/f/image/VgkEChfi6jDJbVgpiM43X5Tn.png?f=fotoalbum_large
Ik heb hier 500 liter nu aan toegevoegd en nu is het weer 'inline' .. ik mist dus wat liters door een vastloper van HASS en een paar dagen water. Maar nu is het weer in lijn. Thanks voor je hulp _/-\o_
  • Obelixxx
  • Registratie: Juli 2020
  • Laatst online: 16:33
Geen matches
Deze kan weg
[ Voor 97% gewijzigd door Obelixxx op 09-01-2023 14:18 ]
  • Gizz
  • Laatst online: 21:13
Gizz
Dunder-Mifflin, Inc.
Geen matches
@TheFes mag ik jou wat vragen in je rol als 'intent leader' nu het year of voice is aangebroken?
Ik zou graag willen meehelpen bij de Nederlandse intents, alleen denk ik dat ik de bedoeling niet helemaal snap. Zo vind ik bijvoorbeeld climate_HassClimateGetTemperature.yaml wel erg leeg met maar 1 variant:
YAML:
        - "hoe warm is het"
        - "hoe warm is [het in] <area>"
Hier kan je natuurlijk veel andere vormen voor verzinnen (zoals "wat is de temperatuur" of hoe heet/koud i.p.v. warm). Die zijn natuurlijk vrij eenvoudig toe te voegen, maar is dat wel de bedoeling om zoveel mogelijk varianten te formuleren die je in de praktijk tegen kunt komen?
Of is het juist bewust nu nog wat eenvoudig en niet te gevarieerd? Voordat ik lekker enthousiast de boel begin te vervuilen met mogelijke varianten check ik het graag even :P
Bij de Duitse versie zie ik wel al wat meer opties staan.
  • CodeBaker
  • Registratie: November 2022
  • Laatst online: 22:30
Geen matches
@Marsjee laat je ook o.b.v noordpool ook verschillende automatiseringen draaien? of gebruik je het puur voor grafieken.
  • gazzzman61
  • Laatst online: 20:17
Geen matches
Ik heb een probleem met de IOS mobile app.
Op laptop:
mijn HA instance is bereikbaar via de nabucasa cloud en ook lokaal.
lokaal via http://192.168.x.x:8123 en ook via http://homeassistant.local:8123.
Alle addons zijn ook bereikbaar via deze manier.
echter op mijn iPhone werkt HA wel zowel op 4G als op wifi
Alleen de addons werken niet op wifi (lokaal) wel op 4G.
hier krijg ik de error 401: Unauthorized.
waar ligt dit aan? webhook?
Ik heb de app al opnieuw geïnstalleerd maar dat helpt niet.
ik durf niet zomaar de webhook weg te doen.
al gezocht in het HA forum en hier, maar vind geen antwoord.
Wie kan mij helpen?
Canon 5dMkIV
  • Hmmbob
Geen matches
op Discord kwam de "NS Status Card" voorbij, handig voor de gebruikers van de NS component:
Afbeeldingslocatie: https://user-images.githubusercontent.com/42770753/211256045-165b1747-db12-4968-b831-eb5d35b4caf7.png
Afbeeldingslocatie: https://user-images.githubusercontent.com/42770753/211256097-f04475c7-77bb-47f3-b62a-cdac1e2826de.png
Te vinden in de repository van JesseFPV: https://github.com/JesseFPV/hacs-ns-card (en die zit niet op GoT, vandaar dat ik hem post)
[ Voor 8% gewijzigd door Hmmbob op 09-01-2023 14:28 ]
  • Groen
  • Registratie: Juli 2022
  • Laatst online: 05-07 22:13
Geen matches
Ik wil graag via een automation de temperatuur van de boiler instellen. Maar dat lukt nog niet. Dit is de code:
YAML:
alias: Boiler 33
action:
  - service: water_heater.set_temperature
    data:
      temperature: 33
    target:
      entity_id: water_heater.boiler
Via deze pijltjes kan ik het ook wijzigen en dat werkt wel.
Afbeeldingslocatie: https://tweakers.net/i/EokMiiVG46SQUQzZl5DegjPRkvY=/800x/filters:strip_exif()/f/image/0hT6S7Rv1MSHeHA929eFuRnC.png?f=fotoalbum_large
Volgens mij is het een attribute dit gewijzigd moet worden:
Afbeeldingslocatie: https://tweakers.net/i/L6gz3IsvnJrValZooCmz_fnR-u0=/800x/filters:strip_exif()/f/image/fNf6Upf9PE5RlfMVjfdFDGWl.png?f=fotoalbum_large
Iemand een idee wat ik kan doen om dit werkend te krijgen?
[ Voor 1% gewijzigd door Septillion op 09-01-2023 13:49 . Reden: Denk aan de ' yaml' bij code-tags aub ]
LG-HM123MR.U34 / LG-WH27S.F5 / 1245 Wp (zuid)
  • Yukkie
Yukkie
Geen matches
Even terugkomend op Yukkie in "Home Assistant: Open source Python3 home automation - deel 5" : Ik heb net voor de zoveelste keer de SSD opnieuw geflashed. ongeveer 1 op de 2 keer kom ik niet eens voorbij het preparing scherm, na enige tijd houd de boel gewoon op met reageren. Zou dat kunnen komen doordat ik een 2,5" SSD in een externe behuizing heb gestoken en dat die teveel power nodig heeft oid?
  • CodeBaker
Geen matches
@groen je moet de operation_mode: heat_pump aan toevoegen
YAML:
alias: Boiler 33
action:
     target:
    data:
      temperature: 33
  • prutsger
  • Laatst online: 06-07 09:17
Geen matches
Voor de badkamer heb ik een lamp die met de RFXCOM (klik-aan-klik-uit) te schakelen is. Zit nu nog in een andere fitting maar het idee is dat als we willen chillen in bad dat niet felwit licht hoeven te doen :)
Ik heb de lamp dus correct gekoppeld maar kon niet direct een dim-comando sturen zodat ie herkend zou worden als dimmable, hij kwam dus binnen als 'switch'. Dat zou moeten werken als je de entiteit daarna omzet naar een 'light'. Dat heb ik gevolgd:
Afbeeldingslocatie: https://tweakers.net/i/mSAkUJ9XNb5RhDvQ_dVJ5513lXY=/232x232/filters:strip_exif()/f/image/7KFtSM7YzQ9TZfsQSkAfhEVt.png?f=fotoalbum_tileAfbeeldingslocatie: https://tweakers.net/i/l05mKz3V8RHQcw-43O0iNtkZIZY=/232x232/filters:strip_exif()/f/image/MVBgR5vpex29jg0K1X0tBQoO.png?f=fotoalbum_tile
Toch krijg ik op een card geen 'schuif' om te dimmen. Vergeet ik nog iets of doe ik nog iets fout? Liefst vervang ik deze niet door een Zwave lamp want het is een leuk extraatje en deze had ik nog liggen...
  • Groen
Geen matches
CodeBaker schreef op maandag 9 januari 2023 @ 13:34:
YAML:
alias: Boiler 33
action:
     target:
    data:
      temperature: 33
Dank voor het meedenken, dit werkt helaas niet. Staat hier ook als optional.
En via Ontwikkelhulpmiddelen -> Services krijg ik deze melding als ik de service probeer aan te roepen: Kan service water_heater.set_temperature niet aanroepen. Unknown error
  • cerebrum
  • Laatst online: 22:16
Geen matches
Groen schreef op maandag 9 januari 2023 @ 13:54:
In dit laatste voorbeeld staat target: 1 spatie te ver ingesprongen
WP Pana 7J mono | AC Toshiba 3.5+4.6kW | PV 3200WP ZZO | Gasloos Nov23
  • Zerobase
Matched: live
Ik heb nog steeds een variabel stroomtarief en was benieuwd wat ik nu 'teveel' betaal ten opzichte van dynamische day-ahead tarieven alsmede het prijsplafond. Ik houd in de berekening geen rekening met zonnepanelen (teruglevering).
Daartoe de volgende template sensors aangemaakt in Home-Assistant:
YAML:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
      - name: "Electricity Consumption Price Difference Variable versus Dynamic"
        unit_of_measurement: "EUR"
        device_class: monetary
        state: >
          {% if states('sensor.electricity_meter_active_tariff') == "normal" %}
            {% set variable_price = states('sensor.dsmr_day_consumption_energy_supplier_price_electricity_delivered_2') %}
          {% else %}
            {% set variable_price = states('sensor.dsmr_day_consumption_energy_supplier_price_electricity_delivered_1') %}
          {% endif %}
          {{ (variable_price | float(default = 0) -
              states('sensor.nordpool_kwh_nl_eur_3_09_0') | float(default = 0))
             | round(2) }}
        availability: >
          {{ not 'unavailable' in
             [ states('sensor.nordpool_kwh_nl_eur_3_09_0'),
               states('sensor.electricity_meter_active_tariff'),
               states('sensor.dsmr_day_consumption_energy_supplier_price_electricity_delivered_2'),
               states('sensor.dsmr_day_consumption_energy_supplier_price_electricity_delivered_1') ]
      - name: "Electricity Consumption Price Difference Prijsplafond versus Dynamic"
        state: >
          {{ (states('input_number.prijsplafond_electricity_price') | float(default = 0) -
             | round(2) }}
        availability: >
               states('input_number.prijsplafond_electricity_price') ]
      - name: Electricity Dynamic Tariff Excess Payment
        state: >
          {{ ( ([ states('sensor.electricity_meter_energy_consumption_tarif_1'),
                  states('sensor.electricity_meter_energy_consumption_tarif_2'),
                  ('-1808.846')  ] | map('float') | sum) *
                  states('sensor.electricity_consumption_price_difference_prijsplafond_versus_dynamic')
                  | float (default = 0) ) | round(2)
        availability: >
             states('sensor.electricity_meter_energy_consumption_tarif_2') ]
      - name: Electricity Variable Tariff Excess Payment
        state: >
                  states('sensor.electricity_consumption_price_difference_variable_versus_dynamic')
                  | float (default = 0) ) | round(2)}}
        availability: >
De '-1806.846' in de code is de beginstand van de slimme meter op het moment van aanmaken van de sensoren.'
Mocht iemand fouten in de code zien dan hoor ik dat graag.
Ik ben in ieder geval benieuwd hoeveel geld ik laat liggen door niet over te stappen naar dynamisch ...
[ Voor 0% gewijzigd door Septillion op 10-01-2023 12:32 . Reden: Denk aan de ' yaml' bij code-tags aub ]
  • bartbh
Geen matches
Yukkie schreef op maandag 9 januari 2023 @ 11:04:
Heb je niet de mogelijkheid om een schermpje tijdelijk aan de rpi te hangen? Bij mij kwam ik er zo achter dat Network Mananger mijn mac randomized, waardoor mijn ipadres van de rpi veranderde.
  • Yukkie
Yukkie
Geen matches
@bartbh Nee, helaas heb ik geen mini-HDMI naar HDMI converter oid. Overigens gebruik ik een ethernet kabel, volgens mij wordt mac randomization alleen gebruikt voor WiFi? Het IP adres is consequent hetzelfde, dat is het probleem niet.
Ik heb net de SDD na de zoveelste mislukte poging aan een Ubuntu machine gehangen, de data op de data partitie lijkt gescrambled/corrupt. Ik heb een andere behuizing besteld net, wellicht dat het daarmee beter gaat. volgende stap zou een andere SSD zijn, maar het idee om low-cost over te stappen op een SSD is dan wel een beetje mislukt.
  • TheFes
  • Laatst online: 21:41
Geen matches
Gizz schreef op maandag 9 januari 2023 @ 12:46:
YAML:
        - "hoe warm is het"
Dat is wel het idee, ik moet zeggen dat ik naar die zinnen voor climate nog neit echt gekeken heb.
Je zou een expansion_rule kunnen aanmaken met
YAML:
warm: (warm | koud | heet)
en dan de zin "Hoe <warm> is [het in] <area>" gebruiken
Je mag helemaal wild gaan op mogelijke zinnen hoor, dat is het idee :)
De twee zinnen die er staan kunnen sowieso al één zin worden door area optioneel te maken
YAML:
        - "hoe warm is [het in] [<area>]"
[ Voor 4% gewijzigd door TheFes op 09-01-2023 16:44 ]
Home Assistant configuratie
  • Trasos
Geen matches
Het begint een redelijk "schiet maar raak"-topic worden met al die losse vragen, maar ik ga toch ook een poging wagen.
Ik wil automation gaan opstellen voor wat Tradfri devices. Nu kan de Tradfri integratie kennelijk niet 'praten' met de remotes, dus dan moet je ZHA of Z2M gebruiken. Nu heb ik dus nog een Zigbee-stick.
Zouden jullie nu wachten op de stick van HA zelf, of toch gewoon een Sonoff of Conbee kopen?
En in geval van het tweede, welk dan? Ik lees nogal wisselende verhalen bij beide sticks.
  • Turb0Turb0
  • Laatst online: 22:27
Geen matches
TheFes schreef op zondag 8 januari 2023 @ 19:41:
Dat laatste klopt niet, elke sensor met de juiste state_class komt in de long term statistics.
Zie hier bijvoorbeeld mijn processor usage
Ik heb zojuist Domoticz sudo shutdown gedaan en de HA na een dagje spelen vers geïnstalleerd aangesloten.
Heeft een beetje look/feel van Wordpress en bevalt wel erg goed en dingen toevoegen zoals de intergas cv of Hue is een paar tellen werk.
De slimme meter er net ook aan gehangen, en ik ga nog wat mooie meters in het dashboard zetten.
Wat ik nog niet helemaal door heb is dat aanpassen van het langer vasthouden dan 10 dagen.
Ik heb trouwens deze video's bekeken, erg basis maar dat scheelde mij weer veel zoeken en proberen. YouTube: HA Basics - Part 1 - Introduction, Frontend, System Settings and Add...
Afbeeldingslocatie: https://tweakers.net/i/2lnV8B7vrztTGnkMt2e35-OP8PA=/800x/filters:strip_exif()/f/image/y3COvMyU9VxANs5nDrkmneGP.png?f=fotoalbum_large
  • Groen
Geen matches
cerebrum schreef op maandag 9 januari 2023 @ 14:14:
Ja, dat zag ik. Dus daar lag het niet aan. Ik moet misschien maar eens een 'dummy boiler' maken om te testen of ik daarvan dan wel de temperatuur kan veranderen. Of moet ik nog iets doen om deze service te 'enablen'? Als hij erin staat zou het moeten werken toch?
  • Hmmbob
Geen matches
Trasos schreef op maandag 9 januari 2023 @ 16:29:
No worries, daar is zo'n groot topic nou juist voor.
Ik heb happy met de sonoff stick icm zigbee2mqtt, werkt prima. Maar er zijn hier ook genoeg Tweaker die juist de Conbee beter vinden. Beetje Android vs Apple discussie als je het mij vraagt :+
Die HA SkyConnect stick is wel iets meer klaar voor de toekomst, maar dan moet hij wel beschikbaar zijn....
  • RobertMe
  • Laatst online: 22:51
Geen matches
TheFes schreef op maandag 9 januari 2023 @ 16:24:
YAML:
Nee? "Hoe warm is" is geen correct Nederlands en zal waarschijnlijk ook niemand vragen. En "hoe warm is het" zou dan mogelijk geïnterpreteerd worden met "het" als area? Daarnaast kun je met deze dan ook vragen "hoe warm is het in" zonder een area te benoemen.
Dan kom je al eerder op deze uit, als het optionele genest mag worden:
YAML:
        - "hoe warm is het [[in] <area>]"
Alleen klopt die dan nog steeds niet, want je moet dan "hoe warm is het woonkamer" zeggen, wat natuurlijk ook weer niet klopt. Het moet dan "hoe warm is woonkamer" / "hoe warm is de woonkamer" / "hoe warm is het in woonkamer " / "hoe warm is het in de woonkamer" zijn. Maar "het" kan weer niet optioneel want zonder area is het wel "hoe warm is het".
En dit laat mij ook meteen denken: hoe zit het dan überhaupt met voorvoegsels? Want ik zou eerder zeggen "hoe warm is het in de woonkamer", met "de" ervoor dus. In principe kan dus bij elke entity / device / area een "de" / "het" ervoor. Is het de bedoeling dat de gebruiker dat dan zelf opneemt als alias? (Dus bv "Living room", "the living room", "woonkamer", "de woonkamer"). Of moet dit bij elke regel als optionele tekst worden toegevoegd? Wat in het engels makkelijk kan met "[the] <area>". Maar in het Nederlands moet het weer "de" of "het" zijn ("de WC" en "het kleine kamertje" :+). Of kan Rhasspy (/HA? Gezien dit daarin komt zodat het ook met chat integraties werkt?) deze woorden uiteindelijk weg filteren? Waardoor die "the" / "de" / "het" / ... negeert als die voor een "variabele" gebruikt worden.
  • TheFes
Geen matches
RobertMe schreef op maandag 9 januari 2023 @ 17:11:
YAML:
Ik zit op mobiel, dus kan even niet uitgebreid reageren, maar de en het zijn al optioneel in de expansion rule voor <area>. Die hoever er dus niet meer bij.
Wat betreft het samenvoegen van die zinnen heb je gelijk, het had "Hoe <warm> is [het] [in] <area>" moeten zijn als je ze echt samen will voegen.
Maar los is dan wellicht beter
  • Goochelaar
Geen matches
..... Nu kan de Tradfri integratie kennelijk niet 'praten' met de remotes, dus dan moet je ZHA of Z2M gebruiken. Nu heb ik dus nog een Zigbee-stick.
Ik heb een CC2652RB Zigbee stick en die bevalt mij prima. Hier kun je eventueel nog een langere antenne aan koppelen, mocht je dat willen. Ik heb dat niet en toch prima bereik in het hele huis. Overigens kun je hier ook andere firmware op zetten en is deze Matter compatible.
Hij wordt hier gebruikt in combinatie met onder meer Aqara sensoren, Hue lampen en Frient rookmelders.
N.B. gekoppeld aan een Synology waarop HA als VM draait.
[ Voor 4% gewijzigd door Goochelaar op 09-01-2023 18:49 . Reden: typo, Matter ]
  • Wachten...
  • Laatst online: 20:41
Geen matches
Zijn er hier mensen die de slimme meter gas standen naar mindergas.nl sturen via home assistant?
Ik heb een p1 kabel ana mij HA gekoppeld en deze leest de standen uit. Nu zou ik volgens deze site de data moeten kunnen exporteren naar mindergas.nl, maar ik zie ze niet verschijnen onder de "meterstanden"
Iemand enig idee waarom dit niet werkt?
Als je dit kunt lezen, dan werkt mij Signature!
  • htca
  • Laatst online: 03-07 16:42
Geen matches
Wachten... schreef op maandag 9 januari 2023 @ 18:55:
Hoe ziet je eigen code er uit? En werkt je api call buiten HA wel? (Ik upload niet vanuit ha, maar vanuit dsmr reader, ook mijn historische data heb ik via een api call naar minder gas kunnen uploaden)
  • Wachten...
Geen matches
htca schreef op maandag 9 januari 2023 @ 19:02:
Ik heb alles letterlijk gekopieerd en op de juiste plekken gezet binnen HA. (uiteraard wel met mijn eigen API)
Kan ik de API op een andere manier testen binnen windows? Want het Curl commando wat op mindergas staat, is voor linux toch?
  • Groen
Geen matches
Nou, geen idee wat daar aan de hand was, maar onderstaande werkt nu:
YAML:
data:
  temperature: 42
target:
  • Wachten...
Geen matches
@htca
Ik krijg de volgende melding:
Afbeeldingslocatie: https://tweakers.net/i/bLEtDhNUdbdOyYTSxzt3lqUgngw=/800x/filters:strip_exif()/f/image/naSSFJANVGW982QpxFyQQBlC.png?f=fotoalbum_large
  • musicpixel
  • Laatst online: 11-05 05:29
Geen matches
Wachten... schreef op maandag 9 januari 2023 @ 19:19:
Ben geen member op mindergas, maar je hebt curl tegenwoordig standaard in windows zitten (vanaf Win 10 v1803)
https://4sysops.com/archives/how-to-use-curl-on-windows/
Feel free to Buy me a coffee
  • htca
Geen matches
Lijkt erop dat je rest_command niet goed in je configuration.yaml staat gedefinieerd of is geïnitialiseerd. Heb je wel opnieuw opgestart na de wijziging (even checken of je yaml goed is)
  • Wachten...
Geen matches
htca schreef op maandag 9 januari 2023 @ 19:50:
Heb gereboot, en de melding is nu wel weg als ik de automation start, echter komt er niks terecht in de mindergas meterstanden.
@musicpixel, dit commando moet ik kunnen runnen, maar dat lukt me dus niet binnen windows
curl -v -H "Content-Type:application/json" -H "AUTH-TOKEN:<jouw authenticatietoken>"
-d "{ \"date\": \"<jjjj-mm-dd>\", \"reading\": <meterstand> }" https://www.mindergas.nl/api/meter_readings
  • htca
Geen matches
Wachten... schreef op maandag 9 januari 2023 @ 20:00:
Probeer eens in powershell en geef dan eens foutmelding
  • Wachten...
Geen matches
htca schreef op maandag 9 januari 2023 @ 20:11:
Ik heb dit topic er even bij gepakt, en gekopieerd. Daarna even de juist entity voor mijn gasmeter ingevoerd en mijn API van Mindergas.nl, en daarna deed hij het wel.
Blijkbaar staan er dus wat dingen verkeerd in de eerder link die ik heb gebruikt.
Alles werkt nu dus naar behoren :) Scheelt me weer handmatig invoeren.
[ Voor 3% gewijzigd door Wachten... op 09-01-2023 20:18 ]
  • Marsjee
Geen matches
CodeBaker schreef op maandag 9 januari 2023 @ 12:59:
Nee tot zover niet, letterlijk de code ( sensor ) hier van tweakers gecopy'd :+
Ben nog vol in onderzoek zegmaar O-)
  • TheFes
Geen matches
YAML:
        - "hoe warm is het"
Heb al wat extra zinnen ingeschoten
https://github.com/home-assistant/intents/pull/565/files
  • Xqlus1ve
  • Registratie: Augustus 2019
  • Laatst online: 06-07 03:21
Xqlus1ve
Ik roep ook maar wat…
Geen matches
Begin een langzamerhand steeds meer dingen te zoeken in huis die ik al reeds bezit en die ik slimmer kan maken. Het verhaal met de Duco Silent MV is mij nog niet helemaal duidelijk, ga ik later dieper op in.
Maar een vraagje betreft mijn domme thermostaat en mijn Intergas Extreme 36 ketel. Wat is nu het slimste om te doen. Een intergas gateway nemen als slimme bediening in HA (en zoals ik begrijp daarmee ook data kan uitlezen van mijn ketel) of een andere slimme thermostaat aanschaffen zoals bijvoorbeeld een Tado of een Honeywel, etc?
  • Turb0Turb0
Geen matches
Xqlus1ve schreef op maandag 9 januari 2023 @ 21:19:
Ik heb toevallig een intergas HRE 36/30A met de gateway en die kan ik uitlezen/bedienen met HA.
Werkt beter dan de brakke app van intergas :) ik moet de app altijd 2 keer opstarten voordat het werkt..
Hier staat hij op mijn dashboard.
Nu weet ik niet of een andere thermostaat wellicht voordeliger is en meer opties heeft, maar bij mij zat het bij de ketel.
  • Turb0Turb0
Geen matches
Ik loop vast met de gasmeter, in Domoticz kreeg ik netjes power en gas door via de p1 poort.
Is dit iets wat je handmatig moet toevoegen ergens?
Afbeeldingslocatie: https://tweakers.net/i/zhkvtKk8Xu-cPUzy1K3DvqNGdU8=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/BqWAx6og4STSLqx0wJEkY6Xr.png?f=user_large
In de demo zie ik hem wel netjes staan https://demo.home-assistant.io/#/energy
Afbeeldingslocatie: https://tweakers.net/i/Y-eOymKcQQeGZ03fD30L6ap4fLI=/800x/filters:strip_exif()/f/image/jAwoL5wU2Ly5lKvmg9a0n8A4.png?f=fotoalbum_large
Ik kan de gasmeter niet selecteren. wel deze link.
Afbeeldingslocatie: https://tweakers.net/i/v6cYcl-soEuN8ssdK019oLNISQ8=/800x/filters:strip_exif()/f/image/hj0a7h4dxRRybsXBTaxvZxrO.png?f=fotoalbum_large
  • johannesberg740
  • Laatst online: 20:05
Geen matches
Turb0Turb0 schreef op dinsdag 10 januari 2023 @ 07:18:
Als je naar je DSMR-integratie gaat, staat hier de gasmeter wel tussen? Je zal in je screenshot je gasmeter moeten selecteren. Anders weet HASS niet waar hij welke data weg moet halen. Anders even een screenshot van de entities in je integratie?
  • Gizz
Gizz
Geen matches
Een optie die je niet noemt, die veruit het goedkoopst is én je ketel aanstuurbaar maakt via HA: je domme thermostaat houden en tussen die thermostaat en je ketel een OpenTherm Gateway van €29,50 plaatsen.
  • RudolfR
  • Laatst online: 23:02
Geen matches
Begrijp ik het niet goed of maken de intents op deze manier geen onderscheid tussen de gemeten temperatuur en het ingestelde setpoint?
  • TheFes
Geen matches
RudolfR schreef op dinsdag 10 januari 2023 @ 09:36:
Ik moet zeggen dat ik zelf helemaal geen climate entities heb, vandaar dat ik dit ook zelf nog niet opgepakt heb.
Ik zal wel eens even navragen hoe dit nu precies afgehandeld wordt.
De climate_HassClimateSetTemperatue intents zijn uiteraard om het setpoint in te stellen, maar van Get weet ik het niet zeker dus.
[ Voor 13% gewijzigd door TheFes op 10-01-2023 09:51 ]
  • Magnetism
  • Registratie: Augustus 1999
  • Laatst online: 19:58
Geen matches
Yukkie schreef op maandag 9 januari 2023 @ 15:48:
Weet je zeker dat je voeding krachtig genoeg is? Uit persoonlijke ervaring kan ik zeggen dat een te zwakke voeding voor corruption kan zorgen op je drive.
--<BR>Duh?<BR>
  • Obelixxx
Geen matches
Ik ben op zoek naar een elektriciteit meter voor in mijn meterkast. (1 locatie).
Bij voorkeur Zigbee, geschikt voor deconz (Conbee 2)
Is hier iets voor beschikbaar?
Ik heb zelf deze gevonden, maar deze zie ik niet in de compatibility list.
https://aliexpress.com/item/1005004891519043.html
Graag volgende keer zelf schone link plaatsen
[ Voor 38% gewijzigd door Septillion op 10-01-2023 12:31 . Reden: link cleanup ]
  • Sp33dFr34k
Sp33dFr34k
Retro-Geek
Geen matches
Obelixxx schreef op dinsdag 10 januari 2023 @ 11:13:
https://nl.aliexpress.com...urPageLogUid=YtuIUFkTH3fk
Je gaat serieus Ali automaten overwegen? Zou ik persoonlijk nooit doen.
i7 9700k + Be-Quiet Dark Rock 4 Pro | Gigabyte Z390 Aorus Ultra | Gigabyte RTX5070Ti | Samsung 970 Pro 512GB + 860 EVO 1TB + 860 QVO 4TB | 2x8GB DDR4 3000Mhz | Seasonic Platinum 660W | Fractal Design R6 | Samsung Oddyssey G7 Neo | Edifier M60
  • Gizz
Gizz
Geen matches
@Obelixxx even bij Blakadder zoeken op DIN en door de mogelijkheden klikken. Je komt dan bijvoorbeeld deze tegen die compatible is met Deconz. Te koop bij Amazon.de.
Als het je alleen gaat om meten en niet om schakelen, dan kun je ook een model met klem overwegen. Scheelt weer <1 W van het relais dat altijd aan moet staan. Staat helaas weer niet bij of hij werkt met Deconz.
Zelf gebruik ik naar tevredenheid een Tuya, maar volgens de lijst werkt hij niet met Deconz (of is het nog onbekend of hij compatible is).
Sp33dFr34k schreef op dinsdag 10 januari 2023 @ 11:44:
Dit zijn geen (zekerings)automaten, maar 'gewoon' relais (net als tussenstekkers en zo) in DIN-formaat. Of bedoelde je dat niet met automaat? :)
Je kunt je nog steeds kunt afvragen of je een relais van Aliexpress wilt gebruiken natuurlijk. Zelf durf ik dat wel aan met de meestgebruikte Tuya-modellen, maar dat moet ieder voor zich weten.
[ Voor 79% gewijzigd door Gizz op 10-01-2023 12:50 ]
  • Kenhas
  • Laatst online: 03-07 13:13
Geen matches
Gizz schreef op dinsdag 10 januari 2023 @ 11:46:
En waarom dan Tuya modellen wel? Tuya is toch geen garantie voor een bepaalde kwaliteit? Is niet omdat je een relais via het Tuya platform kunt bedienen, dat de relais zelf goede kwaliteit is
2x Marstek Venus E 5.12 v155 - CT003 V122 - BMS 216
  • Gizz
Gizz
Geen matches
@Kenhas ik schreef daarom ook meestgebruikte TuYa-modellen. Niet TuYa ansich :)
In de praktijk komt dat voor mij neer op:
  • Veel orders bij diverse winkels op Aliexpress met veel positieve reviews
  • Het apparaat zie ik goed terugkomen in compatibiliteitslijstjes en/of er worden op Github bij Z2M verzoekjes over aangemaakt (met andere woorden: er zijn waarschijnlijk relatief veel andere gebruikers)
  • Ik zie op fora/reddit/waardanook andere mensen die zonder problemen het apparaat toepassen
Dan durf ik het wel aan, zeker door qua load niet op het randje te gaan zitten (mijn TuYa DIN-relais schakelt 8A, de helft van wat hij aan zou moeten kunnen).
Een apparaat wat ik bijna nergens tegenkom of waar nog nauwelijks orders van zichtbaar zijn of reviews, of wat maar bij 1 vage winkel te krijgen is? Dat is voor mij een niet veelgebruikt TuYa-apparaat :)
  • Turb0Turb0
Geen matches
johannesberg740 schreef op dinsdag 10 januari 2023 @ 08:05:
EDIT- Zelf opgelost door jou wel weer aan het denken gezet. oplossing onderaan ;)
Dit zie ik in het dashboard, unknown.
Afbeeldingslocatie: https://tweakers.net/i/uvprtCAdss-MJzggtU5aj50q-C4=/full-fit-in/4000x4000/filters:no_upscale():fill(white):strip_exif()/f/image/n9RWGvctuPZUmPfTfc9pqFPH.png?f=user_large
Dit in DSMR
Afbeeldingslocatie: https://tweakers.net/i/gD6fQSAZHXO2rXNZcLjbZohBD1A=/800x/filters:strip_exif()/f/image/9Tt5Rj66EZcSior6W1skRPG3.png?f=fotoalbum_large
Maar wellicht weet ik wat ik fout heb gedaan, Als ik nu een nieuwe toevoeg merk ik een keuzemenu op (vorige keer niks mee gedaan) en wellicht moet hij niet op 2.2 staan? Is dat aan te passen of oude deleten en nieuwe proberen en die paar dagen historie vergeten.
Afbeeldingslocatie: https://tweakers.net/i/48YDbxmMnkCg_H4HgMC6H8eZHUA=/800x/filters:strip_exif()/f/image/O0wwZReMtUHX3zWfYQMtqKkR.png?f=fotoalbum_large
Edit Oplossing
in DSMR delete en opnieuw toegevoegd en nu op 5 gezet.
Afbeeldingslocatie: https://tweakers.net/i/DiGe26q58eFdpjxn0BIFpUkl11w=/800x/filters:strip_exif()/f/image/oUgAArHMmlKZWofaEMk1ZldP.png?f=fotoalbum_large
[ Voor 13% gewijzigd door Turb0Turb0 op 10-01-2023 12:52 . Reden: Oplossing ]
  • Yukkie
Yukkie
Geen matches
Magnetism schreef op dinsdag 10 januari 2023 @ 10:44:
Goeie. Het is een originele Raspberry Pi voeding, zoals deze: https://elektronicavoorjo...oundation-4-b-voeding-wit
met de volgende specs:
Stroomsterkte (Max) 3A
Uitgangsspanning    5.1 VDC
Vermogen (Max)  15 W
Zou het kunnen zijn dat dat niet voldoende is?
  • GENETX
  • Laatst online: 23:21
Geen matches
Even een verzoekje tussendoor voor mensen met een dynamisch contract:
Bij Zonneplan krijg ik een voorspelling van de CO2 terug via de addon. Dat is natuurlijk erg tof (zie ook GENETX in "Home Assistant - Show je setup" ). Deze waarde wijkt wel af van https://app.electricitymaps.com/map en https://co2monitor.nl/ . De modellen er achter zijn dan ook anders, en deels gesloten helaas.
Tot nu toe kon ik ook niet echt aan de CO2 uitstoot van de energiemix komen. Voor een aantal onderzoeksprojecten willen we eigenlijk wel een vereenvoudigd dashboard testen met een aantal consumenten. Doordat het lastig is om aan de data te komen (ik kon geen publieke data vinden) zijn we al met een Master student aan de slag gegaan om een voorspelling te doen aan de hand van beschikbare data.
Maar de data van Zonneplan is dus al een leuk aanknopingspunt. We vroegen ons af of wellicht andere aanbieders ook dit soort data in hun API hebben zitten. Dus hierbij het verzoek:
Zouden jullie ons kunnen helpen door even te kijken in de data van de addon van je eigen dynamische aanbieder (bijvoorbeeld ook attributen) of daar ook CO2 informatie wordtgemeld?
Alvast hartelijk dank!
Turb0Turb0 schreef op dinsdag 10 januari 2023 @ 12:38:
Dit in DSMR
Edit Oplossing
Je DSMR versie moet matchen met het type DSMR versie van je slimme meter omdat dta aangeeft hoe de berichten er uit zien. Het beste kun je dus nog even controleren of DSMR 5 wel correct is voor in de toekomst. Dat doe je door het typenummer van je slimme meter te googlen. (of wellicht staat het zelfs ergens op de slimme meter).
[ Voor 41% gewijzigd door GENETX op 10-01-2023 13:44 ]
  • buhito81
  • Registratie: Oktober 2022
  • Laatst online: 23-04-2024
Geen matches
Is het iemand gelukt om, op dezelfde HA device, parralel Zigbee2MQTT Stable en Zigbee2MQTT Edge te laten draaien met twee verschillende coördinators? Ik had bedacht om zo makkelijk te migreren van de Conbee II naar de Sonoff Dongle P, maar krijg het met geen mogelijkheid voor elkaar...
  • Hmmbob
Geen matches
GENETX schreef op dinsdag 10 januari 2023 @ 13:39:
Het zal ook deels afhankelijk zijn van de mix die een bedrijf inkoopt natuurlijk.
  • Hmmbob
Geen matches
Edit Oplossing
De meeste meters in NL zijn DSMR4 of 5. Zoals @GENETX zegt, dit staat ook op je meter (kan ook ESMR staan ipv DSMR)
  • TheFes
Geen matches
Even een update, er was niet echt rekening gehouden met dat zowel setpoint als gemeten temperatuur mogelijk was. Hier komt nog een update voor, waarbij het dus opgesplitst wordt in 2 intents.
  • Sp33dFr34k
Sp33dFr34k
Retro-Geek
Geen matches
Is het mogelijk om de standaard weer integratie een locale mee te geven? Ik weet dat deze mee verandert met je taalinstelling van HA, maar ik wil HA zelf niet in het Nederlands hebben. De weerintegratie wel.. :) Moet ik dan gaan denken aan een template sensor?
  • TheFes
Geen matches
Sp33dFr34k schreef op dinsdag 10 januari 2023 @ 14:54:
Ja, dan moet je met template sensors gaan werken.
Het zou fijn zijn als je Dashboard taal anders kan zijn als je server taal.
  • GENETX
Geen matches
Hmmbob schreef op dinsdag 10 januari 2023 @ 14:09:
Klopt, we vermoeden ook dat het energiebedrijf zijn eigen mix kent. Maar die van Zonneplan lijkt tot nu toe redelijk tussen co2monitor en electricitymaps in te zitten. Die geven de algemene energiemix van Nederland en dus niet de eigen inkoop. Dus ben ook wel nieuwschierig, als andere suppliers ook dergelijke voorspellingen hebben, of die nog sterk afwijken.
Edit @Kalentum hieronder. Ik wil het topic ook niet vertroebelen met teveel offtopic zaken dus edit even mijn post. ENTSO-E zou kunnen met bijvoorbeeld IPCC omrekenfactoren. Al ontbreken daar heel veel bronnen in (kleine PV, andere windmolens). Daarom heeft Electricitymaps al eigen modellen en co2monitor heeft ook andere data die men meeneemt. We verbazen ons er vooral over hoe weinig openheid er in modellen en data is gezien de urgentie van klimaatverandering...
[ Voor 29% gewijzigd door GENETX op 10-01-2023 16:20 ]
  • Kalentum
  • Laatst online: 22:24
Geen matches
GENETX schreef op dinsdag 10 januari 2023 @ 15:08:
Uiteindelijk is er maar 1 mix die er op het net staat. Ik gok dat Zonneplan die gebruikt. Het zou kunnen dat ze hun data via de API van https://transparency.ents...ionPerProductionType/show halen en dan zelf een omrekenfactor voor elke bron eroverheen gooien. Helemaal goed krijg je het nooit want zelfs binnen de categorie 'Kolen' heb je natuurlijk nog weer verschillen per productie eenheid.
EDIT: zonneplan is OOK energieleverancier, dat wist ik niet.
[ Voor 3% gewijzigd door Kalentum op 10-01-2023 15:24 ]
  • Magnetism
Geen matches
Yukkie schreef op dinsdag 10 januari 2023 @ 13:31:
Vermogen (Max)  15 W
In principe zou dat voldoende moeten zijn, als je de specs van RPi bekijkt. Het ligt er ook aan wat je verder nog op je USB poorten hebt zitten. Volgens mij mag de totale power draw op de usb poorten niet meer dan 6W (1.2A) zijn. Eventueel zou je kunnen proberen de ssd op een powered USB hub te zetten, als je die hebt, om te zien of het uitmaakt.
--<BR>Duh?<BR>
  • Mavamaarten
  • Laatst online: 16:27
Mavamaarten
Omdat het kan!
Geen matches
Ik heb een vrij specifieke vraag waar ik helaas online geen antwoord op vind. Ik heb sinds kort een LED plafondlamp waarvan ik de driver vervangen heb door een Zigbee exemplaar. Het moest vrij specifiek een constant-current driver zijn, waardoor de keuze nogal beperkt was en ik uitgekomen ben op een driver die de kleurtemperatuur kan aanpassen door cold en warm white te mengen. Dat is er eentje gebaseerd op de Tuya TS0502B, welke ik gemakkelijk gekoppeld kreeg in ZHA.
Nu heeft mijn lamp geen kleurtemperatuur, enkel "gewoon" wit licht, dus is het vrij vervelend dat mijn Light in HA nu de mogelijkheid heeft om de kleurtemperatuur te wijzigen (als ik het licht "warm" maak gaat het licht nu natuurlijk gewoon uit). Is er een manier om deze functie weg te halen, zodat ik enkel brightness en aan/uit kan kiezen?
Ah, rubber duck moment, terwijl ik dit typ zie ik net deze pagina: https://www.home-assistant.io/integrations/light.template/
Ik denk dat dat de sleutel is tot mijn probleem :)
EDIT: Yup! Dat was de sleutel
Android developer & dürüm-liefhebber
  • Yukkie
Yukkie
Geen matches
Magnetism schreef op dinsdag 10 januari 2023 @ 16:16:
Ik heb na aanleiding van jouw opmerking nog eens een beetje rond gekeken en kwam hier uit: https://jamesachambers.co...s-for-raspberry-pi-4-400/ Op die pagina staat bij power requirements:
For solid state storage older models of solid state drives (SSDs) are also known to draw more power than their newer counterparts. If you have a drive that you think may fall into this category then definitely be on the lookout for power related issues and extra cautious about your power setup.
Aan gezien de SSD waar ik nu mee werk een 11 jaar oud exemplaar is, zou het best wel eens zo kunnen zijn dat hij te power-hongerig is. Heb net dus maar een nieuwe besteld. Een Kingston A400, aangezien die volgens die pagina het beste/populairste is voor dit doeleinde.
Moet ik alleen nog weer een ander doel zoeken voor een 64GB SSD ;)
  • TheFes
Geen matches
Mavamaarten schreef op dinsdag 10 januari 2023 @ 16:25:
Dat zou inderdaad ook mijn suggestie zijn geweest.
  • PnD
  • Laatst online: 18:09
PnD
like in Pinda ^_^
Geen matches
Ik heb een lamp die zichzelf inschakelt. Hoe kan ik dit verder troubleshooten?
Heb deconz en een conbee2 en dit is een lohonsoho dimmer. Ik weet zeker dat niemand deze lamp aanschakelt.
Het is elke keer ca 6 minuten na uitschakeling 😫
Afbeeldingslocatie: https://tweakers.net/i/vVhc1RIgIjL9yLsXH4acVi3e1hQ=/x800/filters:strip_icc():strip_exif()/f/image/zzFZhG2ZHcsSNJuV9b9VuAvO.jpg?f=fotoalbum_large
  • TheFes
Geen matches
PnD schreef op dinsdag 10 januari 2023 @ 19:29:
Als HA niet laat zien waardoor hij ingeschakeld is, dan is hij ingeschakeld buiten HA om. HA ziet dan alleen de state change.
Is er wellicht iets in een andere app die dit kan veroorzaken?
  • PnD
PnD
like in Pinda ^_^
Geen matches
TheFes schreef op dinsdag 10 januari 2023 @ 19:32:
Wellicht deconz/phoscon? Of is dat niet buiten HA om?
Het is consequent 6 minuten na uitschakeling 🤨
Dat lohonso heeft iets met Tuya te maken. Ik heb ook tuya wifi lampen hangen, maar zie het verband niet....
  • TheFes
Geen matches
PnD schreef op dinsdag 10 januari 2023 @ 20:24:
Tuya is een producent die een hoop smart zooi verkoopt, zowel Zigbee als WiFi, die andere merken onder hun eigen merk weer kunnen verkopen (Kruidvat, Action voor WiFi, Blitzwolf, Iohonso voor Zigbee).
Heb je ook automatiseringen in Deconz zelf ingesteld?
  • PnD
PnD
like in Pinda ^_^
Geen matches
TheFes schreef op dinsdag 10 januari 2023 @ 20:30:
Ik zou niet weten hoe 😂 heb de lamp via phoscon toegevoegd en meer niet.
  • NeoFoX
Matched: live
So... Ik dacht gisteren even een mooie aanpassing gedaan te hebben om een counter handmatig te increasen.
Ging daarna HASS op zijn bek einde van de dag (+- 20:00) dacht ik even slim te zijn en op VM level wat aan en uit te zetten (ESXI) verwijder ik door onhandigheid de vmdk en heb ik mijn HASS onbruikbaar gemaakt...
Ok... LANG leve en hulde aan de Google Drive backup _/-\o_ _/-\o_ ... Ik dacht dat daar de history van de energy niet in zat, maar ik heb zojuist alles gerestored en toch zit alles er weer in 8) O+ I love it!!! Meteen een kop koffie voor hem gekocht... als iemand deze backup add-on nog niet heeft: meteen regelen, It can save lives!
Maar... om toch terug te komen op de vraag. Nu is de backup van 8-1 en daarin dus ook de laatste energy / gas en water hoeveelheid... deze is natuurlijk zojuist geupdate met de waardes van 'nu' , wat resulteerd in deze spike:
Afbeeldingslocatie: https://tweakers.net/i/GqurIxe7_HoTqL7YXrHw9KpewnM=/800x/filters:strip_exif()/f/image/1IwZBxu5QzcQnJEef2WKMwfO.png?f=fotoalbum_large
Is er een mogelijkheid dat ik deze spike alsnog (handmatig) verdeel over de 1,5 dag die ik nu gemist heb? Zodat de verdeling wat beter is. Of zeggen jullie, neem je verlies en laat het hierbij. O-)
  • TheFes
Matched: live
NeoFoX schreef op dinsdag 10 januari 2023 @ 21:12:
Ik zou het zo laten, het zit nog gewoon in dezelfde maand. Denk je dat je over een maand of twee nog naar je dagverbruik in januari gaat kijken?
  • NeoFoX
Geen matches
TheFes schreef op dinsdag 10 januari 2023 @ 21:17:
Het valt inderdaad wel in dezelfde maand, ik denk dat je gelijk hebt dat een dag-vergelijking toch niet zo heel interessant is / gaat zijn. Maandelijks is wel interessant (genoeg) en het valt idd in dezelfde maand.
Ik denk dat ik het dan maar zo laat ;) Thanks.
  • kepler
  • Laatst online: 22:32
Matched: live
Ik heb vlak voor kerst kopjes koffie gekocht voor mijn meest gebruikte integraties, waaronder deze backup. Ik ben van plan dit vaker te doen, ik gebruik het zoveel dat er ook wel wat voor tegenover mag staan! Zelfs iets (nuttigs) toevoegen ben ik niet kundig genoeg voor en nu überhaupt ook niet genoeg tijd voor.
Dan maar afkopen :P
  • CappieL
  • Laatst online: 04-07 13:43
Geen matches
Heb je hier dan een template sensor voor aangemaakt?
Ik maak gebruik van onderstaande code in mijn "sensors.yaml", kan ik deze ook in mijn long-term statistics krijgen, zonder een nieuwe template sensor aan te maken?
YAML:
- platform: systemmonitor
  resources:
    - type: processor_use
[ Voor 3% gewijzigd door CappieL op 10-01-2023 22:15 ]
  • raymondw
  • Laatst online: 23:00
Matched: live
Ken dat, heb ik ook gedaan!
Al zou een netwerk backup ook een coole optie zijn O-)
Vandaag Frigate in HA erbij gezet en Zoneminder/ZMninja uitgefaseerd.
Nog even wachten op een Coral voor een betaalbare prijs, de Ryzen heeft gelukkig wel wat power over.
Veel mee gepield en ik word er steeds enthousiaster van, het gaat zoveel makkelijker dan voorheen.
  • TheFes
Geen matches
CappieL schreef op dinsdag 10 januari 2023 @ 22:12:
YAML:
  resources:
Die van mij komen ook uit die integratie en hebben vanuit de integratie al state_class: measurement mee gekregen.
Hoefde ik dus niets voor te doen.
YAML:
unit_of_measurement: '%'
icon: mdi:cpu-64-bit
friendly_name: Processor use
  • CappieL
Geen matches
TheFes schreef op woensdag 11 januari 2023 @ 07:51:
YAML:
Dat is gek, want als ik jouw code onder mijn code plak, krijg ik deze error in mijn logs:
YAML:
Invalid config for [sensor.systemmonitor]: [state_class] is an invalid option for [sensor.systemmonitor]. Check: sensor.systemmonitor->resources->0->state_class. (See /config/sensors.yaml, line 28). Please check the docs at https://www.home-assistant.io/integrations/systemmonitor
  • Hmmbob
Geen matches
CappieL schreef op woensdag 11 januari 2023 @ 09:21:
YAML:
Lees nog een keer wat hij schrijft.
Je hoeft het dus **niet** zelf toe te voegen
  • CappieL
Geen matches
Hmmbob schreef op woensdag 11 januari 2023 @ 09:23:
Ik dacht even dat ie ze zo in z'n config had staan vanuit de integratie (en dat ik gewoon meer regels had moeten toevoegen tijdens het instellen van de integratie.
Dumb me... |:(
  • DennusB
Geen matches
Ik dacht, misschien leuk een automation van mij te gebruiken waar ik heel blij mee ben :) Die stuurt een push melding als ik een dure dag qua energie heb, gebaseerd op het gemiddelde verbruik die maand :
YAML:
alias: "Notification : Expensive day"
description: ""
trigger:
    value_template: "  {{ ((states.sensor.dsmr_day_consumption_total_cost.state|float) > ((states.sensor.dsmr_current_month_total_cost.state|float) / now().day)) }} "
condition: []
action:
  - service: notify.all_devices
    data:
      message: >-
        Let op : Dure dag vandaag, al {{
        states('sensor.dsmr_day_consumption_total_cost') }} euro aan energie
        verbruikt.
  - service: automation.turn_off
    data: {}
    target:
      entity_id: automation.notification_expensive_day
mode: single
[ Voor 0% gewijzigd door Septillion op 11-01-2023 10:31 . Reden: Denk aan de ' yaml' bij code tags aub ]
  • -Casper
  • Laatst online: 27-06 21:47
Geen matches
DennusB schreef op woensdag 11 januari 2023 @ 09:26:
description: ""
trigger:
condition: []
action:
    data:
      message: >-
        verbruikt.
    data: {}
    target:
mode: single
T is maar wat je leuk vind :P
Vraagje; waarom zet je je automation uit op het eind?
  • DennusB
Geen matches
-Casper schreef op woensdag 11 januari 2023 @ 09:40:
Ja nou leuk niet, maar dan weet ik dat de gashaard beter ff uit kan ;) :P
Zodat ik de melding maar 1x per dag krijg zonder een boolean te hoeven gebruiken :) Een andere automation zet hem elke nacht om 00:00 weer aan!
  • -Casper
Geen matches
DennusB schreef op woensdag 11 januari 2023 @ 09:41:
Je trigger conditie kan maar max 1 keer per dag verspringen naar true toch? Dus volgens mij is die stap overbodig.
  • TheFes
Geen matches
Dat kun je ook met een template condition in de automation doen.
YAML:
- condition: template
  value_template: "{{ as_local(this.attributes.last_triggered).date() != now().date() if this.attributes.get('last_triggered') else true }}"
Verder zou je states('sensor.je_sensor') moeten gebruiken in plaats van states.sensor.je_sensor.state
  • barrymossel
  • Laatst online: 06-07 14:51
Geen matches
  • Tym
Tym
Matched: live
Die plugin vond ik ook altijd fantastisch. Maar nu ik over ben gegaan naar dockerized Home Assistant (ipv HassIO), kan ik geen plugins meer gebruiken.
Heeft iemand een goede alternatieve manier van het maken van backups, zoals de Google Drive plugin doet? Momenteel gebruik ik duplicati om een backup van de config directory te maken, maar dat werkt niet altijd heel lekker.
  • Kalentum
Geen matches
Tym schreef op woensdag 11 januari 2023 @ 11:07:
Ik gebruik rsync maar dat komt op hetzelfde neer. Hoezo werkt dat niet lekker? Wat ik doe is: HA stoppen, config directory (inclusief SQLite database) backuppen, HA starten.
  • Tym
Tym
Geen matches
Kalentum schreef op woensdag 11 januari 2023 @ 11:10:
Dat stukje scripting er omheen (bijvoorbeeld starten en stoppen HA, is dat eigenlijk perse nodig?) en de summiere UI maken het voor mij wat minder gebruiksvriendelijk. Iets dat in zou haken op de backup functie van Home Assistant zelf zou denk ik al beter zijn.
Zet je code tussen [code=yaml] [/code] tags om het goed leesbaar te houden; ook makkelijker voor de eventuele foutopsporing.
Lees ook eerst even de topicstart voor je je vraag plaatst, wellicht wordt je vraag daar al beantwoord. Wil je pronken met je setup mag dat in Home Assistant - Show je setup.
