• sunturion
  • Laatst online: 25-11 11:35
Afbeeldingslocatie: https://i.postimg.cc/mknwFX4f/xiaomi-redmi-k20pro-2.jpg
Xiaomi Mi 9T / Redmi K20 (Pro)
Redmi is a sub-brand owned by the Chinese electronics company Xiaomi. It was introduced as a budget smartphone line manufactured by Xiaomi, that was first announced in July 2013. It became a sub-brand, separated from Xiaomi, on 10 January 2019. Redmi phones use the Xiaomi MIUI user interface on top of Android
Xiaomi Redmi K20 Pro was launched by Xiaomi in the first week of June 2019. The Xiaomi Redmi is the first phone of the company to release 48 megapixels dual camera.
The smartphone has a different Sony IMX 586 sensor for the dual camera. The design of the smartphone is slim along with a combining high performance and mobility.
The minimalist design is in continuity by Xiaomi Redmi K20 Pro, as they have adopted a new process to manufacture. The body is made out of Plastic which is great for stability and fashion as well.
The display type is IPS and the size is 6.39 inches full HD screen which gives a resolution of 1080 x 2340 pixels. The pixel density is 409 PPI (pixels per inch) and the display is protected by Corning Gorilla Glass 5 and a 2.5D curved glass screen.
The smartphone is equipped with Qualcomm Snapdragon 855 chipset and 1x 2.84 GHz Kryo 485, 3x 2.42 GHz Kryo 485, 4x 1.8 GHz Kryo 485 processor.
The internal storage comes with a 6 GB RAM that supports MIUI V10 (Android 8.1 Oreo) operating system for the smooth functioning of the smartphone. The internal storage is 64 GB and 128 GB.
The smartphone comes in different colors, Black, and Blue which gives the user a new sleek and fancy look. The device also handles dual Nano SIM card.
Specificaties Xiaomi Redmi K20 (Pro)
OS:Android 9.0 (Pie); MIUI 10
Dimensions:156.7 x 74.3 x 8.8 mm
Weight:191 g
SIM:Dual SIM (Nano-SIM, dual stand-by)
Display type:Super AMOLED capacitive touchscreen, 16M colors
Display Size:6.39 inches, 100.2 cm2 (~86.1% screen-to-body ratio)
Display Resolution:1080 x 2340 pixels, 19.5:9 ratio (~403 ppi density)
Display Protection:Corning Gorilla Glass 5
Chipset: Pro: Qualcomm SDM855 Snapdragon 855 (7 nm)
Chipset: Non-Pro: Qualcomm SDM730 Snapdragon 730 (8 nm)
CPU: Pro: Octa-core (1x2.84 GHz Kryo 485 & 3x2.42 GHz Kryo 485 & 4x1.8 GHz Kryo 485)
CPU: Non Pro: Octa-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver)
GPU: Pro Adreno 640
GPU: Non-Pro Adreno 618
SD card:No
Internal Memory256 GB, 8 GB RAM or 128 GB, 6/8 GB RAM or 64 GB, 6 GB RAM
Camera Wide:48 MP, f/1.8, 26mm (wide), 1/2", 0.8µm, Laser/PDAF
Camera Telephoto:8 MP, f/2.4, 53mm (telephoto), 1/4", 1.12µm, Laser/PDAF, 2x optical zoom
Camera Ultrawide:13 MP, f/2.4, 12mm (ultrawide), 1/3", 1.12µm
Camera Features:Dual-LED flash, HDR, panorama
Video:Pro: 2160p@30/60fps, 1080p@30/120/240fps, 1080p@960fps
Video:Non-Pro: 2160p@30fps, 1080p@30/120/240fps, 1080p@960fps
Selfie Camera:Motorized pop-up 20 MP, f/2.2, 0.8µm
Selfie Video:1080p@30fps
3.5mm jack:Yes
Sound Features:24-bit/192kHz audio, Active noise cancellation with dedicated mic
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth:5.0, A2DP, LE, aptX HD
GPS:Yes, with dual-band A-GPS, GLONASS, BDS, GALILEO
NFC:Yes
RadioYes
USB2.0, Type-C 1.0 reversible connector, USB On-The-Go
SensorsFingerprint (under display), accelerometer, gyro, proximity, compass
BatteryNon-removable Li-Po 4000 mAh battery
ChargingPro: Fast battery charging 27W (Quick Charge 4+)
ChargingNon-Pro: Fast battery charging 18W
ColorsCarbon black, Flame red, Glacier blue
Price Pro +/- 400 EUR
PriceNon-Pro +/- 300 EUR
Photo's
Afbeeldingslocatie: https://i.postimg.cc/Y00R0cJz/xiaomi-redmi-k20pro-5.jpg
Afbeeldingslocatie: https://i.postimg.cc/851t8f43/xiaomi-redmi-k20pro-6.jpg
Videos
Video Test:
Unboxing & Review:
Xiaomi Mi 9T Pro Water Test:
Redmi K20 Pro Teardown:
Relevante topics
[Xiaomi Mi 9T / Redmi K20 (Pro)] Prijzen en Levertijden
Xiaomi Mi 9T / Redmi K20 (PRO) Accessoires
[Xiaomi Mi 9] Rooten & Custom ROM's]
Debloaten zonder Root?
Dat kan met XiaomiADBFastbootTools
Check voor het gemak ook deze video: adb fastboot Xiaomi debloat tutorial
Hoe schakel ik NFC in?
NFC inschakelen:
Settings > More > NFC aan > Secure element position > HCE Wallet
Manage apps > "Jouw Banking App" > Autostart = On
Manage apps > "Jouw Banking App" > App permissions > Alles aan
Manage apps > "Jouw Banking App" > Other permissions > Alles aan
Manage apps > "Jouw Banking App" > Battery saver = No restrictions
Additional settings > Privacy, Battery optimization > "Jouw Banking App" > Don't optimize.
Hoe zorg ik ervoor dat notificaties op mijn smartwatch worden getoond?
Open de app info van jouw smartwatch app en zorg ervoor dat de volgende settings goed staan:
- Autostart: enabled
- App permission: alles enabled
- Other permissions: alles enabled
- Battery saver: NO RESTRICTIONs
- Developer options: Bluetooth AVRCP version 1.6
- Additional settings > privacy> special app permission > notification settings > "jouw smartwatch app (Enabled)
Chatten over de Xiaomi Mi 9T / Redmi K20 (Pro)
Voor het ongestoord discussieren over de Xiaomi Mi 9T / Redmi K20 (Pro) kun je terecht in de discord: https://discord.gg/cuavtf9
Versiebeheer
- 04.06.2019 - Topic aangemaakt. Tot mijn verbazing was er nog geen topic aangemaakt voor de Redmi K20 Pro. Gezien ik in October mijn huidige phone wil gaan vervangen en dit een van de kanshebbers is leek het me handig om dit topic alvast aan te maken.
- 17.06.2019 - Topic Change (Xiaomi 9T aan Titel toegevoegd) en toevoeging link naar Prijzen en Levertijden topic. Met dank aan l3art
- 21.06.2019 - Link naar de discord toegevoegd
- 29.07.2019 - Link naar de MI 9 Rooten & Custom ROM's toegevoegd
- 04.11.2019 - instructies voor notificaties smartwatch toegevoegd
[ Voor 20% gewijzigd door sunturion op 04-11-2019 20:18 ]
In the name of God, impure souls of the living dead shall be banished into eternal damnation. Amen.
  • HansH
  • Laatst online: 22-11 11:46
Zal zeer wrs in Europa als de Mi 9t (Pro) worden uitgebracht.
Dit toestel houd ik in de gaten als vervanger voor m'n Oneplus 3.
  • sunturion
Het is zeker een interessant toestel. Ik heb de geruchten ook gelezen dat hij mogelijk in Europa als de Mi 9T gereleased zal worden . Verder zijn er al langer geruchten dat het mogelijk ook een Poco F2 label gaat krijgen. Tijd zal het zeggen.
Ik hoop eigenlijk dat de Poco F2 een goedkopere versie wordt van de K20 Pro met plastic ipv glass body en een sdcard slot. Dan kan de prijs nog wat omlaag
  • Edzeau
  • Laatst online: 20-11 19:40
Op Facebook kwam ik deze telefoon tegen als het "goedkope alternatief" voor de OnePlus 7 Pro. Nu ben ik best fan van de OnePlus toestellen, uiteraard eerder vanwege de prijs, maar ook voornamelijk vanwege de software die op hun toestellen staat. Wat is precies de ervaring met de Xiaomi schil om Android heen? Zijn er veel voor- en nadelen t.o.v. de OnePlus schil?
  • ChinaGeek
  • Registratie: Oktober 2017
  • Laatst online: 17-05-2021
Edzeau schreef op dinsdag 4 juni 2019 @ 11:59:
OnePlus is bijna stock Android en MIUI allesbehalve.
Er zit absoluut veel verschil in.
Maar alles went en gezien het prijsverschil zou dat wat mij betreft geen rol mogen spelen.
  • xeoMe
  • Laatst online: 19-10 13:49
Veel mensen zijn toch te spreken over MIUI en met de huidige hardware die aanwezig is zal het niet zo snel traag zijn.
Zat eerst te kijken naar de Oneplus 7 Pro ter vervanging voor mijn Oneplus 5T maar deze ziet er ook erg goed uit en zeker voor de prijs.
Nog even wachten op de beschikbaarheid en de uitgebreide reviews.
  • RoD
RoD
Admin Mobile & FP PowerMod
sunturion schreef op dinsdag 4 juni 2019 @ 11:12:
Volgens de geruchten wordt de Poco F2 de versie die in India uitkomt maar blijft ie hoe dan ook gebaseerd op de K20. Ik denk daarom dat het bij de Mi 9T en Mi 9T Pro blijft.
Hoe dan ook, ik ben erg benieuwd naar 12 juni :)
  • Mirr0r
  • Laatst online: 09-09-2024
Ook ik ga de mi 9T pro bestellen.
Nog even afwachten naar de prijzen omdat deze niet gelijk zullen zijn aan de k20pro ben ik bang.
Liefst wil ik de 8/128 black carbon variant 😍
  • NeWSJuNK
  • Laatst online: 26-11 11:33
De Mi9 T krijgt de SD 730. Lijkt toch een kleine downgrade tov de Mi9.
  • Vitruvian
  • Laatst online: 17-09 11:02
Wow, I don't believe!
Mirr0r schreef op dinsdag 4 juni 2019 @ 20:02:
Er komt geen Mi 9T pro. Alleen de gewone variant. Dan was die zoals de Xiaomi Mi 9T allang uitgelekt. Zie deze post op reddit.
https://www.reddit.com/r/...xiaomi_store_in_paris_no/
En dan koopt niemand meer de Xiaomi Mi 9.
Dus er komt alleen een Xiaomi Mi 9T met dezelfde specs zoals de Redmi K20 non pro.
[ Voor 11% gewijzigd door Verwijderd op 06-06-2019 17:35 ]
  • Ruiten_Wisser
  • Registratie: Maart 2018
  • Laatst online: 18:46
Mijn hype was met de review van TechTablets.com een beetje weggeëbd... -O-
Edit: Chinese variant
Maar gelukkig kwam hij met een update :)
[ Voor 10% gewijzigd door Ruiten_Wisser op 06-06-2019 22:31 ]
Mi 9T Pro • Soundcore Space One • CCwGTV 4K • Soundcore Motion+ • TCL 65C81K
Jammer dat deze variant niet gaat uitkomen in Nederland de Mi 9T pro. Alleen de K20 variant met Snapdragon 730.
Och, als je weinig gaat gamen op je telefoon is de K20 ( Mi 9T) ook al prima smartphone ;)
  • Spollie
  • Laatst online: 23:30
Wat nou als ik een Redmi K20 Pro in China bestel, is deze dan bruikbaar op de Nederlandse netwerken? Enige nadeel is dat de ROM slechts tweetalig lijkt te zijn (Engels / Chinees), maar ik heb m'n OS sowieso liever in het Engels. Zijn er verder nog nadelen, buiten de misschien wat onhandige garantieafhandeling?
robpol schreef op vrijdag 7 juni 2019 @ 08:30:
Ja, geen Band 20 LTE. Dat is een heel groot probleem in NL ;)
  • Spollie
Afbeeldingslocatie: https://i.imgur.com/PXciG1E.png
Ik zit bij T-Mobile, en die lijkt hij wel allemaal te ondersteunen. Of heeft T-Mobile wel plannen om B20 te gaan gebruiken?
[ Voor 4% gewijzigd door Spollie op 07-06-2019 08:45 ]
  • ChinaGeek
robpol schreef op vrijdag 7 juni 2019 @ 08:45:
Nee die plannen hebben ze niet.
Heb jij plannen om over te stappen?
  • Spollie
ChinaGeek schreef op vrijdag 7 juni 2019 @ 09:24:
Nope, ik ben juist net overgestapt van Vodafone naar T-mobile met een 2-jarig contract. Is in combinatie met T-mobile Thuis veruit de beste deal. Dus wat dat betreft zit ik voorlopig nog wel goed. Misschien moet ik de gok maar gewoon wagen :P
[ Voor 7% gewijzigd door Spollie op 07-06-2019 09:47 ]
  • Mirr0r
Ik wil toch denk ik wel perse een Pro.
Dus het wordt of overwegen om over te stappen naar T-Mobile of ik wacht nog even omdat er geruchten rondgaan dat de Poco F2 de Pro variant gaat worden.
Het is dus een kwestie van even afwachten allemaal :)
Mirr0r schreef op vrijdag 7 juni 2019 @ 11:30:
En wat mis je aan de Xiaomi Mi 9 als ik vragen mag?
  • Spollie
Verwijderd schreef op vrijdag 7 juni 2019 @ 11:36:
Voor mij is de kleine accu eigenlijk de enige reden om geen Xiaomi Mi 9 te nemen. Ik struggle nu al jaren met mijn Huawei Nexus 6P die ook een kleine accu heeft, dus ik wil in mijn volgende telefoon per se een wat grotere accu.
[ Voor 22% gewijzigd door Spollie op 07-06-2019 11:47 ]
robpol schreef op vrijdag 7 juni 2019 @ 11:46:
Maar de batterij is gewoon best wel aardig hoor. Zie review GSMarena. Niks mis mee https://www.gsmarena.com/xiaomi_mi_9-review-1891p3.php
  • Mirr0r
O.a. Batterij en 3.5MM jack. En een full display zonder notch maakt het wel heel mooi.
EDIT: Ook heeft deze een nieuwere generatie in display fingerprint sensor die het beter moet doen als die van de MI 9.
Natuurlijk is het nog wel overwegen tegenover de meerprijs t.o.v. MI 9. Maar ik zal pas een aanschaf doen met de aankomende salaris. Dus nog ff 2 weekjes wachten.
[ Voor 35% gewijzigd door Mirr0r op 07-06-2019 12:03 ]
Mirr0r schreef op vrijdag 7 juni 2019 @ 12:00:
Let wel op, er komt alleen een K20 variant met Snapdragon 730. Er komt geen Mi 9T pro.
Dus als je de Snapdragon 730 geen probleem vindt....
  • ChinaGeek
Verwijderd schreef op vrijdag 7 juni 2019 @ 12:05:
Of als je het gemis van B20 geen probleem vindt, dan kan je de K20 pro gewoon aanschaffen.
Die is er wel namelijk.
  • Mirr0r
Ik wil hoe dan ook de SD855 :)
Het is nog niet zeker of er geen Pro komt of niet! Er gaan ook weer geruchten rond dat de Poco F2 de K20Pro wordt.
Het is dus eerst alle geruchten afwachten :D En dan wordt het anders waarschijnlijk een K20 Pro i.c.m. T-mobile.
Mirr0r schreef op vrijdag 7 juni 2019 @ 12:12:
Als volgende week de K20 pro niet wordt aangekondigd, ben ik bang dat het nog maanden gaat duren eer de Mi 9T pro komt ;)
  • ChinaGeek
Verwijderd schreef op vrijdag 7 juni 2019 @ 12:13:
Als volgende week de K20 pro niet wordt aangekondigd, ben ik bang dat het nog maanden gaat duren eer de K20 pro komt ;)
De K20 pro is allang aangekondigd.
  • sunturion
Dat klopt niet. De Pro variant komt er wel degelijk. Zie ook dit artikel op GizmoChina
ChinaGeek schreef op vrijdag 7 juni 2019 @ 12:19:
Aangepast ;)
sunturion schreef op vrijdag 7 juni 2019 @ 12:26:
We zien het volgende week ;)
  • ChinaGeek
  • Celica_T20
  • Laatst online: 17-11 09:56
https://www.gsmarena.com/...ed_k20_pro-news-37449.php
Lijkt toch wel een mi 9t pro te komen
  • ChinaGeek
Verwijderd schreef op vrijdag 7 juni 2019 @ 12:44:
Lees deze post eens, https://www.reddit.com/r/...ro_appeared_on_geekbench/ is heel makkelijk geekbench te foppen ;)
Waarom heb je het continu over de K20 pro waar je de Mi9T pro bedoelt?
  • sunturion
Ruiten_Wisser schreef op donderdag 6 juni 2019 @ 22:03:
[YouTube: Redmi K20 Pro Unboxing & Review - Value Flagship King!]
[YouTube: Redmi K20 Pro - Battery life update, FAQ, Notifications & Face Unlocking]
Goede review. Even een samenvatting van de minpunten
- Geen ondersteuning voor band 20
- WiFi 5G connectie issues
- Soms UI stotter
- Geen Widevine L1 support
- Geen EIS voor front camera
- EIS jitter bij back camera
- Microphone audio is slecht
  • Vitruvian
Belsimpel geeft wel aan dat de Xiaomi Mi 9T Pro 64GB Black binnekort wordt verwacht. :)
https://www.belsimpel.nl/xiaomi-mi-9t-pro/64gb-zwart
  • Riziko
  • Laatst online: 31-10-2024
Vitruvian schreef op zaterdag 8 juni 2019 @ 14:51:
Tjah met die 64GB en niet uitbreidbaar geheugen wordt het toch echt een No Go!! Met minimaal 128GB was ik denk ik overstag gegaan...
  • 13art
  • Laatst online: 14:52
13art
Moderator Mobile
Riziko schreef op zaterdag 8 juni 2019 @ 15:37:
Kan bijna niet anders dan dat die er ook gaat komen.
Enjoy the silence...
Er komt toch ook een variatie aan RAM geheugens en opslag? 6 of 8GB, 64/128/256GB..
Ze weten niet eens of hij gaat komen. Mijn bronnen weten alleen van de niet-pro, en dat is waarschijnlijk ook de bron van Belsimpel. Ik weet ook dat dit al een tijdje op hun pagina's staat, terwijl Xiaomi Rusland het maar net "bevestigd" heeft.
https://www.reddit.com/r/...irmed_that_the_mi_9t_pro/
[ Voor 4% gewijzigd door Verwijderd op 08-06-2019 21:25 ]
  • 13art
13art
Moderator Mobile
Verwijderd schreef op zaterdag 8 juni 2019 @ 21:24:
Maar waarom zou belsimpel hem op de website zetten en er bij zetten 'binnenkort verwacht' als ze niet eens weten of hij gaat komen? Zou ik een vreemde actie vinden.
[ Voor 3% gewijzigd door 13art op 08-06-2019 21:27 ]
l3art schreef op zaterdag 8 juni 2019 @ 21:26:
Omdat de verwachting is dat hij wel is gaat komen, maar het is nog niet daadwerkelijk bevestigd door Xiaomi. Ze willen op deze manier verkeer trekken. Als je vroeg een pagina aanmaakt hiervoor ga je hoger ranken op Mi9T Pro in Google.
[ Voor 13% gewijzigd door Verwijderd op 08-06-2019 22:08 ]
  • sjoerdkoolen
  • Laatst online: 26-01-2021
Ik zit bij KPN maar zie dat maar 1 4g frequentie wordt ondersteund. Hoe goed/slecht gaat deze telefoon werken?
https://www.kimovil.com/e...ecker/NL/xiaomi-redmi-k20
  • ninasky11
  • Laatst online: 01-11 18:50
sjoerdkoolen schreef op zondag 9 juni 2019 @ 22:45:
Heb ook KPN en Mi6 zonder band20. In grote steden altijd 4G zonder problemen, in mijn Dorp gemixt 4G/3G en binnen in het huis 3G. Maar ligt ook puur aan het dekking van KPN in jouw woonplaats denk ik.
  • Gerard4
  • Registratie: Juli 2015
  • Laatst online: 23-05 20:38
Is er veel verschil tussen energieverbruik van de sd 855 en de sd 730?
Is er een site waar dit allemaal te vinden is? Ik kan er niet veel over vinden.
  • 13art
13art
Moderator Mobile
Gerard4 schreef op maandag 10 juni 2019 @ 10:15:
Ja, de 730 is zuiniger. Op YouTube staan wat filmpjes die dit vergelijken. 730 haalt ongeveer 2 uur extra sot (afhankelijk van de test natuurlijk).
  • Gerard4
l3art schreef op maandag 10 juni 2019 @ 10:25:
Dat maakt mn keuze en stuk eenvoudiger. De mi9t is dan wel echt heel erg wat ik wil met Amoled en nfc.
De gewone K20 boet echt vrij weinig in ten opzichte van K20 pro. Alleen iets mindere hoofdcamera en wat mindere GPU.
Ben benieuwd woensdag naar de Xiaomi Mi 9T!
  • 13art
13art
Moderator Mobile
Verwijderd schreef op maandag 10 juni 2019 @ 15:35:
Waarbij het enige verschil met de camera zou zijn 60fps vs 30fps 4K en slow motion in een lagere resolutie. Wat betreft fotografie zijn de specs precies hetzelfde.
  • Mole
  • Laatst online: 23:00
Mi9t Pro staat nu ook op de Belsimpel site:
Edit: Note to self, lees het topic even door voor je iets plaatst.
[ Voor 26% gewijzigd door Mole op 10-06-2019 20:36 ]
Is al naar voren gekomen, is om clicks te genereren. Die M9t pro komt pas eind dit jaar is de verwachting. Alleen de Mi9t woensdag 12 juni wordt gepresenteerd.
  • Mole
Verwijderd schreef op maandag 10 juni 2019 @ 18:58:
Treurig...
Heb zelf nog 2 weken bedenktijd op mijn mi 9, ben benieuwd wat woensdag brengt (vooral benieuwd naar de prijs).
  • Gerard4
Nou, de sd 855 is toch wel behoorlijk sneller dan de 730. Al vraag ik me af wat je er - behalve gaming- wezenlijk van merkt.
Gerard4 schreef op maandag 10 juni 2019 @ 20:59:
Buiten gaming vrij weinig. Snapdragon 730 is vrij krachtige soc hoor: https://www.qualcomm.com/...g-and-industry-leading-ai
  • NeWSJuNK
Mole schreef op maandag 10 juni 2019 @ 20:13:
Treurig...
Heb je net de Mi9 aangeschaft?
  • jelleeelco
  • Laatst online: 26-11 08:07
Ik ga zaterdag naar China (voor werk) en ben van plan langs de Xiaomi store te gaan in Shanghai. Ik heb nu de Oneplus 6 (256gb) en echt geen enkele reden om te upgraden, maar ga toch eens kijken of ik de K20 Pro wat vind!
  • Bladspinazie
  • Registratie: Februari 2018
  • Laatst online: 26-11-2023
Ben nu toch wel heel benieuwd naar de presentatie morgen. Zou het toch wel jammer vinden als er geen Pro versie in europa uit komt. helemaal als wij de zelfde prijs mogen gaan betalen voor een non pro waar je in china een pro versie voor hebt. Als er toch geen pro versie uitkomt wat wordt dan de nieuwe flagship killer van het moment?
  • ChinaGeek
In China eet je een 5 gangen diner waar je hier alleen het toetje voor hebt.
Beetje scheve vergelijking.
  • jelleeelco
Inderdaad. K20 Pro versie (256gb) is in China EUR 385,- ... da's toch echt een laag bedrag voor een SD855
Enige wat ik echt jammer vind is die Widevine L1...
Bladspinazie schreef op dinsdag 11 juni 2019 @ 13:11:
De Snapdragon is echt heel powerful, de K20 dus de Mi 9T wordt echt een prima telefoon. Als je gamet veel op je telefoon is het wat anders. Game je veel?
  • Mole
NeWSJuNK schreef op dinsdag 11 juni 2019 @ 06:50:
Ja, maar nog niet in gebruik. Wacht morgen even af.
  • jelleeelco
Verwijderd schreef op dinsdag 11 juni 2019 @ 15:11:
Is die 730 powerful bedoel je? Ik game niet bijzonder veel, maar een spelletje PUBG vind ik altijd wel geinig.. kan ook prima op de huidige OnePlus 6 (speel eigenlijk alleen op iPad pro..)
Hoe verhoudt die 730 zich tot de SD 845, enig idee?
EDIT: Net gekeken op de Chinese Xiaomi site. Verschil tussen de K20 en K20 Pro (beiden 8GB en 256gb) is slechts EUR 50,-...
[ Voor 15% gewijzigd door jelleeelco op 11-06-2019 16:03 ]
  • ninasky11
Afbeeldingslocatie: http://i67.tinypic.com/2ypnnmq.png
Wel aan de dure kant, niet? 😅😅😅
  • Bladspinazie
ik zou gewoon de snelste processor in mijn telefoon willen hebben, toch snap ik helemaal niks van de visie van xiaomi, dezelfde telefoon 3 verschillende namen geven allemaal op een ander tijdstip uit laten komen en verwarring veroorzaken. als ze nu gewoon de poco f2 hadden gelanceerd wereldwijd was het allemaal wat makkelijker geweest.
  • taz3d_nl
  • Laatst online: 25-02 12:08
ninasky11 schreef op dinsdag 11 juni 2019 @ 17:22:
Is al aangepast.
364 euro
Mooie prijs voor die specs
Ben benieuwd wat de 128gb versie gaat kosten. :)
  • liter
  • Laatst online: 22-08 21:23
Ik ook! Maar dit is al een mooi prijsje. Alleen staat er niet bij welke band wordt ondersteund.
Ook zit er geen cover bij volgens de site. Maar die kan je op Ali scoren uiteraard.
[ Voor 49% gewijzigd door liter op 11-06-2019 18:45 ]
  • jeroentje93
  • Laatst online: 11-11 17:38
liter schreef op dinsdag 11 juni 2019 @ 18:44:
Staat wel frequenties bij (uitgebreide specs) ;)
Wifi 802.11a, 802.11ac, 802.11b, 802.11g, 802.11n
Frequenties 800, 850, 900, 1800, 1900, 2100, 2600
Contact opgenomen met Belsimpel, ze verwachten een gewone Xiaomi Mi 9 T en de specs kloppen dus niet bij het plaatje. Is de gewone Mi 9T.
Ze gaan de K20 pro verkopen en niet de Mi 9T pro. Met grijze import dus en zonder band 20 support. Jongen wist er veel van en zag de Mi 9T wel al in systeem met Snapdragon 730 soc :) Prijs van €369 wat je ziet is dus de Mi 9T.
Dus resume, K20 pro gaan ze verkopen met Snapdragon 855 maar geen band 20 support.
En de Xiaomi Mi 9T met Snapdragon 770 chip aangezien er komende maand geen Mi 9T pro komt ;)
[ Voor 3% gewijzigd door Verwijderd op 11-06-2019 19:54 ]
  • CLB
CLB
Dat is KS heh, klinkt leuk, maar die zijn zeker niet alwetend.
CLB schreef op dinsdag 11 juni 2019 @ 19:57:
Nu nog eens aan het bellen, hou jullie op de hoogte.
  • 13art
13art
Moderator Mobile
jelleeelco schreef op dinsdag 11 juni 2019 @ 15:01:
De Mi 9T schijnt dan wel weer L1 te hebben. Zag een video van de Mi 9T op YouTube waarbij de reviewer dit toonde.
  • LukasW
  • Laatst online: 15:53
Heb hem maar besteld. Zie vanzelf wel of ze hem kunnen leveren of niet (al had ik liever een 8/128GB gehad, maar deze prijs leek me te mooi om het niet te proberen).
[ Voor 39% gewijzigd door LukasW op 11-06-2019 20:08 ]
  • Kuzomu
  • Registratie: November 2015
  • Laatst online: 17-11 01:28
Toch hoop ik nog op de 9T Pro/K20 Pro met Band 20 in europa. Wil best tot 500 neerleggen voor de 6GB/128GB versie. Heb zojuist deze besteld voor 364 maar betwijfel of die geleverd gaat worden inderdaad.
Toen ik aan de lijn was met Belsimpel kon de mevrouw mij niet veel zinnigs vertellen. We gaan het zien.
Nou update.
Belsimpel kreeg veel telefoontjes ( van Tweakers denk ik hehe) over de Mi 9T pro. Ze (klantenservice medewerker) gaf nogmaals aan dat de specs gewijzigd konden worden ook na bestelling. Dit vind ik echt klanten beduvelen maar wie ben ik maar tenslotte hehe.
Ze gaf nogmaals aan dat er echt een mindere processor in kan komen en dat de presentatie morgen moet worden afgewacht.
Heel aparte werkwijze belsimpel.
Iemand die weet hoe laat de persconferentie is?
Zie ook dat door alle telefoontjes het is aangepast na binnenkort leverbaar en je kunt hem niet meer bestellen. Foei Belsimpel!
[ Voor 15% gewijzigd door Verwijderd op 11-06-2019 20:19 ]
  • wavepressure
  • Registratie: December 2015
  • Laatst online: 18-10-2024
Zouden jullie een mindere processor op de koop toenemen wanneer deze de accuduur verlengt? Ik heb meerdere comparisons op Youtube gezien waaruit blijkt dat de K20/Mi 9T minder energie verbruikt dan de K20/Mi 9T Pro-versie. Ik denk dat de non-pro versie mijn dagelijks gebruik makkelijk aankan. (voornamelijk veel multitasken, social media, netflix etc.)
Wat denken jullie?
  • LukasW
Verwijderd schreef op dinsdag 11 juni 2019 @ 20:16:
Lijkt me sterk dat ze je zomaar iets anders gaan leveren dan wat je besteld hebt, dan zullen ze gewoon annuleren.
Zie hier 11:30 CET overigens, wat volgens mij 12:30 onze tijd zou zijn: https://www.techadvisor.c...one/xiaomi-mi-9t-3697469/
Edit: Xiaomi Italië gaat om 16:00 live: https://www.facebook.com/...=mo&s=100003774566544&w=y
Edit2: Volgens het inschrijfformulier voor Parijs begint het evenement daar om 13:30:
https://docs.google.com/f...tAcxTHmuXj0raSgA/viewform
Zijn evenementen in Milaan, Parijs en Madrid. Geen idee of die overal op dezelfde tijd zouden moeten zijn.
[ Voor 31% gewijzigd door LukasW op 11-06-2019 21:02 ]
  • 13art
13art
Moderator Mobile
wavepressure schreef op dinsdag 11 juni 2019 @ 20:38:
Wat denken jullie?
Precies ook mijn overweging.
De enige verschillen met de pro lijken te zijn:
- minder krachtige maar zuinigere processor
- geen laser autofocus
- geen 60 maar 30fps 4K
- minder goede haptic feedback.
Ik heb nu ook geen laser autofocus op mijn 5T dus denk niet dat ik dat ga missen. 4K filmen doe ik ook nooit, en als ik film gebruik ik de beelden ook nooit in het maken van een film ofzo. Haptic feedback schakel ik altijd uit. Kortom ik zie niet heel veel redenen om voor de eventuele Pro versie te gaan.
LukasW schreef op dinsdag 11 juni 2019 @ 20:39:
Lijkt mij ook niet. Anders kan iedere gek van alles gaan verkopen en nadien de specs aanpassen en er mee weg komen. Daarmee zou fraude wel heel makkelijk gemaakt worden. Terwijl hier juist de koper goed beschermd is bij online aankopen.
[ Voor 23% gewijzigd door 13art op 11-06-2019 20:56 ]
Wat denken jullie?
Zolang je niet gaat gamen en 60 FPS 4K niet zo belangrijk vindt is de Mi 9T uitstekend _/-\o_
Hier nog goede filmpje van de K20 ( Xiaomi mi 9T) YouTube: REDMI K20 (NON PRO) - UNBOXING & FIRST LOOK! WOW AGAIN!
[ Voor 12% gewijzigd door Verwijderd op 11-06-2019 21:07 ]
  • Bladspinazie
Er zijn trouwens zat filmpjes op YouTube uit Italië Frankrijk en Spanje waarbij ze de mi 9t unboxen en laten zien !
Bladspinazie schreef op dinsdag 11 juni 2019 @ 21:26:
Links??
  • 13art
13art
Moderator Mobile
En daar is de eerste vergelijking van de K20 met de standaard camera app en de gcam app.
YouTube: Redmi K20 Pro GCam Vs Stock Camera Comparison
Voor foto's is gcam meestal de beste optie.
Video is wat mij betreft de stock app nog de winnaar. Nu alleen die audio bitrate nog wat omhoog. Komt vast een mod voor (was er al, met wisselend succes) voor de mi 9.
[ Voor 36% gewijzigd door 13art op 11-06-2019 21:37 ]
  • Bladspinazie
je moet gewoon even op youtube zoeken naar mi 9t.
YouTube: Recensione XIAOMI Mi9t e confronto REDMI K20pro
hier bijvoorbeeld eentje die de chinese k20 vergelijkt met de europese
Hier nog een goede preview gevonden van de Xiaomi Mi 9T YouTube: Xiaomi Mi 9T(Redmi K20) - DEFINITELY WORTH THE WAIT!!!
  • PaT
PaT
Moderator Mobile
Ja, dat mod
l3art schreef op dinsdag 11 juni 2019 @ 20:42:
Je zet mij nu wel aan het denken. Ik had mijn zinnen op een pro gezet, maar als je jouw rijtje zo bekijkt is een non-pro inderdaad de verstandige keuze.
We zullen het morgen gaan beleven!
PaT schreef op dinsdag 11 juni 2019 @ 23:07:
Als je niet veel spelletjes speelt dan is de non pro echt een super deal inderdaad!
  • 13art
13art
Moderator Mobile
Verwijderd schreef op dinsdag 11 juni 2019 @ 23:30:
Maar ook met spelletjes kan de 730 prima zijn mannetje staan. Als ik me niet vergis gezien op YouTube dat daar met de 730 pubg werd gespeeld. Ging prima.
  • HansH
Ik heb de Mi 9t (non pro) gekozen. Speel geen spelletjes op mijn telefoon, met name de camera en accuduur is voor mij belangrijk.
Qua camera zou hij met name met 4k video-opnames minder zijn dan de Pro, dit ga ik niet gebruiken. Fotokwaliteit zou (nagenoeg) gelijk zijn. Accuduur zou de non-Pro een streepje voor hebben op de Pro vanwege de Snapdragon 730 t.o.v de 855.
Ben benieuwd, krijg de telefoon als het goed is vanmiddag binnen (via Honorbuy). :9
HansH schreef op woensdag 12 juni 2019 @ 07:39:
Wat, zo snel al? :P Is dat niet gewoon een Redmi K20 met geflashte rom stiekem :X ?
  • HansH
Verwijderd schreef op woensdag 12 juni 2019 @ 09:23:
Haha. Dat heb ik me ook afgevraagd, maar wat ze tonen op de productpagina ziet er legitiem uit (foto's van het toestel en band 20 als ondersteunde frequentie in de specs). Dat ontkracht het in ieder geval.
Blijkt het anders te zijn, dan gaat het toestel terug. :)
Voor de geïnteresseerden: Mi 9t op Honorbuy.
  • 13art
13art
Moderator Mobile
HansH schreef op woensdag 12 juni 2019 @ 09:37:
Ben vooral benieuwd naar wat de prijs gaat worden. Al is die 360 euro bij honorbuy niet slecht.
l3art schreef op woensdag 12 juni 2019 @ 09:45:
Komt nog €25 verzendkosten bij ;)
Hier een batterij vergelijk tussen de K20 (mi 9t) en de rest van de Android smartphone toppers anno 2019. De K20 is een batterij topper!!!
YouTube: Redmi K20 vs K20 Pro, OnePlus 7 Pro, Xiaomi Mi 9, P30 Pro BATTERY DR...
[ Voor 41% gewijzigd door Verwijderd op 12-06-2019 11:03 ]
Hou ons op de hoogte ;)
Pssst, volgende keer je vorige post even wijzigen ipv meerdere berichten onder elkaar te posten... (y)
[ Voor 9% gewijzigd door 13art op 12-06-2019 10:16 ]
  • MelleJ
  • Registratie: Februari 2016
  • Laatst online: 23-11 13:09
Gisteren de Xiaomi Mi 9T Pro 64GB/6GB RAM besteld via een Nederlandse retailer maar helaas zojuist geannuleerd. Jammer, was een mooie prijs! Ben benieuwd wat het gaat worden.
  • mahsalti
  • Laatst online: 14-10 22:42
MelleJ schreef op woensdag 12 juni 2019 @ 11:53:
Wat was de prijs? is er ergens de 128GB of 256GB versie beschikbaar? heb alleen belsimpel gezien die iets aanbied maar nog geen prijzen etc.
Zeg gewoon Belsimpel ;)
Over 5 uur weten we of er vandaag een Xiaomi Mi 9T pro wordt aangekondigt :)
  • MelleJ
Nouja, ik vraag me het dus af aangezien zij hem expliciet annuleren nu.
"Gisteren heb je via onze website een bestelling geplaatst voor een Xiaomi Mi 9T Pro 64GB Black. Het was door een technische fout gisteren mogelijk om deze bestelling te plaatsen. Het toestel is op dit moment nog niet leverbaar en is dus ook nog niet te bestellen bij Belsimpel. De informatie die gisteren op onze website stond was dus onjuist. Onze excuses voor het ongemak!"
Vraag me eigenlijk af hoe het zit mocht hij dus dadelijk wel bestelbaar zijn maar voor een stuk hogere prijs. Theoretisch gezien annuleren zij dan een bestelling omdat hij niet leverbaar is maar is hij een paar uur later wel leverbaar maar voor een compleet andere prijs. Prijs was €364,- voor de 64GB / 6GB RAM versie dus.
Edit: Ook voor mij, lees eerst het topic door voordat je informatie gaat spuwen :P
[ Voor 5% gewijzigd door MelleJ op 12-06-2019 12:26 ]
MelleJ schreef op woensdag 12 juni 2019 @ 12:24:
Is ook omdat de verwachting is dat er pas over enkele maanden een Xiaomi Mi 9T pro komt. Dit maakt het vermoeden alleen maar groter :) ;)
Pagina: 1 2 ... 53 Laatste
Voor prijzen en levertijden: [Xiaomi Mi 9T / Redmi K20 (Pro)] Prijzen en Levertijden
Voor accessoires: [Xiaomi Mi 9T / Redmi K20 (Pro)] Accessoires
Voor rooten en custom roms van de 9T/K20 [Xiaomi Mi 9T / Redmi K20] Rooten & Custom roms
Voor rooten en custom roms van de 9T Pro / K20 Pro: [Xiaomi Mi 9T Pro / Redmi K20 Pro] Rooten & Custom roms
