Cookies op Tweakers
Tweakers maakt gebruik van cookies, onder andere om de website te analyseren, het gebruiksgemak te vergroten en advertenties te tonen. Door gebruik te maken van deze website, of door op 'Ga verder' te klikken, geef je toestemming voor het gebruik van cookies. Wil je meer informatie over cookies en hoe ze worden gebruikt, bekijk dan ons cookiebeleid.
Meer informatie
  • +14Henk 'm!
  • sunturion
  • Registratie: december 2000
  • Laatst online: 00:46
Xiaomi Mi 9T / Redmi K20 (Pro)
Redmi is a sub-brand owned by the Chinese electronics company Xiaomi. It was introduced as a budget smartphone line manufactured by Xiaomi, that was first announced in July 2013. It became a sub-brand, separated from Xiaomi, on 10 January 2019. Redmi phones use the Xiaomi MIUI user interface on top of Android
Xiaomi Redmi K20 Pro was launched by Xiaomi in the first week of June 2019. The Xiaomi Redmi is the first phone of the company to release 48 megapixels dual camera.
The smartphone has a different Sony IMX 586 sensor for the dual camera. The design of the smartphone is slim along with a combining high performance and mobility.
The minimalist design is in continuity by Xiaomi Redmi K20 Pro, as they have adopted a new process to manufacture. The body is made out of Plastic which is great for stability and fashion as well.
The display type is IPS and the size is 6.39 inches full HD screen which gives a resolution of 1080 x 2340 pixels. The pixel density is 409 PPI (pixels per inch) and the display is protected by Corning Gorilla Glass 5 and a 2.5D curved glass screen.
The smartphone is equipped with Qualcomm Snapdragon 855 chipset and 1x 2.84 GHz Kryo 485, 3x 2.42 GHz Kryo 485, 4x 1.8 GHz Kryo 485 processor.
The internal storage comes with a 6 GB RAM that supports MIUI V10 (Android 8.1 Oreo) operating system for the smooth functioning of the smartphone. The internal storage is 64 GB and 128 GB.
The smartphone comes in different colors, Black, and Blue which gives the user a new sleek and fancy look. The device also handles dual Nano SIM card.
Specificaties Xiaomi Redmi K20 (Pro)
OS:Android 9.0 (Pie); MIUI 10
Dimensions:156.7 x 74.3 x 8.8 mm
Weight:191 g
SIM:Dual SIM (Nano-SIM, dual stand-by)
Display type:Super AMOLED capacitive touchscreen, 16M colors
Display Size:6.39 inches, 100.2 cm2 (~86.1% screen-to-body ratio)
Display Resolution:1080 x 2340 pixels, 19.5:9 ratio (~403 ppi density)
Display Protection:Corning Gorilla Glass 5
Chipset: Pro: Qualcomm SDM855 Snapdragon 855 (7 nm)
Chipset: Non-Pro: Qualcomm SDM730 Snapdragon 730 (8 nm)
CPU: Pro: Octa-core (1x2.84 GHz Kryo 485 & 3x2.42 GHz Kryo 485 & 4x1.8 GHz Kryo 485)
CPU: Non Pro: Octa-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver)
GPU: Pro Adreno 640
GPU: Non-Pro Adreno 618
SD card:No
Internal Memory256 GB, 8 GB RAM or 128 GB, 6/8 GB RAM or 64 GB, 6 GB RAM
Camera Wide:48 MP, f/1.8, 26mm (wide), 1/2", 0.8µm, Laser/PDAF
Camera Telephoto:8 MP, f/2.4, 53mm (telephoto), 1/4", 1.12µm, Laser/PDAF, 2x optical zoom
Camera Ultrawide:13 MP, f/2.4, 12mm (ultrawide), 1/3", 1.12µm
Camera Features:Dual-LED flash, HDR, panorama
Video:Pro: 2160p@30/60fps, 1080p@30/120/240fps, 1080p@960fps
Video:Non-Pro: 2160p@30fps, 1080p@30/120/240fps, 1080p@960fps
Selfie Camera:Motorized pop-up 20 MP, f/2.2, 0.8µm
Selfie Video:1080p@30fps
3.5mm jack:Yes
Sound Features:24-bit/192kHz audio, Active noise cancellation with dedicated mic
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth:5.0, A2DP, LE, aptX HD
GPS:Yes, with dual-band A-GPS, GLONASS, BDS, GALILEO
NFC:Yes
RadioYes
USB2.0, Type-C 1.0 reversible connector, USB On-The-Go
SensorsFingerprint (under display), accelerometer, gyro, proximity, compass
BatteryNon-removable Li-Po 4000 mAh battery
ChargingPro: Fast battery charging 27W (Quick Charge 4+)
ChargingNon-Pro: Fast battery charging 18W
ColorsCarbon black, Flame red, Glacier blue
Price Pro +/- 400 EUR
PriceNon-Pro +/- 300 EUR
Photo's
Videos
Video Test:
Unboxing & Review:
Xiaomi Mi 9T Pro Water Test:
Redmi K20 Pro Teardown:
Relevante topics
[Xiaomi Mi 9T / Redmi K20 (Pro)] Prijzen en Levertijden
Xiaomi Mi 9T / Redmi K20 (PRO) Accessoires
[Xiaomi Mi 9] Rooten & Custom ROM's]
Debloaten zonder Root?
Dat kan met XiaomiADBFastbootTools
Check voor het gemak ook deze video: adb fastboot Xiaomi debloat tutorial
Hoe schakel ik NFC in?
NFC inschakelen:
Settings > More > NFC aan > Secure element position > HCE Wallet
Manage apps > "Jouw Banking App" > Autostart = On
Manage apps > "Jouw Banking App" > App permissions > Alles aan
Manage apps > "Jouw Banking App" > Other permissions > Alles aan
Manage apps > "Jouw Banking App" > Battery saver = No restrictions
Additional settings > Privacy, Battery optimization > "Jouw Banking App" > Don't optimize.
Hoe zorg ik ervoor dat notificaties op mijn smartwatch worden getoond?
Open de app info van jouw smartwatch app en zorg ervoor dat de volgende settings goed staan:
- Autostart: enabled
- App permission: alles enabled
- Other permissions: alles enabled
- Battery saver: NO RESTRICTIONs
- Developer options: Bluetooth AVRCP version 1.6
- Additional settings > privacy> special app permission > notification settings > "jouw smartwatch app (Enabled)
Chatten over de Xiaomi Mi 9T / Redmi K20 (Pro)
Voor het ongestoord discussieren over de Xiaomi Mi 9T / Redmi K20 (Pro) kun je terecht in de discord: https://discord.gg/cuavtf9
Versiebeheer
- 04.06.2019 - Topic aangemaakt. Tot mijn verbazing was er nog geen topic aangemaakt voor de Redmi K20 Pro. Gezien ik in October mijn huidige phone wil gaan vervangen en dit een van de kanshebbers is leek het me handig om dit topic alvast aan te maken.
- 17.06.2019 - Topic Change (Xiaomi 9T aan Titel toegevoegd) en toevoeging link naar Prijzen en Levertijden topic. Met dank aan l3art
- 21.06.2019 - Link naar de discord toegevoegd
- 29.07.2019 - Link naar de MI 9 Rooten & Custom ROM's toegevoegd
- 04.11.2019 - instructies voor notificaties smartwatch toegevoegd
sunturion wijzigde deze reactie 04-11-2019 20:18 (20%)
In the name of God, impure souls of the living dead shall be banished into eternal damnation. Amen.
  • +1Henk 'm!
  • sunturion
Het is zeker een interessant toestel. Ik heb de geruchten ook gelezen dat hij mogelijk in Europa als de Mi 9T gereleased zal worden . Verder zijn er al langer geruchten dat het mogelijk ook een Poco F2 label gaat krijgen. Tijd zal het zeggen.
Ik hoop eigenlijk dat de Poco F2 een goedkopere versie wordt van de K20 Pro met plastic ipv glass body en een sdcard slot. Dan kan de prijs nog wat omlaag
  • 0Henk 'm!
  • sunturion
Mr Brightside schreef op vrijdag 7 juni 2019 @ 12:05:
Let wel op, er komt alleen een K20 variant met Snapdragon 730. Er komt geen Mi 9T pro.
Dus als je de Snapdragon 730 geen probleem vindt....
Dat klopt niet. De Pro variant komt er wel degelijk. Zie ook dit artikel op GizmoChina
  • 0Henk 'm!
  • sunturion
Ruiten_Wisser schreef op donderdag 6 juni 2019 @ 22:03:
Mijn hype was met de review van TechTablets.com een beetje weggeëbd... -O-
Edit: Chinese variant
[YouTube: Redmi K20 Pro Unboxing & Review - Value Flagship King!]
Maar gelukkig kwam hij met een update :)
[YouTube: Redmi K20 Pro - Battery life update, FAQ, Notifications & Face Unlocking]
Goede review. Even een samenvatting van de minpunten
- Geen ondersteuning voor band 20
- WiFi 5G connectie issues
- Soms UI stotter
- Geen Widevine L1 support
- Geen EIS voor front camera
- EIS jitter bij back camera
- Microphone audio is slecht
  • +1Henk 'm!
  • sunturion
Discord link is toegevoegd aan de topicstart. Overigens lukt het mij niet op de discord te komen, ondanks dat de Discord status "All Systems Operational" is
  • sunturion
Deze werkt wel! Ik pas direct de topic start aan
  • sunturion
jelleeelco schreef op zaterdag 22 juni 2019 @ 21:03:
Als ik wat meer ervaring heb post ik het. Mochten jullie vragen hebben, stel ze gerust...
Zit de ingebouwde call recorder functie nog in MIUI en hoe functioneert deze?
  • sunturion
HMC schreef op donderdag 27 juni 2019 @ 20:47:
Call recorder zit gewoon in MIUI 10.
Kun je ook wat zeggen over hoe die functioneerd? Vraag is met name ook gericht op de Tweakers die hun Mi9T/K20 al ontvangen hebben. Kunnen jullie wat vertellen over de opname functionaliteit (werking/gebruiksvriendelijkheid) en de kwaliteit van de opnamens?
  • sunturion
HMC schreef op donderdag 4 juli 2019 @ 16:42:
@sunturion Geen idee over de kwaliteit. Zelf heb ik nog nooit gesprekken opgenomen.
Zou je dit voor mij kunnen testen?
  • 0Henk 'm!
  • sunturion
Hahahaha. Thanks voor de confirmatie. Jij begrijpt hem! ;)
Nog een kleine vraag over de werking. Kan je dit aanzetten als het gesprek al aan de gang is of moet je van te voren hebben ingesteld dat hij gesprekken moet opnemen?
sunturion wijzigde deze reactie 05-07-2019 18:22 (59%)
  • 0Henk 'm!
  • sunturion
Ik wist het dus niet zeker maar had wel een vermoeden. Ik las het en der dat het zou moeten kunnen, maar ik kon nergens dit vermoeden bevestigd krijgen. Vandaar de vragen.
Nogmaals bedankt!
  • +1Henk 'm!
  • sunturion
Ik heb de link toegevoegd
  • sunturion
l3art schreef op maandag 12 augustus 2019 @ 15:28:
[modbreak] Nogmaals, maar dan nu een officieel verzoek, wie opent er een root topic? Anders gaat er teveel door elkaar lopen. [/]
Had het graag zelf gedaan maar vanwege vakantie nu niet in de gelegenheid.
Ik zag je verzoek gister avond dus ik dacht ik creëer het vandaag wel maar je was me voor. In ieder geval bedankt!
  • sunturion
l3art schreef op dinsdag 20 augustus 2019 @ 19:15:
Een van m'n favo reviewers op youtube met z'n sidekick 'Witte sokken' heeft de k20 pro gereviewd.
Zijn conclusie, bespaar jezelf geld en ga voor de k20.
Dit zal dus ook opgaan voor de 9T vs 9T Pro.
[YouTube: Redmi K20 Pro "Real Review" - Save Your Money]
Ik ken praktisch alle tech reviewers op Youtube maar van hem had ik nog nooit gehoord. Super komische manier van reviewen. Wat ik ook wel positief vind is dat zijn oordeel afwijkt van de andere Tech reviewers die allemaal toch de voorkeur geven aan de Pro.
Uiteindelijk moet iedereen voor zich zelf bepalen of de 9T/K20 Pro de meerprijs van 100 euro waard is ten opzichte van de 9T/K20. Zeker voor mensen die om de 2 jaar wisselen van phone kan ik me voorstellen dat de meerwaarde van de Pro beperkt is.
  • sunturion
Meivogeltje schreef op vrijdag 6 september 2019 @ 17:42:
Vraagje:
In m'n whatsapp kon ik altijd tekst selecteren en dan aangeven of dit vet, cursief of doorstreept moest worden enz.
Nu viel mij op dat deze functies niet aanwezig zijn. Is dit op een of andere manier op te lossen?
Leek mij een feature van whatsapp zelf...is dit door miu?
Heb nu alleen opties voor knippen,plakken, alles selecteren en delen.
Had je op je oude telefoon toevallig Gboard geïnstalleerd? Volgens mij is dat namelijk een Gboard functie
  • sunturion
Hahahaha. Volgens mij is het dus een fucntie van de keyboard app die je geinstalleerd hebt. Of het nou Gboard is of swiftkey. Ik denk dus dat @Meivogeltje vergeten is dat die functie wordt geborgd door gebruik van een keyboard app
  • sunturion
l3art schreef op vrijdag 6 september 2019 @ 13:35:
@sunturion Is het misschien een idee om dit tooltje aan de TS toe te voegen: https://saki-eu.github.io/XiaomiADBFastbootTools/
Aangezien menigeen toch wil debloaten zonder te rooten.
Heb ik toegevoegd inclusief de stappen voor gebruik van NFC.
  • sunturion
DxOMark heeft eindelijk een review van de K20 Pro. Conclusie: Goede prestaties voor de prijs maar zit niet binnen de top 10 van smartphones
  • sunturion
Dank voor de toelichting, ik laat je opmerking deze keer dan ook staan als hint voor de lezers, maar crossposten vinden we niet wenselijk.
@l3art : dit is overigens een crosspost. Heb de vraag ook gesteld in het levertijden topic maar ik denk in hindsight dat er in dit topic meer mensen rondzweven die de telefoon al hebben besteld
l3art wijzigde deze reactie 18-10-2019 09:39 (65%)
  • sunturion
Misschien dubbelop maar wat L3rt zegt klopt. In de bootloader zitten instructies voor integriteitschecks. Die integriteitscheck hebben o.a. als doel er voor te zorgen dat er geen ongeautoriseerde software op je phone staat. Dit is de reden waarom je een phone moet unlocken om een nieuw rom te flashen.
Op het moment dat je bijvb op Global zit, de phone unlocked, Xiaomi.EU rom flashed en de phone weer locked gaat de integriteitscheck weer in werking en wordt er dus vastgesteld dat er ongeautoriseerde software op je phone staat en zal de phone niet opstarten.
Als jij dus je phone voor werkdoeleinde gebruikt moet je de bootloader al helemaal niet unlocken want applicaties zoals MobileIron zullen niet werken als de bootloader unlocked is.
Als je de phone weer wilt locken kan dat alleen als de custom rom, de custom recovery en de root is verwijderd en je dus weer op de originele meegeleverde rom zit (stock). Als dit niet het geval is bricked je telefoon en is het maar de vraag of je dit kunt herstellen.
  • sunturion
emui is het os van Huawei dus ik denk dat je android 10 bedoelt. Deze melding verdwijnt in ieder geval vanzelf. Gewoon even wachten
  • sunturion
wowly schreef op woensdag 6 november 2019 @ 23:07:
vreemd, ik krijg die xiaomi adb tool niet geopend op mijn w10 64 biot pc
9t pro, QFKEUXM met MIUI global 11.0.3 erop
Ik heb mezelf developer gemaakt, usb debugging aangezet. PTP gekozen. Maar krijg niets als ik op de xiaomiadbfastboottools druk: heel even een flits op het scherm maar verolgens niets. Via de android abd tool krijg ik wel een command achtig screen, maar ik wil graag via die xiaomi tools werken want betere UI
Je moet even een terminal (cmd) openen en navigeren naar de map waar adb staat en vervolgens deze commando uitvoeren: java -jar XiaomiADBFastbootTools.jar.
  • sunturion
Is er een reden waarom je specifiek die launcher wilt en niet bijvoorbeeld de Poco Launcher? Met de Poco Launcher heb ik gewoon een app drawer en de app staat ook gewoon in de playstore
  • sunturion
Ik merk op dat 4G verkeer wordt onderbroken als mijn Mi 9T Pro verbinding probeert te maken met een WiFI netwerk. Heel vervelend als je bijvoorbeeld op een NS station staat want bijna elke trein heeft free Wifi. Hebben jullie dit probleem ook? Iemand hier een oplossing voor?
Ik heb al gespeeld met alle WiFi settings maar niets blijkt te helpen. De enige oplossing is WiFi uitschakelen, maar dat is niet echt een oplossing
  • sunturion
jdan schreef op vrijdag 8 november 2019 @ 10:53:
Automatisch verbinden uitschakelen van dat (free wifi-)netwerk. Eenmaal je op de trein zit, kies je zelf het (juiste) netwerk.
Ik dacht al dat het misschien was dus ik heb dat vanochtend al gedisabled. Moet vanmiddag even controleren of dat inderdaad het probleem oplost. Maar bedankt voor de extra confirmatie.
  • sunturion
Ari Gold schreef op dinsdag 12 november 2019 @ 01:08:
Iemand gelukt om smsjes over te zetten van een niet Xiaomi telefoon.
Heb altijd SMS Backup & Restore gebruikt. Nu zet hij de telefoongesprekken en smsjes wel terug alleen Berichten blijft leeg.
De makkelijkste manier is door de Google messages app op je oude phone te installeren. Vervolgens via settings--> Google --> Backup een backup te maken. Als je vervolgens op je Xiaomi ook de messages app installeert zal hij de backup bij Google ophalen en als je sms'jes restoren
  • sunturion
Ari Gold schreef op woensdag 13 november 2019 @ 13:52:
Blijven ze dan in je Google Messages staan of worden ze verplaatst naar je Berichten app?
Een ding klopte niet helemaal in mijn vorige post. De methode die je kan gebruiken hangt ook af van of je de phone al operationeel hebt of dat je in de setup zit als je de phone voor de eerste keer aanzet. De eerder genoemde methode met Google messages werkt alleen als je al een backup hebt met de messages app en tijdens de initiële setup een Restore woot doen.
Als je je phone al in gebruik hebt moet je een andere methode gebruiken. Voor het overzetten moet je dan eerst een backup via een andere applicatie maken. Ik heb hiervoor gebruik gemaakt van super backup and restore.
Kort samenvattend:
1. Installeer Super Backup & Restore op oude phone
2. Maak backup van data en store die lokaal
3. Installeer de Google messages app
4. Installeer Super Backup & Restore op nieuwe telefoon
4. Restore je sms data
5. Open de Google messages app en dan zijn al je sms'jes zichtbaar
Als je ondertussen al sms'jes in de Google messages app hebt gekregen moet je eerst via de in mijn eerdere post de backup terugzetten en vervolgens bovenstaande stappen uitvoeren.
Ik hoop dat het nog te volgen is O-)
sunturion wijzigde deze reactie 13-11-2019 20:17 (66%)
  • sunturion
jdan schreef op zaterdag 9 november 2019 @ 16:32:
Wat ik nog kan aanraden:
- een mooier startscherm mét app-lade erop plaatsen
- een gcam installeren
- Opera gebruiken in plaats van Chrome
Nog iemand een tip?
Media Volume Only: hiermee kan je de volume knoppen standaard koppelen aan volume control voor media.
Zonder deze app kan je alleen het geluid van je media harder of zachter te zetten door een van de volume knoppen in te drukken en vervolgens op de drie puntjes te drukken en dan de media slider te gebruiken. Super omslachtig dus.
  • sunturion
etienne001 schreef op zaterdag 30 november 2019 @ 22:57:
Vandaag mijn 9T Pro 128GB mogen ontvangen.
Ik kom van een Nokia 7+ met Android one af.
Ik ben nu al wel happy met deze foon, maar het is soms nog wel even wat zoeken door de MIUI interface.
Waar ik tot nu toe het meeste last van heb ik het zoeken van een app.
Bij mijn 7+ had ik m'n homescreen met daarachter wat andere schermen.
Deed ik een swipe omhoog dan zag ik alle geïnstalleerde apps op alfabetische volgorde.
Dit is in MIUI niet aanwezig (volgens mij ;) )
Alle geïnstalleerde apps komen op de achterliggende schermen maar volgens mij op geïnstalleerde volgorde.
Nou zoek ik mij wezenloos hoe ik dit kan ordenen, liefst dus alfabetisch.
Is hierin iets mogelijk?
Download de Poco Launcher uit de App store voor deze functionaliteit.
  • sunturion
N97 schreef op maandag 2 december 2019 @ 14:54:
Is het voor jou mogelijk om een foto te maken van je telefoon (scherm uit) vanuit een hoek?
Ben nieuwsgierig hoe het screenprotector op een full display telefoon er uit ziet.
Check mijn post in het [Xiaomi Mi 9T (Pro)/ Redmi K20 (Pro)] accesoire topic. Daar heb ik een aantal foto's geplaatst van mijn screenprotector.
koelkast schreef op maandag 2 december 2019 @ 14:53:
Hebben jullie vanmiddag een NL-alert gekregen? Ik niet met mijn 9T, met NL Android en alle regio's op NL staan en noodoproepen allemaal geactiveerd.
Iedereen om me heen kreeg een alert, maar ik niet, met Youfone abonnement (KPN).
Of krijg je slechts een melding als er een Chinese kerncentrale ontploft?
Ik heb de melding ontvangen (Vodafone) en geen settings hoeven te wijzigen.
sunturion wijzigde deze reactie 03-12-2019 19:01 (32%)
  • sunturion
HWSHHZ schreef op dinsdag 3 december 2019 @ 16:17:
Vandaag mijn nieuwe 9T Pro in ontvangst mogen nemen. Pracht apparaatje.
Ben nu op zoek naar een app die alle bestanden van je oude telefoon in 1x over kan zetten naar de nieuwe, zoal bijvoorbeeld Samsung Smart Switch.
Is er een soortgelijke app die zo ongeveer alles 1 op 1 kopieert en zoveel mogelijk instellingen en dergelijke hetzelfde instelt als op de oude telefoon? Op internet uiteraard tig apps te bekennen, maar doe het liever in 1x goed aangezien het om heel wat data gaat...
Bedankt alvast!
Naar mijn weten is er geen app die alles 1 op 1 kan kopiëren. Gaat ook bijna niet omdat elke fabrikant zijn eigen specifieke dingen heeft. De beste manier om 90% van de zaken over te zetten is via google services een backup te maken deze bij het instellen van je phone terug te zetten. Echter kun je dit alleen bij de initialisatie van de phone doen. Als je de telefoon al in gebruik hebt dan kan je geen backup terug zetten.
Lokaal opgeslagen data moet je eerst naar een pc kopiëren en dan terug naar de phone. Verder kun je met behulp van apps zoals Google Photos, Messages al content bij Google in de cloud opslaan zodat het overzetten van lokale Photos niet nodig is.
  • sunturion
ReVision. schreef op maandag 16 december 2019 @ 09:59:
Nog even terugkomend op bovenstaande verhaal, ik heb na de tip van @knakworst de Wallet op HCE gezet. Dit werkte uiteindelijk en het heeft een week perfect gewerkt. Nu krijg ik echter de melding bij elke pin terminal, "Volg instructies op toestel." Mijn telefoon begint op dat moment ook te trillen.
Ik vermoed dat ik dan een pincode of iets dergelijks moet invullen, maar behalve trillen gebeurt er niets op
het toestel, er komt geen pop-up of iets op het scherm om een pincode in te vullen.Ik zie gewoon mijn home screen verder niets.
Dit gebeurt nu dus altijd en bij elk bedrag, ook onder de 25 euro.
Iemand dit wel eens gehad en hier een oplossing voor heeft. Zit bij ING
Heb precies hetzelfde probleem. Het werkte flawless voordat ik de Miui updates installeerde. Het probleem is dat Miui je banking app van de autostart haalt. Je moet dus elke keer autostart opnieuw aanzetten.
Nu is het bij mij 50/50. Als ik met m'n mobiel betaal en ik krijg niet het scherm om m'n pincode in te toetsen, dan long press ik op de banking app en kies ik mobile payment. Dan kan ik direct mijn pincode invoeren
  • sunturion
Yfka schreef op vrijdag 20 december 2019 @ 12:27:
Bij mij (Mi T9) werkt ING contactloos betalen zonder problemen. Na een update een maand(?) geleden, heb ik wel iets gewijzigd omdat het toen ineens niet meer werkte.
Instellingen> apps> apps beheren> bankieren (ING)> andere toestemmingen> "pop up vensters weergeven terwijl het op de achtergrond uitgevoerd wordt". Verder is in dat rijtje aangevinkt "NFC" en "permanente melding".
Ik durf niet te beweren dat dit in jouw situatie ook de oplossing is, maar het is misschien de moeite waard om te testen. Autostart voor de ING app staat overigens bij mij uit 🙃
Goede tip! Ik zag bij mij dat deze uit stond en zelfs bij toegang tot NFC stond een vraagteken. Heb overigens desondanks vandaag succesvol een NFC betaling gedaan. Nu allemaal gecorrigeerd. Hoop dat ik nu altijd probleemloos m'n mobiel kan gebruiken
  • sunturion
Merellecht schreef op dinsdag 24 december 2019 @ 17:40:
Ik heb net de zwarte variant besteld. Ik ben nu juist nog op zoek naar een goede screenprotector (bij voorkeur tempered glass). Iemand die er één kan aanraden? Bij sommige lees ik dat ze niet het volledige scherm bedekken en het zou zonde zijn zo één te bestellen.
Bedankt!
Check even het Mi9T accesoire topic. Daar staan meerdere reviews van screen protectors
  • sunturion
pinojo123 schreef op donderdag 9 januari 2020 @ 16:40:
Werkt die call recorder out of the box, of moet je in de weer met root/magisk om het werkend te krigen?
Heb zelf een keer Boldbeast recorder gekocht en die heb ik nu werkend op mijn Mi 9T Pro met de laatste eu rom android 10.
Dat is het hem dus. Heb ook heel bewust voor Xiaomi gekozen vanwege de call recorder maar deze functionaliteit zit niet in de meegeleverde global rom. Je moet dus de custom Xiaomi EU rom of fe china rom gebruiken om de call recorder te kunnen gebruiken.
Dit is overigens geen specifieke Xiaomi beperking (met een Samsung heb je hetzelfde probleem) maar het gevolg van de AVG.
  • sunturion
snah001 schreef op maandag 13 januari 2020 @ 12:41:
Nee hoor, hier werkt de app CallRecorder gewoon met de Global EU Rom uit mijn signature.
Alleen die is unlocked/geroot met de CallRecorder module uit Magisk erbij.
Oftewel, je hebt of een China rom of custom rom. Of je hebt dit voor elkaar dmv Magisk. Maar dus niet out of the box.
  • sunturion
Darkz0rs schreef op maandag 13 januari 2020 @ 12:25:
uhmm, ik heb niks gedaan. En ik heb gewoon de callrecorder. Mi9T EU global (PFJEUXM)
Heb je ook getest dat je gesprekken kunt opnemen? Ik heb namelijk het hele internet afgezocht en op bijna elke forum wordt dit probleem besproken. Zou raar zijn als jij er geen last van hebt. Zelfde geldt voor alle losse apps in de appstore die call recording functionaliteit hebben.
Volgende keer je vorige post graag wijzigen ipv meerdere berichten binnen 24 uur onder elkaar posten.
l3art wijzigde deze reactie 13-01-2020 18:19 (10%)
  • sunturion
Goede toevoeging Snah001. Er is inderdaad een verschil tussen de Mi9T en de Mi9T Pro. Ik heb de Mi9T Pro. Verder helpt ook het handmatig installeren van de Xiaomi dialer niet.
  • sunturion
depl0y schreef op donderdag 16 januari 2020 @ 09:09:
Ik heb sinds gisteren de Mi 9T Pro en moet zeggen dat het me goed bevalt. De vingerafdrukscanner daarentegen, pff, die doet vaak wel zijn best, maar faalt vaak. Ik zit op 11.0.3 met Android versie QKQ1.190825.002.
De fingerprint scanner werkt bij mij perfect. Weet wel dat het gebruik van een screenprotector de fingerprint scanner belemmerd. Ik heb dan ook het volgende gedaan:
1. Screenprotector aangebracht
2. Scherm vetvrij gemaakt
3. 5 vingerafdrukken per duim toegevoegd (vanuit alle hoeken)
  • sunturion
GuustVB schreef op donderdag 16 januari 2020 @ 11:39:
Hoe doe je dat?
Bij mij zit er een limiet op het aantal vingerafdrukken? (zijn er volgens mij maar max 5)
Sorry, ik heb me vergist. Ik heb gewoon het maximum van 5 fingerprints toegevoegd. Volgens mij drie voor de primaire duim en 2 voor de ander.
De belangrijkste tip die ik kan geven is tijdens het scannen niet alleen conform aanwijzingen de duim randen te scannen maar ook je duim een kwartslag (links en rechts) te draaien. Dit was voor mij de oplossing.
  • sunturion
Even testen hoor. nee ik heb geen problemen met spraakgestuurd typen. Dit bericht is letterlijk opgesteld door middel van spraak. Heb alleen interpunctie toegevoegd.
  • sunturion
izzet3838 schreef op zaterdag 18 januari 2020 @ 14:30:
Een vraagje voor de mi9T gebruikers, zijn er tussen jullie al mensen die de camera hebben kunnen vergelijken met de camera van de Galaxy s8?
Ik vraag vooral ook af hoe fel de invloed is van de optische beeldstabilisatie?
Ik niet. Is een beetje rare vergelijking om te maken gezien de S8 meer dan 2 jaar geleden uitkwam. Maar op basis van de dxomark score (102) scoort hij beter dan de S9+ (100). Dus ik zou zeggen, sowieso beter dan de S8.
  • sunturion
AtlAntA schreef op maandag 20 januari 2020 @ 00:10:
Deze ondersteunt toch wel band 20 op 4g? Ik heb deze ook net besteld uit Hongkong en ik ben er van uit gegaan dat alleen het geheugen en de opslag het verschil was maar begin nu toch wat te twijfelen.
Als je de Mi9T hebt besteld hoef je je geen zorgen te maken. Maakt niet uit waar je het hebt gekocht. Alle Mi9T modellen ondersteunen band20. Alleen de Redmi K20 ondersteunt geen band20 want deze is niet bedoeld voor de Europese markt.
  • sunturion
Bij mij werkt dit sinds de aller eerste update niet meer. Of de settings worden gereset en ik krijg geen notificatie op lock screen of de settings zijn wel goed en ik krijg geen notificatie op mijn lockscreen.
Ik heb mezelf al volledig ingesteld op het toepassen van de workaround: Op het moment dat het pin apparaat aangeeft dat ik mijn pin moet invoeren unlock ik mijn phone, long press op banking app en kies ik vervolgens voor mobile payment. Dan verschijnt het scherm voor invoeren van pin wel.
  • sunturion
De top drie apps/processen bij mij zijn Boost, screen en Instagram.
Waarden van Google Play Services:
Storage: 656 mb
Data usage: 26.9 mb
Battery 3.6%
Apple iPhone 11 Microsoft Xbox Series X LG OLED C9 Google Pixel 4 CES 2020 Samsung Galaxy S20 4G Sony PlayStation 5 Nintendo Switch Lite
'14 '15 '16 '17 2018
Tweakers vormt samen met Hardware Info, AutoTrack, Gaspedaal.nl, Nationale Vacaturebank, Intermediair en Independer DPG Online Services B.V.
Alle rechten voorbehouden © 1998 - 2020 Hosting door True
