Xiaomi Mi 9T / Redmi K20 (Pro)
Redmi is a sub-brand owned by the Chinese electronics company Xiaomi. It was introduced as a budget smartphone line manufactured by Xiaomi, that was first announced in July 2013. It became a sub-brand, separated from Xiaomi, on 10 January 2019. Redmi phones use the Xiaomi MIUI user interface on top of AndroidXiaomi Redmi K20 Pro was launched by Xiaomi in the first week of June 2019. The Xiaomi Redmi is the first phone of the company to release 48 megapixels dual camera.
The smartphone has a different Sony IMX 586 sensor for the dual camera. The design of the smartphone is slim along with a combining high performance and mobility.
The minimalist design is in continuity by Xiaomi Redmi K20 Pro, as they have adopted a new process to manufacture. The body is made out of Plastic which is great for stability and fashion as well.
The display type is IPS and the size is 6.39 inches full HD screen which gives a resolution of 1080 x 2340 pixels. The pixel density is 409 PPI (pixels per inch) and the display is protected by Corning Gorilla Glass 5 and a 2.5D curved glass screen.
The smartphone is equipped with Qualcomm Snapdragon 855 chipset and 1x 2.84 GHz Kryo 485, 3x 2.42 GHz Kryo 485, 4x 1.8 GHz Kryo 485 processor.
The internal storage comes with a 6 GB RAM that supports MIUI V10 (Android 8.1 Oreo) operating system for the smooth functioning of the smartphone. The internal storage is 64 GB and 128 GB.
The smartphone comes in different colors, Black, and Blue which gives the user a new sleek and fancy look. The device also handles dual Nano SIM card.
Specificaties Xiaomi Redmi K20 (Pro)
| OS: | Android 9.0 (Pie); MIUI 10 |
| Dimensions: | 156.7 x 74.3 x 8.8 mm |
| Weight: | 191 g |
| SIM: | Dual SIM (Nano-SIM, dual stand-by) |
| Display type: | Super AMOLED capacitive touchscreen, 16M colors |
| Display Size: | 6.39 inches, 100.2 cm2 (~86.1% screen-to-body ratio) |
| Display Resolution: | 1080 x 2340 pixels, 19.5:9 ratio (~403 ppi density) |
| Display Protection: | Corning Gorilla Glass 5 |
| Chipset: | Pro: Qualcomm SDM855 Snapdragon 855 (7 nm) |
| Chipset: | Non-Pro: Qualcomm SDM730 Snapdragon 730 (8 nm) |
| CPU: | Pro: Octa-core (1x2.84 GHz Kryo 485 & 3x2.42 GHz Kryo 485 & 4x1.8 GHz Kryo 485) |
| CPU: | Non Pro: Octa-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver) |
| GPU: | Pro Adreno 640 |
| GPU: | Non-Pro Adreno 618 |
| SD card: | No |
| Internal Memory | 256 GB, 8 GB RAM or 128 GB, 6/8 GB RAM or 64 GB, 6 GB RAM |
| Camera Wide: | 48 MP, f/1.8, 26mm (wide), 1/2", 0.8µm, Laser/PDAF |
| Camera Telephoto: | 8 MP, f/2.4, 53mm (telephoto), 1/4", 1.12µm, Laser/PDAF, 2x optical zoom |
| Camera Ultrawide: | 13 MP, f/2.4, 12mm (ultrawide), 1/3", 1.12µm |
| Camera Features: | Dual-LED flash, HDR, panorama |
| Video: | Pro: 2160p@30/60fps, 1080p@30/120/240fps, 1080p@960fps |
| Video: | Non-Pro: 2160p@30fps, 1080p@30/120/240fps, 1080p@960fps |
| Selfie Camera: | Motorized pop-up 20 MP, f/2.2, 0.8µm |
| Selfie Video: | 1080p@30fps |
| 3.5mm jack: | Yes |
| Sound Features: | 24-bit/192kHz audio, Active noise cancellation with dedicated mic |
| WLAN: | Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot |
| Bluetooth: | 5.0, A2DP, LE, aptX HD |
| GPS: | Yes, with dual-band A-GPS, GLONASS, BDS, GALILEO |
| NFC: | Yes |
| Radio | Yes |
| USB | 2.0, Type-C 1.0 reversible connector, USB On-The-Go |
| Sensors | Fingerprint (under display), accelerometer, gyro, proximity, compass |
| Battery | Non-removable Li-Po 4000 mAh battery |
| Charging | Pro: Fast battery charging 27W (Quick Charge 4+) |
| Charging | Non-Pro: Fast battery charging 18W |
| Colors | Carbon black, Flame red, Glacier blue |
| Price | Pro +/- 400 EUR |
| Price | Non-Pro +/- 300 EUR |
Photo's
Videos
Video Test:Unboxing & Review:
Xiaomi Mi 9T Pro Water Test:
Redmi K20 Pro Teardown:
Relevante topics
[Xiaomi Mi 9T / Redmi K20 (Pro)] Prijzen en LevertijdenXiaomi Mi 9T / Redmi K20 (PRO) Accessoires
[Xiaomi Mi 9] Rooten & Custom ROM's]
Debloaten zonder Root?
Dat kan met XiaomiADBFastbootToolsCheck voor het gemak ook deze video: adb fastboot Xiaomi debloat tutorial
Hoe schakel ik NFC in?
NFC inschakelen:Settings > More > NFC aan > Secure element position > HCE Wallet
Manage apps > "Jouw Banking App" > Autostart = On
Manage apps > "Jouw Banking App" > App permissions > Alles aan
Manage apps > "Jouw Banking App" > Other permissions > Alles aan
Manage apps > "Jouw Banking App" > Battery saver = No restrictions
Additional settings > Privacy, Battery optimization > "Jouw Banking App" > Don't optimize.
Hoe zorg ik ervoor dat notificaties op mijn smartwatch worden getoond?
Open de app info van jouw smartwatch app en zorg ervoor dat de volgende settings goed staan:- Autostart: enabled
- App permission: alles enabled
- Other permissions: alles enabled
- Battery saver: NO RESTRICTIONs
- Developer options: Bluetooth AVRCP version 1.6
- Additional settings > privacy> special app permission > notification settings > "jouw smartwatch app (Enabled)
Chatten over de Xiaomi Mi 9T / Redmi K20 (Pro)
Voor het ongestoord discussieren over de Xiaomi Mi 9T / Redmi K20 (Pro) kun je terecht in de discord: https://discord.gg/cuavtf9Versiebeheer
- 04.06.2019 - Topic aangemaakt. Tot mijn verbazing was er nog geen topic aangemaakt voor de Redmi K20 Pro. Gezien ik in October mijn huidige phone wil gaan vervangen en dit een van de kanshebbers is leek het me handig om dit topic alvast aan te maken.- 17.06.2019 - Topic Change (Xiaomi 9T aan Titel toegevoegd) en toevoeging link naar Prijzen en Levertijden topic. Met dank aan l3art
- 21.06.2019 - Link naar de discord toegevoegd
- 29.07.2019 - Link naar de MI 9 Rooten & Custom ROM's toegevoegd
- 04.11.2019 - instructies voor notificaties smartwatch toegevoegd
[ Voor 20% gewijzigd door sunturion op 04-11-2019 20:18 ]
In the name of God, impure souls of the living dead shall be banished into eternal damnation. Amen.
