Cookies op Tweakers
Tweakers maakt gebruik van cookies, onder andere om de website te analyseren, het gebruiksgemak te vergroten en advertenties te tonen. Door gebruik te maken van deze website, of door op 'Ga verder' te klikken, geef je toestemming voor het gebruik van cookies. Wil je meer informatie over cookies en hoe ze worden gebruikt, bekijk dan ons cookiebeleid.
Meer informatie
[Xiaomi Mi 9T / Redmi K20 (Pro)] Ervaringen & Discussie
  • +8Henk 'm!
  • sunturion
  • Registratie: december 2000
  • Laatst online: 13-07 11:11
http://i64.tinypic.com/jtowmx.png
Redmi is a sub-brand owned by the Chinese electronics company Xiaomi. It was introduced as a budget smartphone line manufactured by Xiaomi, that was first announced in July 2013. It became a sub-brand, separated from Xiaomi, on 10 January 2019. Redmi phones use the Xiaomi MIUI user interface on top of Android
Xiaomi Redmi K20 Pro was launched by Xiaomi in the first week of June 2019. The Xiaomi Redmi is the first phone of the company to release 48 megapixels dual camera.
The smartphone has a different Sony IMX 586 sensor for the dual camera. The design of the smartphone is slim along with a combining high performance and mobility.
The minimalist design is in continuity by Xiaomi Redmi K20 Pro, as they have adopted a new process to manufacture. The body is made out of Plastic which is great for stability and fashion as well.
The display type is IPS and the size is 6.39 inches full HD screen which gives a resolution of 1080 x 2340 pixels. The pixel density is 409 PPI (pixels per inch) and the display is protected by Corning Gorilla Glass 5 and a 2.5D curved glass screen.
The smartphone is equipped with Qualcomm Snapdragon 855 chipset and 1x 2.84 GHz Kryo 485, 3x 2.42 GHz Kryo 485, 4x 1.8 GHz Kryo 485 processor.
The internal storage comes with a 6 GB RAM that supports MIUI V10 (Android 8.1 Oreo) operating system for the smooth functioning of the smartphone. The internal storage is 64 GB and 128 GB.
The smartphone comes in different colors, Black, and Blue which gives the user a new sleek and fancy look. The device also handles dual Nano SIM card.
Specificaties Xiaomi Redmi K20 (Pro)
OS:Android 9.0 (Pie); MIUI 10
Dimensions:156.7 x 74.3 x 8.8 mm
Weight:191 g
SIM:Dual SIM (Nano-SIM, dual stand-by)
Display type:Super AMOLED capacitive touchscreen, 16M colors
Display Size:6.39 inches, 100.2 cm2 (~86.1% screen-to-body ratio)
Display Resolution:1080 x 2340 pixels, 19.5:9 ratio (~403 ppi density)
Display Protection:Corning Gorilla Glass 5
Chipset: Pro: Qualcomm SDM855 Snapdragon 855 (7 nm)
Chipset: Non-Pro: Qualcomm SDM730 Snapdragon 730 (8 nm)
CPU: Pro: Octa-core (1x2.84 GHz Kryo 485 & 3x2.42 GHz Kryo 485 & 4x1.8 GHz Kryo 485)
CPU: Non Pro: Octa-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver)
GPU: Pro Adreno 640
GPU: Non-Pro Adreno 618
SD card:No
Internal Memory256 GB, 8 GB RAM or 128 GB, 6/8 GB RAM or 64 GB, 6 GB RAM
Camera Wide:48 MP, f/1.8, 26mm (wide), 1/2", 0.8µm, Laser/PDAF
Camera Telephoto:8 MP, f/2.4, 53mm (telephoto), 1/4", 1.12µm, Laser/PDAF, 2x optical zoom
Camera Ultrawide:13 MP, f/2.4, 12mm (ultrawide), 1/3", 1.12µm
Camera Features:Dual-LED flash, HDR, panorama
Video:Pro: 2160p@30/60fps, 1080p@30/120/240fps, 1080p@960fps
Video:Non-Pro: 2160p@30fps, 1080p@30/120/240fps, 1080p@960fps
Selfie Camera:Motorized pop-up 20 MP, f/2.2, 0.8µm
Selfie Video:1080p@30fps
3.5mm jack:Yes
Sound Features:24-bit/192kHz audio, Active noise cancellation with dedicated mic
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth:5.0, A2DP, LE, aptX HD
GPS:Yes, with dual-band A-GPS, GLONASS, BDS, GALILEO
NFC:Yes
RadioYes
USB2.0, Type-C 1.0 reversible connector, USB On-The-Go
SensorsFingerprint (under display), accelerometer, gyro, proximity, compass
BatteryNon-removable Li-Po 4000 mAh battery
ChargingPro: Fast battery charging 27W (Quick Charge 4+)
ChargingNon-Pro: Fast battery charging 18W
ColorsCarbon black, Flame red, Glacier blue
Price Pro +/- 350 EUR
PriceNon-Pro +/- 260 EUR
Photo's
http://i64.tinypic.com/2vsew45.jpg
http://i67.tinypic.com/2lk5w12.jpg
http://i67.tinypic.com/29urlon.jpg
Videos
Video Test: YouTube: Redmi K20 Pro Full Video Test - SHOT ENTIRELY ON REDMI K20 PRO!
Unboxing & Review: YouTube: Redmi K20 Pro Unboxing & Initial Review - Flagship Killer 2.0 is Here!
Relevante topics
[Xiaomi Mi 9T / Redmi K20 (Pro)] Prijzen en Levertijden
Chatten over de Xiaomi Mi 9T / Redmi K20 (Pro)
Voor het ongestoord discussieren over de Xiaomi Mi 9T / Redmi K20 (Pro) kun je terecht in de discord: https://discord.gg/cuavtf9
Versiebeheer
- 04.06.2019 - Topic aangemaakt. Tot mijn verbazing was er nog geen topic aangemaakt voor de Redmi K20 Pro. Gezien ik in October mijn huidige phone wil gaan vervangen en dit een van de kanshebbers is leek het me handig om dit topic alvast aan te maken.
- 17.06.2019 - Topic Change (Xiaomi 9T aan Titel toegevoegd) en toevoeging link naar Prijzen en Levertijden topic. Met dank aan l3art
- 21.06.2019 - Link naar de discord toegevoegd
sunturion wijzigde deze reactie 21-06-2019 22:35 (7%)
In the name of God, impure souls of the living dead shall be banished into eternal damnation. Amen.
  • +3Henk 'm!
  • Pinned
  • Tano
  • Registratie: december 2001
  • Laatst online: 16-07 14:04
hsb85 schreef op donderdag 11 juli 2019 @ 11:57:
Heb je wel een ringtone of heb je do not disturb aanstaan?
Qua volte trouwens hoe heb je dat voor elkaar gekregen, het lukt mij niet op mijn huidige Motorola z2 play bij T-mobile..
Ik bedoel dat degene die mij belt de telefoon niet hoort overgaan (tuut.......tuut.......tuut....).
Qua activeren:
VoLTE *#*#86583#*#*
VoWIFI *#*#869434#*#*
Zodra je deze code intikt zie je dat bijvoorbeeld VoLTE detectie wordt uitgeschakeld. Dat betekent dat je het vervolgens handmatig kan inschakelen in de sim card settings (settings -> sim cards & mobile networks -> en dan de betreffende simkaart kiezen).
OnePlus 7 Pro (8GB intern) Nintendo Switch Lite LG OLED C9 Google Pixel 3a XL FIFA 19 Samsung Galaxy S10 Sony PlayStation 5 Televisies
Tweakers vormt samen met Tweakers Elect, Hardware.Info, Autotrack, Nationale Vacaturebank, Intermediair en Independer de Persgroep Online Services B.V.
Alle rechten voorbehouden © 1998 - 2019 Hosting door True
