Automobilista 2
  • CoronelHimself
  • Laatst online: 28-10 11:40
CoronelHimself
Division Brabant
Nieuwe update uit met 5 nieuwe wagens.
:| 60's Mini
:) Lotus 23
:P Mini Challenge
:Y Mercedes 190 DTM
:9 BMW M3 E30
O+ BMW M1 Procar (dus de 485pk versie zoals die in het voorprogramma van de F1 meedeed en niet de 800pk+ group 5 versie zoals in de DRM (voorloper DTM)
Automobilista 2 V1.0.4.0 Update Released
The new update adds several Classic cars, brings the popular Mini Challenge JCW as it is in the top class of the UK Mini series, two Kart circuits, along the usual package of new features, fixes & improvements.
One of these features is the initial revision of the HEAD MOVEMENT setting for cockpit cameras (renaming what was before "WORLD MOVEMENT"), although users will still have the option to use the original legacy head movement if they so prefer - please check the descriptions in-game for more details as to how best configure this option to your preference.
V1.0.4.0 CHANGELOG
CONTENT
Added 1960s Touring Car Series (featuring Lotus 23 & Mini Cooper S 1965)
Added BMW M1 Procar Series
Added German Group A Series (featuring BMW M3 E30 & Mercedes 190 Evolution
Added Mini JCW UK Series
Added Buskerud Kart Track (2 layouts)
Added Speedland Kart track (4 layouts)
Added Hockenheim 1988 Short layout (part of Hockenheimring DLC)*
GENERAL
Added borderless window mode option (Perfromance Options Screen)
Altered behaviour of helmet/cockpit cameras to prevent locking to world horizon and improve smoothing/damping of camera view
Fixed issue where event date was not correctly set if host changed track via multiplayer lobby
Added 'Start New Championship' flow; Added Select championship type, select vehicle/livery, Pre-allocate opponents Added championship specific AI Skill / Aggression settings to championship overview (can be adjusted mid season as desired
Fixed clamping of range when validating Multiplayer AI difficulty setting on client.
Added support to look backwards when pressing loo left / look right simultaneously
Fixed "dummy" objects unintentionally appearing in reflections at higher settings.
Player now retains control of steering/shifting during pitstops when 'Manual pitstops' setting is enabled.
Fixed issue where sometimes player control was not restored after an AI controlled pitstop.
UI & HUD
Added Help text to advanced setup screen
Fixed missing center suspension setting heading localisations
Added help text for all setings (subject to further review/localisation adjustments)
Changed 'WORLD MOVEMENT' to 'HEAD MOVEMENT' to reflect new functionality
Adjusted showroom climate brightness
Added French & Spanish localization options
'Waiting for host' message now also displayed after race sessions in multiplayer when appropriate.
Changed 'EXIT' button to 'RETURN TO MAIN MENU' on post session leaderboard
Added confirmation step when attempting to exit while waiting for host to return to lobby at the end of multiplayer events.
Fixed incorrect activation states on Broadcast Control overlay toggles.
Fixed menu mouse activations and highlight state throughout on Broadcast Control
Added Start New Championship screen for championship and vehicle/livery selection (additional championships to follow)
Replaced "Reset Championship" button with "Start New Championship"
Entering championship mode now opens new championship page if no valid save is present.
DEDICATED SERVER TOOL
Limit AI Difficulty slider to 70-120%
Max Grid Size and Max Human Opponents now allowed to be equal in http UI
Replaced AllowableTimePenalty with AllowedCutsBeforePenalty and limit to correct range (1-50)
PHYSICS & AI
Replaced open Salisbury-based open differential physics with more effective alternative;
Further reduced differential lock per clutch setting
Fixed CTD with Caterham Academy / Supersport
Fixed F-V12, MP4-12, kart shifter & other unreleased cars missing latest minimal AI strentgh adjustment (being too slow below 100% setting as a result)
M1 Procar: Revised tyre construction; Revised Suspension Geometry; Lowered engine inertia; Increased brake torque; Revised tyre constructio
Adjusted AI lateral movement in initial launch off the line
Reduced differential locking increment per clutch setting (all cars)
Slightly adjusted kart tyre treads & FFB max force
Slightly reduced F-V10 Gen2 AI tyre rolling resistance to better match player´s
AUDIO
Onboard cameras now all use onboard sounds
All cars revised for any persisting inacurate engine sound position (forward-rear, left-right)
Added helictoper & drone sound effect (track dependent, where animation is present as sound effects are tagged to the respective objects)
Puma P052: engine sound offset to side fixed, corrected small click in low-ish rpm loop.
Kart 125 2T: increased internal engine volume slightly, external decreased slightly
Camaro SS: increased external sound volume (both trackside and external on car views); fixed bad on-power low RPM samples overlap and general transition from idling to on-power.
Ultima GTR Race: Adjusted filtering on external audio (trackside).
Super V8: Adjusted SUB-frequencies over RPM range
Puma P052 small adjustment to interior sound.
TRACKS
Reworked treeline and grass blade shader, added few new types of grass blades & reworked existing ones.
Reworked fog/haze shader with different exponent steps depending on angle you look at, so you can see the sunlit air when facing the sun
Adjusted fog levels in heavy cloud/overcast setting for european tracks
Added custom track animated objects (still WIP) to Spielberg, Kyalami and Buskerud
Small art passes to Spielberg, Bathurst, Kansai
Ortona: Fixed pit speed warning on track over 60kph; Added correct trigger for pit exit on layout 4;
optimized track cut mesh
Fixed VIR South hole after pit exit
Silverstone 2020: Extensive performance pass
Outon Park: Marbles test : less boxes (78->24), bigger boxes, 0.5-1.5 range, no brake zones
Snetterton: Fixed some AI pit lane issues (hitting pitwall, driving onto grass at pitlane to main path merge)
Adjusted textures; fixed some object LOD popping; Adjusted 100 layout pitlane/pitexit/trackcut to prevent a DQ in some cases
Curitiba: Minor optimization & art pass; improved pit lane path merge to main path; remapped garage/pitbox locations; calibrated dynamic brake marker spacing
Spielberg Historic:Restored road patch bumps; minor optimization pass; calibrated brake marker spacing
Londrina: Fixed black treelines
Imola 2001: Added period-accurate ad boards
Silverstone 2020 Intl: Improved AI line.
Added VR Spectator cams to Interlagos, Silvestone 2001, Bathurst, Hockenheimring, Imola
Fixed objects popping in Spielberg, Silverstone 1975, Silverstone 2020
Brasilia: Fixed several object LOD popping; Various object & texture adjustments
Brands Hatch: Upgraded road seam & roadline shaders; Improved brake marker texture and spacing; Minor optimization pass
Interlagos: Fixed object LOD popping; Upgraded road seam & roadline shaders;
Imola: Fixed hole at Acque Minerali; closed some open edges between double sawtooth curbs; fixed some grass glitches; calibrated brake marker spacing; upgraded sign placement to latest references;
Upgrade distance marker shader to rz_basic, rework sign placement based on recent reference video; moved start trigger 5m to align with pitwall starting gantry; added garage door collisions; relaxed road noise slightly; minor optimization pass
Ortona; Minor Art pass; Added new AI paths for paddock area; Fixed broken UV4 groove mapping. Upgraded road seam & roadline shaders; ;New HUD track maps. Optimized track cut mesh; Added starting lights; Fixed wrong way/DQ bug from new paddock pit lane; Updated fast lines for layout 1 and 3; Minor optimization pass
Guapore: Fixed various object LOD issues; Minor Optimization & art pass; Fixed some open edges; added animated drones
Adjusted road noise for Guapore and Ibarra
VEHICLES
SuperKart: Updated liveries
Added Stock Car 2020 dangling damaged parts
Added Sprintrace dirt and damage effects + dangling parts
Added Super_V8 dirt and damage effects + dangling parts
Fixed Caterham Academy Driver & car animations
Steam - PTR83
  • PatrickC
  • Laatst online: 00:09
Ik heb vanmiddag een aantal uren AMS2 en rF2 gespeeld, maar dat verschil is toch wel groot. In AMS2 heb ik veel onderstuur bij veel auto’s. Ook in PC2 had ik hier veel last van trouwens. Als je dan in een snelle bocht de AI gewoon probeert te volgen, haal je de bocht niet door onderstuur, maar de AI lijkt hier helemaal geen last van te hebben. En in langzamere bochten is de AI dan juist weer veel langzamer dan ik.
  • savale
  • Laatst online: 15-10 15:47
PatrickC schreef op zaterdag 3 oktober 2020 @ 20:22:
Ik merk het niet echt, maar ik zal er eens op letten. Ik merk inderdaad tegen de AI wel dat ik vaak het meeste "pak" in de langzaamste bochten. Neem aan dat je al trail braking toepast waar handig?
  • PatrickC
savale schreef op zaterdag 3 oktober 2020 @ 22:29:
Het is wat Billy Strange noemt in onderstaande video na 2 min 20 sec. Dat je instuurt, maar er te weinig gebeurt... je moet 90 graden sturen om een flauw bochtje door te gaan.
[ Voor 9% gewijzigd door PatrickC op 04-10-2020 14:14 ]
  • H-Alien
  • Laatst online: 13-06-2025
H-Alien
aka Schenk
Klinkt alsof de steering lock verkeerd staat? Toegegeven laatste patch nog niet geprobeerd maar had daar tot nu toe geen last van.
www.simsport-racing.com
  • PatrickC
H-Alien schreef op zondag 4 oktober 2020 @ 18:36:
De stuuruitslag op het scherm komt in ieder geval overeen met die van mijn stuur.
  • H-Alien
H-Alien
aka Schenk
Je zou voor de zekerheid nog onderstaande folder kunnen deleten en daarna het stuur weer opnieuw instellen, wellicht dat er toch iets raars aan de hand is (AMS2 heeft , zeker met stock setup, inderdaad wel de neiging tot ondersturen maar zo extreem als je aangeeft lijkt me toch eerder een bug ergens).Ik vind het voorbeeld van Jimmy een beetje lastig, hij heeft ook wel een wagen te pakken die echt mega onderstuurt als je ook maar iets te snel de bocht in gaat (zoals velen classic cars).
Ander dingetje is het altijd of soms? Ik heb namelijk wel een keer gehad dat na wat alt-tab werk mijn stuur ineens mega licht was tov normaal, zelfde idee dat de steering lock niet klopte en ik het stuur veel te ver moest insturen om reactie te krijgen. Was na een herstart weer back to normal.
Delete profiles map in:
\Documents\Automobilista 2\savegame\randomnummer\automobilista 2
[ Voor 40% gewijzigd door H-Alien op 05-10-2020 08:36 ]
  • CoronelHimself
CoronelHimself
Division Brabant
Okay vanuit SRHI.eu proberen we vanavond een 2-tal funraces te organiseren.
Mocht je geintereseerd zijn zoek dan op SRHI.EU Funrace. We starten rond 8:30 met de Mini UK op Ibarra:
15 minuten kwalificatie (dient ook als practice)
10 ronden racen
Daarna gevolgd door een race met de BMW M1 Procar op Hockenheim 1988 Short
20 minuten kwalificatie
18 ronden racen.
Kleine tip voor de BMW zet de final drive op 4.875 als je ook de 5e versnelling wilt gebruiken. :+
Steam - PTR83
  • savale
CoronelHimself schreef op dinsdag 6 oktober 2020 @ 17:36:
10 ronden racen
18 ronden racen.
Leuk! Ik doe denk wel mee. 20:30 bedoel je denk? Ook met discord?
  • PatrickC
H-Alien schreef op maandag 5 oktober 2020 @ 08:31:
Bedankt voor de tip ;) , maar ik delete die folder altijd al voor elke nieuwe build en kalibreer daarna ook mijn stuur. Het is verder niet bij alle auto’s even erg, maar in het algemeen geldt het wel in bepaalde mate voor alle auto’s. Ik had hier bij PC2 ook veel last van. B.v. de Pouhon bocht op Spa... in de meeste sims kan ik de AI daar prima volgen op dezelfde snelheid en lijn, maar in PC2 onderstuurde ik altijd die bocht uit. Ik heb vergelijkbare problemen in AMS2 in zo’n zelfde type bochten. Net of de AI met andere physics rijdt. En in de langzamere bochten is de AI dan weer veel langzamer. Ik heb dat in de beta wel eens gemeld bij Reiza en zij gaven toen aan dat ik de AI voor mij lager moest instellen, maar dan zijn ze op andere delen van het circuit gewoon veel te langzaam. In andere sims zoals AC, rF2, RaceRoom, ACC en AMS1 heb ik dit probleem niet.
  • CoronelHimself
CoronelHimself
Division Brabant
savale schreef op dinsdag 6 oktober 2020 @ 18:41:
Ja 20:30 8)7 Geen idee of deze link werkt. @H-Alien kun jij anders de goede link plaatsen.
Steam - PTR83
  • savale
CoronelHimself schreef op dinsdag 6 oktober 2020 @ 19:13:
De link is goed, maar moet nog even toegang regelen, dus vanavond gok ik nog even zonder voice chat dan.
  • CoronelHimself
CoronelHimself
Division Brabant
savale schreef op dinsdag 6 oktober 2020 @ 19:37:
Volgens mij als je de race-rules accepteerd dan krijg je vrij snel toegang. :+
Steam - PTR83
  • H-Alien
H-Alien
aka Schenk
Was een leuke pot mannen, jammer dat ik er race 2 uitgeknikkerd werd (denk dat tegelijk streamen tevens wat voor mijn koper lijntje). Die M1 Pro op Hockenheim Short 88 is echt een briljante combinatie, bijna het zo leuk als de V12 op Adelaide classic :)
@PatrickC mjah, de ai heeft zeker nog wel wat werk nodig. Zonde want dat was just de highlight van de originele ams.
[ Voor 19% gewijzigd door H-Alien op 07-10-2020 07:19 ]
  • PatrickC
H-Alien schreef op woensdag 7 oktober 2020 @ 07:18:
Ja, komt wel goed. Ik heb volledig vertrouwen in Reiza. Ik ben wel benieuwd hoe het zo dadelijk met Spa-Francorchamps gaat in AMS2 als deze released wordt en dan met name de Pouhon bocht. In rFactor 2 komt Spa er ook aan (als officiële S397 laser scanned track), dus dan kan ik mooi vergelijken (wat ook al kon met AC, ACC en RaceRoom natuurlijk).
  • TiezZ_BE
  • Laatst online: 20:06
Volgende keer probeer ik mee toen! ( te laat gezien hier)
https://www.techpowerup.com/review/
  • H-Alien
H-Alien
aka Schenk
PatrickC schreef op woensdag 7 oktober 2020 @ 10:13:
Same here, zitten nog steeds wel wat eigenaardigheden in AMS2 (had gister weer een keer dat stuur lichter voelde, na reconnect weer normaal) maar Reiza is volgens mij mega dedicated dus heb goede hoop dat ook dit soort dingetjes opgelost worden.
Ik vind hun balans van "realistisch" neigend naar "fun" erg prettig :)
  • TiezZ_BE
H-Alien schreef op woensdag 7 oktober 2020 @ 10:47:
Exact dit, samen met hoe fijn het draait in VR
  • stijn014
  • Laatst online: 23-10 12:51
Toch wel beetje geprikkeld. Als de Ring uitkomt is de kans groot dat ik op dat moment toch instap.
  • PatrickC
Eerder vandaag wat races gedaan in de nieuwe Lotus 23, Mini JCW UK en Mercedes 190 Evolution in de nieuwe beta versie. Dat ging al een heel stuk beter dan in de laatste release versie. Het bleek dat er een probleem was met de standaard banden onder enkele van de nieuwe auto’s. |:(
Wat me wel meteen weer opviel is hoe groot het verschil in snelheid is van de AI tussen de verschillende auto’s. Met dezelfde AI setting rijd ik met gemaak de AI voorbij in de ene auto, maar in een andere auto zijn ze niet bij te houden. Ook het starten is enorm verschillend. In b.v. de nieuwe Mercedes rijd ik bijna de halve grid voorbij bij de start, terwijl het bij de mini JCW UK gewoon prima gaat. Dit probleem zit er al sinds het begin van de beta’s in, maar is wel voor een heel stuk opgelost. Maar bij nieuwe auto’s lijkt Reiza door hetzelfde proces heen te moeten om de AI snelheid te tweaken en ook hun starts te verbeteren.
  • H-Alien
H-Alien
aka Schenk
Zin in de update van morgen. Ik heb meteen maar even een SRHI server klaar gezet zodat we het weekend los kunnen op rondjes Nordschleife met een mooie multiclass :)
https://store.steampowere.../view/2933492783933191333
Ps. Alle AMS 2 producten momenteel in de steam Halloween sale.
[ Voor 11% gewijzigd door H-Alien op 29-10-2020 21:29 ]
  • PatrickC
Gisteren al wat rondjes gereden in beide nieuwe Porsches op de Nurburgring GP. Is toch wel een andere ervaring als beide auto’s in rF2, maar ze rijden wel lekker. De GT3 was nogal onstabiel met aanremmen, maar nadat ik de rembalans wat verder naar voren had gezet, was dat probleem opgelost. AMS2 is hard op weg, naast rF2, om mijn favoriete sim te worden.
  • naish123
  • Laatst online: 24-10 19:22
PatrickC schreef op vrijdag 30 oktober 2020 @ 09:59:
Hoe werkt dat nou met de AMS2 beta? Ik heb AMS2 beta in mijn steam library staan maar als ik het opent dan zie nooit nieuwe content. Of moet onder het tabje beta nog wat aanklikken?
  • PatrickC
naish123 schreef op vrijdag 30 oktober 2020 @ 13:25:
Je moet de notformedia branch gebruiken en de beta opties van Steam. Je moet dan wel een password invullen wat op het Reiza forum staat in de beta thread.
  • Temujin
  • Laatst online: 13-10 15:22
Temujin
Zegt ook wel eens iets
PatrickC schreef op vrijdag 30 oktober 2020 @ 14:04:
Om iets precieser te zijn. Lees hier de eerste post van Renato even door. Daarin staat het password vermeld en een omschrijving van hoe je dit in steam verwerkt.
https://forum.reizastudio...ta-v1-0-4-8-now-up.13605/
Beta-Forum is alleen toegankelijk voor mensen met een account en beta access.
  • naish123
Thanks! Nooit gelezen. Hij is nu aan het downloaden. :-)
  • PatrickC
Nieuwe versie 1.0.5.0 is nu released met de GT3’s, GT4 en Porsche Cup. Voor de Nurburgring zijn 3 layouts beschikbaar. De Nordschleiffe was nog niet klaar, dus die zit er nog niet bij.
https://forum.reizastudio...-v1-0-5-0-released.13686/
  • savale
PatrickC schreef op zaterdag 31 oktober 2020 @ 18:32:
Super toevoeging, ga het snel even proberen!
  • PatrickC
Ik heb even met de Porsche Cup op Oulton Park gereden, maar dat is geen succes... Die auto stuitert over de weg. O-)
  • CoronelHimself
CoronelHimself
Division Brabant
PatrickC schreef op zaterdag 31 oktober 2020 @ 21:17:
Dat had ik ook, tenminste in de bochten. Ook werkten de shift lichten van de Chevy niet. Dit zal volgende week met een hotfix wel opgelost zijn.
Steam - PTR83
  • FightingAce
  • Laatst online: 21:49
Dat is schijnbaar een reeds bekende bug. Iets met de springs.
  • naish123
Ik vind de Porsche Cup ook niet geweldig rijden. Even AMS1 opgestart en dat rijdt echt stukken beter.
  • PatrickC
@naish123 Het lijkt er op dat Reiza deze nieuwe content te vroeg heeft released, maar daarvoor bewust gekozen heeft. GT3/4 en Porsche Cup content en Nurburgring trekken nu eenmaal meer klanten als de niet-standaard content, waar juist AMS altijd bekend om stond. En er moet gewoon geld verdiend worden door Reiza. Als beta tester voor AMS2 kregen we ook maar 1-2 dagen om te testen.. maw, eigenlijk waren we (degene met toegang tot de Beta) geen beta tester meer, maar zijn we dat nu allemaal in de release versie. Nu vind ik het als jarenlange trouwe klant van Reiza niet zo’n probleem om als beta tester gezien te worden, maar niet iedereen denkt daar hetzelfde over.
  • TiezZ_BE
Ivm wat @PatrickC zegt:
https://forum.reizastudio...c.11982/page-9#post-87196
Bug ivm nieuwe porsches:
https://twitter.com/ReizaStudios/status/1323282491617222656
[ Voor 25% gewijzigd door TiezZ_BE op 02-11-2020 16:34 ]
  • PatrickC
Hotfix voor de problemen in versie 1.0.5:
https://forum.reizastudio...13686/page-12#post-102745
  • H-Alien
H-Alien
aka Schenk
Voor de liefhebbers, aankomende donderdag organiseren we 2 kleine public fun races:
Race 1: Formula Trainer Advanced op Goiania (erg leuke combo voor een korte funrace)
Race 2: German Group A op Donnington (90's DTM bakken, Scooter op de radio verplicht)
Dag: Donderdag 5 november
Start: 20:30 uur - 10 minuutjes practice - 10 minuutjes qualy en 12 rondjes race (circa 20 minuten).
Server: SRHI - Public server
De server staat al te draaien op de German Group A mochten mensen alvast wat rondjes willen draaien :)
[ Voor 5% gewijzigd door H-Alien op 03-11-2020 14:59 ]
  • TiezZ_BE
H-Alien schreef op dinsdag 3 november 2020 @ 14:59:
Mooi, de 1ste haal ik niet. De 2e race moet hopelijk nog lukken.
  • H-Alien
H-Alien
aka Schenk
Was lekker rustig gisteren :) Welke dag / uur zou jullie het beste uitkomen? Blijf het gewoon proberen :)
Kijk wel uit naar de ranked online patch die als het goed is eind dit jaar zou moeten uitkomen..
  • TiezZ_BE
H-Alien schreef op vrijdag 6 november 2020 @ 19:40:
Iets voor 9 nog langs geweest maar niemand te zien :)
  • H-Alien
H-Alien
aka Schenk
Neuh, heb Remi tot tien voor 9 zitten wachten, daarna een andere public gejoined. Bleek na de laatste Fanatec driver update mijn stuur het überhaupt niet meer te doen...toen maar voetbal gaan kijken ;)
  • H-Alien
H-Alien
aka Schenk
Ik ga wel eerst ;) Woensdag avond komt mij goed uit. Ja mij ook, prima O-)
Ook een leuke combinatie, Mini JCW UK op Oulton International. Korte 3 lap race, van mist naar licht bewolkt net na zonsopkomst, wat levert ams2 toch mooie plaatjes op _/-\o_
[ Voor 10% gewijzigd door H-Alien op 08-11-2020 18:10 ]
  • TiezZ_BE
Vrij random voor mij. Maandag bijna altijd mogelijk, en donderdag is de moeilijkste vr mij op korte termijn
  • savale
Ik doe graag weer een potje AMS2 mee, maar op het moment een beetje drukker dan anders. Maandag of woensdag lukt hier meestal ook wel.
  • PatrickC
Voor degene met toegang tot de beta...
“Added Nurburgring Nordschleife layout” :P
  • multynoob
  • Laatst online: 21:12
Ook ik kan op de maandag. Zou wel graag het weekend kunnen oefenen met auto en baan, dus als dat i.i.g op vrijdag bekend gemaakt kan worden, graag.
  • H-Alien
H-Alien
aka Schenk
Helder, maandag is favoriet :) Dan plan ik komende maandag alvast een race in:
Dag: Maandag 16 november
Track: Oulton Park - International
Car: Mini Cooper JCW UK
Practice: 19:30-20:30 CET
Qualy: 20:30-20:45 CET
Race: 20:45-21:15 CET
Server: SRHI - Mini JCW UK (geen wachtwoord)
[ Voor 8% gewijzigd door H-Alien op 12-11-2020 14:36 ]
  • multynoob
H-Alien schreef op donderdag 12 november 2020 @ 14:35:
Ik ga dit weekend een paar rondjes rijden met de mini (hoop dat ik erin pas met mijn 2 meter) ;)
  • H-Alien
H-Alien
aka Schenk
Digitaal moet dat lukken ;)
Leuke wagen, vrij eenvoudig in gebruik en kan best een tikkie hebben zonder direct te spinnen. Leek me dus een goede combi voor een eerste race, lekker toegankelijk maar wel erg fun. Wel extreem belangrijk om je snelheid in de bochten mee te nemen. Hij heeft logischerwijs niet de trekkracht van een Dragracer :D
  • CoronelHimself
CoronelHimself
Division Brabant
H-Alien schreef op vrijdag 13 november 2020 @ 08:56:
Ja, is wel een goede combinatie. Oulton Park is ook wel een van de leukste engelse circuits die er is. Nog lekker smal en vol gridbakken. Heb de race ook in mijn agenda gezet.
[ Voor 3% gewijzigd door CoronelHimself op 13-11-2020 09:50 ]
Steam - PTR83
  • StephanL
  • Laatst online: 12-10 17:46
Nordschleife is uit in de game, samen met een update!
  • RobbieHifi
  • Registratie: Februari 2015
  • Laatst online: 28-10 10:45
Inmiddels toch de game aangeschaft. Ik worstel nog wel wat met de FF. Op een 1 of andere mannier krijg ik nog onvoldoende gevoel in de achterkant van de wagen.
Maar mijn inmiddels wel vermaakt en krijg er een beetje het oude Assetto Corsa gevoel van.
  • PatrickC
Ben niet zo’n Norschleife fan, maar ik heb me er gisteren prima vermaakt met de M1. De FFB is inmiddels zo ver verbeterd dat ik kan anticiperen op overstuur en onderstuur en daarmee komt het steeds dichterbij rFactor 2 wat dat betreft. De Porsches zijn wat mij betreft nog steeds te ‘bouncy’ en niet geschikt om mee op hobbelige circuits te rijden.
  • H-Alien
H-Alien
aka Schenk
Er zit sowieso soms nog wel wat rara stuiter gedrag in. De porsche's hebben er wel het meeste last van maar had het bijv. ook met de ginetta toen ik een curb net wat verkeerd raakte op Nord. Op zich logisch dat je dan wat stuitert maar niet 10 seconden lang alsof de banden als een kiezeltje over het water scheren.
Edit: blijkt een kleine fout in de track mesh te zijn op Nords, duidelijk te zien in de replay dat de wielen even door de grond zakken met dat rare stuiteren als gevolg.
Maar idd, physics en ffb worden steeds beter. FFb vind ik al top, physics doet soms nog wat raar. Nordschleife vind ik persoonlijk echt subliem, geeft mij veel meer een "echt" gevoel dan de AC versie.
[ Voor 14% gewijzigd door H-Alien op 16-11-2020 08:36 ]
  • H-Alien
H-Alien
aka Schenk
Kleine reminder, vanavond race night ;)
  • Darkangle
  • Laatst online: 13-02 20:39
Veel plezier alvast vannavond. Had er graag bij geweest.
  • RobbieHifi
Darkangle schreef op maandag 16 november 2020 @ 14:59:
Is voor mij nog te vroeg. Zaterdag de game binnen en nu wel meer gevoel in de FFB gekregen. Die Ultima.....what a blast
  • savale
H-Alien schreef op maandag 16 november 2020 @ 14:35:
Niet geoefend / ken de Mini nog niet, maar ik doe mee. :9
  • TiezZ_BE
voor of tegen 20h online
Heb maar 1 race en enkele hotlaps met de mini gedaan.
  • savale
TiezZ_BE schreef op maandag 16 november 2020 @ 19:32:
Nog een discord erbij of dat niet?
  • TiezZ_BE
Zo meteen?
  • savale
Zag niks op srhi dus vandaar
  • TiezZ_BE
savale schreef op maandag 16 november 2020 @ 20:09:
aanwezig :)
  • savale
Het was een leuke race! Stuk of 9 aan de start, maar wel veel afhakers. TiezZ 1 en ik 2 uiteindelijk. wOOp :D
  • H-Alien
H-Alien
aka Schenk
Ik begreep het ja, krijg je deels natuurlijk met een public lobby. Hopelijk volgende keer nog wat meer vaste mensen (zoals ikzelf maar dat is op maandag niet vanzelfsprekend). Komt denk ik ook doordat de playerbase gewoon nog erg klein is. Hopen dat het met de multiplayer rating einde jaar beetje aantrekt.
  • H-Alien
H-Alien
aka Schenk
En nog een kleine hotfix met extra Nordschleife layouts en wat bugfixes:
A setup reset to default on Porsche cars is in order for the latest adjustments.
V1.0.5.6 CHANGELOG
  • Added Nurburgring 24h Endurance Layout
  • Added support to order Vehicle group filters alphabetically (original sorting)
  • Fixed class list scroll bar on Vehicle browser
  • Fixed helper spring implementation bug causing deflection to subtract from vehicle´s suspension travel (fixes issues with Porsches bouncing on bumpstops & AI cars occasionally rolling because of it)
  • Adjusted Porsche Cup FFB max force
  • Adjusted engine compression curves for Mercedes GT3, Stock Cars, Montana (slightly reduced engine braking in all)
  • Adjusted Traction Control base slip to allow for more slip before system kicks in
  • Porsche Cup AI wet tire callibration pass
  • Nurburgring / Nordschleife various fixes & adjustments to render and materials; tweaks to outer terrain geometry & grass/terrain texture blending, car park around Youtube corner, LOD distance tweaks, fixed grasscrete material in GP segment; reduced Reduced tire barrier flickering for Nordschleife layout; adjusted some TVcameras to minimise shimmering issues (still more to fix)
  • Camaro GT4R: Corrected brake and tail lights color
  • Mercedes 190E: Fixed cockpit red materials
  • MetalMoro AJR: Fixed head and brake lights
  • Super V8: Fixed head and brake lights
[ Voor 87% gewijzigd door H-Alien op 16-11-2020 22:14 ]
  • TiezZ_BE
Heb me toch behoorlijk vermaakt. Meerdere rondes nek-aan-nek racen, dat bevalt wel met die mini.
  • CoronelHimself
CoronelHimself
Division Brabant
TiezZ_BE schreef op maandag 16 november 2020 @ 22:27:
Jammer genoeg crashte ik in de hairpin, moest naar de pits voor reparatie. Kon daarna nog wel wat snelle ronden neerzetten. Was iets te enthousiast om het gat met jouw te dichten. :P
Steam - PTR83
  • TiezZ_BE
CoronelHimself schreef op maandag 16 november 2020 @ 22:39:
De bandjes waren redelijk op de laatste 5+ min
  • savale
Je kwam nog aardig dicht achter mij over de finish. Ik had ook wat schade inmiddels. :P
  • multynoob
Ik ben op een gegeven moment maar gestopt met de race. Heb de hele tijd in mijn ééntje rondes gereden, de meeste andere die rond dezelfde rondetijden zaten waren er al mee gestopt. Volgende keer beter. Maar tijden zoals jullie 1:51 heb ik gezien ga ik voorlopig niet redden (net begonnen met simracen). Veel blijven rijden en volgend jaar kan ik met jullie meekomen.
  • savale
multynoob schreef op dinsdag 17 november 2020 @ 11:58:
Ik ben op een gegeven moment maar gestopt met de race....
Ik snap dat: maar opgeven is niet de manier. Ten eerste is dat niet zo leuk voor de anderen, ten tweede weet je nooit wat er nog gebeurd. Ik startte zelf ook achterin met rondetijden van ~1:56 en werd toch nog 2e door fouten van anderen... Ten derde: rondjes blijven rijden wordt je ook beter / consistenter van.
  • multynoob
savale schreef op dinsdag 17 november 2020 @ 15:23:
Ja daar heb je gelijk in, vond het zelf ook jammer dat er veel mensen stopte.
  • TiezZ_BE
Ik ben zelf ook nog niet zolang bezig. Hoofdzakelijk AMS 2 sinds full release owv de goede VR performance.
Die mini vereist ook wel een redelijke specifieke manier hoe je de auto de bocht in moet gooien/duwen. (Rij overigens niet zo vaak met de voorwiel aangedreven auto's)
Edit: 30 minuten was eigenlijk net te lang met deze auto icm public lobby
[ Voor 4% gewijzigd door TiezZ_BE op 17-11-2020 18:06 ]
  • H-Alien
H-Alien
aka Schenk
Noted: Ik zal het terugbrengen naar 20 minuten. Suggesties voor de volgende race? Anders verzin ik wel weer wat, de Ginettta G55 Supercuup bijvoorbeeld of Copa Montana :)
  • TiezZ_BE
Aanraders:
BMW M1
Stock car 19 en 20
Caterham superlight O+
DTM
F3
Roco (P3 klasse?)
Ginetta
Superkart (zeer leuk op juiste tracks)
P2 klasse
GT3
GT4 (leuk maar moet imo nog wat gepatched worden)
Leuk maar minder spannend:
Sprint Race
Mini JCW
Opala's
Leuk maar iets moeilijker handelbaar:
Super V8
Ultima race
Copa Montana heb ik een tijd terug een aantal online races mee gedaan, op zich leuk maar was moeilijk om mee op't randje te rijden. Leek nog niet helemaal op punt te staan, maar dat is al enkele updates/patches geleden.
  • H-Alien
H-Alien
aka Schenk
Montana valt duidelijk onder categorie leuk maar moeilijk handelbaar. Ik vind het een topper, maar easy is hij niet nee.
  • CoronelHimself
CoronelHimself
Division Brabant
Roco001 op een circuit zonder lang recht stuk. Donington, Brands Hatch of 1 van de vele zuid Amerikaanse banen.
Velo Cita is een leuk circuit geschikt voor deze wagen
Azure Circuit, voor dit circuit is dit ding snel zat voor mij. Even de steering lock wat naar boven zetten 25 graden (anders moet je 3x je stuur ronddraaien in de hairpin) en de final gear naar 4.2 en dan gaan. _/-\o_
[ Voor 57% gewijzigd door CoronelHimself op 21-11-2020 16:24 ]
Steam - PTR83
  • RobbieHifi
Hebben er mensen ervaring met VR?
Zelf speel ik nu Automobilista 2 op VR. Echt wel een mooie ervaring. De eigen auto is super gedetailleerd, alleen zou ik net iets meer scherpte op te baan willen hebben. Weet iemand welke instelling ik zou moeten of kunnen tweaken om dit te bereiken?
  • RobbieHifi
TiezZ_BE schreef op donderdag 19 november 2020 @ 16:02:
Super V8
Ultima race
Ultima vind ik 1 van de meest vermakelijke auto's in het spel. Force feedback is geweldig en ook wel eens wat listiger. Vind dat veel wagens teveel grip hebben achter. Denk aan de F1 wagens in het spel, die hebben echt zoveel grip dat is niet normaal.
  • TiezZ_BE
RobbieHifi schreef op dinsdag 24 november 2020 @ 11:06:
Heb je supersampling geprobeerd? Tijdens early Acces werd het aangeraden om dit in het config bestand te doen.
Ik gebruik het zelf overigens niet omdat ik niet genoeg performance over hou om continu 80fps te behalen...
  • RobbieHifi
TiezZ_BE schreef op dinsdag 24 november 2020 @ 13:38:
Thanx ga ik even proberen.
  • Darkangle
Sharpening moet omhoog.
Probeer dit eens:
-<data id="0x4240A500" class="GraphicConfigData">
<prop name="Name" data=""/>
<prop name="Build" data="1281"/>
<prop name="Version" version="2"/>
<prop name="Mode" refresh_dem="1000" refresh_num="50000" height="720" width="1280" adapter="0"/>
<prop name="Vsync" vsync="0"/>
<prop name="FrameLatency" framelatency="2"/>
<prop name="AntiAlias" antialias="3"/>
<prop name="SMAAFXAA" smaafxaa="0"/>
<prop name="Windowed" windowed="0"/>
<prop name="TextureFilter" texturefilter="5"/>
<prop name="TextureResolution" textureresolution="2"/>
<prop name="Brightness" brightness="10"/>
<prop name="CarDetailLevel" cardetaillevel="3"/>
<prop name="TrackDetailLevel" trackdetaillevel="3"/>
<prop name="ShadowDetailLevel" shadowdetaillevel="0"/>
<prop name="MotionblurLevel" motionblurLevel="0"/>
<prop name="EffectsDetailLevel" effectsdetaillevel="2"/>
<prop name="EnvmapDetailLevel" envmapdetaillevel="3"/>
<prop name="MirrorEnabled" mirrorenabled="0"/>
<prop name="MirrorEnhanced" mirrorenhanced="0"/>
<prop name="EnvmapReflectionDetailLevel" envmapreflectiondetaillevel="3"/>
<prop name="GraphicsLevel" graphicslevel="4"/>
<prop name="SuperSampling" supersampling="0"/>
<prop name="LowSuperSampling" lowsupersampling="0"/>
<prop name="VRSuperSampling" vrsupersampling="5"/>
<prop name="SharpeningStrength" sharpeningstrength="1.500000"/>
<prop name="SharpeningClamp" sharpeningclamp="0.090000"/>
<prop name="OffsetBias" offsetbias="1.000000"/>
</data>
  • RobbieHifi
Dank voor de hulp. Ga ik morgen even invoeren en testen!
  • Kevin Kater
  • Laatst online: 07-09-2025
Wel aardig dikke black friday deals voor de Automobilista liefhebbers:
https://store.steampowered.com/app/1066890/Automobilista_2/
  • Beakzz
  • Laatst online: 27-10 15:05
Ja heb het track pack al in de winkelwagen staan. Blijf de season pass te duur vinden zonder te weten welke auto's daarin komen. En als je nu al ziet dat bv. Hockenheim 75% korting heeft denk ik dat je met de season pass gewoon de hoofdprijs betaal voor als je geen geduld hebt.
  • Mu.siQ
  • Laatst online: 04-10 05:02
Mu.siQ
XBL: MusiQ2
Beakzz schreef op donderdag 26 november 2020 @ 09:37:
Dit, helemaal eens. Nurburg los gekocht want ja, Nordschleife. Rest maar beetje zo links en rechts los meepikken on sale :)
Therefore I must know what I am doing. Maybe.
  • CoronelHimself
CoronelHimself
Division Brabant
Automobilista 1.0.6 is uit.
CONTENT
Added BMW M6 to GT3 class
Added Ginetta G55 to GT4 class
UI / HUD
Fixed issue where too much chat history was played back in some instances
Seat adjustment input is now continuous (hold to move)
Adjusted various background image anchors to improve display on 16:10 and triple screen
PHYSICS & AI
Slightly increased longitudinal slip in Cup / Stock 2020 / Proto P3-P4 tires
Stiffened sidewalls for GT / Stock / Proto tires
Revised default tyre pressures & ranges for all cars (closer to optimal and / or as per real series regulations - requires setup reset to default)
Adjusted default steering lock / ratio for GT3 / GT4 cars to more accurate values (requires setup reset)
Revised Balance of Performance for GT3 / GT4 class
Revised brakes for GT3/GT4 cars
Corrected tyre tread width for Porsche Cayman Clubsport (265mm front / 305 mm rear), Porsche 997 3.8 Cup (275mm / 315mm)
Revised Porsche Cup aero, adjusted default roll bars
Reduced front splitter downfroce dropoff with yaw in all GT/ Stock Cars
Fixed missing wet tire compound for Camaro GT4R
Adjusted Camaro GT4R suspension
Adjusted Copa Montana center of gravity height
Revised Procar, Group A, Ultima Race baseline damper rates
Fixed Ultima race front left, rear right fast damper ranges incorrectly available
Improved rear efficiency, reduced Group A rear brake torque
Adjusted FFB max force for F-Vee, Procar, Mini, Stock Car 2020, GT3, GT4 cars
Callibrated tire temperature color display range (correcting errors with some tires not displaying correct colors for optimal / overheat tires)
Adjusted rear wing efficiency for Stock2020, Montana
AI
Further smoothing out of AI lateral transitions to reduce jerkiness/weaving/abrupt lane changes
Added logic to prevent AI slowing on track after returning from partially outside track limits
Added logic for AI to be more reactive and switch switch behaviors more often
Initial steps to reduce the impact of small Front-to-Rear collisions between AI (as seen at race starts especially with vehicles of differing performance)
Reduced range of AI variation from ideal racing line
GT3, Porsche Cup, P4, P3, P2, F3 callibration pass
Minor AI aggression scalar adjustment for GT cars
Further wet weather callibration passes for all GT / Stock / Proto cars
AUDIO
Adjusted Mclaren 720s tire skid volume.
Lowered tranny whine given enigne sounds feature them prominently
TRACKS
Nurburgring: Various fixes for LODding / Z-Fighting issues; Corrected a few trackside ads;
add proper groove to 24hr layout; trimmed roadverge excess polys; Various crowd corrections; Various texture updates; further correction to trackside shimmering cameras; minor optimization pass
Kyalami: New AIW pit lane path (fix AI hitting pit wall when leaving pitbox, improved merge to main path at T1); Relax track cut limits on some runoff areas; Minor performance, art pass & LOD fixes
Interlagos: Fixed floating pit box lines
Campo / Curvelo: Adjusted flag LOD range
Montreal Historic: added missing HUD map
VEHICLES
Porsche Cayman GT4 - Fixed red cockpit material issue
Fixed lights for Fusca (all variants) + wiper uv mapping fix (HC1/HC2)
Adjusted brake glow ranges for carbon brakes (player & AI)
Camaro GT4R: Fixed missing RPM leds
Steam - PTR83
  • RobbieHifi
Nice nice. Zo meteen maar even de update binnen harken.
  • TiemenC
  • Registratie: Juni 2020
  • Laatst online: 28-10 11:41
TiemenC
iRacing
Wow...
i.v.m. de sale acties vandaag Automobilista 2 aangeschaft. Ik ben zeer positief verrast over de relatieve eenvoud qua setup (gameplay/visuals etc) maar vooral zeer onder de indruk van de feel van deze game! Ga dit topic ook actief volgen vanaf nu!
Youtube | Twitch
  • Kevin Kater
Ik vind die nieuwe m6 gt3 maar niets. Glijdt alle kanten op, lijkt wel alsof Traction control veels te laat ingrijpt en hij standaard op regenbanden rijdt.
  • CoronelHimself
CoronelHimself
Division Brabant
November development update
In ieder geval 2 GT1’s. De Porsche en de Mercedes. Nog een beetje onduidelijk of de McLaren een road of een race car wordt.
Steam - PTR83
  • PatrickC
Wel mooi dat we ook 2 historische layouts van Spa erbij krijgen langs de huidige layout. rF2 heeft nu 2 layouts, maar de 1991 versie ontbreekt daar helaas.
  • RobbieHifi
Heerlijk hoor. Zelf heb ik mijn hart nu redelijk verpand aan deze game. In VR en mijn rig speelt deze game geweldig. Vooral die stock cars zijn leuk, ook die kleinere stock cars. De feel van de wagens goed, de verplaatsing van het gewicht voelt zoals in een auto. Enig nadeel is lift of oversteer, die er niet in lijkt te zitten. Of echt weinig. Oversteer door vroeg op het gas te staan is wel goed voelbaar en op te vangen. Al met al rij ik met een grote smile.
Hoeven van mij geen gt4 en gt3 wagens in. Daarvoor heb ik Assetto Corsa competizione. GT1 is geweldig.
Wat betreft banen, zou klassiek Zandvoort (pre 1984 mooi zijn). Maar vermoed dat Zandvoort er niet in komt, zit in al veel games.
  • Mystikal
  • Laatst online: 28-10 07:32
Mystikal
It never hurts to help!
Kan iemand mij uitleggen waarom ik eventueel AM2 zou aanschaffen als ik al AC en ACC heb. Ik rij tegenwoordig met de hp reverb g2 icm 3060 ti.
Daarnaast is de belasting te zwaar voor deze combo?
Basement Bios ---- Exo-S
  • Djurres
  • Laatst online: 20-10 09:21
Mystikal schreef op dinsdag 22 december 2020 @ 07:28:
Ga ik even linken naar het VR topic.
Ben zelf een beginnende VR Simracer, en ik heb deze vraag aan iemand gesteld waarom ik AMS2 aan zou moeten schaffen. Kreeg onderstaand antwoord.
Banandy in "VR Racing"
[ Voor 8% gewijzigd door Djurres op 22-12-2020 07:39 ]
  • Djurres
Nou ik loop een avondje te kutten, maar ik krijg hem dus echt niet lekker draaiend. Veel stutters, erger dan AC, terwijl deze veel lichter zou moeten lopen..
Iemand nog tips?
  • Darkangle
Sharpenings waardes in xml file opschroeven, andere settings wat omlaag. Google even de sharpenings settings toepasbaar voor jou.
  • Djurres
Darkangle schreef op dinsdag 22 december 2020 @ 22:30:
Atm alles practisch op laag, en dezelfde stutters blijven daar. Neem aan dat een RTX2080 capabel genoeg moet zijn om dit soepel te draaien? i5 7600k draait op 4,5 ghz.. verder 32gb 3600 mhz ram..
  • TiezZ_BE
Djurres schreef op woensdag 23 december 2020 @ 14:32:
Bij mij praktisch alles op medium, msaa op high. Draait hier bijna altijd soepel met 6700k + gtx1080 op een rift S. Dus er klopt iets niet bij u...
%'s Cpu en GPU usage (ingame) nagekeken? Niet dat dit een directe oorzaak zal aanwijzen maar toch handig om te weten of 1 vd 2 'gewoon' niet benut/gebruikt wordt zoals het hoort, ofwel mogelijk om 1 of andere reden gebottlenecked wordt door de andere.
In afterburner kan je de grafiek open vouwen en redelijk terug in de tijd kijken (wel even de gewenste zaken aanvinken in de settings, mogelijk kan je daar (in de opties) ook een log maken van deze zaken)
  • Darkangle
Specs zijn goed genoeg. Ik vrot niet met PC's, als ze dit doen gaat er hier een clean install (auto) overheen, doen ze het nog is het even kijken naar de hardware en vervangen wat er kapot is.
Geen idee of je een installatie van het jaar kruik of 10 crypominers er op hebt of een complete cleane bak (gezien de CPU gok ik niet op het laatste) hebt.
