• Balance
  • Laatst online: 28-10 06:59
Lenovo heeft de eerste Panther Lake-laptops in z'n Nederlandse webshop staan:Hier de specs van beide processors vergeleken. De Ultra 7 355 is dus echt een kleine processor, met maar 8 cores (4 Performance, 4 Low Power Efficient), waar de 356H ook nog 8 extra Efficient cores heeft. Beide hebben een GPU met 4 Xe-cores.
  • Olaf Oztorum
  • Registratie: Januari 2026
  • Laatst online: 07-02 11:11
*knip* offtopic
[ Voor 96% gewijzigd door br00ky op 25-01-2026 09:36 ]
  • Help!!!!
  • Registratie: Juli 1999
Help!!!!
Mr Majestic
Igor: Panther Lake sets new benchmark at IPC, Intel overtakes Zen 5 at microarchitecture level
Conclusion
Panther Lake marks a clear step forward for Intel at the microarchitecture level and shows that the company is once again ahead of AMD’s Zen 5 and Zen 5c designs in terms of IPC. The combination of Cougar Cove P-cores and Darkmont E-cores not only delivers higher efficiency, but also measurably more performance per clock cycle. Even though IPC alone does not provide a complete picture of overall performance, the current data underscores that Intel has created a technically convincing foundation with Panther Lake to regain a leading role in the high-end mobile segment.
PC Specs
  • Help!!!!
Help!!!!
Mr Majestic
Er waren al een tijdje positievere signalen die geen wishfull thinking leken te zijn maar het begint er nu daadwerkelijk op te lijken dat Intel Foundry inderdaad de weg terug heeft gevonden.
TPU: Intel 18A-P Node Delivers 9% Performance Increase and 18% Power Savings
"Intel's next-generation 18A node is ready, and the company has tested it, showcasing some impressive results. At the VLSI 2026 Symposium in Honolulu, Hawaii, Intel will present its new research on the capabilities of the upcoming 18A-P node. According to the paper, the 18A-P node can deliver a 9% performance increase at the same power level or achieve 18% power savings at the same performance level compared to the standard 18A.
However, there is more to this than meets the eye. Typically, node generations show similar performance and power improvements across generations. What would be expected in terms of power and performance improvements when transitioning from 18A to 14A is now already available with the 18A-P node, but without any density improvements.
This makes the 18A-P node a very attractive option for external customers who expect the transistor density of the 18A node found in "Panther Lake," but with significantly better characteristics.
For reference designs, Intel uses an Arm core sub-block to test frequency and power scaling. The new 18A-P node can yield much better results on paper, but one of the most interesting improvements is in manufacturing, specifically in something called skew corners. When a node is manufactured, no two transistors are identical due to the inherent physics of the manufacturing process, especially at today's scale. These variations are measured between fast and slow "corners," meaning faster and slower transistors. The skew refers to how wide the performance and power gap is between these transistors. Intel has managed to improve the skew corners on the 18A-P node by 30% compared to the standard 18A, meaning that power and performance characteristics are now more predictable, especially for parametric yields. This means that chip functions are now more predictable, and Intel has to deal with far fewer variations with the new node.
ETC.."
PC Specs
  • Stefie2010
  • Laatst online: 01-11 11:33
De markten lijken er ook weer (veel) vertrouwen in te hebben want het aandeel staat inmiddels op een all time high en is de afgelopen maand met meer dan 100% gestegen.
My fun: Track prepared Renault Megane 3 RS @ 306HP
  • Q_7
Q_7
Afbeeldingslocatie: https://tweakers.net/i/jiFIYzTp4-amwL5VIFmfOud4DDc=/fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():strip_exif()/f/image/oSMyTeFdYm06YXbJXD0Dl1CH.jpg?f=user_large
Dankzij overheidscontracten, maar zwaar overbought, dus ik verwacht een sterke correctie.
AMD 9950X3D - X670E-Hero - G.Skill Royal Neo 48GB 6400 CL26 1:1 - RTX 5090 Astral LC 32GB - 9100Pro 2TB - BeQuit 1500w - Corsair 6500D - LG 3440P 240Hz WOLED
  • XWB
XWB
Devver
Nou was ik wel benieuwd waar die verwachtingen op gebaseerd zijn want er zijn geen nieuwe CPU's voor consumenten of servers aangekondigd. Maar Intel lift dus mee op de AI race. Er zou ook een deal met Musk in de maak zijn.
They expect CPU shipments to grow by more than 20% in 2026 and 2027, “driven by the rise of agentic AI.”
Intel’s manufacturing segment, which still has a single internal customer for now, lost $2.4 billion. Intel hopes to change that after a new deal with Elon Musk’s companies.
The narrative was boosted in the past month by Intel buying back a portion of a factory it had previously sold to Apollo Global Management, as well as with a new deal with Musk’s companies to build a massive factory complex in Texas.
[ Voor 3% gewijzigd door XWB op 30-04-2026 21:25 ]
March of the Eagles
  • kujinshi
  • Registratie: Januari 2023
  • Laatst online: 30-10 12:04
kujinshi
seven heroes
250K en 270K worden/zijn al een groot succes.
Hoe je het ook keert, Intel 270K verslaat de 9950X op heel veel vlakken. Al die AMD verhalen dat Intel nergens is, zijn niet waar.
En Panther Lake gaat Intel nog meer helpen.
  • Help!!!!
Help!!!!
Mr Majestic
The beast is back?
via TPU: Intel Solves 18A Yield Issues, Production Reaches 30,000 Wafers Per Month
"Intel has reportedly resolved all yield issues it experienced with its 18A node over the past few months. According to the sell-side equity research firm BlueFin Research Partners, Intel has fixed these yield issues, making the high-volume production of its latest node sustainable from both a manufacturing yield and economic standpoint.
Etc..... "
PC Specs
  • Help!!!!
Help!!!!
Mr Majestic
PC Specs
  • Help!!!!
Help!!!!
Mr Majestic
Meer positief Intel nieuws:
Intel's EMIB-T to Rival TSMC's CoWoS with 50% Cost Advantage, Volume Production in 2027
However, this EMIB-T advanced packaging will only enter mass production next year, as Intel is currently ramping up its regular EMIB and Foveros for customers. According to Taiwan's Unimicron, which manufactures PCBs and silicon substrates, Intel's EMIB-T will reach high-volume production in 2027. The company also notes that customers, including ASIC designers like Broadcom and Meta, are considering switching from TSMC's CoWoS packaging to EMIB to reduce costs while maintaining the same benefits and even gaining more features in some areas. The price gap between EMIB-T and CoWoS (presumably CoWoS-L or CoWoS-R) can be as much as 50%, depending on whether an expensive interposer is required. This means that the costs of advanced packaging are passed back to the customer, who can then invest in other production areas."
PC Specs
  • andru123
  • Laatst online: 27-09 12:07
@Help!!!! helaas oudere links met uitleg wat is EBIB werken niet, was er goed uitleg wat is het?
Pagina: 1 ... 13 14 Laatste
