iRacing Vorige deel Overzicht
Pagina: 1 ... 4 ... 422 Laatste
  • Niellie41
  • Laatst online: 08:14
Niellie41
[object Object]
De release notes voor de update van vandaag!
Here is another small follow-up to our 2016 Season 1 Release. We've fixed a few more issues to make your racing experience even better.
Rendering
- The rendering cutoff distance for track surfaces at most tracks has been increased by 1km. [/li]
- Improved the graphics autoconfig to set the "Video Memory to Use" limit to approximately 10% less than the dedicated video memory of the GPU, rather than to the full amount dedicated video memory. This is because Microsoft Windows uses a portion of the video memory for itself, leaving even less for the simulator, especially in newer versions of Windows. The first time the simulator executes, your existing video memory setting may be automatically lowered to this new setting if it was set too high. Please do not increase it, as it will only lead to performance issues and stuttering. The setting in renderer.ini has been renamed from "VidMemMB" to "VideoMemMB" to help facilitate this change.
Scoring
- Fixed a bug that was causing official multi-class series with embedded qualifying to fail to reorder the starting grid to keep all cars in a class gridded together.
McLaren MP4-30
- DRS Status can now be seen in telemetry. The variable has four possible values:
  • 0 = Inactive
  • 1 = Available in Next Zone
  • 2 = Available and in a DRS Zone
  • 3 = Active
- DRS can now be used for Lone Qualifying.
- A low oil pressure warning will now trigger the dashboard to enter a failure mode when the engine lets go.
- Fixed an issue where Control Setting changes where not appearing in the display.
- Fixed a bug that was allowing Spotters and Crew Chiefs to adjust the diff preload control in the F8 Black Box.
Nürburgring
- Added a large speed limit sign, portable toll booth, and cones for the length of the straight alongside the pit lane on the Tourist config.
Weer geen DX11. -O- ;)
[ Voor 3% gewijzigd door Niellie41 op 22-12-2015 13:11 ]
  • -PassY-
  • Laatst online: 09-12-2021
-PassY-
Niellie41 schreef op dinsdag 22 december 2015 @ 13:07:
Scoring
_/-\o_
"If you don't come walking back to the pits every once in a while holding a steering wheel in your hands, you're not trying hard enough" iRacing Profiel
  • A1AD
  • Registratie: Juli 2013
  • Laatst online: 21-10 17:45
JoepW schreef op dinsdag 22 december 2015 @ 11:33:
Natuurlijk staat ie gedeeld.... Waar anders dan in de setup database ;)
http://iracingsetupsync.nickthissen.nl/Setups/Details/12840
Whoops, kwestie van eerst zoeken en dan pas vragen... Thx anyway.
- Deze advertentie is geblokkeerd door Pi-Hole -
  • gtrNL
  • Laatst online: 31-10 21:17
Gewoon even dat bestandje (use_dx11.dll of zo) in je iRacing folder op '1' zetten. Ik rij al sinds vorige week met DX11. 700+ fps op m'n 5x 4K schermen op de Voodoo 3dfx. Werkt best lekker.
iRacing Profiel
  • dabelg
  • Laatst online: 26-06-2025
JoepW schreef op dinsdag 22 december 2015 @ 12:56:
Ik stream ook vanaf een 2de pc.
Moet alleen nog een kabeltje leggen om het iRacing geluid naar die pc te brengen.
Nu is het wel erg stil. ;)
mmm hoe breng je geluid over enkel stereo dan ?
mic-kabel ? (heb hier nog oude portable staan maar i3 zal te zwak zijn denk ik )
dan maar niet streamen tot dx11 uitkomt en ik eventueel nieuwe pc build met nvidia pascal kaart
[ Voor 11% gewijzigd door dabelg op 22-12-2015 14:27 ]
Mijn iRacing profiel / YouTube / Twitch.TV
  • A1AD
:( weer offline?
  • dabelg
kijk eens 5 posts boven je :p
en kan nog tot 20u duren ;p
[ Voor 34% gewijzigd door dabelg op 22-12-2015 15:07 ]
  • A1AD
dabelg schreef op dinsdag 22 december 2015 @ 15:06:
8)7 :? :X :(
edit: om eens iets nuttig te zeggen: ik heb een headset gekocht en ik moet zeggen, tegen mijn verwachtingen in, dat ik er sneller mee ben :o Vooral in het remmen helpt het goed, je hoort veel meer detail.
[ Voor 35% gewijzigd door A1AD op 22-12-2015 15:13 ]
  • JoepW
JoepW
dabelg schreef op dinsdag 22 december 2015 @ 14:26:
idd enkel stereo.
  • Sanderrr
  • Laatst online: 14-02-2025
Iemand hier met een Thrustmaster 599XX wheel?
Heb mijne gisteren ontvangen (samen met alle PC onderdelen, morgen vrij dus PC in elkaar zetten en hopelijk in de avond eerste rondjes iRacing) maar het valt me op dat de linker paddle een ander geluid maakt dan de rechter. Rechts is een duidelijke klik, terwijl links meer als een veertje dat verspringt klinkt... Even checken of dat normaal is.
Ich liebe es wenn ein plan funktioniert
  • DarkPino
  • Laatst online: 10-10 09:23
Ik ben vergeten tot hoe laat de update is. Was het idd tot 1900 gmt? of is dat een grap?
iRacing Profiel
  • gtrNL
iRacing.com Downtime Schedule:
CET
Tuesday 2015-12-22 1100 Hosted Sessions Unavailable*
Tuesday 2015-12-22 1500 Service Unavailable
Tuesday 2015-12-22 1900 Service Restored
CET is onze tijdzone, dus om 19:00 is alles weer online als het goed is.
iRacing Profiel
  • ThiJor
  • Laatst online: 16-09 08:55
gtrNL schreef op dinsdag 22 december 2015 @ 16:22:
19:00 morgenavond welteverstaan 8)7
  • alexbl69
Is er een tooltje waarmee je op een tweede scherm (liefst op een tablet) een overlay van het circuit met daarop de posities van de rijders kunt tonen?
  • DarkPino
Thanks! En niet zo negatief, denk dat het wel goed komt ;)
iRacing Profiel
  • JoepW
JoepW
De download is al beschikbaar (21 mb): http://members.iracing.com/download/member/home.jsp
  • FransJansen
  • Laatst online: 20-12-2025
Site is up
“If everything seems under control, you're not going fast enough.” www.facebook.com/bcapaintings
  • Red Baron
  • Laatst online: 01-11 17:48
Red Baron
alexbl69 schreef op dinsdag 22 december 2015 @ 16:38:
En er zullen er vast nog wel een paar zijn die het kunnen gok ik zo.
[ Voor 5% gewijzigd door Red Baron op 22-12-2015 18:11 ]
iRacing Profiel - Radicals Online - CyclingMaster parser
  • martijn_8519
  • Laatst online: 14-10 12:31
SanderF1 schreef op dinsdag 22 december 2015 @ 16:00:
Toevallig gisteren ook het stuurtje aangeschaft. Ik heb het maar even in de winkel gecontroleerd bij mij was het gelukkig goed als ik jouw was zou ik m gewoon omruilen voor een goeie vind het zelf altijd erg irritant! Komt dus helaas vaker voor had het zelf bij de originele shifters en het vorige ferrari stuurtje.
iRacing Profiel
  • alexbl69
Red Baron schreef op dinsdag 22 december 2015 @ 18:11:
Bedankt :)
  • Sanderrr
martijn_8519 schreef op dinsdag 22 december 2015 @ 19:41:
Online besteld dus helaas niet kunnen testen. Heb de verkoper gebeld (Wheelstandcentre) en die zei dat zijn stuur hetzelfde heeft...dus dan denk je dat het normaal is. Thanks hiervoor, ga er morgen achteraan!
  • Scifo83
  • Laatst online: 19-05 22:53
Mijn Neo race maar eens in beeld gebracht ^^
iRacing Profiel
  • The_FrankO
Ik merk dat ik erg veel moeite heb om uit een setup meer snelheid te halen.
Zojuist met de BMW op Spa geoefend. Onze basis setup is voor deze auto stabiel. Als ik dan wat wijzig op de setup om bijvoorbeeld meer grip te krijgen lijkt het iets beter of sneller te gaan. Ga ik later weer terug naar de orginele setup, is dat voor mijn gevoel toch weer beter en ben ik toch weer sneller...
Gebrek aan talent denk ik :/
Ik zou het graag wetenschappelijk willen aanpakken en het gevoels kwestie uit de formule willen halen. Hoe kan ik dit aanpakken en waar moet ik beginnen?
iRacing Profiel | Mijn SimRig
  • JoepW
JoepW
Bij de geplande GoT iRacing setup school binnenkort ;)
Mooie actie foto uit de NES met beide GoT auto's erop.
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/22265537/topic_2016/151222-06_thumb.jpg
Bron: http://members.iracing.co.../225/3341982.page#9450650
Scifo83 schreef op dinsdag 22 december 2015 @ 22:35:
[video]
Leuke video!
Wat een vreemd ongeluk de eerste keer met die Corvette. Leek wel ghost contact.
En coole inhaal actie in de busstop!
[ Voor 37% gewijzigd door JoepW op 22-12-2015 22:51 ]
  • JoepW
JoepW
@Red Baron: Welke overlay gebruik jij voor jouw stream?
  • A1AD
JoepW schreef op dinsdag 22 december 2015 @ 22:41:
Leuke video!
Wat een vet geluid! Ik kom net van een avondje skippy :+
  • JoepW
JoepW
Ik heb YoepTube nu ook aan de gang en met geluid. Moet nog wel even zoeken naar de herkomst van een storend geluid (piep) in het geluid. YouTube: Test broadcast
  • Scifo83
Leuke video!
Yup ik zie ook geen contact buiten dat ik wel iets voelde :P
Nuja al in lap 7 zo een risicootje pakke was mss niet slim. Ma kvoelde dat we een goede race setup hadde, en het kriebelde te hard -.-
iRacing Profiel
  • ThiJor
JoepW schreef op dinsdag 22 december 2015 @ 23:04:
Mooi! Ik mis wel een pedalcam :)
  • dabelg
welke webcam gebruik je joep ? mooi en duidelijk beeld
  • JoepW
JoepW
ThiJor schreef op woensdag 23 december 2015 @ 00:10:
Die gaat er niet komen. ;)
dabelg schreef op woensdag 23 december 2015 @ 07:26:
pricewatch: Logitech HD Pro Webcam C920
  • Salandur
  • Laatst online: 01-11 16:17
Salandur
Software Engineer
Hallo allemaal! Ik ben ook al een tijdje aan het iRacen en heb me inmiddels ook aangemeld voor de GoT league. Maandag voor het eerst meegedaan en me best behoorlijk vermaakt :), ookal was starte ik de eerste race als laatste en de 2e race niet gefinished.
Hebben jullie nog tips om wat constanter te worden qua rondetijden? Bij mij schommelen ze nogal, met iets te veel incidenten tot gevolg.
Assumptions are the mother of all fuck ups | iRacing Profiel
  • JoepW
JoepW
Salandur schreef op woensdag 23 december 2015 @ 09:54:....Hebben jullie nog tips om wat constanter te worden qua rondetijden? Bij mij schommelen ze nogal, met iets te veel incidenten tot gevolg.
Welkom!
Drie tips:
  1. Veel oefenen
  2. Oefenen in verkeer
  3. Meedoen aan de GoT Driving en Close Racing school
(Ennuh misschien ff een link naar je iRacing Profiel plaatsen in je handtekening hier. Uitleg hoe)
[ Voor 16% gewijzigd door JoepW op 23-12-2015 10:00 ]
  • Red Baron
Red Baron
JoepW schreef op dinsdag 22 december 2015 @ 23:00:
http://ir-apps.kutu.ru/#/
Die apps draai ik dan lokaal en daarbij heb ik onder andere die stream en track overlay geïntegreerd en dus de styling aangepast en nog wat andere dingen gecustomized.
Maar ik weet nog niet of we die blijven gebruiken of eens gaan kijken of we iets kunnen met de mogelijkheden van JRT.
  • JoepW
JoepW
Owk, dan ga ik meteen eens met die van JRT aan de gang.
Ik stuur de telemetry data door naar mijn streaming-pc en ga zien of ik daar de boel aan de gang krijg... ;)
  • FransJansen
Misschien leuk voor de film makers onder ons.
Deze gozer legt uit hoe een paint te maken in photoshop(maar dat wisten de meeste al) :Y
Hij heeft ook een pack gemaakt waarmee je een aantal camera standpunten toe kunt voegen.
Vanaf 21:37 legt hij dat uit.
oa Dynamic TV en Random TV
De zipfiles voor het camera pack.
https://www.youtube.com/r...1MDk1MTM3NEAxNDUwODY0OTc0
  • Red Baron
Red Baron
JoepW schreef op woensdag 23 december 2015 @ 10:38:
Nou is JRT natuurlijk voornamelijk een timing app, maar qua functionaliteit is het wat gelikter.
Dus er is nog wel wat werk vereist om er iets van te bouwen wat handig is als overlay bij een stream.
De browser apps van kutu is eigenlijk al kant en klaar en daar kan je dus meteen mee aan de slag zonder dat je er zelf veel tijd in hoeft te steken.
  • Arfman
  • Laatst online: 31-10 13:27
Arfman
Drome!
Ik krijg de lokale stream overlay niet aan de praat, hij laat dan een html paginas zien met "ir browser docs" oid. Via kutu.ru lukt het wel, toevallig een idee wat ik fout doe? Server is gestart en apps map staat erin.
  • JoepW
JoepW
Ik ben aan het prutsen met JRT en het is idd veel werk, maar wel onwijs veel mogelijkheden.
Ik heb de JRT server gestart, replay gestart en de HTML pagina aangeroepen op mijn stream-pc en klaar was kees.
Volgende uitdaging. Hoe zorg ik dat de te capturen windows steeds dezelfde afmetingen hebben. ;(
[ Voor 19% gewijzigd door JoepW op 23-12-2015 12:31 ]
  • Niellie41
Niellie41
[object Object]
De resultaten van afgelopen NES race staan online. Racing Lions valt nu van 6e naar de 9e plek in de stand. :'( :'( :'(
  • Scifo83
Ow yeah, wij lekker gestegen naar P4 in GT1 >:)
Top 5 lijkt me wel een mooi streefdoel voor ons team. Ik kijk al uit naar de volgende events!
iRacing Profiel
  • ThiJor
De Fenix GT1 heeft hun eerste puntje *O*
Wij klimmen door naar P2, maar SimRC heeft wel een mooie voorsprong van 42 punten.
Onze HPD doet ook een redelijk goede zaak met hun 15 punten, klimmen nu naar 9.
GoT1 en GoT2 staan er ook mooi voor.
  • JoepW
JoepW
Ik heb de overlays van JRT aan de gang.
De track overlay komt pas na 1 rondje en het timing overzicht is wat druk.
  • BM
  • Laatst online: 08:24
BM
Admin Softe Goederen
Daarnet voor het eerst wat rondjes met de nieuwe build kunnen doen.
De McLaren is... een handje vol, en kolere wat een enorme hoeveelheid settings voor de ERS :X
Ook maar rondje nordschleife gedaan. Geen baan die ik heel vaak zal rijden, maar hij is wel erg mooi :)
Xbox
  • Fuelke
  • Laatst online: 00:07
Fuelke
Forza Ferrari
Lotus 49 op de Nürburgring ... wie waagt er zich aan deze week ?
La Ferrari più bella è quella che dobbiamo ancore fare: La Prossima
  • JoepW
JoepW
Ik niet ;)
Ff een snel testje gedaan van 1 rondje met de overlay aan.
[YouTube: http://youtu.be/4aSNmgPso_c]
Nu die vervelende piep nog een keer vinden in het geluid...
  • Niellie41
Niellie41
[object Object]
Welke piep eigenlijk? Het kan aan mij liggen, maar ik hoor niets. Ik hoor alleen een piep bij het remmen.
  • Red Baron
Red Baron
JoepW schreef op woensdag 23 december 2015 @ 12:22:
:? Ik neem aan dat je toch gewoon een browser plugin gebruikt en niet echte webbrowser vensters opstart om die vervolgens te gaan capteren met windows capture ofzo?
Niellie41 schreef op woensdag 23 december 2015 @ 17:03:
ik hoor een continue interfererend geluid. Lijkt mij ook precies een netsignaal te zijn dat stoort oid
  • JoepW
JoepW
Red Baron schreef op woensdag 23 december 2015 @ 17:09:
nee. Ik had alleen moeite met goed sizen met de plugin.
  • Niellie41
Niellie41
[object Object]
Verwijderd schreef op woensdag 23 december 2015 @ 17:16:
Ah dat, wanneer het helemaal stil is. Ik het begin meteen overgeslagen. :P Tijdens het rijden hoorde ik in ieder geval geen gepiep.
ik hoor het onder het rijden ook (super oren denk ik, of gewoon jaren van al dat kabaal weg gebleven :D)
  • ThunderNet
ThunderNet
Flits!
Hebben er meer mensen last van dat er onder in beeld slechts 1 iRacing online staat, en 0 myRacers?
Heb je liever vooraf, of achteraf, dat ik zeg dat ik geen flauw idee heb wat ik doe?
  • nickkoole
  • Laatst online: 18-11-2024
FransJansen schreef op woensdag 23 december 2015 @ 11:15:
[video]
Hier een link naar de iracing forumpagina waar ook de zipfile te downloaden is voor camera beelden: http://members.iracing.com/jforum/posts/list/1991828.page
iRacing Profiel
  • nickkoole
Fuelke schreef op woensdag 23 december 2015 @ 16:42:
lijkt me wel gaaf, ik ga wat practice doen maar ofdat de race ook daadwerkelijk komt weet ik niet, probeer wel een sof race mee te pakken als ik gaat race
iRacing Profiel
  • JoepW
JoepW
ThunderNet schreef op woensdag 23 december 2015 @ 17:43:
Bug...
Of eigenlijk. Ze hebben het uitgezet om de site sneller te maken..... Helpt alleen niet.
[ Voor 16% gewijzigd door JoepW op 23-12-2015 18:16 ]
  • -PassY-
-PassY-
Ik denk iedereen. Is namelijk vaker gebruikt om de website/database/backend te ontlasten
  • JoepW
JoepW
Niellie41 schreef op woensdag 23 december 2015 @ 17:21:
Het is volgens mij het 5.1 kastje van mijn headset. Want met eenander kabeltje naar mijn stereo doet ie het ook. Het signaal komt optisch daar, dus lijkt mij het kastje de boosdoener. :(
  • JoepW
JoepW
Doet bij jullie dit het: http://members.iracing.co.../member/LeagueSessions.do
Edit: na 10x proberen wel.... :)
NES/GES server is up.
[ Voor 25% gewijzigd door JoepW op 23-12-2015 20:07 ]
  • Salandur
Salandur
Software Engineer
JoepW schreef op woensdag 23 december 2015 @ 09:59:
Welkom!
Drie tips:
  1. Veel oefenen
Dank je! Ik was zowiso van plan om, als ik tijd heb, me aan te sluiten bij de Driving school. Lijkt me uitermate leerzaam.
[b]JoepW schreef op woensdag 23 december 2015 @ 09:59:(Ennuh misschien ff een link naar je iRacing Profiel plaatsen in je handtekening hier. Uitleg hoe)
Done :)
  • bluuuurgh
  • Laatst online: 23-08 22:47
Wat fijn bij de Nurburgring als je een opwarmrondje doet in de Lotus en dan in rondje 1 na 4/6 bochten er keihard vanaf knalt :D
iRacing Profiel
  • aicaramba
  • Laatst online: 19-09 11:20
bluuuurgh schreef op woensdag 23 december 2015 @ 20:41:
Klinkt als mijn meeste pogingen!
CS:GO Stats | DotA 2 Stats | iRacing Profiel
  • HeAdWaVe74
  • Laatst online: 14-11-2022
JoepW schreef op woensdag 23 december 2015 @ 20:06:
bij mij doet niets het
Edit : o, toch wel.. .duurt alleen erg lang
Edit2 , like a lifetime... i give up
[ Voor 12% gewijzigd door HeAdWaVe74 op 23-12-2015 21:49 ]
iRacing Profiel
  • Nickrsd
  • Laatst online: 08:08
op mn pc draait iracing wel aardig.. maar die nieuwe track nurburgring kan hij slecht verteren.. flinke fps drops naar 35/40. grahics staan op medium ingesteld ongeveer.. jmmr
  • derx666
  • Laatst online: 30-10 16:12
derx666
mecker ende blaet
ok
BMC Roadmachine Two (2024)
Colnago CLX evo di2 (2021)
Cube Nuroad Race (2022)
  • PatrickPost1972
  • Laatst online: 14-06-2024
Die camerapack is echt gaaf hier een klein voorbeeld (niet de beste kwaliteit).
[YouTube: https://youtu.be/NgV0ZEoHUUk]
iRacing Profiel Game Pc
  • DarkPino
Er waren plannen om met een groepje te participeren in de mp4-30 toch? Is daar nog iets van terecht gekomen?
iRacing Profiel
  • JoepW
JoepW
PatrickPost1972 schreef op donderdag 24 december 2015 @ 03:57:
[video]
Mooie camera posities!
  • PatrickPost1972
Zeker alleen de kwaliteit van de video vind ik zwaar tegenvallen maar eens zoeken naar een goed gratis alternatief om dit wel goed te krijgen. Zie hier op de site betere kwaliteit voorbij komen.
De password-reset functie doet het niet op de GoT site !
http://www.got-racing.eu/wp/?page_id=514
Ik ontvang geen emails, gister avond paar keer geprobeerd en zojuist ook weer :'(
  • JoepW
JoepW
Verwijderd schreef op donderdag 24 december 2015 @ 10:25:
Ik stuur je wel ff een nieuw ww. Ik heb me nooit in die code verdiept. Misschien is er iemand die PHP prammer is en er eens goed naar kan kijken. Op de verlanglijst staat sowieso nog eens ene integratie van al onze sites ;)
Ik heb de overlay nu aangepast. Is wel heel flexibel hoor.
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/22265537/topic_2016/layout_broadcast_t.png
  • PatrickPost1972
JoepW schreef op donderdag 24 december 2015 @ 10:36:
Heb jij een kleine energie centrale in de kelder, of gaat de verlichting even dimmen als je de powerknop omzet :+
Dankje Joep! Heb je mijn email ?
  • JoepW
JoepW
PatrickPost1972 schreef op donderdag 24 december 2015 @ 10:46:
Ik kan idd de boel niet in een keer aanzetten en mijn electra-rekening is ook heftig, maar dat komt door 2x kantoor aan huis.
Ik heb geen mail van jou ontvangen. Stuur anders ff je gewenste email per mail aan me dan stel ik dat in: joepw(AT)got-racing.eu
Ziet er goed uit. ik ga volgende week ook eens in de JRT kijken, naar wat ik gelezen heb kan je het in config bestanden aanpassen. Vraag gaat alleen zijn of mijn pc het allemaal gaat trekken :X :D
Done!
  • JoepW
JoepW
Verwijderd schreef op donderdag 24 december 2015 @ 10:57:
Daarom heb ik een aparte PC. Enkel de server die de webserver op basis van de telemetry stuurt draait op mijn Race PC. OBS en de webcam zitten op een aparte I5 PC.
in het kader van "Hoe zou een NASCAR auto het doen op de Nordschleife?". De cup viel een beetje tegen door de stuiter setup. De xfinity was dikke fun! :9~
  • JoepW
JoepW
Verwijderd schreef op donderdag 24 december 2015 @ 11:02:
[video]
_/-\o_ :D
  • deRidder
  • Laatst online: 03-09-2025
[video]
Haha, je probeert niet eens voorzichtig te doen. Gewoon raggen met dat ding!
Daarom is het ook één van de leukste auto's van de service. 8)
  • JoepW
JoepW
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/22265537/topic_2016/newyear2016.png
  • PatrickPost1972
[video]
Seizoensfinale Got :9 :o :+
  • DirkT
DirkT
toet
Sign me up! RWD op de ring is echt fantastisch!
iRacing profiel - FanaLEDs voor je racesimulatie displays en meer!
Vraagje, hoe krijg je filmpjes van een race zoals hierboven zo simpel mogelijk op het forum ?
  • nickkoole
PatrickPost1972 schreef op donderdag 24 december 2015 @ 09:57:
OBS is goed alternatief, hiermee kan je streamen maar ook recorden
link naar OBS https://obsproject.com/
link naar OBS om te zien wat je systeem aan kan en best perfomance https://obsproject.com/estimator
link naar settings guide OBS http://help.twitch.tv/cus...open-broadcaster-software
iRacing Profiel
  • PatrickPost1972
nickkoole schreef op donderdag 24 december 2015 @ 17:30:
Klopt heb wat zitten knutselen tot nu toe hehehe maar dan heb je ook wat, nu wat betere kwaliteit.
Mijn recording profile voor OBS heb ik klaar, nu nog mijn streaming profile maar daar ga ik morgen mee verder :+ :+ :+
[YouTube: http://www.youtube.com/watch?v=S6iFoYHPKbw]
[YouTube: http://www.youtube.com/watch?v=q5EgAbAmBmc]
[ Voor 8% gewijzigd door PatrickPost1972 op 24-12-2015 18:10 ]
  • NickThissen
  • Laatst online: 08-08 16:09
NickThissen
DarkPino schreef op donderdag 24 december 2015 @ 07:56:
Ik heb nog bijna elke avond wel even geoefend maar heb niemand anders gezien... Voor mij is het ook een beetje lastig een vaste avond te vinden met maandag t/m woensdag eigenlijk al bezet, donderdag meestal geen tijd en vrijdag is alweer veel te laat om te beginnen. Dus ik oefen meestal eventjes voor of na onze eigen hosted dingen, niet echt lang aan een stuk.
Daarbij is mijn oefenen momenteel niet veel meer dan hopeloos op wat settings klikken en maar weer wat rondjes doen zonder enig verschil te voelen :+ Ik heb werkelijk geen idee waar ik heen moet met de setup, zelfs niet welke downforce ik moet pakken.
[ Voor 17% gewijzigd door NickThissen op 24-12-2015 18:24 ]
  • A1AD
Salandur schreef op woensdag 23 december 2015 @ 20:17:
Zeker doen, het was echt heel leuk vorige keer. Tip: Headset met mic. :)
  • The_FrankO
Ik gebruik zelf NVidia Shadowplay, 1080p 60fps is geen enkel probleem, het kost ongeveer 5fps. Shadowplay is echter zeer beperkt, bijvoorbeeld geen overlay mogelijkheden. Volgens mij ook geen drie schermen mogelijkheid, of zoals Joep doet met de webcam.
Tijdje terug had ik OBS geprobeerd maar was niet tevrede over de kwaliteit en performance. Opnemen in 1080p en 60fps gaf geen vloeiend beeld. Erg jammer want ik wilde zelf ook wat met de overlays gaan doen. :|
  • JoepW
JoepW
Ik zal binnenkort eens op 60 FPS testen...
  • Salandur
Salandur
Software Engineer
A1AD schreef op donderdag 24 december 2015 @ 18:56:
Die heb ik, moet alleen nog even teamspeak up to date brengen en een push-to-talk button vinden en instellen
  • DarkPino
NickThissen schreef op donderdag 24 december 2015 @ 18:22:
Zullen we samen wat doen? Ik heb me ingeschreven op de Apex Academy en daar leer ik al veel, maar denk dat we samen ook een eind kunnen komen?
iRacing Profiel
  • NickThissen
NickThissen
Is goed.. Voor deze week ben ik eigenlijk wel klaar met de setup, wat ik ook doe hij wordt niet beter. Zat net in een server met redelijk snel weer en toen ging het wel goed. Hier de Q en R setups:
Race: http://iracingsetupsync.nickthissen.nl/Setups/Details/12894
Qualy: http://iracingsetupsync.nickthissen.nl/Setups/Details/12893
En replays van een Q en R rondje:
Q rondje: https://dl.dropboxusercon...309718/McF1_16S1_W2_Q.rpy
R rondje: https://dl.dropboxusercon...309718/McF1_16S1_W2_R.rpy
Kijk je niet blind er op, vooral Q rondje is niet zo goed (eerste keer met Q setup), ik laat nog veel tijd liggen.
  • DarkPino
Wat voor tijd was het? Ga vanavond even proberen te kijken. Ben nu aan het werk :)
Merk zelf dat ik (nog) niet echt goed ben in hotlappen. Moet erg wennen aan het extra vermogen als je ERS op 1 zet (rijdt op Montréal meestal op 5/6)
iRacing Profiel
  • NickThissen
NickThissen
Staat bij de setups ;) 17.3 R en 15.7 Q maar daar kan nog zeker wat vanaf. Dat extra vermogen in Q is ook vervelend ja, vooral uit T2 wil hij soms halverwege de "straight" in de 4 nog wel spinnen. Ik weet ook nog helemaal niet of ik een Q ga doen, ligt eraan in welke grid ik terecht kom wanneer ik ga racen. Beviel me goed vorige keer om achteraan te starten.
  • ThunderNet
ThunderNet
Flits!
blegh, weer eens een remsensor van de pedalen stuk... :/ altijd fijn in een race :X
  • ThiJor
Prettige feesten allemaal! o<:)
  • NickThissen
NickThissen
Fijne feestdagen! :)
  • BobvK
  • Laatst online: 18-09-2022
Fijne feestdagen allemaal! o<:)
Gisteren 2 races gedaan in de Skip, maar wat een onderstuurd hok is dat geworden dit seizoen. Kon je hem eerder nog een beetje beter laten insturen door te spelen met het gas, nu moet je hem een beetje de bocht inremmen om hem te laten sturen, en vooral wachten met gas geven. Totaal de omgekeerde wereld 8)7
Ondanks dat de auto minder leuk is geworden wel leuk geracet gisteren, dat wel. 1 race constant in gevecht geweest voor de overwinning met 2 andere. Uiteindelijk 2de geworden nadat ik in de laatste ronde werd verschalkt in de Corkscrew. Andere race na een slechte kwalificatie naar voren moeten werken om uiteindelijk 3de te worden.
Updates aan je rig showen? > Het grote 'show je race-rig' topic
Je (racing)hardware (en mods) bespreken? > Racesturen, servo's en pedalen
Advies nodig voor de aankoop van een nieuwe pc voor iRacing? > Desktop Aankoopadvies
Advies over de aankoop/update van enkele onderdelen van je pc voor iRacing? > Componenten Aankoopadvies
