Reg. datum: 21 maart 2002
You are the network administrator for Testking.com. The network consists of a single Active Directory
forest containing two domains, hq.hmopslab.com and mm. hmopslab.com. The function level of both
domains is Windows 2000 mixed. hq.hmopslab.com contains 2 domain controllers running Windows
Sever 2003 and 3 domain controllers running Windows 2000 server.You are the network admin for hq.hmopslab.com. Users in your domain require access to applications and shared folders that reside on member severs in mm.hmopslab.com. You need to create a group in hq.hmopslab.com that will provide the required access.
What should do you?
Ik zou dus zeggen Domain Local - Security gezien er op hq.hmopslab.com rechten gegeven moet worden.. "Users in your domain require access to applications and shared folders that reside on member severs in mm.hmopslab.com"
" 1 muis maakt nog geen piepshow ! "
