DIY Ambilight howto?
Pagina: 1 ... 18 ... 63 Laatste
  • 669.220 views sinds 30-01-2008
  • Pistolen_Paul
  • Laatst online: 22-11 08:41
Foutbucket 487578253, type 5
Naam van gebeurtenis: CLR20r3
Antwoord: Niet beschikbaar
Id van CAB-bestand: 0
Handtekening van probleem:
P1: ambilight.exe
P2: 1.0.0.0
P3: 498c31ce
P4: Microsoft.DirectX.Direct3D
P5: 1.0.2902.0
P6: 42056de2
P7: 64d
P8: 4d
P9: QCY4DIB5O25PGM21GWVR3WY1CSEKPR3H
P10:
Ik heb visual studio 2008 geïnstalleerd staan, daarmee was meteen .net framework (2, 2.5, 3 en 3.5) geïnstalleerd.
hmm:
http://www.dotnetspider.c...tType-clr-r-Solution.aspx
Introduction
EventType clr20r3, P1 picreationprocess.exe, P2 1.0.0.0, P3 47dac8ad, P4 picreationprocess, P5 1.0.0.0, P6 47dac8ad, P7 18, P8 7, P9 system.io.filenotfoundexception, P10 NIL.
Source:
If you create a console application in .Net and XP environment, the .exe of the application can be run on the local machine without any errors. When trying to copy the files and folders from the local machine to a Server (Windows 2003 Server) and try to run the same exe it will throw the above specified error.
Solution:
Windows 2003 Server has lot of security related configurations which is a nightmare and one such thing with the server is it needs all the *.dll files in the bin directory of the project. If the files are not in the directory then it will throw the error. So when copying the files and folders make sure you copy all the dependencies (all the referenced class libraries, dlls, references, etc.,) along with them. Copy the "System" related dlls files as well.
Summary
There are several reasons for the above error and this is one such reason in the myriad of reasons. Please feel free to contact me if you have any questions related to this article
EDIT 2:
Debuggen met visual studio 2008 gaf de volgende melding:
LoaderLock was detected
Message: Dll C:\Windows\assembly\GAC\Microsoft.DirectX.Direct3D\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3D.dll is bezig met een poging tot uitvoering met begeleiding binnen OS Loader-vergrendeling. Probeer geen code met begeleiding uit te voeren binnen een DllMain- of afbeeldingsinitialisatiefunctie, omdat de toepassing hierdoor kan vastlopen
Windows lijkt dus bepaalde dingen te blokeren, het is dus een soort van beveiliging die het programma laat vastlopen...
[ Voor 73% gewijzigd door Pistolen_Paul op 25-01-2010 21:34 ]
  • happyguppy
  • Laatst online: 13-11 23:46
DGTL_Magician schreef op zaterdag 09 januari 2010 @ 17:40:
Mijn broertje en ik hebben allebei een AmbX setje gekocht. Nu draait hij Mac OS en ik Linux dus is dat niet heel erg ideaal :P
Wij hebben een Mac/Linux aansturing gemaakt op basis van Ruby-USB, www.sexybiggetje.nl/moblo...quence-with-combustd.html
Dit bestaat uit verschillende componenten, er is een setcolor.rb die alle lampen tegelijk op 1 RGB kleur zet en een boblight.rb die luistert naar de popen output van boblight. Op deze manier is het AmbX setje ook prima te gebruiken.
Nog ff een videotje van mijn setup:
[video]
Ik ben al een tijdje op zoek om een AmbX setje op Mac OS te draaien voor films, als ik dit goed begrijp heb jij dit voor elkaar gekregen?
Zo ja, dan zou ik graag wat meer uitleg zien hoe ik dit zelf voor elkaar kan krijgen :)
  • Pistolen_Paul
System.BadImageFormatException was unhandled
  Message="Poging om een programma te laden met een onjuiste indeling. (Uitzondering van HRESULT: 0x8007000B)"
  Source="AmbiLight"
  StackTrace:
       bij AmbiLight.USBAPI._MPUSBOpen(UInt32 instance, String pVID_PID, String pEP, UInt32 dwDir, UInt32 dwReserved)
       bij AmbiLight.USBAPI.OpenPipes() in E:\Projectjes\Leon Ambilight\nieuwere versie\KDVken\AmbiLight_src\USBAPI.cs:regel 50
       bij AmbiLight.USBAPI.SendPacket(Byte* SendData, UInt32 SendLength) in E:\Projectjes\Leon Ambilight\nieuwere versie\KDVken\AmbiLight_src\USBAPI.cs:regel 67
       bij AmbiLight.USBAPI.UpdateAllColor(UInt32 RLB, UInt32 GLB, UInt32 BLB, UInt32 RLT, UInt32 GLT, UInt32 BLT, UInt32 RTL, UInt32 GTL, UInt32 BTL, UInt32 RTR, UInt32 GTR, UInt32 BTR, UInt32 RRT, UInt32 GRT, UInt32 BRT, UInt32 RRB, UInt32 GRB, UInt32 BRB) in E:\Projectjes\Leon Ambilight\nieuwere versie\KDVken\AmbiLight_src\USBAPI.cs:regel 138
       bij AmbiLight.AmbiLight.SendData() in E:\Projectjes\Leon Ambilight\nieuwere versie\KDVken\AmbiLight_src\AmbiLight.cs:regel 754
       bij AmbiLight.AmbiLight.CaptureTimer_Tick(Object sender, EventArgs e) in E:\Projectjes\Leon Ambilight\nieuwere versie\KDVken\AmbiLight_src\AmbiLight.cs:regel 122
       bij System.Windows.Forms.Timer.OnTick(EventArgs e)
       bij System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       bij System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       bij System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       bij System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       bij System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       bij System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       bij AmbiLight.Program.Main() in E:\Projectjes\Leon Ambilight\nieuwere versie\KDVken\AmbiLight_src\Program.cs:regel 19
       bij System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       bij Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       bij System.Threading.ThreadHelper.ThreadStart()
  InnerException:
Bij het debuggen van het programma krijg ik bovenstaande foutmelding...
op regel van USBAPI.cs:
myOutPipe = _MPUSBOpen(selection, vid_pid_norm, out_pipe, 0, 0);
  • KDVken
  • Laatst online: 05-11-2023
Pistolen_Paul schreef op dinsdag 26 januari 2010 @ 20:38:
Heb jij mijn usb versie nagemaakt?
De ambilight64.rar is normaal voor mijn usb versie.
Van de BoblightDX heb ik geen 64-bit versie denk ik.
  • Pistolen_Paul
Ik heb jou source gepakt en geprobeert te debuggen, dat terwijl deze setup werkte onder windows vista 64bit (zelfde pc, hardware etc).
ok, dit maakt mij bedroeft, programma gedownload en op een andere computer gezet (windows 7, 64bit).
En het programma werkt...
Op mijn eigen pc:
Ik krijg nu ook een andere error:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
Zie het einde van dit bericht voor meer informatie over het aanroepen
van JIT-foutopsporing (Just In Time) in plaats van dit dialoogvenster.
************** Tekst van uitzondering **************
System.BadImageFormatException:  is geen geldige Win32-toepassing. (Uitzondering van HRESULT: 0x800700C1)
   bij AmbiLight.AmbiLight.AmbiLight_Load(Object sender, EventArgs e)
   bij System.Windows.Forms.Form.OnLoad(EventArgs e)
   bij System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   bij System.Windows.Forms.Control.CreateControl()
   bij System.Windows.Forms.Control.WmShowWindow(Message& m)
   bij System.Windows.Forms.Control.WndProc(Message& m)
   bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladen assembly's **************
mscorlib
    Assembly-versie: 2.0.0.0
    Win32-versie: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
AmbiLight
    Assembly-versie: 1.0.0.0
    Win32-versie: 1.0.0.0
    CodeBase: file:///E:/Projectjes/Leon%20Ambilight/nieuwere%20versie/KDVken/AmbiLight_src/bin/x64/Release/AmbiLight.exe
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
mscorlib.resources
System.Windows.Forms.resources
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_nl_b77a5c561934e089/System.Windows.Forms.resources.dll
************** JIT-foutopsporing **************
Als u JIT-foutopsporing wilt inschakelen, moet in het configuratiebestand voor deze
toepassing of computer (machine.config) de waarde
jitDebugging in het gedeelte system.windows.forms zijn ingesteld.
De toepassing moet ook zijn gecompileerd terwijl foutopsporing
was ingeschakeld.
Bijvoorbeeld:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
Wanneer JIT-foutopsporing is ingeschakeld, worden onverwerkte uitzonderingen
naar het JIT-foutopsporingsprogramma gestuurd dat op de computer is geregistreerd
en worden niet door dit dialoogvenster verwerkt.
  • Pittie
  • Laatst online: 07:18
Pittie schreef op dinsdag 08 december 2009 @ 16:41:
Hier is zeker nog steeds geen oplossing voor :'( ?
Vandaag nog iets opgemerkt, omdat ik zelf nog niet geprobeerd had met Vista Media Center, vandaag eventjes vista geinstalleerd om te kijken of het werkt. Dus hup vista erop, boblight erop, driver geinstalleerd voor de ambilight en hop we hebben een werken ambilight.
Media center opgestart en waarempel, de leds gaan niet uit! Maar blijven netjes blauw (zoals hoort bij het begin scherm van mediacenter). Echter omdat ik nog geen videodriver had geinstalleerd kon ik geen filmpjees afspelen, wel de plaatjes afspelen en dan kleurt de ambilight mooi mee!
Daarna toch maar de videokaartdriver geinstalleerd, nieuwste variant vanaf de Nvidia site, reboot zoals gevraagd... Windows media center weer opgestart... leds uit :(
Zodra de videokaart driver geinstalleerd wordt kapt ie er dus mee :(
  • Pistolen_Paul
hmm, als ik settings.xml verwijder dan start het programma wel, maar de verlichting doet nog niets.
Een andere error nadat ik de videodriver (ATI) gedeinstalleerd had.
Message: Dll C:\Windows\assembly\GAC\Microsoft.DirectX.Direct3D\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3D.dll is bezig met een poging tot uitvoering met begeleiding binnen OS Loader-vergrendeling. Probeer geen code met begeleiding uit te voeren binnen een DllMain- of afbeeldingsinitialisatiefunctie, omdat de toepassing hierdoor kan vastlopen.
:o
Het probleem gevonden:
Het heeft iets te maken met mijn tweede scherm wat ook aan deze pc zit.
Haal ik het 2e scherm eraf dan werkt het programma gewoon.
[ Voor 82% gewijzigd door Pistolen_Paul op 27-01-2010 23:26 ]
  • LED-Maniak
  • Laatst online: 07:30
Brrr, ik heb dit weekend het voor elkaar gekregen om direct de output van een DVD-speler in een controller te stoppen die living colors lampen aanstuurt. Werkt allemaal leuk en aardig, alleen de kleuren van die livingcolors krijg ik niet goed.
Zolang er een enkele kleur in beeld is, gaat alles perfect en heb je redelijk mooie kleuren. Maar zodra er maar iets van groen in zit, krijg je direct dat groen overheerst en hij er wit van wil maken(wat living colors ook niet kan want dan krijg je geel/wittig).
Op gewone RGB LED-Strips werkt het overigens wel perfect..
[ Voor 5% gewijzigd door LED-Maniak op 13-02-2010 16:18 ]
  • Wharfedale
  • Laatst online: 14-10 09:34
Zijn er eigenlijk mogelijkheden om ambilightapparaatje aan te sluiten op een hdmiuitgang? Voor bv. tussen een mediastreamer en een tv?
Zal wrs niet zijn met de beveiligingen maar ik dacht: ik zal eens aan de specialisten vragen.
  • LED-Maniak
Dat kan, maar niet direct. Moeten eerst 2 converters tussen.
  • Compizfox
  • Laatst online: 21-11 21:37
Compizfox
Bait for wenchmarks
Ik hoop dat dit in dit topic thuis hoort, want ik heb een probleem met Boblight (en Cobustd) onder Linux.
Ik heb een amBX set, die prima werkt onder Windows, al helemaal met Aurora Synesthesia. Alleen, ik dual-boot met Ubuntu dus wil de amBX set ook onder Ubuntu aan de praat hebben.
Dit lukt me met Boblight en CombustD, via deze how-to: http://code.google.com/p/combustd/wiki/ConfiguringBoblight
Ik heb alles gecompileerd gekregen en het werkt zelfs!
Het probleem is dat hij er wel heel erg traag van wordt, er is bijna niet meer mee te werken. Ongeveer om de seconden heb ik een soort van FPS drop, dan hangt het systeem voor ongeveer een paar milliseconden.
Heeft iemand hier een oplossing voor?
Het zou me zelfs al redelijk blij maken als je gewoon 1 vaste kleur of een soort overgang (wat je bij de amBX onder Windows ook hebt, die scenes) kon instellen, want het lijkt me dat de traagheid komt door het 'capturen' van het beeld.
Systeem specs:
E5300 @ 3.9 GHz
HD3850
2 Gig ram
[ Voor 20% gewijzigd door Compizfox op 22-02-2010 13:44 ]
Gewoon een heel grote verzameling snoertjes
  • bobo1on1
  • Laatst online: 19-10-2025
Geef eens de -x flag mee aan boblight-X11.
Impedance, a measure of opposition to time-varying electric current in an electric circuit.
Not to be confused with impotence.
  • Compizfox
Compizfox
Bait for wenchmarks
Dankje, nu werkt het bijna perfect! Bijna perfect, want het lijkt alsof hij te veel blauw weergeeft. De lampen worden ook wel rood, bijvoorbeeld als ik een puur rood beeld op zet. Maar meestal zijn de lampen vooral blauw. Is hier iets aan te doen, de witbalans instellen of iets dergelijks?
EDIT: Laat maar, ik denk dat ik al aardig heb gevonden wat ik wilde met de -s setting. Als je -s 40 doet is het al een heel stuk beter :)
[ Voor 19% gewijzigd door Compizfox op 22-02-2010 17:19 ]
  • bobo1on1
Hm jij hebt duidelijk niet de versie van http://code.google.com/p/boblight/
  • Compizfox
Compizfox
Bait for wenchmarks
Klopt, ik heb hem van http://blogger.xs4all.nl/loosen/articles/408184.aspx
De versie van http://code.google.com/p/boblight/ gaf fouten met het compileren, programmeerfoutjes in de code.
  • emiel.h
  • Laatst online: 22-07 21:15
Een paar dagen terug heb ik m'n momolight project eindelijk weer tevoorschijn gehaald nadat ik er ongeveer een jaar geleden aan was begonnen volgens deze howto http://divxstation.com/article.asp?aId=151
Helaas kreeg ik het niet werkend en heb ik het weggelegd.
Nu ben ik alle verbindingen nog maar eens goed gaan nakijken en toen bleek dat ik de Vss van de pic was vergeten te solderen. |:( Dat heb ik nu gedaan en eindelijk werkt het!
Ik draai hier Windows 7 x64 en gebruik boblight om de lichten aan te sturen. Het nadeel is dus dat ik elke keer aero uit moet zetten als ik de lampen aan wil doen. Verder werkt het met games ook wat minder aangezien de lampen maar eens in de zoveel seconden gerefreshed worden.
Nu zag ik dat KDVken boblight aan heeft gepast met directx waardoor aero gewoon aan kan blijven en het met games beter werkt.
Dat zou voor mij ideaal zijn maar helaas is er geen 64 bit versie...
Ik vroeg mij af of die nog gemaakt kan worden, ik weet niets af van programmeren en dus ook niet hoeveel tijd het kost om zoiets om te zetten in 64 bit.
  • Pistolen_Paul
Er is een 64 bit versie:
KDVken schreef op dinsdag 10 maart 2009 @ 09:59:
Ik heb het nooit getest onder 64-bit, dus het zou héél goed kunnen dat het niet draait.
Ik heb net een nieuwe pc in elkaar gestoken en er staat ook 64-bit op, dus ik zal toch binnenkort eens moeten kijken om het laten werken op 64-bit :)
Nog even geduld dus.
64-bit versie: http://uterror.dommel.be/ambilight/AmbiLight64.rar
  • emiel.h
maar die werkt toch alleen voor zijn usb ambilight?
ik bedoelde deze http://uterror.dommel.be/ambilight/BobLightDX.rar
die zou ik graag in 64 bit willen zien ;)
  • KDVken
Hi,
Ik heb inderdaad nooit een "64-bit" versie gemaakt van dat programma.
De source had ik zelf ook niet meer, maar heb het snel even opnieuw gemaakt met de originele Boblight source.
http://uterror.dommel.be/ambilight/BobLightDX64.rar
Het is niet exact hetzelfde als de USB versie, maar het zou moeten werken (hopelijk). Probeer het en laat maar weten ;)
Greetz.
  • Compizfox
Compizfox
Bait for wenchmarks
Zijn http://code.google.com/p/boblight/ en http://blogger.xs4all.nl/loosen/articles/408184.aspx eigenlijk ook van jou? Of zijn er meerdere projecten met dezelfde naam en functie?
  • emiel.h
KDVken schreef op donderdag 25 februari 2010 @ 20:14:
Hi,
Greetz.
Dankjewel, dat heb je erg snel gedaan!
Helaas werkt het voor mij nog niet goed met aero.
Het lijkt erop dat door jouw directx toevoeging dwm.exe veel meer geheugen nodig heeft (ik heb pieken gezien tot1,6 gb) en dan krijg ik dit soort foutmeldingen http://img36.imageshack.us/img36/7632/aerodk.jpg of aero gaat vanzelf uit.
Maar als aero eenmaal uit is vind ik hem wel beter werken dan eerst, in games worden de veranderingen op het beeld een stuk sneller doorgegeven aan de lampen waardoor ik het effect een stuk beter vind.
Ik kwam net toevallig nog een aangepaste boblight tegen die met directx werkt.
Verwijderd schreef op vrijdag 31 juli 2009 @ 14:23:
Hi
I don't understand Your language but I would like to share my App which is based on BobLight written by Bob van Loosen and continued by me but with new name epiLight.
How it works?
It is designed to work with Windows Vista (i didn't tested it with XP), so it is using DirectX 9 to screen capture through FrontBufferData which isn't super fast but works much faster than GDI32 screen capture or even CopyFromScreen function. There is also Auto enable function which detects process name and than it is Disabling Aero and starting to work.
You can download app here: http://itlite.pl/epiLightDX/epiLightDX.zip
Source of this app is here: http://itlite.pl/epiLightDX/epiLightDX_src.zip
Ik zou deze software ook graag willen uitproberen maar helaas doen de links het niet meer, heeft iemand dit programma nog?
  • bobo1on1
Compizfox schreef op donderdag 25 februari 2010 @ 20:32:
Die zijn beide van mij.
Wat voor probleem had je precies met het compilen? Want het werkt hier gewoon prima.
  • Compizfox
Compizfox
Bait for wenchmarks
OK, http://code.google.com/p/boblight/ en http://blogger.xs4all.nl/loosen/articles/408184.aspx zijn dus van jou, en KDVken heeft een gelijkwaardig programma met dezelfde naam, maar dan voor Windows?
Hmm, ik weet het niet precies meer, maar ./configure ging gewoon goed. Ik moest nog wel wat dependencies installeren natuurlijk. Bij make ging het verkeerd; hij gaf allemaal syntax errors in de code aan. Toen heb ik dus maar een andere versie gezocht, deze dus http://blogger.xs4all.nl/loosen/articles/408184.aspx
  • bobo1on1
Je hebt waarschijnlijk de verkeerde versie van portaudio geinstalleerd.
  • Compizfox
Compizfox
Bait for wenchmarks
Het zou zomaar kunnen. Raar dat je daardoor syntax errors krijgt bij het compileren.
Maar het draait nu allemaal prima hoor! Wat is het verschil eigenlijk tussen die versies?
[ Voor 6% gewijzigd door Compizfox op 26-02-2010 15:48 ]
  • LED-Maniak
[YouTube: http://www.youtube.com/watch?v=dCo7SHyXuoI]
Nieuw videotje van stand-alone TV-Set. Een PC is dus niet nodig.
Kleur is wel erg afhankelijk van de compressor die er een DVD van maakt. Soms komt het niet precies overeen maar dat komt vooral omdat die compressor van zwart beeld lichtelijk groen beeld maakt.
  • KDVken
Compizfox schreef op vrijdag 26 februari 2010 @ 10:38:
Het programma dat ik hier gezet heb is ook NIET van mij :)
Ik heb het slechts een klein beetje aangepast. Ook de windows versie is van Bobo _/-\o_
@emiel.h
Gebruikt die USB versie ook zoveel geheugen met aero aan?
  • emiel.h
Ja, als ik de usb versie aanzet (zonder dat dan mijn lampen aangaan natuurlijk) gebruikt dwm evenveel geheugen als met de seriële versie.
Ik heb al wel gemerkt dat als ik hem op "gaming mode" zet het geheugengebruik maximaal op 700mb komt en niet meer bij de 1,6gb van wanneer hij op "movie mode" staat. Ook werkt windows met "gaming mode" beter, bij het verslepen van vensters bewegen ze vloeiender over het scherm dan met "movie mode".
Toch schakelt windows met "gaming mode" aero ook uit. Ik heb trouwens 4gb geheugen in m'n pc.
  • hardware.tom
  • Laatst online: 17-08 23:32
Hallo
Ik ben toch weer van plan om verder te gaan maar kan iemand samenvatten wat ik allemaal nodig heb (link naar downloads enzo?), dus:
  • schema programmer
  • schema ambilight ding 8)7 (met de pic dus)
  • De pic (een PIC16f628A?)
  • En de .hex file
Heb ik nog meer nodig?
En het liefst de simpelste programmer voor een PIC16f628A. Ik heb al rond gekeken maar sommige hebben veel onderdelen (duur) en sommige weer weinig en ik heb geen idee wat goed is.
Sorry ik ben een beetje een Noob in programmeren, maar ik wil het wel graag leren...
  • AIex
  • Laatst online: 03-01-2025
Voor de mensen die een Ambilight op hun PC scherm willen zetten: ik heb onlangs een ambilight gemaakt voor mijn 24" scherm.
Afbeeldingslocatie: http://www.avalondesigns.nl/photo.jpg
Ik heb hiervoor RGB Ledstrips gebruikt die ik over had van een project en op te knippen waren in stukken van 10cm. Mijn resolutie is 6 strips boven,onder; 4 links rechts.
Dit wordt aangestuurd door een arduino (Duemilanove) bordje en TLC5940 LED drivers.
De arduino maakt gebruik van de arduino library voor de TLC5940 en de rest van de code is zelf geschreven. Een python script bepaalt welke kleuren er naar de arduino gestuurd worden en heeft een refreshrate van rond de 10-12Hz.
Het werkt (nog) niet met (alle) spellen maar films werken er erg goed mee!
In principe alles waar je een printscreen van kan maken werkt met dit systeem.
[ Voor 4% gewijzigd door AIex op 06-04-2010 00:30 ]
  • LED-Maniak
ook met aero aan?
  • DP Kunst
  • Laatst online: 22-11 20:16
Zo aan de foto te zien wel ;).
Mijn nieuwe portfolio (Under Construction) | Benieuwd wat Solar Team Twente gaat doen?
  • Pittie
maar misschien nog wel belangrijker, werkt het ook met het mediacenter van windows 7 (A)?
  • vandeGerrit
  • Laatst online: 01-11 00:03
vandeGerrit
Well, this can't be right
AIex schreef op dinsdag 06 april 2010 @ 00:27:
Nope, dat het nu met Aero werkt, zoals op de foto kan, maar dan is of de CPU heel hoog. Dit komt door de methode. Alles waarvan je een printscreen kan maken werkt op basis van schermen die ook bij de CPU bekend zijn. Van spellen met AA, en ook MediaCenter, zijn de beelden enkel bij de GPU bekend dan moet je via een moeilijke methode achter halen. Anders als dus een printscreen.
  • AIex
In windows media player (win vista) werkt het prima, ook VLC geen problemen. Ik ga na mn vakken kijken of ik een andere methode kan gebruiken om de screenshots te maken maar mn eerste testjes met GTK zijn ontzettend traag...
De CPU wordt idd goed gebruikt, 1 van mn 8 (i7 HT) cores is maxed out maar daar merk je niets van tijdens full HD film kijken.
EDIT: aero staat idd aan, dit werkt zonder problemen.
[ Voor 7% gewijzigd door AIex op 06-04-2010 13:37 ]
  • nhubbers
  • Laatst online: 03-10-2021
Wow na het doorkijken van dit forum ben ik ook zeer enthousiast om ook een eigen ambilight te maken!!
maar....
Wat heb ik nodig als ik zelf een LED Ambilight kit wel maken?
en zij deze setjes eigenlijk ook kant en klaar te koop?
kosten$$$?
  • Compizfox
Compizfox
Bait for wenchmarks
Als je iets kant-en-klaar zoekt, zou je een amBX Starters setje (30 euro) kunnen nemen en die gebruiken met Aurora Synesthesia (Windows) of Combustd in combinatie met Boblight-X11 (Linux).
Zie dit voor meer info: http://www.tuxplace.nl/aa...r-met-je-ambx-systeem.php
  • nhubbers
Thanx @Compizfox
Vindt dat AMBX setje niet echt een ideale oplossing. Ik heb mijn HDTV aangesloten op mijn pc in de huiskamer. Het liefste heb ik daarom iets als ledstrips voor achter de tv voor het verlichten van de muur..
heb je enig idee wat hier de mogelijkheden in zijn? heb al het een en ander gezocht, hoopte eigenlijk er van af te komen zonder te hoeven solderen...
  • AIex
Als je een breadboard gebruikt hoef je alleen maar de kabels aan de ledjes te solderen, de rest is inpluggen. Daar kom je eignelijk nooit onderuit tenzij je een kant en klare oplossing hebt... Geen idee of die er zijn eigenlijk..
  • LED-Maniak
Er zijn kant en klare oplossingen :)
Helaas alleen nog niet mainstream.
  • AIex
Zelf maken is ook wel leuk :) Niet moeilijk en je kan t precies zo maken als je wil!
Ik heb een philips ambilight televisie en ben er zéér blij mee. Ik vind alleen de lichtzuiltjes die beschikbaar zijn voor de pc voor achter je scherm een stuk mooier.
Het idee achter de leds achter je televisie is juist geboren uit het felle licht waar je in kijkt als je tv kijkt in tegenstelling wat sommige andere mensen beweren in dit topic. Het mooie effect is eigenlijk meer een bijkomstigheid lijkt me.
De tv die ik hier heb staan is een 94 cm Cineos. Ik geloof LCD en in ieder geval HDMI. Het dingetje schijnt ooit een dikke 3000 euro gekost te hebben (jaar oud). Ik heb hem geërft van mijn onlangs overleden oma en als herinnering zitten er dikke sop-waterstrepen van m'n oma op die het mooie ding goed dacht te verzorgen. Ik kan er niet mee zitten en er schijnen produkten voor te koop te zijn. Hield immers van de lieve vrouw :).
Mijn moeder wordt zenuwachtig als de telefoon piept als hij in de lader moet, en zij begint te gillen als er een smsje binnenkomt. Ach, ooit zijn wij die lui die er geen bal van snappen en loopt er grut over straat met nicotine-veilige sigaretten !!!
Leuk speelgoed in ieder geval. Starter kit kost bij de computerland 25 euro's en de service daar vind ik erg goed. !request meer foto's van zelfgemaakte ambilight.
[ Voor 4% gewijzigd door Verwijderd op 13-04-2010 22:40 ]
  • AIex
Ik heb er nog een paar gemaakt, op de foto zie je niet goed de kleur en licht intensiteit aangezien mn iphone cam niet heel goed is (2G).
http://www.avalondesigns.nl/photo1.jpg
http://www.avalondesigns.nl/photo2.jpg
http://www.avalondesigns.nl/photo3.jpg
Hij draait nu op 20Hz en vraagt 50% van 1 CPU Thread. (merk ik niets van iig).
Deze fotos zijn gemaakt met de 5 block average functie aan zodat de lichten minder reageren op locale kleurverschillen.
http://www.avalondesigns.nl/gui.jpg
Hier een screenshotje van mn GUI (plaatje frontend idd lekker geript van inet). Hiermee kan je hem zo responsive krijgen als je wil :).
Het werkt nog steeds met de zelfde code en ik denk dat ik dat ook niet meer ga veranderen. Alles wat je kan printscreenen werkt hiermee. De lowlevel code om plaatjes uit de frontbuffer van mn videokaart te halen ging met hooguit 0.3 Hz...
  • somers1234
  • Laatst online: 22-11 20:48
Ik gebruik nu het programma van KDVken maar bij mij werkt dit niet in games. Films, youtube en webpagina's werken perfect maar als ik een game start dan blijven de gekleurde vakjes zwart.
Ik draai op Windows 7 64 bit. Ik heb het programma in Battlefield: Bad Company 2 en in Supreme Commander 2 geprobeerd. In beide spellen doet het programma niets.
Waar zou dit aan kunnen liggen?
  • vandeGerrit
vandeGerrit
somers1234 schreef op vrijdag 16 april 2010 @ 10:37:
Probeer is de AA uit te zetten in het spel. Dan zal je waarschijnlijk wel resultaat hebben.
  • somers1234
Ah inderdaad. Is er nog geen versie waar AA wel gewoon aan kan?
  • AIex
Zie net dat AA ook bij mijn code het probleem was.. Je kan in je NVIDIA controle paneel AA forcen naar 4x oid en ingame het uitzetten. Dan werkt het ook in games!
Nu nog even mn best doen dat de CPU load naar beneden gaat :)
  • Baseje
  • Laatst online: 21:53
Ik heb al een aantal weken 2 led parren,
Nu heb ik ook een DMX kastje gekocht van Velleman: K8082
Deze werkt prima met de bijgeleverde software.
Nu ben ik benieuwd of ik deze setup ook kan gebruiken voor ambilight,
Ik kon op google hier niks over vinden.
Alvast bedankt.
MVG Bas
  • hardware.tom
Ik ben nu ook begonnen met solderen, het is alleen nog even wachten op de pic-programmer uit Maleisië en aangezien er geen vliegtuigen vliegen duurt het wat langer jammer genoeg.
Maar dat is geen probleem want ik moet mijn casemod nog afmaken :P
  • LED-Maniak
Baseje schreef op zondag 18 april 2010 @ 10:04:
Alvast bedankt.
MVG Bas
Ja, een user hier heeft software gemaakt welke op DMX werkt. Dus ik zou even dit topic doorzoeken :)
  • DP Kunst
Moet je even zoeken naar SendTheLight van vandeGerrit ;). Werkt echt prima! Heb er nu 50 DMX lampen mee aangestuurd (wel een hel om te configureren :P). Voor meer info: ScrapDMX topic.
  • vandeGerrit
vandeGerrit
MVG Bas
Je kunt de versie downloaden via: http://gvrstudio.nl/Send-the-light/. De velleman wordt wel ondersteund, alleen weet ik nog niet zo goed hoe goed deze het doet. Zou jij dit even willen controleren, en bij fouten deze willen posten?
  • Baseje
Het werkt perfect, buiten dat het niet in game werkt en dat er een vertraging inzit,
Weet iemand hier een oplossing voor?
Bedankt.
Wij hebben ook een doe-het-zelf Ambilight systeem gemaakt voor de PC.
Het is open source en alle sources, een how-to guide, demo-materiaal etc. is te vinden op http://amblone.com
  • AIex
Amblone, kijk eens naar de TLC5940 chips voor de arduino. Heel veel goedkoper dan een aantal Mega's gebruiken om alle PWM signalen te versturen!
Heeft er hier iemand intresse in mijn code? Het runt in Python met een paar C functies. Je hebt er Python2.6, pygame, pyserial, PIL, psyco en numpy voor nodig. (de laatste 5 zijn python modules).
Arduino code is in C.
Je hebt er een arduino (ongeacht type) voor nodig en TLC5940 chips. Je kan dan in principe zoveel ledstrips gebruiken als je wil.
Dit programma werkt in games (zonder AA, tenzij geforced in NVIDIA controle paneel), windows media player en VLC. Ik krijg rond de 20Hz refreshrate en je kan het helemaal finetunen door de GUI.
  • LED-Maniak
AIex schreef op dinsdag 20 april 2010 @ 21:32:
Met de TLC chip heb je nog steeds een microcontroller nodig voor de aansturing. Zij gebruiken hier dus een arduino voor om 3 kanten van de TV te belichten. Ik zie niet dat ze meer dan 3 kanten of nog meer dan 3 kanalen gebruiken dus dit is een prima oplossing.
Een kleine correctie: De Amblone PC software is in C++ geschreven, de Arduino code is Java. Je hebt inderdaad alleen een Arduino nodig voor het aansturen van de LED strips, en geen extra processors. Je moet alleen zelf een simpel circuitje maken met weerstandjes en transistors. De Mega heeft 14 PWMs, en Amblone ondersteunt tot 4 RGB kanalen. Ik heb er zelf maar 3 in gebruik, maar als je de guide volgt kan je er heel makkelijk 4 van maken (geen softwareaanpassingen, alleen de hardware voor 4 ipv 3). Andere Arduino's zijn goedkopen, maar die hebben minder PWMs en kunnen dus niet 4 kanalen aansturen.
[ Voor 3% gewijzigd door Verwijderd op 20-04-2010 23:22 ]
  • hardware.tom
Ik heb mijn pic-programmer eindelijk binnen, maar welke .HEX kan ik het best gebruiken om hem te testen? Ik gebruik dat schema van divxststation en een pic16f628a
En nog een vraagje over het schema: moet die kristal er ook bij? En zoniet hoe zou het achema er dan uitzien?
  • RafkeP
  • Laatst online: 11-05-2023
@ hardware-tom
Ik raad de mensen altijd aan om in eerste instantie mijn eigen HEX (CC versie) erin te steken.
Deze heeft geen moodlight functionaliteit en dat heeft als voordeel dat je om te testen niet per ongeluk in mood-mode komt. Zo weet je op elk moment wat je zou moeten zien op de uitgangen.
Wanneer je de PIC opstart met die HEX file zal de PIC alle uitgangen uitsturen op halve kracht (RGB 127,127,127).
Nadien steek je beter de HEX file van Bikkel erin. Die is meer betrouwbaar en heeft moodlight functionaliteit.
Het kristal is noodzakelijk.
Origineel was ik begonnen met interne klok, maar die bleek niet snel genoeg voor 9 uitgangen.
  • hardware.tom
Heb je het ook nodig als je eerst alleen 3 RGB-leds gaat aansturen?
Want in die divxstation tutorial (van jou?) staat iets over V1 en die had ook geen kristal.
  • AIex
LED-Maniak schreef op dinsdag 20 april 2010 @ 22:51:
Klopt maar met zo'n chip heb je geen mega nodig voor 3 LED strips. Een normale arduino kan dan dus in de plaats van de mega komen en dan ben je goedkoper uit ;)
  • RafkeP
hardware.tom schreef op woensdag 21 april 2010 @ 08:26:
Die tutorial is inderdaad van mij, maar kan ik niet meer aanpassen aangezien DS gesloten is.
3 RGB leds zijn ook 9 outputs, dus het kristal blijft noodzakelijk.
  • hardware.tom
Ok bedankt voor de informatie, dan ga ik morgen even een kristal en een seriele kabel (die had ik ook nog niet) halen.
Oja nog een vraag: Wat voor condensator meot ik gebruiken voor de ze kristal: http://www.okaphone.com/artikel.asp?id=424120
30pF of 15pF?
[ Voor 37% gewijzigd door hardware.tom op 21-04-2010 09:37 ]
  • LED-Maniak
AIex schreef op woensdag 21 april 2010 @ 09:10:
Je kan zoiezo een gewone arduino gebruiken. Die 9 kanalen kan je makkelijk in software opwekken en je hebt nog een zee van tijd over.
  • Sh4wn
  • Laatst online: 12-11-2017
Sh4wn
Bio-informatica
Ik ben wel geinteresseerd in de code :) Aangezien ik binnenkort ook wat (DMX) Led stripjes wil gaan maken, + DMX Software voor linux, inclusief een soort van ambilight optie. Dus ben wel benieuwd hoe je de scherm kleuren op vraagt :)
  • Baseje
Ik heb nogsteeds geen antwoord op me vraag:$
Hoe krijg ik het ingame met send the light aan de praat?
  • vandeGerrit
vandeGerrit
Baseje schreef op woensdag 21 april 2010 @ 16:42:
Als je gewoon het forum had doorgelezen (of zoeken) had je het geweten.
De gebruikte methods zijn op dit ogenblik nog niet geschikt voor Ambilight met AA aan. Zet dit uit en het werkt. Op dit moment werkt het niet met AA aan. Hier ga ik eind zomer vakantie wat aan doen.
  • Baseje
Zonder AA in Cod4 werkt het ook niet:S
  • FulmeN
  • Laatst online: 23:59
Ik heb hier nog een AT90S4414 van atmel
Nu heb ik me hier de laatste jaren weinig meer in verdiept, is het hier mee mogelijk ?
  • LED-Maniak
Jahoor. :)
  • FulmeN
Oh mooi ga ik daar maar is verder mee kijken :)
Ook even kijken hoe ik het weer moest inladen op de atmel haha (jaartje of 5 geleden)
  • RafkeP
[b][message=33866940,noline]
30pF of 15pF?
Om eerlijk te zijn, heb ik daar ook niet zo veel verstand van.
Volgens mij maakt het hier niet veel uit of je nu 15, 20 of 22pF gebruikt.
Als je toch nog moet bestellen kan je het kristal ook hier kopen : http://www.voti.nl/winkel/p/X-10M.html
Dat is goedkoper (verzendkosten heb ik niet bekeken) en je hebt direct de juiste capaciteiten.
Voor MoMoLight specifieke vragen mag je me ook altijd mailen op mijn gmail adres.
Je weet wel: MoMoLight apestaartje ...
  • LED-Maniak
FulmeN schreef op woensdag 21 april 2010 @ 20:50:
De vraag is of dat wel werkt met de hex bestanden van hier. Waarschijnlijk zal je eea. opnieuw moeten compileren. Een nieuwe chip halen kost je 2 euro dus dat zou mijn eerste keus zijn.
RafkeP schreef op donderdag 22 april 2010 @ 08:06:
Atmega8 heeft bijvoorbeeld 36pF condensatoren intern bij het kristal zitten dat je met fuses aan kan zetten. De aangeraden waarde voor externe condensatoren is tussen de 12pf en 22pf.
[ Voor 42% gewijzigd door LED-Maniak op 22-04-2010 08:15 ]
  • AIex
Wat zijn die DMX setjes eigenlijk? Ik heb deze: http://www.elmolight.eu/product.php?id_product=159 en die werken briljant! Als je meer licht wil kan je event. deze nemen http://www.elmolight.eu/product.php?id_product=160
De eerste is al VEEL licht! Ik zal de code morgen uploaden.
  • Sh4wn
Sh4wn
Bio-informatica
AIex schreef op donderdag 22 april 2010 @ 12:52:
DMX is het protocol wat gebruikt wordt voor lichtsturing op alle grote feesten. Die LED stripjes zien er trouwens wel goed uit, leuke prijs ook.
  • hardware.tom
Ik heb hem net afgemaakt alleen volgens mij is mijn pic stuk? Hoe kan ik dit controleren? Als ik mijn pic eruit heb dan doet hij precies het zelfde als met; alleen de 2e led brand groen en een beetje rood.
Na een tijdje gaan led 1 en 2 ontzettend fel groen licht geven
Ik heb wel per ongeluk de pinnen van de usb-b connector verkeerd omgehad: dus de + en de - omgedraaid en toen werd hij ontzettend heet (je kon je vinger er aan branden). Zou de pic kapot kunnen zijn of de MAX232? Als ik de pic programeer in pickit dan gaat het allemaal goed, maar als ik op read druk dan zie ik overal 0-en. Hij ziet wel dat eht een PIC16F628 is...
Printscreens:
Afbeeldingslocatie: http://i42.tinypic.com/scxnp2.png
Dit klopt denk ik niet?
Afbeeldingslocatie: http://i43.tinypic.com/8xkmx5.png
Zo hoort het toch te zijn? Dit is niet geread van de pic maar van de HEX file die ik had gewrite.
[ Voor 16% gewijzigd door hardware.tom op 23-04-2010 18:02 ]
  • RafkeP
Wat had ik nu weer aangeraden? :)
De HEX file van Bikkel staat op "code-protect". Die kan je dus niet meer uitlezen nadat hij geprogrammeerd is.
Ik zou zeggen: probeer het eens met de HEX file vanop Divxstation. Als je die weer kan uitlezen is de kans groot dat de PIC nog werkt.
Die USB connector had ik er alleen maar opstaan voor demo doeleinden.
Ik weet niet hoe je het precies gemaakt hebt, maar je mag hem nooit samen met een externe voeding gebruiken.
Kijk je circuit nog eens na voor kortsluitingen. Vergeet ook niet niet de massa's van de seriele poort, brain en power met mekaar te verbinden.
  • hardware.tom
Als ik die van divxstation gebruik dan kan ik het ook niet terug lezen, dan krijg ik weer overal 0-en. En er staat nog steeds code-protect.
Ik gebruik de USB als externe voeding. Ik vind het een beetje onnodig een testvoeding hier op mijn bureau te hebben staan. :P
Update: ik heb het ding nog eens nagekeken en ik heb ontdekt dat ik de ground van de MAX232 niet aangesloten had |:( .
Maar ik heb nog steeds het probleem dat als ik de kabel eruit haal of de pic eruit haal dat het helemaal niet veranderd.
Dat test programma daar heb ik die filters toch niet voor nodig?
Zou mijn pic kapot kunnen zijn? of de max232?
Nog een update: Hij werkte net even met het testprogramma. alleen blauw werkte niet en na een tijdje ging de led uit en nu krijg ik de led niet meer aan.
[ Voor 88% gewijzigd door hardware.tom op 24-04-2010 13:00 ]
  • AIex
Hier is de code van mn ambilight:
www.avalondesigns.nl/ambilight.rar
Je hebt er python 2.6 voor nodig met de modules: pygame, numpy, psyco,pil en pyserial.
Het werkt voor een Arduino (ongeacht type) met TLC5940 led drivers.
Het werkt voor VLC, windows mediaplayer, games (zonder AA of via Nvidia controlepaneel geforced) en je desktop natuurlijk op 18-20Hz.
Via de GUI kan je de overgangen zo soepel maken als je zelf wil, de profielen die er nu bij zitten zijn experimenten van mij maar zijn makkelijk aan te passen.
EDIT: de C library was verkeerd gecompileerd, dit is nu gefixt. Iedereen die voor 22:30 de code gedownload heeft moet dit nogmaals doen om de goede versie te bemachtigen.
[ Voor 55% gewijzigd door AIex op 24-04-2010 22:28 ]
  • RafkeP
@ hardware.tom
Als je na het programmeren van de divxstation HEX file de PIC ook niet kan uitlezen, moet je eens kijken of je in de PICkit programmer software nergens code protection hebt aanstaan.
Ik heb er zelf nog nooit mee gewerkt, maar ik kan mij inbeelden dat hij de laatste instellingen onthoudt en als je daarvoor de mood HEX file hebt ingeladen zou het kunnen dat de code protection blijft opstaan.
Het kan natuurlijk ook zijn dat je PIC stuk is want "ontzettend heet" is nooit gezond.
De PIC doet al het echte werk, dus als je die eruit haalt zal het zeker niet meer veranderen.
Met mijn firmware is het normaal dat er niets veranderd wanneer je de kabel eraf haalt.
Als je de mood firmware erin hebt zitten hangt het er vanaf in welke stand je zit:
- in MoMo-mode zal er niets veranderen zonder kabel
- in Mood-mode zal het default programma spelen (zowel met als zonder kabel)
Het default mood programma zal eerst door de kleuren faden, daarna elke kleur flikkeren en daarna wit flikkeren.
De filter heb je niet nodig voor het test programma. Die kan je enkel gebruiken bij Zoomplayer, GOM player en BSplayer.
Er zijn wat dingen die je kan proberen om te debuggen (best met mijn firmware):
- Doe de spanning eraf, steek enkel de MAX232 in zijn voetje en sluit het cricuit aan op de seriele poort van een PC.
- Zet de spanning weer op en start hyperterminal op de PC
Hyperterminal vind je op een engelse Windows XP Pro machine onder
"start/all programs/accessories/communications/hyperterminal".
(het zou kunnen dat er geen hyperterminal staat op een XP home. In dat geval kan je een ander terminal
programma gebruiken)
- Geef je test connectie een naam.
- Bij "Connect using" selecteer je de juiste com poort. Klik op "OK".
- Stel in op "9600,8,None,1,None" en klik op "OK"
- Nu zit je in een hyperterminal sessie. Typ wat willekeurige karakters op je toetsenbord en merk op dat er
niets op het scherm verschijnt.
- Leg nu een draadbruggetje tussen pin 7 en pin 8 van het IC voetje van de PIC.
- Typ opnieuw wat op je toetsenbord en je zal zien dat de tekens nu wel op je scherm verschijnen.
Als dit werkt, wil het zeggen dat het gedeelte rond de MAX232 goed is uitgevoerd.
- Koppel de spanning en de PC weer af.
- Steek de PIC nu in zijn voetje (let op de orientatie) en sluit 1 LED(strip) aan.
- Wanneer je nu de spanning opzet zou de LED(strip) moeten branden op halve kracht.
- Sluit vervolgens ook de andere LED(strip)s aan. Ook die zouden moeten branden aan halve kracht.
- Als dit allemaal in orde is kan je ook de PC weer aansluiten en testen met het programma dat je vindt op
Divxstation.
Kan je me eventueel eens hoge resolutie foto's doorsturen van jouw ontwerp (boven en onderkant)?
Bij een aantal mensen heb ik zo al fouten kunnen vinden.
  • hardware.tom
Oke bedankt voor de uitgebreide uitleg!!
Ik heb dat met hyperterminal gedaan (wel met een ander programma ,want ik heb windows 7), maar ik krijg ook geen tekens als ik de draadbrug er in heb zitten. Betekent dit dat ik niets niet goed heb gesoldeerd (ik kan zelf niks vinden) of dat de max232 zelf kapot is?
Ik wou net bij samenkopen.net een nieuwe PIC, max232 en een ledstrip kopen. :P Gewoon voor de zekerheid....
  • RafkeP
Als je alles goed hebt ingesteld, je zeker bent dat je het draadbruggetje op de juiste plaats hebt gezet en je krijgt dan nog niets terug dan is ofwel de MAX stuk ofwel heb je iets verkeerds gedaan in het gedeelte rond de MAX.
Kijk ook eens na of je Rx en Tx niet hebt omgewisseld op de seriele poort.
  • hardware.tom
Alles heb ik nog 2 keer gecheckt en heb niks kunnen vinden. Ik heb via SK.net een bestelling gedaan met een nieuwe print en een max232, een pic en een led strip, dus ik ga het helemaal opnieuw opbouwen met de lay-out van jouw die op divxstation staat alleen ik heb hem een beetje aangepast met rgb leds in plaats van die connector.
Daar ga ik dus maar op wachten. Maar heeel erg bedankt voor de uitgebreide uitleg. ;)
  • FulmeN
Nu had ik de rgb ledstrip van dealextreme op het oog, maar heb geen creditcard en die heb je ook nodig i.s.m. paypal
De ikea dioder heb ik nu als alternatief zijn deze daar goed geschikt voor dus ook een common + en een Red Green Blue of zit ik aan meer problemen vast bij deze set?
  • hardware.tom
ik zou toch voor die van dealxtreme gaan hoor. Ik heb alleen een jongerenrekening en ik heb succesvol een paypal rekening gemaakt. Ik heb nu al 2 dingen besteld met paypal.
Je kan dus gewoon paypal koppelen aan elke rekening.
Die ikea dioder is gewoon veel te duur.... ;)
  • LED-Maniak
FulmeN schreef op maandag 26 april 2010 @ 19:25:
samenkopen.net kan je ze ook krijgen ;)
  • FulmeN
LED-Maniak schreef op maandag 26 april 2010 @ 19:37:
Zat er net toevallig op en besteld, bedankt voor de handige link :)
Nu afwachten tot alles binnen is voordat ik kan beginnen hehe
[ Voor 12% gewijzigd door FulmeN op 26-04-2010 19:56 ]
  • AIex
  • RafkeP
@ hardware.tom
Kijk ook de PIC een keer na. Het is niet normaal dat je met mijn firmware geen verify kan doen
en zelfs als de MAX stuk is, zouden alle LEDs moeten aangaan op halve kracht.
  • hardware.tom
Ik heb al een nieuwe printplaat en pic besteld bij SK.net en ik heb de oude printplaat uit elkaar gehaald (en de goede onderdelen) dus ik bouw hem gewoon weer opnieuw.
  • Eoghlear
  • Laatst online: 23-03 12:54
Verwijderd schreef op dinsdag 20 april 2010 @ 17:24:
Dit hele project van jullie is zeker windows only? Ik heb namelijk een mediacenter op xbmc (live) draaien, wat in feite een minimale ubuntu install is. Dit lijkt me fantastisch om een keer te maken en hier op aan te kunnen sluiten.
Dan kan ik het (nog) niet voor tv, maar wel al voor films en enkele series.
  • DP Kunst
Eoghlear schreef op dinsdag 27 april 2010 @ 22:26:
Dit is iets waar ik ook wel interesse in heb! Ik heb namelijk een USB -> DMX printje met een FT232RL. Volgens mij zijn er voor die FT232RL wel linux drivers te vinden. Dan alleen nog een XBMC plugin om de kleurtjes uit te sturen naar de USB -> DMX print en je bent al een heel eind!
  • AIex
Python is crossplatform dus in principe zou mijn code ook op ubuntu moeten werken.. Event. zou ik de C functies er uit kunnen halen zodat alles met python gaat.
  • LED-Maniak
Krijg je dan geen problemen met direct x en dergelijke?
  • bobo1on1
Het schijnt dat een bepaalde xbmc developer plannen heeft om zoiets native in xbmc te bouwen, maar dat laat nog even op zich wachten.
  • kaasaanfiets
kaasaanfiets
Extreme Edition of koekoek
Is er hier al iemand die kant en klare setjes wil maken en verkopen? Zoja wat krijg ik dan wat kan het en wat kost het en via wat werkt het.(vga, usb, lcd tv? laptop? ps3)
  • LED-Maniak
Die zijn al eens gemaakt. Via USB en via de TV kan allebei :)
  • AIex
LED-Maniak schreef op woensdag 28 april 2010 @ 01:22:
Heb nog even gekeken en de Imagegrab.grab() van PIL werkt alleen in windows.... Dus als je zelf een andere methode aandraagt om het scherm te capturen kan het, anders niet
  • hardware.tom
Ik heb nog een vraag over het "power part" van de divxstation tutorial.
Zijn er ook andere alternatieven voor die IRFZ44n? Als mijn circuit werkt wil ik namelijk 1m ledstrip kopen via dealxtreme (10 euro :P).
  • LED-Maniak
Voor 1 meter kan je volgens mij ook een BS170 pakken. Anders IRLZ34N ofzo?
