[OC-Ervaringen] Lanparty NFII Ultra B en Infinity Deeltje 3
Pagina: 1 2 ... 7 Laatste
  • 2.119 views sinds 30-01-2008
  • Astennu
  • Laatst online: 19-08 17:53
Link naar het vorige topic:
[OC-Ervaringen] Lanparty NFII Ultra B en Infinity Deeltje 2
LANPARTY NFII ULTRA B
Afbeeldingslocatie: http://www.dfi.com.tw/Imgs/Product/lp_kt400a_4s.jpg
[img=400,300]url= http://www.envynews.com/reviews/images/606/14.jpg[/img]
Klickbaar
[img=400,300]url= http://www.lanparty.com.tw/LP1/board3.jpg[/img]
Klickbaar
CPU
AMD Athlon XP 266/333/400MHz FSB
AMD Athlon 200/266MHz FSB
AMD Duron 200/266MHz FSB
Chipset
nVIDIA® nForce2 chipset
- nForce2 Ultra 400
- nForce2 MCP-T
System Memory
Supports dual channel memory interface
Supports up to 3GB memory (unbuffered DIMM)
Supports PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400)
DDR SDRAM DIMM, 2.5V type
Three 184-pin DDR SDRAM DIMM sockets
BIOS
Award BIOS, Windows® 95/98/2000/ME/XP Plug and Play compatible
Genie BIOS provides:
- CPU/DRAM/AGP overclocking
- CPU/AGP/DRAM/Chipset overvoltage
4Mbit flash memory
CMOS Reloaded
Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-USB
- Wake-On-Ring (external modem)
- Wake-On-LAN
- RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system temperature
Monitors ±12V/5V/3.3V/VBAT(V)/5VSB(V) voltages
Monitors CPU/chassis fan speed
Read back capability that displays temperature, voltage and fan speed
CPU Temperature Protection function monitors CPU temperature during system boot-up
Audio
Realtek ALC650
AC'97 2.2 S/PDIF extension compliant codec
Supports Microsoft® DirectSound/DirectSound 3D
AC’97 supported with full duplex, independent sample rate converter for
audio recording and playback
S/PDIF-in/out interface
6-channel audio output
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy
- Full duplex support at both 10 and 100 Mbps
Realtek RTL8110S Gigabit LAN
- Full duplex support at 10, 100 and 1000 Mbps
PCI IDE
Supports ATA/33, ATA/66, ATA/100 and ATA/133 hard drives
UDMA Modes 3, 4, 5 and 6 Enhanced IDE (data transfer rate up to 133MB/sec.)
SATA IDE with RAID
Silicon Image Sil3114 PCI to Serial ATA controller
Supports four SATA (Serial ATA) interfaces which are compliant with SATA 1.0
specification (1.5Gbps interface)
Supports RAID 0 and RAID 1
IEEE 1394
nVIDIA® nForce2 MCP-T and Agere FW803 Phy chips
Supports three 100/200/400 Mb/sec ports
AGP
Supports AGP 8x up to 2132MB/sec. and AGP 4x up to 1066MB/sec. bandwidth
for 3D graphics applications
Rear Panel I/O Ports #(piccie verderop)
1 PS/2 mouse port
1 PS/2 keyboard port
1 DB-9 serial port
1 DB-25 parallel port
4 USB 2.0/1.1 ports
2 RJ45 LAN ports
2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
3 audio jacks: line-out, line-in and mic-in
2 audio jacks for center/bass and rear out
I/O Connectors
1 connector for 2 additional external USB 2.0/1.1 ports
3 connectors for 3 external IEEE 1394 ports
1 front audio connector for external line-out and mic-in jacks
2 internal audio connectors (AUX-in and CD-in)
1 S/PDIF connector for optical cable connection
1 connector for IrDA interface
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
2 ATX power supply connectors
3 fan connectors for CPU fan, chassis fan and 2nd fan
4 diagnostic LEDs
1 diagnostic LED connector for external 4 diagnostic LEDs display
EZ touch switches (power switch and reset switch)
Expansion Slots
1 AGP slot that supports 8x/4x AGP
5 PCI slots
PCB
4 layers, ATX form factor
30.5cm (12") x 24.5cm (9.64")
#Rear Panel
heatsinkje southbridge (zit met thermal tape losjes vast)
Nog 2 klickbare gifjes :)
[img=400,300]url= http://www.xs4all.nl/~mvgemert/NF2Ultra_layout.gif[/img]
Klickbaar
[img=400,300]url= http://www.xs4all.nl/~mvgemert/NF2Ultra_glow.gif[/img]
Klickbaar
INFINITY
[img=400,300]url= http://www.dfi.com.tw/Upload/Product_Picture/NFII%20ULTRA%20INFINITY%20b.jpg[/img]
Klickbaar
CPU
Chipset
- nForce2 Ultra 400
- nForce2 MCP-T
Memory
BIOS
4Mbit flash memory
CMOS Reloaded
Power Management
- Wake-On-USB
- Wake-On-LAN
Hardware Monitor
Audio
Realtek ALC650
AC’97 supported with full duplex, independent sample rate converter for audio recording and playback
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy chips
Integrated IEEE 802.3, 10BASE-T and 100BASE-TX compatible PHY
PCI IDE
SATA IDE with RAID
IEEE 1394
AGP
1 PS/2 mouse port
1 DB-9 serial port
4 USB 2.0/1.1 ports
1 RJ45 LAN port
I/O Connectors
2 IDE connectors
1 floppy connector
Expansion Slots
5 PCI slots
PCB
Meer specs
CPU Clock: 100MHz to 300MHz in 1MHz increments
CPU Multiplier: 5 to 22 in 0.5 increments
CPU Voltage: 1.1V to 2.0V in 0.025V increments
AGP Voltage: 1.5V to 1.8V in 0.1V increments
Chipset Voltage: 1.6V to 1.9V in 0.1V increments
DRAM Voltage: 2.6V to 3.3V in 0.1V increments
Verschillen LANPARTY NFII ULTRA B en LANPARTY NFII ULTRA rev. A
A ->Audio Connectivity 3 port backplane speaker
B ->S/PDIF I/O on I/O shield 5 port backplane speaker, S/PDIF I/O on backplane
A ->IDE RAID Highpoint HPT372N RAID controller w/ 2 ports
A ->SATA Marvell 88i8030, 1 port bridge from primary ATA
B ->SATA RAID 4 device RAID0, RAID1 Silicon Image Sil3114, 4 port
A ->NVIDIA 10/100, RTL8101 10/100
B ->NVIDIA 10/100, RTL8110S 10/100/1000
B ->Mounting holes rondom de socket
Uit de review van Hexus*
A nip here, a tuck there. The biggest change is the dropping of IDE RAID support in favour of SATA. The Sil3114 offers 4 full SATA channels which the board duly makes good use of, giving you 4 physical ports to hang your drives from. The chip does RAID0 and RAID1 on all channels, giving you decent flexibility in your disk configuration. You can run seperate RAID levels on two channel pairs, as far as I can make out without explicit testing anyway. The lack of physical IDE ports for the old Highpoint chip on the old board means a layout change for the B revision, I'll talk about that on the following page.
Verschillen LANPARTY NFII ULTRA B en Infinity
De lanparty heeft naast 100 Mbit Nvidia lan een Realtek RTL 10S Gigabit lan onboard.
De goodies zitten alleen bij de LANPARTY
[img=200,150]url= http://img.hexus.net/dfinf2ub/box_inside2.jpg[/img]
Klickbaar
Sleurtas (Transpo)
[img=200,150]url= http://img.hexus.net/dfinf2ub/transpo.jpg[/img]
Klickbaar
Rounded (uv-sensitive) cables (1 ide en 1 fdd)
[img=200,150]url= http://img.hexus.net/dfinf2ub/rounded_cables.jpg[/img]
Klickbaar
Frontx -> met o.a.: diagnostic LED connector for external 4 diagnostic LEDs display http://www.frontx.com
[img=200,150]url= http://img.hexus.net/dfinf2ub/frontx.jpg[/img]
Klickbaar
2 SATA-kabels en SATA voedingsconnector
1 DFI Lanpartysticker
1 DFI Lanpartycasebadge
and last but not least: power and resetbutton op het mobo, werkt dus dmv alleen de voeding aan te sluiten :).
[url= url=http://img.hexus.net/dfinf2ub/sata.jpg ][img=200,150]url= url=http://img.hexus.net/dfinf2ub/sata.jpg[/img][/url]
Klickbaar
De Lanparty heeft een UV-coating en 4 diagnostic LEDs op het mobo(en extern), de Infinity niet.
Even een plaatje van de UV-coating:
[img=200,150]url= http://www.lanparty.com.tw/LP1/board3.jpg[/img]
Klickbaar
Links naar fabrikant+mobo:
http://www.lanparty.com.t..._r_us.jsp?PRODUCT_ID=2320
http://www.lanparty.com.tw/LP1/index_lp_us.jsp
Bios’en:
http://www.lanparty.com.t...Y_TYPE=null&STATUS_FLAG=A
INFINITY
http://www.dfi.com.tw/Sup...Y_TYPE=null&STATUS_FLAG=A
Beta-bios:
Die duiken op 4 verschillende plekken op :(.
De meeste recente verschijnen op: http://forums.amdmb.com/s...ad.php?s=&threadid=281088
verder op**: http://www.dfi.com.tw/Sup...DEX_TYPE=MB&STATUS_FLAG=B
en op: http://www.angrygames.com/CMOS_Reloaded_NFIIB.htm
en tenslotte dook er 1tje op bij: http://www.xtremesystems....6&perpage=25&pagenumber=5
http://www.dfi-street.com/bios.html
http://www.midnightmachine.com/dfi/
Modded BIOS: http://underclock.proboar...on=display&num=1074106235
INFINITY
http://myweb.hinet.net/ho...dfi/betabios/N24IDC18.zip
bios en utilities verzameld door Psychosis op: http://www.midnightmachine.com/dfi/
What are recommened DDR memory modules on LANPARTY NFII UltraB?
http://www.lanparty.com.t...SUBMITTED=No&PAGE_TYPE=US
Issues
1) De ruimte rondom de socket
Die is krap. De volgende (onscherpe doch functionele) foto zal veel verduidelijken:
Vanaf hier gezien zit er linksboven een laag chipje naast de socket, door de gebruikte constructie van zalman heb ik er geen last van, de koeler wordt aangedraaid op de 2 dwarsverbindingen. Van andere gebruikers heb ik gehoord dat ze met wat washers onder de steunconstructie werken om te voorkomen dat dit chipje wordt geplet.
Zie ook: http://forums.amdmb.com/s...ad.php?s=&threadid=278704
2) 2,0 volt is momenteel het maximale van de Vcore, zonder mod
Hier (op GoT) werd er geopperd dat deze d.m.v. een bios update verhoogd kan worden, ik heb hier nog niks overgelezen! Zodra ik iets concreets weet zal ik het hier posten. Tot die tijd is het misschien een idee om na te gaan denken over een eventuele mod.
3) Grote fluctuaties op de 5 en 12 volt rail
Ik heb er zelf geen last van (TrueControl) maar het wordt wel genoemd in de diverse fora. Ik heb me er niet in verdiepd omdat ik er geen last van heb. Het staat wel als puntje op mijn agenda om het mee te nemen.
4) Memoryproblemen
Heb ik ook geen last van, ik gebuik dus A-data oem wat waarschijnlijk geen BH-5 chippies zijn. Het blijkt dat reepjes beplakt met winbond het beste werken op deze plank. Hiervoor geldt weer hetzelfde als voor het vorige punt, geen last van staat op de agenda
threads over wel/niet passen verschillende luchtkoelers
Thermalright 900a
http://forums.amdmb.com/s...ad.php?s=&threadid=280992
Zalman CNPS7000A
http://forums.amdmb.com/s...ad.php?s=&threadid=275858
Swiftech MCX462-V
http://forums.amdmb.com/s...ad.php?s=&threadid=279640
Thermalright AX-7
http://forums.amdmb.com/s...ad.php?s=&threadid=279623
reviews:
Op de onderstaande sites zijn revieuws te vinden van de: LANPARTY NFII ULTRA B:
Hexus*
FastLane
TheModFathers
Club OC
DataFuse.net
NinjaLane
Ohls-Place
Viperlair
[H]ard|OCP
Hexus.net
FiringSquad
PCStats
Hardwarezoom
Envy News
Legion Hardware
INFINITY
http://www.mbreview.com/nf2inf.php
links (fora-INFINITY en LANPARTY NFII ULTRA B meestal door elkaar in 1 topic):
Bijna alle topics op:
http://forums.amdmb.com/forumdisplay.php?s=&forumid=66
en hier de overige die ik heb gebruikt:
http://www.xtremesystems....6&perpage=25&pagenumber=1
http://www.xtremesystems....readid=24691&pagenumber=1
http://www.ocworkbench.co...b=get_topic;f=34;t=000015
En hier een handig forum over de DFI planken. Er is ook iemand van DFI support aanwezig die de vragen terug koppelt naar de technische mensen bij DFI.:
DFI Support @ AMDMB Forums
Voltmods
Dit natuurlijk voor het echte DOC werk :P
We hebben de volgende mods:
- V-Core mod
- OVP mod voor V-Core
- V-Dimm mod
V-Core mod en OVP mod
Deze doe ik maar in een keer want ze zitten op de zelfde chip:
Afbeeldingslocatie: http://www.xtremesystems.org/forums/attachment.php?s=&postid=327062
hier kun je dus zien welke pinnen je moet hebben.
Pin 7 is de V-core mod zonder OVP mod zul je ongeveer 2.1 volt halen en dan kick je mobo zichzelf uit. Hier kun je het beste een 20K tienslag potmeter pakken. Dan kun je het voltage precies afstellen.
Pin 10 is de OVP met deze mod is tot nu toe 2.17v gehaald hierbij was de weerstand van tussen pin 10 en ground 3K.
[img=400,300]url= http://home.kabelfoon.nl/~vnrswk/DSCF0761.JPG[/img]
Klickbaar !!
En een plaatje van hoe het resultaat zal zijn :).
V-Dimm mod
De V-Dimm mod. Voor de echte die hards aangezien de Infinity en de Lanparty beide standaard 3.3 v bieden. De V-Dimm wordt bij deze planken van de +5v lijn gehaald bij de meeste andere van de 3.3 en dan was er een 3.3v mod op de voeding nodig om een stabiele v-dimm te krijgen. Gelukkig is dat hier niet nodig :).
[img=400,300]url= http://www.xtremesystems.org/forums/attachment.php?s=&postid=307748[/img]
Klickbaar !!
Er wordt wel bij gezegd oppassen met het draaien aan de pod dus misschien verstanding ook hier weer een 200k 10 slag moet je misschien wel lang proberen voordat je het gewenste resultaat hebt maar wel minder kans op een kapot mobo ;)
Startpost door:
- Spice
- MaTr1x
- Astennu
Versie 2.6b
  • Spice
  • Laatst online: 09-01 14:46
Spice
- Mijn vader is een tovenaar -
nice one :).
Ook leuk CPC (Clock per Clock) uitgelegd:
http://forums.amdmb.com/s...ghlight=command+per+clock
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
voor het geval mensen ditnog niet weten.
DFI NF-II Infitity:
Thermalright SLK-900A past perfect
Thermalright SLK-900U past echt nog maar net, ik heb er een mobo mee gemold
(heb allebei de koelers gehad dus het is zeker)
But, you might suffer some performance loss when DRAM is working in RANDOM Access mode because there is a lot of COMMAND and ADDRESS change in RANDOM Access mode
"Some"? Nou.."some" is het niet hoor. Als je het uit zet krijg je echt een mega performance hit :+
De SLK947U past toch bijna perfect bij mij,
ik heb de nieuwe neo backplate en de installatie gaat vrijwel perfect enkel dat de koelblok ietwat duwt tegen de condensatoren onderaan maar, t'is niets om je zorgen over te maken
  • willy83
  • Laatst online: 13-06-2024
Ik heb hem ook DFI infinity.
Leuk maar hoe zet je het WC blokje vast met schroeven?
Er zitten allerlei kleine dingentjes in de weg :9
  • Exigence
  • Laatst online: 14-11 12:21
Exigence
dnkroz
willy83 schreef op 06 maart 2004 @ 18:53:
Geen moer op de bovenkant van je mobo zetten, gewoon de bout door je mobo en door je WC blok en dan aan de bovenkant van je blok de veer+moer erop zetten, anders heb je kans dat het beruchte weerstandje eraf gaat. Het enige "probleem" is dat je bout meedraait, even vasthouden dus :P
Vandaag op ufo is mijn infinity gemod. Wou nu net mijn pc starten maar die doet dus gewoon niks, teminste alle fans gaan aan, leds van het geheugen en mobo ook maar ik krijg geen beeld of teken van mijn toetsenbord dat er ook wat gebeurt. Voor de Vdimm is 100k gebruikt en voor de Vcore 50k, beide staan nog op maximale weerstand. Iemand die meschien weet waar ik het probleem moet zoeken?
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 06 maart 2004 @ 23:27:
Vcore ff los halen ?
Toen ik me vcore gemod had net op ufo boote ie ook niet maar nadat ik de mod los had gehaald deed ie t perfect.
The Doctor schreef op 06 maart 2004 @ 23:33:
Met andere woorden een Vcore mod met ons bord is niet mogelijk?
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 06 maart 2004 @ 23:45:
Nee bij Serenity werkt ie wel :)
Met mijn bord wilde hij om een of andere reden niet maar als ie eerst nog niet gemod wat en het deed en nu gemod is en het niet meer doet zou ik eerst even de mods los halen om te kijken of t daar aan ligt.
The Doctor schreef op 06 maart 2004 @ 23:50:
als het aan de mods ligt is het gewoon onmogelijk deze mods nog werkend te krijgen, ze zitten werkelijk super netjes vast (met een vergrootglas na gekeken)
Hoop dat het de Vcore is die geeft je toch bijna geen winst.
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 06 maart 2004 @ 23:53:
Inderdaad probeer eerst de vcore mod die gaf bij mij problemen en die zat ook goed gesoldeerd dat had er niets mee te maken.
The Doctor schreef op 06 maart 2004 @ 23:55:
De Vcoremod is ongedaan en mijn prommie staat nu koud te worden, wish me good luck! ;)
Nee weer niks :(
Ga nu aan mijn huiswerk als ik nog tijd over hou ga ik hem er maar weer uit slopen (uit en in elkaar samen 1,5 uur werk denk :S ) schiet niet op zo ;(
[ Voor 22% gewijzigd door Verwijderd op 07-03-2004 10:47 ]
hey ik heb er al even naar gezocht maar kan niet vinden welke bios het nou is, diegene die tot 3.6 vddr kan?
want mijn mushkin doet nu 255 fsb @ 3.3v, maar hij kan nog wel harder met iets meer.
welke bios is het?
btw:
9.5 x 255 @ 2.000 - 11-2-2-2 @ 3.3 - Vdd 1.9 - AGP66 @ 1.5v - CPC ON, AGGRESSIVE = 55.47 pifast
muhhaha >:)
Verwijderd schreef op 07 maart 2004 @ 21:27:
welke bios is het?
btw:
muhhaha >:)
CPC on wtf dat zou mijn mobo/mem nooit doen (infinity + pc3500 level2)
Maar om je uit de hemel te halen er is geen bios met 3,6Vmem, ff naar de startpost kijken en een Vmem mod doen en je kan tot 5Vmem gaan geloof ik doordat hij van de 5V lijn word gehaald maar ik zou niet hoger gaan als 3,6Vmem max en enkel voor bench!
Verwijderd schreef op 07 maart 2004 @ 10:41:
Nee weer niks :(
zou je bios niet een beetje corrupt zijn??
fannetjes en ledjes draaien maar geen boot..... bij mij gaat er dan een belletje rinkelen.... a) bios corrupt
b) beruchte weerstandje
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 07 maart 2004 @ 23:02:
Er is WEL een BIOS met 3,6vmem, en ik heb hem zelf gedraaid, dus nu moet je geen onzin gaan verklaren. Zal meteen even zoeken.
  • MaTr1x
  • Laatst online: 14-11 22:53
Ja idd er was een BIOS met 3.6vdimm, die had ik zelf in de startpost gezet, alleen ik zie dat die link niet meer werkt omdat het forum waar die op stond op de schop is. Ook via Google's cache en archive.org kom ik niet verder.
Ik had beide BIOSsen gedowned van dat forum, maar weet niet meer welke het is, ik heb ze iig nu zelf gehost, volgens mij is het de DFI-Lan-revb-2711-sata.zip.
Klopt dat Exigence?
Uit een eerdere post van Spice:
vDimm volts are now 2.6-2.9- 3.4, 3.5 , 3.6 replace 3.0 , 3.1 and 3.2 /3.3
So options are 2.8 2.9 3.4 3.5 3.6
Hier staan ze: http://matr1x.net.tf/DFI
π MW finishers
  • mydogisgone
  • Laatst online: 15:03
mydogisgone
Watskeburtwithmydog
damn heb nog steeds mijn mobo geprobeerd.. haha erg ben ik :P
maar ja ff wachten tot me casemodje klaar is :)
waar kan je trouwens een extra bios chip kopen?
want heb geen zin om me mobo steeds op te sturen voor een rma of what so ever.
als het zou gebeuren dat mijn bios corrupt raakt :P
Mijn hond is nog steeds echt weg! En die komt ook niet weer. :O
mydogisgone schreef op 08 maart 2004 @ 00:09:
mail me
[ Voor 6% gewijzigd door Verwijderd op 08-03-2004 01:11 ]
  • Aham brahmasmi
  • Laatst online: 21-12-2025
MaTr1x schreef op 07 maart 2004 @ 23:40:
Ja idd er was een BIOS met 3.6vdimm [...]
Maar deze is toch niet ook voor de Infinity of wel? Gebruikte jij dezelfde, Exigence?
Exigence schreef op 07 maart 2004 @ 23:22:
Op amdmb was hier laatst ook een discussie over en er stond dan wel 3,6Vmem in het bios er kwam in practijk gewoon 3,3Vmem op het geheugen te staan, meschien heb ik het mis maar dan moet ik de schuld geven aan andere users die mij dit hebben verteld.
ooh naja jammer, ik weet zeker dat mijn mem wel 265 doet op 3.6 volt, ongeveer
maarja 255 op 3.3 is ook niet verkeerd >:)
nu nog een amd 2400+ mobile aan zien te schaffen, en gaan met die banaan :9~
[ Voor 4% gewijzigd door Verwijderd op 08-03-2004 08:33 ]
  • _Droopy
  • Laatst online: 08-08-2019
_Droopy
Tweaken of school?,....Hmmm..
Verwijderd schreef op 07 maart 2004 @ 23:10:
En als het geen van beide is dan?
zowel met een andere bios chip loopt ie niet, EN ik weet zeker dat er geen weerstandjes of andere componenten verrot zijn.
Enig idee?
Life is but a joke,.... But i see nobody laughing. Specs 3DMark2k1se 21671 3D Mark03 7195
Verwijderd schreef op 08 maart 2004 @ 08:32:
Je kan het bios gewoon proberen maar alleen het feit al dat niemand heb gebruikt zegt al wat over de overclock mogelijkheden. Waarom doe je niet gewoon een Vmem mod?
  • SlowikPL
  • Laatst online: 18-08 14:37
WOW, wat zijn dit voor geheugen ( Merk type:? ) dit geheugen ga ik ook kopen , maar dan in 1024MB :)
[ Voor 7% gewijzigd door SlowikPL op 08-03-2004 15:00 ]
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
alleen tweakstore heeft nog de 1024 mb versie a 430 euri!
dus als je net een bank berooft heb...
ik zal die vddr mod es bekijken, misschien doe ik die wel.
  • Exigence
Exigence
dnkroz
Aham brahmasmi schreef op 08 maart 2004 @ 03:01:
Ik weet in ieder geval dat het gebaseerd was op het 31-12 BIOS, die naar mijn mening wel lekker klokte. Maar of er ook echt 3,6v uitkwam? Volgens mij wel, want bij het overzicht van de voltages schommelde de Vddr tussen de 3,55 en 3,58 zo'n beetje.
Maar ik heb hem er niet op gehouden, want ik had toen al de Vddr mod gedaan, dus dan werd het een beetje te :P
Ik kan hem trouwens ook niet meer terugvinden op m'n HD. :|
  • mydogisgone
mydogisgone
Watskeburtwithmydog
welke bios versie is nou een goede voor de DFI Lanparty NFII Rev B???
ik heb van het weekend een lan en ik wil mijn bios en of pc niet verneuken door een slecht bios versie.
dus als iemand mij kan vertellen welke het het beste doet :) met een lichte overclock van de fsb :P
  • unfor
  • Laatst online: 25-10 11:27
Ik krijg dit mobo binnenkort ook binnen, samen met een XP-Mobile 2500+ en 2x 256 PC3500 van geil :)
  • Aham brahmasmi
mydogisgone schreef op 08 maart 2004 @ 13:56:
Ff teruglezen in het vorige deel van dit topic, luiwammes. :z
  • Vincentio
unfor schreef op 08 maart 2004 @ 20:05:
Ik heb nu al medelijden met je.
Geil is echt niks en ik spreek helaas uit ervaring :(
  • LeXuS007
  • Laatst online: 13-11 01:05
Infinity + BH6
CPC aan
Standaard NB SB koeling nog
Afbeeldingslocatie: http://home.quicknet.nl/qn/prive/vt.nguyen/250.JPG
[ Voor 23% gewijzigd door LeXuS007 op 08-03-2004 21:30 ]
AMD Opteron 165 | Asus A8R-MVP | Twinmos 2x512MB BH5-UTT | Hitachi T7K250 250GB SATA-II | X800GTO²
hahaha nog ff verder clocken jonge :)
Afbeeldingslocatie: http://members.chello.nl/~pleeuwesteijn/images/SANDRA3900.JPG
Afbeeldingslocatie: http://members.chello.nl/~pleeuwesteijn/images/pi5547-2.JPG
mushkin bh5 lvl2 @ 3.3 v @ 11-2-2-2 >:)
CPC aan, en ik draai nog dual channel ook! 8)
[ Voor 25% gewijzigd door Verwijderd op 09-03-2004 08:36 ]
  • Tjaps
Tjaps
Snap ik toch...
LeXuS007 schreef op 08 maart 2004 @ 21:30:
Infinity + BH6
CPC aan
Euu..... volgens mij doe je iets niet helemaal goed want je mem score is heel erg laag voor die FSB.
EDIT:
Navi gaat ook wel leuk :)
Tijd voor een Vmem modje ? ;)
[ Voor 11% gewijzigd door Tjaps op 08-03-2004 22:06 ]
  • Spice
Spice
weer een reviewtje: http://www.modthebox.com/review301_1.shtml Met veel mooie plaatjes :).
Ben met 1 reepje Vitesta aan de gang geweest, 3900MB/s in sandra, single channel is wel aardig hoog, of niet ?
[ Voor 8% gewijzigd door Spice op 08-03-2004 23:37 ]
  • willy83
Wat doe ik fout?
Als ik mijn CPC aan zet in de bios dan krijg ik een foutmelding dat mijn windowsinstall gerepareerd moet worden, als ik het uit zet heb ik dit niet.
Timings 11-2-2-2-2-9-12
het maakt niet uit op welk voltage ik mijn geheugen ook zet (bh-5) een FSB van 200 dus ook niet extreem hoog.
Dan nog iets, mijn Vcore schommeld terwijl mijn 3,3V, 5,0V en 12V lijnen stabiel zijn met de multimeter.
willy83 schreef op 09 maart 2004 @ 00:21:
Wat doe ik fout?
Ik heb het ook ik kan CPC tot iets van 220 booten en verder niet het is op sommige planken op een of andere manier gewoon niet mogelijk.
  • willy83
Oee en wat betekeken de 9 en die 12 in mijn timings?
Toen dat op 13-15 stond maakte hij in prime binnen een minuut fouten. Nadat dit op 9-12 stond was hij stabiel.
  • Tjaps
Tjaps
Snap ik toch...
Spice schreef op 08 maart 2004 @ 23:36:
Welke FSB haalde je SC met die Vitesta ?
3900 is zeker niet gek voor SC :)
[ Voor 6% gewijzigd door Tjaps op 09-03-2004 08:37 ]
kep net die mobile 2400+ betaald, en wat mosfet koelblokjes besteld, dus je kan binnenkort de echte results verwachten :p
doelstelling ~2550 mhz
pifast ~51 sec
  • Spice
Spice
The Doctor schreef op 09 maart 2004 @ 08:37:
262 :).
  • Aham brahmasmi
Ahahaha!: http://www20.tomshardware...rd/20040308/kt800-15.html
Ik zat nog een beetje te dubben of ik nou een Infinity zou kopen of nog even zou wachten op nieuwe revisies hiervan en ook KT880 mobo's. Jullie hebben vast wel gehoord dat deze een Dual-Channel geheugencontroller heeft, en de in de bovenstaande uitgebreide test wint de KT880 het bij zo'n 75~80% van de tests met een klein verschil gok ik. :D
Nu nog afwachten of deze chipset een PCI/AGP-lock krijgt en of het ook een overklokmonster wordt (kom maar DFI met een KT880 Lanparty ;) ). Dan wordt het interessant. :)
  • sapphire
  • Laatst online: 15:49
sapphire
Die-hard pruts0r
mmm, ik zit ff vast met dit bordje.
Ik kan gewoon Pifasten en een paar uur Sisoft burnin doen op 255x8 maar dan lopen 3dmark en UT2k3 bench steeds vast, de MP verhogen zou misschien kunnen op 2v maar dat doe ik nog niet omdat ik nog op lucht loop en alles dan wel erg warm word.
240x10 wil die ook niet doen, CH-5 mem op 3,2 en vcore op 1,85 :(
Misschien dat een ander bios zou helpen, iemand een tip welke goed OCed bij nieuwe bordjes ?
iemand nog tips waar je op moet letten met Pifast op dit bordje want ik haal echt belabberde scores.
edit:@ persoon hierboven: Nou lekker veel beeter die via chipset, als ie van de nForce wint is het echt kiele kiele met 1 sec bij encoding of 1 frame bij een game. Ik zou ckers geen bord meer kopen met deze chipset, ga dan gelijk voor de A64.
[ Voor 31% gewijzigd door sapphire op 09-03-2004 14:41 ]
Gabriël AM5
  • Tjaps
Tjaps
Snap ik toch...
sapphire schreef op 09 maart 2004 @ 14:34:
1 - 31
2 - 17 (1-31 romsip)
Zijn veruit de beste biossen 2 - 17 liep bij mij niet zo lekker (kwam er windows niet mee in) maar bij andere doet ie t perfect. Gewoon ff proberen dus.
  • Exigence
Exigence
dnkroz
Hm, ik heb net m'n BH-5 binnen en even snel getest, maar nog steeds kom ik niet echt goed over de 255 heen. Op 3,5v.
Met m'n CH-5 deed ik ook die snelheid, dus ik vermoed dat het aan mijn northbridge ligt, ik heb waarschijnlijk een hele slechte te pakken :+ Zal even kijken wat ik moet halen voor de VDD mod.
  • Aham brahmasmi
sapphire schreef op 09 maart 2004 @ 14:34:edit:@ persoon hierboven: Nou lekker veel beeter die via chipset, als ie van de nForce wint is het echt kiele kiele met 1 sec bij encoding of 1 frame bij een game. Ik zou ckers geen bord meer kopen met deze chipset, ga dan gelijk voor de A64.
Ik wil geen ~350 euro uitgeven voor A64 mobo+proc maar ~100 voor een nieuw AXP mobotje om het maximale uit m'n XP te halen en eindelijk wat ervaring op te doen met overklokken (gaat nauwelijks met m'n KT400). Maar ik vind het toch wel mooi dat VIA uiteindelijk een chipset heeft ontwikkeld die zelfs een tikje beter is dan de NF2 (alleen veel en veel te laat helaas, voor tweakers/gamers iig :/ ).
Maar ik denk dat ik idd toch beter nu een Infinity voor 98 euro koop, aangezien deze waarschijnlijk alleen duurder zal worden de komende maanden (NF2 mobo's zakken niet echt onder de 100 euro, kijk maar naar de 3RDA+/NF7-S/AN-7/A7N8X).
Enige reden waarom ik nog een beetje twijfel is dat er toch best veel DFI's overlijden zelfs bij niet-extreme overclocks, en ik ben gewoon benieuwd hoe overklokbaar die KT880 wordt.
[ Voor 10% gewijzigd door Aham brahmasmi op 09-03-2004 15:11 ]
  • Exigence
Exigence
dnkroz
Hoezo bij "niet extreme" overclocks.... voorbeeld? Volgens mij is er geen enkele DFI overleden die non-oc'ed draaide.
  • sapphire
sapphire
Die-hard pruts0r
tja als er 1000 DFI's worden verkocht en er overlijden er 10 dan denkt iedereen "ow wat zijn er toch veel overleden" terwijl het overgroten merendeel gewoon werkt.
Slechte ervaringen blijven nou eenamel veel langer/beter in je geheugen hangen.
Gabriël AM5
Exigence schreef op 09 maart 2004 @ 15:06:
Voel is of je nb/sb aan de 8erkant van je mobo erg warm worden.
Denk ook aan je cpu die willen ook niet altijd super hoog kwa FSB.
Wat vond je btw van mijn verzendmetode? :P
  • Aham brahmasmi
sapphire schreef op 09 maart 2004 @ 15:48:
Dûh. Dit bord wordt anders wel (o.a.) verkocht als overklokbord en ik volg dit topic ook omdat ik het bord wil kopen om te _overklokken_. Tuurlijk is het op eigen risico; begin daar niet over.
Maar serieus, ik had het idee dat er hier toch ook wel mensen bij zaten die niet zo extreem overgeklokt hadden als bv. Serenity maar wel na een reboot opeens een zwart scherm kregen dat ook nix meer wilde laten zien... maar ik zal nog eens terugzoeken.
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 09 maart 2004 @ 16:33:
Nah, binnenkort een Mobile, dus dan kan ik verder bekijken. Als het dan nog niet lukt doe ik een VDD mod.
Stevig verzonden trouwens :D 8)7 _/-\o_
  • SlowikPL
Ik heb nu problemen met mijn mobo :(
Eerst dacht ik dat het eenmalig was deze vastloper van gisteren. Maar nu het ik het om de 5 min. Zelfs als ik niets doe op de PC :(
In begin valt mijn geluid weg , in nForce op de equalizer gaan alle kanalen op rood en vervolgens bevriest mijn systeem. Geheugen zetten om losse timing helpt niets , allen als ik de FSB ze van 220 naar 200 gaat het goed :(
Ik vind het echt shit. Ook begin ik nu boot problemen ondervinden en het systeem boot niet goed , blijft steken in bios. USB gaan vanzelf uit :(
Shit shit, ik denk dat mijn mobo niet lang meer volhoud. Maar ik moet het meet onderzoek doen voordat ik de mobo schuld geef.
Alle voltages en temps zijn ok :?
Had iemand ook deze ervaring ?
nou als je op 200 fsb draait, dus no od'ed doet hij ut wel.
dus je oc'ed gewoon te ver, niks mis met mobo
koel je wel goed genoeg
  • Exigence
Exigence
dnkroz
SlowikPL schreef op 09 maart 2004 @ 20:39:
Welk geheugen? Wel genoeg volts?
Verwijderd schreef op 09 maart 2004 @ 20:59:
In pricipe is er natuurlijk niks mis met het mobo maar het is natuurlijk altijd jammer als iedereen hard gaat en jij niet. Slowpik
(of wat je nick ook was)
probeer je Southbrige is te coolen, als deze heet word komen er vaak complicaties het geluid voor.
eeeh waarom quote je mij? :p
  • sapphire
sapphire
Die-hard pruts0r
The Doctor schreef op 09 maart 2004 @ 14:51:
1 - 31
Ik snap dat met die romsip niet, kan iemand me uitleggen wat dat is ? :?
Gabriël AM5
  • quarantaine
  • Laatst online: 24-06-2013
quarantaine
mongtastic.be
man , dit moederbord kan serieus moeilijk doen
als ik ga overclocken , boot hij regelmatig nietmeer en bij een biosreset zet hij alles op chs, als ik dan dat verander krijg ik info over men graka bij de volgende boot en dan blijft hij hangen.
gisteren een paar uren zitten klooien maar hij werkt nu blijkbaar alleen maar fatsoenlijk als je de jumper van 100fsb weghaalt.
mss men bios herflashen ? (iemand een id dewelke goed zou werken)
  • SlowikPL
Ik heb nu de mama plank uitgebouwd en in gebruik genomen buiten de behuizing om even te kijken welke onderdelen warm worden. De SB word inderdaad zeer warm dat ik mijn vinger niet al te lang op kan houden. Deus denk ik dat het daar aan lag. Ik ga een NB water blokje aanschaffen voor de SB. Weet nog niet op welke manier ik gen ga monteren want er zitten geen gaten rondom de SB.
Ik zaal me even melden of dit inderdaad mijn probleem was om dit super – plankje te overkloken.
SlowikPL schreef op 10 maart 2004 @ 22:45:
Kijk das weer een zorg minder (het was al een algemeen probleem bij de Nforce bordjes en dus ook bij deze plank blijkt) dus binnenkort gaan we knallen SlowikPL!
  • willy83
Wat voor koeling gebruiken jullie voor op de SB?
Gewoon het standaard blokkie met een vette fan er op?
Od zo'n zalman vervanger voor op de NB?
  • Tjaps
Tjaps
Snap ik toch...
willy83 schreef op 10 maart 2004 @ 23:16:
Als je je SB gaat koelen is een zalman blokje + een beetje airflow meer dan genoeg.
Maar ook zonder koeling moet 250 niet echt een probleem zijn lijkt mij.
Ik haal het iig simpel met alleen NB koeling.
The Doctor schreef op 10 maart 2004 @ 23:42:
ik heb de nb heatsink op de sb gelijmt en deze blijft gewoon kamer temp ondanks dat er geen flow op komt. voor de heatsink werd hij wel goed warm.
  • willy83
Binnenkort/over een tijdje als mijn mobile binnenkomt(IA) dan zullen we eens kijken
  • Aham brahmasmi
Verwijderd schreef op 10 maart 2004 @ 22:52:
Bij sommige reviews van de DFI's wordt geschreven dat het mooi is dat er een koelblokje op de SB zit maar dat dat echt niet nodig is want deze wordt absoluut niet warm. |:( Nooit aan gevoeld zeker... Ik herinner me een infraroodforo van de Epox 8RDA+ waarop duidelijk te zien was dat de SB echt een stuk heter werd dan de NB (NB was natuurlijk afdoende gekoeld). Ik dacht dat de nieuwere steppings van de MCP-T iets minder warm werden maar dat is inmiddels ook alweer een tijd terug. Feit blijft dus dat de SB koeling nodig heeft, zeker bij overklokken (misschien slechte airflow in je kast, SlowikPL?).
@VinnieWeiss: misschien dat het per mobo een beetje verschilt maar als je airflow slecht is kun je beter eerst idd het NB blokje erop plakken (Zalman of waterblokje op de NB) en een fan erover laten blazen ofzo. Niet dat er veel overklokkers zullen zijn die een slechte airflow hebben ;) maar toch raar dat de SB bij SlowikPL zo heet werd.
[ Voor 19% gewijzigd door Aham brahmasmi op 11-03-2004 02:20 ]
  • Vincentio
SB heeft natuurlijk niet per see koeling nodig. Kijk maar naar de dingen die de SB moet doen.
Ik kwam zonder koeling op mijn NF7-s net zo ver als met, alleen nu is mijn geluid nog goed op 230mhz, wat anders echt verrot begon te klinken.
  • Spice
Spice
Dat zou ik ook graag willen weten :).
Ik denk toch dat ik er een simpel koolance blokje oplijm, ik heb geen idee hoe anders.
  • SlowikPL
Aham brahmasmi schreef op 11 maart 2004 @ 00:45:
Wan mijn airflow in de kast betreft is het 100% goed.
3x 120mm fans Entermax
5 x 80mm fans Papst
Ik denk als ik mij nog een fan opzet dan gaan mijn kast van 80 kg vliegen.
PS;
In mijn case is nu 18C en mijn SB word +/- 38C :)
SlowikPL schreef op 11 maart 2004 @ 11:19:
5 x 80mm fans Papst
PS;
toch een dikke 20C verchil maar zolang je onder de grens (mijn grens iig) van 50C blijft maakt het niet veel uit.
  • MaTr1x
Ik zat aan hetzelfde te denken om te gaan doen als ik mijn water cooling binnen heb tezamen met m'n RevB Lanparty (nog ff w8 op geld).
Zou het misschien kunnen met een socket A hold down zoals die van TS:
Afbeeldingslocatie: http://www.tweakstore.nl/shop/images/m4shd1_lg.jpg
Maarreh dan moet je nog wel een RBX of Maze3/4 hebben liggen, want alleen die kun je daarmee gebruiken....
π MW finishers
  • Tjaps
Tjaps
Snap ik toch...
Het is imo erg nutteloos om een waterblok op je SB te monteren.
Een zalman NB blokje + 4x4 fan koelt net zo goed en kost stukken minder.
  • Spice
Spice
Zo duur is een simpel wb niet, de ukkepukkies die ik heb van koolance heb ik allemaal voor 15 euro gekocht, bovendien is het stiller.
Maar goed nieuws, ik kan weer aan de gang, de postbode bracht net een pakje uit Zweden waar een bios-saviour inzit, ben benieuwd.
  • sapphire
sapphire
Die-hard pruts0r
Ik heb gewoon een Zalman NB47J erop, klein beetje airflow erop en hijs lekker koel :). Met de standaard sink kwam ik trouwens ook gewoon op fsb 255 ondanks dat ie lekker heet werd.
Gabriël AM5
  • Syzzer
  • Laatst online: 11-11 00:18
Syzzer
Prutser
Stukgezaagde oude coolermaster sink voor een Duron1100 werkt ook perfect. Beetje airflow in me kast en het ding wordt (werd :( ) absoluut niet heet meer.
Spice schreef op 11 maart 2004 @ 14:27:
Vanwaar helemaal uit zweden :?
  • Spice
Spice
Ik kon ze hier niet vinden, vandaar.
  • Syzzer
Syzzer
Prutser
Dus nu weten we waar we onze bios-chip heen moeten sturen als hij corrupt is? >:)
FF serieus:
Had jij ook dat alle 4 de leds bleven branden en het board niet wilde booten? Dan zou het voor mij wellicht ook een oplossing zijn.
  • Spice
Spice
Syzzer schreef op 11 maart 2004 @ 18:34:
FF serieus:
Yep, maar die heb ik ge-RMA't dit is mijn 2e en ben nu wat behoedzamer vandaar de saviour.
  • Exigence
Exigence
dnkroz
Spice schreef op 11 maart 2004 @ 18:43:
Tweakstore heeft BIOS-chips van DFI voor 5 euro inclusief verzenden :) Alleen wordt er atm niet op de mails gereageerd, maar da's een probleem van de TPG geloof ik :D
  • Syzzer
Syzzer
Prutser
In dat geval ga ik binnekort (weer! ben de afgelopen 7 dagen 3 keer geweest) maar eens langs tweakstore, voor die 5 euro wil ik de gok nog wel wagen.
heb deze nu ook op mn bureautje liggen (Lanparty Ultra B) maar wat ik me afvraag, hiervoor heb ik een NF7-s gehad, en daar werd aangeraden de NB ook te lappen ivm bol lopen van de casing immers.
zijn er al mensen die het bij dit bord hebben gedaan? of is het niet nodig bij de DFI borden?
en hoe zit het met de steppings van de NB, zit er nog veel verschil in? heb de coller er al afgehaald, want mn WC blokje moet er namelijk op, en ik zag A1 staan, en wat me bijstaat uit de eerdere Abit draadjes dat er ook nog verschil zat tussen de NB steppings qua OC potentie...
[ Voor 9% gewijzigd door Verwijderd op 11-03-2004 20:30 ]
  • Spice
Spice
Ik heb gewoon naar DFI gemaild in december voor een bioschipje, DFI stuurde het chipje netjes op, voor niks!
[ Voor 28% gewijzigd door Spice op 11-03-2004 20:25 ]
  • MonkeySandwich
  • Laatst online: 09-11 16:43
Ik heb me lanparty plankje sinds vandaag ook binnen!!! (Gister was ik niet thuis toen de postbode kwam) Heb nu ook nog geen tijd om hem in te bouwen, toch wel jammer zon stage :( maarja, we gaan toch pas echt hard als de mobile binnen is :9
  • Spice
Spice
Plaatje met wat temps van de diverse mosfets, handig als je wilt gaan heatsinken. Dit zijn ze overigens niet allemaal, bij de AGP-sleuf zit ook een erg warme.
Dit geeft alvast wel een goed beeld van de diverse temps:
Afbeeldingslocatie: http://www.hwcool.com/forum/files/dfi-255-mhz-rilevamenti-temp.gif
Wat doet 'Thermal throtling' eigenlijk? De rede dat ik het vraag is het volgende: Als ik m'n fsb boven 200MHz zet, gaat de fsb schommelen bij m'n Barton. Soms schommelt ie enkele MHz-en. Om alles uit te sluiten heb ik er ff een XP1800+ ingezet en de CMOS gecleard. Ik was vergeten om de tt te disablen en ik zag dezelfde schommeling op stockspeed bij de 1800+ die ik bij m'n 2500+ >200Mhz fsb zag. Het lijkt er dus op dat de tt stiekum toch aanstaat. Overigens kan het niet aan de temps liggen want die waren op 11x220@1,95V max 46 graden. Met tt aan op de 1800+ zie ik het effect al verschijnen bij een stressed temp van 31 graden. Wat ik al gedaan heb? Alles. Samen met Travis van DFI heb ik alles doorgelopen en samen kwamen we er niet uit. Het enige wat ik net tegenkwam en nog niet gedaan heb, is de 100MHz jumper eraf gehaald. Iemand info over de functie van tt en het voordeel van het verwijderen van de 100MHz jumper?
  • esox-oc
esox-oc
atec
kheb ffies vraagje over m'n mem op men infinity dat doet naamlijk nogal vaag als ik er een 2600+ barton ingooi ipv 2000+ het zit zo. als ik mijn 2000+ erin heb zitten kan het geheugen(geil pc 2700 cL 3) gerust op 3 v en cl 2-2-2-2 en fsb @ 186 maar zodra ik m'n 2600+ erin zet trekt ie niet meer dan 2.6 v en een fsb @ 150, de timings blijven dan wel 2-2-2-2. |:( iemand een verklaring?
http://specs.tweak.to/10443
2-2-2-2 ? wrom die eerste 2, op nforce 2 schijnt 11 het snelst te zijn
11-2-2-2 voor AMD
5-2-2-2 voor P4's hoor ik altijd...maar jij doet 2-2-2-2?
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 12 maart 2004 @ 19:06:
11-2-2-2 voor AMD
Nou, deze DFI's zijn voor zover bekend de enige uitzondering op de regel dat 11-2-2-2 op een nForce sneller is als 5-2-2-2. Bij de DFI is strakker gewoon sneller. Dus ook al is het een nForce2.... 5-2-2-2 is sneller.
Maar ik denk dat hij het wel goed bedoelt, die 2-2-2-2, want in het BIOS zit er nog een getal tussenin :?
Dus 11-2-2-2-2 :)
  • Vandread
  • Laatst online: 09:42
erik ff btw.... je hebt een PM van mij op een ander forum... ;)
en je site is aardig oud :+
""Ik ben van plan binnen kort een AMD Athlon XP 1800+ (Thoroughbred, 1533 MHz)
te kopen (meestal zijn die over te klokken naar plm. 1900 - 2000 Mhz)""""
hehehe ;)
  • HeepH
  • Laatst online: 15-11 21:43
HeepH
Dope Rapper
dus dit bordje klokt wel lekker ? ik zie sommige van jullie een fsb halen van 255 ? ik neem aan dat je dat met vmod hebt gedaan ? en heb je dan ook sinks op die mosfets geplakt? of is dat met eeen ''standaard'' moederbord?
wat is er trouwens voor verschil tussen de lanparty en de infinity kwa overclock....helemaal nix ? want dan ga ik voor de infinity, ik hoef geen koele tas en groene kleurtjes ( cker niet als ze me 50 euro meer kosten ;P)
(edit : prijs van lanparty... :|)
[ Voor 12% gewijzigd door HeepH op 13-03-2004 01:09 ]
http://specs.tweak.to/16495
  • _Droopy
_Droopy
Hmmm, voor zover ik weet is er GEEN verschil tussen de LP en de infinity.
Behalve de extra's en die UV-slots + aan/uit & reset knoppen.
Ik heb m'n LP gesloopt, en ga (als de belasting m'n geld terug gestort heeft) voor de infinity. (evt soldeer ik de slots van m'n oude LP wel over op m'n toekomstige infinity, who know's)
Dus voor de overclock resultaten hoef je geen LP te halen. (voor de inkomsten van de verkopende zaak misschien wel, maar da's de alcohol talkin', not me ;) )
  • sapphire
sapphire
Die-hard pruts0r
HeefStan schreef op 13 maart 2004 @ 01:00:
ik haalde 255 standaard zonder sinks te verwisselen en zonder vmods oid :)
Verwijderd schreef op 11 maart 2004 @ 20:22:
Bij mij stond ie iig wel bol, dus heb ik em maar gevlakt, niet dat het bord harder ging, alleen de bord temp daalde wat.
[ Voor 39% gewijzigd door sapphire op 13-03-2004 20:02 ]
Gabriël AM5
  • Fern
  • Laatst online: 22-08 08:54
Vandread schreef op 13 maart 2004 @ 00:43:
hehehe ;)
Ik heb nu een xp1800 draaien op 2,2Ghz,is zeker niet slecht ,is eentje van 0344.
had hiervoor een xp3000,die ging stabiel tot 2,3.was een 0313.
overigens,die xp1800 van mij draait nu op een Iwill xp333/r bord,ben heel benieuwd wat ie op m´n Lanparty doet :)
PowerStation
  • quarantaine
quarantaine
mongtastic.be
na veel problemen en een 5tal biosen eindelijk de goede voor mijn bord gevonden :)
240fsb is mogelijk maar het wordt een beetje te warm met de stockkoeling dus ik heb hem maar terug op 230 gezet.
alles loopt nu lekker soepel dusjah, wat kan je meer wensen (250fsb mss }) )
  • willy83
Zit er zo veel verschil in de biossen dan?
Ik wist wel dat er verschil in zat. maar over wat voor verschil praat je dan?
En is dat meestal een bepaalde die het op alle goed doet voor de infinity of dat verschilt echt per versie?
  • PASware
  • Laatst online: 15:57
willy83 schreef op 14 maart 2004 @ 00:05:
het kan idd veel verschillen, bij de ene werkt een bepaald bios beter dan bij een ander. Als je zelf wilt weten wat voor jouw het beste is: test ze :)
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
  • Xtremer
  • Laatst online: 15-11 18:57
quarantaine schreef op 13 maart 2004 @ 23:58:
En welke bios versie is dat ?
Wil je dat delen met Ons ;)
Zit namelijk maar met 247 fsb :|, Ik wil hoger ;)
Xtremer schreef op 14 maart 2004 @ 12:14:
PASware schreef op 14 maart 2004 @ 12:11:
Lezen is ook een kunst appart :)
