[OC-Ervaringen] Lanparty NFII Ultra B en Infinity
Pagina: 1 2 ... 7 Laatste
  • 2.628 views sinds 30-01-2008
  • Spice
  • Laatst online: 09-01 14:46
Spice
- Mijn vader is een tovenaar -
Het gaat om deze planken:
LANPARTY NFII ULTRA B
Afbeeldingslocatie: http://www.lanparty.com.tw/Upload/Product_Picture/LP%20NFII%20ULTRA%20B%20b.jpg
CPU
AMD Athlon XP 266/333/400MHz FSB
AMD Athlon 200/266MHz FSB
AMD Duron 200/266MHz FSB
Chipset
nVIDIA® nForce2 chipset
- nForce2 Ultra 400
- nForce2 MCP-T
System Memory
Supports dual channel memory interface
Supports up to 3GB memory (unbuffered DIMM)
Supports PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400)
DDR SDRAM DIMM, 2.5V type
Three 184-pin DDR SDRAM DIMM sockets
BIOS
Award BIOS, Windows® 95/98/2000/ME/XP Plug and Play compatible
Genie BIOS provides:
- CPU/DRAM/AGP overclocking
- CPU/AGP/DRAM/Chipset overvoltage
4Mbit flash memory
CMOS Reloaded
Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-USB
- Wake-On-Ring (external modem)
- Wake-On-LAN
- RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system temperature
Monitors ±12V/5V/3.3V/VBAT(V)/5VSB(V) voltages
Monitors CPU/chassis fan speed
Read back capability that displays temperature, voltage and fan speed
CPU Temperature Protection function monitors CPU temperature during system boot-up
Audio
Realtek ALC650
AC'97 2.2 S/PDIF extension compliant codec
Supports Microsoft® DirectSound/DirectSound 3D
AC’97 supported with full duplex, independent sample rate converter for
audio recording and playback
S/PDIF-in/out interface
6-channel audio output
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy
- Full duplex support at both 10 and 100 Mbps
Realtek RTL8110S Gigabit LAN
- Full duplex support at 10, 100 and 1000 Mbps
PCI IDE
Supports ATA/33, ATA/66, ATA/100 and ATA/133 hard drives
UDMA Modes 3, 4, 5 and 6 Enhanced IDE (data transfer rate up to 133MB/sec.)
SATA IDE with RAID
Silicon Image Sil3114 PCI to Serial ATA controller
Supports four SATA (Serial ATA) interfaces which are compliant with SATA 1.0
specification (1.5Gbps interface)
Supports RAID 0 and RAID 1
IEEE 1394
nVIDIA® nForce2 MCP-T and Agere FW803 Phy chips
Supports three 100/200/400 Mb/sec ports
AGP
Supports AGP 8x up to 2132MB/sec. and AGP 4x up to 1066MB/sec. bandwidth
for 3D graphics applications
Rear Panel I/O Ports #(piccie verderop)
1 PS/2 mouse port
1 PS/2 keyboard port
1 DB-9 serial port
1 DB-25 parallel port
4 USB 2.0/1.1 ports
2 RJ45 LAN ports
2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
3 audio jacks: line-out, line-in and mic-in
2 audio jacks for center/bass and rear out
I/O Connectors
1 connector for 2 additional external USB 2.0/1.1 ports
3 connectors for 3 external IEEE 1394 ports
1 front audio connector for external line-out and mic-in jacks
2 internal audio connectors (AUX-in and CD-in)
1 S/PDIF connector for optical cable connection
1 connector for IrDA interface
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
2 ATX power supply connectors
3 fan connectors for CPU fan, chassis fan and 2nd fan
4 diagnostic LEDs
1 diagnostic LED connector for external 4 diagnostic LEDs display
EZ touch switches (power switch and reset switch)
Expansion Slots
1 AGP slot that supports 8x/4x AGP
5 PCI slots
PCB
4 layers, ATX form factor
30.5cm (12") x 24.5cm (9.64")
#Rear Panel
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/backplane.jpg
heatsinkje southbridge(zit met thermal tape losjes vast)
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/sb_sink.jpg
INFINITY
Afbeeldingslocatie: http://www.dfi.com.tw/Upload/Product_Picture/NFII%20ULTRA%20INFINITY%20b.jpg
CPU
Chipset
- nForce2 Ultra 400
- nForce2 MCP-T
Memory
BIOS
4Mbit flash memory
CMOS Reloaded
Power Management
- Wake-On-USB
- Wake-On-LAN
Hardware Monitor
Audio
Realtek ALC650
AC’97 supported with full duplex, independent sample rate converter for audio recording and playback
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy chips
Integrated IEEE 802.3, 10BASE-T and 100BASE-TX compatible PHY
PCI IDE
SATA IDE with RAID
IEEE 1394
AGP
1 PS/2 mouse port
1 DB-9 serial port
4 USB 2.0/1.1 ports
1 RJ45 LAN port
I/O Connectors
2 IDE connectors
1 floppy connector
Expansion Slots
5 PCI slots
PCB
Meer specs
CPU Clock: 100MHz to 300MHz in 1MHz increments
CPU Multiplier: 5 to 22 in 0.5 increments
CPU Voltage: 1.1V to 2.0V in 0.025V increments
AGP Voltage: 1.5V to 1.8V in 0.1V increments
Chipset Voltage: 1.6V to 1.9V in 0.1V increments
DRAM Voltage: 2.6V to 3.3V in 0.1V increments
Verschillen LANPARTY NFII ULTRA B en LANPARTY NFII ULTRA rev. A
A ->Audio Connectivity 3 port backplane speaker
B ->S/PDIF I/O on I/O shield 5 port backplane speaker, S/PDIF I/O on backplane
A ->IDE RAID Highpoint HPT372N RAID controller w/ 2 ports
A ->SATA Marvell 88i8030, 1 port bridge from primary ATA
B ->SATA RAID 4 device RAID0, RAID1 Silicon Image Sil3114, 4 port
A ->NVIDIA 10/100, RTL8101 10/100
B ->NVIDIA 10/100, RTL8110S 10/100/1000
B ->Mounting holes rondom de socket
Uit de review van Hexus*
A nip here, a tuck there. The biggest change is the dropping of IDE RAID support in favour of SATA. The Sil3114 offers 4 full SATA channels which the board duly makes good use of, giving you 4 physical ports to hang your drives from. The chip does RAID0 and RAID1 on all channels, giving you decent flexibility in your disk configuration. You can run seperate RAID levels on two channel pairs, as far as I can make out without explicit testing anyway. The lack of physical IDE ports for the old Highpoint chip on the old board means a layout change for the B revision, I'll talk about that on the following page.
Verschillen LANPARTY NFII ULTRA B en Infinity
De lanparty heeft naast 100 Mbit Nvidia lan een Realtek RTL 10S Gigabit lan onboard.
De goodies zitten alleen bij de LANPARTY
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/box_inside2.jpg
Sleurtas (Transpo)
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/transpo.jpg
Rounded (uv-sensitive) cables (1 ide en 1 fdd)
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/rounded_cables.jpg
Frontx -> met o.a.: diagnostic LED connector for external 4 diagnostic LEDs display http://www.frontx.com
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/frontx.jpg
2 SATA-kabels en SATA voedingsconnector
1 DFI Lanpartysticker
1 DFI Lanpartycasebadge
and last but not least: power and resetbutton op het mobo, werkt dus dmv alleen de voeding aan te sluiten :).
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/sata.jpg
De Lanparty heeft een UV-coating en 4 diagnostic LEDs op het mobo(en extern), de Infinity niet.
Links naar fabrikant+mobo:
http://www.lanparty.com.t..._r_us.jsp?PRODUCT_ID=2320
http://www.lanparty.com.tw/LP1/index_lp_us.jsp
bios:
http://www.lanparty.com.t...Y_TYPE=null&STATUS_FLAG=A
INFINITY
http://www.dfi.com.tw/Sup...Y_TYPE=null&STATUS_FLAG=A
beta-bios:
Die duiken op 4 verschillende plekken op :(.
De meeste recente verschijnen op: http://forums.amdmb.com/s...ad.php?s=&threadid=281088
verder op**: http://www.dfi.com.tw/Sup...DEX_TYPE=MB&STATUS_FLAG=B
en op: http://www.angrygames.com/CMOS_Reloaded_NFIIB.htm
en tenslotte dook er 1tje op bij: http://www.xtremesystems....6&perpage=25&pagenumber=5
INFINITY
http://myweb.hinet.net/ho...dfi/betabios/N24IDC18.zip
bios en utilities verzameld door Psychosis op: http://www.midnightmachine.com/dfi/
What are recommened DDR memory modules on LANPARTY NFII UltraB?
http://www.lanparty.com.t...SUBMITTED=No&PAGE_TYPE=US
Issues
1) De ruimte rondom de socket
Die is krap. De volgende (onscherpe doch functionele) foto zal veel verduidelijken:
Afbeeldingslocatie: http://www.experimentalinsanity.com/upload/images/zalmanonscherp.jpg
Vanaf hier gezien zit er linksboven een laag chipje naast de socket, door de gebruikte constructie van zalman heb ik er geen last van, de koeler wordt aangedraaid op de 2 dwarsverbindingen. Van andere gebruikers heb ik gehoord dat ze met wat washers onder de steunconstructie werken om te voorkomen dat dit chipje wordt geplet.
Zie ook: http://forums.amdmb.com/s...ad.php?s=&threadid=278704
2) 2,0 volt is momenteel het maximale van de Vcore, zonder mod
Hier (op GoT) werd er geopperd dat deze d.m.v. een bios update verhoogd kan worden, ik heb hier nog niks overgelezen! Zodra ik iets concreets weet zal ik het hier posten. Tot die tijd is het misschien een idee om na te gaan denken over een eventuele mod.
3) Grote fluctuaties op de 5 en 12 volt rail
Ik heb er zelf geen last van (TrueControl) maar het wordt wel genoemd in de diverse fora. Ik heb me er niet in verdiepd omdat ik er geen last van heb. Het staat wel als puntje op mijn agenda om het mee te nemen.
4) Memoryproblemen
Heb ik ook geen last van, ik gebuik dus A-data oem wat waarschijnlijk geen BH-5 chippies zijn. Het blijkt dat reepjes beplakt met winbond het beste werken op deze plank. Hiervoor geldt weer hetzelfde als voor het vorige punt, geen last van staat op de agenda
threads over wel/niet passen verschillende luchtkoelers
Thermalright 900a
http://forums.amdmb.com/s...ad.php?s=&threadid=280992
Zalman CNPS7000A
http://forums.amdmb.com/s...ad.php?s=&threadid=275858
Swiftech MCX462-V
http://forums.amdmb.com/s...ad.php?s=&threadid=279640
Thermalright AX-7
http://forums.amdmb.com/s...ad.php?s=&threadid=279623
reviews:
http://www.hexus.net/cont...?dXJsX3Jldmlld19JRD02NjA= *
http://www.hardocp.com/article.html?art=NTU4
http://ohls-place.com/nuk...ews&file=article&sid=3729
http://www.envynews.com/index.php?ID=606
http://www.fastlanehw.com...?action=view&id=65&page=1
http://www.themodfathers....page=&action=show&id=6362
http://www.hardwarezoom.c...jsp?ReviewID=184&PageNo=1
INFINITY
http://www.mbreview.com/nf2inf.php
links (fora-INFINITY en LANPARTY NFII ULTRA B meestal door elkaar in 1 topic):
Bijna alle topics op:
http://forums.amdmb.com/forumdisplay.php?s=&forumid=66
en hier de overige die ik heb gebruikt:
http://www.xtremesystems....6&perpage=25&pagenumber=1
http://www.xtremesystems....readid=24691&pagenumber=1
http://www.ocworkbench.co...b=get_topic;f=34;t=000015
Voorlopige bevindingen (resultaten) van mijzelf
Gedaan op LANPARTY NFII ULTRA B met bios LPNFIIULB1127 (laatste bios bij DFI zelf):
Processor: AMD 1700 XP Th-B. Zonder aanpassing om deze 133 op 166/200 standaard te laten draaien!
2 x 256 MB A-Data DDR3200 (dual channel, 2 en 3)
Afbeeldingslocatie: http://www.barebones4u.nl/imageshomepage/adata.jpg
Dit laatste werkte voor mij het beste, met de nieuwste beta bios** kun je beter 1 en 3 combineren.
nb: 1 reepje in 1 gaat ook als een speer, weinig minder dan dualchannel kwa prestaties in Sandra.
Antec 550 TrueControl
Koolance pc2 kast, NB watergecooled, CPU gekoeld met Zalman ZM-WB2 waterblok
review: http://www.themodfathers....page=&action=show&id=6200
3 casefans, niet aan tijdens testen (kast is niet af)
CD-rom: LG 52X
DVD± RW: BTC DRW 1008IM (nog niet in de PW >:))
link: http://www.btceurope.nl/english/2-2-dvd_rw.htm#drw1008im
Videokaartje: tests gedaan met Matrox Parhelia 128MB bulk
HD: Maxtor 120GB (DiamondMax Plus 9, 7200rpm, 8MB)
Gelukt (pifast) 9,5 * 250
Afbeeldingslocatie: http://www.barebones4u.nl/imageshomepage/pifast2.JPG
252 Sandra mem
Afbeeldingslocatie: http://www.barebones4u.nl/imageshomepage/mem252snelsmall.JPG
geheugen op 252. Timings zijn niet fantastisch maar het ging om de hoogste fsb. nb: het is oem geheugen van momenteel 35 euro per latje :).
Later (misschien zondag) hoop ik resultaten te posten met een andere CPU, Barton 2500 XP mobile :).
Geheugen wil ik vervangen door:
A-Data DDR4000 oem of Vitesta
review:
http://www.nordichardware...00_roundup/index.php?ez=3
Voorlopige bevindingen (resultaten) van Oskar-wu (medwerker DFI)
After several BIOS modify and timing fine tuning , finally break 4100MB/sec barrier ...
Configuration :
Barton 3200+ @ 266 * 10 @ 2.0V
ChipSet Voltage @ 1.7V
Memory Voltage @ 3.3V
AGP Voltage @ 1.5V
ATI R9800 PRO @ default clock
A-DATA Winbond BH5 Single Side 256MB * 2
DRAM Timing and Driving :
11-2-2-2-2-9-12-Enable-Enable-Fast
Auto-Auto-Auto-Auto-Auto-Auto
Note : CPU is watercooled and an extra FAN for PWM airflaw is a must because there is no CPU FAN air flaw to the PWM when you using Liquid Cooling or Vapor Phase Change Cooling
pic: http://myweb.hinet.net/home8/oskarwu/266-4100.jpg[/img]
link: http://www.xtremesystems....1&perpage=25&pagenumber=1
[ Voor 34% gewijzigd door Spice op 08-01-2004 23:10 ]
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
die Lanparty lijkt me een erg trendy bordje, zeker als je een fsb van 250 kan draaien is dat natuurlijk niet verkeerd :9
en die UV stuff op de mobo is ook niet verkeerd natuurlijk
4x sata is ook erg netjes.. nu nog een dvdbrander/cdrom speler die werkt op sata zijn we eindelijk van de ide af. Start je pc gelijk een stuk sneller op.
[ Voor 31% gewijzigd door Verwijderd op 19-12-2003 17:26 ]
  • Wormaap
Dat lanparty bordje ziet er wel funky uit, vooral met al die leuke extraatjes :P
Wat gaat't geintje kosten?
Ticking away, the moments that make up a dull day
Wormaap schreef op 19 december 2003 @ 18:06:
Kun je zo opzoeken hoor.. maar hij kost 158 euro..niet niks dus, maar wel compleet. De Infinity is wat goedkoper als het goed is, maar die heb ik nog nergens gezien in NL..
  • Remy
  • Laatst online: 17-11 20:15
Remy
I usually get 100% accuracy
Hoeft niet dubbel:
[rml][ Ervaringen] DFI LanParty NFII Ultra 400[/rml] in PMG, en staat de Infinity ook in. Bovendien is de startpost een stuk netter.
Alle info over de bordjes in 1 topic houden is wel zo handig en overzichtelijk.
Ok, ff duidelijkheid gekregen van Fewture Serenity, dit zal dus specifiek over het OC'en van de bordjes gaan. Gaat u vooral uw gang :)
[ Voor 38% gewijzigd door Remy op 19-12-2003 18:14 ]
LinkedIn
Instagram
  • Vincentio
Overigens als je van plan ben voor beter geheugen te gaan, zou ik toch voor Mushkin PC3500 Black Level 2 gaan, aangezien die vaak wel met lagere timings en hoge mhz'en werken ipv PC4000 geheugen wat qua timings vaak erg brak is. En lagere timings is natuurlijk vaak wel beter.
Ik zal is kijken of ik misschien via via ook nog wat info kan krijgen over het bordje >:)
  • OverSoft
  • Laatst online: 23-11 08:41
Onzin, elk mobo werkt met alleen de voeding aangesloten...
Een schroevendraaier op de powerbutton pins is genoeg om em aan te zetten
NL: 3x Victron Multiplus II 5000VA, 1x Victron SmartSolar MPPT RS 450/200, 50kWh (3x Yixiang v2 met EVE MB30's) | IT: Deye SUN-15K-SG01HP3-EU-AM2, Deye BOS-G50 Pro (51,2kWh HV)
OverSoft schreef op 19 december 2003 @ 19:24:
Ja, maar bij deze zitten dus knopjes op het mobo als ik me niet vergis.. Je hoeft dus niet met een schroevendraaier te pielen..
Helemaal links zie je 2 knopjes op het mobo zitten ;)
Afbeeldingslocatie: http://www.lanparty.com.tw/LP1/images/imagebank/lp_other_15b.jpg
[ Voor 27% gewijzigd door Verwijderd op 19-12-2003 20:03 ]
  • Astennu
  • Laatst online: 19-08 17:53
Die 502 fsb die je post is nix vergeleken met wat de mobo's kunnen er zijn mensen @ Xtreme die halen 268 1:1 wat dus gelijk staat aan 536 Mhz op strakke timings :9~ dus ik ga maar voor een infinity kijken :P
  • Garrett
  • Laatst online: 22-11 06:58
Garrett
Watercooler
Ik heb idd ook het idee dat ik die Abit een rotschop moet geven :D
Alleen nog effies wachten tot er een voltmodje is voor de cpu, want dat moet natuurlijk over die 2.0 volt heen he ;) :D :+
I love watercooling
  • Stinger666
  • Laatst online: 08-02 00:01
Mooi startpost. Ik hoop wat aan deze draad te gaan hebben.
[Offtopic] Nu mn Shuttle SN45G overleden is en gecrediteerd wordt heb Stinger weer centjes [O/Offtopic]
Ik heb hier nog een overleden NF7-S liggen, maar daar begin ik niet meer aan! Die dingen gaan zo dood. Ik hoop dat DFI een mooie plank heeft gemaakt voor het betere OC-werk.
Iedereen die daar voor gaat moet duidelijk letten dat tie de ULTRA B te pakken heeft! Het eerste bord heeft geen gaten rond de socket en deze wel.
De Infinity heeft duidelijk minder ballen de dan LanParty.
Alleen heb ik nog wat onduidelijheid over de voltages, want door de verschillende types heb je ook verschillende voltages!
[ Voor 11% gewijzigd door Stinger666 op 20-12-2003 15:04 ]
Ik hoop dat al deze bordjes het goed doen, en je geen geluk moet hebben. Zoals het er nu uitziet, wordt dit mijn volgende bordje wel... Dit dacht ik eerst ook van de AN7, maar blijkbaar doen deze het niet zo goed. Ik vind het alleen wel spijtig dat ze zo duur kosten. Dit komt mede doordat er een grote troep accessoires wordt bijgeleverd die mij helemaal niet interesseren. Die flashy kleuren mogen er voor mijn part best wel zijn 8)
  • SmokeyTheBandit
  • Laatst online: 01-11 04:49
SmokeyTheBandit
DOCer met Pensioen
Echt een heel onder gewaardeerd boardje maar de prestaties zijn van de hoogste orde ;)
Als ik het zo zie past daar niet/net aan een prom op maar de ruimte houd niet over :/
[ Voor 3% gewijzigd door SmokeyTheBandit op 20-12-2003 18:39 ]
Turn it off and on again.
  • YoupY
  • Laatst online: 08-06-2024
Garrett schreef op 19 december 2003 @ 23:01:
Voltmodje is er al, hoorde ik gisteren van Serenity. Als het goed is zit er een HIP6301 chip op die het voltage voor de core regelt. Door een 50 K vr op pin 7 te zetten kun je zelf het voltage aanpassen
Geen credits voor mij, mod is niet door mij bedacht, heb er alleen maar van gehoord. Als 2.3 op de abit nf7-s niet genoeg is, dan zou deze mod ook daar nog kunnen helpen >:)
  • Spice
Spice
Openingspost afgemaakt, en ge-edit, opmerkingen/aanvullingen en commentaar welkom. Voltmod is meteen een goede, ik zou wel graag een linkje hebben naar een gelukte/werkende mod.
  • ThomasW
  • Laatst online: 21-11 18:28
godver, das nou al de tweede keer dat ik een mobo koop wat het beste te overclocken schijnt te zijn en waarna een week later er een betere is...
[ Voor 6% gewijzigd door ThomasW op 21-12-2003 01:21 ]
  • Wormaap
Er is geen best bord :P 'K ben tevreden met mijn Asusje, al is die Lanparty wel érg verleidelijk... Zo'n hoge oc zie je niet vaak :P
  • Garrett
Garrett
Watercooler
SmokeyTheBandit schreef op 20 december 2003 @ 18:38:
Ik heb het idee dat als ik dit bordje neem, en dan m'n Maze4 waterblokje monteer, dat ik dan ook niet erg veel ruimte over heb tussen het blokje en die 3 condensatoren/elco's onderaan de socket(hoe heten die dingen ook weer) :+
I love watercooling
  • Spice
Spice
update: tools en bios door Psychosis verzameld.
Is al gepost :P De hele rel om die plank komt juist van die link :)
  • Spice
Spice
Vanmiddag aan de gang geweest met Barton 2500 XP mobile AQZFA 0336XPMW.
Alleen CPUID, geen pifast, sandra etc. is om te kijken wat de top is.
Nog geen koeling op mosfets en het orginele heatsinkje zit (nog >:)op de southbridge.
Afbeeldingslocatie: http://www.barebones4u.nl/imageshomepage/2604small.jpg
Best lekker :).
  • El Snorro
  • Laatst online: 24-11 16:47
wow, ik d8 dat ik goed oc mem had voor oem, zie ik ineens mijn Adata mem staan!! :9
Dit mem kan bij mij wel op 230 mhz draaien maar wel in 2-3-3-11 dit op 2.8v.
Dit vond ik een hele prestatie voor Oem geheugen, wat zijn jou/jullie maximale results met dit mem en kan ik strakkere timings draaien door en meer volts op te zetten??
E6600||Gigabyte P35C-DS3R||2x1gb Crucial Pc8500||Sapphire X1900XTX||2xSamsung Spinpoint F1 750GB RAID-0
El Snorro schreef op 21 december 2003 @ 20:39:
Ik heb dezelfde repen in mn server zitten. Eerst ff heel snel getest voordat ze erin gingen en ze doen idd 230 met 11-3-3-2. Ze kunnen nog wel aardig wat harder en ik geloof zelfs dat ik ze op 250 had gezien, maar met hele slechte timings. Mja..ze kosten dan ook niks.
Deze repen hadden eerst altijd BH-5 chips btw.. Het wereld record staat met A-data memory ;)
  • Epsilon
  • Laatst online: 15:45
Epsilon
Avatar revival!
Ik heb er vandaag ook maar es 1 besteld bij tweakstore ;)
Moest nog wat meer hebben dus de keus waar ik hem ging halen was snel gemaakt.
Ben benieuwd dus :).
[ Voor 205% gewijzigd door Verwijderd op 23-12-2003 12:36 ]
  • Astennu
K ben me aan het Rot zoeken naar de Infinity maar dat gaat dus niet lukken :(. K probeer het nog 2 dagen en dan ga ik ook maar voor een lanparty.
  • Gipsy King
  • Laatst online: 05-11 10:03
ga binnekort me zusjes pc upgraden denk dat ik daar ook die lanparty inknikker >:)
  • RommelD
  • Laatst online: 09-05-2022
RommelD
Stargate overheerscht!
Beetje jammer dat de infinity nergens te koop is. De lanparty versie is focking duur :'(
X2 3800+@2700@1.67 volt@WC, 2*512 mb G-Skill PC3500 @ 245 2-2-2-5, Sparkle 7800 GTX@515-1400
[ Voor 227% gewijzigd door Verwijderd op 23-12-2003 12:36 ]
[ Voor 255% gewijzigd door Verwijderd op 25-12-2003 18:11 ]
  • Astennu
ooh tnx :P.
Zijn er nog mensen die zo'n mobo willen ?
Anders kunnen we dat bij tweakstore neer leggen en ( ik gok dat die ze iets goedkoper zal kunnen leveren ).
Zo jah Mail dan naar : Astennu91@hotmail.com
  • Spice
Spice
Let op m.b.t. de Infinity
Got 2 more Infinity boards in on Friday but had to work over the weekend so I didn't have a lot of time to prime test and so forth. I found that these boards are very different from the first one I got that was a week 24 NB and made in China and had a metal CPU latch. These both were week 45NB's and had the traditional N2 plastic brown CPU latches and were both "Made in Taiwan". The rails were better at 11.75v but not the full 12v I was looking for with my Fortron 400 but I got over it. Both the boards ran fine without any unusual hiccups.
Meer goed nieuws van dezelfde poster:
Oh I almost forgot, there is no need to do the L12 wire mod to these boards. Just drop any 133FSB CPU in and they will overclock past 240FSB depending on the ram without a problem. <- Abit NF7-2.0 user.
Infinity OC-draadje: http://www.xtremesystems....ead.php?s=&threadid=24476
[ Voor 3% gewijzigd door Spice op 23-12-2003 00:55 ]
  • Astennu
Spice schreef op 23 december 2003 @ 00:55:
Die cpu die ik heb is gelockt en heeft dus de nieuwe coating die unlocken moeilijk maakt maar smokey heeft er wel 255 mee gedaan dus deze heeft de mod niet nodig. MAar toch maar eens goed gaan kijken welke ik nu wil :)
  • De_Bastaard
  • Laatst online: 24-11 11:54
Ik las op XS Dat die plank best lekker oc'able was >:)
  • YoupY
RommelD schreef op 22 december 2003 @ 18:02:
Ik heb ondertussen al 2 sites gezien waar ze die planken wel verkopen in Nederland. Is gewoon een kwestie van even zoeken dus. Ik heb nu niet de linkjes, die staat thuis ergens in m'n geschiedenis, maar ik ben nu niet thuis, en kan je er dus nog niet aan helpen.
Prijs van die plank was gelijk aan de prijs van een "normaal" moederbord, zo rond de 110 euri
  • Exigence
  • Laatst online: 17:27
Exigence
dnkroz
Hoppa:
http://www.budget-direct.nl
Daar is hij te koop. Google is je beste vriend :)
Prijs per stuk:
€ 123,84 incl. B.T.W.
Prijs per tien of meer:
€ 121,36 incl. B.T.W
[ Voor 40% gewijzigd door Exigence op 24-12-2003 12:07 ]
Bedankt, ik zal eerst Abit halen. Toen zag ik ineens deze moederbord, maarja waar ze het verkopen is het beetje te duur en verzendkosten ook. Dus toch maar Abit :(
  • Astennu
Verwijderd schreef op 24 december 2003 @ 13:45:
Nou ik zou het wel weten zekers geen ABIT duidelijk DFI !!!!
Ja dat weet ik, maar als nou meer winkels het verkopen. Alleen lay out van deze bord vind ik niet zo super, ik heb nogal een grote cooler (V 11+) :(
  • Smollys
  • Laatst online: 24-12-2024
Verwijderd schreef op 24 december 2003 @ 18:58:
Zo'n gewoon klein koelertje dat je hebt ,toch geen reden om een snel bord te laten liggen >:)
Als je nu al spreekt van die grote zalmann dingen ,dan wordt het tijd om eens gaan te kijken of ie wel past ;)
  • Astennu
http://www.budget-direct.nl verkoopt em en ik kan nou niet zeggen dat de volcano 11+ groot is :? de thermalright SLK 900 en de Switech MXC 462 dat zijn de grote coolers.
  • Smollys
Astennu schreef op 24 december 2003 @ 19:03:
Volcano11 + zijn gewoon standarddingen uit koper ,niet slecht maar ook niet supper goed of speciaal groot ,hij past gewoon op elk bord .
Heb nog 2 van die dingen in men schuif liggen
geen geldige reden dus om het beste OC bord van het moment te laten liggen .
  • Exigence
Exigence
dnkroz
Smollys schreef op 24 december 2003 @ 19:14:
Ik heb in ieder geval een goede reden: geldgebrek :(
Ik wou dat er meer winkels waren die het verkopen. Veel geld heb ik niet, vandaar.
  • quarantaine
  • Laatst online: 24-06-2013
quarantaine
mongtastic.be
het is zeer verleidelijk om een infinity te kopen (staan een 105 euro in een duitse shop) alleen heb ik gelezen dat mushkin black lvl2 er niet goed in overclockt, soms 200Mhz fsb en soms 245. (daar betaal je dan veel geld voor :( )
wat denken jullie? is het de laatste investering waard? (heb nu een crappy nf7-s)
de enigste 2 nadelen voor mij zouden zijn dat het geen soundstorm heeft op de analoge uitgang en dat de mushkin niet goed zou gaan.
  • YoupY
De keuze voor een moederbord is natuurlijk helemaal afhankelijk van wat je er zelf mee wil gaan doen. Als je er gewoon hard mee wilt gaan en 250+ fsb snelheden mee wilt halen dan lijkt het 't perfecte bord.
Als je echter meer waarde hecht aan je soundstorm dan kun je beter voor een ander bord kiezen. Wat dat muskin betreft heb ik geen idee, wat dat betreft zul je de gok moeten nemen.
Als je echter een Infinity gaat halen let dan wel op dat je geen KT400 chipset meeneemt.
  • Spice
Spice
van mijzelf voorlopig geen updates meer :(. Ik zal wel nieuws/reviews posten maar mijn bios (hopelijk) is corrupted.
Vanwege de niet ideale timings van mij A-Data reepjes ben ik vandaag aan de slag geweest met twinmos twister 3700 reepjes. Na wat biosflashes (in windows) om te kijken welke het beste werkte, kreeg ik mijn Lanparty niet meer aan de gang. Suggesties zijn welkom maar volgens mij heb ik al het mogelijke geprobeerd.
Andere CPU, niks 2500 mobile werkt nog wel :). ander geheugen, andere videokaart, batterij eruit, snoer los, atx-connector, 12 volt-connector los allemaal niks. Zal wel ff w88 worden op nieuw bioschipje. Geeft verder niks zat andere dingen te doen :).
  • Astennu
quarantaine schreef op 25 december 2003 @ 00:20:
K heb ook mush pc 3200 en pc 3500 lv 2 getest en op mijn NF7-S liep het ook totaal niet Mijn corsair gaat veel harder. Ik weet wel dat die 2 planken BH5 chippies minder leuk vinden maar met de 12-10 bios zou dat wel goed gaan. 250+ fsb's.
  • quarantaine
quarantaine
mongtastic.be
YoupY schreef op 25 december 2003 @ 00:46:
ik wil er hard meegaan maar aangezien het mijn hoofdrig is wil ik een beetje extra, maar ik veronderstel dat ik eventueel wel mijn sb 1024 kan gebruiken.
ik hoop alleen dat ze die Vcore aanpassen want 2.0V is "weinig". ik heb juist iets meer nodig om stabiel te werken op 2400Mhz.
ik denk btw dat ik nog een weekje ga wachten, kijken of ik reden heb om mijn nf7 te RMA'en en dan eventueel dit te kopen (als die mushkin kwestie een beetje opklaart).
Ik heb gelezen dat de mosfets op dit plankje behoorlijk warm worden, zeker als je de volle 3.3V Vdimm gebruikt. Extra koeling is dus aan te raden. Maar hoe plakken jullie koelblokken op de mosfets? Zalman adhesive, koelpasta met een beetje lijm, gewoon lijm of nog anders? Moet je ook opassen met sommige geleidende pasta?
  • PASware
  • Laatst online: 16:08
geleidende pasta is in princiepe niet erg, zolang je maar neit knoeit e.d.
Je kan in de hoekjes een heel klein beetje seconde lijm erop doen en in het midden AS3 (o.i.d.) doen. Dat van zalman werkt ook goed :)
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
Krijg als het goed is dinsdag mijn DFI-bord binnen waarna ik mijn Innovatek zooi er gooi. Jullie horen van mij.
  • Exigence
Exigence
dnkroz
PASware schreef op 27 december 2003 @ 12:59:
Dat Zalman spul wil nog wel eens loslaten als het erg heet wordt. Dus houd er iig een fan op gericht (ervaring :X , m´n mosfetkoeling is er een keer afgeflikkerd toen ik er geen fan op had. Gloeiend heet, maar gelukkig wist ik het op tijd te pakken, anders was m´n radeon naar de eeuwige jachtvelden geweest :X )
als ik het zo bekijk gaat de prometeia wel passen welliswaar net aan maar hij gaat kijk maar naar die witte lijn voor de socket volgens mij is dat precies waar dat plastic ding dat om je mobo moet van de prometeia eindigt.
Check ook de review op de frontpage!!!
nieuws: DFI LANParty NFII Ultra B moederbordreview
  • Spice
Spice
Staat erbij in de openingspost.
Allang geleden gepost op de FP, de output is niet meer zoals het was :(.
Kijk naar de datum van HARd[ocp]!
[ Voor 19% gewijzigd door Spice op 29-12-2003 01:34 ]
  • aKra
aKra
Intentionally left blank.
erik9287nl schreef op 24 december 2003 @ 12:06:
Hoppa:
Prijs per stuk:
€ 105,86 incl. B.T.W.
€ 103,74 incl. B.T.W.
  • Jack
  • Laatst online: 01-11 13:20
Jack
MHz Matters
aKra schreef op 29 december 2003 @ 09:16:
Prijs per stuk:
Die is het niet!
Het moederbord met die prijs heeft een andere board layout en heeft geen sata voor zover ik zag.
De Infinity kost bij Budget-direct.nl € 123,84
De Lanparty verkopen ze volgens mij niet daar.
[Specs]
  • D-Three
  • Laatst online: 07:42
Na het lezen van de uitgebreide startpost is, als ik het goed begrijp, het enige verschil tussen de Lanparty NFII Ultra B en de Infinity het gigabit LAN, 2 USB poorten minder bij de Infinity en al die "rommel" ;) die je er bij krijgt?
Als dat zo is, dan is mijn keuze tussen die 2 borden snel gemaakt. Gigabit LAN heb ik niet nodig en de helft van de bijgeleverde spullen ga ik toch niet gebruiken! En USB poorten zijn altijd handig maar voorlopig heb ik er maar een 4-tal nodig en ben ik dus tevreden met 6.
Alhoewel, die FrontX zou ik wel kunnen gebruiken :P En het is ook wel jammer dat er op de Infinity geen diagnostic LED's en power- en resetknoppen terug te vinden zijn.
De enige stap die ik nu nog moet overwinnen is het daadwerkelijk kopen van dit bordje. Ik ben heel erg tevreden van mijn NF7-S 1.2 en wou dan ook een NF7-S 2.0 kopen. Al m'n moederborden die ik de voorbije 4 jaar heb gekocht waren van ABIT en ik heb er nog nooit echte problemen mee gehad.
Maar de prijs van zo'n Infinity valt echt wel mee. Net geen 92 dollar op newegg.com! Een NF7-S kost er eigenlijk ook net geen 100 dollar.
Moeilijk, moeilijk, moeilijk... ;) Heeft iemand al zo'n Infinity en had hij niet liever een LanParty NFII Ultra B gekocht? Of omgekeerd? Of zijn jullie er best tevreden over?
  • Jack
Jack
MHz Matters
Maar wat wel vreemd is,
bij Tweakstore en bij Budget-direct heeft de lanparty/infinity een andere board layout! Die hebben nl ATA raid ipv 4x SATA :/
Ook heeft de Lanparty bij Tweakstore op het plaatje geen switches.
Lekker verwarrend
Er staat wel op de pic onder de southbridge Rev 1.0, is dat het misschien?
Kijk en huiver:
Afbeeldingslocatie: http://www.tweakstore.nl/shop/images/lanpartynfgroot.jpg
[ Voor 30% gewijzigd door Jack op 29-12-2003 11:22 ]
[Specs]
  • Chiron
  • Laatst online: 08:56
Chiron
Moderator Discord / TFV & AWM
is dat geen A ipv een B :?
  • Neo-morpheus
  • Laatst online: 18-09-2025
Bij tweakstore zijn het wel degelijk de Rev B bordjes die binnen zijn
mijn is op de post :D , foto is gewoon nog van de vorige versie , gewoon ff mailen
om zeker te zijn zou ik zeggen
Is een rev A idd..
  • Chiron
Chiron
interessant bordje iig.. jammer dat ie niet zonder alle extra prul te krijgen is, alleen dat tuig waar je je kast in kan hangen lijkt me op zich wel wat.. zou behoorlijk moeten schelen in prijs
die kleur is echt te coool
toch maar es even sparen ;)
  • Astennu
Chiron schreef op 29 december 2003 @ 12:45:
Als je het hoe leest weet je dat de Infinity die zonder de extra's is.
  • ken
  • Laatst online: 20-11 22:28
ken
Astennu schreef op 29 december 2003 @ 12:58:
maar die klokken een stuk minder ver over. raar maar waar ;)
Canon 5D Mark II, Canon 35 f/1.4L
  • Tjaps
Tjaps
Snap ik toch...
ken schreef op 29 december 2003 @ 13:11:
Heb je linkje naar een forum waar dat hard word gemaakt want hier geloof ik weinig van. Het is precies hetzelfde bord als de lanparty rev B (ook kwa layout) alleen de gigabit lan chip is eraf.
Mwoah..wat is minder ver? 256MHz vind ik aardig wat: http://www.dslreports.com...277f3656cb45ef71/4001.jpg
Dat is een infinity ;)
Btw:
Let even op de MP (9,5) en dan zo'n membench neerzetten. Dat haal je dus noooooit met een NF7-S. Smokey had dezelfde FSB zowat maar lang geen 4000MB/s.
En nog een infinity:
http://www.xtremesystems....ment.php?s=&postid=308655
En nog een:
Got mine up to 10,5x255 dc 11-2-2-2-2,0-9-12-en-en-fast 3dmarkable...
Needs more vdimm. I am on beta 12-10, dual twinmos bh-5 week 303.
Got a really good 23567 3DMarks with 11x253 above timings but I am not able to publish till I get my dsl. Moving flat these days
And have to wait for my new telephone service
Gonna try the vcore mod now
[ Voor 59% gewijzigd door Verwijderd op 29-12-2003 13:45 ]
  • Chiron
Chiron
en zonder uv-kleurtje.. :{
  • Astennu
The Doctor schreef op 29 december 2003 @ 13:35:
Jah idd die gaan ook gewoon 255 dus :P
Chiron schreef op 29 december 2003 @ 14:17:
Je kunt niet alles hebben :?
  • Chiron
Chiron
Dit is mijn case:
Afbeeldingslocatie: http://www.pisang.demon.nl/images/case9.jpg
begrijp je nu waarom een uv-kleurtje wel zo interessant voor mij is? (heb 2 blacklight ccfl's erin zitten) ;)
maar ik denk dat ik dan alle extra meuk maar voor lief neem.. want het is echt een super bord zo te zien ook qua overclocken en features
  • Jack
Jack
MHz Matters
als ik deze link van je open, dan zie ik een speelgoed dinosaurus :?
[Specs]
  • Tjaps
Tjaps
Snap ik toch...
Ik heb net een infinity besteld dus asap results :)
Jack schreef op 29 december 2003 @ 16:28:
Vaag.. hij zit bij een post, misschien is dat het..
Dit is em:
http://www.fewture.cistron.nl/img/4001.jpg
  • Astennu
Chiron schreef op 29 december 2003 @ 15:31:
Dit is mijn case:
Jep maar als je zoveel uitgeeft aan lampjes enz kan 35 euro voor een mobo er ook wel af want de infinity kost 123 euro de lanparty 158 dus valt op zig wel mee.
The Doctor schreef op 29 december 2003 @ 16:44:
K ben benieuwt
  • Stinger666
Ik benb zowieso benieuwd! De TS heeft zn BIOS al gefrituurd. Dit doet me aan de 8RDA+, NF7S taferelen denken! Ik heb al van 3 nForce 2 planken die verotte BIOS gefrituurd! Wat is dat toch met die dingen!
Bij Budget-Direct hebben ze die Rev A voor 105 en dat is dan de voorloper van de LANParty waar wij het nu over hebben en de Infinity is idd 123 Euri's.
Ik w8 results van de Infinity af! De board lay-out is het zelfde. Die leuke knopjes voor power en reset van de LANParty zijn handig maar niet nodig en gigabit lan kan ook gemist worden! Verder identiek!
  • D-Three
En 2 USB-poorten minder. :P
Hmm, op de site van DFI zelf staat er dat ze allebei evenveel USB-poorten hebben. Foutje op de site van newegg dus...
[ Voor 71% gewijzigd door D-Three op 29-12-2003 18:58 ]
  • Astennu
Als mijn A64 overstap niet lukt ga ik voor de Lanparty B of mits goed leverbaar bij een goede winkel voor de infinity.
  • Chiron
Chiron
Astennu schreef op 29 december 2003 @ 17:32:
K ben benieuwt
35 euro vind ik anders behoorlijk wat op een mobo van 158 euro.. waarbij ik persoonlijk dat oerlelijke frontpaneel links zou laten liggen, evenals de rounded cables (floppy cable iig) en heel incidenteel dat hengsel zou gebruiken..
wat ik een + punt vind van het mobo is het goede Vmem en dat het natuurlijk lekker wil OCen maar ik vind het wel zwaar jammer als ik dan hier naar kijk:
de ruimte om de socket en dan nog is de prijs
ik w8 iig even af wat de bevindingen zijn van andere hier voordat ik mijn geld waag.
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 30 december 2003 @ 21:44:
Er is een vcore mod voor hoor :)
En de prijs voor de infinity valt toch best mee ?
[ Voor 6% gewijzigd door Tjaps op 30-12-2003 22:25 ]
  • Spice
Spice
reviewtje toegevoegd. Meer info over de Vcore mod zou ik graag willen ontvangen om toe te voegen aan de openingspost.
  • Tjaps
Tjaps
Snap ik toch...
Spice schreef op 30 december 2003 @ 23:51:
http://www.xtremesystems....ead.php?s=&threadid=23709
Daar staat wat over de vreg chip en dat hij ook geruikt word op andere mobos.
Verder niemand heeft m geprobeerd of iig niemand heeft gepost dat hij werkt maar als ik mijn bord heb ga ik m testen.
  • Tjaps
Tjaps
Snap ik toch...
Die knopjes lijken vel op elkaar :+
[ Voor 92% gewijzigd door Tjaps op 31-12-2003 00:05 ]
  • Jack
Jack
MHz Matters
The Doctor schreef op 31 december 2003 @ 00:04:
:P
[ Voor 18% gewijzigd door Jack op 31-12-2003 00:17 ]
[Specs]
The Doctor schreef op 30 december 2003 @ 22:08:
maar die in finity heb ik nog niet gezien (in nederland iig)
en de Vcore mod is nog niet bewezen wil eerst wel is zien of die het ook echt doet.
  • D-Three
Als die mod begint te ruiken, dan ben ik er redelijk van overtuigd dat hij niet werkt. En jouw mobo dan misschien ook niet meer :P
  • D-Three
Foutje 8)7
[ Voor 97% gewijzigd door D-Three op 31-12-2003 10:38 ]
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 31 december 2003 @ 10:17:
http://www.budget-direct.nl/ daar heb ik m besteld.
Die vcore mod ga ik wel ff proberen dus dan weet je het snel genoeg ;)
Laagvliegerke schreef op 31 december 2003 @ 10:35:
Daar hebben ze RMA toch voor uigevonden :? :9
The Doctor schreef op 31 december 2003 @ 12:37:
ja je mag hem uitproberen en OCen dan kijk ik verder :)
haha rma na een mod dat zien ze gelijk aan je soldeer....
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 31 december 2003 @ 12:57:
Dat zien ze dus echt niet :P
Ik heb al 2x een mobo waar is op gesoldeerd heb terug gebracht gewoon het soldeer goed weg halen.
  • Spice
Spice
nieuw beta bios:
DFI Lanparty NF2
12/31 BIOS update as follows :
Key Change of 12-31 BIOS Since The 12-18 BIOS(12-18 BIOS is previous beta BIOS)
1 . Add Command Per Clock Option in Advanced ChipSet Feature BIOS menu
Choose Disabled will improve Double Side DRAM Overclocking Ability
2 . Fix 12-18 BIOS 8X , 8.5X fail to boot when CPU interface is Aggressive
and FSB >= 200 MHz
3 . Change The topology of DIMM Driving and Strength
get it here -> (directe link op verzoek van Bluetooth weggehaald)
link: http://www.ocworkbench.co...b=get_topic;f=34;t=000021
DFI NF2 Infinity
zelfde verhaal als hier boven is te vinden op:
http://www.ocworkbench.co...b=get_topic;f=34;t=000020
[ Voor 23% gewijzigd door Spice op 31-12-2003 17:59 ]
  • SileX
la maar.
[ Voor 86% gewijzigd door SileX op 01-01-2004 15:11 ]
  • D-Three
Eh... Neen, RMA dient daar niet voor. Maar eigenlijk was het een grapje dat doelde op een kleine vaut in jouw post ;)
THE DOCTOR waneer verw8 jij me mobo binnen te krijgen :? :)
[ Voor 13% gewijzigd door Verwijderd op 01-01-2004 23:34 ]
  • Tjaps
Tjaps
Snap ik toch...
Laagvliegerke schreef op 01 januari 2004 @ 23:27:
Owh lol zie nu pas dat ik gebruikt niet goed heb geschreven :9 (alcohol is bad 4 me :+ )
Verwijderd schreef op 01 januari 2004 @ 23:34:
Ik heb geen id ik hoop morgen (vrijdag) maar dat zal er wel niet inzitten omdat oud en nieuw er tussen zit en het dan altijd wat langzaamer gaat. Als die winkel een beetje snel is dan denk ik dat ik m begin volgende week wel heb.
[ Voor 40% gewijzigd door Tjaps op 01-01-2004 23:50 ]
  • Buzz_NL
  • Laatst online: 24-11 11:28
W00t ik heb mij DFI NFII LANPARTY Rev B van Tweakstore binnen, (te snel) willen inbouwen. waardoor die op dit moment stroom op het bord staat(rood ledje)
als ik dan met de powerswitch op het bord hem op te starten gaat het bord ff aan(Dram LED, Fans draaien en CCFL's aan) dan gaat die na 5 sec weer uit, staat nog steeds stroom op bord(rood ledje brand).
Vermoed dat ik (stom, stom) op de achterkant via de kopere bevestigingspunten contact maakt met mijn Case of dat ik de proc naar de haaien heb geholpen door te snel mijn maze4 er op te willen prakken. 8)7
Ga vanmiddag bord uit case schroefen en alleen eens met proc buiten de case te booten, anders ff andere proc proberen.
- Bordje ziet er goed uit ;)
- Haastige spoed is zelden goed |:(
Buzz_NL schreef op 02 januari 2004 @ 08:34:
hoe vroeg komt bij jou het mobo wel niet aanzette dan dat je om 8:34 alles al (verneukt :P ) ingebouwd hebt :?
trouwens je cpu krjig je niet zomaar dood door een maze4 denk eerder dat je mobo kortsluiting maakt met iets dus ik zou hem maar is snel uit je pc trekken voordat je hem voorgoed kortsluit.
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
Jongens dit is echt een Wannahave :D ;)
Op Xtreme is de 272 5-2-2-2 al gehaald :D :D :*)
