BThGvNeOA
En voor makkelijk booten van allemaal ISO's: Ventoy
Of als je er meer tijd aan wil besteden met diskpart de USB eens helemaal leeggooien
https://learn.microsoft.c...windows-commands/diskpart
Maar meestal werkt een nieuwe USB wel gelijk uit het doosje.
https://www.system-rescue.org/
Maar... Clonezilla heeft er geen zin in:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
| Starting /usr/sbin/ocs-sr at 2025-12-07 21:52:09 CET... *****************************************************. Clonezilla image dir: /home/partimag Shutting down the Logical Volume Manager Finished Shutting down the Logical Volume Manager Found /home/partimag is using FAT file system. Set VOL_LIMIT_IN_INTERACTIVE to 4096 MB. The selected devices: sdb PS. Next time, you can run this command directly: /usr/sbin/ocs-sr -q2 -c -j2 -z9p -i 4096 -sfsck -senc -plu -p poweroff savedisk "Laptop_disc" sdb *****************************************************. The selected devices: sdb Searching for data/swap/extended partition(s)... The data partition to be saved: sdb1 The selected devices: sdb1 The next step is to save the hard disk or partition(s) on this machine as an image.: *****************************************************. Machine: Unknown product name sdb (465.8G|TOSHIBA_MK5059GSX|pci-0000_01_00_0-usb-0_4_1_0-scsi-0_0_0_0|Y0NPD0M6B) sdb1 (465.8G|vfat|In_TOSHIBA_MK5059GSX|EVITA|pci-0000_01_00_0-usb-0_4_1_0-scsi-0_0_0_0|Y0NPD0M6B) *****************************************************. -> "/home/partimag/Laptop_disc". Shutting down the Logical Volume Manager Finished Shutting down the Logical Volume Manager Starting saving /dev/sdb1 as /home/partimag/Laptop_disc/sdb1.XXX... /dev/sdb1 filesystem: vfat. *****************************************************. *****************************************************. Use partclone with zstd to save the image. Image file will be split with size limit 4096 MB. *****************************************************. If this action fails or hangs, check: * Is the disk full ? *****************************************************. Running: partclone.vfat -z 10485760 -N -L /var/log/clonezilla//partclone.log -c -s /dev/sdb1 --output - | zstd -c -T0 -3 | split -a 2 -b 4096MB - "/home/partimag/Laptop_disc/sdb1.vfat-ptcl-img.zst." 2> /tmp/img_out_err.mXSKkH Opening User Interface mode. Partclone v0.3.38 http://partclone.org Starting to clone device (/dev/sdb1) to image (-) Reading Super Block memory needed: 143067525 bytes bitmap 122096001 bytes, blocks 2*10485760 bytes, checksum 4 bytes Calculating bitmap... Please wait... fs_open, 284, ERROR:Bad file descriptorFailed to use partclone program to save or restore an image! *****************************************************. Failed to save partition /dev/sdb1. Saving block devices info in /home/partimag/Laptop_disc/blkdev.list... Saving block devices attributes in /home/partimag/Laptop_disc/blkid.list... Checking the integrity of partition table in the disk /dev/sdb... The partition table on this disk is invalid.: /dev/sdb It is not supported by parted. Parted is used by Clonezilla to parse the filesystem from the partition table, and it has detected this partition table as invalid. The error messages from parted are:: *****************************************************. Error: Could not stat device /dev/sdb - No such file or directory. *****************************************************. If you continue, unexpected behavior may occur (e.g., dd may be used instead of partclone or ntfsclone, even for supported filesystems), and the saved image may not be complete. Are you sure you want to continue? (y/N) Smart choice. Program terminated.. |
Hoe dat dan
Ik wil wel echt een bit-by-bit image van de HDD maken.
Nu een andere, grotere stick proberen om er via ubuntu dan maar direct naar toe te gaan...
BThGvNeOA
Bedankt voor de input allen!
Slotje
BThGvNeOA
Nu wil ik daar ook een bit-by-bit kopie van maken, die ook makkelijk te mounten is.
Maar de eerdere opties hierboven werkten domweg niet of een error of veel te geavanceerd (dat forensische image) voor het doel.
Nog andere goede tool die wel gewoon werkt?
BThGvNeOA
bit-by-bit kopie = forensic imageDropjesLover schreef op zondag 15 februari 2026 @ 18:51:
Toch een schopje... Ik heb nog een oude hdd gevonden.
Is het voor een disk recovery?
Is de disk/partitie(s) niet toegankelijk/zichtbaar?
Er zijn genoeg (backup) tools om disk/partities naar een image te schrijven en mounten.
Zelf gebruik ik vaak Terabyte Image, Macrium Reflect (free), ook nog wel eens Ghost voor speciale gevallen.
Klonen van oude msdos HDD
The_Doman schreef op dinsdag 15 februari 2022 @ 14:26:
Er is toch nog geen image gemaakt dacht ik?
Let wel op bij het aansluiten van de oude IDE harde schijf dat Windows niet per ongeluk bestanden zomaar gaat wijzigen ("repareren") waardoor het kassasysteem (misschien) niet meer goed functioneert/opstart.
Eventueel auto mount uitzetten eerst:
TenForums: How to Enable or Disable Automatic Mounting of New Disks and Drives in Windows
Er zit mogelijk een belangrijk bestand op, dat eerder al eens verwijderd is.The_Doman schreef op zondag 15 februari 2026 @ 22:05:
Zelf gebruik ik vaak Terabyte Image, Macrium Reflect (free), ook nog wel eens Ghost voor speciale gevallen.![]()
Ik wil de bit-by-bit kopie kunnen benaderen en er recovery tools op los laten, om te kijken wat er nog in de niet-gebruikte bitjes staat.
Ik had eens een forensic image programma geprobeerd, dat was heel hiërarchisch, met projecten en documentatie en allerlei inrichting waar ik geen weet van heb. Vandaar dat ik daar wat huiverig voor ben.
Het is een 2,5" sata schijf, geen Ata/ide
BThGvNeOA
Mogelijk een eenvoudige "undelete" actie dus?DropjesLover schreef op zondag 15 februari 2026 @ 22:54:
Zelf gebruik in bij zulke undelete/recovery acties eigenlijk altijd GetDataBack.
Geen freeware maar met de evaluatie versie kan je losse bestanden previewen/openen om te controleren of de recovery succesvol is.
En als je handig bent kan je het volledige bestand uit de temp map halen.
Getdataback kan ook een image maken van je HDD.
Je kan een quick/undelete scan doen of een full/deep/4star scan.
:fill(white):strip_exif()/f/image/J1nLFImhhXiqVnsxK6VcyLJY.png?f=user_large)
Hier staan mogelijk ook nog wat tips/tools:
HD gecrasht: hoe krijg ik gegevens terug?
Hulp bij per ongeluk geformateerde schijf
Dat maakt niet uit, het ging er om dat het soms nuttig kan zijn Windows auto mount uit te zetten om te voorkomen dat Windows de schijf probeert te lezen.DropjesLover schreef op zondag 15 februari 2026 @ 22:54:
Vooral nuttig met schijven/partities die bad sectors hebben en Windows blijft hangen op eindeloze retries.
Oude 1TB externe hdd gevonden om de backup naar toe te maken. Zat ook nog een treasure trove aan oude GoG downloaded games opThe_Doman schreef op maandag 16 februari 2026 @ 11:48:
Met diskpart automatic volume uit gezet, te recoveren drive met een sata-usb converter aangesloten... Windows herkende en opende hem meteen
Maar begon niet te miepen over of de drive hersteld moest worden.
Eerst een full image trekken met GetDataBack, maar lijkt niet zo goed te gaan
:strip_exif()/f/image/jJcD6NWn8KnCm6qQh5YF1aXo.png?f=user_large)
Hopelijk zijn dit alleen de intensief gebruikte eerste sectors...
edit
Op de schijf krijg ik alleen maar errors, maar wanneer ik de image laad kan hij wel foutenvrij bestanden vinden
Hij is nog steeds bezig met de 4* deep recovery, 2nd pass voor de recovery tree. Geen idee wat daarna nog komt, gewoon kalm laten snorrenThe_Doman schreef op vrijdag 6 maart 2026 @ 19:53:
Deze leesfouten kreeg je toch niet op de hele schijf neem ik dan aan?
Anders zou je niets zinnigs terug kunnen halen lijkt mij.
Maar hebt de te herstellen bestanden (gedeeltelijk?) dus wel terug kunnen halen?
[ Voor 14% gewijzigd door DropjesLover op 06-03-2026 21:18 ]
BThGvNeOA
Deze leesfouten kreeg je toch niet op de hele schijf neem ik dan aan?DropjesLover schreef op vrijdag 6 maart 2026 @ 10:14:
edit
Ik zoek een extensie die er niet tussen staat.
Middels de search vind ik die missende extensies ook niet. De search geeft aan dat er 14 miljoen files moeten zijn
Tips?
BThGvNeOA
Als je voor het grootste deel alleen maar errors krijgt kan het ook zijn dat de USB interface een probleem krijgt/vastloopt en er geen zinnige data meer wordt gelezen.DropjesLover schreef op vrijdag 6 maart 2026 @ 10:14:
Veel USB interfaces kunnen niet goed omgaan met veel read/bad sector errors.
Zie bijvoorbeeld recent topic:
Data van schijf kopiëren zonder beschadigde bestanden
Je zou kunnen testen wat een ander bad sector tool scan aangeeft?
Externe hdd bewogen tijdens opstarten
Ook altijd ervoor zorgen dat de PC niet tussendoor in slaap/standby gaat.The_Doman schreef op donderdag 12 juni 2025 @ 13:33:
Wil je het echt zeker weten dan kan je een zogenaamde "bad sector test" op de schijf uitvoeren.
Daar zijn diverse tooltjes voor zoals het bekende HD Tune
Ook wel prima is deze zo te zien:
Macrorit Disk Scanner (Free Portable)
Zelf gebruik ik meestal de oudere "classic versies" GetDataBack for NTFS/FAT32 V4.33.
GetDataBack zegt zelf dat er ~14 miljoen bestanden gevonden zijn. Maar in de LOSTFILES recovery tree ontbreken grote hoeveelheden extensies. Dat vind ik wel heel opvallend. In een andere recovery tree van een oude windows installatie heeft hij wel een paar van dat soort (.dat, .ini) bestanden gevonden.The_Doman schreef op vrijdag 6 maart 2026 @ 22:17:
Nu maar eerst eens de image overzetten naar mn NAS ipv de externe hdd uit 2008 waar ik het nu even op geparkeerd heb. Met een whopping 40mb/s
Ik denk dat het beste is een oude laptop pakken, een usb bootstickje met linux en daar mee nog eens een image maken, kijken of dat beter gaat en nogmaals recoveren.
BThGvNeOA
