How much wood would a woodchuck chuck if a woodchuck could chuck wood ?
Hi, Dank weer voor de update die ik net gedaan heb.
Iets kleins dat ik zie. In de HA log:
Ik vermoed dat het uit zendure_forecasting_global.yaml komt. Geen idee of dat de werking (altijd) beïnvloed.1
| Logger: homeassistant.helpers.template
Source: helpers/template/__init__.py:746
First occurred: 07:23:57 (1 occurrence)
Last logged: 07:23:57
Template variable error: 'this' is undefined when rendering '{{ (this.attributes.get('raw') if this is not none and this.attributes is defined else none) or [] }}' |
De vervolg error is:
Een ander heel klein ding (en zal aan mijn keuze liggen voor Engelstalige HA).code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41Logger: homeassistant Source: helpers/template/__init__.py:485 First occurred: 07:23:57 (4 occurrences) Last logged: 07:30:00 Error doing job: Task exception was never retrieved (task: None) Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 483, in async_render render_result = render_with_context(self.template, compiled, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/template/context.py", line 44, in render_with_context return template.render(**kwargs) ~~~~~~~~~~~~~~~^^^^^^^^^^ File "/usr/local/lib/python3.14/site-packages/jinja2/environment.py", line 1295, in render self.environment.handle_exception() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^ File "/usr/local/lib/python3.14/site-packages/jinja2/environment.py", line 942, in handle_exception raise rewrite_traceback_stack(source=source) File "<template>", line 1, in top-level template code File "/usr/local/lib/python3.14/site-packages/jinja2/sandbox.py", line 319, in getattr value = getattr(obj, attribute) File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 766, in _fail_with_undefined_error return super()._fail_with_undefined_error(*args, **kwargs) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^ jinja2.exceptions.UndefinedError: 'this' is undefined The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/template/coordinator.py", line 191, in _handle_triggered run_variables = self._render_run_variables(run_variables) File "/usr/src/homeassistant/homeassistant/components/template/coordinator.py", line 168, in _render_run_variables variables.update(section.async_simple_render(variables)) ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/helpers/script_variables.py", line 79, in async_simple_render rendered_variable = template.render_complex(value, run_variables) File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 160, in render_complex return value.async_render(variables, limited=limited, parse_result=parse_result) ~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 485, in async_render raise TemplateError(err) from err homeassistant.exceptions.TemplateError: UndefinedError: 'this' is undefined
Bij hover over wordt de tijd met am/pm weergegeven bij mij in diverse graphs. De graphs van standaard Gielz zijn wel in 24 uur formaat.
Op te lossen:
Bestaande code voobeeld:
YAML:
wordt dan (hour12: false toegevoegd)1
| const tijd = d.toLocaleString(navigator.language, { weekday: 'short', hour: '2-digit', minute: '2-digit' }); |
YAML:
| const tijd = d.toLocaleString(navigator.language, { weekday: 'short', hour: '2-digit', minute: '2-digit', hour12: false }); |
[ Voor 8% gewijzigd door oeps op 21-11-2026 08:38 ]
Hoi,
Letten jullie actief op het aantal Relay switches, en proberen jullie die nog te minimaliseren? Ik merk dat ik er nu toch standaard zo’n 150 a 250 per dag heb.
Start charging stond op -400watt in de zomer maar nu -250watt om net wat meer zon te vangen.
Start discharge staat op 150watt.
Nu in de winter heb ik voor 95% discharge relay switches aldus de grafiek van Gielz. Het lijkt dus niet het pendelen tussen charge en discharge te zijn.
In de zomer gaven de Envoy microomvormers erg veel charge relay switches dus zette ik bijvoorbeeld in de ochtend met automation de start charging naar -600watt om dat met de opkomende zon te voorkomen. Maar in de winter blijk ik nu ook behoorlijk wat discharge relay switches te hebben.
Als je erop let welk aantal relay switches houden jullie aan? En kan 250 a 300 per dag kwaad? Geen idee wat de Zendure software zelf in Zenki modus doet bijvoorbeeld?
Dit topic is alleen voor de integratie met Home Assistant.
Zie voor algemeen: Het grote Zendure plug-and-play thuisaccu systemen topic
Voor integratie met Homey: Zendure Batterijen Slim aansturen met Athom Homey
Omnibattery Home Assistant integratie: Omnibattery Home Assistant integratie - Deel 1
Zoek voor andere zaken het juiste topic.
/f/image/0v2O7HX8Uiu7yATMO5FPcC4x.png?f=fotoalbum_large)
