- Mr.Whitewolf88
- Registratie: Oktober 2015
Laatst online: 10:57
Oké...... Update van Amazon op de 2e hands bestelling drop die vandaag plaatsvond:
"Hello,
Thank you for your email.
I am truly sorry for any inconvenience this may have caused you.
I have checked your order 305-6026687-2397925 and I can see that the item Sony PlayStation 5 is not in stock at the moment.
When the system allows you to place an order, it means that the item is in stock.
If there are only few left in stock and more people order at the same time, the system still allows you to place the order.
However, after the process, when the order is placed, if the system cannot choose a warehouse the item should be sent from, it means that the item is actually out of stock and that others reserved it already.
I sincerely apologize for the inconvenience.
As soon as we receive the item from the supplier, we will dispatch the order to you immediately. However, the date of the re-stocking is still not known or available. To keep you fully informed on the progress of your order, we will send you an e-mail when we dispatch your order from our Fulfilment Centre, confirming the date, contents and method of delivery.
In this case, there are two options:
a. We can leave the order as it is and wait for the item to re-stock.
b. We can also immediately cancel the item: At the moment, we cannot give you an exact information on the number of days that this item will take to re-stock. We are waiting for a shipment from the supplier and the system is displaying the information based on the previous intervals of delivery for the same item. The data on the exact number of days is not available until the manufacturer sends a new batch to Amazon - when that happens, the website displays the accurate information with a counter for the remaining number of days until re-stock. I can only advise you to periodically check the website for an update and at the moment when you realize that you would not be able to have it in time, to simply reply to this e-mail and notify us to cancel it.
Thank you for your patience and understanding."
Jammer mensen, ik annuleer hem hier.
Dit topic is er voor de Tweaker die op zoek is naar een PS5 (Pro) console voor een redelijke prijs.
Om het topic leesbaar en zinvol te houden gelden daarom aanvullende regels:
• Houd het on-topic: berichten over de actuele voorraad bij fysieke- en webwinkels.
• Géén discussie over scalping, woekerprijzen, en het beleid van (web)winkels.
• Geen rants naar elkaar, webwinkels, klantenservicemedewerkers, pakketbezorgers, etc.
Géén vraag en aanbod.
Bots en Telegram-groepen kunnen in de TS worden opgenomen,
mits deze geen commercieel oogmerk hebben, zoals werken met referrals of betaalde toegang/voordelen.
Plaats alleen orders bij vertrouwde partijen. Als het te mooi is om waar te zijn, is dat waarschijnlijk ook zo. Een goed begin is onze
Pricewatch Shopreview:fill(white):strip_exif()/f/image/aYnEOc9vWTETmuPnQnGMS37b.png?f=user_large)
| Wel zin in gezellig (offtopic) kletsen?
Daarvoor kun je terecht op de Tweakers Discord |
