• Hmmbob
  • Laatst online: 20:21
Lang verwacht en toch gekomen! Kan hem nog niet OTA binnen halen als ik voor updates check, ben hem nu handmatig aan het binnen halen.
ZE551ML:
[ZenFone 2] [160825] ZE551ML_ WW_4.21.40.134 OTA (Android M)
【Version】
【Model Name】
ZenFone2 (ZE551ML)
【Release Date】
2016/08/31
(Download the firmware manually from our officical website, https://www.asus.com/Phon...E551ML/HelpDesk_Download/)
【Release Note】
1.APP2SD not supported in M. Please backup before upgrade.
2.Adjust pre-load app after upgrade to Android M
3.Please backup your data before upgrading
4."The apps listed below will no longer be pre-loaded once your device has been upgraded to Android 6.0 (Marshmallow).
Thanks for your support.
1. ASUS Backup
2. Data Transfer
3. Dr. Eye (TW SKU)
4. Jawbone UP
5. EZTABLE (TW SKU)
6. Google Play Books
7. Google Play Games
8. Google Play Newsstand
9. Google+
10. Mirror
11. Omlet
12. Party Link
13. PC Link
14. Photo Frame
15. Remote Link
16. TripAdvisor
17. What's Next
18. Yahoo Shopping (TW SKU)
19. ZenFlash (Can be downloaded from Google play)
20. Zinio
21. Asus Game center"
5.Multi-user and SnapView will not be supported. If you wish to continue to use multi-user, please keep using current account
6.Remove Asus Email, Asus Calendar, Asus Messaging, Asus Browser and Asus Music after Factory Reset. You could use Gmail, Google Calendar, Google Messenger, Chrome and Google Play Music for relevant services
7."Add new features and new apps:
- Google Calendar
- Google Messenger
- Facebook
- Facebook messenger
- Instagram"
ZE550ML:
[160825] ZE550ML_ WW_4.21.40.112 OTA (Android M)
【Version】
【Model Name】
ZenFone2 (ZE550ML)
【Release Date】
2016/08/31
(Download the firmware manually from our officical website,https://www.asus.com/Phone/ZenFone_2_ZE550ML/HelpDesk_Download/)
【Release Note】
1. ASUS Backup
2. Data Transfer
3. Dr. Eye (TW SKU)
4. Jawbone UP
5. EZTABLE (TW SKU)
9. Google+
10. Mirror
11. Omlet
12. Party Link
13. PC Link
14. Photo Frame
15. Remote Link
16. TripAdvisor
17. What's Next
20. Zinio
- Google Calendar
- Google Messenger
- Facebook
- Instagram
[ Voor 33% gewijzigd door Hmmbob op 31-08-2016 21:15 ]
  • Qu3st
  • Registratie: Juli 2015
  • Laatst online: 21:02
Qu3st
#36
Ik heb het gelijk gecheckt, maar ik kan nog niet updaten :(
  • Hmmbob
Even het linkje in mijn gequote bericht aanklikken op je telefoon, na het downloaden het .zip bestand verplaatsen naar je 'root'. Je krijgt dan een melding dat er een updatebestand gevonden is.
Je kan het ook downloaden op de PC en dan met de kabel naar je root zetten.
  • kaasszje
  • Laatst online: 04-11 11:54
kaasszje
Live to Dare, Dare to Live
Harde reset in de upgrade ?
Of blijven al je gegevens bewaard ?
Ik ben verstopt zoek een ander :P
  • Dreamvoid
Dreamvoid
Bij mijn Zenfone 2 Laser bleef alles bewaard na de upgrade, maar dat was wel met de OTA, niet handmatig.
  • Hmmbob
Bij de handmatige route blijft je data ook bewaard als je de OTA gebruikt.
  • kaasszje
kaasszje
Ok ff alles backuppen en morgen eens upgraden :)
Hoe bevalt android m tot dusverre ?
  • Hmmbob
Merk eerlijk gezegd weinig verschil....
  • Ralph Smeets
  • Laatst online: 02-11 16:53
Ralph Smeets
sinds 10-7-2009
Hoe lang duurde de update bij jullie?
Mestreechs volksleed:
Jao diech höbs us aon 't hart gelege, Mestreech door alle ieuwe heer
Veer bleve diech altied genege, En deilde dreufheid en plezeer....etc.
  • Hmmbob
De handmatige update heeft alles bij elkaar een half uurtje gelopen denk ik, inclusief de reboot en "app optimizing"
  • Ralph Smeets
Ralph Smeets
sinds 10-7-2009
okay, dan laat ik hem lekker doorlopen
  • Ralph Smeets
Ralph Smeets
sinds 10-7-2009
En update is afgerond, reboot is geweest. Mooi, was even bang dat het bricked was. Maar loopt nu zoals het hoort.
  • rockhopper
  • Laatst online: 01-11 15:35
rockhopper
Pinguïn geen klimmer!
Ik kreeg vandaag wel een update maar het lijkt me alleen een security patch geweest te zijn. Ik zit nog steeds op android 5.0 maar wel is de 'security' bijgewerkt naar 1 september 2016....
Op zich goede zaak dat ze de boel veilig houden, maar ik had deze week liever M gezien.
Canon R7 || RF 100-500mm F/4.5-7.1 L IS USM || 100-400mm F/4.5-5.6 L IS USM || EF-S 15-85mm F/3.5-5.6 IS USM || 50mm F1.4 USM || Speedlite 430EX II
  • Hmmbob
Welk toestel heb je?
  • rockhopper
rockhopper
De Asus Zenfone 2 ZE551ML 4G Dual Sim 64GB. Hopelijk binnenkort dan maar.
  • kaasszje
kaasszje
rockhopper schreef op zaterdag 03 september 2016 @ 13:01:
Update hiervan is niet ota (over the air)
Kortom je kan de update van de asus site downloaden en op je telefoon zetten.
  • rockhopper
rockhopper
Is dat tijdelijk en komt hij nog ota of is het alleen maar handmatig te doen? Niet dat het een enorm probleem is om uiteindelijk handmatig te doen, maar ik laat het liever via ota lopen als ik daarvoor een weekje langer moet wachten is dat geen probleem.
Voor de mensen die de update al wel hebben gedaan, blijven de gegevens van je toestel bewaard?
  • Hmmbob
rockhopper schreef op zaterdag 03 september 2016 @ 18:34:
Ja.
Edit: mijn vrouw krijgt net op haar telefoon een kleinere security update OTA. Er lijkt dus een soort 'twee sporen' beleid te zijn voor de Zenfone 2....
[ Voor 26% gewijzigd door Hmmbob op 04-09-2016 17:46 ]
  • Dreamvoid
Dreamvoid
Dat is ws tijdelijk, de andere Zenfone 2 varianten (Laser/Max/Selfie) hebben na een tijdje Android 6 via een OTA update gekregen.
  • parryfiend
  • Laatst online: 29-05 17:40
Hallo, de zenfone2 deluxe van mijn vriendin vertoont sinds afgelopen week kuren met het touchscreen. Ghosttouches komen voor en soms verschijnt er een rare verkleuring op 2/3 van het lcd scherm dat na verloop van tijd weer verdwijnt. Dit gebeurde op de stock rom van android5.0; inmidddels geupgrade naar android 6.0 maar probleem persisteert wat duidt op een hw probleem. Phone en marshmellow doen het normaal ondanks periodieke ghosttouches.
Heeft iemand hier hetzelfde meegemaakt? Hoe dit op te lossen? De telefoon is gekocht via hong kong. Is er een kans dat Asus nl het kan/wil oplossen? De zenfone2 is nog geen 2 jaar oud, ze was er dik tevreden mee tot dit gebeurde.
  • rockhopper
rockhopper
parryfiend schreef op dinsdag 06 september 2016 @ 08:18:
Hou je ons op de hoogte van de reactie van asus.nl nadat je antwoord op je mailtje hebt gekregen? O-)
Verder wel een vervelend gebeurtenis, ik wacht denk ik zelf maar op de ota update naar 6.0 Al klinkt jouw geval inderdaad als hardware en dan wordt het of zelf sleutelen of kijken of je verkopende partij / asus / verzekering wat voor je kan betekenen.
  • parryfiend
Ok, net gebeld met de nederlandse Asus helpdesk en de grootste imbeciel ooit aan de lijn gehad.
Hij had het over dat er een reden was waarom ze deze 'chinaphones' niet hier uitbrachten en dat hij niets voor me kon betekenen. Hij raadde me aan een nieuw toestel te kopen aangezien reparatiekosten bijna net zo duur zouden zijn als een nieuw toestel. En dat terwijl mijn zenphone2 zelf nog geen jaar oud is....
Way to go Asus, als een helpdeskmedewerker zo denigrerend praat over een eigen product. Asus service is ronduit knudde vergeleken met Apple. Daar doen ze tenminste niet moeilijk over reparatie van een in het buitenland gekocht product en doen ze niet denigrerend over hun eigen productlijnen. Van service heeft Asus geen kaas gegeten.
Mijn beste kans: mailen met asus hk en kijken of ze mij daar verder kunnen helpen.
Asus was vroeger 1 van mijn favoriete merken vanwege bang for buck gehalte maar nu ik te maken krijg met hun waardeloze service....
Grrr....
[ Voor 13% gewijzigd door parryfiend op 07-09-2016 15:27 ]
  • Dreamvoid
Dreamvoid
Asus verkoopt helemaal geen telefoons in Nederland, dus het is niet zo gek dat de Nederlandse helpdesk er niets van weet, of reserve onderdelen in huis heeft.
Zinniger is het ws om even de Franse helpdesk te bellen, daar wordt hij wel officieel verkocht. Grote kans dat ze je een reservescherm kunnen opsturen, die kan je dan zelf (of bij een willekeurige telefoonreparateur) vervangen. Anders het typenummer ofzo, dan kan je hem via Ebay/AliExpress bestellen.
[ Voor 38% gewijzigd door Dreamvoid op 07-09-2016 16:08 ]
  • parryfiend
Dank voor de suggestie dreamvoid. Daar heb ik tenminste wat aan.
Waarom had de nederlandse helpdesk me niet intern kunnen doorverwijzen naar de franse of duitse helpdesk? Dat is een stuk behulpzamer dan: "nee we kunnen niets voor u doen en uw chinaphone, u kunt beter een nieuwe kopen".
  • kaasszje
kaasszje
http://www.asusparts.eu/e...ZenFone%202%20ZE551ML#LCD Module
via asusparts kan je alle onderdelen zo bestellen.
  • parryfiend
Bedankt voor alle suggesties mensen!
Ik houdt jullie nog op de hoogte hoe het allemaal afloopt.
  • mcwieger
  • Laatst online: 12-10 12:10
Mocht het alleen het scherm zijn, ik heb deze besteld nadat de telefoon exact op de verkeerde manier was gevallen en het scherm gebarsten: http://www.ebay.de/itm/361334500168
Moet nog het ontvangen (deze week) en er (laten) opzetten, maar houd je op de hoogte.
Iemand al ervaring met het vervangen van het scherm? Zijn er verlijmde onderdelen of is het een kwestie van losschroeven, aansluiten en weer vast?
  • Dreamvoid
Dreamvoid
YouTube: Asus Zenfone 2 Screen Replacement (nothing left out)
Filmpje over hoe je het scherm verwisselt.
hallo tweakers, aangenaam kennis maken met u allen
ik heb al veel gelezen in deze topic en het begint
me een beetje onzeker te maken
op 4 september heb ik via dealextreme een
ASUS ZENFONE 2 besteld
ze551ml 4gb / 64 gb
ik ben bang dat ik geen rekening heb gehouden met WW of CN of TW
ik hoop dat ik uw reacties kan begrijpen, want ik ben een complete leek
ik weet namelijk niet eens wat rooten is
Wil je voortaan de wijzig-knop gebruiken om iets toe te voegen? Twee posts onder elkaar plaatsen binnen 24 uur is niet toegestaan.
[ Voor 63% gewijzigd door rens-br op 12-09-2016 09:19 ]
  • Hmmbob
Over rooten hoef je je niet druk te maken als je gewoon je telefoon wil gebruiken zoals hij is ;) er zijn fanatiekelingen die graag (nog) meer controle willen hebben over hun telefoon (voor een diversiteit aan redenen), dan ga je rooten om 'super user' rechten op je telefoon te krijgen.
Lang verhaal kort: niet van toepassing voor je.
Heb je een linkje naar het model dat je besteld hebt? Dan kunnen we aan de hand van de frequentie banden vaststellen of je blij wordt of iets minder blij :+
  • mcwieger
Dank hiervoor!
Ik heb 'm vluchtig bekeken en...zal 'm doorsturen naar de reparateur... :D
hmmbob
okee hier! begrepen! ik ga me dus niet bezig houden met rooten
(waarschijnlijk hetzelfde als een auto chippen ofzo.....j)
ik ga even op zoek naar de link, wacht even
http://www.dx.com/p/asus-...-blue-406701#.V9ZVUPmLSCg
  • rens-br
  • Laatst online: 18:22
rens-br
Admin IN & Moderator Mobile
Verwijderd schreef op maandag 12 september 2016 @ 09:14:
hmmbob
In die specificaties staat het volgende:
2G: GSM 850/900/1800/1900MHz;
3G: WCDMA 850/900/1900/2100MHz;
4G: FDD-LTE B1/B3 TDD-LTE B38/39/40/41
In Nederland worden de volgende frequenties gebruikt:
Nederland:
2G3G4G
KPN8
900 Mhz
1 / 8
2100 / 900 Mhz
3 / 7 / 20 /
1800 / 2600 / 800 Mhz
Vodafone8
900 Mhz
1 / 8
2100 / 900 Mhz
3 / 7 / 20 /
T-Mobile3
1800 Mhz
1 / 8
2100 / 900 Mhz
3 / 7 / 8
1800 / 2600 / 900 Mhz
Tele2--7 / 20
2600 / 800 Mhz
ZUM--7
2600 Mhz
Aangezien 4G band 3, 7, 8 en 20 ontbreekt zal 4G volledig niet werken met dit model.
[ Voor 3% gewijzigd door rens-br op 12-09-2016 09:23 ]
dat is duidelijke taal inderdaad
ik hoop gewoon dat het (stiekum toch) een goed type is..... tegen beter weten in, eigenlijk
maar kan ik vanaf de buitenkant van de doos zien welke versie het is WW of CN of TW?
kan ik hem dan nog ongestraft terugsturen?
kan ik er iets aan laten veranderen?
is het niet-hebben van 4G een groot probleem (buiten het feit dat het sneller ofzo is van wel)?
  • rockhopper
rockhopper
Verwijderd schreef op maandag 12 september 2016 @ 10:46:
Als het goed is staat het op de doos. Of je 'm terug kan sturen of niet hangt er vanaf of je wet kopen op afstand toe kan passen of niet (zakelijke of particuliere aanschaf)
Je kan altijd een leuk stickertje plakken, of je de interne hardware wilt aanpassen zou ik persoonlijk niet doen.
Het niet-hebben van 4G is geen enkel probleem als je het niet erg vind om iets langer te wachten op internetpagina's/foto's/bestanden terwijl je niet op wifi zit. Voor wifi (wat de meeste mensen 80 tot 90% van de dag gebruiken) maakt het niks uit. Eventueel zou je er last van kunnen hebben mocht je 'm ooit tweedehands willen doorverkopen en je potentiele koper wil per sé 4G ofzo.
oke bedankt voor reactie
ik blijf het spannend vinden en ben ook best zenuwachtig.
voor het eerst iets besteld uit china en dan gelijk ook nog zo'n technisch apparaat
ohja, en over die 4G... vind ik niet zo belangrijk
en ALS ik 'm wil verkopen (doe ik niet, want ik deed met de vorige smartphone ook al 5 jaar)
dan spreek ik wel een taiwanees aan, hahahaha, probleem opgelost
  • bilgy_no1
Een paar vragen aan de Asus gebruikers hier... Hoe is de ZenUI schil en hoe is Asus met updates van Android?
Ik gebruik al jaren HTC's en heb nu nog de 2,5 jaar oude HTC One M8. Prachtig toestel, maar ik overweeg om het de komende maanden ergens te vervangen. Ik ben een beetje aan het rondkijken en heel enthousiast word ik niet van de meeste modellen. Nu viel mijn oog op de Asus Zenfone 3 Deluxe (https://www.asus.com/Phone/ZenFone-3-Deluxe-ZS570KL/), wat qua specs een fantastisch toestel lijkt. Voor ik besluit dit model aan te schaffen (ik meen vanaf eind september in EU te verkrijgen) ben ik toch wel benieuwd naar jullie ervaringen met Asus op het gebied van de software.
Hoe is de ZenUI schil? Is het zo'n enorm bloated verhaal als bij Samsung (en voorheen ook bij HTC), of kun je zelf allerlei meegeleverde apps van derden gewoon verwijderen?
En hoe is Asus met updates? Ik zag dat ze de meeste Zenfone 2 modellen wel al hebben bijgewerkt naar MarshMallow, maar kan niets vinden over een officieel updatebeleid (2 jaar major updates of zo). En krijg je ondertussen wel gewoon de maandelijkse security patches uitgerold?
Ik vind het erg spijtig dat de meeste reviews hier nauwelijks aandacht aan besteden.
  • Dreamvoid
Dreamvoid
ZenUI als schil zelf is niet echt 'bloated' maar Asus levert wel een enorme lading aan eigen Asus apps mee, en die kan je lang niet altijd verwijderen. Je kan ze wel 1 voor 1 disablen, waardoor ze verdwijnen van je app lijst en niet meer geladen worden.
Hier wat meer over ZenUI: http://www.tomshardware.c...sus-zenfone-2,4267-6.html
Artikel gaat over ZenUI op Android 5, maar inmiddels is de Android 6 versie uit en de UI verschillen zijn echt minimaal.
Security patches komen netjes door, maar gezien hun beleid de afgelopen jaren kan je maar 1 Android update verwachten - oftewel de ZF3 zal ws Android 7 krijgen, ergens in April/Mei ofzo, en dan is de koek wel op.
Die ZF3 Deluxe is wel aardig aan de (introductie)prijs, dus als je nog kan wachten loont dat waarschijnlijk wel, Asus zat de afgelopen drie jaar enorm te stunten met hun prijzen zo midden-December dus de kans is groot dat dit weer gebeurt.
[ Voor 32% gewijzigd door Dreamvoid op 14-09-2016 12:30 ]
  • bilgy_no1
Dreamvoid schreef op woensdag 14 september 2016 @ 12:19:
Dank voor deze informatie. Bij HTC zit ik nog op security update van 12-2015, dus als Asus die wel netjes iedere maand uitrolt is dat al winst...
Het model waar ik naar kijk is de 256GB variant, dus dan vind ik het OK om een aantal te disablen ipv echt te verwijderen. Voor die hoeveelheid opslag en alle top-specs vind ik €699 overigens ook wel OK, maar dan moet je er ook wel lang mee kunnen doen.
Ik wacht het nog wel even af. Nogmaals Dank.
goedemorgen, hier zijn we nog steeds in afwachting van de Zenfone 2 met 4GB RAM en 64GB ROM
(als we alle specs mogen geloven)
we hebben 'm via Deal Extreme uit het zuid-oosten
de vraag:
we denken dat er een amerikaans stekker zit, aan de oplader
a) is het dan een WW-versie of een US-versie
b) hoe moeten we gaan opladen?
bedankt alvast voor eventuele antwoorden 8)7
[ Voor 11% gewijzigd door Verwijderd op 16-09-2016 10:21 . Reden: duidelijker geformuleerd ]
  • 4x2
  • Laatst online: 21:06
4x2
lộn xộn quá
Het zal wel een Taiwanese versie zijn, die gebruiken dezelfde stekkers als de US, maar de kans is vrij groot dat er een verloopstekkertje bij zit (en anders bestel je die ergens voor 50 cent)
Ben ondertussen ook weer terug bij mn ZF2, mn xiaomi RN3 heeft de vorm van een iphone nadat ik dr net verkeerd op ging zitten :+
Eigenlijk is het ook gewoon een goed toestel, buiten het wat lichtzwakke scherm en niet geweldige camera.
Accuduur is niet zo'n punt meer sinds ik m op balanced (oid, de op 1 na snelste iig) heb gezet.
Heb sowieso 2 powerbanks met quickcharge (en genoeg 230v laders die het ook hebben)
Uitvallende simkaarten heb ik geen last meer van sinds ik creatief ben geweest met tape en stukjes plastic om alles op zn plek te drukken.
De Marshmallow update werkt tot nu toe ook prima, zenUI werkt eigenlijk prima als je gewoon een voorraad meegeleverde apps uit zet.
Als ie het nog een jaartje vol weet te houden kijk ik wel een keer naar de ZF3.
leeg
  • mcwieger
mcwieger schreef op zondag 11 september 2016 @ 14:42:
Helaas helaas, de reparateur gaf aan er niks mee te kunnen. In plaats van dit stukje glas van €30 zal ik een complete LCD module moeten aanschaffen (~€100). Zo wordt een telefoon van €280 er één van meer dan €400, da's balen... :(
[ Voor 42% gewijzigd door mcwieger op 17-09-2016 14:31 ]
ASUS_Z00ADA
nou, hij is binnen hoor, de asus zenfone 2 4gb 64 gb
betekent: 4gb ram en 64 gb intern geheugen
of
betekent: 4 gb ram en 64 gb extern geheugen
ding doet het, heeft een CN code aan het eind van het serienummer, dus chinees, dus geen 4G
we hebben hem al open gemaakt en gezien dat er geen enkele card in zit
4 september besteld en 17 september binnengekregen
[ Voor 43% gewijzigd door Verwijderd op 17-09-2016 23:28 . Reden: duidelijker ]
  • rockhopper
rockhopper
Verwijderd schreef op zaterdag 17 september 2016 @ 23:03:
ASUS_Z00ADA
of
betekent: 4 gb ram en 64 gb extern geheugen?
4gb werkgeheugen en 64gb intern opslag geheugen. We spreken van extern geheugen als het opslag geheugen op een (micro)sd-kaart staat. Deze zou je er dus nog eventueel bij kunnen prikken.
oke rockhopper, ik begin het door te krijgen, dank dank
om het beeld compleet te krijgen, wat doet het ROM-verhaal dan in deze?
dat zit toch op de chip, ofzo?
please please nog zo'n mooi en duidelijk antwoord en ik zal geen domme vragen meer stellen
[ Voor 6% gewijzigd door Verwijderd op 18-09-2016 18:56 . Reden: duidelijker ]
  • mcwieger
Nu bevestigd dat hij werkt, voor mensen met een defect scherm:
http://www.ebay.nl/itm/Er...831435:g:KwsAAOSwu1VW3pxP
40 euro excl. verzendkosten voor een LCD module.
  • Hmmbob
Heb je toevallig je proces vastgelegd met camera ofzo? Ik heb zelf ineens ook allerlei klachten met het touchscreen....
  • mcwieger
Ik heb het laten doen. Eerder in dit thread staat een instructiefilmpje voor het vervangen van het scherm en het staat hier beschreven: https://www.ifixit.com/Gu...Display+Replacement/60851
dit hebben we vorige week van het forum geleerd:
wanneer de specificaties van de asus zenfone 2 / 4gb 64 gb is, dan
betekent dat: 4gb werkgeheugen en 64gb intern opslag geheugen.
en wat is ROM? zit dat dan op de chip? hoeveel MB kan dat bijvoorbeeld zijn?
want in de advertentie stond: zenfone 2 / 4GB/64GB ROM
  • Dreamvoid
Dreamvoid
ROM zit er niet op, ze zullen daarmee wel de opslag bedoelen.
Ik hoop overigens voor je dat 3G wel werkt, volgens de spec sheet van Asus doet de CN-versie dat niet op de Europese netwerken (die allemaal WCDMA gebruiken).
4G zal werken op band 3, waar KPN, T-Mobile en Vodafone zitten. Tele2 zit daar niet.
[ Voor 4% gewijzigd door Dreamvoid op 28-09-2016 14:56 ]
  • Lampuhkap
Heb hier een US versie en die doet gewoon alles :D
  • Hmmbob
De US versie ondersteunt andere banden (zijnde wel de banden die in NLD worden gebruikt):
2G :
EDGE/GPRS/GSM :
850/900/1800/1900
3G :
WCDMA :
850/900/1900/2100
TD-SCDMA: (CN/IN Only)
1900 ~ 2100
4G :
FDD-LTE: (TW)
2100MHz(1)/1900MHz(2)/1800MHz(3)/1700MHz
AWS(4)/850MHz(5)/900MHz(8)/700MHz(28)
FDD-LTE: (WW)
AWS(4)/850MHz(5)/2600MHz(7)/900MHz(8)/800MHz(20)
FDD-LTE: (US)
AWS(4)/850MHz(5)/2600MHz(7)/900MHz(8)/700MHz(17)/800MHz(20)
FDD-LTE: (CN/IN)
2100MHz(1)/1800MHz(3)
TDD-LTE: (CN/IN)
2600MHz(38)/1900MHz(39)/1900MHz(40)/1900MHz(41)
Frequenties in gebruik in NLD:
rens-br schreef op maandag 12 september 2016 @ 09:22:
Nederland:
2G3G4G
KPN8
900 Mhz
1 / 8
2100 / 900 Mhz
3 / 7 / 20 /
Vodafone8
900 Mhz
1 / 8
2100 / 900 Mhz
3 / 7 / 20 /
T-Mobile3
1800 Mhz
1 / 8
2100 / 900 Mhz
3 / 7 / 8
Tele2--7 / 20
2600 / 800 Mhz
ZUM--7
2600 Mhz
Dreamvoid schreef op woensdag 28 september 2016 @ 14:56:
kweet ook niet hoe dat zit met ROM, zal toch wel ergens op de microchip zitten, ofzo?
3G werkt wel ja, tenminste ik zie een blokje dat "3G" heet, blokje staat bovenin het balkje van toestel
hier via t-mobile
het is trouwens een heel heel fijn toestel, voelt prettig aan, lekker snel, nog niet gecrasht
nog niet beschadigd, we zijn er gelukkig mee :*) :*) :*) :*)
we hebben ook een stoot-ding gekocht bij dx.com (bescherm-rubber voor aan de achterkant)
voor 4,36 euro afgegeven aan bij ons aan de deur, inclusief transportkosten dus, je lacht je rot
een zwak aspect is dat er een non-removable battery in zit, wat te doen als accu vervangen moet worden?
groeten, peter
  • Dreamvoid
Dreamvoid
Ah da's mooi, dan doet die CN-versie dus zowel Europese (WCDMA) *en* Chinese (TD-SCDMA) 3G, dat werd uit dat tabelletje niet helemaal duidelijk :)
Dan ben je hopelijk minstens drie jaar verder :)
"Non-removable" betekent trouwens niet dat het onmogelijk is, maar dat je het toestel open moet schroeven om de accu te vervangen. Dat openschroeven kan je door elke telefoonreparateur op de hoek laten doen, en een vervangende accu kan je op ebay vanuit China/Taiwan bestellen.
[ Voor 19% gewijzigd door Dreamvoid op 28-09-2016 23:33 ]
okee bedankt....
toch fijne teksten
echt goed hoor die dx.com.... toko in china
en waar kan ik vragen stellen over een app, die ik wel op mijn aftandse LG uit 2010 had,
en die nu niet blijkt te werken?
  • kaasszje
kaasszje
Je kan de vraag altijd stellen ;)
  • rens-br
rens-br
Verwijderd schreef op vrijdag 30 september 2016 @ 01:23:
Dit mag ook gewoon in dit topic. Over welke app gaat het?
Overigens zie ik dat je veel beginnersvraagjes stelt, helemaal niks mis mee natuurlijk. Maar lees voor de zekerheid nog even Het algemeen beleid en Forum FAQ.
op mijn LG van 2010 had ik een app, genaamd
simple mp3 downloader
hier kon ik online een paar mooie liedjes downloaden
en off-line die liedjes afspelen
en nu, heel gek, meldt de app bij afspelen van zo'n liedje
dat het niet gaat, omdat er geen verbinding is......
  • knakworst
  • Laatst online: 19:58
knakworst
Get more sats!
Volgens mij is dat die Duitse app die de nek is omgedraaid omdat die illegaal is. Ik denk dus dat je op zoek moet naar alternatieven.
  • kaasszje
kaasszje
Makkelijkste vraag is dan natuurlijk werkt deze app nog steeds op je LG ?
ja, deze app werkt nog steeds op de LG
in ieder geval met het afspelen van de muziek, maar daar gaat het dan ook helemaal om,
om dat afspelen van de muziek, in een keiharde eenzame non-verbinding-situatie
zit geen simcard in, in die oude LG
en het toestel heeft ook geen wifi-verbinding
[ Voor 9% gewijzigd door Verwijderd op 01-10-2016 18:08 . Reden: duidelijker ]
  • rockhopper
rockhopper
Verwijderd schreef op zaterdag 01 oktober 2016 @ 18:03:
Met andere woorden je LG speelt mp3 bestanden af, althans zo klinkt het. Dan zou je deze liedjes over kunnen zetten naar je nieuwe toestel en deze met iedere mp3speler-app kunnen afspelen.
Je initiële vraag klonk meer alsof je mp3 via discutabele wijze wilde gaan downloaden, nu klinkt het meer alsof het alleen om afspelen gaat. Begrijp ik je goed? Persoonlijk gebruik ik poweramp voor het afspelen, maar er zijn honderden zo niet duizenden apps die mp3's voor je kunnen afspelen. Voor het downloaden van mp3's kan ik je verder niet mee helpen. O-)
  • Hmmbob
De ingebouwde Music app van Asus speelt Mp3 ook zonder problemen...
rockhopper schreef op zaterdag 01 oktober 2016 @ 19:33:
ja, speelt mp3 af..... tuurlijk is het over te zetten..... en ja, liedjes die ingeladen zijn, zijn af te spelen
initiele vraag was inderdaad: het appje op die oude LG kon alle liedjes downloaden in de wifi en zonder wifi of enig andere netwerkverbinding, gewoon afspelen, en waarom dan is het zo, dat:
ik dat nu op mijn supersonische toestel niet meer kan?
bestaan die appjes niet meer ofzo?
Hmmbob schreef op zaterdag 01 oktober 2016 @ 20:55:
tuurlijk, is inderdaad zo....
maar de grote vraag is: hoe krijg ik die liedjes in die
Music app van Asus? en het liefst internet als bron
en niet de data van LG naar nieuwe toestel,
want die liedjes komen intussen mijn strot uit 8)7
dus: hoe krijg ik liedjes van internet in een music app
[ Voor 6% gewijzigd door Verwijderd op 01-10-2016 23:06 ]
  • kaasszje
kaasszje
Aangezien dit geen legale actie is zou je dat ergens anders moeten vragen.
Meest legale wijze is een app als spotify, waarmee je muziek streamt...
Dan wel download als je een betaald abo hebt.
  • Hmmbob
Of YouTube.
hmmbob....
ja youtube ja graag, want daar is wel alles te vinden....
ik kan van een youtube-liedje een mp3 maken
hoe krijg ik die mp3-tjes in de music app van asus?
ondertussen heb ik weer een andere app gedwonload
en nee hoor, als ik uit de wifi ben, en mijn data uit heb staan,
dan krijg ik weer een melding dat er geen verbinding is
en ik hoor helemaal nix van muziek
[ Voor 38% gewijzigd door Verwijderd op 03-10-2016 10:17 ]
  • parryfiend
Update:
Scherm van de zenfone2 laten vervangen nadat het na 1 jaar gebruik ineens last kreeg van ghosttouches.
Ik had eerst aangeklopt bij Asus maar die weigerden het te servicen. Pas na lang aandringen (4 belletjes later) wilden ze het wel servicen voor 135 euro. Helaas voor Asus had ik de telefoon al afgegeven aan de jongens van www.pcservice.nl Die deden het voor 14 euro meer maar bij hun krijg je wel een jaar extra garantie na reparatie. De zenfone 2 is inmiddels gefixed met een nieuwe digitizer en scherm. Werkt weer als nieuw uit de doos. Puik werk en ik kan pcservice.nl aan iedereen aanraden.
Als ie weer stukgaat na 2 jaar wss geen Asus meer. Dat hele getouwtrek met Asus om hem gerepareerd te krijgen stond me erg tegen. Pas na 4x bellen bieden ze je een optie aan ter reparatie met eventuele kosten die je maakt. Dat is echt, echt belabberde service.
Voorheen raadde ik de zenfone2 altijd van harte aan aan iedereen die op zoek is naar een goede budgetphone. Na deze ghosttouch affaire kan ik dat helaas niet meer met een gerust hart doen. Na wat internet research lijkt de hele zenfone2 lijn op den duur geplaagd te zijn door ghosttouches. Komt waarschijnlijk doordat de digitizer chip die de touchinput verwerkt het waarschijnlijk vaker dan normaal begeeft. Het is de zwakke schakel in een anders excellente telefoon. Opgepast dus bij aanschaf van deze phone, nieuw of tweedehands.
  • rens-br
rens-br
Verwijderd schreef op zondag 02 oktober 2016 @ 16:30:
Zet de MP3'tjes eens in de map 'music' of 'muziek'. De meeste. zo niet alle, muziek applicaties pakken de nummers dan automatisch op.
Wat voor app levert Asus mee voor de muziek?
okee, ik ga dat proberen, met dat mappengedoe, kweetniet, maar wel proberen
Asus levert een appje mee, genaamd:
"Muziek"
tja....groenachtig appje met een dubbele muzieknoot erop
het is toch raar dat er een verbinding met het internet nodig is
om de muziek af te spelen of ben ik nou achterlijk aant worden?
  • rens-br
rens-br
Verwijderd schreef op maandag 10 oktober 2016 @ 19:20:
Heb de app net geïnstalleerd op mijn OnePlus One. Bij het opstarten vraagt hij toestemming tot 'Opslag' en na toestemming vind hij mijn muziek direct. Heb je toevallig bij het opstarten de toestemming geweigerd?
Je kan dit aanpassen bij:
'Instellingen' -> 'Apps' -> 'Muziek' -> 'Machtegingen' -> 'Opslagruimte'
Daarbij heb ik net ook alle internet verbindingen uitgezet en de muziek speelt gewoon af.
okee
ik ga naar:
- instellingen
- apps
- muziek-appje kiezen (Asus muziek-icoontje)
- dan zie ik machigingen staan, inderdaad
onder het kopje machtigingen een hele rij:
- een telefoontje
- contacten
- iets over sd-kaart (waarschijnlijk is dit de optie, waar u het over heeft?)
- accounts
- netwerkverbindingen
- uitvoeren bij opstarten
- voorkomen dat toestel overschakelt naar slaapmodus
- audio-instellingen wijzigen
- sticky broadcast verzenden en systeeminstellingen aanpassen
een hele rij, inderdaad
als ik ergens op tik, dan krijg ik wat uitleg, maar het is niet te editten
zo raar
  • rockhopper
rockhopper
Mogelijk zit peterspijzer op een andere android versie dan rens-br met zijn one plus one. Dat zou eventueel een verklaring van het verschil in permissie mogelijkheden verklaren.
  • rens-br
rens-br
rockhopper schreef op dinsdag 11 oktober 2016 @ 17:02:
Waarschijnlijk wel. Als je het niet kan aanpassen dan zit je nog op een versie lager dan Android 6.0, waar mijn OPO op draait.
Verwijderd schreef op dinsdag 11 oktober 2016 @ 16:38:
Als je het niet kan aanpassen dan worden alle permissies toegestaan tijdens de installatie, dus dat is het probleem inderdaad niet.
Heb je je muziek inmiddels in het mapje 'Music' of 'Muziek' gezet?
Heb je ook al een andere muziek speler geprobeerd?
muziek nog niet in het mapje "music" gezet, want weet bij god niet hoe ik dat moet doen
heb al vele muziek spelertjes geprobeerd, en ze hebben allemaal internetverbinding nodig
  • rens-br
rens-br
Verwijderd schreef op woensdag 12 oktober 2016 @ 10:39:
Je doet dan toch echt iets fout hoor. Muziek spelers hebben helemaal geen internet nodig. Welke heb je allemaal geprobeerd?
Verder wat is de bron van je muziek? Waar staat het opgeslagen?
Je kan de muziek verplaatsten door middel van een file browser. Bijvoorbeeld: Google Play: File Manager (deze kan ook al standaard op je apparaat staan).
  • rockhopper
rockhopper
Ik ben even 'out of the box' aan het denken, maar het lijkt bijna alsof peterspijzer een hyperlink opslaat die naar de muziek verwijst in plaats van een echte mp3. (misschien slaat hij wel een link op die naar een youtube liedje verwijst of iets dergelijks)
Dit valt op zich makkelijk na te gaan om even snel naar de bestandgrootte van je muziekbestanden te kijken. Als deze minder is dan 1MB dan is het zeker geen mp3. Ik zeg het alleen maar omdat mijn pa er ook een handje van heeft om dit soms te doen, dus je zou echt niet de eerste zijn.
Voor de rest legt rens-br de stappen die je zou moeten doorlopen wat mij betreft prima uit.
  • rens-br
rens-br
rockhopper schreef op woensdag 12 oktober 2016 @ 11:19:
Daar lijkt het inderdaad ook op. In eerdere berichten heeft hij het over youtube filmpjes offline afspelen o.i.d.
nou, ik heb het lek boven
een kennis van mij heeft mij 2 liedjes ge-appt.....
deze zijn op de een of andere manier automatisch in mijn Asus muziek app terechtgekomen
deze liedjes zie ik staan in mijn Asus muziek app en
deze liedjes kan ik off-line afspelen
dus: liedjes worden mij ge-appt,
ze komen automatisch in mijn muziekApp terecht
en ik kan ze off line afspelen
hoewel ik het allemaal niet goed begrijp,
werkt het wel voor mij
heb gekeken, liedje is ongeveer 5 MB, dus dan mp3?
ik heb nix met hyperlinks gedaan, echt niet
Wil je voortaan de wijzig-knop gebruiken om iets toe te voegen? Twee reacties onder elkaar plaatsen binnen 24 uur is niet toegestaan.
[ Voor 10% gewijzigd door rens-br op 13-10-2016 07:52 ]
  • kaasszje
kaasszje
Verwijderd schreef op woensdag 12 oktober 2016 @ 19:56:
hoe heb je de liedjes wel op je telefoon gezet?
  • rockhopper
rockhopper
Vandaag hier trouwens de oktober 'veiligheids' systeem update binnen. Nog altijd android 5.0, ik denk dat ik een dezer dagen toch maar eens handmatig naar 6.0 zal gaan.
  • Hmmbob
Ik zie niet per se een voordeel om naar 6 over te gaan. Sterker nog: sinds die update heb ik last van issues met mijn scherm (slechte registratie aanrakingen, flikkerend scherm alsof hij moeite heeft de helderheid te bepalen) die ik daarvoor niet had. Might be unrelated, maar toch....
  • rens-br
rens-br
Fijn dat de liedjes die je geappt hebt gekregen wel werken. Nou terug naar je eigen muziek en het beantwoorden van mijn openstaande vragen:
rens-br schreef op woensdag 12 oktober 2016 @ 10:44:
We proberen je allemaal te helpen, maar als je maar selectief vragen gaat beantwoorden komen we helaas niet verder.
  • rockhopper
rockhopper
Hmmbob schreef op donderdag 13 oktober 2016 @ 00:21:
Klinkt een beetje als het euvel waar perryfriend ook al last van had. Timing kan soms vervelend uitpakken, van de andere kant waarom zou Asus het niet OTA pushen als het allemaal echt vlekkeloos zou zijn en wel de safety patches.
De safety is voor mij het belangrijkst dus ik ga er maar vanuit dat het daar nog redelijk goed mee zit verder wil ik gewoon even kijken wat 6 anders maakt. Maar omdat we inmiddels alweer bij 7 zijn heeft dat ook niet zoveel meerwaarde meer. (nadelen van android dat te veel en te snel updates geeft)
Ik twijfel zelf nog of er weer een asus komt. Ik ben onder de indruk van de patches en ook wel de bouwkwaliteit. Mijn foon toch al zeker 4x laten vallen en buiten wat mini krasjes en een ergens een verbogen hoekje is alles nog heel. Mijn vorige telefoons mochten allemaal na 1x vallen al meteen ter reparatie. Maar goed dat kan ook net aan geluk en de manier van vallen liggen.
rens, het is geen onwil, het is mijn gebrek aan kennis.... ik ben geen techneut
ik ben helemaal niet in staat om sommige vragen te beantwoorden, dat is het eigenlijk
file browser, man.... en de vraag: waar staan ze dan? ik heb absoluut geen enkel idee man
ik heb ca. 15 muziekappjes gebruikt, gehaald vanuit play store, en alle appjes elk na het installeren, liedjes opzoeken (vinden nix), daarna weer wegdoen, kijken of alles nog hetzelfde is, dan weer een andere app, ik word helemaal raar van.... de eerste de beste debiel loopt vrolijk met zijn oortjes in...
kweet bij god niet meer welke, maar de 15 van de top 20 van play store, helemaal gek van geworden...
waar staat het opgeslagen, rens, ik zou het niet weten, vind het zo moeilijk, het verschil tussen intern en rom en extern, ik lees overal wat anders
sterker nog, ik denk dat de helft van de smartphonegebruikers het niet eens weet als je het ze vraagt
verplaatsen door een file browser, durf ik niet man
ik zie wel een appje genaamd: bestandsbeheer
ik zie ook in bestandsbeheer staat dat ze in mijn whatsapp-directory van Muziek App staan
heb 2 liedjes ge-appt gekregen, eentje kan ik wel hernoemen en de andere weer niet
wat wil je nog meer weten?
laat anders maar, ik heb nooit een dief van andermans tijd willen zijn
ik snap alleen niet dat er mensen zijn zonder schooldiploma, die vrolijk
en blij hun muziek aan het beluisteren zijn, zonder internetverbinding te hebben
en deze sukkel weer niet
[ Voor 9% gewijzigd door Verwijderd op 13-10-2016 12:42 . Reden: duidelijker ]
  • rens-br
rens-br
Verwijderd schreef op donderdag 13 oktober 2016 @ 12:39:
rens, het is geen onwil, het is mijn gebrek aan kennis.... ik ben geen techneut.
Geeft niks. Niet iedereen is een techneut en niet iedereen weet het meteen. Laat in ieder geval ook één ding duidelijk zijn. Je kan gewoon gaan spelen met de verschillende instellingen. Slopen lukt niet en gebeurd niet.
We zullen de locatie en de filebrowser maar even laten voor wat het is. Ik verwacht namelijk dat de nummers die je probeert af te spelen helemaal niet op je telefoon staan. Waardoor de muziek apps ze niet kunnen vinden.
Ook andere muziek apps zullen we dan maar even laten voor wat het is. De standaard muziek app van Asus werkt gewoon (gezien de andere bestanden).
In principe heb je binnen Android twee verschillende 'opslaglocaties':
  • Interne opslag (ook wel ROM genoemd)
  • Externe opslag (SD kaart)
Voor het afspelen maakt het eigenlijk niet uit op welke opslag het staat. Op beide opslagen heb je een map met 'Muziek' of 'Music', staat het daar in dan zal je muziek speler het sowieso 'zien'.
We laten de technische achtergrond maar even voor wat het is. Mijn vragen:
  • Welke liedjes wil je afspelen?
  • Hoe kom je hieraan? (Waarmee gedownload bijv.)
Ben je ook niet. :) We proberen je gewoon allemaal te helpen. Bij de ene persoon lukt dit meteen en bij de andere persoon zijn wat meer stappen nodig. Geeft helemaal niks.
[ Voor 3% gewijzigd door rens-br op 13-10-2016 13:21 ]
om te beginnen, bedankt voor jullie geduld
antwoord op vraag 1:
welke liedjes wil je afspelen?
bijvoorbeeld:
roberto carlos - amigo
leonnard cohen - waiting for the miracle
paul simon - trailways bus
eek-a-mouse - noah's ark
ennio morricone - once upon a time in the west
massive attack - spying glass
paul simon - can i forgive him
antwoord op vraag 2:
ik kan ze downloaden vanaf youtube, vanaf mijn laptopje
dan converteer ik die youtube naar mp3 en dan staan ze op mijn laptop
maar hoe *knip* ik ze dan in mijn phone krijg
het is me een raadsel
en waar (locatie) in mijn phone ze dan terechtkomen,
geen idee
bovendien zit ik nu in de wifi, gebruik ik de Muziek App van Asus
en de Muziek App van Asus vindt niet eens een liedje van:
Elvis, Prince, the Stones en the Beatles
ook niet van Frans Bauer denk ik
en nee, niet over afspeellijsten beginnen aub
fijn weekend gewenst
Houden we het wel een beetje netjes
[ Voor 3% gewijzigd door rens-br op 14-10-2016 15:42 ]
  • rens-br
rens-br
Verwijderd schreef op vrijdag 14 oktober 2016 @ 14:14:
Kijk daar gaat het dus mis. De nummers staan dus nog helemaal niet op je telefoon, maar op je laptop. De stappen die je nu moet doen:
  1. Hang je telefoon aan je laptop met een USB kabel
  2. Ontgrendel de telefoon
  3. Kies op de telefoon in de notificatiebalk voor MTP-Opslag
  4. Ga naar op je laptop naar 'Deze Computer', selecteer je telefoon en ga naar de map 'Music' of 'Muziek'
  5. Sleep of kopieer op je laptop de nummers naar de map 'Music' of 'Muziek'
  6. Koppel je telefoon los en kijk of de nummers nu wel gevonden kunnen worden.
  • rockhopper
rockhopper
En als dat allemaal te moeilijk is, lief aan je vrienden vragen of zij liedjes naar je willen appen.
Ter verduidelijking van rens-br, stappen 4 en 5 vinden plaats op je pc/laptop 1 t/m 3 en 6 op de telefoon. Veel succes!
we gaan aan de slag
één ding wel raar dus, en dat is dat er geen music te downloaden is vanaf het telefoontoestel
we laten dat even voor wat het is
zoals gezegd morgen of overmorgen aan de slag en we zullen het hier gaan terugkoppelen
vriendelijk bedankt hoor, en ook voor jullie tijd
  • Gnermo
  • Laatst online: 03-09 18:40
Gnermo
All about that bass!
Nog steeds geen 6.0 via de normale update...
  • kaasszje
kaasszje
Gnermo schreef op zondag 16 oktober 2016 @ 14:03:
Je kan hem gewoon via de site van asus downloaden.
Daar staat / stond ook dat deze als manual update beschikbaar was.
  • rockhopper
rockhopper
Ik denk dat gnermo en ik allebei een beetje vrees hebben waarom asus het nog niet OTA gepushed heeft.
Verwijderd schreef op zaterdag 15 oktober 2016 @ 10:44:
we gaan aan de slag
Natuurlijk kan dat wel. Alleen moet je daar wel de skills voor hebben.
  • rens-br
rens-br
rockhopper schreef op vrijdag 14 oktober 2016 @ 16:38:
Dat is inderdaad duidelijker, heb mijn post erop aangepast.
rens, rockhopper, kaasszje
het is gelukt, dank dank
via laptop naar youtube, liedje kiezen, omzetten naar mp3, daarna draadje leggen,
daarna die stappen uitvoeren die mij ge-adviseerd zijn
en alles gewoon af te spelen, dank dank
heel blij hier, sorry voor al die tijd die jullie aan ons besteed hebben
p.s. als jullie iemand heel gelukkig en swingend zien lopen met oordopjes,
dan ben ik het
[ Voor 23% gewijzigd door Verwijderd op 17-10-2016 18:15 . Reden: duidelijker ]
  • rens-br
rens-br
Verwijderd schreef op maandag 17 oktober 2016 @ 18:07:
Graag gedaan.
Fijn dat het dan eindelijk gelukt is! Geniet van je muziek.
[ Voor 3% gewijzigd door rens-br op 17-10-2016 22:00 ]
Pagina: 1 ... 5 6 Laatste
