• theduke1989
  • Laatst online: 04-11 10:44
Voor de mensen die graag willen updaten, zelf maar aan de slag gegaan.
OTA UPDATE PROCEDURE voor ZenFone2
Laatste update voor WW SKU = http://dlcdnet.asus.com/p...0A-WW-2.20.40.90-user.zip
29
30
31
32
33
34
35
36
37
38
39
40
ASUS ZenFone 2=ZE551ML(Z00AD/Z00ADA/Z00ADB/Z00ADC) software Image: V2.20.40.90 for WW SKU only*
Improvement Item:
1. Fixed the display issue after answering a call.
2. Fixed the issue that photo will be yellowish when use flash.
3. Improve stability of modem
4. Fixed Quick charging issue
5. Dim the lowest brightness level in Manual mode
6. Improve memory usage
New Feature:
1. Power Saver:
NEW Power saver UI
Added Battery mode detail pages
Added Customized modes
2. Auto start Manager:
Add “Clean up in suspend” function. (If user use the app which already deny from auto-starting, the app will be clean up after display off.)
Provide ZenUI Apps for user to deny from auto-starting.
3. ASUS Mobile Manager:
Add “Power & Boost” function.
Add the Battery and Memory layout.
For more information please refer to:
TW:http://www.asus.com/zentalk/tw/ReleaseNotes
WW:http://www.asus.com/zentalk/ReleaseNotes
CN:http://zentalk.asus.com.cn/ReleaseNotes
Steps of Update:
1.  Check software version of your device**
2.  Download device software and Update SOP (From “Manual” Item)
3.  Only apply to same SKU update, Example: WW->WW, CN->CN, .
4.  Software update cannot transfer the software SKU and downgrade the software version.
5.  Wrong SKU may cause update failure, please update the same SKU version only.
*How to know the device model?
Path: Settings->About-> Model number
Example: ASUS_T00I
**How to know the device software version?
Path: Settings->About-> software information->Build number
***System upgrade may cause part of data missing, please buckup your important data before system upgrading.
Laatste update voor CN SKU = http://dlcdnet.asus.com/p...0A-CN-2.20.40.63-user.zip
ASUS ZenFone 2=ZE551ML(Z00AD/Z00ADA/Z00ADB/Z00ADC) software Image: V2.20.40.63 for CN SKU only*
Improvement Item:
1. Fixed baterry display error issue.
2. Fixed the issue which is about sliding to answer and hanging up the call.
3. Improve the call stability.
4. Improve the compatibility for some APP.
5. Improve the fluency of using the camera.
Steps of Update:
Example: ASUS_T00I
Deze worden niet door mij constant bijgewerkt.
Voor de meest recente versie ga je naar: https://www.asus.com/supp...0/13/Lk0Sg1Ulh0Ph49Hl/32/
LET OP:
Alleen van toepassing op dezelfde SKU update Ex: WW-> WW, CN-> CN, TW-> TW *.
Software-update kan de software SKU niet overdragen en downgraden de softwareversie.
Verkeerde SKU kan veroorzaken kunnen optreden, dan kunt u alleen werken dezelfde SKU-versie.
Stap 1. Download OTA ZIP-bestand van ASUS officiële website. http://www.asus.com/support/
Ex: UL-ASUS_T00G-WW-2014.2.20.838687-user.zip
UL [Apparaat] - [SKU] - [VERSION] - [BUILDTYPE] .zip
Stap 2. Sluit de telefoon op de pc via een USB-kabel aan, en plaats de update bestand in de rootfolder van je smartphone.
Hetzelfde zoals hieronder en zet de OTA zip-bestand naar je telefoon root directory van interne opslag.
Afbeeldingslocatie: https://i.gyazo.com/812b20fec37d8edc3303bdaf9d7e2f5b.png
Stap 3. Verwijder USB-kabel uit de telefoon, u krijgt een notificatie te zien dat er een update beschikbaar is. Druk hierop. (Zie hier onder)
Afbeeldingslocatie: https://i.gyazo.com/3bd4fad411e00fbe653ad0ada2bcb895.png
Stap 4. Sluit de lader aan op je smartphone en zorg ervoor dat de batterij minimaal 15% capeciteit over hebt. (Zie hier onder)
upgrade beschikbaar "bericht, en druk vervolgens op OK.
Afbeeldingslocatie: https://i.gyazo.com/7d7ae72209a33f9dcdadf786e9e8783e.png
Stap 5. En dan zal het systeem de update proces automatisch uitgevoeren. Als u het bericht hieronder pops, betekent dit systeem update correct geinstalleerd.
Afbeeldingslocatie: https://i.gyazo.com/ab532b2847f9d37dae7000dfc3cde66f.png
  • theduke1989
Please swipe down the screen top side will see the Quick settings.
1. Settings
2. About
3. Model Number
Afbeeldingslocatie: https://i.gyazo.com/6320e67a86e7ef03434d9d93d9760700.png
1.Settings
2.About
3.Model Number
4.Build number
Afbeeldingslocatie: https://i.gyazo.com/e558a429bbf630d8203e95be15b20ed2.png
  • Dreamvoid
Dreamvoid
Als je je Zenfone gewoon koopt bij de grote Europese webwinkels (Amazon etc) dan heb je de WW versie te pakken., het zijn enkel wat kleine resellers die Chinafones grijs importeren.
Dreamvoid schreef op vrijdag 18 september 2015 @ 18:22:
Zijn hier ook een hoop users die zelf de telefoon uit China halen.
  • Redinox
  • Laatst online: 15-06 22:40
Verwijderd schreef op vrijdag 18 september 2015 @ 19:04:
Kan natuulijk ook prima, alleen dan moet je wel accepteren dat de telefoon niet 100% compatible is met de nederlandse telefoonnetwerken (4G). Hoeft geen probleem te zijn, maar als je wel specifiek op zoekt bent naar de de WW versie, moet je ook bij Europese webshop goed opletten. Goed zoeken op typenummers etc. (en er van uit gaan dat de sites de juiste info geven). Heb zelf gisteren de WW versie besteld via amazon.de maar heb ook daar nog behoorlijk moeten zoeken om de juiste versie te vinden. Denk dat 75% van de items die bekeken heb, toch de CN versie waren.
D3 Profile
  • Dreamvoid
Dreamvoid
goed, maar dat is dan niet van amazon zelf, maar van resellers.
  • Redinox
Klopt helemaal, maar als je niet zo bekend bent met amazon, is dat soms nog niet zo makkelijk te zien, zeker als je uit moet wijken naar de Franse, Duitse of Italiaanse site. Maar goed, dat is nog altijd te verantwoordelijkheid van de koper.
Nog makkelijker zou zijn als ASUS gewoon officieel in Nederland zou releasen...Markt is er best voor, maar ze zien er toch geen brood in. Dual-sim is sowieso (nog) geen gemeengoed hier.
D3 Profile
  • theduke1989
ik zoek voor iemand waar ik nog de asus zenfone 2.3 4gb/64gb kan krijgen iekand tips??
  • Majin Buu
ik krijg hm vandaag binnen.
Heb hm vrijdag hier besteld:
http://www.eglobalcentral...-free-unlocked-black.html
Ultra 7 270 Plus / NZXT N7 Z890 / RTX 5070 AORUS INFINITY
  • theduke1989
een vertrouwde shop dus
De verhalen over eglobalcentral zijn nogal wisselend, om het zacht uit te drukken.
  • theduke1989
Ja daarom, ik had deze daar gezien maar veel gelezen veel pro's en con's waardoor ik het maar niet had gedaan. Maar ''Majin Buu'' heeft hem besteld en heeft hem binnen enkele dagen al ontvangen dat is wel nice.
  • Majin Buu
Zojuist door mn vrouw aan de deur ontvangen.
Helaas zit ik nu op mn werk.
Prijs was 285 (4GB/64GB/3580)met een kortingcode en gratis verzending.
Tip; koop wel met Paypal of een CC, dat geeft je wat meer zekerheid.
[ Voor 3% gewijzigd door Majin Buu op 21-09-2015 11:59 ]
  • theduke1989
Bedankt toch maar inderdaad via PayPal gedaan, even in de chat gesproken.
Zeiden van morgen of overmorgen wordt het verstuurd en binnen 2-3 werkdagen geleverd. Dus wel gelijk.
Jij had je zeker aangemeld voor hun nieuwsbrief waardoor je extra €10,- korting kreeg.
WW versie, als dat zo is wel geniaal dan :D
[ Voor 8% gewijzigd door theduke1989 op 21-09-2015 12:07 ]
  • Majin Buu
Nee, had Chkout5 gebruikt voor 5 euro korting.
Kan niet wachten om naar huis te gaan, heb KPN 4G dus zal vanavond bevestigen als het de WW versie is 8)
  • theduke1989
is goed, want volgens hun is dat wel zo :D
Afbeeldingslocatie: https://i.gyazo.com/91d865ef74818c8c53b987a9dc5a69ef.png
Ja begrijp ik.
  • Dreamvoid
Dreamvoid
theduke1989 schreef op maandag 21 september 2015 @ 09:25:
Er zijn er nog een paar bij Amazon Frankrijk zelf te koop: http://www.amazon.fr/Asus-ZenFone-Smartphone-débloqué-4G/dp/B00XVIXFYG/ref=sr_1_8?s=electronics&ie=UTF8&qid=1442831232&sr=1-8&keywords=ze551ml
[ Voor 6% gewijzigd door Dreamvoid op 21-09-2015 12:30 ]
  • theduke1989
Bedankt,
Net te laat, nu al bij de vorige shop besteld. We zullen zien wanneer het aankomt.
En wat de kwaliteit daarvan is. Qua body/scherm/camera is het niet zo denderend maar goed.
Leuk hardware dat wel.
  • Majin Buu
Zoals verwacht heb ik een officiële WW versie gekregen. Zojuist geupgrade naar 2.20.40.90, thanks for the tutorial.
Wat mij betreft is eGlobal betrouwbaar en staat op mijn eshop shortlist.
  • theduke1989
behalve op de rom (update) hoe kan je verder zien dat het een WW variant is?, super om te weten helemaal top, ga dan maar ook even afwachten...
[ Voor 37% gewijzigd door theduke1989 op 21-09-2015 22:41 ]
  • Majin Buu
Softwareversie in Android en de Asus sticker op de doos.
Edit: en 4G werkt prima met KPN _/-\o_
[ Voor 27% gewijzigd door Majin Buu op 21-09-2015 23:32 ]
Majin Buu schreef op maandag 21 september 2015 @ 23:30:
De softwareversie zegt niks. De WW versie kan prima op een CN model geflasht worden. Inzicht in de 4G banden zal het meest betrouwbaar zijn.
  • Majin Buu
Duidelijk, maar de Asus sticker en de werking van KPN 4g confirmeren wel de WW versie lijkt me zo...
of is er een LTE banden-app die ik moet draaien voor confirmatie?
[ Voor 25% gewijzigd door Majin Buu op 22-09-2015 00:14 ]
Majin Buu schreef op dinsdag 22 september 2015 @ 00:13:
Werking van LTE kan ook over de 1800 band gaan die de CN versie wel heeft.
Wellicht deze: Google Play: Mobile Radio Frequency
  • Majin Buu
Afbeeldingslocatie: http://i62.tinypic.com/351wglg.jpg
WW versie. Eglobalcentral is te vertrouwen... ;)
  • kaasszje
  • Laatst online: 04-11 11:54
kaasszje
Live to Dare, Dare to Live
En hoe bevalt het toestel tot nu toe ?
Ik ben verstopt zoek een ander :P
  • Majin Buu
Pro:
- vloeiend gebruikservaring in menu/apps en media
- multitasking met zwaardere games/apps
- scherm doet qua helderheid niet onder voor een G3, prima dus
- veel updates vanuit Asus
- plaatsing volume/power buttons / knockknock
Con:
- camera niet de beste ivm een G3 (maar acceptabel voor mij)
- buttons onderaan scherm cheap looking en niet verlicht
- veel bloatware / niet alles te verwijderen
- ondanks de vele updates, krijgt deze zenfone Android M???
**had hiervoor een LG G3 16GB
Edit: hint naar Android M voor Zenfone 2
[ Voor 15% gewijzigd door Majin Buu op 22-09-2015 12:45 ]
  • harmrh
  • Laatst online: 04-08-2024
Ik zit te kijken naar deze telefoon voor mijn vrouw (uiteraard in het rood) maar zie nogal een aanzienlijk prijsverschil tussen Chinese resellers (AliExpress) en aanbieders in Europa. Verschil loopt op tot wel 100,00 euro en da's nogal wat. Ik heb veel ervaring met AliExpress dus ben geenszins huiverig daar te bestellen, maar is zo'n Chinese variant hier wel goed te gebruiken? Zou gaan om een 32gb rom, 4gb ram model: http://www.aliexpress.com...2_71_72_73_74_75,201409_3
De CN versie mist wel wat 4G banden t.o.v. de WW versie die hier wordt aangeboden.
Of dat belangrijk is, is verder aan jou.
  • harmrh
Ìn haar geval zou het om T-Mobile gaan. Maken op 4G gebruik van 1800 mhz en 2600 mhz..
Klopt, de 2600 heeft de CN versie niet.
En T-Mobile is bezig met 4G op de 900. Heeft ie ook niet.
  • harmrh
De CN versie heeft echter wel B1 (2100) en B3 (1800) en met die laatste zou je dus 4g dekking moeten hebben, toch?
Dat klopt. Maar geen volledige dekking dus.
  • harmrh
Is dat omdat ze op verschillende plaatsen onder verschillende frequenties uitzenden?
  • theduke1989
Ze hebben wel die dekking, echter is 2100 / 1800 een veel minder sterkere dekking dan bijvoorbeeld 800/900 wat veel lager zit dan de twee andere genoemde. Waardoor je al gouw verlies krijgt.
Zelf met de Mi4i gehad, doordat deze ook de 2100 en de 1800 ondersteunde alsnog geen goede dekking.
  • harmrh
By the way: ik heb zelf een Oneplus One en die dekt volgens mij ook enkel op de 1800 mHz band en daarmee heb ik (ook T-Mobile) nog nooit problemen ondervonden. In Gelderland is sinds dit jaar ook prima 4G dekking.
  • kaasszje
kaasszje
Nieuwe generatie staat nu ook op asus.com:
https://www.asus.com/Phone/ZenFone-Products/
Zien er wel goed uit :)
  • theduke1989
de asus zenfone2 is verdomd snel hoor. Alles verloopt echt vlekkeloos :)
En het updaten van de software super easy. WW versie gedownload usb lospluggen en hij zag meteen de update. Super fijn toestel!!
  • Dreamvoid
Dreamvoid
harmrh schreef op donderdag 24 september 2015 @ 20:40:
Je kan ook voor de nieuwe ZD551KL variant gaan, die heeft een betere frontcamera (met front-flits) en accuduur, en het 3 GB/32GB model is 299 euro.
http://www.amazon.fr/Asus-ZenFone-Selfie-Smartphone-débloqué/dp/B011IP4ZJ2/ref=sr_1_1?ie=UTF8&qid=1443348119&sr=8-1
(dan heb je de officiele Europese versie te pakken)
Van de hele Zenfone 2 lineup moeten we het in Europa voorlopig doen met:
- ZE551ML (de originele met Intel)
- ZE500KL ("Laser"), dit is de kleinere 5" versie, nu een paar weken te koop
- ZD551KL ("Selfie"), net deze week te koop
- ZE550KL ("Laser"), bij Amazon.fr "binnenkort leverbaar", bij Darty ligt hij al wel in de schappen
De rode ZE500KL is te koop voor 157 euro (8 GB) of 199 euro (16 GB), en dan heb je een Europese versie, maar die is qua specs natuurlijk wel wat minder (Snapdragon 410, 2 GB, 8 mpx cam, 720p scherm).
Overigens, hier is een unboxing video van de ZE551ML "Deluxe", dit is de standaard Intel versie maar met een bizarre glitterende facetten-behuizing. Er zijn natuurlijk al foto's van maar zo'n video laat toch beter zien hoe dat eruit ziet. Ik vraag me af of deze Deluxe een hit wordt in Europa (waar al te bizarre toestellen het nooit zo goed doen), maar het is tenminste weer eens wat anders dan normaal.
[ Voor 32% gewijzigd door Dreamvoid op 27-09-2015 12:41 ]
  • theduke1989
heb van iemand hier een zenfone2 liggen heeft hem pas.
Wil deze uploaden.
Ik heb de tutorial gevolgd die ik zelf heb geschreven vanuit asus zelf.
Maar wanneer ik de usb loskoppel krijg ik geen melding te zien met er is een nieuwe update.
Ik heb de WW / CN gebruikt maar bij beide geen succes. Er staat wel een WW versie op wat raar is, aangezien het een CN variant is qua doos en alles.
LRX21V.WW-ASUS_Z00A-2.13.40.13_20150401_8390_user044030427_201501060109 is zijn versie wat erop is geïnstalleerd.
Iemand nog tips??
krijgt ook melding: U heeft 4 virussen bla bla enz...
[ Voor 17% gewijzigd door theduke1989 op 28-09-2015 22:58 ]
  • kaasszje
kaasszje
Ik heb hem besteld.
Ben erg benieuwd :)
  • Majin Buu
theduke1989 schreef op maandag 28 september 2015 @ 22:55:
Iemand nog tips??
Doe eerst eens een Factory Reset om van alle troep op de foon af te komen..
  • Gnermo
  • Laatst online: 03-09 18:40
Gnermo
All about that bass!
Iemand anders die last heeft van de "Asus Zenflash" app?
Als ik een foto wil maken nu vraagt hij altijd of ik deze of de normale camera app wil openen.
Verwijderen lukt ook niet...
  • Hmmbob
  • Laatst online: 20:21
Uitschakelen?
  • kaasszje
kaasszje
Weet iemand waar je de asus flipcover kan kopen.
Vind hem erg mooi dus wil eigenlijk de originele van asus hebben.
  • Dreamvoid
Dreamvoid
Amazon?
  • hgoor
  • Laatst online: 03-11 00:14
Verwijderd schreef op donderdag 24 september 2015 @ 20:41:
Ik heb gelezen dat je daarna gewoon de firmware van WW versie er over kan flashen dus die banden zijn niet hardwarematig!
  • hgoor
Wil deze uploaden.
Iemand nog tips??
Sommige leveranciers leveren hem al geflashed met WW rom en geroot en dus ook met virussen. Wat geeft trouwens die melding? Welk programma?
hgoor schreef op dinsdag 06 oktober 2015 @ 14:23:
Je kan die firmwareversie er inderdaad overheen flashen, maar daarmee heb je niet ineens alle banden van het internationale toestel. Die zijn namelijk wel hardwarematig.
  • hgoor
Verwijderd schreef op dinsdag 06 oktober 2015 @ 14:31:
Misschien heb ik wat gemist dan want op XDA beweren ze het tegendeel?
hgoor schreef op dinsdag 06 oktober 2015 @ 14:33:
Waar beweren ze dat? Heb je een link?
  • hgoor
Verwijderd schreef op dinsdag 06 oktober 2015 @ 14:33:
Was al aan het zoeken ;-)
De hardware zelf zou de volgende banden gewoon moeten ondersteunen:
2G Network:
850MHZ 850MHZ
900MHZ 900MHZ
1800MHZ 1800MHZ
1900MHZ 1900MHZ
3G Network:
850MHZ 850MHZ
900MHZ 900MHZ
1900MHZ 1900MHZ
2100MHZ 2100MHZ
4G Network:
800MHZ 800MHZ
850MHZ 850MHZ
900MHZ 900MHZ
1700MHZ 1700MHZ
1800MHZ 1800MHZ
1900MHZ 1900MHZ
2100MHZ 2100MHZ
2600MHZ 2600MHZ
Verder lees ik bij comments op het flashen naar de WW rom:
"As far as I know, ZenFone 2 uses the following LTE modem: Intel XMM 7262 Slim Modem—LTE Advanced. It should be the same in all devices."
M.a.w. als dat klopt kan het toestel meer banden aan dan er in de CN software versie gebruikt worden..
[ Voor 11% gewijzigd door hgoor op 06-10-2015 14:46 ]
Deze Ultimate zou alles ondersteunen en op beide SIMs 4G aan moeten kunnen.
http://www.aliexpress.com...1527_1_71_72_73_74_75,0_0
hgoor schreef op dinsdag 06 oktober 2015 @ 14:38:
2G Network:
850MHZ 850MHZ
900MHZ 900MHZ
1800MHZ 1800MHZ
1900MHZ 1900MHZ
3G Network:
850MHZ 850MHZ
900MHZ 900MHZ
1900MHZ 1900MHZ
2100MHZ 2100MHZ
4G Network:
800MHZ 800MHZ
850MHZ 850MHZ
900MHZ 900MHZ
1700MHZ 1700MHZ
1800MHZ 1800MHZ
1900MHZ 1900MHZ
2100MHZ 2100MHZ
2600MHZ 2600MHZ
Niet de hardware van het CN model. Die mist ban 20/800MHz sowieso.
  • hgoor
Verwijderd schreef op dinsdag 06 oktober 2015 @ 14:45:
Zou kunnen maar ik las bij comments op het flashen naar de WW rom:
  • hgoor
Op XDA een hele thread over basebands en flashen van de CN vs WW versie.
Nog geen tijd om alles na te lezen dus nog geen idee of het nou werkt of niet.
[ Voor 19% gewijzigd door hgoor op 06-10-2015 15:10 ]
hgoor schreef op dinsdag 06 oktober 2015 @ 15:04:
Volgens mij werkt het nergens, globaal gelezen.
  • hgoor
Op het Zenfone forum staat:
Unfortunately, flashing the WW won't enable the bands. A method to unlock the bootloader may solve this. ZenFone 2 will soon appear in US with a different WW version I guess (without the asian-market bloatware) and maybe at that time (or somewhere near) ASUS will release a method to unlock the bootloader (as I heard they did before).
Dus ik heb ook weinig hoop...
  • Dreamvoid
Dreamvoid
Ik zou mijlenver wegblijven van elke image die niet van Asus zelf komt. Je hebt geen enkele garantie wat voor rommel er wel niet meegebakken is op die willekeurig op het internet rondzwervende ROMs.
  • kaasszje
kaasszje
Is er eigenlijk een manier om te zien welke banden je huidige toestel ondersteund?
Zit via mijn bedrijf nog vast op vodafone 3g, maar wil eigenlijk weten of 4g wel ondersteund wordt als het beschikbaar komt.
  • theduke1989
kaasszje schreef op dinsdag 06 oktober 2015 @ 21:53:
Als je weet welke toestel je hebt, kan je meteen zien of deze WCDMa of ook een 4G FDD-LTE ondersteuning heeft. Want het is hardwarematig en vrijwel niet softwarematig.
  • kaasszje
kaasszje
Ik heb als het goed is de normale ww versie.
Wil dit alleen zeker weten, vandaar mijn vraag.
  • theduke1989
momus had als het goed is in deze topic of een andere topic, een app in de android playstore die je moet downloaden zodat je kan zien welke banden je allemaal ondersteunt. Hij kan je daarbij verder helpen volgens mij...
  • kaasszje
kaasszje
Dank je wel :)
Ondertussen wat pm's gestuurd met Momus.
Verder sinds vandaag de asus flip cover.
Super fijn toestel en hoesje maakt hem toch af.
Ik ben super blij met mijn aankoop :)
  • harmrh
Gisteren exemplaar uit China binnen gekregen. Voor € 216,00 op AliExpress gekocht, inclusief een tempered glass screenprotector. Heb afgelopen jaren veel uit China besteld (ook hardware) maar moest voor het eerst betalen. Verkoper had echter aangegeven dat het een mp5 speler was met een waarde van usd 50 dus btw was maar 9 euro en een beetje. Helaas nog 13 verwerkingskosten er overheen van PostNL..
Mijn vrouw is er dolgelukkig mee en mijn eerste indruk is ook prima! Geen last van bloatware, hoewel er wel wat op staat wat je er niet af kunt halen...
Hey
Wie heeft er er ervaring met flashen android asus zenfone 2 ze551ml Gr Thomas
  • theduke1989
Verwijderd schreef op maandag 19 oktober 2015 @ 21:35:
Hey
Staat gewoon in de topic:theduke1989 in "[ASUS Zenfone 2] Ervaringen & Discussie"
Bedankt maar ik zit met eoot dus dat werkt niet.
Root
http://forum.xda-develope...tloop-rooted-zf2-t3127835
Wie kan me helpen met flashen?
Probeer het eerst eens zelf met de guide, mocht je daarna nog vragen hebben dan kun je die hier stellen
[ Voor 30% gewijzigd door The Wizard op 21-10-2015 10:09 ]
  • biker72
  • Laatst online: 10-06 18:25
Hi all,
Ik heb wat problemen met mijn simkkarten van Tele2.
Deze willen niet samen tegelijk werken in mijn Zenfone.
TD van Tel2 geeft aan dat tweede sim niet ondersteund zou worden.
Wissel van provider dus maar. Maar dan zou ik wel graag kiezen voor een die zeker werkt in de Asus.
Welke providers hebben jullie en werken deze goed in de Zenfone 2?
Alvast bedankt.
Groet,
Dennis
Wat bedoel je precies? De telefoon kan gewoon 2 simkaarten, ongeacht de provider, aan. Alleen werkt 3G/4G maar op 1 SIM slot.
  • kaasszje
kaasszje
Hier vodafone en tmobile naast elkaar.
0 problemen...
Je hebt geen 2 sims van dezelfde provider en nummer er in.
Kortom 2 verschillende sims met verschillende telefoonnummers zou geen probleem mogen geven.
  • biker72
Verwijderd schreef op zaterdag 31 oktober 2015 @ 12:27:
TD van Tele2 gaf aan "dat ik geluk had dat tweede SIM kaart werkte".
Dat de telefoon 2 simkaarten aan kan dat klopt, maar schijnbaar ondersteund Tele2 het niet of niet goed.
Sim 2 hoeft aaleen maar te bellen, dus 3G/4G is niet nodig.
Ik heb 2 sims van Tele2. Beiden er in werkt niet, alleen mijn oude erin werkt vlekkeloos. Ik gok er op dat de omzetting naar het nieuwe 4G netwerk nu voor de nodige problemen zorgt.
Kortom, tweede sim van andere provider proberen en dan overstappen.
  • biker72
kaasszje schreef op maandag 02 november 2015 @ 12:08:
0 problemen...
Thanks!
Goed te weten dat Vodafone en TMobile er in werken.
Welke zit bij jou op Sim1?
  • kaasszje
kaasszje
biker72 schreef op maandag 02 november 2015 @ 13:47:
Thanks!
Heb Vodafone nu op sim1 zitten.
Werkt super met 4g :)
  • Dreamvoid
Dreamvoid
biker72 schreef op maandag 02 november 2015 @ 13:46:
Haha, honderden miljoenen dual sim telefoons die het wereldwijd prima doen, en dan nog heb je "geluk" dat het werkt? Het mag niet gekker worden, voor je het weet feliciteert je garage je nog dat je auto vandaag startte.
[ Voor 14% gewijzigd door Dreamvoid op 02-11-2015 17:11 ]
  • Ralph Smeets
  • Laatst online: 02-11 16:53
Ralph Smeets
sinds 10-7-2009
Tele2 heeft alleen een 4G netwerk. Voor 2G zijn ze verplicht om te roamen op de netwerken van andere T-Mobile. Dit laatste wordt bij sommige telefoons gezien als roaming en zonder roaming aan te zetten, kan de telefoon dan geen connectie maken. De gemiddelde servicedesk medewerker weet dit dus gewoon niet en dan wordt er al snel over geluk gesproken.
Dit komt vooral voor bij telefoons die niet officieel in Nederland uit zijn gekomen.
Mestreechs volksleed:
Jao diech höbs us aon 't hart gelege, Mestreech door alle ieuwe heer
Veer bleve diech altied genege, En deilde dreufheid en plezeer....etc.
  • kaasszje
kaasszje
Iemand nieuwe firmware al geinstalleerd ?
  • Hmmbob
En dit zijn de releasenotes van die nieuwe firmware:
【Version】
V2.20.40.139_20151104
【Model Name】
ZenFone2 (ZE551ML)
【Release Date】
2015/11/12
【Release Note】
1 Improve screen turn into black during phone call issue.
2 Fix Miracast frame rate drop issue.
3 Fix NFC connect issue.
4 Fix network data warning notice don not come up issue
5 FixWi-Fi conncet issue
6 Fix 3G cannot camp to H plus in Laos and Paraguay issue.
7 Fix the coming call issue when using bluetooth earphone.
8 Fix Unlock Tool issue.
9 Improve service stability of modem
10 Fix the charging issue of roaming to LTE when data roaming option disabled
11 Fix boost stability issue
12 Fix the issue that user would still receive the notifications from Auto start denied Apps
13 Fix ASUS Mobile Manager data usage restriction issue
14 Fix ZenMotion Shake Shake screenshot issue
15 Fix URL recognition issue in Messages
16 Modify HK Chinese strings
17 Fix IME issue when open Yahoo PC version webpage by ASUS Browser
18 Fix countdown alarm issue after set in Snap View
19 Fix string issue in Theme Apps
20 Fix charge remained time display issue when quick charging
21 Fix SIM PIN lock issue in Cover View
22 Modify Quick charge notification UI layout
23 Fix System UI stability issue
24 Fix Power saver settings issue
25 Fix JP FlipFont issue
26 Fix Battery Simplified Chinese string issue
27 Fix ASUS Mobile Manager data usage calculation issue
28 Improve Auto Start Manager stability
29 Remove BookLive from JP SKU
30 Fix Documents UI stability issue
31 Fix Snap View UI issue and improve its performance when install 3rd party apps
32 Improve Hand Writing accuracy
33 Fix flashlight turn-off issue when double tap power key
34 Fix Power Saver Ultra saving mode notification settings issue
# New Features
1 Add phone number editing function in Dual SIM settings
2 Add 128G SD card turn into Power Saver mode function.
3 Add Latvian and Lithuanian language
Wat er niet bij staat, maar wat volgens de Stagefright detector wel gefixt is zijn de 'nog openstaande stagefright bugs'. Na het installeren van deze firmware krijg ik keurig "not vulnerable" te zien.
[ Voor 5% gewijzigd door Hmmbob op 13-11-2015 08:29 ]
  • FJVersteeg
  • Laatst online: 04-09 10:41
Heb ook een Zenfone 2 doch bij telefoon info staat ZOAD. Nergens dat ie Zenfone 2 heet. Ook op de Asus website niets over de zenfone 2. Kijk ik verkeerd ofzo?
  • Hmmbob
ASUS-Z00AD is een van de interne benamingen, net als de ZE551ML - het betekent allemaal Zenfone 2 :)
  • Dreamvoid
Dreamvoid
Net de zilveren ZE500KL (16 GB) besteld. Amazon had 'm in de actie voor 149 euro, en voor die prijs laat ik 'm niet lopen.
  • hgoor
FJVersteeg schreef op maandag 16 november 2015 @ 00:39:
Hey, ik probeer je al een paar dagen te bereiken over je advertentie.... Wellicht heb je tijd om te antwoorden?
  • Sr Juan
  • Laatst online: 18:05
Sr Juan
7 uur later dan bij jou in NL
Volgens mij mis ik het kopje update......
Afbeeldingslocatie: http://upload.onderkoffer.com/images/Screenshot_2015-11-18-15-19-46%5B1%5D.jpg
Maar handmatig lukt dit ook niet met het schema wat hier boven vermeld staat.
Harde fabrieksinstelling helpt ook niet,.....
[ Voor 9% gewijzigd door Sr Juan op 18-11-2015 16:25 ]
El trago de mezcal, como lo senos de las mujeres, uno es insuficiente, tres son demasiados
  • kaasszje
kaasszje
Hij zou ook nog bij je applicaties kunnen staan.
Systeemupdate
Bij mij is deze overigens nog gewoon aanwezig:
Afbeeldingslocatie: https://lh3.googleusercontent.com/1Dtp1fFctmclfgo_v3J0RyRr8ddPKe67ENbraaYPZ6aNMp8uGcWGJ3zIGuiEpWqC29EVQgg_HLjwDmMZgWie2syGmdeLEfEBc_xkiJP4U_gYs8hi-ZpeS9MOPK0n2c8pvNERGQTIf1NiGI8lFt6OaQ6jIFf9Kx-Z2Yt45LZNSPohUXo-SvWJEKiYTUkSzeMAug2HkiCEOxGS5jAMHHmrP6hemJBM9FsbNlTSWdfwDs5HFfa_zM6dE5mkqa-ueDSyQSQ2XjDFA0gmTk5tmUy5yaRIxvFwdH9wTI6O-BoZ8yebN4e5bg3VvggC4-wIerNaJpLZPQxcosoZ8dtSwxviesRf1m3ivw2Twh6f5ZQSOT6PGE-tze77un5vQdIx0_jclTgAVdt2MoSf0AtfcR9y8iESe2hdl-1Q7QXWMx1bI73yq9r8ATLbaMU_VU3b5CBTzwRdYiVwXSgBqlbijkmNnlBRXAhQt4vi8JlobHYm5L3WmE4AZBdsXHypt0vJsUjjOSIRIHO6KSI39TI4P4WZVeR-b98xe3jHhy5cTUhaXIcz=w543-h965-no
[ Voor 84% gewijzigd door kaasszje op 18-11-2015 17:21 ]
  • Hmmbob
Toevallig een tweede gebruiker aangemaakt op je telefoon?
Alleen de 'hoofdgebruiker' krijgt die optie te zien.
  • Sr Juan
Sr Juan
Hmmbob schreef op woensdag 18 november 2015 @ 22:03:
Nee ik heb de telefoon sinds gisteren in mijn bezit, hoe kan ik zien of er meerdere gebruikers zouden zijn?
En zou die niet weg zijn na de hard reset waarbij ik alles nieuw zou moeten zijn.
Ik mis ook je software informatie...
  • Sr Juan
Sr Juan
Afbeeldingslocatie: http://upload.onderkoffer.com/images/Screenshot_2015-11-18-22-24-16a.jpg
De gebruikers heb ik gevonden en ik ben de enige die er is en gast, maar die staat nu uit.
Ik heb ook geprobeerd via een sd kaart, en dan via het recovery mode, maar daar vindt ik niks over updaten.
Uit deze informatie kan ik toch opmaken dat ik de WW versie heb, maar nu ik op het doosje kijk zie ik bij het c.p/n nummer kijk zie ik CN staan 8)7
[ Voor 20% gewijzigd door Sr Juan op 18-11-2015 23:18 ]
  • Gnermo
Gnermo
Ik probeer nu mijn zenfone op mijn PC aan te sluiten, maar ik zie hem niet als schijf.
Alleen als "Asus PC Suite". Nu hoef ik al deze meuk niet op mijn PC, heeft iemand nog een idee hoe ik dit weer gewoon in kan stellen?
  • Hmmbob
Ontgrendel je het scherm wel na aansluiten? Zolang je de telefoon niet ontgrendeld, gaat de USB storage niet beschikbaar komen.
  • theduke1989
Mildpower schreef op woensdag 18 november 2015 @ 22:33:
Dan is jou versie geroot, en hebben ze een WW image opgedaan :)
Je moet deze opnieuw unrooten en gewoon de normale CN erop zetten.
Je moet dit gewoon doen:
Firmware: http://yunpan.cn/cmXN3neTi24QP passwords; 0f6b
Tool :http://yunpan.cn/cmXN2IN4jhYeT password‘ 143c
Video :http://yunpan.cn/cm8RNw36WsqQq password” a8ce
since the phone is cn version , it can't be root to ww version ,pls udnerstand
and download the firmware and tool , then watche the video how to root , hope it can help you
regards
  • Dreamvoid
Dreamvoid
Voor de liefhebbers, review van de Zenfone 2 Laser (ZE500KL):
productreview: Asus Zenfone 2 Laser (ZE500KL) 16GB Zilver review door Dreamvoid
  • Freak
  • Laatst online: 13-05-2025
Heeft iemand nog een alternatief voor het opsturen van de telefoon naar Asus ter reparatie als het scherm kapot is? Aangezien deze telefoon in Nederland minder bekend is, is het volgens mij lastiger om reparatie bij kleine shops gedaan te krijgen van wat ik zo zie...
  • Dreamvoid
Dreamvoid
Vervangend scherm kopen op Ebay en de kapotte telefoon inclusief het nieuwe scherm inleveren bij de reparateur. Zo heb ik het tenminste een jaar of 2 terug gedaan bij een kapotte Chinaphone.
  • Hmmbob
Weer een update, naar versie 2.2.40.156 nu:
【Version】
V2.20.40.156_20151218_8265
【Model Name】
ZenFone2 (ZE551ML)
【Release Date】
2015/12/23
【Release Note】
1.Several Apps update
2.Fix icon display issue in Settings
3.Improve the stability of Snap View
4.Improve the stability of Camera
6.Fixed WiFi Hotspot issue
7.Fixed Data transmission issue
8.Fixed Bluetooth transmission issue
9.Fixed SD card related issue
10.Extend the shutdown mimunes by power key press.
11.Improve the compatibility of apps
12.Fixed calling issue in Singapore
13.Fixed 3G cannot camp to H plus in some countries.
14.Support Zawgyi Myanmar string translation
15.Move Screenshot settings to the first layer
16.Allow Clean Master S key to be uninstalled
17.Improve ringtone chooser stability
18.Improve the stability of Email App
19.Modify Italy PosteMobile MMS APN setting issue
# New Features
1.Add Game Center
2.Add new wallpaper3.3.Add Theme Store
  • Hmmbob
kaasszje schreef op maandag 02 november 2015 @ 16:44:
Ben even in Nederland en kan bevestigen dat ook een prepaid sim (met de juiste bundel) prima op Vodafone 4G werkt :)
  • kaasszje
kaasszje
Hmmbob schreef op zondag 27 december 2015 @ 11:52:
Dank je wel.
Ben ondertussen al geruime tijd een zeer tevreden gebruiker van de zenfone 2 :)
Werkt super, ook met vodafone 4g :)
Pagina: 1 ... 3 ... 6 Laatste
