Voor de LLM compute enthusiastelingen:
GeForce Unlocked: Modders Boost RTX 20, RTX 30, and RTX 40 Compute Performance by Up to 2x
NVIDIA's GeForce RTX 30-series and RTX 40-series graphics cards are based on the same dies as their professional-grade GPUs. This means the compute potential of consumer-oriented RTX GPUs is restricted by NVIDIA's firmware stack, but modders have managed to unlock the instruction issuing rate equivalent to their professional GPU counterparts. Starting with the GeForce RTX 30-series "Ampere," a researcher developed an unlock that effectively doubles the instruction issuing speed of FP/BF16 FMA into FP32 operations on GA102, GA103, GA104, and GA106 cards. As a result, cards like the GeForce RTX 3090 Ti experience up to 80% faster matrix multiplication in BF16, which is crucial for running nearly all neural networks. The unlock supports GA102, GA103, GA104, and GA106-based GeForce RTX graphics cards.
Next, we have the GeForce RTX 40-series "Ada Lovelace" with another project that has demonstrated a massive 2× speedup in FP16 and BF16 tensor throughput with FP32 accumulation. When the GeForce RTX 4090 was tested with FP16 tensor throughput and matrix accumulation, the GPU achieved 165.6 TeraFLOPS, while the unlock pushed that number to 331.6 TeraFLOPS. This is intriguing as these computational performance numbers are typically reserved for the higher-end professional segment like the NVIDIA RTX 6000 "Ada Lovelace." It seems NVIDIA artificially limited the AD102 silicon's performance in compute-sensitive matrix multiplication and accumulation, affecting the performance of running large language models. For this unlock, AD102, AD103, and AD106 are officially unlocked.
These two separate GPU unlocks appeared nearly simultaneously, with one demonstrated for the GeForce RTX 30-series "Ampere" and the other for the GeForce RTX 40-series "Ada Lovelace." Both unlocks successfully pass NVIDIA's driver checks and override PCIe Function Level Reset (FLR), running stock NVIDIA drivers, and CUDA benchmarks are performed normally. For example, the same 450 W TGP board power is used before and after the unlock on both GA102 and AD102. For those running compute-intensive tasks like local LLMs, the added compute power results in significantly higher token throughput in prefill and decode, allowing consumers to enjoy higher performance. However, it's important to note that any GPU modification will void the warranty and must be enabled at boot so these mods bind before NVIDIA drivers bind the card to the kernel.
Update 09:20 UTC: NVIDIA's GeForce RTX 20-series "Turing" are also being unlocked by the same technique, boosting the performance by 2x.
