• Frank1973
  • Laatst online: 01-11 20:16
Frank1973
XBL: Ghostleader1NL
Is dus de patch nu al uit voor de 360???
  • AR10
  • Laatst online: 16-11 13:34
04/11 - X360 & PS3 Title Update Fix Lists
Xbox
1. The game will now return the correct list of servers after searching a game
2. A corrupted save data bug has been fixed.
3. The game will now automatically unlock the FTE missions when a specific DLC is added to the game.
4. Gameplay online
o The player is now not blocked after healing another soldier as a medic
o If the player fires the SMAW weapon during a PvP game, the sight will now disappear as normal.
o The player can now change weapons after firing a machine gun multiple times
o The PF98 QueenBee weapon does now always have an effect on vehicles for the client
o During a PvP game if the player spawns inside a vehicle, the weapon will now be correctly attached to the player and now float next to the player.
o “Shots Fired” dialogue will now be triggered adequately in the annihilation mode.
5. The inventory UI from the crate or corpse can now be opened correctly when the player is standing at distance.
6. Loading the 1st checkpoint with javelin equipped in the mission Dragon’s fury will not cause a loss of audio in certain instances.
7. If the fireteams are following orders and then the player select an ROE order on all fireteams including themselves the orders will now be spread across all fireteams.
8. The reloading time is now correct when the player is going prone straight after firing a SMAW or Queen Bee weapons.
9. When exiting the credits, the heading will not transition twice.
PS3
1. The game will now automatically unlock the FTE missions when a specific DLC is added to the game.
2.Gameplay online
o Lag issues reduced for 8 players pvp
o The Client and Host shooting are now synchronised. The client will no longer empty a magazine into a player and not killing him.
o In an online game, the mines are now correctly synchronised. The player can place mines on the ground with no problems.
o The weapon will now continue working if the player spam the fire button and the change fire rate button.
o The Players will now position correctly when re-spawned inside a vehicle
o Clients are now able to enter vehicles with no problem
3. All sniper rifles will now have a sway effect.
4. When a building is destroyed any corpses that are within the building are removed, so they are not floating in the air.
6. A rare online crash bug has been fixed when the Client is assaulting the fuel depot towards the end of the mission Bleeding Edge
7. If the player signs out whilst creating an online then the LAN game will not fail to create
8. Friend status changed message will not cause an issue to join a new game
9. Loading the 1st checkpoint with javelin equipped in the mission Dragon’s fury will not cause a loss of audio in certain instances
10. If the fireteams are following orders and then the player select an ROE order on all fireteams including themselves the orders will now be spread across all fireteams
11. The reloading time is now correct when the player is going prone straight after firing a SMAW or Queen Bee weapons
11. The game now only mounts the missions and DLC directories, so any loose files that are placed in the other directory will no longer be read by the game. It will now only use the files from the original NeFS volume.
12. The LOD in the FTE Ambush is now corrected when loading the mission for first time
13. If the player signs out whilst creating an online then the LAN game will not fail to create
14. When exiting the credits, the heading will not transition twice.
__________________
  • robhoeben
  • Registratie: Oktober 2008
  • Laatst online: 25-01-2025
info over nieuwe skirmish DLC pack: http://community.codemast...m/showthread.php?t=394543
(gaat 3,99 kosten).
Wat is die sniper rifle "sway effect".
[ Voor 28% gewijzigd door robhoeben op 04-11-2009 15:18 ]
PSN ID: robhoeben
  • Cascade
  • Laatst online: 20-11 20:09
Voor de PC:
- de Skirmish DLC pack: http://community.codemast...m/showthread.php?t=394545. Gratis voor PC.
- de patch notes: http://community.codemast...m/showthread.php?t=394523.
Release staat voor 5 november.
  • Tom
Tom
Patch: wat een tegenvaller.
DLC: wat een afzetters.
  • Castor385
  • Laatst online: 20-11 08:30
robhoeben schreef op woensdag 04 november 2009 @ 15:15:
Als je hebt geschoten met je sniper rifle zwaait je geweer alle kanten op, soort van terugslag van het wapen.
[ Voor 4% gewijzigd door Castor385 op 04-11-2009 15:46 ]
Study everything, You'll find something you can use
  • Frank1973
Frank1973
XBL: Ghostleader1NL
weinnig verandert na de patch!! Dooie blijven nog gewoon rechtop staan.. mijn wapen blijft nog steeds weer wisselen tussen full auto en single shot.. en nog meer dingetjes.. Jammer!!!
DLC gaat 400M$ kosten terwijl ze eerst beweerden dat het DLC wat uit zou komen gratis zou zijn... Ze willen nog snel even cashen voordat MW2 uit komt!!
  • Tankbuster
  • Laatst online: 12:11
Deze hele game is toch een tegenvaller, en je ziet zeker hoe CM zich inzet om OFP DR nog enig zins goed te maken na die patch... De communicatie met de gamers bestaat ook niet, en ze willen toch blijkbaar alleen cashen voor MW2 .
Vraag me af , of CM nog iets zal doen nadat MW2 uitgekomen is, of gewoon meteen de login server eruit gooit.
Heb het spel gisteren gespeeld,
ik had er stiekem meer van verwacht, zoals hier te lezen zit er nog een aantal bugs in.
Vond de eerste leuker, en het gaf een -specialer- gevoel.
  • Freak187
  • Laatst online: 19:11
Freak187
geen
Ik vind het inderdaad een beetje zuur dat de DLC geld gaat kosten. Ik dacht te hebben vernomen dat het gratis zou zijn, al weet ik niet meer waar ik dat gehoord heb. Nu betalen we dus voor DLC van een spel dat zelf qua content al niet heel uitgebreid is.
Het hele Operation Flashpoint 2 gebeuren brengt zo wel een nare smaak in de mond. Ik vind het best een leuk spel maar er zitten zoveel kleine nadeeltjes aan dat het me moeilijk wordt gemaakt er veel plezier van te hebben.
Kia Niro-EV 2024
  • Tankbuster
Freak187 schreef op woensdag 04 november 2009 @ 17:46:
Jij kan het spel spelen met een Athlon 700 en een Radeon 7500? Dat doe je goed dan ! :+
  • Tom
Tom
Tankbuster schreef op woensdag 04 november 2009 @ 18:21:
Misschien heeft ie een PS3/Xbox :+
Ik ben het verder met em eens. Zitten nogal wat bugjes en minpuntjes in waardoor het niet de game is die het had moeten zijn. Vooral de singleplayer is slecht uitgewerkt en kort (ondanks dat ik het nog niet heb uitgespeeld). Met zo'n groot eiland hadden ze er wel meer uit kunnen halen. Voor de release kwamen ze wekelijks met filmpjes waardoor men hoge verwachtingen had. Met een goede patch moet er best wat op te lossen zijn, maar als ik dat lijstje doorkijk is het wel erg mager. Die DLC is ook een haastklus geweest als ik het zo zie, wat dingen die er toch al inzaten opengezet en een paar extra missies. Helemaal een blunder dat zoiets op de PC dan wel gratis is. Ik vond Codemasters altijd wel voor kwaliteit staan...
  • Sissors
Dus PC multiplayer wordt nog niet gefixed? Misschien heb ik het gemist, maar dat betekend dus dat er nog geen enkele info is of er nou wel of geen dedi servers komen?
Bij olietank aanvallen had ik juist (op PC) echt het idee dat computer andere AI had gekregen. Silenced weapons zullen wel verschil maken voor hoe ai reageerd, maar nu kon je gewoon langs AI heen lopen. En ik vond het nogal onduidelijk waar je nu naartoe moest na het opblazen van de handel, dus eerste keer ging ik maar over op iedereen neerschieten (mijn teamgenoten waren allemaal dood ondertussen), en toen vond ik ook juist dat ai zwaar belabberd bezig was. Ze rende recht naar me toe waar ze 1 voor 1 dood gingen.
[ Voor 61% gewijzigd door Sissors op 04-11-2009 18:37 ]
  • Freak187
Freak187
geen
Die specs zijn volgens mij van jaren geleden :P Dit account is van mijn broer die em (denk ik) niet meer gebruikt. Ik speel het spel op de 360.
Kia Niro-EV 2024
  • Sak3d
  • Laatst online: 10-12-2023
Sak3d
Reise, Reise
Nu weet ik nog steeds niet of ik deze of arma2 moet kopen :(
  • robhoeben
Ik start net de game op, en wil verder gaan met mijn campaign. Tot mijn grote verbazing begin ik weer bij level 4, terwijl ik al bij level 6 was. Op een of andere manier is de vorige keer dat ik het spel gespeeld heb niks opgeslagen ofzo! Nou moet ik dus 2 missies, waar ik al lang genoeg over had gedaan opnieuw doen! Begin steeds meer gefrustreed te raken van dit spel. Als de online Co-op niet zo leuk was had ik em al weer verkocht denk ik..
PSN ID: robhoeben
  • Edmin
  • Laatst online: 18-11 20:49
Edmin
Crew Council
get on my horse!
[PC]
Ik vind het best een aardige SP shooter. Het context sensitive order systeem is een goede vondst. Helaas zit ik nu even vast in level 3 (het verdedigen van een dorpje), maar dat mag de pret niet drukken.
  • Beakzz
  • Laatst online: 19:53
Frank1973 schreef op woensdag 04 november 2009 @ 17:12:
Persoonlijk denk ik dat ze het wel gratis willen doen , maar dat microsoft het niet pikt. Die bepalen de minimum prijs en tja dan moet de Ps3 natuurlijk ook betalen anders wordt het helemaal een zooitje.
Dit zag ik al aankomen dus heb ik Ofp tijdig geannuleerd . Wat doe ik dan hier in vredesnaam ? Ff checken of het al wat beter was geworden, want ik mis het origineel en die had ik graag terug gezien met betere graphics ;) Ben alweer weg :p
  • Tom
Tom
Beakzz schreef op donderdag 05 november 2009 @ 00:35:
Dan nog klopt het niet, want bij Codemasters was al voor de release bekend dat ze met DLC gingen werken. Inhoudelijk stelt deze DLC ook geen kont voor zoals ik het nu zie, het staat allemaal al op de disc. Echt nieuwe dingen komen er niet bij. Als ze het gratis hadden willen doen, dan hadden ze dat al gelijk open moeten zetten. Als Microsoft of Sony er inderdaad geld voor vragen, dan is dat echt wel bekend bij Codemasters.
Op het codemasters forum is het topic van de patch/DLC al 25 pagina's. Ze krijgen (terecht) veel kritiek...
  • Mektheb
  • Laatst online: 15:10
Leuk al die multiplayers en patchnotes gezeur, als ze nu het geen fixen met die 64 limiet in de editor dan zou het spel weer leuk worden :)
  • Cascade
Mektheb schreef op donderdag 05 november 2009 @ 14:18:
En waar zou dat eventueel kunnen staan? Juist... in dat patch notes gezeur. |:(
  • Mektheb
Cascade schreef op donderdag 05 november 2009 @ 15:00:
Dus dat is veranderd ?, dan heb ik dat gemist >.>
wat is nu het limiet ? wat je pc aan kan of weer een "cijfer"
edit: kan het niet vinden zo snel
[ Voor 5% gewijzigd door Mektheb op 05-11-2009 15:17 ]
  • Freich
  • Laatst online: 01-03-2025
Freich
YOU ARE NEX!
http://www.gamer.nl/doc/5...int-gratis-voor-PC-versie
Het eerste downloadbare contentpakket voor Operation Flashpoint: Dragon Rising verschijnt vandaag gratis voor PC. Dat heeft ontwikkelaar Codemasters bekendgemaakt.
3 Inches of Bloodsport!
  • SlideR NL
  • Laatst online: 09:50
Freich schreef op donderdag 05 november 2009 @ 16:04:
Ja en voor de Xbox moet ik er weer voor betalen :(
Heb het wel gedaan, daar niet van, want ik had nog 900 puntjes over die ik op dit moment toch nergens aan ging uitgeven. Maar heb hem nog niet getest want ben nog niet thuis. Hij staat wel in download queue :D Dus xbox aanzetten en hij word gelijk gedownload :P
  • Cascade
Mektheb schreef op donderdag 05 november 2009 @ 15:16:
Dat is het hele punt: als ze het gedaan hebben, dan zou het in de notes staan. Dus waarom is iets als patch notes gezeur? Daar zat ik over te zeuren. :P
Helaas is het niet aangepast.
  • Dutchie!
  • Laatst online: 07-12-2023
Living in Australia! - Ja, ik heb dyslectie
  • Mektheb
Cascade schreef op donderdag 05 november 2009 @ 16:41:
Awh ja zo snap em !
Ok helaas is die het dus nog niet waard om te installeren :(
Terug naar Arma dan maar
  • Freich
Freich
YOU ARE NEX!
Zo eindelijk missie 1 op hardcore gehaald met alle sec objectives completed. _/-\o_
Echt een goed spel gewoon, ik zat er helemaal in. Ik merk ook nauwelijks iets van bugs etc.
Heeft iemand al de .50cal sniper gevonden in missie 1?. Ik wel en het ownt ;p
Je ziet de kogel echt in een boogje vallen, en das extra cool als je dan een headshot maakt.
Ook alle commando's werken best goed. Ipv fire at will, fire on return bijv.
  • zezke
  • Laatst online: 20-11 10:28
Freich schreef op donderdag 05 november 2009 @ 18:58:
Dat is ook mijn gevoel over het spel :) Al vind ik het wel een bummer dat de DLC betalend is in tegenstelling tot vorige berichten. En het is niet echt OFP2, net iets te beperkt daarvoor, maar niettemin een vermakelijk game.
Ik ben net begonnen met level 1 en tot nu toe vind ik het nog leuk.
Het spel draait ook verder prima met alle settings om zijn max. Volgens mij ondersteund dit spel ook
mutiTH
  • Freich
Freich
YOU ARE NEX!
zezke schreef op donderdag 05 november 2009 @ 20:10:
Op pc wel gratis hoor :o
  • supakeen
  • Laatst online: 09-09-2025
Was het niet zo dat alle extra content via Xbox Live verplicht betaald moet zijn? Dacht dat dat ook het geval was bij TF2 met de class updates.
Hoe zit het voor de PS3?
[ Voor 30% gewijzigd door supakeen op 06-11-2009 11:42 ]
  • Wildfire
  • Laatst online: 18:21
Wildfire
Joy to the world!
Edmin schreef op woensdag 04 november 2009 @ 23:11:
[PC]
Het enige lullige aan het context-sensitive order systeem is dat ik niet al rennende opdrachten kan uitvaardigen. En het gebeurt me ook vaak dat ik een opdracht uitvaardig maar het menu vergeet te sluiten, waardoor ik weer een andere opdracht geef als ik weer wil gaan lopen (ik gebruik namelijk de pijltjestoetsen, ik ben geen WASD-gamer).
Maar goed. Zit nog maar in het 2e level. Wel irritant dat er een tijdsgelimiteerde missies zijn, in het 2e leven heb ik een bepaald gedeelte echt tien keer opnieuw moeten doen omdat ik elke keer echt letterlijk twee seconden tekort kwam. In tijdsgelimiteerde missies moet je je dus echt niet teveel bezig houden met sluipen, dat kan verkeerd aflopen :P
Systeemspecs | Mijn V&A spulletjes | Mijn RIPE Atlas probe
  • jorisdekloris
  • Laatst online: 18-11 18:13
Hoe is het met de verbindingsissues na de patch voor de PC?
Tierelier
  • zezke
Wildfire schreef op zondag 08 november 2009 @ 21:55:
Ik heb eigenlijk nog nooit last gehad van een tijdslimiet. Wel heb ik vaak het gevoel dat ik vooruit gepusht word om mn opdracht te vervullen, maar dit vind ik deel van de sensatie.
  • Wildfire
Wildfire
Joy to the world!
zezke schreef op maandag 09 november 2009 @ 09:00:
Misschien probeer ik te "stealthy" te zijn. Ik neem namelijk mijn tijd om gebieden op vijanden te controleren voordat ik en m'n team weer een stuk verder trekken. Vaak komt het erop neer dat ik een gebied verken via m'n scope of met de verrekijker, als ik alles veilig acht ga ik weer een meter of 100 verder en herhaal ik het verkennen via de scope of verrekijker weer. Dit vertraagt dus wel de boel.
Aangezien in de 2e missie het onopgemerkt blijven een secondary objective was heb ik me dus aan bovenstaand proces gehouden. Ik wil niet als een kip zonder kop honderden meters sprinten namelijk :)
Maar goed, na een keer of tien was ik gelukkig nèt snel genoeg om na het laden van het checkpoint de missie toch te voltooien. Had alleen weinig tijd om uit de buurt van m'n C4 te komen, want om de een of andere reden moet je stilstaan om je remote control van de detonator te bedienen. Wat je in realiteit rennend of iig lopend toch ook wel zou kunnen doen... :P
  • PLAE
  • Laatst online: 20-11 09:59
In Operation Flashpoint 1 had je online hele opbouwmissies. Zogenaamde campaigns (niet samen een singleplayermissie doen ofzo) waarin je tanks kon krijgen etc etc. Dat kom ik nu helemaal niet tegen.
Het enige wat ik zie is:
* samen singleplayersmissie spelen
* MP game is vaak gewoon vechten om een dorpje ofzo.
Daarnaast zie ik ook maar erg weiniger servers constant met altijd dezelfde mappen.
Valt nog wat tegen allemaal :{
Die nieuwe gun is wel prachtig idd met die vallende kogels hehe.
  • AR10
Morgen wordt het PS3 network gepatch volgens CM.
Hopelijk zijn er dan minder netwerk issues en gaat de multiplayer/lobby een stuk beter!
I've just been informed that tomorrow (11th Nov) we will be taking down our PS3 online hosting service for scheduled maintenance work between the hours of 13:00-16:00.
  • AR10
Goed nieuws!
Er komt binnenkort een grote tweede patch aan.
Deze bevat significant meer fixes SP en MP.
Currently the team is dedicated to working on a 2nd patch/TU, and whilst the release date is still TBA, the good news is that this 2nd patch/title update will be a significant update and will address a wide variety of issues for SP and MP across the board.
While the the 1st patch/TU was primarily put out to address priority issues immediately affecting the quality of the game, the upcoming 2nd patch/TU will contain a much greater number of fixes and hopefully satisfy everyone’s needs.
Het is bevestigd door Helios dat er geen dedi servers komen, dus ik stop hier ook mee, erg jammer want de game is op zich hardstikke mooi en draait ook nog eens goed :/
  • GekooktEi
  • Laatst online: 20-11 12:09
Ik ga het spel verkopen, denk ik. Het is leuk, maar weegt niet op tegen de AAA-titels die uit zijn gekomen en binnenkort of volgend jaar uitkomen, zoals Modern Warfare 2 (die het gewoon verslaat in zijn genre), Uncharted 2 die ik nog moet kopen omdat ik dit spel prioriteit gaf, Assassin's Creed 2, en volgend jaar Heavy Rain, Mafia II, Gran Turismo 5, God of War III, Battlefield: Bad Company 2...
M.a.w, ik ga dit spel verkopen voor waarschijnlijk Uncharted 2.
  • The_Scarabial
  • Laatst online: 17:16
The_Scarabial
MTB for life!
Vanmiddag nog even weer gespeeld, maar krijg toch niet het lekkere gevoel wat ik had bij OFP1.
  • _Quinten_
  • Laatst online: 23-08 09:14
Voor wie het nog niet zou gezien hebben, de demo is uit.
  • zezke
GekooktEi schreef op donderdag 19 november 2009 @ 16:45:
Als jij dit spel in dezelfde categorie plaatst als Modern Warfare 2 kan ik me niet voorstellen dat je het voldoende tactisch aanpakt om er van te genieten.
  • Wildfire
Wildfire
Joy to the world!
zezke schreef op vrijdag 20 november 2009 @ 08:17:
Ja, Modern Warfare 2 valt niet te vergelijken met OFP2. In MW2 is veel meer gericht op actie en hoef je niet veel na te denken. In OFP2 sluip je veel meer rond, verken je eerst goed het terrein, doe je ook wat aan planning. Dat alles heb ik MW2 nog niet gezien iig :)
Hallo. Ik heb gisteren de demo gedownload. En single player gespeeld. Heb nooit de 1st versie gespeeld. Maar was 6 jaar lang een America's Army player. Ik hoe van teamwork, stealthy games. Ik speel ook MW2. Maar dit kan je echt niet vergelijken. MW2 zeer goed spel. Alleen meer gebasseerd op actie.
Ik ben ga deze kopen als........
Ik heb nu bijvoorbeeld de Demo. Ging kijken hoe de multiplayer was. Was geen een server beschikbaar.
Ik wil dit spel echt graag hebben.
Alleen mijn vraag is kan ik de demo ook multilpayer spelen? (demo updaten, want ik vind geen servers)
En als ik hem gekocht heb. Zijn er dan wel servers voor multiplayer beschikbaar?
En zijn er veel servers?
Laggy servers?
Ik wacht op de antwoorden voordat ik mijn besluit maak.
Alvast bedankt!
  • macciez
  • Laatst online: 29-12-2025
Nu dit topic weer actief is, moet ik even wat kwijt.
Ik vond dit spel echt lachen om te spelen, maar sommige dingen sloegen echt helemaal nergens op. Coop laatste missie, ik moest deze gewoon 5 a 6 keer spelen, niet omdat ik te slecht was maar:
- 1 keer ontploft mn coop buddy, zonder schoten, zonder knal, gewoon bam dood
- 1 keer ontploft de tank waar we inzitten, omdat ik zachtjes tegen een huisje aan parkeerde
- 1 keer ga ik spontaan dood terwijl ik die chopper vlieg
- 1 keer zegt de radio "nog 2 minuten" en dan nog geen 30 seconde later "mission failed"
Vrijwel geen hinderlijke bugs gehad het hele spel, maar daarvoor des te meer in de laatste missie. Ow ook nog grappig, ik stuur de AI een huis in en als ik zelf dan dat huis binnenloop staan ze daar gewoon thee te drinken met de tegenstanders, 1 meter naast elkaar maar niemand die iets doet.
@hierboven:
Ik speel op de xbox en heb eigenlijk nooit echt problemen met het vinden van servers, connectie is nooit top, maar eigenlijk ook nooit echt heel slecht
Do what you love, do it often
  • WoRReLbier
  • Laatst online: 16:44
Verwijderd schreef op vrijdag 20 november 2009 @ 10:23:
Laggy servers?
Alvast bedankt!
Ik heb zelf de PC versie ervan.. En af en toe heb ik wel eens connectie problemen.. Die ik dan weer benut door het spelen van missies die door anderen zijn gemaakt( zo'n 50 stuks)
Ik zoek alleen maar naar "Ranked" servers(Infiltration en Annihilation) Als je graag unranked, ranked en co-op wil spelen is er keus genoeg naar mijn beleving..
Laggy servers heb ik wel eens mee gemaakt en dan zoek ik gewoon weer verder zonder problemen..
Ik denk dat je met co-op zelden een laggy server zal meemaken ivm de 4 player max.
Tot nu toe vermaak ik mij super met dit spel itt MW2..
Hoop dat je hier wat aan hebt..
  • Dyoma
  • Laatst online: 23-02 09:07
Ik heb het spel voor de PS3
Kan alleen de objectives niet zien? Als ik dood ga zie ik een lijstje met wat ik nog moet doen maar deze kan ik tijdens het spelen niet naar voren krijgen. Ik speel nu op de makkelijkste moeilijkheids graad dus zie wel welke kant ik op moet maar als ik hem straks op het hoogst zet ben je dat dus kwijt. als je dan je objectives niet kan zien dan wordt het lastig. is hier een knop/ knoppen combi voor?
kan er ook niets over terug vinden in de handleiding.
  • Tom
Tom
Select-knop ingedrukt blijven houden.
Gister een Javelin (of zoiets) gevonden, in de 1e missie (xbox360).
Klopt het dat je er alleen mee kan schieten als je een target "gelocked" hebt?
Ik kon een APC niet "targeten", is dat normaal?
Verwijderd schreef op dinsdag 24 november 2009 @ 10:40:
Het klopt dat het targetten niet altijd lukt, je moet ongeveer 40 procent van het voertuig in zicht hebben voordat de lock zich voordoet.
De verbindingsissues waren voor zover ik mij herinner onderdeel van de changelog en repareert wat problemen aan de Client-side. Ook de servers zijn een paar keer "down" geweest voor onderhoud. Patch 2 gaat waarschijnlijk ook nog wat problemen fixen. Mijn persoonlijke opinie is wel dat het grootste probleem bij de servers van Quazal (de online service die gebruikt wordt) ligt en niet aan de client-side, Matches via Direct IP zorgen er namelijk voor dat een groot deel van de mogelijke vertraging verdwijnt/verholpen is. Naarmate de tijd strekt denk ik dat de problemen langzamerhand verholpen gaan worden.
  • zezke
Tweede DLC is aangekondigd. Deze zal al zeker extra MP modi bevatten.
Ik zou liever een uitbreiding van de SP zien en een free roam mode die misschien vijanden bevat?
  • Dinictus208
Dinictus208
Tele romeo
Ik heb het spel nu ook tot level 6 gespeeld en was een fervent opf1 speler. Kortom, vol verwachting klopte mijn hart!! Maar het stel me eerlijk gezegd diep teleur. Graphics zijn okay maar niks om over naar huis te schrijven maargoed daar gaat het niet om. Het belangrijkste dat ik mis is de vrijheid om echt te doen wat je wilt. Waar je in opf in een missie gewoon een hind kon stelen en de hele boel vanuit de lucht kon bestoken moet je nu dit en dit doen. Via waypoint lopen etc. Voertuigen kun je maar beperkt gebruiken waar je in opf1 gewoon zelfs een traktor kon stelen. Maar neeee niet in deze game hoor. U dient op de rails te blijven.
bv bij dat airfield, ik flanken van hier tot gunter totdat ik van boven op de berg een jeep zie staan. Ik pak mijn bazoooka of hoe heet dat ding. Vuur af, een grote explosie midden in die jeep. En wat schets mijn verbazing????? JEEP VOLLEDIG intact met 2 man erin. Want kennelijk was het niet de BEDOELING dat ik die jeep zo aanviel ofzo. Nou dan houdt het voor mij op hoor. Daar speel ik toch geen OPF voor?
kortom, ik ben niet positief over dit stuk nijlpaardenstront. En waar is de muziek? En waar is het verhaal?
DOEJ
oh ja nog iets, ik reed een keer in een humvee, heerlijk raggen met dat ding dus ik zie een vijand die ik denk over te gaan rijden. Ik rijd circa 100, iig vol gas, nee die gast schuift op zijn knieen naar mij gericht voor mijn hummvee uit om vervolgens te vuren en die jeep onschadelijk te maken!!!!!! ik wil een vliegend mannetje zien of iig een DOOJE.
DOEJ again!!!
[ Voor 13% gewijzigd door Dinictus208 op 29-11-2009 15:33 ]
I could feel at the time There was no way of knowing Fallen leaves in the night Who can say where they're blowing As free as the wind And hopefully learning Why the sea on the tide Has no way of turning
Ik heb hem er maar weer af gedonderd. Niet mijn smaak game maar het ziet er allemaal wel goed uit.
Helaas kwam die demo veel te laat uit maar goed geld moet rollen.
  • zezke
Dinictus208 schreef op zondag 29 november 2009 @ 15:30:
DOEJ
DOEJ again!!!
Met sommige punten ga ik akkoord. Je schrijfstijl echter totaal niet, maar dat is een andere zaak. En de muziek is met opzet weggelaten, loop maar eens buiten op het veld met je bb-gun ofzo, je zal geen muziek horen.
  • Dinictus208
Dinictus208
Tele romeo
Ieder heeft zijn eigen schrijfstijl maar bedankt voor je mening.
OPF1 was toch een een simulator? Waarom mocht daar dan wel muziek in? muziek geeft body aan een game en het gemis van muziek vind ik zonde.
Verder vind ik het gewoon een teleurstelling dat iets dat zich een simulator noemt overduidelijke defecten vertoont. Helemaal omdat het in OPF1 wel allemaal kon. Dit spel voelt niet als OPF2 maar als OPF0,5.
  • WoRReLbier
Ik denk dat je dit misschien moet zien als een semi-simulator.. Komt denk ik ook omdat ze het voor de consoles hebben uit gebracht.. Omdat daar meer geld valt te halen.
Als je kijkt naar de 1e patch waarvoor de consolegamers voor moesten betalen..
Al met al vermaak ik mij wel zeker met deze game. Zeker omdat ik er nu ook al wel een 100+ SP/MP/COOP extra missies erbij heb..
De infiltration in MP en zonder respawn geeft mij nog het meeste voldoening en spanning..
Binnenkort de 2e patch en hopen dat er wat aan het MP gedeelte word gedaan..
  • Witwasser
De PS3 versie is vandaag te koop voor €36,95 bij Gameoffer.
  • Dutchie!
Wie wilt mede auteur worden van de StartPost ? Heb nog steeds geen tijd om het fatsoenlijk te updaten. ;( DM mij even.
Edit: iemand een idee wat dit te betekenen heeft? goed is het niet...
http://operationflashpoint2.org/2009/11/site-is-closed/
[ Voor 35% gewijzigd door Dutchie! op 30-11-2009 18:25 ]
  • Jackal131
  • Laatst online: 19-11 12:47
Tja, blijkbaar zijn er meer mensen ontevreden over het spel.
Ik heb het spel in ieder geval ingeruild nadatik het uitgespeeld had.
Ik heb me trouwens prima vermaakt met de SP, maar om het helemaal opnieuw te spelen op Veteran zag ik niet zo zitten. En de MP boeide me helemaal niet.
psn: jackal131 | "When you jump from a plane and your parachute is broken, you've still got the rest of your life to fix it"
  • Dinictus208
Dinictus208
Tele romeo
Ik denk dat ze er compleet de stekker uit trekken omdat het niet te redden valt.
  • GekooktEi
Ik heb 'm maar verkocht, de multiplayer was net grotendeels gefixed, maar toen hadden ze het voor mij al verneukt. En ik vond de campaign op sommige stukken onduidelijk en frustrerend, hoewel ik wel hou van realisme hoor.
Het enige wat goed voelde vond ik, in ieder geval realistischer dan in CoD bijv, was natuurlijk het snipen en het LMG-schieten voelde ook alsof het echt impact had en je echt suppresive fire gaf vanaf een afstand, of het echt effect had. Dat heb ik echt niet bij CoD, maar op alle andere vlakken prefereer ik die laatste.
  • WoRReLbier
zezke schreef op donderdag 26 november 2009 @ 20:07:
Free Roam is inmiddels beschikbaar gemaakt :)
http://community.codemast...m/showthread.php?t=398512
  • robhoeben
Ik kan nergens vinden wat het 2e DLC pack gaat bevatten.... iemand?
PSN ID: robhoeben
  • zezke
Dat ziet er heerlijk uit, jammer dat CM er niet in slaagt om hetzelfde te verwezelijken voor de consoles. Voor zover ik weet is er enkel bekend dat de tweede DLC nog wat extra multplayer modi zal bevatten. Geen idee of we nog iets mogen verwachten.
  • robhoeben
Dit weekend weer eens OFP2 in de PS3 gedaan, en 4 missies gespeeld. Level 6, 7, 8 en 9 waren een stuk makkelijker dan level 3, 4 en 5. Nu moet ik dus nog maar 2 missies.
Even iets anders:
Ik had $20,- PSN credits gewonnen voor een US account, en had dus de DLC voor OFP2 gedownload voor $4,99 (Skirmish Pack) op mijn US account. Toen ik daarna OFP2 opstartte kon ik nergens de nieuwe missies vinden. Na wat googlewerk blijkt dat je daarvoor dus een game nodig hebt met een andere regiocode...
Ik heb een europese game, en die werkt niet samen met DLC van de US Playstation Store. Waar slaat het op?? Maarja, nu hgeb ik dus de DLC, maar ik kan em niet spelen..
PSN ID: robhoeben
Inmiddels wordt ik een beetje moe van het spel.
Ik ben in een missie waarbij ik eerst een AA installatie moet uitschakelen en vervolgens een gecrashte Helo moet zoeken.
Naja goed ik heb nog 30 kogels en that's about it. Nu was ik gisteravond al over de heuvel gekomen en had de AA installatie uitgeschakeld.
Maar helaas werd ik voor m'n flikker geschoten door mn over enthiausiaste machine gunner die achter me stond en poogde de vijand voor me uit te schakelen.
Inmiddels een poging of 35 later ben ik de missie helemaal zat. Heb daarnet nog gezocht naar een unlimited health cheat maar helaas niet gevonden.
Puntje bij paaltje. Ik kom deze missie niet door. Is er A of een mogelijkheid om deze missie te skippen? Of weet iemand een manier om eromheen te komen?
Want ik wordt gek van het voor m'n flikker geschoten te worden door de vijandelijke helicopter of m'n eigen machine gunner die dit ook al een keer of 14 gedaan heeft. En altijd als ik natuurlijk behoorlijk gevorderd ben.
Ik moet zeggen ARMA is toch iets beter uitgewerkt dan FP2 wat er grafisch wat beter uitziet. Maar de AI is ronduit crappy. :( :@
Opgelost.
Cheat gevonden. En erdoorheen gebanjerd.
Ja dat mag wel denk ik nadat ik het nog 15 keer geprobeerd had.
In totaal zit ik bijna op 50 x proberen. En nu was ik de missie gewoon ronduit zat. Gewoon een kwestie van slechte AI + slecht missie design.
  • aramdin
  • Laatst online: 24-07-2024
Wat heb je precies gedaan? Mag je best delen :D
Instagram / YouTube
aramdin schreef op vrijdag 22 januari 2010 @ 13:17:
Gewoon een cheat gedownload waarbij ik infinite health had.
En de missie uitgespeeld.
Vervolgens spel uitgezet.
Cheat uitgezet en het spel weer opgestart.
Maar vondt de missie zelf bar slecht in elkaar steken.
Erg veel rambo akties.
Geen support van andere leger eenheden.
Er was mogelijkheid tot luchtsteun want er was geen AA meer aanwezig.
Maar nooit gekregen.
Uberhaupt vindt ik OPF2 no way een gerechtvaardigde opvolger van OPF.
ARMA en ARMA II veel meer.
  • Avalaxy
  • Laatst online: 13-11 23:11
Wat ik trouwens nooit gesnapt heb bij dit spel... Voor je een missie start kun je je unit bekijken en de air support... Soms stond daar dan iets van 10x mortar strike of iets dergelijks, maar als ik dan de missie zat te spelen kon ik dat helemaal niet oproepen...
Vanaf vandaag om 15:00 de tweede patch beschikbaar :)
Hier onderstaan de aanpassingen.
Support added for 2 new PvP game modes included in DLC Pack 2
The host is now able to press "Start" button to ready up and begin the 10 second countdown into game
irrespective of whether all players are ready or not.
Improved multiplayer stability.
Online synchronisation has been improved mitigating various issues such as shots fired not being registered and missing animations
Improved bullet hit detection on clients
Medics no longer become unable to move if the player they are trying to heal attempts to heal themselves at the same time.
The corpse looting inventory now appears appropriately when characters are killed
The corpse looting inventory updates appropriately when swapping weapons.
Tweaks and amends to enemy and friendly AI.
The damaged vehicle icon no longer becomes stuck on screen if the player is spawned into a vehicle just as it becomes critically damaged.
Fly in camera at the start of the Lumber Yard Infiltration mission now behaves appropriately
alt tabbing when in the lobby no longer causes graphical corruption on ground texture
Speed hack checking has been activated to block 3rd party speed hacks during online games.
Anti-cheat measures implemented to combat leaderboard hacking
Ammo counter for Fire team leaders in PvP matches now counts down the remaining ammo correctly.
Vehicle control responsiveness improved for clients, with input lag reduced
Sessions that you cannot join such as those that contain DLC not present on the players machine appear as greyed out on the browse server screen.
If someone without DLC is invited to a game that requires DLC content they will receive a message explaining this and the game can still be started. They no longer take up a space in the lobby.
Improved On & Offline stability
Player positioned appropriately after exiting a vehicle.
Players are no longer able to access a locked vehicle by using an unlocked vehicle
Mines are no longer triggered by neutral (inactive) vehicles
Death cam view behaves correctly if the player dies whilst in a vehicle and swapping between 3rd & 1st person camera views
It is no longer possible to enter aimed view mode while the weapon select OSD is open.
Binocular functionality no longer impaired by previously selected inventory item.
Weapon torches now turn off properly when swapping out the current weapon via ammo crates with the torch light switched on.
Players stance is now correctly maintained after operating an emplaced weapon
The player is now able to order a fire team under their control to operate an emplaced weapon
"Move To" orders now correctly issued to the pilot rather than individual fire team members when mixed fire teams occupy the crew seats in helicopters.
Helicopter chain guns no longer jam
Weapons rotations for a.i. gyrostablised weapons are no longer updated if they've not got a target set.
Weapon OSD for the M134 Minigun in the AH-6J Helicopter now displays the correct number of rounds loaded (9999).
Helicopters no longer make inappropriate wheel contact surface sounds sound when flying over grassland.
"Live Link" feature in the Mission Editor should now default to launch the game in Windowed mode
The mission editor should now be able to read multiple databases so text strings can be easily added.
Unavailable Bradley and ZBD200 squad references removed from Mission editor
Mouse look sensitivity for mounted weapons is now aligned with other weapons
Respawn timer now displayed in all game modes.
Fixed crash using empty string with OFP:displaySystemMessage
Fixed rare crash in AI input. Unchecked possible invalid cast in AI input.
Changed client prediction code for extrapolating positions, based on how far in the past there is accurate server data. (Optimisation)
getVelocities bug fix for helicopter suspension. Refactor removed getVelocities usage.
Audio Feedback Manager can search blocked speakers list by name as well. (Optimisation)
Destructor of commands is always called in the CommandPool. Prevents possible memory leaks.
walkEchelonControlledSubUnits now recurses through only controlled units. Now processes correct sub units.
Friendly fire feedback will revert to root echelon if no fireteam members are still alive. Processes feedback case correctly.
Fixed clients showing low LOD back weapon between their feet after looting ammo crates.
The player can now add custom audio and modify further AI parameters (Weapon usage values and dispersion system).
Added OFP:getTerrainHeight( x, z ) script cmd to return height of terrain, suitable as a Y value in cmds such as OFP:spawnAtLocation
Can issue AI fireteam a Defend order to unmounted/neutral vehicles.
ik heb het spel sinds vandaag ook, aangeschaft voor de 360. Moet zeggen dat ik het brilliant vind, maar het geduld wat je op moet kunnen brengen om er daadwerkelijk van te genieten, ja dat is simpelweg niet mainstream. Ik heb de demo ook geprobeerd, maar op de pc dat vond ik gewoon rot spelen, het werkte niet voor mij, de kwaliteit van de port is simpelweg te slecht voor woorden. Heb de gok toch gewaagd om em voor de xbox te kopen nadat ik er toch nog wat meer over gelezen heb, en hij stelt niet teleur.
De game is zeker geen OFP 1, het is een totaal ander conflict met totaal andere missies. Dat is niet direct kwaliteit-gerelateerd, maar smaak, en ook dit conflict bevalt mij goed. Ik merk gewoon dat ik wil opletten bij elke heuvel die ik benader, elke keer weer mijn Binoculars erbij pakken om eventuele riflemen te spotten, nadenken over mijn tactieken, en ze vervolgens uitvoeren. Ik durf zelfs enigszins te vertrouwen op mn manschappen, ze zijn niet onfeilbaar, maar ook zeker niet nutteloos, tot zover een fijne balans. Ik heb wel wat graphical glitches gezien, maar waren niet storend..
Deze game is totaal niet voor iemand die even snel een missie wil aanpakken, dit vraagt om geduld, precisie, en de acceptatie van rotte eieren wanneer je de dingen verkeerd plant of uitvoert. Eveneens vind ik het mooi dat je, na doodgaan, weer kunt beginnen bij een marker, en dat et gevecht waar je net dood ging, bijna altijd net iets anders uitpakt, of gigantisch, het dwingt je om waakzaam te blijven. Ben je echter iemand die zijn vaardigheden in games verkrijgt door voorspelbare situaties, tja, :).. dan is dit inderdaad niet voor jou.
Ik kijk dan ook uit naar de beruchte hardcore modus :).. Lijkt me giga cool.. Het is geen perfect spel, geen enkel spel is dat in mijn ogen, maar het biedt mij een vorm van vermaak wat ik in elk geval erg goed kan waarderen. (Arma 2 had bij mij rotte input lag waar ik mij maar niet overheen kon zetten).
  • Freak187
Freak187
geen
Ik zal dan ook maar even mijn mening delen.
Mijn eerste indrukken (heb het spel gekocht voor Xbox 360 op de dag dat ie uitkwam) waren goed, maar dat werd steeds minder. Ik vond de AI van zowel je team als je tegenstanders ondermaats, te weinig missies met voertuigen (sowieso te weinig missies in het spel). Vergelijken met OF1 doe ik niet, want dan valt het sowieso tegen.
Ik heb het spel zonder volledig uit te spelen naast me gelegd, om het 2 weken geleden weer op te pakken. Door veel voorzichtiger en rustiger aan te spelen, gaat het een stuk beter en realistischer. Ook heb ik ontdekt dat als je je team bijvoorbeeld ordered om surpressive fire te geven, ze veel beter (en meer) schieten dan als je dat niet doet. Als je ze namelijk geen orders geeft, schieten ze wel op de vijand, maar niet genoeg (naar mijn mening).
Ik speel het spel nu wel met plezier, omdat ik een "realistische" shooter zoals deze gewoon veel interessanter vind dan iets als COD. Dat ik daarom nog steeds met gemengde gevoelens speel komt omdat ik nog steeds denk dat het spel veel vetter had kunnen zijn dan dat het nu is. Vooral gezien de beloftes die ze deden voor de release van het spel.
Wel heb ik gisteren voor het eerst in hardcore mode gespeeld. Dat deed ik eerst niet omdat ik het kompas echt miste, maar deze mode is toch wel een stuk leuker om te spelen. Het is nu alleen een kwestie van nog beter vooruit kijken en dan maar op je Map kijken waar de vijanden precies zitten.
Ook heb ik die Skirmish uitbreiding gekocht. Ik weigerde in eerste instantie te betalen voor een uitbreiding van een toch al niet heel uitgebreid spel, maar ik had toch zin in meer Single missions. Twee van die missions zijn dus free roaming (bij dag en nacht)... Leuk hoor, maar je kan verder niks anders dan rijden of vliegen. Snel op uitgekeken dus.
Kia Niro-EV 2024
  • Player1S
  • Laatst online: 19:25
Player1S
Probably out in the dark
nou gisteren deze ook gekocht maar wat is het soms belachelijk moeilijk zeg :S
en waarom je maar 1x artie kunt aanroepen??? Willen ze de vijand nu verslaan of geld besparen??
  • Freak187
Freak187
geen
Ik heb de Overwatch DLC ook gekocht en ik moet zeggen, die extra missies (ook die van de Skirmish DLC) zijn wel vet. Alsnog vind ik 2 missies per DLC (die island tours niet meegerekend) te weinig, maar dat terzijde.
Ik vraag me iets af en ik hoop dat iemand van jullie me erbij kan helpen. Als er in de verte een voertuig van de tegenstander staat die op te blazen is met de rocket launcher, hoe kan ik dan 1 van mijn teammaten (die beschikt over een rocket launcher) orderen om dat dat te doen? Telkens als ik van hem vraag het voertuig te "engagen", gaat hij er vrolijk naartoe lopen. Dan roep ik hem maar weer snel terug, voordat ie aan gort geschoten wordt. Waarom pakt ie dan niet z'n rocket launcher? Als dit geen mogelijkheid is vind ik dat een serieus gebrekkig.
Kia Niro-EV 2024
  • Player1S
Player1S
Yay!! eindelijk voorbij missie 5 gekomen. *O*
ik verloor eerst telkens de piloten. Nu via de map de opdracht gegeven richting evac zone en een hold fire command. Toen ging het gelukkig wel goed.
Missie 6 ging nog even moeilijk toen de afleidingsmissie ging buggen (jeep bleef donuts maken op de map).
Missie 7 ging eigenlijk van een leien dakje! Lijkt erop dat ik het spel doorkrijg!!
  • Freak187
Freak187
geen
Gisteren voor het eerst online co-op gedaan met wat Engelse gasten. De eerste, tweede en derde Campaign missies gedaan. Vond het best vermakelijk. Zijn er hier eigenlijk nog mensen die het online spelen? Het is namelijk nog best lastig om een goed online potje te vinden. Mijn gamertag is "Ome Leon".
Kia Niro-EV 2024
  • WoRReLbier
En hup.. They pulled out the plug of OFP.. CM heeft het geld binnen, 2e patch ff gauw af geraffeld..
http://community.codemast...tches-additional-dlc.html
  • GekooktEi
WoRReLbier schreef op dinsdag 16 februari 2010 @ 21:38:
Ik ben serieus heel blij dat ik het spel al op Marktplaats heb gezet toen hij nog full-priced was. Ik heb er geen spijt van. Ik hoop toch dat ze de Operation Flashpoint-franchise nog een kans geven, het is zonde om dat zomaar weg te gooien. En anders moet er wel een ArmA 3 komen, dat is misschien nog beter, en dan zonder al die bugs :9
Inmiddels ook in het bezit van OF:DR, alleen heb ik nog wat moeite met het aimen, ik vind hem zo sloom reageren. meerdere mensen hier last van? Ik ben namelijk een echte CS speler.
[ Voor 11% gewijzigd door Verwijderd op 28-02-2010 13:39 ]
  • Tromp.et
  • Laatst online: 20:23
Vandaag voor 6,99 op steam. (Geld volgens mij nog het hele weekeind).
  • _Quinten_
Ik heb hem gekocht. Maar bevat deze Steam versie ook beide DLC (Skirmish en Overwatch)?
  • Tromp.et
Volgens mij niet, het staat er nergens bij. En als het wel was inbegrepen hadden ze het er vast luid en duidelijk bijverteld...
  • zezke
_Quinten_ schreef op vrijdag 05 maart 2010 @ 17:26:
Ik dacht dat deze DLC voor PC toch al gratis was?
  • _Quinten_
Bij Single Missions kan ik bovenaan Skirmish map pack en Overwatch map pack selecteren. De DLC is dus meegeleverd.
  • haarbal
  • Laatst online: 18:49
dit weekend 7 euro op steam
Mechwarrior Online: Flapdrol
  • Perzikvrucht
  • Laatst online: 13:42
Heb hem ook gekocht. Wat kan er nou misgaan voor 7 euro :).
Zal hem straks even online proberen.
  • AntraXxX
  • Laatst online: 18:52
Vrij weinig.
Op de vele bugs/glitches etc na nog steeds een goede game!
Poor man wanna be rich, rich man wanna be king And a king ain't satisfied till he rules everything.
  • Tromp.et
_Quinten_ schreef op zaterdag 06 maart 2010 @ 17:52:
Nice! Heb hem dus ook maar aangeschaft. 8)
  • Lithiumion
  • Laatst online: 20-11 10:47
Hmm ik heb een probleem met het einde van missie 5, ik heb het hele dorp uitgemoord waarbij 1 pilot is omgekomen maar die andere wilt maar niet van z'n plek afkomen. Ook al ren ik zelf met m'n hele squad naar de "Extraction Point"hij blijft maar midden in het dorp staan waardoor ik de missie niet kan uitspelen. Weet iemand wat ik nog moet doen dan?
Ik kan het laatste stukje niet overnieuw doen want ik heb een checkpoint gehad
  • Frank1973
Frank1973
XBL: Ghostleader1NL
Lithiumion schreef op woensdag 10 maart 2010 @ 21:10:
Zit niets op dan het weer opnieuw te proberen dat is 1 van de vette bugs.. Heb ik ook 2x gehad erg frustrerend als je op HC speelt.. :(
Voor de PC gamers: de game is nu in de actie bij Mediaoffer voor € 7,95.
  • Mystikal
  • Laatst online: 20-11 12:36
Mystikal
It never hurts to help!
Verwijderd schreef op vrijdag 29 oktober 2010 @ 16:07:
Je gaat dit spel toch aan niemand aan bevelen. Vol met bugs, geen support en waar al na een maand of 6 de stekker uitgetrokken is door de ontwikkelaars. Echt een schande!
Basement Bios ---- Exo-S
Nee, want ik heb de game zelf nog nooit gespeeld. :+
Ik zag alleen de prijs staan.
  • WoRReLbier
Mystikal schreef op vrijdag 29 oktober 2010 @ 16:13:
En de volgende editie van OFP hebben ze voor de launch al verkloot. Operation Flashpoint: Red River
  • Hillie
  • Laatst online: 18:13
Hillie
Poepen = ultieme ontspanning
Mijn excuses voor de enorme kick van dit, in vele ogen, matige spel. Ik speel het sinds kort, tot m'n plezier, maar ik heb een probleempje: Ik kan geen rocketlaunchers afschieten. Zowel de Javelin als de Queen Bee laten me mooi richten, maar afvuren gaat niet. Ik speel op een PS3, en ik heb geen idee wat er aan de hand zou kunnen zijn. Ik heb een tijdje gericht gezocht op het web, maar niks kunnen vinden.
Zie ik iets elementairs over het hoofd, of moet ik de schijf er maar uithalen en BFBC2 scoren om leuker te kunnen knallen? Dit spel spreekt me aan, maar een aantal missies is aanmerkelijk lastiger als je de raketjes niet kunt gebruiken. Alle tips zijn welkom! :)
Liefhebber van schieten en schijten. Ouwehoer en niet-evangelisch atheist.
Daniel36: Dat zeg ik(?) Nee, dat zeg ik niet, je hebt gelijk.
  • Hillie
Hillie
Niemand een tipje? :'(
  • WoRReLbier
Moet je dat ding niet op een voertuig laten locken? Geen idee want het is echt een hele poos geleden dat ik dit heb gespeeld..
Volgens mij zijn alle console servers ook leeg? Als ze Übderhaupt nog bestaan :P
Pagina: 1 2 3 4 Laatste
