De Devschuur Coffee Corner Overzicht Volgende deel Laatste deel
Pagina: 1 ... 127 ... 201 Laatste
  • 858.084 views
  • .oisyn
  • Laatst online: 15:04
.oisyn
Moderator Devschuur®
Demotivational Speaker
Mother.. shitter... son of ass!
Peter Gibbons: The thing is, Bob, it's not that I'm lazy, it's that I just don't care.
Bob Porter: Don't... don't care?
Peter Gibbons: It's a problem of motivation, all right? Now if I work my ass off and Initech ships a few extra units, I don't see another dime, so where's the motivation? And here's something else, Bob: I have eight different bosses right now.
Bob Slydell: I beg your pardon?
Peter Gibbons: Eight bosses.
Bob Slydell: Eight?
Peter Gibbons: Eight, Bob. So that means that when I make a mistake, I have eight different people coming by to tell me about it. That's my only real motivation is not to be hassled, that and the fear of losing my job. But you know, Bob, that will only make someone work just hard enough not to get fired.
[ Voor 73% gewijzigd door .oisyn op 15-04-2011 14:35 ]
  • Sebazzz
  • Laatst online: 14:16
Sebazzz
3dp
Sowieso, die Nederlandse functienamen... Dat is echt iets wat ze gewoon Engels hadden moeten laten. Degene die zelf in een Excel sheet formules gaat maken, die weet ook wel hoe hij iets in het Engels kan doen.
  • .oisyn
.oisyn
1>f:\xxxxxx\sdtreaverguicli.dll : warning C4945: 'Accessor' : cannot import symbol from 'f:\someotherdirectory\debug\sdtreaverguicli.dll': as 'ReaverGUI::Accessor' has already been imported from another assembly 'SDTReaverGUICLI'
1>        f:\xxxx\sdtreaverguicli.dll : see declaration of 'ReaverGUI::Accessor'
1>        first seen type is used; re-order imported assemblies to use the current type
1>        This diagnostic occurred while importing type 'ReaverGUI.Accessor' from assembly 'SDTReaverGUICLI, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null'.
Wat doe ik nu weer verkeerd. Ik heb gewoon twee projects in mijn solution, en de ene referencet de andere. Maar de DLL wordt wel gekopiëerd naar een andere dir (dus niet de standaard build dir), en nu lijkt hij ze te willen referencen van beide plekken 8)7
.edit: het probleem treedt op als je 3 projects hebt, A, B en C, waarbij A een dependency heeft op B en C, en B ook weer op C, en je copy local aan hebt staan. Op een of andere manier ontstaat er dan een link naar de target folder van C én de local folder van A waar C ook in staat door de copy local.
[ Voor 14% gewijzigd door .oisyn op 15-04-2011 15:02 ]
  • .oisyn
.oisyn
Afbeeldingslocatie: http://images1.memegenerator.net/ImageMacro/7263714/shitty-wpf-y-u-no-bind-to-property.jpg?imageSize=Medium&generatorName=Y-U-NO
  • CodeCaster
CodeCaster
Stop AI Slop
Ach, ruilen? Mijn Cluster Shared Volume staat in redirected access en is er met geen mogelijkheid uit te krijgen, omdat een backup halverwege werd afgebroken. :')
Maandag beginnen aan een nieuw project, eindelijk weer devven! *O*
[ Voor 17% gewijzigd door CodeCaster op 15-04-2011 16:25 ]
Waar is de brand, meester?
  • alienfruit
  • Laatst online: 06:27
alienfruit
the alien you never expected
Tjonguh, een of andere vaag render probleem in IE9 waarbij flash content uitgerekt wordt :|
Hmm, $.browser lijkt niet te werken in IE9. Vaag.
[ Voor 24% gewijzigd door alienfruit op 15-04-2011 17:04 ]
  • defcon84
  • Laatst online: 12-10 10:49
defcon84
Multipass?
  • Gamebuster
  • Laatst online: 08-10 21:18
alienfruit schreef op vrijdag 15 april 2011 @ 16:42:
Zijn de "width" en "height" attributes gelijk aan de daadwerkelijke grootte van het element?
JavaScript:
$("flashObject").attr({
  "width": "640",
  "height": "480"
Als je met CSS de hoogte/breedte gaat aanpassen zonder de width/height attributes te veranderen, krijg je bij sommige elementen/objecten dat het uitgerekt wordt. O.a. met Canvas lijkt dat altijd het geval te zijn. Met flash nooit getest.
[ Voor 7% gewijzigd door Gamebuster op 16-04-2011 01:17 ]
Let op: Mijn post bevat meningen, aannames of onwaarheden
  • R4gnax
  • Laatst online: 17-09 02:19
Gamebuster schreef op zaterdag 16 april 2011 @ 01:15:
Flash rekt standaard alles op. Je moet de scale mode expliciet op 'no scale' zetten in ActionScript code.
stage.scaleMode = StageScaleMode.NO_SCALE; als ik me goed herinner.
Iemand zou GoT's [mono] tag eens aan moeten passen om ook tenminste Courier New te gebruiken i.p.v. Courier. Het gebrek aan ClearType ondersteuning doet pijn aan de ogen.
  • Alex)
  • Laatst online: 18-09 21:34
R4gnax schreef op zaterdag 16 april 2011 @ 11:52:
Kan je ook zelf met Stylish, of met de custom CSS-feature uit de Karmastore:
Cascading Stylesheet:
.mono {
    font-family: consolas, courier new, courier, monospace !important;
We are shaping the future
  • Sebazzz
Sebazzz
3dp
Grappige class uit het .NET Framework: ExpandoObject.
C#:
    static void Main(string[] args)
        dynamic sampleObject = new ExpandoObject();
        // Create a new event and initialize it with null.
        sampleObject.sampleEvent = null;
        // Add an event handler.
        sampleObject.sampleEvent += new EventHandler(SampleHandler);
        // Raise an event for testing purposes.
        sampleObject.sampleEvent(sampleObject, new EventArgs());
        sampleObject.number = 10;
        sampleObject.Increment = (Action)(() => { sampleObject.number++; });
        // Before calling the Increment method.
        Console.WriteLine(sampleObject.number);
        sampleObject.Increment();
    // Event handler.
    static void SampleHandler(object sender, EventArgs e)
        Console.WriteLine("SampleHandler for {0} event", sender);
  • armageddon_2k1
  • Laatst online: 06-07 10:25
Iets wat PHP al jaren kan dus met stdClass ;)
/flauw
Engineering is like Tetris. Succes disappears and errors accumulate.
  • Gamebuster
Wat is MongoDB toch een prachtig iets voor snelle PHP projectjes :D
Script dat redirects van A naar B onthoud in een Mongo DB.
PHP:
$database = new Mongo();
$database = $database->selectDB("groepsreizen");
$user = $database->redirectedUsers->findOne(array(
    "ip" => $_SERVER["REMOTE_ADDR"]
if(!$user)
    $user = array(
$user["lastredirect"] = MONGONOW;
$database->redirectedUsers->save($user);
header("Location: ".@$_GET["to"]);
Script contact e-mail adres aanpast op website B wanneer de gebruiker vanaf website A afkomt via de redirect.
PHP:
if($user)
    list($_off, $lastRedirect) = sscanf((string)@$user["lastredirect"], "%f %d");
else
    $lastRedirect = 0;
if($lastRedirect < time() - AFFILIATE_LIFETIME)
    $email = "regular@email.address";
else
    $email = "affiliate@email.address";
Heb een samenwerking gesloten met een andere website, maar die hebben niet eens een dynamische website (> 100 HTML's met pagina's van nog voor het jaar 2000) en producten bestellen gaat door een e-mail te sturen. Als ze nu een e-mail sturen naar de affiliate e-mail adres weten we dat ze gekomen zijn via mijn website.
De pagina met het e-mail adres staat nu op mijn server op website A en is embedded via een iframe op website B. Heeft me wel wat denkwerk gekost om dit te bedenken gezien website B gewoon bestaat uit 100en HTML's die ik niet mocht aanpassen, behalve die contact.html dan.
Mooi/netjes is anders, maar het werkt :9
[ Voor 3% gewijzigd door Gamebuster op 17-04-2011 15:46 ]
  • .Gertjan.
  • Laatst online: 25-04 15:06
.Gertjan.
Owl!
Gisterenavond even een stukje code gemaakt waar ik wel trots op ben :P Ben nu een tijdje bezig in WPF iets leuks te maken en ben wat aan het spelen met binding en validatie.
Nu had ik binding met die INotifyPropertyChanged al goed aan de gang (hoewel het bagger is dat je zelf het PropertyChanged event moet triggeren met een string parameter :S, maar goed daar is wel een snippet voor te maken), maar zat validatie me een beetje dwars. Had de interface IDataErrorInfo al gevonden, maar daar krijg je de property naam als string mee en moest je op basis daarvan je validatie maar uitpluizen...
C#:
public string this[string columnName] {
    get {
        string res = null;
        if (columnName == "Name") {
            if (!ValidationHelper.ValidateMaxLength(Name, 255)) {
                res = ValidationHelper.PrepareMessage(ValidationHelper.ValidationMessageMaxLength, "Name", 255);
        } else if (columnName == "Role") {
            if (!ValidationHelper.ValidateMaxLength(Name, 100)) {
                res = ValidationHelper.PrepareMessage(ValidationHelper.ValidationMessageMaxLength, "Role", 100);
        return res;
Dat zat me toch niet helemaal lekker... Als je flinke classes hebt wordt een dergelijke functie vanzelf een drama.
Nu zag ik dat je DataAnnotations had in .NET, maar dat schijnt wel te werken bij MVC, maar WPF schijnt dat niet native te ondersteunen (tenminste dat was wat ik begreep en wat ik ondervonden had was dat het toepassen van die DataAnnotations binnen WPF niet automatisch iets opleverde). Het is natuurlijk mooier om je validatie op basis van attributen te doen (dus [Required()] of [StringLength(MaxLength)]) in plaats van alle validatie in een functie te kieperen. Je krijg dan namelijk een lading dubbele code (je moet voor iedere property die validatie starten).
Helaas schrijven veel tutorials het wel op de eerstgenoemde manier.
Uiteindelijk maar eens de mouwtjes opgestroopt en gekeken of ik via reflectie iets moois kon doen en na ongeveer een half uurtje knutselen is het me gelukt om een functie te bouwen waaraan de property naam wordt meegegeven (vanuit de public string this[string columnName]) en die vervolgens mbv reflection uitpluist welke validatie attributen er zijn en daar de validaties van uitvoert (waarbij de huidige DataAnnotation attributen uiteraard ook gebruikt worden, het wiel opnieuw uitvinden is niet echt handig). Dit alles zit nu in een base class waarvan mijn dataobjecten erven zodat ik in ieder geval voldoe aan DRY (Don't Repeat Yourself).
Het is vast geen revolutionair idee, maar was toch wel trots toen ik het voor elkaar had :) Dit scheelt me een ontzettende bak dubbele code en voorkomt dat ik perongeluk iets vergeet te bouwen in de validatie functie. Nu is het gewoon een kwestie van attributen toepassen en gaan met die banaan :) Daarnaast is het toch wel een kleine overwinning dat ik best makkelijk een functie met reflection heb opgezet :P
The #1 programmer excuse for legitimately slacking off: "My code's compiling"
Firesphere: Sommige mensen verdienen gewoon een High Five. In the Face. With a chair.
  • Hoogie2004
  • Laatst online: 08:14
Hoogie2004
Whohooooo
Wat is het rustig hier... Iedereen nog weekend?
Chad: Private Cycling Coach | Strava
  • defcon84
defcon84
Multipass?
Hoogie2004 schreef op maandag 18 april 2011 @ 10:09:
nog wakker aant worden :z
@defcon84 Idem hier, man wat is wakker worden toch een bitch :+ . En het wordt ook steeds erger wanneer je het weer buiten ziet :|
  • defcon84
defcon84
Multipass?
Verwijderd schreef op maandag 18 april 2011 @ 10:15:
hehe ja, maar ik zit lekker thuis atm :-)
seffes wss even naar buiten dus })
.Gertjan. schreef op maandag 18 april 2011 @ 07:59:
het gaat wel, maar je moet even zelf de provider registreren
bvb: dit werkt niet
C#:
[MetadataTypeAttribute(typeof(myClass.myClassMetadata))]
public partial class myClass
    public string Name { get; set; }
public partial class myClassMetadata
    [StringLength(3)]
    public string Name;
zo zou het wel moete werken:
C#:
        TypeDescriptor.AddProviderTransparent(new AssociatedMetadataTypeTypeDescriptionProvider(typeof(myClass), typeof(myClassMetadata)), typeof(myClass));
    [StringLength(3)]
    public string Name;
@defcon84: Nice, ik hoop dat er om 5 uur nog wat zon te pakken is :)
Documenteren is echt fijn! Ik heb het na twee uur werken alweer gehad...
  • Rutix
  • Laatst online: 21-04 11:06
Verwijderd schreef op maandag 18 april 2011 @ 10:25:
Wie niet :P. Ik vind documenteren ook niet echt fijn maar is vaak wel noodzakelijk en als het goed gebeurt dan voorkomt het gezeik later.
Ik moet nog echt wakker worden net 20 minuten zitten staren op een error dat gewoon een typfoutje bleek te zijn :(.
Nothing to see here!
  • PeterSelie
  • Laatst online: 25-09 00:09
Rutix schreef op maandag 18 april 2011 @ 10:57:
* PeterSelie stopt Rutix in de koffiehoek :*
  • defcon84
defcon84
Multipass?
haha ja idd, terrible work :)
ik ga even wat mix11 sessions kijken :)
nu deze: NuGet In Depth: Empowering Open Source on the .NET Platform
  • Caelorum
Kijk hier eens naar -> http://digitalmoto.net/bl...ypropertychanged-support/ :)
Maakt je leven iets makkelijker.
  • jip_86
  • Laatst online: 13:59
Het is weer maandag. Lang leve 'duidelijke' specs van importbestanden -O-
  • D-Raven
  • Laatst online: 16-10-2025
Ik denk ik download IE9 eens, aangezien automatische updates uitstaat op mn werk pc.
Via google kom ik hier uit.
Het koste me toch zeker 2 minuten voordat ik de download link gevonden had. Wat een stommiteit dat die link niet duidelijker in beeld word gebracht.
  • .Gertjan.
.Gertjan.
Owl!
Mmm, zoiets had ik ook al eens langs zien komen. Het eerste stukje heb ik zo al:
C#:
 public event PropertyChangedEventHandler PropertyChanged = delegate { };
  public void OnPropertyChanged(String propertyName)
    var handler = PropertyChanged;
    if ( handler != null )
      handler(this, new PropertyChangedEventArgs(propertyName));
Dat leek me sowieso al netter dan iedere keer in de set {} je check doen of de handler != null en het event triggeren. Maar op zich is dit wel een interessante, want zo weet je zeker dat je code typesafe is. Mocht je property dan van naam veranderen gaat in ieder geval de compiler klagen :)
Eens even doorlezen, zie in de code wel wat dingen die niet direct een belletje doen rinkelen.
C#:
public void OnPropertyChanged<TProperty>(Expression<Func<TProperty>> property)
    var lambda = (LambdaExpression)property;
    MemberExpression memberExpression;
    if ( lambda.Body is UnaryExpression )
      var unaryExpression = (UnaryExpression)lambda.Body;
      memberExpression = (MemberExpression)unaryExpression.Operand;
    else
      memberExpression = (MemberExpression)lambda.Body;
    OnPropertyChanged(memberExpression.Member.Name);
Ziet er sowieso we indrukwekkend uit :P
  • Sebazzz
Sebazzz
3dp
Microsoft zou echt eens moeten werken aan Mac of Linux support voor .NET. Ik weet dat Mono bestaat, maar dat is ook maar mehmeh als je met bijvoorbeeld WPF wilt werken. .NET zou een echte concurrent voor Java worden als ze hard aan cross-platform support zouden werken.
  • CoolGamer
  • Laatst online: 15-10 21:57
CoolGamer
What is it? Dragons?
Sebazzz schreef op maandag 18 april 2011 @ 11:23:
De vendor-lockin komt Microsoft iets te goed uit, dus ik zou er voorlopig niet op rekenen dat het zal gaan gebeuren.
¸.·´¯`·.¸.·´¯`·.¸><(((º>¸.·´¯`·.¸><(((º>¸.·´¯`·.¸.·´¯`·.¸.·´¯`·.¸<º)))><¸.·´¯`·.¸.·´¯`·.¸.·´¯`·.¸
  • Sebazzz
Sebazzz
3dp
TheCoolGamer schreef op maandag 18 april 2011 @ 11:24:
Ja en misschien dat ze ook meehelpen aan hun eigen graf als ze dat doen. Toch vind ik het jammer, want .NET zit imo geweldig in elkaar en het is een super platform om voor te programmeren.
[ Voor 0% gewijzigd door Sebazzz op 18-04-2011 11:30 . Reden: OMG, vindt -> vind ]
  • .Gertjan.
.Gertjan.
Owl!
Mmm, als ze willen dat Silverlight een beetje landt als web-standaard moeten ze er echt wel in gaan investeren. Qua desktop applicaties kun je inderdaad je vendor-lockin benutten, maar op het web gaat dat niet echt lekker werken.
  • Rutix
SoaDmaggot schreef op maandag 18 april 2011 @ 11:07:
* Rutix stopt Rutix in de koffiehoek :*
Ja net even een paar bakkies naar binnen gewerkt ;). En nu bijna lunch tijd :D dus gaat wel wat beter nu ;)
  • Caelorum
.Gertjan. schreef op maandag 18 april 2011 @ 11:26:
Daarom ook dat ze 'een beetje' meehelpen aan moonlight. In principe hoeft namelijk alleen de silverlight runtime te werken zodat gebruikers je applicaties kunnen gebruiken. Voor devven koop je dan maar een windows licentie :P
  • .Gertjan.
.Gertjan.
Owl!
Caelorum schreef op maandag 18 april 2011 @ 11:54:
Och die Windows licentie krijg je over het algemeen toch bij je hardware. Het is lastiger om hardware te vinden zonder Windows dan met (Of je moet een mac hebben, maar laten we daar maar niet over beginnen :D). :)
En die paar tientjes voor een TOP operating system is toch een schijntje :P
* aait nog eens over zijn BizSpark MSDN accountje :P
  • Rutix
.Gertjan. schreef op maandag 18 april 2011 @ 11:58:
MSDN account FTW idd ;)
[ Voor 42% gewijzigd door Rutix op 18-04-2011 12:03 ]
  • Sebazzz
Sebazzz
3dp
Ik ga MSDNAA missen als ik klaar ben met mijn opleiding.
  • .Gertjan.
.Gertjan.
Owl!
Sebazzz schreef op maandag 18 april 2011 @ 12:18:
Als je (serieus) gaat freelancen kun je WebsiteSpark of BizSpark overwegen (3 jaar voor 300 dollar). Ook kun je Maps overwegen (300 euro per jaar). Technet was geloof ik ook wel te betalen.
  • Hoogie2004
Hoogie2004
Whohooooo
Ik mis het ook nog steeds, en ben toch al 2 jaar aan het werk
  • Rutix
Hoogie2004 schreef op maandag 18 april 2011 @ 13:14:
Je werk heeft geen MSDN ;(?
  • Hoogie2004
Hoogie2004
Whohooooo
Rutix schreef op maandag 18 april 2011 @ 14:25:
Niet voor elke developer naar het schijnt, in ieder geval nog steeds geen eigen account voor iedereen...
  • .Gertjan.
.Gertjan.
Owl!
Hoogie2004 schreef op maandag 18 april 2011 @ 14:48:
Gewoon de dames en heren met een MSDN account ieder keer lastig vallen, heb je zo een eigen inlog :)
Maar bij grotere bedrijven is het gebruikelijk dat niet iedereen op MSDN kan. Bij mijn baas is het de bedoeling dat het ook via bepaalde mensen loopt, dus als ik op de laptop van mijn baas iets wil hebben moet ik dat aanvragen.
Bij grote bedrijven als Cap heeft ook niet iedere developer toegang tot MSDN (tenminste ik had het niet :(). Gelukkig had ik mijn "mannetjes" bij de klant als ik iets moest hebben, die hadden MSDN en Technet. Sowieso wordt het dan vaag, als je ingehuurd bent bij een klant en je moet ergens software voor hebben, waar haal je het dan. De laptop die ik gebruikte om te ontwikkelen was van de klant dus die zette de software erop, maar als ik op de laptop van mijn baas had gewerkt was het misschien lastiger.
Als ik thuis iets wil testen/gebruiken voor mijn freelance klusjes log ik gewoon zelf in op mijn MSDN :)
Overigens ken ik ook bedrijven waar men onder MSDN usenet verstaat :+ Tonnen binnenslepen aan projecten en te beroerd om legale software te kopen... Mja die lopen vanzelf wel tegen de lamp.
  • BM
  • Laatst online: 15:22
BM
Admin Softe Goederen
Vorige week 3 dagen bezig geweest om alle code te voorzien van commentaar boven de functies. Wat een enorm k*t werk is dat.
Jaja, ik had dat gelijk moeten doen bij het ontwikkelen, maar goed, code tikken is leuker dan commentaar schrijven, dus schiet het er wel 'eens' ( O-) ) bij in, en tja... dan moet het op het eind nog gebeuren.
Had vanmorgen ook zo'n momentje... half uur aan het debuggen geweest, voor iets wat uiteindelijk een missende '!' voor een expressie bleek te zijn :(
Xbox
  • PeterSelie
BM schreef op maandag 18 april 2011 @ 15:00:
Ik was vanochtend bezig met
JavaScript:
if (typeof typeof var == 'undefined')
Dat gaat ook altijd false opleveren.. :O
  • .oisyn
.oisyn
Ik ben sowieso wel fan van achteraf commentaar toevoegen. Dingen willen door implementatiedetails nog weleens wijzigen terwijl ik aan het tikken ben. Anders ben je de hele tijd bezig die dingen te updaten :)
  • Rutix
.oisyn schreef op maandag 18 april 2011 @ 15:10:
Ja dat is wel zo maar dan moet het wel gebeuren voordat er gecommit word naar versioning ;). Als ik ergens een hekel aan heb is dat een niet gedocumenteerde code op de versioning (Experimental/Prototype branch uitgezonderd)\
Edit: nog 15 minuten te gaan :D
[ Voor 3% gewijzigd door Rutix op 18-04-2011 15:52 ]
  • .oisyn
.oisyn
WTF, waarom mag je in C++/CLI geen delegate definieren op een abstract sealed class? 't Is toch geen instance member :? 8)7
.edit: oh, lol
https://connect.microsoft...rs-when-adding-a-delegate
Je kunt de error zelfs gewoon uitzetten :D
C++:
public ref class Foo abstract sealed
public:
#pragma warning(disable: 4693)
    delegate void Bar();
(ja, het is echt een error, geen warning)
[ Voor 62% gewijzigd door .oisyn op 18-04-2011 16:54 ]
  • defcon84
defcon84
Multipass?
.oisyn schreef op maandag 18 april 2011 @ 16:50:
.edit: oh, lol
C++:
public:
ja, maar ben je dan wel goed bezig? als je gewoon errors gaat afzetten? O-)
  • .oisyn
.oisyn
Als de error gewoon een bekende compiler bug is? Ja.
  • defcon84
defcon84
Multipass?
.oisyn schreef op maandag 18 april 2011 @ 17:12:
_O- dan mag het idd wel ja 8)
  • PrisonerOfPain
  • Laatst online: 07-04 13:41
Probeer jij nu iedere keer zwaar exotische dingen voor elkaar te krijgen of is C++/CLI een bagger product?
  • .oisyn
.oisyn
Er zitten wat eigenaardigheden in, maar een baggerproduct... nee. Bedenk dat veel van de issues waar ik hier op GoT over zat te zeuren uiteindelijk mijn fout bleken, he :). De enige echte bugs die ik tegenkwam was dus dit en die identifier in multiple assemblies bug. Die laatste krijg ik niet eens als ik met incredibuild bouw.
[ Voor 10% gewijzigd door .oisyn op 18-04-2011 17:33 ]
  • Gamebuster
SoaDmaggot schreef op maandag 18 april 2011 @ 15:05:
JavaScript:
Wat probeer je hier te doen Afbeeldingslocatie: http://forum.onzin.com/img/em/hmm.gif
  • Alex)
Yo dawg, I heard you liked types...
  • farlane
  • Laatst online: 00:16
Lol, treat errors as warnings. Is een veelgevraagde optie heb ik gehoord :P
Somniferous whisperings of scarlet fields. Sleep calling me and in my dreams i wander. My reality is abandoned (I traverse afar). Not a care if I never everwake.
Doet me denken aan een 'trucje' wat een paar klasgenoten van me uit het eerste jaar hadden bedacht!
Ja, als je twee keer op build drukt, zijn alle warnings weg, kijk maar!
:F
  • CoolGamer
CoolGamer
Verwijderd schreef op maandag 18 april 2011 @ 20:24:
:F
Inderdaad jammer dat er compilers zijn die warnings "vergeten" zodra er incrementeel gebuild wordt. Gelukkig heb ik daar geen last van in Java, maar die keren dat ik programmeer in C++ is het wel irritant. Die warnings zijn er natuurlijk niet voor niets gewoonlijk.
  • RomeoJ
RomeoJ
Matched: (.*)
Vandaag toch voortgang geboekt bij het uitpluizen van een wazige exception bij het builden van een domain.
Ben er namelijk achter gekomen dat een externe webservice host zijn resources gegenereerd heeft met Metro, nu blijkt dat Metro niet helemaal goed werkt met de WebLogic applicatieserver die wij voor ons domain gebruiken en dat die exceptions ook daaruit voortkomen, verder heeft mijn speurtocht ook geen oplossing opgeleverd, alleen de tip dat je de eigen WebLogic webservice framework moet gebruiken voor de webservices, dus gaan we daar komende week weer lekker mee verder prullen. :/
You only need two tools in life: WD-40 and Duct-Tape, if it doesn't move and it should, use the WD-40. If it does move and it shouldn't, use the Tape.
  • PeterSelie
Controleren of een variabele gedefinieerd is of niet? De variabelenaam var is in dit voorbeeld uiteraard fictief en misschien wat ongelukkig gekozen. Voor de duidelijkheid: dankzij de tussenkomst van een collega tweemaal typeof neergeplempt.
  • Gamebuster
SoaDmaggot schreef op maandag 18 april 2011 @ 21:41:
Ik gebruik:
JavaScript:
if(variable === undefined)
  • Makkelijk
  • Laatst online: 13-10 07:38
Gamebuster schreef op maandag 18 april 2011 @ 22:04:
Ik gebruik:
JavaScript:
JavaScript:
if (_.isUndefined(variable))
underline.js _/-\o_ _/-\o_
Dan ben je in elk geval zeker van je zaak..
[ Voor 9% gewijzigd door Makkelijk op 18-04-2011 22:08 ]
  • Gamebuster
Makkelijk schreef op maandag 18 april 2011 @ 22:07:
JavaScript:
Ik vind dat maar lelijk.
Waarom dan niet meteen:
JavaScript:
if(_.equalsTrue(_.isUndefined(variable)))
[ Voor 3% gewijzigd door Gamebuster op 18-04-2011 22:10 ]
  • PeterSelie
JavaScript:
if(!(_.equalsTrue(_.isUndefined(variable))) === false)
  • Voutloos
En nu nog false vervangen door een complex lijkende expressie welke altijd false oplevert.
[/obfuscation]
{signature}
  • Sebazzz
Sebazzz
3dp
:F
In C# zet ik daarom de buildopties zo strict mogelijk. Zo veel mogelijk warnings, en warnings als fout beschouwen.
Zou wel prettig zijn overigens als bepaalde dingen van ReSharper als compile error zouden opduiken. Dan heb je eigenlijk een soort bug-preventing system in je compiler zitten.
  • alienfruit
alienfruit
Aah, nieuwe aanpassing in de overtijd regeling op het werk. Nu krijg je alleen nog compensatie (=tijd) wanneer je meer dan de wettelijke 60 uur overtijd hebt gewerkt. Serieus, ik begin dit toch wel te zien als een indirecte loonsverlaging :+ Hoe zit dat in Nederland? Nooit gewerkt voor een baas in Nederland.
  • Voutloos
Op dagen dat het wel kan een beetje in je voordeel afronden? Je baas vertellen dat je een zelfde baan zonder overwerkgezeik kan vinden? Etc. etc.
{signature}
  • Rutix
Sebazzz schreef op maandag 18 april 2011 @ 22:39:
Bedoel je style fouten of echte programmeer fouten? Die programmeer fouten haal je namelijk als goed is eruit met unittesting (wat je tegelijk doet met building als het goed is :P)
  • D-Raven
:( zit al vanaf 8 uur te klooien met een vage shit in IE9. Ik ging er eigenlijk als vanzelf vanuit dat ik ergens een CSS / XHTML fout had gemaakt waardoor het niet werkte.
Ik kreeg namelijk vaag gedrag bij :hover effects, dingen zoals je hovert boven een link, en het effect wordt toegepast op de link daarboven (in een ul/li structuur).
He-le-maal gek werd ik ervan.
Collega: Hmmm bij mij werkt het prima... :+
Is mijn IE installatie gewoon fucked up :? 8)7 ;(
*roar*
  • .oisyn
.oisyn
Aight, wat zie ik vandaag in mijn Steam account? Een verse kopie van Portal 2. Thanks, Valve :7
  • Creepy
  • Laatst online: 13:11
Creepy
Tactical Espionage Splatterer
Tss, teveel games de laatste tijd, en ik heb al geen tijd om ze uit te spelen :/ :+
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
  • Hydra
  • Laatst online: 26-04 10:16
.oisyn schreef op dinsdag 19 april 2011 @ 10:41:
Oeh! Bedankt voor de heads-up! Heb ik dit weekend weer wat te doen :P
https://niels.nu
  • defcon84
defcon84
Multipass?
grr... ik heb mijn kopie van gamersland nog niet binnen gekregen :'(
zal nog wel een paar dagjes duren lijkt me..
  • TJHeuvel
Ik zit eigenlijk nog te twijfelen voor welk platform ik hem zou halen, Xbox of PC. PC is toch wel leuker, maar xbox net wat beter voor m'n RSI :(
Freelance Unity3D developer
  • PeterSelie
RSI? Zó 2001 :*
  • Makkelijk
Ik heb net rounded corners gemaakt met absolute positioning en javascript om de hoogte en breedte van het element automatisch de content te laten matchen. Ik voel me schuldig ten opzichte van webdevelopment in het algemeen, het is zo'n waardeloze oplossing :D.
  • Gamebuster
Makkelijk schreef op dinsdag 19 april 2011 @ 12:51:
Wat zie je als je JS uitzet? :P
  • Makkelijk
Gamebuster schreef op dinsdag 19 april 2011 @ 12:52:
Dat wíl ik niet weten ;)
  • Creepy
Creepy
CyCloneNL schreef op dinsdag 19 april 2011 @ 10:52:
De PS3 versie natuurlijk, krijg je via Steam de PC versie er gratis bij :Y)
  • beany
  • Laatst online: 15-10 17:39
beany
Meeheheheheh
Creepy schreef op dinsdag 19 april 2011 @ 13:08:
Ik dacht dat Valve games sowieso 1x kopen = spelen op elk platform was?? Of is dat alleen met spellen op de Mac en PC ?
  • Creepy
Creepy
De PS3 versie krijgt Steam functionaliteit (of eigenlijk, steam draairt op de PS3 ;) ). En ze doen een voucher erbij zodat je de PC versie ook kan downloaden. Als je hetzelfde steam account gebruikt op je PS3 en PC dan kan je je PS3 save op de PC kan gebruiken en andersom. Ook kan je met de PS3 versie samenspelen met iemand op de PC. De 360 versie krijgt deze functionaliteit niet simpelweg omdat Microsoft geen externe zaken toestaat op hun xbox live netwerk.
[ Voor 7% gewijzigd door Creepy op 19-04-2011 13:38 ]
  • nerz101
  • Laatst online: 24-03 21:38
Helaas kreeg ik gezellig een bericht van de IBG dat ik mijn lesgeld in 1 keer moet afbetalen (mislukte afschrift)... Dus dat word nog even een maandje wachten op Portal 2 :( :'(
  • D-Raven
CSS3 border radius ftw!.. en dan schijt hebben aan oudere browsers natuurlijk :P
  • .oisyn
.oisyn
Lol @ "edgeless cubes" (spheres dus) in Portal 2 :D
Net even coop zitten spelen met een collega in de pauze :)
  • Makkelijk
D-Raven schreef op dinsdag 19 april 2011 @ 13:40:
Was ook mijn eerste idee, maar deze klant gebruikt IE6 en het moet er absoluut pixel perfect uit zien. Hij deed nogal moeilijk tegen onze designer :X
  • D-Raven
Makkelijk schreef op dinsdag 19 april 2011 @ 14:47:
IE6.. .. :S Kun je niet zoiets zeggen van, "oww dat kunnen we wel oplossen hoor", en dan vervolgens nieuwe browser versie installeren :P. Probleem opgelost, en istie gelijk weer bij.
  • Hydra
GodverdeteringKUTzooi.
Zou fijn zijn als ons eigen bedrijf onze eigen tools eens fatsoenlijk zou testen. Ik heb voor een projectje een aantal tools nodig, 2 daarvan zijn externe open source tools, 2 daarvan zijn intern. Het externe OS spul werkt helemaal prima, alleen beide interne tools werken gewoon NIET naar behoren omdat ze nooit fatsoenlijk getest zijn.
Ik wil naar huihuihuis :'(
https://niels.nu
  • PrisonerOfPain
Hydra schreef op dinsdag 19 april 2011 @ 15:09:
Ik weet niet wat de complexiteit is van jullie interne tools maar meestal als ze eenvoudig genoeg zijn (lees: geen onderdeed van onze pipeline + editor) dan ben ik geneigt ze zelf te patchen. Zeker als het me zó dwars zit.
  • Hydra
PrisonerOfPain schreef op dinsdag 19 april 2011 @ 15:16:
Het probleem is vooral dat het gewoon ZO veel extra tijd kost, en ik zit gewoon met een project waarvan je een klant meldt dat het X tijd kost. Gelukkig heb ik wat slack ingebouwd voor dit soort problemen maar ik erger me er kapot aan dat onze eigen zooi zo vaak niet goed werkt. Suf genoeg kost een stuk open source software gebruiken waar ik nog geen ervaring mee heb me vaak minder tijd dan ik verwacht had en spullen die wij intern maken me vaak meer tijd.
https://niels.nu
  • Woy
Woy
Kewl, meteen even besteld voor PS3
“Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life.”
  • PrisonerOfPain
Kwam er net achter dat 'ie in de company store hier voor ongeveer 15E te verkrijgen is, daar gaat mijn passweekend :o
  • Jan_V
  • Laatst online: 14:02
nerz101 schreef op dinsdag 19 april 2011 @ 13:38:
Dat zou betekenen dat je eerder al een keer geld hebt 'over' gehouden...
Battle.net - Jandev#2601 / XBOX: VriesDeJ
  • Hillie
  • Laatst online: 15-10 22:11
Hillie
Poepen = ultieme ontspanning
alienfruit schreef op dinsdag 19 april 2011 @ 08:58:
Zorgen dat je een leven krijgt naast het werk. :+ Is dat 60 uur per maand? Knaken voor overwerk is leuk, maar op een gegeven moment creeer je ook verwachtingen. Ik zit nu in een project waar ik een beetje voor aan het plannen ben (en daarna gaan kloppen), maar ik richt altijd op 40 uur per week. Tuurlijk loopt het weleens uit en moet er altijd wel een keertje extra tijd in, maar ik probeer dat zoveel mogelijk te beperken. Overigens werk ik ook niet in Nederland, maar in Californie. Project nu is 3 man technisch uitvoerend, en we zitten alle 3 ongeveer 8 uur van elkaar vandaan (UK, Shanghai, Californie). Erg handig allemaal, maar goed, dat scheelt een hoop storingen gedurende de bulk van de dag. :)
Liefhebber van schieten en schijten. Ouwehoer en niet-evangelisch atheist.
Daniel36: Dat zeg ik(?) Nee, dat zeg ik niet, je hebt gelijk.
  • roy-t
  • Laatst online: 23-05 08:49
Paar maand werk je (fulltime) ongeveer 180 uur (40*4.5). Als je baas zou willen dat je pas na 60 uur (een derde meer) pas compensatie krijgt voor je overwerk zou ik er serieus aan denken om ergens anders te gaan werken (of nooit over te werken, dat is immers niet verplicht).
Allemaal leuk aan aardig dit soort regels, en hoe het wettelijk zit weet ik niet meer, gratis 1/3 meer werken in een maand is (zelfs incidenteel) wel heel erg overdreven. Een paar uurtjes extra prima, doen we niet moeilijk over, maar 60!!
~ Mijn prog blog!
  • Avalaxy
  • Laatst online: 12-03 15:40
Wtf, gozer uit m'n klas (prima programmeur, zowel Java als C#, net als ik tweedejaarsstudent informatica) is geweigerd voor een stage omdat hij niet genoeg Java-kennis zou hebben :') Sommige mensen snappen volgens mij het punt van een stage niet helemaal...
Overigens heb ik zelf een keer een aanbod gehad voor een 'stage' als PHP-klopper waar ik vanuit huis mocht werken :z Leer je ook zo lekker veel van...
  • alienfruit
alienfruit
Nee joh, 60uur paar jaar dacht ik. Maar ik moet deze check in het werktijdenregistratiesysteem implementeren dus zal morgen het ticket er nog eens op nalezen :|
  • Caelorum
Avalaxy schreef op woensdag 20 april 2011 @ 00:12:
Per toeval heb ik tijdens mijn stage ook 4 van de 5 dagen thuis gewerkt. (6uur kantoortijd) Kan je zeggen dat je enorm goed leert zelfstandig te werken en het maximale te halen uit die paar uur die er zijn voor het vergaren van informatie zoals requirements, designs e.d.
  • Avalaxy
Caelorum schreef op woensdag 20 april 2011 @ 00:29:
Mja, thuiswerken doe ik al als zelfstandig ondernemer. In een stage zoek ik juist het samen leren werken in een team, waar in mijn ogen ook dingen als Scrum bij komen kijken wat juist erg gefocust is op face-to-face contact. Maar ik kan me inderdaad voorstellen dat iedereen iets anders zoekt in een stage en dat zelfstandig werken ook een doel kan zijn. Het lijkt mij dan alleen dat er weinig (of minder) controle is op je werkstijl?
  • FragFrog
  • Laatst online: 10:07
Mwoach, toen ik een jaar fulltime ging coden heb ik in de eerste vier weken op kantoor volgens mij meer geleerd dan de ~ vier jaar als hobbyist aanprutsen daarvoor bij elkaar. Begrijpen hoe code werkt is één ding, begrijpen waarom iemand het op die manier implementeert een tweede. In mijn ervaring doe je dat het beste door domweg over iemands schouder te hangen als hij uitlegt hoe en waarom een specifiek stukje code in elkaar zit.
Daarnaast de mogelijkheid hebben om af en toe een probleem eens aan een ander voor te leggen kan ook erg nuttig zijn; wellicht denkt een collega net even anders waardoor je weer nieuwe manieren leert om problemen op te lossen :)
Overigens werk ik voor m'n programmeer(bij)baan nu weer vooral thuis, maar dat is meer omdat kantoor bijna een uur reizen is en ik momenteel de enige developer ben :+
[ Site ] [ twitch ] [ jijbuis ]
  • Caelorum
Minder controle klopt, maar ook dat helpt bij het leren geheel zelfstandig te kunnen werken. Ik heb overigens express gezocht naar een bedrijf waar ik wel elke dag aanwezig 'moet' zijn en met behoorlijk wat vakkennis voor mijn afstuderen.voornamelijk om de reden die Fragfrog hierboven aanhaalt.
Ik wilde alleen maar duidelijk maken dat een stage waarbij je thuis werkt ook iets positiefs kan zijn.
  • Jan_V
Pff, het uitzoeken van een nieuw toetsenbord en muis is nog niet zo eenvoudig. Moet de spullen namelijk iedere dag meenemen in m'n laptop tas, dus zo'n mooie MS Ergo 4000 is geen optie. Zo'n plat en klein toetsenbord is wel handig, maar heeft vaak een onhandige indeling (insert, delete, etc.). Muizen net zo, ik vond de MS Laser 6000 een super muis, maar die is niet meer te krijgen. De Bluetrack 4500 leek een waardige vervanging, maar die is net iets te klein.
Bestaat er een computerwinkel waar ze veel toetsenborden en muizen op voorraad hebben, zodat je ze ook kunt voelen? Mediamarkt heeft vaak wel een paar op voorraad, maar zijn vaak maar enkele van de MS en Logitech series.
  • Hydra
Voor veel bedrijven is een stagair gewoon een erg goedkope programmeur. Ze snappen dan niet (nouja snappen, ze zijn gewoon laks) dat je als stagebedrijf dan wel een bepaalde verantwoordelijkheid hebt en een stagair moet begeleiden. Tijdens m'n eerste stage ging dat goed maar in m'n 2e stage (afstudeerstage) werd ik ook redelijk aan m'n lot overgelaten.
https://niels.nu
Dit topic is niet de plaats om te lopen helpdesken. De Coffee Corner is primair bedoeld als uitlaatklep, niet als vraagbaak
