• Passievrucht
  • Laatst online: 15:14
Aangezien er in het discussie topic continue vragen, opmerkingen, etc over de perfomance geplaatst wordt, is het maar tijd voor een algemeen topic. Dus alle perfomance gerelateerde vragen over GTA4 hier plaatsen.
Ik zal ook proberen alle tips bij te werken die in dit topic gepost wordt.
1. Disable Video Recording
- Start the game and goto Options > Game > Video Recording and set it too off. This will stop the hitching and provide a good boost to your frame rate.
2. Disable Superfetching in Vista
- Run services.msc > Superfetch > Properties > Startup Type: Disable > Restart your computer.
3. Disable all unneeded services / start up programs
- Start > msconfig > Check Hide all Microsoft Services > Uncheck everything. Goto Startup and disable everything (you do not have to disable Rockstar Games Social Club).
4. Full Screen Blur
- While ingame press "P" (confirmed to work for some people)
5. Higher FSB (ADVANCED USERS ONLY)
- Lower your multiplier in the BIOS and increase your FSB to achieve stock clock rates for your CPU. This does lead to increases in frame rate. Going from stock 266x9 to 400x6 gave me a 7fps increase. (GEVAARLIJK!!!!!!!!!!!!!)
6. Install Microsoft .NET Framework 3.5
- http://msdn.microsoft.com/en-us/netf.../aa569263.aspx
7. Ensure Video Memory is GREEN
- Even with autoconfig settings sometimes you will be yellow, lower your draw distance until you are green. This also prevents the video memory crash error from ever happening.
8. Move pagefile to another Hard Drive that GTA 4 is not on.
- If you only have one HD this does not apply. This also should not matter if you have 4GB or more of system memory.
9. Turn off Windows Search
- - Run services.msc > Windows Search > Properties > Startup Type: Disable > Restart your computer.
Other tips;
1. Uninstall Your current videocard drivers, then run "DriverCleaner". Goto nVidia or ATI's website and download the latest WHQL drivers and install them after a reboot.
2. Ensure you have your motherboards latest chipset drivers. Use CPU-Z to see what motherboard you have, then goto the manufactures website and look for the chipset drivers. You could also goto Intel or AMD's websites if you know your chipset models.
3. Defrag your harddrive
4. Window out of GTA IV, ALT+CTRL+DEL, right click GTA4.exe and set priority to High.
UNCONFIRMED AT THE MOMENT
1. AMD Processors must install AMD Fusion (Beta) for better perfomance.
[ Voor 78% gewijzigd door Passievrucht op 05-12-2008 11:39 ]
Steam id is passievrucht \\ Xbox Live GT: Meneer Passievrucht
  • ThinkPad
  • Laatst online: 16:20
Hier haal ik 15fps max, met illegale versie
P4 3Ghz, 2GB DDR2, 8600GT.
Oja alles op low, 800*600
[ Voor 19% gewijzigd door ThinkPad op 04-12-2008 16:55 ]
Misschien in de TS dadelijk wat configuraties vermelden waarmee het wel/niet goed loopt? Dingen als CPU/GPU/MEM/Res/OS in een mooi tabelletje zetten?
Ikzelf speel op een E8400 met een 8800GT 512MB, 4GB (3,2GB), XP SP3 op 1680*1050. En het speelt lekker vloeiend met een FPS schommelend rond de 25/30 (beetje afhankelijk van dag/nacht).
  • TheZeroorez
ThinkPadd schreef op donderdag 04 december 2008 @ 16:55:
Lekker boeiend, ver kom je toch niet :)
Een serieuze discussie over de performance kan trouwens best (in SGD, want een probleem is het niet), maar als het teveel een opsomming wordt gaat 't dicht.
[ Voor 23% gewijzigd door TheZeroorez op 04-12-2008 17:03 ]
  • Passievrucht
TheZeroorez schreef op donderdag 04 december 2008 @ 17:02:
Nou het wordt echt overspoeld in het topic daar. Vandaar dat ik even vlug dit topic heb geopend, want moet ik ook alle perfomance tips verzamelen en posten in de TS.
  • TheZeroorez
Passievrucht schreef op donderdag 04 december 2008 @ 17:05:
Ja ik begrijp dat het daar een rotzooitje werd, sterker nog, dat heb ik gezien :P
Wat ik enkel bedoel is dat het ook hier niet de bedoeling is om enkel uitdraaien van benchmarks te zien, wat meer informatie in iedereen z'n post mag ook wel :)
  • 3lmo
  • Laatst online: 14-11-2024
Hoe wijzig ik überhaupt mijn instellingen? Als ik in het options menu dingen verander, save, quit, en opnieuw opstart staan de instellingen weer op default. Zelfde als ik het ingame doe, en op alle mogelijke manieren. Moet ietsjes omlaag, GTA is wat te optimistisch. :P
  • Nyarlathotep
  • Laatst online: 14:50
Nyarlathotep
Crawling Chaos
Kan je niet een .ini file o.i.d. aanpassen?
Ik ga hem ook eerst maar eens "proberen". Ik moet zeggen dat 1920x1080, wat ik sinds kort kan draaien, nog prima draait met mijn 8800GTX. Behalve Crysis dan :P
Het spel is al voor 29 euro te krijgen, dus mocht hij goed draaien dan komt hij er zeker in.
Zijn er nog specifieke geforce drivers die ik moet gebruiken?
Mijn muziekcollectie op Discogs
3lmo schreef op donderdag 04 december 2008 @ 17:12:
Dit probleem heb ik ook. Wat je ook veranderd, het wordt altijd weer terug gezet naar de instellingen die GTA vindt dat het beste is. Het enige wat er wel vastgehouden wordt is de aspect ratio.
  • Julian
  • Laatst online: 24-11 18:52
Tis nogal processor-afhankelijk. Ik kan enorm varieren in de kwaliteits-instellingen, maar voor de framerate maakt dat weinig uit. Hoger dan een gemiddelde van 22 fps in het spel (30 in de benchmark met default settings) kom ik gewoon niet.
Ik heb een Opteron 170 @ 2700 Mhz (een dual core AMD met 2x 1MB cache), 2 GB werkgeheugen op 540 Mhz, en een 8800GT op 700/1900.
Phanteks Enthoo Evolv mATX Tempered Glass Grijs | Gigabyte B650M Aorus Elite AX | AMD 9800X3D | NZXT Kraken Z63 | 64GB DDR5 6000C28 | NVIDIA RTX 5090 FE | LG 83G4 4K 144Hz | Corsair RM1200e | Meta Quest 3
Hey is zeker niet te spelen met een Geforce Go 7300 met alles op laagst? :(
  • TheZeroorez
Verwijderd schreef op donderdag 04 december 2008 @ 18:29:
Heb je ook maar _iets_ in dit topic of over de minimum system specs gelezen? Kom op zeg, een beetje inzet is niet mis ;)
  • GENETX
  • Laatst online: 06:59
Statistics
Average FPS: 29.28
Duration: 37.47 sec
CPU Usage: 92%
System memory usage: 56%
Video memory usage: 75%
Graphics Settings
Video Mode: 1680 x 1050 (60 Hz)
Texture Quality: Medium
Render Quality: Low
View Distance: 1
Detail Distance: 1
Hardware
Microsoft® Windows Vista" Ultimate
Service Pack 1
Video Adapter: ATI Radeon HD 3870
Video Driver version: 7.14.10.618
Audio Adapter: Realtek Digital Output (Realtek High Definition Audio)
AMD Athlon(tm) 64 X2 Dual Core Processor 5600+
File ID: benchmark.cli
AMD Athlon X2 5600+ @ 2.8GHz (Stock)
4GB DDR2-800MHz (2x2GB)
GigaByte GA-MA-790X-DS4 (AM2+)
Club3D ATI Radeon HD3870 512MB (Stock)
Vista Ultimate x64 SP1
Driver versie van ATI kon nog wel eens v8.10 zijn. Verder heb ik wel alles uit, dus MSN uit, AV uit etc etc. Vista is licht getweaked (geen indexed search en superfetch). Draait als een zonnetje, ware het niet dat het de illegale versie is en ik dus bijna moet kotsen van het schommelende beeld. Maar dat zou voor de framerate niks uit mogen maken
  • aicaramba
  • Laatst online: 07-11 14:20
julianus schreef op donderdag 04 december 2008 @ 17:55:
Dus denk je dat de processor overklokken van 2,4 naar bv 3 ghz zou een goed merkbaar verschil kunnen leveren ingame?
CS:GO Stats | DotA 2 Stats | iRacing Profiel
volgens mij niet, wat ik gelezen heb, is dat het geheugen van de vidoekaart het meeste er toe doet
  • Soldaatje
Is het de moeite waard om het te proberen met een amd 64 3200 en geforce 6600gt?
  • Marzman
Marzman
They'll never get caught.
Net eens gekeken op canirunit.com en ik vraag me echt af of die recommended specs zo boeiend zijn:
Afbeeldingslocatie: http://www.schaap.tv-a.googlepages.com/gta4.PNG
Ok, een duurdere videokaart zal er vast veel beter uit zien. Maar het lijkt me heel sterk dat mijn processor en geheugen niet toereikend zijn.
  • 3lmo
Verwijderd schreef op donderdag 04 december 2008 @ 17:47:
Precies, het speelt nu niet zo prettig en ik vind het wel erg leuk. Dus een tijdelijke oplossing tot SLI wordt ondersteund zou heel fijn zijn. :*)
  • Passievrucht
Ik weet niet wat er precies heeft geholpen, dat prefect of de driver versie 8.12 (beta) maar ik kan nu fantsoenlijk gamen.
Zelfde specs als jou, maar alleen andere merk videokaart, moederbord en vermoedelijk geheugen en ik haal nu:
Statistics
Average FPS: 29.05
Duration: 37.14 sec
CPU Usage: 96%
System memory usage: 54%
Video memory usage: 56%
Graphics Settings
Video Mode: 1024 x 768 (60 Hz)
Render Quality: Low
View Distance: 15
Detail Distance: 15
Hardware
Service Pack 1
Video Driver version: 7.14.10.630
Audio Adapter: Speakers (High Definition Audio Device)
File ID: Benchmark.cli
  • martijnve
  • Laatst online: 22-11 18:06
Marzman schreef op donderdag 04 december 2008 @ 19:55:
Ik heb 4gb mem en een Q6600 en hij gebruikt 75% ram en 80% cpu.
En dat is niet eens met zon hele hoge framerate.
Dus duidelijk heel cpu en mem belastend.
Hierdoor ben ik ook maar genoodzaakt een phenom te kopen
Ik heb de game een stuk vloeiender gekregen door in de Nvidia pannel te kiezen voor maximum pre-rendered frames op 8 te zetten.
  • Julian
aicaramba schreef op donderdag 04 december 2008 @ 19:44:
Dat denk ik wel ja. Bij mij ging in de benchmark met de recomended setting de perfermance van 27 fps naar 31 fps, door de processor (en het geheugen en de FSB) een kleine 10% te verhogen (van FSB 250 naar 270). Een vergelijkbare stijging in de fps dus, als in de fsb =) Dus je weet wat je te doen staat ;+)
Hierbij voor de volledigheid nog even de resultaten van de laatste bench:
Average FPS: 30.91
Duration: 37.27 sec
CPU Usage: 91%
System memory usage: 83%
Video memory usage: 95%
Graphics Settings
Video Mode: 1280 x 1024 (75 Hz)
Render Quality: High
View Distance: 25
Detail Distance: 37
Hardware
Microsoft Windows XP Professional
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GT
Video Driver version: 180.43
Audio Adapter: Envy24 Family Audio (WDM)
Dual Core AMD Opteron(tm) Processor 170
  • Bagel
  • Laatst online: 16:10
Net mijn CPU wat meer overclocked, en ik merk het wel. Eerst lagde het wat met regen, nu al wat minder.
Eerder bekend als: BioHazard
  • SpX
  • Laatst online: 22-11 09:56
SpX
Damn. Wat heb ik me vergist in Rockstar -> GTA 4.. Ik heb `n jaar lang de console-versie van GTA 4 ontweken, om het om de PC te kunnen spelen met alle pracht en praal dat me werd voorgeschoteld, zowel op papier(lees previews) en de zogenoemde in-game trailers.
Vandaag GTA 4 bij de lokale Bartsmit gehaald, en direct geïnstalleerd. Het eerste wat me opviel waren de vereiste updates aan windows voordat ik überhaupt de social club snelkoppeling kreeg geopend zonder error .. :> Na `n half uur was me dit gelukt, en kon ik aan de slag.
De game werd automatisch ingesteld op:
1680x1050
textures : medium
Render quality : high
Dat was positief imo, omdat ik veel slechtere dingen had gelezen. Toen ik eindelijk aan het spelen was viel me op dat het alles behalve vloeiend verliep. De FPS zijn niet echt constant laag te noemen, maar ik heb het gevoel dat er zò veel memory van je GPU word gevraagd, zodat er haperingen onstaan bij het inrijden van elk nieuw deel van `t spel,(leakage?) dat het met de huidige driver niet echt aangenaam spelen is. Dit is overigens ook met lagere instellingen, net zoals de andere errors hieronder.
Helaas is dit niet het enige probleem. Ik heb namelijk vanaf 14.00 vanmiddag niet langer dan 5 minuten achter elkaar zonder spelen, errors,freezes of artifacts.. :'( Hier een opsomming van de errors:
(meest voorkomende) Knal geel beeld, dat niet verdwijnt, en alleen de HUD/Rader zichtbaar laat.
Fatal error resc10: schijnt met videogeheugen te maken hebben.
D3D800 error.
Beeld vol met artifacts
Als ze deze problemen met `n patch kunnen oplossen dan zou ik alsnog respect voor Rockstar kunnen terug krijgen, maar op dit moment is dit echt behoorlijk laag. Als het overigens na `n week zo blijft dan eis ik m`n geld terug, zoals dat bij steam ook schijnt te kunnen.
Echt triest dit :|
[ Voor 4% gewijzigd door SpX op 04-12-2008 21:44 ]
  • Julian
Wat voor specs heb je?
  • Phase
  • Laatst online: 30-04-2022
Phase
Supremely Insane
Ik moet zeggen, ik had echt mijn twijfels over het spel, zeker gezien mijn grafische kaart niet zo heel super is... Maar zoals mijn systeem nu draait, draait het spel gewoon goed :)
Statistics
Average FPS: 34.40
Duration: 37.35 sec
CPU Usage: 75%
System memory usage: 61%
Video memory usage: 92%
Graphics Settings
View Distance: 25
Detail Distance: 37
Hardware
Microsoft® Windows Vista" Business
Service Pack 1
Video Adapter: NVIDIA GeForce 9600 GT
Video Driver version: 178.13
Audio Adapter: Speakers (2- Aureon 7.1 Universe)
Intel(R) Core(TM)2 Duo CPU E8200 @ 3.20GHz
Verschil tussen deze gegevens en de benchmarkspecs zijn: cpu opgeklokt naar 3.2Ghz, en de grafische kaart opgeklokt met rivatuner...
Time is never wasted when you're wasted all the time.
  • Vinnie
Van naar wat heb je die 9600GT geclocked dan?
C:\>_
  • aicaramba
Ik ben in de andere topics verschillende posts tegen gekomen van mensen met ongeveer dezelfde specs als ik (E6600, 2gb ram, 8800gt) die het spel soepel op medium kunnen draaien. Ikzelf speel het spel met alles op low en de slides ongeveer rond de 1/4 - 1/3 en haal nog geen 30 fps gem. Ik gebruik een res. van 1024x768
Ik heb de video capture al uitgezet, zijn er nog meer tweaks die ik heb gemist?
[ Voor 4% gewijzigd door aicaramba op 04-12-2008 23:16 ]
  • Vin87
  • Laatst online: 16-11 20:07
aicaramba schreef op donderdag 04 december 2008 @ 23:10:
Ik heb zon beetje dezelfde setup als jij, alleen heb ik een 8800GTS (640MB). Overklokken van zowel je CPU als VGA maken een hoop goed. Hij draait bij mij goed op een mix van medium/high.
  • Shaidar
  • Laatst online: 02-04 15:01
Shaidar
Die benchmarks zeggen niet zo veel, de camera angles zijn daar slim gekozen zodat méér FPS krijgt dan dat je dezelfde scene "echt" zou spelen ...
Statistics
Average FPS: 38.35
Duration: 37.18 sec
CPU Usage: 91%
Graphics Settings
Video Mode: 1440 x 900 (60 Hz)
Texture Quality: High
Render Quality: Highest
View Distance: 19
Detail Distance: 100
Hardware
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GTX
Video Driver version: 180.48
Audio Adapter: SoundMAX HD Audio
Intel Pentium III Xeon processor
specs in sig
 iPhone 12 Pro 128GB  MacBook Pro (13-inch, 2020, i7, 16GB, 1TB)
  • prutser001
  • Laatst online: 11-11 12:58
prutser001
Vaak zit het tegen en soms zi
Wat een onzin, ik was aan het overwegen om GTA4 aan te schaffen dus was even forums aan het browsen en kwam al het een en ander over performance/login etc problemen tegen en ben wat verder gaan kijken.
In deze thread werdt www.canirunit.com gepost, wat zie ik : mijn systeem voldoet aan de 'minimum systeemeisen' , dit was wel heel grappig:
CPU
Recommended: Intel Core 2 Quad 2.4GHz, AMD Phenom X3 2.1GHz
You Have: 4 processors running - Intel(R) Xeon(R) CPU 5160 @ 3.00GHz FAIL: Sorry, your CPU does not meet this recommended requirement. If you really want to make this product fly, click the 'We Recommend' button to check out some great computers.
En verderop:
Video Card
Recommended: 512MB NVIDIA 8600+ / 512MB ATI 3870+
You Have: ATI Radeon HD 3800 Series (ATI Radeon Graphics Processor (0x9501)) FAIL: Sorry, your video card does not meet this recommended requirement. Upgrading to a more powerful video card will make all your applications look better. Click the 'We Recommend' button to see some great options.
Laat ik nou net een 3870 hebben.
Kortom, alle 'problemen' bijelkaar is het het wel waard?
Asus Z390 Maximus IX Hero, Intel 9900K, RTX3080, 64GB DDR4 3000, 2TB NVME, Samsung 850Evo 1TB, 4 x 14TB Toshiba, Be Quiet SB 801, Samsung 34"
  • Phase
Phase
Supremely Insane
Vinnie schreef op donderdag 04 december 2008 @ 23:03:
Naar dit:
Afbeeldingslocatie: http://www.freeimagehosting.net/uploads/th.a87bef84ac.jpg
Works like a charm :)
/edit: ik heb met opzet maar gewoon een screenshot geplaatst, want ik heb serieus geen idee hoe ik dat moet vertalen naar iets dat zinnig lijkt.
[ Voor 17% gewijzigd door Phase op 04-12-2008 23:29 ]
  • aicaramba
Vin87 schreef op donderdag 04 december 2008 @ 23:12:
Hoeveel ghz draait je cpu dan? Ik neem aan ook c2d..
  • 3lmo
Voor de mensen met SLI: bij mij leidde het inschakelen van 'single-gpu' in het Nvidia control panel tot ongeveer 10 meer FPS.
Performance van het spel is prima, wel ontzettend zaad dat ik mn resolutie niet hoger "mag" zetten, nou speel ik dus op een brakke resolutie. Maar goed, het draait prima, al mag je dat ook wel verwachten met een 3870x2 en een E8400 @ 3.92 ghz en 4gb ram. Hogere settings dan dit krijg ik het trouwens niet jammer genoeg, volgens mij nog genoeg speling over:
Statistics
Average FPS: 49.64
Duration: 37.15 sec
CPU Usage: 86%
System memory usage: 58%
Video memory usage: 79%
Graphics Settings
View Distance: 47
Hardware
Microsoft Windows XP Home Edition
Service Pack 3
Video Adapter: ATI Radeon HD 3870 X2
Video Driver version: 6.14.10.6879
Audio Adapter: Realtek HD Audio output
Intel Pentium III Xeon-processor
  • k1n9_n01z3
k1n9_n01z3
gewoon KNz dus
Statistics
Average FPS: 21.71
Duration: 37.21 sec
CPU Usage: 91%
System memory usage: 85%
Video memory usage: 99%
Graphics Settings
Render Quality: Medium
View Distance: 20
Detail Distance: 20
Hardware
Service Pack 3
Video Adapter: NVIDIA GeForce 8800 GTS 512
Audio Adapter: SB Audigy 2 ZS Audio [BC00]
AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
(cpu = 2.7 ghz, mem 2 gig pc3200)
Steam Inventaris
Big Pimpin' here @ G.o.T.
  • frankknopers
  • Laatst online: 14-10 11:04
frankknopers
Goud is geen geld
Intel Core 2 Duo E8500 @ 4,10 GHz
4GB DDR2-1066 CL5
Sapphire HD4870X2 2GB
Catalyst 8.11 drivers
Statistics
Average FPS: 46.38
Duration: 36.87 sec
CPU Usage: 92%
System memory usage: 60%
Video memory usage: 93%
Graphics Settings
Video Mode: 1920 x 1200 (60 Hz)
View Distance: 32
Hardware
Service Pack 1
Video Adapter: ATI Radeon HD 4870 X2
Video Driver version: 7.14.10.621
Audio Adapter: Speakers (Creative SB X-Fi)
Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
[ Voor 12% gewijzigd door frankknopers op 05-12-2008 10:12 ]
Goud is geen geld
  • Vin87
aicaramba schreef op donderdag 04 december 2008 @ 23:45:
De E6600 draait 3,1 Ghz, De 8800 GTS draait op 621/1350/999 (stock is dat volgens mij 500/1080/800). De benchmark geeft op 1400*1050 met textures medium, rendering op high en sliders op 1/3e zo'n 40 FPS.
  • NazGulPRB
  • Laatst online: 22-06-2024
Mijn benchmark gegevens: Cat 8.11
===Statistics===
Average FPS: 39.28
Duration: 37.91 sec
CPU Usage: 53%
System memory usage: 63%
===Graphics Settings===
View Distance: 25
Detail Distance: 37
===Hardware===
Microsoft® Windows Vista" Home Premium
Service Pack 1
Video Adapter: (2x) ATI Radeon HD 4850 Series
Audio Adapter: Supreme FX
Q6600 @ 3.40GHz
MB: Asus M2F
I.t.t. vele berichten oiver issues met Radeon geen enkel probleem (tot nu toe :*) )
  • Luqq
  • Laatst online: 23-11 21:46
Ik heb het spel gister gehaald, met de volgende specs:
e6600 @ 3.15 ghz
2gb ram
nvidia 8800gts 320mb
Het draait alleen wel soepel, alleen 't ziet er niet uit. Kan niet eens om 1680x1050 spelen. Zou ik veel prestatiewinst merken als ik er nu een e8400 oid inzet met een ati hd4870? Of kan ik beter wachten tot de nieuwe generaties. Het is wel.."speelbaar".
  • Sendar
  • Laatst online: 11:22
Luqq schreef op vrijdag 05 december 2008 @ 10:10:
e6600 @ 3.15 ghz
2gb ram
Heb het zelfde systeem, maar inderdaad valt mij erg tegen. Ik speel het op low.. zonde van zo'n spel. Ik hoop dat een patch nog het een en ander oplost, maar heb er een hard hoofd in.
Zonde.
http://www.flickr.com/photos/sendar/ - www.sanderhendriks.eu - www.twomendesign.nl
al iets bekend wanneer ze die eerste patch uitbrengen ? wordt ongeduldig :9
  • Maverick
  • Laatst online: 08:56
Wat ik begrepen heb van mensen die een gekraakte versie spelen krijgen ze na de kraak er een aantal (5-7)fps bij. Het lijkt er dus op dat de DRM een stuk performance wegneemt. Volgens mij is R* hier een beetje in doorgeslagen.
Heb zelf het spel overigens nog niet gespeeld. Als ik lees wat mensen hier voor prestaties halen met bepaalde specs ben ik bang dat het niet al te best gaat draaien :{
PSN: DutchTrickle PVoutput
  • H3llSiNG
  • Laatst online: 25-10 14:02
H3llSiNG
Meh.
Op het moment speel ik met een AMD X2 3800+, 2 gig RAM en een 8800GT 512mb op medium en high.
Zou ik met een betere processor en 4 gig ram het spel op high / high kunnen spelen? Of ligt dit puur aan het geheugen van je videokaart.
Systeem: Pentium II 350 MHZ @ 400MHZ, Nvidia Riva 128 LX, 128MB RAM, Windows ME Plus (32 Bit)
  • Passievrucht
Mensen met een AMD processor, wil iemand dit uitproberen:
http://www.amd.com/us/fusion/Pages/index.aspx
Het schijnt dat je hier ook een FPS boostje mee krijg. Iemand met een phenom kreeg 20 FPS erbij, maar het kan ook een gerucht zijn.
Heb net maar even een small upgrade gedaan naar een 8800GTS/512 alleen denk ik dat mijn CPU
toch wel een harde bottleneck is dit is de AMD-FX62 zou het veel uitmaken als ik een Phenom X4 9850 haal ?
  • KoffieNT
  • Laatst online: 19-11 14:23
KoffieNT
banaan
Zal even mijn specs posten, misschien dat iemand er wat aan heeft:
Q6600@3,2ghz
8800GT (600,1500,1800)
4x1GB@800mhz
2x320GB Barracudas@Raid0
XP64SP2
FPS: 24-50, overdag liggen de fps wat hoger dan snachts, drukte van auto's of mensen maakt bij mij totaal niet uit.
Wat ik wel erg storend vind is dat ik 'maar' op een res speel van 1280x1024, met details maar op medium, en dat ding daaronder (effe naam kwijt) op very high. Ik MAG details niet veranderen van medium naar high omdat volgens dat metertje onderin ik dan teveel van mn videokaartgeheugen zou gebruiken.
resultaat: karteltjes hier en daar, net niet scherp genoeg af en toe..
Ik vind dat ik met mijn (tegenwoordig redelijk gemiddelde) pc dit spel toch wel op Max moet kunnen spelen, iig op High.
+dat het installeren echt belachelijk was.
dvd 1 installeren
dvd 2 installeren
dvd 1 terug erin
c****
registreren op die community
registreren op live
spel opstarten
spelen
en op moment van saven moet je dan een key invullen...ik kan dus niet saven.
Maar ik kan in ieder geval wel lekker sandboxen :D:D :9~
Ga dit weekend ook nog even installeren op mn andere pc, die op een 42" plasma zit (die ik vandaag binnen krijg..hoop ik);
E8400@4,0ghz
4x1GB@1000mhz
2x500GB Barracudas@Raid0
XP64SP2
Zal de benchmarks van deze 2 pcs vanavond effe hierbij zetten.
[ Voor 14% gewijzigd door KoffieNT op 05-12-2008 13:52 ]
:D
  • Passievrucht
Verwijderd schreef op vrijdag 05 december 2008 @ 10:50:
Probeer eens AMD Fusion te installeren. Ben benieuwd of je met de dualcore ook een boost krijg.
4. Full Screen Blur
Other tips;
[ Voor 72% gewijzigd door Passievrucht op 05-12-2008 11:39 ]
  • H3llSiNG
H3llSiNG
Meh.
Ik heb dat fusion eens geinstalleerd. Zal zo eens kijken of het een verschil maakt. 20FPS zoals hier beweerd word geloof ik niet in. maar ieder fps extra is welkom.
Statistics
Average FPS: 39.80
Duration: 37.42 sec
CPU Usage: 76%
System memory usage: 78%
Video memory usage: 97%
Graphics Settings
Video Mode: 1400 x 1050 (60 Hz)
View Distance: 61
Hardware
Windows Windows Vista" Extreme Edition
Service Pack 1
Video Adapter: NVIDIA GeForce 9800 GX2
Video Driver version: 180.60
Audio Adapter: Digital Audio Interface (SB Audigy)
Intel(R) Xeon(R) CPU X3210 @ 3.13GHz
niet slecht, alleen krijg ik die no ristrictions niet an de gang
  • Deagle
AMD Fusion helpt bij mij niet bepaald veel gewoon ingame, benchmark nog niet getest. Nu ff met hoge fsb testen.
  • frankknopers
frankknopers
Goud is geen geld
Ik snap die klachten over de perfomance niet zo/ Ik heb het spel ook eens op mijn 2e game PC getest en daar loopt ie uitstekend op 1680x1050 met Medium. Ik zal zo even de benchmark van dat systeem posten..
Goud is geen geld
  • ravw
  • Laatst online: 16:05
ravw
Ik speel hier ok eigelijk zonder echt veel problemen ...
Statistics
Average FPS: 22.44
Duration: 37.13 sec
CPU Usage: 93%
System memory usage: 51%
Video memory usage: 100%
Graphics Settings
Texture Quality: Low
View Distance: 4
Detail Distance: 35
Hardware
Service Pack 3
Audio Adapter: SB Live! 24-bit
AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Afbeeldingslocatie: http://img.photobucket.com/albums/v652/ravw/GTA%204/GTAIV2008-12-0510-08-38-71.jpg
Afbeeldingslocatie: http://img.photobucket.com/albums/v652/ravw/GTA%204/GTAIV2008-12-0423-06-50-28.jpg
[ Voor 16% gewijzigd door ravw op 05-12-2008 13:28 ]
Systeem:AMD Ryzen 7 9800X3D ,RTX 5080 OC,FURY 64 GB DDR5-6000,ASUS TUF Gaming B850M-PLUS WIFI, SAMSUNG 990 EVO Plus 4 TB
  • roy-t
  • Laatst online: 16-11 13:27
Vreselijk dat een bedrijf als Rockstar dit promoot, "Uncheck everything" in msconfig startup staat anders ook lekker je virusscanner, ik zie al veel "net niet nerds" hun complete beveiliging uitzetten :(
Prefetching uitzetten lijkt me trouwens absoluut niets toevoegen aan de snelheid van GTA4, prefteching gebeurt uberhaupt niet tijdens het draaien van een zware applicatie, en prefteching zorgt er alleen maar voor dat GTA4 zelf sneller start, ook is het zo dat prefteching geen ram claimed, (het gebruikt het wel, maar geeft het meteen vrij wanneer nodig).
~ Mijn prog blog!
  • TheZeroorez
roy-t schreef op vrijdag 05 december 2008 @ 13:25:
Ze zeggen dat alles wat niet nodig is uit moet, en daar hebben ze gelijk in. Dingen als een indexing service of die laatste zoektool van MS die met windowsupdate door de strot geduwd is vreten vreselijk veel CPU, RAM en hardeschijfsnelheid. Laat GTA dat nu net ook graag hebben...
Ik zie ze liever dit promoten dan 'koop een nieuwe videokaart van 600 euro' oid. Dat er dan prutsers zijn die alles uitschakelen... Tja :P
  • frankknopers
frankknopers
Goud is geen geld
De benchmark op mijn 2e gamebak:
Intel E6600 @ 3,0 GHz
ASUS 975X mobo
Radeon HD2900XT 512MB
3 GB DDR2-800
Catalyst 8.11
Statistics
Average FPS: 27.09
Duration: 37.62 sec
CPU Usage: 91%
System memory usage: 81%
Graphics Settings
View Distance: 33
Hardware
Service Pack 1
Video Adapter: ATI Radeon HD 2900 XT
Audio Adapter: Speakers (Creative SB Audigy 2 ZS (WDM))
Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Taskmanager na het afsluiten:
Afbeeldingslocatie: http://www.knopers.net/webspace/tweakers/gta4-taskmanager.png
Goud is geen geld
  • Lampuhkap
  • Laatst online: 08:51
TheZeroorez schreef op vrijdag 05 december 2008 @ 13:38:
Voel ik me ff dom 8)7 Ik kom dus na jouw post er pas achter dan de Indexing Service nu dus onder Windows Search schuilgaat. En dat heb ik nu dus EINDELIJK een keer uit kunnen zetten als service _/-\o_
Dankje _/-\o_
Welke zoektool zie ik nog over t hoofd verder :S?
  • Passievrucht
Rockstar promoot dit niet volgens mij. Ik heb dit van het steam forum
  • Zerora
  • Laatst online: 18:12
Zerora
Ik Henk 'm!
Ik las ergens dat het ook kan helpen om als je als ATi gebruiker schaduwproblemen hebt om dan de 8.12 Beta drivers van ATI catalyst te installeren.
  • KoffieNT
KoffieNT
banaan
Speedlink schreef op vrijdag 05 december 2008 @ 13:53:
Dankje _/-\o_
Google maar eens op msconfig xp/vista en dat soort dingen, er is gruwelijk veel wat je uit kunt zetten. Mijn systeem draait (met antivirus en creativedrivers) met 24 processen..Ik zie bij andere mensen vaak 50+ processen voorbij komen en 114 icons in hun taakbalk.
Hey, waarom is mijn pc zo langzaam zeggen ze dan.. :z
:D
  • Lampuhkap
ja met MSconfig enzo weet ik een heeeeel eind te komen. Booten op 4 cores ipv op 1 enz. Kom daar een heel eind mee hoor, maar toch....
  • KoffieNT
KoffieNT
banaan
Speedlink schreef op vrijdag 05 december 2008 @ 14:08:
services.msc @ uitvoeren :), valt ook veel uit te zetten. Gewoon kijken wat er onnodig aan processen loopt.
Maar goed, back to GTA weer :D
:D
  • Bobmeister
  • Laatst online: 18:20
Al een oplossing voor de restricities qua grafisch aspect?
  • frankknopers
frankknopers
Goud is geen geld
Awsom schreef op vrijdag 05 december 2008 @ 14:29:
Deze toevoeging geven aan de shortcut van GTA IV:
-norestrictions
Functie: Do not limit graphics settings
Goud is geen geld
  • H3llSiNG
H3llSiNG
Meh.
H3llSiNG schreef op vrijdag 05 december 2008 @ 12:09:
Zoals gezegd heb ik het uitgeprobeerd. Ja ik vind het wel wat beter gaan, niet dat ik meer FPS heb maar ik heb het gevoel dat de performance wat minder inzakt.
frankknopers schreef op vrijdag 05 december 2008 @ 15:07:
-norestrictions
werkt bij mij niet , :/
  • Tuinstoel
  • Laatst online: 24-12-2025
Statistics
Average FPS: 35.63
Duration: 37.33 sec
CPU Usage: 87%
System memory usage: 77%
Video memory usage: 71%
Graphics Settings
View Distance: 25
Detail Distance: 37
Hardware
Service Pack 3
Video Adapter: ATI Radeon HD 3800 Series (3870)
Video Driver version: 6.14.10.6869
Audio Adapter: Sound Blaster X-Fi Xtreme Audio
Intel Pentium III Xeon-processor (C2D E8400)
Valt mee te leven, maar toch hapert hij soms nog :S.
  • KoffieNT
KoffieNT
banaan
Tuinstoel schreef op vrijdag 05 december 2008 @ 16:20:
:S
Een 3870 en nog dat je niet op high/very high kunt spelen, pff...
:D
ik word nu wel echt moe van de mem memrestrict al van alles bij mij .exe. gesodemieterd maar niks helpt, kun je dat niet instellen in een of ander hardware.xml ofzo?
  • frankknopers
frankknopers
Goud is geen geld
KoffieNT1.5 schreef op vrijdag 05 december 2008 @ 16:23:
:S
Onthoud wel dat GTA is ontworpen voor een console met een afgeleide van de ATI X1900 serie en een snelle triplecore op 3,2 GHz.
Een HD3870 mag dan wel 2x zo snel zijn als een X1900 serie, feit blijft dat een Xbox veel meer geoptimaliseerd is en dat Rockstar gewoon de bovengrens flink heeft willen oprekken voor de PC. Zo is de draw distance van de Xbox te vergelijken met 22 op de PC versie. En mijn HD2900XT haalt al een draw distance van 32 met details op medium en dat draait prima.
Tip is om die onderste twee (traffic en shadows) flink terug te schroeven, want deze belasten de CPU, maar ook de GPU heel zwaar.
Goud is geen geld
  • superbassie
  • Laatst online: 23-11 20:43
Hij speelt best aardig, nu nog een beetje tweaken
Statistics
Average FPS: 44.14
Duration: 37.20 sec
CPU Usage: 62%
Video memory usage: 69%
Graphics Settings
View Distance: 25
Detail Distance: 37
Hardware
Service Pack 3
Video Adapter: ATI Radeon HD 4800 Series
  • Bobnofski
Specs: E6420 @ 3.2Ghz (8X400) / 2GB DDR2 / ATI 4870 512MB Club3D OC @ 800/950 - WinXP 32-bit SP3
Graphics Settings:
Video Mode: 1280 x 1024 (70 Hz)
View Distance: 40
Detail Distance: 40
Shadow Density: 0 <<< gaf grootste boost, +10 fps gemiddeld tov SD: 7
Vehicle Density: 25 <<< iets hoger dan de console default
Benchmark: Average FPS: 41.95
Ingame loopt het redelijk soepel, fps zakt wel naar 25 als er veel auto's in beeld zijn maar overall voelt het vloeiend aan. Render Quality op Very High of Highest geeft nauwelijks verbetering in kwaliteit dus High is blijkbaar genoeg.Als ik het gebrek aan AA wegdenk ziet het er eigenlijk best goed uit. De shadows vond ik al meteen erg lelijk en nu ze uit staan mis ik ze niet eens. Vehicle Density kan makkelijk hoger maar ik vind het maar lastig spelen als er zoveel verkeer is.
Direkt na de 1e speelsessie heb ik de partitie van GTA IV gedefragmenteerd met JkDefrag:
jkdefrag -a 7 [partitie]
Hiermee wordt alles op directory volgorde gezet en dit duurt uren. (iets van 3 uur bij mij op een 3/4 gevulde 80GB partitie). Defragmenteren is altijd aan te raden en bij GTA IV helemaal met z'n 15GB.
Mensen die last hebben van restricties. Volgens mij kan je deze uitzetten door -norestrictions -nomemrestrict aan de shortcut van LaunchGTAIV.exe toe te voegen.
  • superbassie
Verwijderd schreef op vrijdag 05 december 2008 @ 17:34:
Werkt niet bij mij :N
Bij mij draait het wel acceptabel, maar ik heb een vreemde schaduw bug. Alle schaduws zijn opgebouwd uit spikkels.
  • Vis
  • Laatst online: 18:28
Vis
Ik heb ook een rare bug lijkt het..
De schaduwen flikkeren constant.. van het licht.. hier wat voorbeelden:
http://img514.imageshack.us/my.php?image=naamloos2yd8.jpg
en als ik even met de muis een klein beetje beweeg, krijg ik ineens andere schaduws..:
http://img504.imageshack.us/my.php?image=naamloosyq2.jpg
:s
Ik heb al veel instellingen geprobeerd, en het is de heletijd zo...
Mijn benchmark btw:
Statistics
Average FPS: 29.88
Duration: 37.24 sec
CPU Usage: 95%
System memory usage: 62%
Video memory usage: 55%
Graphics Settings
View Distance: 41
Detail Distance: 37
Hardware
Service Pack 1
Video Adapter: ASUS EAH4870 series
Video Driver version: 7.14.10.597
Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz
8.11 drivers zojuist gedownload, maar het baat niks.. 8.12 beta zelfs ook erop gehad.
Ik wordt gek van dat geflikker.
Iemand die hier een oplossing voor heeft? Thnx!
  • P!m
  • Laatst online: 15:15
P!m
Heb ook dat geflikker de hele tijd. Schaduwen die alleen maar bestaan uit spikkels. Voor de rest draait het wel redelijk. Omdat ik helaas te weinig geheugen (slechts 256MB) op mijn grafische kaart heb, kan ik niet op de native resolutie van mijn monitor spelen (1280 *1024) en moet ik op 1024 * 768 spelen.
Mijn benchmark
Statistics
Average FPS: 35.75
Duration: 37.09 sec
CPU Usage: 95%
System memory usage: 90%
Graphics Settings
Video Mode: 1024 x 768 (75 Hz)
View Distance: 3 :'(
Hardware
Service Pack 1
Video Adapter: ATI Radeon HD 3850 (256 MB)
Audio Adapter: Luidsprekers (Realtek High Definition Audio)
Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Heb de Ati 8.12 BETA drivers, en hiermee loopt het wel wat beter dan met de 8.11 drivers, maar ik heb nu dus nog steeds dat geflikker van schaduwen. (Zie plaatje - klik-)
  • Vis
Vis
Echt onwijs irritant idd!
  • KoffieNT
KoffieNT
banaan
frankknopers schreef op vrijdag 05 december 2008 @ 17:07:
Een HD3870 mag dan wel 2x zo snel zijn als een HD3870, feit blijft dat een Xbox veel meer geoptimaliseerd is en dat Rockstar gewoon de bovengrens flink heeft willen oprekken voor de PC. Zo is de draw distance van de Xbox te vergelijken met 22 op de PC versie. En mijn HD2900XT haalt al een draw distance van 32 met details op medium en dat draait prima.
With all due respect, daar hebben wij, pc-gamers, niets mee te maken. Ze maken een spel voor de pc, en dan dient het fatsoenlijk te werken.
En daarnaast moet er niet vanuit kunnen worden gegaan dat voor elk spel er weer een nieuwe generatie computer moet worden gekocht.
Waarom kopen mensen toch consoles? Omdat, als je een spel koopt, het gewoon werkt. Ik zou bijna overstappen naar ps3 zeg :P.
Ik heb sinds vandaag ook last van de drunken camera, ik ga nog een andere versie van het spel proberen..anders weet ik het ook niet meer. (koop ik hem gewoon 8)7, dat is lang geleden, 2,5 jaar ofzo, als het niet langer is :P)
[ Voor 8% gewijzigd door KoffieNT op 05-12-2008 20:22 ]
:D
voor de mensen die het niet lukt om de gta.exe te veranderen en geen high texures kunnen selecteren
ga naar de main gta folder, dus c:/rockstar/gtaiv
maak daar een text bestandje aan met commandline.text
zet daar dit in: -nomemrestrict -norestrictions -novblank
sla het bestandje op , en hoppa je kunt nu alles op high zetten LET OP er kunnen texure problemen optreden
benchmark van mij met alles max out
Statistics
Average FPS: 40.02
Duration: 37.23 sec
CPU Usage: 80%
System memory usage: 80%
Graphics Settings
View Distance: 100
Hardware
Service Pack 1
Draait prima hier. (had veel achtergrondprogramma's draaien tijdens de benchmark)
Statistics
Average FPS: 30.20
Duration: 37.32 sec
CPU Usage: 87%
System memory usage: 96%
Video memory usage: 66%
Graphics Settings
View Distance: 20
Detail Distance: 33
Hardware
Service Pack 3
Video Driver version: 178.24
Audio Adapter: Juli@ Ch12
Intel(R) Core(TM)2 CPU 6300 @ 2.52GHz
  • PainkillA
  • Laatst online: 20-11 21:44
niet eens zo heel slecht, valt me wel op dat gta 4 erg zuinig is met memory en cpu.had wel meer in de 80/90% verwacht en amper 55% memory is niet veel.
Statistics
Average FPS: 43.08
Duration: 38.05 sec
CPU Usage: 68%
System memory usage: 55%
Graphics Settings
Video Mode: 1680 x 1050 (60 Hz) + 16x AF forced
View Distance: 100
q6600 @ 3.6
4gb
4870 @ 790/2000
vista 64 sp1
catalyst 8.11
[ Voor 17% gewijzigd door PainkillA op 05-12-2008 21:55 ]
  • Initial G
  • Laatst online: 10:29
Draait hier ook goed
E8400 433FSB (mem 1:1) 3.2GHz
HD4850 stock 512mb
2GB ram
Statistics
Average FPS: 37.53
Duration: 37.06 sec
CPU Usage: 82%
Video memory usage: 78%
Graphics Settings
View Distance: 25
Detail Distance: 37
Hardware
Service Pack 3
Video Driver version: 6.14.10.6860
Audio Adapter: Theatron Agrippa Wave Device
  • H3llSiNG
H3llSiNG
Meh.
Welke NVidia drivers gebruiken jullie? Ik probeerde net de beta 180.48 drivers. Het spel liep opeens heel soepel met een 20fps boost. Maar na een tijdje vielen alle textures weg. Je zag alleen nog maar de andere auto's rijden.
  • Kuhr89
  • Laatst online: 15:34
Ik heb het spel ook nu.
verwachtte alleen niet zoveel van mijn PC.
Het valt eigenlijk nog wel mee. Ik kan het nog wel redelijk spelen.
Niet op Native res. maar op 1280x 720 en dan upscalen naar 1680x1050
Dit zijn de resultaten.
Ik heb wel van die lelijke schaduwen. meer mensen hebben daar last van. En als ik savonds speel. Alles wat licht geeft zitten van die rare blokjes omheen lijkt het wel. Misschien een bug voor Ati.
Ik heb de 8.11 drivers er nog op staan. Maar zal met mijn 1950Pro AGP niet zoveel uitmaken of het nu 8.11 of 8.12beta zal zijn.
Statistics
Average FPS: 21.41
Duration: 37.28 sec
CPU Usage: 90%
System memory usage: 89%
Video memory usage: 67%
Graphics Settings
Video Mode: 1280 x 768 (60 Hz)
View Distance: 20
Detail Distance: 16
Hardware
Service Pack 3
Video Adapter: Radeon X1950 Pro
Audio Adapter: SB X-Fi Audio [E000]
AMD Athlon(tm) 64 X2 Dual Core Processor 4800+
Specs staan onderin ;) Ach het valt te spelen. In april nieuwe pc. zullen zien wat dat brengt. Hopelijk nadat R* flink wat optimalisaties doet. native res met goede FPS op hoogste settings.
| PS5 PSN: Hitting-Apex89
  • LordRAN
  • Laatst online: 08-10 17:02
H3llSiNG schreef op vrijdag 05 december 2008 @ 22:00:
Zelfde hier. Ook die drivers en de textures vallen weg na 5 tot 10 minuten.
Heel veel mensen hebben hier last van. Ik denk dat we echt moeten wachten op de patch voordat we dit spel echt kunnen gaan spelen....
E6600, 8800GTX btw.
  • Avalaxy
  • Laatst online: 13-11 23:11
Zijn er hier mensen die nog een oude Athlon 64 X2 of dual-core Opteron hebben? Ik heb hier een Opteron 165 @ 2.8GHz, maar de performance is echt om te huilen... En dat is met een HD4870. Heb bijna alles op medium, traffic op 30%, details op 70%...
  • Imperium
Takkezooi! Sinds ik 8.12 beta heb geprobeerd krijg ik mijn textures ook niet meer terug :(
Zelfs na een driverclean en 8.11 weer terugzetten geen resultaat!
wat een ongelofelijk bugged release zeg..
  • H3llSiNG
H3llSiNG
Meh.
Avalaxy schreef op vrijdag 05 december 2008 @ 22:40:
ik heb een x2 3800+ met een 8800gt en 2 gig ram. draait gewoon goed op medium / very high. ik heb alleen vervelende texture problemen.
  • Kuhr89
Kijk maar mijn post boven je.
Een X2 4800+ Socket 939. Staat op 2.8Ghz.
Ik heb een 1950Pro AGP. beetje overclock. Als je naar de settings kijkt. valt het mee vond ik. Het is wel gewoon te spelen. Maar de schaduwen maken het echt heel erg lelijk.
Als ik naar 1024x768 ga. is het gewoon goed te spelen. Maar upscalen ziet er dan niet uit
  • Deagle
H3llSiNG schreef op vrijdag 05 december 2008 @ 22:49:
Draai de benchmark even, ben benieuwd naar je fps dan...
  • SalimRMAF
  • Laatst online: 24-11 14:53
SalimRMAF
SpaceX - 4K
Initial G schreef op vrijdag 05 december 2008 @ 21:56:
HD4850 stock 512mb
2GB ram
Statistics
Average FPS: 37.53
Duration: 37.06 sec
CPU Usage: 82%
Graphics Settings
View Distance: 25
Detail Distance: 37
Hardware
Service Pack 3
Als ik onze resultaten vergelijk.. zie ik dat mijn 9800GTX+ stukken beter is dan jouw 4850? Ben best verbaasd, aangezien de HD4850 eigenlijk beter zou moeten zijn. Ik heb een aantal settings hoger dan jij. En dan nog 20% meer FPS. Vreemd.
Ik gebruik 180.60 Winvista Drivers, Ultimate 32BIT, 2GB 1000Mhz, CPU is een Xeon op 4Ghz+
Statistics
Average FPS: 43.64
Duration: 36.99 sec
CPU Usage: 95%
System memory usage: 91%
Video memory usage: 94%
Graphics Settings
Video Mode: 1680 x 1050 (59 Hz)
View Distance: 52
Hardware
Service Pack 1
Video Adapter: NVIDIA GeForce 9800 GTX/9800 GTX+
Audio Adapter: Luidsprekers (SoundMAX Integrated Digital HD Audio)
Intel(R) Xeon(R) CPU E3110 @ 3.00GHz
PS: Als ik perse alles op "Full" wil zetten, waar moet ik dan bijvoorbeeld "-norestrictions" zetten? In de Console?
[ Voor 3% gewijzigd door SalimRMAF op 05-12-2008 23:40 ]
Gulfstream G650
  • Initial G
salimrmaf schreef op vrijdag 05 december 2008 @ 23:39:
Statistics
Average FPS: 43.64
Duration: 36.99 sec
CPU Usage: 95%
Graphics Settings
View Distance: 52
Hardware
Service Pack 1
CPU afhankelijk denk ik, plus waarschijnlijk betere optimalisatie voor nvidia.
  • zonoskar
  • Laatst online: 18:10
zonoskar
<-- Mika R.I.P!
Mijn benchmark:
Statistics
Average FPS: 44.04
Duration: 37.14 sec
CPU Usage: 60%
System memory usage: 30%
Graphics Settings
View Distance: 40
Hardware
Service Pack 1
Audio Adapter: Speakers (Sound Blaster X-Fi Xtreme Audio (Vista))
Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz
Spec:
CoreQuad 2.4 GHz @ 3.6Ghz (dus niet als hierboven staat op maar 2.4GHz)
Windows Vista Home premium 64bit
8GB geheugen
nVidia 8800GT 512MB, standaard snelheid.
Is deze game eigenlijk geoptimaliseerd voor dual/quad core CPUs?
  • k1n9_n01z3
k1n9_n01z3
gewoon KNz dus
heeft iemand de speciale drivers ( http://www.nzone.com/object/nzone_gtaiv_downloads.html ) al geprobeert ?
Steam Inventaris
  • SalimRMAF
SalimRMAF
SpaceX - 4K
Ooeh, dit lijken goede drivers. :D Maar heb ik pech dat ik net na een Frisse WinVista32-installatie na n uur eindelijk de 180.60 Drivers heb kunnen installeren. :O
Ik denk dat deze drivers veel verbeteringen zullen brengen. Kan iemand ze testen?
Gulfstream G650
  • Bagel
salimrmaf schreef op zaterdag 06 december 2008 @ 00:35:
Ik lees op GTAforums dat mensen een increase van zon 10FPS merken. :> :*)
edit: De server word nu natuurlijk geraped, ik download niet erg hard. :'( Ik ga ze ff installen wanneer ze binnen zijn en ff een minuut of 10 spelen in de nacht met regen en lichten. Daar had ik wat moeite mee, kijken of dat beter is.
[ Voor 20% gewijzigd door Bagel op 06-12-2008 01:11 ]
  • k1n9_n01z3
k1n9_n01z3
gewoon KNz dus
Statistics
Average FPS: 21.55
Duration: 37.21 sec
CPU Usage: 89%
System memory usage: 79%
Video memory usage: 98%
Graphics Settings
View Distance: 20
Detail Distance: 20
Hardware
Service Pack 3
Video Driver version: 180.84
oude benchmak is boven aka ik ga er dus 71-55= 0.16 frames op achteuit.
[ Voor 0% gewijzigd door k1n9_n01z3 op 06-12-2008 01:43 . Reden: typo ]
Steam Inventaris
  • Jamoru
  • Laatst online: 23-04 15:38
Vis schreef op vrijdag 05 december 2008 @ 19:11:
Ik heb de game zelf (nog) niet, maar ik heb precies hetzelfde probleem met World of Warcraft op mijn Crossfire rig (2 x HD4870). Lijkt er dus op dat het een driver probleem is.
"There is only one success--to be able to spend your life in your own way."
Pagina: 1 2 ... 21 Laatste
