• FloRadix
  • Laatst online: 07:10
Een niewe update voor de PCH-A100 is sinds vandaag officieel beschikaar, hier onder is de changelog:
Release Date:21 January 2009
Firmware Version: 01-17-090116-15-POP-402-000
Release Note:
1. Requires NMT apps 00-17-090115-15-POP-402
2. Browser / System
- Improvement on font engine character rendering (30% speed up)
- faster navigation on local drives
- Use numeric key to input item number to jump to the page where item is located
- Improved fileplayer speed
- Hebrew translation added
- Fixed HDMI display output blackout issue for auto EDID
- Discrete RC (Logitech) scancode fix
- Updated network share and webservices language packs.
- Removed EXT2 option for NMT installation
- Note: due to long term reliability issue with EXT2 on device that is frequently turned off abruptly
- Additional symbols can be input from "1" key
- HTTP download manager (only works with links with special "download" attributes.
- File player hide Recycle Bin folder
- Fixed 'TV MODE' + '3' key handling bug
- Fixed recovery kernel no red screen displayed
- Browser image caching fix, should fix some YAMJ crashes or no image issue.
- Fixed HDD spin-up during standby
- Fixed slow loading of HTML pages
3. Web Services
- New UI
- customizable icon feature with browse image utility (need NMT apps)
- bug fixes on customizable service icon with browse feature.
- Web Services page modification
- Fixed a "save/remove service" bug
- Now able to customise JPG/BMP icon
- Fixed slow IR response while playback Internet Radio
- Immediate response to STOP during Internet video streaming
- Fine-tune Web Service UI
4. Network
- Improved SMB server startup time
- Improved browsing time for SMB client
- Atheros USB WiFi stability fixes
- Fixed SMB client hostname resolution picked up wrong IP address from the IP list
- Fixed file copy failed from HDD to SMB/NFS with names containing whitespace
- Fixed UPnP AV server playall issue broken in previous release
- Fixed Samba server halts after device name change
- Torrent client is now by default Transmission (btpd removed)
**** IMPORTANT NOTE: Please ensure completion with previous downloads with BTPD, as new Transmission client cannot inherit previous downloads.
- Fixed torrent schedule page not working
- Fixed occasionally newly created SMB/NFS shares doesn't show up in media source list
- Atheros USB WiFi added support for TP-Link v2 stick
- Fixed persistent private IP when DHCP server unavailable (e.g. cross-cable connection etc)
5. Playback
- Bookmark/resume for single playback
- 10 bookmarks available now
- Press stop to bookmark the last video playback
- Press enter / play with focus on bookmarked clip to resume
- Press "0" to start from beginning of clip
- Auto framerate synchronisation
- Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC)
- switch to NTSC(60Hz) when selected mode not applicable.(previously, it will follow TV mode selected)
- Use 59.94 for NTSC when matching content detected.
- Fixed incorrect data shown on infobar.
- Fixed after ISO playback, screen goes blank when framerate sync kicks in
- Improved info display
- Disable incorrect video MPEG1/2 VBR display.
- Fixed incorrect framerate info for video playback (*.mov, *.mp4).
- Fixed video bitrate calculation error (less 1 packet every second)
- Modified infobar UI (height, spacing and text displayed)
- Fixed info bar losing text after paused
- Improved accuracy of mpeg1/2 bitrate information
- Photo app
- Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed
- Fade-In Fade-out effect added for photo transition
- Enable large jpeg rotation. (downscale before rotate)
- Fixed faded color for jpeg at 360-deg rotation
- TV Type setting for DVD playback
- the TV type setting is now working for DVD video playback (4:3 and 16:9 only, 16:10 will treat as 16:9)
- DVD Menu
- new popup menu if MENU key on PCH remote controller is pressed
- user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu
- Modified progressive zoom and pan in ISO/IFO playback
- Removed up/down keys as prev/next track/td>
- VCD *.DAT playback fixed using soft demux
- Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt
- Improved handling of MKV H.264 profile and vlevel.
- Fixed cannot stream MPEG from UPnP AV server, liveTV
- Fixed .pls file unable to start when playback locally (HDD/SMB/NFS)
- *.m3u playlist supported.
- Fixed TS with stream6 as teletext playback cause out of memory
- Fixed MKV H264 L4.1 pixelated video issue
6. Subtitle
- Fixed Hebrew SRT subtitle containing invalid character
- Fixed subtitle parsing with BOM (UTF8 support only)
- Thai subtitle support
- Fixed wrong character rendered in Thai subtitle
- Changed default subtitle font size to 28 and Y offset to 10
- Exception handling in SSA subtitle parsing
- Slight adjustment of subtitle position
NMT Apps Version:00-17-090115-15-POP-402
Release Note:
1. Minimum firmware version to use this NMT App is 00-17-090116-15-POP-402-000
2. Improved on samba client browsing time and server boot up time
3. Fixed occasional slow samba response
4. Upgraded to nzbget 0.51
5. Upgraded to nzbgetweb 1.2 (Categories can be modifed in /mnt/syb8634/nzbgetweb/setting.php5)
6. Various Casgle fixes
7. Fixed FTP password saving
8. Improved Setup Page loading time
9. Remove btpd, using Transmission as default BT client
10. Fixed sometimes unable to access casgle web ui
11. Fixed HDD spin-up during standby
Heerlijk zo'n lange changelog, wordt ik altijd blij van :D
Ik verwacht dat die eind van de week rijpgemaakt is voor de A-110 en B-110.
Nadeel is als je een niet-Sybas-NMT hebt (eGreat, HDX etc.) dat je een paar weken moet wachten tot de firmware geport is.
  • JvdS
  • Laatst online: 20-11 13:20
Ik zie helaas nergens staan dat het streaming WMV probleem is opgelost (rtl gemist en andere zenders zou ik hiermee werkend kunnen maken)...
http://www.networkedmediatank.com/showthread.php?tid=14470
  • Ortep
Ortep
Soylent Green is People!
Verwijderd schreef op woensdag 21 januari 2009 @ 10:23:
Ik hoop voor je dat het zo snel is. Het is Chinees nieuwjaar. Ongeveer heel Azie is 2-3 weken gesloten
Only two things are infinite, the universe and human stupidity, Einstein
Alleen de doden kennen het einde van de oorlog, Plato
  • wvkreg
  • Laatst online: 17-11 16:58
Verwijderd schreef op dinsdag 20 januari 2009 @ 23:42:
Uhm, "lang" voor een ISO, ongeveer 10-15 seconden gok ik.. :) Dus overheen te komen ;)
Maar ik ben als een kind zo blij :D Het is veel makkelijker dan ik dacht.. nu nog even alle netwerkshares goed krijgen, en alles verder instellen :) Leuk, spelen!
Nog 1 vraag: hoe gaat het parren op de PCH?
Parren matig, repareren dramatisch traag 300 Mhz 256 MB wat verwacht je?
Ortep schreef op woensdag 21 januari 2009 @ 10:57:
Wat heeft Azië hiermee te maken?
Bij de vorige firmware duurde het 2 weken, dus dat corrigeer ik even :)
[ Voor 12% gewijzigd door Verwijderd op 21-01-2009 11:26 ]
  • LtMarx
  • Laatst online: 25-11 17:39
LtMarx
ATTENTIOOOON!!!
Ik vind het wel jammer dat die sub/idx support er niet doorheen is gekomen. Die zal er de volgende keer wel weer bij zitten dan.
  • PipelineNoise
  • Laatst online: 17-11 13:08
Ook met de nieuwe firmware lukt het me niet om Uitzending Gemist af te spelen ( via www.jorisvdstraten.nl/uzg), mijn PCH A100 crasht zodra ik op de 'play'-link klik op de webpagina.
Vooralsnog heb ik niemand anders gevonden die hetzelfde probleem heeft. Is hier iemand die het ook niet lukt om Uitzending Gemist te bekijken?
  • vwtune
  • Laatst online: 15-11-2024
PipelineNoise schreef op woensdag 21 januari 2009 @ 12:33:
Ik kan ze (de meeste, niet allemaal) wel afspelen MAAR wel zonder geluid!!
Ik heb alles via coax aangesloten op mijn receiver. hdmi audio staat uit.
Dus ik weet niet waar het aan ligt.
iemand een idee?
  • JvdS
Ik heb dit al vaker gehoord (maar heb er zelf bijna nooit last van). Je moet dan eerst een normale divx of dvd file afspelen om het geluid weer terug te krijgen. Of de NMT herstarten.
  • DiMacho
  • Laatst online: 01-11 22:27
vwtune schreef op woensdag 21 januari 2009 @ 13:21:
iemand een idee?
Lees het topic nog maar eens goed door...
Je moet eerst een andere file openen. Maakt niet uit welke, avi/iso/mkv etc... En dan Doet het geluid het wel!
*edit: te laat ;)
  • vwtune
Oke dan ga ik dat eens proberen. Lijkt mij wel een bug dan
  • Ortep
Ortep
Verwijderd schreef op woensdag 21 januari 2009 @ 11:11:
Wat Azie er mee te maken heeft? Euuuh China en Maleisie liggen In Azie en daar wordt een groot deel van het werk gedaan. Alleen het hoofdkantoor zit in de VS
Syabas Technology is a worldwide company, headquartered in Fremont, California, USA. Our facilities are situated in the USA, China and Malaysia.
Je kan dus een behoorlijk 'invloed' verwachten van de grootste vakantie/volksverhuizing ter wereld
[ Voor 12% gewijzigd door Ortep op 21-01-2009 14:35 ]
Dat zou jammer zijn voor een grote groep gebruikers. Ben benieuwd!
  • giohardcore
  • Laatst online: 04-11 16:53
Ik zie ook helaas nergens dat de A-100 nu DTS e.d. kan downmixen, dan had ik graag gehad, aangezien mijn A-100 op de slaapkamer staat en ik daar geen DTS receiver heb.
Mocht dat niet erin komen in de toekomst, dan maar de A-110 boven zetten. Weet iemand of het uberhaupt wel mogelijk is dat de A-100 in de toekomst kan downmixen?
  • LtMarx
LtMarx
ATTENTIOOOON!!!
nee je a100 zal nooit DTS kunnen downmixen, omdat jij niet betaald hebt voor de DTS licentie .En syabas gaat jou niet op eigen kosten dat laten doen :P
[ Voor 25% gewijzigd door LtMarx op 21-01-2009 16:43 ]
  • qless
  • Laatst online: 26-11 13:40
qless
...vraag maar...
giohardcore schreef op woensdag 21 januari 2009 @ 16:36:
Denk het niet, aangezien ze voor de DTS licentie moeten betalen
Website
Drones: Air 3s, Mini 4 Pro, Avata 2
Camera's: Canon R6, Canon 5d2, Dji Osmo Action 4
Objectieven: 8 fisheye, 14f2.8, 24f2.8, 50f1.8, 135f2, 17-40f4, 24-105f4, 70-300f4-5.6, 150-600f5-6.3, 25f2.8-2.5x-5x
  • catchingfire
  • Laatst online: 26-11 22:30
De chinezen waar ik business-wise mee werk zijn er een weekje tussenuit vanaf aanstaand weekend en gaan dan op maandagmorgen weer vrolijk er tegenaan... niks 2-3 weken.
  • Beauty555
  • Laatst online: 20-09-2010
De chinees bij mij in de straat is gewoon de hele week geopend :? 8)7 |:(
En dat 365 dagen per jaar ..... Sambal bij :P
[ Voor 34% gewijzigd door Beauty555 op 21-01-2009 17:33 ]
  • Ortep
Ortep
catchingfire schreef op woensdag 21 januari 2009 @ 17:26:
Ben jij ooit wel eens in China geweest? Het hele land gaat echt bijna twee weken plat. En natuurlijk zijn er mensen aan het werk. Maar die zijn voornamelijk bezig om de zaak in goede banen te leiden. Er gaan bijna een kwart miljard mensen op reis, allemaal tegelijk. Dat ze maar een week weg zijn wil niet zeggen dat de week er voor en de week erna alles 'normaal' is.
[ Voor 5% gewijzigd door Ortep op 21-01-2009 17:38 ]
  • Dijkhuis
  • Laatst online: 23-11 10:46
Nog een vraagje over Uitzending Gemist ( via www.jorisvdstraten.nl/uzg), hoe kom je na een programma te hebben bekeken weer terug bij de lijst programma's? ik kom er enkel wel door de NMT uit te zetten. :/
  • MaZo
FloRadix schreef op woensdag 21 januari 2009 @ 10:04:
Ik blijf vurig hopen op toekomstige DTS-ondersteuning... O-)
  • Beauty555
Dijkhuis schreef op woensdag 21 januari 2009 @ 18:57:
Met de RETURN knop op je afstandbediening
Jammer dat er weer niks is gedaan aan audio playback options of ik lees er over heen. Veel taalgebruik in de log is niet echt dagelijkse kost voor mij maar als ik zo kijk staan onder het kopje playback voornamelijk aanpassingen mbt video playback. Geen screensaver, geen shuffle mode, etc!! De PCH is wat betreft audio-afspeelmogelijkheden echt flut. En onder media (van "networkMEDIAtank") schaar ik toch ook echt audio.
  • simonanton
  • Laatst online: 04-05-2025
Ik ben erg blij met de geupdate versie van NZBGet waarbij SSL versleuting bij het downloaden vanaf usenet mogelijk is geworden.
Ik kijk erg uit naar uitzending gemist van de commerciële omroepen JORIS.
Superapparaat de PCH. Echt geweldig.
  • JvdS
Waarom mijn naam in hoofdletters?
Ik kan helaas door een beperking in de codecs van de NMT rtl gemist nog niet werkend maken.
  • simonanton
Dan heeft het wel geholpen. Maar ik zal het niet meer doen. Mijn complimenten voor de webservice "Uitzending gemist".
JvdS schreef op woensdag 21 januari 2009 @ 21:26:
MaZo schreef op woensdag 21 januari 2009 @ 19:56:
Lees 'es een paar posts boven je.
Verwijderd schreef op woensdag 21 januari 2009 @ 20:18:
Het gebruik *.m3u playlist is toegevoegd, maar verder kun je inderdaad beter de andere muziekoplossingen gebruiken die voor de NMT's zijn gefabriceerd.
[ Voor 45% gewijzigd door Verwijderd op 21-01-2009 22:31 ]
  • Ray
  • Laatst online: 29-07 15:17
Ray
ik heb echt al behoorlijk gezocht maar kan het antwoord niet vinden. Het schijnt dat je de itunes library in de pch 110 kan importeren. Maar hoe ? Ik zou het al tof vinden dat hij gewoon mijn netwerk library ziet en die af kan spelen maar ik kom er niet achter hoe dit zou moeten. Weet iemand wat er kan en hoe het moet (of waar ik het wel kan vinden ?)
  • simonanton
Wisten jullie dat surfen met de popcorn (beperkt) mogelijk is met de volgende webservice.
http://pici.picidae.net/
Test het maar.
Meer info:
http://www.picidae.net/how_picidae_works/lang-pref/en/
Vraagje aan de Linux-goeroe's onder ons (aangezien ik dat zelf niet ben). ;)
Ik gebruik als Torrent-client Transmission (i.c.m. Transmission Remote GUI). Nu is 't helaas niet mogelijk om een Torrent automatisch te laten stoppen met seeden bij een vooraf gedefinieerde ratio (zoals dat wel mogelijk is bij clients als uTorrent en Azureus). Nou heb ik even op internet gespeurd en een script gevonden waarmee dit wel mogelijk zou moeten zijn:
http://forum.transmission...=33369&hilit=ratio#p33369 (post 13 jan)
Kan iemand mij vertellen hoe ik dit werkend krijg op een PCH A-110? M.a.w. waar plaats ik dit script (pad/bestandnaam) en hoe roep ik deze aan?
Ik vermoed dat het script wordt opgeslagen onder de naam tr_check_ratio.awk in 't pad "scripts" (bestaat nog niet op m'n PCH) en aangeroepen wordt vanuit de bin. Maar er zijn ongetwijfeld mensen hier die daar meer kaas van gegeten hebben.
B.v.d. _/-\o_
  • LtMarx
LtMarx
ATTENTIOOOON!!!
Transmission heeft al automatisch stoppen op ratio. Ik gebruik torrentwatch en daar kan je de ratio aangeven waarbij de torrent moet stoppen, dit werkt prima!
Alleen via de webinterface kan je dit niet instellen, eigenlijk zou je in het transmission GUI topic moeten vragen om deze feature, het moet wel mogelijk zijn met de huidige transmission.
[ Voor 37% gewijzigd door LtMarx op 22-01-2009 11:02 ]
  • 4of9
  • Laatst online: 15-04 15:52
misschien stomme vraag hoor, maar waar kun je NMT's het meest goedkoop aanschaffen?
Ik ben al aan het zoeken geweest op US en Chinese sites maar kon ze zo snel niet vinden. iemand wat linkjes?
Aspirant Got Pappa Lid | De toekomst is niet meer wat het geweest is...
Lt. Marx schreef op donderdag 22 januari 2009 @ 11:01:
Bedankt voor de snelle reaktie.
Als ik me niet vergis is Transmission multiplatform. Als bijv. MacOS app. is je ratio in te stellen alleen kan dit inderdaad niet via de webinterface van de NMT. Om te gaan wachten op een volgende versie van de GUI is een optie maar daar gaat sowieso waarschijnlijk nog wel behoorlijk wat tijd overheen. Als 't even kan dan zou 't script wellicht een snellere oplossing zijn. :)
Zie nu trouwens dat je Torrentwatch gebruikt. Deze draait gewoon naast Transmission? Ik ga er even induiken! Bedankt.
Edit: Heb even gekeken maar ik kan geen optie vinden waarin alle torrents in een bepaalde watch-folder gestopt kunnen worden na het bereiken van je ratio. Als iemand nog een suggestie heeft m.b.t. 't eerder genoemde script hoor ik het graag!
[ Voor 17% gewijzigd door Verwijderd op 22-01-2009 12:25 ]
  • DiMacho
4of9 schreef op donderdag 22 januari 2009 @ 11:36:
http://www.popcornhour.com/onlinestore/
  • FirePuma142
FirePuma142
Sergius Bauer
Ik heb mijn A-110 hier afgelopen zondag besteld en gisteren in ontvangst mogen nemen bij de 2e afleverpoging aangezien ze op dinsdag ook al langs waren geweest. Is inclusief verzendkosten E259,-
http://www.digimania.be/en/index.asp
[ Voor 9% gewijzigd door FirePuma142 op 22-01-2009 12:46 ]
Joris, bedankt! :) :)
Ik zit nu in Duitsland even het Jeugdjournaal weekoverzicht te kijken.. :D
Ray schreef op woensdag 21 januari 2009 @ 23:34:
Kijk even op www.networkedmediatank.com.
simonanton schreef op donderdag 22 januari 2009 @ 00:00:
Test het maar.
Meer info:
Ha wat vet :D
[ Voor 25% gewijzigd door Verwijderd op 22-01-2009 13:26 ]
Pff, ik krijg TorrentWatch nog niet aan de praat.. :(
De Windows installer werkt niet.. dus ik hem alles ge-upload via FTP, en CHMOD 755 gedaan. Als ik hem wil uitvoeren via de PCH krijg ik een Syntax error. Als ik hem zo uitvoer via mijn browser:
http://192.168.2.24:8088/stream/file=/opt/sybhttpd/localhost.drives/HARD_DISK/Torrents/torrentwatch-installer.cgi?install
Dan zie ik simpelweg het script.
Iemand?
Oh, en hij is vast gelopen. Blauw scherm.. :{ Ik kan echter nog wel FTP'en. Als ik hem met de remote aan en uit zet gebeurt er niets.. :(
Anyway; erg leuk speeltje.. :)
Alleen net de trailer van Earth gedownload, 1080p.. en daar waren de vogels! En dat trok 'ie niet, de PCH of de TV. Toevallig dat ik net als eerste 1080p file de vogels te pakken heb.. :+
  • qless
qless
...vraag maar...
Verwijderd schreef op donderdag 22 januari 2009 @ 14:59:
Jaja, toeval? ;)
Website
Waarschuwing, ik ben een ontzettende n00b op dit gebied.
Ik heb een apple laptop, een airport wireless n router met daarop aangesloten een harde schijf van 500gb. Als ik een film download met nzb dan sluit ik nu laptop aan op de tv en wil dat graag wat strakker hebben met minder geklooi.
1. Met een a110 popcorn kan ik ook gewoon nzb downloaden met usenet? Hoe bedien ik dat dan, met de afstandbediening?
2, Kan een popcorn gewoon mijn harde schijf die aan mijn router zit benaderen en daarvan de films lezen?
3. Een harde schijf installeren in de a100, is dat moeilijk? Lees er weinig over, kan wel schroeven maar niet solderen.
4. De amerikaanse site is de beste plek om het te kopen? Zijn er nu nog wachttijden?
  • qless
qless
...vraag maar...
Verwijderd schreef op donderdag 22 januari 2009 @ 16:07:
1) volgens mij moet je wel de nzb's uploaden naar de pch. (En je PCH moet een harddisk ingebouwd hebben)
2) ja, mits je netwerk snelgenoeg is (100 mbps) wifi is af te raden, alhoewel de 802.11N snel genoeg zou moeten zijn
3) in de a100 standaard IDE disk, in de a110 is dat SATA geworden. Solderen dus niet nodig (gelukkig)
4) sommige (web)winkels hebben hem ook in NL/BE op voorraad
Website
Ik lees zojuist dat een harde schijf in popcorn linux formatteerd is (ext2 of zo). Lijkt mij lastig, heeft iemand anders hier ook een apple + popcorn? Werkt dat?
  • qless
qless
...vraag maar...
Verwijderd schreef op donderdag 22 januari 2009 @ 16:39:
Geen probleem, je benaderd je PCH via netwerk, en dus is dat gewoon samba/cifs. Enkel als je de schijf in je pc wilt gebruiken moet je een ext3 driver hebben
Website
  • Ray
Ray
heb je hem afgespeeld via de interne hd ? want dan moet het gewoon werken mits je lcd het aankan.
trouwens er is ook zoiets als een Edit button, gebruik die eens wat vaker :)
Voor een "goedkope" mediaplayer vind ik hem nog best duur trouwens :) bij importeren ongeveer 350 dollar mét wifi zónder harde schijf. Wifi adapter kan ik in Nederland uberhaupt niet eens vinden trouwens. Jullie wel?
Ja, wat er nou zo duur aan dat ding moet zijn?
Anyway; er draaien 2 Torrent dingen op, die standaard (blauwe interface), en 1tje die "Clutch" heet. Hoe kan ik de instellingen van Clutch wijzigen? De upload trekt m'n hele verbinding dicht.. :(
Je kan downloaden via usenet. Je moet dan even via FTP een configuratiebestand naar je PC halen, de account gegevens van je news server er in zetten, en weer terugFTPen. Via TV+afstandsbediening kun je de usernet-downloadservice aan en uit zetten, maar geen voortgang of andere details zien of downloads toevoegen.
Details kun je wel via een webbrowser op de PC zien (via het IP adres van de router, poort 8066, dan inloggen met 'nmt' en '1234').
Via de webinterface, maar ook via FTP (en andere file transfermogelijkheden die de PCH biedt) kun je NZB bestanden op de PCH zetten zodat de usenet service ze ziet en gaat downloaden, inclusief controle/reparatie en uitpakken van RARs.
Volgens mij is het niet mogelijk via de web-mogelijkheden van de PCH zelf de pagina te bekijken, etc want de webpagina van de usenet service is vrij geavanceerd (maar heb ik zelf nog niet geprobeerd). Wellicht lukt dit met was kunst en vliegwerk wel via die picidae dienst een paar posts terug :))
Ik heb ook al getest dat als de PCH aan het par-verifieren is, en je sluit de dienst af, hij daar tegen kan (de volgende keer begint hij dan wel opnieuw met par-verifieren van de download waar hij aan bezig was, maar hij slaat hem niet over). Of dat ook goed gaat als je dat tijdens unrarren doet weet ik nog niet (hoop het wel, want dan hoef je als hij uit moet niet eerst via je PC te controleren of hij wel uit kan...)
  • J_star
  • Laatst online: 26-11 22:42
Ik wil een mediatankje gaan kopen, alleen twijfel ik tussen de Popcornhour A110 en HDX1000.
Beide zijn naar mijn idee exact hetzelfde. Uitzondering op de extra coaxiaal aansluiting en cardreader extra voor de HDX.
Dit zijn geen opties waarover ik me druk maak. Tevens zijn ze beide 220 dollar met 45 dollar verzendskosten. Waar ik mij nu druk om maak is kwaliteit van het product en garantie afhandeling. Ik kan me namelijk voorstellen een bedrijf in Singapoor duurder verzenden is als naar Amerika, tevens naar mij toe in levertijd.
Tevens staat bij HDX1000 nog steeds levertijd tussen 1 en 4 weken, waar popcorn bijna direct verzend.
Ik hoor graag jullie meningen om mijn keuze te kunnen maken.
Ik kies tussen deze 2 omdat prijs goed is en hardeschijf erin kan plaatsen, verder de lovende topics hier op tweakers.net.
J_star schreef op donderdag 22 januari 2009 @ 18:27:
De verzending van Popcorn Hour zal pas op 6 februari weer beginnen vanuit China. Ze schijnen daar 13 dagen lang een kater te hebben van het oud & nieuwfeest.
  • Beauty555
Ze zijn momenteel bezig met Music Juke Box Release 6. Een Beta is al te vinden op:
http://www.networkedmedia...ead.php?tid=12057&page=33
Ze proberen in versie 6 ook de shuffle aan het werken te krijgen met interne HDD.
Skins import enz. Dus zenken aan je ;)
Voor MyiHome werkt de shuffle al lang.
[ Voor 3% gewijzigd door Beauty555 op 22-01-2009 18:55 ]
  • Beauty555
Zie http://www.networkedmedia...ead.php?tid=12057&page=33
Daar is al een Beta versie 6 van MusicJukeBox te vinden met itunes koppeling.
  • Borromini
Borromini
Mislukt misantroop
Verwijderd schreef op donderdag 22 januari 2009 @ 17:20:
Probeer voor de grap es een PC in mekaar te boxen die je hetzelfde gebruiksgemak biedt. Die kost makkelijk het dubbele (of het driedubbele als je 't met Windows doet) en hij verbruikt minimaal het dubbele ook, en makkelijk meer zelfs.
Dus het is een goedkoop ding, als je alle features en de zuinigheid in acht neemt.
Ik ben voor de HDX 1000 gegaan vanwege de strakkere look - je kan dat ding bij je A/V-installatie zetten en het valt niet uit zijn rol. Ook de fanloze constructie is een groot pluspunt imho, al klagen sommigen in het HDX 1000-topic wel over oververhitting als er een schijf in wordt gemonteerd (dit lijkt vooral met Samsung Spinpoints het geval te zijn). Ik ga alles ernaar streamen, ik heb een 3 TB RAID 5 Linux server draaien hier, en er is geen enkele HD die daar momenteel tegenop kan.
Ik heb de 18e besteld, de 19e zat er al een tracking reference van DHL in m'n inbox. Ik had ook eerst gerekend op een levertijd van 14 werkdagen (de facto zo'n drie weken dus), maar het blijkt een stuk sneller te gaan :). Mijn bestelling is momenteel al onderweg van Hong Kong naar Europa ^_^.
[ Voor 49% gewijzigd door Borromini op 22-01-2009 19:00 ]
De Popcorn Hour heeft ook een fanloze constructie.. :) Die van mij wordt aardig warm.. de buitenkant kun je lekker je handen aan opwarmen, het koelblok is iets te heet om langer vast te houden. Ik heb een Samsung schijf erin hangen, er staat geen SpinPoint op.
  • Rhapsody
  • Laatst online: 10:45
Rhapsody
In Metal We Trust
Nou ik heb een ook besteld. (PCH A110 icm 1TB HDD)
Net alle 22 pagina's doorgelezen, dus ik ben er klaar voor. :D
🇪🇺 pro Europa!
  • Borromini
Borromini
Mislukt misantroop
Ok ik dacht dat de Popcorn wel een fan had. My bad :).
  • J_star
Maar als hij zo heet wordt met een hardeschijf is dat dan wel verstandig, en als je geen HDD hebt geplaatst is dan conceptronics niet net zo goed?
Ik ga persoonlijk liever voor hardeschijf, zodat ik niet apart een pc moet aanlaten om iets te kijken.
Dag,
Erg bedankt voor je UzG tool! Het lukt mij alleen niet om het NOS Journaal van vandaag te bekijken.. als ik op NOS Journaal zoek staat hij er niet bij, als ik op Ned 1 bij de N kijk krijg ik een enorme lijst.. Is daar iets aan te doen? Of doe ik iets verkeerd?
  • Ray
Ray
voor mij was de afweging tussen de hdx en de pch de mogelijkheid van dts downmix van belang. dat kon (kan?) alleen de pch. Er stond een stuk van op de hdx site dat het erbij zou komen maar daar lees ik niets meer van. Ik wilde niet wachten op die update anders had ik inderdaad, vanwege de looks, voor de hdx gekozen. Oja die ibood aanbieding maakte het ook wat makkelijker :)
Gisteren voor het eerst uitzending gemist op tv bekeken via HDX1000 dankzij de tool van JvdS. Super!
Ik bedacht me dat er ook andere nuttige internetpagina's/toepassingen zijn waarvan het mooi zou zijn om die op de tv te kunnen bekijken die eigenlijk niets met streaming video of audio te maken hebben. Bijvoorbeeld: buienradar.nl, fileindex.nl, NS reisplanner, wikipedia.
Ik was niet van plan om echt te gaan browsen vanaf de bank, maar 'even iets opzoeken'.
De file-index en ns reisplanner heb ik als webservice toegevoegd door gebruik te maken van de 'mobiele' pagina's:
http://m.fileindex.nl
http://mobiel.ns.nl/mobiel/planner.action?lang=nl (het =-teken zit helaas niet op de afstandsbediening)
Vormgeving is niet geweldig, maar het werkt wel.
Buienradar gaat niet. Ik vond wel op het web dat ze een applicatie voor windows MCE hebben ontwikkeld, dus het idee is niet zo gek.
Zijn er mensen die nog andere voorbeelden gebruiken? Ik vind overigens de web services die standaard bereikbaar zijn via MSP en Community wat ver weg (veel clicks voor je er bent) en het laadt allemaal wat traag.
  • simonanton
Wat dacht je van:
Verwijderd schreef op donderdag 22 januari 2009 @ 20:00:
  • dejay
  • Laatst online: 21-10 09:58
Bij mij werkt de uitzendgemist tools van JvdS niet. Ook vanaf mijn PC werkt het niet. lijkt wel of uitzendiggemist het blokkeert. Werkt het bij andere nog wel?
Heb deze topic beetje doorgebladerd, maar kan geen antwoord vinden. Dus misschien is al gevraagd, maar kan het niet vinden.
Heb op PC een share aangemaakt. Ik brrowse via de Popcorn door m'n netwerk en vind m'n PC. Als ik op mijn PC enter druk krijg ik melding "NO DATA AVAILABLE". Dit moet toch werken of niet?
Bestaat er geen uitgebreidere handleiding van de Popcorn A110 dan Quik Setup?
Ik ben voornemens 'm morgen te bestellen bij mobile harddisk.nl, kost daar 300 euro zonder hd. Zoek er alleen nog een (stille!) harde schijf bij. Kan kiezen uit deze 15 . Wil er eentje van minimaal 1 tb - welke raden jullie me aan?
Verwijderd schreef op donderdag 22 januari 2009 @ 22:57:
Zou voor de Western Digital WD1000FYPS RE2-GP gaan. Als je die niet gebruikt wordt gaat tie terug naar 5400 rpm, dus minder warmte.
EDIT: sorry voor de 2 replies. Weet ook niet hoe dit kan??
[ Voor 5% gewijzigd door Verwijderd op 22-01-2009 23:32 ]
  • Oxellaar
Zou als ik jouw was voor een WD Green Power gaan.
Zijn heerlijk stil, echt bijna onhoorbaar.
Is wel 7200rpm maar wordt totaal niet warm.
En gebruikt weinig stroom, al maakt het weinig uit of je nu 16 of 13 watt gebruikt.
Maja alle beetjes helpen.
Heb zelf deze erin, bevalt goed
[ Voor 9% gewijzigd door Oxellaar op 22-01-2009 23:35 ]
  • Borromini
Borromini
Mislukt misantroop
@ SwiftGLX:
De WD10EACS bedoel je? Die draait standaard op 5400 RPM. Er is geen enkele HD in de handel van WD die 'dynamisch' opschaalt, hoewel hun promotalk daar wel verwarring over blijkt te scheppen (en heel wat shops dus niet weten wat ze in hun specificaties moeten zetten).
Even ter verduidelijking:
* WD10EACS = 1 TB S-ATA HD 5400 RPM Green Power
* WD10EADS = 1 TB S-ATA HD 7200 RPM Green Power
[ Voor 20% gewijzigd door Borromini op 22-01-2009 23:40 ]
  • simonanton
dejay schreef op donderdag 22 januari 2009 @ 21:38:
Werkt bij mij ook niet altijd even goed. Geluid en beeld niet altijd sync enzo.
Top 50 doet het ook niet.
Althans nu. Maar omdat JvdS er continue aan werkt kan het morgen anders zijn. :-)
Verwijderd schreef op donderdag 22 januari 2009 @ 21:59:
Moet ik eerst iets op de PC installeren om dit te kunnen? (sorry voor de NOOB vraag)
  • Ortep
Ortep
Verwijderd schreef op vrijdag 23 januari 2009 @ 00:23:
En je NMT heeft toegang tot die share? Username? Password? Probeer eens je 'guest' accont open te zetten zonder password. En geef 'guest' ook toegang tot de share.
Simpelweg een share maken is hetzelfde als zeggen: Ik heb een plek waar anderen bij mogen. Maar je vertelt niet wie de anderen zijn en je geeft ze ook geen sleutel
  • Ray
Ray
Borromini schreef op donderdag 22 januari 2009 @ 23:36:
@ SwiftGLX:
mmm ik dacht dat de eads ook 5400 rpm was....heb zelf nog getwijfeld tussen deze 2 en gekozen voor de eads vanwege het feit dat deze 32 mb cache heeft en de eacs 16 mb. Nou weet ik niet of dat enigzins uitmaakt in de pch maar ze waren even duur en ik dacht dat er verder geen verschil in zat
  • Rubert
  • Laatst online: 22-11 19:50
Ik heb hem zelf overigens besteld via biosscoopstoelen.nl. €259,- incl. BTW en verzendkosten.
Heb hem gister binnen gekregen, dus vanavond maar eens mee spelen.
Zal vandaag alleen nog even een harde schijf uitzoeken.
Dank voor de link. Ik zit nu niet thuis om het uit te proberen, maar op de pc zie ik diverse pagina's als een soort afbeelding binnenkomen. Het vereist wel het intikken van de hele url (dus incl http://www.....) heb ik gemerkt. Zal vanavond eens uitproberen of het prettig werkt op tv/hdx.
Hoe vaakt loopt jullie PCH vast? Ik heb elke dag wel 1 of 2 keer dat ik hem even aan en uit moet zetten met de Remote omdat hij niets meer doet..
Misschien wordt hij toch te warm?
Had trouwens NIEMAND mij even kunnen vertellen dat er rechtsonderin in Clutch een knopje zit? :( :( Ik moest er speciaal een topic voor openen op NMT.com. Beetje jammer.
*Volgende keer graag de edit-knop (Afbeeldingslocatie: http://tweakimg.net/g/forum/images/icons/edit.gif)gebruiken.
[ Voor 44% gewijzigd door een moderator op 01-02-2009 11:57 ]
  • wiene
  • Laatst online: 26-11 22:23
Verwijderd schreef op vrijdag 23 januari 2009 @ 12:02:
Bij mij loopt hij niet vast tijdens het gebruik. Wel merk ik dat als mijn receiver en/of tv nog niet op het goede kanaal staan dat de PCH geen beeld meer geeft. Hij loopt niet vast kan hem nog wel aan en uit zetten. Tv mode lukt dan wel niet. Uit en aanzetten geeft weer beeld.
  • Twan V
  • Laatst online: 10-11 12:50
Twan V
...en er stralend uitzien
Ray schreef op donderdag 22 januari 2009 @ 19:52:
Ik ben voor deze gegaan, maar wil je zeggen dat deze geen DTS Downmixing heeft? Er zit toch (ongeveer) hetzelfde bord in als in de PCH?
Blaat het niet dan schaadt het niet...
Reflex Discoshow - Het beste wat je bruiloft kan overkomen
I-Fect schreef op vrijdag 23 januari 2009 @ 12:06:
Als topics openen daar voor jou net zo makkelijk gaat als berichten posten hier, dan moet dat geen probleem geweest zijn, toch ;) ?
Maar: wat is Clutch? En had je daar een vraag over gesteld dan?
En terugkomend op de bird-scene in Planet Earth: de 1-1 rip van de blueray versie werkt vlekkeloos. Ter herhaling: heb hem zelf via een gesharede, gemounte-blueray-iso afgespeeld en de scene draaide zonder haperen (zat een d-link DIR655 router tussen, host is een pc met xp-pro rop). Een andere versie welke was geconverteerd om te kunnen draaien op een ps3 draaide wel met haperingen (file stond in dat geval direct op de hd in de pch).
Op poort 8077 draait een Torrent service, de GUI van dit ding heet Clutch :) Volgens mij heet de app zelf Transmission.
Okay, ik moet dan ook maar eens ergens de B-Ray versie op weten te snorkelen :)
Dat Clutch ding gebruikt Port 51413, moet ik die nog speciaal enablen op mijn Router? Probleem is dat ik een Duitse Router heb.. :P Omdat ik in Duitsland zit.
Afbeeldingslocatie: http://i42.tinypic.com/2ljn8ki.jpg
Zo goed? Bij Auswahl kan ik kiezen uit WEB/FTP/TEL-NET server.. heb ik nu blank gelaten.
Bij protocol TCP/UDP/ESP/GRE. Die staat op TCP.
[ Voor 48% gewijzigd door Verwijderd op 23-01-2009 12:42 ]
wiene schreef op vrijdag 23 januari 2009 @ 12:06:
Hm, ik heb het soms tijdens het gebruik dat ik hem aan/uit moet zetten..
Twan V schreef op vrijdag 23 januari 2009 @ 12:10:
Technisch is het mogelijk ja, maar iStar heeft geen licentie. Popcorn Hour wel.
[b][message=31395737,noline]
Let wel dat je alleen de 'hoofdbestanden' af kan spelen van een (geripte) blueray (in de map: stream) en dus geen menu e.d. hebt.
Gebruik zelf geen torrents, maar alleen de usenet functionaliteit. Heb verder in mijn router niets in hoeven stellen of poorten hoeven te openen/forwarden.
Lullig vraagje: zit er een hdmi kabeltje bij de A110?
  • arutten
  • Laatst online: 09:26
Verwijderd schreef op vrijdag 23 januari 2009 @ 13:40:
Ja, er zit een 1,5m lange HDMI kabel in de doos.
AMD Ryzen 7 9800X3D NVIDIA RTX 5080
  • Punkbuster
  • Laatst online: 21-11 19:47
hebben jullie misschien een link voor PCH-A110, ( ik heb heb nu 3 dagen ) en ik wil downloaden via newsserver, nzb get heb je daarvoor ofzo?
alvast bedankt mede tweakers.
automation fanboy
Punkbuster schreef op vrijdag 23 januari 2009 @ 13:42:
Zorgen dat je op Usenet komt, dan zorgen dat je aan NZB bestanden komt, die uploaden naar je A-110. Succes.
  • Royz
  • Laatst online: 25-11 10:51
Royz
Kleurenblind!!
arutten schreef op vrijdag 23 januari 2009 @ 13:41:
En ik moet eerlijk zeggen dat ik de kwaliteit vrij goed vond eigenlijk
Fotografie kanalen: Website - Royz.nl | YouTube - @Royz.nl | Instagram - @Royz.nl.
  • mno
  • Laatst online: 08:01
mno
NZBGet wordt meegeïnstalleerd als je vanuit het PCH-maintenance menu de NMT-APPS installeert. Je moet dus wel een HD in je PCH hebben zitten. Voor informatie over hoe je NZBGet vervolgens instelt, zie: http://www.networkedmediatank.com/showthread.php?tid=7035
Gewoon rösti
  • HuMon
  • Laatst online: 18-11 19:00
Ik heb zelf een HDX, die de eerste week wel eens vastliep. Ik heb toen enkele instellingen gewijzigd, o.a. de audio over HDMI (die standaard AAN staat) UIT gezet.
Die tip vond ik hier: http://www.networkedmediatank.com/showthread.php?tid=12836
Geen idee of het echt de oorzaak was, maar ik eigenlijk geen vastlopers meer gehad...
[ Voor 3% gewijzigd door HuMon op 23-01-2009 14:12 ]
  • Twan V
Twan V
Verwijderd schreef op vrijdag 23 januari 2009 @ 13:20:
Ik maak gebruik van de Philips 37PFL9632 (link) en voor zover ik kan vinden, kan deze met dts over hdmi overweg.
Klopt en/of kan dit en doet mijn tv de decoding, of praat ik nu echt poep?
  • qless
qless
...vraag maar...
Twan V schreef op vrijdag 23 januari 2009 @ 14:48:
Als jouw TV dts over HDMI snapt dan doet jouw tv de decoding ja
Website
  • Punkbuster
mno schreef op vrijdag 23 januari 2009 @ 13:54:
dank je wel. hier heb ik wat aan. :*)
automation fanboy
Die Torrent app is wel echt waardeloos op de PCH. Het gaat _enorm_ traag.. kom niet boven de 70KB/s uit, terwijl er zoveel aanstaat dat dat toch zou moeten gebeuren. Op mijn PC gaat het met uTorrent prima.. iemand enig idee waar het aan ligt?
  • qless
qless
...vraag maar...
Verwijderd schreef op vrijdag 23 januari 2009 @ 15:57:
Ding is maar 300 mhz ofzo, met 256 Mb ram...Het is dan ook een extratje dat je kan bittorrentten
Website
qless schreef op vrijdag 23 januari 2009 @ 16:10:
Oh. Dus gaat het daarom traag? En als je Usenet gebruikt, gaat hij dan wederom zo traag? Wat voor downloadsnelheden halen jullie op dat ding?
Verwijderd schreef op vrijdag 23 januari 2009 @ 16:12:
NZBGet downloadt hier gemiddeld met 1200 kb/s. Misschien is het aantal connecties te beperkt met de PCH, weet dat je daar op de pc wat voor in kon stellen, maar dat is al weer lang geleden dat ik daar wat mee gedaan heb...
  • qless
qless
...vraag maar...
Verwijderd schreef op vrijdag 23 januari 2009 @ 16:23:
Meeste nieuwsservers laten maar beperkt aantal threads toe (mijn provider maar 2, ewaka 8 )
Nieuwsgroeps is voor downloaden minder cpu belastend dan bittorrent, alleen het unrarren/unparren is wel heel zwaar
Website
Iemand anders die wel met Torrent download op de PCH? Zoja; wat zijn jouw ervaringen mbt de downloadsnelheid?
[ Voor 34% gewijzigd door Verwijderd op 23-01-2009 18:58 ]
Pagina: 1 ... 11 ... 35 Laatste
Kijk voordat je een vraag stelt eerst even op [Wiki] Network Media Tank
Bij deze nogmaals de aansporing om nieuwe onderwerpen in separate topics te plaatsen. Dit topic zal op termijn gesloten worden.
