https://noxiouspl.uk/
http://paradigit.nl/article2.php?id=13&group=192Noxious schreef op woensdag 06 mei 2009 @ 15:56:
Misschien geef ik het nog een poging met een losse pen:
http://www.informatique.nl/885179/wacom-graphire-4-pen.html
Of ga ik weer op zoek naar een 2e handsje. Voor een nieuwe is er voorlopig nog geen geld
Prijzen vallen toch nog wel mee?
Si vis pacem, para bellum
First I started sketching, get a little loose and just slap on a couple of thoughts.
Started out with the central figure, a Loomis figure with armor added. It was my guideline for the overall style and look, but very rough and first try.
After that, I started work on the thigh pad right next to it on the right. However I found it quite nice to look at, I wanted a more tribal look to it, and went from the rough sketch/proof of concept on the left to the next version, right hand side of the paper. That was the outline I wanted for my thigh pad.
Then I looked at the initial design, and back to my thigh pad. I thought the chest plate could use more edge, and started sketching the version that is seen upper left.
The first version of the thigh pad may be salvaged as part of the back armor, but I'm not sure yet.
The rest is just me doodling and try to find the right look.
Now I've got the outline for the thigh pad, I thought it was time to render a full scale one on a full A4 paper.
Result:
I wanted a mix between P1, P2, Terminator and generic tribal armor. I thought I succeeded pretty well.
I went back to the initial sketch and drew up a full scale chest plate loosely based upon that version.
However I kept the 80's vibe, I combined it with a more tribal look, wear and tear. When I compared thigh pad with this chest plate, I sighed and realised I had to re-do the thigh pad.
In this version I kept the shape, but I damaged it and roughed it up more.
Now, you might wonder why the fuck I just draw lines instead of shading the thing properly.
One word: photoshop.
(Still WIP, just a couple of hours in. Color to follow shortly, same for chest plate)
I hope you all like it, and do leave critiques.
So you start dicking around in Photoshop after you've done the shading, and this is the best you can come up with.
Taking the lessons learned on that one to the chestplate, you move on. Cursing yourself for not sticking to the lines-only-design (since it makes it that much harder to use the magic wand to mask your shading)
Skipping right to the colored version:
Looking back at the thigh pad made me all "meh", so I loaded the file back up again and did a quick and dirty job to match the coloring better, resulting in this piece:
This speed suits me alright, so expect more updates soon
www.avpnews.com
Prima tekeningen, maar aan de zijkanten missen ze diepte, waardoor ze alsnog vrij plat lijken, zonde.
Pong is probably the best designed shooter in the world.
It's the only one that is made so that if you camp, you die.
www.avpnews.com
hey leuk trouwens jongens.. tijd geleden dat er in dit bericht wat gepost is
Ik heb zelf nog 2 speedy's gemaakt die ik nog wel ff zal posten vanmiddag
Wat betreft blurry en dergelijke: het is gewoon een vrij glad iets, en ik zou niet weten hoe ik het beter kan renderen.
www.avpnews.com
Weet iemand waarom er een rare gele kleine gloed bij de lippen zit rond zwarte omlijning ik krijg het niet weg ?!
*edit* vergeten.
Ik gebruik Illustrator
[ Voor 8% gewijzigd door 42dpi op 02-06-2009 19:23 ]
Wat doet Ctrl+W ook alweer?
Humankind… be both.
Star Wars Awakens | Instagram
Ik was vergeten bij te zetten ik gebruik illustrator.Spike_wolf schreef op dinsdag 02 juni 2009 @ 19:06:
Photoshop outerglow per ongeluk aangezet?
Dan had hij er wel even boven mogen zetten dat ie te lui was om te vertalenkrvabo schreef op maandag 01 juni 2009 @ 21:46:
Het is gewoon een Nederlander hoor, maar te lui om z'n copy/paste van een ander forum te vertalen denk ik.
Verder over dat blurry zijn, je probeert het met die textures toch juist verweerd eruit te laten zien, dan is het dus niet meer glad. Kijk maar naar roest, dat glimt niet meer... maar ik bedoel meer dat je textures gewoon niet scherp meer ogen en dat de shading niet echt diepte en dynamiek toevoegt.
Maar ik zal de komende tijd eens gaan oefenen om er wat meer diepte in te krijgen, al vind ik dit al mijlen beter dan het gewoon "plat" inkleuren.
www.avpnews.com
[ Voor 11% gewijzigd door RoyK op 03-06-2009 01:02 ]
Wel een klein foutje, bij de eerste plaatje op de boom onderin zit een 'vierkant' blokje wat er niet hoort.
@skullsplitter, bij de tightpad heeft het 'bolletje' rechtsboven een verkeerde schaduw, hierdoor lijkt het alsof hij boven de rest (het schild) zweeft. als je het vergelijkt met de andere knopjes.
[ Voor 19% gewijzigd door ZpAz op 03-06-2009 08:48 ]
De meeste mensen deugen!
Hij is nog in nieuwstaat, de pen ook
Heb je voor die bovenste een achtergrond genomen van bergen en daar overheen gebrushed? De bergen zien er vreemd uit. Verder net resultaat voor een uur brushen.RoyK schreef op woensdag 03 juni 2009 @ 01:01:
Hier 2 speedy's gedaan van het weekend. Getracht ze binnen een uur te maken. Wat brushes oefenen en kleur gebruik. Begonnen met een willekeurige foto van een dagje uit, kleuren door elkaar gehusseld en gaan.. De bovenste heb ik in de tuin gedaan onder een parasol. Ik zag voor 50 procent wat, de rest is op de gok hihi, nog redelijk uit de verf gekomen denk ik zo
http://hawvie.deviantart.com/
Hier op t.net in de V&AD-rez schreef op woensdag 03 juni 2009 @ 12:54:
hoe heb je dat weten te regelen?
Geluk moet je soms hebben
De bovenste was een foto van wat stenen in een branding van een zee.. ik heb de kleuren gebruikt uit de foto. Een klein stukje defence.. deze tekening heb ik gemaakt in de tuin, onder de parasol. Het tekent niet echt lekker..je ziet de helft niet van wat je doet.HawVer schreef op woensdag 03 juni 2009 @ 13:10:
Begin nu ook beetje de burn / dodge tool te gebruiken maar ik krijg nog steeds niet het gewenste resultaat wat ik wil. Potlood tekenen op papier gaat nog steeds beter af.
Living in Australia! - Ja, ik heb dyslectie
Helaas werkt het record programma een beetje kut. Het lijkt er op dat er ergens een conflict is..want photoshop draaid namelijk voor geen meter meer zodra ik op record druk
Alle zwarte getekende lijnen of nou met pen/cil tool is of paintbrush ik krijg zo vreemde gelige omlijnen.
Hier gebeurd het ook zie grote zwarte streep.
En bij een screenshot zie je het niet meer
Ik heb niks lopen instellen of lopen kloten.
Volgens mij moet ik even goed naar mijn Scherm drivers en kleuren profile gaan kijken.
[ Voor 19% gewijzigd door 42dpi op 04-06-2009 00:32 ]
Was een pentekening, is gefotografeerd en vervolgens alles helemaal zwart gemaakt, ik zal morgen eens vragen of me vriendin (die hem een beetje bijgewerkt heeft en zwart gemaakt op de pc) me de foto wil sturen.
de draak is niet echt mooi geworden maar ik moest er per se een monster bij doen. het schip en het eilandje vind ik persoonlijk het beste deel. Door de pc is btw nog de kleine sloep voor het schip onduidelijk geworden (was hij al maar nu zie je hem helemaal niet meer)
@M4rius, leuk geworden! Misschien had ik zelf voor de linker camera gekozen om als hoofd te gebruiken, maar totaal plaatje vin dik hem geslaagd!
Leuk concept, en netjes uitgewerkt ook. Deze digitale versie is wat haperig, ik ben benieuwd hoe het origineel er uit ziet.
Misschien is het wat om zelf met Photosho/Illustrator/Painter de tekening te digitaliseren?
Hier weer eens wat van mijn kant:
Jessica Drew, imo the one and only Spiderwoman.
De schets heb ik hier eerder al gepost geloof ik, nu ben ik bezig met de kleuren.
C&C is welkom
Humankind… be both.
Had ergens een schets liggen, ooit eens getekend in een saaie les. Met de bedoeling die thuis verder uit te werken, maar nu ik van school af ben heb ik al mijn zooi weg gegooid. (waar dat blad waarschijnlijk tussen zat) Nu weet ik nog wel wat ik geschetst had, dus ben ik opnieuw gaan tekenen!
Het haar is een place holder en het vuurtje een impuls idee waar ik zojuist op kwam. Schaduw heb ik al een beetje in blauw uitgewerkt. (zal niet op alle plaatsen kloppen)
Oplettende kijker ziet dat haar linker hand een vinger mist.
Make something idiot proof, and someone will make a better idiot.
Verstand op nul en nadenken!
Wat voor tabblet gebruik je eigenlijk als ik vragen mag?RoyK schreef op woensdag 03 juni 2009 @ 01:01:
Dezelfde als mijZpAz schreef op vrijdag 12 juni 2009 @ 22:49:
Doen er trouwens mee met de Daily Sketch op cgtalk?
Leuk Forum..
Vraagje.. ik wil graag een tekentablet aanschaffen maar weet niet welke goed zijn om mee te tekenen.
hebben jullie ervaring.. kunnen jullie me een adviseren plus tekening erbij? Dank jullie!!
een tekeningetje gemaakt door mij... (foto)
en nog een..
[ Voor 16% gewijzigd door Verwijderd op 14-06-2009 13:06 . Reden: verkleinen fotos ]
Je weet wel, die rode balk die er onder staat
Hoi ZpAz, ik maak gebruik van een wacom cintiq 12". Hier voor had ik een Intuos3. Deze heb ik achteraf met veel spijt verkocht.ZpAz schreef op vrijdag 12 juni 2009 @ 22:49:
ps, ik doe niet mee aan daily sketch. Zou ik eigenlijk best eens kunnen doen.. Ik komt helaas niet zo aan mijn tekenuren de laatste tijd.
Oke, ik heb het gelezen.. maar is niet bepaald hetgene wat ik bedoel..Borgoth schreef op zaterdag 13 juni 2009 @ 23:58:
In dit topic staan zo'n beetje de meeste voor en nadelen van types wacoms. Staat ook netjes in de start post vermeld hoor.
Als ik op Youtube kijk kan ik eigenlijk geen normale (gedailleerde) tekeningen vinden van een bamboo fun.. alleen strip.. kun je er wel gewoon mee tekenen? heb er een nodig waarmee ik levensecht kan tekenen bij wijze van.. Kom je dan wel in categorie bamboo, bamboo one, bamboo fun of heb je echt een intuos nodig?
Nergens tekeningen als bewijs op dat forom stukkie ofzo
Tja dat is de stijl van de mensen die er mee tekenen. Het tablet vervangt gewoon de muis, verde niet zo heel veel bijzonders (op de drukpunten enzo na).Verwijderd schreef op zondag 14 juni 2009 @ 13:10:
Nergens tekeningen als bewijs op dat forom stukkie ofzo.. ja strip
.. nja..
De stijl hangt af van de tekenaar, niet het tablet
Ook met een bamboo fun of een tablet van 20 tientjes van trust ofzo kun je levensecht tekenen, mits je het talent ervoor hebt.
Humankind… be both.
Mensen, tekenen doe je met een pen in je handen. Of dit nou gebeurd op een bambo of een intuos of een cintiq, maakt geen verschil. 512 druklevels of 1024 druklevels.. je tekening wordt er niet minder mooi van. toegegeven, de duurdere modellen hebben een paar extra's zoals de hoek herkennen waar je je pen in houd.. wat je kwast beïnvloed. Maar onthou altijd.. programma's zoals photoshop of een tekentablet "are just tools"
Als je een tablet koop, koop een wacom. En als je nog een beginner ben koop lekker een bambo en kijk hoe het je bevalt. Je kan dan voor 7 tientjes al lekker beginnen ipv 350 euro met de vraag of je het wel leuk vind of niet!
Ik denk dat je geen bambo tegen komt op youtube omdat deze mensen vaak al verder zijn in het digitaal tekenen. Levensecht tekenen door ander materiaal te kopen.. ? Teken je ook beter met een bryunzeel potlood dan met een ikea potlood? Laat je niet zo beperken met deze gedachten. Koop lekker een bambo en begin! en als je niet weet hoe je van je geld af moet komen koop je een Intuos4 A5 model.Verwijderd schreef op zondag 14 juni 2009 @ 13:10:
.. nja..
Tekenen zoals met een potlood zal het nooit worden. Je blijft immers naar je beeldscherm kijken en niet naar je tablet. (als je het eenmaal gewent bent) Wat het dichtste bij komt is een Cintiq, maar dat is natuurlijk ook geen papier. (en sterves duur voor iemand die niet eens weet of het wel wat is.)
Digitaal tekenen is anders dan met potlood en papier. Je zult het echt zelf moeten uitproberen of het voor jou dicht genoeg bij echt tekenen komt. Je zou kunnen kijken of je er een van familie/kennisen/vrienden kan lenen. Als dat niet gaat zou ik voor een A5 gaan. A6 is leuk voor muis vervanging, maar niet groot genoeg voor tekenen. De A4 lijkt beter voor tekenen, maar wat nu als het niet bevalt? een A4 tablet kost 400 euro, Beetje zonde van het geld imho.
De vorige versie Wacom's zijn nu toch mooi aan 50% van de originele prijs te koop, dus voor de prijs hoef je het niet te laten. Een Wacom Intuos 3 A4 voor 220 euro incl. 2 jaar garantie
Ben nu met dit bezig:
Ik heb de bamboo pas een paar dagen en ben geen andere tekentablets gewend maar ik moet zeggen dat hij me goed bevalt. Ook het formaat heb ik geen probleem mee, als ik normaal op papier teken ben ik daar ook mee aan het schuiven en is het werkelijke gebied waarbinnen mijn pen/potlood beweegt niet groter dan een A6, nu werk ik ingezoomed en scroll ik de tekening over het scherm ipv het schuiven met papier onder mijn pen.
Even afwachten wat ik ga nemen..
of een bamboo fun medium of een intuos3 A5...
Scheelt niet heel veel kwa prijs.. miss even kijken welke dingen duurder zijn met bijbestelling ed.
Eerst even werken deze vakantie en dan wil ik er zeker eentje kopen.
Wat voor een bamboo heb jij -db-?
Groetjes..
Vanmiddag naar mijn oude school gegaan om mijn schoolexamen tekeningen van vorig jaar op te halen.
"Imaginaire Architectuur"
Geïnspireerd door Escher (voor het gemak 2
Ik zou zeggen, scan ze in en kleur ze digitaal in
ik heb geen A3 scannerRoyK schreef op dinsdag 16 juni 2009 @ 08:40:
Gaaf M4rius, lekker vreemd!
Mijn grootste probleem met digitaal tekenen is dat ik gewend ben om mijn papier te draaien als ik schuine lijnen moet teken etc. Bij een tablet gaat dat stukken moeilijker omdat je bij draaien van je wacom eerst moet kijken waar je pointer ook alweer was.
[ Voor 27% gewijzigd door Verwijderd op 16-06-2009 18:12 ]
Niemand?Spike_wolf schreef op zaterdag 06 juni 2009 @ 15:09:
C&C is welkom
Humankind… be both.
M4rius, Photoshop CS4 heeft een kantelbaar canvas. In Painter X is dat al heel lang aanwezig. Ik scan A3 tekeningen in 2 keer. De ene kant en dan de andere kant. Even in photoshop aan elkaar plakken en hopla!!Verwijderd schreef op dinsdag 16 juni 2009 @ 17:51:
ik heb geen A3 scanner. Maar wie weet dat ik de foto's optimaliseer en inkleur als ik tijd heb.
Je hebt ongeveer hetzelfde "probleem" als ik heb bij mijn tekening "imaginaire architectuur". Doordat je contouren gebruikt worden de voorwerpen gestyleerd en verdwijnt de plasticiteit van een voorwerp, in dit geval de vrouw. Je probeert de plasticiteit al wat te verbeter door middel van de schaduwen dat lukt ook. Om dit nog meer te verbeteren zou je bijvoorbeeld kunnen beginnen bij de vouwen in haar pak enkel met schaduw en highlights ervan weer te geven in plaats van een zwarte ruwe lijn.
Iet over de anatomie, haar rechter schouder zit op een andere hoogte dan de linker. Dat kan komen door haar contra-pose maar dan zouden ze horizontale lijnen iets schuiner moeten staan.
Good luck
Klinkt wel erg leukn0isH schreef op woensdag 17 juni 2009 @ 14:07:
Zijn er hier ook mensen die wel eens komen op websites als iscribble.net, ratemydrawings.com of een paintchat? Dit zijn websites waar je tegelijk op een canvas kunt werken met helaas maar beperkte tools. Ik vind het altijd wel leuk om te zien hoe anderen aan het tekenen zijn of samen aan iets te werken.
Is het ook
Thanks, ik ga idd nog wat met de kleuren spelen.RoyK schreef op woensdag 17 juni 2009 @ 09:19:
Weinig commentaar van mijn kant. Misschien iets met de kleuren doen. Het is een beetje hard nu met de kleuren. hightlights, schaduwen...
Die zwarte lijnen zorgen idd voor een vreemd beeld, maar als ik de lijnen helemaal weg laat word het bij mij alleen maar een smurrie bendeVerwijderd schreef op woensdag 17 juni 2009 @ 12:35:
Good luck
De vouwen weg halen en alleen met schaduw/highlights doen doen is wel een idee, daar ga ik iig naar kijken, thanks
Humankind… be both.
De rest is natuurlijke zelf gemaakt.
Bron: ik werd vrolijke wakker
[ Voor 45% gewijzigd door 42dpi op 04-07-2009 05:47 ]
De mijne?RoyK schreef op maandag 22 juni 2009 @ 08:58:
hoe bedoel je? Tracen?
[ Voor 4% gewijzigd door 42dpi op 22-06-2009 10:27 ]
Omdat je zegt, regelrecht uit Illustrator..waarom het wiel opnieuw uitvinden
Ik bedoel alleen die veer, dat ik die geript heb. ik had er wel een nagemaakt half dan maar die zag er niet zo mooi uit.RoyK schreef op maandag 22 juni 2009 @ 11:22:
Ja
[ Voor 6% gewijzigd door 42dpi op 22-06-2009 14:02 ]
C&C is welkom
[Edit]
En deze heb ik vanochtend even in elkaar geflanst
Heb hier even geen grotere versie van, deze is genomen met een iSigh
[ Voor 27% gewijzigd door Spike_wolf op 22-06-2009 14:03 ]
Humankind… be both.
Spider women toch? hij is tof alleen de de bruin gele achtergrond vindt ik persoonlijke niet mooi.Spike_wolf schreef op maandag 22 juni 2009 @ 13:57:
Ik heb weer wat tijd gevonden om wat aan de kleuren te werken, heb nu de kreukels gemaakt met alleen schaduw kleuren, gene vaste lijnen meer:
C&C is welkom
[Edit]
Tweede is Indiana Jones?
[ Voor 21% gewijzigd door 42dpi op 22-06-2009 14:04 ]
Die achtergrond gaat ook niet blijven, ik vind het zelf altijd wel fijn werken om een achtergrond kleur te hebben die afsteekt tegen de kleuren van je objecten, en die niet egaal is. Maakt het inkleuren van je objecten fijner en makkelijker
Humankind… be both.
True, ik neem altijd een lichtere actergrond kleur licht blauw of groen.Spike_wolf schreef op maandag 22 juni 2009 @ 14:10:
Spiderwoman en Indy idd
wip's op een rij zijn hier te vinden:
http://1.bp.blogspot.com/...JgECe9Po/s1600-h/wips.jpg
ben zelf best tevreden. Helaas schiet de tijd me te kort deze maand. Ik heb ook geen tijd meer om hier mee verder te gaan. Op naar de volgende
De tweede heeft eh.. een gezicht wat de ene kant op gaat en de haarlijn de andere
Ziet er weer goed uit! zeker die wips erbij zijn intressant. Ik snap nog steeds niet dat je dit zo voor elkaar krijgt getekent. Hulde man!RoyK schreef op zondag 28 juni 2009 @ 23:39:
Zo, alweer even een tijdje geleden dat ik echt voor een prive tekening ben gaan zitten. Opnieuw voor een wedstrijd met als thema Gothic Beauty. Ik zat aan een lief babytje te denken die in gothic stijl zijn slaapje doet. Wat schetswerk bracht me tot deze tekening.
C&C is eventueel nog wel welkom, misschien dat ik over een tijd nog eens wat aanpassingen maak ofzo.
Humankind… be both.
gemaakt in Photoshop CS3 met een wacom intuos4
Greets Miel
Maar verder vind ik hem wel netjes.
oja, en is die ene poot niet wat erg groot ten opzichte van die andere? zo ver staat ie toch niet vooraan?
Maar, ik ben het ook met Tjeemp eens: hij lijkt nog niet helemaal af. Misschien ben je het daar niet mee eens, maar misschien wel als je hem een keer spiegelt. Dan zie je opeens de delen waar je je tijdens het tegenen op blind hebt gestaard. Ik vind hem iets te weinig zwart hebben. Hij blijft overal wat flets.
Nogmaals - ik vind hem echt prachtig, ik heb zelf een poster van Earth Dragon hier hangen, van Peter Pracownik - als je verder gaat in die richting zie ik je tekeningen graag tegemoet!
Overigens nog wat te zeggen over het Copyright-stukje: én copyright én (c) is gewoon dubbelop. Bovendien is het erg nietszeggend, want op jouw tekening berust gewoon auteursrecht - copyright is niet hetzelfde en daarvoor moet je zover ik weet je ontwerp eerst laten registereren of patenteren. Het zegt nu dus eigenlijk niets, sorry
Ik zou gewoon je naam eronder zetten, en wel op een plek die niet gemakkelijk weg te poetsen is. Je zou wat kleine gedetailleerde struikjes erachter kunnen zetten, of samen met je handtekening iets doen. Je handtekening zou wel met een wat dunner penseeltje hebben gemogen. Het lettertype van je naam zou ik zo houden, erg stijlvol.
[ Voor 7% gewijzigd door Dark Blue op 04-07-2009 18:21 ]
heidiulrich.nl | adventura.nl : rugzakavonturen | pathwise.nl : prepping geeks to get jobs
Kijk, dat de grote meesters dat deden, a-la. Maar deze tekeningen, hoe mooi ze soms ook zijn, zijn geen schilderijen.
Je naam op de tekening VERPEST de hele tekening, imho. Het is gewoon zonde. En elke naam valt er wel af te halen met een half uurtje photoshop en wellicht zelf wat aanstippen.
Zelfs al zouden mensen mijn tekeningen gebruiken, dan zou ik me (vooralsnog) vereerd voelen dat mensen mijn creatie mooi genoeg vonden om te gebruiken. Maargoed, ik doe het dan ook uit hobby.
Om eerlijk te zijn (nofi) vind ik je 'handtekening' of naam er onder zetten erg pretentieus.
Het gaat allemaal om de kleine dingetjes die iets in dat vreemde brein van je doen.
Verder vind ik de lucht erg mooi gedaan! En hoe half doorschijnend de vleugels zijn. Ga vooral zo door
Ik begrijp niet dat mensen klagen dat iemand een krabbel er op zet en dit vervolgens spiegelt tegen de groten in de kunst wereld. Dat is wel heel erg krom. Een beetje respect mensen voor elkaars werk svp, en een krabbel ala finish hoort er gewoon bij! Net als de slagroom op het gebak, het koekje bij de thee en de teenslippers bij gordon.
Dat mensen werk kopieren is helaas orde van de dag. Ik heb het zelf ook een keer mee gemaakt. Een tekening waar ik 30 uur werk in had zitten is in 2 minuten geript en ging vervolgens met de eer vandoor. Weinig plezier heb ik daar aan over gehouden. Helaas is dit niet te voorkomen tenzij je mega grote watermerken in je tekening plaats..wat weer een enorme afbreuk doet van je werkstuk (om te zien) Als tekenaar ben je wat dat betreft zo goed als vogelvrij. Het minste wat een tekenaar kan doen, en daar komt hij weer..is zijn werkstuk ondertekenen. Niet dat het helpt... maar daar komt de eer hen toe wat hen toe hoort te komen.
@ Tryfal, voor een eerste digitale tekening heb je het prima gedaan kerel! Ik neem aan dat je wel al enige photoshop / painter kennis bezit? Het spiegelen wat als tip is gegeven kan, maar werkt vaak eerder als er meerdere objecten aanwezig zijn die de aandacht vragen. In dit geval heb je een draak in het midden, dus spiegelen zal weinig effect geven. Je kan deze truuk wel toe passen als je dus iets wil vertellen aan de kijker. Ook een tekening wordt gelezen net als een boek..dus van links naar rechts. Zorg dat de leesrichting klopt.. dan klopt ook de rust in het bekijken. Het spiegelen is dan echt een hele belangrijke tool die je niet moet vergeten. Als jij tevreden met moet je het zo laten. Je kan nog even met de kleuren spelen via ctrl+b en de levels ctrl+l nog even na lopen voor iets meer contrast. Verder dikke pluim!
Toevallig ben ik ook met een draken tekening bezig. De maand juli staat in het teken van de "dragon rider" en dit is mijn werkstuk. Nog niet klaar..vandaag de schets ingescaned en uitgewerkt. Ik wil er nog meer detail in verwerken voordat ik hem in ga kleuren. Zo krijgt het meisje nog een echte princessen toeter en een stafje met ster in haar hand.. en komen er nog bloemen en vlinders..
Gisteren ook weer wat gedaan en ik zie dat mijn grootste probleem is: Photoshop en de Tools. Ik teken alles met 1 brush (varrieer wel in dikte en opacity), soms de burn en smuge tool. Probeer wel alles in grijswaarden te tekenen en dan met een color overlay de boel aan te passen.
Maar dan nog.. het blijft een bende
De 'grote meesters' deden dat waarschijnlijk ook al voordat ze 'groot' waren, denk je ook niet?krvabo schreef op zaterdag 04 juli 2009 @ 23:50:
Dat vraag ik me toch af, waarom plaatsen zoveel mensen hun naam op hun tekening.
Zolang een handtekening niet de halve tekening/foto/schilderij beslaat snap ik niet waarom je je zou storen aan een handtekening, mensen hebben tijd en energie gestopt in iets wat van hun is en om dat aan te geven zetten ze hun eigen naam (handtekening) erop, niks mis mee toch
The devil is in the details.
Ik heb het hier op de zaak ook al mee gekregen. Misschien komt het ook omdat je kleur mist. Het hele idee moet een beetje fantasie aanvoelen alsof je het enkel maar kan dromen. Ik denk als ik een hartje teken op het shirt en dan speelgoed toetertje en stafje mee teken is het opgelost.Stalllone schreef op maandag 06 juli 2009 @ 14:37:
@RoyK: goed dat je zegt dat het een princesje is, want ik dacht dat het een jongetje was(probleem los je wel op met toeter en het stafje denk ik. Maar toch verwacht ik een jurkje bij een princesje
Ik heb nog wel een hele leuke brush set voor je. Moet ik vanavond even op de computer kijken. Ik werk in ieder geval al een tijdje met deze set. Moet ik hem opzoeken voor je?
haha, ja het heeft er wel iets van weg heh..Noxious schreef op maandag 06 juli 2009 @ 14:26:
Haha doet me wel een beetje aan The Neverending Story denken RoyK
Oeh zou ik die brush set ook mogen vasthouden? Ik heb hetzelfde probleemRoyK schreef op maandag 06 juli 2009 @ 15:17:
Best wel ja
edit knop ftw
Die broek met riem is ook wat jongensachtig, maar op zich begrijp ik wel waarom je dat zo gedaan hebt.
Geweldige tekening verder, zoals altijd
Dat zit wel Schnorr.
Denk dat RoyK dat niet zo'n probleem vind.Noxious schreef op maandag 06 juli 2009 @ 17:09:
Word jou Cintiq ook warm RoyK? Mijnes best wel eigenlijk
@Stukfruit, ik zit er over na te denken om het gewoon als jongetje door te zetten. Als de mensen het toch zo zien heb ik daar op zich geen problemen mee.
De brushset voor de mensen die interesse hebben: http://rapidshare.com/files/22271789/Brush_Set.abr
Credits zijn voor Leventep: http://leventep.deviantart.com/
maakt prachtige tekeningen op een eigen manier.
Ik zie er ook een jongen in en denk dat dat eigenlijk ook toffer is. Jongetje + draak is
@ Tryfal.
Hele mooie tekeningen en voor de eerste x al helemaal. Ben het er wel mee eens dat er meer contrast in mag zitten. Denk dat als je alleen al een aantal highlights plaatst je echt een ontzettend mooie tekening hebt.
Je hebt dit ook al op zijn hals en hier zie je ook meteen een stuk meer diepte in.
Ik ga het bij een jongetje houden inderdaad. En ja, ik ga straks als ik klaar ben er een kleur overheen leggen. Werken in grijstinten is een leuke tactiek om later in te kleuren. Ik doe het voor een deel professioneel, maar helaas nog niet 100%. Dat zou ik graag willen doen. Voor een werkgever of freelance. Als ik maar kan tekenen.Verwijderd schreef op dinsdag 07 juli 2009 @ 11:08:
@ Roy k,
Ik zie er ook een jongen in en denk dat dat eigenlijk ook toffer is. Jongetje + draak isBij een meisje zou ik eerder aan een pony denken. Ga je het ook nog helemaal in kleuren? Ziet er iig weer geniaal uit. Doe je dit eigenlijk ook voor je werk of is het een overdreven uitgelopen hobbie ?
Met je eerste argument ben ik het eens. Ja, als je er een handtekening onder zet dan is het meestal af. 'Het recht'..'het recht', mensen denken al snel dat dingen hun recht zijn. Dit staat echt niet in de wet dus het is geen recht.RoyK schreef op zondag 05 juli 2009 @ 23:28:
Mensen, je naam op de tekening zetten maakt je eigen tekening AF! Iemand die 20 uur aan een tekening heeft gewerkt..de vader is van het ontwerp.. en deze met bloed zweet en tranen op digitaal papier heeft gekregen..heeft al het recht om daar zijn eigen kenmerk aan toe te voegen.
'Mensen', als je wilt discussieren mag je dat best wel op de man doen hoor. Ik had het over algemeen, jij hebt het over mijn opmerking.Ik begrijp niet dat mensen klagen dat iemand een krabbel er op zet en dit vervolgens spiegelt tegen de groten in de kunst wereld. Dat is wel heel erg krom. Een beetje respect mensen voor elkaars werk svp, en een krabbel ala finish hoort er gewoon bij! Net als de slagroom op het gebak, het koekje bij de thee en de teenslippers bij gordon.
Ik klaag niet, ik vraag het mij af. Ik heb, persoonlijk, nog nooit mijn handtekening onder een tekening gezet. Maargoed, het langst dat ik ooit met een tekening bezig ben geweest is een uur of 12-14.
Ik had het juist niet over dit laatste werk wat hier was gepost, want dit vond ik (wellicht met een uitzondering ertussen) toch allemaal zeer sterk getekend. Ik had het meer over het algemeen. Ik kom soms echt verschrikkelijk slechte tekeningen tegen waar mensen een enorme handtekening onder zetten. De handtekening is vaak nog mooier dan de tekening zelf.'Een beetje respect voor elkaars werk'
Ik kan me voorstellen dat je dat vervelend vind, en terrecht overigens, maar je kunt er altijd voor kiezen om je tekeningen NIET openbaar te maken.Dat mensen werk kopieren is helaas orde van de dag. Ik heb het zelf ook een keer mee gemaakt. Een tekening waar ik 30 uur werk in had zitten is in 2 minuten geript en ging vervolgens met de eer vandoor. Weinig plezier heb ik daar aan over gehouden.
Hieronder is overigens niet direct op jou gericht, maar algemeen
Er is een opvatting die ik ooit heb gelezen of gehoord, ik weet niet meer waar, die stelt dat artistieke mensen hun (levens)waarde halen uit de acceptatie van hun werk. Ik denk dat dit ergens wel klopt.
Het is natuurlijk fijn om als artistiek iemand je werk te kunnen laten zien, maar je kunt er net zo goed voor kiezen om je werk niet te delen over het internet, dan kan het ook niet gestolen worden.
En daar is precies het punt wat ik duidelijk maak: Een handtekening is een vorm van een 'watermerk'. Het is de beeltenis van 'echtheid'. Als er een handtekening onder staat die afsteekt van de tekening (denk: witte letters op donkere achtergrond) dan verpest dit in mijn ogen de tekening.Helaas is dit niet te voorkomen tenzij je mega grote watermerken in je tekening plaats..wat weer een enorme afbreuk doet van je werkstuk (om te zien)
Pff als je tekeningen wilt rippen dan is die handtekening er in 90% van de gevallen binnen een minuut af. Photoshop met clone tool en wellicht even een brush er over: klaar.Als tekenaar ben je wat dat betreft zo goed als vogelvrij. Het minste wat een tekenaar kan doen, en daar komt hij weer..is zijn werkstuk ondertekenen. Niet dat het helpt... maar daar komt de eer hen toe wat hen toe hoort te komen.
Dat maakt meteen mijn punt sterk. In deze digitale tijd is het weghalen van een watermerk of handtekening een kleine handeling. Deze handtekening die er op staat verpest echter wel het kunststuk.
Dat weet ik niet, maar als ze op dat moment niet (bijna) minstens zo goed waren als de meesters ervoor dan zijn ze in mijn ogen net zo pretentieus als veel kunstenaars in deze tijdHahn schreef op maandag 06 juli 2009 @ 14:40:
Ik vind dat het de tekening verpest door het IN YOUR FACE-gehalte van een handtekening.Zolang een handtekening niet de halve tekening/foto/schilderij beslaat snap ik niet waarom je je zou storen aan een handtekening, mensen hebben tijd en energie gestopt in iets wat van hun is en om dat aan te geven zetten ze hun eigen naam (handtekening) erop, niks mis mee toch
Het zou wat zijn als iedereen zijn handtekening in een opvallende kleur op iets wat hij gemaakt had zou zetten.
Leuk, een oude eiken kast met in witte letters "Piet Heijnen"
En geweldig, je authentieke indiaans wandkleed met "Imala Jalon" onderaan.
Of de wandschilder die in kleine letters boven elke plint zijn initialen schildert in het zwart.
Kijk, in mijn ogen verpest een handtekening een kunstwerk omdat het zo goed als altijd opvalt. Als jij je handtekening leuk in de tekening kunt verwerken of niet te opvallend naar voren laat komen heb ik er ook niet veel tegen. Als het echter substantieel naar voren springt dan is dat imho gewoon slecht voor je algehele tekening.
Wat neem je het ook allemaal persoonlijk. Helemaal niet nodig. Ik praat inderdaad in het algemeen. Ik heb geen reden om op de man te praten. Ik vind dat een krabbel er op hoort.. jij niet...Prima. zet je er geen één onder je werk.
En je werk niet posten of openbaar maken zodat het ook niet gestolen kan worden. Tja.. wat dacht je van alle vliegtuigen niet meer laten vliegen? Kan er ook niemand meer een vliegtuig kapen. Een omgedraaide wereld heh vind je ook niet? Mensen moeten gewoon met hun tengels van ander mans werk afblijven. klaar.
Als je het mij vraag gaan we weer lekker tekeningen posten en daar over praten, ipv dit soort discussies die heen en weer gaan maar waar geen antwoord uit gaat komen. Doet afbraak aan dit draadje.
mee eens?
[ Voor 51% gewijzigd door RoyK op 09-07-2009 01:00 ]
als je goed kijkt naar wandschilderingen zit er in de meeste gevalllen wel een handtekening op, maar inderdaad, werk zoiets een beetje weg, dat werd ook vaak gedaan.Of de wandschilder die in kleine letters boven elke plint zijn initialen schildert in het zwart.
[b][message=32230509,noline]mee eens?
Eens is
M'n Samsung T220 komt er aan
Ze gebruiken het inmiddels wel voor authenticatie van echtheid, maar of dat de hoofdreden was om te ondertekenen weet ik niet.
Misschien kun je het ook wel zo zien als dat je wilt dat een schrijver zijn boek ondertekent of een artiest zijn album... wie weet
Dus vind in het geval van de tekening waar het nu over gaat prima dat er een handtekening onderstaat, vind hem persoonlijk alleen wel heel opvallend, dat hoeft dan ook weer niet.
Precies. Het is een stukje 'eer' . Je moet natuurlijk niet je naam 60 bij 40 cm op een doek gaan kalken. Gewoon netjes in de hoek.. beetje sierlijk. De finish op een tekening.Tjeemp schreef op donderdag 09 juli 2009 @ 09:58:
Volgens mij is het meer zo dat kunstenaars ooit begonnen zijn hun commissions te ondertekenen. Het is meer een soort van reclame voor je naam, ik zou het niet zien als middel om te zorgen dat het niet gestolen wordt.
@RoyK, ik heb af en toe wat zitten kloten in painter en photoshop (deze is volledig in photoshop gemaakt), maar dit is mijn echte fullcolor tekening. waar ik denk ik wel veel van leer is het diep instuderen van tekeningen van profs en bedenken hoe ze dat zouden doen en een beetje logisch erbij na denken
maar je maakt echt dope tekeningen man, niet mijn stijl maar wel erg mooi, wat voor studies heb je gedaan en doe je???
als ik weer wat heb laat ik het jullie wel zien.
Greets Emiel
ja, ik heb een grafisch lyceum achter de rug. Maar het tekenen heeft er altijd al ingezeten. Sinds mijn 6e jaar teken ik al actief..dus dat is al weer 24 jaartjes. Maar de laatste 5 jaar digitaal en heeft het ook een enorme vlucht genomen. Ik train om nog beter te worden
