[NAS] Conceptronic CH3SNAS / Dlink DNS-323 Deel 2 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 20 ... 22 Laatste
  • 247.808 views
  • Maverick
  • Laatst online: 20:30
ehuurman schreef op woensdag 21 januari 2009 @ 19:57:
cat /proc/partitions
major minor  #blocks  name
   7     0       5604 loop0
  31     0         64 mtdblock0
  31     1         64 mtdblock1
  31     2       1536 mtdblock2
  31     3       6336 mtdblock3
  31     4        192 mtdblock4
   8     0  488386584 sda
   8     1     530113 sda1
   8     2  487339807 sda2
   8     4     514080 sda4
start-usbstick.sh:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
#!/ffp/bin/sh
# PROVIDES: usbdisk
# BEFORE: LOGIN
# REQUIRE: SERVERS
. /ffp/etc/ffp.subr
# see
# "Attaching USB Storage to the DNS-323 for Linux Newbies & Dummies"
# http://forum.dsmg600.info/viewtopic.php?pid=3221#p3221
# usb-storage.ko module:
#  http://www.domaigne.com/download/dns-323/usb-storage.ko
name="usbdisk"
start_cmd="usbdisk_start"
stop_cmd="usbdisk_stop"
status_cmd="usbdisk_status"
usbdisk_mount_options="-t auto"
#usbdisk_mount_options="-t auto -o umask 0"
usbdisk_dev="sdb"
#usbdisk_dev="sdc1"
usbdisk_mountp="/mnt/usb"
usbdisk_start()
    insmod /mnt/HD_a2/ffp/custom/$(uname -r)/usb-storage.ko 2>/dev/null
    #insmod /ffp/lib/modules/$(uname -r)/usb-storage.ko 2>/dev/null
    #insmod /ffp/lib/modules/$(uname -r)/ntfs.ko        2>/dev/null
    # wait for disk...
    grep -w $usbdisk_dev /proc/partitions >/dev/null 2>/dev/null
    if [ $? -ne 0 ]; then
        let timeout=60
        echo "Waiting for $usbdisk_dev (up to $timeout seconds) ..."
        while [ $timeout -gt 0 ]; do
            [ $? -eq 0 ] && break
            sleep 2
            let timeout=${timeout}-2
        done
            echo "Failed. Did not find $usbdisk_dev in /proc/partitions."
            exit 1
        fi
    fi
    # mount it
    mkdir -p $usbdisk_mountp
    echo "Mounting /dev/$usbdisk_dev on $usbdisk_mountp"
    mount $usbdisk_mount_options /dev/$usbdisk_dev $usbdisk_mountp >$usbdisk_mountp/mount-error.txt 2>&1
        echo "Failed"
        cat $usbdisk_mountp/mount-error.txt
    fi
usbdisk_stop()
    mount | grep $usbdisk_mountp >/dev/null 2>/dev/null
    if [ $? -eq 0 ]; then
        echo "Unmounting $usbdisk_mountp"
        umount $usbdisk_mountp
    else
        echo "Nothing mounted on $usbdisk_mountp"
    fi
usbdisk_status()
    mount | grep $usbdisk_mountp 2>/dev/null
        echo "$usbdisk_dev is not mounted"
    fi
run_rc_command "$1"
Alleen regel 30 heb ik zelf tussengevoegd. Als ik deze regel via telnet uitvoer gaat het wel goed
je moet
usbdisk_dev="sdb"
Vervangen door
usbdisk_dev="sda2"
Prulleman schreef op woensdag 21 januari 2009 @ 11:55:
je kan wel een link maken van /mnt/usb naar /mnt/HD_a2/sdc1/ zodat je usb te benaderen is via explorer/ftp, maar je moet dan dan wel de log files laten schijven naar /mnt/usb, dan loopt het helemaal buiten de hdd om, behalve als je via explorer gaat benaderen.
Ik had dezelfde fout gemaakt met mijn nzb monitor folder, die had ik staan op de link /mnt/HD_a2/usb > geen spindown. monitor folder gezet op de mount dir /mnt/usb > wel spindown
Ok, ik heb hem nu gemount op /mnt/sdc1/ alleen hoe maak ik nu een link in HD_a2 naar de map zodat ik er met samba ook bij kan?
[ Voor 10% gewijzigd door Maverick op 21-01-2009 20:18 ]
PSN: DutchTrickle PVoutput
  • mrwolf
thanks, dat lijkt inderdaad te werken. Klopt het wel dat ik als ik nu ls geef op /mnt/usb dat ik dan alsnog de inhoud van HD_a2 krijg te zien?
# cd /mnt/usb
# ls
Backups         UPnP            fun_plug        temp
ChangeLog.txt   backup funplug  fun_plug.d      twonky
Downloads       ffp             lnx_bin         unpack
PACKAGES.css    ffp.log         mediatomb       usbstorage
PACKAGES.htm    ffp.old         mldonkey.old    usenet
README.txt      firmware        packages        www
  • Maverick
nee, dat klopt niet.. Weet eerlijk gezegd niet hoe dat kan.
  • Krypt
  • Laatst online: 05-11 11:08
Je partitions geeft je usb disk niet weer. Dus je kernel driver is niet geladen.
Verder kan je wel in die dir schrijven omdat het gewoon een directory is waar vervolgens een device aan gemount wordt. Maar aangezien er niets gemount wordt, zal je waarschijnlijk gewoon op je hdd aan 't werken zijn.
Verander je start-usbdisk.sh de volgende code:
naar
insmod /ffp/custom/usb-storage.ko 2>/dev/null
sda is je HDD, niet je usb. Dus daarom zie je de inhoud van je disk.
sda=1e schijf, sdb=2e schijf, sdc=3e schijf. Als je dus 1 disk erin hebt zitten + usb, dan is je usb sdb. Als je 2 disks hebt + usb, dan is je usb sdc.
[ Voor 18% gewijzigd door Krypt op 21-01-2009 21:12 ]
Pvouput live
  • RunaR
  • Laatst online: 26-09 17:23
RunaR
Maverick schreef op woensdag 21 januari 2009 @ 21:01:
Omdat het een mount is naar de harddisk. Volgens die tabel is sda2 zijn hardisk van 500GB. De usb is nergens te vinden. Voer eerst die insmod uit en daarna cat /proc/partitions.
Staat je usb-storage.ko wel in die directory: /mnt/HD_a2/ffp/custom/$(uname -r)/usb-storage.ko
/$(uname -r) wordt vertaald naar een directory met de naam van je huidige linux kernel. Staat je usb-storage.ko misschien niet in /mnt/HD_a2/ffp/custom/usb-storage.ko
.......eeeh, precies wat Krypt zegt
[ Voor 3% gewijzigd door RunaR op 21-01-2009 21:14 ]
ISS Detector en meer voor Android
  • Krypt
Precies zoals RunaR zegt.
Wist zelf niet wat die "uname -r" deed; weer wat bij geleerd.
Maverick schreef op woensdag 21 januari 2009 @ 20:18:
Je kunt een symlink aanmaken met
ln -s <Symlink verwijst naar> <Plaats van Symlink>
Bijv.
ln -s /mnt/HD_a2/Music /mnt/usb/Music
Deze maakt een symlink in /mnt/usb/Music aan die gedirect wordt naar /mnt/HD_a2/Music
[edit]
Heb trouwens net mijn smb.conf in /etc/samba aangepast. Even 't Volume_1 kopje gekopieerd en USB genoemd. Mountpoint aangepast naar /mnt/usb. Gesaved; en direct kwam er de share erbij. Ideaal. Direct ook maar Music, Video en Photo aangemaakt. Was minder werk dan ik verwacht had.
[ Voor 150% gewijzigd door Krypt op 21-01-2009 21:34 ]
Pvouput live
  • Maverick
Krypt schreef op woensdag 21 januari 2009 @ 21:12:
Bijv.
Euhm, je bedoelt je laatste zin andersom? dus een link in HD_a2/music die verwijst naar USB/music? Ik snap de volgorde niet helemaal :P (ik ga even googlen ;) )
Hm, als ik hem op /mnt/sdc1/ mount dan kan ik hem wel benaderen via putty en hij is ook echt gemount want ik zie de bestanden maar mijn webserver werkt niet :/
En hoe kom je aan dat bestand? bij mij zit ie er niet in
[ Voor 34% gewijzigd door Maverick op 21-01-2009 21:43 ]
  • Krypt
Nope; klopt zo. Alleen een ongelukkig voorbeeld.
ln -s /mnt/usb /mnt/HD_a2/usb
maakt een Symlink /mnt/HD_a2/usb aan die naar /mnt/usb verwijst.
symlink kan je trouwens weer verwijderen met "rm /mnt/HD_a2/usb"
Pvouput live
  • Krypt
Diegene die extra shares wilt aanmaken:
Hiervoor moet je de smb.conf aanpassen, echter wordt deze bij elke reboot overschreven. Dus we maken een script welke na een reboot de custom smb.conf overschrijft en de smb restart (misschien niet nodig, maar wel netter)
Kopieer de /etc/samba/smb.conf naar een plek op je hdd. Ik heb /mnt/HD_a2/ffp/custom gekozen.
Edit de smb.conf en maak onderaan een nieuwe entry aan
[ USB ]
comment =
path = /mnt/usb
valid users =
read only = no
guest ok = yes
oplocks = no
map archive = no
Spreekt wel voor zich neem ik aan. Sla deze smb.conf op, op je hdd.
Maak nu een nieuwe sh aan in /mnt/HD_a2/ffp/start. ik heb deze smbshares.sh genoemd.
#!/ffp/bin/sh
# PROVIDES: smbshares
# BEFORE: LOGIN
# REQUIRE: SERVERS
. /ffp/etc/ffp.subr
name="smbshares"
start_cmd="smbshares_start"
smbshares_start()
  /usr/bin/smb stop
  cp /mnt/HD_a2/ffp/custom/smb.conf  /etc/samba/smb.conf
  /usr/bin/smb start
run_rc_command "$1"
En dan nog executable maken en uitvoeren:
chmod a+x /mnt/HD_a2/ffp/start/smbshares.sh
sh /mnt/HD_a2/ffp/start/smbshares.sh start
Et voila; je hebt je nieuwe shares. Ook bij restart.
Pvouput live
  • Maverick
ik heb het exact zo gedaan. Hier gaat het mis:
/mnt/HD_a2 #  sh ffp/start/smbshares.sh start
: not foundmbshares.sh: line 2:
: not foundmbshares.sh: line 6:
ffp/start/smbshares.sh: .: line 7: can't open /ffp/etc/ffp.subr
  • Krypt
Hoe heb je die file gemaakt? Via de Windows Explorer "New File" ?
Want je moet die files in unix indeling opslaan. Verwijderd in "[NAS] Conceptronic CH3SNAS / Dlink DNS-3..." zie daar.
Ik gebruik Primalscript om ze als unix bestanden op te slaan.
[edit]
Als ik dus een nieuw tekstdocument maak via de explorer, deze hernoem en open in notepad. De inhoud erin past en opsla, dan geef de NAS de volgende fouten.
/mnt/HD_a2/ffp/start # sh test.sh start
: not foundne 2:
: not foundne 6:
test.sh: .: line 7: can't open /ffp/etc/ffp.subr
Opslaan als unix indeling, en dan werkt ie wel.
[ Voor 39% gewijzigd door Krypt op 21-01-2009 22:33 ]
Pvouput live
  • Maverick
mijn excuses. Dat was inderdaad mijn fout :)
Heb nu webserver en php via usbstick draaien. Geen spinups als iemand erop komt ( *D ) en de samba shares "media" "media_admin" (met schrijfrechten is die) "system" (de hdd met ffp etc erop) en "usb".
Ben helemaal happy met m'n NAS nu. Nu alleen nog eens kijken of ik mysql er ook nog bij kan vrotten :P
  • groennom
  • Laatst online: 26-01 07:43
Krypt schreef op dinsdag 20 januari 2009 @ 22:44:
Ik heb eerst de volgende handleiding gevolgt hiero
Dus.. even een stappenplan:
1. Download eerst de usb kernel module: hiero
2. Plaats deze op je NAS. Deze heb ik zelf op /mnt/HD_a2/ffp/custom gezet.
3. Vervolgens de module laden: insmod /mnt/HD_a2/ffp/custom/usb-storage.ko
4. Vervolgens fdisk draaien: fdisk /dev/sdb (manual zegt sdc, maar dat is als je 2 disks erin hebt, ik heb er maar 1. In de manual staat ook hoe je partities maakt. Dit heb ik niet gedaan daarom moet ik sdb mounten ipv sdb1)
Tot stap 4 geen probleem, bij het uitvoeren van de fdisk krijg ik de melding segmentation vault. Fdisk zelf voert hij wel goed uit en ook het insmod commando geeft geen foutmelding. Enig idee??
  • Maverick
groennom schreef op donderdag 22 januari 2009 @ 17:38:
IK heb dit ook gehad. Oplossing was om met een live cd van GParted de usbdisk te formatteren. http://gparted.sourceforge.net/download.php
  • mrwolf
Ik heb de ln -s /mnt/usb /mnt/HD_a2/usb optie gebruikt, ik kan de bestaande smb.conf nergens vinden, en ik heb geen zin om op alle machines in het netwerk weer shares aan te passen :)
nzbget draait (nzb-check en log folder op usb), volgende stap is lighttpd op usb stick krijgen...
Eindelijk
Ik heb het aan de praat.
Ik heb mijn ch3snas gekocht om de TVICO TVIX 4100 van extra opslag te voorzien.
Maar het werkte maar niet.
De tvix blijkt erg kritisch.
Ik heb de fonzplug 0.5 geïnstalleerd
en 4 wijzigingen gedaan in /ffp/etc/exports en in de funplug file zelf.
funplug :
Ik heb een link gemaakt in de root dir naar de /mnt/HD_a2 map en die /nda genoemd (net disk a).
# create /nda link
echo "ln -snf /mnt/HD_a2 /nda"
De bovenstaande regels komen voor de #create /ffp link
De wijzigingen gemaakt met notepad++ via het samba netwerk
maakt de nfsd.sh zelf startend.
door
chmod a+x ffp/start/nfsd.sh
uit te voeren
En maak de etc/exports file wijzigbaar
chmod 777 ffp/etc/exports
Dit heb ik gedaan met putty.exe
Wijzig met notepad++ de exports file
ffp/etc/exports :
/nda 192.168.1.0/24(rw,no_root_squash,no_subtree_check)
De tvix4100 kan de files op de harddisk (mnt/HD_a2) vinden door bij de netwerk instellingen
/nda en 192.168.1.x in te vullen. (x het nummer van je ch3snas)
Omdat de TVIX met de afstandsbediening moet worden bedient is het gebruik maken van een korte naam zonder hoofd en kleine letters bijzonder aan te raden.
Welke idioot gaat er uberhaubt disk namen verzinnen als HD_a2. Rare jongens die linux freaks!
Misschien heb ik heel omslachtigs gedaan maar dit werkt!
/mnt/HD_a2 zoals in de etc/exports standaard staat vermeld werkt niet met de TVIX.
Het gekke is dat als je showmount -e uitvoert je gewoon een "/mnt/HD_a2" share ziet.
De TVIX ziet de /nda share.
Doe er je voordeel mee.
  • mrwolf
NZBget geeft bij een reboot of stroomstoring op de NAS na het opnieuw opstarten de volgende fouten:
ERROR	Thu, 22 Jan 2009 19:41:51 +0000 Could not open file /mnt/HD_a2/usenet/queue/4
ERROR	Thu, 22 Jan 2009 19:41:51 +0000 Could not open file /mnt/HD_a2/usenet/queue/6
ERROR	Thu, 22 Jan 2009 19:41:51 +0000 Could not open file /mnt/HD_a2/usenet/queue/5
Dit blijft zich herhalen, en de log file groeit als kool met deze meldingen. Nieuwe nzb's worden niet meer geladen, het lijkt of het programma 'hangt'.
De workaround is om de map /mnt/HD_a2/usenet/queue leeg te mapen, nzbget te herstarten en all is well. Maar als dit gebeurt als ik er niet ben, en er staat een hele lading in de queue heb ik een log file van honderden MB's en nzb's die niet geprocessed zijn. Hoe kan ik dit anders oplossen?
  • Krypt
ehuurman schreef op donderdag 22 januari 2009 @ 18:04:
smb.conf staat in /etc/samba
telnet naar je CH3NAS; vervolgens cd /etc/samba en daar moet ie staan.
Verder hoef je niet je hele lighttpd op usb te hebben staan. Als je alleen de pages, errorlog en accesslog op je usb hebt staan dan spint je disk ook niet op als je nzbgetweb benaderd. Verder nog php-cgi op je usb om het opspinnen nog meer tegen te gaan. Werkt bij mij perfect.
Zou trouwens niet weten waarom je queue errors krijgt.
[ Voor 3% gewijzigd door Krypt op 22-01-2009 20:58 ]
Pvouput live
DeOS schreef op woensdag 21 januari 2009 @ 11:54:
Dus je resolv.conf ziet er nu zo uit?:
search wan
nameserver 192.168.0.1
Verder neem ik aan dat je router ook je dns server is?
heb even gekeken wat er stond bij dns bij IPconfig/all.
Dat adres ingevoerd in resolv.conf. Nu werkt het wel :P
  • DeOS
  • Laatst online: 13-11 13:41
ehuurman schreef op donderdag 22 januari 2009 @ 20:49:
Welke versie heb je van nzbget?
Repeat after me: I Will Use Google Before Asking Stupid Questions
  • mrwolf
nzbget -v
nzbget version: 0.6.0-testing
Hallo allemaal, fijne thread dit.
Ik heb m´n schijven (van ongelijke grootte) niet als RAID geconfigureerd, ik ga er dan ook van uit, dat ik bij het upgraden naar 1.05 niet met een format vraag wordt geconfronteerd? Klopt deze aanname?
Grtz
Jdeje
  • Maverick
Verwijderd schreef op vrijdag 23 januari 2009 @ 11:05:
Grtz
Jdeje
Dat klopt. Als je het niet 100% vertrouwt kun je altijd de schijven eruit halen tijdens de firmware upgrade.
Maverick schreef op vrijdag 23 januari 2009 @ 11:06:
[...]Dat klopt. Als je het niet 100% vertrouwt kun je altijd de schijven eruit halen tijdens de firmware upgrade.
Bedankt voor de snelle response!
Grtz
Jdeje
  • DeOS
ehuurman schreef op vrijdag 23 januari 2009 @ 11:02:
nzbget -v
Wat er species mis gaat weet ik ook niet, maar zorg iid geval dat je de nieuwste versie van nzbget hebt geïnstalleerd. Of je de laatste 0.6 versie hebt kan ik niet beoordelen want het r* nummer staat er niet bij. 0.6.0-r269 is iid geval de laatste versie. Let wel op dat je hierbij ook de nieuwe nzbget.conf moet gebruiken van aroundmyroom.
Mocht dat niet baten dan kun je de settings wat tweaken in de onderstaande regels uit nzbget.conf .
### DOWNLOAD QUEUE                                                         ###
# Save download queue to disk (yes, no).
# This allows to reload it on next start.
SaveQueue=yes
# Reload download queue on start, if it exists (yes, no).
ReloadQueue=yes
# Reload Post-processor-queue on start, if it exists (yes, no).
# For this option to work the options <SaveQueue> and <ReloadQueue> must
# be also enabled.
ReloadPostQueue=yes
# Reuse articles saved in temp-directory from previous program start (yes, no).
# This allows to continue download of file, if program was exited before
# the file was completed.
ContinuePartial=yes
  • anconakip
  • Laatst online: 05-11 15:46
Bestaat er een website applicatie die ik in mijn lighttpd map kan zetten om mijn foto's die ik heb opgeslagen op de hd te laten zien via een website?
Zonder dat ik dus een fotoalbum moet gaan inrichten en ik mijn foto's op 2 plekken heb staan?
Ik kan natuurlijk via ftp wel bij de foto's, maar dan zie ik alleen de bestandsnamen. Het zou handig zijn als ik dus de foto's te zien krijg (bijv. net als in windows verkenner) .
The Force is like Duck-tape, it has a light side, a dark side and it holds the universe together
  • Krypt
Ik lees wel op sites die Gallery2 met lighttpd aan de praat hebben gekregen (mod_rewrite module moet draaien), dat zou ook moeten werken op je NAS.
Echter heb ik ook dit gevonden. De source kun je hier vinden
Weet alleen niet of GD2 op de NAS aanwezig is.
[ Voor 6% gewijzigd door Krypt op 23-01-2009 15:58 ]
Pvouput live
  • Prulleman
  • Laatst online: 20:08
Prulleman
Heeft er iemand nog een tip voor een budget gigabit switch. Ik merk dat ik met mijn asus 530g router wired maar 6 MB/s haal. Ergens in een review gelezen dat de ethernet snelheid niet echt geweldig van die router, dus ik ga er wel vanuit dat de router de bottleneck is.
Ik hoef geen superswitch, als het maar niet meer de bottleneck is. Is bijvoorbeeld een sweex van 22 euro al voldoende om de NAS op zijn max te laten werken?
Strava
  • DanielZ
  • Laatst online: 31-05-2024
Ik heb vandaag eindelijk alles binnen voor mijn ch3snas. Ik heb er 2x 1TB inzitten en dit heb ik als JBOD geconfigureerd. Dit lijkt me makkelijker om al mijn download's etc. op 1 plek te hebben. Ik weet niet of dit nog uitmaakt?
Ik wil hem graag "hacken" en wat programma's opzetten natuurlijk!
Ik weet dat ik moet beginnen met de funplug installatie maar wat moet ik nog meer installeren? / wat moet ik daarna installeren? Ik wil graag een nzb grabber erop die ik van buiten af kan bereiken tevens zou ik er graag twonky op willen hebben.
Ik ben een echte linux leek die wie zou me kunnen / willen helpen?
Alvast bedankt!
edit: en als hij alles automatisch's na checked met par2 en unrar'd dan zou dat geweldig zijn. hoe krijg ikd at voor elkaar?
[ Voor 9% gewijzigd door DanielZ op 23-01-2009 22:11 ]
  • Maverick
http://wiki.dns323.info/howto:ffp dit is een goede start :)
  • Krypt
Ik heb even gekeken naar dat script voor die foto's. Die moest een beetje herschreven worden voordat ie met lighttpd werkte.
[edit]
Joepie.. Hij werkt nu wel. had de libjpg en libpng nog niet geinstalleerd.
php.ini aanpassen:
extension=gd.so
extension_dir = "/ffp/lib/php/extensions/no-debug-non-zts-20060613/"
En de PHP code aanpassen:
hier
Als je over de filename hover't dan wordt de thumbnail getoond.
PS. werkt trouwens niet met mijn firefox, maar wel met IE.
[edit]
Hij werkt wel, maar erg snel issie niet. Om van een jpg van 567KB een thumbnail te maken is ie een kleine minuut aan het rekenen. Is dus niet echt werkzaam. (het was gisteren laat, zat op de verkeerde host te kijken |:( )
[ Voor 84% gewijzigd door Krypt op 24-01-2009 14:40 ]
Pvouput live
  • mrwolf
Ik heb lighttpd draaien, en wil ook wat pagina's tonen aan de grote boze buitenwereld hierop. Welke risico's loop ik hiermee, en hoe kan ik dit verminderen? Alles draait nu onder user root, dat schijnt niet verstandig te zijn?
  • Puck
  • Laatst online: 13-11 11:08
Puck
EINDBAAS.org
Je kunt lighttpd onder zijn eigen user draaien, zodat deze enkel toegang heeft tot specifieke mappen. Heb ik gedaan via deze post. Staat niet echt geweldig uitgelegd, maar je komt er vast uit.
Trouwens, voor de mensen met lighttpd draaiend, vindt ik Music Browser erg handig om overal en altijd mijn muziek te kunnen luisteren. Werkt erg goed! Heb de map wel afgeschermd met een wachtwoord.
[ Voor 31% gewijzigd door Puck op 24-01-2009 00:14 ]
Arrived anxious, left bored
  • DanielZ
Die ga ik nu ook doorlopen :)
Ik was begonnen met http://knowledge.forestblue.nl/ch3snas.html
Maar bij stap 7 ging het al mis. Ik kreeg foutmeldingen m.b.t. permissies.
Bij de volgende sap moest ik de map debian in zijn geheel verwijderen en dat kon ik ook niet voor elkaar krijgen. Vervolgens ben ik uit terminal gegaan en heb ik via ftp geprobeerd de map te verwijderen of de permissies te veranderen. Dat werkte ook niet,
Als last resort wou ik de schijven weer gaan formatteren en ik kreeg een error. Ik reboot mijn ch3snas nu en er staat dat 1 schijf geformatteerd moet worden. Er staan er dus geen 2!!
is dit normaal?
* DanielZ gaat nu slapen dus ik zie morgen wel wat de status van de HDD's is
  • Toppe
  • Laatst online: 16:35
Toppe
Oké ✅
Prulleman schreef op vrijdag 23 januari 2009 @ 17:32:
Hier in almere hebben we de Hardwareoutet (slechte winkel, tenzei je weet wat je wilt hebben) hier hadden ze een Sweex liggen voor iets van €40 of €50,- je kan goedkoper gaan alleen moet je rekening houden dat je ook nog goede CAT6 kabels nodig hebt, hadden ze daar alleen 20 meter van en moest je dan afknippen.
Heb nu een D-Link 100 switch, opzich qua snelheid gewoon goed, je doet er iets langer over, voor het downloaden heb je geen gigabit nodig.
Weet iemand overigens hoe ik het best een map kan chmodden, zodat je wel kan schrijven en bewerken maar niet verwijderen? alvast bedankt!
Hoe halen jullie al die hoge performancecijfers? Sinds een wek heb ik ook de CH3NAS, maar ik kom qua snelheid niet verder dan 3,18MB/s (volgens Vista). Lezen of schrijven maakt qua snelheid niet veel uit. Ik verricht de handeling via een aangemaakte netwerkshare (dus geen FTP oid).
Het netwerk is bedraad. Ik heb een Linksys WRT610N router. De NAS is via 1000Mbps aangesloten en mijn mediacenter via een Linksys Homeplug (200Mbps). Volgens het bijgeleverde Linksys beheertooltje haal ik via de Homeplug circa 90Mbps, dat kan de bottleneck dus niet zijn.
Alles staat verder standaard ingesteld. Ook met mijn laptop (Vista, bedraad, 100Mbps) kom ik niet tot andere performancecijfers. Wat wel opvalt is dat de CH3SNAS bij de Lan settings als speed 0Mbps weergeeft, de link speed staat op 'auto' ingesteld.
Ik heb het forum zo goed mogelijk doorgenomen, maar ik zie niet de gouden tip óf ik heb er overheen gelezen. Het zijn zoveel pagina's met info :P .
Ik heb JumboFrames geprobeerd, maar dat gaf geen verbetering (wellicht had ik het verkeerd ingesteld?). De performance ging zelfs nog iets naar beneden (2,95MB/s)
Alle apparatuur is (natuurlijk) voorzien van de laatste firmware. Blijkbaar doe ik toch iets fout. Volgens mij moet 8a9MB/s toch wel haalbaar zijn....... :?
  • GoVegan
  • Laatst online: 15-10 20:37
[b][message=31399259,noline]
ik gebruik nu op mijn p3 server kplaylist
werkt erg fijn, selecteren welke mappen je wilt luisteren en deze streamen in winamp, echt fijn voor op je werk :)
  • GoVegan
[b][message=31399627,noline]
wikipedia
chmod -R 660
dan zet de de hele map (+inhoud, de -R staat voor recursief) op lezen+schrijven voor de eigenaar & de groep.
de rest kan er dan niets mee.
  • DanielZ
Ik heb deze tutorial doorlopen:
Ik heb ook de extra pakketten geïnstalleerd wie kan me nu een schop in de goede richting geven? Mijn doel is een goed werkende en beveiligde download NAS te maken. Wat ik er graag nog op zou willen is een goede en simpel te begrijpen NZB grabber die alle gedownloade bestanden par(2)'t en unrar't en die vervolgens automatisch te laten verwijderen. Tevens zou ik ook twonky op willen zetten. Het liefst kan ik deze NAS van buiten bereiken en de NZB grabber ook(webinterface ?) Maar hoe kan ik ervoor zorgen dat niet iedereen daarbij kan?
Alvast bedankt!,
DanielZ
  • goosjuh
  • Laatst online: 22-07 11:57
DanielZ schreef op zaterdag 24 januari 2009 @ 19:52:
Alvast bedankt!,
DanielZ
Ik gebruik nzbget, met nzbgetweb, werkt perfect, zie hier voor de installatie:
http://www.aroundmyroom.c...and-nzbget/#comment-34747
  • DanielZ
goosjuh schreef op zaterdag 24 januari 2009 @ 20:18:
Ik ga proberen om nzbget te installeren. Wordt alles dan ook automatisch ge par't en ge unrar't?
thanx
  • DanielZ
Alle stappen gevolgd en de NAS gereboot en gecheked met ps welke processen draaide.
nzbget staat er 5 keer in, hoort dit?
1680 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1682 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1683 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1684 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1685 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
Ik wil nu graag NZBGETWEB installeren maar hoe weet ik of ik een webserver heb draaien? Ik weet wel dat ik alle additional packages heb gedownload en geïnstalleerd. Daar zat lighthttpd ook in. Ik zie hem niet staan als ik ps in typ.
Waar moet ik NZBGETWEB "installeren" / neerzetten?
Alvast bedankt!
Ik heb deze gevonden en gevolgd: http://nas-tweaks.net/CH3SNAS:Tutorials/lighttpd
nu draait hij wel goed :D En ik heb de map nzbgetweb in www/pages gezet maar als ik ernaartoe navigeer krijg ik een 403. Wat moet ik allemaal aanpassen en/of veranderen moet dit goed en veilig draaien? Thanx!!
[ Voor 17% gewijzigd door DanielZ op 24-01-2009 23:35 ]
  • Toppe
Toppe
Oké ✅
@ GoVenga (of iemand anders)
iemand enig idee hoe ik het best een map automatisch kan chmodden? moet het nu elke keer met de hand doen, dat schiet helemaal niet op. Ik gebruik SABnzbd, deze kan zelf scripts runnen, kan dus gewoon in een script chmod -R 660 downloads/complete er in zetten en laten uitvoeren?
Iemand ander beter idee, heb liever een ander soort script zodat ik ook gelijk al mijn muziek en foto's kan laten chmodden.
Enig idee?
  • DanielZ
De lighthttpd webserver draait goed. Mijn enige probleem is nu nog getnzb en getnzbweb te laten werken. Ik heb getnzb wel geinstalleerd en die schijnt ook te draaien. Maar als ik een nzb in de map /mnt/HD_a2/nzb zet dan gebeurt er niks en als ik hem in /mnt/HD_a2/usenet/nzb/ zet dan gebeurt er ook niks.
Wat kan ik hieraan doen? En hoe moet ik nzbgetweb laten werken? Hoe zorg ik dat het veilig is? Want chmodden met 777 is naar mijn idee niet echt veilig.
Iemand die me kan helpen?
Edit: Ik heb dit doorlopen http://gathering.tweakers.net/forum/view_message/30886776 maar nzbgetweb werkt maar niet. Ik kan nu wel inloggen maar als ik een nzb upload dan gebeurd er niks. Ik zie alleen de upload box en een menu links. Maar daar werkt helemaal niks |:(. Ik heb nu net gekeken of de nzb die ik geupload heb in de map /mnt/hd_a2/nzb/ staat en daar staat hij. de naam is veranders in naam.nzb.qeueud
Is er een manier waarop ik kan testen dat nzbget überhaupt werkt? / nzb's binnenhaalt? Ik gebruik tweaknews zonder username en wachtwoord. dus die heb ik ook leeg gelaten in mijn configuratie bestand. Ik neem aan dat alles dan gewoon moet blijven werken?
Edit2: net maar even met ps gekeken wat er allemaal draait en het wordt steeds meer. Klopt dit?
1592 root inotify_upnp
1593 root inotify_upnp
1595 root inotify_itune
1596 root mt-daapd
1601 root inotify_itune
1602 root inotify_itune
1653 root /ffp/sbin/telnetd -l /ffp/bin/sh
1668 root /ffp/sbin/sshd
1679 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1691 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1692 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1693 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1694 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1697 root /ffp/sbin/lighttpd -f /ffp/etc/lighttpd.conf
1699 root /ffp/bin/php-cgi -c /ffp/etc/php.ini
1700 root /ffp/bin/php-cgi -c /ffp/etc/php.ini
1701 root /ffp/bin/php-cgi -c /ffp/etc/php.ini
1702 root /ffp/bin/php-cgi -c /ffp/etc/php.ini
1707 root sshd: root@pts/0
1713 root -sh
1741 root /web/webs
1754 root /usr/sbin/samba/smbd -D
1758 root /usr/sbin/samba/nmbd -D
1762 root /usr/sbin/samba/smbd -D
1802 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1803 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1804 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1805 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1806 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1807 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1808 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1809 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1810 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
2568 root ps
Alvast bedankt!
Ik heb nzbget en nzbget.conf gedelete en ik heb alles opnieuw gedownload en weer terug gezet. ik heb de config file aangepast en alles weer uitgevoerd volgens de tutorial. Gereboot maar nu wilt hij nzbgetweb niet meer openen :/ de webserver draait wel maar hij lijkt een timeout te geven ofzo. hoe kan ik dit nu weer oplossen? :(
[ Voor 88% gewijzigd door DanielZ op 25-01-2009 13:50 ]
  • Nick Name
  • Laatst online: 22:31
Nick Name
SinFest!
Toppe schreef op zondag 25 januari 2009 @ 08:32:
Enig idee?
chmod -R 660 /mnt/HD_a2/Photos/
Hiermee chmod je alles in /mnt/HD_a2/Photos inclusief alle onderliggende mappen en bestanden. Dit kun je via een cronjob bijvoorbeeld elke nacht uitvoeren.
http://www.sinfest.net | Q: Does it ever get windy in Australia? I have never seen it rain on TV, so how do the plants grow? (UK) A: We import all plants fully grown and then just sit around watching them die
  • DanielZ
deze processen draaien er nu allemaal:
PID USER COMMAND
1 root init
2 root [ksoftirqd/0]
3 root [events/0]
4 root [khelper]
5 root [kthread]
11 root [kblockd/0]
14 root [khubd]
49 root [pdflush]
50 root [pdflush]
52 root [aio/0]
51 root [kswapd0]
189 root [scsi_eh_0]
190 root [scsi_eh_1]
200 root [mtdblockd]
217 root [kcryptd/0]
218 root [kmirrord/0]
229 root [loop0]
1182 root atd
1201 root crond
1431 root chkbutton
1438 root /sys/custom/upnp/upnp 0 CONCEPTRONIC http://www.conceptronic.net Grab'n'GO Media Store CH
1460 root fancontrol
1492 root op_server 6 6 6
1499 root -sh
1525 root pure-ftpd (SERVER)
1552 root lpd Waiting
1557 root inotify_upnp
1585 nobody mt-daapd
1586 root mt-daapd
1587 root mt-daapd
1588 root mt-daapd
1596 root mt-daapd
1686 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1687 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
1688 root /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
3428 root /web/webs
3484 root /usr/sbin/samba/smbd -D
3495 root /usr/sbin/samba/nmbd -D
3499 root /usr/sbin/samba/smbd -D
3894 root sshd: root@pts/0
3982 root -sh
12958 root /ffp/bin/php-cgi -c
12964 root /ffp/bin/php-cgi -c
12965 root ps
het wilt hier dus echt voor geen meter :/ Is er een manier om te kijken of nzbget uberhaupt werkt. hij draait wel maar volgens mij werkt het gewoon niet :/
Alvast bedankt
edit: Ik heb de lighttpd.conf aangepast en nu laad hij weer wel php bestanden erg vreemd. Maar wie kan me helpen? Hoe weet ik dat nzbget aan het downloaden is? Waar kan ik de status zien? nzbgetweb laat niks zien. Ik krijg zelf geen bericht als de nzb geupload is. Het enige wat ik zie is dat er .queued achter de nzb naam is gaan staan.
Als het goed is nzbget zojuist gaan downloaden :D nu nog maar hopen dat hij alles goed uitpakt etc. Is er een manier om dit na tekijken? En hoe graag ik nzbweb aan de praat?
Wie kan me hier mee helpen?
Edit: Hier dan meer een screenshot van mijn webinterface ...
Afbeeldingslocatie: http://www.danielz.nl/CH3SNAS/interface.png
[ Voor 11% gewijzigd door DanielZ op 25-01-2009 14:42 ]
  • Krypt
Hou je er rekening mee dat in de nzbget.conf vermeld staat dat ie poll't om het uur? 3600 seconden dus.
Die waarde moet je verlagen om nzbget sneller de nzb te laten oppakken.
Denk er ook aan dat bij elke keer dat je je lighttpd.conf aanpast, je de webserver moet restarten om de conf in te laden. En je ziet heus wel dat nzbget iets aan doen is, ga maar eens naar /usenet/tmp en /usenet/queue. Daar zet ie de tijdelijke bestanden neer. En in /usenet/download moet er elke keer een bestand erbij gekomen als ie die gedecodeerd heeft.
Verder zie ik in je screenshot dat ie de server gegevens nog niet eens overneemt. Heb je de account gegevens van nzbgetweb naar nzbget nagekeken?
[ Voor 12% gewijzigd door Krypt op 25-01-2009 14:47 ]
Pvouput live
  • DanielZ
Krypt schreef op zondag 25 januari 2009 @ 14:46:
Ik heb er nog even naar gekeken en besloten op een nieuw nzbget.conf bestand te gebruiken die beschikbaar gesteld is door aroundmyroom. Nu heb ik die er (eindelijk) instaan en restart ik nzbget.sh krijg ik deze error:
FATAL ERROR: Invalid option "MergeNzb"
root@CH3SNAS:/mnt/HD_a2/ffp/start#
En hoe kan ik ervoor zorgen dat de bestanden zich automatisch parren en unrarren? Ik heb postprocess.sh er ook instaan als het goed is en ik had ook via die tutorial een nieuwere versie van winrar geinstalleerd : http://wolf-u.li/1790/unr...3snas-bzw-d-link-dns-323/
nogmaals bedankt!
Edit: Ik heb er maar een # voor gezet. En het schijnt opgelost te zijn:
root@CH3SNAS:/mnt/HD_a2/ffp/start# sh nzbget.sh restart
Stopping nzbget
Starting /ffp/bin/nzbget -D -c /ffp/etc/nzbget.conf
WARNING: nzbget: Not running
FATAL ERROR: Invalid option "ProcessLogKind"
FATAL ERROR: Invalid option "ParTimeLimit"
Ik was idd de password vergeten. Nu ziet hij tenminste wel wat :) Hij geeft nu 1 error aan en dat is deze:
Messages
INFO Sun, 14 May 2000 07:39:16 +0000 nzbget daemon-mode
ERROR Sun, 14 May 2000 07:39:26 +0000 Could not load diskstate due file version mismatch
Nu ga ik proberen om wat te downloaden. En kijken of hij het part en unrar't!
Alvast bedankt!
[ Voor 29% gewijzigd door DanielZ op 25-01-2009 17:43 ]
  • RunaR
RunaR
Heb je de nieuwste versies van nzbget (0.6.0-r269 voor de dns-323) en nzbgetweb (v 1.3 (testing 2) )?
  • batowhizz
  • Laatst online: 15-09-2025
help
ik heb iets doms gedaan 8)7 8)7 namelijk de gehele schijf chmod 666 gegeven iets te rigoreus
waarna ik na een reboot helemaal niks meer zie
heb de ch3 al teruggezet naar default maar ook geen resultaat
ik zie het apparaat wel via upnp en krijg in mijn netwerk wel volume 1
maar ik krijg geen toegang
telnet en ssh doen ook niks meer
heeft iemand een idee hoe dit op te lossen "het gaat weer eens om de fotos natuurlijk
alle hulp is welkom
  • RunaR
RunaR
Ook in ffp/start staat dus alles op 666, dus telnet en ssh worden niet meer op gestart.
Je kan via ftp de rechten proberen goed te zetten (pokke werk) of fun plug er opnieuw op zetten (makkelijker). Zet de interne ftp server aan en log in op je nas met Fillezilla
[ Voor 13% gewijzigd door RunaR op 25-01-2009 20:23 ]
  • DanielZ
RunaR schreef op zondag 25 januari 2009 @ 18:39:
Ik heb wel de nieuwste nzbget maar ik heb v1.2 van nzbgetweb waar kan ik v1.3 testing 2 halen?
thanx!
  • DeOS
DanielZ schreef op zondag 25 januari 2009 @ 20:42:
Op dezelfde plek waar je ook de laatste versie van nzbget hebt gedownload: http://sourceforge.net/project/showfiles.php?group_id=102632
  • Maverick
w00t, meer goed nieuws vanaf hier. Had als lighttpd en php op mijn usb stick draaien. Nu zien we dit:
root@localhost has the encrypted password: *AA1420F182E88B9E5F874F6FBE7459291E8F4601
maw, Mysql is up and running :7
( http://maverick.dynasoft.nl/wp/ :P )
[ Voor 8% gewijzigd door Maverick op 25-01-2009 21:36 ]
  • Krypt
Geweldig! gewoon wordpress vanaf je NAS runnen. Wel pokketraag natuurlijk; zeker als ie NZB aan het binnen trekken is (en aan het parren en unrarren is)
Nice work Maverick
[ Voor 6% gewijzigd door Krypt op 25-01-2009 21:43 ]
Pvouput live
  • Maverick
Ja, ik heb wel het idee dat het een beetje traag is inderdaad. Hoewel ik niet van nieuwsgroepen download dus parren en rarren doe ik niet. Moet alleen mysql nog een beetje fixen, draai nu gewoon als root en das geloof ik niet helemaal de bedoeling :P
  • batowhizz
RunaR schreef op zondag 25 januari 2009 @ 20:18:
helaas kom wel binnen via ftp maar krijg geen mappenlijst meer en kan ook geen rechten wijzigen
weet dat ik hier commentaar op ga krijgen maar ik heb alles onder root gedaan
misschien dat dit nu het probleem is
begin al licht te vrezen voor mijn data
  • Krypt
Misschien iets om te proberen (weet niet of het werkt; ben niet zo bekend met het complete rechtensysteem van linux fs'en).
1. Haal je disk eruit en plaats een andere (zeker eruit halen anders format je nas deze ook terwijl hij zegt van niet!)
2. Format de disk en zet hier funplug op.
3. Plaats de oude disk in je 2e bay.
4. Boot je nas opnieuw.
Als het meezit kun je weer met telnet naar je nas. Kijk dan eens of je bij je originele disk komt.
Pvouput live
  • batowhizz
morgen maar even naar de onderdelen boer en maar van de nood een deugd maken
>:) >:) >:) >:) 1tb halen!!
  • DanielZ
DeOS schreef op zondag 25 januari 2009 @ 20:45:
Ik heb hem geïnstalleerd en geconfigureerd maar ik krijg alleen een blanke pagina op index.php wat doe ik fout?
werkt nu wel :) het enige wat na deze helse dag nog niet werkt is het unrarren. Ik heb unrar.sh en unrar.cfg van aroundmyroom gedownload en in ffp/etc gezet
in getnzbweb zie ik wel een Error verschijnen na het par checken dat hij geen permissie heeft om het proves te starten o.i.d. dit zal dan hoogst waarschijnlijk unrar.sh en de cfg daarvan zijn.
Iemand die me hiermee nog kan helpen? Tevens klopt de tijd op de CH3SNAS niet is dit ook te fixxen?
[ Voor 38% gewijzigd door DanielZ op 26-01-2009 00:02 ]
  • Krypt
Ik ga toch maar eens een ander USB sticky proberen.
Telkens raakt mijn pages folder voor lighttpd corrupt.
/mnt/usb/www.old # ls -l
?rwsrwsrwt 65535 -1       -1      4294967295 Jan  1  1970 logs
?rwsrwsrwt 65535 -1       -1      4294967295 Jan  1  1970 pages
Ik krijg dan zoiets te zien. CHMOD, RM etc werkt niet meer, ik zou niet de juiste rechten hebben.
e2fsck -c /dev/sdb werkt ook niet, die knalt eruit met een foutmelding.
Toch maar eens een ander sticky proberen.
Pvouput live
  • Toppe
Toppe
Oké ✅
Nick Name schreef op zondag 25 januari 2009 @ 10:42:
op 660 kan ik geen bestanden via windows op mijn NAS server zetten, 2de vraag is hoe de f**k kan je een cronjob maken in unix, iemand een voorbeeld?
[i]Heb wel op internet gezocht, als ik een /bin/chmod_cron file aanmaak en die met de hand uitvoer, geen probleem werkt zoals het hoort, zodra ik hem als crontab ga instellen (zie hier onder) krijg ik geen response
0 * * * * /bin/chmod_cron
Nu doet hij het niet (ja, hij doet het nu elk uur zodra het 00 is), iemand enig idee? alvast bedankt!!
[ Voor 26% gewijzigd door Toppe op 26-01-2009 09:48 ]
  • Krypt
Crontab is toch gewoon onderdeel in funplug?
Pvouput live
  • RunaR
RunaR
Voor het toevoegen van cronjobs..... kijk eens in je /ffp/etc/fun_plug.local
Kopieer fun_plug.local uit de examples directory of maak er een aan. En zet het volgende stukje er in.
Je kan hier cronjobs toe voegen.
#  Add required jobs to crontab  #
CRONTXT=/mnt/HD_a2/crontab.txt
# start with existing crontab
/bin/crontab -l > $CRONTXT
# add Rsync job; keep ffp on USB drive in sync with ffp on HD_a2
# /bin/echo "55 5 * * * /ffp/bin/rsync -av --delete /mnt/USB/ffp /mnt/HD_a2" >> $CRONTXT
# install the new crontab
/bin/crontab $CRONTXT
# clean up
/bin/rm $CRONTXT
of maak een /ffp/start/editcron.sh aan
#!/bin/sh
# .-[ editcron.sh ] .-
# script to keep cronjobs persistent (e.g. after reboot)
# w 22/10/08 horto
# ref/credit: http://tinyurl.com/5m2349 - thanks chumby!
FFP=/mnt/HD_a2/ffp
CRONTXT=$FFP/etc/crontab.txt
# note:  on a fresh reboot, this will always have been reset to standard
# add cronjobs here preceeded by /bin/echo.
# don.t forget to enclose them in double quotes.
/bin/echo "<hier je cron job>" >> $CRONTXT
# clean up
/bin/rm $CRONTXT
[ Voor 119% gewijzigd door RunaR op 26-01-2009 10:28 ]
  • Jelte
En dan kun je na het restarten met "crontab -l" kijken of je sync opdracht er tussenstaat :)
  • batowhizz
helaas 1tb ;) ;) schijf eringezet met funplug
alleen zodra ik de 2e schijf erbij zet wil funplug vanaf schijf 1 en dus ook telnet niet starten
terug bij af dus
schijven omgewisseld van links naar rechts en we hebben weer ssh en telnet
maar nu wat is het goede commando
chmod 777 /mnt/HD_b2 -R
dat was het goede commando
iedereen super bedankt voor de ideeen en hulp
[ Voor 45% gewijzigd door batowhizz op 26-01-2009 15:25 ]
  • Krypt
Kun je nu wel bij Volume_2 (neem aan dat ie zo gemount wordt in Samba) of zie je nog steeds niets?
En als je via telnet naar de mount van je oude disk gaat; zie je dan wel inhoud? kun je chmodden?
Pvouput live
  • DanielZ
DanielZ schreef op zondag 25 januari 2009 @ 23:22:
in getnzbweb zie ik wel een Error verschijnen na het par checken dat hij geen permissie heeft om het proces te starten o.i.d. dit zal dan hoogst waarschijnlijk unrar.sh en de unrar.cfg daarvan zijn.(Ik heb unrar.sh en unrar.cfg in ffp/etc/ gezet)
Kan iemand me hier nog mee helpen?
Puck schreef op zaterdag 24 januari 2009 @ 00:12:
Bedankt voor deze tip, werkt inderdaad goed (snel "geinstalleerd"). Kan je wellicht aangeven hoe je het afschermen met een wachtwoord gedaan hebt?
Door zulke tips/vindingen blijf ik het een super aankoop vinden die ch3snas!!!
DanielZ schreef op maandag 26 januari 2009 @ 15:35:
De tijd kan je instellen op de standaard website van je nas (tools > time). Ik heb hier een ntp server ingevuld. In mijn ssh sessie krijg ik dan 'juiste' tijd.
Voor je andere probleem is het wellicht handig als je iets meer info post, als de melding permissies zijn is het wellicht handig om van de verschillende scripts de rechten te posten.
(Of wellicht zelf iets uitzoeken? Bij al je vragen staat wel dat het nu werkt maar niet wat de oplossing was, zo heeft iemand anders er ook niet veel aan!)
  • RunaR
RunaR
Verwijderd schreef op maandag 26 januari 2009 @ 15:36:
Ik heb de zelfde music browser draaien, ook met password protectie. Ik heb deze tutorial gebruikt: http://www.shadowandy.net...word-protected-clutch.htm
Maar dan een beetje verbouwd voor mijn toepassing. Deze tutorial is wat verouderd. clutch zit al een tijdje ingebakken in transmission. Maar het principe blijft het zelfde.
  • anconakip
Ik heb nzbget en nzbgetweb geinstalleerd en het werkt perfect. Je kan in nzbgetweb categorien maken, ideaal. Kan ik op de een of andere manier er voor zorgen dat hij ook per categorie kijkt waar hij het bestand neer moet zetten?
bijv. categorie film op volume_1
categorie programma op volume_2
RunaR schreef op maandag 26 januari 2009 @ 15:59:
klopt het dat je hiermee al je pagina's op je nas achter een username/pw zet?
  • RunaR
RunaR
Verwijderd schreef op maandag 26 januari 2009 @ 16:21:
Ja, dat klopt (een beetje).
In die tutorial zorgt het deel: auth.require = ( “/clutch/” =>, dat de /clutch directory beveiligd wordt. De rest is nog steeds open. Ik heb daar auth.require = ( “/” => van gemaakt en nu is alles beveiligd.
Het is me nog niet gelukt om 1 deel achter een password te zetten en alleen dat deel extern te gebruiken. En een deel alleen voor intern te kunnen gebruiken. Dan zou je lighttpd 2x moeten draaien ofzo.
Ik vond later dat je wel een deel kan beveiligen en een deel open kan laten
[ Voor 35% gewijzigd door RunaR op 26-01-2009 17:11 ]
RunaR schreef op maandag 26 januari 2009 @ 16:50:
Ja, dat klopt. Het is me nog niet gelukt om 1 deel achter een password te zetten en alleen dat deel extern te gebruiken. Dan zou je lighttpd 2x moeten draaien ofzo.
Zit wat in, de reden dat ik het vroeg was namelijk nzbgetweb, die 'host' ik ook en daar zit al een username/pw optie in (dus das dubbel op...)
  • DanielZ
Verwijderd schreef op maandag 26 januari 2009 @ 15:45:
Dat komt omdat ik er zelf ook een soort van write-up / tutorial van wil / ga maken. En daar zet ik alle problemen in die ik tegen kwam met de oplossingen :)
Dit krijg ik te zien in Nzbgetweb 1.3
ERROR Mon, 15 May 2000 03:11:26 +0000 Could not start script: Permission denied
en dit zijn de permissies van de 2 unpak bestanden:
-rw-r--r-- 1 root root 13217 May 14 11:54 unpak.cfg
-rw-r--r-- 1 root root 74535 May 14 11:54 unpak.sh
Is er toevallig ook een manier om dit unpak proces te herstarten?/ om de gedownloade bestanden uit te pakken?
En ik heb ergens gelezen dat twonky goed werkt met de Xbox 360. Iemand een installatie link/tutorial van?
Gr
  • RunaR
RunaR
je unpak.sh is niet executable. chmod a+x unpak.sh
[ Voor 4% gewijzigd door RunaR op 26-01-2009 18:56 ]
  • DanielZ
RunaR schreef op maandag 26 januari 2009 @ 18:26:
je unpak.sh is niet executable. chmod a+x inpak.sh
Ik heb hier geen inpak.sh staan? ik heb unpak-update.rar gedownload van http://www.aroundmyroom.com/ch3snas-funplug/ en die in /ffp/etc gezet..
inpak.sh niet nodig chmod +x unpak.sh en alles werkt als een trein :D
Waar kan ik inpak.sh vandaan halen?
Ieman die me kunt helpen met Twonky te installeren?
[ Voor 16% gewijzigd door DanielZ op 26-01-2009 20:19 ]
  • RunaR
RunaR
http://wiki.dns323.info/howto:twonkyupnpserver
[ Voor 99% gewijzigd door RunaR op 26-01-2009 20:42 ]
  • zeroday
  • Laatst online: 22:55
zeroday
There is no alternative!
anconakip schreef op maandag 26 januari 2009 @ 16:17:
als je het script wat ik gebruik unpak.cfg/unpak.sh doorleest dan werkt dat vast en zeker
zie voorbeeld: erotica die ik een vast naam heb gegeven ..
unpak_subfolder_by_newsgroup_1="erotica:/mnt/HD_a2/usenet/Erotica"
unpak_subfolder_by_newsgroup_2="pictures:/mnt/HD_a2/Pictures"
dat kan dus ook naar een andere HDD
There are no secrets, only information you do not yet have
Hallo
Ik heb pas een DNS-323 gekocht, met daarin 2x 1 TB schijven
Ik ben bezig geweest met eerst Telnet, en daarna met Debian Etch te installeren. Ik krijg als newbie in Debian het niet voor elkaar goed werkend te krijgen. :(
Daarnaast beginnen de netwerkverbindingen die ik heb met de DNS-323 te klapperen; de ene keer is de verbinding wel beschikbaar, de andere keer niet:
"Er is een fout opgetreden tijdens het herstellen van de verbinding met...
Microsoft Windows netwerk: De lokale apparaatnaam wordt al gebruikt
Deze verbinding is niet hersteld.:"
en nog een andere melding. }:O
Ik heb het idee dat dit te maken heeft met het installeren van Debian op de DNS-323. Daarom wil ik deze deinstalleren, maar ik kan er niet uit komen hoe ik dat verwijderen kan. Ik wil gewoon weer terug naar de oorspronkelijke situatie
Moet ik de dirs waar het in staat verwijderen? (../etch/.. en lnx_bin) en zo nee waarom niet? :?
moet ik firmware update of opnieuw installeren en zo nee waarom niet? :?
moet ik de schijven opnieuw formatteren en zo nee waarom niet? :?
heel graag hoor ik een oplossing wat ik het beste kan doen.
Hartstikke bedankt voor het antwoord alvast!
gtz
Yellowflag :)
  • Prulleman
Prulleman
Verwijderd schreef op dinsdag 27 januari 2009 @ 09:53:
Hallo
gtz
Yellowflag :)
Klinkt alsof er ip conflicts zijn, misschien omdat de ingebouwde distro en debian naast elkaar hetzelfde werk proberen te doen...
Als je niet weet wat je ermee wilt gaan doen kan je beter debian links laten liggen en beginnen met de standaard packages voor deze nas (nzbget, transmission, lightpd, enz.) maar eerste bedenken wat je ermee wilt doen natuurlijk :)
verder zou je met het verwijderen van de debian mappen en een factory reset weer netjes opnieuw moeten kunnen beginnen. Je dat zou als het goed is moeten blijven zoals het is. Maar ik zou nog even wachten op een extra bevestiging ;)
Strava
  • RunaR
RunaR
gtz
Yellowflag :)
Welkom op GoT. Groeten is hier niet nodig. Iedereen groet elkaar standaard al.
Volgens mij (geen ervaring met Debian) is je nas weer helemaal standaard als je de debian directories er afgooit. Het makkelijkst is waarschijnlijk de fun_plug disablen, door het bestand te hernoemen. Of door de originele fun_plug er overheen te zetten. Dan heb je weer een telnet en kan je met voldoende rechten de boel schoon maken.
Als je geen custom firmware er in hebt zitten hoef je die ook niet opnieuw te flashen.
Schijven formatteren is ook een manier om de directories te verwijderen. Beetje rigoureus en je hebt kans op het 94% probleem.
Blijft bij mij altijd de vraag waarom iedereen er meteen debian op zet. tegenwoordig kan bijna alles met fun_plug. Die ene tutorial is een beetje achterhaald.
  • Mattie84
  • Laatst online: 11-11 07:06
Runar, misschien zouden we een compleet nieuwe tutorial moeten neerzetten in de OP in een nieuw deel (voor zowel USB als op de HDD). Gelijk met werkende configs voor nzbget en lighttpd 8)7
Debian is ook naar mijn mening achterhaald en niet zo makkelijk als de funplug
Misschien een idee?
  • zeroday
zeroday
Om eens en voor altijd een 'goede' how-to te hebben voor nzbget & nzbgetweb & lighthttpd
http://www.aroundmyroom.c...how-to-that-replaces-all/
Enjoy!
  • anconakip
zeroday schreef op dinsdag 27 januari 2009 @ 09:13:
ik heb jou script gebruikt. Jouw regels heb ik veranderd in;
unpak_subfolder_by_newsgroup_1="Series:/mnt/HD_a2/Video/Series"
unpak_subfolder_by_newsgroup_2="Film Humor:/mnt/HD_b2/Film Humor"
maar er gebeurt niets. Hij pakt gewoon nog op de oude plek uit.
  • DanielZ
En als we een mac gebruiken? :)
[ Voor 41% gewijzigd door DanielZ op 28-01-2009 11:16 ]
  • DeOS
Dan gebruik je i.p.v. putty een ssh client die op je Mac werkt }:O .
  • DanielZ
DeOS schreef op dinsdag 27 januari 2009 @ 15:00:
i know maar er staat " run the .exe file and follow the install"
daarom ;)
  • Markie2202
  • Laatst online: 12-06 09:12
Zijn er mensen die de CH3SNAS gebruiken met Windows Vista Ultimate SP1. Ik zit namelijk met hetvolgende probleem:
Ik heb 2 notebooks met Windows Vista Ultimate SP1, en 1 werkstation met Windows XP pro SP3. Heb fun plug 0.5 geinstallerd. Nu wil ik met de CH3SNAS offline bestanden gebruiken. Als ik dit doe met de XP machine werkt alles perfect. Maar als ik dit doe met de Vista dan krijg ik de volgende foutmelding:
Het proces heeft geen toegang tot het bestand omdat het door een ander proces wordt gebruikt.
Ik heb heel het internet al gehad, maar heb nog geen oplossing kunnen vinden. Het schijnt iets te maken te hebben met oplocks. Nu heb ik op mijn CH3SNAS al geprobeerd om de smb.conf aan te passen met deze configuratie aanpassing. Als ik dan de NAS opnieuw opstart zijn deze wijzigingen weer ongedaan.
Alvast bedankt voor de hulp _/-\o_
  • Prulleman
Prulleman
Je hebt zelfs een putty port voor symbian S60 (nokia) 8)
afgezien van het lastig commando's kloppen op een numeriek tobo werkt het prima :)
[ Voor 8% gewijzigd door Prulleman op 27-01-2009 16:27 ]
Strava
  • Krypt
Markie2202 schreef op dinsdag 27 januari 2009 @ 15:19:
Markie, voor dat restart probleem, lees deze eens door: Krypt in "[NAS] Conceptronic CH3SNAS / Dlink DNS-3..."
Pvouput live
  • zeroday
zeroday
DanielZ schreef op dinsdag 27 januari 2009 @ 14:46:
Dan schijn je veel verstand te hebben. Maar volgens mij is alles wat ik opnoem op de mac te doen.
  • zeroday
zeroday
anconakip schreef op dinsdag 27 januari 2009 @ 14:44:
Op gebied van Film en series zul je toch e.e.a. meer moeten veranderen in het script
Ik zou zeggen: print het script uit en loop het even na .. d'r staat genoeg info die je kan gebruiken.
Als je iets speciaals wil, dan moet je er wat werk voor verzetten
  • zeroday
zeroday
DanielZ schreef op dinsdag 27 januari 2009 @ 15:19:
daarom ;)
ik kom dat in mijn text niet tegen
Now we download: PUTTY
http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe
this tool will allow you to logon to the shell of the CH3SNAS and configure the device further
Kijk .. een klein beetje eigen initiatief mag je toch wel verwachten hier?
shell, putty, telnet mac .. www.google.com ?
  • Prulleman
Prulleman
Strava
Bedankt voor je aangepaste bericht, ik heb het uitgevoerd hoe je het omschrijft. Na mijn eigen fouten gecorrigeerd te hebben werkt het prima! Kan nu rustig op mijn werk goeie muziek luisteren :) Mijn dank!
Is musicbrowser wellicht iets voor de eerste pagina van dit topic???
[ Voor 3% gewijzigd door Verwijderd op 27-01-2009 20:53 ]
  • RunaR
RunaR
Het zal in iedergeval dan voor de TS van deel 3 zijn. De topic starter heeft zijn NAS een paar maanden terug verkocht.
De music browser is super. Nu nog een mobile telefoon die de muziek kan spelen via de musicbrowser én een audio out heeft. Dan kan ik die op mijn autoradio aansluiten.
=> nooit meer cd's wisselen en al mijn muziek beschikbaar.
[ Voor 49% gewijzigd door RunaR op 27-01-2009 21:42 ]
  • groennom
Vraag: Ik gebruik mijn CH3SNAS in combinatie met de CFULLHDMA. In principe werkt dit vlekkeloos, ik merk echter wel dat mijn opnames enorm haperen en soms zelfs vastlopen. Ook merk ik dat dit steeds vaker gebeurt naarmate de CH3SNAS langer up is (oftewel, na een reboot lijkt het probleem tijdelijk verholpen).
Ik heb een mappenstructuur waarin ik al mijn bestanden (films, foto's en mp3) onder een submap heb staan (/mnt/HD_a2/share). Eerst heb ik een aparte map voor mp3 aangemaakt (/mnt/HD_a2/mp3), toen leek het probleem verholpen (gaat ook om 1000'en mp3 bestanden). Ik had / heb het idee dat de NFS shares om de een of andere reden niet een groot aantal bestanden aan kan.
Een andere mogelijkheid is dat. door het downloaden parren en unrarren, de processor en / of het geheugen niet worden vrijgegeven ook al wordt er niet gedownload. Heeft iemand anders ook dit probleem? En kun je zien op de NAS hoeveel processor belasting is en wat het geheugen gebruik is? Indien meer info nodig dan hoor ik het graag!
