Afbeeldingslocatie: http://global.msi.com.tw/uploads/prod_8cd1237b5f99ef0f4756f3ff72429dbd.jpg
Marketing Name: Media Live
Model Name: MS-6421;MS-7329
PCB Version: 1.2
BIOS Version: A7329NMS.110
Feature
7-in-1 Flash Card Reader
The Card reader supports CF/SD/MS/MS-Pro/SM/MMC/MD memory card, which helps user to import digital photos conveniently into their system.
Suction Type Optical Driver
The suction-type optical driver provides an extremely easy and convenient way of inserting or ejecting the disk.
Fancy LED
The fancy LED is a status-displaying panel that easily shows the status details of the DVD, music, pictures, TV programs and messages.
Full set of connecting ports
It comes with full set of connecting ports including USB and IEEE 1394 ports, as well as a DV output, S-video port, and multi-channel audio output, which support the connection to most of the consumer electronics such as TVs and stereo sets.
Specification
Processor SupportSupport AMDR Athlon 64 X2, Athlon 64 and Sempron in the Socket AM2 package.
Supported FSBHyperTransport supporting speed up to 1GHz (2000MT/s)
ChipsetNorth Bridge: nVidia® C51PVG Chipset
South Bridge: nVidia® MCP51 Chipset
VideoNVIDIA GeForce 6150
MemorySupports DDR2 400/533/667/800 SDRAM (4GB Max)
4 DDR2 DIMMs (240-pin, non-ECC / 1.8V)
LANSupports 10/100/1000 Fast Ethernet LAN by Vitesse® VSC8601
IEEE 1394Chip integrated by VIA® VT 6308P
Transfer rate is up to 400Mb
AudioChip integrated by Realtek® ALC883
Flexible 8-channel high definition audio with jack sensing
Compliant with Azalia V1.0 Spec
IDESupports 2 IDE ports by nVidia® MCP51
Supports Ultra DMA 66/100/133 mode
Supports PIO, Bus Master operation mode
SATASupports 4 SATA2 ports by nVidia® MCP51(2 SATA2 ports only for Media Live)
Supports storage and data transfers at up to 300 MB/s
Support RAID 0, 1 or JBOD
Floppy1 floppy port
Supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
ConnectorsBack Panel
3 Component Video Out (RGB)
8 Audio RCA Out (for 8-channel audio support)
1 HDMI
1 Digital Video Out (HDMI)
4 USB 2.0 Ports
1 IEEE 1394 Port
3 AV Out
1 S-Video Out
1 SCART Out
1 Graphics Card Out (D-Sub)
1 LAN Jack (RJ45)
1 Digital Audio Out (Coaxial)
1 Digital Audio Out (Optical)
Front Panel
1 Headphone (Green)
1 Microphone (Pink)
1 IEEE 1394 Port
2 USB 2.0 Ports
4 Slots 3.5" Memory Card Reader
On-Board Pinheaders
- 2 USB 2.0 Pinheaders
- 1 CD-In Pinheader
- 1 TV-Out Pinheader
- 2 SPDIF-Out/In Pinheaders
- 1 Graphics Card Pinheader
VFDVFD (integrated Bluetooth v2.0+EDR and Wi-Fi/IEEE802.11b+g, Optional)
Slots1 PCI slot
Supports 3.3V / 5V PCI bus Interface
Form FactorStandard Micro-ATX (24.4 cm X 24.4 cm)
Mounting8 mounting holes
Front View
Afbeeldingslocatie: http://global.msi.com.tw/uploads/Image/product_img/other/slim/6421/6421_1.jpg
1. Microphone (Pink)9. Rew Button
2. USB 2.0 Port10. Fwd Button
3. IEEE 1394 Port11. Skip Button
4. USB 2.0 Port12. On / Standby
5. Headphone (Green)13. Eject Button (for ODD)
6. Stop Button14. Slim Slot-In Optical Disk Drive
7. Play Button15. Memory Card Reader Drive
8. Replay Button16. Integrated VFD Module
Rear View
Afbeeldingslocatie: http://global.msi.com.tw/uploads/Image/product_img/other/slim/6421/6421_2.jpg
1. Ventilation Hole9. AV Out
2. Power Switch10. S-Video Out
3. Power Jack (AC In)11. SCART Out
4. Component Video Out12. Graphics Card Out (D-Sub)
5. Audio RCA Out13. LAN Jack (RJ45)
6. Digital Video Out (HDMI)14. PCI Expansion Slot
7. USB 2.0 Ports15. Digital Audio Out (Coaxial)
8. IEEE 1394 Port16. Digital Audio Out (Optical)
Succesfully Tested CPU's
Athlon 64 x2 3600+ (65W)
Athlon 64 x2 4000+ (65W)
Athlon 64 x2 4400+ (65W)
Athlon 64 x2 4800+ (65W)
Athlon 64 x2 5000+ (65W)
Athlon 64 x2 5200+ (65W)
Athlon 64 x2 3800+ (65/89W)
Athlon 64 x2 4200+ (65/89W)
Athlon 64 x2 4600+ (65/89W)
Athlon 64 x2 5000+ (89W)
Athlon 64 x2 4000+ (65/89W)
Athlon 64 x2 4400+ (65/89W)
Athlon 64 x2 4800+ (65/89W)
Athlon 64 x2 5200+ (89W)
Athlon 64 FX62 (125W)
Athlon 64 3000+ (62W)
Athlon 64 3200+ (62W)
Athlon 64 3500+ (62W)
Athlon 64 3800+ (62W)
Sempron 3000+ (62W)
Sempron 3400+ (62W)
Sempron 3600+ (62W)
Sempron 3800+ (62W)
Sempron 2800+ (62W)
Sempron 3200+ (62W)
Sempron 3500+ (62W)
Used Motherboard
Afbeeldingslocatie: http://217.110.237.67/news/7329-010R.gif
MSI 7329-010R
Video Chipset (NVidia Geforce 6150) Tests/Reviews
The Tech Report
Planet X64
X-bit labs
Cooling System
The Media Live is designed to operate with just two quiet fans, keeping the overall level of noise down. However the CPU cooler provided is designed to suck cold air in through the top of the case, and then exhaust the heated air into the case. For lower power processors, this may not be the most effective cooling. The fan in the cooler can be flipped through 180degrees in order to exhaust the hot air through the top of the case, rather than into the case. To do so, carefully unclip the large black plastic surround from around the top of the radiator assembly and pull off. This will allow the fan and it's capture assembly to slide out sideways. Remove the fan capture assembly from the fan, flip the fan through 180 degrees and realigh the capture assembly. Putting it back together is simply a case of re-inserting the fan aseembly under the radiator and then clipping the black plastic housing back on again.
PCI/PCI Express
The motherboard provided has a 1x PCI express socket, but this is masked by the PCI riser. It MAY be possible to replace the PCI riser with a PCI express riser and thus use the PCI express functionality.
Dependant on the CPU, this can result in lower internal temperatures, which can be useful, given how hot some tuners run.
Supported Media Centers
Windows MCE
MythTV
Reden van dit Topic
De reden dat ik dit topic open is dat ik op zoek ben naar de voor mij ultieme HTPC. Het is de bedoeling dat er één centrale plek komt voor al mijn media bestanden. Dit gaat gebeuren dmv. een NAS.
Daarnaast wil ik op elke plek waar het nodig is een kleine media player plaatsen, die alles wat op de NAS staat kan afspelen. In eerste instantie heb ik een Xbox 360 aangeschaft die als Extender dient voor Windows Media Center die op een PC draait. Wat games betreft is het natuurlijk een geweldig product, maar de ondersteuning van verschillende videoformaten valt behoorlijk tegen.
Inmiddels heb ik ook de verschillende UnPn clients bekeken. Het nadeel van deze apparaten is dat je altijd wel weer een codec mist. Ik wil gewoon elk willekeurig videobestand kunnen afspelen, nu en in de toekomst. Dus toen kwam ik terrecht op het bouwen van een HTPC. Na veel zoeken ben ik min of meer bij toeval terecht gekomen op de MSI Media Live. Wat mij betreft the best of both worlds, een apparaat met het formaat dat enigzins in de buurt komt van een UnPn client en de mogelijkheid om een eigen besturingssysteem te installeren, wellicht op een CompactFlash kaartje.
Ik heb nog niet zoveel ervaringen en reviews kunnen vinden op het Internet en hoop dat dmv. van dit topic hier wat meer over te horen.
Voor mij is het van belang dat hij videobestanden (vooral High Definition) flekkeloos afspeelt vanaf de NAS die dmv. Gigabit met elkaar verbonden zijn.
[ Voor 7% gewijzigd door Verwijderd op 04-12-2007 10:25 ]
  • Sappie
  • Laatst online: 28-10 10:54
Sappie
De Parasitaire Capaciteit!
Ik ben ook gecharmeerd van de media live. De looks vind ik erg netjes (met uitzondering van het grote MSI logo) en ook de specs zijn voldoende. Als het apparaatje een beetje oke blijkt, ga ik er waarschijnlijk binnenkort ook een aanschaffen.
Ik heb me dr een tijdje geleden enigszins in verdiept. Onder Windows MCE schijnt alles goed te werken (als ik het me goed herinner). Met mediaportal waren er wat problemen mbt de VFD. MythTV schijnt nu ook redelijke support te bieden (http://www.mythtv.org/wiki/index.php/MSI_Media_Live).
Verder zouden er wat, niet onoverkomelijke, problemen met het bios zijn. CPU die niet goed wordt herkend e.d.
Heb helaas dus ook geen ervaring met dit apparaat, maar ben naast de TS ook benieuwd naar ervaringen van tweakers :)
Specs | Audioscrobbler
  • DubbelU
  • Laatst online: 22-10 07:14
Is dit nou alleen een htpc behuizing? Of kan je dit ding kant en klaar kopen en dan als htpc gebruiken?>
Overigens een prima topic! Ik ben ook op zoek naar een simpele, maar wel alles-kunnende HTPC.
[ Voor 31% gewijzigd door DubbelU op 04-12-2007 11:58 ]
Als ik het zo zie is het een behuizing met mobo (met onboard sound/vga). CPU, geheugen, hdd er erbij en je kunt gaan.
Al is het me niet helemaal duidelijk of die Slim Slot-In Optical Disk Drive er ook al bij zit.
Edit: lijkt er op dat ie d'r bij zit. Alleen jammer van het prijskaartje, een dikke 300E. Gaat hem met de komende upgrade niet worden ben ik bang :(
[ Voor 26% gewijzigd door Verwijderd op 04-12-2007 12:11 ]
  • Gait
  • Laatst online: 13:22
Dus met al dit ding kun je nog niks beginnen dan komt er dus nog vanalles bij?
  • DubbelU
Wat zijn de afmetingen van de behuizing? En waarom is dat kreng zo duur?
  • kaajee
  • Laatst online: 07-10 08:04
DubbelU schreef op zaterdag 08 december 2007 @ 19:25:
Hij is 32cm diep. (Dimension: 320mm (D) x 430mm (W) x 80mm (H) )
Hier de directe link naar dat (lellike) ding...... :9
En hier is ie ook al even kort besproken....
  • Sappie
Sappie
Ik sta op het punt er een te bestellen, maar vraag me nog een ding af, nl: is het Windows Remote Keyboard te gebruiken icm de ingebouwde IR ontvanger. Ik neem aan van wel, maar zou het graag even zeker weten. Iemand die dat kan bevestigen?
speelt het 1080p,
en in H264 formaat ?
Sorry, in de bron wordt het getest.
Maar het antwoord is dus JA prima
[ Voor 48% gewijzigd door Verwijderd op 10-12-2007 19:53 ]
  • kaajee
Verwijderd schreef op maandag 10 december 2007 @ 19:50:
speelt het 1080p,
Dat ligt er natuurlijk wel helemaal aan welke CPU je er in zet. Als je er AMD Sempron 3200+ in zet wet ik zeker dat ie geen 1080p afspeelt. Buiten dat: zoveel reviews zovveel resultaten. Ik heb al verschillende gelezen dat het met zowel de 6150 als de 690g eigenlijk niet mogelijk is vloeiend HD (1080p) materiaal af te spelen. Dus staar je er niet blind op.......
  • Sappie
Sappie
kaajee schreef op maandag 10 december 2007 @ 21:57:
Ik sta, zoals al duidelijk was, op het punt er een te kopen. Dit in combinatie met een Athlon X2 4800+. Heb je links naar deze reviews?
  • Noxa
  • Laatst online: 28-10 22:27
Dus als ik het goed begrijp is dit een vrij volledige behuizing. Alle slots en porten zitten erop, hij moet alleen nog even gevuld worden. Er zit wel een video chipset in, alleen nog geen geheugen, processor, HDD en DVD-drive?
  • Sappie
Sappie
Noxa schreef op dinsdag 11 december 2007 @ 11:53:
Hij is inderdaad vrij volledig. Het moederbordje wat er bij zit bezit onboard audio en video. Er is een geheugenkaart lezer in de behuizing geïntegreerd en de slot-in slimline DVD-RW is reeds ingebouwd. Je hebt dus inderdaad alleen geheugen, processor een HDD en eventuele randapparatuur nodig.
  • Sappie
Sappie
Bij deze even mijn eerste indrukken. Ik heb hem namelijk besteld en in elkaar gedraaid.
Het is een erg mooie behuizing imho, zowel van binnen als van buiten. Vwb de buitenkant is dat uiteraard subjectief en ik vind em mooi. Het is echter wel jammer dat de voorkant van plastic is. De binnenkant is gewoon erg netjes. Alle kabeltjes mooi weggewerkt en alles is al aangesloten (ook de DVDRW).
Het installeren van de cpu koeler is een crime; ik heb de voeding en de PCI riser kaart eruit gehaald omdat ik het allemaal niet goed kon zien. Nadat de cpu koeler is geplaatste is de rest (in mijn geval een harddisk en 2 reepjes geheugen) een eitje.
Ik ga binnenkort mediaportal installeren en zal dan verdere ervaringen posten. Ik zal hem, totdat er een LCD tv is, gaan gebruiken icm een ouderwetse tv en zal dan ook de scart aansluiting gebruiken.
  • kaajee
Sappie schreef op vrijdag 14 december 2007 @ 10:21:
Leuk! Kan je niet een paar fotootjes maken en posten? Altijd leuk en nuttig. Mn. gezien de moeite om een CPU te plaatsen, kan nuttig zijn......
  • Sappie
Sappie
kaajee schreef op vrijdag 14 december 2007 @ 10:30:
Heb geen digicam helaas en mn telefoon maakt erg slechte pics die het tonen niet waard zijn. Ik zal binnenkort es kijken of ik wat foto's kan maken. Ben nu aan het vechten met de tv-out, wil op een of andere manier niet echt snel lukken :s
  • Noxa
Wat voor hardware heb jij erbij gekocht? En welke motivatie had je daarbij? En hoeveel ben je nu in totaal kwijt geweest voor je setup?
  • Sappie
Sappie
Dit was mn bestelling:
AMD Athlon 64 X2 Dual-Core 4800+ | ADO4800DDBOX € 91.90
Kingston Memory 2GB 800MHz DDR2 Non-ECC CL5 Kit 2 | KVR800D2N5K2/2G € 47.00
MSI Media Live Silver € 308.70
Samsung 500GB Serial ATA II HDD | HD501LJ € 89.30
Trust Wireless Media Center Keyboard KB-2950 | 14909 € 44.00
Maakt in totaal € 580,90
Geld zat dus, maar ik vind het het wel waard. Motivatie voor verdere hardware; ik wilde even vooruit kunnen en in de nabije toekomst ook kunnen genieten van HDTV (iig 720p). Daarbij redelijk wat schijfruimte voor allerlei media en een draadloos RF toetsenbordje voor het bedieningsgemak.
Ik heb Mediaportal nu draaiend en alles werkt eigenlijk prima (ook de VFD). Zojuist ook wat HD trailers (720p en 1080p) geprobeerd en zo op het eerste gezicht lijkt alles prima te draaien, heb geen flauw idee of het zware HD trailers waren maargoed :)
Moet me nu nog es wat verder verdiepen in Mediaportal, want er is erg veel mogelijk (zoals ook uit dit topic blijkt: Media Portal erg mooi alternatief voor Windows Media Center).
  • Noxa
Sappie schreef op vrijdag 14 december 2007 @ 17:12:
Ok dat klinkt wel interesant. Ik vind 580 euro ook wel een schappelijke prijs voor zo'n samenstelling. Is je fan een beetje huiskamer stil?
  • Sappie
Sappie
Noxa schreef op zaterdag 15 december 2007 @ 11:49:
Nog niet echt tijd gehad om daarnaar te kijken. Wel maakt de "Smart fan" bios optie veel verschil heb ik zo snel gemerkt. Wanneer ik meer tijd heb gehad zal ik wat verdere ervaringen posten.
  • rachez
  • Laatst online: 31-10 18:47
Ik heb zojuist de msi media live ook besteld. Mijn redenen om deze te bestellen ipv een los samen te stellen systeem:
  • Geringe diepte van de behuizing: 32 cm.
  • Afstandsbediening bijgeleverd.
  • HDMI aansluiting.
  • redelijk stil.
Als hij binnen is zal ik ook mijn ervaringen posten.
  • rachez
Alles binnen, bijna dezelfde config als Sappie:
AMD Athlon 64 X2 Dual-Core 5000
MSI Media Live
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0231_resize.JPG
Voorkant:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0234_resize.JPG
Achterkant:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0239_resize.JPG
Frontaansluitingen:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0244_resize.JPG
Bijgeleverd:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0249_resize.JPG
De binnenkant is netjes afgewerkt.
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0251_resize.JPG
Koeler is erg stil icm Cool & Quiet van AMD:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0265_resize.JPG
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0268_resize.JPG
Cpu en memory geplaatst:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0273_resize.JPG
Om de HD-cage eruit te krijgen moet het frontje los, er is plaats voor 2 stuks:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0275_resize.JPG
Er zit een PCI riser kaart in. Als je deze weghaalt komt de PCI-E slot te voorschijn:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0288_resize.JPG
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0290_resize.JPG
Klaar. Toetsenbordje van Trust werkt heerlijk vind ik:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0301%20resize.jpg
Ik heb er XP pro op draaien en met dank aan dit topic mediaportal geinstalleerd. Mijn tv is een panasonic hd ready plasma en de msi kan hier al het HD materiaal op afspelen. Ik vind hem overigens erg stil. Al met al ben ik zeer tevreden!
  • kaajee
Leuk en nuttig verslag!!
Gaat er eigenlijk nog een fan op die CPU cooler of niet?
En als er nog een fan op gaat, welke is dut?
Waar zitten de evt. fans eigenlijk allemaal ?
  • rachez
Thanks.
De fan van de cpu koeler zit onder die radiator, je ziet hem van boven niet zitten. Je kunt hem net zien zitten op de 7de foto hierboven Hij zit tussen de radiator en de base. Merk van de fan geen idee.
Er zitten in totaal 2 fans in het systeem, een voor de cpu en een in de voeding. Als je Cool & Quiet gebruikt, hoor je ze amper en ik ben best kritisch mbt geluid en pc's. Er zijn geen montagemogelijkheden voor extra fans.
Nog een tip voor als iemand problemen heeft bij het monteren van de koeler: Let erop dat je niet als een lompe aap (zoals ik :P ) op de koeler zelf drukt maar op het omcircelde zwarte nokje van de koeler op de foto hieronder. Het staat wel in de gebruiksaanwijzing, maar niet echt duidelijk.
Afbeeldingslocatie: http://84.83.235.227:81/htpc/IMG_0293_resize.jpg
Nog een voorbeeldje van Mediaportal:
Afbeeldingslocatie: http://84.83.235.227:81/htpc/http%20mp%202%20res.jpg
[ Voor 9% gewijzigd door rachez op 20-01-2008 13:57 ]
  • Sappie
Sappie
Nette fotoshoot rachez :)
Ging het installeren van de cooler bij jou eenvoudig? Hier was het echt een ellende. Het was zelfs zo dat ik een klein stuk plastic van de cooler heb afgeknipt met een tang, omdat het anders met geen mogelijkheid pastte (waarschijnlijk een klein foutje ofzo).
Verder ben ik ook erg tevreden over de Media Live. In combinatie met Mediaportal speelt ie alles af en hij is behoorlijk stil. Ik gebruik ipv AMD's Cool & Quiet de MSI Smart Fan optie in de bios, die werkt ook prima. Voor wat betreft het toetsenbord; als ie werkt doet ie het prima. Er zijn echter momenten dat de verbinding wegvalt / hapert, maar gelukkig is dat niet al te vaak.
  • rachez
Nee het installeren van de cooler was inderdaad geen pretje. maar toen ik een schroevendraaier op dat zwarte nokje zette, klikte hij er zo in.. Ik heb niets hoeven afknippen, wel inderdaad veel moeten verwijderen om goed te kunnen zien waar ik nu mee bezig was.
MSI smart fan heb ik nog niet geprobeerd, eens kijken of dat nog wat uitmaakt.
Welke codecs gebruik jij? Ik vond in eerste instantie het beeld wat flets, maar gebruik nu ffdshow voor video_ts en coreavc voor x264 met een goed resultaat.
  • knakworst
  • Laatst online: 31-10 20:16
knakworst
Get more sats!
mooie fotoshoot rachez.
Ik ben ook van plan om deze kast aan te schaffen, vooral omdat ik de SCART wil gebruiken. Ik heb nog wel een aantal vraagjes:
Zit er al een DVD-speler ingebouwd of moet je een slot-in DVD-speler los bijkopen? De website van MSI is niet duidelijk hierover.
Zit er wifi ingebouwd?
Ik heb zelf nog een analoge breedbeeld-tv die ik nog niet weg wil doen. Hoe is de resolutie van de scart op de TV?
En meer een vraag over media center in het algemeen: zijn mp3's goed te bedienen zonder de TV aan te hebben?
  • kaajee
Over die SCART aansluiting gesproken.....wat spuugt die uit eigenlijk? Kan ik nergens vinden.....
composiet? s-video? RGB? (of combi?)
  • rachez
DVD: slot-in DVD speler ingebouwd. Schijnt zelfs een burner te zijn. Niet geprobeerd.
Wifi: er zit een " wireless bluetooth connector 802.11g" in. Ik heb er geen connect mee kunnen maken naar mijn router. Nou heb ik daar ook niet veel tijd ingestoken omdat ik met een utp kabel werk ivm HD-content.
SCART: supports 480i. Er zit een jumper op het moederbord waarmee je vwb scart out kan kiezenvoor het beeldformaat: 4:3 of 16:9 en een jumper voor external composite video source of external rgb video source.
Display is heel summier qua info, veel meer dan een klok displayen heb ik hem nog niet op kunnen betrappen. Mp3's afspelen zonder de tv aan wordt daarom lastig.
  • Alex)
  • Laatst online: 27-10 22:33
Hmm, dit ziet eruit als een erg mooi kastje. Is er ook iemand die er Windows Vista op heeft gezet en daar het Media Center van gebruikt? Zo ja, draait dat een beetje vlotjes enzo? :)
En dat display... hoe werkt dat, kun je daar zelf iets mee doen? Lijkt me wel leuk om het als Sideshow-device ofzo te gebruiken. Of om er eigen tekst op te tonen o.i.d.?
We are shaping the future
  • kaajee
Alex) schreef op dinsdag 22 januari 2008 @ 23:37:
Huh? Dat heeft toch geen drol met het kastje (zelf) te maken? Je kunt er in principe inzetten wat je wilt........qua CPU, geheugen & disk in ieder geval en er zit zelfs een PCIe slot op........
En display: vergeet alle extra mogelijkheden maar, het is een 'gewoon' simpel VFD schermpje, meer dan de tijd of bijv. de MP3 die 'momenteel' afgespeeld wordt zit er niet in.....
Dus geen 'navigatie mogelijkheden' en ook niet als SideShow device te gebruiken.......
  • Alex)
kaajee schreef op dinsdag 22 januari 2008 @ 23:54:
Ik bedoelde: er zit onboard video op, is dat een beetje redelijk spul (kan het Aero enzo aan)?
Ok, thanks :)
  • kaajee
Alex) schreef op woensdag 23 januari 2008 @ 00:01:
Er zit een NVIDIA GeForce 6150 grafische kaart in/op die moet prima in staat zijn Vista te draaien, zelfs Aero. Ok zal niet top-of-the-bill zijn. Maar als je het hebt over Vista MCE heb je toch niets aan Aero? Dan draai je de grafische schil van MCE en dat heeft niets met Aero te maken (daar zie/merk je niets van onder MCE). Sterker nog: als je MCE gebruikt zou ik Aero juist uitzetten.....
En anders, zoals gezegd, er zit een PCIe slot op dan kun je tzt altijd nog een andere VGA kaart inzetten. Dan verlies je waarschijnlijk wel de mogelijkheid een PCI kaart (tuner?) te gebruiken. Of het wordt modden en proppen...... :P
  • Sherlock
  • Laatst online: 31-10 19:26
Sherlock
No Shit
Hmm, die ziet er inderdaad wel erg interessant uit. Dit is echt een goede kandidaat om straks mijn dvd-speler en videorecorder (ja echt waar :'( ) te vervangen.
@rachez: ik kan je foto's niet zien, ligt dat aan mij of zijn ze weg?
[ Voor 18% gewijzigd door Sherlock op 23-01-2008 11:19 ]
And if you don't expect too much from me, you might not be let down. Gin Blossoms - Hey Jealousy
  • knakworst
knakworst
Get more sats!
Wat is eigenlijk het bereik van het trust toetsenbord, daar lees ik nog wel wat klachten over namelijk. Ik vind die logitech dinovo edge alleen een beetje duur, en het toetsenbord van microsoft is blijkbaar ook niet best als ik de reviews lees.
  • Vos
  • Laatst online: 10:18
Vos
AFCA
@rachez
Met die:
AMD Athlon 64 X2 Dual-Core 5000 en NVIDIA GeForce 6150 ben je goed in staat 1080p HD films te bekijken?
* Vos is noob op dit gebied
#36
  • knakworst
knakworst
Get more sats!
Vos schreef op woensdag 23 januari 2008 @ 11:42:
@rachez
Met die:
Goed inleestopic is deze: Nieuwe stille HTPC die op de toekomst is voorbereid
Heb ik ook al een heleboel info vandaan gehaald. Ik denk dat je met het systeem een heel eind komt, behalve een veelbesproken vogelscene (zie hiervoor mijn aangehaalde topic).
[ Voor 12% gewijzigd door knakworst op 23-01-2008 12:16 ]
  • vanenkelen
  • Laatst online: 11:05
vanenkelen
uhmmm.....speechless
Bedankt voor die uitgebreide fotoshoot en uitleg. Ik overweeg dit apparaat ook aan te schaffen, maar twijfel nog omdat het voor mij nog niet duidelijk is of je de PCI-Express slot ook daadwerkelijk kunt gebruiken (bijv voor een Vista Saber TV kaart).
Past een low-profile kaartje of zit er geen opening achter in de kast?
Zijn er PCI-E riser kaartjes die je kunt gebruiken (bestaan deze)? En zijn ze dan universeel of zou het een specifiele MSI accessoire moeten zijn?
Hopelijk heeft rachez of iemand anders hier antwoord op!
Naast de info in hierbovengenoemd topic ben ik ook wel benieuwd naar de praktijkervaring binnen dit systeem (het mobo incl deze processor), dus als rachez hier info over heeft....
[ Voor 28% gewijzigd door vanenkelen op 23-01-2008 12:27 ]
  • Vos
Vos
AFCA
knakworst schreef op woensdag 23 januari 2008 @ 12:15:
Danku, die ga ik eens doorspitten.
#36
  • knakworst
knakworst
Get more sats!
vanenkelen schreef op woensdag 23 januari 2008 @ 12:16:
Hier heb je benchmarks:
http://techreport.com/articles.x/11931/10
http://www.xbitlabs.com/a...6150-gf6100_15.html#sect0
De chipset kan H.264 1080p gemakkelijk decoderen. Wel een waarschuwing dat x.264 mkv files (nog) niet hardwarematig versneld kunnen worden, dus dat komt volledig op de processor aan. Met een 5000+ kom je wel een heel eind.
[ Voor 3% gewijzigd door knakworst op 23-01-2008 13:42 ]
  • kaajee
knakworst schreef op woensdag 23 januari 2008 @ 13:40:
Correctie: deze chipset, de NVIDIA GeForce 6150, heeft GEEN hardwarematige versnelling voor HD materiaal (h.264/vc-1)
Het decoderen van (hd) video komt dus volledig ten laste van de CPU (en niet de GPU)!! Dat het wel loopt ligt dus ook geheel aan de keuze van je processor (CPU) daar is in het reed genoemde topic veel over te lezen (en als stelregel: alles (dual core) boven de 2,4Ghz)
  • knakworst
knakworst
Get more sats!
[quote]kaajee schreef op woensdag 23 januari 2008 @ 14:09:
Wat gek dat deze chipset een lagere processorbelasting laat zien dan de 690G chipset in de eerste benchmark.
  • kaajee
knakworst schreef op woensdag 23 januari 2008 @ 14:10:
Waarom vind je dat gek? Zijn toch twee compleet verschillende producten/chipset? Tuurlijk zitten er verschillen tussen die twee. Zegt echter helemaal niets over de hw versnelling.
Als je een ATi videokaart, bijv. een HD2600, vergelijkt met bijv. een nVidia 8400 zul je ook verschillen zien.......
Hetzelfde geldt als je appels met peren vergelijkt........(vandaar ook de uitdrukking wellicht) :P
  • knakworst
knakworst
Get more sats!
kaajee schreef op woensdag 23 januari 2008 @ 15:19:
Omdat de 690G wel H.264 decodeert dacht ik hieruit op te maken?
nieuws: AMD lanceert 690-chipset
  • kaajee
knakworst schreef op woensdag 23 januari 2008 @ 15:58:
Dat is een heel oud bericht, nog voor de daadwerkelijk introductie van de 690G.
Wellicht wilden ze het er wel in, maar het zit er echt niet in......
De 690G heeft geen UVD (Unified Video Decoder) onboard en die is nodig om h.264 en VC-1 materiaal te decoderen. UVD werd pas bij de HD modellen van ATi geïntroduceerd.
De 690G is obv de ATi x1250 chip (die dus geen UVD heeft) (btw ook de geforce 6150 heeft het gewoon niet)
Leesvoer1-x1250
Leesvoer2-uvd
Leesvoer3
onboard grafische chips die wél UVD hebben komen eraan, dat wordt de RS780 chipset, lees hier maar eens
  • rachez
@Alex) Ik heb op de media center ook Vista op geinstalleerd gehad. Draait prima zoals kaajee al aangaf.
@Sherlock De foto's zouden het inmiddels moeten doen.
@knakworst. Bereik is iig 5 meter.. Ik heb ook wat reviews gelezen en naar aanleiding daarvan op dit tobo uitgekomen omdat ik dezelfde conclusies trok als jij. Tot nu toe geen spijt. Maar goed ik heb hem pas 2 weken..
@Vos Ja, HD content speelt prima af. Maar ik speel het af op een HD ready tv 720p. Ik weet niet of het downscalen al in de mediacenter gebeurt en daardoor de cpu wellicht ontlast? Tot nu toe nog geen HD content gezien wat ik niet kon afspelen. Cpu belasting zit rond de 55% bij het afspelen van dergelijk materiaal. Die vogelscene kan ik nu wel afspelen, maar heb die alleen op 720p materiaal. Zal eens kijken of ik hem op 1080p kan vinden..
@vanenkelen Er zit alleen een opening voor een riser kaart. Niet voor een low profile kaartje. De bijgeleverde riser kaart is voor een optionele PCI insteekkaart. Verder zitten er als je die PCI riser kaart weghaalt 2 PCI-E slots op het mobo een x1 en een x16. Als je een PCI-E slot wilt gebruiken vervalt de nu aanwezige riser kaart. Of er een riser kaart bestaat voor de PCI-E sloten weet ik niet. Ook is de ruimte die je hebt beperkt. Dus afhankelijk van de grote van de kaart, kan het toch wel een uitdaging worden. Als je de afmetingen hebt, wil ik wel eens kijken...
Voorts heeft kaajee gelijk: het decoderen van HD-materiaal gebeurt door de cpu, maar tot nu toe heb ik daar geen problemen mee gehad.
Over die vogelscene. Zojuist een versie gevonden van 150 mb met alleen die vogelscene. Duurt 20 seconden ongeveer, maar die wordt niet vloeiend afgespeeld. Gek daarbij is wel dat mijn cpu belasting maar op 33% zit. Als ik hetzelfde materiaal afspeel op mijn Q6600 schokt hij ook, terwijl daar de cpu belasting op 10 % zit. Ik vertrouw die scene daarom niet helemaal. Geen idee wat de oorsprong is van het materiaal 1080p / 720p..
Ik heb zelf een 720p versie ervan en deze wordt wel vloeiend afgespeeld. Ben nu nog op zoek naar de hele film op 1080p formaat. Wordt vervolgd..
  • kaajee
rachez schreef op woensdag 23 januari 2008 @ 23:27:
Afbeeldingslocatie: http://www.ameri-rack.com/assets/ARC1-PELX16-Cx.jpg
(google: pci-e riser card flexible)
Over die vogelscene. Zojuist een versie gevonden van 150 mb met alleen die vogelscene. Duurt 20 seconden ongeveer, maar die wordt niet vloeiend afgespeeld. ................
Linkje? of anders search tipje?
  • vanenkelen
vanenkelen
Kaajee en rachez, bedankt voor de info! (Het woordje flexible in die zoekopdracht doet wonderen ;-) )
Die vogelscene loopt in mijn gewone computer (Intel C2D 6850, 2gb en Asus 8600 GTS en de juiste codecs) ook niet soepel. Terwijl daar de CPU-load ook onder de 25% blijft. Wie weet ligt het zomaar aan de rondzwervende versie.
  • Sappie
Sappie
over die vogelscene. Zojuist een versie gevonden van 150 mb met alleen die vogelscene. Duurt 20 seconden ongeveer, maar die wordt niet vloeiend afgespeeld. Gek daarbij is wel dat mijn cpu belasting maar op 33% zit. Als ik hetzelfde materiaal afspeel op mijn Q6600 schokt hij ook, terwijl daar de cpu belasting op 10 % zit. Ik vertrouw die scene daarom niet helemaal. Geen idee wat de oorsprong is van het materiaal 1080p / 720p..
Ik heb zojuist ook even gekeken naar de vogelscene. De performance wisselt nogal afhankelijk van welke codec ik gebruik. Met behulp van ffdshow trekt mijn configuratie het een stuk slechter dan met coreavc. Met coreavc gaat het net niet vloeiend, maar hapert iig niet alles.
Verder speelt mijn E6400@3.2GHz de scene wel vloeiend af met coreavc (max 70% cpu belasting) en ffdshow. Met vlc (die afaik een ingebouwde x264 codec gebruikt anders dan coreavc en ffdshow) gaat het niet lekker.
Om ook op je eerdere vraag terug te komen; ik ben er nog niet uit welke codecs ik nu precies moet gaan gebruiken. Tis iig echt een codec hell. Zo werkt ffdshow prima vanuit mediaportal, maar weigert coreavc HD video af te spelen
  • D-Day
  • Laatst online: 11-08 08:33
Allereerst complimenten voor dit topic, bedankt alvast voor alle info :)
Mijn vraag is of iedereen met de MSI Live de stock koeler van AMD gebruikt, of zijn er andere opties?
Racism is a symptom of illiteracy. It's in our DNA: the human race is 1, not many.
  • kaajee
DrDDay schreef op donderdag 24 januari 2008 @ 15:17:
Zit std. een cooler bij, die is goed en zou ik maar gewoon gebruiken......waarom een ander nemen?
  • rachez
kaajee: Ik heb gezocht op PlanethEarth-Vogelscene. Ben benieuwd wat hij op jouw systeem doet.
vanenkelen:
Opvallend dat die file op jouw systeem hetzelfde laat zien (lage cpu load en wel schokken). Alhoewel was het dezelfde versie?
Sappie: ok, ik ben momenteel bezig met deze instellingen voor ffdshow die thaclown doorgaf in het mediaportal topic.
  • rachez
Ok, ik heb zojuist de vogelscene geprobeerd in een mkv container 1080p x264 bestand. Deze speelt wel vloeiend af zonder haperingen (97% load als alle vogels in beeld zijn).
Volgens mij is die " PlanethEarth-Vogelscene" die rondzwerft gewoon crap.
  • vanenkelen
vanenkelen
rachez schreef op donderdag 24 januari 2008 @ 20:06:
vanenkelen:
De versie die ik heb is een volledige film in een wmv bestand van ongeveer 4,5 gieg. Gisteravond nog eens gechecked cpu-load blijft tussen 20 en 30 % gedurende de gehele scene (op een C2D 6850 en 8600 GTS).
Ga nog eens op zoek naar andere versies, vindt 4,5 gieg sowieso vrij weinig voor een 1080p film van een uur, of valt dat wel mee?
On-topic: Ik heb in ieder geval genoeg info om binnenkort maar eens tot aanschaf over te gaan. Wat is jullie ervaring met de levertijd? Er zijn sowieso maar weinig winkels die hem hebben en hij is lang niet altijd op voorraad.
  • kaajee
vanenkelen schreef op vrijdag 25 januari 2008 @ 09:18:
Is appels met peren vergelijken. Waar het met die 'vogelscene' over gaat is een x.264 ge-encodeerde versie. Jij hebt het over de Windows Media versie (WMV) WMV's draaien iha veel beter/soepeler......
  • vanenkelen
vanenkelen
Even voor mijn begrip (waarschijnlijk noobvraagje)... zit er dan een groot kwaliteitsverschil tussen de x.264 versie en de 1080p WMV versie?
  • Robo1993
  • Laatst online: 31-10 02:46
Ik heb er net een besteld icm:
AMD Athlon 64 X2 5200+
Kingston 2048 mb (2* 1024 kit) DDR2 800.
WD SE16 500 GB.
Hauppauge WINTV PVR-350.
3Com W-Lan USB stick.
Heeft er al iemand ervaring met de SCART aansluiting op het moederbord? (Met betrekking tot de beeldkwaliteit op een 'gewone' breedbeeld TV).
En denken jullie dat het mogelijk is om een 1080p HD film te bekijken icm met de 5200+?
Dell U2412M, Intel Xeon W3680 @ 4,3GHz, AMD Radeon RX 5700XT, Scythe Mugen 2, Asus P6T, 12GB DDR3, Kingston A2000 NVMe 1TB, OCZ Vertex 4 120 GB, 2X 500GB WD Caviar Black RAID-0, Cooler Master Real Power M700W, Logitech G533, Logitech MX5500, @Odido 1 Gb/s
  • kaajee
Robo1993 schreef op woensdag 30 januari 2008 @ 21:11:
WD SE16 500 GB.
Geen antwoord op je vraag, maar een wedervaag: waarom heb je de Hauppauge WINTV PVR-350 gekozen?
  • Robo1993
Omdat deze kaart erg goed uit de testen komt, en een kennis van mij ook erg goede ervaringen met deze kaart heeft. Ik heb ook zitten denken aan een PVR 150, maar die schijnt minder te zijn in het encoderen van opgenomen video.
  • kaajee
Robo1993 schreef op donderdag 31 januari 2008 @ 08:49:
Volgens mij (en deze en deze post) is er nauwelijks verschil, behlave het feit dat de 350 een TV-out met mpeg2 DEcoder heeft. Ze gebruiken allemaal een Conexant mpeg2 ENcoder. De tv-out van de 350 ga je waarschijnlijk toch niet gebruiken want die wordt door vrijwel geen enkel programma ondersteund. Je koopt 2 150's voor de prijs van je 350 (of 1x een 500MCE met dubbele tuner). Dubbele tuner is wel lekker hoor op een HTPC.
  • Sherlock
Sherlock
No Shit
Even een linkje voor in de topicstart:
pricewatch: MSI Media Live (Socket AM2, Zilver)
Ik moet nog even sparen, dus ik hoop dat de prijs van dit ding net zo hard naar beneden gaat als het saldo op mijn bankrekening naar boven, dan komt het er wel van :)
Is het misschien een idee om een lijstje te maken van gebruikte hardware en die ook in de topicstart mee te nemen? (Niet dat de TS dit zelf moet doen)
  • Greasygerrit
  • Laatst online: 19-01 11:18
WD SE16 500 GB.
Ik heb de mijne nu 1 week binnen (bij zercom voor 318, incl stille CPU koeler, Afstand bediening, DVD RW)
erbij aangeschaft:
AMD Athlon 64 X2 6000+
samsung spindisk 500Gb (zou de stilste moeten zijn)
Hauppauge WINTV HVR-1300 (zit ook nog een afstandbediening bij :| )
Ik snap niet waarom jij 3Com W-Lan USB stick erbij gekocht hebt. Het moederbord heeft standaard wifi en bluetooth aan boord (werkte gelijk met XP en de bijgeleverde drivers)
Na installatie van alle HW onderdelen (koeler is een ramp, bouw gelijk de voeding maar even uit voor je wat molt) kwam ik tot de ontdekking (stom natuurlijk, was te zien) dat je een USB keyboard nodig hebt. PS2 is geen aansluiting voor. Dus maar gelijk een draadloze geschikt voor MCE gekocht.
Een tot nu toe prima functionerende (usb stickje erin en werkt gelijk al in de bios !!) TRUST KB-2950 met ingebouwde trackball als muis, dus ook op de bank te gebruiken en kost maar 40 € bij dixons !
(zorg wel dat je de nieuwste uitvoering krijgt de oude hadden kuren, zie forums)
Na XP pro, drivers en media portal (vanwege de vele positieve reacties tov MCE) installatie begon e.e.a. te werken (wel veel in te stellen gegevens!)
Media portal werkt goed intuitief is mooi en heeft veel (te veel?) mogelijkheden. (zelfs het display werkt onder mediaportal !)
Ik heb alleen nog een paar problemen:
1) Mijn breedbeeld TV (CRT) heeft RGB op 2 scarts (altijd al met goed gevolg gebruikt bij mijn DVD recorder), dus wilde ik dat ook doen via de scart van de media live. De composiet uitgang en S-vhs
werken gewoon, maar de RGB via de SCART krijg ik niet aan de praat. (ja, een goede kabel en de jumpers gezet op RGB). ;( Ga proberen met een RGB naar scart kabel of de 3 losse RCA RGB's wel werken, maar die kabel is niet zo makkelijk te krijgen tot nu toe.
2) De radio heeft kuren (onder media portal), na het wisselen van een paar zenders begint het geluid te piepen (als bij rondzingen). Met de radio SW van haupage zelf (buiten media portal) gebeurt dit niet ???. Ik heb hier ook nog niets over gevonden op het web
3) De knoppen onder het display werken ook (nog) niet. Nog niet zwaar na gezocht gezien de eertse 2 problemen.
Daarnaast nog wat kleinere ongemakken, maar dat is voornamelijk de juiste instelling vinden denk ik.
(b.v. internet radio, (analoge) TV gids, direct radio starten via AB,...)
Dus als iemand nog tips heeft over de 3 grotere problemen dan graag info.
Als ik niet verkeerd ben, kan je enkel afspelen en niet opnemen??
of is er een mogelijkheid om een tv kaartje te installeren
gr
A
  • kaajee
Verwijderd schreef op dinsdag 19 februari 2008 @ 18:27:
gr
A
Ja, gezien de foto's elders in deze post moet het zonder meer mogelijk zijn om een PCI tuner (of zelfs een PCIe tuner) in te bouwen. En anders heb je altijd nog externe (firewire of usb) tuners......
Ja zou wel even goed moeten kijken naar de maten van een gewenste tv/tuner kaart (hoogte/breedte/lengte/?). Ik weet dat een Hauppauge 500MCE nogal een joekel is die in sommige (kleinere) kasten niet echt lekker wou 'passen'........
Kan er iemand bevestigen of het er een dvd-rw standaard bij is of...
thx
A
  • kaajee
Verwijderd schreef op maandag 25 februari 2008 @ 15:23:
thx
A
Dat kun je zelf door het topic even te lezen, je vraag wordt minimaal 2x beantwoord.........
das waar, maar heb deze middag de handleiding gedownload en daar spreken ze enkel over plaats voor een dvd... eentje zegt ja, ander denk het...
wou het gewoon zeker zijn dat het een dvd rw was
[ Voor 28% gewijzigd door Verwijderd op 25-02-2008 16:17 ]
  • Jag
  • Laatst online: 31-10 17:03
Jag
Ik zit ook te overwegen deze barebone te kopen voor de bouw van een nieuwe htpc. Alleen gebruik ik mijn setup component video (wat het wat lastiger maakt). Nou heeft deze wel component video aansluitingen, alleen staat in de handleiding dat het RGB is (ipv YPbPr). Nou zal dat wel niet kloppen, want RGB met losse cinch aansluitingen wordt voor zover ik weet nooit gedaan (en er worden altijd fouten mee gemaakt). Maar heeft iemand die component video uitgang wel eens gebruikt (op 720p oid)?
En die hmdi uitgang, weet iemand welke versie dat is?
  • deepbass909
  • Laatst online: 01:30
deepbass909
Ik moet zeggen dat dit apparaat er erg interessant uit ziet. Ik was zelf nog steeds van plan om een HTPC op te bouwen rond een MSI-bordje dat op het moment in m'n vaste pc zit (ook met RGB/component uitgangen), maar deze vangt eigenlijk alle punten al op waar ik nog mee zat.
Alleen hoe zit het met de VFD en ir-onvanger? Weet iemand volgens welk protocol deze worden aangestuurd? Ik wil dit apparaat namelijk gaan gebruiken in combinatie met MythTV op Linux (video performance is onder linux hoger dan windows heb ik gemerkt, zeker bij een hoge IO-load).
  • Jag
Jag
Lekker verwarrend altijd component video en RGB (toch echt niet hetzelfde of uitwisselbaar). In de handleiding van de MSI media live staat dat het een RGB component video output is, maar vervolgens staat er dan bij dat R,G en B respectievelijk Pr, Y and Pb is, wat ook overéénkomt met de normale kleurcodering voor Y, Pb, Pr. En het zou 720p en 1080i ondersteunen. Klinkt als dat het gaat werken, maar zou het graag van iemand horen die het geprobeerd heeft (voor zover er iemand bestaat op deze wereld die component video gebruikt).
En niemand een idee of het een HDMI 1.3a uitgang is? Ik kan het nergens vinden.
  • Sappie
Sappie
deepbass909 schreef op dinsdag 26 februari 2008 @ 12:56:
In de wiki van MythTv is volgens mij te vinden dat de Futaba DM-140GINK, die onder andere de VFD herbergt, goed ondersteund wordt.
Jag schreef op dinsdag 26 februari 2008 @ 13:34:
Ik heb geen idee wat de verschillen tussen de verschillende HDMI standaarden zijn en weet ook niet over welke versie de MSI beschikt. Ik heb een MSI Media Live, dus zou het, mits het is na te kijken, voor je kunnen uitzoeken. Heb je enig idee hoe ik dit check?
belangrijkste toevoeging van 1.3(a) als ik het zo snel goed zie: hogere bandbreedte, Dolby TrueHD and DTS-HD Master Audio. De twee audio codecs kan ik iig niet testen aangezien ik geen receiver heb die daar wat mee kan. Verder lijkt me zo de meerwaarde van deze codecs niet echt groot wanneer gebruikt in de Media Live; de Media Live kan de decoding natuurlijk net zo goed voor zijn rekening nemen en vervolgens uncompressed audio oversturen (of is 5.1 niet losless te versturen dmv bijv toslink?). Vwb de hogere bandbreedte; geen idee hoe te testen.
[ Voor 22% gewijzigd door Sappie op 26-02-2008 15:59 ]
  • catchingfire
  • Laatst online: 12:00
En ben al geruimte tijd aan het zoeken naar een oplossing om m'n DVD-images, VIDEO_TS-folders, foto's, mp3's (CD's gebruik ik niet meer) met 1 apparaat op een gebruiksvriendelijke (lees: vrouwvriendelijke) manier te kunnen weergeven. Daarom lijkt me een HTPC wel wat. Aangezien ik nog een oude breedbeeld CRT heb heb ik nu nog niks aan DVI/HDMI maar ik wel future proof zijn. Als de TV morgen "poef" zegt komt er een LCD, en wil ik ook HD content kunnen bekijken.
Ik lig in dubio of ik zelf iets moet gaan bouwen of iets op basis van de MSI Media Live ga bouwen. Voor de MSI variant zit ik te denken aan:
#ProductPrijsSubtotaal
1AMD Athlon X2 6400+€ 139,-€ 139,-
1Corsair TWIN2X2048-6400C4 2GB (2x 1GB) DDR2€ 47,50€ 47,50
1MSI Media Live (Socket AM2, Zilver)€ 306,40€ 306,40
1Trust KB-2950 Wireless Media Center Keyboard€ 44,96€ 44,96
1VistaView Saber 2020 Dual Analog PCIe MCE TV-FM Tuner Card (PCI-e 1x)€ 149,95€ 149,95
1Western Digital Caviar GP WD5000AACS, 500GB€ 86,10€ 86,10
ImporterenTotaal€ 773,91
Beargumentatie:
CPU: aangezien er geen hardware accelerated HD support op de on-board video zit, wil ik in ieder geval niet met de CPU meteen aan 't plafond zitten, WORDT DEZE CPU GESUPPORT?
RAM: 2GB lijkt me genoeg voor Vista MCE of Media Portal?
KEYBOARD: gewoon oke lijkt me, remote control zit al bij de MSI
SABER: schijnbaar beter dan Hauppauge varianten, PAST DEZE KAART?
HDD: de GP-serie van WD is stil, energie-zuinig en snel genoeg.
Al met al vind ik het nog best een berg geld, waar ik veel DVD'tjes voor kan branden. Dus ik twijfel behoorlijk. Ik vind 't veel te duur om alleen maar als TV-frontend te gebruiken voor media, hij moet op z'n minst ook als fileserver/leech-station kunnen functioneren. Ook maak ik me wat zorgen over upgradability.
Wat is het stroomverbruik van de MSI in standby mode? En kan ie in die modus nog wel wakker worden om een programma op te nemen van TV?
  • Garyu
  • Laatst online: 30-10 18:53
Garyu
WW
Is het voor jou niet handiger dan om een NAS in je netwerk te hangen en een media-player frontend te kopen die daarmee om kan gaan (Popcorn-hour bijvoorbeeld)?
  • catchingfire
Dat traject heb ik ook overwogen, maar is ook aan de prijs als je het fatsoenlijk wilt doen:
Apple TV : 400euro, mooi, zeer vrouwvriendelijk, beperkt met afspeelbare content (of met de hand alles omzetten naar wel ondersteund formaat
Synology 107+, 500GB : 320euro, media-player kost ook al snel >100 euri... kom je ook alweer >>400euro uit. En als ik al die ellende lees met de media-player, daar wordt je ook niet vrolijk van. Er is niet 1 apparaat wat nu fatsoenlijk doet wat er belooft wordt. De Popcorn-hour bijvoorbeeld schijnt nogal crappy subtitles weer te geven.
  • Jag
Jag
Sappie schreef op dinsdag 26 februari 2008 @ 15:38:Ik heb geen idee wat de verschillen tussen de verschillende HDMI standaarden zijn en weet ook niet over welke versie de MSI beschikt. Ik heb een MSI Media Live, dus zou het, mits het is na te kijken, voor je kunnen uitzoeken. Heb je enig idee hoe ik dit check?
Verschil is idd de mogelijkheid voor DTS-HD en Dolby TrueHD. Ik vermoed dat het niet zo lang gaat duren voordat die compressie methoden ook bij mkv's vaker zullen zitten. Decoden naar lossless stream zal idd wel kunnen waarschijnlijk. Dat kan niet over SPDIF (max 1.5MBit: stereo pcm, DD of DTS stream), wel over HDMI (ook andere versies dan 1.3). Maar geef er altijd wel de voorkeur aan om te laten decoden door een receiver.
Het is niet echt van levensbelang. Zou wel heel graag willen weten of die component video out het een beetje doet en acceptabele kwaliteit geeft (is ook wel eens anders).
  • Alex)
Zijn er hier eigenlijk mensen die een tv-tuner met ondersteuning voor DVB-C hebben ingebouwd, en ook bijbehorende CAM enzo? :)
  • Sappie
Sappie
Jag schreef op woensdag 27 februari 2008 @ 16:11:
Als je een component kabel hebt en in de buurt van Eindhoven woont kan je dat wel komen checken..
  • deepbass909
deepbass909
Hmm, ik lees daar dat Lirc iig wel de IR-ontvanger goed ondersteund, knoppen, bluetooth en wifi ook goed werken, maar dat het display nog geen native ondersteuning heeft, en alleen via een patch werkt. Aangezien het er op het moment nog niet van komt om een HTPC aan te schaffen (eerst goede speakers), zal over een maandje of wat de driver vast wel opgenomen zijn in lcdproc.
Ik denk dat deze barebone een goede kans maakt. Ik vind hem er redelijk goed uitzien, er is ruimte voor 2 harddisks (1 systeem, 1 data (video, mp3)). Aangezien hij geen HDD recorder krijgt (er staat hier al een Humax digitale recorder) en ik (nog) geen HD-content kan afspelen zal een lichte AMD X2 proc goed genoeg zijn. Met deze heb ik al ervaring op een vergelijkbaar moederbordje (MSI K9NGM2) en die presteert erg goed met linux en het bordje in deze barebone lijkt daar een doorontwikkeling van te zijn.
  • Jag
Jag
Sappie schreef op woensdag 27 februari 2008 @ 20:04:
Tis al niet meer nodig, mijn receiver die ik ter reparatie had weggebracht (component video out deed het niet meer) blijkt vochtschade te hebben en reparatie zou €360,- kosten, teveel dus. Dus ga waarschijnlijk maar rechtstreeks hdmi verbinding gebruiken (of misschien toch 2e hands receiver met wel werkende component video kopen).
Woon ook niet in de buurt van Eindhoven, maar toch bedankt voor het aanbod.
  • catchingfire
Woei, het gaat wel hard omlaag met de prijs van de MSI Media Live! Vorige week nog 306 euri, nu nog "slechts" 271 euri!!!
Weet iemand wat de snelste CPU is die ondersteund wordt door MSI? Gaat een Phenom werken?
  • kaajee
catchingfire schreef op woensdag 05 maart 2008 @ 21:52:
Lijkt me niet, neem toch even de moeite om op de site van MSI te kijken, heb je sneller je antwoord............
  • catchingfire
kaajee schreef op woensdag 05 maart 2008 @ 22:26:
Die moeite heb ik al genomen voordat ik die vraag postte, maak je geen zorgen. Omdat daar echter over een compatibiliteit t/m de x2 5200+ gesproken wordt vraag ik me af of het lijstje wel enigszins up-to-date is.
  • kaajee
catchingfire schreef op donderdag 06 maart 2008 @ 08:48:
Ten eerste had je dat van die moeite best even kunnen noemen.....en ten tweede kun je zien dat de lijst met CPU's bij MSI wel degelijk bijgewerkt wordt, aangezien deze lijst duidelijk verschilt met de CPU lijst in de topicstart.....Ten derde Phenoms hebben eigenlijk als platform/socket een AM2+ nodig, dat heeft dit board zeker niet.Er zijn nog maar wenig (geen?) MSI AM2 moederborden die de Phenom ondersteunen.........
In principe zou een sneller AMD x2 AM2 CPU gewoon moeten werken, die verschilt niets van een andere (bijv. x2 5200+ CPU). Het zal wel zijn dat de temps te hoog kunnen worden met een zwaardere CPU en dat de fan (en airflow) wellicht in beginsel niet goed genoeg zijn voor snellere........
  • catchingfire
kaajee schreef op donderdag 06 maart 2008 @ 09:41:
1) dat hoef ik helemaal niet te noemen, je mag aannemen dat mensen eerst zelf kijken.
2) die lijst uit december vorig jaar gaat ook maar "tot" de x2 5200, dus?
3) er zijn genoeg AM2 mainboards waarop een phenom probleemloos loopt, dus?
Het statement "zou gewoon moeten werken" zien potentiele kopers toch liever iets formeler.
  • kaajee
catchingfire schreef op donderdag 06 maart 2008 @ 10:14:
Nou dat blijkt nergens uit, sterker nog het tegendeel blijkt.....
Huh, als je kijnkt naar de lijst in de topicstart staan daar de BE versies (nog) niet tussen, als je kijkt op de MSI site staan de BE versies er wél tussen. Daaruit blijkt dat MSI de CPU lijst wel degelijk bijwerkt!
Ik zei toch; veel/de meeste MSI boards met AM2 ondersteunen (nog) geen Phenoms. Dat andere dat wel doen, leuk, maar heb jij geen drol aan.......
(zie ook hier en op de website van MSI bij een willekeurig AM2 bord (de populaire K9N Platinum bijv., maar daar kijk je toch niet..... :P
Voor een formeler statement zou ik je willen doorverwijzen naar een verkopers forum, dat wil zeggen een winkel die dat ding verkoopt, of naar de makers van dat ding.
Dit is een gebruikers forum en geen commerciële toko die 'formele' en officiële antwoorden op je vragen (kunnen) geven.......
[ Voor 10% gewijzigd door kaajee op 06-03-2008 10:50 ]
  • catchingfire
kaajee schreef op donderdag 06 maart 2008 @ 10:49:
Als je gewoon geen antwoord kunt geven op de vraag of een Phenom werkt mag je de volgende keer ook gewoon helemaal niet reageren. Dat scheelt weer.
Welke moet ik nemen op de site van zercom, en wat is het verschil??
gr
A
  • kaajee
Verwijderd schreef op dinsdag 11 maart 2008 @ 15:57:
gr
A
Nou ik zou de goedkoopste nemen!!!
(mail ze anders even joh, weinig mensen hier werken bij zercom, hoe moeten wij weten wat ze bedoelen? wij lezen niet meer dan jij. Sowieso was het wel aardig geweest van als je even wat linkjes vermeld had........je verwacht van ons een onmogelijk antwoord en ook nog eens of we zelf even willen uitzoeken wat zercom op hun site heeft staan...............)
heb ik reeds gedaan en dit was hun antwoord
Als u de vendorcode kopiert en u gaat naar google. En de producten zijn
percies het zelfde. Dan kan het zijn dat we 2 leveranciers het zelfde product
hebben alleen de ene is goedkoper als de ander.
ik hoop dat ik u voldoende informatie heb gegeven.
Met vriendelijke groet,
Afdeling Verkoop
Kristel
dat is de reden van mijn vraag
http://www.zercom.nl/inde...=2111&f=1&h=1&s=1&a=58729 eentje van 267,9 €
en eentje van 310.3 €
[ Voor 5% gewijzigd door Verwijderd op 11-03-2008 18:55 ]
  • Ray-zor
  • Laatst online: 31-10 11:20
Ray-zor
ach, je typt eens wat...
Ik ben aan hte kijken voor mijn eerste HTPC (na jarenlang plezier van een netwerked DVD speler is nu ook de wens van recording erbij gekomen). Op dit moment ben ik nog in eht ebzit van een breedbeeld CRT TV en heb niet zo'n behoefte om die per direct te vervangen. De scart op deze kast is dus voor mij het belangrijkste onderscheid tov ander behuizingen/oplossingen.
Na wat gebladerd te hebben in verschillende GoT topics (waaronder Nieuwe stille HTPC die op de toekomst is voorbereid) heb ik toch nog wat n00b vragen.
- Als ik deze kast via optical aan mijn receiver aansluit, heb ik dan DD en of DTS (als dat op het schijfje staat natuurlijk). Of is een losse soundkaart daarvoor nodig? Op de productpagina van MSI kan ik die termen namelijk niet terugvinden maar bij sommige winkels wordt ie "MSI DTS" genoemd(http://kijkshop.shops.nl/product/79764/).
- Als ik wil opnemen en TV kijken tegelijkertijd, heb ik een dual TV tuner nodig als het goed begrpen heb. Tips daarvoor? De Hauppauge 500 is niet meer terug te vinden in de pricewatch (ja, één link naar "product is niet meer in assortiment").
  • Jorn
  • Laatst online: 28-10 08:18
Ik zit er ook aan te denken om de msi media live te kopen en hem als mediacenter en dan tegelijk als een soort NAS(niet hoofdzakelijk, gewoon voor erbij) en als downloadcomputer te gebruiken omdat hij waarschijnlijk toch altijd aan zal staan.
Nu vraag ik mij alleen af of hij draadloos netwerk is of dat dit een optie is?
Hier op het forum zeggen sommigen namelijk dat er onboard wireless staat.
en op de site van msi staat: VFD (integrated Bluetooth v2.0+EDR and Wi-Fi/IEEE802.11b+g, Optional)
Waaruit ik opmaak dat bluetooth en wireless een optie zijn?
Of zit dit er toch standaard op?
* Erkens is een sukkel en ramt in mirc op f5 :+
* XTerm GROOOOOOTE kuis houden op hd's :)
  • kaajee
Jorn schreef op woensdag 12 maart 2008 @ 22:49:
Zoek en lees gewoon even joh! Staat al lang en breed in dit topic. Tipje: je kunt ook alleen in dit/een topic zoeken, rechtsboven. Je zou wellicht als zoektermen: bluetooth en wifi kunnen gebruiken.........
(ik snap dat niet: je overweegt deze media live, maar je hebt nog wel 2 concrete vragen: BT & WiFi, je ziet een topic op tweakers, ga je dan niet eerst uitzoeken in dat topic of je vraag al beantwoord is? Ten eerste heb je je antwoord dan meteen en ten tweede vervuil je een topic niet met onnodige vragen en ten derde; het kost je veel minder moeite dan het typen van je hele vraag/bericht.)
[ Voor 3% gewijzigd door kaajee op 12-03-2008 23:20 ]
  • Jorn
kaajee schreef op woensdag 12 maart 2008 @ 23:18:
En waaruit trek jij de conclusie dat ik het topic niet doorgelezen heb en een topic zie en zomaar wat post?
In dit topic staat:
en nog:
1 keer werkt het wel en de andere keer dus niet, misschien omdat het er niet op zit?
Er zal toch vast niet voor niets op de site van msi staan dat het een optie is, waarom zou dit er staan dan...
Weet het liever van tevoren dan dat ik er achteraf achter kom.
  • kaajee
Jorn schreef op donderdag 13 maart 2008 @ 08:14:
In dit topic staat:
en nog:
BEIDE posts zeggen dát het er inderdaad op zit. Dat de ene het niet aan de praat heeft gekregen is weer heel wat anders!! Jij vraagt of het er op zit, ja dus en dat staat heel duidelijk in dit topic. Je had het in ieder geval kunnen noemen (maar je hebt na mijn post pas zitten zoeken ws....)
Als iets er op zit moet het ook werken, anders heb je garantie, dat iemand dat WiFi niet a/d praat heeft gekregen is een instelling/software/router issue natuurlijk........)
  • Jorn
kaajee schreef op donderdag 13 maart 2008 @ 09:01:
Oke, het zit er op dan, dan zal dat optional wel een foutje op de site zijn ofzo.
Ik vind alleen niet dat het terecht is dat je suggereert dat ik niet gezocht heb, ik heb namelijk weldegelijk gezocht, kwam op de site van msi en andere sites tegen dat het optional was, heb zeker 5keer het topic doorgelezen voordat ik poste.
Als ik nu de composite (gele tulp) wil gebruiken van de media live, zal ik dan goed beeld hebben?
Want dit heb ik vandaag reeds uitgetest:
1. Heb deze middag mijn 8800 gt aangesloten via s-video en dat was een ramp. Aansluiten via composite is niet mogelijk.
2. Mijn oude Medion latop aansluiten via de composite is perfect beeld (voor mij toch voldoende)
3. Sweex mediacenter via composite ==> ook perfect
Dit alles zou het moeten trekken tot aankoop LCD of Plasma.
[ Voor 12% gewijzigd door Verwijderd op 17-03-2008 14:00 ]
  • kaajee
Verwijderd schreef op maandag 17 maart 2008 @ 13:58:
Ik zou zeggen: probeer het!! (mijn hemel)
Maare...hij heeft toch ook een RGB scart? Die geeft analoog in principe het beste beeld......
Thx
wou het gewoon 100% zeker zijn.
ps:
kaajee schreef op maandag 17 maart 2008 @ 14:03:
mag ik eens het adres van jou shop, kennelijk mag jij alles eerst ff uitproberen... :)
  • kaajee
Verwijderd schreef op maandag 17 maart 2008 @ 14:58:
Als ik dit/jou bericht lees: "Als ik nu de composite (gele tulp) wil gebruiken van de media live, zal ik dan goed beeld hebben?"
Lijkt het me logisch dat ik er vanuit mag gaan dat je zo'n ding hebt..............toch?
(verder zeg je nl. niets, en ik ben m'n glazen bol helaas vergeten..........)
ja maar nog geen media live
Pagina: 1 2 Laatste
